[Swift-commit] r7895 - in SwiftApps/tryswift: . scripts
wilde at ci.uchicago.edu wilde at ci.uchicago.edu
Sun Jun 1 23:36:36 CDT 2014
Author: wilde
Date: 2014-06-01 23:36:36 -0500 (Sun, 01 Jun 2014)
New Revision: 7895
Added:
   SwiftApps/tryswift/hosts
Modified:
   SwiftApps/tryswift/scripts/001-introduction.html
   SwiftApps/tryswift/scripts/001-introduction.swift
Log:
Edit intro swift and html. Add hosts file for all-host push (to be developed)
Added: SwiftApps/tryswift/hosts
--- SwiftApps/tryswift/hosts	                        (rev 0)
+++ SwiftApps/tryswift/hosts	2014-06-02 04:36:36 UTC (rev 7895)
@@ -0,0 +1,14 @@
+swiftvm1.ci.uchicago.edu
+swiftvm2.ci.uchicago.edu
+swiftvm3.ci.uchicago.edu
+swiftvm4.ci.uchicago.edu
+ec2-23-20-13-105.compute-1.amazonaws.com
+ec2-54-87-184-8.compute-1.amazonaws.com
+ec2-54-82-124-154.compute-1.amazonaws.com
+ec2-54-221-180-8.compute-1.amazonaws.com
+ec2-54-82-219-10.compute-1.amazonaws.com
+ec2-54-221-179-105.compute-1.amazonaws.com
+ec2-54-82-146-148.compute-1.amazonaws.com
+ec2-54-82-18-151.compute-1.amazonaws.com
+ec2-54-87-83-42.compute-1.amazonaws.com
+ec2-54-237-161-160.compute-1.amazonaws.com
Modified: SwiftApps/tryswift/scripts/001-introduction.html
--- SwiftApps/tryswift/scripts/001-introduction.html	2014-05-31 20:14:47 UTC (rev 7894)
+++ SwiftApps/tryswift/scripts/001-introduction.html	2014-06-02 04:36:36 UTC (rev 7895)
@@ -6,14 +6,33 @@
    <body>
       <h2>Welcome to Try Swift!</h2>
       <p>
-         If you are an existing Swift user, and would like to try testing your code,
-         please enter your code in the editor on the right and click "execute".
+<pre>
+        This web interface lets you learn Swift from your browser - nothing to install.
+        You can run the built-in example scripts, change them, and run your own scripts.
+        - select a code example from the drop-down "Example" menu above
+        - click [Explain] to view an explanation of the  example
+        - click [Execute] (below) to run the example
+        - click [File outputs] to view the output files produced by your script
+        - click [Reset] to restore the example to its initial state (LOOSES YOUR CHANGES!)
+        The example scripts are:
+            Hello World   - Shows the basic syntax for running an app to produce a file
+            Foreach       - Introduces the foreach statement to run multiple apps in parallel
+            Multiple apps - Show dependencies between apps to specify a workflow
+            Multi-stage   - Example of a larger multi-stage workflow
+        To test your own script, enter some Swift code below, or in any other window
+        TrySwift gives you a few built-in "apps" to run, as needed by each example.
+        It executes on a pool of virtual machines, one VM per Swift run (at the moment).
+        The Swift language is explained in the Swift User Guide - see http://swift-lang.org/docs
+</pre>
       </p>
-      <p>
-         If you would like to learn Swift, select an example script above to learn more.
-      <p>
    </body>
 </html>
Modified: SwiftApps/tryswift/scripts/001-introduction.swift
--- SwiftApps/tryswift/scripts/001-introduction.swift	2014-05-31 20:14:47 UTC (rev 7894)
+++ SwiftApps/tryswift/scripts/001-introduction.swift	2014-06-02 04:36:36 UTC (rev 7895)
@@ -1,26 +1,27 @@
-        This "Try Swift" interface lets you learn Swift from your browser - nothing to install.
-        TrySwift gives you a few built-in "apps" to run, and executes on a set of virtual machines.
-        Here's how:
-        - select the examples from the drop-down menu
-        - click [Explain] to read some background info on teh example
-        - click [Run] to run your code
-        There are 4 other example scripts you may choose from:
-            Hello World   - Gives the basic syntax for running an application
-            Foreach       - Introduces the foreach statement to run multiple apps at once
-            Multiple apps - Show dependencies between multiple applications
-            Multi-stage   - Example of a larger multi-stage workflow
-        To run your own script, enter the code below, or in any other Example window
+tracef("Hello, World! This is my %s code!\n","Swift");
