[Swift-commit] r8019 - in trunk/src/org/griphyn/vdl: karajan/lib mapping mapping/nodes
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Sun Jul 13 02:37:20 CDT 2014
Author: hategan
Date: 2014-07-13 02:37:19 -0500 (Sun, 13 Jul 2014)
New Revision: 8019
Modified:
   trunk/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java
   trunk/src/org/griphyn/vdl/mapping/OpenArrayEntries.java
   trunk/src/org/griphyn/vdl/mapping/nodes/AbstractDataNode.java
   trunk/src/org/griphyn/vdl/mapping/nodes/AbstractFutureArrayDataNode.java
   trunk/src/org/griphyn/vdl/mapping/nodes/InitMapper.java
Log:
fixed future notification loops (see r4024 in cog)
Modified: trunk/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java
--- trunk/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java	2014-07-13 07:35:49 UTC (rev 8018)
+++ trunk/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java	2014-07-13 07:37:19 UTC (rev 8019)
@@ -288,7 +288,7 @@
 	        catch (ConditionalYield y) {
 	            helper.resetItUpdated();
-	            y.getFuture().addListener(this);
+	            y.getFuture().addListener(this, y);
 	            throw new ConditionalYield(helper);
@@ -323,7 +323,7 @@
 	    private boolean itUpdated;
         @Override
-        public synchronized void addListener(FutureListener l) {
+        public synchronized void addListener(FutureListener l, ConditionalYield y) {
             if (itUpdated) {
                 l.futureUpdated(this);
Modified: trunk/src/org/griphyn/vdl/mapping/OpenArrayEntries.java
--- trunk/src/org/griphyn/vdl/mapping/OpenArrayEntries.java	2014-07-13 07:35:49 UTC (rev 8018)
+++ trunk/src/org/griphyn/vdl/mapping/OpenArrayEntries.java	2014-07-13 07:37:19 UTC (rev 8019)
@@ -46,7 +46,7 @@
                             return false;
                         else {
-                            throw new ConditionalYield(source);
+                            throw new ConditionalYield(source, keyList.size());
@@ -64,7 +64,7 @@
                             throw new NoSuchElementException();
                         else {
Modified: trunk/src/org/griphyn/vdl/mapping/nodes/AbstractDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/nodes/AbstractDataNode.java	2014-07-13 07:35:49 UTC (rev 8018)
+++ trunk/src/org/griphyn/vdl/mapping/nodes/AbstractDataNode.java	2014-07-13 07:37:19 UTC (rev 8019)
@@ -25,6 +25,7 @@
 import java.util.List;
 import java.util.Map;
+import k.rt.ConditionalYield;
 import k.rt.FutureListener;
 import k.rt.FutureValue;
@@ -446,12 +447,8 @@
     public void addListener(DSHandleListener listener) {
         throw new UnsupportedOperationException();
-    public void addListener(FutureListener l) {
-        addListener(l, true);
-    public void addListener(FutureListener l, boolean partialUpdates) {
+    public void addListener(FutureListener l, ConditionalYield y) {
     	boolean closed;
     	WaitingThreadsMonitor.addThread(l, this);
     	synchronized(this) {
Modified: trunk/src/org/griphyn/vdl/mapping/nodes/AbstractFutureArrayDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/nodes/AbstractFutureArrayDataNode.java	2014-07-13 07:35:49 UTC (rev 8018)
+++ trunk/src/org/griphyn/vdl/mapping/nodes/AbstractFutureArrayDataNode.java	2014-07-13 07:37:19 UTC (rev 8019)
@@ -16,6 +16,7 @@
 import org.globus.cog.karajan.futures.FutureNotYetAvailable;
@@ -77,12 +78,12 @@
     @Override
         boolean shouldNotify;
             shouldNotify = addListener0(l);
-            if (keyList != null && partialUpdates) {
+            if (keyList != null && y.getSequence() != keyList.size()) {
                 shouldNotify = true;
Modified: trunk/src/org/griphyn/vdl/mapping/nodes/InitMapper.java
--- trunk/src/org/griphyn/vdl/mapping/nodes/InitMapper.java	2014-07-13 07:35:49 UTC (rev 8018)
+++ trunk/src/org/griphyn/vdl/mapping/nodes/InitMapper.java	2014-07-13 07:37:19 UTC (rev 8019)
@@ -107,7 +107,7 @@
             this.node = node;
             waitingMapperParam = mapper.getFirstOpenParameter();
             if (waitingMapperParam != null) {
-                waitingMapperParam.addListener(this);
+                waitingMapperParam.addListener(this, null);
                 if (variableTracer.isEnabled()) {
                     variableTracer.trace(node.getThread(), node.getLine(), node.getName() + " WAIT "
                         + Tracer.getVarName(waitingMapperParam));
