[Swift-commit] r8028 - www/papers
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Wed Jul 16 15:33:43 CDT 2014
Author: wozniak
Date: 2014-07-16 15:33:42 -0500 (Wed, 16 Jul 2014)
New Revision: 8028
Modified:
   www/papers/index.php
Log:
Link to papers
Modified: www/papers/index.php
--- www/papers/index.php	2014-07-16 20:06:20 UTC (rev 8027)
+++ www/papers/index.php	2014-07-16 20:33:42 UTC (rev 8028)
@@ -55,7 +55,7 @@
         <span class="title">Compiler techniques for massively scalable implicit task parallelism</span>
 	<span class="source">Proc SC</span>
         <span class="date">2014.</span>
-        [ <a href="pdfs/.pdf">pdf</a> ]
+        [ <a href="pdfs/Swift_2014.pdf">pdf</a> ]
 </div>
 <div class="publication">
@@ -63,7 +63,7 @@
         <span class="title">Design and evaluation of the GeMTC framework for GPU-enabled many-task computing</span>
 	<span class="source">Proc. HPDC</span>
+        [ <a href="pdfs/GeMTC_2014.pdf">pdf</a> ]
 </div>
@@ -71,7 +71,7 @@
         <span class="title">Evaluating storage systems for scientific data in the cloud</span>
 	<span class="source">Proc. ScienceCloud (Best Paper Awardee)</span>
+        [ <a href="pdfs/ScientificStorageCloud_2014.pdf">pdf</a> ]
 </div>
@@ -79,7 +79,7 @@
         <span class="title">Toward computational experiment management via multi-language applications</span>
 	<span class="source">Proc. ASCR Workshop on Software Productivity for Extreme-Scale Science</span>
+        [ <a href="pdfs/Multilanguage_2014.pdf">pdf</a> ]
 </div>
@@ -87,7 +87,7 @@
         <span class="title"> Productive composition of extreme-scale applications using implicitly parallel dataflow</span>
+        [ <a href="pdfs/Dataflow_2014.pdf">pdf</a> ]
 </div>
@@ -95,7 +95,7 @@
         <span class="title">Reusability in science: From initial user engagement to dissemination of results</span>
 	<span class="source">Proc. Workshop on Sustainable Software for Science: Practice and Experiences at SC</span>
         <span class="date">2013.</span>
+        [ <a href="pdfs/Reusability_2013.pdf">pdf</a> ]
 </div>
@@ -103,7 +103,7 @@
         <span class="title">Extending the Galaxy portal with parallel and distributed execution capability </span>
 	<span class="source">Proc. DataCloud </span>
+        [ <a href="pdfs/Swift-Galaxy_2013.pdf">pdf</a> ]
 </div>
@@ -111,7 +111,7 @@
         <span class="title">Enabling multi-task computation on Galaxy-based gateways using Swift</span>
 	<span class="source">Proc. Science Gateway Institute Workshop</span>
+        [ <a href="pdfs/Galaxy-Gateways_2013.pdf">pdf</a> ]
 </div>
@@ -119,7 +119,7 @@
         <span class="title">Turbine: A distributed-memory dataflow engine for high performance many-task applications. </span>
 	<span class="source">Fundamenta Informaticae 128(3) </span>
+        [ <a href="pdfs/Turbine_2013.pdf">pdf</a> ]
 </div>
@@ -128,7 +128,7 @@
         <span class="title">Dataflow coordination of data-parallel tasks via MPI 3.0 </span>
 	<span class="source">Proc. EuroMPI</span>
+        [ <a href="pdfs/Swift_MPI_2013.pdf">pdf</a> ]
 </div>
@@ -137,7 +137,7 @@
         <span class="title">JETS: Language and system support for many-parallel-task workflows </span>
 	<span class="source"> J. Grid Computing 11(3), 2013. </span>
+        [ <a href="pdfs/JETS_2013.pdf">pdf</a> ]
 </div>
@@ -145,7 +145,7 @@
         <span class="title">Swift/T: Large-scale application composition via distributed-memory data flow processing </span>
 	<span class="source">Proc CCGrid</span>
+        [ <a href="pdfs/Swift_2013.pdf">pdf</a> ]
 </div>
@@ -153,7 +153,7 @@
         <span class="title">Evaluating cloud computing techniques for smart power grid design using parallel scripting </span>
+        [ <a href="pdfs/Swift_PowerGrid_2013.pdf">pdf</a> ]
 </div>
@@ -161,7 +161,7 @@
         <span class="title">A model for tracing and debugging large-scale task-parallel programs with MPE </span>
 	<span class="source">Proc. Workshop on Leveraging Abstractions and Semantics in High-performance Computing at PPoPP</span>
+        [ <a href="pdfs/Swift_MPE_2013.pdf">pdf</a> ]
 </div>
@@ -169,7 +169,7 @@
         <span class="title">Turbine: A distributed-memory dataflow engine for extreme-scale many-task applications </span>
 	<span class="source">Proc. Workshop on Scalable Workflow Enactment Engines and Technologies at SIGMOD</span>
         <span class="date">2012.</span>
+        [ <a href="pdfs/Turbine_2012.pdf">pdf</a> ]
 </div>
@@ -531,3 +531,9 @@
 } catch(err) {}</script>
 </body>
 </html>
+ Local Variables:
+ mode: html
+ End:
