[Swift-commit] r7961 - in trunk/src/org/griphyn/vdl/mapping: . file nodes
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Fri Jul 4 01:48:29 CDT 2014
Author: hategan
Date: 2014-07-04 01:48:28 -0500 (Fri, 04 Jul 2014)
New Revision: 7961
Added:
   trunk/src/org/griphyn/vdl/mapping/GenericMappingParamSet.java
Modified:
   trunk/src/org/griphyn/vdl/mapping/AbstractMapper.java
   trunk/src/org/griphyn/vdl/mapping/DSHandle.java
   trunk/src/org/griphyn/vdl/mapping/Mapper.java
   trunk/src/org/griphyn/vdl/mapping/MappingParamSet.java
   trunk/src/org/griphyn/vdl/mapping/NullMapper.java
   trunk/src/org/griphyn/vdl/mapping/RootHandle.java
   trunk/src/org/griphyn/vdl/mapping/file/RegularExpressionMapper.java
   trunk/src/org/griphyn/vdl/mapping/nodes/AbstractClosedArrayDataNode.java
   trunk/src/org/griphyn/vdl/mapping/nodes/AbstractClosedNonCompositeDataNode.java
   trunk/src/org/griphyn/vdl/mapping/nodes/AbstractFutureArrayDataNode.java
   trunk/src/org/griphyn/vdl/mapping/nodes/AbstractFutureNonCompositeDataNode.java
   trunk/src/org/griphyn/vdl/mapping/nodes/AbstractFutureStructDataNode.java
   trunk/src/org/griphyn/vdl/mapping/nodes/InitMapper.java
   trunk/src/org/griphyn/vdl/mapping/nodes/RootFutureArrayDataNode.java
   trunk/src/org/griphyn/vdl/mapping/nodes/RootFutureMappedSingleDataNode.java
   trunk/src/org/griphyn/vdl/mapping/nodes/RootFuturePrimitiveDataNode.java
   trunk/src/org/griphyn/vdl/mapping/nodes/RootFutureStructDataNode.java
Log:
some more mapper stuff cleaning
Modified: trunk/src/org/griphyn/vdl/mapping/AbstractMapper.java
--- trunk/src/org/griphyn/vdl/mapping/AbstractMapper.java	2014-07-04 06:46:49 UTC (rev 7960)
+++ trunk/src/org/griphyn/vdl/mapping/AbstractMapper.java	2014-07-04 06:48:28 UTC (rev 7961)
@@ -19,7 +19,6 @@
 import java.util.Collection;
 import java.util.HashSet;
-import java.util.Map;
 import java.util.Set;
 import org.apache.log4j.Logger;
@@ -66,7 +65,7 @@
     @Override
-    public void setParameters(Map<String, Object> params) {
+    public void setParameters(GenericMappingParamSet params) {
         this.params = newParams();
         this.params.setAll(params);
Modified: trunk/src/org/griphyn/vdl/mapping/DSHandle.java
--- trunk/src/org/griphyn/vdl/mapping/DSHandle.java	2014-07-04 06:46:49 UTC (rev 7960)
+++ trunk/src/org/griphyn/vdl/mapping/DSHandle.java	2014-07-04 06:48:28 UTC (rev 7961)
@@ -84,6 +84,8 @@
     public void closeShallow();
     public void closeDeep();
+    public void closeArraySizes();
     public Collection<Path> getFringePaths() throws HandleOpenException;
Added: trunk/src/org/griphyn/vdl/mapping/GenericMappingParamSet.java
--- trunk/src/org/griphyn/vdl/mapping/GenericMappingParamSet.java	                        (rev 0)
+++ trunk/src/org/griphyn/vdl/mapping/GenericMappingParamSet.java	2014-07-04 06:48:28 UTC (rev 7961)
@@ -0,0 +1,74 @@
+//This code is developed as part of the Java CoG Kit project
+//The terms of the license can be found at http://www.cogkit.org/license
+//This message may not be removed or altered.
+ * Created on Jun 1, 2014
+package org.griphyn.vdl.mapping;
+import java.util.ArrayList;
+import java.util.Collection;
+import java.util.Collections;
+import java.util.Iterator;
+import java.util.List;
+import org.globus.cog.karajan.util.Pair;
+public class GenericMappingParamSet {
+    private final String descriptor;
+    private List<Pair<String, Object>> params;
+    public GenericMappingParamSet(String descriptor) {
+        this.descriptor = descriptor;
+    public void addParam(Pair<String, Object> param) {
+        if (params == null) {
+            params = new ArrayList<Pair<String, Object>>(4);
+        params.add(param);
+    public String toString() {
+        StringBuilder sb = new StringBuilder();
+        sb.append('<');
+        sb.append(descriptor);
+        if (params != null) {
+            sb.append("; ");
+            Iterator<Pair<String, Object>> it = params.iterator();
+            while (it.hasNext()) {
+                Pair<String, Object> p = it.next();
+                sb.append(p.s);
+                sb.append(" = ");
+                sb.append(p.t);
+                if (it.hasNext()) {
+                    sb.append(", ");
+        sb.append(">");
+        return sb.toString();
+    public String getDescriptor() {
+        return descriptor;
+    public Collection<Pair<String, Object>> getParams() {
+            return Collections.emptyList();
+        else {
+            return params;
+    public void put(String name, Object value) {
+        addParam(new Pair<String, Object>(name, value));
Modified: trunk/src/org/griphyn/vdl/mapping/Mapper.java
--- trunk/src/org/griphyn/vdl/mapping/Mapper.java	2014-07-04 06:46:49 UTC (rev 7960)
+++ trunk/src/org/griphyn/vdl/mapping/Mapper.java	2014-07-04 06:48:28 UTC (rev 7961)
@@ -18,7 +18,6 @@
 import org.griphyn.vdl.mapping.nodes.AbstractDataNode;
@@ -83,7 +82,7 @@
     Set<String> getSupportedParamNames();
-    void setParameters(Map<String, Object> params);
+    void setParameters(GenericMappingParamSet params);
      * Called after all parameters have been closed
Modified: trunk/src/org/griphyn/vdl/mapping/MappingParamSet.java
--- trunk/src/org/griphyn/vdl/mapping/MappingParamSet.java	2014-07-04 06:46:49 UTC (rev 7960)
+++ trunk/src/org/griphyn/vdl/mapping/MappingParamSet.java	2014-07-04 06:48:28 UTC (rev 7961)
@@ -4,8 +4,8 @@
 import org.griphyn.vdl.karajan.lib.Tracer;
@@ -86,10 +86,10 @@
-    public void setAll(Map<String, Object> m) {
+    public void setAll(GenericMappingParamSet m) {
         if (m != null) {
-            for (Map.Entry<String, Object> e : m.entrySet()) {
-                set0(e.getKey(), e.getValue());
+            for (Pair<String, Object> e : m.getParams()) {
+                set0(e.s, e.t);
Modified: trunk/src/org/griphyn/vdl/mapping/NullMapper.java
--- trunk/src/org/griphyn/vdl/mapping/NullMapper.java	2014-07-04 06:46:49 UTC (rev 7960)
+++ trunk/src/org/griphyn/vdl/mapping/NullMapper.java	2014-07-04 06:48:28 UTC (rev 7961)
@@ -11,7 +11,6 @@
@@ -74,7 +73,7 @@
     @Override
     @Override
Modified: trunk/src/org/griphyn/vdl/mapping/RootHandle.java
--- trunk/src/org/griphyn/vdl/mapping/RootHandle.java	2014-07-04 06:46:49 UTC (rev 7960)
+++ trunk/src/org/griphyn/vdl/mapping/RootHandle.java	2014-07-04 06:48:28 UTC (rev 7961)
@@ -25,7 +25,6 @@
     Mapper getActualMapper();
     boolean isArray();
-    void closeArraySizes();
     void mapperInitialized(Mapper mapper);
Modified: trunk/src/org/griphyn/vdl/mapping/file/RegularExpressionMapper.java
--- trunk/src/org/griphyn/vdl/mapping/file/RegularExpressionMapper.java	2014-07-04 06:46:49 UTC (rev 7960)
+++ trunk/src/org/griphyn/vdl/mapping/file/RegularExpressionMapper.java	2014-07-04 06:48:28 UTC (rev 7961)
@@ -20,8 +20,6 @@
 import java.util.Arrays;
-import java.util.HashMap;
 import java.util.regex.Matcher;
 import java.util.regex.Pattern;
@@ -29,6 +27,7 @@
 import org.griphyn.vdl.mapping.AbsFile;
 import org.griphyn.vdl.mapping.AbstractMapper;
 import org.griphyn.vdl.mapping.FileSystemLister;
+import org.griphyn.vdl.mapping.GenericMappingParamSet;
 import org.griphyn.vdl.mapping.MappingParamSet;
 import org.griphyn.vdl.mapping.Path;
 import org.griphyn.vdl.mapping.PhysicalFormat;
@@ -116,7 +115,7 @@
 	public static void main(String[] args) {
 		RegularExpressionMapper reMapper = new RegularExpressionMapper();
-		Map<String, Object> params = new HashMap<String, Object>();
+		GenericMappingParamSet params = new GenericMappingParamSet("regex");
 		params.put("source", "2mass-j1223.fits");
 		params.put("match", "(.*)\\.(.*)");
 		params.put("transform", "\\1_area.\\2");
Modified: trunk/src/org/griphyn/vdl/mapping/nodes/AbstractClosedArrayDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/nodes/AbstractClosedArrayDataNode.java	2014-07-04 06:46:49 UTC (rev 7960)
+++ trunk/src/org/griphyn/vdl/mapping/nodes/AbstractClosedArrayDataNode.java	2014-07-04 06:48:28 UTC (rev 7961)
@@ -155,4 +155,11 @@
     public int arraySize() {
         return values.length;
+    @Override
+    public void closeArraySizes() {
+        for (DSHandle h : values) {
+            h.closeArraySizes();
Modified: trunk/src/org/griphyn/vdl/mapping/nodes/AbstractClosedNonCompositeDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/nodes/AbstractClosedNonCompositeDataNode.java	2014-07-04 06:46:49 UTC (rev 7960)
+++ trunk/src/org/griphyn/vdl/mapping/nodes/AbstractClosedNonCompositeDataNode.java	2014-07-04 06:48:28 UTC (rev 7961)
@@ -39,4 +39,8 @@
     public boolean isArray() {
         return false;
+    @Override
Modified: trunk/src/org/griphyn/vdl/mapping/nodes/AbstractFutureArrayDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/nodes/AbstractFutureArrayDataNode.java	2014-07-04 06:46:49 UTC (rev 7960)
+++ trunk/src/org/griphyn/vdl/mapping/nodes/AbstractFutureArrayDataNode.java	2014-07-04 06:48:28 UTC (rev 7961)
@@ -170,6 +170,19 @@
             handles = Collections.emptyMap();
+    @Override
+        closeShallow();
+        try {
+            for (DSHandle h : getAllFields()) {
+        catch (Exception e) {
+            throw new IllegalStateException(e);
     @Override
     public void closeDeep() {
Modified: trunk/src/org/griphyn/vdl/mapping/nodes/AbstractFutureNonCompositeDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/nodes/AbstractFutureNonCompositeDataNode.java	2014-07-04 06:46:49 UTC (rev 7960)
+++ trunk/src/org/griphyn/vdl/mapping/nodes/AbstractFutureNonCompositeDataNode.java	2014-07-04 06:48:28 UTC (rev 7961)
@@ -91,4 +91,8 @@
         value = null;
         super.clean0();
+    @Override
Modified: trunk/src/org/griphyn/vdl/mapping/nodes/AbstractFutureStructDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/nodes/AbstractFutureStructDataNode.java	2014-07-04 06:46:49 UTC (rev 7960)
+++ trunk/src/org/griphyn/vdl/mapping/nodes/AbstractFutureStructDataNode.java	2014-07-04 06:48:28 UTC (rev 7961)
@@ -139,4 +139,11 @@
             throw exception;
+    @Override
+        for (DSHandle h : fields) {
Modified: trunk/src/org/griphyn/vdl/mapping/nodes/InitMapper.java
--- trunk/src/org/griphyn/vdl/mapping/nodes/InitMapper.java	2014-07-04 06:46:49 UTC (rev 7960)
+++ trunk/src/org/griphyn/vdl/mapping/nodes/InitMapper.java	2014-07-04 06:48:28 UTC (rev 7961)
@@ -10,7 +10,6 @@
 package org.griphyn.vdl.mapping.nodes;
 import k.rt.Future;
@@ -24,6 +23,7 @@
 import org.griphyn.vdl.mapping.DependentException;
 import org.griphyn.vdl.mapping.DuplicateMappingChecker;
 import org.griphyn.vdl.mapping.HandleOpenException;
 import org.griphyn.vdl.mapping.InvalidPathException;
 import org.griphyn.vdl.mapping.Mapper;
@@ -98,7 +98,7 @@
     @Override
     @Override
Modified: trunk/src/org/griphyn/vdl/mapping/nodes/RootFutureArrayDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/nodes/RootFutureArrayDataNode.java	2014-07-04 06:46:49 UTC (rev 7960)
+++ trunk/src/org/griphyn/vdl/mapping/nodes/RootFutureArrayDataNode.java	2014-07-04 06:48:28 UTC (rev 7961)
@@ -115,9 +115,4 @@
     public Mapper getActualMapper() {
         return mapper;
-    @Override
-    public void closeArraySizes() {
-        closeShallow();
Modified: trunk/src/org/griphyn/vdl/mapping/nodes/RootFutureMappedSingleDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/nodes/RootFutureMappedSingleDataNode.java	2014-07-04 06:46:49 UTC (rev 7960)
+++ trunk/src/org/griphyn/vdl/mapping/nodes/RootFutureMappedSingleDataNode.java	2014-07-04 06:48:28 UTC (rev 7961)
@@ -118,9 +118,4 @@
         return mapper;
-    @Override
-        // does not apply
Modified: trunk/src/org/griphyn/vdl/mapping/nodes/RootFuturePrimitiveDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/nodes/RootFuturePrimitiveDataNode.java	2014-07-04 06:46:49 UTC (rev 7960)
+++ trunk/src/org/griphyn/vdl/mapping/nodes/RootFuturePrimitiveDataNode.java	2014-07-04 06:48:28 UTC (rev 7961)
@@ -97,9 +97,4 @@
     public Mapper getMapper() {
         throw new UnsupportedOperationException("Primitive types do not have a mapper");
-    @Override
-        // does not apply
Modified: trunk/src/org/griphyn/vdl/mapping/nodes/RootFutureStructDataNode.java
--- trunk/src/org/griphyn/vdl/mapping/nodes/RootFutureStructDataNode.java	2014-07-04 06:46:49 UTC (rev 7960)
+++ trunk/src/org/griphyn/vdl/mapping/nodes/RootFutureStructDataNode.java	2014-07-04 06:48:28 UTC (rev 7961)
@@ -129,9 +129,4 @@
         return mapper;
-    @Override
-        // does not apply
