[Swift-commit] r7474 - usertools/plotter/src/plotter
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Tue Jan 14 12:48:29 CST 2014
Author: wozniak
Date: 2014-01-14 12:48:29 -0600 (Tue, 14 Jan 2014)
New Revision: 7474
Modified:
   usertools/plotter/src/plotter/Lines.java
   usertools/plotter/src/plotter/Plots.java
   usertools/plotter/src/plotter/Util.java
Log:
New feature for drawing rectangles
Modified: usertools/plotter/src/plotter/Lines.java
--- usertools/plotter/src/plotter/Lines.java	2014-01-14 17:33:03 UTC (rev 7473)
+++ usertools/plotter/src/plotter/Lines.java	2014-01-14 18:48:29 UTC (rev 7474)
@@ -1,10 +1,12 @@
 package plotter;
+import static plotter.Util.matches;
 import gnu.getopt.Getopt;
 import java.awt.BasicStroke;
 import java.awt.Color;
+import java.awt.Graphics2D;
 import java.awt.geom.Rectangle2D;
 import java.io.*;
 import java.util.ArrayList;
@@ -144,10 +146,12 @@
        @param ylabel Y label text.
        @param output EPS filename.
        @return true/false depending if the method completed without error or not
+   * @throws UserInputException
   public static boolean plot(XYSeriesCollection collection,
-      String title, String xlabel,
-      String ylabel, String output)
+                             String title, String xlabel,
+                             String ylabel, String output)
+  throws UserInputException
     EPSDocumentGraphics2D g2d = null;
     Rectangle2D.Double rectangle = null;
@@ -182,6 +186,8 @@
     chart.draw(g2d, rectangle);
+    drawGraphics(g2d);
     try
       g2d.finish();
@@ -457,6 +463,40 @@
       renderer.setSeriesStroke(i, dottedStroke);
+  static void drawGraphics(Graphics2D g2d)
+    String s = properties.getProperty("graphics");
+    int count = Integer.parseInt(s);
+    for (int i = 0; i < count; i++)
+      String p = "graphic."+i;
+      String d = properties.getProperty(p);
+      if (d == null)
+        throw new UserInputException("no such property: " + p);
+      String[] tokens = d.split("\\s");
+      if (tokens.length == 0)
+        throw new UserInputException("property too short: " + p);
+      String shape = tokens[0];
+      if (matches(shape, "rectangle"))
+        drawRectangle(g2d, tokens);
+      else
+        throw new UserInputException("unknown shape: " + shape);
+  static void drawRectangle(Graphics2D g2d, String[] tokens)
+    Color color = Plots.string2color(tokens[1]);
+    double x0 = Integer.parseInt(tokens[2]);
+    double y0 = Integer.parseInt(tokens[3]);
+    double x1 = Integer.parseInt(tokens[4]);
+    double y1 = Integer.parseInt(tokens[5]);
+    g2d.setColor(color);
+    g2d.fill(new Rectangle2D.Double(x0, y0, x1, y1));
   static String toString(double[][] array)
     StringBuilder sb = new StringBuilder();
Modified: usertools/plotter/src/plotter/Plots.java
--- usertools/plotter/src/plotter/Plots.java	2014-01-14 17:33:03 UTC (rev 7473)
+++ usertools/plotter/src/plotter/Plots.java	2014-01-14 18:48:29 UTC (rev 7474)
@@ -1,7 +1,7 @@
 package plotter;
+import java.awt.Color;
 import java.awt.Font;
 import java.util.Properties;
 import org.jfree.chart.JFreeChart;
@@ -32,4 +32,20 @@
     result = new Font(name, Font.PLAIN, 12);
     return result;
+  static Color string2color(String s)
+    Color result = null;
+    if (s.compareToIgnoreCase("black") == 0)
+      result = Color.BLACK;
+    if (s.compareToIgnoreCase("white") == 0)
+      result = Color.WHITE;
+    if (result == null)
+      throw new UserInputException("unknown color: " + s);
+    return result;
Modified: usertools/plotter/src/plotter/Util.java
--- usertools/plotter/src/plotter/Util.java	2014-01-14 17:33:03 UTC (rev 7473)
+++ usertools/plotter/src/plotter/Util.java	2014-01-14 18:48:29 UTC (rev 7474)
@@ -72,6 +72,15 @@
     return sb.toString();
+  public static boolean matches(String s1, String s2)
+    assert(s1 != null);
+    assert(s2 != null);
+    if (s1.compareToIgnoreCase(s2) == 0)
+      return true;
+    return false;
   public static void fatal(String s)
     System.err.println(s);
