[Swift-commit] cog r4016
swift at ci.uchicago.edu swift at ci.uchicago.edu
Wed Jul 9 13:05:02 CDT 2014
r4016 | timgarmstrong | 2014-07-09 13:01:28 -0500 (Wed, 09 Jul 2014) | 1 line
Update to work with new configId scheme
Index: modules/provider-coaster-c-client/src/CoasterClient.cpp
--- modules/provider-coaster-c-client/src/CoasterClient.cpp	(revision 4015)
+++ modules/provider-coaster-c-client/src/CoasterClient.cpp	(working copy)
@@ -129,14 +129,18 @@
 	started = false;
-std::string CoasterClient::setOptions(Settings& s) {
+string CoasterClient::setOptions(Settings& s) {
 	LogInfo << "Setting options: " << s << endl;
 	ServiceConfigurationCommand scc(s);
 	scc.execute(channel);
-	return scc.getConfigId();
+	string *id = scc.getConfigId();
+	if (id == NULL) {
+		throw CoasterError("Did not get expected response for config");
+	return *id;
-void CoasterClient::submit(Job& job, std::string* configId) {
+void CoasterClient::submit(Job& job, const std::string* configId) {
 	{ Lock::Scoped l(lock);
 		jobs[job.getIdentity()] = &job;
Index: modules/provider-coaster-c-client/src/CoasterClientTest.cpp
--- modules/provider-coaster-c-client/src/CoasterClientTest.cpp	(revision 4015)
+++ modules/provider-coaster-c-client/src/CoasterClientTest.cpp	(working copy)
@@ -28,15 +28,15 @@
 		s.set(Settings::Key::MAX_NODES, "1");
 		s.set(Settings::Key::JOBS_PER_NODE, "2");
-		std::string* configId = client.setOptions(s);
+		std::string configId = client.setOptions(s);
 		Job j1("/bin/date");
 		Job j2("/bin/echo");
 		j2.addArgument("testing");
 		j2.addArgument("1, 2, 3");
-		client.submit(j1, configId);
-		client.submit(j2, configId);
+		client.submit(j1, &configId);
+		client.submit(j2, &configId);
 		client.waitForJob(j1);
 		client.waitForJob(j2);
Index: modules/provider-coaster-c-client/src/RunCoasterJob.cpp
--- modules/provider-coaster-c-client/src/RunCoasterJob.cpp	(revision 4015)
+++ modules/provider-coaster-c-client/src/RunCoasterJob.cpp	(working copy)
@@ -226,7 +226,7 @@
 		s.set(*skey, pair.value);
 	Job j(executable);
@@ -258,7 +258,7 @@
 		j.setStderrLocation(*str);
-	client.submit(j, configId);
+	client.submit(j, &configId);
 	client.waitForJob(j);
Index: modules/provider-coaster-c-client/src/coasters.cpp
--- modules/provider-coaster-c-client/src/coasters.cpp	(revision 4015)
+++ modules/provider-coaster-c-client/src/coasters.cpp	(working copy)
@@ -299,14 +299,16 @@
 coaster_rc
 coaster_apply_settings(coaster_client *client,
-                                  coaster_settings *settings)
+        coaster_settings *settings, coaster_config_id **config)
                                   COASTER_THROWS_NOTHING {
-  if (settings == NULL || client == NULL) {
+  if (settings == NULL || client == NULL || config == NULL) {
     return coaster_return_error(COASTER_ERROR_INVALID, "invalid arg");
   try {
-    client->client.setOptions(*settings);
+    string *configId = new string;
+    *configId = client->client.setOptions(*settings);
+    *config = configId;
     return COASTER_SUCCESS;
   } catch (const CoasterError& err) {
     return coaster_error_rc(err);
@@ -316,6 +318,12 @@
 coaster_rc
+coaster_config_id_free(coaster_config_id *config) COASTER_THROWS_NOTHING {
+  delete config;
+  return COASTER_SUCCESS;
+coaster_rc
 coaster_job_create(const char *executable, size_t executable_len,
                   int argc, const char **argv, const size_t *arg_lens,
                   const char *job_manager, size_t job_manager_len,
@@ -595,10 +603,10 @@
 coaster_rc
-coaster_submit(coaster_client *client, coaster_job *job)
-                COASTER_THROWS_NOTHING {
+coaster_submit(coaster_client *client, const coaster_config_id *config,
+               coaster_job *job) COASTER_THROWS_NOTHING {
   try {
-    client->client.submit(*job);
+    client->client.submit(*job, config);
Index: modules/provider-coaster-c-client/src/JobSubmitCommand.h
--- modules/provider-coaster-c-client/src/JobSubmitCommand.h	(revision 4015)
+++ modules/provider-coaster-c-client/src/JobSubmitCommand.h	(working copy)
@@ -13,7 +13,8 @@
 	private:
 		Job* job;
 		std::string ss;
-		std::string* configId;
+                bool haveConfigId;
+		std::string configId;
 	public:
 		static std::string NAME;
 		JobSubmitCommand(Job* job, const std::string* configId);
Index: modules/provider-coaster-c-client/src/CoasterClient.h
--- modules/provider-coaster-c-client/src/CoasterClient.h	(revision 4015)
+++ modules/provider-coaster-c-client/src/CoasterClient.h	(working copy)
@@ -67,15 +67,17 @@
 		void stop();
 		// TODO: how long does this hold a reference to settings?
-		std::string* setOptions(Settings& settings);
+		std::string setOptions(Settings& settings);
 		 * Submit a job.  The job should have been filled in with
 		 * all properties.  The ownership of the job object stays
 		 * with the caller, but this client will retain a reference
 		 * to the job until done jobs are purged.
+                 * configId: if non-null, uses specific server-side config
-		void submit(Job& job);
+		void submit(Job& job, const std::string* configId);
 		 * Wait for job to be done.  Upon completion no actions
Index: modules/provider-coaster-c-client/src/ServiceConfigurationCommand.cpp
--- modules/provider-coaster-c-client/src/ServiceConfigurationCommand.cpp	(revision 4015)
+++ modules/provider-coaster-c-client/src/ServiceConfigurationCommand.cpp	(working copy)
@@ -10,7 +10,7 @@
 ServiceConfigurationCommand::ServiceConfigurationCommand(Settings& s): Command(&NAME) {
 	settings = &s;
-	configId = null;
+	configId = NULL;
 void ServiceConfigurationCommand::send(CoasterChannel* channel, CommandCallback* cb) {
@@ -35,6 +35,6 @@
 	configId = getInData()->at(0)->str();
-std::string* getConfigId() {
+std::string* ServiceConfigurationCommand::getConfigId() {
 	return configId;
Index: modules/provider-coaster-c-client/src/coasters.h
--- modules/provider-coaster-c-client/src/coasters.h	(revision 4015)
+++ modules/provider-coaster-c-client/src/coasters.h	(working copy)
@@ -29,6 +29,10 @@
 #define COASTERS_H_
 #ifdef __cplusplus
+#include <string>
+#endif
+#ifdef __cplusplus
 extern "C" {
 #endif
@@ -55,10 +59,12 @@
 typedef class Coaster::Settings coaster_settings;
+typedef std::string coaster_config_id;
 typedef class Coaster::Job coaster_job;
 #else
 // Treat these types as opaque pointer to unimplemented struct for C
 typedef struct coaster_settings_opaque_ coaster_settings;
+typedef struct coaster_config_id_opaque_ coaster_config_id;
 typedef struct coaster_job_opaque_ coaster_job;
 #endif
@@ -177,12 +183,18 @@
  * Apply settings to started coasters client.
  * TODO: currently it isn't safe to free settings until client is shut
  *       down
+ * config: set to identifer for this service config, must be freed with
+ *     coaster_free_config_id
 coaster_rc
                                   COASTER_THROWS_NOTHING;
+coaster_rc
+coaster_config_id_free(coaster_config_id *config) COASTER_THROWS_NOTHING;
  * Create a new coasters job for later submission.
  * Some standard arguments can be specified now, or left as NULL to be
@@ -303,8 +315,8 @@
  * shuts down.
 coaster_rc
-                COASTER_THROWS_NOTHING;
+               coaster_job *job) COASTER_THROWS_NOTHING;
  * Check for completion of jobs.
Index: modules/provider-coaster-c-client/src/JobSubmitCommand.cpp
--- modules/provider-coaster-c-client/src/JobSubmitCommand.cpp	(revision 4015)
+++ modules/provider-coaster-c-client/src/JobSubmitCommand.cpp	(working copy)
@@ -21,7 +21,13 @@
 JobSubmitCommand::JobSubmitCommand(Job* pjob, const std::string* pconfigId): Command(&NAME) {
 	job = pjob;
-	configId = pconfigId;
+	if (pconfigId != NULL) {
+		haveConfigId = true;
+		configId = *pconfigId;
+	else {
+		haveConfigId = false;
 void JobSubmitCommand::send(CoasterChannel* channel, CommandCallback* cb) {
@@ -45,7 +51,9 @@
 void JobSubmitCommand::serialize() {
 	stringstream idSS;
 	idSS << job->getIdentity();
-	add(ss, "configid", configId);
+	if (haveConfigId) {
+		add(ss, "configid", configId);
 	add(ss, "identity", idSS.str());
 	add(ss, "executable", job->getExecutable());
 	add(ss, "directory", job->getDirectory());
