[Swift-commit] r7974 - trunk/etc
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Wed Jul 9 14:37:52 CDT 2014
Author: hategan
Date: 2014-07-09 14:37:52 -0500 (Wed, 09 Jul 2014)
New Revision: 7974
Added:
   trunk/etc/swift.conf
Removed:
   trunk/etc/sites.xml
   trunk/etc/swift.properties
   trunk/etc/tc.data
Log:
new config mechanism I
Deleted: trunk/etc/sites.xml
--- trunk/etc/sites.xml	2014-07-04 18:29:09 UTC (rev 7973)
+++ trunk/etc/sites.xml	2014-07-09 19:37:52 UTC (rev 7974)
@@ -1,27 +0,0 @@
-<?xml version="1.0" encoding="UTF-8"?>
-<config xmlns="http://www.ci.uchicago.edu/swift/SwiftSites">
-<!-- sites.xml specifies details of the sites that Swift can run on.
-The entry for localhost should work on most linux-like systems
-without any change.
-It may be necessary to change /var/tmp to a different
-working directory.
-The jobThrottle profile is set to 0 so that Swift will not try to run more
-than two jobs at once (the minimum) when using the local sites. This is
-appropriate for local execution, but make sure if/when using another
-execution mechanism to submit to an HPC resource that this jobThrottle
-is updated.
-  <pool handle="localhost">
-    <filesystem provider="local" />
-    <execution provider="local" />
-    <workdirectory >/var/tmp</workdirectory>
-    <profile namespace="karajan" key="jobThrottle">0</profile>
-  </pool>
-</config>
Added: trunk/etc/swift.conf
--- trunk/etc/swift.conf	                        (rev 0)
+++ trunk/etc/swift.conf	2014-07-09 19:37:52 UTC (rev 7974)
@@ -0,0 +1,236 @@
+# The host name of the submit machine is used by GRAM as a callback
+# address to report the status of submitted jobs. In general, Swift
+# can automatically detect the host name of the local machine.
+# However, if the machine host name is improperly configured or if
+# it does not represent a valid DNS entry, certain services (such as
+# GRAM) will not be able to send job status notifications back to
+# the client. The value of this property can be an IP address.
+# Format:
+#    hostName=string
+#hostName=localhost
+# A TCP port range can be specified to restrict the ports on which GRAM
+# callback services are started. This is likely needed if your submit
+# host is behind a firewall, in which case the firewall should be
+# configured to allow incoming connections on ports in the range.
+# Format:
+#     tcp.port.range=start,end
+TCPPortRange="50000, 50100"
+# false	- means an error will be immediately reported and cause the
+# 		workflow to abort. At this time remote jobs that are already
+#		running will not be canceled
+# true	- means that Swift will try to do as much work as possible and
+#		report all errors encountered at the end. However, "errors"
+#		here only applies to job execution errors. Certain errors
+#		that are related to the Swift implementation (should such
+#		errors occur) will still be reported eagerly.
+# Default: false
+lazyErrors=true
+# Enables tracing of procedure invocations, assignments,
+# iteration constructs, as well as certain dataflow events
+# such as data intialization and waiting. This is done at
+# a slight decrease in performance. Traces will be available
+# in the log file.
+tracingEnabled=false
+# Indicates when wrapper logs should be fetched from the remote site:
+# true	- always transfer wrapper logs
+# false	- only transfer wrapper logs if the job fails
+# Default: false
+alwaysTransferWrapperLog=true
+#                          Throttling options                             #
+# For the throttling parameters, valid values are either a positive integer
+# or "off" (without the quotes).
+# Limits the number of concurrent submissions for a workflow instance. This
+# throttle only limits the number of concurrent tasks (jobs) that are being
+# sent to sites, not the total number of concurrent jobs that can be run.
+# The submission stage in GRAM is one of the most CPU expensive stages (due
+# mostly to the mutual authentication and delegation). Having too many
+# concurrent submissions can overload either or both the submit host CPU
+# and the remote host/head node causing degraded performance.
+# Default: 4
+jobSubmitThrottle=4
+#jobSubmitThrottle=off
+# Limits the number of concurrent submissions for any of the sites Swift will
+# try to send jobs to. In other words it guarantees that no more than the
+# value of this throttle jobs sent to any site will be concurrently in a state
+# of being submitted.
+# Default: 2
+hostJobSubmitThrottle=2
+#hostJobSubmitThrottle=off
+# Limits the total number of concurrent file transfers that can happen at any
+# given time. File transfers consume bandwidth. Too many concurrent transfers
+# can cause the network to be overloaded preventing various other signalling
+# traffic from flowing properly.
+# Default: 4
+fileTransfersThrottle=4
+#fileTransfersThrottle=off
+# Limits the total number of concurrent file operations that can happen at any
+# given time. File operations (like transfers) require an exclusive connection
+# to a site. These connections can be expensive to establish. A large number
+# of concurrent file operations may cause Swift to attempt to establish many
+# such expensive connections to various sites. Limiting the number of concurrent
+# file operations causes Swift to use a small number of cached connections and
+# achieve better overall performance.
+# Default: 8
+fileOperationsThrottle=8
+#fileOperationsThrottle=off
+# Indicates whether the working directory on the remote site should be
+# left intact even when the workflow completes successfully. This can be
+# used to inspect the site working directory for debugging purposes.
+# Default: false
+keepSiteDir=false
+# number of time a job will be retried if it fails (giving a maximum of
+# 1 + execution.retries attempts at execution)
+executionRetries=0
+# Enables/disables replication. Replication is used to deal with jobs sitting
+# in batch queues for abnormally large amounts of time. If replication is enabled
+# and certain conditions are met, Swift creates and submits replicas of jobs, and
+# allows multiple instances of a job to compete.
+replicationEnabled=false
+# If replication is enabled, this value specifies the minimum time, in seconds,
+# a job needs to be queued in a batch queue in order to be considered for
+# replication
+replicationMinQueueTime=60
+# The maximum number of replicas that Swift should attempt.
+replicationLimit=3
+# Controls how Swift will communicate the result code of running user programs
+# from workers to the submit side. In files mode, a file
+# indicating success or failure will be created on the site shared filesystem.
+# In provider mode, the execution provider job status will
+# be used. Notably, GRAM2 does not return job statuses correctly, and so
+# provider mode will not work with GRAM2. With other
+# providers, it can be used to reduce the amount of filesystem access compared
+# to files mode.
+# statusMode=files
+# Controls how swift will supply parameters to the remote wrapper script.
+# 'args' mode will pass parameters on the command line
+# 'files' mode will pass parameters through an additional input file
+# valid values: args, files
+# Default: files
+# wrapperParameterMode=args
+# Determines if Swift remote wrappers will be executed by specifying an
+# absolute path, or a path relative to the job initial working directory
+# valid values: absolute, relative
+# wrapperInvocationMode=absolute
+# Limits the number of concurrent iterations that each foreach statement
+# can have at one time. This conserves memory for swift programs that
+# have large numbers of iterations (which would otherwise all be executed
+# in parallel).
+# Default: 16384
+maxForeachThreads=16384
+# controls whether the log file will contain provenance information
+# enabling this will increase the size of log files, sometimes
+# significantly.
+logProvenance=false
+# The URL prefix used to access local files in wrapper
+# staging mode. Full URLs are created by concatenating:
+#	* the value of this property
+#	* the current swift work directory (as an absolute path)
+#	* the file in question (relative to the current work directory)
+#wrapperStagingLocalServer=file://
+# Files mapped by the concurrent mapper (i.e. when you don't
+# explicitly specify a mapper) are deleted when they are not
+# in use any more. This property can be used to prevent
+# files mapped by the concurrent mapper from being deleted.
+# Format:
+#	fileGCEnabled=(true|false)
+# Default: true
+site.local {
+	execution {
+		type: local
+	filesystem {
+		type: local
+	workDirectory: "."
+	app.ALL {
+		executable: "*"
+sites: [local]
\ No newline at end of file
Deleted: trunk/etc/swift.properties
--- trunk/etc/swift.properties	2014-07-04 18:29:09 UTC (rev 7973)
+++ trunk/etc/swift.properties	2014-07-09 19:37:52 UTC (rev 7974)
@@ -1,388 +0,0 @@
-sites.file=${swift.home}/etc/sites.xml
-tc.file=${swift.home}/etc/tc.data
-# The host name of the submit machine is used by GRAM as a callback
-# address to report the status of submitted jobs. In general, Swift
-# can automatically detect the host name of the local machine.
-# However, if the machine host name is improperly configured or if
-# it does not represent a valid DNS entry, certain services (such as
-# GRAM) will not be able to send job status notifications back to
-# the client. The value of this property can be an IP address.
-# Format:
-#    hostname=string
-#hostname=localhost
-# A TCP port range can be specified to restrict the ports on which GRAM
-# callback services are started. This is likely needed if your submit
-# host is behind a firewall, in which case the firewall should be
-# configured to allow incoming connections on ports in the range.
-# Format:
-#     tcp.port.range=start,end
-#tcp.port.range=50000,50100
-# false	- means an error will be immediately reported and cause the
-# 		workflow to abort. At this time remote jobs that are already
-#		running will not be canceled
-# true	- means that Swift will try to do as much work as possible and
-#		report all errors encountered at the end. However, "errors"
-#		here only applies to job execution errors. Certain errors
-#		that are related to the Swift implementation (should such
-#		errors occur) will still be reported eagerly.
-# Default: false
-lazy.errors=false
-# Enables tracing of procedure invocations, assignments,
-# iteration constructs, as well as certain dataflow events
-# such as data intialization and waiting. This is done at
-# a slight decrease in performance. Traces will be available
-# in the log file.
-tracing.enabled=true
-# What algorithm to use for caching of remote files. LRU (as in what
-# files to purge) is the only implementation right now. One can set
-# a target size (in bytes) for a host by using the swift:storagesize
-# profile for a host in sites.xml
-# Default: LRU
-caching.algorithm=LRU
-# true       - generate a provenance graph in .dot format (Swift will
-#			 choose a random file name)
-# false      - do not generate a provenance graph
-# <filename> - generate a provenange graph in the give file name
-# Default: false
-pgraph=false
-# graph properties for the provenance graph (.dot specific)
-# Default: splines="compound", rankdir="TB"
-pgraph.graph.options=splines="compound", rankdir="TB"
-# node properties for the provenance graph (.dot specific)
-# Default: color="seagreen", style="filled"
-pgraph.node.options=color="seagreen", style="filled"
-# true	- clustering of small jobs is enabled. Clustering works in the
-#       following way: If a job is clusterable (meaning that it has the
-#       GLOBUS::maxwalltime profile specified in tc.data and its value
-#       is less than the value of the "clustering.min.time" property) it will
-#       be put in a clustering queue. The queue is processed at intervals
-#       specified by the "clustering.queue.delay" property. The processing
-#       of the clustering queue consists of selecting compatible jobs and
-#		grouping them in clusters whose max wall time does not exceed twice
-#       the value of the "clustering.min.time" property. Two or more jobs are
-#       considered compatible if they share the same site and do not have
-#       conflicting profiles (e.g. different values for the same environment
-#       variable).
-# false	- clustering of small jobs is disabled.
-# Default: false
-clustering.enabled=false
-# <seconds>	- the intervals at which the clustering queue is processed
-# Default: 4
-clustering.queue.delay=4
-# <seconds>	- the threshold time for clustering
-# Default: 60
-clustering.min.time=60
-# Kickstart is a useful tool that can be used to gather various information
-# about a remote process. Before it can be used it must be installed on the
-# remote site and the corresponding entry be set in the sites file.
-# This option allows controlling of how Swift uses Kickstart. The following
-# values are possible:
-# false - do not use Kickstart
-# true  - use Kickstart. If a job is scheduled on a site that does not have
-#       Kickstart installed, that job will fail.
-# maybe - Use Kickstart if installed (i.e. the entry is present in the sites
-#       file)
-# Default: maybe
-kickstart.enabled=maybe
-# Indicates when Kickstart records should be fetched from the remote site:
-# true	- always transfer Kickstart records if Kickstart was used (see
-#		kickstart.enabled)
-# false	- only transfer Kickstart records if the job fails
-# Default: false
-kickstart.always.transfer=false
-# Indicates when wrapper logs should be fetched from the remote site:
-# true	- always transfer wrapper logs
-# false	- only transfer wrapper logs if the job fails
-# Default: false
-wrapperlog.always.transfer=false
-#                          Throttling options                             #
-# For the throttling parameters, valid values are either a positive integer
-# or "off" (without the quotes).
-# Limits the number of concurrent submissions for a workflow instance. This
-# throttle only limits the number of concurrent tasks (jobs) that are being
-# sent to sites, not the total number of concurrent jobs that can be run.
-# The submission stage in GRAM is one of the most CPU expensive stages (due
-# mostly to the mutual authentication and delegation). Having too many
-# concurrent submissions can overload either or both the submit host CPU
-# and the remote host/head node causing degraded performance.
-# Default: 4
-throttle.submit=4
-#throttle.submit=off
-# Limits the number of concurrent submissions for any of the sites Swift will
-# try to send jobs to. In other words it guarantees that no more than the
-# value of this throttle jobs sent to any site will be concurrently in a state
-# of being submitted.
-# Default: 2
-throttle.host.submit=2
-#throttle.host.submit=off
-# The Swift scheduler has the ability to limit the number of concurrent jobs
-# allowed on a site based on the performance history of that site. Each site
-# is assigned a score (initially 1), which can increase or decrease based
-# on whether the site yields successful or faulty job runs. The score for a
-# site can take values in the (0.1, 100) interval. The number of allowed jobs
-# is calculated using the following formula:
-# 	2 + score*throttle.score.job.factor
-# This means a site will always be allowed at least two concurrent jobs and
-# at most 2 + 100*throttle.score.job.factor. With a default of 4 this means
-# at least 2 jobs and at most 402.
-# Default: 4
-throttle.score.job.factor=0.2
-#throttle.score.job.factor=off
-# Limits the total number of concurrent file transfers that can happen at any
-# given time. File transfers consume bandwidth. Too many concurrent transfers
-# can cause the network to be overloaded preventing various other signalling
-# traffic from flowing properly.
-# Default: 4
-throttle.transfers=4
-#throttle.transfers=off
-# Limits the total number of concurrent file operations that can happen at any
-# given time. File operations (like transfers) require an exclusive connection
-# to a site. These connections can be expensive to establish. A large number
-# of concurrent file operations may cause Swift to attempt to establish many
-# such expensive connections to various sites. Limiting the number of concurrent
-# file operations causes Swift to use a small number of cached connections and
-# achieve better overall performance.
-# Default: 8
-throttle.file.operations=8
-#throttle.file.operations=off
-# Indicates whether the working directory on the remote site should be
-# left intact even when the workflow completes successfully. This can be
-# used to inspect the site working directory for debugging purposes.
-# Default: false
-sitedir.keep=false
-# number of time a job will be retried if it fails (giving a maximum of
-# 1 + execution.retries attempts at execution)
-execution.retries=0
-# Enables/disables replication. Replication is used to deal with jobs sitting
-# in batch queues for abnormally large amounts of time. If replication is enabled
-# and certain conditions are met, Swift creates and submits replicas of jobs, and
-# allows multiple instances of a job to compete.
-replication.enabled=false
-# If replication is enabled, this value specifies the minimum time, in seconds,
-# a job needs to be queued in a batch queue in order to be considered for
-# replication
-replication.min.queue.time=60
-# The maximum number of replicas that Swift should attempt.
-replication.limit=3
-# WARNING: This option is deprecated. Please use the hostname option.
-# The IP address of the submit machine is used by GRAM as a callback
-# can automatically detect the IP address of the local machine.
-# However, if the machine has more than one network interface, Swift
-# will pick the first one, which may not be the right choice. It is
-# recommended that this property is set properly before attempting to
-# run jobs through GRAM.
-# Format:
-#    ip.address=x.y.z.w
-#ip.address=127.0.0.1
-# Controls how Swift will communicate the result code of running user programs
-# from workers to the submit side. In files mode, a file
-# indicating success or failure will be created on the site shared filesystem.
-# In provider mode, the execution provider job status will
-# be used. Notably, GRAM2 does not return job statuses correctly, and so
-# provider mode will not work with GRAM2. With other
-# providers, it can be used to reduce the amount of filesystem access compared
-# to files mode.
-# status.mode=files
-# Controls how swift will supply parameters to the remote wrapper script.
-# 'args' mode will pass parameters on the command line
-# 'files' mode will pass parameters through an additional input file
-# valid values: args, files
-# Default: files
-# wrapper.parameter.mode=args
-# Determines if Swift remote wrappers will be executed by specifying an
-# absolute path, or a path relative to the job initial working directory
-# valid values: absolute, relative
-# wrapper.invocation.mode=absolute
-# Limits the number of concurrent iterations that each foreach statement
-# can have at one time. This conserves memory for swift programs that
-# have large numbers of iterations (which would otherwise all be executed
-# in parallel).
-# Default: 1024
-foreach.max.threads=16384
-# controls whether the log file will contain provenance information
-# enabling this will increase the size of log files, sometimes
-# significantly.
-provenance.log=false
-# Controls whether file staging is done by swift or by the execution
-# provider. If set to false, the standard swift staging mechanism is
-# used. If set to true, swift does not stage files. Instead, the
-# execution provider is instructed to stage files in and out.
-# Provider staging is experimental.
-# When enabled, and when coasters are used as an execution provider,
-# a staging mechanism can be selected for each site
-# using the swift:stagingMethod site profile in sites.xml. The
-# following is a list of accepted mechanisms:
-# * file:  Staging is done from a filesystem accessible to the
-#          coaster service (typically running on the head node)
-# * proxy: Staging is done from a filesystem accessible to the
-#          client machine that swift is running on, and is proxied
-#          through the coaster service
-# * sfs:   (short for "shared filesystem") Staging is done by
-#          copying files to and from a filesystem accessible
-#          by the compute node (such as an NFS or GPFS mount).
-use.provider.staging=false
-provider.staging.pin.swiftfiles=false
-# Controls whether wrapper staging is enabled
-# With wrapper staging, files are staged in and out by the
-# swift wrapper, on the worker node.
-use.wrapper.staging=false
-# The URL prefix used to access local files in wrapper
-# staging mode. Full URLs are created by concatenating:
-#	* the value of this property
-#	* the current swift work directory (as an absolute path)
-#	* the file in question (relative to the current work directory)
-#wrapper.staging.local.server=file://
-# Files mapped by the concurrent mapper (i.e. when you don't
-# explicitly specify a mapper) are deleted when they are not
-# in use any more. This property can be used to prevent
-# files mapped by the concurrent mapper from being deleted.
-# Format:
-#	file.gc.enabled=(true|false)
-# Default: true
Deleted: trunk/etc/tc.data
--- trunk/etc/tc.data	2014-07-04 18:29:09 UTC (rev 7973)
+++ trunk/etc/tc.data	2014-07-09 19:37:52 UTC (rev 7974)
@@ -1 +0,0 @@
-* * * INSTALLED INTEL32::LINUX null
