[Swift-commit] r7814 - SwiftApps/swift-galaxy/swift
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Mon May 5 20:07:20 CDT 2014
Author: ketan
Date: 2014-05-05 20:07:20 -0500 (Mon, 05 May 2014)
New Revision: 7814
Modified:
   SwiftApps/swift-galaxy/swift/swiftforeach.sh
   SwiftApps/swift-galaxy/swift/swiftforeach.xml
Log:
unify list and range
Modified: SwiftApps/swift-galaxy/swift/swiftforeach.sh
--- SwiftApps/swift-galaxy/swift/swiftforeach.sh	2014-05-05 22:01:47 UTC (rev 7813)
+++ SwiftApps/swift-galaxy/swift/swiftforeach.sh	2014-05-06 01:07:20 UTC (rev 7814)
@@ -1,118 +1,238 @@
 #!/bin/bash
-#ToDo:
-#1. Add a variable number of arguments such that user can add and remove them.
+# originally list
-# numeric range
-site=$1
+wdir=$(mktemp -d /tmp/swift-gal.XXXX)
+range_or_list=$1
 shift
+k_or_t=$1
+shift
+sites=$1
+shift
+swiftargs=$1
+shift
 interpreter=$1
 shift
 executable=$1
 shift
-rstart=$1
+stdin=$1
 shift
-rend=$1
+if [ "$range_or_list" == "list" ] ; then
+    listfile=$1
+    shift
+else
+    rstart=$1
+    shift
+    rend=$1
+    shift
+    stepsize=$1
+    shift
+fi
+outloc=$1
 shift
-stepsize=$1
+logfile=$1
 shift
-outloc=$1
-shift
 outlistfile=$1
 shift
-logfile=$1
-shift
+stringargs=$1
+shift
-a=()
-while [ $# -gt 0 ] ; do
-  a+=("\"$1\"")
-  shift
-done
-#workout the array only if user adds args else make it blank
-if [ ${#a[@]} -gt 0 ] ; then
-    tmp=$(printf -- '%s,' "${a[@]}")
-    arrayexpr='string args[]=['$(echo $tmp | sed s/,$//)'];';
+if [ "$k_or_t" = "swiftK"  ] ; then
+    #invoke the k.sh
+    k "${@}"
 else
-    arrayexpr='string args[];'
+    #invoke the t.sh
+    t "${@}"
+    echo "stc + turbine; not implemented yet" > /tmp/swiftT.txt
 fi
-#Build Swift source code
-cat << EOF > /tmp/script.swift
-* Swift source script is generated automatically via the Swift-Galaxy
-* integration tool. Be careful before making any changes to it directly as
-* it might be tied with other configuration and paramter values.
-type file;
-app (file _out, file _err) anapp(file _exec, int _i, string _args[]){
-    $interpreter @_exec _i _args stdout=@_out stderr=@_err;
-$arrayexpr
-file exec<"$executable">;
-foreach i in [$rstart:$rend:$stepsize]{
-    file out <single_file_mapper; file=@strcat("$outloc", "/", i, ".out")>;
-    file err <single_file_mapper; file=@strcat("$outloc", "/", i, ".err")>;
-    (out,err) = anapp(exec, i, args);
+function k()
+ #workout the array only if user adds args else make it blank
+ if [ "${stringargs}"  ] ; then
+     stringarrayexpr='string stringargs[]=['$(echo $stringargs | sed -e 's/ *$//g' -e 's/[^ ][^ ]*/"&"/g' -e 's/ /,/g')'];';
+ else
+     stringarrayexpr='string stringargs[];'
+ fi
+ #workout standard input file
+ if [ "${stdin}" ] ; then
+     stdinfilexpr='file stdinfile<'\"${stdin}\"'>;'
+ else
+     stdinfilexpr='file stdinfile<'\"/dev/null\"'>;'
+ fi
+ fileargs=()
+ while [ $# -gt 0 ] ; do
+   fileargs+=("\"$1\"")
+   shift
+ done
+ if [ ${#fileargs[@]} -gt 0 ] ; then
+     tmp=$(printf -- '%s,' "${fileargs[@]}")
+     filearrayexpr='file fileargs[] <fixed_array_mapper; files="'$(echo $tmp | sed -e 's/,$//' -e 's/\"//g')'">;';
+ else
+     filearrayexpr='file fileargs[];'
+ fi
+ cat << EOF > $wdir/script.swift
+ * Swift source script is generated automatically via the Swift-Galaxy
+ * integration tool. Be careful before making any changes to it directly as
+ * it might be tied with other configuration and paramter values.
+ type file;
+ app (file _out, file _err) anapp(file _exec, int _i, string _stringargs[], file _fileargs[], file _stdin){
+     $interpreter @_exec _i _stringargs @_fileargs stdin=@_stdin stdout=@_out stderr=@_err;
+ $stringarrayexpr
+ $filearrayexpr
+ $stdinfilexpr
+ file exec<"$executable">;
+ file listfile<"$listfile">;
+ string list[] = readData(listfile);
+ foreach l, i in list{
+     file out <single_file_mapper; file=@strcat("$outloc", "/", l, ".", i, ".out")>;
+     file err <single_file_mapper; file=@strcat("$outloc", "/", l, ".", i, ".err")>;
+     (out,err) = anapp(exec, i, stringargs, fileargs, stdinfile);
 EOF
-swift=$(which swift)
-#build site
-BASEDIR=$(dirname $0)
-$BASEDIR/buildsite.sh $site
-#build config
-if [ $site -eq "localhost" ] ; then
-cat << EOF > /tmp/cf
-use.provider.staging=false
-wrapperlog.always.transfer=true
-execution.retries=0
-provider.staging.pin.swiftfiles=false
-sitedir.keep=true
-lazy.errors=false
+ swift=$(which swift)
+ BASEDIR=$(dirname $0)
+ $BASEDIR/buildsite.sh $sites $wdir
+ #build config
+ cat << EOF > $wdir/cf
+ use.provider.staging=true
+ wrapperlog.always.transfer=true
+ execution.retries=0
+ provider.staging.pin.swiftfiles=false
+ sitedir.keep=true
+ lazy.errors=false
+ EOF
+ #build tc
+ IFS=',' read -ra S <<< "$sites"
+ for site in "${S[@]}" ; do
+ cat << EOF >> $wdir/tc
+ $site $interpreter $interpreter
 EOF
-else
-use.provider.staging=true
-sitedir.keep=true
-lazy.errors=false
+ touch None # Create a "None" file in case user does not specify any stdin file
+ $swift -sites.file $wdir/sites.xml -tc.file $wdir/tc -config $wdir/cf $wdir/script.swift "${swiftargs}" 2>$logfile
+ EXITCODE=$?
+ $(for i in $(find $outloc -type f); do echo "$(basename $i) $i"; done)
+ cat << EOF > $outlistfile
+ $(for i in $(find $outloc -type f -iname "*.out"); do echo "$i"; done)
 EOF
-fi
+ if [ "$EXITCODE" -ne "0" ]; then
+        cat $logfile >&2
+ fi
+ exit $EXITCODE
+ #dum ditty dum ditty dum dum dum
-#build tc
-cat << EOF > /tmp/tc
-$site $interpreter $interpreter
-EOF
-$swift -sites.file /tmp/sites.xml -tc.file /tmp/tc -config /tmp/cf /tmp/script.swift 2>$logfile
-EXITCODE=$?
+function t()
+ else
+ fi
+ else
+ fi
+ fileargs=()
+   shift
+ done
+ else
+ fi
+ import files;
+     $interpreter _exec _i _stringargs _fileargs @stdin=_stdin @stdout=_out @stderr=_err;
-#`for i in \`find $HOME/swift-sandbox -type f\`; do echo "\`basename $i\` $i"; done`
-#Populate output file
-cat << EOF > $outlistfile
-`for i in \`find $outloc -type f\`; do echo "$i"; done`
+ $stringarrayexpr
+ $filearrayexpr
+ $stdinfilexpr
+ string list[] = split(read(input_file(listfile)),"\n");
+     file out <sprintf("$outloc/%s.%i.out", l, i)>;
+     file err <sprintf("$outloc/%s.%i.err", l, i)>;
 EOF
+ stc=$(which stc)
+ turbine=$(which turbine)
+ $stc -j `which java` $wdir/script.swift "${swiftargs}" 2>$logfile
+ $turbine -n 3 $wdir/script.tcl
-#cleanup
-rm -rf /tmp/sites.xml /tmp/tc /tmp/cf /tmp/script.swift
+ EXITCODE=$?
+EOF
+        cat $logfile >&2
+ fi
+ exit $EXITCODE
-if [ "$EXITCODE" -ne "0" ]; then
-       cat $logfile >&2
-fi
-exit $EXITCODE
-#dum ditty dum ditty dum dum dum
Modified: SwiftApps/swift-galaxy/swift/swiftforeach.xml
--- SwiftApps/swift-galaxy/swift/swiftforeach.xml	2014-05-05 22:01:47 UTC (rev 7813)
+++ SwiftApps/swift-galaxy/swift/swiftforeach.xml	2014-05-06 01:07:20 UTC (rev 7814)
@@ -11,9 +11,9 @@
     <description>A generic tool to run executable via Swift foreach parallel construct</description>
     <command interpreter="bash">
     #if $rangeorlist.rl == "rng"
-        swiftforeachrange.sh
+        swiftforeach.sh
+        "range"
         "${k_or_t}"
         "${site}"
         "${swiftargs}"
@@ -31,7 +31,8 @@
             ${a.fileargname}
         #end for
     #elif $rangeorlist.rl == "lst"
-        swiftforeachlist.sh
+        swiftforeach.sh
+        "list"
         "${k_or_t}"
         "${site}"
         "${swiftargs}"
@@ -47,7 +48,8 @@
             ${a.fileargname}
         #end for
     #else
-        swiftforeachtest.sh
+        swiftforeach.sh
+        "drytest"
         "${k_or_t}"
         "${site}"
         "${swiftargs}"
