[Swift-commit] r7529 - in SwiftApps/swift-galaxy: . swift
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Thu Jan 30 17:20:58 CST 2014
Author: ketan
Date: 2014-01-30 17:20:58 -0600 (Thu, 30 Jan 2014)
New Revision: 7529
Added:
   SwiftApps/swift-galaxy/swift/postprocess.py
   SwiftApps/swift-galaxy/swift/swift-catsn.sh
   SwiftApps/swift-galaxy/swift/swift-catsn.xml
   SwiftApps/swift-galaxy/swift/swift-skeleton.xml
Removed:
   SwiftApps/swift-galaxy/swift/catsn.xml
   SwiftApps/swift-galaxy/swift/swiftforeachrangepp.py
Modified:
   SwiftApps/swift-galaxy/README.txt
   SwiftApps/swift-galaxy/swift/swiftforeachlist.sh
   SwiftApps/swift-galaxy/swift/swiftforeachlist.xml
   SwiftApps/swift-galaxy/swift/swiftforeachrange.sh
   SwiftApps/swift-galaxy/swift/swiftforeachrange.xml
Log:
swift galaxy enhancements
Modified: SwiftApps/swift-galaxy/README.txt
--- SwiftApps/swift-galaxy/README.txt	2014-01-30 15:26:30 UTC (rev 7528)
+++ SwiftApps/swift-galaxy/README.txt	2014-01-30 23:20:58 UTC (rev 7529)
@@ -9,47 +9,31 @@
 3. (Re)start Galaxy. You should see the tools in a toolset titled Swift.
-==An example (obsolete) ==
+==An example of integrating a Swift tool into Galaxy==
 A simple Hello World Swift tool to run with Galaxy.
 To set up with your Galaxy environment follow the steps below:
-0. Prerequisite: Sun/Oracle java. Should work with IBM java but not tested rigorously.
+0. Prerequisite: Sun/Oracle java. Should work with IBM java but not tested.
 1. Download and install Swift where Galaxy server is running. From a command prompt the following wget will pull the latest release:
-wget http://www.ci.uchicago.edu/swift/packages/swift-0.94.1.tar.gz
+wget http://swiftlang.org/packages/swift-0.94.2-RC2.tar.gz
-Do untar at a suitable location:
+2. Create a swift-tool directory and copy the Swift tool skeleton files in this directory
-tar zxf swift-0.94.1.tar.gz
+cp swift/swift-skeleton* /location/of/galaxy-server/tools/
-Put the bin dir on system PATH:
+3. Edit the tool_conf.xml file present at the top-level of galaxy directory tree to add the following lines between the <toolbox> and </toolbox> xml tags:
-export PATH=$PATH:/location/to/swift-0.94.1/bin
-Edit above line to match the location of Swift and add it to your environment file (.bashrc, .bash_profile or the corresponding ones for other shells).
-Make sure Swift is available from a command prompt:
-which swift
-swift -version
-2. untar and copy the swift-galaxy.tgz to the tools directory of your Galaxy location:
-tar zxf swift-galaxy.tgz
-cp -r swift-galaxy /location/of/galaxy-server/tools/
-3. Edit the tool_conf.xml file present at the top-level of galaxy-server directory tree to add the following lines between the <toolbox> and </toolbox> xml tags:
-<section name="swift-hello" id="swift-hello">
-  <tool file="swift-galaxy/helloswift.xml" />
+<section name="swift-galaxy" id="swift-galaxy">
+  <tool file="currdir/nameoftoolfile.xml" />
 </section>
 4. Restart the Galaxy server. The swift-galaxy tool should be available in the tool box of Galaxy GUI.
-5. Invoke it by entering any number in the dialog box or leaving it to default. A message "Hello World!" will be written to output files as many times and the files should be available for browsing from Galaxy GUI.
+5. Invoke it by entering any number in the dialog box or leaving it to default.
-Please note that the Cluster option is not implemented in this example.
+6. For examples of othe Galaxy-Swift tools, look into the swift directoty.
Deleted: SwiftApps/swift-galaxy/swift/catsn.xml
--- SwiftApps/swift-galaxy/swift/catsn.xml	2014-01-30 15:26:30 UTC (rev 7528)
+++ SwiftApps/swift-galaxy/swift/catsn.xml	2014-01-30 23:20:58 UTC (rev 7529)
@@ -1,22 +0,0 @@
-<tool id="catsn" name="Swift catsn">
-  <description>A Swift tool to run the catsn workflow</description>
-  <command interpreter="bash">
-  swift-catsn "$site" "$data" "$n" "$html_file.files_path" "$log_file" "$html_file"
-  </command>
-  <inputs>
-    <param name="site" type="select" label="Execution Location">
-       <option value="localhost">Localhost</option>
-       <option value="midway">Midway</option>
-       <option value="uc3">UC3</option>
-       <option value="stampede">Stampede</option>
-    </param>
-    <param name="n" type="text" value="1" label="Number of tasks to run "/>
-    <param name="data" type="data" label="Input data file"/>
-  </inputs>
-  <outputs>
-     <data format="txt" name="log_file" type="data" label="Swift output" />
-     <data format="html" name="html_file" label="catsnoutput.html" />
-  </outputs>
-</tool>
Copied: SwiftApps/swift-galaxy/swift/postprocess.py (from rev 7528, SwiftApps/swift-galaxy/swift/swiftforeachrangepp.py)
--- SwiftApps/swift-galaxy/swift/postprocess.py	                        (rev 0)
+++ SwiftApps/swift-galaxy/swift/postprocess.py	2014-01-30 23:20:58 UTC (rev 7529)
@@ -0,0 +1,65 @@
+#post processing, set build for data and add additional data to history^M
+from galaxy import datatypes, config, jobs, tools
+from galaxy.model import HistoryDatasetAssociation
+import operator
+import shutil
+import os
+import glob
+from os.path import basename
+def createDsRef(outDataItems, param_dict, outputName, outputFormat, outputDsRefName, nameSpace):
+    dsrefXML="<?xml version=\"1.0\" ?>\n"
+    dsrefXML=dsrefXML+"<dataSetRefs xmlns=\"http://ci.uchicago.edu/galaxy-es/datasetrefs/"+nameSpace+"\" >\n"
+    dsrefFileName=""
+    for outDataName, outDataItem in outDataItems:
+        if outDataName==outputDsRefName:
+            dsrefFileName=outDataItem.get_file_name()
+        else:
+            if outDataName==outputName:
+                dsrefXML=dsrefXML+"<dataSetRef id=\"%s\" name=\"%s\" path=\"%s\" type=\"%s\"/>\n" % (outDataItem.id,outDataItem.name,outDataItem.get_file_name(),outputFormat)
+    print "dsrefFileName:"+dsrefFileName
+    primaryCollectedDatasets=param_dict["__collected_datasets__"]["primary"]
+    for primaryCollectedDataset in primaryCollectedDatasets:
+        primaryCollectedDatasetItems=primaryCollectedDatasets[primaryCollectedDataset]
+        for primaryCollectedDatasetItem in primaryCollectedDatasetItems:
+            outDataItem=primaryCollectedDatasetItems[primaryCollectedDatasetItem]
+            if outputFormat in outDataItem.extension:
+                dsrefXML=dsrefXML+"<dataSetRef id=\"%s\" name=\"%s\" path=\"%s\" type=\"%s\"/>\n" % (outDataItem.id,outDataItem.name,outDataItem.get_file_name(),outDataItem.extension)
+    dsrefXML=dsrefXML+"</dataSetRefs>\n"
+    return dsrefFileName, dsrefXML
+def writeDsRef(dsrefFileName, dsrefXML):
+    dsrefFile = open(dsrefFileName, "w", 0)
+    dsrefFile.write(dsrefXML)
+    dsrefFile.flush()
+    dsrefFile.close()
+def setSizeAndPeak(outDataItems,outputDsRefName):
+            outDataItem.dataset.file_size=None
+            outDataItem.set_size()
+            outDataItem.set_peek()
+def writeoutlist(app, inp_data, out_data, param_dict, tool, stdout, stderr):
+    outDataItems = out_data.items()
+    outDataItems = sorted(outDataItems, key=operator.itemgetter(0))
+    dsrefAcmoFileName, dsrefAcmoXML = createDsRef(outDataItems,param_dict,"acmo","acmo.csv","acmoDsRef","facit/acmo")
+    writeDsRef(dsrefAcmoFileName, dsrefAcmoXML)
+    setSizeAndPeak(outDataItems,"acmoDsRef")
+    app.model.context.flush()
Deleted: SwiftApps/swift-galaxy/swift/swift-catsn
--- SwiftApps/swift-galaxy/swift/swift-catsn	2014-01-30 15:26:30 UTC (rev 7528)
+++ SwiftApps/swift-galaxy/swift/swift-catsn	2014-01-30 23:20:58 UTC (rev 7529)
@@ -1,328 +0,0 @@
-#!/bin/bash
-#set -x
-set -e
-site=$1
-data=$2
-n=$3
-outdir=$4
-logfile=$5
-htmlfile=$6
-mkdir -p $outdir
-swift=`which swift`
-# use "here" document for configs
-cat << EOF > /tmp/catsn.swift
-type file;
-app (file o) cat (file i) {
-  cat @i stdout=@o;
-#file out[]<simple_mapper; location="outdir", prefix="f.",suffix=".out">;
-file out[]<simple_mapper; location="$outdir", prefix="f.",suffix=".txt">;
-string d=@arg("data");
-foreach j in [1:@toInt(@arg("n","1"))] {
- file data<single_file_mapper; file=d>;
- out[j] = cat(data);
-EOF
-case "$site" in
-midway )
-cat << 'EOF' > /tmp/sites.xml
-<?xml version="1.0" encoding="UTF-8"?>
-<config xmlns="http://www.ci.uchicago.edu/swift/SwiftSites">
- <pool handle="midway">
-  <execution provider="coaster" jobmanager="local:slurm"/>
-  <profile namespace="globus" key="queue">sandyb</profile>
-  <profile namespace="globus" key="jobsPerNode">16</profile>
-  <profile namespace="globus" key="maxWalltime">02:00:00</profile>
-  <profile namespace="globus" key="maxTime">7500</profile>
-  <profile namespace="globus" key="highOverAllocation">100</profile>
-  <profile namespace="globus" key="lowOverAllocation">100</profile>
-  <profile namespace="globus" key="slots">2</profile>
-  <profile namespace="globus" key="maxNodes">1</profile>
-  <profile namespace="globus" key="nodeGranularity">1</profile>
-  <profile namespace="karajan" key="jobThrottle">.31</profile>
-  <profile namespace="karajan" key="initialScore">10000</profile>
-  <workdirectory>/tmp/swift.work</workdirectory>
- </pool>
-</config>
-EOF
-cat << 'EOF' > /tmp/tc
-midway echo  echo
-midway cat   cat
-EOF
-cat << 'EOF' > /tmp/cf
-use.provider.staging=true
-wrapperlog.always.transfer=true
-execution.retries=1
-provider.staging.pin.swiftfiles=false
-sitedir.keep=true
-lazy.errors=false
-EOF
-uc3 )
-  <pool handle="uc3">
-    <execution provider="coaster" url="uc3-sub.uchicago.edu" jobmanager="ssh-cl:condor"/>
-    <!--<execution provider="coaster" jobmanager="local:condor"/>-->
-    <profile namespace="karajan" key="jobThrottle">.09</profile>
-    <profile namespace="karajan" key="initialScore">1000</profile>
-    <profile namespace="globus"  key="jobsPerNode">1</profile>
-    <profile namespace="globus"  key="maxWalltime">3600</profile>
-    <profile namespace="globus"  key="slots">1</profile>
-    <profile namespace="globus"  key="condor.Requirements">UidDomain == "osg-gk.mwt2.org"</profile>
-    <profile namespace="globus"  key="condor.+AccountingGroup">"group_friends.{env.USER}"</profile>
-    <profile namespace="globus"  key="jobType">nonshared</profile>
-    <filesystem provider="local" url="none" />
-    <!--<workdirectory>/home/maheshwari/test/catsn/swift.work</workdirectory>-->
-  </pool>
-</config>
-EOF
-uc3 echo  /bin/echo
-uc3 cat   /bin/cat
-EOF
-sitedir.keep=true
-lazy.errors=false
-EOF
-stampede )
-<pool handle="stampede">
-  <execution provider="coaster" jobmanager="gt2:gt2:slurm" url="login5.stampede.tacc.utexas.edu:2119/jobmanager-slurm"/>
-  <!--<execution provider="coaster" jobmanager="ssh-cl:slurm" url="stampede.tacc.utexas.edu"/>-->
-  <!--<filesystem provider="gsiftp" url="gsiftp://gridftp.stampede.tacc.utexas.edu:2811"/>-->
-  <filesystem provider="local"/>
-  <profile namespace="globus" key="ppn">16</profile>
-  <profile namespace="globus" key="project">TG-STA110005S</profile>
-  <profile namespace="globus" key="queue">normal</profile>
-  <profile namespace="globus" key="slurm.mail-user">ketancmaheshwari at gmail.com</profile>
-  <profile namespace="globus" key="slurm.mail-type">ALL</profile>
-  <profile namespace="globus" key="maxTime">8000</profile>
-  <profile namespace="karajan" key="jobThrottle">.15</profile>
-</pool>
-</config>
-EOF
-stampede echo echo
-stampede cat cat
-EOF
-sitedir.keep=true
-lazy.errors=false
-EOF
-localhost )
-<pool handle="localhost">
-  <execution provider="local" jobmanager="local:local"/>
-  <!--<workdirectory>/home/kcm92/powergridapps/swiftscripts/swift.work</workdirectory>-->
-  <profile namespace="karajan" key="jobThrottle">0.31</profile>
-</pool>
-</config>
-EOF
-localhost echo echo
-localhost cat cat
-EOF
-use.provider.staging=false
-sitedir.keep=true
-lazy.errors=false
-EOF
-echo "defaulting to localhost"
-  </pool>
-</config>
-EOF
-localhost cat cat
-EOF
-sitedir.keep=true
-lazy.errors=false
-EOF
-esac
-$swift -sites.file /tmp/sites.xml -tc.file /tmp/tc -config /tmp/cf /tmp/catsn.swift -n=$n -data=$data 2> std.err
-EXITCODE=$?
-swiftlog=`\ls -t *.log | head -1`
-#/tmp/plotswiftlogs $logfile 2>gnuplot.err
-cat << 'EOF' > /tmp/plotswiftlogs
-#!/bin/bash
-#usage: ./extract4plots <swift.logfile>
-SWIFTLOGFILE=$1
-#TMPDIR=`mktemp -d plotlog.XXX`
-grep -i ProgressTicker $SWIFTLOGFILE > swiftoutfile.out
-SWIFTOUTFILE=swiftoutfile.out
-#extract start time
-TMPDATE=`grep -i progress $SWIFTOUTFILE 2>/dev/null | head -n 1 | cut -f1-2 -d ' '`
-START_TIME=`date +%s -d "$TMPDATE"`
-#extract end time
-TMPDATE=`grep -i progress $SWIFTOUTFILE 2>/dev/null | tail -n 1 | cut -f1-2 -d ' '`
-END_TIME=`date +%s -d "$TMPDATE"`
-#duration
-DIFFTIME=$((END_TIME - START_TIME))
-#echo 0 > active.txt
-#echo 0 > cumulative.txt
-#extract active runs in a file
-(grep -o -i "Active:[0-9]*" $SWIFTOUTFILE 2>/dev/null | awk -F: '{print $2}' > active.txt)
-#extract successful completions in a file
-(grep -o -i "Successfully:[0-9]*" $SWIFTOUTFILE 2>/dev/null | awk -F: '{print $2}' > cumulative.txt)
-#prepare tics
-activelines=`wc -l active.txt | awk '{print $1}'`
-cumulines=`wc -l cumulative.txt | awk '{print $1}'`
-if [ $activelines -ne 0 ]
-then
-  activelinespertic=`echo "scale=5 ; $DIFFTIME / $activelines" | bc`
-fi
-seq 0 $activelinespertic $DIFFTIME > activetics.txt
-if [ $cumulines -ne 0 ]
-then
-    cumulinespertic=`echo "scale=5 ; $DIFFTIME / $cumulines" | bc`
-fi
-seq 0 $cumulinespertic $DIFFTIME > cumultics.txt
-#final plot data
-paste activetics.txt active.txt > plot_active.txt
-paste cumultics.txt cumulative.txt > plot_cumulative.txt
-cat << EOF1 > plotit.gp
-set terminal png enhanced
-set output "activeplot.png"
-set nokey
-set xlabel "Time in sec"
-set ylabel "number of active jobs"
-set title "Active jobs"
-plot "plot_active.txt" using 1:2 with line
-set output "cumulativeplot.png"
-set ylabel "number of completed jobs"
-set title "Cumulative jobs"
-plot "plot_cumulative.txt" using 1:2 with lines
-EOF1
-gnuplot plotit.gp 2>/dev/null
-#cp *.png ../
-echo `pwd`>/tmp/curdir
-echo `ls`>/tmp/dirlist
-#cd ..
-EOF
-sh /tmp/plotswiftlogs $swiftlog
-cp *.png $outdir/
-#for i in `find $outdir`
-#do
-#  lastfile=$i
-#done
-#bname=`basename $lastfile`
-cat << EOF > $htmlfile
-<!DOCTYPE HTML>
-<html xmlns="http://www.w3.org/1999/xhtml">
-<head>
-  <title>Catsn output</title>
-</head>
-<body>
-<h2>Swift run trace plots</h2>
-<a href="activeplot.png" alt="active plot">active plot</a>
-<a href="cumulativeplot.png" alt="cumulative plot">cumulative plot</a>
-<h2>Browse output of catsn application</h2>
-`for i in \`find $outdir -type f\`; do echo "<a href=\`basename $i\`>Output: \`basename $i\`</a><br/>"; done`
-</body>
-</html>
-EOF
-if [ "$EXITCODE" -ne "0" ]; then
-       cat std.err >&2
-fi
-cp std.err $logfile
-rm std.err
-exit $EXITCODE
Copied: SwiftApps/swift-galaxy/swift/swift-catsn.sh (from rev 7523, SwiftApps/swift-galaxy/swift/swift-catsn)
--- SwiftApps/swift-galaxy/swift/swift-catsn.sh	                        (rev 0)
+++ SwiftApps/swift-galaxy/swift/swift-catsn.sh	2014-01-30 23:20:58 UTC (rev 7529)
@@ -0,0 +1,276 @@
+#!/bin/bash
+#set -x
+set -e
+site=$1
+data=$2
+n=$3
+outdir=$4
+logfile=$5
+htmlfile=$6
+mkdir -p $outdir
+swift=`which swift`
+# use "here" document for configs
+cat << EOF > /tmp/catsn.swift
+type file;
+app (file o) cat (file i) {
+  cat @i stdout=@o;
+#file out[]<simple_mapper; location="outdir", prefix="f.",suffix=".out">;
+file out[]<simple_mapper; location="$outdir", prefix="f.",suffix=".txt">;
+string d=@arg("data");
+foreach j in [1:@toInt(@arg("n","1"))] {
+ file data<single_file_mapper; file=d>;
+ out[j] = cat(data);
+EOF
+case "$site" in
+midway )
+cat << 'EOF' > /tmp/sites.xml
+<?xml version="1.0" encoding="UTF-8"?>
+<config xmlns="http://www.ci.uchicago.edu/swift/SwiftSites">
+ <pool handle="midway">
+  <execution provider="coaster" url="swift.rcc.uchicago.edu" jobmanager="ssh-cl:slurm"/>
+  <profile namespace="globus" key="queue">sandyb</profile>
+  <profile namespace="globus" key="jobsPerNode">16</profile>
+  <profile namespace="globus" key="maxWalltime">02:00:00</profile>
+  <profile namespace="globus" key="maxTime">7500</profile>
+  <profile namespace="globus" key="highOverAllocation">100</profile>
+  <profile namespace="globus" key="lowOverAllocation">100</profile>
+  <profile namespace="globus" key="slots">2</profile>
+  <profile namespace="globus" key="maxNodes">1</profile>
+  <profile namespace="globus" key="nodeGranularity">1</profile>
+  <profile namespace="karajan" key="jobThrottle">.31</profile>
+  <profile namespace="karajan" key="initialScore">10000</profile>
+  <workdirectory>/tmp/swift.work</workdirectory>
+ </pool>
+</config>
+EOF
+uc3 )
+  <pool handle="uc3">
+    <execution provider="coaster" url="uc3-sub.uchicago.edu" jobmanager="ssh-cl:condor"/>
+    <!--<execution provider="coaster" jobmanager="local:condor"/>-->
+    <profile namespace="karajan" key="jobThrottle">.09</profile>
+    <profile namespace="karajan" key="initialScore">1000</profile>
+    <profile namespace="globus"  key="jobsPerNode">1</profile>
+    <profile namespace="globus"  key="maxWalltime">3600</profile>
+    <profile namespace="globus"  key="slots">1</profile>
+    <profile namespace="globus"  key="condor.Requirements">UidDomain == "osg-gk.mwt2.org"</profile>
+    <profile namespace="globus"  key="condor.+AccountingGroup">"group_friends.{env.USER}"</profile>
+    <profile namespace="globus"  key="jobType">nonshared</profile>
+    <filesystem provider="local" url="none" />
+    <!--<workdirectory>/home/maheshwari/test/catsn/swift.work</workdirectory>-->
+  </pool>
+</config>
+EOF
+stampede )
+<pool handle="stampede">
+  <execution provider="coaster" jobmanager="ssh-cl:slurm" url="stampede.tacc.utexas.edu"/>
+  <filesystem provider="local"/>
+  <profile namespace="globus" key="ppn">16</profile>
+  <profile namespace="globus" key="project">TG-STA110005S</profile>
+  <profile namespace="globus" key="queue">normal</profile>
+  <profile namespace="globus" key="slurm.mail-user">ketancmaheshwari at gmail.com</profile>
+  <profile namespace="globus" key="slurm.mail-type">ALL</profile>
+  <profile namespace="globus" key="maxTime">8000</profile>
+  <profile namespace="karajan" key="jobThrottle">.15</profile>
+</pool>
+</config>
+EOF
+localhost )
+<pool handle="localhost">
+  <execution provider="local" jobmanager="local:local"/>
+  <!--<workdirectory>/home/kcm92/powergridapps/swiftscripts/swift.work</workdirectory>-->
+  <profile namespace="karajan" key="jobThrottle">0.31</profile>
+</pool>
+</config>
+EOF
+echo "defaulting to localhost"
+  </pool>
+</config>
+EOF
+esac
+cat << 'EOF' > /tmp/cf
+use.provider.staging=true
+wrapperlog.always.transfer=true
+execution.retries=1
+provider.staging.pin.swiftfiles=false
+sitedir.keep=true
+lazy.errors=false
+EOF
+cat << 'EOF' > /tmp/tc
+localhost echo echo
+localhost cat cat
+stampede echo echo
+stampede cat cat
+uc3 echo  /bin/echo
+uc3 cat   /bin/cat
+midway echo  echo
+midway cat   cat
+EOF
+$swift -sites.file /tmp/sites.xml -tc.file /tmp/tc -config /tmp/cf /tmp/catsn.swift -n=$n -data=$data 2> std.err
+EXITCODE=$?
+swiftlog=`\ls -t *.log | head -1`
+#/tmp/plotswiftlogs $logfile 2>gnuplot.err
+cat << 'EOF' > /tmp/plotswiftlogs
+#!/bin/bash
+#usage: ./extract4plots <swift.logfile>
+SWIFTLOGFILE=$1
+#TMPDIR=`mktemp -d plotlog.XXX`
+grep -i ProgressTicker $SWIFTLOGFILE > swiftoutfile.out
+SWIFTOUTFILE=swiftoutfile.out
+#extract start time
+TMPDATE=`grep -i progress $SWIFTOUTFILE 2>/dev/null | head -n 1 | cut -f1-2 -d ' '`
+START_TIME=`date +%s -d "$TMPDATE"`
+#extract end time
+TMPDATE=`grep -i progress $SWIFTOUTFILE 2>/dev/null | tail -n 1 | cut -f1-2 -d ' '`
+END_TIME=`date +%s -d "$TMPDATE"`
+#duration
+DIFFTIME=$((END_TIME - START_TIME))
+#echo 0 > active.txt
+#echo 0 > cumulative.txt
+#extract active runs in a file
+(grep -o -i "Active:[0-9]*" $SWIFTOUTFILE 2>/dev/null | awk -F: '{print $2}' > active.txt)
+#extract successful completions in a file
+(grep -o -i "Successfully:[0-9]*" $SWIFTOUTFILE 2>/dev/null | awk -F: '{print $2}' > cumulative.txt)
+#prepare tics
+activelines=`wc -l active.txt | awk '{print $1}'`
+cumulines=`wc -l cumulative.txt | awk '{print $1}'`
+if [ $activelines -ne 0 ]
+then
+  activelinespertic=`echo "scale=5 ; $DIFFTIME / $activelines" | bc`
+fi
+seq 0 $activelinespertic $DIFFTIME > activetics.txt
+if [ $cumulines -ne 0 ]
+then
+    cumulinespertic=`echo "scale=5 ; $DIFFTIME / $cumulines" | bc`
+fi
+seq 0 $cumulinespertic $DIFFTIME > cumultics.txt
+#final plot data
+paste activetics.txt active.txt > plot_active.txt
+paste cumultics.txt cumulative.txt > plot_cumulative.txt
+cat << EOF1 > plotit.gp
+set terminal png enhanced
+set output "activeplot.png"
+set nokey
+set xlabel "Time in sec"
+set ylabel "number of active jobs"
+set title "Active jobs"
+plot "plot_active.txt" using 1:2 with line
+set output "cumulativeplot.png"
+set ylabel "number of completed jobs"
+set title "Cumulative jobs"
+plot "plot_cumulative.txt" using 1:2 with lines
+EOF1
+gnuplot plotit.gp 2>/dev/null
+#cp *.png ../
+echo `pwd`>/tmp/curdir
+echo `ls`>/tmp/dirlist
+#cd ..
+EOF
+sh /tmp/plotswiftlogs $swiftlog
+cp *.png $outdir/
+#for i in `find $outdir`
+#do
+#  lastfile=$i
+#done
+#bname=`basename $lastfile`
+cat << EOF > $htmlfile
+<!DOCTYPE HTML>
+<html xmlns="http://www.w3.org/1999/xhtml">
+<head>
+  <title>Catsn output</title>
+</head>
+<body>
+<h2>Swift run trace plots</h2>
+<a href="activeplot.png" alt="active plot">active plot</a>
+<a href="cumulativeplot.png" alt="cumulative plot">cumulative plot</a>
+<h2>Browse output of catsn application</h2>
+`for i in \`find $outdir -type f\`; do echo "<a href=\`basename $i\`>Output: \`basename $i\`</a><br/>"; done`
+</body>
+</html>
+EOF
+if [ "$EXITCODE" -ne "0" ]; then
+       cat std.err >&2
+fi
+cp std.err $logfile
+rm std.err
+exit $EXITCODE
Copied: SwiftApps/swift-galaxy/swift/swift-catsn.xml (from rev 7523, SwiftApps/swift-galaxy/swift/catsn.xml)
--- SwiftApps/swift-galaxy/swift/swift-catsn.xml	                        (rev 0)
+++ SwiftApps/swift-galaxy/swift/swift-catsn.xml	2014-01-30 23:20:58 UTC (rev 7529)
@@ -0,0 +1,22 @@
+<tool id="catsn" name="Swift catsn">
+  <description>A Swift tool to run the catsn workflow</description>
+  <command interpreter="bash">
+  swift-catsn "$site" "$data" "$n" "$html_file.files_path" "$log_file" "$html_file"
+  </command>
+  <inputs>
+    <param name="site" type="select" label="Execution Location">
+       <option value="localhost">Localhost</option>
+       <option value="midway">Midway</option>
+       <option value="uc3">UC3</option>
+       <option value="stampede">Stampede</option>
+    </param>
+    <param name="n" type="text" value="1" label="Number of tasks to run "/>
+    <param name="data" type="data" label="Input data file"/>
+  </inputs>
+  <outputs>
+     <data format="txt" name="log_file" type="data" label="Swift output" />
+     <data format="html" name="html_file" label="catsnoutput.html" />
+  </outputs>
+</tool>
Copied: SwiftApps/swift-galaxy/swift/swift-skeleton.xml (from rev 7523, SwiftApps/swift-galaxy/swift/catsn.xml)
--- SwiftApps/swift-galaxy/swift/swift-skeleton.xml	                        (rev 0)
+++ SwiftApps/swift-galaxy/swift/swift-skeleton.xml	2014-01-30 23:20:58 UTC (rev 7529)
@@ -0,0 +1,22 @@
+<tool id="skeleton(replace with an id)" name="Swift Skeleton (replace with a name)">
+  <description>A description here</description>
+  swift-skeleton.sh "$site" "$data" "$n" "$html_file.files_path" "$log_file" "$html_file"
+  </command>
+  <inputs>
+    </param>
+  </inputs>
+  <outputs>
+     <data format="txt" name="log_file" type="data" label="Standard out" />
+  </outputs>
+</tool>
Modified: SwiftApps/swift-galaxy/swift/swiftforeachlist.sh
--- SwiftApps/swift-galaxy/swift/swiftforeachlist.sh	2014-01-30 15:26:30 UTC (rev 7528)
+++ SwiftApps/swift-galaxy/swift/swiftforeachlist.sh	2014-01-30 23:20:58 UTC (rev 7529)
@@ -16,6 +16,8 @@
 listfile=$1
 shift
 logfile=$1
+shift
+outlistfile=$1
 cat << EOF > /tmp/script.swift
 type file;
@@ -60,12 +62,6 @@
 </config>
 EOF
-cat << EOF > /tmp/tc
-midway echo  echo
-midway sh /bin/sh
-midway cat   cat
-EOF
 uc3 )
@@ -93,12 +89,6 @@
 </config>
 EOF
-uc3 sh /bin/sh
-uc3 echo  /bin/echo
-uc3 cat   /bin/cat
-EOF
 stampede )
@@ -127,12 +117,6 @@
 </config>
 EOF
-stampede sh /bin/sh
-stampede echo echo
-stampede cat cat
-EOF
 localhost )
@@ -148,11 +132,6 @@
 </config>
 EOF
-localhost sh /bin/sh
-localhost cat cat
-EOF
@@ -169,12 +148,6 @@
 </config>
 EOF
-localhost cat cat
-EOF
 esac
@@ -187,9 +160,29 @@
 lazy.errors=false
 EOF
+cat << EOF > /tmp/tc
+localhost sh /bin/sh
+localhost cat cat
+stampede sh /bin/sh
+stampede echo echo
+stampede cat cat
+uc3 sh /bin/sh
+uc3 echo  /bin/echo
+uc3 cat   cat
+midway echo  echo
+midway sh /bin/sh
+midway cat   cat
+EOF
 $swift -sites.file /tmp/sites.xml -tc.file /tmp/tc -config /tmp/cf /tmp/script.swift 2>$logfile
 EXITCODE=$?
+#`for i in \`find $HOME/swift-sandbox -type f\`; do echo "\`basename $i\` $i"; done`
+cat << EOF > $outlistfile
+`for i in \`find $HOME/swift-sandbox -type f\`; do echo "$i"; done`
+EOF
        cat $logfile >&2
 fi
Modified: SwiftApps/swift-galaxy/swift/swiftforeachlist.xml
--- SwiftApps/swift-galaxy/swift/swiftforeachlist.xml	2014-01-30 15:26:30 UTC (rev 7528)
+++ SwiftApps/swift-galaxy/swift/swiftforeachlist.xml	2014-01-30 23:20:58 UTC (rev 7529)
@@ -7,6 +7,7 @@
             $executable
             $listfile
             $log_file
+            $outlist
   </command>
   <inputs>
@@ -46,9 +47,10 @@
   <outputs>
+     <data format="txt" name="outlist" type="data" label="Output list" />
   </outputs>
-  <help>
+<help>
 .. class:: warningmark
 **TIP**. A generic Swift foreach to run arbitrary executables in parallel over a list of items listed in a file.
Modified: SwiftApps/swift-galaxy/swift/swiftforeachrange.sh
--- SwiftApps/swift-galaxy/swift/swiftforeachrange.sh	2014-01-30 15:26:30 UTC (rev 7528)
+++ SwiftApps/swift-galaxy/swift/swiftforeachrange.sh	2014-01-30 23:20:58 UTC (rev 7529)
@@ -20,6 +20,8 @@
 stepsize=$1
 shift
 logfile=$1
+shift
+outlistfile=$1
 type file;
@@ -61,13 +63,6 @@
   </pool>
 </config>
 EOF
-midway echo  echo
-midway sh /bin/sh
-midway cat   cat
-EOF
 uc3 )
@@ -94,13 +89,6 @@
   </pool>
 </config>
 EOF
-uc3 sh /bin/sh
-uc3 echo  /bin/echo
-uc3 cat   /bin/cat
-EOF
 stampede )
@@ -128,13 +116,6 @@
 </pool>
 </config>
 EOF
-stampede echo echo
-stampede cat cat
-EOF
 localhost )
@@ -150,11 +131,6 @@
 </config>
 EOF
-localhost cat cat
-EOF
@@ -171,12 +147,6 @@
 </config>
 EOF
-localhost cat cat
-EOF
 esac
@@ -189,9 +159,30 @@
 lazy.errors=false
 EOF
+localhost cat cat
+uc3 sh /bin/sh
+uc3 echo  /bin/echo
+uc3 cat   /bin/cat
+stampede echo echo
+stampede cat cat
+midway echo  echo
+midway sh /bin/sh
+midway cat   cat
+EOF
 EXITCODE=$?
+EOF
        cat $logfile >&2
 fi
Modified: SwiftApps/swift-galaxy/swift/swiftforeachrange.xml
--- SwiftApps/swift-galaxy/swift/swiftforeachrange.xml	2014-01-30 15:26:30 UTC (rev 7528)
+++ SwiftApps/swift-galaxy/swift/swiftforeachrange.xml	2014-01-30 23:20:58 UTC (rev 7529)
@@ -8,7 +8,8 @@
             $rstart
             $rend
             $stepsize
-            $log_file
+            $logfile
+            $outlist
   </command>
   <inputs>
@@ -49,12 +50,16 @@
     </conditional>
   </inputs>
   <outputs>
+     <data format="txt" name="logfile" type="data" label="Swift output" />
   </outputs>
-  <code file="swiftforeachrangepp.py">
-    <hook postprocess="postprocess" />
+  <code file="postprocess.py">
+    <hook postprocess="writeoutlist" />
   </code>
-  <help>
+<help>
 **TIP**. A generic Swift foreach to run arbitrary executables in parallel over a range of numbers.
@@ -69,13 +74,13 @@
 **Example**
-Pick up an executable from the Executable list. Select the start, end and the step size values.
+Pick up an executable from the Executable list. Enter the start, end and the step size values.
 If an executable is echo.sh:
 echo $1
-Start, end and step is 0, 9 and 2, the executable will be invoked in parallel 5 times for n where n is 0 2 4 6 8:
+The start, end and step is 0, 9 and 2, the executable will be invoked in parallel 5 times for n where n is 0 2 4 6 8:
 echo n
Deleted: SwiftApps/swift-galaxy/swift/swiftforeachrangepp.py
--- SwiftApps/swift-galaxy/swift/swiftforeachrangepp.py	2014-01-30 15:26:30 UTC (rev 7528)
+++ SwiftApps/swift-galaxy/swift/swiftforeachrangepp.py	2014-01-30 23:20:58 UTC (rev 7529)
@@ -1,67 +0,0 @@
-#post processing, set build for data and add additional data to history^M
-from galaxy import datatypes, config, jobs, tools
-from galaxy.model import HistoryDatasetAssociation
-import operator
-import shutil
-import os
-import glob
-from lxml import etree
-from os.path import basename
-def createDsRef(outDataItems, param_dict, outputName, outputFormat, outputDsRefName, nameSpace):
-    dsrefXML="<?xml version=\"1.0\" ?>\n"
-    dsrefXML=dsrefXML+"<dataSetRefs xmlns=\"http://ci.uchicago.edu/galaxy-es/datasetrefs/"+nameSpace+"\" >\n"
-    dsrefFileName=""
-    for outDataName, outDataItem in outDataItems:
-        if outDataName==outputDsRefName:
-            dsrefFileName=outDataItem.get_file_name()
-        else:
-            if outDataName==outputName:
-                dsrefXML=dsrefXML+"<dataSetRef id=\"%s\" name=\"%s\" path=\"%s\" type=\"%s\"/>\n" % (outDataItem.id,outDataItem.name,outDataItem.get_file_name(),outputFormat)
-    print "dsrefFileName:"+dsrefFileName
-    primaryCollectedDatasets=param_dict["__collected_datasets__"]["primary"]
-    for primaryCollectedDataset in primaryCollectedDatasets:
-        primaryCollectedDatasetItems=primaryCollectedDatasets[primaryCollectedDataset]
-        for primaryCollectedDatasetItem in primaryCollectedDatasetItems:
-            outDataItem=primaryCollectedDatasetItems[primaryCollectedDatasetItem]
-            if outputFormat in outDataItem.extension:
-                dsrefXML=dsrefXML+"<dataSetRef id=\"%s\" name=\"%s\" path=\"%s\" type=\"%s\"/>\n" % (outDataItem.id,outDataItem.name,outDataItem.get_file_name(),outDataItem.extension)
-    dsrefXML=dsrefXML+"</dataSetRefs>\n"
-    return dsrefFileName, dsrefXML
-def writeDsRef(dsrefFileName, dsrefXML):
-    dsrefFile = open(dsrefFileName, "w",0)
-    dsrefFile.write(dsrefXML)
-    dsrefFile.flush()
-    dsrefFile.close()
-def setSizeAndPeak(outDataItems,outputDsRefName):
-            outDataItem.dataset.file_size=None
-            outDataItem.set_size()
-            outDataItem.set_peek()
-def exec_after_process(app, inp_data, out_data, param_dict, tool, stdout, stderr):
-    outDataItems = out_data.items()
-    outDataItems = sorted(outDataItems, key=operator.itemgetter(0))
-    dsrefAcmoFileName, dsrefAcmoXML = createDsRef(outDataItems,param_dict,"acmo","acmo.csv","acmoDsRef","facit/acmo")
-    writeDsRef(dsrefAcmoFileName, dsrefAcmoXML)
-    setSizeAndPeak(outDataItems,"acmoDsRef")
-    app.model.context.flush()
