[Swift-commit] r7487 - in trunk: . bin etc lib lib/perl
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Wed Jan 22 10:30:47 CST 2014
Author: davidk
Date: 2014-01-22 10:30:47 -0600 (Wed, 22 Jan 2014)
New Revision: 7487
Added:
   trunk/etc/templates/
Removed:
   trunk/etc/apps/
   trunk/etc/certificate/
   trunk/etc/sites/
   trunk/lib/listcoasterurls.jar
   trunk/lib/perl/SwiftConfig.pm
   trunk/lib/perl/XML/
Modified:
   trunk/bin/swift
   trunk/build.xml
   trunk/etc/swift.properties
Log:
Cleanup - remove some old files related to the old swiftrun/swiftconfig
Add templates directory, and use by default unless SWIFT_SITE_CONF is defined
Modified: trunk/bin/swift
--- trunk/bin/swift	2014-01-21 22:25:59 UTC (rev 7486)
+++ trunk/bin/swift	2014-01-22 16:30:47 UTC (rev 7487)
@@ -40,6 +40,10 @@
     fi
 fi
+if [ -z "$SWIFT_SITE_CONF" ]; then
+   export SWIFT_SITE_CONF=$SWIFT_HOME/etc/templates
+fi
 OPTIONS="$OPTIONS -Djava.endorsed.dirs=$SWIFT_HOME/lib/endorsed"
 LOCALCLASSPATH=$SWIFT_HOME/etc$CPDELIM$SWIFT_HOME/libexec
Modified: trunk/build.xml
--- trunk/build.xml	2014-01-21 22:25:59 UTC (rev 7486)
+++ trunk/build.xml	2014-01-22 16:30:47 UTC (rev 7487)
@@ -81,7 +81,6 @@
 		<copy todir="${dist.dir}/lib/perl">
 			<fileset dir="${cog.dir}/modules/${module.name}/lib/perl"/>
 		</copy>
-                <copy file="${cog.dir}/modules/${module.name}/lib/listcoasterurls.jar" todir="${dist.dir}/bin"></copy>
 		<chmod perm="+x">
 			<fileset dir="${dist.dir}/bin">
@@ -224,15 +223,9 @@
 		<copy todir="${dist.dir}/etc"
 			file="${cog.dir}/modules/${module.name}/etc/log4j.properties"
 			overwrite="true"/>
-		<copy todir="${dist.dir}/etc/sites">
-			<fileset dir="${cog.dir}/modules/${module.name}/etc/sites"/>
+		<copy todir="${dist.dir}/etc/templates">
+			<fileset dir="${cog.dir}/modules/${module.name}/etc/templates"/>
 		</copy>
-		<copy todir="${dist.dir}/etc/apps">
-			<fileset dir="${cog.dir}/modules/${module.name}/etc/apps"/>
-		</copy>
-		<copy todir="${dist.dir}/etc/certificate">
-			<fileset dir="${cog.dir}/modules/${module.name}/etc/certificate"/>
-		</copy>
 		<chmod perm="+x" file="${dist.dir}/bin/swift"/>
 		<chmod perm="+x" file="${dist.dir}/bin/swift-osg-ress-site-catalog"/>
 		<chmod perm="+x" file="${dist.dir}/libexec/cdm_broadcast.sh"/>
Modified: trunk/etc/swift.properties
--- trunk/etc/swift.properties	2014-01-21 22:25:59 UTC (rev 7486)
+++ trunk/etc/swift.properties	2014-01-22 16:30:47 UTC (rev 7487)
@@ -386,12 +386,3 @@
 # Default: true
-# Add a default definition for 'local' site
-site.local {
-   jobManager=local
-   tasksPerWorker=1
-   filesystem=local
-   workdir=$RUNDIRECTORY
-   taskThrottle=1
Deleted: trunk/lib/listcoasterurls.jar
(Binary files differ)
Deleted: trunk/lib/perl/SwiftConfig.pm
--- trunk/lib/perl/SwiftConfig.pm	2014-01-21 22:25:59 UTC (rev 7486)
+++ trunk/lib/perl/SwiftConfig.pm	2014-01-22 16:30:47 UTC (rev 7487)
@@ -1,847 +0,0 @@
-package SwiftConfig;
-use strict;
-use warnings;
-use File::Copy;
-use File::Path;
-use Pod::Usage;
-use FindBin qw($Bin);
-use lib "$FindBin::Bin/../lib/perl";   # Use libraries in $swift_home/lib/perl
-use SwiftConfig;
-use Getopt::Long;
-use File::Which qw(which where);
-use XML::Simple;
-require Exporter;
-our @ISA = qw(Exporter);
-our %EXPORT_TAGS = ( 'all' => [ qw() ] );
-our @EXPORT_OK = ( @{ $EXPORT_TAGS{'all'} } );
-our @EXPORT = qw(create_directory get_entry add_ssh remove_ssh
-update_tc_hostname update_xml write_file print_directory strip_directory
-copy_file cat_file add_application edit_application remove_application
-list_applications initialize_swiftconfig update_site_applications import_tc
-import_xml edit_profile add_to_group list_group remove_from_group
-our $VERSION = '0.01';
-# Prepare data
-my $xml = new XML::Simple();
-my @execution_providers =
-    ( "gt4", "local", "pbs", "condor", "ssh", "coaster", );
-# Create a new directory if it does not exist
-sub create_directory {
-    my $directory = $_[0];
-    if ( !-d "$directory" ) {
-        mkdir "$directory"
-            or die "Unable to create directory $directory\n";
-# Process keyboard input
-sub get_entry {
-    my ( $entry_description, $entry_value, $use_default, @allowable_values, ) = @_;
-    # If use_default is specified, automatically plug in the default value
-    if($use_default) {
-        return $entry_value;
-   if(!@allowable_values) {
-        print "$entry_description [$entry_value]: ";
-    else {
-        print "$entry_description [";
-        my $counter=0;
-        foreach my $allowable(@allowable_values) {
-            if($counter != 0) {
-                print " ";
-            if($allowable eq $entry_value) {
-                print "*$allowable";
-            else {
-                print "$allowable";
-           $counter++;
-        print "]: ";
-    my $new_value = <STDIN>;
-    chomp($new_value);
-    if ($new_value) {
-        $entry_value = $new_value;
-    # Check if value entered is valid (if valid values were passed)
-    my $is_valid = 0;
-    if (@allowable_values) {
-        foreach my $allowable (@allowable_values) {
-            if ( $allowable eq $entry_value ) {
-                $is_valid = 1;
-        if ( !$is_valid ) {
-            my $error_message = q{};
-                $error_message = $error_message . $allowable . ' ';
-            print 'Invalid value selected. Please select from: '
-                . "$error_message\n\n";
-            $entry_value = get_entry( $entry_description, $entry_value, 0,
-                @allowable_values, );
-# Add new entry to auths.default
-sub add_ssh {
-    my ( $ssh_site, $ssh_url) = @_;
-    # Open authfile
-    my $auth_file = "$ENV{'HOME'}/.ssh/auth.defaults";
-    if( -e "$auth_file") {
-        open( AUTH_FILE, "<$auth_file")
-            || die "Unable to open $auth_file for reading\n";
-    else {
-        open( AUTH_FILE, "+>$auth_file" )
-            || die "Unable to open $auth_file for read/write!\n";
-    my @auth_data = <AUTH_FILE>;
-    close(AUTH_FILE);
-    # Get existing values and modify if found
-    my $ssh_username;
-    my $ssh_password;
-    my $found = 0;
-    foreach (@auth_data) {
-        if (/username/i && /^$ssh_url/i) {
-            ( my $setting, $ssh_username, ) = split( '=', $_ );
-            chomp($ssh_username);
-            $ssh_username = get_entry( 'Username',   $ssh_username, 0);
-            $_ = "$ssh_url.username=$ssh_username\n";
-            $found = 1;
-        if (/\.password/i && /^$ssh_url/i) {
-            ( my $setting, $ssh_password, ) = split( '=', $_ );
-            chomp($ssh_password);
-            $ssh_password = get_entry( 'Password', $ssh_password, 0);
-            $_ = "$ssh_url.password=$ssh_password\n";
-            $found = 1;
-    # Add new entry if needed
-    if(!$found) {
-        $ssh_username = getlogin();
-        $ssh_username = get_entry( 'Username',   $ssh_username, 0 );
-        $ssh_password = get_entry( 'Password', '', 0);
-        # Password based authentication
-        push( @auth_data, "$ssh_url.type=password\n" );
-        push( @auth_data, "$ssh_url.username=$ssh_username\n" );
-        push( @auth_data, "$ssh_url.password=$ssh_password\n" );
-    # Write data
-    write_file( $auth_file, @auth_data );
-# Remove an entry from auth.defaults
-sub remove_ssh {
-    my ( $ssh_url, ) = @_;
-    # Open auth.defaults
-    else {
-        return;
-    close(AUTH_FILE);
-    # Remove
-        if (/^$ssh_url/i) {
-            $_ = '';
-    # Write data
-# Update TC with correct hostname
-sub update_tc_hostname {
-    my ( $tc_filename, $tc_host ) = @_;
-    # Store TC data
-    open( TC_FILESTREAM, "$tc_filename" )
-        or die("Unable to open tc file $tc_filename!");
-    my @tc_data = <TC_FILESTREAM>;
-    close(TC_FILESTREAM);
-    foreach my $line (@tc_data) {
-        # Ignore comments
-        my $first_character = substr( $line, 0, 1 );
-        if ( $first_character eq '#' ) {
-            next;
-        # Replace old entry with new entry
-        my ($line_tc_host,   $line_tc_name,     $line_tc_path,
-            $line_tc_status, $line_tc_platform, $line_tc_profile,
-        ) = split( /\s+/, $line );
-        $line =
-              "$tc_host\t"
-            . "$line_tc_name\t"
-            . "$line_tc_path\t"
-            . "$line_tc_status\t"
-            . "$line_tc_platform\t"
-            . "$line_tc_profile\n";
-    write_file( $tc_filename, @tc_data );
-# Update XML hash with values from command line
-sub update_xml {
-    # Set up data
-    my ($xml_filename, $edit_mode, $option_default) = @_;
-    # Values for edit mode
-    # 0 - Edit all
-    # 1 - All but name
-    # 2 - Customized.. to do
-    if ( !-e $xml_filename ) {
-        die "Unable to update xml file $xml_filename\n";
-    my $xml_ref = $xml->XMLin(
-        $xml_filename,
-        ForceArray => [qw(workdirectory profile)],
-        KeyAttr    => [],
-    # Handle
-    if($edit_mode == 0) {
-        $xml_ref->{handle} = get_entry( 'Site Entry Name', $xml_ref->{handle}, $option_default);
-    # Execution
-    my $initial_exprovider = $xml_ref->{execution}{provider};
-    $xml_ref->{execution}{provider} = get_entry(
-        'Execution Provider',
-        $xml_ref->{execution}{provider},
-        $option_default,
-        @execution_providers,
-    my $current_exprovider = $xml_ref->{execution}{provider};
-    # Handle changes in execution provider
-    if( $initial_exprovider ne $current_exprovider ) {
-        # Add SSH fields
-        if( $current_exprovider eq 'ssh' ) {
-            if( !$xml_ref->{execution}{url} ) {
-                $xml_ref->{execution}{url} = 'unknown';
-        # Add coaster fields
-        if( $current_exprovider eq 'coaster' ) {
-            if( !$xml_ref->{execution}{jobmanager} ) {
-                $xml_ref->{execution}{jobmanager} = 'unknown';
-            if( !$xml_ref->{execution}{url} ){
-    # Job manager
-    if ( $xml_ref->{execution}{jobmanager}) {
-                get_entry( 'Execution Job Manager',
-                $xml_ref->{execution}{jobmanager},
-                $option_default
-    # Execution URL
-    if ( $xml_ref->{execution}{url} ) {
-                get_entry( 'Execution URL',
-                            $xml_ref->{execution}{url},
-                            $option_default
-    # Grid FTP
-    if ( $xml_ref->{gridftp} ) {
-        $xml_ref->{gridftp}{url} =
-            get_entry( 'GridFTP URL', $xml_ref->{gridftp}{url}, $option_default);
-    # Work directory
-    if ( $xml_ref->{workdirectory} ) {
-        $xml_ref->{workdirectory}[0] =~ s/\$HOME/$ENV{'HOME'}/;
-	$xml_ref->{workdirectory}[0] =~ s/\$USER/$ENV{'USER'}/;
-        $xml_ref->{workdirectory} =
-            [ get_entry( 'Work Directory', $xml_ref->{workdirectory}[0], $option_default) ];
-    # Job manager
-    if ( $xml_ref->{jobmanager} ) {
-        if ( $xml_ref->{jobmanager}{universe} ) {
-            $xml_ref->{jobmanager}{universe} =
-                get_entry( 'Job Universe', $xml_ref->{jobmanager}{universe}, $option_default);
-        if ( $xml_ref->{jobmanager}{url} ) {
-            $xml_ref->{jobmanager}{url} =
-                get_entry( 'Job Manager URL', $xml_ref->{jobmanager}{url}, $option_default);
-        if ( $xml_ref->{jobmanager}{major} ) {
-            $xml_ref->{jobmanager}{major} =
-                get_entry( 'Job Major Number',
-                $xml_ref->{jobmanager}{major}, $option_default);
-        if ( $xml_ref->{jobmanager}{minor} ) {
-            $xml_ref->{jobmanager}{minor} =
-                get_entry( 'Job Minor Number',
-                $xml_ref->{jobmanager}{minor}, $option_default);
-    # Filesystem
-    if ( $xml_ref->{filesystem} ) {
-        if ( $xml_ref->{filesystem}{provider} ) {
-            $xml_ref->{filesystem}{provider} = get_entry(
-                'Filesystem Provider',
-                $xml_ref->{filesystem}{provider},
-                $option_default,
-        if ( $xml_ref->{filesystem}{url} ) {
-            $xml_ref->{filesystem}{url} =
-                get_entry( 'Filesystem URL', $xml_ref->{filesystem}{url}, $option_default);
-    # Profiles
-    foreach my $profile ( @{ $xml_ref->{profile} } ) {
-        $profile->{content} =
-            get_entry( $profile->{key}, $profile->{content}, $option_default);
-    return $xml_ref;
-# Write a file given variable and filename
-sub write_file {
-    my ( $filename, @data ) = @_;
-    open( TEMPFILESTREAM, ">$filename" )
-        or die("Unable to open $filename!\n");
-    print TEMPFILESTREAM @data;
-    close(TEMPFILESTREAM);
-# Print all files in a directory
-sub print_directory {
-    my ($directory) = @_;
-    chdir($directory)
-        || die "Unable to change directories to $directory\n";
-    my @files = <*>;
-    foreach my $file (@files) {
-        ( my $basename, my $ext ) = split( /\./, $file );
-        my @path = split( '/', $basename );
-        print "$basename\n";
-# Append one file to another
-sub cat_file {
-    my ( $src, $dst ) = @_;
-    if ( -e $dst ) {
-        open( DSTFILE, ">>$dst" ) || die "Unable to open $dst for append\n";
-    else {
-        open( DSTFILE, ">$dst" )
-            or die "Unable to open $dst for writing\n";
-    open( SRCFILE, $src ) || die "Unable to open $src for reading\n";
-    foreach my $line (<SRCFILE>) {
-        print DSTFILE $line;
-# Copy a file to a new location
-sub copy_file {
-    if ( !-e $src ) { die "Unable to access $src\n"; }
-    if ( !-e $dst ) { die "Unable to access $dst\n"; }
-    copy( $src, $dst ) or die "Unable to copy $src to $dst\n";
-# Strip directory name out of a string
-sub strip_directory {
-    my ($fullpath) = @_;
-    my @path = split( '/', $fullpath );
-    my $filename = $path[$#path];
-    return $filename;
-# Add an application
-sub add_application {
-    my ($app_filename) = @_;
-    open(APPFILE, "+<$app_filename") || die "Unable to open application file $app_filename for writing\n";
-    print "Enter name of new application: ";
-    my $app_name = <STDIN>;
-    chomp($app_name);
-    foreach(<APPFILE>){
-        my ($site, $name, $path, $status, $platform, $profile) = split(/\s+/);
-        if($name eq $app_name) {
-            print "$name already exists\n";
-            return;
-    my $app_path_guess = which("$app_name");
-    if(!$app_path_guess) {
-        $app_path_guess = "/path/to/$app_name";
-    my $app_path = get_entry("Path", $app_path_guess, 0);
-    my $app_time = get_entry("Walltime (hh:mm:ss)", "00:20:00", 0);
-    while($app_time !~ m/(\d+:\d+:\d+)/ ) {
-        print "Error: incorrect format\n";
-        $app_time = get_entry("Walltime", $1, 0);
-    print APPFILE "SWIFTCONFIGURATION\t$app_name\t$app_path\tINSTALLED\tINTEL32::LINUX\tGLOBUS::maxwalltime=\"$app_time\"\n";
-    close(APPFILE);
-    print "Added $app_name\n";
-# Remove an application
-sub remove_application {
-    open(APPFILE, "$app_filename") || die "Unable to open application file $app_filename\n";
-    my $app_to_remove = get_entry("Name of application to remove", '', 0);
-    my @app_data;
-    my $found=0;
-    foreach my $line (<APPFILE>){
-        my ($site, $name, $path, $status, $platform, $profile) = split(/\s+/, $line);
-        if($name eq $app_to_remove) {
-            $found=1;
-        else {
-            push(@app_data, $line);
-    close(APPFILE);
-    if(!$found) {
-        print "Unable to find application named $app_to_remove\n";
-        return;
-    else {
-        write_file($app_filename, @app_data);
-        print "Removed $app_to_remove\n";
-# List applications
-sub list_applications {
-    open(APPFILE, $app_filename) || die "Unable to open application file $app_filename\n";
-    my @app_data = <APPFILE>;
-    close(APPFILE);
-    my ($site, $name, $path, $status, $platform, $profile);
-    my $counter=0;
-    my $header = sprintf("\n%-15s %-30s %-35s\n", 'Command Name', 'Path', 'Profile');
-    $header .= sprintf("%-15s %-30s %-35s\n",    '------------', '----', '-------');
-    print $header;
-    foreach(@app_data) {
-        ($site, $name, $path, $status, $platform, $profile) = split(/\s+/);
-        if($name) {
-            my $nicely_formatted = sprintf("%-15s %-30s %-35s", $name, $path, $profile);
-            print "$nicely_formatted\n";
-# Edit application
-sub edit_application {
-    close(APPFILE);
-    print "Application to edit: ";
-    my $app_to_edit = <STDIN>;
-    chomp($app_to_edit);
-    my $found=0;
-        if( $name eq $app_to_edit) {
-                $found=1;
-                my $previous_name = $name;
-                # App name
-		        $name = get_entry("New application name", $name, 0);
-                if($name ne $previous_name) {
-                    $path = which("$name");
-                # Path
-                if(!$path) {
-                    $path = "/path/app";
-                $path = get_entry("New path", $path, 0);
-                # Time
-                my $time = '';
-                my $wallfound=0;
-                my $counter=0;
-                my @profiles = split(/;/, $profile);
-                foreach (@profiles) {
-                    if( m/maxwalltime=\"(\d+:\d+:\d+)\"/ig ) {
-                        $wallfound=1;
-                        my $default_time = $1;
-                        $time = get_entry("Walltime", $default_time, 0);
-                        while($time !~ m/(\d+:\d+:\d+)/ ) {
-                        s/(\d+:\d+:\d+)/$time/g;
-                if( !$wallfound ) {
-                    $time = get_entry("Time", "00:20:00", 0);
-                    push(@profiles, "GLOBUS::maxwalltime=\"$time\"");
-                $profile = join(';', @profiles);
-                $_ = "$site\t$name\t$path\t$status\t$platform\t$profile\n";
-    if(!$found) {
-        print "Unable to find application named $app_to_edit\n";
-        return;
-    else {
-        print "$app_to_edit updated\n";
-    open(APPFILE, ">$app_filename") || die "Unable to open application file $app_filename for writing\n";
-    print APPFILE @app_data;
-    close(APPFILE);
-# Initialize swiftconfig. Prepare things it needs for first run
-sub initialize_swiftconfig {
-    create_directory("$ENV{'HOME'}/.swift");
-    create_directory("$ENV{'HOME'}/.swift/sites");
-    create_directory("$ENV{'HOME'}/.swift/groups");
-    if(!-e "$ENV{'HOME'}/.swift/apps") {
-        create_directory("$ENV{'HOME'}/.swift/apps");
-        my @app_files = glob("$FindBin::Bin/../etc/apps/*.apps");
-        foreach my $app_file(@app_files) {
-            copy_file($app_file, "$ENV{'HOME'}/.swift/apps");
-# Associate application sets with a configuration
-sub update_site_applications {
-    my ($site, $use_defaults) = @_;
-    my $apps = '';
-    if(! -d "$ENV{'HOME'}/.swift/sites/$site") {
-        print "Unable to find configuration for $site\n";
-        return;
-    if(-e "$ENV{'HOME'}/.swift/sites/$site/apps") {
-        open(APPLIST, "$ENV{'HOME'}/.swift/sites/$site/apps")
-            || die "Unable to open app list $ENV{'HOME'}/.swift/sites/$site/apps";
-        my @apps_file_data = <APPLIST>;
-        close(APPLIST);
-        foreach my $current_app (@apps_file_data) {
-            chomp($current_app);
-            if($apps) {
-                $apps = "$apps $current_app";
-            else {
-                $apps = "$current_app";
-    if(!$use_defaults) {
-        my @all_available_appsets = glob("$ENV{'HOME'}/.swift/apps/*.apps");
-        print "Available application sets: ";
-        foreach(@all_available_appsets) {
-           $_ = strip_directory($_);
-           ($_, my $junk) = split('\.');
-            print "$_ ";
-        print "\n";
-    if(!$apps) {
-        $apps = "linux";
-    $apps = get_entry("Select application sets for $site", $apps, $use_defaults);
-    my @all_list = split(/ /, $apps);
-    open(APPFILE, ">$ENV{'HOME'}/.swift/sites/$site/apps")
-        || die "Unable to open $ENV{'HOME'}/.swift/sites/$site/apps for writing!\n";
-    foreach(@all_list) {
-        print APPFILE "$_\n";
-    close(APPFILE);
-        print "Successfully saved application sets for $site\n\n";
-# Import existing XML file into swiftconfig style format
-sub import_xml {
-    my ($xml_filename) = @_;
-    if(! -e $xml_filename) {
-        die "Unable to find file to import: $xml_filename\n";
-        $xml_filename,
-        ForceArray => [qw(workdirectory profile pool)],
-        KeyAttr    => "pool",
-    foreach my $pool ( @{$xml_ref->{pool}} ) {
-        if(-d "$ENV{'HOME'}/.swift/sites/$pool->{handle}") {
-            print "Configuration for $pool->{handle} already exists. Skipping\n";
-        else {
-            create_directory("$ENV{'HOME'}/.swift/sites/$pool->{handle}");
-            my $xml_out_ref = $xml->XMLout(
-                $pool,
-                RootName      => 'pool',
-                SuppressEmpty => 1,
-            write_file("$ENV{'HOME'}/.swift/sites/$pool->{handle}/sites.xml",
-                        $xml_out_ref );
-            update_site_applications($pool->{handle});
-# Import tc.data files into swiftconfig application set
-sub import_tc {
-    my ($tc_filename) = @_;
-    if(! -e $tc_filename) {
-        die "Unable to find file to import: $tc_filename\n";
-    open(TCFILE, $tc_filename) || die "Unable to open $tc_filename for reading\n";
-    my @tc_data = <TCFILE>;
-    close(TCFILE);
-    foreach(@tc_data) {
-        $site = "SWIFTCONFIGURATION";
-        if(!$name) {
-            $_ = '';
-            next;
-        my $first_character = substr( $_, 0, 1 );
-            $_ = '';
-            next;
-   print "Enter name to call this application set: ";
-   my $set_name = <STDIN>;
-   chomp($set_name);
-   if(-e "$ENV{'HOME'}/.swift/apps/$set_name.apps") {
-       print "Set named $set_name already exists\n";
-       my $yesno = get_entry("Overwrite $set_name?", "No", 0, ("yes", "no"));
-       if($yesno eq "no") {
-           return;
-   write_file("$ENV{'HOME'}/.swift/apps/$set_name.apps", @tc_data);
-   print "Successfully imported application set named $set_name\n";
-sub edit_profile {
-    my ($xml_filename, @profiles_to_edit) = @_;
-	print "Unable to edit profile on $xml_filename\n";
-	return;
-        $xml_filename,
-        KeyAttr    => [],
-	foreach my $profile_to_edit(@profiles_to_edit) {
-		if(lc($profile->{key}) eq lc($profile_to_edit)) {
-            			get_entry( $profile->{key}, $profile->{content}, 0);
-    return $xml_ref;
-sub add_to_group {
-    my ($group_filename) = @_;
-    if(!-e $group_filename) {
-        print "Unable to find file $group_filename for editing\n";
-        return;
-    open(GROUPFILE, ">>$group_filename") || die "Error opening $group_filename\n";
-    my @all_sites = glob("$ENV{'HOME'}/.swift/sites/*");
-    foreach(@all_sites) {
-    my $new_site = get_entry("Enter name of site to add", '', 0, @all_sites);
-    print GROUPFILE "$new_site\n";
-    close(GROUPFILE);
-sub list_group {
-        print "Unable to find $group_filename for editing\n";
-        return;
-    system("cat $group_filename");
-sub remove_from_group {
-        return;
-    open(GROUPFILE, $group_filename) || die "Error opening $group_filename\n";
-    my @group_data = <GROUPFILE>;
-    close(GROUPFILE);
-    my $remove_group = get_entry("Enter name of site to remove", '', 0);
-    $remove_group .= "\n";
-    my $found=0;
-    foreach(@group_data) {
-        if($_ eq $remove_group)
-            $found=1;
-            $_ = '';
-    if(!$found) {
-        print "Unable to find site $remove_group. Use 'l' to get a list\n";
-    write_file($group_filename, @group_data);
-1;
-__END__
-=head1 SwiftConfig
-SwiftConfig - Perl module for swiftconfig and swiftrun applications
-=head1 SYNOPSIS
-  use SwiftConfig;
-=head1 DESCRIPTION
-The SwiftConfig module provides a set of standard routines needed to handle
-Swift Configuration.
-create_directory(directory_name)
-    Creates a directory, handles errors
-get_entry($entry_description, $entry_value, $use_default, @allowable_values)
-    get_entry is used to get input from the user
-    $entry_description is used to describe the data to the user
-    $entry_value is the default value. If the user hits enter, it will be used
-    $use_default, if true, will set input to $entry_value without prompting
-    @allowable_values is a list of all available options for that input
-add_ssh($ssh_site, $ssh_url)
-    Add an entry to ~/.ssh/auth.defaults
-    $ssh_site is the swift configuration name
-    $ssh_url is the network name/address to connect to
-remove_ssh($ssh_url)
-    Remove an entry from ~/.ssh/auth.defaults
-    $ssh_url is the network name/address to remove
-update_tc_hostname($filename, $tc_hostname)
-    Change the site name in a tc.data file
-    $filename is the filename of the tc.data
-    $tc_hostname is the value of the new hostname
-update_xml($xml_filename, $edit_mode, $option_default)
-    Edit and update a sites.xml file
-    $xml_filename filename to edit
-    There are currently two edit modes: 0=edit everything, 1=everything but name
-    $option_default, if true, will automatically use defaults
-write_file($filename, @data)
-    Write to $filename with @data. Handle errors
-print_directory($directory)
-    List all files within a directory without paths
-cat_file($src, $dst)
-    Concatenate $src to $dst, handle errors
-copy_file($src, $dst)
-    Copy file $src to $dst, handle errors
-strip_directory($fullpath)
-    Given a string like "/foo/blah/file.txt", return "file.txt"
-add_application($filename)
-    Add an application to an application set
-remove_application($filename)
-    Remove an application from an application set
-list_applications($filename)
-    List all applications contained in $filename
-edit_application($filename)
-    Edit an application in $filename
-initialize_swiftconfig()
-    Set up swiftconig directory structure and copy required files
-update_site_applications($site, $use_defaults)
-    Associate application sets with a configuration
-    $site is the name of the configuration
-    If $use_defaults > 0, it will save without prompting
-import_xml($filename)
-    Import existing site configuration(s) from $filename
-import_tc($filename)
-    Import an application set from an existing tc.data file
-=cut
