[Swift-commit] r7985 - in trunk/src/org: globus/swift/data griphyn/vdl/karajan griphyn/vdl/util
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Thu Jul 10 19:47:15 CDT 2014
Author: hategan
Date: 2014-07-10 19:47:15 -0500 (Thu, 10 Jul 2014)
New Revision: 7985
Modified:
   trunk/src/org/globus/swift/data/Director.java
   trunk/src/org/griphyn/vdl/karajan/Loader.java
   trunk/src/org/griphyn/vdl/util/ConfigPropertyType.java
   trunk/src/org/griphyn/vdl/util/ConfigTree.java
   trunk/src/org/griphyn/vdl/util/SwiftConfig.java
   trunk/src/org/griphyn/vdl/util/SwiftConfigSchema.java
Log:
a few fixes and updates to the config stuff
Modified: trunk/src/org/globus/swift/data/Director.java
--- trunk/src/org/globus/swift/data/Director.java	2014-07-11 00:46:15 UTC (rev 7984)
+++ trunk/src/org/globus/swift/data/Director.java	2014-07-11 00:47:15 UTC (rev 7985)
@@ -114,8 +114,8 @@
     static void init(SwiftConfig config) throws IOException
-        broadcastMode = config.getStringProperty("cdm.broadcast.mode");
-        logfile = config.getStringProperty("logfile");
+        broadcastMode = config.getCDMBroadcastMode();
+        logfile = config.getCDMLogFile();
         if (broadcastMode.equals("file"))
             broadcasted.put("LOCAL_FILE", new HashSet<String>());
Modified: trunk/src/org/griphyn/vdl/karajan/Loader.java
--- trunk/src/org/griphyn/vdl/karajan/Loader.java	2014-07-11 00:46:15 UTC (rev 7984)
+++ trunk/src/org/griphyn/vdl/karajan/Loader.java	2014-07-11 00:47:15 UTC (rev 7985)
@@ -99,6 +99,7 @@
     static {
         CMD_LINE_OPTIONS = new ArrayList<String>();
+        CMD_LINE_OPTIONS.add("sites");
         CMD_LINE_OPTIONS.add("hostName");
         CMD_LINE_OPTIONS.add("TCPPortRange");
         CMD_LINE_OPTIONS.add("lazyErrors");
@@ -657,9 +658,15 @@
             "string", ArgumentParser.OPTIONAL);
         Map<String, SwiftConfigSchema.Info> desc = SwiftConfig.SCHEMA.getPropertyDescriptions();
-        for (Map.Entry<String, SwiftConfigSchema.Info> e : desc.entrySet()) {
-            SwiftConfigSchema.Info pi = e.getValue();
-            ap.addOption(e.getKey(), pi.doc, pi.type.toString(),
+        for (String opt : CMD_LINE_OPTIONS) {
+            if (!SwiftConfig.SCHEMA.isNameValid(opt)) {
+                throw new RuntimeException("Invalid property: " + opt);
+            SwiftConfigSchema.Info pi = desc.get(opt);
+            if (pi == null) {
+                throw new RuntimeException("No info for property '" + opt + "'");
+            ap.addOption(opt, pi.doc, pi.type.toString(),
         return ap;
Modified: trunk/src/org/griphyn/vdl/util/ConfigPropertyType.java
--- trunk/src/org/griphyn/vdl/util/ConfigPropertyType.java	2014-07-11 00:46:15 UTC (rev 7984)
+++ trunk/src/org/griphyn/vdl/util/ConfigPropertyType.java	2014-07-11 00:47:15 UTC (rev 7985)
@@ -21,6 +21,8 @@
 import org.globus.swift.catalog.types.Arch;
 import org.globus.swift.catalog.types.Os;
+import com.typesafe.config.ConfigOrigin;
 public abstract class ConfigPropertyType<T> {
     public static final ConfigPropertyType<Boolean> BOOLEAN = new CPTBoolean();
     public static final ConfigPropertyType<String> STRING = new CPTString();
@@ -42,11 +44,11 @@
     @SuppressWarnings("unchecked")
-    public Object check(String propName, Object value, String source) {
-        return checkValue(propName, (T) value, source);
+    public Object check(String propName, Object value, ConfigOrigin loc) {
+        return checkValue(propName, (T) value, loc);
-    public abstract Object checkValue(String propName, T value, String source);
+    public abstract Object checkValue(String propName, T value, ConfigOrigin loc);
     public abstract ConfigPropertyType<?> getBaseType();
@@ -75,9 +77,9 @@
         @Override
-        public Object checkValue(String propName, String value, String source) {
+        public Object checkValue(String propName, String value, ConfigOrigin loc) {
             if (!choices.contains(value)) {
-                throw new IllegalArgumentException(source + ":\n\tInvalid value '" + value + "' for property '" +
+                throw new IllegalArgumentException(location(loc) + ":\n\tInvalid value '" + value + "' for property '" +
                     propName + "'. Valid values are: " + pp(choices));
             return value;
@@ -108,7 +110,7 @@
     private static class CPTString extends ConfigPropertyType<String> {
         @Override
             // all values accepted
             return value;
@@ -126,7 +128,7 @@
     private static class Int extends ConfigPropertyType<Integer> {
         @Override
-        public Object checkValue(String propName, Integer value, String source) {
+        public Object checkValue(String propName, Integer value, ConfigOrigin loc) {
             return value;
@@ -143,7 +145,7 @@
     private static class CPTBoolean extends ConfigPropertyType<Boolean> {
         @Override
-        public Object checkValue(String propName, Boolean value, String source) {
+        public Object checkValue(String propName, Boolean value, ConfigOrigin loc) {
             return value;
@@ -160,9 +162,9 @@
     private static class SPInt extends ConfigPropertyType<Integer> {
         @Override
             if (value <= 0) {
                 propName + "'. Must be a " + toString());
             return value;
@@ -181,9 +183,9 @@
     private static class PInt extends ConfigPropertyType<Integer> {
         @Override
             if (value < 0) {
             return value;
@@ -203,7 +205,7 @@
     private static class Throttle extends ConfigPropertyType<Object> {
         @Override
-        public Object checkValue(String propName, Object value, String source) {
+        public Object checkValue(String propName, Object value, ConfigOrigin loc) {
             if ("off".equals(value)) {
                 return Integer.MAX_VALUE;
@@ -213,7 +215,7 @@
                     return i;
                 propName + "'. Must be an " + toString());
@@ -230,9 +232,9 @@
     private static class PFloat extends ConfigPropertyType<Double> {
         @Override
-        public Object checkValue(String propName, Double value, String source) {
+        public Object checkValue(String propName, Double value, ConfigOrigin loc) {
             if (value < 0) {
             return value;
@@ -251,7 +253,7 @@
     private static class CPTFloat extends ConfigPropertyType<Double> {
         @Override
             return value;
@@ -270,9 +272,9 @@
         @Override
             if (value < l || value > h) {
             return value;
@@ -291,12 +293,12 @@
     private static class CPTTime extends ConfigPropertyType<String> {
         @Override
             try {
                 WallTime.timeToSeconds(value);
             catch (IllegalArgumentException e) {
-                throw new IllegalArgumentException(source + ":\n\tInvalid time value '" + value + "' for property '" +
+                throw new IllegalArgumentException(location(loc) + ":\n\tInvalid time value '" + value + "' for property '" +
                     propName + "'. Mist be a " + toString());
             return value;
@@ -315,7 +317,7 @@
     private static class PortRange extends ConfigPropertyType<String> {
         @Override
             String[] els = value.split(",\\s*");
             if (els.length == 2) {
                 try {
@@ -326,7 +328,7 @@
                 catch (NumberFormatException e) {
@@ -343,10 +345,10 @@
     private static class CPTFile extends ConfigPropertyType<String> {
         @Override
             File f = new File(value);
             if (!f.exists()) {
                     propName + "'. File does not exist.");
             return value;
@@ -365,7 +367,7 @@
     private static class CPTObject extends ConfigPropertyType<Object> {
         @Override
             return value;
@@ -383,7 +385,7 @@
     private static class StringList extends ConfigPropertyType<Object> {
         @Override
             if (value instanceof List) {
                 List<?> l = (List<?>) value;
                 boolean allStrings = true;
@@ -400,7 +402,7 @@
                 // also allow comma separated strings in a string
                 return Arrays.asList(((String) value).split(",\\s*"));
@@ -414,4 +416,8 @@
             return "list of strings";
+    private static String location(ConfigOrigin loc) {
+        return loc.filename() + ":" + loc.lineNumber();
Modified: trunk/src/org/griphyn/vdl/util/ConfigTree.java
--- trunk/src/org/griphyn/vdl/util/ConfigTree.java	2014-07-11 00:46:15 UTC (rev 7984)
+++ trunk/src/org/griphyn/vdl/util/ConfigTree.java	2014-07-11 00:47:15 UTC (rev 7985)
@@ -119,9 +119,6 @@
         public void getLeafPaths(List<String> l, String partial) {
-            if (value != null) {
-                l.add(partial);
             if (nodes != null) {
                 for (Map.Entry<String, Node<T>> e : nodes.entrySet()) {
                     if (partial == null) {
@@ -132,26 +129,19 @@
+            else {
+                l.add(partial);
         public void expandWildcards(List<String> l, String k, String wildcard, String partial) {
-                if (partial == null) {
-                    l.add(k);
+            if (nodes == null || nodes.isEmpty()) {
+                if (k.isEmpty()) {
+                    l.add(partial);
                 else {
-                    l.add(partial + "." + k);
+                    throw new IllegalArgumentException("No such path: " + partial + "." + k);
-            if (nodes == null || nodes.isEmpty()) {
-                if (rest(k).isEmpty()) {
-                        l.add(k);
-                    else {
                 return;
             String mk = first(k);
@@ -176,7 +166,7 @@
                         // x.* is allowed to not be there
                         return;
+                    if (partial == null || k.equals("")) {
                         l.add(k);
                     else {
Modified: trunk/src/org/griphyn/vdl/util/SwiftConfig.java
--- trunk/src/org/griphyn/vdl/util/SwiftConfig.java	2014-07-11 00:46:15 UTC (rev 7984)
+++ trunk/src/org/griphyn/vdl/util/SwiftConfig.java	2014-07-11 00:47:15 UTC (rev 7985)
@@ -65,7 +65,9 @@
         WRAPPER_STAGING_LOCAL_SERVER("wrapperStagingLocalServer"),
         REPLICATION_MIN_QUEUE_TIME("replicationMinQueueTime"),
         REPLICATION_LIMIT("replicationLimit"),
-        WRAPPER_INVOCATION_MODE("wrapperInvocationMode");
+        WRAPPER_INVOCATION_MODE("wrapperInvocationMode"),
+        CDM_BROADCAST_MODE("CDMBroadcastMode"),
+        CMD_LOG_FILE("CDMLogFile");
         public String propName;
         private Key(String propName) {
@@ -419,6 +421,28 @@
                 else if (ctype.equals("app")) {
                     apps(sc, c);
+                else if (ctype.equals("staging")) {
+                    String staging = getString(c);
+                    if (staging.equals("swift") || staging.equals("wrapper")) {
+                        sc.setProperty("staging", staging);
+                    else if (staging.equals("local")) {
+                        sc.setProperty("staging", "provider");
+                        sc.setProperty("stagingMethod", "file");
+                    else if (staging.equals("service-local")) {
+                    else if (staging.equals("proxy")) {
+                        sc.setProperty("stagingMethod", "proxy");
+                    else if (staging.equals("shared-fs")) {
+                        sc.setProperty("stagingMethod", "sfs");
                 else if (ctype.equals("options")) {
                     Map<String, Object> opt = (Map<String, Object>) getObject(c, "options");
@@ -629,4 +653,12 @@
     public boolean isMappingCheckerEnabled() {
         return (Boolean) get(Key.DM_CHECKER);
+    public String getCDMBroadcastMode() {
+        return (String) get(Key.CDM_BROADCAST_MODE);
+    public String getCDMLogFile() {
+        return (String) get(Key.CMD_LOG_FILE);
Modified: trunk/src/org/griphyn/vdl/util/SwiftConfigSchema.java
--- trunk/src/org/griphyn/vdl/util/SwiftConfigSchema.java	2014-07-11 00:46:15 UTC (rev 7984)
+++ trunk/src/org/griphyn/vdl/util/SwiftConfigSchema.java	2014-07-11 00:47:15 UTC (rev 7985)
@@ -97,7 +97,7 @@
     private String stripDoc(String doc) {
-        return doc.replaceAll("[\\t\\n]+", "");
+        return doc.replaceAll("[\\t\\n]+", " ");
     private ConfigPropertyType<?> getTypeInstance(String type, ConfigValue value) {
@@ -192,8 +192,7 @@
             if (notFound != null) {
                 findMissing(key, confTree, i, validated);
                 ConfigOrigin loc = info.get(key).loc;
-                throw new SwiftConfigException(conf.origin(), "missing property '" + notFound +
-                    "' defined in " + loc.filename() + ":" + loc.lineNumber());
+                throw new SwiftConfigException(conf.origin(), "missing mandatory property '" + notFound + "'");
         return validated;
@@ -201,6 +200,7 @@
     private String findMissing(String key, ConfigTree<Boolean> confTree, Info i, ConfigTree<Object> validated) {
         List<String> found = confTree.expandWildcards(key, STAR);
         for (String f : found) {
             if (!confTree.hasKey(f)) {
                 if (i.optional) {
@@ -208,7 +208,7 @@
                         validated.put(f, i.value);
-                else {
+                else if (!parentsAreOptional(key, confTree)) {
                     return f;
@@ -216,6 +216,27 @@
         return null;
+    private boolean parentsAreOptional(String k, ConfigTree<Boolean> confTree) {
+        while (!k.isEmpty()) {
+            k = parent(k);
+            Info i = info.get(k);
+            if (i != null && !i.optional && !confTree.hasKey(k)) {
+                return false;
+        return true;
+    private String parent(String k) {
+        int ix = k.lastIndexOf('.');
+        if (ix == -1) {
+            return "";
+        else {
+            return k.substring(0, ix);
     private void setValue(Map<String, Object> validated, Config conf, String k) {
         if (!conf.hasPath(k)) {
             String defKey = k + ".\"_default\"";
@@ -235,7 +256,7 @@
                 if (t.getBaseType() != ConfigPropertyType.STRING && t.getBaseType() != ConfigPropertyType.OBJECT) {
                     throw invalidValue(value, k, v, t.getBaseType());
-                return t.check(k, value.unwrapped(), null);
+                return t.check(k, value.unwrapped(), value.origin());
             case NUMBER:
                 if (t.getBaseType() != ConfigPropertyType.INT && t.getBaseType() != ConfigPropertyType.FLOAT) {
@@ -253,12 +274,21 @@
                 return value.unwrapped();
             default:
-                return t.check(k, v, null);
+                return t.check(k, v, value.origin());
     private SwiftConfigException invalidValue(ConfigValue value, String k, Object v, ConfigPropertyType<?> t) {
-        return new SwiftConfigException(value.origin(), "invalid value '" + v + "' for property '" + k + "'. Expected a " + t);
+        switch (t.toString().charAt(0)) {
+            case 'a':
+            case 'e':
+            case 'i':
+            case 'o':
+            case 'u':
+                return new SwiftConfigException(value.origin(), "invalid value '" + v + "' for property '" + k + "'. Expected an " + t);
+            default:
+                return new SwiftConfigException(value.origin(), "invalid value '" + v + "' for property '" + k + "'. Expected a " + t);
     public synchronized Map<String, Info> getPropertyDescriptions() {
