[Swift-commit] r7527 - SwiftApps/heap-plot
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Wed Jan 29 19:14:51 CST 2014
Author: davidk
Date: 2014-01-29 19:14:51 -0600 (Wed, 29 Jan 2014)
New Revision: 7527
Added:
   SwiftApps/heap-plot/heap-plot.pl
Log:
heap-plot.pl
Added: SwiftApps/heap-plot/heap-plot.pl
--- SwiftApps/heap-plot/heap-plot.pl	                        (rev 0)
+++ SwiftApps/heap-plot/heap-plot.pl	2014-01-30 01:14:51 UTC (rev 7527)
@@ -0,0 +1,87 @@
+#!/usr/bin/perl -w
+use strict;
+use Time::Local;
+# Usage: ./heapplot.pl run000.log
+my $first_timestamp=0;
+# Read file
+my $filename=shift;
+open(FILE, "$filename") || die "Unable to open $filename\n";
+my @filedata = <FILE>;
+close(FILE);
+# Open file for writing
+open(FILE, ">heap-plot.dat") || die "Unable to open activityplot.dat for writing\n";
+print FILE "Time Max Crt Used\n";
+sub get_value
+   my $statement = $_[0];
+   my $value = (split /:/, $statement)[1];
+   chop($value);
+   return $value;
+sub timestamp_to_seconds
+   (my $date, my $hhmmss, my @junk) = split('\s+', $_[0]);
+   $hhmmss = (split /,/, $hhmmss)[0];
+   (my $year, my $month, my $monthday) = split('\-', $date);
+   (my $hh, my $mm, my $ss) = split(':', $hhmmss);
+   my $time = timelocal($ss, $mm, $hh, $monthday-1, $month, $year);
+   return $time;
+foreach my $line(@filedata) {
+   if( $line =~ m/HeapMax/ ) {
+      $line =~ s/HeapMax: /HeapMax:/g;
+      $line =~ s/CrtHeap: /CrtHeap:/g;
+      $line =~ s/UsedHeap: /UsedHeap:/g;
+      my @words = split('\s+', $line);
+      my $timestamp = timestamp_to_seconds($line);
+      if($first_timestamp == 0) { $first_timestamp = $timestamp; $timestamp=0; }
+      else { $timestamp = $timestamp - $first_timestamp; }
+      my $max = 0;
+      my $crt = 0;
+      my $used = 0;
+      my $active = 0;
+      foreach my $word(@words) {
+         if($word =~ /HeapMax:/)          { $max = get_value($word);    }
+         elsif($word =~ /CrtHeap:/)       { $crt = get_value($word);    }
+         elsif($word =~ /UsedHeap:/)      { $used = get_value($word);   }
+         # elsif($word =~ /Active:/)        { $active = get_value($word); }
+      # Adjust values for plotting
+      print FILE "$timestamp $max $crt $used\n";
+close(FILE);
+open(FILE, ">heap-plot.gp") || die "Unable to create heap-plot.gp";
+my $gp = <<END;
+set key autotitle columnhead
+set terminal png size 1000,1000 enhanced
+set title "Heap Plot"
+set output "heap-plot.png"
+set xlabel "Time in sec"
+set ylabel "Size in MB"
+set autoscale x
+plot "heap-plot.dat" using 0:(\$2/1048576) with lines, \\
+                  '' using 0:(\$3/1048576) with lines, \\
+                  '' using 0:(\$4/1048576) with lines
+END
+print FILE $gp;
+close(FILE);
+system("gnuplot heap-plot.gp");
+unlink("heap-plot.gp");
+unlink("heap-plot.dat");
Property changes on: SwiftApps/heap-plot/heap-plot.pl
___________________________________________________________________
Added: svn:executable
