[Swift-commit] r7972 - trunk/libexec
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Fri Jul 4 13:28:22 CDT 2014
Author: hategan
Date: 2014-07-04 13:28:21 -0500 (Fri, 04 Jul 2014)
New Revision: 7972
Modified:
   trunk/libexec/_swiftwrap
   trunk/libexec/swift-int.k
   trunk/libexec/swift.k
Log:
removed kickstart
Modified: trunk/libexec/_swiftwrap
--- trunk/libexec/_swiftwrap	2014-07-04 18:09:43 UTC (rev 7971)
+++ trunk/libexec/_swiftwrap	2014-07-04 18:28:21 UTC (rev 7972)
@@ -480,73 +480,49 @@
 if [ ! -x "$EXEC" ]; then
 	fail 254 "The executable $EXEC does not have the executable bit set"
 fi
-if [ "$KICKSTART" == "" ]; then
-    TIMEARGS=(-o swiftapp.resources -f APP_RESOURCES=real_secs:%e,kernel_secs:%S,user_secs:%U,percent_cpu:%P,max_rss:%M,avg_rss:%t,avg_tot_vm:%K,avg_priv_data:%D,avg_priv_stack:%p,avg_shared_text:%X,page_size:%Z,major_pgfaults:%F,minor_pgfaults:%R,swaps:%W,invol_context_switches:%c,vol_waits:%w,fs_reads:%I,fs_writes:%O,sock_recv:%r,sock_send:%s,signals:%k,exit_status:%x)
+TIMEARGS=(-o swiftapp.resources -f APP_RESOURCES=real_secs:%e,kernel_secs:%S,user_secs:%U,percent_cpu:%P,max_rss:%M,avg_rss:%t,avg_tot_vm:%K,avg_priv_data:%D,avg_priv_stack:%p,avg_shared_text:%X,page_size:%Z,major_pgfaults:%F,minor_pgfaults:%R,swaps:%W,invol_context_switches:%c,vol_waits:%w,fs_reads:%I,fs_writes:%O,sock_recv:%r,sock_send:%s,signals:%k,exit_status:%x)
-    if [[ "$OSTYPE" == *darwin* ]]; then
-        TIMECMD=
-        TIMEARGS=
-    elif [ -x /usr/bin/time ]; then
-        TIMECMD="/usr/bin/time"
-    elif [ -x $HOME/swift.time ]; then
-        TIMECMD="$HOME/swift.time"
-    else
-        TIMECMD=""
-	TIMEARGS=""
-    fi
-	if [ "$STDIN" == "" ]; then
-		if [ "$SWIFT_GEN_SCRIPTS" != "" ]; then
-			genScripts
-		fi
-                if [ -n "$TIMECMD" ] && [ -n "$TIMEARGS" ]; then
-                   "$TIMECMD" "${TIMEARGS[@]}" "$EXEC" "${CMDARGS[@]}" 1>>"$STDOUT" 2>>"$STDERR"
-                else
-                   "$EXEC" "${CMDARGS[@]}" 1>>"$STDOUT" 2>>"$STDERR"
-                fi
-	else
-			genScripts
-		fi
-               		"$TIMECMD" "${TIMEARGS[@]}" "$EXEC" "${CMDARGS[@]}" 1>>"$STDOUT" 2>>"$STDERR" <"$STDIN"
-       	 	else
-           		"$EXEC" "${CMDARGS[@]}" 1>>"$STDOUT" 2>>"$STDERR" <"$STDIN"
-        	fi
+if [[ "$OSTYPE" == *darwin* ]]; then
+    TIMECMD=
+    TIMEARGS=
+elif [ -x /usr/bin/time ]; then
+    TIMECMD="/usr/bin/time"
+elif [ -x $HOME/swift.time ]; then
+    TIMECMD="$HOME/swift.time"
+else
+    TIMECMD=""
+TIMEARGS=""
+fi
+if [ "$STDIN" == "" ]; then
+	if [ "$SWIFT_GEN_SCRIPTS" != "" ]; then
+		genScripts
 	fi
-    TIME_EC=$?
-    if [ "_$TIMECMD" != _ ]; then
-		log "$(cat swiftapp.resources)"
-    fi
-    sh -c "exit $TIME_EC"
-	checkError $? "Application $EXEC failed with an exit code of $?"
+            if [ -n "$TIMECMD" ] && [ -n "$TIMEARGS" ]; then
+               "$TIMECMD" "${TIMEARGS[@]}" "$EXEC" "${CMDARGS[@]}" 1>>"$STDOUT" 2>>"$STDERR"
+            else
+               "$EXEC" "${CMDARGS[@]}" 1>>"$STDOUT" 2>>"$STDERR"
+            fi
 else
-	if [ ! -f "$KICKSTART" ]; then
-		log "Kickstart executable ($KICKSTART) not found"
-		fail 254 "The Kickstart executable ($KICKSTART) was not found"
-	elif [ ! -x "$KICKSTART" ]; then
-		log "Kickstart executable ($KICKSTART) is not executable"
-		fail 254 "The Kickstart executable ($KICKSTART) does not have the executable bit set"
-	else
-		mkdir -p $WFDIR/kickstart/$JOBDIR
-		log "Using Kickstart ($KICKSTART)"
-			"$KICKSTART" -H -o "$STDOUT" -e "$STDERR" "$EXEC" "$@" 1>kickstart.xml 2>>"$STDERR"
-		else
-			"$KICKSTART" -H -o "$STDOUT" -i "$STDIN" -e "$STDERR" "$EXEC" "$@" 1>kickstart.xml 2>>"$STDERR"
-		fi
-		export APPEXIT=$?
-		mv -f kickstart.xml "$WFDIR/kickstart/$JOBDIR/$ID-kickstart.xml" 2>&1 >& "$INFO"
-		checkError 254 "Failed to copy Kickstart record to shared directory"
-		if [ "$APPEXIT" != "0" ]; then
-			fail $APPEXIT "Application $EXEC failed with an exit code of $APPEXIT"
-		fi
+		genScripts
 	fi
+           		"$TIMECMD" "${TIMEARGS[@]}" "$EXEC" "${CMDARGS[@]}" 1>>"$STDOUT" 2>>"$STDERR" <"$STDIN"
+   	 	else
+       		"$EXEC" "${CMDARGS[@]}" 1>>"$STDOUT" 2>>"$STDERR" <"$STDIN"
+    	fi
 fi
+TIME_EC=$?
+if [ "_$TIMECMD" != _ ]; then
+	log "$(cat swiftapp.resources)"
+fi
+sh -c "exit $TIME_EC"
+checkError $? "Application $EXEC failed with an exit code of $?"
 if [[ $MPI_RANK == "" || $MPI_RANK == 0 ]]; then
 	if [ "$COLLECT" != "" ]; then
 		logstate "COLLECT"
Modified: trunk/libexec/swift-int.k
--- trunk/libexec/swift-int.k	2014-07-04 18:09:43 UTC (rev 7971)
+++ trunk/libexec/swift-int.k	2014-07-04 18:28:21 UTC (rev 7972)
@@ -85,7 +85,6 @@
 			dir:make(SHARED_DIR, host = rhost)
 			transfer(siteProfile(rhost, "wrapperScript"), srcdir="{SWIFT:HOME}/libexec/", destdir=SHARED_DIR, desthost=rhost)
 			transfer("_swiftseq", srcdir="{SWIFT:HOME}/libexec/", destdir=SHARED_DIR, desthost=rhost)
-			dir:make(dircat(RUN_DIR, "kickstart"), host=rhost)
 			statusMode := configProperty("status.mode", host=rhost)
 			if (statusMode == "files") {
Modified: trunk/libexec/swift.k
--- trunk/libexec/swift.k	2014-07-04 18:09:43 UTC (rev 7971)
+++ trunk/libexec/swift.k	2014-07-04 18:28:21 UTC (rev 7972)
@@ -87,59 +87,13 @@
 		 * all the data in memory until the workflow is done
 	export(mainp,
-		CBFFunction(channel(graph), channel(cleanup)) {
+		CBFFunction(channel(cleanup)) {
 			parallel(
-				if(configProperty("pgraph") != "false") {
-					generateProvenanceGraph(graph)
 				to(cleanup, unique(for(c, cleanup, c)))
-	graphStuff := function(tr, stagein, stageout, err, args = null) {
-		if (configProperty("pgraph") != "false") {
-			errprops := if(err, ",color=lightsalmon", ",color=lightsteelblue1")
-			tp := currentThread()
-			to (graph) {
-				concat(str:quote(tp), " [label=", str:quote(tr), "{errprops}]")
-			for (si, stagein) {
-				si := basename(si)
-				to(graph) {
-					concat(str:quote(si), " [shape=parallelogram]")
-					concat(str:quote(si), " -> ", str:quote(tp))
-			for (pv, stageout) {
-				(path, var) := each(pv)
-				file := fileName(getField(var, path=path))
-				file := basename(file)
-				label := niceName(var, path = path)
-				to(graph) {
-					concat(str:quote(file), " [shape=parallelogram,label=", str:quote(label), "]")
-					concat(str:quote(tp), " -> ", str:quote(file))
-	generateProvenanceGraph := function(gdata) {
-		pgraph := configProperty("pgraph")
-		gname := if(pgraph == "true", "{SWIFT:SCRIPT_NAME}-{SWIFT:RUN_ID}.dot", pgraph)
-		file:write(gname) {
-			"digraph SwiftProvenance \{\n",
-			"	graph [", configProperty("pgraph.graph.options"), "];\n",
-			"	node [", configProperty("pgraph.node.options"), "];\n",
-			for(i, gdata) {
-				"	", i, "\n"
-			"}\n"
-		log(LOG:INFO, "Provenance graph saved in ", gname)
 	export(execute,
 		function(
 			tr, arguments = null,
@@ -223,7 +177,6 @@
 							log(LOG:INFO, exception)
 							echo(exception)
 							mark(stageout, true, mapping=false)
-							graphStuff(tr, stagein, stageout, true, maybe(args=arguments))
@@ -245,7 +198,6 @@
 				mark(stageout, true, mapping=merr)
