[Swift-commit] r7976 - in trunk/src/org: globus/swift/catalog/site globus/swift/catalog/types globus/swift/data griphyn/vdl/karajan griphyn/vdl/karajan/functions griphyn/vdl/karajan/lib griphyn/vdl/karajan/lib/replication griphyn/vdl/karajan/lib/swiftscript griphyn/vdl/mapping griphyn/vdl/mapping/file griphyn/vdl/mapping/nodes griphyn/vdl/util
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Wed Jul 9 14:38:50 CDT 2014
Author: hategan
Date: 2014-07-09 14:38:50 -0500 (Wed, 09 Jul 2014)
New Revision: 7976
Added:
   trunk/src/org/griphyn/vdl/util/ConfigTree.java
   trunk/src/org/griphyn/vdl/util/ConvertConfig.java
   trunk/src/org/griphyn/vdl/util/SwiftConfig.java
   trunk/src/org/griphyn/vdl/util/SwiftConfigException.java
   trunk/src/org/griphyn/vdl/util/SwiftConfigInfo.java
   trunk/src/org/griphyn/vdl/util/SwiftConfigSchema.java
Removed:
   trunk/src/org/griphyn/vdl/util/TriStateBoolean.java
   trunk/src/org/griphyn/vdl/util/VDL2Config.java
   trunk/src/org/griphyn/vdl/util/VDL2ConfigProperties.java
Modified:
   trunk/src/org/globus/swift/catalog/site/Application.java
   trunk/src/org/globus/swift/catalog/site/SwiftContact.java
   trunk/src/org/globus/swift/catalog/site/SwiftContactSet.java
   trunk/src/org/globus/swift/catalog/types/Arch.java
   trunk/src/org/globus/swift/catalog/types/Os.java
   trunk/src/org/globus/swift/catalog/types/SysInfo.java
   trunk/src/org/globus/swift/data/Director.java
   trunk/src/org/griphyn/vdl/karajan/Loader.java
   trunk/src/org/griphyn/vdl/karajan/SwiftRootScope.java
   trunk/src/org/griphyn/vdl/karajan/VDSAdaptiveScheduler.java
   trunk/src/org/griphyn/vdl/karajan/VDSTaskTransformer.java
   trunk/src/org/griphyn/vdl/karajan/functions/ConfigProperty.java
   trunk/src/org/griphyn/vdl/karajan/functions/ProcessBulkErrors.java
   trunk/src/org/griphyn/vdl/karajan/lib/CacheFunction.java
   trunk/src/org/griphyn/vdl/karajan/lib/Execute.java
   trunk/src/org/griphyn/vdl/karajan/lib/GetURLPrefix.java
   trunk/src/org/griphyn/vdl/karajan/lib/New.java
   trunk/src/org/griphyn/vdl/karajan/lib/Operators.java
   trunk/src/org/griphyn/vdl/karajan/lib/Parameterlog.java
   trunk/src/org/griphyn/vdl/karajan/lib/RuntimeStats.java
   trunk/src/org/griphyn/vdl/karajan/lib/SiteCatalog.java
   trunk/src/org/griphyn/vdl/karajan/lib/SiteProperty.java
   trunk/src/org/griphyn/vdl/karajan/lib/SwiftFunction.java
   trunk/src/org/griphyn/vdl/karajan/lib/Throttled.java
   trunk/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java
   trunk/src/org/griphyn/vdl/karajan/lib/Tracer.java
   trunk/src/org/griphyn/vdl/karajan/lib/replication/ReplicationManager.java
   trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
   trunk/src/org/griphyn/vdl/mapping/DuplicateMappingChecker.java
   trunk/src/org/griphyn/vdl/mapping/file/FileGarbageCollector.java
   trunk/src/org/griphyn/vdl/mapping/nodes/AbstractDataNode.java
   trunk/src/org/griphyn/vdl/util/ConfigPropertyType.java
Log:
new config mechanism III
Modified: trunk/src/org/globus/swift/catalog/site/Application.java
--- trunk/src/org/globus/swift/catalog/site/Application.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/globus/swift/catalog/site/Application.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -42,7 +42,7 @@
         env.put(name, value);
-    public void addProperty(String name, String value) {
+    public void addProperty(String name, Object value) {
         if (properties == null) {
             properties = new HashMap<String, Object>();
Modified: trunk/src/org/globus/swift/catalog/site/SwiftContact.java
--- trunk/src/org/globus/swift/catalog/site/SwiftContact.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/globus/swift/catalog/site/SwiftContact.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -55,16 +55,31 @@
     public void setSiteCatalog(SwiftContactSet siteCatalog) {
         this.siteCatalog = siteCatalog;
+     * Get an application with the specified tr. Only this site
+     * is searched. Returns <code>null</code> if not found.
+    public Application getApplication(String tr) {
+        if (apps == null) {
+            return null;
+        else {
+            return apps.get(tr);
+     * Find apps by searching in the following order:
+     * <ol>
+     *  <li>host:tr</li>
+     *  <li>host:*</li>
+     *  <li>pool:tr</li>
+     *  <li>pool:*</li>
+     * </ol>
     public Application findApplication(String tr) {
-         * Find apps in the following order:
-         * host:tr
-         * host:*
-         * pool:tr
-         * pool:*
         Application app = null;
         if (apps != null) {
             app = apps.get(tr);
Modified: trunk/src/org/globus/swift/catalog/site/SwiftContactSet.java
--- trunk/src/org/globus/swift/catalog/site/SwiftContactSet.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/globus/swift/catalog/site/SwiftContactSet.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -49,4 +49,11 @@
         return app;
+    public Map<String, Application> getApplications() {
+            apps = new HashMap<String, Application>();
+        return apps;
Modified: trunk/src/org/globus/swift/catalog/types/Arch.java
--- trunk/src/org/globus/swift/catalog/types/Arch.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/globus/swift/catalog/types/Arch.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -17,91 +17,7 @@
 package org.globus.swift.catalog.types;
- * This is an enumerated data class for the different types of architecture.
- * @author Gaurang Mehta gmehta at isi.edu
- * @version $Revision: 1.5 $
+public enum Arch {
+    INTEL32, INTEL64, SPARCV7, SPARCV9, AMD64;
-import java.io.Serializable;
-import java.util.HashMap;
-public class Arch
-    implements Serializable {
-    private String _value_;
-    private static HashMap<String, Arch> _table_ = new HashMap<String, Arch>(5);
-    protected Arch(String value) {
-        _value_ = value;
-        _table_.put(_value_, this);
-    private static final String _INTEL32 = "INTEL32";
-    private static final String _INTEL64 = "INTEL64";
-    private static final String _SPARCV7 = "SPARCV7";
-    private static final String _SPARCV9 = "SPARCV9";
-    private static final String _AMD64 = "AMD64";
-    public static final Arch INTEL32 = new Arch(_INTEL32);
-    public static final Arch INTEL64 = new Arch(_INTEL64);
-    public static final Arch SPARCV7 = new Arch(_SPARCV7);
-    public static final Arch SPARCV9 = new Arch(_SPARCV9);
-    public static final Arch AMD64 = new Arch(_AMD64);
-    public static final String err = "Error: Illegal Architecture defined. Please specify one of the predefined types \n [INTEL32, INTEL64, AMD64, SPARCV7, SPARCV9]";
-     * Returns the value of the architecture as string.
-     * @return String
-    public String getValue() {
-        return _value_;
-     * Creates a new Arch Object givan a arch string.
-     * @param value String
-     * @throws IllegalStateException Throws Exception if the architecure is not defined in this class.
-     * @return Arch
-    public static Arch fromValue(String value) throws IllegalStateException {
-        Arch m_enum = _table_.get(value.toUpperCase());
-        if (m_enum == null) {
-            throw new IllegalStateException(err);
-        return m_enum;
-     * Creates a new Arch object given a arch string.
-     * @return Arch
-    public static Arch fromString(String value) throws IllegalStateException {
-        return fromValue(value);
-     * Compares if a given Arch object is equal to this.
-     * @param obj Object
-     * @return boolean
-    public boolean equals(Object obj) {
-        return (obj == this);
-    public int hashCode() {
-        return toString().hashCode();
-     * Returns the string value of the architecture.
-     * @return String
-    public String toString() {
-        return _value_;
Modified: trunk/src/org/globus/swift/catalog/types/Os.java
--- trunk/src/org/globus/swift/catalog/types/Os.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/globus/swift/catalog/types/Os.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -17,89 +17,6 @@
- * This is an enumerated data class for the different types of operating systems.
- * @version $Revision: 1.4 $
-public class Os
-    private static HashMap<String, Os> _table_ = new HashMap<String, Os>(5);
-    protected Os(String value) {
-        _value_ = value;
-    private static final String _LINUX = "LINUX";
-    private static final String _SUNOS = "SUNOS";
-    private static final String _AIX = "AIX";
-    private static final String _WINDOWS = "WINDOWS";
-    public static final Os LINUX = new Os(_LINUX);
-    public static final Os SUNOS = new Os(_SUNOS);
-    public static final Os AIX = new Os(_AIX);
-    public static final Os WINDOWS = new Os(_WINDOWS);
-    public static final String err = "Error: Illegal Operating System defined. Please specify one of the predefined types \n [LINUX, SUNOS, AIX, WINDOWS]";
-     * Returns the value of the operating system as string.
-     * @return String
-        return _value_;
-     * Creates a new Os object given an os string.
-     * @throws IllegalStateException Throws Exception if the operating system is not defined in this class.
-     * @return Os
-    public static Os fromValue(String value) throws IllegalStateException {
-        Os m_enum = _table_.get(value.toUpperCase());
-        return m_enum;
-     * @return Os
-    public static Os fromString(String value) throws IllegalStateException {
-     * Compares if a given Os object is equal to this.
-     * @return boolean
-     * Returns the string value of the operating system.
-     * @return String
-        return _value_;
+public enum Os {
+    LINUX, SUNOS, AIX, WINDOWS;
Modified: trunk/src/org/globus/swift/catalog/types/SysInfo.java
--- trunk/src/org/globus/swift/catalog/types/SysInfo.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/globus/swift/catalog/types/SysInfo.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -77,8 +77,8 @@
      * @param glibc String
     public SysInfo(String arch, String os, String osversion, String glibc) {
-        this.arch = (arch == null) ? Arch.INTEL32 : Arch.fromString(arch);
-        this.os = (os == null) ? Os.LINUX : Os.fromString(os);
+        this.arch = (arch == null) ? Arch.INTEL32 : Arch.valueOf(arch);
+        this.os = (os == null) ? Os.LINUX : Os.valueOf(os);
         this.osversion = (osversion == null || osversion.equals("") ) ?
                           null:
                           osversion;
@@ -92,9 +92,9 @@
         if (system != null) {
             String s1[] = system.split("::", 2);
             if (s1.length == 2) {
-                arch = Arch.fromString(s1[0]);
+                arch = Arch.valueOf(s1[0]);
                 String s2[] = s1[1].split(":", 3);
-                os = Os.fromString(s2[0]);
+                os = Os.valueOf(s2[0]);
                 for (int i = 1; i < s2.length; i++) {
                     if (i == 1) {
                         osversion = s2[i];
Modified: trunk/src/org/globus/swift/data/Director.java
--- trunk/src/org/globus/swift/data/Director.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/globus/swift/data/Director.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -33,10 +33,10 @@
 import java.util.regex.Pattern;
 import org.apache.log4j.Logger;
-import org.globus.swift.data.policy.Policy;
 import org.globus.swift.data.policy.Broadcast;
+import org.globus.swift.data.policy.Policy;
 import org.globus.swift.data.util.LineReader;
-import org.griphyn.vdl.util.VDL2Config;
+import org.griphyn.vdl.util.SwiftConfig;
  * Manages CDM policies for files based on pattern matching.
@@ -103,22 +103,20 @@
        Read in the user-supplied CDM policy file.
-    public static void load(File file) throws IOException {
+    public static void load(File file, SwiftConfig config) throws IOException {
         logger.debug("CDM file: " + file);
         Director.policyFile = file;
         List<String> list = LineReader.read(file);
         for (String s : list)
             addLine(s);
-        init();
+        init(config);
-    static void init() throws IOException
-        VDL2Config config = VDL2Config.getConfig();
+    static void init(SwiftConfig config) throws IOException
+        broadcastMode = config.getStringProperty("cdm.broadcast.mode");
+        logfile = config.getStringProperty("logfile");
-        broadcastMode = config.getProperty("cdm.broadcast.mode");
-        logfile = config.getProperty("logfile");
         if (broadcastMode.equals("file"))
             broadcasted.put("LOCAL_FILE", new HashSet<String>());
@@ -313,7 +311,7 @@
                 logger.debug("Policy file does not exist: " +
                     args[1]);
-            load(policyFile);
+            load(policyFile, SwiftConfig.getDefault());
             Policy policy = lookup(name);
             logger.debug(name + ": " + policy);
         } catch (Exception e) {
Modified: trunk/src/org/griphyn/vdl/karajan/Loader.java
--- trunk/src/org/griphyn/vdl/karajan/Loader.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/griphyn/vdl/karajan/Loader.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -35,9 +35,11 @@
 import java.security.SecureRandom;
 import java.text.DateFormat;
 import java.text.SimpleDateFormat;
+import java.util.ArrayList;
 import java.util.Arrays;
 import java.util.Date;
 import java.util.Enumeration;
+import java.util.HashMap;
 import java.util.List;
 import java.util.Map;
@@ -67,9 +69,8 @@
 import org.griphyn.vdl.toolkit.VDLt2VDLx.IncorrectInvocationException;
 import org.griphyn.vdl.toolkit.VDLt2VDLx.ParsingException;
 import org.griphyn.vdl.util.LazyFileAppender;
-import org.griphyn.vdl.util.VDL2ConfigProperties;
-import org.griphyn.vdl.util.VDL2ConfigProperties.PropInfo;
+import org.griphyn.vdl.util.SwiftConfigSchema;
 public class Loader extends org.globus.cog.karajan.Loader {
     private static final Logger logger = Logger.getLogger(Loader.class);
@@ -78,18 +79,37 @@
     public static final String ARG_VERSION = "version";
     public static final String ARG_RESUME = "resume";
     public static final String ARG_INSTANCE_CONFIG = "config";
+    public static final String ARG_SITELIST = "sitelist";
+    public static final String ARG_SITES_FILE = "sites.file";
+    public static final String ARG_TC_FILE = "tc.file";
     public static final String ARG_DRYRUN = "dryrun";
     public static final String ARG_VERBOSE = "verbose";
     public static final String ARG_DEBUG = "debug";
     public static final String ARG_LOGFILE = "logfile";
-    public static final String ARG_CDMFILE = "cdm.file";
+    public static final String ARG_CDMFILE = "cdmfile";
     public static final String ARG_RUNID = "runid";
     public static final String ARG_UI = "ui";
     public static final String ARG_RECOMPILE = "recompile";
-    public static final String ARG_REDUCED_LOGGING = "reduced.logging";
-    public static final String ARG_MINIMAL_LOGGING = "minimal.logging";
-    public static final String ARG_PAUSE_ON_START = "pause.on.start";
+    public static final String ARG_REDUCED_LOGGING = "reducedLogging";
+    public static final String ARG_MINIMAL_LOGGING = "minimalLogging";
+    public static final String ARG_PAUSE_ON_START = "pauseOnStart";
     public static final String ARG_EXECUTE = "e";
+    public static final List<String> CMD_LINE_OPTIONS;
+    static {
+        CMD_LINE_OPTIONS = new ArrayList<String>();
+        CMD_LINE_OPTIONS.add("hostName");
+        CMD_LINE_OPTIONS.add("TCPPortRange");
+        CMD_LINE_OPTIONS.add("lazyErrors");
+        CMD_LINE_OPTIONS.add("keepSiteDir");
+        CMD_LINE_OPTIONS.add("alwaysTransferWrapperLog");
+        CMD_LINE_OPTIONS.add("logProvenance");
+        CMD_LINE_OPTIONS.add("fileGCEnabled");
+        CMD_LINE_OPTIONS.add("mappingCheckerEnabled");
+        CMD_LINE_OPTIONS.add("tracingEnabled");
+        CMD_LINE_OPTIONS.add("maxForeachThreads");
     public static String buildVersion;
@@ -120,18 +140,19 @@
                 source = null;
-            VDL2Config config = loadConfig(ap);
-            addCommandLineProperties(config, ap);
-            config.validateProperties();
-            setupLogging(ap, projectName, runID);
+            SwiftConfig config = loadConfig(ap, getCommandLineProperties(ap));
+            if (ap.isPresent(ARG_SITELIST)) {
+                printSiteList(config);
+                System.exit(0);
+            setupLogging(ap, config, projectName, runID);
             logBasicInfo(argv, runID, config);
-            debugSitesText(config);
-            debugTCText(config);
+            debugConfigText(config);
-            boolean provenanceEnabled = VDL2Config.getConfig().getProvenanceLog();
+            boolean provenanceEnabled = config.isProvenanceEnabled();
             if (ap.isPresent(ARG_CDMFILE)) {
-                loadCDM(ap);
+                loadCDM(ap, config);
             WrapperNode tree = null;
@@ -235,7 +256,14 @@
         System.exit(runerror ? 2 : 0);
-    private static void logBasicInfo(String[] argv, String runID, VDL2Config conf) {
+    private static void printSiteList(SwiftConfig config) {
+        System.out.println("Available sites: ");
+        for (String name : config.getDefinedSiteNames()) {
+            System.out.println("\t" + name);
+    private static void logBasicInfo(String[] argv, String runID, SwiftConfig conf) {
         String version = loadVersion();
         System.out.println(version);
         System.out.println("RunID: " + runID);
@@ -278,6 +306,18 @@
                 System.out.println(loadVersion());
                 System.exit(0);
+            if (ap.isPresent(ARG_SITES_FILE)) {
+                System.err.println("Swift does not use site files any more.\n" +
+                		"Please use the swift-convert-config tool to update your " +
+                		"sites file to a swift configuration file.");
+                System.exit(1);
+            if (ap.isPresent(ARG_TC_FILE)) {
+                System.err.println("Swift does not use TC files any more.\n" +
+                        "sites.xml and tc.data to a Swift configuration file.");
+                System.exit(1);
             if (!ap.hasValue(ArgumentParser.DEFAULT) && !ap.isPresent(ARG_EXECUTE)) {
                 error("No Swift script specified");
@@ -328,13 +368,13 @@
         System.err.print("For usage information:  swift -help\n\n");
-    static void loadCDM(ArgumentParser ap) {
+    static void loadCDM(ArgumentParser ap, SwiftConfig config) {
         String cdmString = null;
         try {
             cdmString = ap.getStringValue(ARG_CDMFILE);
             File cdmFile = new File(cdmString);
             debugText("CDM FILE", cdmFile);
-            Director.load(cdmFile);
+            Director.load(cdmFile, config);
         catch (IOException e) {
             logger.debug("Detailed exception:", e);
@@ -496,19 +536,10 @@
-    static void debugSitesText(VDL2Config config) {
-		String poolFile = config.getPoolFile();
-		logger.info("SITES_FILE " + poolFile);
-		debugText("SITES", new File(poolFile));
+    static void debugConfigText(SwiftConfig config) {
+		logger.info("SWIFT_CONF \n" + config);
-    static void debugTCText(VDL2Config config) {
-        String tcFile = config.getTCFile();
-        logger.info("TC_FILE " + tcFile);
-        debugText("TC", new File(tcFile));
      * The build ID is a UID that gets generated with each build. It is
      * used to decide whether an already compiled swift script can be
@@ -530,29 +561,30 @@
-    private static VDL2Config loadConfig(ArgumentParser ap) throws IOException {
-        VDL2Config conf;
+    private static SwiftConfig loadConfig(ArgumentParser ap, Map<String, Object> cmdLine) throws IOException {
+        SwiftConfig conf;
         if (ap.hasValue(ARG_INSTANCE_CONFIG)) {
             String configFile = ap.getStringValue(ARG_INSTANCE_CONFIG);
-            conf = VDL2Config.getConfig(configFile);
+            conf = SwiftConfig.load(configFile, cmdLine);
+            SwiftConfig.setDefault(conf);
         else {
-            conf = (VDL2Config) VDL2Config.getConfig().clone();
+            conf = (SwiftConfig) SwiftConfig.load().clone();
         return conf;
-    private static void addCommandLineProperties(VDL2Config config,
-            ArgumentParser ap) {
-        config.setCurrentFile("<command line>");
-        Map<String, PropInfo> desc = VDL2ConfigProperties.getPropertyDescriptions();
-        for (Map.Entry<String, PropInfo> e : desc.entrySet()) {
+    private static Map<String, Object> getCommandLineProperties(ArgumentParser ap) {
+        Map<String, Object> cmdConf = new HashMap<String, Object>();
+        Map<String, SwiftConfigSchema.Info> desc = SwiftConfig.SCHEMA.getPropertyDescriptions();
+        for (Map.Entry<String, SwiftConfigSchema.Info> e : desc.entrySet()) {
             String name = e.getKey();
             if (ap.isPresent(name)) {
             	String value = ap.getStringValue(name);
-            	config.setProperty(name, value);
+            	cmdConf.put(name, value);
+        return cmdConf;
     private static ArgumentParser buildArgumentParser() {
@@ -574,6 +606,8 @@
         ap.addFlag(ARG_DRYRUN,
             "Runs the SwiftScript program without submitting any jobs (can be used to get a graph)");
+        ap.addHiddenFlag(ARG_SITES_FILE);
+        ap.addHiddenFlag(ARG_TC_FILE);
         ap.addOption(ARG_RESUME, "Resumes the execution using a log file",
             "file", ArgumentParser.OPTIONAL);
@@ -583,6 +617,7 @@
             "If individual command line arguments are used for properties, they will override " +
             "the contents of this file.", "file",
+        ap.addFlag(ARG_SITELIST, "Prints a list of sites available in the swift configuration");
         ap.addFlag(ARG_VERBOSE,
             "Increases the level of output that Swift produces on the console to include more detail " +
             "about the execution");
@@ -621,10 +656,10 @@
         ap.addOption(ARG_EXECUTE, "Runs the swift script code contained in <string>",
             "string", ArgumentParser.OPTIONAL);
-            PropInfo pi = e.getValue();
-            ap.addOption(e.getKey(), pi.desc, pi.validValues,
+            SwiftConfigSchema.Info pi = e.getValue();
+            ap.addOption(e.getKey(), pi.doc, pi.type.toString(),
         return ap;
@@ -632,7 +667,7 @@
     private static MonitorAppender ma;
-    protected static void setupLogging(ArgumentParser ap, String projectName,
+    protected static String setupLogging(ArgumentParser ap, SwiftConfig config, String projectName,
             String runID) throws IOException {
         String logfile;
         if (ap.isPresent(ARG_LOGFILE)) {
@@ -641,10 +676,9 @@
         else {
             logfile = projectName + "-" + runID + ".log";
-        config.put("logfile", logfile);
+        config.setProperty("logfile", logfile);
         File f = new File(logfile);
         FileAppender fa = (FileAppender) getAppender(FileAppender.class);
@@ -698,6 +732,7 @@
             Logger.getLogger(New.class).setLevel(Level.WARN);
             Logger.getLogger("org.globus.cog.karajan.workflow.service").setLevel(Level.WARN);
+        return logfile;
Modified: trunk/src/org/griphyn/vdl/karajan/SwiftRootScope.java
--- trunk/src/org/griphyn/vdl/karajan/SwiftRootScope.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/griphyn/vdl/karajan/SwiftRootScope.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -17,14 +17,14 @@
 import org.globus.cog.karajan.util.KarajanProperties;
 import org.griphyn.vdl.karajan.lib.swiftscript.FnArg;
 import org.griphyn.vdl.mapping.DuplicateMappingChecker;
 public class SwiftRootScope extends RootScope {
     public SwiftRootScope(KarajanProperties props, String file, Context context) {
         super(props, file, context);
         context.setAttribute("SWIFT:DM_CHECKER", new DuplicateMappingChecker(
-        		(VDL2Config) context.getAttribute("SWIFT:CONFIG")));
+        		(SwiftConfig) context.getAttribute("SWIFT:CONFIG")));
         addVar("PATH_SEPARATOR", File.separator);
         addVar("SWIFT:DRY_RUN", context.getAttribute("SWIFT:DRY_RUN"));
Modified: trunk/src/org/griphyn/vdl/karajan/VDSAdaptiveScheduler.java
--- trunk/src/org/griphyn/vdl/karajan/VDSAdaptiveScheduler.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/griphyn/vdl/karajan/VDSAdaptiveScheduler.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -52,6 +52,7 @@
 import org.globus.cog.karajan.util.ContactSet;
 import org.globus.cog.karajan.util.TypeUtil;
 import org.globus.swift.catalog.site.SwiftContact;
 public class VDSAdaptiveScheduler extends WeightedHostScoreScheduler implements CoasterResourceTracker {
@@ -78,7 +79,7 @@
 		serviceContactMapping = new HashMap<Service, BoundContact>();
-	public static final String PROP_TC_FILE = "transformationCatalogFile";
+	public static final String PROP_CONFIG = "config";
 	public static final String PROP_CLUSTERING_ENABLED = "clusteringEnabled";
 	public static final String PROP_CLUSTERING_QUEUE_DELAY = "clusteringQueueDelay";
 	public static final String PROP_CLUSTERING_MIN_TIME = "clusteringMinTime";
@@ -88,15 +89,15 @@
 	public synchronized String[] getPropertyNames() {
 		if (propertyNames == null) {
 			propertyNames = AbstractScheduler.combineNames(super.getPropertyNames(),
-					new String[] { PROP_TC_FILE });
+					new String[] { PROP_CONFIG });
 		return propertyNames;
 	public void setProperty(String name, Object value) {
-		if (PROP_TC_FILE.equals(name)) {
+		if (PROP_CONFIG.equals(name)) {
 			this.setConstraintChecker(new SwiftSiteChecker());
-			this.addTaskTransformer(new VDSTaskTransformer());
+			this.addTaskTransformer(new VDSTaskTransformer((SwiftConfig) value));
 		else if (PROP_CLUSTERING_QUEUE_DELAY.equals(name)) {
 			clusteringQueueDelay = TypeUtil.toInt(value);
Modified: trunk/src/org/griphyn/vdl/karajan/VDSTaskTransformer.java
--- trunk/src/org/griphyn/vdl/karajan/VDSTaskTransformer.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/griphyn/vdl/karajan/VDSTaskTransformer.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -20,7 +20,6 @@
 package org.griphyn.vdl.karajan;
-import java.io.IOException;
 import java.util.HashSet;
 import java.util.Set;
@@ -34,15 +33,16 @@
 import org.globus.cog.karajan.scheduler.TaskTransformer;
 import org.globus.cog.karajan.util.BoundContact;
 import org.globus.cog.karajan.util.Contact;
+import org.globus.swift.catalog.site.SwiftContact;
 public class VDSTaskTransformer implements TaskTransformer {
 	public static final Logger logger = Logger.getLogger(VDSTaskTransformer.class);
 	private TaskTransformer impl;
-	public VDSTaskTransformer() {
-		this.impl = new SwiftTransformer();
+	public VDSTaskTransformer(SwiftConfig config) {
+		this.impl = new SwiftTransformer(config);
 	public void transformTask(Task task, Contact[] contacts, Service[] services) {
@@ -50,8 +50,13 @@
 	public static abstract class AbstractTransformer implements TaskTransformer {
+		private SwiftConfig config;
-		public void transformTask(Task task, Contact[] contacts, Service[] services) {
+        public AbstractTransformer(SwiftConfig config) {
+		    this.config = config;
+        public void transformTask(Task task, Contact[] contacts, Service[] services) {
 			if (task.getType() == Task.JOB_SUBMISSION) {
 				applyJobWorkDirectory(task, contacts);
@@ -117,7 +122,7 @@
 		private void applyJobWorkDirectory(Task task, Contact[] contacts) {
 			JobSpecification spec = (JobSpecification) task.getSpecification();
 			String dir = spec.getDirectory();
-			BoundContact bc = (BoundContact) contacts[0];
+			SwiftContact bc = (SwiftContact) contacts[0];
 			String workdir = (String) bc.getProperty("workdir");
             if (workdir==null){
@@ -141,24 +146,24 @@
 			// undergo this substitution...
 			String executable = l.get(0);
-			try {
+			String mode = (String) bc.getProperty(SwiftConfig.Key.WRAPPER_INVOCATION_MODE.propName);
+			if (mode == null) {
+			    mode = config.getWrapperInvocationMode();
+			if (mode.equals("absolute")
+			        && (executable.endsWith("shared/_swiftwrap")
+			        || executable.endsWith("shared/_swiftseq"))) {
-				if (config.getProperty("wrapper.invocation.mode", bc).equals("absolute")
-				        && (executable.endsWith("shared/_swiftwrap")
-				        || executable.endsWith("shared/_swiftseq"))) {
-				    String s  = spec.getDirectory() + "/" + executable;
-				    l.set(0, s);
-			catch(IOException ioe) {
-				throw new RuntimeException("Could not determine wrapper invocation mode", ioe);
+			    String s  = spec.getDirectory() + "/" + executable;
+			    l.set(0, s);
 	public static class SwiftTransformer extends AbstractTransformer {
+        public SwiftTransformer(SwiftConfig config) {
+            super(config);
Modified: trunk/src/org/griphyn/vdl/karajan/functions/ConfigProperty.java
--- trunk/src/org/griphyn/vdl/karajan/functions/ConfigProperty.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/griphyn/vdl/karajan/functions/ConfigProperty.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -20,8 +20,6 @@
 package org.griphyn.vdl.karajan.functions;
 import k.rt.Context;
 import k.rt.ExecutionException;
 import k.rt.Stack;
@@ -39,7 +37,7 @@
 import org.globus.cog.karajan.compiled.nodes.Node;
 import org.globus.cog.karajan.parser.WrapperNode;
 public class ConfigProperty extends InternalFunction {
     private ArgRef<String> name;
@@ -47,7 +45,7 @@
     private ArgRef<BoundContact> host;
     private ChannelRef<Object> cr_vargs;
-    private VDL2Config instanceConfig;
+    private SwiftConfig instanceConfig;
     private VarRef<Context> context;
@@ -68,9 +66,12 @@
         context = scope.getVarRef("#context");
         Context ctx = context.getValue();
         Var.Channel r = scope.parent.lookupChannel("...");
+        if (this.name.isStatic()) {
+            checkProperty(this.name.getValue());
         if (this.name.isStatic() && this.instance.isStatic() && this.host.isStatic()
         		&& ctx != null && this.host.getValue() == null) {
-        	String value = getProperty(this.name.getValue(), this.instance.getValue(), getInstanceConfig(ctx));
+        	Object value = getProperty(this.name.getValue(), this.instance.getValue(), getInstanceConfig(ctx));
         	if (r.append(value)) {
         		return null;
@@ -108,44 +109,45 @@
         cr_vargs.append(stack, getProperty(name, instance, getInstanceConfig(stack)));
-    private synchronized VDL2Config getInstanceConfig(Stack stack) {
+    private synchronized SwiftConfig getInstanceConfig(Stack stack) {
         if (instanceConfig == null) {
             Context ctx = this.context.getValue(stack);
-            instanceConfig = (VDL2Config) ctx.getAttribute("SWIFT:CONFIG");
+            instanceConfig = (SwiftConfig) ctx.getAttribute("SWIFT:CONFIG");
         return instanceConfig;
-    private synchronized VDL2Config getInstanceConfig(Context ctx) {
-    	return (VDL2Config) ctx.getAttribute("SWIFT:CONFIG");
+    private synchronized SwiftConfig getInstanceConfig(Context ctx) {
+    	return (SwiftConfig) ctx.getAttribute("SWIFT:CONFIG");
-    public static String getProperty(String name, VDL2Config instanceConfig) {
+    public static Object getProperty(String name, SwiftConfig instanceConfig) {
         return getProperty(name, true, instanceConfig);
-    public static String getProperty(String name, boolean instance, VDL2Config instanceConfig) {
-        try {
-            VDL2Config conf;
-            String prop;
-            if (!instance) {
-                conf = VDL2Config.getConfig();
-                prop = conf.getProperty(name);
-            else {
-                conf = instanceConfig;
-            if (prop == null) {
-                throw new ExecutionException("Swift config property \"" + name + "\" not found in "
-                        + conf);
-            else {
-                return prop;
+    public static Object getProperty(String name, boolean instance, SwiftConfig instanceConfig) {
+        SwiftConfig conf;
+        Object prop;
+        if (!instance) {
+            conf = SwiftConfig.getDefault();
+            prop = conf.getProperty(name);
-        catch (IOException e) {
-            throw new ExecutionException("Failed to load Swift configuration", e);
+        else {
+            conf = instanceConfig;
+        if (prop == null) {
+            throw new ExecutionException("Swift config property \"" + name + "\" not found in "
+                    + conf.getFileName());
+        else {
+            return prop;
+    private void checkProperty(String name) throws CompilationException {
+        if (!SwiftConfig.SCHEMA.propertyExists(name)) {
+            throw new CompilationException(this, "Unknown configuration property: " + name);
Modified: trunk/src/org/griphyn/vdl/karajan/functions/ProcessBulkErrors.java
--- trunk/src/org/griphyn/vdl/karajan/functions/ProcessBulkErrors.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/griphyn/vdl/karajan/functions/ProcessBulkErrors.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -76,7 +76,10 @@
 		VDL2ErrorTranslator translator = VDL2ErrorTranslator.getDefault();
 		Map<String, Integer> count = new HashMap<String, Integer>();
-		for (ExecutionException ex : l) {
+		for (ExecutionException ex : l) {
+		    if (ex == null) {
+		        continue;
 			if (ex.getCause() instanceof ConcurrentModificationException) {
 				ex.printStackTrace();
Modified: trunk/src/org/griphyn/vdl/karajan/lib/CacheFunction.java
--- trunk/src/org/griphyn/vdl/karajan/lib/CacheFunction.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/griphyn/vdl/karajan/lib/CacheFunction.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -26,14 +26,12 @@
 import org.globus.cog.karajan.analyzer.CompilationException;
 import org.globus.cog.karajan.analyzer.Scope;
 import org.globus.cog.karajan.analyzer.VarRef;
-import org.globus.cog.karajan.compiled.nodes.Node;
 import org.globus.cog.karajan.compiled.nodes.InternalFunction;
+import org.globus.cog.karajan.compiled.nodes.Node;
-import org.griphyn.vdl.karajan.functions.ConfigProperty;
 import org.griphyn.vdl.karajan.lib.cache.VDLFileCache;
 import org.griphyn.vdl.karajan.lib.cache.VDLFileCacheFactory;
 public abstract class CacheFunction extends InternalFunction {
 	public static final String CACHE_FILES_TO_REMOVE = "cacheFilesToRemove";
@@ -62,8 +60,8 @@
         synchronized(ctx) {
             VDLFileCache cache = (VDLFileCache) ctx.getAttribute("SWIFT:FILE_CACHE");
             if (cache == null) {
-                cache = VDLFileCacheFactory.newInstance(ConfigProperty.getProperty(
-                    VDL2ConfigProperties.CACHING_ALGORITHM, (VDL2Config) ctx.getAttribute("SWIFT:CONFIG")));
+                SwiftConfig conf = (SwiftConfig) ctx.getAttribute("SWIFT:CONFIG");
+                cache = VDLFileCacheFactory.newInstance(conf.getCachingAlgorithm());
                 ctx.setAttribute("SWIFT:FILE_CACHE", cache);
             return cache;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/Execute.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Execute.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Execute.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -52,7 +52,7 @@
 import org.griphyn.vdl.karajan.lib.RuntimeStats.ProgressState;
 import org.griphyn.vdl.karajan.lib.replication.CanceledReplicaException;
 import org.griphyn.vdl.karajan.lib.replication.ReplicationManager;
 public class Execute extends GridExec {
 	public static final Logger logger = Logger.getLogger(Execute.class);
@@ -66,6 +66,7 @@
 	private boolean replicationEnabled;
 	@Override
     protected Signature getSignature() {
@@ -103,8 +104,8 @@
     protected void addLocals(Scope scope) {
         super.addLocals(scope);
-        VDL2Config config = (VDL2Config) context.getValue().getAttribute("SWIFT:CONFIG");
-        replicationEnabled = "true".equals(config.getProperty("replication.enabled"));
+        config = (SwiftConfig) context.getValue().getAttribute("SWIFT:CONFIG");
+        replicationEnabled = config.isReplicationEnabled();
     @Override
@@ -232,7 +233,7 @@
 		synchronized (ctx) {
 			ReplicationManager rm = (ReplicationManager) ctx.getAttribute("#replicationManager");
 			if (rm == null) {
-				rm = new ReplicationManager(getScheduler(stack));
+				rm = new ReplicationManager(getScheduler(stack), config);
 				ctx.setAttribute("#replicationManager", rm);
 			return rm;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/GetURLPrefix.java
--- trunk/src/org/griphyn/vdl/karajan/lib/GetURLPrefix.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/griphyn/vdl/karajan/lib/GetURLPrefix.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -27,8 +27,7 @@
 import org.globus.cog.karajan.compiled.nodes.functions.AbstractSingleValuedFunction;
 public class GetURLPrefix extends AbstractSingleValuedFunction {
@@ -49,8 +48,8 @@
     @Override
     public Object function(Stack stack) {
-        String localServerBase = ConfigProperty.getProperty("wrapper.staging.local.server",
-            (VDL2Config) ctx.getAttribute("SWIFT:CONFIG"));
+        SwiftConfig config = (SwiftConfig) ctx.getAttribute("SWIFT:CONFIG");
+        String localServerBase = config.getWrapperStagingLocalServer();
         String cwd = this.cwd.getValue(stack);
         if (cwd.endsWith("/.")) {
Modified: trunk/src/org/griphyn/vdl/karajan/lib/New.java
--- trunk/src/org/griphyn/vdl/karajan/lib/New.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/griphyn/vdl/karajan/lib/New.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -59,9 +59,7 @@
 	public static final Logger logger = Logger.getLogger(New.class);
 	private static final Mapper NULL_MAPPER = new NullMapper();
-	private static DuplicateMappingChecker staticDMC = new DuplicateMappingChecker(null);
 	private ArgRef<Field> field;
 	private ArgRef<GenericMappingParamSet> mapping;
 	private ArgRef<Object> value;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/Operators.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Operators.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Operators.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -28,22 +28,11 @@
 import org.griphyn.vdl.type.Field;
 import org.griphyn.vdl.type.Type;
 import org.griphyn.vdl.type.Types;
 public class Operators {
-	public static final boolean PROVENANCE_ENABLED;
-	static {
-		boolean v;
-		try {
-		    v = VDL2Config.getConfig().getProvenanceLog();
-		catch (Exception e) {
-			v = false;
-		PROVENANCE_ENABLED = v;
+	public static final boolean PROVENANCE_ENABLED = SwiftConfig.getDefault().isProvenanceEnabled();
 	public static final Logger provenanceLogger = Logger.getLogger("org.globus.swift.provenance.operators");
Modified: trunk/src/org/griphyn/vdl/karajan/lib/Parameterlog.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Parameterlog.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Parameterlog.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -20,6 +20,7 @@
 package org.griphyn.vdl.karajan.lib;
+import k.rt.Context;
 import k.rt.Stack;
 import k.thr.LWThread;
@@ -29,11 +30,10 @@
 import org.globus.cog.karajan.analyzer.Signature;
+import org.globus.cog.karajan.compiled.nodes.InternalFunction;
-import org.globus.cog.karajan.compiled.nodes.InternalFunction;
 public class Parameterlog extends InternalFunction {
     public static final Logger logger = Logger.getLogger(Parameterlog.class);
@@ -48,12 +48,12 @@
     private Boolean enabled;
-    private VarRef<VDL2Config> config;
+    private VarRef<Context> context;
     @Override
     protected Node compileBody(WrapperNode w, Scope argScope, Scope scope)
-        config = scope.getVarRef("SWIFT_CONFIG");
+        context = scope.getVarRef("#context");
         return super.compileBody(w, argScope, scope);
@@ -65,7 +65,9 @@
         boolean run;
         synchronized(this) {
             if (enabled == null) {
-                enabled = "true".equals(ConfigProperty.getProperty("provenance.log", true, config.getValue(stack)));
+                Context ctx = this.context.getValue(stack);
+                enabled = config.isProvenanceEnabled();
             run = enabled;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/RuntimeStats.java
--- trunk/src/org/griphyn/vdl/karajan/lib/RuntimeStats.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/griphyn/vdl/karajan/lib/RuntimeStats.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -17,7 +17,6 @@
@@ -27,7 +26,6 @@
-import k.rt.ExecutionException;
 import k.rt.Stack;
@@ -42,26 +40,15 @@
 /** this is an icky class that does too much with globals, but is for
 proof of concept. */
 public class RuntimeStats {
-    public static final boolean TICKER_DISABLED;
+    public static final boolean TICKER_DISABLED = !SwiftConfig.getDefault().isTickerEnabled();
-    static{
-        boolean disabled;
-        try{
-            disabled = "true".equalsIgnoreCase(VDL2Config.getConfig().getProperty("ticker.disable"));
-            disabled = false;
-        TICKER_DISABLED = disabled;
 	public static final String TICKER = "SWIFT_TICKER";
     //formatter for timestamp against std.err lines
@@ -105,13 +92,7 @@
             t.start();
             context.getValue(thr.getStack()).setAttribute(TICKER, t);
             // Allow user to reformat output date
-            String format;
-            try {
-                format = VDL2Config.getDefaultConfig().getTickerDateFormat();
-                throw new ExecutionException(this, e);
+            String format = SwiftConfig.getDefault().getTickerDateFormat();
             if (format != null && format.length() > 0) {
                 formatter = new SimpleDateFormat(format);
@@ -253,17 +234,11 @@
 		public ProgressTicker() {
 			super("Progress ticker");
 			states = new HashSet<ProgressState>();
-			try {
-				if ("true".equalsIgnoreCase(VDL2Config.getConfig().getProperty("ticker.disable"))) {
-					logger.info("Ticker disabled in configuration file");
-					disabled = true;
-				tickerPrefix =
-					VDL2Config.getConfig().getTickerPrefix();
+			if (!SwiftConfig.getDefault().isTickerEnabled()) {
+				logger.info("Ticker disabled in configuration file");
+				disabled = true;
-				logger.debug("Could not read swift properties", e);
+			tickerPrefix =SwiftConfig.getDefault().getTickerPrefix();
 			start = System.currentTimeMillis();
Modified: trunk/src/org/griphyn/vdl/karajan/lib/SiteCatalog.java
--- trunk/src/org/griphyn/vdl/karajan/lib/SiteCatalog.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/griphyn/vdl/karajan/lib/SiteCatalog.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -9,412 +9,24 @@
-import java.util.ArrayList;
-import java.util.List;
 import k.rt.Stack;
-import org.globus.cog.abstraction.impl.common.AbstractionFactory;
-import org.globus.cog.abstraction.impl.common.ProviderMethodException;
-import org.globus.cog.abstraction.impl.common.task.ExecutionServiceImpl;
-import org.globus.cog.abstraction.impl.common.task.InvalidProviderException;
-import org.globus.cog.abstraction.impl.common.task.ServiceContactImpl;
-import org.globus.cog.abstraction.impl.common.task.ServiceImpl;
-import org.globus.cog.abstraction.interfaces.ExecutionService;
-import org.globus.cog.abstraction.interfaces.Service;
-import org.globus.cog.abstraction.interfaces.ServiceContact;
 import org.globus.cog.karajan.analyzer.ArgRef;
 import org.globus.cog.karajan.analyzer.Param;
-import org.globus.swift.catalog.site.Application;
-import org.globus.swift.catalog.site.SiteCatalogParser;
-import org.globus.swift.catalog.site.SwiftContact;
-import org.globus.swift.catalog.site.SwiftContactSet;
-import org.w3c.dom.Document;
-import org.w3c.dom.NamedNodeMap;
-import org.w3c.dom.Node;
-import org.w3c.dom.NodeList;
 public class SiteCatalog extends AbstractSingleValuedFunction {
-    private ArgRef<String> fileName;
+    private ArgRef<SwiftConfig> config;
     @Override
     protected Param[] getParams() {
-        return params("fileName");
+        return params("config");
     @Override
-        String fn = fileName.getValue(stack);
-        SiteCatalogParser p = new SiteCatalogParser(fn);
-        try {
-            Document doc = p.parse();
-            return buildResources(doc);
-            throw new ExecutionException(this, "Failed to parse site catalog", e);
+        SwiftConfig config = this.config.getValue(stack);
+        return config.getSites();
-    private static class KVPair {
-        public final String key;
-        public final String value;
-        public KVPair(String key, String value) {
-            this.key = key;
-            this.value = value;
-    private Object buildResources(Document doc) {
-        Node root = getRoot(doc);
-        if (root.getLocalName().equals("config")) {
-            throw new IllegalArgumentException("Old sites file format. Please upgrade your sites file to the new format.");
-        else if (root.getLocalName().equals("sites")) {
-            return parse(root);
-        else {
-            throw new IllegalArgumentException("Illegal sites file root node: " + root.getLocalName());
-    private Object parse(Node config) {
-        SwiftContactSet cs = new SwiftContactSet();
-        NodeList pools = config.getChildNodes();
-        for (int i = 0; i < pools.getLength(); i++) {
-            Node n = pools.item(i);
-            if (n.getNodeType() == Node.ELEMENT_NODE) {
-                String ctype = n.getNodeName();
-                if (ctype.equals("site")) {
-                    try {
-                        SwiftContact bc = pool(n);
-                        if (bc != null) {
-                            cs.addContact(bc);
-                        throw new ExecutionException(this, "Invalid site entry '" + poolName(n) + "': ", e);
-                else if (ctype.equals("apps")) {
-                    SwiftContact dummy = new SwiftContact();
-                    apps(dummy, n);
-                    for (Application app : dummy.getApplications()) {
-                        cs.addApplication(app);
-                else {
-                    throw new IllegalArgumentException("Invalid node: " + ctype);
-        return cs;
-    private String poolName(Node site) {
-       if (site.getLocalName().equals("site")) {
-           return attr(site, "name");
-       else {
-           throw new IllegalArgumentException("Invalid node: " + site.getLocalName());
-    private Node getRoot(Document doc) {
-        NodeList l = doc.getChildNodes();
-        for (int i = 0; i < l.getLength(); i++) {
-            if (l.item(i).getNodeType() == Node.ELEMENT_NODE) {
-                return l.item(i);
-        throw new IllegalArgumentException("Missing root element");
-    private SwiftContact pool(Node n) throws InvalidProviderException, ProviderMethodException {
-        if (n.getNodeType() != Node.ELEMENT_NODE) {
-            return null;
-        String name = poolName(n);
-        SwiftContact bc = new SwiftContact(name);
-        String sysinfo = attr(n, "sysinfo", null);
-        if (sysinfo != null) {
-            bc.setProperty("sysinfo", sysinfo);
-        NodeList cs = n.getChildNodes();
-        for (int i = 0; i < cs.getLength(); i++) {
-            Node c = cs.item(i);
-            if (c.getNodeType() != Node.ELEMENT_NODE) {
-                continue;
-            String ctype = c.getNodeName();
-            if (ctype.equals("execution")) {
-                bc.addService(execution(c));
-            else if (ctype.equals("filesystem")) {
-                bc.addService(filesystem(c));
-            else if (ctype.equals("workdirectory")) {
-                bc.setProperty("workdir", text(c));
-            else if (ctype.equals("scratch")) {
-                bc.setProperty("scratch", text(c));
-            else if (ctype.equals("property")) {
-                bc.setProperty(attr(c, "name"), text(c));
-                apps(bc, c);
-            else {
-                throw new IllegalArgumentException("Unknown node type: " + ctype);
-        return bc;
-    private void apps(SwiftContact bc, Node n) {
-        List<KVPair> envs = new ArrayList<KVPair>();
-        List<KVPair> props = new ArrayList<KVPair>();
-                continue;
-            if (ctype.equals("app")) {
-                bc.addApplication(application(c));
-            else if (ctype.equals("env")) {
-                envs.add(env(c));
-                props.add(this.property(c));
-            else {
-        mergeEnvsToApps(bc, envs);
-        mergePropsToApps(bc, props);
-    private void mergeEnvsToApps(SwiftContact bc, List<KVPair> envs) {
-        for (Application app : bc.getApplications()) {
-            for (KVPair kvp : envs) {
-                if (!app.getEnv().containsKey(kvp.key)) {
-                    // only merge if app does not override
-                    app.setEnv(kvp.key, kvp.value);
-    private void mergePropsToApps(SwiftContact bc, List<KVPair> props) {
-            for (KVPair kvp : props) {
-                if (!app.getProperties().containsKey(kvp.key)) {
-                    app.addProperty(kvp.key, kvp.value);
-    private Application application(Node n) {
-        Application app = new Application();
-        app.setName(attr(n, "name"));
-        app.setExecutable(attr(n, "executable"));
-                continue;
-            if (ctype.equals("env")) {
-                KVPair env = env(c);
-                app.setEnv(env.key, env.value);
-                KVPair prop = property(c);
-                app.addProperty(prop.key, prop.value);
-            else {
-        return app;
-    private Service execution(Node n) throws InvalidProviderException, ProviderMethodException {
-        String provider = attr(n, "provider");
-        String url = attr(n, "url", null);
-        String jobManager = attr(n, "jobManager", null);
-        if (jobManager == null) {
-            jobManager = attr(n, "jobmanager", null);
-        ExecutionService s = new ExecutionServiceImpl();
-        s.setProvider(provider);
-        ServiceContact contact = null;
-        if (url != null) {
-            contact = new ServiceContactImpl(url);
-            s.setServiceContact(contact);
-            s.setSecurityContext(AbstractionFactory.newSecurityContext(provider, contact));
-        if (jobManager != null) {
-            s.setJobManager(jobManager);
-        properties(s, n);
-        return s;
-    private void properties(Service s, Node n) {
-                continue;
-            if (ctype.equals("property")) {
-                property(s, c);
-            else {
-    private void property(Service s, Node c) {
-        s.setAttribute(attr(c, "name"), text(c));
-    private KVPair property(Node c) {
-        return new KVPair(attr(c, "name"), text(c));
-    private Service filesystem(Node n) throws InvalidProviderException, ProviderMethodException {
-        Service s = new ServiceImpl();
-        s.setType(Service.FILE_OPERATION);
-        properties(s, n);
-        return s;
-    private KVPair env(Node n) {
-        String key = attr(n, "name");
-        String value = text(n);
-        return new KVPair(key, value);
-    private String text(Node n) {
-        if (n.getFirstChild() != null) {
-            return n.getFirstChild().getNodeValue();
-        else {
-            return null;
-    private String attr(Node n, String name) {
-        NamedNodeMap attrs = n.getAttributes();
-        if (attrs != null) {
-            Node attr = attrs.getNamedItem(name);
-            if (attr == null) {
-                throw new IllegalArgumentException("Missing " + name);
-            else {
-                return expandProps(attr.getNodeValue());
-        else {
-    private String attr(Node n, String name, String defVal) {
-                return defVal;
-            else {
-        else {
-            return defVal;
-    private String expandProps(String v) {
-        if (v == null) {
-            return null;
-        StringBuilder sb = new StringBuilder();
-        int li = -1;
-        for (int i = 0; i < v.length(); i++) {
-            char c = v.charAt(i);
-            switch (c) {
-                case '{':
-                    if (li != -1) {
-                        li = -1;
-                        sb.append('{');
-                    else {
-                        li = i;
-                    break;
-                case '}':
-                    if (li != -1) {
-                        sb.append(System.getProperty(v.substring(li + 1, i)));
-                        li = -1;
-                    else {
-                        sb.append(c);
-                    break;
-                default:
-                    if (li == -1) {
-                        sb.append(c);
-        return sb.toString();
Modified: trunk/src/org/griphyn/vdl/karajan/lib/SiteProperty.java
--- trunk/src/org/griphyn/vdl/karajan/lib/SiteProperty.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/griphyn/vdl/karajan/lib/SiteProperty.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -54,6 +54,8 @@
 		return getSingle(bc, name.getValue(stack), _default.getValue(stack));
+	public static final Os DEFAULT_OS = Os.LINUX;
 	public static final String SWIFT_WRAPPER_INTERPRETER = "wrapperInterpreter";
 	public static final String SWIFT_WRAPPER_INTERPRETER_OPTIONS = "wrapperInterpreterOptions";
 	public static final String SWIFT_WRAPPER_SCRIPT = "wrapperScript";
@@ -141,9 +143,9 @@
     private Os getOS(SwiftContact bc) {
-    	Object o = bc.getProperty("sysinfo");
+    	Object o = bc.getProperty("OS");
     	if (o == null) {
-    		return Os.LINUX;
+    		return DEFAULT_OS;
     	else {
     		return SysInfo.fromString(o.toString()).getOs();
Modified: trunk/src/org/griphyn/vdl/karajan/lib/SwiftFunction.java
--- trunk/src/org/griphyn/vdl/karajan/lib/SwiftFunction.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/griphyn/vdl/karajan/lib/SwiftFunction.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -17,7 +17,6 @@
 import java.util.Collection;
 import java.util.Collections;
@@ -56,25 +55,13 @@
 public abstract class SwiftFunction extends AbstractFunction {
 	public static final Logger logger = Logger.getLogger(SwiftFunction.class);
-    static {
-        boolean v;
-        try {
-            v = false;
     @Override
Modified: trunk/src/org/griphyn/vdl/karajan/lib/Throttled.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Throttled.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Throttled.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -20,7 +20,6 @@
 import java.util.LinkedList;
 import k.rt.ConditionalYield;
@@ -29,8 +28,7 @@
 import k.thr.Yield;
 import org.globus.cog.karajan.compiled.nodes.Sequential;
-import org.globus.cog.karajan.util.TypeUtil;
 public class Throttled extends Sequential {
     public static final int DEFAULT_MAX_THREADS = 1000000;
@@ -39,13 +37,7 @@
     private int maxThreadCount, current;
     public Throttled() {
-        try {
-            maxThreadCount = TypeUtil.toInt(VDL2Config.getConfig()
-                            .getProperty("max.threads", String.valueOf(DEFAULT_MAX_THREADS)));
-            maxThreadCount = DEFAULT_MAX_THREADS;
+        maxThreadCount = (Integer) SwiftConfig.getDefault().getProperty("maxThreads", DEFAULT_MAX_THREADS);
         current = 0;
         waiting = new LinkedList<FutureObject>();
Modified: trunk/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java
--- trunk/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/griphyn/vdl/karajan/lib/ThrottledParallelFor.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -17,7 +17,6 @@
 import java.util.Iterator;
@@ -41,8 +40,7 @@
 import org.globus.cog.karajan.compiled.nodes.UParallelFor;
 public class ThrottledParallelFor extends UParallelFor {
@@ -229,13 +227,7 @@
 	private int getMaxThreads() {
 	    if (maxThreadCount < 0) {
-            try {
-                        .getProperty("foreach.max.threads", String.valueOf(DEFAULT_MAX_THREADS)));
+            maxThreadCount = SwiftConfig.getDefault().getForeachMaxThreads();
 	    return maxThreadCount;
Modified: trunk/src/org/griphyn/vdl/karajan/lib/Tracer.java
--- trunk/src/org/griphyn/vdl/karajan/lib/Tracer.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/griphyn/vdl/karajan/lib/Tracer.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -9,7 +9,6 @@
@@ -25,7 +24,7 @@
 import org.griphyn.vdl.mapping.RootHandle;
 import org.griphyn.vdl.mapping.nodes.AbstractDataNode;
 public class Tracer {
     public static final Logger logger = Logger.getLogger("TRACE");
@@ -34,12 +33,7 @@
     private ThreadLocal<String> thread = new ThreadLocal<String>();
     static {
-        try {
-            globalTracingEnabled = VDL2Config.getConfig().isTracingEnabled();
-            globalTracingEnabled = false;
+        globalTracingEnabled = SwiftConfig.getDefault().isTracingEnabled();
         NAME_MAPPINGS = new HashMap<String, String>();
         NAME_MAPPINGS.put("assignment", "ASSIGN");
         NAME_MAPPINGS.put("iterate", "ITERATE");
Modified: trunk/src/org/griphyn/vdl/karajan/lib/replication/ReplicationManager.java
--- trunk/src/org/griphyn/vdl/karajan/lib/replication/ReplicationManager.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/griphyn/vdl/karajan/lib/replication/ReplicationManager.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -29,7 +29,7 @@
 import org.globus.cog.abstraction.interfaces.JobSpecification;
 import org.globus.cog.abstraction.interfaces.Task;
 import org.globus.cog.karajan.scheduler.Scheduler;
 public class ReplicationManager {
@@ -52,19 +52,15 @@
     private ReplicationGroups replicationGroups;
     private Scheduler scheduler;
-    public ReplicationManager(Scheduler scheduler) {
+    public ReplicationManager(Scheduler scheduler, SwiftConfig config) {
         this.replicationGroups = new ReplicationGroups(scheduler);
         this.scheduler = scheduler;
         queued = new HashMap<Task, Date>();
         running = new HashMap<Task, Date>();
         try {
-            minQueueTime = Integer.parseInt(VDL2Config.getConfig().getProperty(
-                    "replication.min.queue.time"));
-            enabled = Boolean.valueOf(
-                    VDL2Config.getConfig().getProperty("replication.enabled"))
-                    .booleanValue();
-            limit = Integer.parseInt(VDL2Config.getConfig().getProperty(
-                    "replication.limit"));
+            minQueueTime = config.getReplicationMinQueueTime();
+            enabled = config.isReplicationEnabled();
+            limit = config.getReplicationLimit();
             logger.warn(
Modified: trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
--- trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -18,7 +18,6 @@
 package org.griphyn.vdl.karajan.lib.swiftscript;
 import java.io.BufferedReader;
 import java.io.InputStreamReader;
@@ -45,24 +44,13 @@
 import org.griphyn.vdl.mapping.nodes.NodeFactory;
 public class Misc {
 	private static final Logger logger = Logger.getLogger(Misc.class);
-	static {
-		boolean v;
-		try {
-            v = false;
 	private static final Logger traceLogger = Logger.getLogger("org.globus.swift.trace");
Modified: trunk/src/org/griphyn/vdl/mapping/DuplicateMappingChecker.java
--- trunk/src/org/griphyn/vdl/mapping/DuplicateMappingChecker.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/griphyn/vdl/mapping/DuplicateMappingChecker.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -16,8 +16,7 @@
 public class DuplicateMappingChecker {
     public static final Logger logger = Logger.getLogger(DuplicateMappingChecker.class);
@@ -26,13 +25,8 @@
     private final Map<PhysicalFormat, Entry> map;
-    public DuplicateMappingChecker(VDL2Config conf) {
-    	if (conf == null) {
-    		enabled = true;
-    	else {
-    	    enabled = !"off".equals(conf.getProperty(VDL2ConfigProperties.DM_CHECKER));
+    public DuplicateMappingChecker(SwiftConfig conf) {
+        enabled = conf.isMappingCheckerEnabled();
         map = new HashMap<PhysicalFormat, Entry>();
Modified: trunk/src/org/griphyn/vdl/mapping/file/FileGarbageCollector.java
--- trunk/src/org/griphyn/vdl/mapping/file/FileGarbageCollector.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/griphyn/vdl/mapping/file/FileGarbageCollector.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -17,7 +17,6 @@
 package org.griphyn.vdl.mapping.file;
@@ -27,8 +26,7 @@
 import org.griphyn.vdl.mapping.PhysicalFormat;
 public class FileGarbageCollector implements Runnable {
     public static final Logger logger = Logger.getLogger(FileGarbageCollector.class);
@@ -52,13 +50,7 @@
         queue = new LinkedList<PhysicalFormat>();
         usageCount = new HashMap<PhysicalFormat, Integer>();
         persistent = new HashSet<PhysicalFormat>();
-        try {
-            enabled = !"false".equals(VDL2Config.getConfig().getProperty(VDL2ConfigProperties.FILE_GC_ENABLED));
-            //enabled by default
-            enabled = true;
+        enabled = SwiftConfig.getDefault().isFileGCEnabled();
         if (enabled) {
             thread = new Thread(this, "File Garbage Collector");
             thread.setDaemon(true);
Modified: trunk/src/org/griphyn/vdl/mapping/nodes/AbstractDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/nodes/AbstractDataNode.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/griphyn/vdl/mapping/nodes/AbstractDataNode.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -20,7 +20,6 @@
 package org.griphyn.vdl.mapping.nodes;
@@ -44,7 +43,7 @@
@@ -79,11 +78,7 @@
     public static boolean provenance = false;
     static {
-        try {
-        	provenance = VDL2Config.getConfig().getProvenanceLog();
+       	provenance = SwiftConfig.getDefault().isProvenanceEnabled();
     protected Field field;
Modified: trunk/src/org/griphyn/vdl/util/ConfigPropertyType.java
--- trunk/src/org/griphyn/vdl/util/ConfigPropertyType.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/griphyn/vdl/util/ConfigPropertyType.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -10,25 +10,46 @@
 package org.griphyn.vdl.util;
 import java.io.File;
+import java.util.Arrays;
+import java.util.List;
 import java.util.SortedSet;
 import java.util.TreeSet;
-public abstract class ConfigPropertyType {
-    public static final ConfigPropertyType BOOLEAN = choices("true", "false");
-    public static final ConfigPropertyType ONOFF = choices("on", "off");
-    public static final ConfigPropertyType STRING = new CPTString();
-    public static final ConfigPropertyType INT = new Int();
-    public static final ConfigPropertyType FLOAT = new CPTFloat();
-    public static final ConfigPropertyType FILE = new CPTFile();
+import org.globus.cog.abstraction.impl.common.execution.WallTime;
+import org.globus.swift.catalog.types.Arch;
+import org.globus.swift.catalog.types.Os;
+public abstract class ConfigPropertyType<T> {
+    public static final ConfigPropertyType<Boolean> BOOLEAN = new CPTBoolean();
+    public static final ConfigPropertyType<String> STRING = new CPTString();
+    public static final ConfigPropertyType<Integer> INT = new Int();
+    public static final ConfigPropertyType<Object> THROTTLE = new Throttle();
+    public static final ConfigPropertyType<String> PORT_RANGE = new PortRange();
+    public static final ConfigPropertyType<Integer> STRICTLY_POSITIVE_INT = new SPInt();
+    public static final ConfigPropertyType<Integer> POSITIVE_INT = new PInt();
+    public static final ConfigPropertyType<Double> POSITIVE_FLOAT = new PFloat();
+    public static final ConfigPropertyType<Double> FLOAT = new CPTFloat();
+    public static final ConfigPropertyType<String> FILE = new CPTFile();
+    public static final ConfigPropertyType<String> TIME = new CPTTime();
+    public static final ConfigPropertyType<Object> OBJECT = new CPTObject();
+    public static final ConfigPropertyType<Object> STRING_LIST = new StringList();
+    public static final ConfigPropertyType<String> OS = new CPTOS();
-    public static ConfigPropertyType choices(String... values) {
+    public static ConfigPropertyType<String> choices(String... values) {
         return new Choices(values);
-    public abstract void checkValue(String propName, String value, String source);
+    @SuppressWarnings("unchecked")
+    public Object check(String propName, Object value, String source) {
+        return checkValue(propName, (T) value, source);
+    public abstract Object checkValue(String propName, T value, String source);
+    public abstract ConfigPropertyType<?> getBaseType();
     private static String pp(Collection<String> c) {
         Iterator<String> i = c.iterator();
@@ -43,8 +64,8 @@
-    private static class Choices extends ConfigPropertyType {
-        private SortedSet<String> choices;
+    public static class Choices extends ConfigPropertyType<String> {
+        protected SortedSet<String> choices;
         public Choices(String... values) {
             choices = new TreeSet<String>();
@@ -54,55 +75,343 @@
         @Override
-        public void checkValue(String propName, String value, String source) {
+        public Object checkValue(String propName, String value, String source) {
             if (!choices.contains(value)) {
                 throw new IllegalArgumentException(source + ":\n\tInvalid value '" + value + "' for property '" +
                     propName + "'. Valid values are: " + pp(choices));
+            return value;
+        @Override
+        public ConfigPropertyType<?> getBaseType() {
+            return STRING;
+        @Override
+        public String toString() {
+            return "one of " + choices;
-    private static class CPTString extends ConfigPropertyType {
+    private static class CPTOS extends Choices {
+        public CPTOS() {
+            super();
+            int ix = 0;
+            for (Arch a : Arch.values()) {
+                for (Os o : Os.values()) {
+                    choices.add(a + "::" + o);
+    private static class CPTString extends ConfigPropertyType<String> {
         @Override
             // all values accepted
+            return value;
+        @Override
+            return STRING;
+        @Override
+            return "string";
-    private static class Int extends ConfigPropertyType {
+    private static class Int extends ConfigPropertyType<Integer> {
         @Override
-            try {
-                Integer.parseInt(value);
+        public Object checkValue(String propName, Integer value, String source) {
+            return value;
+        @Override
+            return INT;
+        @Override
+            return "integer";
+    private static class CPTBoolean extends ConfigPropertyType<Boolean> {
+        @Override
+        public Object checkValue(String propName, Boolean value, String source) {
+            return value;
+        @Override
+            return BOOLEAN;
+        @Override
+            return "boolean";
+    private static class SPInt extends ConfigPropertyType<Integer> {
+        @Override
+            if (value <= 0) {
+                throw new IllegalArgumentException(source + ":\n\tInvalid value '" + value + "' for property '" +
+                propName + "'. Must be a " + toString());
-            catch (NumberFormatException e) {
+            return value;
+        @Override
+            return INT;
+        @Override
+            return "strictly positive integer";
+    private static class PInt extends ConfigPropertyType<Integer> {
+        @Override
+            if (value < 0) {
-                    propName + "'. Must be an integer");
+            return value;
+        @Override
+            return INT;
+        @Override
+            return "positive integer";
-    private static class CPTFloat extends ConfigPropertyType {
+    private static class Throttle extends ConfigPropertyType<Object> {
         @Override
-            try {
-                Double.parseDouble(value);
+        public Object checkValue(String propName, Object value, String source) {
+            if ("off".equals(value)) {
+                return Integer.MAX_VALUE;
+            else if (value instanceof Integer) {
+                Integer i = (Integer) value;
+                if (i > 0) {
+                    return i;
+                propName + "'. Must be an " + toString());
+        @Override
+            return INT;
+        @Override
+            return "integer greater than zero or \"off\"";
+    private static class PFloat extends ConfigPropertyType<Double> {
+        @Override
+        public Object checkValue(String propName, Double value, String source) {
+            if (value < 0) {
-                    propName + "'. Must be a floating point number.");
+            return value;
+        @Override
+            return FLOAT;
+        @Override
+            return "positive number";
-    private static class CPTFile extends ConfigPropertyType {
+    private static class CPTFloat extends ConfigPropertyType<Double> {
         @Override
+            return value;
+        @Override
+            return FLOAT;
+    public static class Interval extends ConfigPropertyType<Double> {
+        private double l, h;
+        public Interval(double l, double h) {
+            this.l = l;
+            this.h = h;
+        @Override
+            if (value < l || value > h) {
+            return value;
+        @Override
+            return FLOAT;
+        @Override
+            return "floating point number in the interval [" + l + ", " + h + "]";
+    private static class CPTTime extends ConfigPropertyType<String> {
+        @Override
+            try {
+                WallTime.timeToSeconds(value);
+            catch (IllegalArgumentException e) {
+                throw new IllegalArgumentException(source + ":\n\tInvalid time value '" + value + "' for property '" +
+                    propName + "'. Mist be a " + toString());
+            return value;
+        @Override
+            return STRING;
+        @Override
+            return "string in one of the formats MM, HH:MM, or HH:MM:SS";
+    private static class PortRange extends ConfigPropertyType<String> {
+        @Override
+            String[] els = value.split(",\\s*");
+            if (els.length == 2) {
+                try {
+                    Integer.parseInt(els[0]);
+                    Integer.parseInt(els[1]);
+                    return value;
+                catch (NumberFormatException e) {
+        @Override
+            return STRING;
+        @Override
+            return "port range in the format 'port1, port2'";
+    private static class CPTFile extends ConfigPropertyType<String> {
+        @Override
             File f = new File(value);
             if (!f.exists()) {
                     propName + "'. File does not exist.");
+            return value;
+        @Override
+            return STRING;
+        @Override
+            return "file path";
+    private static class CPTObject extends ConfigPropertyType<Object> {
+        @Override
+            return value;
+        @Override
+            return OBJECT;
+        @Override
+            return "object";
+    private static class StringList extends ConfigPropertyType<Object> {
+        @Override
+            if (value instanceof List) {
+                List<?> l = (List<?>) value;
+                boolean allStrings = true;
+                for (Object o : l) {
+                    if (!(o instanceof String)) {
+                        allStrings = false;
+                if (allStrings) {
+                    return value;
+            else if (value instanceof String) {
+                // also allow comma separated strings in a string
+                return Arrays.asList(((String) value).split(",\\s*"));
+        @Override
+            return OBJECT;
+        @Override
+            return "list of strings";
Added: trunk/src/org/griphyn/vdl/util/ConfigTree.java
--- trunk/src/org/griphyn/vdl/util/ConfigTree.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/util/ConfigTree.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -0,0 +1,319 @@
+//This code is developed as part of the Java CoG Kit project
+//The terms of the license can be found at http://www.cogkit.org/license
+//This message may not be removed or altered.
+ * Created on Jul 6, 2014
+package org.griphyn.vdl.util;
+import java.util.Collections;
+import java.util.Map;
+import java.util.NoSuchElementException;
+import java.util.Set;
+public class ConfigTree<T> {
+    public static class Node<T> {
+        private Map<String, Node<T>> nodes;
+        private T value;
+        protected void checkEmpty(String k) {
+            if (k.isEmpty()) {
+                throw new IllegalArgumentException();
+        protected String first(String k) {
+            int ix = k.indexOf('.');
+            if (ix == -1) {
+                return k;
+            else {
+                return k.substring(0, ix);
+        protected String rest(String k) {
+            if (ix == -1) {
+                return "";
+            else {
+                return k.substring(ix + 1);
+        public Object get() {
+            return value;
+        public T get(String k) {
+            return get(k, null);
+        public T get(String k, String wildcard) {
+                return value;
+            if (nodes == null || nodes.isEmpty()) {
+                throw new NoSuchElementException();
+            Node<T> t = nodes.get(first(k));
+            if (t == null && wildcard != null) {
+                t = nodes.get(wildcard);
+            if (t == null) {
+            return t.get(rest(k), wildcard);
+        public boolean hasKey(String k) {
+                return value != null;
+                return false;
+            if (t == null) {
+                return false;
+            return t.hasKey(rest(k));
+        public T put(String k, T v) {
+                return set(v);
+            else {
+                if (nodes == null) {
+                    nodes = new HashMap<String, Node<T>>();
+                String first = first(k);
+                if (k == first) {
+                    return getOrCreateTree(k).set(v);
+                else {
+                    return getOrCreateTree(first).put(rest(k), v);
+        private Node<T> getOrCreateTree(String k) {
+            Node<T> t = nodes.get(k);
+            if (t == null) {
+                t = new Node<T>();
+                nodes.put(k, t);
+                return t;
+            else {
+                return t;
+        public void getLeafPaths(List<String> l, String partial) {
+            if (value != null) {
+                l.add(partial);
+            if (nodes != null) {
+                for (Map.Entry<String, Node<T>> e : nodes.entrySet()) {
+                    if (partial == null) {
+                        e.getValue().getLeafPaths(l, e.getKey());
+                    else {
+                        e.getValue().getLeafPaths(l, partial + "." + e.getKey());
+        public void expandWildcards(List<String> l, String k, String wildcard, String partial) {
+                    l.add(k);
+                else {
+                    l.add(partial + "." + k);
+                if (rest(k).isEmpty()) {
+                        l.add(k);
+                    else {
+                return;
+            String mk = first(k);
+            if (mk.equals(wildcard)) {
+                    Node<T> n = e.getValue();
+                    String rest = rest(k);
+                    String p;
+                        p = e.getKey();
+                    else {
+                        p = partial + "." + e.getKey();
+                    n.expandWildcards(l, rest, wildcard, p);
+            else {
+                Node<T> t = nodes.get(mk);
+                if (t == null) {
+                    if (first(rest(k)).equals(wildcard)) {
+                        // x.* is allowed to not be there
+                        return;
+                        l.add(k);
+                    else {
+                    return;
+                String p;
+                    p = mk;
+                else {
+                    p = partial + "." + mk;
+                t.expandWildcards(l, rest, wildcard, p);
+        public T set(T v) {
+            T old = value;
+            value = v;
+            return old;
+        public Set<Map.Entry<String, Node<T>>> entrySet() {
+                Map<String, Node<T>> empty = Collections.emptyMap();
+                return empty.entrySet();
+            else {
+                return nodes.entrySet();
+        private void toString(StringBuilder sb, int level, String k) {
+            for (int i = 0; i < level; i++) {
+                sb.append('\t');
+                    sb.append(k);
+                    sb.append(": ");
+                    if (value instanceof String) {
+                        sb.append('\"');
+                        sb.append(value);
+                        sb.append('\"');
+                    else {
+                        sb.append(value);
+                    sb.append('\n');
+            else if (nodes.size() == 1) {
+                String key = nodes.keySet().iterator().next();
+                if (k == null) {
+                    nodes.values().iterator().next().toString(sb, 0, key);
+                else {
+                    nodes.values().iterator().next().toString(sb, 0, k + "." + key);
+            else {
+                if (k != null) {
+                    sb.append(k);
+                    sb.append(' ');
+                sb.append("{\n");
+                    e.getValue().toString(sb, level + 1, e.getKey());
+                    sb.append('\t');
+                sb.append("}\n");
+    private Node<T> root;
+    public ConfigTree() {
+        root = new Node<T>();
+        return root.put(k, v);
+        try {
+            return root.get(k, wildcard);
+            throw new NoSuchElementException("Not a leaf: " + k);
+        catch (NoSuchElementException e) {
+            return null;
+    public List<String> getLeafPaths() {
+        List<String> l = new ArrayList<String>();
+        root.getLeafPaths(l, null);
+        return l;
+     * Find all paths matching the given path. Wildcards are expanded based
+     * on what's in the tree, but the full paths do not need to exist in the tree.
+     * So if a.1.b.2 and a.1.b.3 were in the tree, a.*.b.*.c would generate
+     * a.1.b.2.c and a.1.b.3.c
+    public List<String> expandWildcards(String key, String wildcard) {
+        root.expandWildcards(l, key, wildcard, null);
+        return l;
+        return root.hasKey(k);
+        return root.entrySet();
+        StringBuilder sb = new StringBuilder();
+        root.toString(sb, 0, null);
+        return sb.toString();
Added: trunk/src/org/griphyn/vdl/util/ConvertConfig.java
--- trunk/src/org/griphyn/vdl/util/ConvertConfig.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/util/ConvertConfig.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -0,0 +1,772 @@
+ * Created on Jan 7, 2013
+import java.io.FileOutputStream;
+import java.io.FileReader;
+import java.io.IOException;
+import java.io.PrintStream;
+import java.util.HashSet;
+import java.util.Properties;
+import org.globus.cog.abstraction.impl.common.AbstractionFactory;
+import org.globus.cog.abstraction.impl.common.ProviderMethodException;
+import org.globus.cog.abstraction.impl.common.task.ExecutionServiceImpl;
+import org.globus.cog.abstraction.impl.common.task.InvalidProviderException;
+import org.globus.cog.abstraction.impl.common.task.ServiceContactImpl;
+import org.globus.cog.abstraction.impl.common.task.ServiceImpl;
+import org.globus.cog.abstraction.interfaces.ExecutionService;
+import org.globus.cog.abstraction.interfaces.Service;
+import org.globus.cog.abstraction.interfaces.ServiceContact;
+import org.globus.cog.karajan.scheduler.WeightedHost;
+import org.globus.cog.karajan.util.BoundContact;
+import org.globus.cog.karajan.util.ContactSet;
+import org.globus.cog.karajan.util.TypeUtil;
+import org.globus.cog.util.ArgumentParser;
+import org.globus.cog.util.ArgumentParserException;
+import org.globus.swift.catalog.TCEntry;
+import org.globus.swift.catalog.TransformationCatalog;
+import org.globus.swift.catalog.site.SiteCatalogParser;
+import org.globus.swift.catalog.transformation.File;
+import org.globus.swift.catalog.util.Profile;
+import org.w3c.dom.Document;
+import org.w3c.dom.NamedNodeMap;
+import org.w3c.dom.Node;
+import org.w3c.dom.NodeList;
+public class ConvertConfig {
+    private enum Version {
+        V1, V2;
+    private ContactSet parseSites(String fileName) {
+        SiteCatalogParser p = new SiteCatalogParser(fileName);
+        try {
+            Document doc = p.parse();
+            return buildResources(doc);
+        catch (Exception e) {
+            throw new RuntimeException("Failed to parse site catalog", e);
+    private TransformationCatalog loadTC(String fileName) {
+        return File.getNonSingletonInstance(fileName);
+    public void run(String sitesFile, String tcFile, String conf, PrintStream ps) {
+        if (sitesFile == null && tcFile == null && conf == null) {
+            throw new IllegalArgumentException("You must specify at " +
+            		"least one file type to convert");
+        ContactSet sites = null;
+        if (sitesFile != null) {
+            sites = parseSites(sitesFile);
+        TransformationCatalog tc = null;
+        if (tcFile != null) {
+            tc = loadTC(tcFile);
+        generateConfig(sites, tc, ps);
+        if (conf != null) {
+            Properties props = new Properties();
+            try {
+                props.load(new FileReader(conf));
+                generateConfig(props, ps);
+            catch (IOException e) {
+                throw new RuntimeException("Could not load config file", e);
+    private void generateConfig(Properties props, PrintStream ps) {
+        Set<String> processed = new HashSet<String>();
+        for (String name : propOrder) {
+            if (props.containsKey(name)) {
+                prop(name, props.get(name), ps);
+                processed.add(name);
+        for (Map.Entry<Object, Object> e : props.entrySet()) {
+            String name = (String) e.getKey();
+            if (!processed.contains(name)) {
+    private void prop(String name, Object value, PrintStream ps) {
+        if (removedAttrs.contains(name)) {
+                ps.println("# option removed: " + name);
+                return;
+        if (name.equals("use.provider.staging")) {
+            if (TypeUtil.toBoolean(value)) {
+                ps.println("staging: \"provider\"");
+            return;
+        if (name.equals("use.wrapper.staging")) {
+                ps.println("staging: \"wrapper\"");
+            return;
+        Attr a = props.get(name);
+        if (a == null) {
+            throw new RuntimeException("Unknown configuration property '" + name + "'");
+        ps.print(a.name + ": ");
+        printValue(a.type, value, ps);
+    private void generateConfig(ContactSet sites, TransformationCatalog tc, PrintStream ps) {
+        ps.println("include \"${swift.home}/etc/swift.conf\"");
+        ps.println();
+        if (sites != null) {
+            for (BoundContact bc : sites.getContacts()) {
+                ps.println("site." + bc.getName() + " {");
+                boolean hasFileService = false;
+                boolean hasCoasterService = false;
+                for (Map.Entry<BoundContact.TypeProviderPair, Service> e : bc.getServices().entrySet()) {
+                    String provider = e.getKey().provider;
+                    if (provider == null) {
+                        continue;
+                    if (e.getKey().type == Service.EXECUTION) {
+                        ExecutionService es = (ExecutionService) e.getValue();
+                        ps.println("\texecution {");
+                        ps.println("\t\ttype: \"" + provider + "\"");
+                        if (es.getServiceContact() != null) {
+                            ps.println("\t\tURL: \"" + es.getServiceContact().getContact() + "\"");
+                        if (es.getJobManager() != null) {
+                            ps.println("\t\tjobManager: \"" + es.getJobManager() + "\"");
+                        if (provider.equals("coaster")) {
+                            hasCoasterService = true;
+                            generateCoasterServiceAttributes(bc, ps);
+                        ps.println("\t}");
+                        if (!provider.equals("coaster")) {
+                            generateServiceAttributes(es, ps);
+                    else if (e.getKey().type == Service.FILE_OPERATION) {
+                        hasFileService = true;
+                        ps.println("\tfilesystem {");
+                        if (e.getValue().getServiceContact() != null) {
+                            ps.println("\t\tURL: \"" + e.getValue().getServiceContact().getContact() + "\"");
+                if (!hasFileService) {
+                    ps.println("\tstaging: \"provider\"");
+                if (bc.hasProperty("workdir")) {
+                    ps.println("\tworkDirectory: \"" + bc.getProperty("workdir") + "\"");
+                if (bc.hasProperty("scratch")) {
+                    ps.println("\tscratch: \"" + bc.getProperty("scratch") + "\"");
+                generateSiteAttributes(bc.getProperties(), ps);
+                if (tc != null) {
+                    generateAppInfo(bc.getName(), tc, hasCoasterService, 1, ps);
+                ps.println("}\n");
+        if (tc != null) {
+            generateAppInfo("*", tc, false, 0, ps);
+    private void generateAppInfo(String host, TransformationCatalog tc, boolean hasCoasterService, int level, PrintStream ps) {
+        try {
+            for (TCEntry e : tc.getTC()) {
+                if (e.getResourceId().equals(host)) {
+                    if (e.getLogicalName().equals("*")) {
+                        tabs(level, ps);
+                        ps.println("app.ALL {");
+                    else {
+                        tabs(level, ps);
+                        ps.println("app." + e.getLogicalName() + " {");
+                    tabs(level + 1, ps);
+                    ps.println("executable: " + e.getPhysicalTransformation());
+                    if (e.getProfiles() != null) {
+                        generateAppProfiles(e, hasCoasterService, level, ps);
+                    tabs(level, ps);
+            throw new RuntimeException("Failed to get TC data", e);
+    private void generateAppProfiles(TCEntry e, boolean hasCoasterService, int level, PrintStream ps) {
+        StringBuilder options = new StringBuilder();
+        for (Profile p : e.getProfiles()) {
+            if (p.getProfileKey().startsWith("env.")) {
+                tabs(level, ps);
+                ps.println(p.getProfileKey() + ": \"" + p.getProfileValue() + "\"");
+            else if (p.getProfileKey().equals("maxwalltime")) {
+                tabs(level, ps);
+                ps.println("maxWallTime: \"" + p.getProfileValue() + "\"");
+            else if (p.getProfileKey().equals("queue")) {
+                if (!hasCoasterService) {
+                    tabs(level, ps);
+                    ps.println("jobQueue: \"" + p.getProfileValue() + "\"");
+            else if (p.getProfileKey().equals("project")) {
+                    tabs(level, ps);
+                    ps.println("jobProject: \"" + p.getProfileValue() + "\"");
+            else {
+                if (options.length() != 0) {
+                    options.append(", ");
+                else {
+                    options.append("{");
+                options.append(p.getProfileKey() + ": \"" + p.getProfileValue() + "\"");
+            options.append("}");
+            tabs(level, ps);
+            ps.println("options: " + options.toString());
+    private void tabs(int count, PrintStream ps) {
+        for (int i = 0; i < count; i++) {
+            ps.print('\t');
+    private void generateSiteAttributes(Map<String, Object> properties, PrintStream ps) {
+        if (properties.containsKey("sysinfo")) {
+            ps.println("\tOS: \"" + properties.get("sysinfo") + "\"");
+        if (properties.containsKey("delayBase")) {
+            ps.println("\tdelayBase: " + properties.get("delayBase"));
+        if (properties.containsKey("initialScore")) {
+            double jobThrottle = 2;
+            if (properties.containsKey("jobThrottle")) {
+                jobThrottle = TypeUtil.toDouble(properties.get("jobThrottle"));
+            double initialScore = TypeUtil.toDouble(properties.get("initialScore"));
+            ps.println("\tmaxParallelTasks: " + (int) (jobThrottle * WeightedHost.T + 1));
+            ps.println("\tinitialParallelTasks: " + (int) (jobThrottle * WeightedHost.computeTScore(initialScore) + 1));
+        if (properties.containsKey("maxSubmitRate")) {
+            ps.println("\tmaxSubmitRate: " + properties.get("maxSubmitRate"));
+    private enum AttrType {
+        INT, FLOAT, STRING, BOOLEAN, TIME_FROM_SECONDS;
+    private static class Attr {
+        public Attr(String k, AttrType t) {
+            this.name = k;
+            this.type = t;
+        public AttrType type;
+        public String name;
+    private static final Set<String> removedAttrs;
+    private static final Map<String, Attr> coasterAttrs;
+    private static final Map<String, Attr> serviceAttrs;
+    private static final Map<String, Attr> props;
+    private static List<String> propOrder;
+    static {
+        removedAttrs = new HashSet<String>();
+        removedAttrs.add("pgraph");
+        removedAttrs.add("pgraph.graph.options");
+        removedAttrs.add("pgraph.node.options");
+        removedAttrs.add("clustering.enabled");
+        removedAttrs.add("clustering.queue.delay");
+        removedAttrs.add("clustering.min.time");
+        removedAttrs.add("kickstart.enabled");
+        removedAttrs.add("kickstart.always.transfer");
+        removedAttrs.add("sites.file");
+        removedAttrs.add("tc.file");
+        coasterAttrs = new HashMap<String, Attr>();
+        attr(coasterAttrs, "queue", "jobQueue", AttrType.STRING);
+        attr(coasterAttrs, "project", "jobProject", AttrType.STRING);
+        attr(coasterAttrs, "maxtime", "jobMaxTime", AttrType.TIME_FROM_SECONDS);
+        attr(coasterAttrs, "reserve", AttrType.STRING);
+        attr(coasterAttrs, "lowOverallocation", AttrType.INT);
+        attr(coasterAttrs, "highOverallocation", AttrType.INT);
+        attr(coasterAttrs, "slots", "maxJobs", AttrType.INT);
+        attr(coasterAttrs, "maxNodes", "maxNodesPerJob", AttrType.INT);
+        attr(coasterAttrs, "overallocationDecayFactor", AttrType.FLOAT);
+        attr(coasterAttrs, "internalHostname", AttrType.STRING);
+        attr(coasterAttrs, "allocationStepSize", AttrType.FLOAT);
+        attr(coasterAttrs, "nodeGranularity", AttrType.INT);
+        attr(coasterAttrs, "remoteMonitorEnabled", AttrType.BOOLEAN);
+        attr(coasterAttrs, "userHomeOverride", AttrType.STRING);
+        attr(coasterAttrs, "workerLoggingLevel", AttrType.STRING);
+        attr(coasterAttrs, "workerLoggingDirectory", AttrType.STRING);
+        attr(coasterAttrs, "workerManager", AttrType.STRING);
+        attr(coasterAttrs, "softImage", AttrType.STRING);
+        attr(coasterAttrs, "jobsPerNode", "tasksPerNode", AttrType.INT);
+        serviceAttrs = new HashMap<String, Attr>();
+        attr(serviceAttrs, "queue", "jobQueue", AttrType.STRING);
+        attr(serviceAttrs, "project", "jobProject", AttrType.STRING);
+        attr(serviceAttrs, "maxtime", "jobMaxTime", AttrType.STRING);
+        attr(serviceAttrs, "jobType", "jobType", AttrType.STRING);
+        props = new HashMap<String, Attr>();
+        propOrder = new ArrayList<String>();
+        prop("hostname", "hostName", AttrType.STRING);
+        prop("tcp.port.range", "TCPPortRange", AttrType.STRING);
+        prop("lazy.errors", "lazyErrors", AttrType.BOOLEAN);
+        prop("execution.retries", "executionRetries", AttrType.INT);
+        prop("caching.algorithm", "cachingAlgorithm", AttrType.STRING);
+        prop("throttle.submit", "jobSubmitThrottle", AttrType.INT);
+        prop("throttle.host.submit", "hostJobSubmitThrottle", AttrType.INT);
+        prop("throttle.transfers", "fileTransfersThrottle", AttrType.INT);
+        prop("throttle.file.operations", "fileOperationsThrottle", AttrType.INT);
+        prop("throttle.score.job.factor", "siteScoreThrottlingFactor", AttrType.INT);
+        prop("sitedir.keep", "keepSiteDir", AttrType.BOOLEAN);
+        prop("provenance.log", "logProvenance", AttrType.BOOLEAN);
+        prop("replication.enabled", "replicationEnabled", AttrType.BOOLEAN);
+        prop("replication.min.queue.time", "replicationMinQueueTime", AttrType.INT);
+        prop("replication.limit", "replicationLimit", AttrType.INT);
+        prop("status.mode", "statusMode", AttrType.STRING);
+        prop("wrapper.parameter.mode", "wrapperParameterMode", AttrType.STRING);
+        prop("wrapper.invocation.mode", "wrapperInvocationMode", AttrType.STRING);
+        prop("cdm.broadcast.mode", "CDMBroadcastMode", AttrType.STRING);
+        prop("provider.staging.pin.swiftfiles", "providerStagingPinSwiftFiles", AttrType.BOOLEAN);
+        prop("ticker.date.format", "tickerDateFormat", AttrType.STRING);
+        prop("ticker.prefix", "tickerPrefix", AttrType.STRING);
+        prop("ticker.enabled", "tickerEnabled", AttrType.BOOLEAN);
+        prop("file.gc.enabled", "fileGCEnabled", AttrType.BOOLEAN);
+        prop("mapping.checker", "mappingCheckerEnabled", AttrType.BOOLEAN);
+        prop("wrapperlog.always.transfer", "alwaysTransferWrapperLog", AttrType.BOOLEAN);
+        prop("tracing.enabled", "tracingEnabled", AttrType.BOOLEAN);
+        prop("wrapper.staging.local.server", "wrapperStagingLocalServer", AttrType.STRING);
+        prop("foreach.max.threads", "maxForeachThreads", AttrType.INT);
+    private static void attr(Map<String, Attr> m, String k, AttrType t) {
+        m.put("globus:" + k.toLowerCase(), new Attr(k, t));
+    private static void attr(Map<String, Attr> m, String k, String v, AttrType t) {
+        m.put("globus:" + k.toLowerCase(), new Attr(v, t));
+    private static void prop(String k, AttrType t) {
+        if (!SwiftConfig.SCHEMA.isNameValid(k)) {
+            throw new Error("Invalid prop: '" + k + "'");
+        props.put(k, new Attr(k, t));
+        propOrder.add(k);
+    private static void prop(String k, String v, AttrType t) {
+        if (!SwiftConfig.SCHEMA.isNameValid(v)) {
+            throw new Error("Invalid prop: '" + v + "'");
+        props.put(k, new Attr(v, t));
+        propOrder.add(k);
+    private void generateCoasterServiceAttributes(BoundContact bc, PrintStream ps) {
+        for (String attr : bc.getProperties().keySet()) {
+            Attr a = coasterAttrs.get(attr.toLowerCase());
+            if (a != null) {
+                ps.print("\t\t" + a.name + ": ");
+                printValue(a.type, bc.getProperty(attr), ps);
+            else {
+                if (attr.startsWith("globus.")) {
+                    throw new RuntimeException("Unrecognize profile: '" + attr + "'");
+    private void printValue(AttrType type, Object value, PrintStream ps) {
+        switch (type) {
+            case INT:
+            case FLOAT:
+            case BOOLEAN:
+                ps.println(value);
+                break;
+            case STRING:
+                ps.println("\"" + value + "\"");
+                break;
+            case TIME_FROM_SECONDS:
+                ps.println("\"" + WallTime.format("hms", TypeUtil.toInt(value)) + "\"");
+                break;
+    private void generateServiceAttributes(Service s, PrintStream ps) {
+        for (String attr : s.getAttributeNames()) {
+            Attr a = serviceAttrs.get(attr);
+            if (a != null) {
+                switch (a.type) {
+                    case INT:
+                    case FLOAT:
+                    case BOOLEAN:
+                        ps.println(s.getAttribute(attr));
+                        break;
+                    case STRING:
+                        ps.println("\"" + s.getAttribute(attr) + "\"");
+                        break;
+            else {
+                if (attr.startsWith("globus.") && coasterAttrs.containsKey(attr)) {
+    private ContactSet buildResources(Document doc) {
+        Node root = getRoot(doc);
+        if (root.getLocalName().equals("config")) {
+            return parse(root, Version.V1);
+        else if (root.getLocalName().equals("sites")) {
+        else {
+            throw new IllegalArgumentException("Illegal sites file root node: " + root.getLocalName());
+    private ContactSet parse(Node config, Version v) {
+        ContactSet cs = new ContactSet();
+        NodeList pools = config.getChildNodes();
+        for (int i = 0; i < pools.getLength(); i++) {
+            Node n = pools.item(i);
+            if (n.getNodeType() == Node.ELEMENT_NODE) {
+                try {
+                    BoundContact bc = pool(n, v);
+                    if (bc != null) {
+                        cs.addContact(bc);
+                    throw new RuntimeException("Invalid site entry '" + poolName(n, v) + "': ", e);
+        return cs;
+    private String poolName(Node site, Version v) {
+       if (site.getLocalName().equals("pool")) {
+           return attr(site, "handle");
+       else if (site.getLocalName().equals("site")) {
+           return attr(site, "name");
+       else {
+           throw new IllegalArgumentException("Invalid node: " + site.getLocalName());
+    private Node getRoot(Document doc) {
+        NodeList l = doc.getChildNodes();
+        for (int i = 0; i < l.getLength(); i++) {
+            if (l.item(i).getNodeType() == Node.ELEMENT_NODE) {
+                return l.item(i);
+        throw new IllegalArgumentException("Missing root element");
+    private BoundContact pool(Node n, Version v) throws InvalidProviderException, ProviderMethodException {
+        if (n.getNodeType() != Node.ELEMENT_NODE) {
+            return null;
+        String name = poolName(n, v);
+        BoundContact bc = new BoundContact(name);
+        String sysinfo = attr(n, "sysinfo", null);
+        if (sysinfo != null) {
+            bc.setProperty("sysinfo", sysinfo);
+        NodeList cs = n.getChildNodes();
+        for (int i = 0; i < cs.getLength(); i++) {
+            Node c = cs.item(i);
+            if (c.getNodeType() != Node.ELEMENT_NODE) {
+                continue;
+            String ctype = c.getNodeName();
+            if (v == Version.V1 && ctype.equals("gridftp")) {
+                bc.addService(gridftp(c));
+            else if (v == Version.V1 && ctype.equals("jobmanager")) {
+                bc.addService(jobmanager(c));
+            else if (ctype.equals("execution")) {
+                bc.addService(execution(c));
+            else if (ctype.equals("filesystem")) {
+                bc.addService(filesystem(c));
+            else if (ctype.equals("workdirectory")) {
+                bc.setProperty("workdir", text(c));
+            else if (ctype.equals("scratch")) {
+                bc.setProperty("scratch", text(c));
+            else if (ctype.equals("env")) {
+                env(bc, c);
+            else if (ctype.equals("profile")) {
+                profile(bc, c);
+            else {
+                throw new IllegalArgumentException("Unknown node type: " + ctype);
+        return bc;
+    private Service jobmanager(Node n) throws InvalidProviderException, ProviderMethodException {
+        String provider;
+        String url = attr(n, "url");
+        String major = attr(n, "major");
+        if (url.equals("local://localhost")) {
+            provider = "local";
+        else if (url.equals("pbs://localhost")) {
+            provider = "pbs";
+        else if ("2".equals(major)) {
+            provider = "gt2";
+        else if ("4".equals(major)) {
+            provider = "gt4";
+        else {
+            throw new IllegalArgumentException("Unknown job manager version: " + major + ", url = '" + url + "'");
+        ServiceContact contact = new ServiceContactImpl(url);
+            return new ServiceImpl(provider, Service.EXECUTION,
+                contact, AbstractionFactory.newSecurityContext(provider, contact));
+    private Service gridftp(Node n) throws InvalidProviderException, ProviderMethodException {
+            return new ServiceImpl("local", Service.FILE_OPERATION, new ServiceContactImpl("localhost"), null);
+        else {
+            return new ServiceImpl("gsiftp", Service.FILE_OPERATION,
+                contact, AbstractionFactory.newSecurityContext("gsiftp", contact));
+    private Service execution(Node n) throws InvalidProviderException, ProviderMethodException {
+        String provider = attr(n, "provider");
+        String url = attr(n, "url", null);
+        String jobManager = attr(n, "jobManager", null);
+        if (jobManager == null) {
+            jobManager = attr(n, "jobmanager", null);
+        ExecutionService s = new ExecutionServiceImpl();
+        s.setProvider(provider);
+        ServiceContact contact = null;
+        if (url != null) {
+            contact = new ServiceContactImpl(url);
+            s.setServiceContact(contact);
+            s.setSecurityContext(AbstractionFactory.newSecurityContext(provider, contact));
+        if (jobManager != null) {
+            s.setJobManager(jobManager);
+        return s;
+    private Service filesystem(Node n) throws InvalidProviderException, ProviderMethodException {
+        Service s = new ServiceImpl();
+        s.setType(Service.FILE_OPERATION);
+        return s;
+    private void env(BoundContact bc, Node n) {
+        String key = attr(n, "key");
+        String value = text(n);
+        bc.setProperty("env:" + key, value);
+    private void profile(BoundContact bc, Node n) {
+        String ns = attr(n, "namespace");
+        if (value == null) {
+            throw new IllegalArgumentException("No value for profile " + ns + ":" + key);
+        if (ns.equals("karajan")) {
+            bc.setProperty(key, value);
+        else {
+            bc.setProperty(ns + ":" + key, value);
+    private String text(Node n) {
+        if (n.getFirstChild() != null) {
+            return n.getFirstChild().getNodeValue();
+        else {
+            return null;
+    private String attr(Node n, String name) {
+        NamedNodeMap attrs = n.getAttributes();
+        if (attrs != null) {
+            Node attr = attrs.getNamedItem(name);
+            if (attr == null) {
+                throw new IllegalArgumentException("Missing " + name);
+            else {
+                return attr.getNodeValue();
+        else {
+    private String attr(Node n, String name, String defVal) {
+                return defVal;
+            else {
+        else {
+            return defVal;
+    public static void main(String[] args) {
+        ArgumentParser ap = new ArgumentParser();
+        ap.setExecutableName("swift-convert-config");
+        ap.addFlag("help", "Displays usage information");
+        ap.addOption("sites.file", "Specifies a sites file to convert",
+            "file", ArgumentParser.OPTIONAL);
+        ap.addOption("tc.file", "Specifies a tc.data file to convert",
+        ap.addOption("config", "Specifies an old Swift configuration file to convert",
+        ap.addOption("out", "Indicates that the output should go to a file instead of standard output",
+        try {
+            ap.parse(args);
+        catch (ArgumentParserException e) {
+            System.out.println("Error parsing command line arguments: " + e.getMessage());
+            usage(ap);
+            System.exit(1);
+        if (ap.isPresent("help")) {
+            usage(ap);
+            System.exit(0);
+        ConvertConfig cc = new ConvertConfig();
+        try {
+            PrintStream ps = System.out;
+            if (ap.isPresent("out")) {
+                ps = new PrintStream(new FileOutputStream(ap.getStringValue("out")));
+            cc.run(ap.getStringValue("sites.file", null),
+                ap.getStringValue("tc.file", null), ap.getStringValue("config", null), System.out);
+            System.exit(0);
+            System.out.println("Failed to convert configuration: " + e.getMessage());
+            e.printStackTrace();
+            System.exit(2);
+    private static void usage(ArgumentParser ap) {
+            "Converts an existing set of sites.xml, tc.data, and swift.properties \n" +
+            "files (at least one of which needs to be specified) to a unified Swift\n" +
+            "configuration file.\n");
+        ap.usage();
Added: trunk/src/org/griphyn/vdl/util/SwiftConfig.java
--- trunk/src/org/griphyn/vdl/util/SwiftConfig.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/util/SwiftConfig.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -0,0 +1,632 @@
+ * Created on Jul 5, 2014
+import java.io.File;
+import java.util.ArrayList;
+import java.util.Collection;
+import java.util.HashMap;
+import java.util.SortedSet;
+import java.util.TreeSet;
+import org.apache.log4j.Logger;
+import org.globus.swift.catalog.site.Application;
+import org.globus.swift.catalog.site.SwiftContact;
+import org.globus.swift.catalog.site.SwiftContactSet;
+import org.griphyn.vdl.util.ConfigTree.Node;
+import com.typesafe.config.Config;
+import com.typesafe.config.ConfigFactory;
+import com.typesafe.config.ConfigIncludeContext;
+import com.typesafe.config.ConfigIncluder;
+import com.typesafe.config.ConfigObject;
+import com.typesafe.config.ConfigParseOptions;
+import com.typesafe.config.ConfigSyntax;
+import com.typesafe.config.ConfigValue;
+import com.typesafe.config.ConfigValueType;
+public class SwiftConfig implements Cloneable {
+    public static final Logger logger = Logger.getLogger(SwiftConfig.class);
+    public static final boolean CHECK_DYNAMIC_NAMES = true;
+    public static final List<String> DEFAULT_LOCATIONS;
+    public enum Key {
+        DM_CHECKER("mappingCheckerEnabled"),
+        PROVENANCE_LOG("logProvenance"),
+        FILE_GC_ENABLED("fileGCEnabled"),
+        TICKER_ENABLED("tickerEnabled"),
+        TICKER_DATE_FORMAT("tickerDateFormat"),
+        TICKER_PREFIX("tickerPrefix"),
+        TRACING_ENABLED("tracingEnabled"),
+        FOREACH_MAX_THREADS("maxForeachThreads"),
+        CACHING_ALGORITHM("cachingAlgorithm"),
+        REPLICATION_ENABLED("replicationEnabled"),
+        WRAPPER_STAGING_LOCAL_SERVER("wrapperStagingLocalServer"),
+        REPLICATION_MIN_QUEUE_TIME("replicationMinQueueTime"),
+        REPLICATION_LIMIT("replicationLimit"),
+        WRAPPER_INVOCATION_MODE("wrapperInvocationMode");
+        public String propName;
+        private Key(String propName) {
+            this.propName = propName;
+    public static SwiftConfigSchema SCHEMA;
+    static {
+        SCHEMA = new SwiftConfigSchema();
+        DEFAULT_LOCATIONS = new ArrayList<String>();
+        if (System.getenv("SWIFT_SITE_CONF") != null) {
+            DEFAULT_LOCATIONS.add(System.getenv("SWIFT_SITE_CONF"));
+        String swiftHome = System.getProperty("swift.home");
+        if (swiftHome == null) {
+            swiftHome = System.getenv("SWIFT_HOME");
+                throw new IllegalStateException("SWIFT_HOME is not set");
+        DEFAULT_LOCATIONS.add(swiftHome + File.separator +
+            "etc" + File.separator + "swift.conf");
+        // check keys against schema
+        for (Key k : Key.values()) {
+            if (!SCHEMA.isNameValid(k.propName)) {
+                throw new IllegalArgumentException("Invalid property name for config key '" + k + "': " + k.propName);
+    private static class KVPair {
+        public final String key;
+        public final String value;
+        public KVPair(String key, String value) {
+            this.key = key;
+            this.value = value;
+    private static class IncluderWrapper implements ConfigIncluder {
+        private final ConfigIncluder d;
+        public IncluderWrapper(ConfigIncluder d) {
+            this.d = d;
+        @Override
+        public ConfigIncluder withFallback(ConfigIncluder fallback) {
+            return this;
+        @Override
+        public ConfigObject include(ConfigIncludeContext context, String what) {
+            int b = what.indexOf("${");
+            while (b != -1) {
+                int e = what.indexOf("}", b);
+                String var = what.substring(b + 2, e);
+                what = what.substring(0, b) + resolve(var) + what.substring(e + 1);
+                b = what.indexOf("${");
+            return ConfigFactory.parseFile(new File(what)).root();
+        private String resolve(String var) {
+            String v = null;
+            if (var.startsWith("env.")) {
+                v = System.getenv(var.substring(4));
+            else {
+                v = System.getProperty(var);
+            if (v == null) {
+                throw new IllegalArgumentException("No such system property or environment variable: '" + var + "'");
+            return v;
+    public static SwiftConfig load(String fileName) {
+        return load(fileName, null);
+    public static SwiftConfig load(String fileName, Map<String, Object> override) {
+        logger.info("Loading swift configuration file: " + fileName);
+        ConfigParseOptions opt = ConfigParseOptions.defaults();
+        opt = opt.setIncluder(new IncluderWrapper(opt.getIncluder())).
+            setSyntax(ConfigSyntax.CONF).setAllowMissing(false);
+        Config conf = ConfigFactory.parseFile(new File(fileName), opt);
+        Config oconf = ConfigFactory.parseMap(override, "<command line>");
+        conf = oconf.withFallback(conf);
+        conf = conf.resolveWith(getSubstitutions());
+        ConfigTree<Object> out = SCHEMA.validate(conf);
+        SwiftConfig sc = new SwiftConfig();
+        sc.setFileName(fileName);
+        sc.build(out);
+        return sc;
+    private static Config getSubstitutions() {
+        Map<String, Object> m = new HashMap<String, Object>();
+        for (Map.Entry<String, String> e : System.getenv().entrySet()) {
+            m.put("env." + e.getKey(), e.getValue());
+        return ConfigFactory.parseMap(m).withFallback(ConfigFactory.parseProperties(System.getProperties()));
+    public static SwiftConfig load() {
+        for (String loc : DEFAULT_LOCATIONS) {
+            if (new File(loc).exists()) {
+                return load(loc);
+        throw new IllegalStateException("Could not find swift configuration file");
+    private static SwiftConfig _default;
+    public synchronized static SwiftConfig getDefault() {
+        if (_default == null) {
+            _default = load();
+        return _default;
+    public synchronized static void setDefault(SwiftConfig conf) {
+        _default = conf;
+    private SwiftContactSet definedSites;
+    private SwiftContactSet sites;
+    private ConfigTree<Object> tree;
+    private Map<String, Object> flat;
+    private String fileName;
+    public SwiftConfig() {
+        definedSites = new SwiftContactSet();
+        sites = new SwiftContactSet();
+        flat = new HashMap<String, Object>();
+    public SwiftContactSet getSites() {
+        return sites;
+    public SwiftContactSet getDefinedSites() {
+        return definedSites;
+    public Collection<String> getDefinedSiteNames() {
+        Set<String> s = new TreeSet<String>();
+        for (BoundContact bc : definedSites.getContacts()) {
+            s.add(bc.getName());
+        return s;
+    public void setProperty(String key, Object value) {
+        flat.put(key, value);
+    public String getFileName() {
+        return fileName;
+    public void setFileName(String fileName) {
+        this.fileName = fileName;
+    private void build(ConfigTree<Object> tree) {
+        this.tree = tree;
+        List<String> sites = null;
+        for (Map.Entry<String, ConfigTree.Node<Object>> e : tree.entrySet()) {
+            if (e.getKey().equals("site")) {
+                for (Map.Entry<String, ConfigTree.Node<Object>> f : e.getValue().entrySet()) {
+                    site(definedSites, f.getKey(), f.getValue());
+            else if (e.getKey().equals("sites")) {
+                sites = (List<String>) getObject(e.getValue());
+            else if (e.getKey().equals("app")) {
+                SwiftContact dummy = new SwiftContact();
+                apps(dummy, e.getValue());
+                for (Application app : dummy.getApplications()) {
+                    definedSites.addApplication(app);
+        if (sites == null || sites.isEmpty()) {
+            throw new RuntimeException("No sites enabled");
+        for (String siteName : sites) {
+            this.sites.addContact((SwiftContact) definedSites.getContact(siteName));
+        this.sites.getApplications().putAll(definedSites.getApplications());
+        for (String leaf : tree.getLeafPaths()) {
+            flat.put(leaf, tree.get(leaf));
+    private void apps(SwiftContact sc, ConfigTree.Node<Object> n) {
+         * app."*" {
+        for (Map.Entry<String, ConfigTree.Node<Object>> e : n.entrySet()) {
+            String k = e.getKey();
+            ConfigTree.Node<Object> c = e.getValue();
+            if (e.getKey().equals("ALL")) {
+                sc.addApplication(app("*", e.getValue()));
+            else {
+                sc.addApplication(app(removeQuotes(e.getKey()), e.getValue()));
+        Application all = sc.getApplication("*");
+        if (all != null) {
+            mergeEnvsToApps(sc, all.getEnv());
+            mergePropsToApps(sc, all.getProperties());
+    private String removeQuotes(String key) {
+        if (key.startsWith("\"") && key.endsWith("\"")) {
+            return key.substring(1, key.length() - 2);
+        else {
+            return key;
+    private void mergeEnvsToApps(SwiftContact bc, Map<String, String> envs) {
+        for (Application app : bc.getApplications()) {
+            for (Map.Entry<String, String> e : envs.entrySet()) {
+                if (!app.getEnv().containsKey(e.getKey())) {
+                    // only merge if app does not override
+                    app.setEnv(e.getKey(), e.getValue());
+    private void mergePropsToApps(SwiftContact bc, Map<String, Object> props) {
+            for (Map.Entry<String, Object> e : props.entrySet()) {
+                if (!app.getProperties().containsKey(e.getKey())) {
+                    app.addProperty(e.getKey(), e.getValue());
+    private Application app(String name, ConfigTree.Node<Object> n) {
+         * app."*" {
+         *  executable: "?String"
+         *  options: "?Object"
+         *  jobType: "?String", queue: "?String", project: "?String"
+         *  maxWallTime: "?Time"
+         *  env."*": "String"
+        Application app = new Application();
+        app.setName(name);
+            if (k.equals("executable")) {
+                app.setExecutable(getString(c));
+            else if (k.equals("options")) {
+                Map<String, Object> opt = (Map<String, Object>) getObject(c, "options");
+                for (Map.Entry<String, Object> f : opt.entrySet()) {
+                    app.addProperty(f.getKey(), f.getValue());
+            else if (k.equals("jobQueue")) {
+                app.addProperty("queue", getString(c));
+            else if (k.equals("jobProject")) {
+                app.addProperty("project", getString(c));
+            else if (k.equals("env")) {
+                List<KVPair> envs = envs(c);
+                for (KVPair env : envs) {
+                    app.setEnv(env.key, env.value);
+            else {
+                app.addProperty(k, getString(c));
+        return app;
+    private List<KVPair> envs(Node<Object> n) {
+        List<KVPair> l = new ArrayList<KVPair>();
+            l.add(new KVPair(e.getKey(), getString(e.getValue())));
+        return l;
+    private void site(SwiftContactSet sites, String name, ConfigTree.Node<Object> n) {
+        try {
+            SwiftContact sc = new SwiftContact(name);
+            if (n.hasKey("OS")) {
+                sc.setProperty("sysinfo", getString(n, "OS"));
+                String ctype = e.getKey();
+                if (ctype.equals("execution")) {
+                    sc.addService(execution(c));
+                    sc.addService(filesystem(c));
+                else if (ctype.equals("workDirectory")) {
+                    sc.setProperty("workdir", getString(c));
+                    sc.setProperty("scratch", getString(c));
+                else if (ctype.equals("app")) {
+                    apps(sc, c);
+                else if (ctype.equals("options")) {
+                        sc.setProperty(f.getKey(), f.getValue());
+                else {
+                    sc.setProperty(ctype, getObject(c));
+            sites.addContact(sc);
+            throw new RuntimeException("Invalid site entry '" + name + "': ", e);
+    private Service filesystem(Node<Object> c) throws InvalidProviderException, ProviderMethodException {
+        service(c, s);
+        return s;
+    private Service execution(ConfigTree.Node<Object> n) throws InvalidProviderException, ProviderMethodException {
+        service(n, s);
+        return s;
+    private void service(Node<Object> n, Service s) throws InvalidProviderException, ProviderMethodException {
+        String provider = null;
+        String url = null;
+            if (k.equals("type")) {
+                provider = getString(c);
+            else if (k.equals("URL")) {
+                url = getString(c);
+            else if (k.equals("jobManager")) {
+                ((ExecutionService) s).setJobManager(getString(c));
+                s.setAttribute("project", getObject(c));
+            else if (k.equals("maxJobs")) {
+                s.setAttribute("slots", getObject(c));
+            else if (k.equals("maxJobTime")) {
+                s.setAttribute("maxTime", getObject(c));
+            else if (k.equals("maxNodesPerJob")) {
+                s.setAttribute("maxNodes", getObject(c));
+                s.setAttribute("queue", getObject(c));
+            else {
+                s.setAttribute(k, getObject(c));
+    private String getString(Node<Object> c) {
+        return (String) c.get();
+    private Object getObject(ConfigTree.Node<Object> c) {
+        return c.get();
+    private String getString(ConfigTree.Node<Object> c, String key) {
+        return (String) c.get(key);
+    private Object getObject(ConfigTree.Node<Object> c, String key) {
+        return c.get(key);
+    private void checkType(String name, ConfigValue value, ConfigValueType type) {
+        if (!type.equals(value.valueType())) {
+            throw new SwiftConfigException(value.origin(),
+                "'" + name + "': wrong type (" + value.valueType() + "). Must be a " + type);
+    public Object clone() {
+        return this;
+        SortedSet<String> s = new TreeSet<String>(flat.keySet());
+        for (String k : s) {
+            sb.append(k);
+            sb.append(": ");
+            Object o = flat.get(k);
+            if (o instanceof String) {
+                sb.append('"');
+                sb.append(o);
+                sb.append('"');
+            else {
+                sb.append(o);
+            sb.append('\n');
+    private void check(String name) {
+        if (CHECK_DYNAMIC_NAMES) {
+            if (!SCHEMA.isNameValid(name)) {
+                throw new IllegalArgumentException("Unknown property name: '" + name + "'");
+    private Object get(Key k) {
+        return flat.get(k.propName);
+    public Object getProperty(String name) {
+        check(name);
+        return flat.get(name);
+    public String getStringProperty(String name) {
+        check(name);
+        return (String) flat.get(name);
+    public boolean isFileGCEnabled() {
+        return (Boolean) get(Key.FILE_GC_ENABLED);
+    public boolean isTickerEnabled() {
+        return (Boolean) get(Key.TICKER_ENABLED);
+    public String getTickerDateFormat() {
+        return (String) get(Key.TICKER_DATE_FORMAT);
+    public String getTickerPrefix() {
+        return (String) get(Key.TICKER_PREFIX);
+    public boolean isTracingEnabled() {
+        return (Boolean) get(Key.TRACING_ENABLED);
+    public Object getProperty(String name, Object defVal) {
+        check(name);
+        Object v = flat.get(name);
+        if (v == null) {
+            return defVal;
+        else {
+            return v;
+    public int getForeachMaxThreads() {
+        return (Integer) get(Key.FOREACH_MAX_THREADS);
+    public String getCachingAlgorithm() {
+        return (String) get(Key.CACHING_ALGORITHM);
+    public boolean isReplicationEnabled() {
+        return (Boolean) get(Key.REPLICATION_ENABLED);
+    public String getWrapperStagingLocalServer() {
+        return (String) get(Key.WRAPPER_STAGING_LOCAL_SERVER);
+    public boolean isProvenanceEnabled() {
+        return (Boolean) get(Key.PROVENANCE_LOG);
+    public int getReplicationMinQueueTime() {
+        return (Integer) get(Key.REPLICATION_MIN_QUEUE_TIME);
+    public int getReplicationLimit() {
+        return (Integer) get(Key.REPLICATION_LIMIT);
+    public String getWrapperInvocationMode() {
+        return (String) get(Key.WRAPPER_INVOCATION_MODE);
+    public boolean isMappingCheckerEnabled() {
+        return (Boolean) get(Key.DM_CHECKER);
Added: trunk/src/org/griphyn/vdl/util/SwiftConfigException.java
--- trunk/src/org/griphyn/vdl/util/SwiftConfigException.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/util/SwiftConfigException.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -0,0 +1,20 @@
+import com.typesafe.config.ConfigOrigin;
+public class SwiftConfigException extends RuntimeException {
+    private ConfigOrigin loc;
+    public SwiftConfigException(ConfigOrigin loc, String message) {
+        super((loc.filename() == null ? loc.description() : loc.filename() + ":" + loc.lineNumber()) + " " + message);
Added: trunk/src/org/griphyn/vdl/util/SwiftConfigInfo.java
--- trunk/src/org/griphyn/vdl/util/SwiftConfigInfo.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/util/SwiftConfigInfo.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -0,0 +1,71 @@
+ * Created on Jul 8, 2014
+import org.globus.cog.util.StringUtil;
+public class SwiftConfigInfo {
+        ap.setExecutableName("swift-config-info");
+        ap.addFlag("help", "Prints usage information");
+        ap.addFlag("list", "Lists all available configuration properties");
+        ap.addOption(ArgumentParser.DEFAULT, "A property to print information about",
+            "property", ArgumentParser.OPTIONAL);
+        try {
+            ap.parse(args);
+                ap.usage();
+                System.exit(0);
+            if (ap.isPresent("list")) {
+                list();
+            if (ap.hasValue(ArgumentParser.DEFAULT)) {
+                info(ap.getStringValue(ArgumentParser.DEFAULT));
+            System.exit(0);
+            System.out.println("Error parsing command line: " + e.getMessage());
+            ap.usage();
+            System.exit(1);
+    private static void info(String prop) {
+        SwiftConfigSchema.Info info = SwiftConfig.SCHEMA.getPropertyDescriptions().get(prop);
+        if (info != null) {
+            if (info.doc == null) {
+                System.out.println(prop + ": no description available");
+            else {
+                System.out.println(prop + ":");
+                System.out.println(StringUtil.wordWrap(info.doc, 6, 65));
+        else {
+            System.out.println(prop + ": unknown property");
+    private static void list() {
+        Collection<String> names = SwiftConfig.SCHEMA.listProperties();
+        SortedSet<String> snames = new TreeSet<String>(names);
+        for (String name : snames) {
+            System.out.println(name.replace("\"*\"", "*"));
Added: trunk/src/org/griphyn/vdl/util/SwiftConfigSchema.java
--- trunk/src/org/griphyn/vdl/util/SwiftConfigSchema.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/util/SwiftConfigSchema.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -0,0 +1,288 @@
+public class SwiftConfigSchema {
+    private static final String STAR = "\"*\"";
+    public static class Info {
+        public ConfigPropertyType<?> type;
+        public Object value;
+        public boolean optional;
+        public String doc;
+        public ConfigOrigin loc;
+    private Config schema;
+    private ConfigTree<Info> info;
+    private Map<String, Info> descriptions;
+    private Set<String> validNames;
+    public SwiftConfigSchema() {
+        validNames = new HashSet<String>();
+        schema = ConfigFactory.parseResources("swift.conf.schema");
+        schema = schema.resolve();
+        if (schema.isEmpty()) {
+            throw new RuntimeException("Could not find swift.conf.schema");
+        info = new ConfigTree<Info>();
+        for (Map.Entry<String, ConfigValue> e : schema.entrySet()) {
+            String type = null;
+            Object defaultValue = null;
+            String doc = null;
+            ConfigOrigin loc = null;
+            if (k.endsWith(".\"_type\"")) {
+                type = schema.getString(k);
+                k = k.substring(0, k.lastIndexOf('.'));
+                loc = e.getValue().origin();
+            else if (k.indexOf(".\"_") == -1){
+            else if (k.endsWith(".\"_default\"")){
+                defaultValue = e.getValue().unwrapped();
+            else if (k.endsWith(".\"_doc\"")){
+                doc = stripDoc((String) e.getValue().unwrapped());
+            else if (k.indexOf(".\"_") != -1) {
+                continue;
+            Info i = info.get(k);
+            if (i == null) {
+                i = new Info();
+                info.put(k, i);
+                validNames.add(k);
+            if (type != null) {
+                if (type.startsWith("?")) {
+                    i.optional = true;
+                    type = type.substring(1);
+                i.type = getTypeInstance(type, e.getValue());
+            if (defaultValue != null) {
+                i.value = defaultValue;
+            if (doc != null) {
+                i.doc = doc;
+            if (loc != null) {
+                i.loc = loc;
+    private String stripDoc(String doc) {
+        return doc.replaceAll("[\\t\\n]+", "");
+    private ConfigPropertyType<?> getTypeInstance(String type, ConfigValue value) {
+        if (type.equals("String")) {
+            return ConfigPropertyType.STRING;
+        else if (type.equals("Boolean")) {
+            return ConfigPropertyType.BOOLEAN;
+        else if (type.equals("Int")) {
+            return ConfigPropertyType.INT;
+        else if (type.equals("Float")) {
+            return ConfigPropertyType.FLOAT;
+        else if (type.equals("StrictlyPositiveInt")) {
+            return ConfigPropertyType.STRICTLY_POSITIVE_INT;
+        else if (type.equals("Throttle")) {
+            return ConfigPropertyType.THROTTLE;
+        else if (type.equals("PortRange")) {
+            return ConfigPropertyType.PORT_RANGE;
+        else if (type.equals("PositiveInt")) {
+            return ConfigPropertyType.POSITIVE_INT;
+        else if (type.equals("PositiveFloat")) {
+            return ConfigPropertyType.POSITIVE_FLOAT;
+        else if (type.equals("Time")) {
+            return ConfigPropertyType.TIME;
+        else if (type.equals("Seconds")) {
+        else if (type.equals("OS")) {
+            return ConfigPropertyType.OS;
+        else if (type.equals("StringList")) {
+            return ConfigPropertyType.STRING_LIST;
+        else if (type.equals("Object")) {
+            return ConfigPropertyType.OBJECT;
+        else if (type.startsWith("Choice[")) {
+            String values = type.substring("Choice[".length(), type.length() - 1);
+            return new ConfigPropertyType.Choices(values.split(",\\s*"));
+        else if (type.startsWith("Interval[")) {
+            String values = type.substring("Interval[".length(), type.length() - 1);
+            String[] s = values.split(",\\s*", 2);
+            return new ConfigPropertyType.Interval(Double.parseDouble(s[0]), Double.parseDouble(s[1]));
+        else {
+            throw new IllegalArgumentException(loc(value.origin()) + ": unknown property type: '" + type + "'");
+    private String loc(ConfigOrigin o) {
+        return o.filename() + ":" + o.lineNumber();
+    public ConfigTree<Object> validate(Config conf) {
+        ConfigTree<Object> validated = new ConfigTree<Object>();
+        // build a tree of the actual config so we can easily check them for missing properties
+        ConfigTree<Boolean> confTree = new ConfigTree<Boolean>();
+        // check things in config against schema
+        for (Map.Entry<String, ConfigValue> e : conf.entrySet()) {
+            confTree.put(k, Boolean.TRUE);
+            // check if the properties are defined in the schema
+            Info i = info.get(k, STAR);
+            if (i == null) {
+                i = info.get(k, STAR);
+                throw new SwiftConfigException(e.getValue().origin(), "unexpected property '" + k + "'");
+            // now check values
+            if (i.type == null) {
+                throw new IllegalStateException("Missing type for key " + k);
+            Object value = checkValue(k, e.getValue(), i.type);
+            validated.put(k, value);
+        // check for missing things
+        for (String key : info.getLeafPaths()) {
+            Info i = info.get(key);
+            String notFound = findMissing(key, confTree, i, validated);
+            if (notFound != null) {
+                findMissing(key, confTree, i, validated);
+                ConfigOrigin loc = info.get(key).loc;
+                throw new SwiftConfigException(conf.origin(), "missing property '" + notFound +
+                    "' defined in " + loc.filename() + ":" + loc.lineNumber());
+        return validated;
+    private String findMissing(String key, ConfigTree<Boolean> confTree, Info i, ConfigTree<Object> validated) {
+        List<String> found = confTree.expandWildcards(key, STAR);
+        for (String f : found) {
+            if (!confTree.hasKey(f)) {
+                if (i.optional) {
+                    if (i.value != null) {
+                        validated.put(f, i.value);
+                else {
+                    return f;
+        return null;
+    private void setValue(Map<String, Object> validated, Config conf, String k) {
+        if (!conf.hasPath(k)) {
+            String defKey = k + ".\"_default\"";
+            if (schema.hasPath(defKey)) {
+                validated.put(k, schema.getValue(defKey).unwrapped());
+        else {
+            validated.put(k, conf.getValue(k).unwrapped());
+    private Object checkValue(String k, ConfigValue value, ConfigPropertyType<?> t) {
+        Object v = value.unwrapped();
+        switch (value.valueType()) {
+            case STRING:
+                if (t.getBaseType() != ConfigPropertyType.STRING && t.getBaseType() != ConfigPropertyType.OBJECT) {
+                    throw invalidValue(value, k, v, t.getBaseType());
+                return t.check(k, value.unwrapped(), null);
+            case NUMBER:
+                if (t.getBaseType() != ConfigPropertyType.INT && t.getBaseType() != ConfigPropertyType.FLOAT) {
+                if (t.getBaseType() == ConfigPropertyType.INT) {
+                    Number n = (Number) value.unwrapped();
+                    if (n.intValue() != n.doubleValue()) {
+                return t.check(k, v, null);
+            case BOOLEAN:
+                if (t.getBaseType() != ConfigPropertyType.BOOLEAN) {
+                return value.unwrapped();
+            default:
+    private SwiftConfigException invalidValue(ConfigValue value, String k, Object v, ConfigPropertyType<?> t) {
+        return new SwiftConfigException(value.origin(), "invalid value '" + v + "' for property '" + k + "'. Expected a " + t);
+    public synchronized Map<String, Info> getPropertyDescriptions() {
+        if (descriptions == null) {
+            descriptions = new HashMap<String, Info>();
+            for (String s : info.getLeafPaths()) {
+                Info i = info.get(s);
+                if (i != null && i.doc != null) {
+                    descriptions.put(s, i);
+        return descriptions;
+    public boolean propertyExists(String name) {
+        return info.get(name) != null;
+    public boolean isNameValid(String name) {
+        return validNames.contains(name);
+    public Collection<String> listProperties() {
+        return validNames;
Deleted: trunk/src/org/griphyn/vdl/util/TriStateBoolean.java
--- trunk/src/org/griphyn/vdl/util/TriStateBoolean.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/griphyn/vdl/util/TriStateBoolean.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -1,66 +0,0 @@
- * Copyright 2012 University of Chicago
- * Licensed under the Apache License, Version 2.0 (the "License");
- * you may not use this file except in compliance with the License.
- * You may obtain a copy of the License at
- * http://www.apache.org/licenses/LICENSE-2.0
- * Unless required by applicable law or agreed to in writing, software
- * distributed under the License is distributed on an "AS IS" BASIS,
- * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
- * See the License for the specific language governing permissions and
- * limitations under the License.
- * Created on Feb 7, 2007
-package org.griphyn.vdl.util;
-public final class TriStateBoolean {
-    public static final TriStateBoolean FALSE = new TriStateBoolean(0);
-    public static final TriStateBoolean TRUE = new TriStateBoolean(1);
-    public static final TriStateBoolean MAYBE = new TriStateBoolean(2);
-    private int value;
-    private TriStateBoolean(int value) {
-        this.value = value;
-    public boolean equals(Object obj) {
-        if (obj instanceof TriStateBoolean) {
-            return value == ((TriStateBoolean) obj).value;
-        else {
-            return false;
-    public int hashCode() {
-        return value;
-    public String toString() {
-        switch(value) {
-            case 0: return "false";
-            case 1: return "true";
-            default: return "maybe";
-    public static TriStateBoolean valueOf(String value) {
-        if ("false".equalsIgnoreCase(value) || "no".equalsIgnoreCase(value)) {
-            return FALSE;
-        else if ("true".equalsIgnoreCase(value) || "yes".equalsIgnoreCase(value)) {
-            return TRUE;
-        else {
-            return MAYBE;
Deleted: trunk/src/org/griphyn/vdl/util/VDL2Config.java
--- trunk/src/org/griphyn/vdl/util/VDL2Config.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/griphyn/vdl/util/VDL2Config.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -1,316 +0,0 @@
- * Created on Dec 5, 2006
-import java.io.File;
-import java.io.FileInputStream;
-import java.io.FileNotFoundException;
-import java.io.IOException;
-import java.util.HashMap;
-import java.util.LinkedList;
-import java.util.List;
-import java.util.Map;
-import java.util.Properties;
-import org.apache.log4j.Logger;
-import org.globus.cog.karajan.util.BoundContact;
-import org.globus.common.CoGProperties;
-public class VDL2Config extends Properties {
-    private static final long serialVersionUID = 1L;
-    public static final Logger logger = Logger.getLogger(VDL2Config.class);
-	public static final String CONFIG_FILE_NAME = "swift.properties";
-	public static final String[] CONFIG_FILE_SEARCH_PATH = new String[] {
-			System.getProperty("swift.home") + File.separator + "etc" + File.separator
-					+ CONFIG_FILE_NAME,
-			System.getProperty("user.home") + File.separator + ".swift" + File.separator
-			System.getProperty("vds.home") + File.separator + "etc" + File.separator
-					+ CONFIG_FILE_NAME };
-	private static VDL2Config config;
-	public static VDL2Config getConfig() throws IOException {
-		if(config == null) {
-			config = getDefaultConfig();
-		return config.check();
-	public static synchronized VDL2Config getDefaultConfig() throws IOException {
-		if (config == null) {
-			config = new VDL2Config();
-			for (int i = 0; i < CONFIG_FILE_SEARCH_PATH.length; i++) {
-				config.load(CONFIG_FILE_SEARCH_PATH[i]);
-		return config;
-	public static VDL2Config getConfig(String file) throws IOException {
-		VDL2Config c;
-		try {
-			VDL2Config d = getConfig();
-			c = new VDL2Config(d);
-		catch (Exception e) {
-			c = new VDL2Config();
-		c.load(file);
-		config = c;
-		config.check();
-		return config;
-	private List<String> files, tried;
-	private Map<Object, ConfigPropertyType> types;
-	private Map<Object, String> propertySource;
-	private String currentFile;
-	private VDL2Config() {
-		files = new LinkedList<String>();
-		tried = new LinkedList<String>();
-		propertySource = new HashMap<Object, String>();
-		types = new HashMap<Object, ConfigPropertyType>();
-		put(VDL2ConfigProperties.POOL_FILE, "${swift.home}/etc/sites.xml", ConfigPropertyType.FILE);
-		put(VDL2ConfigProperties.TC_FILE, "${swift.home}/etc/tc.data", ConfigPropertyType.FILE);
-		put(VDL2ConfigProperties.LAZY_ERRORS, "false", ConfigPropertyType.BOOLEAN);
-		put(VDL2ConfigProperties.CACHING_ALGORITHM, "LRU", ConfigPropertyType.STRING);
-		put(VDL2ConfigProperties.CLUSTERING_ENABLED, "false", ConfigPropertyType.BOOLEAN);
-		put(VDL2ConfigProperties.CLUSTERING_QUEUE_DELAY, "4", ConfigPropertyType.INT);
-		put(VDL2ConfigProperties.CLUSTERING_MIN_TIME, "60", ConfigPropertyType.INT);
-		put("throttle.submit", "4", ConfigPropertyType.INT);
-		put("throttle.host.submit", "2", ConfigPropertyType.INT);
-		put("throttle.transfers", "4", ConfigPropertyType.INT);
-		put("throttle.file.operations", "8", ConfigPropertyType.INT);
-		put("throttle.score.job.factor", "4", ConfigPropertyType.FLOAT);
-		put(VDL2ConfigProperties.SITEDIR_KEEP, "false", ConfigPropertyType.BOOLEAN);
-		put(VDL2ConfigProperties.PROVENANCE_LOG, "false", ConfigPropertyType.BOOLEAN);
-		put("execution.retries", "0", ConfigPropertyType.INT);
-		put("replication.enabled", "false", ConfigPropertyType.BOOLEAN);
-		put("replication.min.queue.time", "60", ConfigPropertyType.INT);
-		put("replication.limit", "3", ConfigPropertyType.INT);
-		put("status.mode", "files", ConfigPropertyType.choices("files", "provider"));
-		put("wrapper.parameter.mode", "args", ConfigPropertyType.choices("args", "files"));
-		put("wrapper.invocation.mode", "absolute", ConfigPropertyType.choices("absolute", "relative"));
-		// TODO what are the valid values here?
-		put("cdm.broadcast.mode", "file");
-		put("use.provider.staging", "false", ConfigPropertyType.BOOLEAN);
-		put("use.wrapper.staging", "false", ConfigPropertyType.BOOLEAN);
-		put("ticker.date.format", "", ConfigPropertyType.STRING);
-		put("ticker.prefix", "Progress: ", ConfigPropertyType.STRING);
-		put(VDL2ConfigProperties.FILE_GC_ENABLED, "true", ConfigPropertyType.BOOLEAN);
-		put(VDL2ConfigProperties.DM_CHECKER, "on", ConfigPropertyType.ONOFF);
-	private VDL2Config(VDL2Config other) {
-		this.putAll(other);
-		this.files.addAll(other.files);
-		this.propertySource.putAll(other.propertySource);
-	protected void load(String file) throws IOException {
-	    this.currentFile = file;
-		tried.add(file);
-		File f = new File(file);
-		if (f.exists()) {
-			files.add(file);
-			super.load(new FileInputStream(f));
-		String hostname = getHostName();
-		if (hostname != null) {
-		    CoGProperties.getDefault().setHostName(hostname);
-		String ip = getIP();
-		if (ip != null) {
-			CoGProperties.getDefault().setIPAddress(ip);
-		String tcpPortRange = getTCPPortRange();
-		if (tcpPortRange != null) {
-			CoGProperties.getDefault().put("tcp.port.range", tcpPortRange);
-	public void validateProperties() {
-	    for (Map.Entry<Object, Object> e : this.entrySet()) {
-	        checkType(e.getKey(), e.getValue());
-    protected VDL2Config check() throws IOException {
-		if (files.size() == 0) {
-			throw new FileNotFoundException("No Swift configuration file found. Tried " + tried);
-		else {
-			return this;
-	public synchronized Object put(Object key, Object value, ConfigPropertyType type) {
-	    types.put(key, type);
-	    return put(key, value);
-	 * Overridden to do variable expansion. Variables will be expanded if there
-	 * is a system property with that name. Otherwise, the expansion will not
-	 * occur.
-	public synchronized Object put(Object key, Object value) {
-	    propertySource.put(key, currentFile);
-		String svalue = (String) value;
-		if (svalue.indexOf("${") == -1) {
-			return super.put(key, value);
-		else {
-			StringBuffer sb = new StringBuffer();
-			int index = 0, last = 0;
-			while (index >= 0) {
-				index = svalue.indexOf("${", index);
-				if (index >= 0) {
-					if (last != index) {
-						sb.append(svalue.substring(last, index));
-						last = index;
-					int end = svalue.indexOf("}", index);
-					if (end == -1) {
-						sb.append(svalue.substring(index));
-						break;
-					else {
-						String name = svalue.substring(index + 2, end);
-						String pval = System.getProperty(name);
-						index = end + 1;
-						if (pval == null) {
-							continue;
-						else {
-							sb.append(pval);
-							last = index;
-			sb.append(svalue.substring(last));
-			value = sb.toString();
-	private void checkType(Object key, Object value) {
-	    ConfigPropertyType type = types.get(key);
-	    if (type != null) {
-	        type.checkValue((String) key, (String) value, propertySource.get(key));
-    public String getPoolFile() {
-		return getProperty(VDL2ConfigProperties.POOL_FILE);
-	public String getTCFile() {
-		return getProperty(VDL2ConfigProperties.TC_FILE);
-	public String getIP() {
-		return getProperty(VDL2ConfigProperties.IP_ADDRESS);
-	public String getHostName() {
-	    return getProperty(VDL2ConfigProperties.HOST_NAME);
-	public String getTCPPortRange() {
-		return getProperty(VDL2ConfigProperties.TCP_PORT_RANGE);
-	public boolean getLazyErrors() {
-		return Boolean.valueOf(getProperty(VDL2ConfigProperties.LAZY_ERRORS, "true")).booleanValue();
-	public TriStateBoolean getKickstartEnabled() {
-		return TriStateBoolean.valueOf(getProperty(VDL2ConfigProperties.KICKSTART_ENABLED, "false"));
-	public boolean getSitedirKeep() {
-		return Boolean.valueOf(getProperty(VDL2ConfigProperties.SITEDIR_KEEP, "true")).booleanValue();
-	private Boolean provenanceLogCached;
-	public boolean getProvenanceLog() {
-	    if (provenanceLogCached == null) {
-	        provenanceLogCached = Boolean.valueOf(getProperty(VDL2ConfigProperties.PROVENANCE_LOG, "false"));
-		return provenanceLogCached;
-	public boolean isTracingEnabled() {
-        return Boolean.valueOf(getProperty(VDL2ConfigProperties.TRACING_ENABLED, "false")).booleanValue();
-	public String getTickerDateFormat() {
-		return getProperty("ticker.date.format");
-	public String getTickerPrefix() {
-		return getProperty("ticker.prefix");
-		return "Swift configuration (" + files + "): " + super.toString();
-	public Object clone() {
-		VDL2Config conf = new VDL2Config();
-		conf.putAll(this);
-		conf.files.addAll(files);
-        conf.propertySource.putAll(propertySource);
-		return conf;
-	public String getProperty(String name, BoundContact bc) {
-		if(bc!=null) {
-			if(logger.isDebugEnabled()) {
-				logger.debug("Checking BoundContact "+bc+" for property "+name);
-			String prop = (String) bc.getProperty(name);
-			if(prop != null) {
-				return prop;
-			logger.debug("Getting property "+name+" from global configuration");
-		return getProperty(name);
-    public void setCurrentFile(String f) {
-        this.currentFile = f;
Deleted: trunk/src/org/griphyn/vdl/util/VDL2ConfigProperties.java
--- trunk/src/org/griphyn/vdl/util/VDL2ConfigProperties.java	2014-07-09 19:38:06 UTC (rev 7975)
+++ trunk/src/org/griphyn/vdl/util/VDL2ConfigProperties.java	2014-07-09 19:38:50 UTC (rev 7976)
@@ -1,171 +0,0 @@
- * Created on Dec 23, 2006
-import java.util.TreeMap;
-public class VDL2ConfigProperties {
-	public static final String POOL_FILE = "sites.file";
-	public static final String TC_FILE = "tc.file";
-	public static final String IP_ADDRESS = "ip.address";
-	public static final String HOST_NAME = "hostname";
-	public static final String TCP_PORT_RANGE = "tcp.port.range";
-	public static final String LAZY_ERRORS = "lazy.errors";
-	public static final String PGRAPH = "pgraph";
-	public static final String PGRAPH_GRAPH_OPTIONS = "pgraph.graph.options";
-	public static final String PGRAPH_NODE_OPTIONS = "pgraph.node.options";
-	public static final String CACHING_ALGORITHM = "caching.algorithm";
-	public static final String CLUSTERING_ENABLED = "clustering.enabled";
-	public static final String CLUSTERING_QUEUE_DELAY = "clustering.queue.delay";
-	public static final String CLUSTERING_MIN_TIME = "clustering.min.time";
-	public static final String KICKSTART_ENABLED = "kickstart.enabled";
-	public static final String KICKSTART_ALWAYS_TRANSFER = "kickstart.always.transfer";
-	public static final String WRAPPERLOG_ALWAYS_TRANSFER = "wrapperlog.always.transfer";
-	public static final String SITEDIR_KEEP = "sitedir.keep";
-	public static final String PROVENANCE_LOG = "provenance.log";
-	public static final String FILE_GC_ENABLED = "file.gc.enabled";
-	public static final String TRACING_ENABLED = "tracing.enabled";
-	public static final String DM_CHECKER = "mapping.checker";
-	public static final Map<String, PropInfo> PROPERTIES;
-	static {
-		PROPERTIES = new TreeMap<String, PropInfo>();
-		PROPERTIES.put(POOL_FILE, new PropInfo("file",
-				"Points to the location of the sites.xml file"));
-		PROPERTIES.put(TC_FILE, new PropInfo("file", "Points to the location of the tc.data file"));
-		PROPERTIES.put(IP_ADDRESS, new PropInfo("aaa.bbb.ccc.ddd",
-				"Can be used to specify a publicly reacheable IP address for "
-						+ "this machine which is generally used for Globus callbacks. "
-						+ "Normally this should be auto-detected, but if you have "
-						+ "multiple network cards or NAT then you may need to set this"));
-		PROPERTIES.put(HOST_NAME, new PropInfo("string",
-		        "Can be used to specify a publicly reacheable DNS name or IP address for "
-                        + "Normally this should be auto-detected, but if you do "
-                        + "not have a public DNS name, you may want to set this."));
-		PROPERTIES.put(TCP_PORT_RANGE, new PropInfo("start,end",
-				"A TCP port range can be specified to "
-						+ "restrict the ports on which GRAM callback services are started. "
-						+ "This is likely needed if your submit host is behind a firewall, "
-						+ "in which case the firewall should be configured to allow "
-						+ "incoming connections on ports in the range."));
-		PROPERTIES.put(LAZY_ERRORS, new PropInfo("true|false",
-				"Use a lazy mode to deal with errors. When set to 'true' swift will proceed with the "
-						+ "execution until no more data can be derived because of "
-						+ "errors in dependent steps. If set to 'false', an error will "
-						+ "cause the execution to immediately stop"));
-		PROPERTIES.put(PGRAPH, new PropInfo("true|false|<filename>",
-				"Whether to generate a provenance "
-						+ "graph or not. If 'true' is used, the file name for the graph will "
-						+ "be chosen by swift."));
-		PROPERTIES.put(PGRAPH_GRAPH_OPTIONS, new PropInfo("<string>",
-				"Graph options to be passed to the .dot file. "
-						+ "These will appear in the 'graph' clause in the .dot file: "
-						+ "graph [<string>]; "));
-		PROPERTIES.put(PGRAPH_NODE_OPTIONS, new PropInfo("<string>",
-				"Node options to be passed to the .dot file."
-						+ "These will appear in the 'node' clause in the .dot file: "
-						+ "node [<string>]; "));
-		PROPERTIES.put(CACHING_ALGORITHM, new PropInfo("[LRU]", "The algorithm to use for the "
-				+ "swift file caching mechanism. LRU is the only one available now."));
-		PROPERTIES.put(CLUSTERING_ENABLED, new PropInfo("true|false",
-				"Whether to enable clustering of small jobs. If enabled, jobs with a "
-						+ "max wall time which is less than the value of the "
-						+ CLUSTERING_MIN_TIME
-						+ " property will be clustered into one job which has a cummulative"
-						+ " max wall time greater or equal to the value of the "
-						+ CLUSTERING_MIN_TIME + " property."));
-		PROPERTIES.put(CLUSTERING_QUEUE_DELAY, new PropInfo("<seconds>", "The delay at which "
-				+ "the clustering code scans the clustering queue. A job marked for clustering "
-				+ "will spend no more than the value of this property in the clustering queue."));
-		PROPERTIES.put(CLUSTERING_MIN_TIME, new PropInfo("<seconds>", "The threshold determines "
-				+ " if a job as being clusterable. Also represents the minimum cummulative "
-				+ "wall time that a cluster will have."));
-		PROPERTIES.put(KICKSTART_ENABLED, new PropInfo("<true|false|maybe>",
-				"Controls the use of Kickstart by Swift. The \"maybe\" "
-						+ "value tells Swift to use Kickstart on sites where it is available."));
-		PROPERTIES.put(
-				KICKSTART_ALWAYS_TRANSFER,
-				new PropInfo(
-						"<true|false>",
-						"If Kickstart is used (see \""
-								+ KICKSTART_ENABLED
-								+ "\"), it controls when "
-								+ "Kickstart records are transfered back to the submit host. If set to \"false\" "
-								+ "Swift will only transfer a Kickstart record for a job when the job fails. "
-								+ "If set to \"true\", Swift will transfer Kickstart records whether a job "
-								+ "fails or not."));
-		PROPERTIES.put(
-				WRAPPERLOG_ALWAYS_TRANSFER,
-				new PropInfo(
-						"<true|false>",
-								"Controls when "
-								+ "wrapper logs are transfered back to the submit host. If set to \"false\" "
-								+ "Swift will only transfer a wrapper log for a job when the job fails. "
-								+ "If set to \"true\", Swift will transfer wrapper logs whether a job "
-		PROPERTIES.put(
-				SITEDIR_KEEP,
-				new PropInfo(
-					"<true|false>",
-					"If set to true, keeps remote site run directory after execution has completed."));
-		PROPERTIES.put(
-				PROVENANCE_LOG,
-				new PropInfo(
-					"<true|false>",
-					"If set to true, will record provenance information in the log file"));
-		PROPERTIES.put(FILE_GC_ENABLED, new PropInfo("<true|false>", "Allows disabling the file garbage collector. " +
-				"If set to false, files mapped by collectable mappers (such as the concurrent mapper) will not be " +
-				"deleted when their swift variables go out of scope."));
-		PROPERTIES.put(TRACING_ENABLED, new PropInfo("<true|false>", "Enables execution tracing. If set to 'true', " +
-				"operations within swift such as iterations, invocations, assignments, and declarations, as well " +
-				"as data dependencies will be logged. This comes at a cost in performance. It is therefore " +
-				"disabled by default."));
-		PROPERTIES.put(DM_CHECKER, new PropInfo("<on|off>", "Controls the run-time duplicate mapping checker " +
-				"(which indetifies mapping conflicts). If set to 'on', the checker is enabled. When enabled, a record " +
-				"of all mapped data is kept, so this comes at the expense of a slight memory leak. If set 'off', the" +
-				" mapping checker is disabled. Enabled by default."));
-	public static Map<String, PropInfo> getPropertyDescriptions() {
-		return PROPERTIES;
-	public static String getPropertyDescription(String name) {
-		return PROPERTIES.get(name).desc;
-	public static class PropInfo {
-		public final String validValues;
-		public final String desc;
-		public PropInfo(String validValues, String desc) {
-			this.validValues = validValues;
-			this.desc = desc;
