[Swift-commit] r7843 - in trunk/src/org/griphyn/vdl/karajan/lib: . swiftscript
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Thu May 8 23:56:39 CDT 2014
Author: hategan
Date: 2014-05-08 23:56:39 -0500 (Thu, 08 May 2014)
New Revision: 7843
Added:
   trunk/src/org/griphyn/vdl/karajan/lib/GetFieldConst.java
   trunk/src/org/griphyn/vdl/karajan/lib/StringCache.java
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/AbstractSingleValuedSwiftFunction.java
Modified:
   trunk/src/org/griphyn/vdl/karajan/lib/AppendArray.java
   trunk/src/org/griphyn/vdl/karajan/lib/CleanDataset.java
   trunk/src/org/griphyn/vdl/karajan/lib/CloseDataset.java
   trunk/src/org/griphyn/vdl/karajan/lib/CreateArray.java
   trunk/src/org/griphyn/vdl/karajan/lib/Execute.java
   trunk/src/org/griphyn/vdl/karajan/lib/ExpandArguments.java
   trunk/src/org/griphyn/vdl/karajan/lib/FileName.java
   trunk/src/org/griphyn/vdl/karajan/lib/GetArrayIterator.java
   trunk/src/org/griphyn/vdl/karajan/lib/GetFieldSubscript.java
   trunk/src/org/griphyn/vdl/karajan/lib/GetFieldValue.java
   trunk/src/org/griphyn/vdl/karajan/lib/GetStagingInfo.java
   trunk/src/org/griphyn/vdl/karajan/lib/IsFileBound.java
   trunk/src/org/griphyn/vdl/karajan/lib/Mark.java
   trunk/src/org/griphyn/vdl/karajan/lib/New.java
   trunk/src/org/griphyn/vdl/karajan/lib/Operators.java
   trunk/src/org/griphyn/vdl/karajan/lib/ProcessStageouts.java
   trunk/src/org/griphyn/vdl/karajan/lib/Range.java
   trunk/src/org/griphyn/vdl/karajan/lib/RemoteFileNames.java
   trunk/src/org/griphyn/vdl/karajan/lib/SetDatasetValues.java
   trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java
   trunk/src/org/griphyn/vdl/karajan/lib/SiteCatalog.java
   trunk/src/org/griphyn/vdl/karajan/lib/SliceArray.java
   trunk/src/org/griphyn/vdl/karajan/lib/Stagein.java
   trunk/src/org/griphyn/vdl/karajan/lib/Stageout.java
   trunk/src/org/griphyn/vdl/karajan/lib/SwiftBinaryOp.java
   trunk/src/org/griphyn/vdl/karajan/lib/SwiftFunction.java
   trunk/src/org/griphyn/vdl/karajan/lib/SwiftUnaryOp.java
   trunk/src/org/griphyn/vdl/karajan/lib/TCProfile.java
   trunk/src/org/griphyn/vdl/karajan/lib/Tracer.java
   trunk/src/org/griphyn/vdl/karajan/lib/UnwrapClosedList.java
   trunk/src/org/griphyn/vdl/karajan/lib/WaitFieldValue.java
   trunk/src/org/griphyn/vdl/karajan/lib/While.java
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Assert.java
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ExtractFloat.java
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ExtractInt.java
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FileName.java
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FileNames.java
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FnArg.java
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Fprintf.java
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Java.java
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadData.java
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadStructured.java
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Sprintf.java
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Tracef.java
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/WriteData.java
Log:
interned fields; data type reorganization; propagation of lazy failures in internal functions
Modified: trunk/src/org/griphyn/vdl/karajan/lib/AppendArray.java
--- trunk/src/org/griphyn/vdl/karajan/lib/AppendArray.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/AppendArray.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -21,8 +21,8 @@
 import k.rt.Stack;
 import org.globus.cog.karajan.analyzer.Signature;
-import org.griphyn.vdl.mapping.AbstractDataNode;
 import org.griphyn.vdl.mapping.DSHandle;
+import org.griphyn.vdl.mapping.nodes.AbstractDataNode;
 public class AppendArray extends SetFieldValue {
Modified: trunk/src/org/griphyn/vdl/karajan/lib/CleanDataset.java
--- trunk/src/org/griphyn/vdl/karajan/lib/CleanDataset.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/CleanDataset.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -24,8 +24,8 @@
 import org.globus.cog.karajan.analyzer.ArgRef;
 import org.griphyn.vdl.mapping.file.FileGarbageCollector;
 public class CleanDataset extends SwiftFunction {
 	private ArgRef<AbstractDataNode> var;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/CloseDataset.java
--- trunk/src/org/griphyn/vdl/karajan/lib/CloseDataset.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/CloseDataset.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -26,10 +26,10 @@
 import org.apache.log4j.Logger;
 import org.griphyn.vdl.mapping.InvalidPathException;
 import org.griphyn.vdl.mapping.Path;
 public class CloseDataset extends SwiftFunction {
 	public static final Logger logger = Logger.getLogger(CloseDataset.class);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/CreateArray.java
--- trunk/src/org/griphyn/vdl/karajan/lib/CreateArray.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/CreateArray.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -27,10 +27,10 @@
 import org.globus.cog.karajan.futures.FutureFault;
-import org.griphyn.vdl.mapping.Path;
-import org.griphyn.vdl.mapping.RootArrayDataNode;
 import org.griphyn.vdl.mapping.RootHandle;
 import org.griphyn.vdl.mapping.file.ConcurrentMapper;
+import org.griphyn.vdl.mapping.nodes.RootClosedArrayDataNode;
+import org.griphyn.vdl.type.Field;
 import org.griphyn.vdl.type.Type;
 public class CreateArray extends SetFieldValue {
@@ -53,43 +53,18 @@
 			Type type = checkTypes((List<?>) value);
-			RootHandle handle = new RootArrayDataNode("arrayexpr", type.arrayType());
-			if (type.hasNonPrimitiveComponents()) {
+			RootHandle handle = new RootClosedArrayDataNode(Field.Factory.getImmutableField("arrayexpr", type.arrayType()),
+			    (List<?>) value, null);
+			if (type.hasMappedComponents()) {
 			    handle.init(new ConcurrentMapper());
 			else {
 			    handle.init(null);
-			if (logger.isInfoEnabled()) {
-			    logger.info("CREATEARRAY START array=" + handle.getIdentifier());
-			int index = 0;
-			for (Object o : (List<?>) value) {
-				// TODO check type consistency of elements with
-				// the type of the array
-				DSHandle n = (DSHandle) o;
-				// we know this DSHandle cast will work because we checked
-				// it in the previous scan of the array contents
-				Path p = Path.EMPTY_PATH.addLast(index, true);
-				DSHandle dst = handle.getField(p);
-				deepCopy(dst, n, stack);
-				    logger.info("CREATEARRAY MEMBER array=" + handle.getIdentifier()
-				        + " index=" + index + " member=" + n.getIdentifier());
-				index++;
-			handle.closeShallow();
-			    logger.info("CREATEARRAY COMPLETED array=" + handle.getIdentifier());
+                logger.info("CREATEARRAY array=" + handle.getIdentifier());
 			return handle;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/Execute.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Execute.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Execute.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -20,6 +20,12 @@
 package org.griphyn.vdl.karajan.lib;
+import java.util.Arrays;
+import java.util.HashSet;
+import java.util.Iterator;
+import java.util.List;
+import java.util.Set;
 import k.rt.Abort;
 import k.rt.Channel;
 import k.rt.ConditionalYield;
@@ -32,6 +38,7 @@
 import org.globus.cog.abstraction.interfaces.Status;
 import org.globus.cog.abstraction.interfaces.Task;
+import org.globus.cog.karajan.analyzer.CompilationException;
 import org.globus.cog.karajan.analyzer.Param;
 import org.globus.cog.karajan.analyzer.Scope;
@@ -59,14 +66,35 @@
 	@Override
     protected Signature getSignature() {
 	    Signature sig = super.getSignature();
-	    sig.getParams().add(0, new Param("progress", Param.Type.POSITIONAL));
-	    sig.getParams().add(optional("replicationGroup", null));
-	    sig.getParams().add(optional("replicationChannel", null));
-	    sig.getParams().add(optional("jobid", null));
+	    List<Param> params = sig.getParams();
+	    params.add(0, new Param("progress", Param.Type.POSITIONAL));
+	    params.add(optional("replicationGroup", null));
+	    params.add(optional("replicationChannel", null));
+	    params.add(optional("jobid", null));
+	    removeParams(params, "stdout", "stderr", "stdoutLocation", "stderrLocation",
+	        "stdin", "provider", "securityContext", "nativespec",
+	        "delegation", "batch");
 	    return sig;
-	@Override
+	private void removeParams(List<Param> params, String... names) {
+	    Set<String> snames = new HashSet<String>(Arrays.asList(names));
+	    Iterator<Param> i = params.iterator();
+	    while (i.hasNext()) {
+	        Param p = i.next();
+	        if (snames.contains(p.name)) {
+	            try {
+                    setArg(null, p, new ArgRef.Static<Object>(p.value));
+                catch (CompilationException e) {
+                    throw new RuntimeException("Failed to remove parameter " + p.name, e);
+	            i.remove();
+    @Override
     protected void addLocals(Scope scope) {
         super.addLocals(scope);
         context = scope.getVarRef("#context");
Modified: trunk/src/org/griphyn/vdl/karajan/lib/ExpandArguments.java
--- trunk/src/org/griphyn/vdl/karajan/lib/ExpandArguments.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/ExpandArguments.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -29,9 +29,10 @@
 import org.globus.cog.karajan.analyzer.ChannelRef;
-import org.griphyn.vdl.mapping.ArrayDataNode;
 import org.griphyn.vdl.mapping.PathElementComparator;
+import org.griphyn.vdl.mapping.nodes.ArrayHandle;
 public class ExpandArguments extends SwiftFunction {
 	public static final Logger logger = Logger.getLogger(ExpandArguments.class);
@@ -58,15 +59,17 @@
 	private Object expandArrays(Channel<Object> items) {
         ArrayList<DSHandle> l = new ArrayList<DSHandle>();
         for (Object item : items) {
-            if (item instanceof ArrayDataNode) {
-                ArrayDataNode array = (ArrayDataNode) item;
+            AbstractDataNode h = (AbstractDataNode) item;
+            h.waitFor(this);
+            if (item instanceof ArrayHandle) {
+                ArrayHandle array = (ArrayHandle) item;
                 Map<Comparable<?>, DSHandle> m = array.getArrayValue();
                 SortedMap<Comparable<?>, DSHandle> sorted = new TreeMap<Comparable<?>, DSHandle>(new PathElementComparator());
                 sorted.putAll(m);
                 l.addAll(m.values());
             else {
-                l.add((DSHandle) item);
+                l.add(h);
             // TODO this does not correctly handle structs or
             // externals - at the moment, probably neither of
@@ -85,7 +88,7 @@
                 throw new ExecutionException(this, "Cannot handle argument implemented by " + item.getClass());
                 arraySeen = true;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/FileName.java
--- trunk/src/org/griphyn/vdl/karajan/lib/FileName.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/FileName.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -38,6 +38,7 @@
     @Override
 	public Object function(Stack stack) {
-		return argList(filename(var.getValue(stack)), true);
+		DSHandle var = this.var.getValue(stack);
+		return var.map(var.getPathFromRoot());
Modified: trunk/src/org/griphyn/vdl/karajan/lib/GetArrayIterator.java
--- trunk/src/org/griphyn/vdl/karajan/lib/GetArrayIterator.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/GetArrayIterator.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -24,10 +24,10 @@
 import org.griphyn.vdl.karajan.PairSet;
 public class GetArrayIterator extends SwiftFunction {
 	public static final Logger logger = Logger.getLogger(GetArrayIterator.class);
@@ -67,7 +67,7 @@
 					    if (logger.isDebugEnabled()) {
                             logger.debug("Using future iterator for " + var);
-						return ((ArrayDataNode) var).entryList();
+						return ((ArrayHandle) var).entryList();
Added: trunk/src/org/griphyn/vdl/karajan/lib/GetFieldConst.java
--- trunk/src/org/griphyn/vdl/karajan/lib/GetFieldConst.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/karajan/lib/GetFieldConst.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -0,0 +1,55 @@
+ * Copyright 2012 University of Chicago
+ * Licensed under the Apache License, Version 2.0 (the "License");
+ * you may not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ * http://www.apache.org/licenses/LICENSE-2.0
+ * Unless required by applicable law or agreed to in writing, software
+ * distributed under the License is distributed on an "AS IS" BASIS,
+ * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+ * See the License for the specific language governing permissions and
+ * limitations under the License.
+ * Created on Dec 26, 2006
+package org.griphyn.vdl.karajan.lib;
+import k.rt.ExecutionException;
+import k.rt.Stack;
+import org.globus.cog.karajan.analyzer.ArgRef;
+import org.globus.cog.karajan.analyzer.Param;
+import org.globus.cog.karajan.compiled.nodes.functions.AbstractSingleValuedFunction;
+import org.griphyn.vdl.type.NoSuchTypeException;
+import org.griphyn.vdl.type.Types;
+public class GetFieldConst extends AbstractSingleValuedFunction {
+    private ArgRef<String> name;
+    private ArgRef<String> type;
+    @Override
+    protected Param[] getParams() {
+        return params("name", "type");
+    @Override
+	public Object function(Stack stack) {
+        String name = this.name.getValue(stack);
+        String type = this.type.getValue(stack);
+		try {
+            return Field.Factory.getImmutableField(name, Types.getType(type));
+        catch (NoSuchTypeException e) {
+            throw new ExecutionException("No such type: " + name, e);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/GetFieldSubscript.java
--- trunk/src/org/griphyn/vdl/karajan/lib/GetFieldSubscript.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/GetFieldSubscript.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -22,12 +22,12 @@
 import org.griphyn.vdl.mapping.HandleOpenException;
 import org.griphyn.vdl.mapping.OOBYield;
 public class GetFieldSubscript extends SwiftFunction {
     private ArgRef<DSHandle> var;
@@ -48,7 +48,7 @@
 		    indexh.waitFor();
 		    Object index = indexh.getValue();
 			if ("*".equals(index)) {
-			    return var.getFields(Path.CHILDREN);
+			    return var.getAllFields();
 			else {
 			    return var.getField(Path.EMPTY_PATH.addFirst((Comparable<?>) index, true));
Modified: trunk/src/org/griphyn/vdl/karajan/lib/GetFieldValue.java
--- trunk/src/org/griphyn/vdl/karajan/lib/GetFieldValue.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/GetFieldValue.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -27,8 +27,8 @@
 public class GetFieldValue extends SwiftFunction {
 	public static final Logger logger = Logger.getLogger(GetFieldValue.class);
@@ -52,7 +52,8 @@
 		try {
 			Path path = parsePath(this.path.getValue(stack));
 			if (path.hasWildcards()) {
-			    return var.getFields(path).toArray();
+			    // TODO we should clarify whether we allow generic selectors
+			    return var.getField(path.butLast()).getAllFields().toArray();
 			else {
 				var = (AbstractDataNode) var.getField(path);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/GetStagingInfo.java
--- trunk/src/org/griphyn/vdl/karajan/lib/GetStagingInfo.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/GetStagingInfo.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -85,6 +85,9 @@
     private void addPaths(Info info, Collection<DSHandle> vars, boolean out) throws HandleOpenException {
     	for (DSHandle var : vars) {
+    	    if (!var.getType().hasMappedComponents()) {
+    	        continue;
     	    Mapper m = getMapper(var);
     	    if (out && !m.isStatic() && var.getType().hasArrayComponents()) {
     	        Collection<AbsFile> patterns = m.getPattern(var.getPathFromRoot(), var.getType());
Modified: trunk/src/org/griphyn/vdl/karajan/lib/IsFileBound.java
--- trunk/src/org/griphyn/vdl/karajan/lib/IsFileBound.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/IsFileBound.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -24,8 +24,8 @@
 public class IsFileBound extends SwiftFunction {
Modified: trunk/src/org/griphyn/vdl/karajan/lib/Mark.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Mark.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Mark.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -28,10 +28,10 @@
 import org.griphyn.vdl.mapping.DataDependentException;
 import org.griphyn.vdl.mapping.MappingDependentException;
 public class Mark extends SwiftFunction {
     private ArgRef<Channel<AbstractDataNode>> restarts;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/New.java
--- trunk/src/org/griphyn/vdl/karajan/lib/New.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/New.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -20,7 +20,7 @@
-import java.util.Iterator;
+import java.util.Collections;
 import java.util.Map;
@@ -37,17 +37,23 @@
 import org.globus.cog.karajan.analyzer.VarRef;
 import org.globus.cog.karajan.compiled.nodes.Node;
 import org.globus.cog.karajan.parser.WrapperNode;
 import org.griphyn.vdl.mapping.DuplicateMappingChecker;
-import org.griphyn.vdl.mapping.ExternalDataNode;
 import org.griphyn.vdl.mapping.InvalidMapperException;
 import org.griphyn.vdl.mapping.Mapper;
 import org.griphyn.vdl.mapping.MapperFactory;
 import org.griphyn.vdl.mapping.NullMapper;
-import org.griphyn.vdl.mapping.RootDataNode;
+import org.griphyn.vdl.mapping.nodes.ExternalDataNode;
+import org.griphyn.vdl.mapping.nodes.NodeFactory;
+import org.griphyn.vdl.mapping.nodes.RootClosedPrimitiveDataNode;
+import org.griphyn.vdl.mapping.nodes.RootFutureArrayDataNode;
+import org.griphyn.vdl.mapping.nodes.RootFutureMappedSingleDataNode;
+import org.griphyn.vdl.mapping.nodes.RootFuturePrimitiveDataNode;
+import org.griphyn.vdl.mapping.nodes.RootFutureStructDataNode;
@@ -57,10 +63,9 @@
 	private static final Mapper NULL_MAPPER = new NullMapper();
-	private ArgRef<String> type;
+	private ArgRef<Field> field;
 	private ArgRef<Map<String, Object>> mapping;
 	private ArgRef<Object> value;
-	private ArgRef<String> dbgname;
 	private ArgRef<Number> waitCount;
 	private ArgRef<Boolean> input;
 	private ArgRef<Integer> _defline;
@@ -70,8 +75,8 @@
 	@Override
-	    return new Signature(params("type", optional("mapping", null), optional("value", null),
-	        optional("dbgname", null), optional("waitCount", null), optional("input", Boolean.FALSE), optional("_defline", null)));
+	    return new Signature(params("field", optional("mapping", null), optional("value", null),
+	        optional("waitCount", null), optional("input", Boolean.FALSE), optional("_defline", null)));
 	private Tracer tracer;
@@ -96,22 +101,22 @@
     @Override
-		String typename = this.type.getValue(stack);
+		Field field = this.field.getValue(stack);
 		Object value = this.value.getValue(stack);
         Map<String, Object> mapping = this.mapping.getValue(stack);
-		String dbgname = this.dbgname.getValue(stack);
 		Number waitCount = this.waitCount.getValue(stack);
 		boolean input = this.input.getValue(stack);
 		Integer line = this._defline.getValue(stack);
-		if (typename == null && value == null) {
-            throw new ExecutionException("You must specify either a type or a value");
+		if (field == null && value == null) {
+            throw new ExecutionException("You must specify either a field or a value");
 		Mapper mapper;
+		Type type = field.getType();
+		String dbgname = (String) field.getId();
-		Type type = getType(typename);
 		    String desc = (String) mapping.remove("swift#descriptor");
 		    try {
                 mapper = MapperFactory.getMapper(desc);
@@ -143,32 +148,36 @@
 		try {
 			DSHandle handle;
-			if (typename.equals("external")) {
+			if (Types.EXTERNAL.equals(type)) {
 			    if (tracer.isEnabled()) {
 			        tracer.trace(thread, dbgname + " = external");
-				handle = initHandle(new ExternalDataNode(dbgname), mapper, thread, line, input);
+				handle = initHandle(new ExternalDataNode(field), mapper, thread, line, input);
 			else if (type.isArray()) {
 				// dealing with array variable
 				if (value != null) {
-					if (value instanceof RootArrayDataNode) {
+					if (value instanceof RootHandle) {
+					    handle = (RootHandle) value;
-					        tracer.trace(thread, dbgname + " = " + Tracer.getVarName((RootDataNode) value));
+					        tracer.trace(thread, dbgname + " = " + Tracer.getVarName(handle));
-						handle = (RootArrayDataNode) value;
+						handle.closeShallow();
 					else {
-					    handle = initHandle(createArrayFromList(stack, thread, dbgname, type),
+					    handle = initHandle(createArrayFromList(stack, thread, field, value),
+				else if (input && !type.hasMappedComponents()) {
+				    handle = initHandle(createArrayFromList(stack, thread, field, Collections.emptyList()),
+                            mapper, thread, line, input);
 				else {
 				        tracer.trace(thread, dbgname);
-				    handle = initHandle(createEmptyArray(stack, thread, dbgname, type),
+				    handle = initHandle(createEmptyArray(stack, thread, field),
@@ -180,19 +189,25 @@
 				handle = (DSHandle) value;
 			else {
-				handle = initHandle(new RootDataNode(dbgname, type, getDMChecker(stack)),
-				    mapper, thread, line, input);
-				if (value != null) {
-				    if (tracer.isEnabled()) {
-				        tracer.trace(thread, dbgname + " = " + value);
-					handle.setValue(internalValue(type, value));
-				else {
+			    if (value == null) {
+			        handle = initHandle(NodeFactory.newOpenRoot(field, getDMChecker(stack)),
+			        if (tracer.isEnabled()) {
                         tracer.trace(thread, dbgname + " " + mapper);
+			    else {
+			        if (type.isPrimitive()) {
+                        handle = initHandle(new RootClosedPrimitiveDataNode(field, internalValue(type, value)),
+                    else {
+                        throw new ExecutionException("Cannot create non-primitive data node with value '" + value + "'");
+                        tracer.trace(thread, dbgname + " = " + value);
 			if (AbstractDataNode.provenance && logger.isDebugEnabled()) {
@@ -211,41 +226,27 @@
         if (line != null) {
             handle.setLine(line);
-        handle.setInput(input);
+        if (mapper != NULL_MAPPER) {
+            handle.setInput(input);
         handle.init(mapper);
         return handle;
-    private RootHandle createArrayFromList(Stack stack, LWThread thread, String dbgname, Type type)
+    private RootHandle createArrayFromList(Stack stack, LWThread thread, Field field, Object value)
             throws NoSuchFieldException {
-        RootHandle handle = new RootArrayDataNode(dbgname, type, getDMChecker(stack));
         if (!(value instanceof List)) {
             throw new ExecutionException("An array variable can only be initialized with a list of values");
-            tracer.trace(thread, dbgname + " = " + formatList((List<?>) value));
+            tracer.trace(thread, field.getId() + " = " + formatList((List<?>) value));
-        int index = 0;
-        Iterator<?> i = ((List<?>) value).iterator();
-        while (i.hasNext()) {
-            Object n = i.next();
-            if (n instanceof DSHandle) {
-                handle.getField(index).set((DSHandle) n);
-            else {
-                throw new RuntimeException(
-                        "An array variable can only be initialized by a list of DSHandle values");
-            index++;
-        return handle;
+        return new RootClosedArrayDataNode(field, (List<?>) value, getDMChecker(stack));
-    private RootHandle createEmptyArray(Stack stack, LWThread thread, String dbgname, Type type)
+    private RootHandle createEmptyArray(Stack stack, LWThread thread, Field field)
-        return new RootArrayDataNode(dbgname, type, getDMChecker(stack));
+        return new RootFutureArrayDataNode(field, getDMChecker(stack));
     private Type getType(String typename) {
Modified: trunk/src/org/griphyn/vdl/karajan/lib/Operators.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Operators.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Operators.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -21,9 +21,11 @@
+import org.griphyn.vdl.mapping.DependentException;
 import org.griphyn.vdl.util.VDL2Config;
@@ -101,17 +103,22 @@
         protected DSHandle value(AbstractDataNode v1, AbstractDataNode v2) {
             Type t = type(v1, v2);
             DSHandle r;
-            if (t == Types.STRING) {
-            	r = new RootDataNode(Types.STRING, (String.valueOf(v1.getValue()) + String.valueOf(v2.getValue())));
+            try {
+                if (t == Types.STRING) {
+                	r = NodeFactory.newRoot(Field.GENERIC_STRING, StringCache.get((String.valueOf(v1.getValue()) + String.valueOf(v2.getValue()))));
+                else if (t == Types.INT) {
+                	r = NodeFactory.newRoot(Field.GENERIC_INT, getInt(this, v1) + getInt(this, v2));
+                else {
+                	r = NodeFactory.newRoot(Field.GENERIC_FLOAT, getFloat(this, v1) + getFloat(this, v2));
+                logBinaryProvenance("sum", v1, v2, r);
+                return r;
-            else if (t == Types.INT) {
-            	r = new RootDataNode(Types.INT, getInt(this, v1) + getInt(this, v2));
+            catch (DependentException e) {
+                return NodeFactory.newRoot(Field.Factory.getImmutableField("?", t), e);
-            else {
-            	r = new RootDataNode(Types.FLOAT, getFloat(this, v1) + getFloat(this, v2));
-            logBinaryProvenance("sum", v1, v2, r);
-            return r;
@@ -120,14 +127,19 @@
             DSHandle r;
-            if (t == Types.INT) {
-                r = new RootDataNode(Types.INT, getInt(this, v1) - getInt(this, v2));
+            try {
+                if (t == Types.INT) {
+                    r = NodeFactory.newRoot(Field.GENERIC_INT, getInt(this, v1) - getInt(this, v2));
+                else {
+                    r = NodeFactory.newRoot(Field.GENERIC_FLOAT, getFloat(this, v1) - getFloat(this, v2));
+                logBinaryProvenance("difference", v1, v2, r);
+                return r;
-            else {
-                r = new RootDataNode(Types.FLOAT, getFloat(this, v1) - getFloat(this, v2));
-            logBinaryProvenance("difference", v1, v2, r);
-            return r;
@@ -136,21 +148,26 @@
             DSHandle r;
-                r = new RootDataNode(Types.INT, getInt(this, v1) * getInt(this, v2));
+            try {
+                    r = NodeFactory.newRoot(Field.GENERIC_INT, getInt(this, v1) * getInt(this, v2));
+                else {
+                    r = NodeFactory.newRoot(Field.GENERIC_FLOAT, getFloat(this, v1) * getFloat(this, v2));
+                logBinaryProvenance("product", v1, v2, r);
+                return r;
-            else {
-                r = new RootDataNode(Types.FLOAT, getFloat(this, v1) * getFloat(this, v2));
-            logBinaryProvenance("product", v1, v2, r);
-            return r;
 	public static class FQuotient extends SwiftBinaryOp {
         @Override
-            DSHandle r = new RootDataNode(Types.FLOAT, getFloat(this, v1) / getFloat(this, v2));
+            DSHandle r = NodeFactory.newRoot(Field.GENERIC_FLOAT, getFloat(this, v1) / getFloat(this, v2));
             logBinaryProvenance("fquotient", v1, v2, r);
             return r;
@@ -162,7 +179,7 @@
 	public static class IQuotient extends SwiftBinaryOp {
         @Override
-            DSHandle r = new RootDataNode(Types.INT, getInt(this, v1) / getInt(this, v2));
+            DSHandle r = NodeFactory.newRoot(Field.GENERIC_INT, getInt(this, v1) / getInt(this, v2));
             logBinaryProvenance("iquotient", v1, v2, r);
             return r;
@@ -173,102 +190,157 @@
             DSHandle r;
-                r = new RootDataNode(Types.INT, getInt(this, v1) % getInt(this, v2));
+            try {
+                    r = NodeFactory.newRoot(Field.GENERIC_INT, getInt(this, v1) % getInt(this, v2));
+                else {
+                    r = NodeFactory.newRoot(Field.GENERIC_FLOAT, getFloat(this, v1) % getFloat(this, v2));
+                logBinaryProvenance("remainder", v1, v2, r);
+                return r;
-            else {
-                r = new RootDataNode(Types.FLOAT, getFloat(this, v1) % getFloat(this, v2));
-            logBinaryProvenance("remainder", v1, v2, r);
-            return r;
 	public static class LE extends SwiftBinaryOp {
         @Override
+        protected Field getReturnType() {
+            return Field.GENERIC_BOOLEAN;
+        @Override
-            DSHandle r = new RootDataNode(Types.BOOLEAN, getFloat(this, v1) <= getFloat(this, v2));
+            DSHandle r = NodeFactory.newRoot(Field.GENERIC_BOOLEAN, getFloat(this, v1) <= getFloat(this, v2));
             logBinaryProvenance("le", v1, v2, r);
             return r;
 	public static class GE extends SwiftBinaryOp {
+	    @Override
         @Override
-            DSHandle r = new RootDataNode(Types.BOOLEAN, getFloat(this, v1) >= getFloat(this, v2));
+            DSHandle r = NodeFactory.newRoot(Field.GENERIC_BOOLEAN, getFloat(this, v1) >= getFloat(this, v2));
             logBinaryProvenance("ge", v1, v2, r);
             return r;
 	public static class LT extends SwiftBinaryOp {
+	    @Override
         @Override
-            DSHandle r = new RootDataNode(Types.BOOLEAN, getFloat(this, v1) < getFloat(this, v2));
+            DSHandle r = NodeFactory.newRoot(Field.GENERIC_BOOLEAN, getFloat(this, v1) < getFloat(this, v2));
             logBinaryProvenance("lt", v1, v2, r);
             return r;
 	public static class GT extends SwiftBinaryOp {
+	    @Override
         @Override
-            DSHandle r = new RootDataNode(Types.BOOLEAN, getFloat(this, v1) > getFloat(this, v2));
+            DSHandle r = NodeFactory.newRoot(Field.GENERIC_BOOLEAN, getFloat(this, v1) > getFloat(this, v2));
             logBinaryProvenance("gt", v1, v2, r);
             return r;
 	public static class EQ extends SwiftBinaryOp {
+	    @Override
         @Override
-            DSHandle r = new RootDataNode(Types.BOOLEAN, v1.getValue().equals(v2.getValue()));
+            DSHandle r = NodeFactory.newRoot(Field.GENERIC_BOOLEAN, v1.getValue().equals(v2.getValue()));
             logBinaryProvenance("eq", v1, v2, r);
             return r;
 	public static class NE extends SwiftBinaryOp {
+	    @Override
         @Override
-            DSHandle r = new RootDataNode(Types.BOOLEAN, !v1.getValue().equals(v2.getValue()));
+            DSHandle r = NodeFactory.newRoot(Field.GENERIC_BOOLEAN, !v1.getValue().equals(v2.getValue()));
             logBinaryProvenance("ne", v1, v2, r);
             return r;
 	public static class And extends SwiftBinaryOp {
+	    @Override
         @Override
-            DSHandle r = new RootDataNode(Types.BOOLEAN, getBool(this, v1) && getBool(this, v2));
+            DSHandle r = NodeFactory.newRoot(Field.GENERIC_BOOLEAN, getBool(this, v1) && getBool(this, v2));
             logBinaryProvenance("and", v1, v2, r);
             return r;
 	public static class Or extends SwiftBinaryOp {
+	    @Override
         @Override
-            DSHandle r = new RootDataNode(Types.BOOLEAN, getBool(this, v1) || getBool(this, v2));
+            DSHandle r = NodeFactory.newRoot(Field.GENERIC_BOOLEAN, getBool(this, v1) || getBool(this, v2));
             logBinaryProvenance("or", v1, v2, r);
             return r;
 	public static class Not extends SwiftUnaryOp {
+	    @Override
         @Override
         protected DSHandle value(AbstractDataNode v) {
-            DSHandle r = new RootDataNode(Types.BOOLEAN, !getBool(this, v));
+            DSHandle r = NodeFactory.newRoot(Field.GENERIC_BOOLEAN, !getBool(this, v));
             logUnaryProvenance("not", v, r);
             return r;
 	public static class Inc extends SwiftUnaryOp {
+	    @Override
+            return Field.GENERIC_INT;
         @Override
-            DSHandle r = new RootDataNode(Types.INT, getInt(this, v) + 1);
+            DSHandle r = NodeFactory.newRoot(Field.GENERIC_INT, getInt(this, v) + 1);
             return r;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/ProcessStageouts.java
--- trunk/src/org/griphyn/vdl/karajan/lib/ProcessStageouts.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/ProcessStageouts.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -31,12 +31,12 @@
 import org.griphyn.vdl.mapping.AbsFile;
 import org.griphyn.vdl.mapping.FileSystemLister;
+import org.griphyn.vdl.mapping.nodes.InitMapper;
 public class ProcessStageouts extends SwiftFunction {
     public static final Logger logger = Logger.getLogger(ProcessStageouts.class);
@@ -78,7 +78,7 @@
             Mapper m = var.getMapper();
             if (!m.isStatic() && var.getType().hasArrayComponents()) {
                 Collection<Path> found = m.existing(new FileSystemLister.FileList(collectList));
-                RootDataNode.addExisting(found, m, var.getRoot(), var);
+                InitMapper.addExisting(found, m, var.getRoot(), var);
                 logOnly(var, log);
             else {
Modified: trunk/src/org/griphyn/vdl/karajan/lib/Range.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Range.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Range.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -33,12 +33,13 @@
@@ -49,7 +50,7 @@
 	@Override
-        return new Signature(params("from", "to", optional("step", new RootDataNode(Types.FLOAT, 1))));
+        return new Signature(params("from", "to", optional("step", NodeFactory.newRoot(Field.GENERIC_FLOAT, 1))));
 	@Override
@@ -70,8 +71,9 @@
 		// only deal with int and float
 		try {
 			final AbstractDataNode handle;
+			final Field valueField = Field.Factory.getImmutableField("rangeItem", type);
-			handle = new RootArrayDataNode(type.arrayType()) {
+			handle = new RootFutureArrayDataNode(Field.Factory.getImmutableField("range", type.arrayType()), null) {
 				final DSHandle h = this;
 				    closeShallow();
@@ -87,7 +89,7 @@
 					else {
 						int index = (Integer) path.getFirst();
-						DSHandle value = new RootDataNode(type, new Double(start + incr * index));
+						DSHandle value = NodeFactory.newRoot(valueField, new Double(start + incr * index));
 						return Collections.singletonList(value);
@@ -113,10 +115,10 @@
 														if (type == Types.INT) {
-														    value = new RootDataNode(Types.INT, (int) crt);
+														    value = NodeFactory.newRoot(Field.GENERIC_INT, (int) crt);
 														else {
-														    value = new RootDataNode(Types.FLOAT, Double.valueOf(crt));
+														    value = NodeFactory.newRoot(Field.GENERIC_FLOAT, Double.valueOf(crt));
 														key = index;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/RemoteFileNames.java
--- trunk/src/org/griphyn/vdl/karajan/lib/RemoteFileNames.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/RemoteFileNames.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -43,7 +43,6 @@
         Collection<AbsFile> files = this.files.getValue(stack);
         List<String> ret = new ArrayList<String>();
         for (AbsFile f : files) {
-            String path = null;
             if ("file".equals(f.getProtocol())) {
                 ret.add(PathUtils.remotePathName(f.getPath()));
Modified: trunk/src/org/griphyn/vdl/karajan/lib/SetDatasetValues.java
--- trunk/src/org/griphyn/vdl/karajan/lib/SetDatasetValues.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/SetDatasetValues.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -28,8 +28,8 @@
 public class SetDatasetValues extends SwiftFunction {
     private ArgRef<List<DSHandle>> stageouts;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java
--- trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -43,10 +43,11 @@
 import org.griphyn.vdl.karajan.WaitingThreadsMonitor;
+import org.griphyn.vdl.mapping.DataDependentException;
 public class SetFieldValue extends SwiftFunction {
@@ -111,8 +112,6 @@
         tracer = Tracer.getTracer(this);
         return fn;
     @Override
     protected void initializeArgs(Stack stack) {
@@ -186,9 +185,15 @@
 	    return sb.toString();
-	protected void deepCopy(DSHandle dest, DSHandle source, Stack stack) {
+    protected void deepCopy(DSHandle dest, DSHandle source, Stack stack) {
 	    // don't create a state if only a non-composite is copied
-	    ((AbstractDataNode) source).waitFor(this);
+        try {
+            ((AbstractDataNode) source).waitFor(this);
+        catch (DataDependentException e) {
+            dest.setValue(new DataDependentException(dest, e));
+            return;
         if (source.getType().isPrimitive()) {
             dest.setValue(source.getValue());
@@ -208,7 +213,13 @@
     /** make dest look like source - if its a simple value, copy that
 	    and if its an array then recursively copy */
 	public void deepCopy(DSHandle dest, DSHandle source, State state, int level) {
+	    try {
+            return;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/SiteCatalog.java
--- trunk/src/org/griphyn/vdl/karajan/lib/SiteCatalog.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/SiteCatalog.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -27,6 +27,8 @@
 import org.globus.cog.karajan.util.BoundContact;
 import org.globus.cog.karajan.util.ContactSet;
 import org.globus.swift.catalog.site.SiteCatalogParser;
+import org.globus.swift.catalog.site.SwiftContact;
+import org.griphyn.vdl.util.FQN;
 import org.w3c.dom.Document;
 import org.w3c.dom.NamedNodeMap;
 import org.w3c.dom.Node;
@@ -120,7 +122,7 @@
             return null;
         String name = poolName(n, v);
-        BoundContact bc = new BoundContact(name);
+        SwiftContact bc = new SwiftContact(name);
         String sysinfo = attr(n, "sysinfo", null);
         if (sysinfo != null) {
@@ -252,14 +254,14 @@
         return s;
-    private void env(BoundContact bc, Node n) {
+    private void env(SwiftContact bc, Node n) {
         String key = attr(n, "key");
         String value = text(n);
-        bc.addProperty("env:" + key, value);
+        bc.addProfile(new FQN("env", key), value);
-    private void profile(BoundContact bc, Node n) {
+    private void profile(SwiftContact bc, Node n) {
         String ns = attr(n, "namespace");
@@ -271,7 +273,7 @@
             bc.addProperty(key, value);
         else {
-            bc.addProperty(ns + ":" + key, value);
+        	bc.addProfile(new FQN(ns, key), value);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/SliceArray.java
--- trunk/src/org/griphyn/vdl/karajan/lib/SliceArray.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/SliceArray.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -28,11 +28,11 @@
@@ -77,7 +77,7 @@
     		String destinationTypeName = this.type.getValue(stack);
     		Type destinationType = Types.getType(destinationTypeName);
-    		RootArrayDataNode destinationArray = new RootArrayDataNode(destinationType);
+    		RootFutureArrayDataNode destinationArray = new RootFutureArrayDataNode(sourceArray.getField(), null);
     		Path cutPath = Path.EMPTY_PATH.addLast(this.path.getValue(stack), false);
@@ -89,8 +89,8 @@
     			DSHandle sourceElement = (DSHandle) pair.get(1);
     			DSHandle n = sourceElement.getField(cutPath);
-    			destinationArray.getField((Comparable<?>) index).set(n);
+    			destinationArray.addField((Comparable<?>) index, n);
     		// all of the inputs should be closed, so
@@ -122,9 +122,6 @@
 		catch(NoSuchTypeException nste) {
 			throw new ExecutionException("No such type",nste);
-		catch (NoSuchFieldException e) {
-			throw new ExecutionException(this, e);
 		catch (InvalidPathException e) {
Modified: trunk/src/org/griphyn/vdl/karajan/lib/Stagein.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Stagein.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Stagein.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -37,10 +37,10 @@
 public class Stagein extends SwiftFunction {
     public static final Logger logger = Logger.getLogger(Stagein.class);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/Stageout.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Stageout.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Stageout.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -27,9 +27,9 @@
 public class Stageout extends SwiftFunction {
     public static final Logger logger = Logger.getLogger(Stageout.class);
Added: trunk/src/org/griphyn/vdl/karajan/lib/StringCache.java
--- trunk/src/org/griphyn/vdl/karajan/lib/StringCache.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/karajan/lib/StringCache.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -0,0 +1,28 @@
+//This code is developed as part of the Java CoG Kit project
+//The terms of the license can be found at http://www.cogkit.org/license
+//This message may not be removed or altered.
+ * Created on Apr 5, 2014
+import java.util.Map;
+import java.util.WeakHashMap;
+public class StringCache {
+    private static Map<String, String> cache = new WeakHashMap<String, String>();
+    public synchronized static String get(String s) {
+        String sc = cache.get(s);
+        if (sc == null) {
+        	cache.put(s, s);
+        	return s;
+        else {
+        	return sc;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/SwiftBinaryOp.java
--- trunk/src/org/griphyn/vdl/karajan/lib/SwiftBinaryOp.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/SwiftBinaryOp.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -12,17 +12,29 @@
 import k.rt.Stack;
 import org.globus.cog.karajan.compiled.nodes.functions.BinaryOp;
 public abstract class SwiftBinaryOp extends BinaryOp<AbstractDataNode, DSHandle> {
     @Override
     public DSHandle function(Stack stack) {
-    	AbstractDataNode v1 = this.v1.getValue(stack);
-    	v1.waitFor(this);
-    	AbstractDataNode v2 = this.v2.getValue(stack);
-    	v2.waitFor(this);
-        return value(v1, v2);
+        try {
+        	AbstractDataNode v1 = this.v1.getValue(stack);
+        	v1.waitFor(this);
+        	AbstractDataNode v2 = this.v2.getValue(stack);
+        	v2.waitFor(this);
+            return value(v1, v2);
+            return NodeFactory.newRoot(getReturnType(), e);
+        return Field.GENERIC_ANY;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/SwiftFunction.java
--- trunk/src/org/griphyn/vdl/karajan/lib/SwiftFunction.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/SwiftFunction.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -50,7 +50,6 @@
 import org.griphyn.vdl.karajan.TCCache;
 import org.griphyn.vdl.karajan.functions.ConfigProperty;
 import org.griphyn.vdl.mapping.GeneralizedFileFormat;
@@ -61,6 +60,9 @@
 import org.griphyn.vdl.mapping.PathComparator;
 import org.griphyn.vdl.mapping.PhysicalFormat;
@@ -103,8 +105,8 @@
     @Override
     public void runBody(LWThread thr) {
+        Stack stack = thr.getStack();
 		try {
-		    Stack stack = thr.getStack();
 		    ret(stack, function(stack));
 		catch (AssertFailedException e) {
@@ -112,11 +114,13 @@
             throw e;
-            // This would not be the primal fault so in non-lazy errors mode it
-            // should not matter
-            throw new ExecutionException("Wrapping a dependent exception in VDLFunction.post() - errors in data dependencies",e);
+            ret(stack, NodeFactory.newRoot(getReturnType(), e));
 	 * This will likely break if the engine changes in fundamental ways. It also
@@ -330,9 +334,14 @@
 		// Close the future
 		// Mark all leaves
-		for (DSHandle child : handle.getFields(Path.CHILDREN)) {
-			child.closeShallow();
+		try {
+            for (DSHandle child : handle.getAllFields()) {
+            	child.closeShallow();
+        catch (HandleOpenException e) {
+            throw new RuntimeException("Handle not closed after closeShallow()");
 	public static void waitForAll(Node who, Channel<AbstractDataNode> vargs) throws ExecutionException {
Modified: trunk/src/org/griphyn/vdl/karajan/lib/SwiftUnaryOp.java
--- trunk/src/org/griphyn/vdl/karajan/lib/SwiftUnaryOp.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/SwiftUnaryOp.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -12,15 +12,27 @@
 import k.rt.Stack;
 import org.globus.cog.karajan.compiled.nodes.functions.UnaryOp;
 public abstract class SwiftUnaryOp extends UnaryOp<AbstractDataNode, DSHandle> {
     @Override
-    	v1.waitFor(this);
-        return value(v1);
+        try {
+        	v1.waitFor(this);
+            return value(v1);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/TCProfile.java
--- trunk/src/org/griphyn/vdl/karajan/lib/TCProfile.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/TCProfile.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -37,8 +37,8 @@
 import org.globus.cog.karajan.compiled.nodes.functions.Map.Entry;
-import org.globus.cog.karajan.util.BoundContact;
 import org.globus.swift.catalog.TCEntry;
 import org.globus.swift.catalog.util.Profile;
@@ -46,7 +46,7 @@
 public class TCProfile extends SwiftFunction {
     public static final Logger logger = Logger.getLogger(TCProfile.class);
-    private ArgRef<BoundContact> host;
+    private ArgRef<SwiftContact> host;
        Allows for dynamic attributes from the SwiftScript
        profile statements.
@@ -87,9 +87,9 @@
 		Map<String, Object> dynamicAttributes = readDynamicAttributes(stack);
-		BoundContact bc = this.host.getValue(stack);
+		SwiftContact bc = this.host.getValue(stack);
-		Map<String,Object> attrs = null;
+		Map<String, Object> attrs = null;
 		attrs = attributesFromHost(bc, attrs, stack);
 		TCEntry tce = null;
@@ -176,12 +176,11 @@
 	public static final String PROFILE_GLOBUS_PREFIX = (Profile.GLOBUS + "::").toLowerCase();
-	private void addEnvironment(Stack stack, BoundContact bc) {
-		Map<String,Object> props = bc.getProperties();
-		if (props != null) {
-    		for (Map.Entry<String,Object> e : props.entrySet()) {
-    			String name = e.getKey();
-    			FQN fqn = new FQN(name);
+	private void addEnvironment(Stack stack, SwiftContact bc) {
+		Map<FQN, Object> profiles = bc.getProfiles();
+		if (profiles != null) {
+    		for (Map.Entry<FQN, Object> e : profiles.entrySet()) {
+    			FQN fqn = e.getKey();
     			String value = (String) e.getValue();
     			if (Profile.ENV.equalsIgnoreCase(fqn.getNamespace())) {
     			    cr_environment.append(stack, new Entry(fqn.getName(), value));
@@ -235,11 +234,11 @@
 	   Inserts namespace=globus attributes from BoundContact bc
 	   into given attrs
-	private Map<String,Object> attributesFromHost(BoundContact bc, Map<String, Object> attrs, Stack stack) {
-		        FQN fqn = new FQN(e.getKey());
+	private Map<String,Object> attributesFromHost(SwiftContact bc, Map<String, Object> attrs, Stack stack) {
 		        if (Profile.GLOBUS.equalsIgnoreCase(fqn.getNamespace())) {
 		            Attr a = ATTR_TYPES.get(fqn.getName());
 		            if (a == null) {
Modified: trunk/src/org/griphyn/vdl/karajan/lib/Tracer.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Tracer.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Tracer.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -19,11 +19,11 @@
 import org.globus.cog.karajan.analyzer.VariableNotFoundException;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/UnwrapClosedList.java
--- trunk/src/org/griphyn/vdl/karajan/lib/UnwrapClosedList.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/UnwrapClosedList.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -30,8 +30,8 @@
 public class UnwrapClosedList extends SwiftFunction {
 	public static final Logger logger = Logger.getLogger(UnwrapClosedList.class);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/WaitFieldValue.java
--- trunk/src/org/griphyn/vdl/karajan/lib/WaitFieldValue.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/WaitFieldValue.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -22,9 +22,9 @@
 public class WaitFieldValue extends SwiftFunction {
Modified: trunk/src/org/griphyn/vdl/karajan/lib/While.java
--- trunk/src/org/griphyn/vdl/karajan/lib/While.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/While.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -28,8 +28,8 @@
 import org.globus.cog.karajan.compiled.nodes.InternalFunction;
-import org.griphyn.vdl.type.Types;
 public class While extends InternalFunction {
@@ -85,7 +85,7 @@
             switch(i) {
                 case 0:
                     drefs = RefCount.build(stack, srefs);
-                    var.setValue(stack, new RootDataNode(Types.INT, 0));
+                    var.setValue(stack, NodeFactory.newRoot(Field.GENERIC_INT, 0));
                     c_next.create(stack);
                     RefCount.incRefs(drefs);
                     next = (SingleValueChannel<Object>) c_next.get(stack);
Added: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/AbstractSingleValuedSwiftFunction.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/AbstractSingleValuedSwiftFunction.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/AbstractSingleValuedSwiftFunction.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -0,0 +1,37 @@
+ * Created on Apr 17, 2014
+package org.griphyn.vdl.karajan.lib.swiftscript;
+import k.rt.Stack;
+import k.thr.LWThread;
+public abstract class AbstractSingleValuedSwiftFunction extends AbstractSingleValuedFunction {
+    @Override
+    public void runBody(LWThread thr) {
+        try {
+            ret(stack, function(stack));
+            ret(stack, NodeFactory.newRoot(getFieldType(), e));
+    protected Field getFieldType() {
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Assert.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Assert.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Assert.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -26,8 +26,9 @@
 import org.griphyn.vdl.karajan.AssertFailedException;
 import org.griphyn.vdl.karajan.lib.SwiftFunction;
@@ -58,18 +59,25 @@
             hmessage = fargs.get(1);
-        String message;
-        if (hmessage != null) {
-            hmessage.waitFor(this);
-            message = (String) hmessage.getValue();
+        try {
+            String message;
+            if (hmessage != null) {
+                hmessage.waitFor(this);
+                message = (String) hmessage.getValue();
+            else {
+                message = "Assertion failed";
+            AbstractDataNode hvalue = fargs.get(0);
+            hvalue.waitFor(this);
+            checkAssert(hvalue, message);
-        else {
-            message = "Assertion failed";
+            if (logger.isInfoEnabled()) {
+                logger.info(this + " cannot check assertion: data exception");
-        AbstractDataNode hvalue = fargs.get(0);
-        hvalue.waitFor(this);
-        checkAssert(hvalue, message);
         return null;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ExtractFloat.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ExtractFloat.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ExtractFloat.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -28,10 +28,11 @@
 public class ExtractFloat extends SwiftFunction {
@@ -53,12 +54,15 @@
 			BufferedReader breader = new BufferedReader(freader);
 			String str = breader.readLine();
 			freader.close();
-			DSHandle result = new RootDataNode(Types.FLOAT, Double.parseDouble(str));
+			DSHandle result = NodeFactory.newRoot(Field.GENERIC_FLOAT, Double.parseDouble(str));
 			int provid = SwiftFunction.nextProvenanceID();
 			SwiftFunction.logProvenanceResult(provid, result, "extractfloat");
 			SwiftFunction.logProvenanceParameter(provid, handle, "filename");
 			return result;
+            return NodeFactory.newRoot(Field.GENERIC_FLOAT, e);
 		catch (IOException ioe) {
 			throw new ExecutionException("Reading integer content of file", ioe);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ExtractInt.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ExtractInt.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ExtractInt.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -28,10 +28,11 @@
 public class ExtractInt extends SwiftFunction {
@@ -53,12 +54,15 @@
 			freader.close();
-			DSHandle result = new RootDataNode(Types.INT, Integer.parseInt(str));
+			DSHandle result = NodeFactory.newRoot(Field.GENERIC_INT, Integer.parseInt(str));
 			SwiftFunction.logProvenanceResult(provid, result, "extractint");
 			return result;
+		    return NodeFactory.newRoot(Field.GENERIC_INT, e);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FileName.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FileName.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FileName.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -22,10 +22,10 @@
 public class FileName extends SwiftFunction {
@@ -39,7 +39,7 @@
         AbstractDataNode var = this.var.getValue(stack);
 		String s = argList(filename(var), true);
-		DSHandle result = new RootDataNode(Types.STRING, s);
+		DSHandle result = NodeFactory.newRoot(Field.GENERIC_STRING, s);
 		if (PROVENANCE_ENABLED) {
 		    SwiftFunction.logProvenanceParameter(provid, var, "input");
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FileNames.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FileNames.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FileNames.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -20,18 +20,17 @@
-import k.rt.ExecutionException;
 import k.rt.Stack;
-import org.griphyn.vdl.mapping.InvalidPathException;
 public class FileNames extends SwiftFunction {
@@ -45,16 +44,10 @@
 		String[] f = filename(var);
-		DSHandle returnArray = new RootArrayDataNode(Types.STRING.arrayType());
-		try {
-			for (int i = 0; i < f.length; i++) {
-				Path p = parsePath("["+i+"]");
-				DSHandle h = returnArray.getField(p);
-				h.setValue(relativize(f[i]));
-		} catch (InvalidPathException e) {
-			throw new ExecutionException("Unexpected invalid path exception",e);
+		for (int i = 0; i < f.length; i++) {
+		    f[i] = relativize(f[i]);
+		DSHandle returnArray = NodeFactory.newRoot(Field.GENERIC_STRING_ARRAY, Arrays.asList(f));
 		returnArray.closeShallow();
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FnArg.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FnArg.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/FnArg.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -33,10 +33,10 @@
 public class FnArg extends SwiftFunction {
@@ -48,6 +48,11 @@
         return new Signature(params("..."));
+	@Override
+        return Field.GENERIC_STRING;
     @Override
@@ -87,7 +92,7 @@
 			throw new ExecutionException("Missing command line argument: " + name);
 		else {
-			DSHandle result = new RootDataNode(Types.STRING, value);
+			DSHandle result = NodeFactory.newRoot(Field.GENERIC_STRING, value);
 			    int provid = nextProvenanceID();
 			    logProvenanceResult(provid, result, "arg");
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Fprintf.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Fprintf.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Fprintf.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -30,7 +30,8 @@
     Formatted file output. <br>
@@ -55,26 +56,43 @@
     @Override
-        AbstractDataNode hfilename = this.filename.getValue(stack);
-        AbstractDataNode hspec = this.spec.getValue(stack);
-        hfilename.waitFor(this);
-        hspec.waitFor(this);
-        Channel<AbstractDataNode> args = c_vargs.get(stack);
-        waitForAll(this, args);
-        String filename = (String) hfilename.getValue();
-        String spec = (String) hspec.getValue();
-        StringBuilder output = new StringBuilder();
         try {
-            Sprintf.format(spec, args, output);
+            AbstractDataNode hfilename = this.filename.getValue(stack);
+            AbstractDataNode hspec = this.spec.getValue(stack);
+            hfilename.waitFor(this);
+            String filename = (String) hfilename.getValue();
+            try {
+                hspec.waitFor(this);
+                Channel<AbstractDataNode> args = c_vargs.get(stack);
+                waitForAll(this, args);
+                String spec = (String) hspec.getValue();
+                StringBuilder output = new StringBuilder();
+                try {
+                    Sprintf.format(spec, args, output);
+                catch (RuntimeException e) {
+                    throw new ExecutionException(this, e.getMessage());
+                String msg = output.toString();
+                if (logger.isDebugEnabled()) {
+                    logger.debug("file: " + filename + " msg: " + msg);
+                write(filename, msg);
+                    logger.debug("file: " + filename + " msg: <exception>");
+                write(filename, "<exception>");
-        catch (RuntimeException e) {
-            throw new ExecutionException(this, e.getMessage());
+                logger.debug("<exception>");
-        String msg = output.toString();
-        logger.debug("file: " + filename + " msg: " + msg);
-        write(filename, msg);
         return null;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Java.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Java.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Java.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -28,8 +28,8 @@
@@ -48,6 +48,7 @@
     	AbstractDataNode hlib = this.lib.getValue(stack);
     	AbstractDataNode hname = this.name.getValue(stack);
         Channel<AbstractDataNode> args = this.c_vargs.get(stack);
         hlib.waitFor(this);
         hname.waitFor(this);
@@ -56,7 +57,7 @@
         Object[] p = convertInputs(method, args);
         Type type = returnType(method);
         Object value = invoke(method, p);
-        return new RootDataNode(type, value);
+        return NodeFactory.newRoot(type, value);
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -17,10 +17,10 @@
+import java.io.BufferedReader;
 import java.io.IOException;
 import java.io.InputStreamReader;
-import java.io.BufferedReader;
 import java.util.regex.Matcher;
 import java.util.regex.Pattern;
@@ -35,14 +35,15 @@
-import org.globus.cog.karajan.compiled.nodes.functions.AbstractSingleValuedFunction;
 import org.globus.cog.karajan.util.TypeUtil;
+import org.griphyn.vdl.karajan.lib.StringCache;
@@ -76,27 +77,39 @@
         @Override
         protected void runBody(LWThread thr) {
         	Channel<AbstractDataNode> vargs = c_vargs.get(thr.getStack());
-            SwiftFunction.waitForAll(this, vargs);
+        	StringBuilder buf = new StringBuilder();
+        	try {
+        	    Tracef.waitForAll(this, vargs);
+        	    buf.append("SwiftScript trace: ");
+                boolean first = true;
+                for (AbstractDataNode n : vargs) {
+                    if (!first) {
+                        buf.append(", ");
+                    else {
+                        first = false;
+                    //buf.append(v == null ? args[i] : v);
+                    prettyPrint(buf, n);
+        	    buf.append("SwiftScript trace: <exception>");
-            StringBuilder buf = new StringBuilder();
-            buf.append("SwiftScript trace: ");
-            boolean first = true;
-            for (AbstractDataNode n : vargs) {
-                if (!first) {
-                    buf.append(", ");
-                else {
-                	first = false;
-                //buf.append(v == null ? args[i] : v);
-                prettyPrint(buf, n);
             traceLogger.warn(buf);
 	private static void prettyPrint(StringBuilder buf, DSHandle h) {
-        Object o = h.getValue();
+	    Object o;
+	    try {
+	        o = h.getValue();
+	        buf.append("<exception>");
+	        return;
         if (o == null) {
             buf.append(h);
@@ -131,7 +144,7 @@
-	public static class StrCat extends AbstractSingleValuedFunction {
+	public static class StrCat extends AbstractSingleValuedSwiftFunction {
         private ChannelRef<AbstractDataNode> c_vargs;
         @Override
@@ -140,6 +153,11 @@
         @Override
+        @Override
             Channel<AbstractDataNode> vargs = c_vargs.get(stack);
             Channel<Object> args = SwiftFunction.unwrapAll(this, vargs);
@@ -150,7 +168,7 @@
                 buf.append(TypeUtil.toString(o));
-            DSHandle handle = new RootDataNode(Types.STRING, buf.toString());
+            DSHandle handle = NodeFactory.newRoot(Field.GENERIC_STRING, buf.toString());
@@ -164,7 +182,7 @@
-	public static class Exists extends AbstractSingleValuedFunction {
+	public static class Exists extends AbstractSingleValuedSwiftFunction {
         private ArgRef<AbstractDataNode> file;
         @Override
@@ -173,6 +191,11 @@
         @Override
+        @Override
         	AbstractDataNode dn = file.getValue(stack);
         	String filename;
@@ -187,7 +210,7 @@
                 logger.debug("exists: " + file);
-            DSHandle handle = new RootDataNode(Types.BOOLEAN, file.exists());
+            DSHandle handle = NodeFactory.newRoot(Field.GENERIC_BOOLEAN, file.exists());
@@ -199,7 +222,7 @@
-	public static class StrCut extends AbstractSingleValuedFunction {
+	public static class StrCut extends AbstractSingleValuedSwiftFunction {
         private ArgRef<AbstractDataNode> input;
         private ArgRef<AbstractDataNode> pattern;
@@ -209,6 +232,11 @@
         @Override
+        @Override
         	AbstractDataNode hinput = this.input.getValue(stack);
         	String input = SwiftFunction.unwrap(this, hinput);
@@ -235,7 +263,7 @@
                 logger.debug("strcut matched '" + group + "'");
-            DSHandle handle = new RootDataNode(Types.STRING, group);
+            DSHandle handle = NodeFactory.newRoot(Field.GENERIC_STRING, group);
@@ -247,7 +275,7 @@
-	public static class StrStr extends AbstractSingleValuedFunction {
+	public static class StrStr extends AbstractSingleValuedSwiftFunction {
@@ -257,6 +285,11 @@
         @Override
+        @Override
@@ -267,7 +300,7 @@
                 logger.debug("strstr will search '" + input + "' for pattern '" + pattern + "'");
-            DSHandle result = new RootDataNode(Types.INT, input.indexOf(pattern));
+            DSHandle result = NodeFactory.newRoot(Field.GENERIC_INT, input.indexOf(pattern));
@@ -280,62 +313,63 @@
-    public static class ExecSystem extends AbstractSingleValuedFunction {
+    public static class ExecSystem extends AbstractSingleValuedSwiftFunction {
-        //private ArgRef<AbstractDataNode> pattern;
         @Override
             return new Signature(params("input"));
         @Override
-	    public Object function(Stack stack) {
-		AbstractDataNode hinput = this.input.getValue(stack);
-		String input     = SwiftFunction.unwrap(this, hinput);
-		DSHandle handle  = new RootArrayDataNode(Types.STRING.arrayType());
-		StringBuffer out = new StringBuffer();
-		Process proc;
-		int i = 0;
-		try {
-		    proc = Runtime.getRuntime().exec(new String[] {"bash", "-c", input});
-		    proc.waitFor();
-            int exitcode = proc.exitValue();
-            // If the shell returned a non-zero exit code, attempt to print stderr
-            if ( exitcode != 0 ) {
-                BufferedReader reader = new BufferedReader( new InputStreamReader(proc.getErrorStream()) );
-                String line = "";
-                StringBuffer stderr = new StringBuffer();
+    		AbstractDataNode hinput = this.input.getValue(stack);
+    		String input     = SwiftFunction.unwrap(this, hinput);
+    		DSHandle handle = NodeFactory.newOpenRoot(Field.GENERIC_STRING_ARRAY, null);
+    		StringBuffer out = new StringBuffer();
+    		Process proc;
+    		int i = 0;
+    		try {
+    		    proc = Runtime.getRuntime().exec(new String[] {"bash", "-c", input});
+    		    proc.waitFor();
+                int exitcode = proc.exitValue();
+                // If the shell returned a non-zero exit code, attempt to print stderr
+                if ( exitcode != 0 ) {
+                    BufferedReader reader = new BufferedReader( new InputStreamReader(proc.getErrorStream()) );
+                    String line = "";
+                    StringBuffer stderr = new StringBuffer();
+                    while ( (line = reader.readLine()) != null ) {
+                        stderr.append(line);
+                    logger.warn("swift:system returned exitcode :" + exitcode);
+                    logger.warn("swift:system stderr:\n " + stderr );
+    		    BufferedReader reader = new BufferedReader( new InputStreamReader(proc.getInputStream()) );
+    		    String line = "";
-                    stderr.append(line);
+                    DSHandle el;
+                    el = handle.getField(i++);
+                    el.setValue(line);
-                logger.warn("swift:system returned exitcode :" + exitcode);
-                logger.warn("swift:system stderr:\n " + stderr );
-		    BufferedReader reader = new BufferedReader( new InputStreamReader(proc.getInputStream()) );
-		    String line = "";
-            while ( (line = reader.readLine()) != null ) {
-                DSHandle el;
-                el = handle.getField(i++);
-                el.setValue(line);
-		} catch (Exception e) {
-		    e.printStackTrace();
-		handle.closeDeep();
-		if (PROVENANCE_ENABLED) {
-		    int provid = SwiftFunction.nextProvenanceID();
-		    SwiftFunction.logProvenanceResult(provid, handle, "system");
-		    SwiftFunction.logProvenanceParameter(provid, hinput, "input");
-		return handle;
+    		} catch (Exception e) {
+    		    e.printStackTrace();
+    		handle.closeDeep();
+    		if (PROVENANCE_ENABLED) {
+    		    int provid = SwiftFunction.nextProvenanceID();
+    		    SwiftFunction.logProvenanceResult(provid, handle, "system");
+    		    SwiftFunction.logProvenanceParameter(provid, hinput, "input");
+    		return handle;
-		public static class StrSplit extends AbstractSingleValuedFunction {
+    public static class StrSplit extends AbstractSingleValuedSwiftFunction {
@@ -345,6 +379,11 @@
         @Override
+            return Field.GENERIC_STRING_ARRAY;
+        @Override
@@ -353,17 +392,7 @@
             String[] split = input.split(pattern);
-            for (int i = 0; i < split.length; i++) {
-                DSHandle el;
-                try {
-                    el = handle.getField(i);
-                    el.setValue(split[i]);
+            DSHandle handle = NodeFactory.newRoot(Field.GENERIC_STRING_ARRAY, Arrays.asList(split));
             handle.closeDeep();
@@ -382,7 +411,7 @@
 	 * @return DSHandle representing the resulting string
 	 * @throws ExecutionException
-	public static class StrJoin extends AbstractSingleValuedFunction {
+	public static class StrJoin extends AbstractSingleValuedSwiftFunction {
         private ArgRef<AbstractDataNode> array;
         private ArgRef<AbstractDataNode> delim;
@@ -392,6 +421,11 @@
         @Override
+        @Override
             AbstractDataNode harray = this.array.getValue(stack);
             Map<Comparable<?>, DSHandle> arrayValues = SwiftFunction.waitForArray(this, harray);
@@ -411,7 +445,7 @@
             	result.append(h.getValue());
-            DSHandle handle = new RootDataNode(Types.STRING, result.toString());
+            DSHandle handle = NodeFactory.newRoot(Field.GENERIC_STRING, result.toString());
@@ -423,7 +457,7 @@
-	public static class Regexp extends AbstractSingleValuedFunction {
+	public static class Regexp extends AbstractSingleValuedSwiftFunction {
         private ArgRef<AbstractDataNode> transform;
@@ -434,6 +468,11 @@
         @Override
+        @Override
@@ -461,7 +500,7 @@
                 logger.debug("regexp replacement produced '" + group + "'");
@@ -474,7 +513,7 @@
-	public static class ToInt extends AbstractSingleValuedFunction {
+	public static class ToInt extends AbstractSingleValuedSwiftFunction {
         private ArgRef<AbstractDataNode> str;
         @Override
@@ -483,11 +522,16 @@
         @Override
+        @Override
             AbstractDataNode hstr = str.getValue(stack);
             String str = SwiftFunction.unwrap(this, hstr);
-            DSHandle handle = new RootDataNode(Types.INT, Integer.valueOf(str));
+            DSHandle handle = NodeFactory.newRoot(Field.GENERIC_INT, Integer.valueOf(str));
@@ -499,7 +543,7 @@
-	public static class ToFloat extends AbstractSingleValuedFunction {
+	public static class ToFloat extends AbstractSingleValuedSwiftFunction {
         @Override
@@ -508,6 +552,11 @@
         @Override
+            return Field.GENERIC_FLOAT;
+        @Override
             Object obj = SwiftFunction.unwrap(this, hstr);
@@ -515,10 +564,10 @@
             DSHandle handle;
             if (obj instanceof String) {
-                handle = new RootDataNode(Types.FLOAT, Double.valueOf((String) obj));
+                handle = NodeFactory.newRoot(Field.GENERIC_FLOAT, Double.valueOf((String) obj));
             else if (obj instanceof Number) {
-                handle = new RootDataNode(Types.FLOAT, ((Number) obj).doubleValue());
+                handle = NodeFactory.newRoot(Field.GENERIC_FLOAT, ((Number) obj).doubleValue());
             else {
                 throw new ExecutionException("Expected a string or int. Got " + obj);
@@ -538,7 +587,7 @@
 	 * Takes in a float and formats to desired precision and returns a string
-	public static class Format extends AbstractSingleValuedFunction {
+	public static class Format extends AbstractSingleValuedSwiftFunction {
         @Override
@@ -547,6 +596,11 @@
         @Override
+        @Override
@@ -558,7 +612,7 @@
             String format = (String) args.get(0);
             Object[] a = args.subChannel(1).toArray();
-            DSHandle handle = new RootDataNode(Types.STRING, String.format(format, a));
+            DSHandle handle = NodeFactory.newRoot(Field.GENERIC_STRING, String.format(format, a));
@@ -571,7 +625,7 @@
 	 * Takes in an int and pads zeros to the left and returns a string
-	public static class Pad extends AbstractSingleValuedFunction {
+	public static class Pad extends AbstractSingleValuedSwiftFunction {
         private ArgRef<AbstractDataNode> size;
         private ArgRef<AbstractDataNode> value;
@@ -581,13 +635,18 @@
         @Override
+        @Override
             AbstractDataNode hsize = this.size.getValue(stack);
             Integer size = SwiftFunction.unwrap(this, hsize);
             AbstractDataNode hvalue = this.value.getValue(stack);
             Integer value = SwiftFunction.unwrap(this, hvalue);
                     String.format("%0" + size + "d", value));
@@ -600,7 +659,7 @@
-	public static class ToString extends AbstractSingleValuedFunction {
+	public static class ToString extends AbstractSingleValuedSwiftFunction {
         @Override
@@ -609,13 +668,18 @@
         @Override
+        @Override
             StringBuilder sb = new StringBuilder();
             prettyPrint(sb, hvalue);
-            DSHandle handle = new RootDataNode(Types.STRING, sb.toString());
+            DSHandle handle = NodeFactory.newRoot(Field.GENERIC_STRING, StringCache.get(sb.toString()));
@@ -634,7 +698,7 @@
      * Good for debugging because array needs to be closed
      *   before the length is determined
-	public static class Dirname extends AbstractSingleValuedFunction {
+	public static class Dirname extends AbstractSingleValuedSwiftFunction {
         @Override
@@ -643,12 +707,17 @@
         @Override
+        @Override
             String name = SwiftFunction.filename(dn)[0];
             String result = new AbsFile(name).getDirectory();
-            DSHandle handle = new RootDataNode(Types.STRING, result);
+            DSHandle handle = NodeFactory.newRoot(Field.GENERIC_STRING, result);
@@ -660,7 +729,7 @@
-	public static class Length extends AbstractSingleValuedFunction {
+	public static class Length extends AbstractSingleValuedSwiftFunction {
         @Override
@@ -669,11 +738,16 @@
         @Override
+        @Override
             harray.waitFor(this);
-            DSHandle handle = new RootDataNode(Types.INT, Integer.valueOf(harray.getArrayValue().size()));
+            DSHandle handle = NodeFactory.newRoot(Field.GENERIC_INT, Integer.valueOf(harray.getArrayValue().size()));
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadData.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadData.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadData.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -36,9 +36,11 @@
 import org.globus.cog.karajan.analyzer.Signature;
-import org.griphyn.vdl.mapping.AbstractDataNode;
 import org.griphyn.vdl.mapping.DSHandle;
+import org.griphyn.vdl.mapping.nodes.AbstractDataNode;
 import org.griphyn.vdl.type.Type;
@@ -59,7 +61,13 @@
 		AbstractDataNode dest = this.dest.getValue(stack);
 		AbstractDataNode src = this.src.getValue(stack);
-		src.waitFor(this);
+		try {
+		    src.waitFor(this);
+		    return null;
 		if (src.getType().equals(Types.STRING)) {
 			readData(dest, (String) src.getValue());
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadStructured.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadStructured.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadStructured.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -33,10 +33,12 @@
 import org.griphyn.vdl.mapping.Path;
 public class ReadStructured extends SwiftFunction {
@@ -57,7 +59,13 @@
+        try {
+            return null;
 			dest.closeDeep();
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Sprintf.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Sprintf.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Sprintf.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -26,11 +26,12 @@
+import org.griphyn.vdl.type.Field;
@@ -63,8 +64,12 @@
         return new Signature(params("spec", "..."));
     @Override
+    @Override
@@ -77,9 +82,9 @@
             logger.debug("generated: " + msg);
-        return new RootDataNode(Types.STRING, msg);
+        return NodeFactory.newRoot(Field.GENERIC_STRING, msg);
     public static String format(String spec, Channel<AbstractDataNode> args) {
         logger.debug("spec: " + spec);
@@ -197,11 +202,11 @@
     private static void append_q(DSHandle arg, StringBuilder output) {
-        if (arg instanceof ArrayDataNode) {
-            ArrayDataNode node = (ArrayDataNode) arg;
+        if (arg instanceof ArrayHandle) {
+            ArrayHandle node = (ArrayHandle) arg;
             output.append("[");
             try {
-                int size = node.size();
+                int size = node.arraySize();
                 for (int i = 0; i < size; i++) {
                     String entry = "["+i+"]";
                     DSHandle handle =
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Tracef.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Tracef.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Tracef.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -24,8 +24,10 @@
+import org.globus.cog.karajan.compiled.nodes.Node;
     Formatted trace output. <br>
@@ -52,14 +54,32 @@
     @Override
-        String msg = Sprintf.format(spec, args);
+        String msg;
+        try {
+            msg = Sprintf.format(spec, args);
+            msg = "<exception>";
         logger.info(msg);
         System.out.print(msg);
         return null;
+    public static void waitForAll(Node who, Channel<AbstractDataNode> vargs) {
+            try {
+                n.waitFor(who);
+                // ignore here, will print special message in trace
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/WriteData.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/WriteData.java	2014-05-09 04:48:47 UTC (rev 7842)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/WriteData.java	2014-05-09 04:56:39 UTC (rev 7843)
@@ -32,11 +32,13 @@
@@ -62,7 +64,16 @@
 		// src can be any of several forms of value
+		try {
+        	    logger.info(this + " caught dependent exception");
+            return null;
 		if (dest.getType().equals(Types.STRING)) {
 			writeData((String)dest.getValue(), src);
