[Swift-commit] r8036 - trunk/src/org/griphyn/vdl/karajan/lib
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Wed Jul 16 22:44:51 CDT 2014
Author: hategan
Date: 2014-07-16 22:44:51 -0500 (Wed, 16 Jul 2014)
New Revision: 8036
Added:
   trunk/src/org/griphyn/vdl/karajan/lib/Mapping.java
Log:
added missing mapping function definitions
Added: trunk/src/org/griphyn/vdl/karajan/lib/Mapping.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Mapping.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Mapping.java	2014-07-17 03:44:51 UTC (rev 8036)
@@ -0,0 +1,105 @@
+//This code is developed as part of the Java CoG Kit project
+//The terms of the license can be found at http://www.cogkit.org/license
+//This message may not be removed or altered.
+ * Created on Jun 1, 2014
+package org.griphyn.vdl.karajan.lib;
+import k.rt.Stack;
+import k.thr.LWThread;
+import org.globus.cog.karajan.analyzer.ArgRef;
+import org.globus.cog.karajan.analyzer.ChannelRef;
+import org.globus.cog.karajan.analyzer.CompilationException;
+import org.globus.cog.karajan.analyzer.Scope;
+import org.globus.cog.karajan.analyzer.Signature;
+import org.globus.cog.karajan.analyzer.Var;
+import org.globus.cog.karajan.analyzer.VarRef;
+import org.globus.cog.karajan.compiled.nodes.InternalFunction;
+import org.globus.cog.karajan.compiled.nodes.Node;
+import org.globus.cog.karajan.compiled.nodes.functions.AbstractFunction;
+import org.globus.cog.karajan.parser.WrapperNode;
+import org.globus.cog.karajan.util.Pair;
+import org.griphyn.vdl.mapping.GenericMappingParamSet;
+public class Mapping {
+    public static class Cons extends InternalFunction {
+    	private ArgRef<String> descriptor;
+    	private ChannelRef<Pair<String, Object>> c_vargs;
+    	private VarRef<GenericMappingParamSet> r_mapping;
+        @Override
+        protected Signature getSignature() {
+            return new Signature(params("descriptor", "..."), returns("mapping"));
+        @Override
+        protected void runBody(LWThread thr) {
+            Stack stack = thr.getStack();
+            String descriptor = this.descriptor.getValue(stack);
+            GenericMappingParamSet mp = new GenericMappingParamSet(descriptor);
+            for (Pair<String, Object> param : c_vargs.get(stack)) {
+            	mp.addParam(param);
+            r_mapping.setValue(stack, mp);
+        @Override
+        protected Node compileBody(WrapperNode w, Scope argScope, Scope scope) throws CompilationException {
+            String descriptor = this.descriptor.getValue();
+            Var.Channel args = argScope.lookupChannel("...");
+            Var ret = scope.parent.lookupParam("mapping");
+            if (descriptor == null || args.isDynamic()) {
+            	return this;
+            for (Object o : args.getAll()) {
+            	@SuppressWarnings("unchecked")
+                Pair<String, Object> param = (Pair<String, Object>) o;
+            ret.setValue(mp);
+            return null;
+    public static class Parameter extends AbstractFunction {
+        private ArgRef<String> name;
+        private ArgRef<String> value;
+        @Override
+            return new Signature(params("name", "value"));
+        @Override
+        public Object function(Stack stack) {
+            return new Pair<String, Object>(name.getValue(stack), value.getValue(stack));
+        @Override
+        	Var.Channel crv = scope.parent.lookupChannel("...");
+            if (name.getValue() == null || value.getValue() == null) {
+            	crv.appendDynamic();
+            	return this;
+            else {
+            	crv.append(new Pair<String, Object>(name.getValue(), value.getValue()));
+            	return null;
