[Swift-commit] r8061 - in trunk/src/org/griphyn/vdl: karajan karajan/functions karajan/lib/swiftscript util
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Wed Jul 23 20:48:05 CDT 2014
Author: hategan
Date: 2014-07-23 20:48:05 -0500 (Wed, 23 Jul 2014)
New Revision: 8061
Modified:
   trunk/src/org/griphyn/vdl/karajan/Loader.java
   trunk/src/org/griphyn/vdl/karajan/functions/ConfigProperty.java
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
   trunk/src/org/griphyn/vdl/util/ConfigPropertyType.java
   trunk/src/org/griphyn/vdl/util/ConfigTree.java
   trunk/src/org/griphyn/vdl/util/SwiftConfig.java
   trunk/src/org/griphyn/vdl/util/SwiftConfigSchema.java
Log:
implementation of latest config spec (see swift-devel emails 07/14/14-07/15/14)
Modified: trunk/src/org/griphyn/vdl/karajan/Loader.java
--- trunk/src/org/griphyn/vdl/karajan/Loader.java	2014-07-23 22:08:50 UTC (rev 8060)
+++ trunk/src/org/griphyn/vdl/karajan/Loader.java	2014-07-24 01:48:05 UTC (rev 8061)
@@ -78,7 +78,9 @@
     public static final String ARG_HELP = "help";
     public static final String ARG_VERSION = "version";
     public static final String ARG_RESUME = "resume";
-    public static final String ARG_INSTANCE_CONFIG = "config";
+    public static final String ARG_RUN_CONFIG = "config";
+    public static final String ARG_CONFIG_SEARCH_PATH = "configpath";
+    public static final String ARG_LIST_CONFIG = "listconfig";
     public static final String ARG_SITELIST = "sitelist";
     public static final String ARG_SITES_FILE = "sites.file";
     public static final String ARG_TC_FILE = "tc.file";
@@ -319,6 +321,23 @@
                         "sites.xml and tc.data to a Swift configuration file.");
                 System.exit(1);
+            if (ap.isPresent(ARG_LIST_CONFIG)) {
+                SwiftConfig config = loadConfig(ap, getCommandLineProperties(ap));
+                String val = ap.getStringValue(ARG_LIST_CONFIG);
+                if ("files".equals(val)) {
+                    System.out.println(config.toString(true, false));
+                    System.exit(0);
+                else if ("full".equals(val)) {
+                    System.out.println(config.toString(true, true));
+                    System.exit(0);
+                else {
+                    System.err.println("Invalid argument to -listconfig ('" + val + "'). " +
+                    		"Must be one of 'files' or 'full'");
+                    System.exit(1);
             if (!ap.hasValue(ArgumentParser.DEFAULT) && !ap.isPresent(ARG_EXECUTE)) {
                 System.out.println(loadVersion());
                 error("No Swift script specified");
@@ -560,15 +579,19 @@
     private static SwiftConfig loadConfig(ArgumentParser ap, Map<String, Object> cmdLine) throws IOException {
         SwiftConfig conf;
-        if (ap.hasValue(ARG_INSTANCE_CONFIG)) {
-            String configFile = ap.getStringValue(ARG_INSTANCE_CONFIG);
-            conf = SwiftConfig.load(configFile, cmdLine);
-            SwiftConfig.setDefault(conf);
+        conf = SwiftConfig.load(ap.getStringValue(ARG_RUN_CONFIG),
+            splitConfigSearchPath(ap.getStringValue(ARG_CONFIG_SEARCH_PATH)), cmdLine);
+        SwiftConfig.setDefault(conf);
+        return conf;
+    private static List<String> splitConfigSearchPath(String path) {
+        if (path == null) {
+            return null;
         else {
-            conf = (SwiftConfig) SwiftConfig.load().clone();
+            return Arrays.asList(path.split(File.pathSeparator));
-        return conf;
     private static Map<String, Object> getCommandLineProperties(ArgumentParser ap) {
@@ -608,12 +631,24 @@
         ap.addOption(ARG_RESUME, "Resumes the execution using a log file",
             "file", ArgumentParser.OPTIONAL);
-        ap.addOption(ARG_INSTANCE_CONFIG,
-            "Indicates the Swift configuration file to be used for this run." +
-            " Properties in this configuration file will override the default properties. " +
-            "If individual command line arguments are used for properties, they will override " +
-            "the contents of this file.", "file",
+        ap.addOption(ARG_RUN_CONFIG,
+            "Indicates the run configuration file to be used for this run. If no custom " +
+            "configuration search path is specified, this will replace the default run " +
+            "configuration file ('./swift.conf') if it exists, or append to the configuration " +
+            "search path otherwise. If a search path is specified, the value of this argument " +
+            "will be appended to the search path.", "file",
+        ap.addOption(ARG_CONFIG_SEARCH_PATH,
+            "Specifies a custom configuration search path. If supplied, the default configuration " +
+            "search path will be ignored and configurations will be loaded from files specified in " +
+            "the value of this argument. The files in the value must be separated using the " +
+            "operating system's path separator.", "file",
+            ArgumentParser.OPTIONAL);
+        ap.addOption(ARG_LIST_CONFIG,
+            "Lists details about the loaded configuration. 'files' lists only the configuration " +
+            "files used, while 'full' lists both the files and all the property values.",
+            "files|full",
         ap.addFlag(ARG_SITELIST, "Prints a list of sites available in the swift configuration");
         ap.addFlag(ARG_VERBOSE,
             "Increases the level of output that Swift produces on the console to include more detail " +
Modified: trunk/src/org/griphyn/vdl/karajan/functions/ConfigProperty.java
--- trunk/src/org/griphyn/vdl/karajan/functions/ConfigProperty.java	2014-07-23 22:08:50 UTC (rev 8060)
+++ trunk/src/org/griphyn/vdl/karajan/functions/ConfigProperty.java	2014-07-24 01:48:05 UTC (rev 8061)
@@ -137,8 +137,7 @@
             prop = conf.getProperty(name);
         if (prop == null) {
-            throw new ExecutionException("Swift config property \"" + name + "\" not found in "
-                    + conf.getFileName());
+            throw new ExecutionException("Swift config property \"" + name + "\" not found");
         else {
             return prop;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java	2014-07-23 22:08:50 UTC (rev 8060)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java	2014-07-24 01:48:05 UTC (rev 8061)
@@ -301,6 +301,7 @@
     public static class ExecSystem extends AbstractSingleValuedSwiftFunction {
         private ArgRef<AbstractDataNode> input;
Modified: trunk/src/org/griphyn/vdl/util/ConfigPropertyType.java
--- trunk/src/org/griphyn/vdl/util/ConfigPropertyType.java	2014-07-23 22:08:50 UTC (rev 8060)
+++ trunk/src/org/griphyn/vdl/util/ConfigPropertyType.java	2014-07-24 01:48:05 UTC (rev 8061)
@@ -24,15 +24,15 @@
 import com.typesafe.config.ConfigOrigin;
 public abstract class ConfigPropertyType<T> {
-    public static final ConfigPropertyType<Boolean> BOOLEAN = new CPTBoolean();
+    public static final ConfigPropertyType<Object> BOOLEAN = new CPTBoolean();
     public static final ConfigPropertyType<String> STRING = new CPTString();
-    public static final ConfigPropertyType<Integer> INT = new Int();
+    public static final ConfigPropertyType<Object> INT = new Int();
     public static final ConfigPropertyType<Object> THROTTLE = new Throttle();
     public static final ConfigPropertyType<String> PORT_RANGE = new PortRange();
-    public static final ConfigPropertyType<Integer> STRICTLY_POSITIVE_INT = new SPInt();
-    public static final ConfigPropertyType<Integer> POSITIVE_INT = new PInt();
-    public static final ConfigPropertyType<Double> POSITIVE_FLOAT = new PFloat();
-    public static final ConfigPropertyType<Double> FLOAT = new CPTFloat();
+    public static final ConfigPropertyType<Object> STRICTLY_POSITIVE_INT = new SPInt();
+    public static final ConfigPropertyType<Object> POSITIVE_INT = new PInt();
+    public static final ConfigPropertyType<Object> POSITIVE_FLOAT = new PFloat();
+    public static final ConfigPropertyType<Object> FLOAT = new CPTFloat();
     public static final ConfigPropertyType<String> FILE = new CPTFile();
     public static final ConfigPropertyType<String> TIME = new CPTTime();
     public static final ConfigPropertyType<Object> OBJECT = new CPTObject();
@@ -51,6 +51,11 @@
     public abstract Object checkValue(String propName, T value, ConfigOrigin loc);
     public abstract ConfigPropertyType<?> getBaseType();
+    protected RuntimeException cannotConvert(ConfigOrigin loc, String propName, Object value, String toWhat) {
+        return new IllegalArgumentException(location(loc) + ":\n\tCannot convert value '" + value + "' for property '" +
+                propName + "' to " + toWhat);
     private static String pp(Collection<String> c) {
         StringBuilder sb = new StringBuilder();
@@ -126,10 +131,23 @@
-    private static class Int extends ConfigPropertyType<Integer> {
+    private static class Int extends ConfigPropertyType<Object> {
         @Override
-        public Object checkValue(String propName, Integer value, ConfigOrigin loc) {
-            return value;
+        public Object checkValue(String propName, Object value, ConfigOrigin loc) {
+            if (value instanceof String) {
+                try {
+                    return Integer.parseInt((String) value);
+                catch (NumberFormatException e) {
+                    throw cannotConvert(loc, propName, value, "integer");
+            else if (value instanceof Integer) {
+                return value;
+            else {
         @Override
@@ -143,10 +161,18 @@
-    private static class CPTBoolean extends ConfigPropertyType<Boolean> {
+    private static class CPTBoolean extends ConfigPropertyType<Object> {
         @Override
-        public Object checkValue(String propName, Boolean value, ConfigOrigin loc) {
-            return value;
+                return Boolean.valueOf((String) value);
+            else if (value instanceof Boolean) {
+                return value;
+            else {
+                throw cannotConvert(loc, propName, value, "boolean");
         @Override
@@ -160,20 +186,16 @@
-    private static class SPInt extends ConfigPropertyType<Integer> {
+    private static class SPInt extends Int {
         @Override
-            if (value <= 0) {
+            Integer ivalue = (Integer) super.checkValue(propName, value, loc);
+            if (ivalue <= 0) {
                 throw new IllegalArgumentException(location(loc) + ":\n\tInvalid value '" + value + "' for property '" +
                 propName + "'. Must be a " + toString());
-            return value;
+            return ivalue;
-        @Override
-        public ConfigPropertyType<?> getBaseType() {
-            return INT;
         @Override
         public String toString() {
@@ -181,20 +203,16 @@
-    private static class PInt extends ConfigPropertyType<Integer> {
+    private static class PInt extends Int {
         @Override
-            if (value < 0) {
+            if (ivalue < 0) {
-            return value;
+            return ivalue;
-        @Override
-            return INT;
         @Override
@@ -209,6 +227,14 @@
             if ("off".equals(value)) {
                 return Integer.MAX_VALUE;
+            else if (value instanceof String) {
+                try {
                 Integer i = (Integer) value;
                 if (i > 0) {
@@ -230,20 +256,16 @@
-    private static class PFloat extends ConfigPropertyType<Double> {
+    private static class PFloat extends CPTFloat {
         @Override
-        public Object checkValue(String propName, Double value, ConfigOrigin loc) {
-            if (value < 0) {
+            Double dvalue = (Double) super.checkValue(propName, value, loc);
+            if (dvalue < 0) {
-            return value;
+            return dvalue;
-        @Override
-            return FLOAT;
         @Override
@@ -251,10 +273,23 @@
-    private static class CPTFloat extends ConfigPropertyType<Double> {
+    private static class CPTFloat extends ConfigPropertyType<Object> {
         @Override
-            return value;
+                try {
+                    return Double.parseDouble((String) value);
+                    throw cannotConvert(loc, propName, value, "number");
+            else if (value instanceof Double) {
+                return value;
+            else {
         @Override
@@ -263,7 +298,7 @@
-    public static class Interval extends ConfigPropertyType<Double> {
+    public static class Interval extends CPTFloat {
         private double l, h;
         public Interval(double l, double h) {
@@ -272,18 +307,14 @@
         @Override
-            if (value < l || value > h) {
+            if (dvalue < l || dvalue > h) {
-            return value;
+            return dvalue;
-        @Override
-            return FLOAT;
         @Override
Modified: trunk/src/org/griphyn/vdl/util/ConfigTree.java
--- trunk/src/org/griphyn/vdl/util/ConfigTree.java	2014-07-23 22:08:50 UTC (rev 8060)
+++ trunk/src/org/griphyn/vdl/util/ConfigTree.java	2014-07-24 01:48:05 UTC (rev 8061)
@@ -10,12 +10,14 @@
 package org.griphyn.vdl.util;
 import java.util.ArrayList;
+import java.util.Collection;
 import java.util.Collections;
 import java.util.HashMap;
 import java.util.List;
 import java.util.Map;
 import java.util.NoSuchElementException;
 import java.util.Set;
+import java.util.TreeSet;
 public class ConfigTree<T> {
@@ -49,7 +51,7 @@
-        public Object get() {
+        public T get() {
             return value;
@@ -202,32 +204,18 @@
-        private void toString(StringBuilder sb, int level, String k) {
+        private void toString(StringBuilder sb, int level, String k, String full, boolean sort, ValueFormatter f) {
             if (nodes == null || nodes.isEmpty()) {
-                for (int i = 0; i < level; i++) {
-                    sb.append('\t');
-                if (value != null) {
-                    sb.append(k);
-                    sb.append(": ");
-                    if (value instanceof String) {
-                        sb.append('\"');
-                        sb.append(value);
-                        sb.append('\"');
-                    else {
-                        sb.append(value);
-                    sb.append('\n');
+                f.format(k, full, value, level, sb);
             else if (nodes.size() == 1) {
                 String key = nodes.keySet().iterator().next();
                 if (k == null) {
-                    nodes.values().iterator().next().toString(sb, level, key);
+                    nodes.values().iterator().next().toString(sb, level, key, cat(full, key), sort, f);
                 else {
-                    nodes.values().iterator().next().toString(sb, level, k + "." + key);
+                    String nkey = cat(k, key);
+                    nodes.values().iterator().next().toString(sb, level, nkey, cat(full, key), sort, f);
             else {
@@ -239,9 +227,16 @@
                     sb.append(' ');
                 sb.append("{\n");
-                for (Map.Entry<String, Node<T>> e : nodes.entrySet()) {
-                    e.getValue().toString(sb, level + 1, e.getKey());
+                Collection<String> keys;
+                if (sort) {
+                    keys = new TreeSet<String>(nodes.keySet());
+                else {
+                    keys = nodes.keySet();
+                for (String key : keys) {
+                    nodes.get(key).toString(sb, level + 1, key, cat(full, key), sort, f);
                     sb.append('\t');
@@ -249,6 +244,15 @@
+        private String cat(String full, String key) {
+            if (full == null) {
+                return key;
+            else {
+                return full + "." + key;
         public List<String> getLeafPaths() {
             List<String> l = new ArrayList<String>();
             getLeafPaths(l, null);
@@ -257,7 +261,7 @@
-            toString(sb, 0, null);
+            toString(sb, 0, null, null, false, DEFAULT_VALUE_FORMATTER);
             return sb.toString();
@@ -315,8 +319,40 @@
+        return toString(false, DEFAULT_VALUE_FORMATTER);
+    public String toString(boolean sort, ValueFormatter f) {
-        root.toString(sb, 0, null);
+        root.toString(sb, 0, null, null, sort, f);
+    public interface ValueFormatter {
+        void format(String key, String full, Object value, int indentationLevel, StringBuilder sb);
+    public static class DefaultValueFormatter implements ValueFormatter {
+        @Override
+        public void format(String key, String full, Object value, int indentationLevel, StringBuilder sb) {
+            for (int i = 0; i < indentationLevel; i++) {
+                sb.append('\t');
+            if (value != null) {
+                sb.append(key);
+                sb.append(": ");
+                    sb.append('\"');
+                    sb.append(value);
+                    sb.append('\"');
+                else {
+                    sb.append(value);
+                sb.append('\n');
+    public static final ValueFormatter DEFAULT_VALUE_FORMATTER = new DefaultValueFormatter();
Modified: trunk/src/org/griphyn/vdl/util/SwiftConfig.java
--- trunk/src/org/griphyn/vdl/util/SwiftConfig.java	2014-07-23 22:08:50 UTC (rev 8060)
+++ trunk/src/org/griphyn/vdl/util/SwiftConfig.java	2014-07-24 01:48:05 UTC (rev 8061)
@@ -16,7 +16,6 @@
-import java.util.SortedSet;
 import org.apache.log4j.Logger;
@@ -40,6 +39,7 @@
 import com.typesafe.config.ConfigIncludeContext;
 import com.typesafe.config.ConfigIncluder;
 import com.typesafe.config.ConfigObject;
+import com.typesafe.config.ConfigOrigin;
 import com.typesafe.config.ConfigParseOptions;
 import com.typesafe.config.ConfigSyntax;
 import com.typesafe.config.ConfigValue;
@@ -51,7 +51,9 @@
     public static final boolean CHECK_DYNAMIC_NAMES = true;
     public static final boolean BUILD_CHECK = true;
-    public static final List<String> DEFAULT_LOCATIONS;
+    public static String DIST_CONF;
+    public static String SITE_CONF;
+    public static String USER_CONF;
     public enum Key {
         DM_CHECKER("mappingCheckerEnabled"),
@@ -81,10 +83,7 @@
     static {
         SCHEMA = new SwiftConfigSchema();
-        DEFAULT_LOCATIONS = new ArrayList<String>();
-        if (System.getenv("SWIFT_SITE_CONF") != null) {
-            DEFAULT_LOCATIONS.add(System.getenv("SWIFT_SITE_CONF"));
         String swiftHome = System.getProperty("swift.home");
         if (swiftHome == null) {
@@ -93,11 +92,18 @@
-        DEFAULT_LOCATIONS.add(swiftHome + File.separator +
-            "etc" + File.separator + "swift.conf");
+        DIST_CONF = makePath(swiftHome, "etc", "swift.conf");
+        if (System.getenv("SWIFT_SITE_CONF") != null) {
+            SITE_CONF = System.getenv("SWIFT_SITE_CONF");
+        File userConf = new File(makePath(System.getProperty("user.home"), ".swift", "swift.conf"));
+        if (userConf.exists()) {
+            USER_CONF = userConf.getAbsolutePath();
         // check keys against schema
         for (Key k : Key.values()) {
             if (!SCHEMA.isNameValid(k.propName)) {
                 throw new IllegalArgumentException("Invalid property name for config key '" + k + "': " + k.propName);
@@ -115,11 +121,23 @@
+    public static class ValueLocationPair {
+        public final Object value;
+        public final ConfigOrigin loc;
+        public ValueLocationPair(Object value, ConfigOrigin loc) {
+            this.value = value;
+            this.loc = loc;
     private static class IncluderWrapper implements ConfigIncluder {
         private final ConfigIncluder d;
+        private final List<String> loadedFiles;
-        public IncluderWrapper(ConfigIncluder d) {
+        public IncluderWrapper(ConfigIncluder d, List<String> loadedFiles) {
             this.d = d;
+            this.loadedFiles = loadedFiles;
         @Override
@@ -136,6 +154,7 @@
                 what = what.substring(0, b) + resolve(var) + what.substring(e + 1);
                 b = what.indexOf("${");
+            loadedFiles.add(new File(what).getAbsolutePath());
             return ConfigFactory.parseFile(new File(what)).root();
@@ -153,28 +172,119 @@
             return v;
-    public static SwiftConfig load(String fileName) {
-        return load(fileName, null);
+    private static String makePath(String... els) {
+        StringBuilder sb = new StringBuilder();
+        for (int i = 0; i < els.length; i++) {
+            if (i != 0 && (sb.charAt(sb.length() - 1) != File.separatorChar)) {
+                sb.append(File.separator);
+            sb.append(els[i]);
+        return sb.toString();
-    public static SwiftConfig load(String fileName, Map<String, Object> override) {
+    public static SwiftConfig load(String cmdLineConfig, List<String> configSearchPath, Map<String, Object> cmdLineOptions) {
+        List<String> loadedFiles = new ArrayList<String>();
+        List<String> loadedFileIndices = new ArrayList<String>();
         ConfigParseOptions opt = ConfigParseOptions.defaults();
-        opt = opt.setIncluder(new IncluderWrapper(opt.getIncluder())).
+        opt = opt.setIncluder(new IncluderWrapper(opt.getIncluder(), loadedFiles)).
             setSyntax(ConfigSyntax.CONF).setAllowMissing(false);
-        Config conf = ConfigFactory.parseFile(new File(fileName), opt);
-        if (override != null) {
-            Config oconf = ConfigFactory.parseMap(override, "<command line>");
+        Config conf;
+        if (configSearchPath == null) {
+            conf = loadNormal(cmdLineConfig, opt, loadedFiles, loadedFileIndices);
+        else {
+            conf = loadFromSearchPath(configSearchPath, cmdLineConfig, opt,
+                loadedFiles, loadedFileIndices);
+        if (cmdLineOptions != null) {
+            Config oconf = ConfigFactory.parseMap(cmdLineOptions, "<Command Line>");
             conf = oconf.withFallback(conf);
+            loadedFiles.add("<Command Line>");
+            loadedFileIndices.add("C");
         conf = conf.resolveWith(getSubstitutions());
-        ConfigTree<Object> out = SCHEMA.validate(conf);
-        SwiftConfig sc = new SwiftConfig();
-        sc.setFileName(fileName);
+        ConfigTree<ValueLocationPair> out = SCHEMA.validate(conf);
+        SwiftConfig sc = new SwiftConfig(loadedFiles, loadedFileIndices);
         sc.build(out);
         return sc;
+    private static Config loadFromSearchPath(List<String> configSearchPath, String cmdLineConfig,
+            ConfigParseOptions opt, List<String> loadedFiles, List<String> loadedFileIndices) {
+        Config conf = null;
+        int index = 1;
+        for (String c : configSearchPath) {
+            conf = loadOne(c, conf, opt);
+            loadedFiles.add(c);
+            loadedFileIndices.add(String.valueOf(index++));
+        if (cmdLineConfig != null) {
+            conf = loadOne(cmdLineConfig, conf, opt);
+            loadedFiles.add(cmdLineConfig);
+            loadedFileIndices.add("R");
+        return conf;
+    private static Config loadNormal(String cmdLineConfig, ConfigParseOptions opt,
+            List<String> loadedFiles, List<String> loadedFileIndices) {
+        Config conf;
+        conf = loadOne(DIST_CONF, null, opt);
+        loadedFiles.add(DIST_CONF);
+        loadedFileIndices.add("D");
+        if (SITE_CONF != null) {
+            conf = loadOne(SITE_CONF, conf, opt);
+            loadedFiles.add(SITE_CONF);
+            loadedFileIndices.add("S");
+        if (USER_CONF != null) {
+            conf = loadOne(USER_CONF, conf, opt);
+            loadedFiles.add(USER_CONF);
+            loadedFileIndices.add("U");
+        if (cmdLineConfig == null) {
+            File runConf = new File("swift.conf");
+            if (runConf.exists()) {
+                conf = loadOne(runConf.getPath(), conf, opt);
+                loadedFiles.add(runConf.getPath());
+        return conf;
+    private static Config loadOne(String fileName, Config conf, ConfigParseOptions opt) {
+        File f = new File(fileName);
+        Config nconf = ConfigFactory.parseFile(f, opt);
+        if (conf == null) {
+            return nconf;
+        else {
+            return nconf.withFallback(conf);
     private static Config getSubstitutions() {
         Map<String, Object> m = new HashMap<String, Object>();
@@ -184,21 +294,12 @@
         return ConfigFactory.parseMap(m).withFallback(ConfigFactory.parseProperties(System.getProperties()));
-    public static SwiftConfig load() {
-        for (String loc : DEFAULT_LOCATIONS) {
-            if (new File(loc).exists()) {
-                return load(loc);
-        throw new IllegalStateException("Could not find swift configuration file");
     private static SwiftConfig _default;
     public synchronized static SwiftConfig getDefault() {
         if (_default == null) {
-            _default = load();
+            throw new IllegalStateException("No default Swift configuration set");
         return _default;
@@ -209,14 +310,18 @@
     private SwiftContactSet definedSites;
     private SwiftContactSet sites;
-    private ConfigTree<Object> tree;
+    private ConfigTree<ValueLocationPair> tree;
     private Map<String, Object> flat;
     private String fileName;
+    private List<String> usedFiles;
+    private List<String> usedFileIndices;
-    public SwiftConfig() {
+    public SwiftConfig(List<String> usedFiles, List<String> usedFileIndices) {
         definedSites = new SwiftContactSet();
         sites = new SwiftContactSet();
         flat = new HashMap<String, Object>();
+        this.usedFiles = usedFiles;
+        this.usedFileIndices = usedFileIndices;
     public SwiftContactSet getSites() {
@@ -239,24 +344,16 @@
         flat.put(key, value);
-    public String getFileName() {
-        return fileName;
-    public void setFileName(String fileName) {
-        this.fileName = fileName;
     @SuppressWarnings("unchecked")
-    private void build(ConfigTree<Object> tree) {
+    private void build(ConfigTree<ValueLocationPair> tree) {
         this.tree = tree;
         List<String> sites = null;
         if (BUILD_CHECK) {
             checkKey("sites");
-        for (Map.Entry<String, ConfigTree.Node<Object>> e : tree.entrySet()) {
+        for (Map.Entry<String, ConfigTree.Node<ValueLocationPair>> e : tree.entrySet()) {
             if (e.getKey().equals("site")) {
-                for (Map.Entry<String, ConfigTree.Node<Object>> f : e.getValue().entrySet()) {
+                for (Map.Entry<String, ConfigTree.Node<ValueLocationPair>> f : e.getValue().entrySet()) {
                     site(definedSites, f.getKey(), f.getValue());
@@ -280,7 +377,7 @@
         this.sites.getApplications().putAll(definedSites.getApplications());
         for (String leaf : tree.getLeafPaths()) {
-            flat.put(leaf, tree.get(leaf));
+            flat.put(leaf, tree.get(leaf).value);
@@ -295,16 +392,16 @@
-    private void apps(SwiftContact sc, ConfigTree.Node<Object> n) {
+    private void apps(SwiftContact sc, ConfigTree.Node<ValueLocationPair> n) {
          * app."*" {
-        for (Map.Entry<String, ConfigTree.Node<Object>> e : n.entrySet()) {
+        for (Map.Entry<String, ConfigTree.Node<ValueLocationPair>> e : n.entrySet()) {
             String k = e.getKey();
-            ConfigTree.Node<Object> c = e.getValue();
+            ConfigTree.Node<ValueLocationPair> c = e.getValue();
             if (e.getKey().equals("ALL")) {
                 sc.addApplication(app("*", e.getValue()));
@@ -351,7 +448,7 @@
-    private Application app(String name, ConfigTree.Node<Object> n) {
+    private Application app(String name, ConfigTree.Node<ValueLocationPair> n) {
          * app."*" {
          *  executable: "?String"
@@ -374,9 +471,9 @@
             checkKey("app.*.options.jobProject");
             checkKey("app.*.options.jobQueue");
             if (k.equals("executable")) {
                 app.setExecutable(getString(c));
@@ -410,15 +507,15 @@
-    private List<KVPair> envs(Node<Object> n) {
+    private List<KVPair> envs(Node<ValueLocationPair> n) {
         List<KVPair> l = new ArrayList<KVPair>();
             l.add(new KVPair(e.getKey(), getString(e.getValue())));
         return l;
-    private void site(SwiftContactSet sites, String name, ConfigTree.Node<Object> n) {
+    private void site(SwiftContactSet sites, String name, ConfigTree.Node<ValueLocationPair> n) {
         try {
             SwiftContact sc = new SwiftContact(name);
@@ -436,9 +533,9 @@
                 sc.setProperty("sysinfo", getString(n, "OS"));
                 String ctype = e.getKey();
                 if (ctype.equals("execution")) {
                     sc.addService(execution(c));
@@ -469,7 +566,7 @@
-    private void staging(SwiftContact sc, Node<Object> n) {
+    private void staging(SwiftContact sc, Node<ValueLocationPair> n) {
         String staging = getString(n);
         if (BUILD_CHECK) {
             checkValue("site.*.staging",
@@ -516,14 +613,14 @@
-    private Service filesystem(Node<Object> c) throws InvalidProviderException, ProviderMethodException {
+    private Service filesystem(Node<ValueLocationPair> c) throws InvalidProviderException, ProviderMethodException {
         Service s = new ServiceImpl();
         s.setType(Service.FILE_OPERATION);
         fileService(c, s);
         return s;
-    private void fileService(Node<Object> n, Service s) throws InvalidProviderException, ProviderMethodException {
+    private void fileService(Node<ValueLocationPair> n, Service s) throws InvalidProviderException, ProviderMethodException {
         String provider = null;
         String url = null;
         if (BUILD_CHECK) {
@@ -531,9 +628,9 @@
             checkKey("site.*.filesystem.URL");
             checkKey("site.*.filesystem.options");
             if (k.equals("type")) {
                 provider = getString(c);
@@ -542,7 +639,7 @@
                 url = getString(c);
             else if (k.equals("options")) {
                     s.setAttribute(f.getKey(), getObject(f.getValue()));
@@ -557,13 +654,13 @@
-    private Service execution(ConfigTree.Node<Object> n) throws InvalidProviderException, ProviderMethodException {
+    private Service execution(ConfigTree.Node<ValueLocationPair> n) throws InvalidProviderException, ProviderMethodException {
         ExecutionService s = new ExecutionServiceImpl();
         execService(n, s);
         return s;
-    private void execService(Node<Object> n, Service s) throws InvalidProviderException, ProviderMethodException {
+    private void execService(Node<ValueLocationPair> n, Service s) throws InvalidProviderException, ProviderMethodException {
         String url = null;
         if (BUILD_CHECK) {
@@ -572,9 +669,9 @@
             checkKey("site.*.execution.jobManager");
             checkKey("site.*.execution.options");
@@ -599,7 +696,7 @@
-    private void execOptions(ExecutionService s, Node<Object> n) {
+    private void execOptions(ExecutionService s, Node<ValueLocationPair> n) {
         if (BUILD_CHECK) {
             checkKey("site.*.execution.options.jobProject");
             checkKey("site.*.execution.options.maxJobs");
@@ -609,9 +706,9 @@
             checkKey("site.*.execution.options.jobOptions");
             if (k.equals("jobProject")) {
@@ -643,16 +740,16 @@
-    private String getString(Node<Object> c) {
-        return (String) c.get();
+    private String getString(Node<ValueLocationPair> c) {
+        return (String) c.get().value;
-    private Object getObject(ConfigTree.Node<Object> c) {
-        return c.get();
+    private Object getObject(ConfigTree.Node<ValueLocationPair> c) {
+        return c.get().value;
-    private String getString(ConfigTree.Node<Object> c, String key) {
-        return (String) c.get(key);
+    private String getString(ConfigTree.Node<ValueLocationPair> c, String key) {
+        return (String) c.get(key).value;
     private Object getObject(ConfigTree.Node<Object> c, String key) {
@@ -671,23 +768,82 @@
+        return toString(true, true);
+    public String toString(boolean files, boolean values) {
-        SortedSet<String> s = new TreeSet<String>(flat.keySet());
-        for (String k : s) {
-            sb.append(k);
+        if (files) {
+            for (int i = 0; i < usedFiles.size(); i++) {
+                sb.append("[" + usedFileIndices.get(i) + "] " + usedFiles.get(i) + "\n");
+        if (values) {
+            sb.append(tree.toString(true, new LocationFormatter(usedFiles, usedFileIndices, tree)));
+    private static class LocationFormatter extends ConfigTree.DefaultValueFormatter {
+        private List<String> files, fileIndices;
+        public LocationFormatter(List<String> files, List<String> fileIndices, ConfigTree<ValueLocationPair> tree) {
+            this.files = files;
+            this.fileIndices = fileIndices;
+            this.tree = tree;
+        @Override
+            ValueLocationPair p = tree.get(full);
+            if (p.loc == null) {
+                // properties with default values from the schema, so don't print those
+                return;
+            int start = sb.length();
+                sb.append("    ");
+            sb.append(key);
             sb.append(": ");
-            Object o = flat.get(k);
-            if (o instanceof String) {
-                sb.append('"');
-                sb.append(o);
-                sb.append('"');
+            if (p.value instanceof String) {
+                sb.append("\"");
+            sb.append(p.value);
+                sb.append("\"");
+            int width = sb.length() - start;
+            for (int i = 0; i < 60 - width; i++) {
+                sb.append(' ');
+            sb.append("# [");
+            int index;
+            if (p.loc.filename() == null) {
+                // command line
+                index = files.size() - 1;
             else {
-                sb.append(o);
+                index = files.indexOf(p.loc.filename());
+            if (index == -1) {
+                sb.append('?');
+            else {
+                sb.append(fileIndices.get(index));
+            sb.append("]");
+            if (p.loc.filename() != null) {
+                sb.append(" line ");
+                sb.append(p.loc.lineNumber());
             sb.append('\n');
-        return sb.toString();
     private void check(String name) {
Modified: trunk/src/org/griphyn/vdl/util/SwiftConfigSchema.java
--- trunk/src/org/griphyn/vdl/util/SwiftConfigSchema.java	2014-07-23 22:08:50 UTC (rev 8060)
+++ trunk/src/org/griphyn/vdl/util/SwiftConfigSchema.java	2014-07-24 01:48:05 UTC (rev 8061)
@@ -16,6 +16,8 @@
+import org.griphyn.vdl.util.SwiftConfig.ValueLocationPair;
 import com.typesafe.config.Config;
 import com.typesafe.config.ConfigFactory;
@@ -173,8 +175,8 @@
         return o.filename() + ":" + o.lineNumber();
-    public ConfigTree<Object> validate(Config conf) {
-        ConfigTree<Object> validated = new ConfigTree<Object>();
+    public ConfigTree<ValueLocationPair> validate(Config conf) {
+        ConfigTree<ValueLocationPair> validated = new ConfigTree<ValueLocationPair>();
         // build a tree of the actual config so we can easily check them for missing properties
         ConfigTree<Boolean> confTree = new ConfigTree<Boolean>();
@@ -194,7 +196,7 @@
                 throw new IllegalStateException("Missing type for key " + k);
             Object value = checkValue(k, e.getValue(), i.type);
-            validated.put(k, value);
+            validated.put(k, new ValueLocationPair(value, e.getValue().origin()));
         // check for missing things
@@ -210,14 +212,14 @@
         return validated;
-    private String findMissing(String key, ConfigTree<Boolean> confTree, Info i, ConfigTree<Object> validated) {
+    private String findMissing(String key, ConfigTree<Boolean> confTree, Info i, ConfigTree<ValueLocationPair> validated) {
         List<String> found = confTree.expandWildcards(key, STAR);
         for (String f : found) {
             if (!confTree.hasKey(f)) {
                 if (i.optional) {
                     if (i.value != null) {
-                        validated.put(f, i.value);
+                        validated.put(f, new ValueLocationPair(i.value, null));
                 else if (!parentsAreOptional(key, confTree)) {
@@ -237,8 +239,18 @@
                 return false;
             Info i = info.get(k);
-            if (i != null && !i.optional && !confTree.hasKey(k)) {
-                return false;
+            if (i != null) {
+                if (i.optional) {
+                    if (confTree.hasKey(k)) {
+                        // continue checking parents
+                    else {
+                        return true;
+                else {
+                    return false;
         return true;
@@ -270,9 +282,7 @@
         Object v = value.unwrapped();
         switch (value.valueType()) {
             case STRING:
-                if (t.getBaseType() != ConfigPropertyType.STRING && t.getBaseType() != ConfigPropertyType.OBJECT) {
-                    throw invalidValue(value, k, v, t.getBaseType());
+                // allow auto-conversion from string
                 return t.check(k, value.unwrapped(), value.origin());
             case NUMBER:
                 if (t.getBaseType() != ConfigPropertyType.INT && t.getBaseType() != ConfigPropertyType.FLOAT) {
