[Swift-commit] r7535 - trunk/src/org/griphyn/vdl/karajan/lib
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Thu Jan 30 21:38:40 CST 2014
Author: hategan
Date: 2014-01-30 21:38:40 -0600 (Thu, 30 Jan 2014)
New Revision: 7535
Modified:
   trunk/src/org/griphyn/vdl/karajan/lib/ExpandArguments.java
Log:
removed unused comparator
Modified: trunk/src/org/griphyn/vdl/karajan/lib/ExpandArguments.java
--- trunk/src/org/griphyn/vdl/karajan/lib/ExpandArguments.java	2014-01-31 03:12:12 UTC (rev 7534)
+++ trunk/src/org/griphyn/vdl/karajan/lib/ExpandArguments.java	2014-01-31 03:38:40 UTC (rev 7535)
@@ -18,7 +18,6 @@
 package org.griphyn.vdl.karajan.lib;
 import java.util.ArrayList;
-import java.util.Comparator;
 import java.util.Map;
 import java.util.SortedMap;
 import java.util.TreeMap;
@@ -92,13 +91,5 @@
         return arraySeen;
-    class StringsAsIntegersComparator implements Comparator<Object> {
-		public int compare(Object l, Object r) {
-			Integer lnum = new Integer((String)l);
-			Integer rnum = new Integer((String)r);
-			return lnum.compareTo(rnum);
