[Swift-commit] r8000 - trunk/docs/userguide
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Sat Jul 12 01:31:53 CDT 2014
Author: hategan
Date: 2014-07-12 01:31:53 -0500 (Sat, 12 Jul 2014)
New Revision: 8000
Added:
   trunk/docs/userguide/configuration.old
Removed:
Log:
updated old config
Deleted: trunk/docs/userguide/configuration
--- trunk/docs/userguide/configuration	2014-07-12 06:28:19 UTC (rev 7999)
+++ trunk/docs/userguide/configuration	2014-07-12 06:31:53 UTC (rev 8000)
@@ -1,596 +0,0 @@
-Configuration
-Swift uses a single configuration file called swift.properties. The swift.properties
-file is responsible for:
-1. Defining how to interface with schedulers
-2. Defining app names and locations
-3. Defining various other swift settings and behavior
-Here is an example swift.properties file.
-# Define a site named sandyb
-site.sandyb {
-   tasksPerWorker=16
-   taskWalltime=00:05:00
-   jobManager=slurm
-   jobQueue=sandyb
-   maxJobs=1
-   workdir=/scratch/midway/$USER/work
-   filesystem=local
-# Define sandyb apps
-app.sandyb.echo=/bin/echo
-# Define other swift properties
-sitedir.keep=true
-wrapperlog.always.transfer=true
-# Select which site to run on
-site=sandyb
-The details of this file will be explained more later. Let's first look
-at an example of running Swift. Using the swift.properties the new Swift
-command a user would run is:
-$ swift script.swift
-That is all that is needed. Everything Swift needs to know is defined in
-swift.properties.
-Location of swift.properties
-Swift searches for swift.properties files in multiple locations:
-1. The etc/swift.properties file included with the Swift distribution.
-2. $SWIFT_SITE_CONF/swift.properties - used for defining site templates.
-3. $HOME/.swift/swift.properties
-4. swift.properties in your current directory.
-5. Any property file you point to with the command line argument "-properties
-<file>"
-Settings get read in this order. Definitions in the later files will override
-any previous definitions. For example, if you have execution.retries=10 in
-$HOME/.swift/swift.properties, and execution.retries=0 in the swift.properties
-in your current directory, execution.retries will be set to 0.
-To verify what files are being read, and what values will be set, run:
-$ swift -listconfig
-Selecting a site
-There are two ways Swift knows where to run. The first is via
-swift.properties. The site command specified which site entries
-should be used for a particular run.
-site=sandyb
-Sites can also be selected on the command line by using the -site option.
-$ swift -site westmere script.swift
-The -site command line argument will override any sites selected in
-swift.properties.
-Selecting multiple sites
-To use multiple sites, use a list of site names separated by commas. In
-swift.properties:
-site=westmere,sandyb
-The same format can be used on the command line:
-$ swift -site westmere,sandyb script.swift
-NOTE: You can also use "sites=" in swift.properties, and "-sites x,y,z" on the
-command line.
-Run directories
-When you run Swift, you will see a run directory get created. The run
-directory has the name of runNNN, where NNN starts at 000 and increments for
-every run.
-The run directories can be useful for debugging. They contain:
-.Run directory contents
-|apps     |An apps generated from swift.properties
-|cf       |A configuration file generated from swift.properties
-|runNNN.log|The log file generated during the Swift run
-|scriptname-runNNN.d|Debug directory containing wrapper logs
-|scripts|Directory that contains scheduler scripts used for that run
-|sites.xml|A sites.xml generated from swift.properties
-|swift.out|The standard out and standard error generated by Swift
-Using site templates
-Swift recognizes an environmnet variable called $SWIFT_SITE_CONF, which points to
-a directory containing a swift.properties file. This swift.properties can contain multiple
-site definitions for the various queues available on the cluster you are using.
-Your local swift.properties then does not need to define the entire site. It
-may contain only differences you need to make that are specific to your
-application, like walltime.
-Backward compatability
-New users are encouraged to use the configuration mechanisms described in this documentation.
-However, if you are migrating from an older Swift release to 0.95, the older-style configurations
-using sites.xml and tc.data should still work. If you notice an instance where this is not true,
-please send an email to swift-support at ci.uchicago.edu.
-The swift.properties file format
-Site definitions
-Site definitions in the swift.properties files begin with "site".
-The second word is the name of the site you are defining. In these examples we
-will define a site called westmere.
-The third word is the property.
-For example:
-site.westmere.jobQueue=fast
-Before the site properties are listed, it's important to understand the
-terminology used.
-A *task*, or *app task* is an instance of a program as defined in
-a Swift app() function.
-A *worker* is the program that launches app tasks.
-A *job* is related to schedulers. It is the mechanism by which workers
-are launched.
-Below is the list of valid site properties with brief explanations of what
-they do, and an example swift.properties entry.
-.swift.properties site properties
-[options="header"]
-|Property|Description|Example
-|condor
-|Pass parameters directly through to the submit script generated for the condor
-scheduler. For example, the setting "site.osgconnect.condor.+projectname=Swift"
-will generate the line "+projectname = Swift".
-|site.osgconnect.condor.+projectname=Swift
-|filesystem
-|Defines how files should be accessed
-|site.westmere.filesystem=local
-|jobGranularity
-|Specifies the granularity of a job, in nodes
-|site.westmere.jobGranularity=2
-|jobManager
-|Specifies how jobs will be launched. The supported job managers are
-"cobalt", "slurm", "condor", "pbs", "lsf", "local", and "sge".
-|site.westmere.jobManager=slurm
-|jobProject
-|Set the project name for the job scheduler
-|site.westmere.project=myproject
-|jobQueue
-|Set the name of the scheduler queue to use.
-|site.westmere.jobQueue=westmere
-|jobWalltime
-|The maximum number amount of time allocated in a scheduler job, in hh:mm:ss
-format.
-|site.westmere.jobWalltime=01:00:00
-|maxJobs
-|Maximum number of scheduler jobs to submit
-|site.westmere.maxJobs=20
-|maxNodesPerJob
-|The maximum number of nodes to request per scheduler job.
-|site.westmere.maxNodesPerJob=2
-|pe
-|The parallel environment to use for SGE schedulers
-|site.sunhpc.pe=mpi
-|providerAttributes
-|Allows user to pass attributes through directly to scheduler submit script. Currently
-only implemented for sites that use PBS.
-|site.beagle.providerAttributes=pbs.aprun;pbs.mpp;depth=24
-|slurm
-|Pass parameters directly through to the submit script generated for the slurm
-scheduler. For example, the setting "site.midway.slurm.mail-user=username" generates
-the line "#SBATCH --mail-user=username".
-|site.midway.slurm.mail-user=username
-|stagingMethod
-|When provider staging is enabled, this option will specify the staging mechanism for
-use for each site. If set to 'file', staging is done from a filesystem accessible to
-the coaster service (typically running on the head node). If set to 'proxy', staging
-is done from a filesystem accessible to the client machine that swift is running on,
-and is proxied through the coaster service. If set to 'sfs' (short for "shared filesystem"),
-staging is done by copying files to and from a filesystem accessible by the compute node
-(such as an NFS or GPFS mount)
-|site.osg.stagingMethod=file
-|taskDir
-|Tasks will be run from this directory. In the absence of a taskDir definition,
-Swift will run the task from workdir.
-|site.westmere.taskDir=/scratch/local/$USER/work
-|tasksPerWorker
-|The number of tasks that each worker can run simultaneously.
-|site.westmere.tasksPernode=12
-|taskThrottle
-|The maximum number of active tasks across all workers.
-|site.westmere.taskThrottle=100
-|taskWalltime
-|The maximum amount of time a task may run, in hh:mm:ss.
-|site.westmere.taskWalltime=01:00:00
-|site
-|Name of site or sites to run on. This is the same as running with
-swift -site <sitename>
-|site=westmere
-|userHomeOverride
-|Sets the Swift user home. This must be a shared filesystem. This defaults
-to $HOME. For clusters where $HOME is not accessible to the worker nodes,
-you may override the value to point to a shared directory that you own.
-|site.beagle.userHomeOverride=/lustre/beagle/username
-|workdir
-|The workdirectory element specifies where on the site files can be stored.
-This directory must be available on all worker nodes that will be used for
-execution. A shared cluster filesystem is appropriate for this. Note that
-you need to specify absolute pathname for this field.
-|site.westmere.workdir=/scratch/midway/$USER/work
-Grouping site properties
-The example swift.properties in this document listed the following site
-related properties:
-site.westmere.provider=local:slurm
-site.westmere.jobsPerNode=12
-site.westmere.taskWalltime=00:05:00
-site.westmere.queue=westmere
-site.westmere.initialScore=10000
-site.westmere.filesystem=local
-site.westmere.workdir=/scratch/midway/$USER
-However, you can also simplify this by grouping site properties together with
-curly brackets.
-site.westmere {
-   provider=local:slurm
-   jobsPerNode=12
-   queue=westmere
-   initialScore=10000
-   filesystem=local
-App definitions
-In 0.95, applications wildcards will be used by default. This means that
-$PATH will be searched and pathnames to application do not have to be defined.
-In the case where you have multiple sites defined, and you want
-control over where things run, you will need to define the location of apps.
-In this scenario, you will can define apps in swift.properties with something
-like this:
-app.westmere.cat=/bin/cat
-When an app is defined in swift.properties for any site you are running on,
-wildcards will be disabled, and all apps you want to use must be defined.
-General Swift properties
-Swift behavior can be configured through general Swift properties. Below is a list of properties:
-[options="header"]
-|Name|Valid Values|Default Value|Description
-|config.rundirs
-|true, false
-|true
-|By default, Swift will generate a run directory that contains logs, scheduler submit scripts,
-debug directories, and other files associated with a particular Swift run. Setting this value
-to false disables the creation of run directories and causes all logs and directories to be
-created in the current working directory.
-|execution.retries
-|Positive integer
-|2
-|The number of time a job will be retried if it fails (giving a
- maximum of 1 + execution.retries attempts at execution)
-|file.gc.enabled
-|true, false
-|true
-|Files mapped by the concurrent mapper (i.e. when you don't
- explicitly specify a mapper) are deleted when they are not
- in use any more. This property can be used to prevent
- files mapped by the concurrent mapper from being deleted.
-|foreach.max.threads
-|Positive integer
-|1024
-|Limits the number of concurrent iterations that each foreach
- statement can have at one time. This conserves memory for swift
- programs that have large numbers of iterations (which would
- otherwise all be executed in parallel)
-|lazy.errors
-|true, false
-|false
-|Swift can report application errors in two modes, depending on the
- value of this property. If set to false, Swift will report the
- first error encountered and immediately stop execution. If set to
- true, Swift will attempt to run as much as possible from a
- Swift script before stopping execution and reporting all
- errors encountered. When developing Swift scripts, using the default value of
- false can make the program easier to debug. However in production
- runs, using true will allow more of a Swift script to be
- run before Swift aborts execution.
-|swift.home
-|String
-|Points to the Swift installation directory ($SWIFT_HOME). In general, this should
- not be set as Swift can find its own installation directory, and incorrectly setting it may impair the
- correct functionality of Swift.
-|pgraph
-|true, false
-|false
-|Swift can generate a Graphviz <http://www.graphviz.org/> file
-representing the structure of the Swift script it has run. If
-this property is set to true, Swift will save the provenance graph
-in a file named by concatenating the program name and the instance
-ID (e.g. helloworld-ht0adgi315l61.dot).
-If set to false, no provenance graph will be generated. If a file
-name is used, then the provenance graph will be saved in the
-specified file.
-The generated dot file can be rendered into a graphical form using
-Graphviz <http://www.graphviz.org/>, for example with a command-line
-such as:
-$ swift -pgraph graph1.dot q1.swift
-$ dot -ograph.png -Tpng graph1.dot
-|pgraph.graph.options
-|String
-|splines="compound", rankdir="TB"
-|This property specifies a Graphviz <http://www.graphviz.org>
- specific set of parameters for the graph.
-|pgraph.node.options
-|String
-|color="seagreen", style="filled"
-|Used to specify a set of Graphviz <http://www.graphviz.org> specific
- properties for the nodes in the graph.
-|provenance.log
-|true, false
-|false
-|This property controls whether the log file will contain provenance
- information enabling this will increase the size of log files,
- sometimes significantly.
-|provider.staging.pin.swiftfiles
-|true, false
-|false
-|When provider staging is enabled and provider.staging.pin.swiftfiles
- is set, cache some small files needed by Swift to avoid the cost
- of staging more than once.
-|sitedir.keep
-|true, false
-|false
-|Indicates whether the working directory on the remote site should be
- left intact even when a run completes successfully. This can be used
- to inspect the site working directory for debugging purposes.
-|status.mode
-|files, provider
-|files
-|Controls how Swift will communicate the result code of running user
- programs from workers to the submit side. In files mode, a file
- indicating success or failure will be created on the site shared
- filesystem. In provider mode, the execution provider job status
- will be used. provider mode requires the underlying job execution system to
- correctly return exit codes.
-|tcp.port.range
-|none
-|<start>,<end> where start and end are integers
-|A TCP port range can be specified to restrict the ports on which
- GRAM callback services are started. This is likely needed if your
- submit host is behind a firewall, in which case the firewall should
- be configured to allow incoming connections on ports in the range.
-|throttle.file.operations
-|<int>, off
-|8
-|Limits the total number of concurrent file operations that can
- happen at any given time. File operations (like transfers) require
- an exclusive connection to a site. These connections can be
- expensive to establish. A large number of concurrent file operations
- may cause Swift to attempt to establish many such expensive
- connections to various sites. Limiting the number of concurrent file
- operations causes Swift to use a small number of cached connections
- and achieve better overall performance.
-|throttle.host.submit
-|<int>, off
-|2
-|Limits the number of concurrent submissions for any of the sites
- Swift will try to send jobs to. In other words it guarantees that no
- more than the value of this throttle jobs sent to any site will be
- concurrently in a state of being submitted.
-|throttle.score.job.factor
-|<int>, off
-|4
-|The Swift scheduler has the ability to limit the number of
-concurrent jobs allowed on a site based on the performance history
-of that site. Each site is assigned a score (initially 1), which can
-increase or decrease based on whether the site yields successful or
-faulty job runs. The score for a site can take values in the (0.1,
-100) interval. The number of allowed jobs is calculated using the
-following formula:
-2 + score*throttle.score.job.factor
-This means a site will always be allowed at least two concurrent
-jobs and at most 2 + 100*throttle.score.job.factor. With a default
-of 4 this means at least 2 jobs and at most 402.
-This parameter can also be set per site using the jobThrottle
-profile key in a site catalog entry.
-|throttle.submit
-|<int>, off
-|4
-|Limits the number of concurrent submissions for a run. This throttle
- only limits the number of concurrent tasks (jobs) that are being
- sent to sites, not the total number of concurrent jobs that can be
- run. The submission stage in GRAM is one of the most CPU expensive
- stages (due mostly to the mutual authentication and delegation).
- Having too many concurrent submissions can overload either or both
- the submit host CPU and the remote host/head node causing degraded
- performance.
-|throttle.transfers
-|<int>, off
-|4
-|Limits the total number of concurrent file transfers that can happen
- at any given time. File transfers consume bandwidth. Too many
- concurrent transfers can cause the network to be overloaded
- preventing various other signaling traffic from flowing properly.
-|ticker.date.format
-|String
-|Describes how to format the ticker date output. The format of this string
- is documented in the Java SimpleDateFormat class, at
- http://docs.oracle.com/javase/6/docs/api/java/text/SimpleDateFormat.html
-|ticker.disable
-|true, false
-|false
-|When set to true, suppresses the output progress ticker that Swift
- sends to the console every few seconds during a run
-|ticker.prefix
-|String
-|Progress:
-|String to prepend to ticker output
-|tracing.enabled
-|true, false
-|true
-|Enables tracing of procedure invocations, assignments,
- iteration constructs, as well as certain dataflow events
- such as data intialization and waiting. This is done at
- a slight decrease in performance. Traces will be available
- in the log file.
-|use.wrapper.staging
-|true, false
-|false
-|Determines if the Swift wrapper should do file staging.
-|use.provider.staging
-|true, false
-|false
-|If true, files will be staged by Swift over the network.
-|wrapper.invocation.mode
-|absolute, relative
-|absolute
-|Determines if Swift remote wrappers will be executed by specifying
- an absolute path, or a path relative to the job initial working
- directory. In most cases, execution will be successful with either
- option. However, some execution sites ignore the specified initial
- working directory, and so absolute must be used. Conversely on
- some sites, job directories appear in a different place on the
- worker node file system than on the filesystem access node, with the
- execution system handling translation of the job initial working
- directory. In such cases, relative mode must be used.
-|wrapper.parameter.mode
-|args,files
-|args
-|Controls how Swift will supply parameters to the remote wrapper
- script. args mode will pass parameters on the command line. Some
- execution systems do not pass commandline parameters sufficiently
- cleanly for Swift to operate correctly. files mode will pass
- parameters through an additional input file. This
- provides a cleaner communication channel for parameters, at the
- expense of transferring an additional file for each job invocation.
-|wrapperlog.always.transfer
-|true, false
-|false
-|This property controls when output from the Swift remote wrapper is
- transfered back to the submit site. When set to false, wrapper
- logs are only transfered for jobs that fail. If set to true,
- wrapper logs are transfered after every job is completed or failed.
-Using shell variables
-Any value in swift.properties may contain environment variables. For example:
-workdir=/scratch/midway/$USER/work
-Environment variables are expanded locally on the machine where you are running
-Swift.
-Swift will also define a variable called $RUNDIRECTORY that is the path to the
-run directory Swift creates. In a case where you'd like your work directory
-to be in the runNNN directory, you may do something like this:
-workdir=$RUNDIRECTORY
Deleted: trunk/docs/userguide/configuration.old
--- trunk/docs/userguide/configuration.old	2014-07-12 06:28:19 UTC (rev 7999)
+++ trunk/docs/userguide/configuration.old	2014-07-12 06:31:53 UTC (rev 8000)
@@ -1,542 +0,0 @@
-Configuration
-site.sandyb {
-   tasksPerWorker=16
-   jobManager=slurm
-   jobQueue=sandyb
-   maxJobs=1
-   filesystem=local
-sitedir.keep=true
-site=sandyb
-swift.properties.
-<file>"
-Selecting a site
-site=sandyb
-swift.properties.
-swift.properties:
-command line.
-Run directories
-every run.
-Site definitions
-For example:
-terminology used.
-are launched.
-[options="header"]
-|condor|
-Pass parameters directly through to the submit script generated for the condor
-|filesystem|
-Defines how files should be accessed
-|jobGranularity|
-Specifies the granularity of a job, in nodes
-|jobManager|
-Specifies how jobs will be launched. The supported job managers are
-|jobProject|
-Set the project name for the job scheduler
-|jobQueue|
-Set the name of the scheduler queue to use.
-|jobWalltime|
-The maximum number amount of time allocated in a scheduler job, in hh:mm:ss
-format.
-|maxJobs|
-Maximum number of scheduler jobs to submit
-|maxNodesPerJob|
-The maximum number of nodes to request per scheduler job.
-|providerAttributes|
-Allows user to pass attributes through directly to scheduler submit script. Currently
-|slurm|
-Pass parameters directly through to the submit script generated for the slurm
-|taskDir|
-Tasks will be run from this directory. In the absence of a taskDir definition,
-|tasksPerWorker|
-The number of tasks that each worker can run simultaneously.
-|taskThrottle|
-The maximum number of active tasks across all workers.
-|taskWalltime|
-The maximum amount of time a task may run, in hh:mm:ss.
-|site    |
-Name of site or sites to run on. This is the same as running with
-|site=westmere
-|userHomeOverride|
-Sets the Swift user home. This must be a shared filesystem. This defaults
-|workdir |
-The workdirectory element specifies where on the site files can be stored.
-site.westmere.maxWalltime=00:05:00
-site.westmere.workdir=/scratch/midway/davidkelly999
-curly brackets.
-site.westmere {
-   jobsPerNode=12
-   maxWalltime=00:05:00
-   queue=westmere
-   filesystem=local
-App definitions
-like this:
-[options="header"]
-|config.rundirs
-|true, false
-|true
-|debug directories, and other files associated with a particular Swift run. Setting this value
-|to false disables the creation of run directories and causes all logs and directories to be
-|created in the current working directory.
-|execution.retries
-|Positive integer
-|2
-|Positive integer
-|1024
-|lazy.errors
-|true, false
-|false
-|swift.home
-|String
-|pgraph
-|true, false
-|false
-specified file.
-such as:
-|String
-|String
-|provenance.log
-|true, false
-|false
-|sitedir.keep
-|true, false
-|false
-|status.mode
-|files, provider
-|files
-|tcp.port.range
-|none
-|<int>, off
-|8
-|<int>, off
-|2
-|<int>, off
-|4
-following formula:
-|throttle.submit
-|<int>, off
-|4
- performance.
-|<int>, off
-|4
-|ticker.disable
-|true, false
-|false
-|true, false
-|false
-|absolute
-|args,files
-|args
-|true, false
-|false
-Swift.
Copied: trunk/docs/userguide/configuration.old (from rev 7999, trunk/docs/userguide/configuration)
--- trunk/docs/userguide/configuration.old	                        (rev 0)
@@ -0,0 +1,596 @@
+Configuration
+Swift uses a single configuration file called swift.properties. The swift.properties
+file is responsible for:
+1. Defining how to interface with schedulers
+2. Defining app names and locations
+3. Defining various other swift settings and behavior
+Here is an example swift.properties file.
+# Define a site named sandyb
+site.sandyb {
+   tasksPerWorker=16
+   taskWalltime=00:05:00
+   jobManager=slurm
+   jobQueue=sandyb
+   maxJobs=1
+   workdir=/scratch/midway/$USER/work
+   filesystem=local
+# Define sandyb apps
+app.sandyb.echo=/bin/echo
+# Define other swift properties
+sitedir.keep=true
+wrapperlog.always.transfer=true
+# Select which site to run on
+site=sandyb
+The details of this file will be explained more later. Let's first look
+at an example of running Swift. Using the swift.properties the new Swift
+command a user would run is:
+$ swift script.swift
+That is all that is needed. Everything Swift needs to know is defined in
+swift.properties.
+Location of swift.properties
+Swift searches for swift.properties files in multiple locations:
+1. The etc/swift.properties file included with the Swift distribution.
+2. $SWIFT_SITE_CONF/swift.properties - used for defining site templates.
+3. $HOME/.swift/swift.properties
+4. swift.properties in your current directory.
+5. Any property file you point to with the command line argument "-properties
+<file>"
+Settings get read in this order. Definitions in the later files will override
+any previous definitions. For example, if you have execution.retries=10 in
+$HOME/.swift/swift.properties, and execution.retries=0 in the swift.properties
+in your current directory, execution.retries will be set to 0.
+To verify what files are being read, and what values will be set, run:
+$ swift -listconfig
+Selecting a site
+There are two ways Swift knows where to run. The first is via
+swift.properties. The site command specified which site entries
+should be used for a particular run.
+site=sandyb
+Sites can also be selected on the command line by using the -site option.
+$ swift -site westmere script.swift
+The -site command line argument will override any sites selected in
+swift.properties.
+Selecting multiple sites
+To use multiple sites, use a list of site names separated by commas. In
+swift.properties:
+site=westmere,sandyb
+The same format can be used on the command line:
+$ swift -site westmere,sandyb script.swift
+NOTE: You can also use "sites=" in swift.properties, and "-sites x,y,z" on the
+command line.
+Run directories
+When you run Swift, you will see a run directory get created. The run
+directory has the name of runNNN, where NNN starts at 000 and increments for
+every run.
+The run directories can be useful for debugging. They contain:
+.Run directory contents
+|apps     |An apps generated from swift.properties
+|cf       |A configuration file generated from swift.properties
+|runNNN.log|The log file generated during the Swift run
+|scriptname-runNNN.d|Debug directory containing wrapper logs
+|scripts|Directory that contains scheduler scripts used for that run
+|sites.xml|A sites.xml generated from swift.properties
+|swift.out|The standard out and standard error generated by Swift
+Using site templates
+Swift recognizes an environmnet variable called $SWIFT_SITE_CONF, which points to
+a directory containing a swift.properties file. This swift.properties can contain multiple
+site definitions for the various queues available on the cluster you are using.
+Your local swift.properties then does not need to define the entire site. It
+may contain only differences you need to make that are specific to your
+application, like walltime.
+Backward compatability
+New users are encouraged to use the configuration mechanisms described in this documentation.
+However, if you are migrating from an older Swift release to 0.95, the older-style configurations
+using sites.xml and tc.data should still work. If you notice an instance where this is not true,
+please send an email to swift-support at ci.uchicago.edu.
+The swift.properties file format
+Site definitions
+Site definitions in the swift.properties files begin with "site".
+The second word is the name of the site you are defining. In these examples we
+will define a site called westmere.
+The third word is the property.
+For example:
+site.westmere.jobQueue=fast
+Before the site properties are listed, it's important to understand the
+terminology used.
+A *task*, or *app task* is an instance of a program as defined in
+a Swift app() function.
+A *worker* is the program that launches app tasks.
+A *job* is related to schedulers. It is the mechanism by which workers
+are launched.
+Below is the list of valid site properties with brief explanations of what
+they do, and an example swift.properties entry.
+.swift.properties site properties
+[options="header"]
+|Property|Description|Example
+|condor
+|Pass parameters directly through to the submit script generated for the condor
+scheduler. For example, the setting "site.osgconnect.condor.+projectname=Swift"
+will generate the line "+projectname = Swift".
+|site.osgconnect.condor.+projectname=Swift
+|filesystem
+|Defines how files should be accessed
+|site.westmere.filesystem=local
+|jobGranularity
+|Specifies the granularity of a job, in nodes
+|site.westmere.jobGranularity=2
+|jobManager
+|Specifies how jobs will be launched. The supported job managers are
+"cobalt", "slurm", "condor", "pbs", "lsf", "local", and "sge".
+|site.westmere.jobManager=slurm
+|jobProject
+|Set the project name for the job scheduler
+|site.westmere.project=myproject
+|jobQueue
+|Set the name of the scheduler queue to use.
+|site.westmere.jobQueue=westmere
+|jobWalltime
+|The maximum number amount of time allocated in a scheduler job, in hh:mm:ss
+format.
+|site.westmere.jobWalltime=01:00:00
+|maxJobs
+|Maximum number of scheduler jobs to submit
+|site.westmere.maxJobs=20
+|maxNodesPerJob
+|The maximum number of nodes to request per scheduler job.
+|site.westmere.maxNodesPerJob=2
+|pe
+|The parallel environment to use for SGE schedulers
+|site.sunhpc.pe=mpi
+|providerAttributes
+|Allows user to pass attributes through directly to scheduler submit script. Currently
+only implemented for sites that use PBS.
+|site.beagle.providerAttributes=pbs.aprun;pbs.mpp;depth=24
+|slurm
+|Pass parameters directly through to the submit script generated for the slurm
+scheduler. For example, the setting "site.midway.slurm.mail-user=username" generates
+the line "#SBATCH --mail-user=username".
+|site.midway.slurm.mail-user=username
+|stagingMethod
+|When provider staging is enabled, this option will specify the staging mechanism for
+use for each site. If set to 'file', staging is done from a filesystem accessible to
+the coaster service (typically running on the head node). If set to 'proxy', staging
+is done from a filesystem accessible to the client machine that swift is running on,
+and is proxied through the coaster service. If set to 'sfs' (short for "shared filesystem"),
+staging is done by copying files to and from a filesystem accessible by the compute node
+(such as an NFS or GPFS mount)
+|site.osg.stagingMethod=file
+|taskDir
+|Tasks will be run from this directory. In the absence of a taskDir definition,
+Swift will run the task from workdir.
+|site.westmere.taskDir=/scratch/local/$USER/work
+|tasksPerWorker
+|The number of tasks that each worker can run simultaneously.
+|site.westmere.tasksPernode=12
+|taskThrottle
+|The maximum number of active tasks across all workers.
+|site.westmere.taskThrottle=100
+|taskWalltime
+|The maximum amount of time a task may run, in hh:mm:ss.
+|site.westmere.taskWalltime=01:00:00
+|site
+|Name of site or sites to run on. This is the same as running with
+swift -site <sitename>
+|site=westmere
+|userHomeOverride
+|Sets the Swift user home. This must be a shared filesystem. This defaults
+to $HOME. For clusters where $HOME is not accessible to the worker nodes,
+you may override the value to point to a shared directory that you own.
+|site.beagle.userHomeOverride=/lustre/beagle/username
+|workdir
+|The workdirectory element specifies where on the site files can be stored.
+This directory must be available on all worker nodes that will be used for
+execution. A shared cluster filesystem is appropriate for this. Note that
+you need to specify absolute pathname for this field.
+|site.westmere.workdir=/scratch/midway/$USER/work
+Grouping site properties
+The example swift.properties in this document listed the following site
+related properties:
+site.westmere.provider=local:slurm
+site.westmere.jobsPerNode=12
+site.westmere.taskWalltime=00:05:00
+site.westmere.queue=westmere
+site.westmere.initialScore=10000
+site.westmere.filesystem=local
+site.westmere.workdir=/scratch/midway/$USER
+However, you can also simplify this by grouping site properties together with
+curly brackets.
+site.westmere {
+   provider=local:slurm
+   jobsPerNode=12
+   queue=westmere
+   initialScore=10000
+   filesystem=local
+App definitions
+In 0.95, applications wildcards will be used by default. This means that
+$PATH will be searched and pathnames to application do not have to be defined.
+In the case where you have multiple sites defined, and you want
+control over where things run, you will need to define the location of apps.
+In this scenario, you will can define apps in swift.properties with something
+like this:
+app.westmere.cat=/bin/cat
+When an app is defined in swift.properties for any site you are running on,
+wildcards will be disabled, and all apps you want to use must be defined.
+General Swift properties
+Swift behavior can be configured through general Swift properties. Below is a list of properties:
+[options="header"]
+|Name|Valid Values|Default Value|Description
+|config.rundirs
+|true, false
+|true
+|By default, Swift will generate a run directory that contains logs, scheduler submit scripts,
+debug directories, and other files associated with a particular Swift run. Setting this value
+to false disables the creation of run directories and causes all logs and directories to be
+created in the current working directory.
+|execution.retries
+|Positive integer
+|2
+|The number of time a job will be retried if it fails (giving a
+ maximum of 1 + execution.retries attempts at execution)
+|file.gc.enabled
+|true, false
+|true
+|Files mapped by the concurrent mapper (i.e. when you don't
+ explicitly specify a mapper) are deleted when they are not
+ in use any more. This property can be used to prevent
+ files mapped by the concurrent mapper from being deleted.
+|foreach.max.threads
+|Positive integer
+|1024
+|Limits the number of concurrent iterations that each foreach
+ statement can have at one time. This conserves memory for swift
+ programs that have large numbers of iterations (which would
+ otherwise all be executed in parallel)
+|lazy.errors
+|true, false
+|false
+|Swift can report application errors in two modes, depending on the
+ value of this property. If set to false, Swift will report the
+ first error encountered and immediately stop execution. If set to
+ true, Swift will attempt to run as much as possible from a
+ Swift script before stopping execution and reporting all
+ errors encountered. When developing Swift scripts, using the default value of
+ false can make the program easier to debug. However in production
+ runs, using true will allow more of a Swift script to be
+ run before Swift aborts execution.
+|swift.home
+|String
+|Points to the Swift installation directory ($SWIFT_HOME). In general, this should
+ not be set as Swift can find its own installation directory, and incorrectly setting it may impair the
+ correct functionality of Swift.
+|pgraph
+|true, false
+|false
+|Swift can generate a Graphviz <http://www.graphviz.org/> file
+representing the structure of the Swift script it has run. If
+this property is set to true, Swift will save the provenance graph
+in a file named by concatenating the program name and the instance
+ID (e.g. helloworld-ht0adgi315l61.dot).
+If set to false, no provenance graph will be generated. If a file
+name is used, then the provenance graph will be saved in the
+specified file.
+The generated dot file can be rendered into a graphical form using
+Graphviz <http://www.graphviz.org/>, for example with a command-line
+such as:
+$ swift -pgraph graph1.dot q1.swift
+$ dot -ograph.png -Tpng graph1.dot
+|pgraph.graph.options
+|String
+|splines="compound", rankdir="TB"
+|This property specifies a Graphviz <http://www.graphviz.org>
+ specific set of parameters for the graph.
+|pgraph.node.options
+|String
+|color="seagreen", style="filled"
+|Used to specify a set of Graphviz <http://www.graphviz.org> specific
+ properties for the nodes in the graph.
+|provenance.log
+|true, false
+|false
+|This property controls whether the log file will contain provenance
+ information enabling this will increase the size of log files,
+ sometimes significantly.
+|provider.staging.pin.swiftfiles
+|true, false
+|false
+|When provider staging is enabled and provider.staging.pin.swiftfiles
+ is set, cache some small files needed by Swift to avoid the cost
+ of staging more than once.
+|sitedir.keep
+|true, false
+|false
+|Indicates whether the working directory on the remote site should be
+ left intact even when a run completes successfully. This can be used
+ to inspect the site working directory for debugging purposes.
+|status.mode
+|files, provider
+|files
+|Controls how Swift will communicate the result code of running user
+ programs from workers to the submit side. In files mode, a file
+ indicating success or failure will be created on the site shared
+ filesystem. In provider mode, the execution provider job status
+ will be used. provider mode requires the underlying job execution system to
+ correctly return exit codes.
+|tcp.port.range
+|none
+|<start>,<end> where start and end are integers
+|A TCP port range can be specified to restrict the ports on which
+ GRAM callback services are started. This is likely needed if your
+ submit host is behind a firewall, in which case the firewall should
+ be configured to allow incoming connections on ports in the range.
+|throttle.file.operations
+|<int>, off
+|8
+|Limits the total number of concurrent file operations that can
+ happen at any given time. File operations (like transfers) require
+ an exclusive connection to a site. These connections can be
+ expensive to establish. A large number of concurrent file operations
+ may cause Swift to attempt to establish many such expensive
+ connections to various sites. Limiting the number of concurrent file
+ operations causes Swift to use a small number of cached connections
+ and achieve better overall performance.
+|throttle.host.submit
+|<int>, off
+|2
+|Limits the number of concurrent submissions for any of the sites
+ Swift will try to send jobs to. In other words it guarantees that no
+ more than the value of this throttle jobs sent to any site will be
+ concurrently in a state of being submitted.
+|throttle.score.job.factor
+|<int>, off
+|4
+|The Swift scheduler has the ability to limit the number of
+concurrent jobs allowed on a site based on the performance history
+of that site. Each site is assigned a score (initially 1), which can
+increase or decrease based on whether the site yields successful or
+faulty job runs. The score for a site can take values in the (0.1,
+100) interval. The number of allowed jobs is calculated using the
+following formula:
+2 + score*throttle.score.job.factor
+This means a site will always be allowed at least two concurrent
+jobs and at most 2 + 100*throttle.score.job.factor. With a default
+of 4 this means at least 2 jobs and at most 402.
+This parameter can also be set per site using the jobThrottle
+profile key in a site catalog entry.
+|throttle.submit
+|<int>, off
+|4
+|Limits the number of concurrent submissions for a run. This throttle
+ only limits the number of concurrent tasks (jobs) that are being
+ sent to sites, not the total number of concurrent jobs that can be
+ run. The submission stage in GRAM is one of the most CPU expensive
+ stages (due mostly to the mutual authentication and delegation).
+ Having too many concurrent submissions can overload either or both
+ the submit host CPU and the remote host/head node causing degraded
+ performance.
+|throttle.transfers
+|<int>, off
+|4
+|Limits the total number of concurrent file transfers that can happen
+ at any given time. File transfers consume bandwidth. Too many
+ concurrent transfers can cause the network to be overloaded
+ preventing various other signaling traffic from flowing properly.
+|ticker.date.format
+|String
+|Describes how to format the ticker date output. The format of this string
+ is documented in the Java SimpleDateFormat class, at
+ http://docs.oracle.com/javase/6/docs/api/java/text/SimpleDateFormat.html
+|ticker.disable
+|true, false
+|false
+|When set to true, suppresses the output progress ticker that Swift
+ sends to the console every few seconds during a run
+|ticker.prefix
+|String
+|Progress:
+|String to prepend to ticker output
+|tracing.enabled
+|true, false
+|true
+|Enables tracing of procedure invocations, assignments,
+ iteration constructs, as well as certain dataflow events
+ such as data intialization and waiting. This is done at
+ a slight decrease in performance. Traces will be available
+ in the log file.
+|use.wrapper.staging
+|true, false
+|false
+|Determines if the Swift wrapper should do file staging.
+|use.provider.staging
+|true, false
+|false
+|If true, files will be staged by Swift over the network.
+|wrapper.invocation.mode
+|absolute, relative
+|absolute
+|Determines if Swift remote wrappers will be executed by specifying
+ an absolute path, or a path relative to the job initial working
+ directory. In most cases, execution will be successful with either
+ option. However, some execution sites ignore the specified initial
+ working directory, and so absolute must be used. Conversely on
+ some sites, job directories appear in a different place on the
+ worker node file system than on the filesystem access node, with the
+ execution system handling translation of the job initial working
+ directory. In such cases, relative mode must be used.
+|wrapper.parameter.mode
+|args,files
+|args
+|Controls how Swift will supply parameters to the remote wrapper
+ script. args mode will pass parameters on the command line. Some
+ execution systems do not pass commandline parameters sufficiently
+ cleanly for Swift to operate correctly. files mode will pass
+ parameters through an additional input file. This
+ provides a cleaner communication channel for parameters, at the
+ expense of transferring an additional file for each job invocation.
+|wrapperlog.always.transfer
+|true, false
+|false
+|This property controls when output from the Swift remote wrapper is
+ transfered back to the submit site. When set to false, wrapper
+ logs are only transfered for jobs that fail. If set to true,
+ wrapper logs are transfered after every job is completed or failed.
+Using shell variables
+Any value in swift.properties may contain environment variables. For example:
+workdir=/scratch/midway/$USER/work
+Environment variables are expanded locally on the machine where you are running
+Swift.
+Swift will also define a variable called $RUNDIRECTORY that is the path to the
+run directory Swift creates. In a case where you'd like your work directory
+to be in the runNNN directory, you may do something like this:
+workdir=$RUNDIRECTORY
