[Swift-commit] r7852 - SwiftApps/swift-galaxy/swift
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Sun May 11 14:32:50 CDT 2014
Author: ketan
Date: 2014-05-11 14:32:48 -0500 (Sun, 11 May 2014)
New Revision: 7852
Added:
   SwiftApps/swift-galaxy/swift/swiftforeach.py
Modified:
   SwiftApps/swift-galaxy/swift/swiftforeach.sh
Log:
translate python driver script to python
Added: SwiftApps/swift-galaxy/swift/swiftforeach.py
--- SwiftApps/swift-galaxy/swift/swiftforeach.py	                        (rev 0)
+++ SwiftApps/swift-galaxy/swift/swiftforeach.py	2014-05-11 19:32:48 UTC (rev 7852)
@@ -0,0 +1,191 @@
+#!/usr/bin/env python
+import subprocess
+import sys
+import os
+import distutils.
+def setwdir():
+    return subprocess.check_output(["mktemp", "-d", "/tmp/swift-gal.XXXX"])
+def genargs(args):
+    for a in args:
+        yield a
+def buildcfg():
+    f=open(wdir+"/cf", 'w');
+    f.write('use.provider.staging=true')
+    f.write('wrapperlog.always.transfer=true')
+    f.write('execution.retries=0')
+    f.write('provider.staging.pin.swiftfiles=false')
+    f.write('sitedir.keep=true')
+    f.write('lazy.errors=false')
+    f.close()
+# numeric range
+def main():
+    myargs = genargs(sys.argv)
+    try:
+        range_or_list = next(myargs)
+        k_or_t = next(myargs)
+        sites = next(myargs)
+        swiftargs = next(myargs)
+        interpreter = next(myargs)
+        executable = next(myargs)
+        stdin = next(myargs)
+        if range_or_list == "list":
+            listfile = next(myargs)
+            n = sum(1 for line in open(listfile))
+        else:
+            rstart = next(myargs)
+            rend = next(myargs)
+            stepsize = next(myargs)
+        outloc = next(myargs)
+        outlistfile = next(myargs)
+        logfile = next(myargs)
+        stringargs = next(myargs)
+    except:
+        sys.exit(1)
+    swift = distutils.spawn.find_executable("swift")
+    BASEDIR = os.path.dirname(os.path.realpath(__file__))
+    # workout the file args
+    fileargs=[]
+    for f in myargs:
+        fileargs.append(f)
+    #workout the file array only if user adds args else make it blank
+    if fileargs:
+        if k_or_t == "swiftK":
+            filearrayexpr="file fileargs[] <fixed_array_mapper; files=\""+','.join(fileargs)+"\">;"
+        else: #T
+            filearrayexpr="file fileargs[]="+str(fileargs)+";\n"
+    else:
+        filearrayexpr="file fileargs[];"
+    # create outloc dir
+    if not os.path.exists(directory):
+        os.makedirs(outloc)
+    # workout the stringargs
+    if stringargs:
+        stringarrayexpr="string stringargs[]="+str(stringargs.split())+";\n"
+    else:
+        stringarrayexpr="string stringargs[];\n"
+    wdir = setwdir().rstrip()
+    #workout standard input file
+    if stdin:
+            stdinfilexpr = "file stdinfile<"+stdin+">;"
+        else:
+            stdinfilexpr = "file stdinfile = input("+stdin+");"
+    else:
+            stdinfilexpr = "file stdinfile<\"/dev/null\">;"
+        else:
+            stdinfilexpr = "file stdinfile = input(\"/dev/null\");"
+    #Build Swift source code
+    f = open(wdir+"/script.swift", 'w');
+        f.write("type file; \n")
+        f.write("app (file _out, file _err) anapp(file _exec, int _i, string _stringargs[], file _fileargs[]){ \n")
+        f.write("    "+interpreter+" @_exec _i _stringargs @_fileargs stdout=@_out stderr=@_err; \n")
+        f.write("}\n")
+        f.write(stringarrayexpr)
+        f.write(filearrayexpr)
+        f.write("file exec<'"+executable+"'>;\n")
+            f.write("file listfile<"+listfile+">;\n")
+            f.write("string list[] = readData(listfile);\n");
+            f.write("foreach l, i in list{\n")
+            f.write("file out <single_file_mapper; file=@strcat(\""+outloc+"\", \"/\", l, \".\", i, \".out\")>;\n")
+            f.write("file err <single_file_mapper; file=@strcat(\""+outloc+"\", \"/\", l, \".\", i, \".err\")>;\n")
+            f.write("(out,err) = anapp(exec, i, stringargs, fileargs, stdinfile\n");
+        else:
+            f.write("foreach i in ["+rstart+":"+rend+":"+stepsize+"]{\n")
+            f.write("    file out <single_file_mapper; file=@strcat("+outloc+", '/', i, '.out')>;\n")
+            f.write("    file err <single_file_mapper; file=@strcat('"+outloc+"', '/', i, '.err')>;\n")
+            f.write("    (out,err) = anapp(exec, i, "+stringargs+", "+",".join(fileargs)+");\n")
+        f.write("}\n")
+        #build site
+        if os.path.dirname(sys.argv[0]):
+            basedir=os.path.dirname(sys.argv[0])
+        else:
+            basedir='.'
+        print "%s %s %s" %(basedir, sites, wdir)
+        subprocess.call([basedir+"/buildsite.sh", sites, wdir])
+        #build config
+        buildcfg()
+        #build tc
+        tc=open(wdir+"/tc", 'w');
+        for site in sites.split():
+            tc.write(site+' '+interpreter+' '+interpreter)
+        tc.close()
+    else: # T
+        f.write("import files;\n");
+        f.write("import string;\n");
+        f.write("import io;\n");
+        f.write("\n");
+        f.write(" app (file _out, file _err) anapp(file _exec, int _i, string _stringargs[], file _fileargs[], file _stdin){\n");
+        f.write(" \"" +interpreter+"\"  _exec _i _stringargs _fileargs @stdin=_stdin @stdout=_out @stderr=_err; \n");
+        f.write("}\n");
+        f.write("main{\n");
+        f.write(stringarrayexpr + " \n");
+        f.write(filearrayexpr + " \n");
+        f.write(stdinfilexpr + " \n");
+        f.write("file exec = input("+executable+");\n");
+            f.write(" \n");
+            f.write("file listfile=input("$listfile");\n")
+            f.write("string list[] = split(read(listfile),);\n");
+            f.write("foreach l, i in list{"\n)
+            f.write("    file out <sprintf(\""+outloc+"/%s.%i.out\", l, i)>;\n")
+            f.write("    file err <sprintf(\""+outloc+"/%s.%i.err\", l, i)>;\n")
+        else:
+            f.write("foreach i in ["+rstart+":"+rend+":"+stepsize+"]{ \n");
+            f.write("  file out <sprintf(\""+outloc+"/%i.out\", i)>; \n");
+            f.write("  file err <sprintf(\""+outloc+"/%i.err\", i)>; \n");
+        f.write("(out,err) = anapp(exec, i, stringargs, fileargs, stdinfile);\n")
+        f.write("}\n");
+        f.write("printf("%s", "Done!");\n");
+        f.write("}\n");
+    f.close()
+    #Populate output file
+    outlist=subprocess.check_output(["find", outloc, "-type", "f", "-iname", "*.out"])
+    f=open(outlistfile)
+    f.write(outlist);
+    f.close()
+    #dum ditty dum ditty dum dum dum
+if __name__=='__main__':
+    main()
Property changes on: SwiftApps/swift-galaxy/swift/swiftforeach.py
___________________________________________________________________
Added: svn:executable
Modified: SwiftApps/swift-galaxy/swift/swiftforeach.sh
--- SwiftApps/swift-galaxy/swift/swiftforeach.sh	2014-05-10 18:05:51 UTC (rev 7851)
+++ SwiftApps/swift-galaxy/swift/swiftforeach.sh	2014-05-11 19:32:48 UTC (rev 7852)
@@ -92,8 +92,9 @@
   filearrayexpr='file fileargs[];'
 fi
+#build swift source
  if [ "$range_or_list" == "list" ] ; then ## list
  cat << EOF > $wdir/script.swift
