[Swift-commit] r7607 - branches/release-0.94/docs/siteguide
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Mon Feb 17 18:57:08 CST 2014
Author: davidk
Date: 2014-02-17 18:57:08 -0600 (Mon, 17 Feb 2014)
New Revision: 7607
Modified:
   branches/release-0.94/docs/siteguide/osdc
Log:
Removed redundant redundancy
Modified: branches/release-0.94/docs/siteguide/osdc
--- branches/release-0.94/docs/siteguide/osdc	2014-02-18 00:52:46 UTC (rev 7606)
+++ branches/release-0.94/docs/siteguide/osdc	2014-02-18 00:57:08 UTC (rev 7607)
@@ -12,7 +12,7 @@
 The headnode should have Swift and Java available. The easiest way to do this is to have a copy
 of those packages available in /glusterfs/users/$USER, and have those directories in your $PATH.
-Set the environment variable $SWIFT_USERHOME variable to /glusterfs/users/<yourusername>.
+Set the environment variable $SWIFT_USERHOME to /glusterfs/users/<yourusername>.
 Use the following sites.xml:
