[Swift-commit] r7604 - SwiftApps/swift-galaxy/swift
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Mon Feb 17 14:00:49 CST 2014
Author: ketan
Date: 2014-02-17 14:00:49 -0600 (Mon, 17 Feb 2014)
New Revision: 7604
Added:
   SwiftApps/swift-galaxy/swift/swiftforeachtest.sh
Modified:
   SwiftApps/swift-galaxy/swift/swiftforeach.xml
   SwiftApps/swift-galaxy/swift/swiftforeachlist.sh
Log:
adding test dir
Modified: SwiftApps/swift-galaxy/swift/swiftforeach.xml
--- SwiftApps/swift-galaxy/swift/swiftforeach.xml	2014-02-17 19:43:49 UTC (rev 7603)
+++ SwiftApps/swift-galaxy/swift/swiftforeach.xml	2014-02-17 20:00:49 UTC (rev 7604)
@@ -13,41 +13,64 @@
     <command interpreter="bash">
     #if $rangeorlist.rl == "rng"
-    swiftforeachrange.sh
-    $site
-    $interpret
-    $exec
-    $rangeorlist.rngstart
-    $rangeorlist.rend
-    $rangeorlist.stepsize
-    $outloc
-    $logfile
-    $outlist
-    #for $a in $stringarg
-    ${a.stringargname}
-    #end for
-    #for $a in $filearg
-    ${a.fileargname}
-    #end for
+        swiftforeachrange.sh
+        $site
+        $interpret
+        $exec
+        $rangeorlist.rngstart
+        $rangeorlist.rend
+        $rangeorlist.stepsize
+        $outloc
+        $logfile
+        $outlist
+        #for $a in $stringarg
+            ${a.stringargname}
+        #end for
+        #for $a in $filearg
+            ${a.fileargname}
+        #end for
+    #elif $rangeorlist.rl == "lst"
+        swiftforeachlist.sh
+        $site
+        $interpret
+        $exec
+        $rangeorlist.listfile
+        $outloc
+        $logfile
+        $outlist
+        #end for
+            ${a.fileargname}
+        #end for
     #else
-    swiftforeachlist.sh
-    $site
-    $interpret
-    $exec
-    $rangeorlist.listfile
-    $outloc
-    $logfile
-    $outlist
-    #end for
-    ${a.fileargname}
-    #end for
+        swiftforeachtest.sh
+        $site
+        $interpret
+        $exec
+        $rangeorlist.rend
+        $outloc
+        $logfile
+        $outlist
+        #end for
+            ${a.fileargname}
+        #end for
     #end if
     </command>
+       #if $swiftargs.mode == "advanced"
+       #for $sa in $swiftarg
+          ${sa.swiftargname}
+       #end for
+       #end if
     <inputs>
         <param name="site" type="select" multiple="true" label="Execution Location" help="Multi-select list - hold the appropriate key while clicking to select multiple items">
             <option value="localhost">Localhost</option>
@@ -72,6 +95,7 @@
         <param name="rl" type="select" label="Select range or list">
         <option value="rng">numeric range</option>
         <option value="lst">items list</option>
+        <option value="tst">dry test</option>
         </param>
         <when value="rng">
@@ -98,26 +122,17 @@
             <sanitizer sanitize="False" />
         </param>
-        <conditional name="configuration">
-            <param name="mode" type="select" label="Swift configuration">
-                <option value="default">default configuration</option>
-                <option value="advanced">advanced configuration</option>
+        <conditional name="swiftargs">
+            <param name="mode" type="select" label="Swift commandline arguments">
+                <option value="default">no additional arguments (default)</option>
+                <option value="advanced">add commandline arguments</option>
             </param>
             <when value="default">
             </when>
             <when value="advanced">
-                <param name="remoteurl" size="50" type="text" value="midway.swift.rcc.uchicago.edu" label="remote url" help="remote resource to run jobs on"></param>
-                <param name="throttle" size="5" type="float" value="0.07" label="job throttle" help="number of parallel jobs to run"></param>
-                <param name="project" type="text" value="TG-STA110005S" label="Project allocation" help="name/code of project"></param>
-                <param name="slots" size="5" type="integer" value="1" label="slots" help="number of scheduler jobs"></param>
-                <param name="queue" size="5" type="text" value="normal" label="queue" help="queue to run jobs on"></param>
-                <param name="nodes" size="5" type="integer" value="1" label="nodes" help="number of nodes requested"></param>
-                <param name="nodegranularity" size="5" type="integer" value="1" label="node granularity" help="node granularity"></param>
-                <param name="jobspernode" size="5" type="integer" value="8" label="jobs per node" help="number of jobs per node requested"></param>
-                <param name="ppn" size="5" type="integer" value="8" label="ppn" help="processes per node requested"></param>
-                <param name="walltime" size="5" type="text" value="00:10:00" label="Job walltime" help="time in hh:mm:ss to request to scheduler for this job"></param>
-                <param name="maxtime" size="5" type="integer" value="700" label="application maxtime" help="Application maxtime in seconds for this job"></param>
+            <repeat name="swiftarg" title="swiftarg">
+            <param name="swiftargname" type="text" label="swiftarg" />
+            </repeat>
             </when>
         </conditional>
     </inputs>
Modified: SwiftApps/swift-galaxy/swift/swiftforeachlist.sh
--- SwiftApps/swift-galaxy/swift/swiftforeachlist.sh	2014-02-17 19:43:49 UTC (rev 7603)
+++ SwiftApps/swift-galaxy/swift/swiftforeachlist.sh	2014-02-17 20:00:49 UTC (rev 7604)
@@ -34,7 +34,7 @@
 fileargs=()
 while [ $# -gt 0 ] ; do
-    fileargs+=("\"$1\"")
+  fileargs+=("\"$1\"")
   shift
 done
@@ -91,7 +91,7 @@
 $swift -sites.file $wdir/sites.xml -tc.file $wdir/tc -config $wdir/cf $wdir/script.swift 2>$logfile
 EXITCODE=$?
-#`for i in \`find $HOME/swift-sandbox -type f\`; do echo "\`basename $i\` $i"; done`
+`for i in \`find $HOME/swift-sandbox -type f\`; do echo "\`basename $i\` $i"; done`
 cat << EOF > $outlistfile
 `for i in $(find $outloc -type f -iname "*.out"); do echo "$i"; done`
 EOF
Added: SwiftApps/swift-galaxy/swift/swiftforeachtest.sh
--- SwiftApps/swift-galaxy/swift/swiftforeachtest.sh	                        (rev 0)
+++ SwiftApps/swift-galaxy/swift/swiftforeachtest.sh	2014-02-17 20:00:49 UTC (rev 7604)
@@ -0,0 +1,3 @@
+#!/bin/bash
+echo $@ > /tmp/args.txt
Property changes on: SwiftApps/swift-galaxy/swift/swiftforeachtest.sh
___________________________________________________________________
Added: svn:executable
