[Swift-commit] r7818 - SwiftApps/swift-galaxy/swift
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Tue May 6 10:23:23 CDT 2014
Author: ketan
Date: 2014-05-06 10:23:22 -0500 (Tue, 06 May 2014)
New Revision: 7818
Removed:
   SwiftApps/swift-galaxy/swift/plotswiftlogs
   SwiftApps/swift-galaxy/swift/stochmodel.run
   SwiftApps/swift-galaxy/swift/wind_data.dat
Modified:
   SwiftApps/swift-galaxy/swift/delog
   SwiftApps/swift-galaxy/swift/swiftforeach.sh
   SwiftApps/swift-galaxy/swift/swiftforeachtest.sh
Log:
test, fixes and cleanup
Modified: SwiftApps/swift-galaxy/swift/delog
--- SwiftApps/swift-galaxy/swift/delog	2014-05-06 01:43:46 UTC (rev 7817)
+++ SwiftApps/swift-galaxy/swift/delog	2014-05-06 15:23:22 UTC (rev 7818)
@@ -1 +1 @@
-rm -rfv *.d *.rlog *.log swift.work *.out outdir xhat_outdir obj_outdir /tmp/swift.work Results /scratch/midway/maheshwari/swift.workdir
+rm -rfv *.d *.rlog *.log swift.work *.out outdir /tmp/swift.work Results /tmp/swift-gal.*
Deleted: SwiftApps/swift-galaxy/swift/plotswiftlogs
--- SwiftApps/swift-galaxy/swift/plotswiftlogs	2014-05-06 01:43:46 UTC (rev 7817)
+++ SwiftApps/swift-galaxy/swift/plotswiftlogs	2014-05-06 15:23:22 UTC (rev 7818)
@@ -1,97 +0,0 @@
-#!/bin/bash
-#usage: ./extract4plots <swift.logfile>
-SWIFTLOGFILE=$1
-TMPDIR=`mktemp -d plotlog.XXX`
-grep -i ProgressTicker $SWIFTLOGFILE > $TMPDIR/swiftoutfile.out
-SWIFTOUTFILE=$TMPDIR/swiftoutfile.out
-#extract start time
-TMPDATE=`grep -i progress $SWIFTOUTFILE | head -n 1 | cut -f1-2 -d ' '`
-START_TIME=`date +%s -d "$TMPDATE"`
-#extract end time
-TMPDATE=`grep -i progress $SWIFTOUTFILE | tail -n 1 | cut -f1-2 -d ' '`
-END_TIME=`date +%s -d "$TMPDATE"`
-#duration
-DIFFTIME=$((END_TIME - START_TIME))
-#extract active runs in a file
-grep -o -i "Active:[0-9]*" $SWIFTOUTFILE | awk -F: '{print $2}' > $TMPDIR/active.txt
-#extract successful completions in a file
-grep -o -i "Successfully:[0-9]*" $SWIFTOUTFILE | awk -F: '{print $2}' > $TMPDIR/cumulative.txt
-#prepare tics
-activelines=`wc -l $TMPDIR/active.txt | awk '{print $1}'`
-cumulines=`wc -l $TMPDIR/cumulative.txt | awk '{print $1}'`
-activelinespertic=`echo "scale=5 ; $DIFFTIME / $activelines" | bc`
-seq 0 $activelinespertic $DIFFTIME > $TMPDIR/activetics.txt
-cumulinespertic=`echo "scale=5 ; $DIFFTIME / $cumulines" | bc`
-seq 0 $cumulinespertic $DIFFTIME > $TMPDIR/cumultics.txt
-#final plot data
-paste $TMPDIR/activetics.txt $TMPDIR/active.txt > $TMPDIR/plot_active.txt
-paste $TMPDIR/cumultics.txt $TMPDIR/cumulative.txt > $TMPDIR/plot_cumulative.txt
-cat << EOF > $TMPDIR/plotit.gp
-set terminal png enhanced
-#set term postscript eps enhanced
-#set terminal svg enhanced size 1000 1000
-#set style line 1 linecolor rgb "blue"
-set output "activeplot.png"
-set nokey
-set xlabel "Time in sec"
-set ylabel "number of active jobs"
-set title "Active jobs"
-#set xrange [110000:160000]
-plot "plot_active.txt" using 1:2 with line
-set output "cumulativeplot.png"
-#set xlabel "Time in seconds"
-set ylabel "number of completed jobs"
-set title "Cumulative jobs"
-plot "plot_cumulative.txt" using 1:2 with lines
-#set output "cumulativeplot-openmp.png"
-#set ylabel "number of completed jobs"
-#set title "Cumulative jobs"
-#plot "plot_cumulative.txt" using 1:($2*24) with lines
-#set output "scs_loss.png"
-#set title "SciColSim evolution loss Results"
-#set xlabel "Evolution"
-#set ylabel "Value of loss(AR)"
-#plot "anneal.data" using 1 with lines
-#set output "multiloss.png"
-#set key auto
-#set yrange [0:200]
-#set ylabel "loss"
-#plot "multiloss.txt" using 3 with lines title "multiloss mean val",  "multiloss.txt" using ($3+$4) with lines title "+stddev", "multiloss.txt" using ($3-$4) with lines title "-stddev"
-EOF
-cd $TMPDIR
-gnuplot plotit.gp
-cp *.png ../
-cd ..
-#scicolsim specific
-#grep  "T =" $SWIFTOUTFILE | awk '{print $6}' | cut -c8- | sed 's/....$//' > T.data
-#grep multi_annealing $SWIFTOUTFILE | grep "1;30" | awk '{print $3}' | cut -c11- | sed 's/....$//' > anneal.data
-#grep returning $SWIFTOUTFILE | awk '{print $3, $4, $5, $6}' | sed -e 's/'ci='//' -e 's/'cj='//' -e 's/'r.loss='//' -e 's/'r.sdev='//' | sort -t' ' -k 1,2n > multiloss.txt
Deleted: SwiftApps/swift-galaxy/swift/stochmodel.run
--- SwiftApps/swift-galaxy/swift/stochmodel.run	2014-05-06 01:43:46 UTC (rev 7817)
+++ SwiftApps/swift-galaxy/swift/stochmodel.run	2014-05-06 15:23:22 UTC (rev 7818)
@@ -1,69 +0,0 @@
-# ampl driver file for unit commitment
-# V. M. Zavala - MCS/ANL 2012
-reset; model edrevised.mod;
-option presolve 0;
-option solver cbc;
-#option solver "/homes/ketan/cbc-2.2/2.2/bin/cbc";
-# set model data
-include set_data_ascii.inc;
-# assign reference bus
-let ref_bus := 22671;
-# initialize variables
-let{s in SCEN,t in TESTTIME, j in GEN}   Pgen[s,t,j]:= np_cap[j]/2;
-let{t in TESTTIME, j in GEN}                yuc[t,j]:= 1;
-let{s in SCEN,t in TESTTIME} slackp[s,t]:= 0;
-let{s in SCEN,t in TESTTIME} slackm[s,t]:= 0;
-# fix first-stage variables if requested (for inference app)
-if (fix_x == 1) then{
-read{t in TESTTIME,j in GEN}   yuc[t,j] < stoch_model_x.in;
-read{j in GEN}             Pgen_initial[j] < stoch_model_x.in;
-close stoch_model_x.in;
-fix{t in TESTTIME,j in GEN}   yuc[t,j];
- fix{j in GEN}             Pgen_initial[j];
-# data collection
-param pricehis{s in SCEN,t in 0..TH};
-param  costhisf{t in 0..TH};
-param  costhiss{s in SCEN,t in 0..TH};
-param    genhis{s in SCEN,t in 0..TH, j in GEN};
-param      Phis{s in SCEN,t in 0..TH, j in LIN};
-# start closed_loop
-let   idx_data := 24*90;
-let  idx_state := 0;
-for{idx_cl in 1..TH/T}{
-# assign data for current horizon
-let{s in SCEN,t in TESTTIME}                  wind_totalmh[s,t]:= wind_total[s,t+idx_data];
-fix{s in SCEN,t in TESTTIME, j in LOAD}            Pload[s,t,j]:= loads[t+idx_data,j];
-# compare total wind production to load
-display wind_totalmh;
-# call solver
-solve;
-# collect results over simulation horizon
-let{s in SCEN,t in TESTTIME}                           pricehis[s,idx_state+t] := pfeq.dual[s,t];
-let{t in TESTTIME}                                       costhisf[idx_state+t] := tot_start_cost[t];
-let{s in SCEN,t in TESTTIME}                           costhiss[s,idx_state+t] := tot_gen_cost[s,t];
-let{s in SCEN,t in TESTTIME,j in GEN}                  genhis[s,idx_state+t,j] := Pgen[s,t,j];
-# shift horizon  and set new initial conditions
-let                idx_data :=  idx_data + T;
-let               idx_state := idx_state + T;
-# print results
-include print_results_revised.inc;
Modified: SwiftApps/swift-galaxy/swift/swiftforeach.sh
--- SwiftApps/swift-galaxy/swift/swiftforeach.sh	2014-05-06 01:43:46 UTC (rev 7817)
+++ SwiftApps/swift-galaxy/swift/swiftforeach.sh	2014-05-06 15:23:22 UTC (rev 7818)
@@ -47,6 +47,9 @@
 stringargs=$1
 shift
+swift=$(which swift)
+BASEDIR=$(dirname $0)
 #workout the file args
 fileargs=()
 while [ $# -gt 0 ] ; do
@@ -68,26 +71,17 @@
     stdinfilexpr='file stdinfile<'\"/dev/null\"'>;'
 fi
-touch None # Create a "None" file in case user does not specify any stdin file
-#### End common setup ####
-if [ "$k_or_t" = "swiftK"  ]
-then #### invoke K
+#workout the array only if user adds args else make it blank
+if [ ${#fileargs[@]} -gt 0 ] ; then
+  tmp=$(printf -- '%s,' "${fileargs[@]}")
+  filearrayexpr='file fileargs[] <fixed_array_mapper; files="'$(echo $tmp | sed -e 's/,$//' -e 's/\"//g')'">;';
+else
+  filearrayexpr='file fileargs[];'
+fi
- #workout the array only if user adds args else make it blank
- if [ ${#fileargs[@]} -gt 0 ] ; then
-     tmp=$(printf -- '%s,' "${fileargs[@]}")
-     filearrayexpr='file fileargs[] <fixed_array_mapper; files="'$(echo $tmp | sed -e 's/,$//' -e 's/\"//g')'">;';
- else
-     filearrayexpr='file fileargs[];'
- fi
+ if [ "$range_or_list" == "list" ] ; then ## list
- if [ "$range_or_list" == "list" ]
- then ## list
  cat << EOF > $wdir/script.swift
  * Swift source script is generated automatically via the Swift-Galaxy
@@ -95,7 +89,6 @@
  * it might be tied with other configuration and paramter values.
  type file;
  app (file _out, file _err) anapp(file _exec, int _i, string _stringargs[], file _fileargs[], file _stdin){
@@ -118,15 +111,13 @@
 else ## range
-* Swift source script is generated automatically via the Swift-Galaxy
-* integration tool. Be careful before making any changes to it directly as
-* it might be tied with other configuration and paramter values.
+ * Swift source script is generated automatically via the Swift-Galaxy
+ * integration tool. Be careful before making any changes to it directly as
+ * it might be tied with other configuration and paramter values.
 type file;
@@ -145,35 +136,41 @@
 EOF
- swift=$(which swift)
+fi
+touch None # Create a "None" file in case user does not specify any stdin file
+#### End common setup ####
+if [ "$k_or_t" = "swiftK"  ] ; then #### invoke K
- BASEDIR=$(dirname $0)
- $BASEDIR/buildsite.sh $sites $wdir
+$BASEDIR/buildsite.sh $sites $wdir
- #build config
- cat << EOF > $wdir/cf
- use.provider.staging=true
- wrapperlog.always.transfer=true
- execution.retries=0
- provider.staging.pin.swiftfiles=false
- sitedir.keep=true
- lazy.errors=false
- EOF
- #build tc
- IFS=',' read -ra S <<< "$sites"
- for site in "${S[@]}" ; do
- cat << EOF >> $wdir/tc
- $site $interpreter $interpreter
+#build config
+cat << EOF > $wdir/cf
+use.provider.staging=true
+wrapperlog.always.transfer=true
+execution.retries=0
+provider.staging.pin.swiftfiles=false
+sitedir.keep=true
+lazy.errors=false
 EOF
- $swift -sites.file $wdir/sites.xml -tc.file $wdir/tc -config $wdir/cf $wdir/script.swift "${swiftargs}" 2>$logfile
- EXITCODE=$?
+#build tc from sites and interpreter
+IFS=',' read -ra S <<< "$sites"
+for site in "${S[@]}" ; do
+cat << EOF >> $wdir/tc
+$site $interpreter $interpreter
+EOF
+done
+$swift -sites.file $wdir/sites.xml -tc.file $wdir/tc -config $wdir/cf $wdir/script.swift "${swiftargs}" 2>$logfile
+EXITCODE=$?
 else
-#### Invoke T
+### Invoke T
@@ -183,7 +180,6 @@
  fi
@@ -222,9 +218,6 @@
  EXITCODE=$?
 fi
-$(for i in $(find $outloc -type f); do echo "$(basename $i) $i"; done)
 cat << EOF > $outlistfile
 $(for i in $(find $outloc -type f -iname "*.out"); do echo "$i"; done)
Modified: SwiftApps/swift-galaxy/swift/swiftforeachtest.sh
--- SwiftApps/swift-galaxy/swift/swiftforeachtest.sh	2014-05-06 01:43:46 UTC (rev 7817)
+++ SwiftApps/swift-galaxy/swift/swiftforeachtest.sh	2014-05-06 15:23:22 UTC (rev 7818)
@@ -1,8 +1,6 @@
 #!/bin/bash
->/tmp/args.txt
-numargs=$#
-for i in $(seq 0 $numargs) ; do
-    echo $1 >> /tmp/args.txt
-    shift
-done
+#!/bin/bash
+./swiftforeach.sh list swiftK localhost "" bash x.sh "" list.txt tmpoutlist a.log list1.out ""
+./swiftforeach.sh range swiftK localhost "" bash x.sh "" 0 9 1 tmpoutrange b.log list2.out ""
Deleted: SwiftApps/swift-galaxy/swift/wind_data.dat
--- SwiftApps/swift-galaxy/swift/wind_data.dat	2014-05-06 01:43:46 UTC (rev 7817)
+++ SwiftApps/swift-galaxy/swift/wind_data.dat	2014-05-06 15:23:22 UTC (rev 7818)
@@ -1,8761 +0,0 @@
-  1.4604638e+004
-  1.4634218e+004
-  1.4815815e+004
-  1.4727098e+004
-  1.4743168e+004
-  1.4483015e+004
-  1.2999350e+004
-  1.4630727e+004
-  1.4479719e+004
-  1.4306342e+004
-  1.4157402e+004
-  1.3937587e+004
-  1.3389845e+004
-  1.2486648e+004
-  1.1849529e+004
-  1.1162285e+004
-  1.0812127e+004
-  1.0708416e+004
-  6.8720418e+003
-  8.7812242e+003
-  9.5594627e+003
-  1.0758985e+004
-  1.1421796e+004
-  1.3009577e+004
-  1.4180183e+004
-  1.4329001e+004
-  1.4396551e+004
-  1.4341032e+004
-  1.4108325e+004
-  1.3147303e+004
-  8.8378060e+003
-  1.0591343e+004
-  9.0934965e+003
-  7.6853615e+003
-  6.1331303e+003
-  5.6353524e+003
-  4.4302037e+003
-  3.3891375e+003
-  3.0540820e+003
-  4.9563466e+003
-  6.7906722e+003
-  8.3109852e+003
-  6.4083670e+003
-  9.4898396e+003
-  1.0930867e+004
-  1.0099475e+004
-  1.0554804e+004
-  1.1486225e+004
-  1.2128493e+004
-  1.2527107e+004
-  1.3112883e+004
-  1.3659317e+004
-  1.3730192e+004
-  1.3472952e+004
-  1.1245654e+004
-  1.4206701e+004
-  1.4806646e+004
-  1.4734454e+004
-  1.4761135e+004
-  1.4911007e+004
-  1.4958264e+004
-  1.4989285e+004
-  1.4688689e+004
-  1.4345752e+004
-  1.4005039e+004
-  1.2135346e+004
-  6.6638895e+003
-  7.2567263e+003
-  5.9924644e+003
-  6.3092870e+003
-  2.1547187e+003
-  9.3036575e+003
-  1.3902825e+004
-  1.4328926e+004
-  1.4670176e+004
-  1.4878802e+004
-  1.5000000e+004
-  1.4878856e+004
-  1.3326524e+004
-  1.4198448e+004
-  1.4301489e+004
-  1.4415725e+004
-  1.4378444e+004
-  1.4498946e+004
-  1.4279060e+004
-  1.3914863e+004
-  1.2796871e+004
-  1.2393224e+004
-  1.0395986e+004
-  9.8298310e+003
-  1.0563066e+004
-  1.0364096e+004
-  8.7949911e+003
-  8.2902546e+003
-  8.4147112e+003
-  8.4594761e+003
-  7.2460111e+003
-  7.4637659e+003
-  7.5295553e+003
-  8.2846868e+003
-  8.4298085e+003
-  9.1106839e+003
-  1.0452194e+004
-  1.0058147e+004
-  1.0515954e+004
-  1.0791938e+004
-  1.0878239e+004
-  1.0984556e+004
-  1.2421442e+004
-  1.2526309e+004
-  1.2109814e+004
-  1.2187975e+004
-  1.3500910e+004
-  1.3209517e+004
-  1.0486120e+004
-  1.2258812e+004
-  1.3802451e+004
-  1.4032059e+004
-  1.3377330e+004
-  1.2489842e+004
-  1.1471203e+004
-  1.0850600e+004
-  1.1298938e+004
-  1.0912139e+004
-  1.0839806e+004
-  1.0915816e+004
-  1.1447102e+004
-  1.1111231e+004
-  1.1493451e+004
-  1.0918861e+004
-  9.6301889e+003
-  7.8502798e+003
-  7.4088057e+003
-  8.2662027e+003
-  8.8503890e+003
-  8.3600433e+003
-  7.6097422e+003
-  6.9887984e+003
-  7.2244809e+003
-  5.8163315e+003
-  5.8578837e+003
-  6.8142135e+003
-  8.0361268e+003
-  1.0156091e+004
-  1.1128796e+004
-  1.2739597e+004
-  1.2832609e+004
-  1.3409133e+004
-  1.3291405e+004
-  1.3147447e+004
-  9.8023123e+003
-  1.1100207e+004
-  1.2802876e+004
-  1.2815831e+004
-  1.3073433e+004
-  1.3921522e+004
-  1.4515886e+004
-  1.4488831e+004
-  1.4415337e+004
-  1.4255083e+004
-  1.4106908e+004
-  1.4375706e+004
-  1.1472189e+004
-  1.3094918e+004
-  1.4172600e+004
-  1.4286682e+004
-  1.4293421e+004
-  1.4197785e+004
-  1.4265690e+004
-  1.4333036e+004
-  1.4060515e+004
-  1.2991948e+004
-  1.1920505e+004
-  1.1908054e+004
-  8.4139266e+003
-  9.3300443e+003
-  9.0124664e+003
-  8.3614701e+003
-  7.5923326e+003
-  7.3969297e+003
-  7.4045002e+003
-  6.9294104e+003
-  6.9782450e+003
-  6.5853435e+003
-  5.6027888e+003
-  5.5153168e+003
-  5.5430526e+003
-  4.6971653e+003
-  5.1705340e+003
-  5.5306912e+003
-  6.5798117e+003
-  7.7000285e+003
-  8.6857097e+003
-  9.2988977e+003
-  1.0649614e+004
-  1.1233872e+004
-  1.1358126e+004
-  1.0732146e+004
-  8.6238285e+003
-  9.5651283e+003
-  9.9050952e+003
-  1.0010970e+004
-  1.1646976e+004
-  1.1860142e+004
-  1.1017663e+004
-  1.0123794e+004
-  1.0294310e+004
-  1.0328485e+004
-  1.0328735e+004
-  1.0259523e+004
-  9.2296678e+003
-  1.0185365e+004
-  1.0478528e+004
-  9.5400102e+003
-  1.0836937e+004
-  1.1211469e+004
-  1.1418778e+004
-  1.0803247e+004
-  9.6094019e+003
-  9.7373969e+003
-  1.0541534e+004
-  1.0092324e+004
-  7.8145481e+003
-  8.4654384e+003
-  7.3027336e+003
-  6.9402968e+003
-  7.6689952e+003
-  8.3595990e+003
-  7.6388666e+003
-  7.5505963e+003
-  8.0662858e+003
-  7.1923007e+003
-  5.7492060e+003
-  5.4911117e+003
-  5.9155381e+003
-  4.8508696e+003
-  5.2179338e+003
-  6.6292334e+003
-  6.9216687e+003
-  7.2410945e+003
-  7.6494041e+003
-  7.5113595e+003
-  7.8754058e+003
-  7.6942773e+003
-  8.0416971e+003
-  8.0673828e+003
-  6.5282983e+003
-  6.4137554e+003
-  8.0757559e+003
-  9.7571432e+003
-  1.1137879e+004
-  1.1103022e+004
-  1.2065013e+004
-  1.2489312e+004
-  1.2418812e+004
-  1.1777563e+004
-  1.0927431e+004
-  9.8937299e+003
-  7.9713155e+003
-  6.7819735e+003
-  6.8961700e+003
-  6.2566404e+003
-  5.7496646e+003
-  5.0932616e+003
-  1.8394195e+003
-  2.9395906e+003
-  4.4161939e+003
-  4.7198550e+003
-  5.1044737e+003
-  5.1703642e+003
-  7.5698444e+003
-  7.7816595e+003
-  9.4860846e+003
-  9.2244030e+003
-  9.5443543e+003
-  1.0250938e+004
-  9.4229737e+003
-  7.5854149e+003
-  5.1281729e+003
-  8.7431927e+003
-  9.3942612e+003
-  1.0925057e+004
-  1.2494781e+004
-  1.4617048e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4863523e+004
-  1.4676031e+004
-  1.4484506e+004
-  1.4524968e+004
-  1.4244404e+004
-  1.3808439e+004
-  1.2496348e+004
-  9.4803407e+003
-  9.7736709e+003
-  1.0771415e+004
-  9.7154778e+003
-  9.4543989e+003
-  9.0623354e+003
-  7.3890869e+003
-  6.2508752e+003
-  5.0886659e+003
-  2.0613230e+003
-  0.0000000e+000
-  1.0771810e+003
-  6.7979177e+003
-  7.1838819e+003
-  6.6479566e+003
-  8.1325891e+003
-  8.1190587e+003
-  6.9412771e+003
-  5.6077968e+003
-  5.8705515e+003
-  6.8481542e+003
-  7.6103731e+003
-  8.3501293e+003
-  9.0522048e+003
-  1.0180083e+004
-  1.2517236e+004
-  1.3366998e+004
-  1.2833310e+004
-  1.4022355e+004
-  1.4176963e+004
-  1.4322174e+004
-  1.4334444e+004
-  1.4279905e+004
-  1.4111912e+004
-  1.4002084e+004
-  1.4071263e+004
-  1.0732562e+004
-  1.3120899e+004
-  1.3241310e+004
-  1.3289913e+004
-  1.3153568e+004
-  1.2607650e+004
-  1.2600683e+004
-  1.2544957e+004
-  1.2725473e+004
-  1.2201818e+004
-  1.1474098e+004
-  1.1880459e+004
-  8.9270608e+003
-  1.0210032e+004
-  1.0925674e+004
-  1.1164600e+004
-  1.0764914e+004
-  1.0979607e+004
-  1.0592600e+004
-  9.8162198e+003
-  9.7583630e+003
-  9.8964683e+003
-  8.8958247e+003
-  8.7397326e+003
-  8.0608210e+003
-  8.1619070e+003
-  7.3504930e+003
-  8.0382088e+003
-  7.7118459e+003
-  7.2674756e+003
-  6.2334113e+003
-  5.8431547e+003
-  5.8203088e+003
-  5.7455026e+003
-  5.5800821e+003
-  6.8570401e+003
-  7.8564174e+003
-  7.7161606e+003
-  8.5653244e+003
-  9.5276556e+003
-  8.6756355e+003
-  9.5906841e+003
-  1.1230017e+004
-  1.2264045e+004
-  1.2399421e+004
-  1.1865131e+004
-  1.1451658e+004
-  1.2887561e+004
-  1.0243505e+004
-  1.1847173e+004
-  1.2894840e+004
-  1.3684599e+004
-  1.4127636e+004
-  1.4210979e+004
-  1.4242876e+004
-  1.4150656e+004
-  1.3203352e+004
-  1.3759379e+004
-  1.3974988e+004
-  1.3417503e+004
-  1.3000442e+004
-  1.1845492e+004
-  1.2277074e+004
-  1.4417319e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.2076322e+004
-  1.4897000e+004
-  1.4720062e+004
-  1.4653462e+004
-  1.4466740e+004
-  1.4172617e+004
-  1.4043972e+004
-  1.2890104e+004
-  1.1557656e+004
-  9.8829956e+003
-  8.7323179e+003
-  8.5367666e+003
-  6.1702612e+003
-  7.1326469e+003
-  6.5324079e+003
-  7.4564211e+003
-  8.5370752e+003
-  9.3851424e+003
-  1.0387025e+004
-  1.1620765e+004
-  1.2110906e+004
-  1.2775187e+004
-  1.2575969e+004
-  1.2504335e+004
-  1.0302945e+004
-  1.3906172e+004
-  1.2563315e+004
-  1.2838229e+004
-  1.2882414e+004
-  1.2687524e+004
-  1.2597265e+004
-  1.1614634e+004
-  1.0970847e+004
-  1.0758314e+004
-  1.0288128e+004
-  1.0114996e+004
-  9.0361650e+003
-  6.7228534e+003
-  6.7848430e+003
-  6.8220087e+003
-  7.1732749e+003
-  7.6893060e+003
-  8.9881171e+003
-  8.9253829e+003
-  8.1827589e+003
-  7.5418547e+003
-  8.0333735e+003
-  9.6364617e+003
-  1.0127739e+004
-  1.1646628e+004
-  1.2667632e+004
-  1.3201351e+004
-  1.3769993e+004
-  1.3552437e+004
-  1.3601327e+004
-  1.3217098e+004
-  1.2713829e+004
-  1.1374502e+004
-  1.1130578e+004
-  1.1186375e+004
-  7.9668857e+003
-  7.3172486e+003
-  7.2187024e+003
-  5.9896825e+003
-  6.2685310e+003
-  4.9945978e+003
-  5.6592245e+003
-  5.9005254e+003
-  6.5792015e+003
-  6.2338170e+003
-  6.5014534e+003
-  6.3499975e+003
-  7.5139668e+003
-  9.1379989e+003
-  9.5542845e+003
-  9.2687977e+003
-  8.5863183e+003
-  9.0758520e+003
-  9.4258051e+003
-  9.6298591e+003
-  9.7212965e+003
-  9.6183538e+003
-  9.4370213e+003
-  8.6267553e+003
-  6.6781890e+003
-  7.1908882e+003
-  7.4112830e+003
-  7.4141130e+003
-  8.0993674e+003
-  6.1384773e+003
-  5.8661528e+003
-  5.5360386e+003
-  6.0425172e+003
-  6.2331135e+003
-  7.3111632e+003
-  7.3912723e+003
-  5.7106273e+003
-  5.5063467e+003
-  5.8781842e+003
-  7.1501231e+003
-  7.4451899e+003
-  7.4308416e+003
-  7.3723454e+003
-  7.8567711e+003
-  7.6228960e+003
-  7.4459709e+003
-  6.9587345e+003
-  5.8638733e+003
-  5.8263665e+003
-  4.5055989e+003
-  2.8436927e+003
-  2.5815266e+003
-  1.4737478e+003
-  5.0386013e+003
-  5.8989621e+003
-  5.3344642e+003
-  4.9421662e+003
-  4.9012793e+003
-  4.9506939e+003
-  5.2855550e+003
-  5.9438141e+003
-  6.8177451e+003
-  7.7590123e+003
-  8.4481202e+003
-  7.5585712e+003
-  8.2980809e+003
-  9.9514887e+003
-  1.2905526e+004
-  1.4312394e+004
-  1.4292012e+004
-  1.4857261e+004
-  1.5000000e+004
-  1.3009420e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4693481e+004
-  1.4643895e+004
-  1.4966272e+004
-  1.4970012e+004
-  1.4787153e+004
-  1.4694029e+004
-  1.4653443e+004
-  1.4290510e+004
-  1.4237682e+004
-  1.2919130e+004
-  1.4474984e+004
-  1.4094082e+004
-  1.4171172e+004
-  1.4284654e+004
-  1.4200419e+004
-  1.3612478e+004
-  1.2867021e+004
-  1.2074154e+004
-  1.2093240e+004
-  1.1475811e+004
-  1.0668096e+004
-  7.2439294e+003
-  8.7303146e+003
-  8.3653813e+003
-  7.6986760e+003
-  7.2604085e+003
-  7.7792567e+003
-  8.1130047e+003
-  8.2974310e+003
-  8.3866661e+003
-  8.9405112e+003
-  8.5341046e+003
-  7.9927364e+003
-  7.7718509e+003
-  6.9899210e+003
-  6.9638300e+003
-  6.7659225e+003
-  7.1093142e+003
-  7.2991563e+003
-  6.8767903e+003
-  7.6934791e+003
-  7.7821522e+003
-  7.8216543e+003
-  7.8531126e+003
-  7.8233156e+003
-  6.9522294e+003
-  6.6591518e+003
-  6.6325518e+003
-  6.6580843e+003
-  6.3555215e+003
-  6.7890150e+003
-  6.8891207e+003
-  7.0642888e+003
-  6.8320286e+003
-  6.3737752e+003
-  5.5436397e+003
-  5.1576943e+003
-  6.4914504e+003
-  5.7387781e+003
-  6.3687839e+003
-  6.4308390e+003
-  6.2734878e+003
-  6.4876725e+003
-  6.4941664e+003
-  6.1584640e+003
-  6.3091637e+003
-  5.7402281e+003
-  4.7899058e+003
-  4.8102726e+003
-  4.8939982e+003
-  4.3956205e+003
-  3.9289686e+003
-  5.5061872e+003
-  5.5470573e+003
-  5.2700423e+003
-  5.4074628e+003
-  5.0278879e+003
-  5.2348388e+003
-  4.6101131e+003
-  4.4408374e+003
-  5.0240833e+003
-  6.1152071e+003
-  6.6835540e+003
-  6.3882847e+003
-  6.6668461e+003
-  7.8394472e+003
-  8.1415702e+003
-  7.2696697e+003
-  5.9848743e+003
-  4.6684139e+003
-  2.8942944e+003
-  2.8019687e+003
-  3.3070501e+003
-  2.5910214e+003
-  1.4314987e+003
-  3.8534992e+003
-  6.2982790e+003
-  5.2357355e+003
-  5.0272604e+003
-  5.3962594e+003
-  5.0584472e+003
-  5.1690184e+003
-  4.9319409e+003
-  2.3733825e+003
-  1.8674663e+003
-  3.9131230e+003
-  5.3270261e+003
-  4.7741690e+003
-  3.5228617e+003
-  4.8033253e+003
-  6.0465044e+003
-  6.4354184e+003
-  6.5445502e+003
-  7.1351961e+003
-  6.1159122e+003
-  5.6820687e+003
-  5.6851427e+003
-  6.6394371e+003
-  6.8051028e+003
-  8.7626018e+003
-  9.8700985e+003
-  9.7525488e+003
-  1.1186091e+004
-  1.2148091e+004
-  1.1977491e+004
-  1.1786886e+004
-  1.1670471e+004
-  1.1122932e+004
-  1.0955522e+004
-  8.5505749e+003
-  1.0314628e+004
-  1.0448709e+004
-  1.0385979e+004
-  1.1192427e+004
-  1.1504139e+004
-  1.3439511e+004
-  1.4104301e+004
-  1.4216387e+004
-  1.4231559e+004
-  1.4230738e+004
-  1.4282412e+004
-  9.2069812e+003
-  1.1617117e+004
-  1.2634287e+004
-  1.3755985e+004
-  1.4252133e+004
-  1.4163865e+004
-  1.4057767e+004
-  1.4223056e+004
-  1.4281525e+004
-  1.4292509e+004
-  1.4182438e+004
-  1.4491449e+004
-  1.0433180e+004
-  1.2111644e+004
-  1.3685567e+004
-  1.3778457e+004
-  1.4193909e+004
-  1.4108127e+004
-  1.3645883e+004
-  1.2539153e+004
-  1.0983064e+004
-  9.9111817e+003
-  9.4714199e+003
-  8.9182732e+003
-  6.2315458e+003
-  7.1504760e+003
-  7.3816534e+003
-  6.3503045e+003
-  5.9743150e+003
-  6.1233743e+003
-  7.0836795e+003
-  7.6316002e+003
-  7.4750709e+003
-  7.5902643e+003
-  7.0252588e+003
-  6.9375868e+003
-  7.7537233e+003
-  9.7011463e+003
-  1.0347442e+004
-  9.8876541e+003
-  1.0082942e+004
-  1.0287851e+004
-  1.0031402e+004
-  1.0167991e+004
-  1.0413256e+004
-  1.0861076e+004
-  1.1213174e+004
-  1.1601803e+004
-  9.2470352e+003
-  1.0854291e+004
-  1.1090546e+004
-  1.2188771e+004
-  1.2154009e+004
-  1.1914423e+004
-  1.1501796e+004
-  1.1092450e+004
-  1.1602299e+004
-  1.4502074e+004
-  1.4980428e+004
-  1.4413361e+004
-  9.9192635e+003
-  1.1077996e+004
-  1.1246221e+004
-  1.4389340e+004
-  1.4406407e+004
-  1.4364214e+004
-  1.4087054e+004
-  1.3412246e+004
-  1.3100242e+004
-  1.2514518e+004
-  1.1336575e+004
-  1.0800852e+004
-  8.6264598e+003
-  8.8385719e+003
-  9.9604824e+003
-  1.0153907e+004
-  9.3941784e+003
-  1.0691830e+004
-  1.2315834e+004
-  1.3213231e+004
-  1.3502457e+004
-  1.3767249e+004
-  1.2988381e+004
-  1.2892412e+004
-  1.1108399e+004
-  1.2727293e+004
-  1.3211493e+004
-  1.2949342e+004
-  1.3082253e+004
-  1.2638907e+004
-  1.2021355e+004
-  1.1617553e+004
-  1.1970265e+004
-  1.2122193e+004
-  1.2169804e+004
-  1.2037302e+004
-  1.0492064e+004
-  1.3778985e+004
-  1.3739473e+004
-  1.1934559e+004
-  1.3949745e+004
-  1.4459238e+004
-  1.4609580e+004
-  1.4512488e+004
-  1.4463631e+004
-  1.4192982e+004
-  1.3897833e+004
-  1.4080478e+004
-  1.2234312e+004
-  1.3003037e+004
-  1.4294994e+004
-  1.4470062e+004
-  1.4361884e+004
-  1.4415235e+004
-  1.4389634e+004
-  1.4345621e+004
-  1.4262627e+004
-  1.4222277e+004
-  1.4081542e+004
-  1.3636272e+004
-  1.1659217e+004
-  1.2622429e+004
-  1.3567385e+004
-  1.4032255e+004
-  1.4015588e+004
-  1.4025452e+004
-  1.3969795e+004
-  1.4004818e+004
-  1.3707871e+004
-  1.3197849e+004
-  1.2464983e+004
-  1.1130557e+004
-  9.4842278e+003
-  1.0956735e+004
-  1.1154607e+004
-  1.1102103e+004
-  1.1272361e+004
-  1.0487036e+004
-  9.8683403e+003
-  9.4703844e+003
-  9.0549051e+003
-  8.4705467e+003
-  7.4133889e+003
-  6.7553473e+003
-  5.5238722e+003
-  5.7548244e+003
-  5.6875661e+003
-  1.6051225e+003
-  4.2026773e+002
-  8.9539686e+002
-  1.9395485e+003
-  3.6587482e+003
-  5.3701823e+003
-  5.5331971e+003
-  7.4278833e+003
-  8.5178197e+003
-  9.2523895e+003
-  9.9117717e+003
-  1.1013095e+004
-  1.2062219e+004
-  1.2852101e+004
-  1.3831542e+004
-  1.4118424e+004
-  1.4145167e+004
-  1.4321831e+004
-  1.4426432e+004
-  1.4425608e+004
-  1.4479994e+004
-  1.4010351e+004
-  1.4118594e+004
-  1.3761216e+004
-  1.1712989e+004
-  1.0712392e+004
-  9.7974893e+003
-  8.6829814e+003
-  7.5767150e+003
-  6.4081320e+003
-  5.8829048e+003
-  4.9227422e+003
-  4.6993801e+003
-  5.0885306e+003
-  4.1873780e+003
-  5.8107984e+003
-  5.9665712e+003
-  6.5201013e+003
-  8.3094094e+003
-  8.7357251e+003
-  8.1988957e+003
-  8.9073769e+003
-  9.3771058e+003
-  8.7278003e+003
-  9.2382234e+003
-  8.5998370e+003
-  9.4934231e+003
-  1.0776880e+004
-  1.1458334e+004
-  1.0406241e+004
-  1.1029115e+004
-  1.2097817e+004
-  1.3024363e+004
-  1.2949831e+004
-  1.2541418e+004
-  1.4188205e+004
-  1.4503364e+004
-  9.9500972e+003
-  1.4111632e+004
-  1.4270307e+004
-  1.4707024e+004
-  1.4800199e+004
-  1.4351261e+004
-  1.4409142e+004
-  1.4768074e+004
-  1.4378121e+004
-  1.4424706e+004
-  1.4144187e+004
-  1.3636573e+004
-  9.6444768e+003
-  9.5041747e+003
-  1.0009163e+004
-  1.0935002e+004
-  1.0667843e+004
-  1.2365242e+004
-  1.3204490e+004
-  1.3699200e+004
-  1.3683974e+004
-  1.4012554e+004
-  1.2984965e+004
-  1.3961703e+004
-  1.0137793e+004
-  1.1918972e+004
-  1.2531256e+004
-  1.2594269e+004
-  1.3464707e+004
-  1.2834511e+004
-  1.0959183e+004
-  8.8585548e+003
-  7.1860950e+003
-  7.0195908e+003
-  6.6644474e+003
-  5.8859625e+003
-  4.9916209e+003
-  5.9825393e+003
-  5.9594466e+003
-  6.7251193e+003
-  3.9156185e+003
-  5.0988736e+003
-  6.1351253e+003
-  7.2079983e+003
-  8.4281654e+003
-  8.3617024e+003
-  7.0216475e+003
-  7.0912922e+003
-  6.7809001e+003
-  6.9705054e+003
-  7.5679247e+003
-  8.4736683e+003
-  8.3794527e+003
-  8.7731583e+003
-  9.6065591e+003
-  1.1053568e+004
-  1.2049796e+004
-  1.2838092e+004
-  1.2986587e+004
-  1.3334437e+004
-  1.4062354e+004
-  1.4521259e+004
-  1.4451756e+004
-  1.4572678e+004
-  1.4510068e+004
-  1.4594316e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4800121e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4267581e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4643474e+004
-  1.4404255e+004
-  1.4067538e+004
-  9.6880369e+003
-  9.5288890e+003
-  8.1137043e+003
-  9.0937782e+003
-  8.5854274e+003
-  8.2528275e+003
-  7.5572465e+003
-  8.1722396e+003
-  9.0987208e+003
-  1.0357802e+004
-  1.1228729e+004
-  1.3052231e+004
-  9.4805002e+003
-  9.5240684e+003
-  9.8184787e+003
-  9.2381123e+003
-  8.1361840e+003
-  1.0231635e+004
-  1.1941217e+004
-  1.3170271e+004
-  1.4215765e+004
-  1.4439739e+004
-  1.4725206e+004
-  1.4709380e+004
-  1.1901456e+004
-  1.4328621e+004
-  1.4801070e+004
-  1.4569778e+004
-  1.4509730e+004
-  1.4561757e+004
-  1.4645148e+004
-  1.4526179e+004
-  1.4241119e+004
-  1.4146712e+004
-  1.4173931e+004
-  1.4113412e+004
-  1.2158668e+004
-  1.4289328e+004
-  1.4317921e+004
-  1.4016582e+004
-  1.4529492e+004
-  1.4629424e+004
-  1.4650339e+004
-  1.4576891e+004
-  1.4529512e+004
-  1.4403845e+004
-  1.4020125e+004
-  1.2875908e+004
-  9.9692489e+003
-  1.0429161e+004
-  8.6418236e+003
-  7.7577650e+003
-  7.1825943e+003
-  7.1630558e+003
-  7.6362135e+003
-  7.8691510e+003
-  7.9296263e+003
-  8.0154153e+003
-  6.7209134e+003
-  6.1843787e+003
-  5.6140957e+003
-  6.5164118e+003
-  7.7940088e+003
-  7.3504529e+003
-  7.6546009e+003
-  8.1981775e+003
-  8.7925540e+003
-  5.5695932e+003
-  5.3862940e+003
-  6.6689093e+003
-  7.5352257e+003
-  8.4738248e+003
-  7.9110218e+003
-  9.4590426e+003
-  9.0735452e+003
-  9.7768640e+003
-  1.0310611e+004
-  1.0361878e+004
-  1.0695676e+004
-  1.0986598e+004
-  1.0736037e+004
-  1.0717525e+004
-  1.0586572e+004
-  1.0824228e+004
-  9.1727177e+003
-  9.0529054e+003
-  8.8206118e+003
-  8.6730362e+003
-  1.0022275e+004
-  1.0738376e+004
-  1.1152733e+004
-  1.1201020e+004
-  1.1509478e+004
-  1.1592040e+004
-  1.1160838e+004
-  9.9301227e+003
-  6.9899958e+003
-  8.5092482e+003
-  8.2148459e+003
-  8.6370951e+003
-  8.6102654e+003
-  8.0137262e+003
-  8.0508292e+003
-  7.8329203e+003
-  7.7650416e+003
-  7.3820555e+003
-  7.7287472e+003
-  8.1888309e+003
-  8.1132039e+003
-  7.9290762e+003
-  7.7094138e+003
-  6.8262619e+003
-  5.9207827e+003
-  7.0217579e+003
-  6.6644715e+003
-  6.0004366e+003
-  6.2932051e+003
-  6.9010053e+003
-  6.5315695e+003
-  6.3663386e+003
-  5.8259128e+003
-  5.1309686e+003
-  4.8077354e+003
-  3.1566475e+003
-  2.9443549e+003
-  1.9698490e+003
-  0.0000000e+000
-  3.0803787e+003
-  5.1792297e+003
-  6.0360971e+003
-  7.6424085e+003
-  8.0098398e+003
-  7.2371363e+003
-  7.8566266e+003
-  9.0892714e+003
-  8.4858187e+003
-  1.0515779e+004
-  1.1632925e+004
-  1.2363693e+004
-  1.3896894e+004
-  1.4284029e+004
-  1.4268253e+004
-  1.3508070e+004
-  1.2725922e+004
-  1.0430121e+004
-  1.2075224e+004
-  1.3326251e+004
-  1.3708150e+004
-  1.3606815e+004
-  1.3333076e+004
-  1.2320067e+004
-  1.1612730e+004
-  1.0551017e+004
-  1.0272285e+004
-  1.0265439e+004
-  1.0550800e+004
-  8.0674553e+003
-  8.9121610e+003
-  9.8175919e+003
-  8.0322053e+003
-  8.3964183e+003
-  8.8729891e+003
-  9.4233535e+003
-  1.0556272e+004
-  1.0844777e+004
-  1.1518843e+004
-  1.1554839e+004
-  1.1634080e+004
-  9.1246987e+003
-  9.6649536e+003
-  8.8475278e+003
-  6.4252507e+003
-  2.5030974e+003
-  0.0000000e+000
-  4.8223132e+003
-  5.9091647e+003
-  6.3095408e+003
-  9.2739423e+003
-  1.2091638e+004
-  1.4002867e+004
-  9.5414956e+003
-  1.2942629e+004
-  1.3189751e+004
-  1.3649273e+004
-  1.4366966e+004
-  1.4636004e+004
-  1.4770926e+004
-  1.4842580e+004
-  1.4849564e+004
-  1.4938460e+004
-  1.5000000e+004
-  1.4964678e+004
-  1.3861763e+004
-  1.4873335e+004
-  1.4858591e+004
-  1.4641649e+004
-  1.4466881e+004
-  1.4355976e+004
-  1.4231878e+004
-  1.4061419e+004
-  1.3499465e+004
-  1.2970548e+004
-  1.2473375e+004
-  1.2198572e+004
-  9.4989568e+003
-  9.9775846e+003
-  9.7012179e+003
-  9.4648198e+003
-  9.9017691e+003
-  9.7581187e+003
-  9.6560768e+003
-  9.4750273e+003
-  1.0040307e+004
-  1.0126242e+004
-  1.0159096e+004
-  1.0035799e+004
-  6.0853452e+003
-  7.7743236e+003
-  7.6168651e+003
-  7.5760682e+003
-  6.2833726e+003
-  5.1195741e+003
-  4.3444223e+003
-  3.4019572e+003
-  1.4048059e+003
-  2.6381346e+003
-  3.2159074e+003
-  4.9083576e+003
-  4.8543078e+003
-  5.3196828e+003
-  6.0733839e+003
-  5.8981501e+003
-  7.3894451e+003
-  8.1131159e+003
-  7.7056799e+003
-  7.3681339e+003
-  7.5035738e+003
-  7.2107157e+003
-  7.2424915e+003
-  7.8543538e+003
-  7.9705821e+003
-  8.7023244e+003
-  1.0107390e+004
-  9.6761206e+003
-  9.4715963e+003
-  9.4045555e+003
-  9.6628513e+003
-  8.7524292e+003
-  1.1176901e+004
-  1.4236794e+004
-  1.4736664e+004
-  1.5000000e+004
-  1.1465203e+004
-  1.4946616e+004
-  1.4995395e+004
-  1.4665277e+004
-  1.4807208e+004
-  1.4781769e+004
-  1.4614677e+004
-  1.4655981e+004
-  1.4658028e+004
-  1.4667642e+004
-  1.4621946e+004
-  1.4344220e+004
-  1.0935302e+004
-  1.3621966e+004
-  1.4234808e+004
-  1.4165539e+004
-  1.4101912e+004
-  1.4054979e+004
-  1.3464645e+004
-  1.2828780e+004
-  1.2101428e+004
-  1.1485596e+004
-  1.1123652e+004
-  1.0902801e+004
-  9.2434772e+003
-  8.6906192e+003
-  8.6448217e+003
-  8.7698894e+003
-  9.9557753e+003
-  1.0710070e+004
-  1.1141701e+004
-  1.1433754e+004
-  1.1059784e+004
-  1.0268694e+004
-  1.0120759e+004
-  9.8481759e+003
-  7.8345036e+003
-  8.4266113e+003
-  8.4287481e+003
-  7.1434853e+003
-  6.9707444e+003
-  6.3603010e+003
-  5.7699056e+003
-  5.5568299e+003
-  5.7163069e+003
-  5.9495520e+003
-  5.6191076e+003
-  4.5413240e+003
-  2.5676679e+003
-  2.0135028e+003
-  2.4955947e+003
-  2.4802356e+003
-  5.4545188e+003
-  6.0614815e+003
-  6.9120892e+003
-  8.1157475e+003
-  8.8766452e+003
-  9.6636250e+003
-  9.9976361e+003
-  9.9915715e+003
-  9.3086075e+003
-  1.1065778e+004
-  1.2298101e+004
-  1.2846225e+004
-  1.3351264e+004
-  1.3290772e+004
-  1.2793474e+004
-  1.2407574e+004
-  1.3033798e+004
-  1.2946688e+004
-  1.3004449e+004
-  1.3214582e+004
-  1.3188911e+004
-  1.3880751e+004
-  1.3344874e+004
-  1.2264422e+004
-  1.2827873e+004
-  1.2784096e+004
-  1.3106839e+004
-  1.2594570e+004
-  1.2451453e+004
-  1.2047485e+004
-  1.1567536e+004
-  1.1569071e+004
-  9.2547492e+003
-  1.0441054e+004
-  1.2046080e+004
-  1.2288846e+004
-  1.1666194e+004
-  1.1710763e+004
-  1.1771927e+004
-  1.1442414e+004
-  1.0872409e+004
-  1.0644470e+004
-  1.0148674e+004
-  9.8374366e+003
-  6.8668282e+003
-  7.5542725e+003
-  6.8828798e+003
-  6.8931399e+003
-  7.8866138e+003
-  9.8719819e+003
-  1.1082496e+004
-  1.1129404e+004
-  1.0736206e+004
-  1.0061079e+004
-  9.8078823e+003
-  8.7029149e+003
-  7.3990094e+003
-  9.2700761e+003
-  8.8012180e+003
-  8.4360514e+003
-  7.7027747e+003
-  7.1016189e+003
-  6.6235625e+003
-  6.8712639e+003
-  8.2716918e+003
-  8.8870305e+003
-  1.0195663e+004
-  9.5568632e+003
-  8.8355765e+003
-  9.9249718e+003
-  1.0348319e+004
-  9.3396604e+003
-  1.3080695e+004
-  1.4094140e+004
-  1.1229962e+004
-  1.4019446e+004
-  5.7537004e+003
-  1.4168118e+004
-  1.2409819e+004
-  1.1198443e+004
-  7.5510963e+003
-  1.0476067e+004
-  1.2449274e+004
-  1.4459436e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4779109e+004
-  1.5000000e+004
-  1.4973127e+004
-  1.4396088e+004
-  1.3932624e+004
-  1.1404258e+004
-  1.2490379e+004
-  1.3124220e+004
-  1.3285245e+004
-  1.2154323e+004
-  1.1719791e+004
-  1.1405729e+004
-  1.0803569e+004
-  1.0979757e+004
-  1.0842750e+004
-  9.4148279e+003
-  8.9447294e+003
-  1.0474580e+004
-  1.0654170e+004
-  1.2073502e+004
-  9.8241618e+003
-  1.0735108e+004
-  1.1393666e+004
-  8.0101436e+003
-  6.4510267e+003
-  6.8135170e+003
-  6.8185015e+003
-  6.9813701e+003
-  6.4062007e+003
-  6.4544616e+003
-  5.7861479e+003
-  6.2556668e+003
-  7.1665808e+003
-  8.5007547e+003
-  1.0166471e+004
-  1.0408297e+004
-  9.6927255e+003
-  8.6889407e+003
-  8.7834211e+003
-  1.0125432e+004
-  9.9263118e+003
-  8.1671862e+003
-  7.2932426e+003
-  8.4357286e+003
-  9.0819169e+003
-  1.0383249e+004
-  1.1034219e+004
-  1.1524295e+004
-  1.2521236e+004
-  1.1814155e+004
-  1.2221289e+004
-  1.2604720e+004
-  1.2927573e+004
-  8.2841820e+003
-  1.1474974e+004
-  1.0852282e+004
-  1.0843922e+004
-  1.0291204e+004
-  9.5123974e+003
-  8.4371387e+003
-  8.0675826e+003
-  7.4476846e+003
-  7.5308305e+003
-  6.7131646e+003
-  6.4980960e+003
-  6.8570256e+003
-  7.3573735e+003
-  7.0123758e+003
-  7.0713789e+003
-  6.7994975e+003
-  6.3093348e+003
-  7.1318035e+003
-  8.2868390e+003
-  5.4611297e+003
-  4.7964524e+003
-  5.2555576e+003
-  6.9087118e+003
-  8.2341951e+003
-  7.7071670e+003
-  7.6673284e+003
-  7.4659879e+003
-  7.5914242e+003
-  7.3816621e+003
-  7.2481117e+003
-  6.8707318e+003
-  6.4761274e+003
-  6.0537112e+003
-  6.5645932e+003
-  7.8205565e+003
-  7.9643481e+003
-  8.4133415e+003
-  1.0531654e+004
-  9.1855043e+003
-  8.5728379e+003
-  8.8171523e+003
-  8.7963033e+003
-  9.1893302e+003
-  9.2374726e+003
-  9.7593068e+003
-  9.8509366e+003
-  1.0739447e+004
-  9.7097732e+003
-  9.7198021e+003
-  1.0693049e+004
-  1.1383915e+004
-  1.2439196e+004
-  1.3533839e+004
-  1.4181894e+004
-  1.4305717e+004
-  1.4229583e+004
-  1.4089279e+004
-  1.4134168e+004
-  1.4281123e+004
-  1.3076306e+004
-  1.4187114e+004
-  1.4187817e+004
-  1.4176408e+004
-  1.4135421e+004
-  1.4090997e+004
-  1.3502228e+004
-  1.3233510e+004
-  1.2525716e+004
-  1.1769479e+004
-  1.2250798e+004
-  1.1958145e+004
-  1.0973872e+004
-  1.1881686e+004
-  1.1473418e+004
-  1.0833930e+004
-  1.1196950e+004
-  1.1900890e+004
-  1.2338879e+004
-  1.3326834e+004
-  1.3645038e+004
-  1.3821350e+004
-  1.3940791e+004
-  1.4140934e+004
-  9.9930929e+003
-  1.4077074e+004
-  1.4497044e+004
-  1.4753759e+004
-  1.4677194e+004
-  1.4442834e+004
-  1.3938667e+004
-  1.2907764e+004
-  1.2380220e+004
-  1.2847234e+004
-  1.3579206e+004
-  1.1359191e+004
-  1.1802584e+004
-  1.3090014e+004
-  1.4135285e+004
-  1.3535498e+004
-  1.3254817e+004
-  1.3452397e+004
-  1.2904570e+004
-  1.2649231e+004
-  1.2312797e+004
-  1.1480006e+004
-  1.0671593e+004
-  1.0519124e+004
-  9.3888725e+003
-  7.9363198e+003
-  6.8886571e+003
-  7.8537176e+003
-  7.6754894e+003
-  7.8931987e+003
-  8.4899389e+003
-  7.8401602e+003
-  7.8560037e+003
-  8.9715145e+003
-  9.9519428e+003
-  1.0580305e+004
-  6.4441669e+003
-  7.7639910e+003
-  8.6309266e+003
-  7.4221209e+003
-  7.2698584e+003
-  8.1423531e+003
-  8.1718451e+003
-  8.5642397e+003
-  8.2973969e+003
-  7.8242125e+003
-  6.5184638e+003
-  5.2189921e+003
-  6.4355588e+003
-  7.0334125e+003
-  7.0321991e+003
-  4.4188598e+003
-  3.2297928e+003
-  3.5285907e+003
-  4.6457330e+003
-  5.5306687e+003
-  2.5399096e+003
-  7.1858130e+003
-  9.1080593e+003
-  7.3359031e+003
-  8.1763323e+003
-  1.0732346e+004
-  8.9290812e+003
-  7.6960552e+003
-  7.0271170e+003
-  6.8914436e+003
-  8.0677804e+003
-  8.7445213e+003
-  9.7155992e+003
-  1.0737119e+004
-  9.8512669e+003
-  9.0484760e+003
-  6.0517899e+003
-  6.8466248e+003
-  8.1888250e+003
-  8.1071709e+003
-  8.0731130e+003
-  8.0280502e+003
-  1.0483030e+004
-  1.3518132e+004
-  1.1172404e+004
-  1.0316610e+004
-  8.0378472e+003
-  8.7738759e+003
-  5.8568716e+003
-  9.0746575e+003
-  9.0963285e+003
-  8.0703178e+003
-  9.9411019e+003
-  1.1217857e+004
-  1.0760294e+004
-  9.7667395e+003
-  8.4648519e+003
-  8.2984604e+003
-  7.7178833e+003
-  7.7580898e+003
-  7.4717085e+003
-  6.0676257e+003
-  3.4951801e+003
-  0.0000000e+000
-  2.3380512e+003
-  3.9846646e+003
-  4.0235272e+003
-  5.2688290e+003
-  4.4797040e+003
-  2.8788073e+003
-  4.7908594e+003
-  5.9793720e+003
-  5.2025107e+003
-  7.7421494e+003
-  7.8324247e+003
-  9.7963825e+003
-  1.1518941e+004
-  1.2570508e+004
-  1.2867317e+004
-  1.3821599e+004
-  1.3857268e+004
-  1.3930694e+004
-  1.3478814e+004
-  1.3730738e+004
-  9.3564515e+003
-  9.4812371e+003
-  9.0548790e+003
-  1.0403499e+004
-  9.0645645e+003
-  7.2126478e+003
-  4.7089765e+003
-  4.7891849e+003
-  6.6100268e+003
-  7.3447948e+003
-  6.4376428e+003
-  7.6185749e+003
-  2.1110874e+002
-  1.1373506e+003
-  4.3757936e+003
-  4.9497412e+003
-  6.2684726e+003
-  6.0406612e+003
-  5.3421910e+003
-  5.9610803e+003
-  7.9200691e+003
-  1.1499305e+004
-  1.4576091e+004
-  1.5000000e+004
-  1.4402641e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4909002e+004
-  1.4467209e+004
-  1.4716336e+004
-  1.4679317e+004
-  1.4650656e+004
-  1.4609993e+004
-  1.4795064e+004
-  1.4828855e+004
-  1.4605051e+004
-  1.4540515e+004
-  1.4201620e+004
-  1.3258656e+004
-  1.2017414e+004
-  1.1291449e+004
-  1.1914902e+004
-  1.0340472e+004
-  9.8174494e+003
-  9.5299013e+003
-  9.4850546e+003
-  9.2803055e+003
-  9.0472652e+003
-  8.9645641e+003
-  8.1458484e+003
-  7.0661672e+003
-  4.2546276e+003
-  1.4108127e+003
-  5.8335512e+002
-  1.0146889e+003
-  0.0000000e+000
-  0.0000000e+000
-  0.0000000e+000
-  7.4131086e+002
-  1.6022106e+003
-  2.0770799e+003
-  2.1974531e+003
-  4.1840292e+003
-  5.6402774e+003
-  4.5223642e+003
-  5.5014722e+003
-  6.9221280e+003
-  7.7283190e+003
-  7.7721459e+003
-  8.0817321e+003
-  7.7778470e+003
-  7.2838175e+003
-  7.7189904e+003
-  8.1249837e+003
-  7.8472547e+003
-  7.7363691e+003
-  6.2543381e+003
-  7.7466277e+003
-  7.2656586e+003
-  8.2225310e+003
-  8.8950049e+003
-  9.3533840e+003
-  9.7748716e+003
-  1.0809136e+004
-  1.1618329e+004
-  1.1970662e+004
-  1.1314808e+004
-  1.0556664e+004
-  6.6345732e+003
-  6.6463632e+003
-  6.5032022e+003
-  7.2746443e+003
-  7.4977044e+003
-  8.1142193e+003
-  7.8889939e+003
-  7.1863198e+003
-  6.4160775e+003
-  6.4400400e+003
-  7.0156107e+003
-  7.3654879e+003
-  8.8244128e+003
-  7.8582791e+003
-  8.6853513e+003
-  8.8249663e+003
-  1.0370174e+004
-  1.0941245e+004
-  1.1922483e+004
-  1.1623202e+004
-  1.1243085e+004
-  1.1133588e+004
-  1.1053421e+004
-  1.1290972e+004
-  9.2377126e+003
-  8.8026095e+003
-  8.9373533e+003
-  9.1757044e+003
-  8.5725449e+003
-  9.7099979e+003
-  9.7403763e+003
-  9.2271907e+003
-  9.1182220e+003
-  9.0043299e+003
-  8.3937215e+003
-  8.2742474e+003
-  9.6549021e+003
-  7.9081203e+003
-  8.2856014e+003
-  7.8383385e+003
-  9.5395080e+003
-  1.1176383e+004
-  1.2221771e+004
-  1.2785948e+004
-  1.2887618e+004
-  1.2716079e+004
-  1.2184075e+004
-  1.1533334e+004
-  9.8282771e+003
-  1.1269068e+004
-  1.0978624e+004
-  1.0794367e+004
-  1.0556955e+004
-  1.0769979e+004
-  1.0828544e+004
-  1.0209513e+004
-  9.5137719e+003
-  9.0121265e+003
-  8.1567994e+003
-  8.0307162e+003
-  1.0168467e+004
-  1.0131980e+004
-  1.1256369e+004
-  9.8236835e+003
-  1.1013015e+004
-  1.2507868e+004
-  1.4021151e+004
-  1.4280011e+004
-  1.4407910e+004
-  1.4445569e+004
-  1.4308222e+004
-  1.4420381e+004
-  1.1232421e+004
-  1.3378237e+004
-  1.3411923e+004
-  1.3012345e+004
-  1.2492584e+004
-  1.2298654e+004
-  1.2386837e+004
-  1.2179670e+004
-  1.1168429e+004
-  1.0902152e+004
-  1.1486993e+004
-  1.2063918e+004
-  1.1177430e+004
-  1.0963057e+004
-  1.1435959e+004
-  9.6789524e+003
-  1.1476199e+004
-  1.1546764e+004
-  1.0733248e+004
-  1.0504587e+004
-  1.0406529e+004
-  1.0638678e+004
-  1.0868653e+004
-  1.0263272e+004
-  8.6091671e+003
-  1.1066959e+004
-  1.0953674e+004
-  9.4429814e+003
-  8.4179404e+003
-  8.2217248e+003
-  8.3601949e+003
-  9.0282996e+003
-  9.1982073e+003
-  8.6569087e+003
-  8.6585671e+003
-  7.8009205e+003
-  6.4178891e+003
-  6.7415206e+003
-  5.8559976e+003
-  5.9117999e+003
-  3.9722836e+003
-  6.0296701e+003
-  7.4618641e+003
-  8.8313588e+003
-  9.9238990e+003
-  1.0898124e+004
-  1.1418445e+004
-  1.0722496e+004
-  8.7333012e+003
-  1.1216738e+004
-  9.9782002e+003
-  9.7126705e+003
-  9.5776298e+003
-  1.0067521e+004
-  1.0404540e+004
-  1.0176616e+004
-  9.6210804e+003
-  9.4973669e+003
-  8.6921398e+003
-  7.4706247e+003
-  6.1252518e+003
-  6.1409395e+003
-  6.5952187e+003
-  7.3020032e+003
-  7.2527959e+003
-  7.3933468e+003
-  7.5749785e+003
-  6.5162795e+003
-  6.4908732e+003
-  7.0001880e+003
-  6.8496104e+003
-  6.0681274e+003
-  5.3155844e+003
-  4.0722825e+003
-  5.3203594e+003
-  5.8607589e+003
-  6.6859924e+003
-  8.0999583e+003
-  8.9846017e+003
-  8.7020661e+003
-  8.8184534e+003
-  8.9254723e+003
-  8.7249484e+003
-  9.5903230e+003
-  8.8941581e+003
-  1.0232725e+004
-  1.0706478e+004
-  1.0521954e+004
-  1.1170978e+004
-  1.2512466e+004
-  1.2289820e+004
-  1.3044446e+004
-  1.4138890e+004
-  1.4536861e+004
-  1.4415462e+004
-  1.4839216e+004
-  1.3999461e+004
-  1.4718569e+004
-  1.4585079e+004
-  1.4362790e+004
-  1.4226527e+004
-  1.3863471e+004
-  1.3005983e+004
-  1.2267237e+004
-  1.1705881e+004
-  1.0603914e+004
-  9.5383822e+003
-  9.0802436e+003
-  8.0364191e+003
-  7.3809675e+003
-  6.7710724e+003
-  6.5323381e+003
-  7.2133261e+003
-  6.9420851e+003
-  6.7515115e+003
-  7.2353404e+003
-  7.2918229e+003
-  7.4334467e+003
-  7.7776140e+003
-  7.6357015e+003
-  5.4136383e+003
-  6.9567967e+003
-  7.2914571e+003
-  8.3746646e+003
-  8.3797689e+003
-  8.0609962e+003
-  7.9441481e+003
-  8.4004479e+003
-  8.5951888e+003
-  8.6105226e+003
-  8.5546344e+003
-  8.3593580e+003
-  8.1901362e+003
-  9.0765431e+003
-  9.1195072e+003
-  1.0019727e+004
-  1.2812407e+004
-  1.4195852e+004
-  1.3134091e+004
-  1.4120804e+004
-  1.4408752e+004
-  1.4875879e+004
-  1.4845344e+004
-  1.5000000e+004
-  1.4395046e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4638207e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4653973e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4681622e+004
-  1.4266024e+004
-  1.4815745e+004
-  1.4983997e+004
-  1.4154553e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4973464e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.3780294e+004
-  9.7010363e+003
-  8.1917712e+003
-  1.1310936e+004
-  9.8965791e+003
-  1.3507641e+004
-  1.3554012e+004
-  1.3765462e+004
-  1.4101219e+004
-  1.4272395e+004
-  1.4416189e+004
-  1.4688652e+004
-  1.4826086e+004
-  1.4670777e+004
-  1.4402169e+004
-  1.2496872e+004
-  1.2241314e+004
-  1.2404736e+004
-  1.3741628e+004
-  1.3500178e+004
-  1.3979235e+004
-  1.4143004e+004
-  1.4192295e+004
-  1.4321612e+004
-  1.4128956e+004
-  1.3829451e+004
-  1.3514849e+004
-  9.9970621e+003
-  1.1707246e+004
-  9.8970467e+003
-  8.9752415e+003
-  7.1486200e+003
-  6.2692908e+003
-  6.0784196e+003
-  5.9619368e+003
-  5.9730174e+003
-  6.2039048e+003
-  5.9723830e+003
-  3.8351775e+003
-  1.6122503e+003
-  3.0080328e+003
-  3.1533220e+003
-  5.8748542e+003
-  7.6174181e+003
-  8.7155469e+003
-  1.0193757e+004
-  1.1121322e+004
-  1.1171004e+004
-  1.1535169e+004
-  1.2083812e+004
-  1.1691971e+004
-  1.0325971e+004
-  1.1501575e+004
-  1.1621857e+004
-  1.1512075e+004
-  1.1001734e+004
-  1.0224501e+004
-  9.2666648e+003
-  8.6597987e+003
-  9.2477156e+003
-  1.0439182e+004
-  1.0597366e+004
-  1.1124649e+004
-  9.4253225e+003
-  1.0670077e+004
-  1.0919176e+004
-  1.0402610e+004
-  1.0135706e+004
-  9.6732621e+003
-  9.7695968e+003
-  9.6926672e+003
-  9.6194394e+003
-  1.0365399e+004
-  9.2423537e+003
-  8.0166389e+003
-  6.1149169e+003
-  7.0112661e+003
-  8.9560465e+003
-  8.6875461e+003
-  7.7678205e+003
-  7.1471131e+003
-  6.3106523e+003
-  7.3594311e+003
-  7.1696882e+003
-  7.3800598e+003
-  7.5454383e+003
-  8.0115755e+003
-  5.7496217e+003
-  7.2951002e+003
-  8.0890098e+003
-  9.1902366e+003
-  9.6392392e+003
-  8.7087991e+003
-  9.1081456e+003
-  9.6922402e+003
-  9.7020514e+003
-  9.3872463e+003
-  9.4720711e+003
-  9.7554888e+003
-  8.4477821e+003
-  9.4027607e+003
-  1.0538707e+004
-  1.0151953e+004
-  1.0863096e+004
-  1.1911000e+004
-  1.2228654e+004
-  1.2114524e+004
-  1.2299824e+004
-  1.1786188e+004
-  1.1336688e+004
-  1.1215392e+004
-  1.1269589e+004
-  1.2427636e+004
-  1.4272886e+004
-  1.4160130e+004
-  1.4095589e+004
-  1.3735754e+004
-  1.2900201e+004
-  1.1633518e+004
-  1.0698299e+004
-  9.8901335e+003
-  8.4908450e+003
-  7.2511629e+003
-  7.4197300e+003
-  7.7631189e+003
-  6.5190722e+003
-  6.4703384e+003
-  7.0509953e+003
-  6.9060394e+003
-  6.3509707e+003
-  7.4017998e+003
-  7.7841830e+003
-  8.4215456e+003
-  9.1903027e+003
-  1.0378403e+004
-  7.3133303e+003
-  1.0189031e+004
-  1.0539813e+004
-  1.2521716e+004
-  1.3380934e+004
-  1.4167081e+004
-  1.4398173e+004
-  1.4752845e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4121779e+004
-  1.4646284e+004
-  1.4910063e+004
-  1.4669098e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4811656e+004
-  1.4745843e+004
-  1.4669903e+004
-  1.4548940e+004
-  1.3769466e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4974665e+004
-  1.4617172e+004
-  1.4746468e+004
-  1.4771972e+004
-  1.4777292e+004
-  1.4855458e+004
-  1.4925520e+004
-  1.4889594e+004
-  1.4512723e+004
-  1.1195171e+004
-  1.3210868e+004
-  1.2472851e+004
-  1.3127953e+004
-  1.3010754e+004
-  1.4069465e+004
-  1.4621238e+004
-  1.4998415e+004
-  1.4976641e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4720855e+004
-  1.4529343e+004
-  1.4285345e+004
-  1.4588616e+004
-  1.4991823e+004
-  1.4827456e+004
-  1.4877676e+004
-  1.4956095e+004
-  1.5000000e+004
-  1.4784350e+004
-  1.4536478e+004
-  1.4382463e+004
-  1.3781386e+004
-  1.1777683e+004
-  1.1233448e+004
-  1.0268559e+004
-  8.9035038e+003
-  8.2587982e+003
-  7.6550959e+003
-  7.9435538e+003
-  9.1523550e+003
-  9.0167633e+003
-  6.3455941e+003
-  3.4077947e+003
-  3.6531293e+003
-  5.6488491e+003
-  5.4296927e+003
-  5.0411011e+003
-  6.3584433e+003
-  6.5824564e+003
-  7.9359933e+003
-  7.6170518e+003
-  6.8850285e+003
-  6.8817227e+003
-  6.6294968e+003
-  6.6850377e+003
-  7.1037350e+003
-  7.1479244e+003
-  8.5531852e+003
-  1.0199440e+004
-  9.6071085e+003
-  9.6609307e+003
-  8.7744688e+003
-  9.1489221e+003
-  1.0130569e+004
-  9.4514436e+003
-  9.2088144e+003
-  8.8188430e+003
-  8.1513160e+003
-  6.1715184e+003
-  6.3983365e+003
-  7.8589017e+003
-  8.6600640e+003
-  8.9167077e+003
-  8.9093442e+003
-  9.3809166e+003
-  9.4957980e+003
-  9.1720008e+003
-  9.0786986e+003
-  8.0819689e+003
-  6.7059840e+003
-  6.2571183e+003
-  7.0325435e+003
-  7.1425390e+003
-  7.1184741e+003
-  7.4887276e+003
-  6.7769911e+003
-  6.4787666e+003
-  6.8245185e+003
-  7.4141759e+003
-  7.5973919e+003
-  7.1652653e+003
-  7.8404290e+003
-  5.7802248e+003
-  6.5005778e+003
-  7.5021835e+003
-  8.3194442e+003
-  9.1070989e+003
-  9.4338715e+003
-  8.5041363e+003
-  9.2970958e+003
-  1.0188705e+004
-  1.2417032e+004
-  1.2459151e+004
-  1.2942270e+004
-  9.1233726e+003
-  1.1727934e+004
-  1.3984109e+004
-  1.2889472e+004
-  1.3244862e+004
-  1.4308968e+004
-  1.4731769e+004
-  1.4746503e+004
-  1.4656047e+004
-  1.4303445e+004
-  1.3865946e+004
-  1.2714763e+004
-  1.2000960e+004
-  1.3560890e+004
-  1.2995361e+004
-  1.3422039e+004
-  1.4535890e+004
-  1.4777465e+004
-  1.4967070e+004
-  1.4879856e+004
-  1.4910732e+004
-  1.4782258e+004
-  1.4695056e+004
-  1.4687357e+004
-  1.4121511e+004
-  1.4759418e+004
-  1.5000000e+004
-  1.4965401e+004
-  1.4758242e+004
-  1.4581716e+004
-  1.4444208e+004
-  1.4376421e+004
-  1.4335061e+004
-  1.4350635e+004
-  1.4364710e+004
-  1.4347222e+004
-  1.2114426e+004
-  1.3872644e+004
-  1.4874553e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4979334e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4783654e+004
-  1.4211571e+004
-  1.4716196e+004
-  1.4786293e+004
-  1.4835413e+004
-  1.4827877e+004
-  1.4597823e+004
-  1.4238281e+004
-  1.3727348e+004
-  1.2957858e+004
-  1.2502349e+004
-  1.2132159e+004
-  1.1644598e+004
-  1.0970398e+004
-  1.1668630e+004
-  1.1020949e+004
-  1.1402423e+004
-  1.0558907e+004
-  1.0490039e+004
-  1.0706292e+004
-  1.0850644e+004
-  1.0799384e+004
-  1.0126717e+004
-  9.3871949e+003
-  8.4693499e+003
-  7.0085363e+003
-  7.2415602e+003
-  7.2292194e+003
-  7.8275692e+003
-  6.4402378e+003
-  5.9890921e+003
-  5.9320782e+003
-  6.2308728e+003
-  6.8136383e+003
-  9.3276627e+003
-  1.0341470e+004
-  1.2197048e+004
-  6.9205376e+003
-  9.9778044e+003
-  1.1350595e+004
-  1.3609267e+004
-  1.4041094e+004
-  1.4192064e+004
-  1.4167130e+004
-  1.4176939e+004
-  1.4088837e+004
-  1.3888439e+004
-  1.2814708e+004
-  1.1596045e+004
-  9.2511066e+003
-  9.0477129e+003
-  8.4430163e+003
-  7.8586893e+003
-  7.8376359e+003
-  8.0917059e+003
-  7.4358508e+003
-  7.0982087e+003
-  6.3395532e+003
-  6.3941027e+003
-  6.4247922e+003
-  6.3935672e+003
-  6.1854927e+003
-  6.8903284e+003
-  6.3522680e+003
-  7.4846730e+003
-  8.1266749e+003
-  8.1469858e+003
-  8.3237821e+003
-  7.7033255e+003
-  8.5741890e+003
-  7.6528532e+003
-  7.5833375e+003
-  7.7325730e+003
-  8.3871074e+003
-  9.9255606e+003
-  9.5239558e+003
-  8.9170313e+003
-  8.6002920e+003
-  8.7554196e+003
-  9.7421154e+003
-  1.1203120e+004
-  1.1292763e+004
-  1.0542719e+004
-  1.0256276e+004
-  9.8525464e+003
-  1.0033602e+004
-  1.0860940e+004
-  9.0378211e+003
-  8.8191962e+003
-  8.8037314e+003
-  8.6550895e+003
-  9.4754528e+003
-  9.5530391e+003
-  9.4883842e+003
-  9.4697984e+003
-  9.3662235e+003
-  9.0572360e+003
-  7.4380150e+003
-  8.2599767e+003
-  7.8665648e+003
-  7.4989007e+003
-  7.3549964e+003
-  6.5577604e+003
-  7.2480244e+003
-  7.8794547e+003
-  7.0517735e+003
-  7.6100286e+003
-  8.0429919e+003
-  7.9515827e+003
-  5.8749805e+003
-  5.7532693e+003
-  5.5580964e+003
-  4.5027769e+003
-  2.1999071e+003
-  4.4327089e+003
-  5.1465416e+003
-  5.2304857e+003
-  5.3689367e+003
-  5.8632625e+003
-  6.3480527e+003
-  6.5561440e+003
-  4.5541650e+003
-  6.1566234e+003
-  8.2088203e+003
-  9.0900066e+003
-  8.1685436e+003
-  8.5454832e+003
-  7.8245753e+003
-  8.3920945e+003
-  8.6716270e+003
-  8.1360994e+003
-  7.4933140e+003
-  8.0284841e+003
-  1.0812000e+004
-  9.3677352e+003
-  8.6221530e+003
-  9.4356538e+003
-  1.0018119e+004
-  1.1037641e+004
-  1.1755321e+004
-  1.1791536e+004
-  1.1849172e+004
-  1.2442525e+004
-  1.0985696e+004
-  9.6724684e+003
-  7.9805620e+003
-  8.5344147e+003
-  9.2306408e+003
-  1.0019384e+004
-  9.8203235e+003
-  9.8452106e+003
-  9.6707453e+003
-  9.1928141e+003
-  8.5436622e+003
-  8.6397967e+003
-  8.4160791e+003
-  6.2885912e+003
-  8.5566525e+003
-  8.7598886e+003
-  9.2746980e+003
-  8.5801115e+003
-  9.0054750e+003
-  1.0192231e+004
-  1.1036706e+004
-  1.0721682e+004
-  1.1205569e+004
-  1.1174279e+004
-  1.0908404e+004
-  1.0499884e+004
-  9.3894396e+003
-  1.0080836e+004
-  8.6986021e+003
-  7.1700107e+003
-  6.2546192e+003
-  5.4877778e+003
-  5.7101842e+003
-  5.8420469e+003
-  6.5916981e+003
-  7.1928085e+003
-  7.7545833e+003
-  7.8107923e+003
-  6.1881292e+003
-  6.2236700e+003
-  6.9613381e+003
-  9.1102774e+003
-  1.0215285e+004
-  1.1015769e+004
-  1.1340707e+004
-  1.0581202e+004
-  1.0141809e+004
-  1.0292459e+004
-  9.9494756e+003
-  9.1300539e+003
-  6.7316930e+003
-  6.7469802e+003
-  6.3323985e+003
-  7.0103758e+003
-  6.8523683e+003
-  6.8727941e+003
-  7.2459330e+003
-  6.7233994e+003
-  6.1920621e+003
-  6.1866381e+003
-  6.3122711e+003
-  6.7220368e+003
-  3.2082342e+003
-  2.2880789e+003
-  2.6630021e+003
-  0.0000000e+000
-  1.5670377e+003
-  5.8932968e+003
-  7.3475465e+003
-  7.6742968e+003
-  8.1732699e+003
-  8.4452682e+003
-  8.5323467e+003
-  8.4917884e+003
-  7.1823961e+003
-  7.5608578e+003
-  8.7644028e+003
-  9.6566351e+003
-  9.1752699e+003
-  9.2910945e+003
-  8.7737259e+003
-  8.6738995e+003
-  8.3935537e+003
-  8.1964652e+003
-  8.7631510e+003
-  8.3801290e+003
-  9.4438511e+003
-  8.0818650e+003
-  6.6076349e+003
-  8.2119992e+003
-  9.5355494e+003
-  9.7703666e+003
-  9.6181619e+003
-  9.9868457e+003
-  9.7474863e+003
-  9.2769174e+003
-  9.4036885e+003
-  9.6872708e+003
-  7.7019979e+003
-  8.0180679e+003
-  7.4097706e+003
-  7.8521285e+003
-  7.8862599e+003
-  6.9756760e+003
-  7.0458814e+003
-  7.0818630e+003
-  7.0469740e+003
-  7.3942750e+003
-  7.6212107e+003
-  8.0331130e+003
-  5.8774297e+003
-  6.7858793e+003
-  5.0526846e+003
-  6.3296262e+003
-  6.6286394e+003
-  5.7507044e+003
-  4.8187842e+003
-  5.6265098e+003
-  6.1350865e+003
-  6.3377813e+003
-  5.3438440e+003
-  5.0777790e+003
-  5.7758229e+003
-  7.1658929e+003
-  6.8816661e+003
-  6.7885425e+003
-  6.2921146e+003
-  6.5498023e+003
-  6.6064213e+003
-  6.2183867e+003
-  5.0498603e+003
-  4.6634948e+003
-  4.5687261e+003
-  4.3857684e+003
-  5.0285132e+003
-  2.1155539e+003
-  0.0000000e+000
-  2.7416907e+002
-  0.0000000e+000
-  0.0000000e+000
-  4.9088419e+002
-  1.7638303e+003
-  3.8605084e+003
-  8.2135056e+003
-  8.7801030e+003
-  5.9497100e+003
-  4.0424478e+003
-  5.7662183e+003
-  4.8092876e+003
-  6.0083239e+003
-  6.8251731e+003
-  5.9522311e+003
-  8.2892291e+003
-  9.1881319e+003
-  9.7250825e+003
-  8.8972293e+003
-  9.0742703e+003
-  9.1758180e+003
-  9.0004363e+003
-  9.4690063e+003
-  9.6097636e+003
-  9.9118848e+003
-  1.0552070e+004
-  1.0937108e+004
-  1.1796701e+004
-  1.2074522e+004
-  1.2548494e+004
-  1.2534556e+004
-  1.1906156e+004
-  1.0657603e+004
-  9.9997481e+003
-  9.8693954e+003
-  9.3460985e+003
-  7.6985595e+003
-  6.1220872e+003
-  5.3906247e+003
-  5.2934532e+003
-  5.3205076e+003
-  6.2453775e+003
-  7.3703333e+003
-  6.9521713e+003
-  1.1312021e+004
-  6.9335426e+003
-  9.6296636e+003
-  1.3122951e+004
-  1.4613797e+004
-  1.4656108e+004
-  1.4862599e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.2926132e+004
-  1.4332965e+004
-  1.4697240e+004
-  1.4862313e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4990098e+004
-  1.4940247e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4060591e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4751323e+004
-  1.1684594e+004
-  9.1645237e+003
-  7.2940883e+003
-  6.1109924e+003
-  6.0846096e+003
-  6.6383473e+003
-  7.2848805e+003
-  8.3240326e+003
-  7.6836168e+003
-  7.3149665e+003
-  7.3222876e+003
-  8.3529365e+003
-  8.8919206e+003
-  8.5622460e+003
-  8.5157977e+003
-  1.0213160e+004
-  1.1473742e+004
-  1.1416144e+004
-  1.0262146e+004
-  9.8474701e+003
-  9.6073067e+003
-  9.3334956e+003
-  8.1114094e+003
-  6.3438393e+003
-  4.0561582e+002
-  4.9338711e+003
-  7.6173277e+003
-  8.1979965e+003
-  9.6515621e+003
-  9.9401838e+003
-  1.0555439e+004
-  1.1204735e+004
-  1.2438476e+004
-  1.2991111e+004
-  1.3726179e+004
-  1.3853785e+004
-  1.3384780e+004
-  1.4689700e+004
-  1.4351914e+004
-  1.4352144e+004
-  1.3893380e+004
-  1.3939271e+004
-  1.4075510e+004
-  1.4510647e+004
-  1.4691427e+004
-  1.4697897e+004
-  1.4591968e+004
-  1.4143373e+004
-  1.1993411e+004
-  1.4062098e+004
-  1.4355202e+004
-  1.4496242e+004
-  1.4251580e+004
-  1.3691010e+004
-  1.3787219e+004
-  1.3348001e+004
-  1.2868016e+004
-  1.2121213e+004
-  1.1597200e+004
-  1.1197107e+004
-  1.0874213e+004
-  1.0800695e+004
-  8.6047889e+003
-  8.7931705e+003
-  1.0162987e+004
-  1.1157604e+004
-  1.2127598e+004
-  1.3331766e+004
-  1.4088376e+004
-  1.4241923e+004
-  1.4298649e+004
-  1.3983031e+004
-  1.2426142e+004
-  1.2821723e+004
-  1.0648820e+004
-  1.0788457e+004
-  1.1565678e+004
-  1.0675574e+004
-  1.0052872e+004
-  1.0062980e+004
-  9.9391197e+003
-  1.1037139e+004
-  1.0427495e+004
-  9.3659423e+003
-  9.8900697e+003
-  1.0357397e+004
-  1.0785399e+004
-  1.0799019e+004
-  1.1000265e+004
-  1.0543268e+004
-  1.0143810e+004
-  9.7901431e+003
-  9.0954554e+003
-  8.6694209e+003
-  9.7264622e+003
-  1.0464018e+004
-  8.4039424e+003
-  9.2706552e+003
-  9.8937533e+003
-  9.7688013e+003
-  1.0387232e+004
-  1.0884452e+004
-  1.2140833e+004
-  1.1592473e+004
-  1.0549975e+004
-  1.1517130e+004
-  1.0276514e+004
-  9.4995134e+003
-  1.1074524e+004
-  1.0266440e+004
-  1.0003780e+004
-  9.4539517e+003
-  1.0130070e+004
-  9.1334953e+003
-  9.4781231e+003
-  8.7930478e+003
-  1.1818054e+004
-  1.4232598e+004
-  1.4272504e+004
-  1.4130687e+004
-  1.0264280e+004
-  1.2858109e+004
-  1.4357514e+004
-  1.5000000e+004
-  1.4880674e+004
-  1.4071591e+004
-  1.0816174e+004
-  1.3903217e+004
-  7.6465652e+003
-  7.2759868e+003
-  1.1878430e+004
-  7.9363899e+003
-  1.0012931e+004
-  8.3717781e+003
-  9.8052206e+003
-  1.0887308e+004
-  1.0384128e+004
-  9.0317571e+003
-  9.0035754e+003
-  9.3831353e+003
-  9.5517033e+003
-  9.9428520e+003
-  9.9763147e+003
-  1.0281617e+004
-  7.1627889e+003
-  8.4401671e+003
-  1.0010852e+004
-  1.0799497e+004
-  1.0757979e+004
-  1.0022172e+004
-  9.2195862e+003
-  8.9633090e+003
-  9.0556752e+003
-  8.7844813e+003
-  8.2308721e+003
-  8.3282462e+003
-  8.9225324e+003
-  8.3367010e+003
-  1.0200315e+004
-  9.5009000e+003
-  8.2646443e+003
-  8.0715231e+003
-  6.5503256e+003
-  7.2821816e+003
-  7.4417689e+003
-  7.3749177e+003
-  8.0189642e+003
-  8.0100006e+003
-  8.5355483e+003
-  8.4134563e+003
-  8.8888674e+003
-  9.7086060e+003
-  1.0389594e+004
-  1.0714743e+004
-  9.5721915e+003
-  7.9565683e+003
-  9.0114754e+003
-  9.4010374e+003
-  9.1089941e+003
-  8.4832686e+003
-  1.0275837e+004
-  8.4921531e+003
-  8.6300718e+003
-  7.9358269e+003
-  9.8119300e+003
-  1.1489482e+004
-  1.1847258e+004
-  1.2046636e+004
-  1.1030807e+004
-  1.1506255e+004
-  1.1150376e+004
-  1.2732117e+004
-  1.2249684e+004
-  1.3175625e+004
-  1.1492777e+004
-  1.2040457e+004
-  1.3115363e+004
-  1.3116650e+004
-  1.0825734e+004
-  1.0265123e+004
-  1.0946416e+004
-  9.9381093e+003
-  6.8152515e+003
-  5.7137921e+003
-  5.9031640e+003
-  5.3094664e+003
-  5.2097611e+003
-  5.3048974e+003
-  5.2859667e+003
-  5.2217390e+003
-  5.7591864e+003
-  7.5012790e+003
-  9.4523013e+003
-  1.0614623e+004
-  1.1955298e+004
-  1.2006303e+004
-  1.1038886e+004
-  1.1795523e+004
-  1.2380650e+004
-  1.3152396e+004
-  1.3418746e+004
-  1.3160889e+004
-  1.2299129e+004
-  1.2013338e+004
-  1.1741069e+004
-  1.1893269e+004
-  1.1584606e+004
-  1.1147106e+004
-  1.0761704e+004
-  1.2353932e+004
-  1.2179779e+004
-  1.2336318e+004
-  1.1347633e+004
-  1.1096587e+004
-  1.0899695e+004
-  1.1064539e+004
-  1.0730557e+004
-  1.0857225e+004
-  1.1160569e+004
-  1.0652600e+004
-  9.4004273e+003
-  8.3736762e+003
-  7.6853930e+003
-  7.1318434e+003
-  8.4332247e+003
-  8.4782871e+003
-  8.5971295e+003
-  8.6871340e+003
-  8.4365704e+003
-  8.5786831e+003
-  8.6365783e+003
-  8.5494723e+003
-  1.0489354e+004
-  7.6192296e+003
-  7.9697233e+003
-  9.5136252e+003
-  1.0947586e+004
-  1.1125370e+004
-  1.0969058e+004
-  1.1619407e+004
-  1.1480734e+004
-  1.1331045e+004
-  1.1085992e+004
-  1.0504574e+004
-  8.2885307e+003
-  7.1116444e+003
-  5.3099486e+003
-  5.4104594e+003
-  7.1939045e+003
-  7.8115645e+003
-  8.0941088e+003
-  8.5691029e+003
-  8.5428885e+003
-  8.2565212e+003
-  7.6313954e+003
-  7.4785229e+003
-  6.4507925e+003
-  7.3010808e+003
-  5.7756984e+003
-  7.4007447e+003
-  8.3370762e+003
-  9.3143142e+003
-  9.3536507e+003
-  9.4141175e+003
-  9.2036282e+003
-  8.8145538e+003
-  8.9239289e+003
-  9.3804717e+003
-  6.2709081e+003
-  6.1114121e+003
-  6.2738219e+003
-  5.6129922e+003
-  4.7757788e+003
-  4.3727289e+003
-  5.1782805e+003
-  5.4239609e+003
-  5.5214974e+003
-  4.8746007e+003
-  5.0404383e+003
-  5.5573708e+003
-  5.4923791e+003
-  4.9899502e+003
-  2.2982894e+003
-  4.2297189e+003
-  5.4411159e+003
-  6.2842951e+003
-  6.7031059e+003
-  8.1185574e+003
-  8.4948276e+003
-  8.1088164e+003
-  7.6992566e+003
-  7.5837450e+003
-  7.5886235e+003
-  7.7050497e+003
-  8.3973342e+003
-  8.9813138e+003
-  8.3544307e+003
-  8.1024005e+003
-  8.3723648e+003
-  8.9836052e+003
-  8.7945796e+003
-  8.7470606e+003
-  9.1922825e+003
-  9.5241727e+003
-  9.1467564e+003
-  9.6344040e+003
-  9.9588518e+003
-  1.0519693e+004
-  1.1436568e+004
-  1.1880399e+004
-  1.2471748e+004
-  1.3461235e+004
-  1.4294578e+004
-  1.4343208e+004
-  1.2798949e+004
-  1.2732037e+004
-  1.0217775e+004
-  1.0970581e+004
-  1.0073755e+004
-  1.1582556e+004
-  1.2277242e+004
-  1.2719678e+004
-  1.2128965e+004
-  1.2331973e+004
-  1.1861323e+004
-  1.0967865e+004
-  1.0032578e+004
-  9.7760533e+003
-  8.1447286e+003
-  8.9166745e+003
-  1.0109226e+004
-  1.1228582e+004
-  1.1381985e+004
-  1.1970990e+004
-  1.2398492e+004
-  1.3443496e+004
-  1.4066596e+004
-  1.2492656e+004
-  1.1226688e+004
-  1.2020566e+004
-  8.2054384e+003
-  6.9616154e+003
-  5.7974308e+003
-  6.4327344e+003
-  6.7351741e+003
-  6.5627760e+003
-  8.1136570e+003
-  9.4613752e+003
-  8.5925193e+003
-  7.2255361e+003
-  7.9589936e+003
-  8.5371920e+003
-  7.3700956e+003
-  5.8595577e+003
-  6.8845730e+003
-  6.7791940e+003
-  8.2558450e+003
-  1.1292907e+004
-  1.1580723e+004
-  1.0303704e+004
-  1.0512163e+004
-  1.0907818e+004
-  1.1204047e+004
-  1.0924884e+004
-  7.5308779e+003
-  8.2331017e+003
-  9.1181047e+003
-  9.3105271e+003
-  8.5745396e+003
-  7.6183117e+003
-  5.8037402e+003
-  4.9676050e+003
-  5.6976352e+003
-  6.1163937e+003
-  6.3299585e+003
-  6.6673479e+003
-  3.7720009e+003
-  1.2907931e+003
-  3.8050762e+003
-  3.5581705e+003
-  4.2191732e+003
-  3.0935467e+003
-  7.8517051e+002
-  4.5230470e+002
-  0.0000000e+000
-  1.6051884e+002
-  7.7393419e+003
-  7.9471793e+003
-  3.4814704e+003
-  6.9684122e+003
-  8.1945817e+003
-  7.9942471e+003
-  9.5009542e+003
-  9.9566565e+003
-  1.4230842e+004
-  1.3027073e+004
-  1.4054149e+004
-  1.4219180e+004
-  1.4109562e+004
-  1.4099178e+004
-  1.1406177e+004
-  1.4182420e+004
-  1.3930990e+004
-  1.4016152e+004
-  1.3402675e+004
-  1.2406548e+004
-  1.2344375e+004
-  1.2679775e+004
-  1.3540816e+004
-  1.3766233e+004
-  1.3628327e+004
-  1.2999719e+004
-  9.4274555e+003
-  8.7006771e+003
-  6.9992221e+003
-  5.3572917e+003
-  4.5776297e+003
-  3.0814996e+003
-  4.9574130e+003
-  6.1368574e+003
-  6.9490544e+003
-  7.2498410e+003
-  6.6022853e+003
-  6.0844322e+003
-  6.9187796e+003
-  8.2769576e+003
-  1.0125024e+004
-  1.0262458e+004
-  9.8215287e+003
-  1.0097065e+004
-  9.7316288e+003
-  9.0815458e+003
-  8.3111465e+003
-  7.7877204e+003
-  7.7417598e+003
-  7.1922222e+003
-  5.9405829e+003
-  6.0208822e+003
-  5.2262047e+003
-  5.5931817e+003
-  5.5231809e+003
-  5.7824516e+003
-  6.1202902e+003
-  6.0829500e+003
-  5.3967209e+003
-  4.7342316e+003
-  3.4466146e+003
-  2.6059355e+003
-  1.5067015e+003
-  0.0000000e+000
-  2.2589853e+003
-  3.8027231e+003
-  3.8883399e+003
-  3.2429762e+003
-  2.1907548e+003
-  2.4572208e+003
-  4.2492064e+003
-  4.8484941e+003
-  5.6113452e+003
-  6.0872126e+003
-  5.8661149e+003
-  5.9887086e+003
-  7.2430355e+003
-  7.4775572e+003
-  7.6548130e+003
-  8.5438716e+003
-  9.0262212e+003
-  8.7213279e+003
-  8.7849481e+003
-  9.2445689e+003
-  1.0463584e+004
-  1.0851014e+004
-  1.1244613e+004
-  9.9222886e+003
-  1.1400914e+004
-  1.2771548e+004
-  1.4351597e+004
-  1.4669362e+004
-  1.4750682e+004
-  1.4907726e+004
-  1.4903037e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  9.6945335e+003
-  1.4235141e+004
-  1.4558910e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4998788e+004
-  1.4838116e+004
-  1.4780061e+004
-  1.4551851e+004
-  1.3909302e+004
-  1.3598276e+004
-  1.4487232e+004
-  8.7927681e+003
-  1.0226854e+004
-  1.0384457e+004
-  9.6039296e+003
-  8.1925527e+003
-  5.2707829e+003
-  4.4195401e+003
-  2.9587139e+003
-  0.0000000e+000
-  1.2717178e+003
-  5.3838182e+003
-  6.1523695e+003
-  1.0218047e+004
-  1.2344060e+004
-  1.4307026e+004
-  1.4693372e+004
-  1.4538001e+004
-  1.4256473e+004
-  1.3881682e+004
-  1.4549841e+004
-  1.4747555e+004
-  1.4969578e+004
-  1.5000000e+004
-  1.4623904e+004
-  1.0738703e+004
-  1.1906195e+004
-  1.3115463e+004
-  1.0614817e+004
-  7.2261616e+003
-  7.3784938e+003
-  8.4224594e+003
-  9.9926385e+003
-  9.7966311e+003
-  9.2890147e+003
-  8.2290849e+003
-  7.5383569e+003
-  2.2519468e+003
-  2.4927724e+003
-  5.6970359e+003
-  7.4595587e+003
-  8.1395470e+003
-  8.7517767e+003
-  9.0394558e+003
-  8.5998846e+003
-  9.6424600e+003
-  8.8426168e+003
-  8.8433162e+003
-  9.6074805e+003
-  1.2378596e+004
-  1.1291806e+004
-  1.2874125e+004
-  1.1967205e+004
-  9.8177551e+003
-  1.0863792e+004
-  9.8493212e+003
-  9.4457432e+003
-  9.6908406e+003
-  9.7060549e+003
-  7.1828683e+003
-  7.4402109e+003
-  4.9753699e+003
-  7.0477806e+003
-  7.2878056e+003
-  7.0312899e+003
-  1.4422677e+004
-  1.4862382e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4664915e+004
-  1.4860431e+004
-  1.5000000e+004
-  1.3167820e+004
-  1.4553562e+004
-  1.4424759e+004
-  1.4369247e+004
-  1.4510113e+004
-  1.4715426e+004
-  1.4821807e+004
-  1.4779634e+004
-  1.4773623e+004
-  1.4665011e+004
-  1.4497329e+004
-  1.4228307e+004
-  1.0349298e+004
-  1.0231707e+004
-  9.0755604e+003
-  6.9963721e+003
-  5.4214200e+003
-  5.1842575e+003
-  5.5043389e+003
-  6.0176365e+003
-  6.0730345e+003
-  5.9990182e+003
-  6.3205371e+003
-  6.6522761e+003
-  5.7592750e+003
-  3.9618116e+003
-  4.7188334e+003
-  3.8302327e+003
-  4.8734338e+003
-  5.1174204e+003
-  4.2626353e+003
-  3.9377523e+003
-  2.6386477e+003
-  3.0096234e+003
-  4.8132301e+003
-  6.0570486e+003
-  6.4175356e+003
-  7.5031616e+003
-  7.2262474e+003
-  7.6295466e+003
-  7.4976582e+003
-  6.9635814e+003
-  7.9384315e+003
-  8.8953825e+003
-  9.5185395e+003
-  1.0330471e+004
-  1.1349655e+004
-  1.2470088e+004
-  1.3779902e+004
-  1.4065696e+004
-  1.4388848e+004
-  1.4601822e+004
-  1.4622679e+004
-  1.4579627e+004
-  1.4419865e+004
-  1.4297374e+004
-  1.4191509e+004
-  1.4050337e+004
-  1.4047227e+004
-  1.3268590e+004
-  1.0842803e+004
-  1.0856715e+004
-  1.0763559e+004
-  1.1008671e+004
-  1.0584061e+004
-  1.0834087e+004
-  1.0659918e+004
-  1.0818468e+004
-  1.0845614e+004
-  1.0985154e+004
-  1.1090202e+004
-  1.0924856e+004
-  9.6969443e+003
-  7.9065884e+003
-  8.1800297e+003
-  8.3632823e+003
-  9.0186720e+003
-  9.8467959e+003
-  1.1016602e+004
-  1.2789440e+004
-  1.3928034e+004
-  1.4321691e+004
-  1.4499065e+004
-  1.4191363e+004
-  1.3850833e+004
-  1.4453261e+004
-  1.4702270e+004
-  1.4574877e+004
-  1.4401424e+004
-  1.4472576e+004
-  1.4527548e+004
-  1.4498455e+004
-  1.4551654e+004
-  1.4663920e+004
-  1.4462211e+004
-  1.4366495e+004
-  1.4205637e+004
-  1.4045071e+004
-  1.3780095e+004
-  1.4468147e+004
-  1.4584918e+004
-  1.4839587e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4103580e+004
-  1.4780416e+004
-  1.4511864e+004
-  1.4251713e+004
-  1.4010091e+004
-  1.3771909e+004
-  1.3718037e+004
-  1.2941120e+004
-  1.2348602e+004
-  1.1332261e+004
-  1.0755099e+004
-  9.9317289e+003
-  8.4146989e+003
-  7.3312072e+003
-  8.5987428e+003
-  1.0575563e+004
-  9.7730287e+003
-  9.8465886e+003
-  9.9801805e+003
-  1.0713912e+004
-  1.2316672e+004
-  1.1628361e+004
-  1.0222359e+004
-  1.1185287e+004
-  7.1952274e+003
-  8.1462252e+003
-  7.1832873e+003
-  6.5941512e+003
-  5.7905771e+003
-  6.3441888e+003
-  6.9921466e+003
-  7.4044132e+003
-  7.5974582e+003
-  8.4721387e+003
-  9.1518057e+003
-  9.7677916e+003
-  9.1428252e+003
-  7.1795296e+003
-  9.2744816e+003
-  8.3609313e+003
-  8.0079662e+003
-  7.6190240e+003
-  7.4483544e+003
-  7.3982961e+003
-  7.6194396e+003
-  6.9536670e+003
-  4.9022526e+003
-  5.6161008e+003
-  5.0917111e+003
-  5.1245516e+003
-  5.4174584e+003
-  5.6520863e+003
-  5.9454104e+003
-  6.0045630e+003
-  5.9210494e+003
-  5.2389732e+003
-  3.8591481e+003
-  1.4467601e+003
-  3.0417928e+003
-  2.9433412e+003
-  6.4794727e+003
-  7.6529045e+003
-  8.1381275e+003
-  5.0191317e+003
-  4.8657277e+003
-  2.9020809e+003
-  4.3824444e+003
-  5.0371205e+003
-  2.1037217e+003
-  3.3177935e+003
-  4.6513657e+003
-  5.2011133e+003
-  5.9202731e+003
-  6.6907524e+003
-  5.5995211e+003
-  5.3336612e+003
-  5.9147189e+003
-  7.5846374e+003
-  8.4814278e+003
-  8.5951282e+003
-  8.4993330e+003
-  8.3402980e+003
-  7.2545869e+003
-  5.3112997e+003
-  6.4486672e+003
-  4.7763944e+003
-  6.1593969e+003
-  6.8076768e+003
-  6.5509355e+003
-  6.0067295e+003
-  6.2819191e+003
-  5.7548141e+003
-  5.2695458e+003
-  5.2348433e+003
-  5.0356579e+003
-  5.2923127e+003
-  3.1332352e+003
-  6.1057148e+003
-  6.4533302e+003
-  8.0497698e+003
-  7.9455172e+003
-  8.2137588e+003
-  8.3572595e+003
-  8.5122692e+003
-  9.1443293e+003
-  9.3060565e+003
-  9.8158368e+003
-  1.0478419e+004
-  1.1646779e+004
-  9.2837239e+003
-  1.0183691e+004
-  1.0957920e+004
-  1.1322106e+004
-  1.1273801e+004
-  1.1588634e+004
-  1.1234634e+004
-  1.1145033e+004
-  1.1251659e+004
-  1.1084729e+004
-  1.0745217e+004
-  1.0080793e+004
-  1.1191130e+004
-  1.0367737e+004
-  9.5894096e+003
-  1.0238764e+004
-  1.0304305e+004
-  9.9091002e+003
-  1.0046645e+004
-  8.5734719e+003
-  8.7977642e+003
-  8.1851105e+003
-  5.2578662e+003
-  6.6571882e+003
-  6.0686277e+003
-  6.3070662e+003
-  6.1018019e+003
-  6.7428190e+003
-  6.7637043e+003
-  6.5940733e+003
-  6.4179907e+003
-  5.7490083e+003
-  5.9589102e+003
-  6.8095689e+003
-  7.2564983e+003
-  4.6593157e+003
-  7.2394601e+003
-  7.8106759e+003
-  8.1899386e+003
-  8.5651090e+003
-  8.5033792e+003
-  8.2711352e+003
-  7.3121470e+003
-  6.8207499e+003
-  7.3849363e+003
-  8.4384262e+003
-  1.0405006e+004
-  7.5278498e+003
-  8.8948559e+003
-  8.6513568e+003
-  9.4766073e+003
-  1.0265654e+004
-  1.1138318e+004
-  1.0004118e+004
-  1.0014276e+004
-  9.6773035e+003
-  9.2577794e+003
-  9.6536494e+003
-  8.9305790e+003
-  6.3995071e+003
-  7.8741632e+003
-  8.2033798e+003
-  6.7964818e+003
-  7.1534205e+003
-  7.4988049e+003
-  7.8277198e+003
-  7.5563407e+003
-  7.4225807e+003
-  8.6526650e+003
-  7.4091893e+003
-  6.7803344e+003
-  6.0273998e+003
-  8.8065513e+003
-  9.4010440e+003
-  9.4169298e+003
-  8.7370657e+003
-  9.2979916e+003
-  9.4322621e+003
-  8.5011357e+003
-  8.0025332e+003
-  8.5687934e+003
-  9.4051043e+003
-  9.5558041e+003
-  6.6547020e+003
-  4.6573601e+003
-  2.5193775e+003
-  2.7473859e+003
-  4.0446006e+003
-  5.4193625e+003
-  7.0747943e+003
-  8.0697881e+003
-  7.9641116e+003
-  8.5241692e+003
-  8.7522679e+003
-  9.5272462e+003
-  9.9581737e+003
-  8.2782298e+003
-  9.0375052e+003
-  1.0328521e+004
-  1.0773521e+004
-  1.0865363e+004
-  1.0751728e+004
-  1.0122695e+004
-  9.0702557e+003
-  8.3015051e+003
-  7.5808901e+003
-  6.1856114e+003
-  5.1589270e+003
-  2.8245546e+003
-  0.0000000e+000
-  3.8834380e+003
-  7.7036154e+003
-  9.1131257e+003
-  1.0157199e+004
-  1.0459716e+004
-  9.9694679e+003
-  9.9187957e+003
-  9.0103822e+003
-  9.6560498e+003
-  8.8128617e+003
-  5.4104040e+003
-  8.1617268e+003
-  1.1239039e+004
-  1.3006974e+004
-  1.2982015e+004
-  1.2787861e+004
-  1.3251519e+004
-  1.3642529e+004
-  1.3484369e+004
-  1.3334273e+004
-  1.3469060e+004
-  1.1373561e+004
-  1.1458739e+004
-  9.9091026e+003
-  7.9893865e+003
-  7.0067381e+003
-  6.4598191e+003
-  6.6988439e+003
-  6.1887904e+003
-  5.7090384e+003
-  4.3731349e+003
-  2.3750084e+003
-  3.0234599e+003
-  1.1766045e+003
-  3.5745828e+003
-  6.2534313e+003
-  7.3481995e+003
-  6.6570226e+003
-  7.3509847e+003
-  9.1271248e+003
-  1.0324436e+004
-  1.2345007e+004
-  1.3442423e+004
-  1.4155620e+004
-  1.3754551e+004
-  1.0406521e+004
-  1.2816353e+004
-  1.2599886e+004
-  1.2021014e+004
-  1.0130577e+004
-  9.7117472e+003
-  8.7699330e+003
-  7.8535861e+003
-  7.7425062e+003
-  7.0244407e+003
-  5.6131164e+003
-  7.2183845e+003
-  7.7125816e+003
-  1.0143119e+004
-  1.2252463e+004
-  1.2125642e+004
-  1.0142400e+004
-  9.1455574e+003
-  7.7235463e+003
-  7.2803145e+003
-  7.1167510e+003
-  7.8016304e+003
-  8.4389021e+003
-  8.5366661e+003
-  7.5667628e+003
-  9.0872544e+003
-  6.8845001e+003
-  6.1899389e+003
-  6.7479612e+003
-  7.6967947e+003
-  7.3090887e+003
-  7.1469689e+003
-  8.3283654e+003
-  7.3473692e+003
-  7.0048256e+003
-  7.0912599e+003
-  1.9713676e+003
-  2.3842790e+003
-  1.5824960e+003
-  0.0000000e+000
-  6.4342466e+002
-  4.8269062e+003
-  5.8250748e+003
-  6.8101249e+003
-  7.1916506e+003
-  8.1950589e+003
-  9.0687165e+003
-  9.9904914e+003
-  5.4050319e+003
-  5.8251943e+003
-  8.4884213e+003
-  1.1620470e+004
-  1.3012971e+004
-  1.3447326e+004
-  1.2912711e+004
-  1.2250688e+004
-  1.1236535e+004
-  9.8294648e+003
-  9.4850794e+003
-  8.1851149e+003
-  7.3622724e+003
-  6.4167929e+003
-  7.8333624e+003
-  6.8216244e+003
-  5.8865947e+003
-  5.8376621e+003
-  6.4972995e+003
-  6.1574145e+003
-  6.4825886e+003
-  6.8777054e+003
-  6.5615306e+003
-  6.1711141e+003
-  4.7640420e+003
-  5.1067154e+003
-  4.7805015e+003
-  4.3092449e+003
-  5.5870241e+003
-  5.8390378e+003
-  7.2819950e+003
-  7.2913504e+003
-  7.2789419e+003
-  7.2806319e+003
-  6.9130886e+003
-  7.6665121e+003
-  5.4523266e+003
-  2.8719313e+003
-  4.5680029e+003
-  3.1745745e+003
-  3.9838718e+003
-  3.9009663e+003
-  4.2923389e+003
-  4.5294279e+003
-  3.8545680e+003
-  2.5409848e+003
-  2.8636222e+003
-  3.6677657e+003
-  5.7449924e+003
-  6.9465220e+003
-  6.1407558e+003
-  7.1463738e+003
-  7.1974219e+003
-  6.7406301e+003
-  6.4771015e+003
-  7.0134470e+003
-  6.2257799e+003
-  6.7958021e+003
-  6.0997263e+003
-  6.0029926e+003
-  7.7918150e+003
-  6.0998418e+003
-  8.2846717e+003
-  1.0162078e+004
-  1.0335985e+004
-  1.0398186e+004
-  1.0994938e+004
-  1.0746735e+004
-  1.0954441e+004
-  1.0907056e+004
-  1.1026725e+004
-  1.0564338e+004
-  8.8677528e+003
-  9.9587755e+003
-  9.7356965e+003
-  1.0051236e+004
-  1.0629361e+004
-  1.0720792e+004
-  1.0221790e+004
-  9.2497245e+003
-  8.4315678e+003
-  9.2424888e+003
-  9.1586627e+003
-  9.3637077e+003
-  6.5017165e+003
-  7.2404906e+003
-  6.5052638e+003
-  9.9293934e+003
-  1.2565271e+004
-  1.2901982e+004
-  1.3041471e+004
-  1.2996395e+004
-  1.0961241e+004
-  1.1649050e+004
-  1.2537911e+004
-  1.2072589e+004
-  1.4410087e+003
-  2.0367254e+003
-  6.3571656e+003
-  7.8128982e+003
-  8.1644409e+003
-  7.9625535e+003
-  8.1115099e+003
-  7.2439469e+003
-  7.3689942e+003
-  6.9361593e+003
-  7.2144664e+003
-  8.5767925e+003
-  5.2476323e+003
-  4.4913888e+003
-  6.4680599e+003
-  6.8294158e+003
-  7.4294059e+003
-  7.8053774e+003
-  8.7951187e+003
-  9.4409060e+003
-  1.0153159e+004
-  9.5702221e+003
-  1.4026322e+004
-  1.4156905e+004
-  8.8657290e+003
-  1.0246489e+004
-  1.2590538e+004
-  1.4422736e+004
-  1.2713618e+004
-  1.3046080e+004
-  1.3301771e+004
-  1.2647591e+004
-  1.2796771e+004
-  1.3716864e+004
-  1.2726277e+004
-  1.0539755e+004
-  5.7693609e+003
-  8.5675077e+003
-  1.1349817e+004
-  1.0410482e+004
-  1.0099439e+004
-  1.1517140e+004
-  1.2124079e+004
-  1.3122642e+004
-  1.2324279e+004
-  1.2158293e+004
-  1.2205180e+004
-  1.1892311e+004
-  8.9143136e+003
-  9.7568659e+003
-  8.1227673e+003
-  6.3500495e+003
-  5.4058499e+003
-  4.5472374e+003
-  6.0866360e+003
-  5.5470453e+003
-  1.6602197e+002
-  1.8578068e+003
-  3.7883452e+003
-  3.3225216e+003
-  1.9742115e+003
-  5.1385953e+002
-  3.9077731e+003
-  1.8933235e+003
-  2.2054272e+003
-  6.3156260e+003
-  4.1913372e+003
-  6.9488198e+003
-  7.7643293e+003
-  1.0266475e+004
-  6.9127114e+003
-  5.2511505e+003
-  5.8870647e+001
-  1.0240969e+003
-  2.6163590e+003
-  5.1724745e+003
-  5.5372000e+003
-  5.2604604e+003
-  5.2838191e+003
-  5.6754571e+003
-  5.8584137e+003
-  5.2987272e+003
-  4.5076933e+003
-  3.8788050e+003
-  3.4151248e+003
-  3.5225775e+003
-  2.8733259e+003
-  1.8093918e+003
-  0.0000000e+000
-  1.0795535e+003
-  2.7754500e+002
-  0.0000000e+000
-  9.0553162e+002
-  0.0000000e+000
-  2.7707268e+003
-  5.1900788e+003
-  5.7874955e+003
-  6.5378102e+003
-  7.2404172e+003
-  6.9584685e+003
-  7.6042900e+003
-  7.2979851e+003
-  6.6436143e+003
-  6.5802680e+003
-  7.2929043e+003
-  7.1330503e+003
-  7.5207578e+003
-  7.7095669e+003
-  6.0941090e+003
-  6.1375898e+003
-  6.7324730e+003
-  6.3539827e+003
-  6.7199163e+003
-  7.3856206e+003
-  6.9099188e+003
-  6.2791681e+003
-  5.7336970e+003
-  6.1250121e+003
-  4.9989824e+003
-  3.7517717e+003
-  2.0270446e+003
-  4.1754971e+003
-  3.3284127e+003
-  1.7522747e+003
-  2.9663492e+003
-  2.2665690e+003
-  2.1946821e+003
-  4.7015155e+003
-  4.7593250e+003
-  5.1262892e+003
-  5.2956802e+003
-  4.0256523e+003
-  6.9406231e+002
-  0.0000000e+000
-  1.3529806e+003
-  4.8545542e+001
-  0.0000000e+000
-  0.0000000e+000
-  0.0000000e+000
-  0.0000000e+000
-  1.9105744e+003
-  5.7566395e+003
-  6.7927206e+003
-  4.4084449e+003
-  9.0032342e+003
-  9.2858955e+003
-  7.9040366e+003
-  6.6612651e+003
-  3.4000540e+003
-  5.1593503e+003
-  5.2678603e+003
-  5.5953629e+003
-  6.7201199e+003
-  5.9258621e+003
-  5.5936188e+003
-  5.1160557e+003
-  3.6117174e+003
-  1.6301069e+003
-  1.8176182e+003
-  2.6925144e+003
-  3.6755757e+003
-  2.9776107e+003
-  1.4714214e+003
-  7.1961512e+002
-  6.4631935e+002
-  1.3784135e+003
-  9.0936796e+002
-  0.0000000e+000
-  3.7065335e+003
-  5.4657806e+003
-  5.0072228e+003
-  5.8812034e+003
-  6.3856518e+003
-  5.4793683e+003
-  5.9842340e+003
-  6.1433556e+003
-  6.5785460e+003
-  5.1688039e+003
-  3.5269882e+003
-  4.5670886e+003
-  5.5525570e+003
-  2.0728713e+003
-  3.8527724e+003
-  5.0305078e+003
-  4.9060143e+003
-  4.2802594e+003
-  5.1909190e+003
-  5.5657233e+003
-  5.4868548e+003
-  5.5248154e+003
-  5.6573546e+003
-  5.6130026e+003
-  5.0661694e+003
-  5.4837302e+003
-  5.4849214e+003
-  5.9098361e+003
-  5.4620551e+003
-  6.3312340e+003
-  3.1756159e+003
-  2.1098569e+003
-  4.3778587e+003
-  5.3733805e+003
-  5.5877967e+003
-  6.3841769e+003
-  6.7416745e+003
-  5.8575543e+003
-  7.8369288e+003
-  9.5787071e+003
-  9.5863616e+003
-  1.0115756e+004
-  1.0336706e+004
-  1.0297212e+004
-  1.0415543e+004
-  1.0099925e+004
-  1.0082155e+004
-  1.0545828e+004
-  8.1380135e+003
-  8.8193941e+003
-  8.0032709e+003
-  7.1685078e+003
-  7.6135448e+003
-  8.1851669e+003
-  7.8635292e+003
-  8.0855428e+003
-  9.0333803e+003
-  9.6257221e+003
-  9.9277903e+003
-  9.5930641e+003
-  7.7066137e+003
-  8.0910999e+003
-  9.8946754e+003
-  9.4830051e+003
-  8.5376690e+003
-  6.5759429e+003
-  7.7289846e+003
-  8.6976175e+003
-  1.0036760e+004
-  1.1666412e+004
-  1.1616603e+004
-  1.3064265e+004
-  4.1354681e+003
-  3.3577367e+003
-  5.1410283e+003
-  5.3071700e+003
-  3.8658578e+003
-  1.5108627e+003
-  1.7223051e+001
-  2.3983935e+003
-  4.0122291e+003
-  3.1450738e+003
-  1.9015533e+003
-  1.5889253e+003
-  1.7059994e+003
-  0.0000000e+000
-  4.5913009e+002
-  3.8454060e+002
-  1.3740268e+003
-  4.5888329e+003
-  5.9313580e+003
-  6.3368913e+003
-  6.5389834e+003
-  8.0079893e+003
-  7.2733464e+003
-  6.2922643e+003
-  6.9324580e+003
-  9.0884543e+003
-  9.2501225e+003
-  9.6300279e+003
-  8.4199893e+003
-  1.0679424e+004
-  1.1288787e+004
-  6.6741081e+003
-  7.1241351e+003
-  8.9936766e+003
-  8.2553715e+003
-  8.2626896e+003
-  5.0835977e+003
-  6.3241808e+003
-  7.0707636e+003
-  8.1504495e+003
-  8.1898525e+003
-  1.4767667e+004
-  9.8976934e+003
-  1.1943930e+004
-  1.0355243e+004
-  9.9232964e+003
-  9.2338121e+003
-  9.0760019e+003
-  7.7107337e+003
-  8.1354205e+003
-  7.6092748e+003
-  7.7099566e+003
-  8.0319901e+003
-  7.1813213e+003
-  6.4175565e+003
-  8.5573093e+003
-  8.3248106e+003
-  7.2845923e+003
-  8.3599213e+003
-  6.2220891e+003
-  8.2891906e+003
-  7.9116589e+003
-  8.0517064e+003
-  8.9145604e+003
-  9.8391029e+003
-  9.3974746e+003
-  1.0051104e+004
-  1.0737941e+004
-  9.9615112e+003
-  1.1239958e+004
-  1.1281650e+004
-  1.0532324e+004
-  9.8471216e+003
-  9.8222243e+003
-  8.6986757e+003
-  9.3830351e+003
-  8.5736062e+003
-  8.6084393e+003
-  8.0770468e+003
-  7.9935944e+003
-  8.1157801e+003
-  8.1151703e+003
-  8.2616322e+003
-  7.4956381e+003
-  6.2352758e+003
-  5.8959343e+003
-  6.5368028e+003
-  6.7409952e+003
-  6.7792682e+003
-  7.3127334e+003
-  7.4745658e+003
-  7.6090101e+003
-  6.7380284e+003
-  5.9900257e+003
-  5.0695933e+003
-  3.1288433e+003
-  5.6078846e+003
-  4.5385090e+003
-  7.6509109e+002
-  5.5717259e+002
-  1.1732229e+003
-  2.1972670e+003
-  4.1585390e+002
-  2.1927157e+003
-  2.4746003e+003
-  3.0887979e+003
-  0.0000000e+000
-  3.8216367e+003
-  7.5230860e+003
-  9.2476041e+003
-  6.1601714e+003
-  7.2145547e+003
-  8.3901803e+003
-  9.9004312e+003
-  9.0669439e+003
-  8.3979605e+003
-  9.9188135e+003
-  9.3720552e+003
-  8.6272044e+003
-  8.9535088e+003
-  8.1727367e+003
-  8.3266831e+003
-  7.9830464e+003
-  9.2392207e+003
-  8.5760059e+003
-  7.7162674e+003
-  7.7887734e+003
-  6.7516880e+003
-  6.1944475e+003
-  5.8675081e+003
-  4.1581110e+003
-  3.8564988e+003
-  2.2141436e+003
-  2.8429817e+003
-  2.5847702e+003
-  9.3644845e+002
-  2.4883095e+003
-  2.6087179e+003
-  1.7287660e+003
-  2.8552824e+003
-  5.0847389e+003
-  5.6747216e+003
-  5.5030866e+003
-  5.0631323e+003
-  6.1120144e+003
-  6.4617729e+003
-  5.6395520e+003
-  6.4217439e+003
-  7.3185571e+003
-  6.9522616e+003
-  6.5553289e+003
-  7.5717204e+003
-  7.5227937e+003
-  7.2179354e+003
-  6.1251516e+003
-  5.3120072e+003
-  6.4272348e+003
-  5.3138488e+003
-  5.4044837e+003
-  5.6653468e+003
-  5.8702991e+003
-  5.9703083e+003
-  6.3890118e+003
-  7.4351706e+003
-  8.6857612e+003
-  9.2276656e+003
-  9.2702176e+003
-  9.8048538e+003
-  2.6152022e+003
-  4.5711136e+003
-  4.4905163e+003
-  5.6068393e+003
-  5.5306206e+003
-  5.6161037e+003
-  5.5625188e+003
-  6.3023223e+003
-  6.1484242e+003
-  4.8717551e+003
-  3.1150243e+003
-  3.6059683e+003
-  3.3726779e+003
-  1.9004160e+003
-  3.8964321e+002
-  1.7545885e+003
-  2.4606839e+003
-  4.4542562e+003
-  5.6779564e+003
-  6.6094187e+003
-  7.1349968e+003
-  1.4308249e+004
-  8.5103093e+003
-  9.6022785e+003
-  2.9507782e+003
-  5.4110663e+003
-  2.6728750e+003
-  4.1088924e+003
-  3.5104532e+003
-  5.1870171e+003
-  7.6663404e+003
-  5.5474271e+003
-  3.8663124e+003
-  6.3706671e+002
-  5.9133141e+003
-  7.4740093e+003
-  2.6901149e+003
-  5.1306972e+003
-  5.1092424e+003
-  4.6151011e+003
-  3.7477441e+003
-  7.6072783e+003
-  8.6949678e+003
-  8.0007780e+003
-  8.6120852e+003
-  8.9808666e+003
-  9.7124296e+003
-  9.6761321e+003
-  6.7570433e+003
-  8.4884199e+003
-  7.7006251e+003
-  7.9392441e+003
-  6.8280380e+003
-  8.5589116e+003
-  8.8220993e+003
-  7.6247765e+003
-  6.9773111e+003
-  6.7552273e+003
-  7.1007963e+003
-  6.7492893e+003
-  4.0456122e+003
-  3.7308786e+002
-  0.0000000e+000
-  1.2617616e+003
-  3.4709102e+003
-  5.5699170e+003
-  5.2390305e+003
-  5.5814255e+003
-  6.2784441e+003
-  7.8487709e+003
-  6.8106837e+003
-  6.1722759e+003
-  1.2882737e+003
-  5.6374066e+003
-  6.7666036e+003
-  6.4044011e+003
-  6.1926965e+003
-  7.4527327e+003
-  7.7745913e+003
-  8.0129269e+003
-  9.5576000e+003
-  1.1091750e+004
-  1.3087854e+004
-  1.2803123e+004
-  1.2008456e+004
-  1.2125610e+004
-  1.3413773e+004
-  1.3152577e+004
-  1.3214561e+004
-  1.4148770e+004
-  1.3147302e+004
-  1.2895442e+004
-  1.4378279e+004
-  1.4734349e+004
-  1.4559626e+004
-  1.4143941e+004
-  1.1352517e+004
-  1.3049280e+004
-  1.2563819e+004
-  1.1947592e+004
-  1.0072417e+004
-  9.8663881e+003
-  1.2550155e+004
-  1.4089469e+004
-  1.4221670e+004
-  1.4122945e+004
-  1.4007315e+004
-  1.3585524e+004
-  1.0671743e+004
-  1.0531281e+004
-  1.1816532e+004
-  1.4294193e+004
-  1.4850294e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4972497e+004
-  1.4923080e+004
-  1.4849811e+004
-  1.4578036e+004
-  1.2700639e+004
-  1.4317148e+004
-  1.3925392e+004
-  1.2230665e+004
-  1.0558172e+004
-  9.9140437e+003
-  9.7760140e+003
-  1.0673951e+004
-  1.1006136e+004
-  1.1797015e+004
-  1.2104783e+004
-  1.2477481e+004
-  1.0546639e+004
-  1.1083246e+004
-  1.4326341e+004
-  1.4447058e+004
-  1.4407826e+004
-  1.4323477e+004
-  1.4343003e+004
-  1.4519662e+004
-  1.4712139e+004
-  1.4799313e+004
-  1.4680448e+004
-  1.4576413e+004
-  1.1806693e+004
-  1.3122693e+004
-  1.2933308e+004
-  1.2232749e+004
-  1.2273590e+004
-  1.1562848e+004
-  1.1281326e+004
-  1.1157287e+004
-  1.1721403e+004
-  1.1603909e+004
-  1.2306861e+004
-  1.1710049e+004
-  9.2397281e+003
-  1.2037147e+004
-  1.2909439e+004
-  1.3295225e+004
-  1.3806301e+004
-  1.3957378e+004
-  1.4017477e+004
-  1.4005151e+004
-  1.4012014e+004
-  1.3572802e+004
-  1.2752857e+004
-  1.1374821e+004
-  1.0153828e+004
-  1.1778491e+004
-  1.2911783e+004
-  1.1920576e+004
-  1.2762397e+004
-  1.2455245e+004
-  1.2241557e+004
-  1.0901359e+004
-  1.0069315e+004
-  9.4443427e+003
-  8.3266568e+003
-  8.3331980e+003
-  6.8647294e+003
-  8.7714991e+003
-  7.9320258e+003
-  9.4644069e+003
-  1.0534225e+004
-  1.0607815e+004
-  1.0451568e+004
-  1.0228923e+004
-  9.7361868e+003
-  9.2832224e+003
-  8.6847002e+003
-  7.9327451e+003
-  7.4417248e+003
-  8.3701672e+003
-  8.2197891e+003
-  7.4887390e+003
-  6.6065643e+003
-  6.6685270e+003
-  6.6872881e+003
-  6.2746222e+003
-  5.6517581e+003
-  5.1326215e+003
-  5.3242084e+003
-  5.9364864e+003
-  5.6449955e+003
-  6.4779212e+003
-  7.4852756e+003
-  7.8167260e+003
-  7.6819011e+003
-  8.1733732e+003
-  7.8396676e+003
-  7.1357197e+003
-  6.7507416e+003
-  6.7767261e+003
-  6.6558331e+003
-  6.9054847e+003
-  6.9934084e+003
-  6.7077666e+003
-  4.5141515e+003
-  4.0838158e+003
-  4.1676578e+003
-  5.4400710e+003
-  5.6341860e+003
-  5.5547820e+003
-  2.5698700e+003
-  1.5022833e+003
-  0.0000000e+000
-  0.0000000e+000
-  0.0000000e+000
-  1.1477677e+003
-  0.0000000e+000
-  1.8894553e+003
-  0.0000000e+000
-  2.6108040e+002
-  0.0000000e+000
-  0.0000000e+000
-  0.0000000e+000
-  9.5495003e+002
-  9.4006028e+002
-  0.0000000e+000
-  3.5370562e+003
-  3.9566627e+003
-  3.0929742e+003
-  4.9011007e+003
-  1.8903528e+003
-  0.0000000e+000
-  0.0000000e+000
-  0.0000000e+000
-  2.2071740e+003
-  3.9380997e+003
-  2.3659637e+003
-  4.5819484e+003
-  7.8283526e+003
-  8.3395475e+003
-  8.2555568e+003
-  7.4249946e+003
-  7.0053788e+003
-  7.3615225e+003
-  7.8190695e+003
-  7.3652682e+003
-  6.4071854e+003
-  5.6562926e+003
-  5.5819296e+003
-  5.4997161e+003
-  4.3778493e+003
-  4.2852124e+003
-  3.6996386e+003
-  4.1962655e+003
-  5.3572614e+003
-  6.1529617e+003
-  6.9828832e+003
-  6.4557735e+003
-  6.2853946e+003
-  6.7592074e+003
-  6.9318648e+003
-  7.3361642e+003
-  8.6591450e+003
-  6.8195745e+003
-  6.0680803e+003
-  7.6203908e+003
-  7.5128838e+003
-  7.8285502e+003
-  7.9947436e+003
-  8.4166739e+003
-  9.0386918e+003
-  9.6255894e+003
-  9.5458869e+003
-  9.2030754e+003
-  6.6768717e+003
-  6.7033235e+003
-  5.6917905e+003
-  5.4640444e+003
-  5.1686694e+003
-  5.0262107e+003
-  5.7329716e+003
-  7.3859021e+003
-  5.8516838e+003
-  4.5590723e+003
-  2.6981644e+003
-  2.0504300e+003
-  5.3858967e+003
-  4.9134822e+003
-  4.6603703e+003
-  5.9036473e+003
-  7.6810899e+003
-  8.1997977e+003
-  8.0106951e+003
-  8.1596697e+003
-  8.2479784e+003
-  7.9965925e+003
-  7.5024288e+003
-  6.8502876e+003
-  6.0533001e+003
-  6.2002184e+003
-  6.0958282e+003
-  5.6691136e+003
-  4.2681847e+003
-  6.5703859e+003
-  6.8901403e+003
-  7.5029552e+003
-  7.5444821e+003
-  7.3894798e+003
-  7.6846132e+003
-  8.0774156e+003
-  0.0000000e+000
-  0.0000000e+000
-  8.8731706e+002
-  1.2785911e+003
-  3.8026027e+002
-  2.0614489e+003
-  1.6214557e+003
-  7.8504105e+003
-  7.2713330e+003
-  7.2829772e+003
-  7.9999313e+003
-  7.8578117e+003
-  0.0000000e+000
-  2.5632195e+003
-  5.3873109e+003
-  8.6432428e+003
-  7.8386396e+003
-  7.8621048e+003
-  7.0017132e+003
-  6.7518025e+003
-  7.1735400e+003
-  5.4733881e+003
-  4.6497026e+003
-  2.6160870e+003
-  7.0548515e+003
-  8.2487991e+003
-  8.0543010e+003
-  8.3473312e+003
-  8.4405522e+003
-  7.7185410e+003
-  8.9730573e+003
-  8.3117900e+003
-  7.5650959e+003
-  9.3203575e+003
-  1.0766107e+004
-  1.0506120e+004
-  8.2404517e+003
-  9.3112087e+003
-  8.6444914e+003
-  7.9584098e+003
-  7.4190556e+003
-  8.3069102e+003
-  8.7101999e+003
-  9.0762521e+003
-  8.8499354e+003
-  8.7581015e+003
-  8.4550577e+003
-  8.5654165e+003
-  1.0108675e+004
-  1.0153487e+004
-  9.8892965e+003
-  1.0336175e+004
-  1.1190767e+004
-  1.1337847e+004
-  1.0699500e+004
-  1.1279998e+004
-  1.1353812e+004
-  1.1806177e+004
-  1.2046242e+004
-  1.1586266e+004
-  8.1553968e+003
-  9.7107256e+003
-  9.6347892e+003
-  9.8535087e+003
-  1.0241629e+004
-  1.0625407e+004
-  1.0808044e+004
-  1.0408890e+004
-  1.0504415e+004
-  8.0974393e+003
-  8.1872064e+003
-  7.5799017e+003
-  8.3155986e+003
-  6.9353920e+003
-  7.7001135e+003
-  6.2024939e+003
-  4.3010875e+003
-  4.0428118e+003
-  4.6734249e+003
-  4.2398119e+003
-  2.8420659e+003
-  2.3937756e+003
-  2.1968649e+003
-  3.4247098e+003
-  5.7593676e+003
-  6.4822557e+003
-  5.4086234e+003
-  3.5863455e+003
-  6.5186845e+003
-  1.0174982e+004
-  6.2258884e+003
-  6.2735088e+003
-  7.2463818e+003
-  7.8019508e+003
-  8.0914774e+003
-  8.0273003e+003
-  6.5042407e+003
-  7.1130267e+003
-  8.0390038e+003
-  9.1553699e+003
-  9.1063926e+003
-  1.0104636e+004
-  9.7730171e+003
-  1.0835057e+004
-  1.1252954e+004
-  1.0593947e+004
-  1.0261236e+004
-  1.0178175e+004
-  8.0030699e+003
-  7.9421457e+003
-  6.5004948e+003
-  5.0355241e+003
-  4.0448523e+003
-  5.5471107e+003
-  6.1952646e+003
-  6.1735064e+003
-  5.2142062e+003
-  4.2632449e+003
-  5.3247919e+003
-  6.6243626e+003
-  0.0000000e+000
-  1.0626700e+003
-  5.5930531e+003
-  6.6048446e+003
-  6.9432292e+003
-  9.0784543e+003
-  8.8071665e+003
-  4.6108863e+003
-  2.0320442e+003
-  1.7529495e+003
-  4.2818276e+002
-  0.0000000e+000
-  1.4657715e+003
-  2.8733436e+003
-  1.1113761e+003
-  8.2026959e+002
-  3.2031411e+003
-  5.4578303e+003
-  6.1476515e+003
-  5.1612321e+003
-  5.5145236e+003
-  5.8632761e+003
-  5.9789478e+003
-  6.0100731e+003
-  2.8119170e+003
-  1.4753276e+003
-  0.0000000e+000
-  1.1645733e+003
-  3.4029069e+003
-  4.6166264e+003
-  5.3362747e+003
-  5.0644515e+003
-  4.4729336e+003
-  3.1215161e+003
-  2.8050234e+003
-  2.4127796e+003
-  6.2574085e+001
-  0.0000000e+000
-  0.0000000e+000
-  2.8797743e+003
-  4.0707793e+003
-  6.2025962e+003
-  7.3729939e+003
-  8.0943202e+003
-  8.7145014e+003
-  8.0080964e+003
-  8.5488228e+003
-  8.7599510e+003
-  1.1881966e+004
-  1.2007864e+004
-  1.2566659e+004
-  1.2708876e+004
-  1.3455895e+004
-  1.4052810e+004
-  1.3674358e+004
-  1.2998792e+004
-  1.3524610e+004
-  1.4075571e+004
-  1.3970034e+004
-  1.4565383e+004
-  1.1776112e+004
-  1.3784832e+004
-  1.3391414e+004
-  1.4176030e+004
-  1.3156822e+004
-  1.2128830e+004
-  1.1109645e+004
-  9.5154339e+003
-  8.0810609e+003
-  6.7481260e+003
-  6.9190229e+003
-  7.8567433e+003
-  9.5370169e+003
-  1.3076686e+004
-  1.4083823e+004
-  1.3602359e+004
-  1.1822029e+004
-  1.2437776e+004
-  1.2526091e+004
-  1.3312266e+004
-  1.3354330e+004
-  1.3324940e+004
-  1.2930313e+004
-  1.2219589e+004
-  1.0347340e+004
-  1.2503860e+004
-  1.0987501e+004
-  1.0359392e+004
-  8.9019367e+003
-  8.8707211e+003
-  7.9610484e+003
-  7.3082613e+003
-  7.5009937e+003
-  7.5070157e+003
-  6.4086248e+003
-  6.5885396e+003
-  1.0160313e+004
-  7.2605065e+003
-  8.6941476e+003
-  1.1691884e+004
-  1.2858932e+004
-  1.4066665e+004
-  1.4389738e+004
-  1.4553906e+004
-  1.4534616e+004
-  1.4536238e+004
-  1.4532307e+004
-  1.4419266e+004
-  1.3565756e+004
-  1.4536834e+004
-  1.3934880e+004
-  1.2604112e+004
-  1.1548268e+004
-  1.0939456e+004
-  1.0584223e+004
-  1.0371914e+004
-  1.0265391e+004
-  1.0704553e+004
-  1.1566453e+004
-  1.1408185e+004
-  1.2508518e+004
-  1.4352964e+004
-  1.4210721e+004
-  1.4159789e+004
-  1.4148719e+004
-  1.4364776e+004
-  1.4297846e+004
-  1.4465736e+004
-  1.4459171e+004
-  1.4444024e+004
-  1.4095202e+004
-  1.2566492e+004
-  1.1047449e+004
-  1.1939240e+004
-  1.1649965e+004
-  1.2192118e+004
-  1.1706108e+004
-  1.1143421e+004
-  1.0827084e+004
-  1.0681743e+004
-  9.4032011e+003
-  8.4956601e+003
-  8.8424794e+003
-  9.1107555e+003
-  9.1775315e+003
-  9.0893828e+003
-  9.8194462e+003
-  9.9996784e+003
-  9.5577876e+003
-  1.0215585e+004
-  1.0346600e+004
-  1.0159862e+004
-  9.3719283e+003
-  9.8465513e+003
-  9.5547432e+003
-  9.6763764e+003
-  7.2230865e+003
-  7.1347127e+003
-  7.5650666e+003
-  7.3806092e+003
-  8.3559304e+003
-  8.0864770e+003
-  7.6486417e+003
-  6.8091315e+003
-  6.7052913e+003
-  6.2480900e+003
-  6.4172527e+003
-  6.8336305e+003
-  5.0828604e+003
-  5.8992184e+003
-  5.8221517e+003
-  5.4765914e+003
-  4.4040706e+003
-  2.6548177e+003
-  2.7952422e+003
-  1.7821496e+003
-  1.8672479e+003
-  0.0000000e+000
-  0.0000000e+000
-  0.0000000e+000
-  2.4444499e+003
-  3.3633107e+003
-  4.2376038e+003
-  5.7767493e+003
-  6.4128512e+003
-  6.5488570e+003
-  6.5035884e+003
-  6.2188076e+003
-  6.4609732e+003
-  6.8132900e+003
-  7.7303846e+003
-  7.9623514e+003
-  7.9183496e+003
-  6.8808556e+003
-  8.6255178e+003
-  8.6000044e+003
-  8.7458709e+003
-  9.0742932e+003
-  8.6634135e+003
-  8.6738839e+003
-  8.9289682e+003
-  8.8524505e+003
-  8.9733887e+003
-  8.9253610e+003
-  7.2014395e+003
-  6.8398964e+003
-  7.0270889e+003
-  5.3659379e+003
-  5.9222096e+003
-  6.6846536e+003
-  6.5958651e+003
-  7.0643611e+003
-  6.3064577e+003
-  6.5389800e+003
-  6.7931725e+003
-  5.9972918e+003
-  6.4241124e+003
-  5.3563267e+003
-  5.9733319e+003
-  6.2930395e+003
-  5.6327730e+003
-  5.2531108e+003
-  3.7128078e+003
-  4.5538938e+003
-  5.5351034e+003
-  6.0940877e+003
-  7.0292030e+003
-  7.1063534e+003
-  3.8284812e+003
-  3.3488307e+003
-  2.9444053e+003
-  6.4797021e+002
-  2.5122984e+003
-  2.6265758e+003
-  1.8083527e+003
-  3.2267532e+003
-  4.2393282e+003
-  4.0888360e+003
-  2.2768930e+003
-  2.2836113e+003
-  2.5109225e+003
-  3.1859473e+003
-  1.2710600e+003
-  3.1366806e+003
-  4.0157416e+003
-  5.1189722e+003
-  4.4843395e+003
-  1.6144730e+003
-  0.0000000e+000
-  4.5732753e+003
-  5.5599506e+003
-  5.6723745e+003
-  5.6073942e+003
-  6.8107067e+003
-  6.3042161e+003
-  6.0348055e+003
-  6.6608160e+003
-  6.1826184e+003
-  6.3623836e+003
-  6.2256643e+003
-  6.0451574e+003
-  6.2148039e+003
-  6.3462415e+003
-  6.1456435e+003
-  3.5846413e+003
-  2.5739341e+003
-  9.4450583e+002
-  3.0889885e+003
-  4.7997977e+003
-  4.8693042e+003
-  5.1698751e+003
-  5.5960284e+003
-  5.6517376e+003
-  6.1233882e+003
-  6.3522560e+003
-  5.7405811e+003
-  2.5993199e+003
-  5.4638363e+003
-  5.5471539e+003
-  6.4629692e+003
-  6.9976269e+003
-  7.2131170e+003
-  7.1983480e+003
-  7.1404862e+003
-  6.0510438e+003
-  6.9985492e+003
-  7.1085467e+003
-  7.8331410e+003
-  5.8834640e+003
-  6.3762216e+003
-  7.3401193e+003
-  8.8201549e+003
-  9.2383681e+003
-  1.0278857e+004
-  1.1100604e+004
-  1.1966643e+004
-  1.3413119e+004
-  1.3819395e+004
-  1.2424903e+004
-  1.1904587e+004
-  9.0157868e+003
-  1.3279007e+004
-  1.3220215e+004
-  1.4298650e+004
-  1.2617323e+004
-  1.1164287e+004
-  1.0353945e+004
-  1.0130607e+004
-  9.8825520e+003
-  8.5915722e+003
-  6.5857254e+003
-  6.8821880e+003
-  6.7446958e+003
-  6.6509499e+003
-  1.0193421e+004
-  1.1739819e+004
-  1.1535379e+004
-  1.2180969e+004
-  1.3345418e+004
-  1.3615411e+004
-  1.3348182e+004
-  1.1565162e+004
-  1.3698943e+004
-  1.3029112e+004
-  9.9551260e+003
-  1.0763619e+004
-  1.0549552e+004
-  1.1013599e+004
-  1.0364306e+004
-  1.1028403e+004
-  9.5178317e+003
-  9.1667881e+003
-  8.2795001e+003
-  8.1078401e+003
-  8.2202564e+003
-  8.9934709e+003
-  1.0274814e+004
-  8.9252330e+003
-  9.3773803e+003
-  1.1804999e+004
-  1.2113585e+004
-  1.1559838e+004
-  1.0593637e+004
-  1.1287984e+004
-  1.0475303e+004
-  1.0541109e+004
-  1.0908007e+004
-  1.0249198e+004
-  6.1529706e+003
-  6.0935898e+003
-  6.2652916e+003
-  6.5007676e+003
-  7.3582511e+003
-  6.1801771e+003
-  7.0134822e+003
-  3.6288112e+003
-  4.5586934e+003
-  5.5976878e+003
-  6.2029795e+003
-  7.4451693e+003
-  7.3777627e+003
-  6.1712209e+003
-  7.4637218e+003
-  9.2102922e+003
-  1.0274244e+004
-  1.0954009e+004
-  1.0866417e+004
-  1.1324523e+004
-  1.1836344e+004
-  1.1514071e+004
-  1.2535753e+004
-  1.1528844e+004
-  7.7377714e+003
-  8.6786008e+003
-  8.5255593e+003
-  6.1684493e+003
-  4.4285909e+003
-  5.0377109e+003
-  5.4061638e+003
-  5.5049577e+003
-  6.6037472e+003
-  6.9336391e+003
-  6.4109303e+003
-  5.9195186e+003
-  7.0944024e+003
-  7.5582800e+003
-  8.3012190e+003
-  1.1166341e+004
-  1.1299093e+004
-  1.0557624e+004
-  1.0498080e+004
-  1.0785689e+004
-  1.1072526e+004
-  1.0573615e+004
-  9.8143695e+003
-  9.4596037e+003
-  9.3518218e+003
-  9.8870819e+003
-  9.0467028e+003
-  8.7880165e+003
-  9.3161241e+003
-  7.7260787e+003
-  5.7779613e+003
-  4.0173668e+003
-  0.0000000e+000
-  0.0000000e+000
-  2.0349063e+003
-  4.4535083e+003
-  5.3760972e+003
-  4.8468214e+003
-  4.9434670e+003
-  7.2279781e+003
-  7.2882867e+003
-  5.7551835e+003
-  5.7226935e+003
-  5.5472680e+003
-  5.9673108e+003
-  6.4493170e+003
-  6.0596171e+003
-  4.7756622e+003
-  7.5709617e+003
-  9.1739222e+003
-  8.3555257e+003
-  7.2097817e+003
-  4.7081130e+003
-  5.3603382e+003
-  4.1465399e+003
-  4.9537368e+003
-  5.2346486e+003
-  6.0700313e+003
-  3.9568124e+003
-  5.3899786e+003
-  4.9310969e+003
-  5.8825847e+003
-  5.8654853e+003
-  7.8877575e+003
-  8.9138831e+003
-  9.8613647e+003
-  9.5793666e+003
-  9.0664274e+003
-  9.6940153e+003
-  9.7512241e+003
-  9.8523584e+003
-  1.0337797e+004
-  7.5918334e+003
-  8.5713856e+003
-  7.4845574e+003
-  5.6235969e+003
-  5.8237300e+003
-  6.2623144e+003
-  7.1909566e+003
-  5.4336173e+003
-  5.2598829e+003
-  6.8257552e+003
-  7.1605744e+003
-  6.9151052e+003
-  3.5521632e+003
-  3.9139148e+003
-  4.4599288e+003
-  5.9519629e+003
-  6.6357104e+003
-  6.6248078e+003
-  7.4514145e+003
-  7.1365405e+003
-  8.2300653e+003
-  8.3304531e+003
-  8.4534022e+003
-  9.3858545e+003
-  9.1189711e+003
-  1.0007885e+004
-  9.9829376e+003
-  1.0591772e+004
-  1.2813041e+004
-  1.4363911e+004
-  1.4073040e+004
-  1.2315978e+004
-  1.4089120e+004
-  1.4125442e+004
-  1.4033364e+004
-  1.1589221e+004
-  1.0631415e+004
-  1.0954366e+004
-  1.2177986e+004
-  1.3353017e+004
-  1.2761991e+004
-  1.2633734e+004
-  1.2990509e+004
-  1.2728662e+004
-  1.2674109e+004
-  1.2735031e+004
-  1.1685820e+004
-  1.1053840e+004
-  8.5524742e+003
-  9.3246320e+003
-  8.1247159e+003
-  6.0150872e+003
-  5.3598934e+003
-  5.1411224e+003
-  5.5232704e+003
-  7.4889039e+003
-  7.6695049e+003
-  6.6142665e+003
-  6.6109702e+003
-  7.0680483e+003
-  7.3945468e+003
-  6.2695651e+003
-  6.3174936e+003
-  7.7640201e+003
-  8.6138896e+003
-  9.3973384e+003
-  9.6834026e+003
-  1.0240379e+004
-  1.1430414e+004
-  1.2520215e+004
-  1.2417081e+004
-  1.1416349e+004
-  1.1805839e+004
-  1.4246599e+004
-  1.4182743e+004
-  1.4032671e+004
-  1.4089797e+004
-  1.4416118e+004
-  1.4075613e+004
-  1.4012769e+004
-  1.3434182e+004
-  1.2431042e+004
-  1.0230039e+004
-  9.5355291e+003
-  6.7898887e+003
-  4.4146866e+003
-  5.1461040e+003
-  5.9618071e+003
-  6.3559881e+003
-  6.7300501e+003
-  8.0858920e+003
-  1.0094225e+004
-  1.0624917e+004
-  1.0802007e+004
-  1.0609083e+004
-  1.0119989e+004
-  7.9402254e+003
-  8.6304183e+003
-  7.2813145e+003
-  5.3816246e+003
-  4.0770919e+003
-  3.4348965e+003
-  4.9313878e+003
-  5.7502706e+003
-  6.7566936e+003
-  7.7965326e+003
-  8.3827771e+003
-  7.2951984e+003
-  5.4848842e+003
-  5.9779613e+003
-  7.3257492e+003
-  1.1081163e+004
-  1.0688916e+004
-  1.1044403e+004
-  1.1096059e+004
-  1.1524599e+004
-  1.1097401e+004
-  1.0486339e+004
-  1.0858550e+004
-  1.0406341e+004
-  8.9542643e+003
-  9.9270114e+003
-  9.1880195e+003
-  8.5413152e+003
-  8.1198252e+003
-  7.6858942e+003
-  6.4090910e+003
-  6.1523516e+003
-  6.8745151e+003
-  7.1066583e+003
-  6.7331301e+003
-  5.5979951e+003
-  1.7755961e+003
-  1.3562948e+002
-  0.0000000e+000
-  1.6042664e+003
-  2.9107272e+003
-  4.3536463e+003
-  5.5000389e+003
-  5.6206158e+003
-  6.1148893e+003
-  6.7583248e+003
-  6.8001422e+003
-  7.0468471e+003
-  7.0191319e+003
-  7.7175985e+003
-  3.9444491e+003
-  2.5202439e+003
-  5.1432144e+003
-  6.1400909e+003
-  6.1928574e+003
-  6.0092150e+003
-  5.2317011e+003
-  4.3729533e+003
-  5.5194336e+003
-  5.6428980e+003
-  9.1242384e+001
-  0.0000000e+000
-  0.0000000e+000
-  1.4242304e+003
-  2.7538591e+003
-  2.0447649e+003
-  2.2813065e+003
-  6.6479513e+002
-  0.0000000e+000
-  2.3218507e+003
-  2.9178129e+003
-  1.0075762e+003
-  7.6042190e+002
-  2.3123902e+003
-  0.0000000e+000
-  1.6249207e+003
-  6.8478921e+003
-  6.2787220e+003
-  6.5264535e+003
-  5.5105023e+003
-  6.0055324e+003
-  8.3570253e+003
-  9.8056794e+003
-  9.9738140e+003
-  1.1661279e+004
-  1.2647040e+004
-  1.2696660e+004
-  1.3074444e+004
-  1.2692282e+004
-  1.3493621e+004
-  1.2119390e+004
-  1.2520317e+004
-  1.1427051e+004
-  1.1733847e+004
-  1.2096095e+004
-  1.2298656e+004
-  1.0735676e+004
-  1.0577124e+004
-  1.1337851e+004
-  1.2168440e+004
-  1.3819441e+004
-  1.3409225e+004
-  1.4338177e+004
-  1.3999631e+004
-  1.2840154e+004
-  1.3407145e+004
-  1.4147617e+004
-  1.2962800e+004
-  9.2962153e+003
-  1.0163658e+004
-  1.0560186e+004
-  1.1198147e+004
-  1.1848334e+004
-  1.1691601e+004
-  1.3411732e+004
-  1.4166846e+004
-  1.4250871e+004
-  1.4426263e+004
-  1.4451948e+004
-  1.4271562e+004
-  1.1220364e+004
-  1.4294909e+004
-  1.4304854e+004
-  1.3861962e+004
-  1.3402458e+004
-  1.2674533e+004
-  9.1137565e+003
-  7.6905048e+003
-  6.1986860e+003
-  7.8157356e+003
-  8.0786646e+003
-  7.7383208e+003
-  8.5632873e+003
-  8.9716496e+003
-  8.5197489e+003
-  6.6292700e+003
-  6.5788965e+003
-  5.8446458e+003
-  5.1343637e+003
-  3.7804675e+003
-  3.6646527e+003
-  4.5559739e+003
-  4.0801894e+003
-  3.0889203e+003
-  5.1245560e+003
-  5.7252473e+003
-  4.7450424e+003
-  3.4205074e+003
-  1.5560902e+002
-  1.3233490e+003
-  2.4701306e+003
-  5.0005302e+003
-  5.3416377e+003
-  4.7058088e+003
-  6.2278430e+003
-  7.6958709e+003
-  7.4274587e+003
-  5.5337376e+003
-  5.4062043e+003
-  7.6138492e+003
-  7.9586383e+003
-  9.5649518e+003
-  1.0415792e+004
-  1.1005070e+004
-  1.0685923e+004
-  1.1177141e+004
-  1.1048467e+004
-  1.0264085e+004
-  6.1634786e+003
-  5.3477874e+003
-  4.6652114e+003
-  5.2390204e+003
-  6.4925152e+003
-  7.2199672e+003
-  6.9288452e+003
-  6.2525698e+003
-  6.1091925e+003
-  5.8054677e+003
-  6.5173447e+003
-  7.8372233e+003
-  3.7428617e+003
-  5.5320730e+003
-  5.1086385e+003
-  6.3817160e+003
-  6.3764770e+003
-  6.3543721e+003
-  5.8388769e+003
-  5.4736171e+003
-  5.3580691e+003
-  5.8288554e+003
-  5.4950842e+003
-  4.9193925e+003
-  1.7864913e+003
-  1.2784254e+003
-  0.0000000e+000
-  2.6019563e+003
-  5.0684133e+003
-  5.0112085e+003
-  6.7487924e+003
-  6.7260251e+003
-  7.1570118e+003
-  6.6810402e+003
-  6.7275574e+003
-  6.4126151e+003
-  8.7849196e+003
-  6.5088512e+003
-  5.4787562e+003
-  5.9438236e+003
-  5.6150140e+003
-  5.3430394e+003
-  5.4510156e+003
-  5.4051302e+003
-  5.3003643e+003
-  3.4611066e+003
-  1.8131724e+003
-  3.8491530e+003
-  5.9584132e+003
-  6.5455652e+003
-  7.2901078e+003
-  8.4735461e+003
-  7.1315714e+003
-  7.1478182e+003
-  7.5210884e+003
-  7.9298573e+003
-  8.7818406e+003
-  9.2178110e+003
-  9.6075744e+003
-  1.0212956e+004
-  1.1103043e+004
-  1.0080205e+004
-  9.6075676e+003
-  9.6804039e+003
-  9.5340997e+003
-  9.0131537e+003
-  8.6393029e+003
-  8.3575252e+003
-  9.5716271e+003
-  9.7100297e+003
-  9.9368813e+003
-  9.6374942e+003
-  9.8624549e+003
-  1.1571313e+004
-  1.1356635e+004
-  1.0260043e+004
-  1.0080624e+004
-  1.0337064e+004
-  1.0286647e+004
-  1.0491590e+004
-  9.8008242e+003
-  9.5531995e+003
-  8.7477598e+003
-  9.4514705e+003
-  1.1701180e+004
-  1.0124664e+004
-  1.0049546e+004
-  9.9697416e+003
-  9.2959513e+003
-  9.3465605e+003
-  9.9154663e+003
-  1.0888258e+004
-  1.1299865e+004
-  1.1313257e+004
-  1.1241781e+004
-  1.0626215e+004
-  1.1346379e+004
-  1.2023596e+004
-  1.2416685e+004
-  1.0951767e+004
-  9.5043326e+003
-  9.8288361e+003
-  1.0452497e+004
-  9.9805882e+003
-  1.0079133e+004
-  1.0418755e+004
-  1.0844063e+004
-  1.0727602e+004
-  9.1250847e+003
-  9.1223078e+003
-  8.5980677e+003
-  8.9959900e+003
-  1.0241263e+004
-  1.1460452e+004
-  1.2588604e+004
-  1.3015737e+004
-  1.4360157e+004
-  1.4146275e+004
-  1.4242740e+004
-  1.4137522e+004
-  1.1699640e+004
-  1.2905070e+004
-  1.2927750e+004
-  1.2549948e+004
-  1.3005659e+004
-  1.2005557e+004
-  1.2019268e+004
-  1.1641720e+004
-  1.1393746e+004
-  1.1255862e+004
-  1.0498864e+004
-  9.3811903e+003
-  8.0861282e+003
-  9.4912147e+003
-  9.9878486e+003
-  9.9054268e+003
-  1.1843300e+004
-  1.1801218e+004
-  1.2287729e+004
-  1.0696577e+004
-  1.1750753e+004
-  1.1491259e+004
-  1.0603689e+004
-  1.0257701e+004
-  9.3381541e+003
-  9.9545168e+003
-  8.8723682e+003
-  6.8255067e+003
-  2.0467247e+003
-  3.2452102e+003
-  3.2844154e+003
-  2.8742408e+003
-  2.4197311e+003
-  3.1021524e+003
-  5.1387699e+003
-  6.1293638e+003
-  3.2921338e+003
-  2.6175485e+003
-  9.5475362e+002
-  1.7208089e+003
-  9.8905437e+002
-  4.8163437e+003
-  5.6220877e+003
-  6.4602328e+003
-  6.3463214e+003
-  6.0038047e+003
-  5.6737485e+003
-  5.7971183e+003
-  7.0524877e+003
-  7.3112267e+003
-  5.5435371e+003
-  5.5898473e+003
-  6.8604283e+003
-  7.5036297e+003
-  8.9290214e+003
-  1.0678985e+004
-  1.0005482e+004
-  9.0648224e+003
-  8.2275582e+003
-  6.5318957e+003
-  8.0080259e+003
-  7.2424398e+003
-  6.1778658e+003
-  8.6715757e+003
-  9.9686107e+003
-  1.0526597e+004
-  1.0522531e+004
-  1.0278738e+004
-  9.3666762e+003
-  8.2623541e+003
-  7.9241349e+003
-  7.4759145e+003
-  7.4522610e+003
-  7.1598904e+003
-  6.2912572e+003
-  6.6056157e+003
-  7.7455674e+003
-  1.0291074e+004
-  9.8840953e+003
-  8.7280162e+003
-  7.5299759e+003
-  7.4856318e+003
-  7.4214820e+003
-  7.9481593e+003
-  8.8461479e+003
-  7.5754030e+003
-  9.3611912e+003
-  1.0200861e+004
-  1.1782434e+004
-  1.3913160e+004
-  1.4102198e+004
-  1.4158658e+004
-  1.4165130e+004
-  1.4568294e+004
-  1.1465353e+004
-  5.5524416e+003
-  6.3579182e+003
-  6.5862465e+003
-  7.7525256e+003
-  8.2555798e+003
-  6.4698932e+003
-  6.0917484e+003
-  7.4246595e+003
-  6.0211783e+003
-  6.5209044e+003
-  6.7477006e+003
-  6.3979170e+003
-  6.2706980e+003
-  1.1071541e+004
-  7.9770924e+003
-  8.9163736e+003
-  1.1779147e+004
-  1.3465730e+004
-  1.3905087e+004
-  1.3506625e+004
-  1.3933348e+004
-  1.4048030e+004
-  1.3813297e+004
-  1.3473137e+004
-  1.3075889e+004
-  1.1855773e+004
-  1.1373837e+004
-  1.1865900e+004
-  1.3738178e+004
-  1.3035083e+004
-  1.0516397e+004
-  1.1929626e+004
-  1.2500826e+004
-  1.2104122e+004
-  1.3187354e+004
-  1.2531593e+004
-  1.2700832e+004
-  8.5353899e+003
-  1.0701652e+004
-  1.0242972e+004
-  1.2172264e+004
-  1.1418584e+004
-  1.1862941e+004
-  1.2096041e+004
-  1.3026156e+004
-  1.2785229e+004
-  1.3089958e+004
-  1.2466738e+004
-  1.3257661e+004
-  1.0696104e+004
-  1.1611353e+004
-  1.1171632e+004
-  1.0225592e+004
-  1.0164262e+004
-  1.0155083e+004
-  1.0011354e+004
-  9.5255369e+003
-  8.7373264e+003
-  8.5013683e+003
-  8.7933974e+003
-  8.4143412e+003
-  7.0507934e+003
-  6.3916097e+003
-  6.1650165e+003
-  7.3843829e+003
-  7.2161497e+003
-  7.1621673e+003
-  7.0889671e+003
-  6.4102311e+003
-  5.9403004e+003
-  5.6635497e+003
-  4.9922642e+003
-  3.6887101e+003
-  4.8210330e+003
-  3.7355896e+003
-  5.3336306e+003
-  5.8268423e+003
-  6.8754428e+003
-  6.6773179e+003
-  6.5487486e+003
-  6.9358329e+003
-  7.5025574e+003
-  7.1960818e+003
-  7.4126055e+003
-  6.9100766e+003
-  5.6613124e+003
-  4.8489918e+003
-  1.7269751e+003
-  3.0279125e+003
-  5.3521975e+003
-  4.2586573e+003
-  4.9853727e+003
-  5.9623042e+003
-  6.6820201e+003
-  7.0023943e+003
-  6.8191137e+003
-  6.8626877e+003
-  5.7127696e+003
-  5.7708439e+003
-  6.1544987e+003
-  7.3928439e+003
-  8.0067932e+003
-  8.0691231e+003
-  8.5611692e+003
-  8.9560219e+003
-  9.2034840e+003
-  8.3471842e+003
-  7.9740992e+003
-  7.9022327e+003
-  9.7158311e+003
-  8.6733999e+003
-  8.0950930e+003
-  1.0467051e+004
-  1.1002515e+004
-  1.1893679e+004
-  1.2190123e+004
-  1.2543451e+004
-  1.2961643e+004
-  1.3331308e+004
-  1.3194671e+004
-  1.3149113e+004
-  1.3622721e+004
-  1.4000775e+004
-  1.4148801e+004
-  1.4243414e+004
-  1.4040078e+004
-  1.3401777e+004
-  1.2793529e+004
-  1.2709770e+004
-  1.2111972e+004
-  1.1556052e+004
-  1.0353812e+004
-  1.0196181e+004
-  1.1557895e+004
-  8.3720478e+003
-  7.2123969e+003
-  6.4660890e+003
-  5.8333630e+003
-  4.5341357e+003
-  3.1885234e+003
-  3.0965204e+003
-  1.8477836e+003
-  1.5328572e+003
-  0.0000000e+000
-  0.0000000e+000
-  6.0856256e+003
-  7.7175818e+003
-  8.4323380e+003
-  7.3505589e+003
-  5.6816125e+003
-  6.8651622e+003
-  6.7632769e+003
-  6.4644485e+003
-  6.6207425e+003
-  7.6519791e+003
-  8.0228471e+003
-  8.4057987e+003
-  7.2619523e+003
-  6.5469679e+003
-  6.6473868e+003
-  7.7771868e+003
-  6.7019790e+003
-  7.5136010e+003
-  7.7771910e+003
-  7.4751975e+003
-  7.1655259e+003
-  7.5865310e+003
-  7.3629939e+003
-  7.9053798e+003
-  5.7023132e+003
-  4.1720901e+003
-  5.7631431e+003
-  3.4444684e+003
-  2.8333692e+002
-  0.0000000e+000
-  3.2311695e+003
-  5.6239611e+003
-  6.8355006e+003
-  6.7346058e+003
-  6.3348782e+003
-  6.4251261e+003
-  7.7023908e+003
-  7.5435400e+003
-  9.3690638e+003
-  8.5957303e+003
-  7.7655711e+003
-  7.5134421e+003
-  7.4827400e+003
-  6.8404314e+003
-  5.8673574e+003
-  5.5755444e+003
-  5.9534875e+003
-  6.0340229e+003
-  5.6055019e+003
-  6.2848840e+003
-  7.8403307e+003
-  5.8927328e+003
-  5.3340355e+003
-  4.7376558e+003
-  2.9155967e+003
-  6.7248136e+002
-  0.0000000e+000
-  3.9756141e+002
-  1.9913700e+003
-  3.9429972e+003
-  2.7672044e+003
-  3.9120234e+001
-  2.8866462e+003
-  6.5069457e+003
-  8.3936392e+003
-  8.8051260e+003
-  9.3150939e+003
-  9.0347247e+003
-  8.8919679e+003
-  9.3955879e+003
-  1.0137611e+004
-  1.1213669e+004
-  1.0142556e+004
-  1.3015694e+004
-  1.2949099e+004
-  1.2639363e+004
-  1.1081784e+004
-  9.5317693e+003
-  8.4108351e+003
-  8.1734045e+003
-  8.9084618e+003
-  1.0104325e+004
-  9.2020499e+003
-  9.3650406e+003
-  1.1015573e+004
-  1.2203650e+004
-  1.2454921e+004
-  1.2136892e+004
-  1.3425550e+004
-  1.3380674e+004
-  1.3172389e+004
-  1.3214882e+004
-  1.3231588e+004
-  1.3157438e+004
-  1.2316119e+004
-  1.2244812e+004
-  1.1893163e+004
-  1.2629505e+004
-  1.2627421e+004
-  1.1956578e+004
-  1.1200288e+004
-  1.0308203e+004
-  9.3572223e+003
-  8.7986871e+003
-  8.7686771e+003
-  7.1976928e+003
-  7.9248401e+003
-  6.6938447e+003
-  6.8421381e+003
-  6.7646100e+003
-  6.8972671e+003
-  7.5058083e+003
-  6.9228792e+003
-  6.3113691e+003
-  6.1901866e+003
-  7.0202441e+003
-  7.0869902e+003
-  5.9566826e+003
-  6.6213433e+003
-  6.6805158e+003
-  4.3547422e+003
-  6.2437921e+003
-  5.7185409e+003
-  5.1433910e+003
-  5.4420468e+003
-  5.6063917e+003
-  5.1371758e+003
-  5.5334798e+003
-  5.2412203e+003
-  4.2829118e+003
-  4.1111588e+003
-  3.3603315e+003
-  1.4546636e+003
-  1.4753341e+003
-  1.8736653e+003
-  3.1513548e+003
-  2.4947502e+003
-  8.1765964e+002
-  0.0000000e+000
-  3.1628737e+002
-  1.4731189e+003
-  1.9561781e+002
-  5.4329983e+002
-  3.3794641e+003
-  4.3948104e+003
-  6.4756637e+003
-  7.2252005e+003
-  7.8634085e+003
-  7.1527382e+003
-  7.1463869e+003
-  6.7356234e+003
-  5.9201916e+003
-  5.3802162e+003
-  5.4066411e+003
-  5.4605831e+003
-  5.3928410e+003
-  6.6368335e+003
-  5.3446629e+003
-  4.3842820e+003
-  6.7018121e+003
-  6.0942797e+003
-  5.6988930e+003
-  5.6471843e+003
-  6.3339357e+003
-  6.9601090e+003
-  6.4297262e+003
-  6.2285395e+003
-  6.8991757e+003
-  6.8831852e+003
-  7.0522489e+003
-  7.6735353e+003
-  7.4946333e+003
-  7.0111891e+003
-  7.0719382e+003
-  6.4044419e+003
-  5.7499819e+003
-  5.3874755e+003
-  5.7531262e+003
-  6.2837777e+003
-  5.3746341e+003
-  7.2295377e+003
-  6.7849463e+003
-  5.5859468e+003
-  6.8770004e+003
-  6.9349532e+003
-  6.1946925e+003
-  6.4860080e+003
-  7.3195551e+003
-  7.4739297e+003
-  6.7558567e+003
-  6.6256697e+003
-  6.8173731e+003
-  7.1520776e+003
-  7.7239487e+003
-  7.1591009e+003
-  7.3949447e+003
-  7.1517824e+003
-  6.6525829e+003
-  6.3600641e+003
-  5.7020142e+003
-  5.0247887e+003
-  5.6059380e+003
-  5.4208366e+003
-  4.1454077e+003
-  5.8279458e+003
-  5.3459109e+003
-  3.5919892e+003
-  2.4283349e+003
-  2.9171519e+003
-  2.5236476e+003
-  3.1207679e+003
-  5.1609892e+003
-  5.9772193e+003
-  5.4471092e+003
-  4.9726340e+003
-  5.4033178e+003
-  4.4045428e+003
-  5.1217141e+003
-  5.6081278e+003
-  5.9255166e+003
-  6.3887153e+003
-  5.2974961e+003
-  4.3325883e+003
-  5.0084821e+003
-  4.2860880e+003
-  1.4428545e+003
-  0.0000000e+000
-  0.0000000e+000
-  2.6847624e+003
-  1.6929017e+003
-  1.7015647e+003
-  4.7194808e+003
-  1.6010556e+002
-  2.0684930e+002
-  0.0000000e+000
-  9.8498008e+002
-  1.1500522e+003
-  2.1509832e+003
-  2.9809805e+003
-  4.6906098e+003
-  2.0618810e+003
-  2.5563985e+003
-  3.1613569e+003
-  5.0542917e+003
-  6.1138826e+003
-  6.0037971e+003
-  6.6370659e+003
-  6.7404988e+003
-  6.8883136e+003
-  6.4440831e+003
-  4.4293969e+003
-  2.5157663e+003
-  8.2078022e+002
-  0.0000000e+000
-  0.0000000e+000
-  0.0000000e+000
-  0.0000000e+000
-  1.2629965e+003
-  1.6348842e+003
-  1.4696652e+003
-  2.0216463e+003
-  2.9282693e+003
-  4.6233346e+003
-  5.1797581e+003
-  4.0452479e+003
-  4.5469460e+003
-  6.6180962e+003
-  7.3562709e+003
-  6.8527974e+003
-  7.1642161e+003
-  6.6491125e+003
-  6.0071041e+003
-  6.0427055e+003
-  6.3061845e+003
-  6.5424780e+003
-  5.8198567e+003
-  5.5646029e+003
-  5.2141471e+003
-  3.5006897e+003
-  3.9349788e+003
-  4.5350766e+003
-  4.9754126e+003
-  5.9381811e+003
-  5.7298213e+003
-  4.3764239e+003
-  3.9046456e+003
-  4.7244611e+003
-  3.0394915e+003
-  5.4050673e+003
-  5.2420422e+003
-  5.7328425e+003
-  6.8474918e+003
-  7.3277473e+003
-  7.0234694e+003
-  5.6626872e+003
-  5.5440130e+003
-  5.0373464e+003
-  3.8189696e+003
-  1.2819947e+003
-  1.1193130e+003
-  3.2716457e+003
-  1.2114837e+003
-  1.2363369e+003
-  1.7868256e+003
-  5.8966503e+003
-  6.3040690e+003
-  6.5548409e+003
-  6.0545161e+003
-  6.7619804e+003
-  6.8052642e+003
-  6.7290090e+003
-  6.6268361e+003
-  7.5249381e+003
-  7.0614225e+003
-  6.2391479e+003
-  5.4482959e+003
-  5.9830959e+003
-  5.4034926e+003
-  5.4341370e+003
-  5.1748092e+003
-  5.6930914e+003
-  5.6282818e+003
-  5.0665427e+003
-  5.0923014e+003
-  7.7845481e+003
-  6.3461004e+003
-  5.8966994e+003
-  5.3817612e+003
-  7.1757568e+003
-  7.5880187e+003
-  7.9628631e+003
-  7.9109051e+003
-  7.8051045e+003
-  8.0569675e+003
-  8.0583386e+003
-  7.7833438e+003
-  6.4726596e+003
-  6.3669373e+003
-  7.1941393e+003
-  6.0032010e+003
-  6.6578199e+003
-  6.8981226e+003
-  6.5066082e+003
-  6.7767023e+003
-  6.5407841e+003
-  6.1920033e+003
-  5.7720228e+003
-  5.6160769e+003
-  6.2813778e+003
-  5.7778780e+003
-  4.2056496e+003
-  4.8976687e+003
-  5.4001703e+003
-  5.5266017e+003
-  4.8179281e+003
-  1.6186274e+003
-  1.4140156e+003
-  2.2384059e+003
-  4.5070155e+003
-  5.1041150e+003
-  4.9297212e+003
-  5.9568958e+003
-  7.0551771e+003
-  7.0182106e+003
-  8.2167292e+003
-  7.5298268e+003
-  7.2007881e+003
-  6.4093961e+003
-  6.3768111e+003
-  4.8989579e+003
-  3.4140760e+003
-  1.1862434e+003
-  5.4902117e+003
-  5.0564323e+003
-  4.1143366e+003
-  3.8700616e+003
-  4.0314558e+003
-  5.1110656e+003
-  4.3260579e+003
-  5.5224389e+003
-  4.6664149e+003
-  5.7148885e+003
-  6.1185484e+003
-  6.0828831e+003
-  7.4441446e+003
-  8.0745498e+003
-  8.1886847e+003
-  7.7038662e+003
-  6.3823664e+003
-  6.8949858e+003
-  5.8904503e+003
-  6.5400522e+003
-  5.2945407e+003
-  5.7014842e+003
-  5.7832989e+003
-  5.6279009e+003
-  5.6479845e+003
-  5.5947674e+003
-  3.7591365e+003
-  2.2404735e+003
-  4.0842101e+003
-  6.5154913e+003
-  7.5129659e+003
-  8.2986438e+003
-  8.7714860e+003
-  8.9753103e+003
-  7.5533746e+003
-  6.7391163e+003
-  6.0783802e+003
-  6.7927731e+003
-  8.0082974e+003
-  7.4411921e+003
-  8.0062390e+003
-  7.7523470e+003
-  7.5746421e+003
-  6.5309933e+003
-  6.0644969e+003
-  6.3111076e+003
-  5.5924293e+003
-  5.6003373e+003
-  5.7491696e+003
-  6.0111737e+003
-  4.5828826e+003
-  2.1131576e+003
-  4.2724522e+003
-  3.9074538e+003
-  5.5211476e+003
-  5.8780455e+003
-  6.4156199e+003
-  6.2099804e+003
-  5.3523288e+003
-  4.6574471e+003
-  1.4440184e+003
-  1.5581470e+003
-  9.2609764e+002
-  1.1419822e+003
-  2.2756133e+003
-  5.3081573e+003
-  5.1707306e+003
-  5.5734725e+003
-  4.4890838e+003
-  3.4739327e+003
-  3.8113807e+003
-  4.5561658e+003
-  4.3859226e+002
-  0.0000000e+000
-  0.0000000e+000
-  0.0000000e+000
-  0.0000000e+000
-  9.9445126e+002
-  3.0877438e+003
-  4.1360264e+003
-  4.9050481e+003
-  3.1701019e+003
-  2.0889323e+003
-  1.3595259e+003
-  0.0000000e+000
-  6.2171268e+002
-  1.4059197e+002
-  0.0000000e+000
-  1.6166397e+003
-  7.7659513e+003
-  6.1965499e+003
-  5.9305908e+003
-  6.1478009e+003
-  5.4262135e+003
-  6.0231700e+003
-  5.9973827e+003
-  5.3999670e+003
-  5.5996362e+003
-  2.2963567e+003
-  1.6861951e+003
-  8.7962968e+002
-  1.0721115e+003
-  3.0830485e+003
-  3.3150742e+003
-  3.7337179e+003
-  4.6907809e+003
-  4.8529294e+003
-  4.4349967e+003
-  2.4788204e+003
-  4.9028505e+003
-  5.9014371e+003
-  6.3237684e+003
-  5.2311981e+003
-  5.5068333e+003
-  5.7913854e+003
-  5.9287723e+003
-  5.4825711e+003
-  5.5425848e+003
-  6.1923594e+003
-  7.1284284e+003
-  1.9029299e+003
-  2.9779409e+003
-  3.8533472e+003
-  3.0121360e+003
-  4.4596195e+003
-  5.3600812e+003
-  5.4191545e+003
-  5.2210800e+003
-  5.1841177e+003
-  5.2667045e+003
-  5.7230346e+003
-  6.0235878e+003
-  5.1593669e+003
-  5.4819734e+003
-  6.5482079e+003
-  7.2227162e+003
-  7.7241498e+003
-  8.0096402e+003
-  9.5184703e+003
-  9.9312287e+003
-  1.0126630e+004
-  1.0026173e+004
-  8.9253352e+003
-  8.0347065e+003
-  8.2601065e+003
-  8.4570318e+003
-  8.2739836e+003
-  7.7423649e+003
-  7.6658436e+003
-  6.6431721e+003
-  5.9534412e+003
-  5.6552223e+003
-  5.2838699e+003
-  5.3838761e+003
-  7.3628541e+003
-  6.1463259e+003
-  5.1333730e+003
-  5.4215809e+003
-  6.0809128e+003
-  6.1497039e+003
-  6.4129313e+003
-  7.2086361e+003
-  6.6693384e+003
-  6.5827846e+003
-  6.7676094e+003
-  6.4582399e+003
-  5.9693084e+003
-  5.5667379e+003
-  6.3917989e+003
-  4.6197094e+003
-  2.0582144e+003
-  2.7739645e+003
-  3.9116055e+003
-  4.0103260e+003
-  2.2206564e+003
-  5.7510759e+002
-  9.4293667e+002
-  0.0000000e+000
-  1.7840079e+002
-  1.9056219e+003
-  0.0000000e+000
-  0.0000000e+000
-  0.0000000e+000
-  2.8164920e+002
-  1.3748946e+003
-  3.3948110e+003
-  4.1770420e+003
-  3.9842667e+003
-  5.4345177e+003
-  6.5563901e+003
-  5.6211929e+003
-  5.3348421e+003
-  5.0284895e+003
-  4.7485429e+003
-  3.1884757e+003
-  1.2273884e+003
-  5.5059316e+002
-  0.0000000e+000
-  1.2339220e+001
-  0.0000000e+000
-  1.7924013e+002
-  2.0563663e+002
-  0.0000000e+000
-  2.0629046e+003
-  1.0814038e+003
-  3.0227182e+003
-  3.8368946e+003
-  4.2333775e+003
-  5.2021061e+003
-  8.0817691e+003
-  7.4449576e+003
-  7.2705424e+003
-  6.8208161e+003
-  6.1957500e+003
-  6.0151908e+003
-  6.4278665e+003
-  6.5942335e+003
-  4.4702894e+003
-  5.3068886e+003
-  6.2331258e+003
-  5.7593768e+003
-  5.1854448e+003
-  5.6538226e+003
-  6.1359739e+003
-  5.7940790e+003
-  5.3278138e+003
-  5.6586897e+003
-  6.5798191e+003
-  6.1394346e+003
-  6.3416878e+003
-  6.1090622e+003
-  6.6410843e+003
-  7.4290954e+003
-  7.8466318e+003
-  7.6127870e+003
-  6.6080198e+003
-  4.9226787e+003
-  5.6649077e+003
-  6.2347282e+003
-  6.7926851e+003
-  7.2331258e+003
-  6.2577961e+003
-  5.6694478e+003
-  5.4949786e+003
-  6.7775967e+003
-  8.4277524e+003
-  8.9116380e+003
-  9.2928723e+003
-  8.8488694e+003
-  8.8803614e+003
-  8.8003555e+003
-  1.0417705e+004
-  7.0185104e+003
-  7.5979808e+003
-  7.7078957e+003
-  9.3302393e+003
-  9.4029060e+003
-  9.2390964e+003
-  9.4659933e+003
-  8.9856114e+003
-  8.1719434e+003
-  5.9918342e+003
-  6.6261480e+003
-  6.7999154e+003
-  7.1308364e+003
-  7.3128113e+003
-  7.5193912e+003
-  8.5210706e+003
-  9.3254540e+003
-  1.0732447e+004
-  1.2434714e+004
-  1.2000442e+004
-  1.3016679e+004
-  1.3095939e+004
-  1.3237607e+004
-  1.3030819e+004
-  6.4853805e+003
-  7.4253209e+003
-  8.0817879e+003
-  8.1700274e+003
-  8.8228409e+003
-  8.1720795e+003
-  6.9504931e+003
-  6.4051843e+003
-  5.3577722e+003
-  2.4575940e+003
-  1.1739589e+003
-  2.4555003e+003
-  2.0589599e+003
-  1.6405148e+003
-  3.3450473e+003
-  4.3305585e+003
-  5.5395649e+003
-  4.9029067e+003
-  1.7796430e+003
-  0.0000000e+000
-  2.0959832e+003
-  2.9977463e+003
-  1.9019925e+003
-  2.2605578e+003
-  0.0000000e+000
-  3.1871903e+003
-  2.5507246e+003
-  3.8058820e+003
-  2.5641560e+003
-  2.0218466e+003
-  7.7664404e+002
-  0.0000000e+000
-  0.0000000e+000
-  0.0000000e+000
-  0.0000000e+000
-  0.0000000e+000
-  2.5978085e+003
-  5.6850570e+003
-  2.8738494e+003
-  1.1115691e+003
-  6.9749098e+002
-  1.2981572e+002
-  0.0000000e+000
-  0.0000000e+000
-  0.0000000e+000
-  0.0000000e+000
-  3.0570176e+003
-  5.5122908e+003
-  3.5197659e+002
-  9.6677682e+002
-  9.5143080e+002
-  1.3016139e+003
-  5.3023113e+003
-  6.9934825e+003
-  5.4087831e+003
-  5.2674010e+003
-  5.6089676e+003
-  5.4951330e+003
-  5.6734416e+003
-  4.9210630e+003
-  5.1550331e+003
-  3.1524421e+003
-  4.5368092e+003
-  5.0268175e+003
-  5.0464719e+003
-  5.6254666e+003
-  6.1402536e+003
-  5.8269427e+003
-  7.2813390e+003
-  7.4501963e+003
-  6.8797458e+003
-  6.8003631e+003
-  5.2229272e+003
-  6.2046183e+003
-  6.0118434e+003
-  5.8835168e+003
-  5.6148331e+003
-  5.5574420e+003
-  5.7094511e+003
-  5.2777154e+003
-  3.1803041e+003
-  1.5118207e+003
-  0.0000000e+000
-  5.9225056e+002
-  7.2948423e+003
-  8.3644402e+003
-  8.1247348e+003
-  7.5153621e+003
-  6.1456482e+003
-  7.8781595e+003
-  4.8661157e+003
-  2.7730139e+003
-  0.0000000e+000
-  1.3692556e+003
-  4.7206366e+002
-  3.5031926e+002
-  3.0979744e+003
-  5.2077832e+003
-  4.8174986e+003
-  6.6942692e+003
-  5.6920756e+003
-  5.3744609e+003
-  5.5210659e+003
-  5.4395164e+003
-  5.3927569e+003
-  5.1274323e+003
-  5.0898692e+003
-  3.9406011e+003
-  5.2050328e+003
-  4.8321027e+003
-  1.9695651e+003
-  3.8724860e+003
-  5.4854755e+003
-  5.7334233e+003
-  4.3493759e+003
-  4.1830491e+003
-  5.2125472e+003
-  5.2771030e+003
-  5.4501323e+003
-  4.3940276e+003
-  5.4322602e+003
-  6.5893793e+003
-  6.8160553e+003
-  7.6479811e+003
-  7.9050673e+003
-  8.1022775e+003
-  7.9983864e+003
-  8.2061460e+003
-  8.2638857e+003
-  9.0189938e+003
-  9.6504657e+003
-  1.0005628e+004
-  1.1412526e+004
-  1.2164635e+004
-  1.1687337e+004
-  1.2602792e+004
-  1.3297914e+004
-  1.3689648e+004
-  1.4151800e+004
-  1.4207331e+004
-  1.4610773e+004
-  1.4957426e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4696926e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4316020e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4662642e+004
-  1.4954699e+004
-  1.4194284e+004
-  1.4767609e+004
-  1.4952645e+004
-  1.4018945e+004
-  1.4534642e+004
-  1.4448436e+004
-  1.4181473e+004
-  1.3978627e+004
-  1.3222085e+004
-  1.3411780e+004
-  1.2471997e+004
-  1.1708367e+004
-  1.0580281e+004
-  1.1003804e+004
-  1.0877809e+004
-  1.0322387e+004
-  9.5954167e+003
-  9.1729322e+003
-  9.1473957e+003
-  8.5763077e+003
-  7.8103292e+003
-  6.9858035e+003
-  6.1168932e+003
-  6.3702576e+003
-  5.9672019e+003
-  6.5223330e+003
-  6.6260396e+003
-  6.9229174e+003
-  7.2464936e+003
-  6.8647237e+003
-  7.1675063e+003
-  6.0360554e+003
-  6.1175536e+003
-  6.7336623e+003
-  5.7560299e+003
-  5.8602074e+003
-  7.0873941e+003
-  6.7609128e+003
-  6.7921665e+003
-  6.8702686e+003
-  8.4752600e+003
-  8.1463933e+003
-  9.0246364e+003
-  9.4597181e+003
-  1.0318698e+004
-  1.0967717e+004
-  1.2101441e+004
-  1.2153791e+004
-  8.6356752e+003
-  1.1966658e+004
-  1.2944558e+004
-  1.2857528e+004
-  1.2666923e+004
-  1.2403407e+004
-  1.3049728e+004
-  1.3180148e+004
-  1.3114272e+004
-  1.4222574e+004
-  1.4260084e+004
-  1.4325616e+004
-  1.0976626e+004
-  1.3165985e+004
-  1.4506695e+004
-  1.3955862e+004
-  1.4436755e+004
-  1.4555105e+004
-  1.4695783e+004
-  1.5000000e+004
-  1.3222011e+004
-  1.4841159e+004
-  1.5000000e+004
-  1.5000000e+004
-  8.2173949e+003
-  8.4847403e+003
-  7.4698844e+003
-  7.6789078e+003
-  7.2305135e+003
-  8.9171536e+003
-  9.9065098e+003
-  1.0939268e+004
-  1.0621789e+004
-  9.4237668e+003
-  9.6240995e+003
-  1.0469106e+004
-  6.4078653e+003
-  5.3461163e+003
-  4.6850295e+003
-  4.8372339e+003
-  5.4194062e+003
-  5.3089505e+003
-  6.4268435e+003
-  5.7804106e+003
-  6.9797974e+003
-  6.4299853e+003
-  9.6226511e+003
-  1.2467356e+004
-  6.7712962e+003
-  7.9248497e+003
-  9.3151535e+003
-  1.0085636e+004
-  1.0147420e+004
-  8.9951102e+003
-  9.9091571e+003
-  1.1642743e+004
-  1.1700057e+004
-  1.0425793e+004
-  9.1562497e+003
-  9.6663366e+003
-  8.0042721e+003
-  7.3568177e+003
-  8.4068014e+003
-  1.0219124e+004
-  1.0887920e+004
-  1.0851768e+004
-  1.1037744e+004
-  1.1325030e+004
-  1.0881386e+004
-  1.0749443e+004
-  9.9498587e+003
-  9.7435453e+003
-  8.1783665e+003
-  9.6435539e+003
-  9.4577928e+003
-  8.5567057e+003
-  7.5892480e+003
-  8.2518112e+003
-  9.0487260e+003
-  8.7831170e+003
-  8.7174295e+003
-  9.5873414e+003
-  8.6072456e+003
-  8.4018478e+003
-  8.3214364e+003
-  8.2080383e+003
-  8.4919721e+003
-  8.7725860e+003
-  8.6849076e+003
-  9.5541535e+003
-  9.6507978e+003
-  9.4835377e+003
-  9.4475613e+003
-  8.7227082e+003
-  8.9118537e+003
-  8.5411034e+003
-  5.8997332e+003
-  5.9055423e+003
-  5.2136739e+003
-  5.2847993e+003
-  4.5993360e+003
-  3.4901932e+003
-  3.5498222e+003
-  3.6042675e+003
-  2.8310621e+003
-  2.5213362e+003
-  8.3615086e+002
-  0.0000000e+000
-  2.7318461e+003
-  2.7563325e+003
-  2.5664120e+003
-  3.0715774e+003
-  5.2981928e+003
-  5.7880972e+003
-  5.3332870e+003
-  4.9269530e+003
-  3.8220028e+003
-  4.0341363e+003
-  5.6430991e+003
-  8.4219815e+003
-  6.4900996e+003
-  7.9735105e+003
-  8.5340289e+003
-  8.8095234e+003
-  9.9476293e+003
-  1.0073817e+004
-  1.0424993e+004
-  9.4713840e+003
-  1.1219678e+004
-  1.1619110e+004
-  9.7605285e+003
-  8.5219678e+003
-  8.3360250e+003
-  6.7428396e+003
-  4.6351759e+003
-  4.9320568e+003
-  8.2151328e+003
-  1.2515897e+004
-  1.4303586e+004
-  1.4735261e+004
-  1.4716127e+004
-  1.4824866e+004
-  1.4721656e+004
-  1.4565963e+004
-  1.4221860e+004
-  1.4705759e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4507079e+004
-  1.4396400e+004
-  1.3644260e+004
-  1.3086407e+004
-  1.2197427e+004
-  1.0136187e+004
-  8.9287669e+003
-  7.7589076e+003
-  6.4332317e+003
-  6.7680824e+003
-  6.4501980e+003
-  6.9652749e+003
-  9.1506872e+003
-  1.0823517e+004
-  1.2185235e+004
-  1.3216763e+004
-  1.4164465e+004
-  1.4237102e+004
-  1.4005279e+004
-  1.3682191e+004
-  8.5839202e+003
-  8.4315178e+003
-  7.6467575e+003
-  8.7082007e+003
-  7.4805065e+003
-  7.1282142e+003
-  6.4398718e+003
-  5.4742430e+003
-  5.4238763e+003
-  6.5274469e+003
-  6.3097353e+003
-  9.7437229e+003
-  6.0475931e+003
-  6.3554896e+003
-  2.9133611e+003
-  1.1504990e+003
-  6.8040226e+003
-  8.5763764e+003
-  9.3027835e+003
-  9.4178973e+003
-  8.8552093e+003
-  7.9389411e+003
-  7.5158553e+003
-  8.7700745e+003
-  7.9826577e+003
-  8.7632201e+003
-  7.4780363e+003
-  8.2100350e+003
-  9.0048657e+003
-  8.8556761e+003
-  9.0429944e+003
-  9.1620640e+003
-  9.1525854e+003
-  8.6142446e+003
-  8.5521287e+003
-  8.5319084e+003
-  7.4003934e+003
-  6.7825743e+003
-  7.1724267e+003
-  7.4660327e+003
-  6.6877976e+003
-  7.5859773e+003
-  9.2123735e+003
-  9.5149269e+003
-  9.2623814e+003
-  9.1159724e+003
-  9.2936618e+003
-  9.4038871e+003
-  7.0349421e+003
-  8.0949154e+003
-  7.5066224e+003
-  5.7406204e+003
-  5.5086134e+003
-  5.5304440e+003
-  5.8952209e+003
-  5.9899934e+003
-  6.6911446e+003
-  1.0122217e+004
-  1.1024627e+004
-  1.1579969e+004
-  1.1221878e+004
-  1.3331358e+004
-  1.2356294e+004
-  1.2052109e+004
-  1.0862029e+004
-  1.0303977e+004
-  1.0365205e+004
-  1.0359478e+004
-  1.0951119e+004
-  1.0983809e+004
-  1.0491018e+004
-  9.6035460e+003
-  7.6767401e+003
-  8.2892729e+003
-  8.2801080e+003
-  8.3342996e+003
-  8.2710579e+003
-  7.7671303e+003
-  7.7769709e+003
-  7.0797850e+003
-  7.0259542e+003
-  6.2744285e+003
-  6.2045692e+003
-  5.8443636e+003
-  6.9740070e+003
-  5.5070749e+003
-  4.6829467e+003
-  5.0816949e+003
-  3.4093937e+003
-  2.1094457e+003
-  2.0420227e+003
-  3.2283722e+003
-  4.3418792e+003
-  4.0507156e+003
-  4.1019593e+003
-  5.3344924e+003
-  2.1648101e+003
-  2.2728210e+003
-  4.3947053e+003
-  4.6767554e+003
-  5.0950169e+003
-  5.8727648e+003
-  4.3214421e+003
-  6.1234279e+002
-  1.1804406e+003
-  1.1929998e+003
-  4.1897831e+003
-  5.2370970e+003
-  5.1190211e+003
-  5.1660950e+003
-  5.4647338e+003
-  5.5155667e+003
-  6.5996263e+003
-  6.9684127e+003
-  5.6261129e+003
-  1.8381287e+003
-  0.0000000e+000
-  0.0000000e+000
-  0.0000000e+000
-  0.0000000e+000
-  5.4776100e+003
-  8.1800953e+003
-  7.4535447e+003
-  7.7761855e+003
-  7.5552787e+003
-  7.4256751e+003
-  7.6105024e+003
-  7.9168255e+003
-  8.5201799e+003
-  7.9427089e+003
-  7.4554443e+003
-  5.6157724e+003
-  6.9630792e+003
-  7.6932765e+003
-  7.3456133e+003
-  6.9729421e+003
-  7.0760439e+003
-  6.9676838e+003
-  6.5517380e+003
-  7.1909632e+003
-  7.1104170e+003
-  6.6833622e+003
-  6.4006330e+003
-  6.1337757e+003
-  6.3979589e+003
-  5.5594768e+003
-  6.3601978e+003
-  6.0498012e+003
-  6.3149615e+003
-  6.6374567e+003
-  7.4413136e+003
-  7.3576290e+003
-  6.9949594e+003
-  7.1236270e+003
-  7.6452271e+003
-  5.6925313e+003
-  6.1566268e+003
-  6.3217040e+003
-  8.0486104e+003
-  8.4958653e+003
-  9.4619897e+003
-  9.7052377e+003
-  9.1069443e+003
-  8.4658526e+003
-  7.9609607e+003
-  6.8776257e+003
-  6.4398980e+003
-  7.0934445e+003
-  8.3853568e+003
-  9.4684526e+003
-  1.0075574e+004
-  9.3185898e+003
-  8.2293815e+003
-  6.8109563e+003
-  8.0968716e+003
-  8.1219652e+003
-  6.6452039e+003
-  5.8063498e+003
-  4.3312717e+003
-  4.2182452e+003
-  7.0991009e+003
-  6.8156501e+003
-  6.9388041e+003
-  4.2453291e+003
-  3.2440046e+003
-  3.0738538e+003
-  3.2727368e+003
-  2.9425068e+003
-  2.6064224e+003
-  2.3901037e+003
-  2.4992386e+003
-  3.4849103e+003
-  5.0818266e+003
-  5.4011282e+003
-  6.1131908e+003
-  6.8600006e+003
-  7.8854328e+003
-  7.4621859e+003
-  6.3617678e+003
-  5.9848306e+003
-  6.6823063e+003
-  6.3239802e+003
-  5.7991782e+003
-  3.6498423e+003
-  2.5347859e+003
-  5.2572831e+003
-  6.0198489e+003
-  5.8484611e+003
-  6.2704238e+003
-  5.8769197e+003
-  5.3361740e+003
-  5.5285551e+003
-  5.7525642e+003
-  7.2207674e+003
-  6.4197555e+003
-  6.3724792e+003
-  3.8649419e+003
-  6.1326291e+003
-  6.0219614e+003
-  6.5016140e+003
-  6.9994260e+003
-  6.8765450e+003
-  6.6086661e+003
-  7.9010464e+003
-  7.8683424e+003
-  7.7782454e+003
-  8.5296193e+003
-  8.8206632e+003
-  8.1978418e+003
-  7.7307222e+003
-  8.0264325e+003
-  8.3835673e+003
-  8.5269342e+003
-  8.9054883e+003
-  8.3814781e+003
-  8.0928745e+003
-  7.9500547e+003
-  7.0942781e+003
-  6.4445111e+003
-  5.8863182e+003
-  2.8031650e+003
-  2.4356351e+003
-  3.9402771e+003
-  5.8025060e+003
-  7.1818275e+003
-  7.2318949e+003
-  7.9729002e+003
-  8.7035659e+003
-  9.7801719e+003
-  1.0786477e+004
-  1.1100724e+004
-  1.1519484e+004
-  1.1185413e+004
-  1.1287507e+004
-  1.2886716e+004
-  1.3071407e+004
-  1.4054179e+004
-  1.4222627e+004
-  1.4403408e+004
-  1.4442751e+004
-  1.4544456e+004
-  1.4584555e+004
-  1.4502668e+004
-  1.4592728e+004
-  1.0334188e+004
-  1.4211989e+004
-  1.4546937e+004
-  1.4455925e+004
-  1.4336482e+004
-  1.4134154e+004
-  1.3429594e+004
-  1.2326987e+004
-  1.1760410e+004
-  1.2061839e+004
-  1.2500606e+004
-  1.2245617e+004
-  8.2655803e+003
-  8.7309205e+003
-  9.1305818e+003
-  8.4128893e+003
-  6.7350017e+003
-  6.2227305e+003
-  6.2624930e+003
-  5.6653901e+003
-  5.4428207e+003
-  4.1760847e+003
-  2.0358527e+003
-  3.5722682e+003
-  1.8301911e+003
-  4.6998732e+003
-  6.8465506e+003
-  8.2619534e+003
-  8.9153791e+003
-  9.2376504e+003
-  9.2414628e+003
-  9.2391090e+003
-  9.5181399e+003
-  6.8448284e+003
-  7.2845764e+003
-  9.3930271e+003
-  7.9746440e+003
-  7.2318372e+003
-  7.4801543e+003
-  5.9752537e+003
-  5.9060442e+003
-  6.8245411e+003
-  7.5077476e+003
-  8.1376765e+003
-  8.0662850e+003
-  8.4547265e+003
-  7.7854312e+003
-  7.7538850e+003
-  5.3991422e+003
-  5.4404675e+003
-  6.3204464e+003
-  7.2593961e+003
-  7.2804696e+003
-  7.9656057e+003
-  7.2606322e+003
-  6.7078421e+003
-  4.1798043e+003
-  3.3833419e+003
-  3.8154037e+003
-  5.3286300e+003
-  7.8737472e+003
-  6.8192825e+003
-  6.7455772e+003
-  7.3959928e+003
-  9.3236225e+003
-  1.0507159e+004
-  1.0906161e+004
-  1.2232260e+004
-  1.2148698e+004
-  1.3022422e+004
-  1.1489517e+004
-  9.9359215e+003
-  8.4360144e+003
-  1.1222499e+004
-  9.7947010e+003
-  1.0395324e+004
-  1.0905962e+004
-  1.0653146e+004
-  1.0726526e+004
-  9.8016998e+003
-  1.0207280e+004
-  1.1354212e+004
-  1.1429272e+004
-  1.0483560e+004
-  1.0997644e+004
-  1.1650747e+004
-  1.1833354e+004
-  1.2315291e+004
-  1.3621037e+004
-  1.4119984e+004
-  1.4262125e+004
-  1.4206777e+004
-  1.3317693e+004
-  1.3309426e+004
-  1.3507703e+004
-  1.4075858e+004
-  1.2512776e+004
-  1.4811687e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4867827e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4823335e+004
-  1.1556068e+004
-  1.3417042e+004
-  1.4087129e+004
-  1.4168998e+004
-  1.4235831e+004
-  1.4079482e+004
-  1.4583530e+004
-  1.4858485e+004
-  1.4854364e+004
-  1.4528486e+004
-  1.4057816e+004
-  1.3011969e+004
-  9.8385404e+003
-  1.1825110e+004
-  1.2510194e+004
-  1.3536656e+004
-  1.3095381e+004
-  1.1520288e+004
-  1.2874967e+004
-  1.3019951e+004
-  1.2619576e+004
-  1.1266786e+004
-  1.0826468e+004
-  9.5982624e+003
-  6.8778831e+003
-  8.6616137e+003
-  7.6771449e+003
-  7.8008145e+003
-  7.9894875e+003
-  8.8016993e+003
-  9.4063364e+003
-  8.9377300e+003
-  7.7824054e+003
-  7.2823412e+003
-  7.0161408e+003
-  5.7601852e+003
-  7.9047308e+003
-  9.6424302e+003
-  9.6934752e+003
-  8.8286192e+003
-  8.3690940e+003
-  9.1814400e+003
-  9.3118182e+003
-  9.2434294e+003
-  8.5874078e+003
-  7.9319946e+003
-  8.9715121e+003
-  1.0204434e+004
-  5.3144578e+003
-  6.1229146e+003
-  5.4283860e+003
-  4.6520040e+003
-  5.3880605e+003
-  5.3650611e+003
-  5.8750843e+003
-  5.7096377e+003
-  5.5227528e+003
-  5.5002884e+003
-  5.5142816e+003
-  5.6307109e+003
-  6.9449320e+003
-  8.8480462e+003
-  9.8821917e+003
-  9.9156206e+003
-  1.0033452e+004
-  1.0834247e+004
-  1.0747492e+004
-  1.0175973e+004
-  9.4331453e+003
-  8.5438366e+003
-  8.3912263e+003
-  8.2878476e+003
-  4.4956714e+003
-  5.1466654e+003
-  6.2688815e+003
-  6.8308835e+003
-  6.8956086e+003
-  7.5436097e+003
-  7.5836712e+003
-  8.2025505e+003
-  9.0613333e+003
-  9.9931828e+003
-  8.7386469e+003
-  6.1763915e+003
-  5.2497803e+003
-  5.0380541e+003
-  2.9299883e+003
-  4.5879082e+003
-  4.8972300e+003
-  6.6820488e+003
-  6.8431977e+003
-  7.5871958e+003
-  7.8408747e+003
-  8.9435668e+003
-  8.3872562e+003
-  8.8040651e+003
-  8.0266848e+003
-  1.0127819e+004
-  1.1307804e+004
-  9.8327250e+003
-  1.0772157e+004
-  1.1441995e+004
-  1.2705131e+004
-  1.2487697e+004
-  1.2222480e+004
-  1.2052018e+004
-  1.2262223e+004
-  1.2465880e+004
-  8.1135460e+003
-  8.8010011e+003
-  1.0396560e+004
-  1.0933333e+004
-  1.1263575e+004
-  1.0149281e+004
-  1.0142376e+004
-  9.0366303e+003
-  8.0723367e+003
-  8.3245788e+003
-  9.2440759e+003
-  8.4529768e+003
-  7.0740447e+003
-  8.7289570e+003
-  8.7878085e+003
-  8.4808207e+003
-  8.3801839e+003
-  8.8354445e+003
-  9.6164879e+003
-  9.0760913e+003
-  1.0100582e+004
-  1.1383009e+004
-  1.1212801e+004
-  1.2134560e+004
-  8.9347836e+003
-  1.1142941e+004
-  1.3322105e+004
-  1.3551012e+004
-  1.3310149e+004
-  1.4010992e+004
-  1.4021666e+004
-  1.4104404e+004
-  1.3763623e+004
-  1.3247540e+004
-  1.3660137e+004
-  1.3889468e+004
-  1.1294418e+004
-  1.2103737e+004
-  1.4395596e+004
-  1.4629684e+004
-  1.4967872e+004
-  1.5000000e+004
-  1.4623302e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4865756e+004
-  1.4891453e+004
-  1.4620953e+004
-  1.1784641e+004
-  1.4588375e+004
-  1.4286414e+004
-  1.4412371e+004
-  1.4033645e+004
-  1.3401735e+004
-  1.3238423e+004
-  1.2542659e+004
-  1.3512386e+004
-  1.4172996e+004
-  1.4748230e+004
-  1.4949178e+004
-  1.1875865e+004
-  1.4895319e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4853666e+004
-  1.4718655e+004
-  1.4692975e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4802535e+004
-  1.3272526e+004
-  1.3692940e+004
-  1.2242988e+004
-  1.4355671e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4414343e+004
-  1.4341184e+004
-  1.5000000e+004
-  1.4685462e+004
-  1.4599022e+004
-  1.4537431e+004
-  1.4559949e+004
-  1.4551811e+004
-  1.3884032e+004
-  1.4603349e+004
-  1.4115257e+004
-  1.4106073e+004
-  1.4140307e+004
-  1.2973570e+004
-  1.3411626e+004
-  1.3665887e+004
-  1.3700611e+004
-  1.3043086e+004
-  1.1805899e+004
-  9.9131107e+003
-  7.4991295e+003
-  6.8132153e+003
-  4.6794405e+003
-  1.9823224e+002
-  6.2965908e+002
-  4.8531320e+003
-  6.5759814e+003
-  7.7801119e+003
-  8.3046726e+003
-  8.4287226e+003
-  9.0399325e+003
-  9.9251611e+003
-  9.5085475e+003
-  9.9040034e+003
-  9.8367973e+003
-  9.4694639e+003
-  1.0925941e+004
-  1.2060486e+004
-  1.2308514e+004
-  1.2500359e+004
-  1.2491119e+004
-  1.2346487e+004
-  1.1391662e+004
-  1.0806994e+004
-  9.0756405e+003
-  9.0416329e+003
-  7.7871365e+003
-  6.8184074e+003
-  5.9365681e+003
-  6.1782070e+003
-  7.3528925e+003
-  1.1042672e+004
-  1.1880352e+004
-  1.1504791e+004
-  1.0785477e+004
-  1.0700104e+004
-  1.0131450e+004
-  1.2199688e+004
-  1.1980281e+004
-  1.0571114e+004
-  1.0281845e+004
-  1.0297735e+004
-  1.1128600e+004
-  1.1694741e+004
-  1.1884568e+004
-  1.2722472e+004
-  1.2395753e+004
-  1.3329513e+004
-  1.0656431e+004
-  1.3118487e+004
-  1.2145510e+004
-  1.2612328e+004
-  1.1789607e+004
-  1.0845578e+004
-  9.9575331e+003
-  9.0284838e+003
-  8.1174937e+003
-  7.2917601e+003
-  6.1150027e+003
-  5.2875798e+003
-  3.7187808e+003
-  1.8878923e+003
-  0.0000000e+000
-  2.6353629e+003
-  5.1195240e+003
-  6.3532473e+003
-  7.4359613e+003
-  8.2783813e+003
-  8.7127947e+003
-  9.3210671e+003
-  1.0418584e+004
-  1.0730893e+004
-  9.9346252e+003
-  1.0895413e+004
-  1.1234775e+004
-  1.1816047e+004
-  1.1716867e+004
-  1.2109045e+004
-  1.1776069e+004
-  1.0462066e+004
-  9.1852810e+003
-  8.1221290e+003
-  7.0134665e+003
-  4.9225654e+003
-  6.0855393e+003
-  8.1815508e+003
-  1.0353301e+004
-  1.0356309e+004
-  1.0784069e+004
-  1.1356969e+004
-  1.2627577e+004
-  1.2727905e+004
-  1.3313116e+004
-  1.2733812e+004
-  1.1776632e+004
-  1.1623052e+004
-  7.5770686e+003
-  9.2204548e+003
-  9.4619889e+003
-  9.0626182e+003
-  7.7922636e+003
-  6.6181763e+003
-  6.3208759e+003
-  6.2892103e+003
-  6.2343793e+003
-  5.6255002e+003
-  6.2588468e+003
-  5.6078262e+003
-  4.1708612e+003
-  5.5244542e+003
-  6.2289131e+003
-  6.2951739e+003
-  5.8751219e+003
-  7.2790609e+003
-  7.9316271e+003
-  8.4277355e+003
-  9.1067280e+003
-  9.7450270e+003
-  1.0807030e+004
-  1.1721592e+004
-  9.6146068e+003
-  1.0640881e+004
-  1.0851923e+004
-  1.1651608e+004
-  1.2517318e+004
-  1.3473528e+004
-  1.3382612e+004
-  1.3537044e+004
-  1.3614426e+004
-  1.3681931e+004
-  1.3911280e+004
-  1.4062071e+004
-  1.0821924e+004
-  1.4125654e+004
-  1.4151468e+004
-  1.4286110e+004
-  1.4173656e+004
-  1.4618062e+004
-  1.4503884e+004
-  1.4686577e+004
-  1.4628925e+004
-  1.4588656e+004
-  1.4673029e+004
-  1.4784433e+004
-  1.2252563e+004
-  1.4810115e+004
-  1.4728487e+004
-  1.4620800e+004
-  1.4325483e+004
-  1.4220812e+004
-  1.4304914e+004
-  1.3941514e+004
-  1.2650455e+004
-  1.2320906e+004
-  1.1842037e+004
-  1.0765490e+004
-  9.3810669e+003
-  7.9973356e+003
-  8.2197087e+003
-  9.3693315e+003
-  8.6204755e+003
-  8.8787996e+003
-  9.0276740e+003
-  8.9857178e+003
-  8.6367811e+003
-  7.5960597e+003
-  7.1373715e+003
-  6.0213223e+003
-  4.9606339e+003
-  2.0251961e+003
-  3.2233065e+003
-  1.6992731e+003
-  3.1912470e+003
-  4.5050657e+003
-  5.3506785e+003
-  6.7241904e+003
-  8.8993623e+003
-  1.0011600e+004
-  1.0833658e+004
-  1.1182707e+004
-  1.0399275e+004
-  1.0574507e+004
-  1.1152425e+004
-  1.0935680e+004
-  1.0317606e+004
-  1.0826712e+004
-  1.0715578e+004
-  9.6744369e+003
-  1.1095373e+004
-  1.2787674e+004
-  1.2219585e+004
-  1.1742696e+004
-  8.8870302e+003
-  1.2192333e+004
-  1.2361145e+004
-  1.1842017e+004
-  1.1955942e+004
-  1.1433316e+004
-  1.0266510e+004
-  9.5703957e+003
-  9.6174630e+003
-  9.7612734e+003
-  9.6515392e+003
-  1.0007616e+004
-  7.7612534e+003
-  8.3035449e+003
-  8.9049017e+003
-  7.5842812e+003
-  6.2487320e+003
-  5.6785973e+003
-  6.2410254e+003
-  6.2044892e+003
-  6.1865979e+003
-  5.6246744e+003
-  4.9114881e+003
-  5.1630116e+003
-  7.7873136e+003
-  7.5224850e+003
-  7.1171818e+003
-  8.3823642e+003
-  8.3840973e+003
-  8.4598232e+003
-  8.6088400e+003
-  8.2343045e+003
-  8.2475222e+003
-  8.4276597e+003
-  8.8854238e+003
-  9.4218736e+003
-  6.9783476e+003
-  7.0176553e+003
-  7.6935227e+003
-  7.8321128e+003
-  8.1217139e+003
-  5.9977112e+003
-  6.3403458e+003
-  6.8605886e+003
-  6.7188709e+003
-  6.2680774e+003
-  6.5573511e+003
-  7.1927024e+003
-  6.4824031e+003
-  7.8562382e+003
-  8.0599809e+003
-  8.5368191e+003
-  7.9897591e+003
-  8.3682930e+003
-  8.8611666e+003
-  8.3085342e+003
-  8.3245558e+003
-  7.9686390e+003
-  8.1487728e+003
-  7.8398278e+003
-  8.4654749e+003
-  8.4643540e+003
-  7.9403524e+003
-  7.8457254e+003
-  8.1367199e+003
-  7.8860161e+003
-  9.2751191e+003
-  9.9976158e+003
-  1.0330024e+004
-  1.0892778e+004
-  1.0629697e+004
-  1.0700399e+004
-  8.9128977e+003
-  9.2639283e+003
-  9.6032591e+003
-  1.0917082e+004
-  1.1492970e+004
-  1.2646978e+004
-  1.2826383e+004
-  1.3291833e+004
-  1.3820755e+004
-  1.3808865e+004
-  1.3432736e+004
-  1.3353035e+004
-  1.4027808e+004
-  1.4387238e+004
-  1.4104953e+004
-  1.4136789e+004
-  1.4067905e+004
-  1.4207896e+004
-  1.4034042e+004
-  1.4133785e+004
-  1.4410175e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4940238e+004
-  1.2718204e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4922235e+004
-  1.4616712e+004
-  1.4449723e+004
-  1.4174409e+004
-  1.3320212e+004
-  1.3657265e+004
-  1.3582301e+004
-  1.2496910e+004
-  1.1859223e+004
-  1.0152449e+004
-  1.2723281e+004
-  1.2675245e+004
-  1.2751640e+004
-  1.2435756e+004
-  1.2632841e+004
-  1.2757560e+004
-  1.2025055e+004
-  1.0946839e+004
-  1.0406643e+004
-  9.5467677e+003
-  8.2489435e+003
-  8.1835940e+003
-  1.0046730e+004
-  1.0000027e+004
-  8.4541262e+003
-  7.1049530e+003
-  6.2915147e+003
-  7.2411477e+003
-  8.0121166e+003
-  8.1454782e+003
-  7.4781379e+003
-  7.7620821e+003
-  8.8870823e+003
-  5.6594602e+003
-  6.9996298e+003
-  7.6000931e+003
-  8.3545882e+003
-  8.5272729e+003
-  1.0431292e+004
-  1.0885185e+004
-  1.0819912e+004
-  1.1467976e+004
-  1.1745796e+004
-  1.0283164e+004
-  1.0181007e+004
-  6.7818400e+003
-  8.5494268e+003
-  9.5238453e+003
-  9.0662438e+003
-  9.0180732e+003
-  9.2270320e+003
-  9.6859774e+003
-  9.9164793e+003
-  9.5317936e+003
-  8.7221920e+003
-  7.8512347e+003
-  7.2898235e+003
-  6.7492205e+003
-  5.6880052e+003
-  6.3508833e+003
-  5.5409463e+003
-  4.4627936e+003
-  4.4778260e+003
-  5.0426947e+003
-  4.9808647e+003
-  3.3684808e+003
-  5.1537654e+003
-  5.9260481e+003
-  7.2579928e+003
-  6.3989463e+003
-  6.4496612e+003
-  6.8836099e+003
-  7.6740454e+003
-  7.7629658e+003
-  7.9867851e+003
-  8.3486878e+003
-  8.4462219e+003
-  7.9024098e+003
-  7.9810279e+003
-  7.9940842e+003
-  8.0718303e+003
-  6.2196168e+003
-  6.8664702e+003
-  7.9234127e+003
-  8.8856314e+003
-  7.6563791e+003
-  8.7470152e+003
-  1.0288779e+004
-  1.0685573e+004
-  1.0193268e+004
-  9.9524226e+003
-  9.9518596e+003
-  9.9782388e+003
-  8.4927817e+003
-  1.0485659e+004
-  1.2139918e+004
-  1.1488226e+004
-  1.1693826e+004
-  1.1450334e+004
-  1.1707138e+004
-  1.1472874e+004
-  1.1046821e+004
-  1.0988219e+004
-  1.0266586e+004
-  9.5012927e+003
-  1.0525125e+004
-  1.0643669e+004
-  1.1772746e+004
-  1.1264066e+004
-  1.0535157e+004
-  1.0575322e+004
-  1.0263374e+004
-  1.0238810e+004
-  1.0364559e+004
-  1.1177416e+004
-  1.1306058e+004
-  1.1099297e+004
-  9.0592327e+003
-  1.0913017e+004
-  1.1070730e+004
-  1.0601287e+004
-  9.7067147e+003
-  8.2404809e+003
-  7.9272085e+003
-  8.3657110e+003
-  7.9955623e+003
-  7.6907269e+003
-  8.2667200e+003
-  8.9488888e+003
-  8.2271937e+003
-  8.8478152e+003
-  9.6570623e+003
-  1.0383155e+004
-  9.9699347e+003
-  9.3187616e+003
-  9.0646578e+003
-  9.4499136e+003
-  9.8932764e+003
-  9.4027845e+003
-  8.4209375e+003
-  8.3851623e+003
-  6.4781754e+003
-  6.2488606e+003
-  6.3032680e+003
-  7.0174331e+003
-  7.5251108e+003
-  7.8357363e+003
-  8.4807872e+003
-  6.9745611e+003
-  5.4510584e+003
-  3.1569579e+003
-  1.9581557e+003
-  0.0000000e+000
-  4.1361609e+003
-  2.1622807e+003
-  2.1973831e+003
-  3.8776383e+003
-  3.4827115e+003
-  1.5692641e+003
-  4.4365857e+003
-  5.3216632e+003
-  5.1580715e+003
-  5.5886359e+003
-  4.7856576e+003
-  4.6019656e+003
-  5.3837013e+003
-  5.8026190e+003
-  5.4042069e+003
-  6.0251994e+003
-  6.5403587e+003
-  6.5027559e+003
-  6.6719144e+003
-  6.0726101e+003
-  5.2372376e+003
-  4.4800352e+003
-  3.9911030e+003
-  5.7004603e+003
-  6.9833864e+003
-  5.9965623e+003
-  5.2337832e+003
-  5.5980423e+003
-  4.5043840e+003
-  5.6284706e+003
-  7.0152064e+003
-  8.2758979e+003
-  8.1873050e+003
-  7.5664604e+003
-  7.1198067e+003
-  6.6165636e+003
-  5.9673113e+003
-  5.4207125e+003
-  3.8522297e+003
-  2.8145002e+003
-  3.3736327e+003
-  5.9505896e+003
-  6.4316213e+003
-  6.9096980e+003
-  7.4753270e+003
-  7.0954315e+003
-  7.6634242e+003
-  7.6494835e+003
-  8.8269527e+003
-  8.1969882e+003
-  8.8447985e+003
-  9.4840747e+003
-  9.5967282e+003
-  8.8663561e+003
-  9.3218328e+003
-  9.5963247e+003
-  1.1362314e+004
-  1.1525552e+004
-  1.3334699e+004
-  1.3548153e+004
-  8.1934758e+003
-  1.1507558e+004
-  1.2468513e+004
-  1.3237703e+004
-  1.3620296e+004
-  1.4199941e+004
-  1.3272316e+004
-  1.3085348e+004
-  1.2220774e+004
-  1.0700335e+004
-  1.2340356e+004
-  1.1376885e+004
-  1.0465304e+004
-  1.1367084e+004
-  1.2271068e+004
-  1.1792266e+004
-  1.1495788e+004
-  1.2385901e+004
-  1.2931141e+004
-  1.3207900e+004
-  1.2086631e+004
-  1.2476402e+004
-  1.2632056e+004
-  1.2407289e+004
-  1.0719221e+004
-  1.2866402e+004
-  1.2833877e+004
-  1.1980885e+004
-  1.1995089e+004
-  1.3270733e+004
-  1.4124120e+004
-  1.3988345e+004
-  1.2367008e+004
-  1.1293875e+004
-  1.1303024e+004
-  1.0031057e+004
-  9.3351698e+003
-  9.8501488e+003
-  9.9037710e+003
-  8.2365539e+003
-  8.1877232e+003
-  8.7060416e+003
-  9.7142189e+003
-  9.9187846e+003
-  1.0400487e+004
-  1.0631118e+004
-  1.0647037e+004
-  9.7660250e+003
-  7.6360388e+003
-  9.2086962e+003
-  1.0544309e+004
-  9.5429184e+003
-  9.6418384e+003
-  9.3524162e+003
-  1.0067624e+004
-  1.0069148e+004
-  9.8313546e+003
-  8.5050244e+003
-  8.2247991e+003
-  7.6364324e+003
-  8.7839250e+003
-  9.7247523e+003
-  1.0412423e+004
-  1.0176744e+004
-  9.4436136e+003
-  1.0392367e+004
-  8.1571148e+003
-  8.2925115e+003
-  7.2755936e+003
-  6.1263830e+003
-  7.9962540e+003
-  9.0865979e+003
-  6.8667200e+003
-  7.3811132e+003
-  7.9762261e+003
-  7.2080326e+003
-  7.4286902e+003
-  8.6522583e+003
-  8.9122617e+003
-  8.6372205e+003
-  6.7640870e+003
-  8.4705275e+003
-  1.0049812e+004
-  1.0254002e+004
-  9.1283484e+003
-  8.2060875e+003
-  8.4081139e+003
-  1.0608388e+004
-  1.0671249e+004
-  1.1785592e+004
-  1.2096886e+004
-  1.2077758e+004
-  1.3188593e+004
-  1.3379630e+004
-  1.4364724e+004
-  1.4730658e+004
-  1.2850476e+004
-  1.4984018e+004
-  1.4723322e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4961506e+004
-  1.4905479e+004
-  1.4836107e+004
-  1.4896295e+004
-  1.4789047e+004
-  1.4599403e+004
-  1.2606663e+004
-  1.4316576e+004
-  1.4617536e+004
-  1.4052037e+004
-  1.4067355e+004
-  1.3315640e+004
-  1.2026114e+004
-  1.1058062e+004
-  1.1812421e+004
-  1.1369317e+004
-  1.0155953e+004
-  9.4705645e+003
-  8.2681861e+003
-  8.7932317e+003
-  8.4022172e+003
-  7.1561565e+003
-  6.4141078e+003
-  6.0687719e+003
-  4.5991697e+003
-  3.6721879e+003
-  4.0250027e+003
-  3.5355895e+003
-  4.2863135e+003
-  5.7726998e+003
-  3.4543634e+003
-  6.1282939e+003
-  6.4295839e+003
-  7.6161846e+003
-  7.0481479e+003
-  7.9064700e+003
-  8.7447786e+003
-  9.2819045e+003
-  9.7037519e+003
-  9.7105788e+003
-  9.3318068e+003
-  9.7694690e+003
-  8.7550488e+003
-  8.7268760e+003
-  8.9168627e+003
-  8.9174942e+003
-  8.3993095e+003
-  8.3170976e+003
-  8.1747617e+003
-  7.5471645e+003
-  6.9103981e+003
-  6.1242050e+003
-  6.2065964e+003
-  6.5763785e+003
-  5.0285396e+003
-  2.1729596e+003
-  9.6468707e+002
-  5.8891797e+002
-  0.0000000e+000
-  0.0000000e+000
-  0.0000000e+000
-  2.9955456e+003
-  5.8815407e+003
-  6.9207737e+003
-  6.9781408e+003
-  7.5562398e+003
-  7.3091159e+003
-  8.1595196e+003
-  8.7499659e+003
-  8.2375036e+003
-  8.2734150e+003
-  8.4853271e+003
-  9.5687654e+003
-  1.0673308e+004
-  1.0150519e+004
-  1.0474492e+004
-  1.0527526e+004
-  1.0866457e+004
-  8.4985254e+003
-  1.2016135e+004
-  1.1833896e+004
-  1.1475508e+004
-  1.0824698e+004
-  1.2081122e+004
-  1.3150616e+004
-  1.2930457e+004
-  1.2685177e+004
-  1.1910429e+004
-  1.1504104e+004
-  1.1891623e+004
-  8.1937017e+003
-  9.1861685e+003
-  7.6695567e+003
-  6.3901822e+003
-  6.2345339e+003
-  6.7983982e+003
-  7.2913670e+003
-  7.5137339e+003
-  7.4296602e+003
-  6.9808140e+003
-  6.5265951e+003
-  6.8322154e+003
-  7.4606780e+003
-  8.2442046e+003
-  9.6940577e+003
-  1.0201618e+004
-  9.4767404e+003
-  9.4781196e+003
-  1.0059078e+004
-  1.1103791e+004
-  1.1610210e+004
-  1.1715099e+004
-  1.2305306e+004
-  1.2846171e+004
-  1.1126415e+004
-  1.3280540e+004
-  1.2138000e+004
-  1.1645108e+004
-  1.0097359e+004
-  8.9867809e+003
-  8.3078091e+003
-  7.3198606e+003
-  7.6184490e+003
-  8.1279724e+003
-  8.4491918e+003
-  9.0588419e+003
-  6.4728071e+003
-  6.7957448e+003
-  6.8198674e+003
-  7.0263385e+003
-  6.6966588e+003
-  7.2377898e+003
-  8.4875808e+003
-  8.6020818e+003
-  9.8731001e+003
-  9.6379546e+003
-  9.3144768e+003
-  9.1017257e+003
-  6.7035182e+003
-  7.2354796e+003
-  1.0080525e+004
-  1.1774817e+004
-  1.3366058e+004
-  1.3062401e+004
-  1.2058036e+004
-  1.0937884e+004
-  1.1100433e+004
-  1.0946695e+004
-  1.1066259e+004
-  1.1843795e+004
-  8.9862379e+003
-  1.0957139e+004
-  1.1223407e+004
-  1.1340532e+004
-  1.1731978e+004
-  1.2163871e+004
-  1.3020081e+004
-  1.3389849e+004
-  1.3305756e+004
-  1.2612009e+004
-  1.2859894e+004
-  1.2583202e+004
-  9.2096540e+003
-  1.1523719e+004
-  1.1821795e+004
-  1.1379864e+004
-  1.2273141e+004
-  1.1627550e+004
-  1.1105007e+004
-  1.0446525e+004
-  1.0530605e+004
-  1.0769622e+004
-  1.0794506e+004
-  9.6961177e+003
-  6.5992768e+003
-  6.8393081e+003
-  7.4969232e+003
-  7.6221348e+003
-  8.4338777e+003
-  9.1497322e+003
-  9.9651156e+003
-  1.0229916e+004
-  1.0424314e+004
-  1.0371634e+004
-  1.0825729e+004
-  1.1741721e+004
-  9.3508150e+003
-  1.1715560e+004
-  1.0439883e+004
-  1.1118577e+004
-  1.1796279e+004
-  1.2243624e+004
-  1.1456869e+004
-  1.1132808e+004
-  1.0756835e+004
-  1.0284278e+004
-  9.8459938e+003
-  9.6277061e+003
-  8.1001721e+003
-  8.8634695e+003
-  9.7920796e+003
-  1.0154686e+004
-  1.0992151e+004
-  1.0094231e+004
-  9.8579314e+003
-  9.8526067e+003
-  1.0276526e+004
-  9.3266332e+003
-  8.5841083e+003
-  8.8421805e+003
-  9.6316486e+003
-  9.7904155e+003
-  1.0432630e+004
-  1.0817028e+004
-  1.0542244e+004
-  1.0249457e+004
-  9.5140570e+003
-  8.7435717e+003
-  8.7497927e+003
-  8.7831897e+003
-  8.7049529e+003
-  8.0628457e+003
-  7.0360671e+003
-  8.1396566e+003
-  7.7644194e+003
-  8.7971831e+003
-  8.9114182e+003
-  9.3327653e+003
-  9.8615082e+003
-  1.0097022e+004
-  9.4708197e+003
-  8.4409194e+003
-  7.7953777e+003
-  8.1808153e+003
-  6.7629218e+003
-  6.2199216e+003
-  5.1283727e+003
-  3.3393389e+003
-  8.8887754e+002
-  0.0000000e+000
-  0.0000000e+000
-  4.8360458e+002
-  4.5301439e+003
-  6.8613899e+003
-  8.3216931e+003
-  8.9978785e+003
-  8.1505786e+003
-  8.8262728e+003
-  9.4902688e+003
-  9.2232027e+003
-  9.1329966e+003
-  8.6481879e+003
-  8.6992312e+003
-  8.1410475e+003
-  7.4783403e+003
-  7.2672574e+003
-  6.9964605e+003
-  8.2045212e+003
-  8.6188153e+003
-  9.2879649e+003
-  9.6800031e+003
-  8.8242201e+003
-  9.3919228e+003
-  9.1541994e+003
-  8.9368869e+003
-  8.8663711e+003
-  8.8637237e+003
-  1.0358561e+004
-  1.0679750e+004
-  9.8509788e+003
-  7.8335861e+003
-  8.9938577e+003
-  9.0954655e+003
-  8.8174609e+003
-  9.1541933e+003
-  9.0907840e+003
-  8.6601509e+003
-  7.8282473e+003
-  7.3958913e+003
-  7.1758793e+003
-  6.7362010e+003
-  6.0320283e+003
-  3.1097025e+003
-  5.1605822e+003
-  4.5721668e+003
-  5.0344872e+003
-  6.4508479e+003
-  6.9148480e+003
-  6.7113728e+003
-  6.4727297e+003
-  6.1835343e+003
-  5.9823431e+003
-  6.5574710e+003
-  7.0343944e+003
-  6.8192733e+003
-  8.0025942e+003
-  8.7662442e+003
-  9.0243644e+003
-  9.1820604e+003
-  9.6583570e+003
-  1.0550306e+004
-  1.1225924e+004
-  1.1415506e+004
-  1.1499066e+004
-  1.2873280e+004
-  1.4217651e+004
-  1.4028468e+004
-  1.4827162e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.1703600e+004
-  1.3809439e+004
-  1.4130240e+004
-  1.3941559e+004
-  1.3555537e+004
-  1.4003123e+004
-  1.4011376e+004
-  1.4014546e+004
-  1.3863351e+004
-  1.3838598e+004
-  1.3368868e+004
-  1.2754049e+004
-  8.7494374e+003
-  1.0847553e+004
-  1.0870989e+004
-  1.0570287e+004
-  1.0772084e+004
-  1.1126820e+004
-  1.1368669e+004
-  1.2276198e+004
-  1.1134128e+004
-  1.2099371e+004
-  1.2014335e+004
-  1.2664943e+004
-  1.0252912e+004
-  1.4040026e+004
-  1.4298735e+004
-  1.4251431e+004
-  1.4323999e+004
-  1.4158562e+004
-  1.3378844e+004
-  1.2500144e+004
-  1.1979175e+004
-  1.1219153e+004
-  9.7814032e+003
-  8.7403902e+003
-  7.2926161e+003
-  6.5947065e+003
-  6.1163001e+003
-  6.4892988e+003
-  6.3350131e+003
-  5.7185015e+003
-  6.2740702e+003
-  6.3811268e+003
-  6.8367820e+003
-  6.8219511e+003
-  7.3524658e+003
-  7.8586939e+003
-  8.2212175e+003
-  8.4121312e+003
-  8.4145047e+003
-  8.9618037e+003
-  9.9811505e+003
-  1.0064305e+004
-  1.0365332e+004
-  1.0820447e+004
-  1.0481384e+004
-  1.0813482e+004
-  1.1624816e+004
-  1.1342820e+004
-  1.1740587e+004
-  9.4637925e+003
-  1.0721595e+004
-  1.1262185e+004
-  9.1741819e+003
-  9.7944427e+003
-  1.0006041e+004
-  1.0895648e+004
-  1.0787664e+004
-  1.1883270e+004
-  1.3137309e+004
-  1.2246955e+004
-  9.3195923e+003
-  1.1442503e+004
-  1.1561216e+004
-  8.7571380e+003
-  7.0314465e+003
-  5.7975115e+003
-  6.1673775e+003
-  6.3803548e+003
-  6.7330141e+003
-  7.2316942e+003
-  8.8556598e+003
-  9.9826608e+003
-  7.1568118e+003
-  7.7579420e+003
-  8.2825238e+003
-  9.4256578e+003
-  8.5604542e+003
-  7.7292329e+003
-  7.0894812e+003
-  6.1563469e+003
-  6.2621843e+003
-  7.4636487e+003
-  7.3151418e+003
-  7.2637823e+003
-  8.3902280e+003
-  9.3544348e+003
-  1.0241565e+004
-  9.6909043e+003
-  1.0729626e+004
-  9.4570092e+003
-  9.5437564e+003
-  8.1031195e+003
-  7.8905012e+003
-  8.9203080e+003
-  8.8224632e+003
-  1.0109554e+004
-  9.7302707e+003
-  1.1830709e+004
-  1.2153244e+004
-  1.3317954e+004
-  1.3693128e+004
-  1.4393790e+004
-  1.4444875e+004
-  1.4517855e+004
-  1.4665332e+004
-  1.4489033e+004
-  1.4199576e+004
-  1.3266151e+004
-  1.1752882e+004
-  1.2748247e+004
-  1.2911859e+004
-  1.2143087e+004
-  1.2226110e+004
-  1.2613103e+004
-  1.1616002e+004
-  1.0870676e+004
-  1.0486755e+004
-  1.1157880e+004
-  1.1188622e+004
-  1.0602125e+004
-  1.0338139e+004
-  1.1913235e+004
-  1.2067774e+004
-  1.2107985e+004
-  1.2099986e+004
-  1.0846354e+004
-  1.0577616e+004
-  1.0394067e+004
-  1.1023946e+004
-  1.0766400e+004
-  9.5689698e+003
-  8.8559422e+003
-  6.9918654e+003
-  6.9387704e+003
-  6.7037375e+003
-  6.1689638e+003
-  6.3645941e+003
-  6.1152664e+003
-  5.9813192e+003
-  5.5421437e+003
-  6.1669290e+003
-  7.6526330e+003
-  9.1337777e+003
-  1.0089135e+004
-  9.4533359e+003
-  8.8552893e+003
-  9.3505003e+003
-  8.0424792e+003
-  8.4926750e+003
-  8.1740595e+003
-  7.5840074e+003
-  7.9379792e+003
-  7.8730491e+003
-  7.2658867e+003
-  6.4560034e+003
-  6.3920533e+003
-  5.2324499e+003
-  6.9571298e+003
-  7.1218523e+003
-  7.6627410e+003
-  7.8576139e+003
-  7.1514743e+003
-  6.9253850e+003
-  6.7103714e+003
-  6.7553730e+003
-  7.2774352e+003
-  7.1694017e+003
-  8.2030791e+003
-  8.1626441e+003
-  8.2055416e+003
-  7.8405581e+003
-  7.7634046e+003
-  8.3429194e+003
-  7.2842556e+003
-  6.5048361e+003
-  5.8830421e+003
-  5.9515169e+003
-  5.0519174e+003
-  3.6266518e+003
-  3.6239845e+003
-  5.3111137e+003
-  5.8364330e+003
-  7.0492798e+003
-  6.9505260e+003
-  6.5972883e+003
-  6.2043409e+003
-  7.3406386e+003
-  7.4697800e+003
-  6.6336917e+003
-  6.3560296e+003
-  6.8747105e+003
-  7.2586838e+003
-  5.6507618e+003
-  5.5364460e+003
-  6.5221528e+003
-  6.7980852e+003
-  6.5531339e+003
-  6.0596823e+003
-  5.0947957e+003
-  5.0510786e+003
-  5.6177765e+003
-  6.0390833e+003
-  6.4766888e+003
-  7.2429973e+003
-  7.1270059e+003
-  7.5706741e+003
-  9.1528855e+003
-  1.0278827e+004
-  9.9261362e+003
-  9.4376097e+003
-  8.4871343e+003
-  7.9123192e+003
-  8.0345550e+003
-  9.7293659e+003
-  1.0096585e+004
-  9.7864746e+003
-  7.7825390e+003
-  7.6814826e+003
-  8.2674284e+003
-  8.9266038e+003
-  9.0746692e+003
-  8.5442182e+003
-  8.3506215e+003
-  8.1510291e+003
-  8.1636070e+003
-  7.7765691e+003
-  7.2268307e+003
-  6.6937740e+003
-  5.5167300e+003
-  6.2409802e+003
-  6.4174921e+003
-  5.2713486e+003
-  3.8863184e+003
-  8.2659032e+001
-  1.5890210e+002
-  4.5208973e+003
-  5.5057891e+003
-  6.1988629e+003
-  6.2511919e+003
-  6.0507334e+003
-  6.6346265e+003
-  6.9009708e+003
-  7.4838811e+003
-  6.7797713e+003
-  6.7505008e+003
-  6.6481965e+003
-  6.0139479e+003
-  5.2906993e+003
-  3.7620722e+003
-  2.8596057e+003
-  1.8834228e+003
-  3.3565102e+003
-  2.8757731e+002
-  2.9799645e+003
-  2.7825702e+003
-  5.2657561e+003
-  6.0255571e+003
-  5.5676304e+003
-  5.7391395e+003
-  5.7511047e+003
-  5.3763780e+003
-  5.7204045e+003
-  6.1185761e+003
-  6.9954768e+003
-  5.9093653e+003
-  5.0862762e+003
-  1.8183489e+003
-  3.0705794e+003
-  2.6084604e+003
-  3.7137336e+003
-  4.9215512e+003
-  4.0920101e+003
-  3.7668166e+003
-  3.1356594e+003
-  1.8926704e+003
-  3.0574233e+003
-  4.1764733e+003
-  5.8626431e+003
-  7.6043353e+003
-  8.4165993e+003
-  9.0816317e+003
-  9.8344583e+003
-  1.0249931e+004
-  1.0303469e+004
-  1.0636419e+004
-  1.1351723e+004
-  1.1230485e+004
-  1.0959601e+004
-  9.4192105e+003
-  1.2026964e+004
-  1.2396320e+004
-  1.2933653e+004
-  1.3204015e+004
-  1.3301412e+004
-  1.2939778e+004
-  1.2613446e+004
-  1.2051031e+004
-  1.1649087e+004
-  1.2871084e+004
-  1.3015694e+004
-  1.0044640e+004
-  1.3092703e+004
-  1.3494530e+004
-  1.3603892e+004
-  1.3986177e+004
-  1.4235129e+004
-  1.4083700e+004
-  1.4044218e+004
-  1.4040194e+004
-  1.3851744e+004
-  1.3329832e+004
-  1.3297219e+004
-  1.2414261e+004
-  1.4320152e+004
-  1.4699493e+004
-  1.4401055e+004
-  1.4730959e+004
-  1.4948897e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4145817e+004
-  1.4936071e+004
-  1.4995060e+004
-  1.5000000e+004
-  1.5000000e+004
-  1.4987099e+004
-  1.4808753e+004
-  1.4372910e+004
-  1.4189271e+004
-  1.3286968e+004
-  1.2578629e+004
-  1.1788479e+004
-  7.3866594e+003
-  8.2360516e+003
-  8.0231207e+003
-  9.0101810e+003
-  8.6523929e+003
-  8.9970225e+003
-  9.0536483e+003
-  9.6593325e+003
-  1.0202091e+004
-  1.1052202e+004
-  1.0329222e+004
-  1.0863809e+004
-  6.9227114e+003
-  1.0062115e+004
-  1.1384535e+004
-  1.2248356e+004
-  1.2935084e+004
-  1.2222968e+004
-  1.2013331e+004
-  1.1459208e+004
-  1.1724537e+004
-  1.1560507e+004
-  1.2708470e+004
-  1.4005176e+004
-  1.2689722e+004
-  1.4688497e+004
-  1.5000000e+004
-  1.4878740e+004
-  1.4904220e+004
-  1.4407671e+004
-  1.4295174e+004
-  1.4327414e+004
-  1.4132944e+004
-  1.4371335e+004
-  1.4364555e+004
-  1.4183109e+004
-  9.2753222e+003
-  1.1466913e+004
-  9.4138163e+003
-  9.8752098e+003
-  8.8095095e+003
-  9.2966746e+003
-  8.2091595e+003
-  7.8979952e+003
-  7.3221497e+003
-  6.9919695e+003
-  7.0668830e+003
-  6.1203090e+003
-  5.8040369e+003
-  5.6700062e+003
-  5.6160506e+003
-  6.3435073e+003
-  6.4889347e+003
-  6.3405873e+003
-  6.3700074e+003
-  5.7910466e+003
-  5.8485272e+003
-  6.8462642e+003
-  6.8803586e+003
-  8.1586741e+003
-  5.8493850e+003
-  5.4484592e+003
-  6.1277692e+003
-  6.8770244e+003
-  7.0062926e+003
-  6.6084435e+003
-  7.0887198e+003
-  7.9520997e+003
-  8.0155114e+003
-  8.6635010e+003
-  9.9807829e+003
-  1.0785841e+004
-  6.6340975e+003
-  8.1283461e+003
-  9.8179592e+003
-  1.0756762e+004
-  1.0296159e+004
-  1.0573318e+004
-  1.0729068e+004
-  9.9593970e+003
-  9.5174493e+003
-  9.3200381e+003
-  1.0666613e+004
-  1.0964625e+004
-  9.8860632e+003
-  1.1319071e+004
-  1.2509703e+004
-  1.2661196e+004
-  1.3328256e+004
-  1.3297630e+004
-  1.3155342e+004
-  1.3450837e+004
-  1.3504028e+004
-  1.3903319e+004
-  1.4118087e+004
-  1.4315980e+004
-  1.4001304e+004
-  1.4146675e+004
-  1.4275379e+004
-  1.4363251e+004
-  1.4286439e+004
-  1.4287179e+004
-  1.4295394e+004
-  1.4115738e+004
-  1.3707113e+004
-  1.3210478e+004
-  1.2512895e+004
-  1.2633922e+004
-  1.2125882e+004
-  1.2740344e+004
-  1.0953583e+004
-  9.5622254e+003
-  8.5113293e+003
-  8.0084280e+003
-  7.9704872e+003
-  6.2140435e+003
-  5.5391930e+003
-  5.3799182e+003
-  4.3642110e+003
-  2.8249640e+003
-  0.0000000e+000
-  4.7758066e+002
-  2.6377083e+003
-  5.7771548e+003
-  5.4674808e+003
-  6.6943525e+003
-  7.9820343e+003
-  7.9081290e+003
-  8.5047664e+003
-  9.0581851e+003
-  9.9137355e+003
-  1.0516250e+004
-  9.2366671e+003
-  1.0234123e+004
-  1.0279045e+004
-  1.2318085e+004
-  1.2499570e+004
-  1.2293419e+004
-  1.2354663e+004
-  1.2336548e+004
-  1.1697450e+004
-  1.0724265e+004
-  1.1057731e+004
-  1.1483937e+004
-  1.1444137e+004
-  1.1145743e+004
-  1.0879900e+004
-  1.0958261e+004
-  1.1395920e+004
-  1.0888674e+004
-  1.0412822e+004
-  9.9142688e+003
-  9.5805745e+003
-  9.0602204e+003
-  8.9447336e+003
-  8.3338607e+003
-  5.2623176e+003
-  6.1992126e+003
-  6.6080458e+003
-  8.9456742e+003
-  1.0699771e+004
-  1.0954132e+004
-  1.1644000e+004
-  1.2029956e+004
-  1.1895722e+004
-  1.2017569e+004
-  1.2144519e+004
-  1.2458809e+004
-  1.0662727e+004
-  1.1603767e+004
-  1.2397715e+004
-  1.2339432e+004
-  1.2364182e+004
-  1.3599119e+004
-  1.4144389e+004
-  1.4187817e+004
-  1.3812512e+004
-  1.3107417e+004
-  1.2306262e+004
-  1.2775950e+004
-  8.9080654e+003
-  1.0985420e+004
-  1.0995708e+004
-  1.0460706e+004
-  1.0746053e+004
-  1.0667141e+004
-  1.0622371e+004
