[Swift-commit] r8010 - trunk/docs/userguide
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Sat Jul 12 15:33:58 CDT 2014
Author: hategan
Date: 2014-07-12 15:33:57 -0500 (Sat, 12 Jul 2014)
New Revision: 8010
Modified:
   trunk/docs/userguide/configuration.new
Log:
added details about object merging/overriding
Modified: trunk/docs/userguide/configuration.new
--- trunk/docs/userguide/configuration.new	2014-07-12 09:17:26 UTC (rev 8009)
+++ trunk/docs/userguide/configuration.new	2014-07-12 20:33:57 UTC (rev 8010)
@@ -10,14 +10,14 @@
 include "${swift.home}/etc/swift.conf"
 site.mysite {
-	execution {
-		type: "coaster"
-		URL: "my.site.org"
-		jobManager: "ssh:local"
-	staging: "local"
-	app.ALL {executable: "*"}
+    execution {
+        type: "coaster"
+        URL: "my.site.org"
+        jobManager: "ssh:local"
+    staging: "local"
+    app.ALL {executable: "*"}
 # select sites to run on
@@ -76,6 +76,59 @@
 include "${env.SWIFT_CONFIG_DIR}/glow.conf"
+Property Merging
+If two properties with the same name are present in a configuration file, they are either
+merged or the latter one overrides the earlier one. This depends on the type of property.
+Simple values are always overriden, while objects are merged. For example:
+key: 1
+key: 2
+# key is now 2
+object {
+    key1: 1
+object {
+    key2: 2
+# object is now { key1: 1, key2: 2}
+This can be used to define certain template files that contain most of the definitions for
+sites, and then include them in other files and override or add only certain aspects of
+those sites. For example, the default +swift.conf+ includes a definition for a site named
++local+ that can be used to run things on the Swift client side. If you wanted to override
+only the work directory, the following +swift.conf+ could be used:
+include "${swift.home}/etc/swift.conf"
+site.local {
+    # use existing definition for site.local, but override workDirectory
+    workDirectory: "/tmp"
+If, on the other hand, you want to fully override the definition of +site.local+, you could
+set it to +null+ first and then provide your own definition:
+# forget previous definition of site.local
+site.local: null
+# define your own site.local
+site.local {
 Configuration File Structure
@@ -98,6 +151,7 @@
     execution {...}
     [staging: "swift" | "local" | "service-local" | "shared-fs" | "wrapper"]
     [filesystem {...}]
+    workDirectory: <path>
     [<site options>]
     [<application declarations>]
@@ -111,6 +165,18 @@
 site."My-$pecial-$ite" {...}
+Once sites are declared, they must be explicitly enabled for Swift to use them. This
+can be achieved with the +sites+ option, which accepts either an array or a comma-separated
+list of site names
+sites: ["site1", "site2"]
+# alternatively:
+sites: "site1, site2"
 Execution Mechanism
@@ -478,11 +544,9 @@
 | Name           | Valid values             | Default value |
 Description
-| +sites+        | array of strings (i.e. +["site1", "site2"]+) | none |
+| +sites+        | array of strings (e.g. +["site1", "site2"]+) or CSV string (e.g. "site1, site2") | none |
 Selects, out of the set of all declared sites, a sub-set of sites to
-run applications on. This option can also be supplied on the Swift command line,
-in which case it shoud be a single string with comma-separated items
-(e.g. +swift -sites site1,site2 ...+)
+run applications on.
 | +hostName+     | string                   | autodetected  |
 Can be used to specify a publicly reacheable DNS name or IP address for this
