[Swift-commit] r7841 - in trunk/src/org/griphyn/vdl/type: . impl
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Thu May 8 23:48:06 CDT 2014
Author: hategan
Date: 2014-05-08 23:48:06 -0500 (Thu, 08 May 2014)
New Revision: 7841
Modified:
   trunk/src/org/griphyn/vdl/type/Field.java
   trunk/src/org/griphyn/vdl/type/Type.java
   trunk/src/org/griphyn/vdl/type/impl/FieldImpl.java
   trunk/src/org/griphyn/vdl/type/impl/ImmutableField.java
   trunk/src/org/griphyn/vdl/type/impl/TypeImpl.java
   trunk/src/org/griphyn/vdl/type/impl/UnresolvedType.java
Log:
support fields that are indexed and a bunch of other things
Modified: trunk/src/org/griphyn/vdl/type/Field.java
--- trunk/src/org/griphyn/vdl/type/Field.java	2014-05-09 04:46:37 UTC (rev 7840)
+++ trunk/src/org/griphyn/vdl/type/Field.java	2014-05-09 04:48:06 UTC (rev 7841)
@@ -55,8 +55,7 @@
 	 * of Field.
-	public static final class Factory
+	public static final class Factory {
 	    private static final Map<Field, Field> fieldCache = new HashMap<Field, Field>();
 		public static Field newInstance() {
 			return new FieldImpl();
@@ -77,6 +76,14 @@
 		        return cached;
+	public static final Field GENERIC_STRING = new FieldImpl("?", Types.STRING);
+	public static final Field GENERIC_ANY = new FieldImpl("?", Types.ANY);
+	public static final Field GENERIC_BOOLEAN = new FieldImpl("?", Types.BOOLEAN);
+	public static final Field GENERIC_INT = new FieldImpl("?", Types.INT);
+	public static final Field GENERIC_FLOAT = new FieldImpl("?", Types.FLOAT);
+	public static final Field GENERIC_STRING_ARRAY = new FieldImpl("?", Types.STRING.arrayType());
Modified: trunk/src/org/griphyn/vdl/type/Type.java
--- trunk/src/org/griphyn/vdl/type/Type.java	2014-05-09 04:46:37 UTC (rev 7840)
+++ trunk/src/org/griphyn/vdl/type/Type.java	2014-05-09 04:48:06 UTC (rev 7841)
@@ -111,7 +111,9 @@
 	 * @return Field
 	 * @throws NoSuchFieldException
-	public Field getField(String name) throws NoSuchFieldException;
+	public Field getField(String name) throws NoSuchFieldException;
+	public int getFieldIndex(String name) throws NoSuchFieldException;
 	 * get a list of field names
@@ -187,7 +189,7 @@
-    public boolean hasNonPrimitiveComponents();
+    public boolean hasMappedComponents();
     public boolean hasArrayComponents();
Modified: trunk/src/org/griphyn/vdl/type/impl/FieldImpl.java
--- trunk/src/org/griphyn/vdl/type/impl/FieldImpl.java	2014-05-09 04:46:37 UTC (rev 7840)
+++ trunk/src/org/griphyn/vdl/type/impl/FieldImpl.java	2014-05-09 04:48:06 UTC (rev 7841)
@@ -23,21 +23,13 @@
 public class FieldImpl implements Field {
 	private Comparable<?> id;
 	private Type type;
-	private boolean array = false;
 	public FieldImpl() {
-	public FieldImpl(Comparable<?> id, Type type, boolean array) {
-		this.id = id;
-		this.type = type;
-		this.array = array;
 	public FieldImpl(Comparable<?> id, Type type) {
 		this.id = id;
 		this.type = type;
-		this.array = false;
 	public Comparable<?> getId() {
@@ -48,14 +40,6 @@
 		this.id = id;
-	public boolean isArray() {
-		return array;
-	public void setArray() {
-		array = true;
 	public Type getType() {
 		return type;
Modified: trunk/src/org/griphyn/vdl/type/impl/ImmutableField.java
--- trunk/src/org/griphyn/vdl/type/impl/ImmutableField.java	2014-05-09 04:46:37 UTC (rev 7840)
+++ trunk/src/org/griphyn/vdl/type/impl/ImmutableField.java	2014-05-09 04:48:06 UTC (rev 7841)
@@ -23,11 +23,6 @@
     @Override
-        throw new UnsupportedOperationException();
-    @Override
     public void setType(Type type) {
Modified: trunk/src/org/griphyn/vdl/type/impl/TypeImpl.java
--- trunk/src/org/griphyn/vdl/type/impl/TypeImpl.java	2014-05-09 04:46:37 UTC (rev 7840)
+++ trunk/src/org/griphyn/vdl/type/impl/TypeImpl.java	2014-05-09 04:48:06 UTC (rev 7841)
@@ -30,9 +30,10 @@
 public class TypeImpl extends UnresolvedType {
 	private boolean primitive;
-	private Map<String, Field> fields;
+	private Map<String, Field> fields;
+	private Map<String, Integer> fieldIndices;
 	private Type baseType;
-	private Boolean hasNonPrimitiveComponents, hasArrayComponents;
+	private Boolean hasMappedComponents, hasArrayComponents;
 	public TypeImpl() {
 		this((URI) null, null, false);
@@ -71,7 +72,11 @@
 			throw new DuplicateFieldException(name);
 		else {
-			fields.put(name, field);
+			fields.put(name, field);
+			if (fieldIndices == null) {
+			    fieldIndices = new HashMap<String, Integer>();
+			fieldIndices.put(name, fieldIndices.size());
@@ -92,6 +97,17 @@
 		else {
 			throw new NoSuchFieldException(name);
+	public int getFieldIndex(String name) throws NoSuchFieldException {
+	        throw new NoSuchFieldException("The type " + this + " has no fields");
+	    Integer i = fieldIndices.get(name);
+	    if (i == null) {
+	        throw new NoSuchFieldException("The type " + this + " has no field named '" + name + "'");
+	    return i;
 	public List<String> getFieldNames() {
@@ -132,37 +148,37 @@
         return isArray() || !fields.isEmpty();
-    public synchronized boolean hasNonPrimitiveComponents() {
-        if (hasNonPrimitiveComponents == null) {
+    public synchronized boolean hasMappedComponents() {
+        if (hasMappedComponents == null) {
             if (isPrimitive()) {
-                hasNonPrimitiveComponents = false;
+                hasMappedComponents = false;
             else if (!isComposite()) {
                 // mapped
-                hasNonPrimitiveComponents = true;
+                hasMappedComponents = true;
             else if (isArray()) {
-                if (keyType().hasNonPrimitiveComponents()) {
+                if (keyType().hasMappedComponents()) {
-                else if (itemType().hasNonPrimitiveComponents()) {
+                else if (itemType().hasMappedComponents()) {
                 else {
             else {
                 // struct
                 for (Field f : getFields()) {
-                    if (f.getType().hasNonPrimitiveComponents()) {
-                        return hasNonPrimitiveComponents = true;
+                    if (f.getType().hasMappedComponents()) {
+                        return hasMappedComponents = true;
-        return hasNonPrimitiveComponents;
+        return hasMappedComponents;
     public synchronized boolean hasArrayComponents() {
Modified: trunk/src/org/griphyn/vdl/type/impl/UnresolvedType.java
--- trunk/src/org/griphyn/vdl/type/impl/UnresolvedType.java	2014-05-09 04:46:37 UTC (rev 7840)
+++ trunk/src/org/griphyn/vdl/type/impl/UnresolvedType.java	2014-05-09 04:48:06 UTC (rev 7841)
@@ -85,9 +85,14 @@
 	@Override
-    public boolean hasNonPrimitiveComponents() {
+    @Override
+    public boolean hasMappedComponents() {
+        throw new UnsupportedOperationException();
 	@Override
     public boolean hasArrayComponents() {
