[Swift-commit] r7816 - SwiftApps/swift-galaxy/swift
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Mon May 5 20:18:00 CDT 2014
Author: ketan
Date: 2014-05-05 20:18:00 -0500 (Mon, 05 May 2014)
New Revision: 7816
Modified:
   SwiftApps/swift-galaxy/swift/swiftforeach.sh
Log:
document the unified code
Modified: SwiftApps/swift-galaxy/swift/swiftforeach.sh
--- SwiftApps/swift-galaxy/swift/swiftforeach.sh	2014-05-06 01:08:05 UTC (rev 7815)
+++ SwiftApps/swift-galaxy/swift/swiftforeach.sh	2014-05-06 01:18:00 UTC (rev 7816)
@@ -2,14 +2,19 @@
 # originally list
+#set workdir
 wdir=$(mktemp -d /tmp/swift-gal.XXXX)
+#determine loop mode: over a list or a range
 range_or_list=$1
 shift
+#determine invocation: Swift /K or /T
 k_or_t=$1
 shift
+#build commandline arguments
 sites=$1
 shift
 swiftargs=$1
@@ -42,20 +47,11 @@
 stringargs=$1
 shift
+touch None # Create a "None" file in case user does not specify any stdin file
-if [ "$k_or_t" = "swiftK"  ] ; then
-    #invoke the k.sh
-    k "${@}"
-else
-    #invoke the t.sh
-    t "${@}"
-    echo "stc + turbine; not implemented yet" > /tmp/swiftT.txt
-fi
+if [ "$k_or_t" = "swiftK"  ]
+then # invoke /K
-function k()
  #workout the array only if user adds args else make it blank
  if [ "${stringargs}"  ] ; then
      stringarrayexpr='string stringargs[]=['$(echo $stringargs | sed -e 's/ *$//g' -e 's/[^ ][^ ]*/"&"/g' -e 's/ /,/g')'];';
@@ -135,27 +131,10 @@
  $site $interpreter $interpreter
 EOF
- touch None # Create a "None" file in case user does not specify any stdin file
  $swift -sites.file $wdir/sites.xml -tc.file $wdir/tc -config $wdir/cf $wdir/script.swift "${swiftargs}" 2>$logfile
  EXITCODE=$?
- $(for i in $(find $outloc -type f); do echo "$(basename $i) $i"; done)
- cat << EOF > $outlistfile
- $(for i in $(find $outloc -type f -iname "*.out"); do echo "$i"; done)
-EOF
- if [ "$EXITCODE" -ne "0" ]; then
-        cat $logfile >&2
- fi
- exit $EXITCODE
- #dum ditty dum ditty dum dum dum
-function t()
+else # Invoke T
@@ -217,22 +196,24 @@
  stc=$(which stc)
  turbine=$(which turbine)
  $stc -j `which java` $wdir/script.swift "${swiftargs}" 2>$logfile
  $turbine -n 3 $wdir/script.tcl
  EXITCODE=$?
+fi
+$(for i in $(find $outloc -type f); do echo "$(basename $i) $i"; done)
+cat << EOF > $outlistfile
+$(for i in $(find $outloc -type f -iname "*.out"); do echo "$i"; done)
 EOF
-        cat $logfile >&2
- fi
- exit $EXITCODE
+if [ "$EXITCODE" -ne "0" ]; then
+      cat $logfile >&2
+fi
+exit $EXITCODE
