[Swift-commit] r7599 - trunk/bin
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Sun Feb 16 13:45:40 CST 2014
Author: davidk
Date: 2014-02-16 13:45:40 -0600 (Sun, 16 Feb 2014)
New Revision: 7599
Modified:
   trunk/bin/swiftrun
Log:
Some fixes for config.rundir=false
Start run directories at run001 instead of run000
Some case sensitivity fixes
Modified: trunk/bin/swiftrun
--- trunk/bin/swiftrun	2014-02-16 19:44:27 UTC (rev 7598)
+++ trunk/bin/swiftrun	2014-02-16 19:45:40 UTC (rev 7599)
@@ -348,14 +348,22 @@
       swiftquit "Error: Missing value for property \"$property_input\"";
-   $key = lc($key);
+   if( $key !~ m/^app\./) { $key = lc($key); }
    $value =~ s/^\s+//g;
    if($key eq "sites") { $key = "site"; }
-   $value =~ s/\$(\w+)/$ENV{$1}/g;
    $properties{ $key } = $value;
+# Replace environment variables in properties
+sub env_replace {
+   foreach my $key (sort keys %properties) {
+      my $value = $properties{$key};
+      $value =~ s/\$(\w+)/$ENV{$1}/g;
+      $properties{$key} = $value;
 # Getopt::Long can't accept dots in arguments, work around to make things easy
 foreach my $arg(@ARGV) {
    $arg =~ s/sites.file/sitesfile/g;
@@ -386,7 +394,7 @@
 # Create/increment run directory
-my $run_number = 0;
+my $run_number = 1;
 my @run_directories = <run[0-9][0-9][0-9]>;
 if(@run_directories) {
@@ -395,12 +403,6 @@
    $run_number++;
-$run_directory = getcwd() . "/" . sprintf "run%03s", $run_number;
-$ENV{RUNDIRECTORY} = "$run_directory";
-if(!$option_listconfig) {
-   mkdir($run_directory) || &swiftquit("Unable to create run directory $run_directory");
 # Set @sites array from comma separated list of sites
 if(defined($option_siteslist)) {
    @sites = split(',', $option_siteslist);
@@ -441,7 +443,6 @@
             &record_property( $prefix . ".$_" );
       else {
          &record_property($_);
@@ -462,15 +463,26 @@
    exit;
+# Determine run directory situation
 if(!defined($properties{"config.rundirs"}) || $properties{"config.rundirs"} ne "false") {
+   $run_directory = getcwd() . "/" . sprintf "run%03s", $run_number;
+   if(!$option_listconfig) {
+      mkdir($run_directory) || &swiftquit("Unable to create run directory $run_directory");
    @new_swift_args = ("-Dscript.dir=$run_directory/scripts");
    push(@new_swift_args, "-Drestart.log.name=$run_directory/restart.log");
    push(@new_swift_args, "-swiftoutlog=$run_directory/swift.out");
    push(@new_swift_args, "-runid " . basename($run_directory));
    push(@new_swift_args, "-Ddebug.dir.prefix=" . basename($run_directory) . "/");
    push(@new_swift_args, sprintf( "-logfile $run_directory/run%03s.log", $run_number ));
+} else {
+   $run_directory = getcwd();
+$ENV{RUNDIRECTORY} = "$run_directory";
+&env_replace();
 # Write swift configuration files
 &write_sites("sites.xml") if defined( $option_siteslist ) || defined($properties{site});
 &write_apps("apps")    if !defined( $option_tcfile ) && ( defined( $option_siteslist ) || defined($properties{site}));
