[Swift-commit] cog r4027
swift at ci.uchicago.edu swift at ci.uchicago.edu
Tue Jul 22 15:45:03 CDT 2014
r4027 | yadunand | 2014-07-22 15:41:15 -0500 (Tue, 22 Jul 2014) | 17 lines
Adding first cut of the ec2 cloud provider.
Must test from a machine with a publically reachable ip.
Tested using conf :
execution {
        type:"coaster"
        URL: "127.0.0.1"
        jobManager: "local:ec2-cloud"
        options {
            maxJobs: 5
            tasksPerNode: 2
            workerLoggingLevel: TRACE
            workerLoggingDirectory: /tmp
Index: modules/provider-localscheduler/resources/cog-provider.properties
--- modules/provider-localscheduler/resources/cog-provider.properties	(revision 4026)
+++ modules/provider-localscheduler/resources/cog-provider.properties	(working copy)
@@ -33,3 +33,8 @@
 sandbox=false
 executionTaskHandler=org.globus.cog.abstraction.impl.scheduler.lsf.execution.TaskHandlerImpl
 securityContext=org.globus.cog.abstraction.impl.common.task.SecurityContextImpl
+provider=ec2-cloud
+sandbox=false
+executionTaskHandler=org.globus.cog.abstraction.impl.scheduler.shell.execution.TaskHandlerImpl
+securityContext=org.globus.cog.abstraction.impl.common.task.SecurityContextImpl
Index: modules/provider-localscheduler/etc/provider-ec2-cloud.properties
--- modules/provider-localscheduler/etc/provider-ec2-cloud.properties	(revision 0)
+++ modules/provider-localscheduler/etc/provider-ec2-cloud.properties	(revision 4027)
@@ -0,0 +1,3 @@
+submit.command=/home/yadu/src/swift-trunk/cog/modules/provider-localscheduler/examples/ec2-cloud-provider/stsubmit
+cancel.command=/home/yadu/src/swift-trunk/cog/modules/provider-localscheduler/examples/ec2-cloud-provider/stcancel
+poll.command=/home/yadu/src/swift-trunk/cog/modules/provider-localscheduler/examples/ec2-cloud-provider/ststat
\ No newline at end of file
Index: modules/provider-localscheduler/examples/ec2-cloud-provider/provider-ec2-cloud.properties
--- modules/provider-localscheduler/examples/ec2-cloud-provider/provider-ec2-cloud.properties	(revision 0)
+++ modules/provider-localscheduler/examples/ec2-cloud-provider/provider-ec2-cloud.properties	(revision 4027)
@@ -0,0 +1,3 @@
+submit.command=/path/to/stsubmit
+cancel.command=/path/to/stcancel
+poll.command=/path/to/ststat
Index: modules/provider-localscheduler/examples/ec2-cloud-provider/log
--- modules/provider-localscheduler/examples/ec2-cloud-provider/log	(revision 0)
+++ modules/provider-localscheduler/examples/ec2-cloud-provider/log	(revision 4027)
@@ -0,0 +1,136 @@
+Start
+CMD     : /usr/bin/perl  /usr/local/bin/swift-trunk/bin/worker.pl http://128.135.250.235:45185 0722-3703570-000000 /tmp  1> /tmp/tmp.dXjNyXhGn8 2> /tmp/tmp.gLOB9vWNvL
+AWS_CREDENTIALS_FILE=~/.ssh/boto-test-credentials.csv
+# Update the following only if you want to use a specific keypair
+AWS_KEYPAIR_NAME=swift-test-pair
+AWS_KEYPAIR_FILE=~/.ssh/swift-test-pair.pem
+AWS_REGION=us-west-2
+SECURITY_GROUP=swift_security_group1
+WORKER_IMAGE=ami-23700813
+WORKER_MACHINE_TYPE=t1.micro
+CMD_STRING="mkdir /tmp/; cd /tmp/; /usr/bin/perl  /usr/local/bin/swift-trunk/bin/worker.pl http://128.135.250.235:45185 0722-3703570-000000 /tmp  1> /tmp/tmp.dXjNyXhGn8 2> /tmp/tmp.gLOB9vWNvL"
+/home/yadu/src/swift-trunk/cog/modules/swift/tests/trunk_config/wrapper
+python /home/yadu/src/swift-trunk/cog/modules/provider-localscheduler/examples/ec2-cloud-provider/cloud.py --submit /tmp/submit_script_9016
+jobid=549ec5ddf5bcd4fd985f86ce48a83d0b0116fbd7
+ENV
+XDG_VTNR=7
+SSH_AGENT_PID=2641
+XDG_SESSION_ID=c2
+CLUTTER_IM_MODULE=xim
+SELINUX_INIT=YES
+XDG_GREETER_DATA_DIR=/var/lib/lightdm-data/yadu
+GPG_AGENT_INFO=/run/user/1000/keyring-EqXXD5/gpg:0:1
+TERM=xterm
+SHELL=/bin/bash
+VTE_VERSION=3409
+SSH_AGENT_LAUNCHER=upstart
+WINDOWID=79691788
+UPSTART_SESSION=unix:abstract=/com/ubuntu/upstart-session/1000/2585
+GNOME_KEYRING_CONTROL=/run/user/1000/keyring-EqXXD5
+GTK_MODULES=overlay-scrollbar:unity-gtk-module
+USER=yadu
+LS_COLORS=rs=0:di=01;34:ln=01;36:mh=00:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31;01:su=37;41:sg=30;43:ca=30;41:tw=30;42:ow=34;42:st=37;44:ex=01;32:*.tar=01;31:*.tgz=01;31:*.arj=01;31:*.taz=01;31:*.lzh=01;31:*.lzma=01;31:*.tlz=01;31:*.txz=01;31:*.zip=01;31:*.z=01;31:*.Z=01;31:*.dz=01;31:*.gz=01;31:*.lz=01;31:*.xz=01;31:*.bz2=01;31:*.bz=01;31:*.tbz=01;31:*.tbz2=01;31:*.tz=01;31:*.deb=01;31:*.rpm=01;31:*.jar=01;31:*.war=01;31:*.ear=01;31:*.sar=01;31:*.rar=01;31:*.ace=01;31:*.zoo=01;31:*.cpio=01;31:*.7z=01;31:*.rz=01;31:*.jpg=01;35:*.jpeg=01;35:*.gif=01;35:*.bmp=01;35:*.pbm=01;35:*.pgm=01;35:*.ppm=01;35:*.tga=01;35:*.xbm=01;35:*.xpm=01;35:*.tif=01;35:*.tiff=01;35:*.png=01;35:*.svg=01;35:*.svgz=01;35:*.mng=01;35:*.pcx=01;35:*.mov=01;35:*.mpg=01;35:*.mpeg=01;35:*.m2v=01;35:*.mkv=01;35:*.webm=01;35:*.ogm=01;35:*.mp4=01;35:*.m4v=01;35:*.mp4v=01;35:*.vob=01;35:*.qt=01;35:*.nuv=01;35:*.wmv=01;35:*.asf=01;35:*.rm=01;35:*.rmvb=01;35:*.flc=01;35:*.avi=01;35:*.fli=01;35:
 *.flv=01;35:*.gl=01;35:*.dl=01;35:*.xcf=01;35:*.xwd=01;35:*.yuv=01;35:*.cgm=01;35:*.emf=01;35:*.axv=01;35:*.anx=01;35:*.ogv=01;35:*.ogx=01;35:*.aac=00;36:*.au=00;36:*.flac=00;36:*.mid=00;36:*.midi=00;36:*.mka=00;36:*.mp3=00;36:*.mpc=00;36:*.ogg=00;36:*.ra=00;36:*.wav=00;36:*.axa=00;36:*.oga=00;36:*.spx=00;36:*.xspf=00;36:
+DEBEMAIL=yadudoc1729 at gmail.com
+XDG_SESSION_PATH=/org/freedesktop/DisplayManager/Session0
+XDG_SEAT_PATH=/org/freedesktop/DisplayManager/Seat0
+SSH_AUTH_SOCK=/run/user/1000/keyring-EqXXD5/ssh
+DEFAULTS_PATH=/usr/share/gconf/ubuntu.default.path
+XDG_CONFIG_DIRS=/etc/xdg/xdg-ubuntu:/usr/share/upstart/xdg:/etc/xdg
+NLSPATH=/usr/dt/lib/nls/msg/%L/%N.cat
+GPGKEY=01E58D97
+PATH=/home/yadu/src/swift-trunk/cog/modules/swift/dist/swift-svn/bin:/home/yadu/src/google-cloud-sdk/bin:/home/yadu/src/swift-0.95/cog/modules/swift/dist/swift-svn/bin:/home/yadu/bin/jdk1.7.0_25/bin:/home/yadu/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/home/yadu/cctools/bin:/sbin
+DESKTOP_SESSION=ubuntu
+QT_QPA_PLATFORMTHEME=appmenu-qt5
+JOB=gnome-session
+PWD=/home/yadu/src/swift-trunk/cog/modules/swift/tests/trunk_config/wrapper
+XMODIFIERS=@im=none
+GNOME_KEYRING_PID=2582
+LANG=en_US.UTF-8
+GDM_LANG=en_US
+MANDATORY_PATH=/usr/share/gconf/ubuntu.mandatory.path
+NODE_PATH=/usr/lib/nodejs:/usr/lib/node_modules:/usr/share/javascript
+XFILESEARCHPATH=/usr/dt/app-defaults/%L/Dt
+UBUNTU_MENUPROXY=1
+IM_CONFIG_PHASE=1
+COMPIZ_CONFIG_PROFILE=ubuntu
+GDMSESSION=ubuntu
+SESSIONTYPE=gnome-session
+SHLVL=3
+XDG_SEAT=seat0
+HOME=/home/yadu
+LANGUAGE=en_US
+GNOME_DESKTOP_SESSION_ID=this-is-deprecated
+UPSTART_INSTANCE=
+UPSTART_EVENTS=started starting
+LOGNAME=yadu
+QT4_IM_MODULE=xim
+XDG_DATA_DIRS=/usr/share/ubuntu:/usr/share/gnome:/usr/local/share/:/usr/share/
+DBUS_SESSION_BUS_ADDRESS=unix:abstract=/tmp/dbus-nBcGU7DKx6
+WORKER_LOGGING_LEVELTRACE=
+DEBFULLNAME=Yadu Nand
+LESSOPEN=| /usr/bin/lesspipe %s
+INSTANCE=Unity
+UPSTART_JOB=unity-settings-daemon
+TEXTDOMAIN=im-config
+XDG_RUNTIME_DIR=/run/user/1000
+DISPLAY=:0
+XDG_CURRENT_DESKTOP=Unity
+GTK_IM_MODULE=xim
+LESSCLOSE=/usr/bin/lesspipe %s %s
+TEXTDOMAINDIR=/usr/share/locale/
+COLORTERM=gnome-terminal
+XAUTHORITY=/home/yadu/.Xauthority
+_=/usr/bin/env
+Stat'ing for 549ec5ddf5bcd4fd985f86ce48a83d0b0116fbd7
+python /home/yadu/src/swift-trunk/cog/modules/provider-localscheduler/examples/ec2-cloud-provider/cloud.py --status /home/yadu/src/swift-trunk/cog/modules/provider-localscheduler/examples/ec2-cloud-provider/configs --jobid 549ec5ddf5bcd4fd985f86ce48a83d0b0116fbd7
+549ec5ddf5bcd4fd985f86ce48a83d0b0116fbd7 Q
+549ec5ddf5bcd4fd985f86ce48a83d0b0116fbd7 R
+Cancelling 549ec5ddf5bcd4fd985f86ce48a83d0b0116fbd7
Index: modules/provider-localscheduler/examples/ec2-cloud-provider/README.asc
--- modules/provider-localscheduler/examples/ec2-cloud-provider/README.asc	(revision 0)
+++ modules/provider-localscheduler/examples/ec2-cloud-provider/README.asc	(revision 4027)
@@ -0,0 +1,35 @@
+Swift interface to the Clouds
+There are 3 core functions that the Cloud interface does:
+submit : Submits a string for execution on a cloud instance.
+               The string for execution will be the in the config file in the format :
+               CMD_STRING="<string>"
+               Once the job is submitted, cloud_submit will emit the string jobid=<uniq_jobid>
+               Returns 0 on successful submission.
+               If specification is incorrect, or an error occurred, the error message will go to stderr
+               Error: codes, not defined.
+status : Takes the unique ids of runs, and returns the status of job submitted to the cloud.
+               Prints out following:
+               <jobid> Q|R|C|F [ exitcode [<error message>] ]
+                Q - Queued - Pending run
+                R - Running
+                C - Completed
+                F - Failed optionally
+cancel : Takes one jobid as an argument. Cancels/Terminates the job.
+Examples:
+./cloud.py cloud_submit configs <string>
+./cloud.py cloud_status configs jobid1 jobid2
+./cloud.py cloud_cancel configs jobid1
Index: modules/provider-localscheduler/examples/ec2-cloud-provider/ststat
--- modules/provider-localscheduler/examples/ec2-cloud-provider/ststat	(revision 0)
+++ modules/provider-localscheduler/examples/ec2-cloud-provider/ststat	(revision 4027)
@@ -0,0 +1,11 @@
+#!/bin/bash
+LOG=/home/yadu/src/swift-trunk/cog/modules/provider-localscheduler/examples/ec2-cloud-provider/log
+CONF=/home/yadu/src/swift-trunk/cog/modules/provider-localscheduler/examples/ec2-cloud-provider/configs
+if [[ "$1" != "" ]]
+then
+	echo "Stat'ing for $1 " >> $LOG
+    echo "python /home/yadu/src/swift-trunk/cog/modules/provider-localscheduler/examples/ec2-cloud-provider/cloud.py --status $CONF --jobid $1" >> $LOG
+    python /home/yadu/src/swift-trunk/cog/modules/provider-localscheduler/examples/ec2-cloud-provider/cloud.py --status $CONF --jobid $1 | tee -a $LOG
+fi
Property changes on: modules/provider-localscheduler/examples/ec2-cloud-provider/ststat
___________________________________________________________________
Added: svn:executable
Index: modules/provider-localscheduler/examples/ec2-cloud-provider/configs
--- modules/provider-localscheduler/examples/ec2-cloud-provider/configs	(revision 0)
+++ modules/provider-localscheduler/examples/ec2-cloud-provider/configs	(revision 4027)
@@ -0,0 +1,12 @@
Index: modules/provider-localscheduler/examples/ec2-cloud-provider/stsubmit
--- modules/provider-localscheduler/examples/ec2-cloud-provider/stsubmit	(revision 0)
+++ modules/provider-localscheduler/examples/ec2-cloud-provider/stsubmit	(revision 4027)
@@ -0,0 +1,116 @@
+#!/bin/bash
+rm -f /tmp/stsubmit
+EXECUTABLE=
+DIR=
+ARGS=
+STDOUTLOC=
+STDOUTPATH=
+STDERRLOC=
+STDERRPATH=
+STDINLOC=
+STDINPATH=
+STDIN=
+STDOUT=
+STDERR=
+while read LINE; do
+	echo $LINE >>/tmp/stsubmit
+	case $LINE in
+		executable=*)
+			EXECUTABLE=${LINE#executable=}
+		directory=*)
+			DIR=${LINE#directory=}
+		arg=*)
+            if [[ ${LINE#arg=} == *cscript*pl ]]
+            then
+                # We are replacing with a specific temporary worker script
+                ARGS="$ARGS /usr/local/bin/swift-trunk/bin/worker.pl"
+            else
+                ARGS="$ARGS ${LINE#arg=}"
+            fi
+		attr.*)
+			# ignore attributes
+		stdin.location=*)
+			STDINLOC=${LINE#stdin.location=}
+		stdin.path=*)
+			STDINPATH=${LINE#stdin.path=}
+		stdout.location=*)
+			STDOUTLOC=${LINE#stdout.location=}
+		stdout.path=*)
+			STDOUTPATH=${LINE#stdout.path=}
+		stderr.location=*)
+			STDERRLOC=${LINE#stderr.location=}
+		stderr.path=*)
+			STDERRPATH=${LINE#stderr.path=}
+		env.*)
+			LINE2=${LINE#env.}
+			# split on '='
+			ELS=(${LINE2//=/})
+			NAME=${ELS[0]}
+			VALUE=${ELS[1]}
+			export $NAME=$VALUE
+			echo "Don't know how to interpret line: $LINE" >&2
+			exit 2
+	esac
+done < /dev/stdin
+if [ "$STDOUTLOC" == "tmp" ]; then
+	STDOUTPATH=$(mktemp)
+	echo "stdout.path=$STDOUTPATH"
+fi
+if [ "$STDOUTPATH" != "" ]; then
+	STDOUT="1> $STDOUTPATH"
+fi
+if [ "$STDERRLOC" == "tmp" ]; then
+	STDERRPATH=$(mktemp)
+	echo "stderr.path=$STDERRPATH"
+fi
+if [ "$STDERRPATH" != "" ]; then
+	STDERR="2> $STDERRPATH"
+fi
+if [ "$STDINLOC" != "" ]; then
+	STDIN="< $STDINLOC"
+fi
+echo "Start" > $LOG
+CMD="$EXECUTABLE $ARGS $STDIN $STDOUT $STDERR"
+echo "CMD     : $CMD" >> $LOG
+#SUBMIT_SCRIPT=$(mktemp)
+SUBMIT_SCRIPT=/tmp/submit_script_$RANDOM
+# TODO : Cleanup
+cat /home/yadu/src/swift-trunk/cog/modules/provider-localscheduler/examples/ec2-cloud-provider/configs > $SUBMIT_SCRIPT
+DIR=/tmp/
+# TODO : Fix me
+cat<<EOF >> $SUBMIT_SCRIPT
+CMD_STRING="mkdir $DIR; cd $DIR; $CMD"
+EOF
+cat $SUBMIT_SCRIPT >> $LOG
+echo "$PWD" >> $LOG
+echo "python /home/yadu/src/swift-trunk/cog/modules/provider-localscheduler/examples/ec2-cloud-provider/cloud.py --submit $SUBMIT_SCRIPT" >> $LOG
+python /home/yadu/src/swift-trunk/cog/modules/provider-localscheduler/examples/ec2-cloud-provider/cloud.py --submit $SUBMIT_SCRIPT  | tee -a $LOG
+echo "ENV" >> $LOG
+env >> $LOG
+exit 0
Property changes on: modules/provider-localscheduler/examples/ec2-cloud-provider/stsubmit
Index: modules/provider-localscheduler/examples/ec2-cloud-provider/cog-provider.properties
--- modules/provider-localscheduler/examples/ec2-cloud-provider/cog-provider.properties	(revision 0)
+++ modules/provider-localscheduler/examples/ec2-cloud-provider/cog-provider.properties	(revision 4027)
@@ -0,0 +1,4 @@
+provider=ec2-cloud
+sandbox=false
Index: modules/provider-localscheduler/examples/ec2-cloud-provider/stcancel
--- modules/provider-localscheduler/examples/ec2-cloud-provider/stcancel	(revision 0)
+++ modules/provider-localscheduler/examples/ec2-cloud-provider/stcancel	(revision 4027)
@@ -0,0 +1,10 @@
+#!/bin/bash
+then
+    echo "Cancelling $1" >> $LOG
+    python /home/yadu/src/swift-trunk/cog/modules/provider-localscheduler/examples/ec2-cloud-provider/cloud.py --cancel $CONF --jobid $1 | tee -a $LOG
+fi
Property changes on: modules/provider-localscheduler/examples/ec2-cloud-provider/stcancel
Index: modules/provider-localscheduler/examples/ec2-cloud-provider/cloud.py
--- modules/provider-localscheduler/examples/ec2-cloud-provider/cloud.py	(revision 0)
+++ modules/provider-localscheduler/examples/ec2-cloud-provider/cloud.py	(revision 4027)
@@ -0,0 +1,214 @@
+#!/usr/bin/env python
+import os
+import sys
+import random
+import logging
+import pprint
+import argparse
+import datetime
+import time
+#from __future__ import print_function
+from libcloud.compute.types import Provider
+from libcloud.compute.providers import get_driver
+from libcloud.compute.base import NodeSize, NodeImage
+from libcloud.compute.types import NodeState
+import libcloud.compute.types
+NODESTATES = { NodeState.RUNNING    : "RUNNING",
+               NodeState.REBOOTING  : "REBOOTING",
+               NodeState.TERMINATED : "TERMINATED",
+               NodeState.STOPPED    : "STOPPED",
+               NodeState.PENDING    : "PENDING",
+               NodeState.UNKNOWN    : "UNKNOWN" }
+timestamp = datetime.datetime.fromtimestamp(time.time()).strftime('%Y-%m-%d_%H:%M:%S');
+logging.basicConfig(filename='cloud_ec2'+timestamp+'.log', level=logging.INFO)
+WORKER_USERDATA='''#!/bin/bash
+export JAVA=/usr/local/bin/jdk1.7.0_51/bin
+export SWIFT=/usr/local/bin/swift-trunk/bin
+export PATH=$JAVA:$SWIFT:$PATH
+export WORKER_LOGGING_LEVEL=TRACE
+mkdir -p /home/yadu/.globus/coasters
+def aws_create_security_group(driver, configs):
+    group_name = configs["SECURITY_GROUP"]
+    current    = driver.ex_list_security_groups()
+    if group_name in current:
+        logging.info("Security group: %s is already present", group_name)
+    else:
+        logging.info("Creating new security group: %s", group_name)
+        res = driver.ex_create_security_group(name=group_name,description="Open all ports")
+        if not driver.ex_authorize_security_group(group_name, 0, 65000, '0.0.0.0/0'):
+            logging.info("Authorizing ports for security group failed")
+        if not driver.ex_authorize_security_group(group_name, 0, 65000, '0.0.0.0/0', protocol='udp'):
+        logging.debug("Security group: %s", str(res))
+def check_keypair(driver, configs):
+    if "AWS_KEYPAIR_NAME" in configs and "AWS_KEYPAIR_FILE" in configs:
+        logging.debug("AWS_KEYPAIR_NAME : %s", configs['AWS_KEYPAIR_NAME'])
+        logging.debug("AWS_KEYPAIR_FILE : %s", configs['AWS_KEYPAIR_FILE'])
+        all_pairs = driver.list_key_pairs()
+        for pair in all_pairs:
+            if pair.name == configs['AWS_KEYPAIR_NAME']:
+                logging.info("KEYPAIR exists, registered")
+                return 0
+        logging.info("KEYPAIR does not exist. Creating keypair")
+        key_pair = driver.create_key_pair(name=configs['AWS_KEYPAIR_NAME'])
+        f = open(configs['AWS_KEYPAIR_FILE'], 'w')
+        f.write(str(key_pair.private_key))
+        f.close()
+        os.chmod(configs['AWS_KEYPAIR_FILE'], 0600)
+        logging.info("KEYPAIR created")
+    else:
+        logging.error("AWS_KEYPAIR_NAME and/or AWS_KEYPAIR_FILE missing")
+        logging.error("Cannot proceed without AWS_KEYPAIR_NAME and AWS_KEYPAIR_FILE")
+        exit(-1)
+def _read_conf(config_file):
+    cfile = open(config_file, 'r').read()
+    config = {}
+    for line in cfile.split('\n'):
+        # Checking if empty line or comment
+        if line.startswith('#') or not line :
+            continue
+        temp = line.split('=')
+        config[temp[0]] = temp[1].strip('\r')
+    return config
+def pretty_configs(configs):
+    printer = pprint.PrettyPrinter(indent=4)
+    printer.pprint(configs)
+def read_configs(config_file):
+    config = _read_conf(config_file)
+    if 'AWS_CREDENTIALS_FILE' in config :
+        config['AWS_CREDENTIALS_FILE'] =  os.path.expanduser(config['AWS_CREDENTIALS_FILE'])
+        config['AWS_CREDENTIALS_FILE'] =  os.path.expandvars(config['AWS_CREDENTIALS_FILE'])
+        cred_lines    =  open(config['AWS_CREDENTIALS_FILE']).readlines()
+        cred_details  =  cred_lines[1].split(',')
+        credentials   = { 'AWS_Username'   : cred_details[0],
+                          'AWSAccessKeyId' : cred_details[1],
+                          'AWSSecretKey'   : cred_details[2] }
+        config.update(credentials)
+    else:
+        print "AWS_CREDENTIALS_FILE , Missing"
+        print "ERROR: Cannot proceed without access to AWS_CREDENTIALS_FILE"
+        exit(-1)
+    if 'AWS_KEYPAIR_FILE' in config:
+        config['AWS_KEYPAIR_FILE'] = os.path.expanduser(config['AWS_KEYPAIR_FILE'])
+        config['AWS_KEYPAIR_FILE'] = os.path.expandvars(config['AWS_KEYPAIR_FILE'])
+    return config
+def node_status(driver, node_uuids):
+    logging.info("Checking status of : %s", str(node_uuids))
+    nodes = driver.list_nodes()
+    for node in nodes:
+        logging.info("INFO: Node status : %s",str(node))
+        if node.uuid in node_uuids :
+            if node.state == NodeState.RUNNING:
+                print node.uuid, "R"
+            elif node.state == NodeState.PENDING:
+                print node.uuid, "Q"
+            elif node.state == NodeState.TERMINATED:
+                print node.uuid, "C"
+            elif node.state == NodeState.STOPPED:
+            elif node.state == NodeState.UNKNOWN:
+                print node.uuid, "Q" # This state could be wrong
+            else:
+                logging.warn("Node state unknown/invalid %s", NODESTATE[node.state])
+                return -1
+    return 0
+def node_start(driver, configs, WORKER_STRING):
+    # Setup userdata
+    userdata   = WORKER_USERDATA + WORKER_STRING.lstrip('"').rstrip('"')
+    logging.info("Worker userdata : %s", userdata)
+    size       = NodeSize(id=configs['WORKER_MACHINE_TYPE'], name="swift_worker",
+                          ram=None, disk=None, bandwidth=None, price=None, driver=driver)
+    image      = NodeImage(id=configs['WORKER_IMAGE'], name=None, driver=driver)
+    node       = driver.create_node(name="swift_worker",
+                                    image=image,
+                                    size=size,
+                                    ex_keyname=configs['AWS_KEYPAIR_NAME'],
+                                    ex_securitygroup=configs['SECURITY_GROUP'],
+                                    ex_userdata=userdata )
+    logging.info("Worker node started : %s", str(node))
+    print 'jobid={0}'.format(node.uuid)
+# node_names is a list
+def node_terminate(driver, node_uuids):
+    deleted_flag   = False
+        if node.uuid in node_uuids and node.state == NodeState.RUNNING :
+            logging.info("Terminating node : %s", str(node))
+            code = driver.destroy_node(node)
+            deleted_flag = True
+    return deleted_flag
+def init_checks(driver, configs):
+    aws_create_security_group(driver, configs)
+    check_keypair(driver, configs)
+def init(conf_file):
+    configs    = read_configs(conf_file)
+    #pretty_configs(configs)
+    driver     = get_driver(Provider.EC2_US_WEST_OREGON) # was EC2
+    ec2_driver = driver(configs['AWSAccessKeyId'], configs['AWSSecretKey'])
+    return configs,ec2_driver
+# Main driver section
+#configs, driver = init()
+#args = sys.argv[1:]
+#print "All args : ",str(args)
+if __name__ == '__main__' :
+    parser   = argparse.ArgumentParser()
+    mu_group = parser.add_mutually_exclusive_group(required=True)
+    mu_group.add_argument("-s", "--submit", default=None ,  help='Takes a config file. Submits the CMD_STRING in the configs for execution on a cloud resource')
+    mu_group.add_argument("-t", "--status", default=None ,  help='gets the status of the CMD_STRING in the configs for execution on a cloud resource')
+    mu_group.add_argument("-c", "--cancel", default=None ,  help='cancels the jobs with jobids')
+    parser.add_argument("-v", "--verbose", help="set level of verbosity, DEBUG, INFO, WARN")
+    parser.add_argument("-j", "--jobid", type=str, action='append')
+    args   = parser.parse_args()
+    config_file  = ( args.status or args.submit or args.cancel )
+    configs, driver = init(config_file)
+    if args.submit :
+        # Init checks confirm keypairs and security groups to allow for access to ports
+        init_checks(driver, configs)
+        node_start(driver, configs, configs['CMD_STRING'])
+    elif args.status :
+        node_status(driver, args.jobid )
+    elif args.cancel :
+        node_terminate(driver, args.jobid)
+    else:
+        sys.stderr.write("ERROR: Undefined args, cannot be handled")
+        sys.stderr.write("ERROR: Exiting...")
+        exit(-1)
+    exit(0)
Property changes on: modules/provider-localscheduler/examples/ec2-cloud-provider/cloud.py
