[Swift-commit] r7831 - trunk/docs/userguide
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Wed May 7 08:58:57 CDT 2014
Author: davidk
Date: 2014-05-07 08:58:56 -0500 (Wed, 07 May 2014)
New Revision: 7831
Modified:
   trunk/docs/userguide/configuration
Log:
Formatting
Modified: trunk/docs/userguide/configuration
--- trunk/docs/userguide/configuration	2014-05-06 21:47:58 UTC (rev 7830)
+++ trunk/docs/userguide/configuration	2014-05-07 13:58:56 UTC (rev 7831)
@@ -401,8 +401,8 @@
 |true, false
 |false
 |When provider staging is enabled and provider.staging.pin.swiftfiles
-|is set, cache some small files needed by Swift to avoid the cost
-|of staging more than once.
+ is set, cache some small files needed by Swift to avoid the cost
+ of staging more than once.
 |sitedir.keep
 |true, false
