[Swift-commit] r8058 - www/Swift-T
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Mon Jul 21 14:36:51 CDT 2014
Author: wozniak
Date: 2014-07-21 14:36:51 -0500 (Mon, 21 Jul 2014)
New Revision: 8058
Modified:
   www/Swift-T/turbine-sites.html
Log:
Doc fixes
Modified: www/Swift-T/turbine-sites.html
--- www/Swift-T/turbine-sites.html	2014-07-21 19:23:07 UTC (rev 8057)
+++ www/Swift-T/turbine-sites.html	2014-07-21 19:36:51 UTC (rev 8058)
@@ -1272,20 +1272,23 @@
 </div>
 </div>
 <div class="sect2">
-<h3 id="_eureka">Eureka</h3>
-<div class="paragraph"><p>Eureka is a 100-node x86 cluster at the Argonne Leadership Computing
-Facility (ALCF).  It uses the Cobalt scheduler.</p></div>
+<h3 id="_tukey">Tukey</h3>
+<div class="paragraph"><p><a href="https://www.alcf.anl.gov/user-guides/tukey">Tukey</a> is a 96-node x86
+cluster at the Argonne Leadership Computing Facility (ALCF).  It uses
+the Cobalt scheduler.</p></div>
+<div class="paragraph"><p><strong>As of:</strong> Trunk, 4/9/2014</p></div>
 <div class="sect3">
-<h4 id="_build_procedure_3">Build procedure</h4>
+<h4 id="_public_installation_3">Public installation</h4>
+<div class="paragraph"><p>Add to <code>PATH</code>:</p></div>
 <div class="ulist"><ul>
 <li>
 <p>
-Configure Tcl and c-utils with gcc
+STC: <code>~wozniak/Public/sfw/x86/stc/bin</code>
 </p>
 </li>
 <li>
 <p>
-Configure ADLB with mpicc
+Turbine submit script: <code>~wozniak/Public/sfw/x86/turbine/scripts/submit/cobalt</code>
 </p>
 </li>
 </ul></div>
@@ -1293,34 +1296,13 @@
 <div class="listingblock">
 <div class="content">
 <pre><code>export MODE=cluster
-submit/cobalt/turbine-cobalt-run.zsh -n 3 ~/program.tcl</code></pre>
-</div></div>
-<div class="paragraph"><p>The normal Turbine environment variables are honored, plus the
-<a href="#variables">Turbine scheduler variables</a>.</p></div>
-</div>
-</div>
-<div class="sect2">
-<h3 id="_tukey">Tukey</h3>
-<div class="paragraph"><p><a href="https://www.alcf.anl.gov/user-guides/tukey">Tukey</a> is a 96-node x86
-cluster at the Argonne Leadership Computing Facility (ALCF).  It uses
-the Cobalt scheduler.</p></div>
-<div class="paragraph"><p><strong>As of:</strong> Trunk, 4/9/2014</p></div>
-<div class="sect3">
-<h4 id="_public_installation_3">Public installation</h4>
-<div class="paragraph"><p>Add to <code>PATH</code>:
-* STC: <code><sub>wozniak/Public/sfw/x86/stc/bin</code>
-* Turbine submit script: <code></sub>wozniak/Public/sfw/x86/turbine/scripts/submit/cobalt</code></p></div>
-<div class="paragraph"><p>To run:</p></div>
-<div class="listingblock">
-<div class="content">
-<pre><code>export MODE=cluster
 export QUEUE=pubnet
 export PROJECT=...
 turbine-cobalt-run.zsh -n 3 program.tcl</code></pre>
 </div></div>
 </div>
 <div class="sect3">
-<h4 id="_build_procedure_4">Build procedure</h4>
+<h4 id="_build_procedure_3">Build procedure</h4>
 <li>
 <p>
@@ -1368,7 +1350,7 @@
 <a href="#options">Turbine run script options</a> for additional settings.</p></div>
 </div>
 <div class="sect3">
-<h4 id="_build_procedure_5">Build procedure</h4>
+<h4 id="_build_procedure_4">Build procedure</h4>
 <div class="paragraph"><p>Apparently need to append to use GCC 4.7.2 and set <code>LD_LIBRARY_PATH</code>:</p></div>
@@ -1429,7 +1411,7 @@
 </div></div>
 </div>
 <div class="sect4">
-<h5 id="_build_procedure_6">Build procedure</h5>
+<h5 id="_build_procedure_5">Build procedure</h5>
 <div class="paragraph"><p>To run on the <a href="#login_node">login node</a>:</p></div>
 <li>
@@ -1596,7 +1578,7 @@
 </li>
 </ul></div>
 <div class="sect4">
-<h5 id="_build_procedure_7">Build procedure</h5>
+<h5 id="_build_procedure_6">Build procedure</h5>
 <div class="paragraph"><p><strong>As of:</strong> 0.5.0 - 4/4/2014</p></div>
 <div class="paragraph"><p><strong>Tcl:</strong></p></div>
 <div class="paragraph"><p>The GCC installation does not support shared libraries.  Thus, you
@@ -1673,7 +1655,7 @@
 <div class="paragraph"><p>Blue Waters is a Cray XE6/XK7 at the University of Illinois at
 Urbana-Champaign.</p></div>
 <div class="sect3">
-<h4 id="_build_procedure_8">Build procedure</h4>
+<h4 id="_build_procedure_7">Build procedure</h4>
 <div class="paragraph"><p><strong>As of:</strong>  11/05/2013</p></div>
 <div class="paragraph"><p>Cray systems do not use <code>mpicc</code>.  We set <code>CC=gcc</code> and use compiler
 flags to configure the MPI library.</p></div>
@@ -1953,7 +1935,7 @@
 </div>
 </div>
 <div class="sect3">
-<h4 id="_build_procedure_9">Build procedure</h4>
+<h4 id="_build_procedure_8">Build procedure</h4>
@@ -2012,7 +1994,7 @@
 <h3 id="_raven">Raven</h3>
 <div class="paragraph"><p>Raven is a Cray XE6/XK7 at Cray.</p></div>
 <div class="sect3">
-<h4 id="_build_procedure_10">Build procedure</h4>
+<h4 id="_build_procedure_9">Build procedure</h4>
 <li>
 <p>
@@ -2154,7 +2136,7 @@
 <div id="footer">
 <div id="footer-text">
 Version 0.5.0<br />
-Last updated 2014-04-22 13:21:57 CDT
+Last updated 2014-07-21 14:36:09 CDT
 </div>
 </div>
 </body>
