[Swift-commit] r7597 - trunk/docs/userguide
davidk at ci.uchicago.edu davidk at ci.uchicago.edu
Sun Feb 16 10:44:22 CST 2014
Author: davidk
Date: 2014-02-16 10:44:22 -0600 (Sun, 16 Feb 2014)
New Revision: 7597
Modified:
   trunk/docs/userguide/configuration
Log:
Info about config.rundirs
Modified: trunk/docs/userguide/configuration
--- trunk/docs/userguide/configuration	2014-02-16 16:15:23 UTC (rev 7596)
+++ trunk/docs/userguide/configuration	2014-02-16 16:44:22 UTC (rev 7597)
@@ -314,6 +314,14 @@
 |Name|Valid Values|Default Value|Description
+|config.rundirs
+|true, false
+|true
+|By default, Swift will generate a run directory that contains logs, scheduler submit scripts,
+|debug directories, and other files associated with a particular Swift run. Setting this value
+|to false disables the creation of run directories and causes all logs and directories to be
+|created in the current working directory.
 |execution.retries
 |Positive integer
 |2
