[Swift-commit] cog r3936
swift at ci.uchicago.edu swift at ci.uchicago.edu
Fri Jun 20 18:20:03 CDT 2014
r3936 | timgarmstrong | 2014-06-20 18:17:27 -0500 (Fri, 20 Jun 2014) | 1 line
Add a dose of pedantry to the coaster C client interfaces based on my attempts to understand memory lifetime/ownership. Document in a few cases and add const qualifiers where appropriate in other cases.
Index: modules/provider-coaster-c-client/src/CoasterChannel.h
--- modules/provider-coaster-c-client/src/CoasterChannel.h	(revision 3935)
+++ modules/provider-coaster-c-client/src/CoasterChannel.h	(working copy)
@@ -103,7 +103,7 @@
 		void send(int tag, Buffer* buf, int flags, ChannelCallback* cb);
 		CoasterClient* getClient();
-		string& getURL();
+		const string& getURL() const;
 		void checkHeartbeat();
Index: modules/provider-coaster-c-client/src/CoasterLoop.h
--- modules/provider-coaster-c-client/src/CoasterLoop.h	(revision 3935)
+++ modules/provider-coaster-c-client/src/CoasterLoop.h	(working copy)
@@ -51,7 +51,12 @@
 		virtual ~CoasterLoop();
 		void start();
 		void stop();
+		 * Add a channel for the loop to monitor.
+		 * Ownership of the channel is retained by the caller.
+		 * Must be removed later by a call to removeChannel().
 		void addChannel(CoasterChannel* channel);
 		void removeChannel(CoasterChannel* channel);
 		void addSockets();
Index: modules/provider-coaster-c-client/src/CoasterClient.cpp
--- modules/provider-coaster-c-client/src/CoasterClient.cpp	(revision 3935)
+++ modules/provider-coaster-c-client/src/CoasterClient.cpp	(working copy)
@@ -167,7 +167,7 @@
 	delete cmd;
-void CoasterClient::updateJobStatus(string& remoteJobId, JobStatus* status) { Lock::Scoped l(lock);
+void CoasterClient::updateJobStatus(const string& remoteJobId, JobStatus* status) { Lock::Scoped l(lock);
 	if (remoteJobIdMapping.count(remoteJobId) == 0) {
 		LogWarn << "Received job status notification for unknown job (" << remoteJobId << "): " << status << endl;
@@ -259,12 +259,12 @@
-void CoasterClient::waitForJob(Job& job) { Lock::Scoped l(lock);
+void CoasterClient::waitForJob(const Job& job) { Lock::Scoped l(lock);
 	while (jobs.count(&(job.getIdentity())) != 0) {
 		cv.wait(lock);
-string& CoasterClient::getURL() {
+const string& CoasterClient::getURL() {
 	return URL;
Index: modules/provider-coaster-c-client/src/JobStatus.cpp
--- modules/provider-coaster-c-client/src/JobStatus.cpp	(revision 3935)
+++ modules/provider-coaster-c-client/src/JobStatus.cpp	(working copy)
@@ -44,7 +44,7 @@
 	init(UNSUBMITTED, time(NULL), NULL, NULL);
-JobStatusCode JobStatus::getStatusCode() {
+JobStatusCode JobStatus::getStatusCode() const {
 	return statusCode;
@@ -52,7 +52,7 @@
 	return stime;
-string* JobStatus::getMessage() {
+const string* JobStatus::getMessage() const {
 	return message;
Index: modules/provider-coaster-c-client/src/Job.h
--- modules/provider-coaster-c-client/src/Job.h	(revision 3935)
+++ modules/provider-coaster-c-client/src/Job.h	(working copy)
@@ -27,14 +27,16 @@
                  * TODO: document expectations about lifetime of strings.
                  * It seems very easy for client code to accidentally
                  * pass in a pointer to a stack-allocated string or a
-                 * string with a shorter lifetime than the job.
+                 * string with a shorter lifetime than the job.  Would
+                 * it work to just store them by value and have zero-length
+                 * be equivalent to NULL.  Are zero-length strings meaningful?
 		vector<string*>* arguments;
 		string* directory;
 		string* stdinLocation;
 		string* stdoutLocation;
 		string* stderrLocation;
-        string jobManager;
+		string jobManager;
 		map<string, string>* env;
 		map<string, string>* attributes;
@@ -49,41 +51,41 @@
 		Job(const string &executable);
 		virtual ~Job();
-		string& getExecutable();
+		const string& getExecutable() const;
                   Get the job identity.  The identity is a unique string
                   that is assigned to the job object upon construction
                   and does not change over it's lifetime.
-		string& getIdentity();
+		const string& getIdentity() const;
 		vector<string*>* getArguments();
 		void addArgument(string& arg);
 		void addArgument(const char* arg);
-		string* getDirectory();
+		const string* getDirectory() const;
 		void setDirectory(string& directory);
-		string* getStdinLocation();
+		const string* getStdinLocation() const;
 		void setStdinLocation(string& loc);
-		string* getStdoutLocation();
+		const string* getStdoutLocation() const;
 		void setStdoutLocation(string& loc);
-		string* getStderrLocation();
+		const string* getStderrLocation() const;
 		void setStderrLocation(string& loc);
-		string getJobManager();
+		const string &getJobManager() const;
 		void setJobManager(string jm);
 		void setJobManager(const char *jm);
 		map<string, string>* getEnv();
-		string* getEnv(string name);
+		const string* getEnv(string name) const;
 		void setEnv(string name, string value);
 		map<string, string>* getAttributes();
-		string* getAttribute(string name);
+		const string* getAttribute(string name);
 		void setAttribute(string name, string value);
 		vector<StagingSetEntry>* getStageIns();
@@ -95,10 +97,7 @@
 		vector<string>* getCleanups();
 		void addCleanup(string cleanup);
-		string* getStderr();
-		string* getStdout();
-		JobStatus* getStatus();
+		const JobStatus* getStatus() const;
 		void setStatus(JobStatus* status);
Index: modules/provider-coaster-c-client/src/CoasterChannel.cpp
--- modules/provider-coaster-c-client/src/CoasterChannel.cpp	(revision 3935)
+++ modules/provider-coaster-c-client/src/CoasterChannel.cpp	(working copy)
@@ -326,8 +326,8 @@
 	delete cmd;
-string& CoasterChannel::getURL() {
-	return getClient()->getURL();
+const string& CoasterChannel::getURL() const {
+	return client->getURL();
Index: modules/provider-coaster-c-client/src/CoasterClient.h
--- modules/provider-coaster-c-client/src/CoasterClient.h	(revision 3935)
+++ modules/provider-coaster-c-client/src/CoasterClient.h	(working copy)
@@ -63,15 +63,31 @@
 		void stop();
 		void setOptions(Settings& settings);
+                 * Submit a job.  The job should have been filled in with
+                 * all properties.  The ownership of the job object stays
+                 * with the caller, but this client will retain a reference
+                 * to the job until done jobs are purged.
 		void submit(Job& job);
-		void waitForJob(Job& job);
+                 * Wait for job to be done.  Upon completion no actions
+                 * are taken: job must be purged from client explicitly.
+		void waitForJob(const Job& job);
+                 * Return a list of done jobs and remove references from this
+                 * client.
 		list<Job*>* getAndPurgeDoneJobs();
 		void waitForJobs();
-		void updateJobStatus(string& jobId, JobStatus* status);
+		void updateJobStatus(const string &jobId, JobStatus* status);
-		string& getURL();
+		const string& getURL();
 		void errorReceived(Command* cmd, string* message, RemoteCoasterException* details);
 		void replyReceived(Command* cmd);
Index: modules/provider-coaster-c-client/src/Job.cpp
--- modules/provider-coaster-c-client/src/Job.cpp	(revision 3935)
+++ modules/provider-coaster-c-client/src/Job.cpp	(working copy)
@@ -32,7 +32,7 @@
 	status = NULL;
-string& Job::getIdentity() {
+const string& Job::getIdentity() const {
 	return identity;
@@ -47,7 +47,7 @@
 	arguments->push_back(new string(arg));
-string& Job::getExecutable() {
+const string& Job::getExecutable() const {
 	return executable;
@@ -55,7 +55,7 @@
 	addArgument(*(new string(arg)));
-string* Job::getDirectory() {
+const string* Job::getDirectory() const {
 	return directory;
@@ -63,7 +63,7 @@
 	directory = &pdirectory;
-string* Job::getStdinLocation() {
+const string* Job::getStdinLocation() const {
 	return stdinLocation;
@@ -71,7 +71,7 @@
 	stdinLocation = &loc;
-string* Job::getStdoutLocation() {
+const string* Job::getStdoutLocation() const {
 	return stdoutLocation;
@@ -79,7 +79,7 @@
 	stdoutLocation = &loc;
-string* Job::getStderrLocation() {
+const string* Job::getStderrLocation() const {
 	return stderrLocation;
@@ -87,7 +87,7 @@
 	stderrLocation = &loc;
-string Job::getJobManager() {
+const string& Job::getJobManager() const {
 	return jobManager;
@@ -104,7 +104,7 @@
 	return env;
-string* Job::getEnv(string name) {
+const string* Job::getEnv(string name) const {
 	if (env == NULL) {
 		return NULL;
@@ -131,7 +131,7 @@
 	return attributes;
-string* Job::getAttribute(string name) {
+const string* Job::getAttribute(string name) {
 	if (attributes == NULL) {
 		return NULL;
@@ -187,15 +187,7 @@
 	cleanups->push_back(cleanup);
-string* Job::getStderr() {
-	return stderr;
-string* Job::getStdout() {
-	return stdout;
-JobStatus* Job::getStatus() {
+const JobStatus* Job::getStatus() const {
 	return status;
Index: modules/provider-coaster-c-client/src/JobStatus.h
--- modules/provider-coaster-c-client/src/JobStatus.h	(revision 3935)
+++ modules/provider-coaster-c-client/src/JobStatus.h	(working copy)
@@ -47,9 +47,9 @@
 		JobStatus(JobStatusCode statusCode);
 		JobStatus();
 		virtual ~JobStatus();
-		JobStatusCode getStatusCode();
+		JobStatusCode getStatusCode() const;
 		time_t getTime();
-		string* getMessage();
+		const string* getMessage() const;
 		RemoteCoasterException* getException();
 		const JobStatus* getPreviousStatus();
 		void setPreviousStatus(JobStatus* prev);
Index: modules/provider-coaster-c-client/src/JobSubmitCommand.cpp
--- modules/provider-coaster-c-client/src/JobSubmitCommand.cpp	(revision 3935)
+++ modules/provider-coaster-c-client/src/JobSubmitCommand.cpp	(working copy)
@@ -5,8 +5,8 @@
 using namespace std;
-void add(string& ss, const char* key, string* value);
-void add(string& ss, const char* key, string& value);
+void add(string& ss, const char* key, const string* value);
+void add(string& ss, const char* key, const string& value);
 void add(string& ss, const char* key, const char* value);
 void add(string& ss, const char* key, const char* value, int n);
@@ -75,13 +75,13 @@
 	addOutData(Buffer::wrap(ss));
-void add(string& ss, const char* key, string* value) {
+void add(string& ss, const char* key, const string* value) {
 	if (value != NULL) {
 		add(ss, key, value->data(), value->length());
-void add(string& ss, const char* key, string& value) {
+void add(string& ss, const char* key, const string& value) {
 	add(ss, key, value.data(), value.length());
