[Swift-commit] r7582 - SwiftApps/swift-galaxy/swift
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Mon Feb 10 15:53:00 CST 2014
Author: ketan
Date: 2014-02-10 15:52:59 -0600 (Mon, 10 Feb 2014)
New Revision: 7582
Removed:
   SwiftApps/swift-galaxy/swift/data.txt
   SwiftApps/swift-galaxy/swift/datlist.txt
Modified:
   SwiftApps/swift-galaxy/swift/swiftforeach.xml
   SwiftApps/swift-galaxy/swift/swiftforeachlist.sh
Log:
allow file as argument
Deleted: SwiftApps/swift-galaxy/swift/data.txt
--- SwiftApps/swift-galaxy/swift/data.txt	2014-02-07 20:32:46 UTC (rev 7581)
+++ SwiftApps/swift-galaxy/swift/data.txt	2014-02-10 21:52:59 UTC (rev 7582)
@@ -1,7508 +0,0 @@
-2013-08-27 01:13:50,544+0000 DEBUG Loader setting: sites.file to: /tmp/sites.xml
-2013-08-27 01:13:50,546+0000 DEBUG Loader setting: tc.file to: /tmp/tc
-2013-08-27 01:13:50,546+0000 INFO  Loader VERSION Swift trunk swift-r7005 cog-r3767
-2013-08-27 01:13:50,546+0000 INFO  Loader RUN_ID 20130827-0113-r1k3cjmc
-2013-08-27 01:13:50,547+0000 INFO  Loader ARGUMENTS [-sites.file, /tmp/sites.xml, -tc.file, /tmp/tc, -config, /tmp/cf, /tmp/inference4galaxy.swift, -batch=20]
-2013-08-27 01:13:50,547+0000 INFO  Loader MAX_HEAP 954466304
-2013-08-27 01:13:50,547+0000 INFO  Loader GLOBUS_HOSTNAME swift.rcc.uchicago.edu
-2013-08-27 01:13:50,547+0000 INFO  Loader CWD /scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/.
-2013-08-27 01:13:50,547+0000 DEBUG Loader SWIFT_CONFIGURATION Swift configuration ([/tmp/cf]): {throttle.score.job.factor=4, throttle.file.operations=8, throttle.host.submit=2, pgraph.node.options=color="seagreen", style="filled", wrapper.parameter.mode=args, provenance.log=false, throttle.submit=4, ticker.prefix=Progress:  time:, provider.staging.pin.swiftfiles=false, clustering.enabled=false, replication.min.queue.time=60, sites.file=/tmp/sites.xml, cdm.broadcast.mode=file, kickstart.enabled=maybe, wrapperlog.always.transfer=true, caching.algorithm=LRU, use.provider.staging=true, use.wrapper.staging=true, status.mode=files, clustering.min.time=60, ticker.date.format=, kickstart.always.transfer=false, file.gc.enabled=true, throttle.transfers=4, execution.retries=1, sitedir.keep=true, pgraph.graph.options=splines="compound", rankdir="TB", replication.enabled=false, clustering.queue.delay=4, pgraph=false, mapping.checker=on, wrapper.invocation.mode=absolute, tc.file=/tmp/tc,
 replication.limit=3, lazy.errors=false}
-2013-08-27 01:13:50,547+0000 INFO  Loader SITES_FILE /tmp/sites.xml
-2013-08-27 01:13:50,548+0000 DEBUG textfiles BEGIN SITES:
-<config>
-  <pool handle="midway">
-    <execution provider="coaster" jobmanager="local:slurm"/>
-    <profile namespace="globus" key="queue">sandyb</profile>
-    <profile namespace="globus" key="jobsPerNode">16</profile>
-    <profile namespace="globus" key="maxWalltime">02:00:00</profile>
-    <profile namespace="globus" key="maxTime">7500</profile>
-    <profile namespace="globus" key="highOverAllocation">100</profile>
-    <profile namespace="globus" key="lowOverAllocation">100</profile>
-    <profile namespace="globus" key="slots">2</profile>
-    <profile namespace="globus" key="maxNodes">1</profile>
-    <profile namespace="globus" key="nodeGranularity">1</profile>
-    <profile namespace="karajan" key="jobThrottle">.31</profile>
-    <profile namespace="karajan" key="initialScore">10000</profile>
-    <workdirectory>/tmp/swift.work</workdirectory>
-  </pool>
-</config>
-2013-08-27 01:13:50,548+0000 DEBUG textfiles END SITES:
-2013-08-27 01:13:50,548+0000 INFO  Loader TC_FILE /tmp/tc
-2013-08-27 01:13:50,548+0000 DEBUG textfiles BEGIN TC:
-midway echo  echo
-midway cat   cat
-midway gensample   /home/maheshwari/powergridapps/bin/gensample.py
-midway runampl   /home/maheshwari/powergridapps/bin/run_ampl.py
-midway runampl_l /home/maheshwari/powergridapps/bin/run_ampl_l.py
-midway runampl_u /home/maheshwari/powergridapps/bin/run_ampl_u.py
-2013-08-27 01:13:50,548+0000 DEBUG textfiles END TC:
-2013-08-27 01:13:50,549+0000 DEBUG textfiles BEGIN SWIFTSCRIPT:
-type file;
-app ( file _obj_out, file _xhat_out1, file _xhat_out2, file _ampl_res, file _out)
-    ampl_app (  int _s,
-                int _fix_x,
-                file _stoch_model,
-                file _illinois,
-                file _edrevised_model,
-                file _ascii_data,
-                file _print_results,
-                file _wind_data
-     runampl _s _fix_x @_stoch_model @_xhat_out1 @_xhat_out2 @_obj_out @_illinois @_edrevised_model @_ascii_data @_print_results @_ampl_res @_wind_data stdout=@_out;
-app (file _obj_out, file _ampl_l_res, file _out) ampl_app_L (
-                 int _s,
-                 int _fix_x,
-                 file _illinois,
-                file _ascii_data,
-    runampl_l _s _fix_x @_stoch_model @_obj_out @_illinois @_edrevised_model @_ascii_data @_print_results @_ampl_l_res stdout=@_out;
-app (file _obj_out, file _ampl_u_res, file _out) ampl_app_U (
-    int _s,
-    int _fix_x,
-    file _xhat,
-    file _illinois,
-    file _ascii_data,
-    file _wind_data
-    runampl_u _s _fix_x @_stoch_model @_xhat @_obj_out @_illinois @_edrevised_model @_ascii_data @_print_results @_ampl_u_res @_wind_data stdout=@_out;
-file stoch_model<"/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run">;
-file edrevised_model<"/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod">;
-file ascii_data<"/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc">;
-file print_results<"/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc">;
-file illinois<"/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz">;
-file wind_data<"/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat">;
-file out[] <simple_mapper; location="outdir", prefix="ampl",suffix=".out">;
-file obj_out[] <simple_mapper; location="obj_outdir", prefix="obj_ampl",suffix=".out">;
-file ampl_res[] <simple_mapper; location="Results", prefix="ampl_res",suffix=".out">;
-file xhat_out1[] <simple_mapper; location="outdir", prefix="xhat1",suffix=".out">;
-file xhat_out2[] <simple_mapper; location="outdir", prefix="xhat2",suffix=".out">;
-file out_l[][][] <simple_mapper; location="outdir", prefix="out_l", suffix=".out">;
-file obj_out_l[][][] <simple_mapper; location="obj_outdir", prefix="obj_out_l", suffix=".out">;
-file ampl_l_res[][][] <simple_mapper; location="Results", prefix="ampl_res_l", suffix=".out">;
-file xhat_out_l1[][][] <simple_mapper; location="outdir", prefix="xhat_l1",suffix=".out">;
-file xhat_out_l2[][][] <simple_mapper; location="outdir", prefix="xhat_l2",suffix=".out">;
-file out_u[][][] <simple_mapper; location="outdir", prefix="out_u", suffix=".out">;
-file obj_out_u[][][] <simple_mapper; location="obj_outdir", prefix="obj_out_u", suffix=".out">;
-file ampl_u_res[][][] <simple_mapper; location="Results", prefix="ampl_res_u", suffix=".out">;
-#file upper_out[][][] <simple_mapper; location="outdir", prefix="upper",suffix=".out">;
-#file lower_out[][][] <simple_mapper; location="outdir", prefix="lower",suffix=".out">;
-int nS[] = [10]; //number of scenario sweeps
-int Batch = @toInt(@arg("batch", "20"));
-foreach S, idxs in nS{
-(obj_out[idxs], xhat_out1[idxs], xhat_out2[idxs], ampl_res[idxs], out[idxs]) = ampl_app (S, 0, stoch_model, illinois, edrevised_model, ascii_data, print_results, wind_data);
-foreach B, idxb in [10:Batch:10]{
-  foreach k in [0:B]{
-     (obj_out_l[idxs][idxb][k], xhat_out_l1[idxs][idxb][k], xhat_out_l2[idxs][idxb][k], ampl_l_res[idxs][idxb][k], out_l[idxs][idxb][k]) = ampl_app (S, 0, stoch_model, illinois, edrevised_model, ascii_data, print_results, wind_data);
-    (obj_out_u[idxs][idxb][k], ampl_u_res[idxs][idxb][k], out_u[idxs][idxb][k]) = ampl_app_U(S, 1, stoch_model, xhat_out1[idxs], illinois, edrevised_model, ascii_data, print_results, wind_data);
-2013-08-27 01:13:50,549+0000 DEBUG textfiles END SWIFTSCRIPT:
-2013-08-27 01:13:50,549+0000 INFO  Loader /tmp/inference4galaxy.swift: source file is new. Recompiling.
-2013-08-27 01:13:50,549+0000 DEBUG Loader kmlversion is >acc037ee-2fa6-4e7c-a365-1d291ab1f8a6-no-provenance<
-2013-08-27 01:13:50,549+0000 DEBUG Loader build version is >acc037ee-2fa6-4e7c-a365-1d291ab1f8a6-no-provenance<
-2013-08-27 01:13:51,281+0000 INFO  Warnings Warning: The @ syntax for function invocation is deprecated
-2013-08-27 01:13:51,848+0000 INFO  Loader RUN_START
-2013-08-27 01:13:51,850+0000 INFO  SwiftExecutor swift.home = /home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/..
-2013-08-27 01:13:51,860+0000 INFO  swift Using sites file: /tmp/sites.xml
-2013-08-27 01:13:51,886+0000 INFO  swift Using tc.data: /tmp/tc
-2013-08-27 01:13:51,956+0000 INFO  SiteCatalogParser [Error] sites.xml, line 1, col 9: cvc-elt.1: Cannot find the declaration of element 'config'.
-2013-08-27 01:13:51,983+0000 INFO  AbstractScheduler Setting resources to: {midway=midway}
-2013-08-27 01:13:51,986+0000 INFO  swift Swift trunk swift-r7005 cog-r3767
-2013-08-27 01:13:51,987+0000 INFO  swift RUNID id=run:20130827-0113-r1k3cjmc
-2013-08-27 01:13:52,006+0000 INFO  RuntimeStats$ProgressTicker
-2013-08-27 01:13:52,020+0000 INFO  CreateArray CREATEARRAY START array=dataset:20130827-0113-jpj1ff9e:720000000001
-2013-08-27 01:13:52,020+0000 INFO  CreateArray CREATEARRAY MEMBER array=dataset:20130827-0113-jpj1ff9e:720000000001 index=0 member=dataset:20130827-0113-jpj1ff9e:720000000002
-2013-08-27 01:13:52,020+0000 INFO  CreateArray CREATEARRAY COMPLETED array=dataset:20130827-0113-jpj1ff9e:720000000001
-2013-08-27 01:13:52,020+0000 INFO  AbstractDataNode All partial closes for Batch:int = 20 - Closed have happened. Closing fully.
-2013-08-27 01:13:52,022+0000 INFO  AbstractDataNode All partial closes for nS:int[int] - Closed have happened. Closing fully.
-2013-08-27 01:13:52,023+0000 DEBUG swift FOREACH_IT_START line=73 thread=R-42-0
-2013-08-27 01:13:52,023+0000 DEBUG swift SCOPE thread=R-42-0
-2013-08-27 01:13:52,023+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0x2 name=ampl_app
-2013-08-27 01:13:52,026+0000 DEBUG swift FOREACH_IT_START line=77 thread=R-42-0-1-0
-2013-08-27 01:13:52,026+0000 DEBUG swift SCOPE thread=R-42-0-1-0
-2013-08-27 01:13:52,026+0000 DEBUG swift FOREACH_IT_START line=77 thread=R-42-0-1x2
-2013-08-27 01:13:52,026+0000 DEBUG swift SCOPE thread=R-42-0-1x2
-2013-08-27 01:13:52,026+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1-0x2
-2013-08-27 01:13:52,026+0000 DEBUG swift SCOPE thread=R-42-0-1-0x2
-2013-08-27 01:13:52,026+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1x2-0
-2013-08-27 01:13:52,026+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1-0-1
-2013-08-27 01:13:52,026+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1x3
-2013-08-27 01:13:52,026+0000 DEBUG swift SCOPE thread=R-42-0-1-0-1
-2013-08-27 01:13:52,026+0000 DEBUG swift SCOPE thread=R-42-0-1x3
-2013-08-27 01:13:52,026+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1x2-2
-2013-08-27 01:13:52,026+0000 DEBUG swift SCOPE thread=R-42-0-1x2-0
-2013-08-27 01:13:52,026+0000 DEBUG swift SCOPE thread=R-42-0-1x2-2
-2013-08-27 01:13:52,026+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1x2-3
-2013-08-27 01:13:52,026+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1-0-4
-2013-08-27 01:13:52,026+0000 DEBUG swift SCOPE thread=R-42-0-1x2-3
-2013-08-27 01:13:52,026+0000 DEBUG swift SCOPE thread=R-42-0-1-0-4
-2013-08-27 01:13:52,026+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1-0-3
-2013-08-27 01:13:52,027+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1x2-5
-2013-08-27 01:13:52,027+0000 DEBUG swift SCOPE thread=R-42-0-1x2-5
-2013-08-27 01:13:52,027+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1-0-6
-2013-08-27 01:13:52,027+0000 DEBUG swift SCOPE thread=R-42-0-1-0-6
-2013-08-27 01:13:52,027+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1x2-6
-2013-08-27 01:13:52,027+0000 DEBUG swift SCOPE thread=R-42-0-1x2-6
-2013-08-27 01:13:52,027+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1-0-7
-2013-08-27 01:13:52,027+0000 DEBUG swift SCOPE thread=R-42-0-1-0-7
-2013-08-27 01:13:52,027+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1x2-7
-2013-08-27 01:13:52,027+0000 DEBUG swift SCOPE thread=R-42-0-1x2-7
-2013-08-27 01:13:52,027+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1-0-8
-2013-08-27 01:13:52,027+0000 DEBUG swift SCOPE thread=R-42-0-1-0-8
-2013-08-27 01:13:52,027+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1-0x3 name=ampl_app
-2013-08-27 01:13:52,027+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1-0-1x2 name=ampl_app_U
-2013-08-27 01:13:52,027+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1x4 name=ampl_app_U
-2013-08-27 01:13:52,027+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1x2-8
-2013-08-27 01:13:52,027+0000 DEBUG swift SCOPE thread=R-42-0-1x2-8
-2013-08-27 01:13:52,027+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1-0-1-0 name=ampl_app
-2013-08-27 01:13:52,027+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1x3-0 name=ampl_app
-2013-08-27 01:13:52,027+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1x2-0-1 name=ampl_app_U
-2013-08-27 01:13:52,027+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1x2-0x2 name=ampl_app
-2013-08-27 01:13:52,027+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1-0-9
-2013-08-27 01:13:52,027+0000 DEBUG swift SCOPE thread=R-42-0-1-0-9
-2013-08-27 01:13:52,027+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1x2-9
-2013-08-27 01:13:52,027+0000 DEBUG swift SCOPE thread=R-42-0-1x2-9
-2013-08-27 01:13:52,027+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1-0-10
-2013-08-27 01:13:52,026+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1-0-2
-2013-08-27 01:13:52,027+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1x2-2-1 name=ampl_app_U
-2013-08-27 01:13:52,027+0000 DEBUG swift SCOPE thread=R-42-0-1-0-2
-2013-08-27 01:13:52,027+0000 DEBUG swift SCOPE thread=R-42-0-1-0-10
-2013-08-27 01:13:52,027+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1x2-3-1 name=ampl_app_U
-2013-08-27 01:13:52,027+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1x2-10
-2013-08-27 01:13:52,027+0000 DEBUG swift SCOPE thread=R-42-0-1x2-10
-2013-08-27 01:13:52,027+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1x2-11
-2013-08-27 01:13:52,027+0000 DEBUG swift SCOPE thread=R-42-0-1x2-11
-2013-08-27 01:13:52,028+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1x2-3-0 name=ampl_app
-2013-08-27 01:13:52,028+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1-0-4-1 name=ampl_app_U
-2013-08-27 01:13:52,028+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1x2-12
-2013-08-27 01:13:52,028+0000 DEBUG swift SCOPE thread=R-42-0-1x2-12
-2013-08-27 01:13:52,028+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1x2-5-1 name=ampl_app_U
-2013-08-27 01:13:52,028+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1-0-4-0 name=ampl_app
-2013-08-27 01:13:52,028+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1x2-5-0 name=ampl_app
-2013-08-27 01:13:52,028+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1-0-6-0 name=ampl_app
-2013-08-27 01:13:52,028+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1x2-13
-2013-08-27 01:13:52,028+0000 DEBUG swift SCOPE thread=R-42-0-1x2-13
-2013-08-27 01:13:52,028+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1-0-6-1 name=ampl_app_U
-2013-08-27 01:13:52,028+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1x2-14
-2013-08-27 01:13:52,028+0000 DEBUG swift SCOPE thread=R-42-0-1x2-14
-2013-08-27 01:13:52,028+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1x2-6-0 name=ampl_app
-2013-08-27 01:13:52,029+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1-0x2-1 name=ampl_app_U
-2013-08-27 01:13:52,029+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1x2-15
-2013-08-27 01:13:52,029+0000 DEBUG swift SCOPE thread=R-42-0-1x2-15
-2013-08-27 01:13:52,029+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1x2-16
-2013-08-27 01:13:52,029+0000 DEBUG swift SCOPE thread=R-42-0-1x2-16
-2013-08-27 01:13:52,029+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1x2-17
-2013-08-27 01:13:52,029+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1-0-7-1 name=ampl_app_U
-2013-08-27 01:13:52,029+0000 DEBUG swift SCOPE thread=R-42-0-1x2-17
-2013-08-27 01:13:52,029+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1x2-18
-2013-08-27 01:13:52,029+0000 DEBUG swift SCOPE thread=R-42-0-1x2-18
-2013-08-27 01:13:52,029+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1x2-19
-2013-08-27 01:13:52,029+0000 DEBUG swift SCOPE thread=R-42-0-1x2-19
-2013-08-27 01:13:52,029+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1x2-20
-2013-08-27 01:13:52,029+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1x2-7-1 name=ampl_app_U
-2013-08-27 01:13:52,029+0000 DEBUG swift SCOPE thread=R-42-0-1x2-20
-2013-08-27 01:13:52,029+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1x2-7-0 name=ampl_app
-2013-08-27 01:13:52,027+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1x2-2-0 name=ampl_app
-2013-08-27 01:13:52,027+0000 DEBUG swift SCOPE thread=R-42-0-1-0-3
-2013-08-27 01:13:52,026+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1-0-5
-2013-08-27 01:13:52,026+0000 DEBUG swift FOREACH_IT_START line=78 thread=R-42-0-1x2-4
-2013-08-27 01:13:52,029+0000 DEBUG swift SCOPE thread=R-42-0-1-0-5
-2013-08-27 01:13:52,029+0000 DEBUG swift SCOPE thread=R-42-0-1x2-4
-2013-08-27 01:13:52,030+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1-0-8-1 name=ampl_app_U
-2013-08-27 01:13:52,030+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1x2-6-1 name=ampl_app_U
-2013-08-27 01:13:52,030+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1x2-8-1 name=ampl_app_U
-2013-08-27 01:13:52,030+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1x2-8-0 name=ampl_app
-2013-08-27 01:13:52,030+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1-0-2-1 name=ampl_app_U
-2013-08-27 01:13:52,030+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1-0-10-1 name=ampl_app_U
-2013-08-27 01:13:52,030+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1x2-10-0 name=ampl_app
-2013-08-27 01:13:52,030+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1x2-10-1 name=ampl_app_U
-2013-08-27 01:13:52,030+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1-0-9-0 name=ampl_app
-2013-08-27 01:13:52,030+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1-0-10-0 name=ampl_app
-2013-08-27 01:13:52,030+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1x2-11-0 name=ampl_app
-2013-08-27 01:13:52,031+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1x2-12-0 name=ampl_app
-2013-08-27 01:13:52,031+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1x2-13-0 name=ampl_app
-2013-08-27 01:13:52,031+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1-0-9-1 name=ampl_app_U
-2013-08-27 01:13:52,031+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1x2-14-0 name=ampl_app
-2013-08-27 01:13:52,032+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1x2-15-0 name=ampl_app
-2013-08-27 01:13:52,032+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1-0-2-0 name=ampl_app
-2013-08-27 01:13:52,032+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1x2-9-0 name=ampl_app
-2013-08-27 01:13:52,032+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1-0-7-0 name=ampl_app
-2013-08-27 01:13:52,032+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1x2-11-1 name=ampl_app_U
-2013-08-27 01:13:52,032+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1x2-15-1 name=ampl_app_U
-2013-08-27 01:13:52,032+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1x2-16-0 name=ampl_app
-2013-08-27 01:13:52,032+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1-0-8-0 name=ampl_app
-2013-08-27 01:13:52,033+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1x2-17-1 name=ampl_app_U
-2013-08-27 01:13:52,033+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1x2-17-0 name=ampl_app
-2013-08-27 01:13:52,033+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1x2-18-1 name=ampl_app_U
-2013-08-27 01:13:52,033+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1x2-18-0 name=ampl_app
-2013-08-27 01:13:52,033+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1x2-19-1 name=ampl_app_U
-2013-08-27 01:13:52,033+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1x2-20-1 name=ampl_app_U
-2013-08-27 01:13:52,033+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1x2-19-0 name=ampl_app
-2013-08-27 01:13:52,033+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1-0-3-1 name=ampl_app_U
-2013-08-27 01:13:52,034+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1-0-5-1 name=ampl_app_U
-2013-08-27 01:13:52,034+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1x2-4-1 name=ampl_app_U
-2013-08-27 01:13:52,034+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1-0-3-0 name=ampl_app
-2013-08-27 01:13:52,034+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1-0-5-0 name=ampl_app
-2013-08-27 01:13:52,034+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1x2-4-0 name=ampl_app
-2013-08-27 01:13:52,035+0000 DEBUG swift PROCEDURE line=3 thread=R-42-0-1x2-20-0 name=ampl_app
-2013-08-27 01:13:52,035+0000 INFO  GlobalSubmitQueue No global submit throttle set. Using default (1024)
-2013-08-27 01:13:52,036+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1x2-16-1 name=ampl_app_U
-2013-08-27 01:13:52,036+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1x2-9-1 name=ampl_app_U
-2013-08-27 01:13:52,036+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1x2-14-1 name=ampl_app_U
-2013-08-27 01:13:52,036+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1x2-13-1 name=ampl_app_U
-2013-08-27 01:13:52,036+0000 DEBUG swift PROCEDURE line=29 thread=R-42-0-1x2-12-1 name=ampl_app_U
-2013-08-27 01:13:52,037+0000 INFO  LateBindingScheduler jobs queued: 6
-2013-08-27 01:13:52,039+0000 INFO  LateBindingScheduler jobs queued: 1
-2013-08-27 01:13:52,039+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-6cztedel thread=R-42-0-1x2-3-0 host=midway replicationGroup=null
-2013-08-27 01:13:52,039+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-7cztedel thread=R-42-0-1x2-0x2 host=midway replicationGroup=null
-2013-08-27 01:13:52,039+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-bcztedel thread=R-42-0-1x2-8-0 host=midway replicationGroup=null
-2013-08-27 01:13:52,039+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-9cztedel thread=R-42-0-1x2-7-0 host=midway replicationGroup=null
-2013-08-27 01:13:52,039+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-ccztedel thread=R-42-0-1x2-10-0 host=midway replicationGroup=null
-2013-08-27 01:13:52,039+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-fcztedel thread=R-42-0-1-0-9-0 host=midway replicationGroup=null
-2013-08-27 01:13:52,039+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-ecztedel thread=R-42-0-1x2-12-0 host=midway replicationGroup=null
-2013-08-27 01:13:52,039+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-gcztedel thread=R-42-0x2 host=midway replicationGroup=null
-2013-08-27 01:13:52,039+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-5cztedel thread=R-42-0-1x3-0 host=midway replicationGroup=null
-2013-08-27 01:13:52,039+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-acztedel thread=R-42-0-1-0x3 host=midway replicationGroup=null
-2013-08-27 01:13:52,039+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-dcztedel thread=R-42-0-1-0-10-0 host=midway replicationGroup=null
-2013-08-27 01:13:52,040+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-8cztedel thread=R-42-0-1x2-2-0 host=midway replicationGroup=null
-2013-08-27 01:13:52,040+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-hcztedel thread=R-42-0-1x2-13-0 host=midway replicationGroup=null
-2013-08-27 01:13:52,040+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-icztedel thread=R-42-0-1x2-14-0 host=midway replicationGroup=null
-2013-08-27 01:13:52,040+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-jcztedel thread=R-42-0-1x2-9-0 host=midway replicationGroup=null
-2013-08-27 01:13:52,040+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-kcztedel thread=R-42-0-1-0-2-0 host=midway replicationGroup=null
-2013-08-27 01:13:52,040+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-lcztedel thread=R-42-0-1x2-16-0 host=midway replicationGroup=null
-2013-08-27 01:13:52,040+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-ncztedel thread=R-42-0-1-0-4-0 host=midway replicationGroup=null
-2013-08-27 01:13:52,040+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-ocztedel thread=R-42-0-1x2-11-0 host=midway replicationGroup=null
-2013-08-27 01:13:52,040+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-pcztedel thread=R-42-0-1x2-18-0 host=midway replicationGroup=null
-2013-08-27 01:13:52,040+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-rcztedel thread=R-42-0-1-0-8-0 host=midway replicationGroup=null
-2013-08-27 01:13:52,040+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-qcztedel thread=R-42-0-1-0-1-0 host=midway replicationGroup=null
-2013-08-27 01:13:52,040+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-scztedel thread=R-42-0-1-0-3-0 host=midway replicationGroup=null
-2013-08-27 01:13:52,040+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-mcztedel thread=R-42-0-1x2-15-0 host=midway replicationGroup=null
-2013-08-27 01:13:52,041+0000 DEBUG swift JOB_START jobid=runampl-gcztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat10000.out, outdir/xhat20000.out, obj_outdir/obj_ampl0000.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res0000.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/g/runampl-gcztedel host=midway
-2013-08-27 01:13:52,041+0000 DEBUG swift JOB_START jobid=runampl-dcztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0000.0010.out, outdir/xhat_l20000_0000.0010.out, obj_outdir/obj_out_l0000_0000.0010.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0000.0010.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/d/runampl-dcztedel host=midway
-2013-08-27 01:13:52,041+0000 DEBUG swift JOB_START jobid=runampl-ccztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0010.out, outdir/xhat_l20000_0001.0010.out, obj_outdir/obj_out_l0000_0001.0010.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0010.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/c/runampl-ccztedel host=midway
-2013-08-27 01:13:52,041+0000 DEBUG swift JOB_START jobid=runampl-8cztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0002.out, outdir/xhat_l20000_0001.0002.out, obj_outdir/obj_out_l0000_0001.0002.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0002.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/8/runampl-8cztedel host=midway
-2013-08-27 01:13:52,041+0000 DEBUG swift JOB_START jobid=runampl-9cztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0007.out, outdir/xhat_l20000_0001.0007.out, obj_outdir/obj_out_l0000_0001.0007.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0007.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/9/runampl-9cztedel host=midway
-2013-08-27 01:13:52,041+0000 DEBUG swift JOB_START jobid=runampl-hcztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0013.out, outdir/xhat_l20000_0001.0013.out, obj_outdir/obj_out_l0000_0001.0013.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0013.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/h/runampl-hcztedel host=midway
-2013-08-27 01:13:52,041+0000 DEBUG swift JOB_START jobid=runampl-kcztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0000.0002.out, outdir/xhat_l20000_0000.0002.out, obj_outdir/obj_out_l0000_0000.0002.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0000.0002.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/k/runampl-kcztedel host=midway
-2013-08-27 01:13:52,041+0000 DEBUG swift JOB_START jobid=runampl-mcztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0015.out, outdir/xhat_l20000_0001.0015.out, obj_outdir/obj_out_l0000_0001.0015.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0015.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/m/runampl-mcztedel host=midway
-2013-08-27 01:13:52,041+0000 DEBUG swift JOB_START jobid=runampl-lcztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0016.out, outdir/xhat_l20000_0001.0016.out, obj_outdir/obj_out_l0000_0001.0016.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0016.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/l/runampl-lcztedel host=midway
-2013-08-27 01:13:52,041+0000 DEBUG swift JOB_START jobid=runampl-7cztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0000.out, outdir/xhat_l20000_0001.0000.out, obj_outdir/obj_out_l0000_0001.0000.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0000.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/7/runampl-7cztedel host=midway
-2013-08-27 01:13:52,041+0000 DEBUG swift JOB_START jobid=runampl-6cztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0003.out, outdir/xhat_l20000_0001.0003.out, obj_outdir/obj_out_l0000_0001.0003.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0003.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/6/runampl-6cztedel host=midway
-2013-08-27 01:13:52,041+0000 DEBUG swift JOB_START jobid=runampl-fcztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0000.0009.out, outdir/xhat_l20000_0000.0009.out, obj_outdir/obj_out_l0000_0000.0009.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0000.0009.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/f/runampl-fcztedel host=midway
-2013-08-27 01:13:52,041+0000 DEBUG swift JOB_START jobid=runampl-acztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0000.0000.out, outdir/xhat_l20000_0000.0000.out, obj_outdir/obj_out_l0000_0000.0000.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0000.0000.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/a/runampl-acztedel host=midway
-2013-08-27 01:13:52,041+0000 DEBUG swift JOB_START jobid=runampl-scztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0000.0003.out, outdir/xhat_l20000_0000.0003.out, obj_outdir/obj_out_l0000_0000.0003.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0000.0003.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/s/runampl-scztedel host=midway
-2013-08-27 01:13:52,041+0000 DEBUG swift JOB_START jobid=runampl-ncztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0000.0004.out, outdir/xhat_l20000_0000.0004.out, obj_outdir/obj_out_l0000_0000.0004.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0000.0004.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/n/runampl-ncztedel host=midway
-2013-08-27 01:13:52,041+0000 DEBUG swift JOB_START jobid=runampl-jcztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0009.out, outdir/xhat_l20000_0001.0009.out, obj_outdir/obj_out_l0000_0001.0009.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0009.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/j/runampl-jcztedel host=midway
-2013-08-27 01:13:52,041+0000 DEBUG swift JOB_START jobid=runampl-qcztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0000.0001.out, outdir/xhat_l20000_0000.0001.out, obj_outdir/obj_out_l0000_0000.0001.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0000.0001.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/q/runampl-qcztedel host=midway
-2013-08-27 01:13:52,041+0000 DEBUG swift JOB_START jobid=runampl-rcztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0000.0008.out, outdir/xhat_l20000_0000.0008.out, obj_outdir/obj_out_l0000_0000.0008.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0000.0008.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/r/runampl-rcztedel host=midway
-2013-08-27 01:13:52,041+0000 DEBUG swift JOB_START jobid=runampl-5cztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0001.out, outdir/xhat_l20000_0001.0001.out, obj_outdir/obj_out_l0000_0001.0001.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0001.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/5/runampl-5cztedel host=midway
-2013-08-27 01:13:52,041+0000 DEBUG swift JOB_START jobid=runampl-ecztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0012.out, outdir/xhat_l20000_0001.0012.out, obj_outdir/obj_out_l0000_0001.0012.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0012.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/e/runampl-ecztedel host=midway
-2013-08-27 01:13:52,041+0000 DEBUG swift JOB_START jobid=runampl-bcztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0008.out, outdir/xhat_l20000_0001.0008.out, obj_outdir/obj_out_l0000_0001.0008.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0008.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/b/runampl-bcztedel host=midway
-2013-08-27 01:13:52,041+0000 DEBUG swift JOB_START jobid=runampl-ocztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0011.out, outdir/xhat_l20000_0001.0011.out, obj_outdir/obj_out_l0000_0001.0011.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0011.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/o/runampl-ocztedel host=midway
-2013-08-27 01:13:52,041+0000 DEBUG swift JOB_START jobid=runampl-icztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0014.out, outdir/xhat_l20000_0001.0014.out, obj_outdir/obj_out_l0000_0001.0014.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0014.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/i/runampl-icztedel host=midway
-2013-08-27 01:13:52,041+0000 DEBUG swift JOB_START jobid=runampl-pcztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0018.out, outdir/xhat_l20000_0001.0018.out, obj_outdir/obj_out_l0000_0001.0018.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0018.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/p/runampl-pcztedel host=midway
-2013-08-27 01:13:52,056+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-tcztedel thread=R-42-0-1x2-17-0 host=midway replicationGroup=null
-2013-08-27 01:13:52,056+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-xcztedel thread=R-42-0-1x2-6-0 host=midway replicationGroup=null
-2013-08-27 01:13:52,056+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-ycztedel thread=R-42-0-1x2-4-0 host=midway replicationGroup=null
-2013-08-27 01:13:52,056+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-1dztedel thread=R-42-0-1x2-19-0 host=midway replicationGroup=null
-2013-08-27 01:13:52,056+0000 DEBUG swift JOB_START jobid=runampl-tcztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0017.out, outdir/xhat_l20000_0001.0017.out, obj_outdir/obj_out_l0000_0001.0017.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0017.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/t/runampl-tcztedel host=midway
-2013-08-27 01:13:52,056+0000 DEBUG swift JOB_START jobid=runampl-xcztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0006.out, outdir/xhat_l20000_0001.0006.out, obj_outdir/obj_out_l0000_0001.0006.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0006.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/x/runampl-xcztedel host=midway
-2013-08-27 01:13:52,056+0000 DEBUG swift JOB_START jobid=runampl-ycztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0004.out, outdir/xhat_l20000_0001.0004.out, obj_outdir/obj_out_l0000_0001.0004.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0004.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/y/runampl-ycztedel host=midway
-2013-08-27 01:13:52,056+0000 DEBUG swift JOB_START jobid=runampl-1dztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0019.out, outdir/xhat_l20000_0001.0019.out, obj_outdir/obj_out_l0000_0001.0019.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0019.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/1/runampl-1dztedel host=midway
-2013-08-27 01:13:52,056+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-ucztedel thread=R-42-0-1-0-7-0 host=midway replicationGroup=null
-2013-08-27 01:13:52,056+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-vcztedel thread=R-42-0-1-0-5-0 host=midway replicationGroup=null
-2013-08-27 01:13:52,056+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-zcztedel thread=R-42-0-1x2-5-0 host=midway replicationGroup=null
-2013-08-27 01:13:52,056+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-0dztedel thread=R-42-0-1-0-6-0 host=midway replicationGroup=null
-2013-08-27 01:13:52,057+0000 DEBUG swift JOB_START jobid=runampl-ucztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0000.0007.out, outdir/xhat_l20000_0000.0007.out, obj_outdir/obj_out_l0000_0000.0007.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0000.0007.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/u/runampl-ucztedel host=midway
-2013-08-27 01:13:52,057+0000 DEBUG swift JOB_START jobid=runampl-vcztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0000.0005.out, outdir/xhat_l20000_0000.0005.out, obj_outdir/obj_out_l0000_0000.0005.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0000.0005.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/v/runampl-vcztedel host=midway
-2013-08-27 01:13:52,057+0000 DEBUG swift JOB_START jobid=runampl-0dztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0000.0006.out, outdir/xhat_l20000_0000.0006.out, obj_outdir/obj_out_l0000_0000.0006.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0000.0006.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/0/runampl-0dztedel host=midway
-2013-08-27 01:13:52,057+0000 DEBUG swift JOB_START jobid=runampl-zcztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0005.out, outdir/xhat_l20000_0001.0005.out, obj_outdir/obj_out_l0000_0001.0005.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0005.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/z/runampl-zcztedel host=midway
-2013-08-27 01:13:52,089+0000 INFO  LocalService Started local service: 128.135.112.73:50000
-2013-08-27 01:13:52,094+0000 INFO  BootstrapService Socket bound. URL is http://swift.rcc.uchicago.edu:50001
-2013-08-27 01:13:52,124+0000 INFO  Settings Local contacts: [http://128.135.112.73:50003, http://172.25.181.1:50003, http://10.50.181.1:50003]
-2013-08-27 01:13:52,126+0000 INFO  CoasterService Started local service: http://128.135.112.73:50003
-2013-08-27 01:13:52,126+0000 INFO  CoasterService Reserving channel for registration
-2013-08-27 01:13:52,141+0000 INFO  MetaChannel MetaChannel [context: cpipe, boundTo: null] binding to cpipe://1
-2013-08-27 01:13:52,142+0000 INFO  MetaChannel MetaChannel [context: spipe, boundTo: null] binding to spipe://1
-2013-08-27 01:13:52,142+0000 INFO  CoasterService Sending registration
-2013-08-27 01:13:52,145+0000 INFO  MetaChannel Trying to re-bind current channel
-2013-08-27 01:13:52,146+0000 INFO  RequestHandler Handler(tag: 1, REGISTER) unregistering (send)
-2013-08-27 01:13:52,146+0000 INFO  CoasterService Registration complete
-2013-08-27 01:13:52,146+0000 INFO  CoasterService Started coaster service: http://128.135.112.73:50002
-2013-08-27 01:13:52,148+0000 INFO  RequestHandler Handler(tag: 1, CONFIGSERVICE) unregistering (send)
-2013-08-27 01:13:52,160+0000 INFO  BlockQueueProcessor Starting... id=0827-1301520
-2013-08-27 01:13:52,163+0000 INFO  RequestHandler Handler(tag: 3, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,164+0000 INFO  RequestHandler Handler(tag: 2, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,165+0000 INFO  RequestHandler Handler(tag: 4, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,166+0000 INFO  RequestHandler Handler(tag: 5, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,167+0000 INFO  RequestHandler Handler(tag: 6, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,167+0000 INFO  BlockQueueProcessor
-Settings {
-	slots = 2
-	jobsPerNode = 16
-	workersPerNode = 16
-	nodeGranularity = 1
-	allocationStepSize = 0.1
-	maxNodes = 1
-	lowOverallocation = 100.0
-	highOverallocation = 100.0
-	overallocationDecayFactor = 0.001
-	spread = 0.9
-	reserve = 60.000s
-	maxtime = 7500
-	remoteMonitorEnabled = false
-	internalHostname = 10.50.181.1
-	hookClass = null
-	workerManager = block
-	workerLoggingLevel = NONE
-	workerLoggingDirectory = DEFAULT
-	ldLibraryPath = null
-	workerCopies = null
-	directory = null
-	useHashBang = null
-	parallelism = 0.01
-	coresPerNode = 1
-	attributes = {queue=sandyb}
-2013-08-27 01:13:52,167+0000 INFO  BlockQueueProcessor Jobs in holding queue: 2
-2013-08-27 01:13:52,167+0000 INFO  BlockQueueProcessor Time estimate for holding queue (seconds): 2
-2013-08-27 01:13:52,168+0000 INFO  BlockQueueProcessor Allocating blocks for a total walltime of: 2s
-2013-08-27 01:13:52,168+0000 INFO  BlockQueueProcessor 	 Considering: Job(id:1 7200.000s)
-2013-08-27 01:13:52,168+0000 INFO  BlockQueueProcessor 	  Max Walltime (seconds):   7200
-2013-08-27 01:13:52,168+0000 INFO  RequestHandler Handler(tag: 7, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,168+0000 INFO  BlockQueueProcessor 	  Time estimate (seconds):  7440
-2013-08-27 01:13:52,168+0000 INFO  BlockQueueProcessor 	  Total for this new Block (est. seconds): 1
-2013-08-27 01:13:52,168+0000 INFO  RequestHandler Handler(tag: 8, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,169+0000 INFO  RequestHandler Handler(tag: 9, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,170+0000 INFO  RequestHandler Handler(tag: 11, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,170+0000 INFO  BlockQueueProcessor index: 1, last: 0, holding.size(): 2
-2013-08-27 01:13:52,170+0000 INFO  BlockQueueProcessor Queued: 2 jobs to new Block
-2013-08-27 01:13:52,170+0000 INFO  BlockQueueProcessor index: 1, last: 0, ii: 2, holding.size(): 2
-2013-08-27 01:13:52,170+0000 INFO  Block Starting block: workers=16, walltime=7440.000s
-2013-08-27 01:13:52,171+0000 INFO  RequestHandler Handler(tag: 10, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,172+0000 INFO  RequestHandler Handler(tag: 12, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,172+0000 INFO  RemoteLogHandler BLOCK_REQUESTED id=0827-1301520-000000, cores=16, coresPerWorker=1, walltime=7440
-2013-08-27 01:13:52,172+0000 INFO  RequestHandler Handler(tag: 2, RLOG) unregistering (send)
-2013-08-27 01:13:52,172+0000 INFO  RequestHandler Handler(tag: 13, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,173+0000 INFO  BlockTaskSubmitter Queuing block Block 0827-1301520-000000 (16x7440.000s) for submission
-2013-08-27 01:13:52,173+0000 INFO  BlockQueueProcessor Added 2 jobs to new blocks
-2013-08-27 01:13:52,173+0000 INFO  BlockTaskSubmitter Submitting block Block 0827-1301520-000000 (16x7440.000s)
-2013-08-27 01:13:52,173+0000 INFO  BlockQueueProcessor Committed 10 new jobs
-2013-08-27 01:13:52,173+0000 INFO  ExecutionTaskHandler provider=slurm
-2013-08-27 01:13:52,173+0000 INFO  RequestHandler Handler(tag: 14, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,174+0000 INFO  RequestHandler Handler(tag: 15, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,175+0000 INFO  RequestHandler Handler(tag: 17, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,176+0000 INFO  RequestHandler Handler(tag: 16, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,176+0000 INFO  Block Block task status changed: Submitting
-2013-08-27 01:13:52,177+0000 INFO  RequestHandler Handler(tag: 18, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,177+0000 INFO  RequestHandler Handler(tag: 19, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,178+0000 INFO  RequestHandler Handler(tag: 20, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,179+0000 INFO  RequestHandler Handler(tag: 21, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,180+0000 INFO  RequestHandler Handler(tag: 22, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,180+0000 INFO  RequestHandler Handler(tag: 23, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,181+0000 INFO  RequestHandler Handler(tag: 24, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,182+0000 INFO  RequestHandler Handler(tag: 25, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,182+0000 INFO  RequestHandler Handler(tag: 26, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,183+0000 INFO  RequestHandler Handler(tag: 27, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,183+0000 INFO  RequestHandler Handler(tag: 28, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,184+0000 INFO  RequestHandler Handler(tag: 29, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,184+0000 INFO  RequestHandler Handler(tag: 30, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,185+0000 INFO  RequestHandler Handler(tag: 31, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,185+0000 INFO  RequestHandler Handler(tag: 32, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,185+0000 INFO  RequestHandler Handler(tag: 33, SUBMITJOB) unregistering (send)
-2013-08-27 01:13:52,191+0000 DEBUG AbstractExecutor Writing Slurm script to /home/maheshwari/.globus/scripts/Slurm3927061060097759195.submit
-2013-08-27 01:13:52,192+0000 DEBUG AbstractExecutor Wrote Slurm script to /home/maheshwari/.globus/scripts/Slurm3927061060097759195.submit
-2013-08-27 01:13:52,192+0000 DEBUG AbstractExecutor Command line: sbatch /home/maheshwari/.globus/scripts/Slurm3927061060097759195.submit
-2013-08-27 01:13:52,208+0000 DEBUG AbstractExecutor sbatch done (exit code 0)
-2013-08-27 01:13:52,208+0000 DEBUG AbstractExecutor Waiting for output from sbatch
-2013-08-27 01:13:52,208+0000 DEBUG AbstractExecutor Output from sbatch is: "Submitted batch job 5212616"
-2013-08-27 01:13:52,208+0000 DEBUG AbstractExecutor Submitted job with id '5212616'
-2013-08-27 01:13:52,209+0000 INFO  Block Block task status changed: Submitted
-2013-08-27 01:13:52,459+0000 INFO  AbstractQueuePoller Actively monitored: 0, New: 1, Done: 0
-2013-08-27 01:13:53,006+0000 INFO  RuntimeStats$ProgressTicker   Selecting site:1  Submitted:32
-2013-08-27 01:13:53,333+0000 INFO  BlockQueueProcessor Jobs in holding queue: 16
-2013-08-27 01:13:53,333+0000 INFO  BlockQueueProcessor Time estimate for holding queue (seconds): 18
-2013-08-27 01:13:53,333+0000 INFO  BlockQueueProcessor Allocating blocks for a total walltime of: 18s
-2013-08-27 01:13:53,333+0000 INFO  BlockQueueProcessor 	 Considering: Job(id:31 7200.000s)
-2013-08-27 01:13:53,333+0000 INFO  BlockQueueProcessor 	  Max Walltime (seconds):   7200
-2013-08-27 01:13:53,333+0000 INFO  BlockQueueProcessor 	  Time estimate (seconds):  7440
-2013-08-27 01:13:53,333+0000 INFO  BlockQueueProcessor 	  Total for this new Block (est. seconds): 15
-2013-08-27 01:13:53,333+0000 INFO  BlockQueueProcessor index: 15, last: 0, holding.size(): 16
-2013-08-27 01:13:53,334+0000 INFO  BlockQueueProcessor Queued: 16 jobs to new Block
-2013-08-27 01:13:53,334+0000 INFO  BlockQueueProcessor index: 15, last: 0, ii: 16, holding.size(): 16
-2013-08-27 01:13:53,334+0000 INFO  Block Starting block: workers=16, walltime=7440.000s
-2013-08-27 01:13:53,334+0000 INFO  RemoteLogHandler BLOCK_REQUESTED id=0827-1301520-000001, cores=16, coresPerWorker=1, walltime=7440
-2013-08-27 01:13:53,334+0000 INFO  BlockTaskSubmitter Queuing block Block 0827-1301520-000001 (16x7440.000s) for submission
-2013-08-27 01:13:53,334+0000 INFO  RequestHandler Handler(tag: 3, RLOG) unregistering (send)
-2013-08-27 01:13:53,334+0000 INFO  BlockQueueProcessor Added 16 jobs to new blocks
-2013-08-27 01:13:53,334+0000 INFO  BlockTaskSubmitter Submitting block Block 0827-1301520-000001 (16x7440.000s)
-2013-08-27 01:13:53,334+0000 INFO  ExecutionTaskHandler provider=slurm
-2013-08-27 01:13:53,334+0000 INFO  Block Block task status changed: Submitting
-2013-08-27 01:13:53,345+0000 DEBUG AbstractExecutor Writing Slurm script to /home/maheshwari/.globus/scripts/Slurm3983017732998933676.submit
-2013-08-27 01:13:53,345+0000 DEBUG AbstractExecutor Wrote Slurm script to /home/maheshwari/.globus/scripts/Slurm3983017732998933676.submit
-2013-08-27 01:13:53,345+0000 DEBUG AbstractExecutor Command line: sbatch /home/maheshwari/.globus/scripts/Slurm3983017732998933676.submit
-2013-08-27 01:13:53,357+0000 DEBUG AbstractExecutor sbatch done (exit code 0)
-2013-08-27 01:13:53,357+0000 DEBUG AbstractExecutor Waiting for output from sbatch
-2013-08-27 01:13:53,357+0000 DEBUG AbstractExecutor Output from sbatch is: "Submitted batch job 5212617"
-2013-08-27 01:13:53,357+0000 DEBUG AbstractExecutor Submitted job with id '5212617'
-2013-08-27 01:13:53,357+0000 INFO  Block Block task status changed: Submitted
-2013-08-27 01:13:54,007+0000 INFO  RuntimeStats$ProgressTicker   Selecting site:1  Submitted:32
-2013-08-27 01:13:55,007+0000 INFO  RuntimeStats$ProgressTicker   Selecting site:1  Submitted:32
-2013-08-27 01:13:56,007+0000 INFO  RuntimeStats$ProgressTicker   Selecting site:1  Submitted:32
-2013-08-27 01:13:57,007+0000 INFO  RuntimeStats$ProgressTicker   Selecting site:1  Submitted:32
-2013-08-27 01:13:57,472+0000 INFO  AbstractQueuePoller Actively monitored: 1, New: 1, Done: 0
-2013-08-27 01:13:58,008+0000 INFO  RuntimeStats$ProgressTicker   Selecting site:1  Submitted:32
-2013-08-27 01:13:59,008+0000 INFO  RuntimeStats$ProgressTicker   Selecting site:1  Submitted:32
-2013-08-27 01:13:59,349+0000 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-2013-08-27 01:13:59,353+0000 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 10.50.182.128:49546]
-2013-08-27 01:13:59,354+0000 INFO  LocalTCPService Received registration: blockid = 0827-1301520-000001, url = midway384
-2013-08-27 01:13:59,354+0000 INFO  MetaChannel MetaChannel [context: worker-1, boundTo: null] binding to TCPChannel [type: server, contact: 10.50.182.128:49546]
-2013-08-27 01:13:59,355+0000 INFO  RemoteLogHandler WORKER_ACTIVE blockid=0827-1301520-000001
-2013-08-27 01:13:59,356+0000 INFO  RequestHandler Handler(tag: 4, RLOG) unregistering (send)
-2013-08-27 01:13:59,357+0000 DEBUG Cpu worker started: block=0827-1301520-000001 host=midway384 id=0
-2013-08-27 01:13:59,357+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=0
-2013-08-27 01:13:59,358+0000 INFO  Block Started CPU 0:1377566039s
-2013-08-27 01:13:59,358+0000 DEBUG Cpu worker started: block=0827-1301520-000001 host=midway384 id=1
-2013-08-27 01:13:59,358+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=1
-2013-08-27 01:13:59,358+0000 INFO  Block Started CPU 1:1377566039s
-2013-08-27 01:13:59,358+0000 DEBUG Cpu worker started: block=0827-1301520-000001 host=midway384 id=2
-2013-08-27 01:13:59,358+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=0 Cpus sleeping: 1
-2013-08-27 01:13:59,358+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=2
-2013-08-27 01:13:59,358+0000 INFO  Block Started CPU 2:1377566039s
-2013-08-27 01:13:59,358+0000 DEBUG Cpu worker started: block=0827-1301520-000001 host=midway384 id=3
-2013-08-27 01:13:59,358+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=3
-2013-08-27 01:13:59,358+0000 INFO  Block Started CPU 3:1377566039s
-2013-08-27 01:13:59,358+0000 DEBUG Cpu worker started: block=0827-1301520-000001 host=midway384 id=4
-2013-08-27 01:13:59,358+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=4
-2013-08-27 01:13:59,358+0000 INFO  Block Started CPU 4:1377566039s
-2013-08-27 01:13:59,358+0000 DEBUG Cpu worker started: block=0827-1301520-000001 host=midway384 id=5
-2013-08-27 01:13:59,358+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=5
-2013-08-27 01:13:59,358+0000 INFO  Block Started CPU 5:1377566039s
-2013-08-27 01:13:59,358+0000 DEBUG Cpu worker started: block=0827-1301520-000001 host=midway384 id=6
-2013-08-27 01:13:59,358+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=6
-2013-08-27 01:13:59,358+0000 INFO  Block Started CPU 6:1377566039s
-2013-08-27 01:13:59,358+0000 DEBUG Cpu worker started: block=0827-1301520-000001 host=midway384 id=7
-2013-08-27 01:13:59,358+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=7
-2013-08-27 01:13:59,358+0000 INFO  Block Started CPU 7:1377566039s
-2013-08-27 01:13:59,358+0000 DEBUG Cpu worker started: block=0827-1301520-000001 host=midway384 id=8
-2013-08-27 01:13:59,358+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=8
-2013-08-27 01:13:59,358+0000 INFO  Block Started CPU 8:1377566039s
-2013-08-27 01:13:59,358+0000 DEBUG Cpu worker started: block=0827-1301520-000001 host=midway384 id=9
-2013-08-27 01:13:59,358+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=9
-2013-08-27 01:13:59,358+0000 INFO  Block Started CPU 9:1377566039s
-2013-08-27 01:13:59,358+0000 DEBUG Cpu worker started: block=0827-1301520-000001 host=midway384 id=10
-2013-08-27 01:13:59,358+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=10
-2013-08-27 01:13:59,358+0000 INFO  Block Started CPU 10:1377566039s
-2013-08-27 01:13:59,358+0000 DEBUG Cpu worker started: block=0827-1301520-000001 host=midway384 id=11
-2013-08-27 01:13:59,358+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=11
-2013-08-27 01:13:59,358+0000 INFO  Block Started CPU 11:1377566039s
-2013-08-27 01:13:59,358+0000 DEBUG Cpu worker started: block=0827-1301520-000001 host=midway384 id=12
-2013-08-27 01:13:59,358+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=12
-2013-08-27 01:13:59,358+0000 INFO  Block Started CPU 12:1377566039s
-2013-08-27 01:13:59,358+0000 DEBUG Cpu worker started: block=0827-1301520-000001 host=midway384 id=13
-2013-08-27 01:13:59,359+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=13
-2013-08-27 01:13:59,359+0000 INFO  Block Started CPU 13:1377566039s
-2013-08-27 01:13:59,359+0000 DEBUG Cpu worker started: block=0827-1301520-000001 host=midway384 id=14
-2013-08-27 01:13:59,359+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=14
-2013-08-27 01:13:59,359+0000 INFO  Block Started CPU 14:1377566039s
-2013-08-27 01:13:59,359+0000 DEBUG Cpu worker started: block=0827-1301520-000001 host=midway384 id=15
-2013-08-27 01:13:59,359+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=15
-2013-08-27 01:13:59,359+0000 INFO  Block Started CPU 15:1377566039s
-2013-08-27 01:13:59,359+0000 INFO  Block Started worker 0827-1301520-000001:000000
-2013-08-27 01:13:59,359+0000 INFO  AbstractStreamCoasterChannel Using NIO sender for TCPChannel [type: server, contact: 0827-1301520-000001-000000]
-2013-08-27 01:13:59,359+0000 INFO  Cpu 0827-1301520-000001:0 (quality: 1.0) submitting urn:1377566031931-1377566031969-1377566031970: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0000.0009.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0000.0009.out|outdir/xhat_l10000_000
 0.0009.out|outdir/xhat_l20000_0000.0009.out|Results/ampl_res_l0000_0000.0009.out|outdir/out_l0000_0000.0009.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0000.0009.out outdir/xhat_l20000_0000.0009.out obj_outdir/obj_out_l0000_0000.0009.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0000.0009.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,360+0000 INFO  RequestHandler Handler(tag: 5, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,361+0000 INFO  RequestHandler Handler(tag: 2537, REGISTER) unregistering (send)
-2013-08-27 01:13:59,361+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=1 Cpus sleeping: 1
-2013-08-27 01:13:59,361+0000 INFO  Cpu 0827-1301520-000001:1 (quality: 1.0) submitting urn:1377566031946-1377566031972-1377566031973: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0013.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0013.out|outdir/xhat_l10000_000
 1.0013.out|outdir/xhat_l20000_0001.0013.out|Results/ampl_res_l0000_0001.0013.out|outdir/out_l0000_0001.0013.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0013.out outdir/xhat_l20000_0001.0013.out obj_outdir/obj_out_l0000_0001.0013.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0013.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,361+0000 INFO  RequestHandler Handler(tag: 6, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,362+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=2 Cpus sleeping: 1
-2013-08-27 01:13:59,362+0000 INFO  Cpu 0827-1301520-000001:2 (quality: 1.0) submitting urn:1377566031939-1377566031975-1377566031976: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0009.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0009.out|outdir/xhat_l10000_000
 1.0009.out|outdir/xhat_l20000_0001.0009.out|Results/ampl_res_l0000_0001.0009.out|outdir/out_l0000_0001.0009.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0009.out outdir/xhat_l20000_0001.0009.out obj_outdir/obj_out_l0000_0001.0009.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0009.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,362+0000 INFO  RequestHandler Handler(tag: 7, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,362+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=3 Cpus sleeping: 1
-2013-08-27 01:13:59,362+0000 INFO  Cpu 0827-1301520-000001:3 (quality: 1.0) submitting urn:1377566031947-1377566031978-1377566031979: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0000.0000.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0000.0000.out|outdir/xhat_l10000_000
 0.0000.out|outdir/xhat_l20000_0000.0000.out|Results/ampl_res_l0000_0000.0000.out|outdir/out_l0000_0000.0000.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0000.0000.out outdir/xhat_l20000_0000.0000.out obj_outdir/obj_out_l0000_0000.0000.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0000.0000.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,362+0000 INFO  RequestHandler Handler(tag: 8, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,363+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=4 Cpus sleeping: 1
-2013-08-27 01:13:59,363+0000 INFO  Cpu 0827-1301520-000001:4 (quality: 1.0) submitting urn:1377566031937-1377566031981-1377566031982: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0002.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0002.out|outdir/xhat_l10000_000
 1.0002.out|outdir/xhat_l20000_0001.0002.out|Results/ampl_res_l0000_0001.0002.out|outdir/out_l0000_0001.0002.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0002.out outdir/xhat_l20000_0001.0002.out obj_outdir/obj_out_l0000_0001.0002.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0002.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,363+0000 INFO  RequestHandler Handler(tag: 9, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,363+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=5 Cpus sleeping: 1
-2013-08-27 01:13:59,363+0000 INFO  Cpu 0827-1301520-000001:5 (quality: 1.0) submitting urn:1377566031944-1377566031984-1377566031985: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0003.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0003.out|outdir/xhat_l10000_000
 1.0003.out|outdir/xhat_l20000_0001.0003.out|Results/ampl_res_l0000_0001.0003.out|outdir/out_l0000_0001.0003.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0003.out outdir/xhat_l20000_0001.0003.out obj_outdir/obj_out_l0000_0001.0003.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0003.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,363+0000 INFO  RequestHandler Handler(tag: 10, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,363+0000 INFO  TCPBufferManager Adjusting buffer size to 8650752 for 2 sockets
-2013-08-27 01:13:59,363+0000 INFO  AbstractCoasterChannel Timeout check started for TCPChannel [type: server, contact: unknown]
-2013-08-27 01:13:59,363+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=6 Cpus sleeping: 1
-2013-08-27 01:13:59,363+0000 INFO  AbstractTCPChannel Channel started: TCPChannel [type: server, contact: 10.50.181.33:37280]
-2013-08-27 01:13:59,363+0000 INFO  Cpu 0827-1301520-000001:6 (quality: 1.0) submitting urn:1377566031938-1377566031987-1377566031988: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0011.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0011.out|outdir/xhat_l10000_000
 1.0011.out|outdir/xhat_l20000_0001.0011.out|Results/ampl_res_l0000_0001.0011.out|outdir/out_l0000_0001.0011.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0011.out outdir/xhat_l20000_0001.0011.out obj_outdir/obj_out_l0000_0001.0011.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0011.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,364+0000 INFO  RequestHandler Handler(tag: 11, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,364+0000 INFO  LocalTCPService Received registration: blockid = 0827-1301520-000000, url = midway033
-2013-08-27 01:13:59,364+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=7 Cpus sleeping: 1
-2013-08-27 01:13:59,364+0000 INFO  MetaChannel MetaChannel [context: worker-2, boundTo: null] binding to TCPChannel [type: server, contact: 10.50.181.33:37280]
-2013-08-27 01:13:59,364+0000 INFO  Cpu 0827-1301520-000001:7 (quality: 1.0) submitting urn:1377566031945-1377566031990-1377566031991: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0007.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0007.out|outdir/xhat_l10000_000
 1.0007.out|outdir/xhat_l20000_0001.0007.out|Results/ampl_res_l0000_0001.0007.out|outdir/out_l0000_0001.0007.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0007.out outdir/xhat_l20000_0001.0007.out obj_outdir/obj_out_l0000_0001.0007.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0007.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,364+0000 DEBUG Cpu worker started: block=0827-1301520-000000 host=midway033 id=0
-2013-08-27 01:13:59,364+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=0
-2013-08-27 01:13:59,364+0000 INFO  Block Started CPU 0:1377566039s
-2013-08-27 01:13:59,364+0000 INFO  RemoteLogHandler WORKER_ACTIVE blockid=0827-1301520-000000
-2013-08-27 01:13:59,364+0000 DEBUG Cpu worker started: block=0827-1301520-000000 host=midway033 id=1
-2013-08-27 01:13:59,364+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=1
-2013-08-27 01:13:59,364+0000 INFO  RequestHandler Handler(tag: 12, RLOG) unregistering (send)
-2013-08-27 01:13:59,364+0000 INFO  Block Started CPU 1:1377566039s
-2013-08-27 01:13:59,364+0000 DEBUG Cpu worker started: block=0827-1301520-000000 host=midway033 id=2
-2013-08-27 01:13:59,364+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=2
-2013-08-27 01:13:59,364+0000 INFO  Block Started CPU 2:1377566039s
-2013-08-27 01:13:59,364+0000 DEBUG Cpu worker started: block=0827-1301520-000000 host=midway033 id=3
-2013-08-27 01:13:59,364+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=3
-2013-08-27 01:13:59,365+0000 INFO  Block Started CPU 3:1377566039s
-2013-08-27 01:13:59,365+0000 INFO  RequestHandler Handler(tag: 13, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,365+0000 DEBUG Cpu worker started: block=0827-1301520-000000 host=midway033 id=4
-2013-08-27 01:13:59,365+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=4
-2013-08-27 01:13:59,365+0000 INFO  Block Started CPU 4:1377566039s
-2013-08-27 01:13:59,365+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=8 Cpus sleeping: 1
-2013-08-27 01:13:59,365+0000 DEBUG Cpu worker started: block=0827-1301520-000000 host=midway033 id=5
-2013-08-27 01:13:59,365+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=5
-2013-08-27 01:13:59,365+0000 INFO  Block Started CPU 5:1377566039s
-2013-08-27 01:13:59,365+0000 DEBUG Cpu worker started: block=0827-1301520-000000 host=midway033 id=6
-2013-08-27 01:13:59,365+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=6
-2013-08-27 01:13:59,365+0000 INFO  Cpu 0827-1301520-000001:8 (quality: 1.0) submitting urn:1377566031935-1377566031993-1377566031994: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0000.0008.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0000.0008.out|outdir/xhat_l10000_000
 0.0008.out|outdir/xhat_l20000_0000.0008.out|Results/ampl_res_l0000_0000.0008.out|outdir/out_l0000_0000.0008.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0000.0008.out outdir/xhat_l20000_0000.0008.out obj_outdir/obj_out_l0000_0000.0008.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0000.0008.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,365+0000 INFO  Block Started CPU 6:1377566039s
-2013-08-27 01:13:59,365+0000 DEBUG Cpu worker started: block=0827-1301520-000000 host=midway033 id=7
-2013-08-27 01:13:59,365+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=7
-2013-08-27 01:13:59,365+0000 INFO  Block Started CPU 7:1377566039s
-2013-08-27 01:13:59,365+0000 DEBUG Cpu worker started: block=0827-1301520-000000 host=midway033 id=8
-2013-08-27 01:13:59,365+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=8
-2013-08-27 01:13:59,365+0000 INFO  Block Started CPU 8:1377566039s
-2013-08-27 01:13:59,365+0000 DEBUG Cpu worker started: block=0827-1301520-000000 host=midway033 id=9
-2013-08-27 01:13:59,365+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=9
-2013-08-27 01:13:59,365+0000 INFO  Block Started CPU 9:1377566039s
-2013-08-27 01:13:59,365+0000 DEBUG Cpu worker started: block=0827-1301520-000000 host=midway033 id=10
-2013-08-27 01:13:59,365+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=10
-2013-08-27 01:13:59,365+0000 INFO  RequestHandler Handler(tag: 14, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,365+0000 INFO  Block Started CPU 10:1377566039s
-2013-08-27 01:13:59,365+0000 DEBUG Cpu worker started: block=0827-1301520-000000 host=midway033 id=11
-2013-08-27 01:13:59,365+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=11
-2013-08-27 01:13:59,365+0000 INFO  Block Started CPU 11:1377566039s
-2013-08-27 01:13:59,365+0000 DEBUG Cpu worker started: block=0827-1301520-000000 host=midway033 id=12
-2013-08-27 01:13:59,365+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=12
-2013-08-27 01:13:59,365+0000 INFO  Block Started CPU 12:1377566039s
-2013-08-27 01:13:59,365+0000 DEBUG Cpu worker started: block=0827-1301520-000000 host=midway033 id=13
-2013-08-27 01:13:59,365+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=13
-2013-08-27 01:13:59,365+0000 INFO  Block Started CPU 13:1377566039s
-2013-08-27 01:13:59,365+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=9 Cpus sleeping: 1
-2013-08-27 01:13:59,365+0000 DEBUG Cpu worker started: block=0827-1301520-000000 host=midway033 id=14
-2013-08-27 01:13:59,365+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=14
-2013-08-27 01:13:59,365+0000 INFO  Block Started CPU 14:1377566039s
-2013-08-27 01:13:59,365+0000 DEBUG Cpu worker started: block=0827-1301520-000000 host=midway033 id=15
-2013-08-27 01:13:59,365+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=15
-2013-08-27 01:13:59,365+0000 INFO  Cpu 0827-1301520-000001:9 (quality: 1.0) submitting urn:1377566031936-1377566031996-1377566031997: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/ampl0000.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_ampl0000.out|outdir/xhat10000.out|outdir/xhat20000.out|Re
 sults/ampl_res0000.out|outdir/ampl0000.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat10000.out outdir/xhat20000.out obj_outdir/obj_ampl0000.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res0000.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,365+0000 INFO  Block Started CPU 15:1377566039s
-2013-08-27 01:13:59,365+0000 INFO  Block Started worker 0827-1301520-000000:000000
-2013-08-27 01:13:59,365+0000 INFO  RequestHandler Handler(tag: 3002, REGISTER) unregistering (send)
-2013-08-27 01:13:59,365+0000 INFO  RequestHandler Handler(tag: 15, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,366+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=10 Cpus sleeping: 1
-2013-08-27 01:13:59,366+0000 INFO  Cpu 0827-1301520-000001:10 (quality: 1.0) submitting urn:1377566031933-1377566031999-1377566032000: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0000.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0000.out|outdir/xhat_l10000_00
 01.0000.out|outdir/xhat_l20000_0001.0000.out|Results/ampl_res_l0000_0001.0000.out|outdir/out_l0000_0001.0000.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0000.out outdir/xhat_l20000_0001.0000.out obj_outdir/obj_out_l0000_0001.0000.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0000.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,366+0000 INFO  RequestHandler Handler(tag: 16, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,366+0000 INFO  RequestHandler Handler(tag: 17, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,366+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=11 Cpus sleeping: 1
-2013-08-27 01:13:59,366+0000 INFO  Cpu 0827-1301520-000001:11 (quality: 1.0) submitting urn:1377566031930-1377566032002-1377566032003: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0000.0010.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0000.0010.out|outdir/xhat_l10000_00
 00.0010.out|outdir/xhat_l20000_0000.0010.out|Results/ampl_res_l0000_0000.0010.out|outdir/out_l0000_0000.0010.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0000.0010.out outdir/xhat_l20000_0000.0010.out obj_outdir/obj_out_l0000_0000.0010.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0000.0010.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,366+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:13:59,367+0000 INFO  RequestHandler Handler(tag: 18, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,367+0000 INFO  RequestHandler Handler(tag: 2538, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,367+0000 INFO  RequestHandler Handler(tag: 19, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,367+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=12 Cpus sleeping: 1
-2013-08-27 01:13:59,367+0000 INFO  Cpu 0827-1301520-000001:12 (quality: 1.0) submitting urn:1377566031929-1377566032006-1377566032007: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0016.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0016.out|outdir/xhat_l10000_00
 01.0016.out|outdir/xhat_l20000_0001.0016.out|Results/ampl_res_l0000_0001.0016.out|outdir/out_l0000_0001.0016.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0016.out outdir/xhat_l20000_0001.0016.out obj_outdir/obj_out_l0000_0001.0016.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0016.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,367+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=13 Cpus sleeping: 1
-2013-08-27 01:13:59,367+0000 INFO  Cpu 0827-1301520-000001:13 (quality: 1.0) submitting urn:1377566031948-1377566032009-1377566032010: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0000.0001.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0000.0001.out|outdir/xhat_l10000_00
 00.0001.out|outdir/xhat_l20000_0000.0001.out|Results/ampl_res_l0000_0000.0001.out|outdir/out_l0000_0000.0001.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0000.0001.out outdir/xhat_l20000_0000.0001.out obj_outdir/obj_out_l0000_0000.0001.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0000.0001.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,367+0000 INFO  RequestHandler Handler(tag: 20, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,368+0000 INFO  RequestHandler Handler(tag: 21, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,368+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=14 Cpus sleeping: 1
-2013-08-27 01:13:59,368+0000 INFO  Cpu 0827-1301520-000001:14 (quality: 1.0) submitting urn:1377566031928-1377566032012-1377566032013: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0012.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0012.out|outdir/xhat_l10000_00
 01.0012.out|outdir/xhat_l20000_0001.0012.out|Results/ampl_res_l0000_0001.0012.out|outdir/out_l0000_0001.0012.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0012.out outdir/xhat_l20000_0001.0012.out obj_outdir/obj_out_l0000_0001.0012.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0012.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,368+0000 INFO  GetFileHandler Handler(tag: 2539, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,368+0000 INFO  RequestHandler Handler(tag: 22, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,368+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=15 Cpus sleeping: 1
-2013-08-27 01:13:59,368+0000 INFO  Cpu 0827-1301520-000001:15 (quality: 1.0) submitting urn:1377566031950-1377566032015-1377566032016: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0000.0004.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0000.0004.out|outdir/xhat_l10000_00
 00.0004.out|outdir/xhat_l20000_0000.0004.out|Results/ampl_res_l0000_0000.0004.out|outdir/out_l0000_0000.0004.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0000.0004.out outdir/xhat_l20000_0000.0004.out obj_outdir/obj_out_l0000_0000.0004.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0000.0004.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,368+0000 INFO  RequestHandler Handler(tag: 23, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,369+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=0 Cpus sleeping: 1
-2013-08-27 01:13:59,369+0000 INFO  Cpu 0827-1301520-000000:0 (quality: 1.0) submitting urn:1377566031932-1377566032018-1377566032019: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0010.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0010.out|outdir/xhat_l10000_000
 1.0010.out|outdir/xhat_l20000_0001.0010.out|Results/ampl_res_l0000_0001.0010.out|outdir/out_l0000_0001.0010.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0010.out outdir/xhat_l20000_0001.0010.out obj_outdir/obj_out_l0000_0001.0010.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0010.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,369+0000 INFO  RequestHandler Handler(tag: 24, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,370+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=1 Cpus sleeping: 1
-2013-08-27 01:13:59,370+0000 INFO  Cpu 0827-1301520-000000:1 (quality: 1.0) submitting urn:1377566031934-1377566032021-1377566032022: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0015.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0015.out|outdir/xhat_l10000_000
 1.0015.out|outdir/xhat_l20000_0001.0015.out|Results/ampl_res_l0000_0001.0015.out|outdir/out_l0000_0001.0015.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0015.out outdir/xhat_l20000_0001.0015.out obj_outdir/obj_out_l0000_0001.0015.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0015.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,370+0000 INFO  RequestHandler Handler(tag: 25, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,370+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=2 Cpus sleeping: 1
-2013-08-27 01:13:59,370+0000 INFO  Cpu 0827-1301520-000000:2 (quality: 1.0) submitting urn:1377566031927-1377566032024-1377566032025: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0008.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0008.out|outdir/xhat_l10000_000
 1.0008.out|outdir/xhat_l20000_0001.0008.out|Results/ampl_res_l0000_0001.0008.out|outdir/out_l0000_0001.0008.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0008.out outdir/xhat_l20000_0001.0008.out obj_outdir/obj_out_l0000_0001.0008.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0008.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,370+0000 INFO  RequestHandler Handler(tag: 26, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,371+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=3 Cpus sleeping: 1
-2013-08-27 01:13:59,371+0000 INFO  Cpu 0827-1301520-000000:3 (quality: 1.0) submitting urn:1377566031943-1377566032027-1377566032028: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0014.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0014.out|outdir/xhat_l10000_000
 1.0014.out|outdir/xhat_l20000_0001.0014.out|Results/ampl_res_l0000_0001.0014.out|outdir/out_l0000_0001.0014.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0014.out outdir/xhat_l20000_0001.0014.out obj_outdir/obj_out_l0000_0001.0014.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0014.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,371+0000 INFO  RequestHandler Handler(tag: 27, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,371+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=4 Cpus sleeping: 1
-2013-08-27 01:13:59,371+0000 INFO  Cpu 0827-1301520-000000:4 (quality: 1.0) submitting urn:1377566031940-1377566032030-1377566032031: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0000.0002.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0000.0002.out|outdir/xhat_l10000_000
 0.0002.out|outdir/xhat_l20000_0000.0002.out|Results/ampl_res_l0000_0000.0002.out|outdir/out_l0000_0000.0002.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0000.0002.out outdir/xhat_l20000_0000.0002.out obj_outdir/obj_out_l0000_0000.0002.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0000.0002.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,371+0000 INFO  RequestHandler Handler(tag: 28, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,371+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=5 Cpus sleeping: 1
-2013-08-27 01:13:59,372+0000 INFO  Cpu 0827-1301520-000000:5 (quality: 1.0) submitting urn:1377566031949-1377566032033-1377566032034: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0000.0003.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0000.0003.out|outdir/xhat_l10000_000
 0.0003.out|outdir/xhat_l20000_0000.0003.out|Results/ampl_res_l0000_0000.0003.out|outdir/out_l0000_0000.0003.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0000.0003.out outdir/xhat_l20000_0000.0003.out obj_outdir/obj_out_l0000_0000.0003.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0000.0003.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,372+0000 INFO  RequestHandler Handler(tag: 29, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,372+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=6 Cpus sleeping: 1
-2013-08-27 01:13:59,372+0000 INFO  Cpu 0827-1301520-000000:6 (quality: 1.0) submitting urn:1377566031942-1377566032036-1377566032037: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0018.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0018.out|outdir/xhat_l10000_000
 1.0018.out|outdir/xhat_l20000_0001.0018.out|Results/ampl_res_l0000_0001.0018.out|outdir/out_l0000_0001.0018.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0018.out outdir/xhat_l20000_0001.0018.out obj_outdir/obj_out_l0000_0001.0018.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0018.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,372+0000 INFO  RequestHandler Handler(tag: 30, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,372+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=7 Cpus sleeping: 1
-2013-08-27 01:13:59,372+0000 INFO  Cpu 0827-1301520-000000:7 (quality: 1.0) submitting urn:1377566031941-1377566032039-1377566032040: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0001.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0001.out|outdir/xhat_l10000_000
 1.0001.out|outdir/xhat_l20000_0001.0001.out|Results/ampl_res_l0000_0001.0001.out|outdir/out_l0000_0001.0001.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0001.out outdir/xhat_l20000_0001.0001.out obj_outdir/obj_out_l0000_0001.0001.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0001.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,373+0000 INFO  RequestHandler Handler(tag: 31, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,373+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=8 Cpus sleeping: 1
-2013-08-27 01:13:59,373+0000 INFO  Cpu 0827-1301520-000000:8 (quality: 1.0) submitting urn:1377566031953-1377566032042-1377566032043: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0000.0005.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0000.0005.out|outdir/xhat_l10000_000
 0.0005.out|outdir/xhat_l20000_0000.0005.out|Results/ampl_res_l0000_0000.0005.out|outdir/out_l0000_0000.0005.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0000.0005.out outdir/xhat_l20000_0000.0005.out obj_outdir/obj_out_l0000_0000.0005.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0000.0005.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,373+0000 INFO  RequestHandler Handler(tag: 32, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,373+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=9 Cpus sleeping: 1
-2013-08-27 01:13:59,373+0000 INFO  Cpu 0827-1301520-000000:9 (quality: 1.0) submitting urn:1377566031954-1377566032045-1377566032046: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0005.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0005.out|outdir/xhat_l10000_000
 1.0005.out|outdir/xhat_l20000_0001.0005.out|Results/ampl_res_l0000_0001.0005.out|outdir/out_l0000_0001.0005.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0005.out outdir/xhat_l20000_0001.0005.out obj_outdir/obj_out_l0000_0001.0005.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0005.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,373+0000 INFO  RequestHandler Handler(tag: 33, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,374+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=10 Cpus sleeping: 1
-2013-08-27 01:13:59,374+0000 INFO  Cpu 0827-1301520-000000:10 (quality: 1.0) submitting urn:1377566031957-1377566032048-1377566032049: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0017.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0017.out|outdir/xhat_l10000_00
 01.0017.out|outdir/xhat_l20000_0001.0017.out|Results/ampl_res_l0000_0001.0017.out|outdir/out_l0000_0001.0017.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0017.out outdir/xhat_l20000_0001.0017.out obj_outdir/obj_out_l0000_0001.0017.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0017.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,374+0000 INFO  RequestHandler Handler(tag: 34, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,374+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=11 Cpus sleeping: 1
-2013-08-27 01:13:59,374+0000 INFO  Cpu 0827-1301520-000000:11 (quality: 1.0) submitting urn:1377566031958-1377566032051-1377566032052: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0006.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0006.out|outdir/xhat_l10000_00
 01.0006.out|outdir/xhat_l20000_0001.0006.out|Results/ampl_res_l0000_0001.0006.out|outdir/out_l0000_0001.0006.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0006.out outdir/xhat_l20000_0001.0006.out obj_outdir/obj_out_l0000_0001.0006.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0006.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,374+0000 INFO  RequestHandler Handler(tag: 35, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,375+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=12 Cpus sleeping: 1
-2013-08-27 01:13:59,375+0000 INFO  Cpu 0827-1301520-000000:12 (quality: 1.0) submitting urn:1377566031962-1377566032054-1377566032055: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0019.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0019.out|outdir/xhat_l10000_00
 01.0019.out|outdir/xhat_l20000_0001.0019.out|Results/ampl_res_l0000_0001.0019.out|outdir/out_l0000_0001.0019.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0019.out outdir/xhat_l20000_0001.0019.out obj_outdir/obj_out_l0000_0001.0019.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0019.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,375+0000 INFO  RequestHandler Handler(tag: 36, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,375+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=13 Cpus sleeping: 1
-2013-08-27 01:13:59,375+0000 INFO  Cpu 0827-1301520-000000:13 (quality: 1.0) submitting urn:1377566031963-1377566032057-1377566032058: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0004.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0004.out|outdir/xhat_l10000_00
 01.0004.out|outdir/xhat_l20000_0001.0004.out|Results/ampl_res_l0000_0001.0004.out|outdir/out_l0000_0001.0004.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0004.out outdir/xhat_l20000_0001.0004.out obj_outdir/obj_out_l0000_0001.0004.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0004.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,375+0000 INFO  RequestHandler Handler(tag: 37, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,375+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=14 Cpus sleeping: 1
-2013-08-27 01:13:59,376+0000 INFO  Cpu 0827-1301520-000000:14 (quality: 1.0) submitting urn:1377566031964-1377566032060-1377566032061: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0000.0006.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0000.0006.out|outdir/xhat_l10000_00
 00.0006.out|outdir/xhat_l20000_0000.0006.out|Results/ampl_res_l0000_0000.0006.out|outdir/out_l0000_0000.0006.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0000.0006.out outdir/xhat_l20000_0000.0006.out obj_outdir/obj_out_l0000_0000.0006.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0000.0006.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,376+0000 INFO  RequestHandler Handler(tag: 38, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,376+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=15 Cpus sleeping: 1
-2013-08-27 01:13:59,376+0000 INFO  Cpu 0827-1301520-000000:15 (quality: 1.0) submitting urn:1377566031966-1377566032063-1377566032064: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0000.0007.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0000.0007.out|outdir/xhat_l10000_00
 00.0007.out|outdir/xhat_l20000_0000.0007.out|Results/ampl_res_l0000_0000.0007.out|outdir/out_l0000_0000.0007.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0000.0007.out outdir/xhat_l20000_0000.0007.out obj_outdir/obj_out_l0000_0000.0007.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0000.0007.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:13:59,376+0000 INFO  RequestHandler Handler(tag: 39, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,381+0000 INFO  GetFileHandler Handler(tag: 2539, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,381+0000 INFO  GetFileHandler Handler(tag: 2539, GET) -> 40
-2013-08-27 01:13:59,381+0000 INFO  GetFileHandler Handler(tag: 40, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,382+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:13:59,383+0000 INFO  RequestHandler Handler(tag: 3003, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,383+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:13:59,383+0000 INFO  RequestHandler Handler(tag: 2540, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,383+0000 INFO  GetFileHandler Handler(tag: 40, GET) reader: LR-Handler(tag: 40, GET)
-2013-08-27 01:13:59,383+0000 INFO  GetFileHandler Handler(tag: 40, GET) sending length: 1925, 579976243
-2013-08-27 01:13:59,383+0000 INFO  GetFileHandler Handler(tag: 2539, GET) sending length: 1925, 232442368
-2013-08-27 01:13:59,383+0000 INFO  GetFileHandler Handler(tag: 3004, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,383+0000 INFO  GetFileHandler Handler(tag: 3004, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,383+0000 INFO  GetFileHandler Handler(tag: 3004, GET) -> 45
-2013-08-27 01:13:59,383+0000 INFO  GetFileHandler Handler(tag: 2541, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,383+0000 INFO  GetFileHandler Handler(tag: 2541, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,383+0000 INFO  GetFileHandler Handler(tag: 2541, GET) -> 46
-2013-08-27 01:13:59,384+0000 INFO  ReadBuffer RB-LR-Handler(tag: 40, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,384+0000 INFO  ReadBuffer RB-LR-Handler(tag: 40, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,384+0000 INFO  LocalIOProvider LR-Handler(tag: 40, GET) rbuf: RB-LR-Handler(tag: 40, GET)
-2013-08-27 01:13:59,384+0000 INFO  Buffers I allocated buffers: {RB-LR-Handler(tag: 40, GET) -> 1} (1)
-2013-08-27 01:13:59,384+0000 INFO  RequestHandler Handler(tag: 41, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,384+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:13:59,385+0000 INFO  RequestHandler Handler(tag: 3005, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,385+0000 INFO  RequestHandler Handler(tag: 42, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,385+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:13:59,385+0000 INFO  RequestHandler Handler(tag: 43, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,385+0000 INFO  RequestHandler Handler(tag: 2542, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,385+0000 INFO  RequestHandler Handler(tag: 44, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,385+0000 INFO  GetFileHandler Handler(tag: 40, GET) unregistering (last)
-2013-08-27 01:13:59,385+0000 INFO  GetFileHandler Handler(tag: 45, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,386+0000 INFO  ReadBuffer RB-LR-Handler(tag: 40, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,386+0000 INFO  GetFileHandler Handler(tag: 45, GET) reader: LR-Handler(tag: 45, GET)
-2013-08-27 01:13:59,386+0000 INFO  Buffers O allocated buffers: {POW-Command(tag: -1, GET) -> 1} (1)
-2013-08-27 01:13:59,386+0000 INFO  GetFileHandler Handler(tag: 45, GET) sending length: 1925, 2474267
-2013-08-27 01:13:59,386+0000 INFO  GetFileHandler Handler(tag: 2539, GET) unregistering (last)
-2013-08-27 01:13:59,386+0000 INFO  ReadBuffer RB-LR-Handler(tag: 45, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,386+0000 INFO  GetFileHandler Handler(tag: 3006, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,386+0000 INFO  GetFileHandler Handler(tag: 3004, GET) sending length: 1925, 673733348
-2013-08-27 01:13:59,386+0000 INFO  ReadBuffer RB-LR-Handler(tag: 45, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,386+0000 INFO  LocalIOProvider LR-Handler(tag: 45, GET) rbuf: RB-LR-Handler(tag: 45, GET)
-2013-08-27 01:13:59,386+0000 INFO  GetFileHandler Handler(tag: 3006, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,386+0000 INFO  GetFileHandler Handler(tag: 45, GET) unregistering (last)
-2013-08-27 01:13:59,386+0000 INFO  GetFileHandler Handler(tag: 3006, GET) -> 51
-2013-08-27 01:13:59,386+0000 INFO  ReadBuffer RB-LR-Handler(tag: 45, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,386+0000 INFO  GetFileHandler Handler(tag: 3004, GET) unregistering (last)
-2013-08-27 01:13:59,386+0000 INFO  GetFileHandler Handler(tag: 46, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,386+0000 INFO  GetFileHandler Handler(tag: 2543, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,386+0000 INFO  GetFileHandler Handler(tag: 46, GET) reader: LR-Handler(tag: 46, GET)
-2013-08-27 01:13:59,386+0000 INFO  GetFileHandler Handler(tag: 2543, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,386+0000 INFO  GetFileHandler Handler(tag: 46, GET) sending length: 1925, 1460675721
-2013-08-27 01:13:59,386+0000 INFO  GetFileHandler Handler(tag: 2543, GET) -> 52
-2013-08-27 01:13:59,386+0000 INFO  ReadBuffer RB-LR-Handler(tag: 46, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,386+0000 INFO  GetFileHandler Handler(tag: 2541, GET) sending length: 1925, 1691273990
-2013-08-27 01:13:59,386+0000 INFO  ReadBuffer RB-LR-Handler(tag: 46, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,386+0000 INFO  LocalIOProvider LR-Handler(tag: 46, GET) rbuf: RB-LR-Handler(tag: 46, GET)
-2013-08-27 01:13:59,386+0000 INFO  GetFileHandler Handler(tag: 46, GET) unregistering (last)
-2013-08-27 01:13:59,387+0000 INFO  ReadBuffer RB-LR-Handler(tag: 46, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,387+0000 INFO  GetFileHandler Handler(tag: 2541, GET) unregistering (last)
-2013-08-27 01:13:59,387+0000 INFO  RequestHandler Handler(tag: 47, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,387+0000 INFO  RequestHandler Handler(tag: 48, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,387+0000 INFO  RequestHandler Handler(tag: 49, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,387+0000 INFO  RequestHandler Handler(tag: 50, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,387+0000 INFO  GetFileHandler Handler(tag: 51, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,387+0000 INFO  GetFileHandler Handler(tag: 51, GET) reader: LR-Handler(tag: 51, GET)
-2013-08-27 01:13:59,387+0000 INFO  GetFileHandler Handler(tag: 51, GET) sending length: 1925, 1032247301
-2013-08-27 01:13:59,387+0000 INFO  GetFileHandler Handler(tag: 3006, GET) sending length: 1925, 1607487441
-2013-08-27 01:13:59,387+0000 INFO  ReadBuffer RB-LR-Handler(tag: 51, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,387+0000 INFO  ReadBuffer RB-LR-Handler(tag: 51, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,388+0000 INFO  LocalIOProvider LR-Handler(tag: 51, GET) rbuf: RB-LR-Handler(tag: 51, GET)
-2013-08-27 01:13:59,388+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:13:59,388+0000 INFO  GetFileHandler Handler(tag: 51, GET) unregistering (last)
-2013-08-27 01:13:59,388+0000 INFO  RequestHandler Handler(tag: 3007, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,388+0000 INFO  ReadBuffer RB-LR-Handler(tag: 51, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,388+0000 INFO  GetFileHandler Handler(tag: 52, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,388+0000 INFO  GetFileHandler Handler(tag: 3006, GET) unregistering (last)
-2013-08-27 01:13:59,388+0000 INFO  GetFileHandler Handler(tag: 52, GET) reader: LR-Handler(tag: 52, GET)
-2013-08-27 01:13:59,388+0000 INFO  GetFileHandler Handler(tag: 52, GET) sending length: 1925, 895071792
-2013-08-27 01:13:59,388+0000 INFO  GetFileHandler Handler(tag: 2543, GET) sending length: 1925, 1034567771
-2013-08-27 01:13:59,388+0000 INFO  ReadBuffer RB-LR-Handler(tag: 52, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,388+0000 INFO  ReadBuffer RB-LR-Handler(tag: 52, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,388+0000 INFO  RequestHandler Handler(tag: 2544, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,388+0000 INFO  LocalIOProvider LR-Handler(tag: 52, GET) rbuf: RB-LR-Handler(tag: 52, GET)
-2013-08-27 01:13:59,388+0000 INFO  GetFileHandler Handler(tag: 52, GET) unregistering (last)
-2013-08-27 01:13:59,388+0000 INFO  ReadBuffer RB-LR-Handler(tag: 52, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,388+0000 INFO  GetFileHandler Handler(tag: 2543, GET) unregistering (last)
-2013-08-27 01:13:59,388+0000 INFO  RequestHandler Handler(tag: 53, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,388+0000 INFO  RequestHandler Handler(tag: 54, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,389+0000 INFO  GetFileHandler Handler(tag: 3008, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,389+0000 INFO  RequestHandler Handler(tag: 55, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,389+0000 INFO  GetFileHandler Handler(tag: 3008, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,389+0000 INFO  GetFileHandler Handler(tag: 3008, GET) -> 57
-2013-08-27 01:13:59,389+0000 INFO  RequestHandler Handler(tag: 56, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,389+0000 INFO  GetFileHandler Handler(tag: 2545, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,389+0000 INFO  GetFileHandler Handler(tag: 2545, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,389+0000 INFO  GetFileHandler Handler(tag: 57, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,389+0000 INFO  GetFileHandler Handler(tag: 2545, GET) -> 58
-2013-08-27 01:13:59,389+0000 INFO  GetFileHandler Handler(tag: 57, GET) reader: LR-Handler(tag: 57, GET)
-2013-08-27 01:13:59,389+0000 INFO  GetFileHandler Handler(tag: 57, GET) sending length: 1925, 1292849429
-2013-08-27 01:13:59,389+0000 INFO  GetFileHandler Handler(tag: 3008, GET) sending length: 1925, 680812857
-2013-08-27 01:13:59,389+0000 INFO  ReadBuffer RB-LR-Handler(tag: 57, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,389+0000 INFO  ReadBuffer RB-LR-Handler(tag: 57, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,389+0000 INFO  LocalIOProvider LR-Handler(tag: 57, GET) rbuf: RB-LR-Handler(tag: 57, GET)
-2013-08-27 01:13:59,389+0000 INFO  GetFileHandler Handler(tag: 57, GET) unregistering (last)
-2013-08-27 01:13:59,389+0000 INFO  GetFileHandler Handler(tag: 58, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,390+0000 INFO  ReadBuffer RB-LR-Handler(tag: 57, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,390+0000 INFO  GetFileHandler Handler(tag: 3008, GET) unregistering (last)
-2013-08-27 01:13:59,390+0000 INFO  GetFileHandler Handler(tag: 58, GET) reader: LR-Handler(tag: 58, GET)
-2013-08-27 01:13:59,390+0000 INFO  GetFileHandler Handler(tag: 58, GET) sending length: 1925, 515737837
-2013-08-27 01:13:59,390+0000 INFO  GetFileHandler Handler(tag: 2545, GET) sending length: 1925, 1062047763
-2013-08-27 01:13:59,390+0000 INFO  ReadBuffer RB-LR-Handler(tag: 58, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,390+0000 INFO  ReadBuffer RB-LR-Handler(tag: 58, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,390+0000 INFO  LocalIOProvider LR-Handler(tag: 58, GET) rbuf: RB-LR-Handler(tag: 58, GET)
-2013-08-27 01:13:59,390+0000 INFO  GetFileHandler Handler(tag: 58, GET) unregistering (last)
-2013-08-27 01:13:59,390+0000 INFO  ReadBuffer RB-LR-Handler(tag: 58, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,390+0000 INFO  GetFileHandler Handler(tag: 2545, GET) unregistering (last)
-2013-08-27 01:13:59,390+0000 INFO  RequestHandler Handler(tag: 59, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,390+0000 INFO  RequestHandler Handler(tag: 60, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,390+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:13:59,391+0000 INFO  RequestHandler Handler(tag: 3009, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,391+0000 INFO  RequestHandler Handler(tag: 61, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,391+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:13:59,391+0000 INFO  RequestHandler Handler(tag: 2546, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,391+0000 INFO  RequestHandler Handler(tag: 62, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,391+0000 INFO  GetFileHandler Handler(tag: 3010, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,391+0000 INFO  GetFileHandler Handler(tag: 3010, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,391+0000 INFO  GetFileHandler Handler(tag: 3010, GET) -> 63
-2013-08-27 01:13:59,391+0000 INFO  GetFileHandler Handler(tag: 63, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,391+0000 INFO  GetFileHandler Handler(tag: 2547, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,391+0000 INFO  GetFileHandler Handler(tag: 2547, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,392+0000 INFO  GetFileHandler Handler(tag: 63, GET) reader: LR-Handler(tag: 63, GET)
-2013-08-27 01:13:59,392+0000 INFO  GetFileHandler Handler(tag: 2547, GET) -> 64
-2013-08-27 01:13:59,392+0000 INFO  GetFileHandler Handler(tag: 63, GET) sending length: 1925, 393903022
-2013-08-27 01:13:59,392+0000 INFO  GetFileHandler Handler(tag: 3010, GET) sending length: 1925, 1783490700
-2013-08-27 01:13:59,392+0000 INFO  ReadBuffer RB-LR-Handler(tag: 63, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,392+0000 INFO  ReadBuffer RB-LR-Handler(tag: 63, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,392+0000 INFO  LocalIOProvider LR-Handler(tag: 63, GET) rbuf: RB-LR-Handler(tag: 63, GET)
-2013-08-27 01:13:59,392+0000 INFO  GetFileHandler Handler(tag: 63, GET) unregistering (last)
-2013-08-27 01:13:59,392+0000 INFO  GetFileHandler Handler(tag: 64, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,392+0000 INFO  ReadBuffer RB-LR-Handler(tag: 63, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,392+0000 INFO  GetFileHandler Handler(tag: 3010, GET) unregistering (last)
-2013-08-27 01:13:59,392+0000 INFO  GetFileHandler Handler(tag: 64, GET) reader: LR-Handler(tag: 64, GET)
-2013-08-27 01:13:59,392+0000 INFO  GetFileHandler Handler(tag: 64, GET) sending length: 1925, 1951428684
-2013-08-27 01:13:59,392+0000 INFO  ReadBuffer RB-LR-Handler(tag: 64, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,392+0000 INFO  GetFileHandler Handler(tag: 2547, GET) sending length: 1925, 1104772279
-2013-08-27 01:13:59,392+0000 INFO  ReadBuffer RB-LR-Handler(tag: 64, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,392+0000 INFO  LocalIOProvider LR-Handler(tag: 64, GET) rbuf: RB-LR-Handler(tag: 64, GET)
-2013-08-27 01:13:59,392+0000 INFO  GetFileHandler Handler(tag: 64, GET) unregistering (last)
-2013-08-27 01:13:59,392+0000 INFO  ReadBuffer RB-LR-Handler(tag: 64, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,392+0000 INFO  GetFileHandler Handler(tag: 2547, GET) unregistering (last)
-2013-08-27 01:13:59,392+0000 INFO  RequestHandler Handler(tag: 65, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,393+0000 INFO  RequestHandler Handler(tag: 66, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,393+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:13:59,393+0000 INFO  RequestHandler Handler(tag: 3011, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,393+0000 INFO  RequestHandler Handler(tag: 67, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,393+0000 INFO  RequestHandler Handler(tag: 2548, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,393+0000 INFO  RequestHandler Handler(tag: 68, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,394+0000 INFO  GetFileHandler Handler(tag: 3012, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,394+0000 INFO  GetFileHandler Handler(tag: 3012, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,394+0000 INFO  GetFileHandler Handler(tag: 3012, GET) -> 69
-2013-08-27 01:13:59,394+0000 INFO  GetFileHandler Handler(tag: 69, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,394+0000 INFO  GetFileHandler Handler(tag: 2549, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,394+0000 INFO  GetFileHandler Handler(tag: 2549, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,394+0000 INFO  GetFileHandler Handler(tag: 69, GET) reader: LR-Handler(tag: 69, GET)
-2013-08-27 01:13:59,394+0000 INFO  GetFileHandler Handler(tag: 2549, GET) -> 70
-2013-08-27 01:13:59,394+0000 INFO  GetFileHandler Handler(tag: 69, GET) sending length: 1925, 1280890835
-2013-08-27 01:13:59,394+0000 INFO  ReadBuffer RB-LR-Handler(tag: 69, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,394+0000 INFO  GetFileHandler Handler(tag: 3012, GET) sending length: 1925, 1556186317
-2013-08-27 01:13:59,394+0000 INFO  ReadBuffer RB-LR-Handler(tag: 69, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,394+0000 INFO  LocalIOProvider LR-Handler(tag: 69, GET) rbuf: RB-LR-Handler(tag: 69, GET)
-2013-08-27 01:13:59,394+0000 INFO  GetFileHandler Handler(tag: 69, GET) unregistering (last)
-2013-08-27 01:13:59,394+0000 INFO  GetFileHandler Handler(tag: 70, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,394+0000 INFO  ReadBuffer RB-LR-Handler(tag: 69, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,394+0000 INFO  GetFileHandler Handler(tag: 3012, GET) unregistering (last)
-2013-08-27 01:13:59,394+0000 INFO  GetFileHandler Handler(tag: 70, GET) reader: LR-Handler(tag: 70, GET)
-2013-08-27 01:13:59,395+0000 INFO  GetFileHandler Handler(tag: 70, GET) sending length: 1925, 757303999
-2013-08-27 01:13:59,395+0000 INFO  GetFileHandler Handler(tag: 2549, GET) sending length: 1925, 102017729
-2013-08-27 01:13:59,395+0000 INFO  ReadBuffer RB-LR-Handler(tag: 70, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,395+0000 INFO  ReadBuffer RB-LR-Handler(tag: 70, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,395+0000 INFO  LocalIOProvider LR-Handler(tag: 70, GET) rbuf: RB-LR-Handler(tag: 70, GET)
-2013-08-27 01:13:59,395+0000 INFO  GetFileHandler Handler(tag: 70, GET) unregistering (last)
-2013-08-27 01:13:59,395+0000 INFO  GetFileHandler Handler(tag: 2549, GET) unregistering (last)
-2013-08-27 01:13:59,395+0000 INFO  ReadBuffer RB-LR-Handler(tag: 70, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,395+0000 INFO  RequestHandler Handler(tag: 71, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,395+0000 INFO  RequestHandler Handler(tag: 72, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,395+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:13:59,395+0000 INFO  RequestHandler Handler(tag: 3013, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,396+0000 INFO  RequestHandler Handler(tag: 73, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,396+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:13:59,396+0000 INFO  RequestHandler Handler(tag: 2550, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,396+0000 INFO  RequestHandler Handler(tag: 74, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,396+0000 INFO  GetFileHandler Handler(tag: 3014, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,396+0000 INFO  GetFileHandler Handler(tag: 3014, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,396+0000 INFO  GetFileHandler Handler(tag: 3014, GET) -> 75
-2013-08-27 01:13:59,396+0000 INFO  GetFileHandler Handler(tag: 75, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,396+0000 INFO  GetFileHandler Handler(tag: 2551, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,396+0000 INFO  GetFileHandler Handler(tag: 75, GET) reader: LR-Handler(tag: 75, GET)
-2013-08-27 01:13:59,396+0000 INFO  GetFileHandler Handler(tag: 2551, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,396+0000 INFO  GetFileHandler Handler(tag: 75, GET) sending length: 1925, 2111640038
-2013-08-27 01:13:59,396+0000 INFO  GetFileHandler Handler(tag: 2551, GET) -> 76
-2013-08-27 01:13:59,396+0000 INFO  GetFileHandler Handler(tag: 3014, GET) sending length: 1925, 1019368344
-2013-08-27 01:13:59,396+0000 INFO  ReadBuffer RB-LR-Handler(tag: 75, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,396+0000 INFO  ReadBuffer RB-LR-Handler(tag: 75, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,396+0000 INFO  LocalIOProvider LR-Handler(tag: 75, GET) rbuf: RB-LR-Handler(tag: 75, GET)
-2013-08-27 01:13:59,396+0000 INFO  GetFileHandler Handler(tag: 75, GET) unregistering (last)
-2013-08-27 01:13:59,397+0000 INFO  ReadBuffer RB-LR-Handler(tag: 75, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,397+0000 INFO  GetFileHandler Handler(tag: 3014, GET) unregistering (last)
-2013-08-27 01:13:59,397+0000 INFO  GetFileHandler Handler(tag: 76, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,397+0000 INFO  GetFileHandler Handler(tag: 76, GET) reader: LR-Handler(tag: 76, GET)
-2013-08-27 01:13:59,397+0000 INFO  GetFileHandler Handler(tag: 76, GET) sending length: 1925, 822207122
-2013-08-27 01:13:59,397+0000 INFO  ReadBuffer RB-LR-Handler(tag: 76, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,397+0000 INFO  GetFileHandler Handler(tag: 2551, GET) sending length: 1925, 2091003888
-2013-08-27 01:13:59,397+0000 INFO  ReadBuffer RB-LR-Handler(tag: 76, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,397+0000 INFO  LocalIOProvider LR-Handler(tag: 76, GET) rbuf: RB-LR-Handler(tag: 76, GET)
-2013-08-27 01:13:59,397+0000 INFO  GetFileHandler Handler(tag: 76, GET) unregistering (last)
-2013-08-27 01:13:59,397+0000 INFO  ReadBuffer RB-LR-Handler(tag: 76, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,397+0000 INFO  GetFileHandler Handler(tag: 2551, GET) unregistering (last)
-2013-08-27 01:13:59,397+0000 INFO  RequestHandler Handler(tag: 77, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,397+0000 INFO  RequestHandler Handler(tag: 78, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,398+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:13:59,398+0000 INFO  RequestHandler Handler(tag: 3015, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,398+0000 INFO  RequestHandler Handler(tag: 79, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,398+0000 INFO  RequestHandler Handler(tag: 2552, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,398+0000 INFO  RequestHandler Handler(tag: 80, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,398+0000 INFO  GetFileHandler Handler(tag: 3016, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,398+0000 INFO  GetFileHandler Handler(tag: 3016, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,398+0000 INFO  GetFileHandler Handler(tag: 3016, GET) -> 81
-2013-08-27 01:13:59,398+0000 INFO  GetFileHandler Handler(tag: 81, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,398+0000 INFO  GetFileHandler Handler(tag: 2553, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,398+0000 INFO  GetFileHandler Handler(tag: 2553, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,398+0000 INFO  GetFileHandler Handler(tag: 81, GET) reader: LR-Handler(tag: 81, GET)
-2013-08-27 01:13:59,399+0000 INFO  GetFileHandler Handler(tag: 2553, GET) -> 82
-2013-08-27 01:13:59,399+0000 INFO  GetFileHandler Handler(tag: 81, GET) sending length: 1925, 1585222203
-2013-08-27 01:13:59,399+0000 INFO  GetFileHandler Handler(tag: 3016, GET) sending length: 1925, 1147441139
-2013-08-27 01:13:59,399+0000 INFO  ReadBuffer RB-LR-Handler(tag: 81, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,399+0000 INFO  ReadBuffer RB-LR-Handler(tag: 81, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,399+0000 INFO  LocalIOProvider LR-Handler(tag: 81, GET) rbuf: RB-LR-Handler(tag: 81, GET)
-2013-08-27 01:13:59,399+0000 INFO  GetFileHandler Handler(tag: 81, GET) unregistering (last)
-2013-08-27 01:13:59,399+0000 INFO  GetFileHandler Handler(tag: 82, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,399+0000 INFO  ReadBuffer RB-LR-Handler(tag: 81, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,399+0000 INFO  GetFileHandler Handler(tag: 3016, GET) unregistering (last)
-2013-08-27 01:13:59,399+0000 INFO  GetFileHandler Handler(tag: 82, GET) reader: LR-Handler(tag: 82, GET)
-2013-08-27 01:13:59,399+0000 INFO  GetFileHandler Handler(tag: 82, GET) sending length: 1925, 362965846
-2013-08-27 01:13:59,399+0000 INFO  GetFileHandler Handler(tag: 2553, GET) sending length: 1925, 27107283
-2013-08-27 01:13:59,399+0000 INFO  ReadBuffer RB-LR-Handler(tag: 82, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,399+0000 INFO  ReadBuffer RB-LR-Handler(tag: 82, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,399+0000 INFO  LocalIOProvider LR-Handler(tag: 82, GET) rbuf: RB-LR-Handler(tag: 82, GET)
-2013-08-27 01:13:59,399+0000 INFO  GetFileHandler Handler(tag: 82, GET) unregistering (last)
-2013-08-27 01:13:59,399+0000 INFO  ReadBuffer RB-LR-Handler(tag: 82, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,399+0000 INFO  GetFileHandler Handler(tag: 2553, GET) unregistering (last)
-2013-08-27 01:13:59,399+0000 INFO  RequestHandler Handler(tag: 83, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,400+0000 INFO  RequestHandler Handler(tag: 84, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,400+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:13:59,400+0000 INFO  RequestHandler Handler(tag: 3017, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,400+0000 INFO  RequestHandler Handler(tag: 85, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,400+0000 INFO  RequestHandler Handler(tag: 2554, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,400+0000 INFO  RequestHandler Handler(tag: 86, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,400+0000 INFO  GetFileHandler Handler(tag: 3018, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,400+0000 INFO  GetFileHandler Handler(tag: 3018, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,401+0000 INFO  GetFileHandler Handler(tag: 3018, GET) -> 87
-2013-08-27 01:13:59,401+0000 INFO  GetFileHandler Handler(tag: 87, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,401+0000 INFO  GetFileHandler Handler(tag: 2555, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,401+0000 INFO  GetFileHandler Handler(tag: 2555, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,401+0000 INFO  GetFileHandler Handler(tag: 87, GET) reader: LR-Handler(tag: 87, GET)
-2013-08-27 01:13:59,401+0000 INFO  GetFileHandler Handler(tag: 2555, GET) -> 88
-2013-08-27 01:13:59,401+0000 INFO  GetFileHandler Handler(tag: 87, GET) sending length: 1925, 1958960935
-2013-08-27 01:13:59,401+0000 INFO  GetFileHandler Handler(tag: 3018, GET) sending length: 1925, 1184642388
-2013-08-27 01:13:59,401+0000 INFO  ReadBuffer RB-LR-Handler(tag: 87, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,401+0000 INFO  ReadBuffer RB-LR-Handler(tag: 87, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,401+0000 INFO  LocalIOProvider LR-Handler(tag: 87, GET) rbuf: RB-LR-Handler(tag: 87, GET)
-2013-08-27 01:13:59,401+0000 INFO  GetFileHandler Handler(tag: 87, GET) unregistering (last)
-2013-08-27 01:13:59,401+0000 INFO  GetFileHandler Handler(tag: 88, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,401+0000 INFO  ReadBuffer RB-LR-Handler(tag: 87, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,401+0000 INFO  GetFileHandler Handler(tag: 3018, GET) unregistering (last)
-2013-08-27 01:13:59,401+0000 INFO  GetFileHandler Handler(tag: 88, GET) reader: LR-Handler(tag: 88, GET)
-2013-08-27 01:13:59,401+0000 INFO  GetFileHandler Handler(tag: 88, GET) sending length: 1925, 11877363
-2013-08-27 01:13:59,401+0000 INFO  ReadBuffer RB-LR-Handler(tag: 88, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,401+0000 INFO  GetFileHandler Handler(tag: 2555, GET) sending length: 1925, 229464416
-2013-08-27 01:13:59,401+0000 INFO  ReadBuffer RB-LR-Handler(tag: 88, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,401+0000 INFO  LocalIOProvider LR-Handler(tag: 88, GET) rbuf: RB-LR-Handler(tag: 88, GET)
-2013-08-27 01:13:59,401+0000 INFO  GetFileHandler Handler(tag: 88, GET) unregistering (last)
-2013-08-27 01:13:59,401+0000 INFO  ReadBuffer RB-LR-Handler(tag: 88, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,401+0000 INFO  RequestHandler Handler(tag: 89, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,401+0000 INFO  GetFileHandler Handler(tag: 2555, GET) unregistering (last)
-2013-08-27 01:13:59,402+0000 INFO  RequestHandler Handler(tag: 90, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,402+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:13:59,402+0000 INFO  RequestHandler Handler(tag: 3019, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,402+0000 INFO  RequestHandler Handler(tag: 91, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,402+0000 INFO  RequestHandler Handler(tag: 2556, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,402+0000 INFO  RequestHandler Handler(tag: 92, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,403+0000 INFO  GetFileHandler Handler(tag: 3020, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,403+0000 INFO  GetFileHandler Handler(tag: 3020, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,403+0000 INFO  GetFileHandler Handler(tag: 3020, GET) -> 93
-2013-08-27 01:13:59,403+0000 INFO  GetFileHandler Handler(tag: 93, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,403+0000 INFO  GetFileHandler Handler(tag: 2557, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,403+0000 INFO  GetFileHandler Handler(tag: 2557, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,403+0000 INFO  GetFileHandler Handler(tag: 93, GET) reader: LR-Handler(tag: 93, GET)
-2013-08-27 01:13:59,403+0000 INFO  GetFileHandler Handler(tag: 2557, GET) -> 94
-2013-08-27 01:13:59,403+0000 INFO  GetFileHandler Handler(tag: 93, GET) sending length: 1925, 1724859291
-2013-08-27 01:13:59,403+0000 INFO  GetFileHandler Handler(tag: 3020, GET) sending length: 1925, 828352984
-2013-08-27 01:13:59,403+0000 INFO  ReadBuffer RB-LR-Handler(tag: 93, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,403+0000 INFO  ReadBuffer RB-LR-Handler(tag: 93, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,403+0000 INFO  LocalIOProvider LR-Handler(tag: 93, GET) rbuf: RB-LR-Handler(tag: 93, GET)
-2013-08-27 01:13:59,403+0000 INFO  GetFileHandler Handler(tag: 93, GET) unregistering (last)
-2013-08-27 01:13:59,403+0000 INFO  GetFileHandler Handler(tag: 94, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,403+0000 INFO  GetFileHandler Handler(tag: 3020, GET) unregistering (last)
-2013-08-27 01:13:59,403+0000 INFO  ReadBuffer RB-LR-Handler(tag: 93, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,403+0000 INFO  GetFileHandler Handler(tag: 94, GET) reader: LR-Handler(tag: 94, GET)
-2013-08-27 01:13:59,403+0000 INFO  GetFileHandler Handler(tag: 94, GET) sending length: 1925, 113324400
-2013-08-27 01:13:59,403+0000 INFO  ReadBuffer RB-LR-Handler(tag: 94, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,403+0000 INFO  GetFileHandler Handler(tag: 2557, GET) sending length: 1925, 1972679558
-2013-08-27 01:13:59,403+0000 INFO  ReadBuffer RB-LR-Handler(tag: 94, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,403+0000 INFO  LocalIOProvider LR-Handler(tag: 94, GET) rbuf: RB-LR-Handler(tag: 94, GET)
-2013-08-27 01:13:59,403+0000 INFO  GetFileHandler Handler(tag: 94, GET) unregistering (last)
-2013-08-27 01:13:59,404+0000 INFO  ReadBuffer RB-LR-Handler(tag: 94, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,404+0000 INFO  GetFileHandler Handler(tag: 2557, GET) unregistering (last)
-2013-08-27 01:13:59,404+0000 INFO  RequestHandler Handler(tag: 95, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,404+0000 INFO  RequestHandler Handler(tag: 96, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,404+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:13:59,404+0000 INFO  RequestHandler Handler(tag: 3021, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,404+0000 INFO  RequestHandler Handler(tag: 97, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,404+0000 INFO  RequestHandler Handler(tag: 2558, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,405+0000 INFO  RequestHandler Handler(tag: 98, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,405+0000 INFO  GetFileHandler Handler(tag: 3022, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,405+0000 INFO  GetFileHandler Handler(tag: 3022, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,405+0000 INFO  GetFileHandler Handler(tag: 3022, GET) -> 99
-2013-08-27 01:13:59,405+0000 INFO  GetFileHandler Handler(tag: 99, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,405+0000 INFO  GetFileHandler Handler(tag: 2559, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,405+0000 INFO  GetFileHandler Handler(tag: 2559, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,405+0000 INFO  GetFileHandler Handler(tag: 99, GET) reader: LR-Handler(tag: 99, GET)
-2013-08-27 01:13:59,405+0000 INFO  GetFileHandler Handler(tag: 2559, GET) -> 100
-2013-08-27 01:13:59,405+0000 INFO  GetFileHandler Handler(tag: 99, GET) sending length: 1925, 1266137668
-2013-08-27 01:13:59,405+0000 INFO  ReadBuffer RB-LR-Handler(tag: 99, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,405+0000 INFO  GetFileHandler Handler(tag: 3022, GET) sending length: 1925, 560327953
-2013-08-27 01:13:59,405+0000 INFO  ReadBuffer RB-LR-Handler(tag: 99, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,405+0000 INFO  LocalIOProvider LR-Handler(tag: 99, GET) rbuf: RB-LR-Handler(tag: 99, GET)
-2013-08-27 01:13:59,405+0000 INFO  GetFileHandler Handler(tag: 99, GET) unregistering (last)
-2013-08-27 01:13:59,405+0000 INFO  GetFileHandler Handler(tag: 100, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,406+0000 INFO  ReadBuffer RB-LR-Handler(tag: 99, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,406+0000 INFO  GetFileHandler Handler(tag: 3022, GET) unregistering (last)
-2013-08-27 01:13:59,406+0000 INFO  GetFileHandler Handler(tag: 100, GET) reader: LR-Handler(tag: 100, GET)
-2013-08-27 01:13:59,406+0000 INFO  GetFileHandler Handler(tag: 100, GET) sending length: 1925, 861309059
-2013-08-27 01:13:59,406+0000 INFO  ReadBuffer RB-LR-Handler(tag: 100, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,406+0000 INFO  GetFileHandler Handler(tag: 2559, GET) sending length: 1925, 1981573833
-2013-08-27 01:13:59,406+0000 INFO  ReadBuffer RB-LR-Handler(tag: 100, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,406+0000 INFO  LocalIOProvider LR-Handler(tag: 100, GET) rbuf: RB-LR-Handler(tag: 100, GET)
-2013-08-27 01:13:59,406+0000 INFO  GetFileHandler Handler(tag: 100, GET) unregistering (last)
-2013-08-27 01:13:59,406+0000 INFO  GetFileHandler Handler(tag: 2559, GET) unregistering (last)
-2013-08-27 01:13:59,406+0000 INFO  ReadBuffer RB-LR-Handler(tag: 100, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,406+0000 INFO  RequestHandler Handler(tag: 101, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,406+0000 INFO  RequestHandler Handler(tag: 102, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,407+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:13:59,407+0000 INFO  RequestHandler Handler(tag: 3023, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,407+0000 INFO  RequestHandler Handler(tag: 103, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,407+0000 INFO  RequestHandler Handler(tag: 2560, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,407+0000 INFO  RequestHandler Handler(tag: 104, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,407+0000 INFO  GetFileHandler Handler(tag: 3024, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,407+0000 INFO  GetFileHandler Handler(tag: 3024, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,407+0000 INFO  GetFileHandler Handler(tag: 3024, GET) -> 105
-2013-08-27 01:13:59,407+0000 INFO  GetFileHandler Handler(tag: 105, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,407+0000 INFO  GetFileHandler Handler(tag: 2561, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,407+0000 INFO  GetFileHandler Handler(tag: 2561, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,407+0000 INFO  GetFileHandler Handler(tag: 105, GET) reader: LR-Handler(tag: 105, GET)
-2013-08-27 01:13:59,407+0000 INFO  GetFileHandler Handler(tag: 2561, GET) -> 106
-2013-08-27 01:13:59,407+0000 INFO  GetFileHandler Handler(tag: 105, GET) sending length: 1925, 962070825
-2013-08-27 01:13:59,407+0000 INFO  GetFileHandler Handler(tag: 3024, GET) sending length: 1925, 1119977512
-2013-08-27 01:13:59,407+0000 INFO  ReadBuffer RB-LR-Handler(tag: 105, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,407+0000 INFO  ReadBuffer RB-LR-Handler(tag: 105, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,407+0000 INFO  LocalIOProvider LR-Handler(tag: 105, GET) rbuf: RB-LR-Handler(tag: 105, GET)
-2013-08-27 01:13:59,407+0000 INFO  GetFileHandler Handler(tag: 105, GET) unregistering (last)
-2013-08-27 01:13:59,407+0000 INFO  GetFileHandler Handler(tag: 106, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,408+0000 INFO  ReadBuffer RB-LR-Handler(tag: 105, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,408+0000 INFO  GetFileHandler Handler(tag: 3024, GET) unregistering (last)
-2013-08-27 01:13:59,408+0000 INFO  GetFileHandler Handler(tag: 106, GET) reader: LR-Handler(tag: 106, GET)
-2013-08-27 01:13:59,408+0000 INFO  GetFileHandler Handler(tag: 106, GET) sending length: 1925, 1251476784
-2013-08-27 01:13:59,408+0000 INFO  GetFileHandler Handler(tag: 2561, GET) sending length: 1925, 1275442086
-2013-08-27 01:13:59,408+0000 INFO  ReadBuffer RB-LR-Handler(tag: 106, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,408+0000 INFO  ReadBuffer RB-LR-Handler(tag: 106, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,408+0000 INFO  LocalIOProvider LR-Handler(tag: 106, GET) rbuf: RB-LR-Handler(tag: 106, GET)
-2013-08-27 01:13:59,408+0000 INFO  GetFileHandler Handler(tag: 106, GET) unregistering (last)
-2013-08-27 01:13:59,408+0000 INFO  ReadBuffer RB-LR-Handler(tag: 106, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,408+0000 INFO  GetFileHandler Handler(tag: 2561, GET) unregistering (last)
-2013-08-27 01:13:59,408+0000 INFO  RequestHandler Handler(tag: 107, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,408+0000 INFO  RequestHandler Handler(tag: 108, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,408+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:13:59,408+0000 INFO  RequestHandler Handler(tag: 3025, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,409+0000 INFO  RequestHandler Handler(tag: 109, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,409+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:13:59,409+0000 INFO  RequestHandler Handler(tag: 2562, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,409+0000 INFO  RequestHandler Handler(tag: 110, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,409+0000 INFO  GetFileHandler Handler(tag: 3026, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,409+0000 INFO  GetFileHandler Handler(tag: 3026, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,409+0000 INFO  GetFileHandler Handler(tag: 3026, GET) -> 111
-2013-08-27 01:13:59,409+0000 INFO  GetFileHandler Handler(tag: 111, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,409+0000 INFO  GetFileHandler Handler(tag: 2563, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,409+0000 INFO  GetFileHandler Handler(tag: 2563, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,409+0000 INFO  GetFileHandler Handler(tag: 111, GET) reader: LR-Handler(tag: 111, GET)
-2013-08-27 01:13:59,409+0000 INFO  GetFileHandler Handler(tag: 2563, GET) -> 112
-2013-08-27 01:13:59,409+0000 INFO  GetFileHandler Handler(tag: 111, GET) sending length: 1925, 943319734
-2013-08-27 01:13:59,409+0000 INFO  GetFileHandler Handler(tag: 3026, GET) sending length: 1925, 1650487184
-2013-08-27 01:13:59,409+0000 INFO  ReadBuffer RB-LR-Handler(tag: 111, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,409+0000 INFO  ReadBuffer RB-LR-Handler(tag: 111, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,409+0000 INFO  LocalIOProvider LR-Handler(tag: 111, GET) rbuf: RB-LR-Handler(tag: 111, GET)
-2013-08-27 01:13:59,409+0000 INFO  GetFileHandler Handler(tag: 111, GET) unregistering (last)
-2013-08-27 01:13:59,409+0000 INFO  GetFileHandler Handler(tag: 112, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,409+0000 INFO  ReadBuffer RB-LR-Handler(tag: 111, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,409+0000 INFO  GetFileHandler Handler(tag: 3026, GET) unregistering (last)
-2013-08-27 01:13:59,409+0000 INFO  GetFileHandler Handler(tag: 112, GET) reader: LR-Handler(tag: 112, GET)
-2013-08-27 01:13:59,409+0000 INFO  GetFileHandler Handler(tag: 112, GET) sending length: 1925, 1848873994
-2013-08-27 01:13:59,410+0000 INFO  GetFileHandler Handler(tag: 2563, GET) sending length: 1925, 2006582799
-2013-08-27 01:13:59,410+0000 INFO  ReadBuffer RB-LR-Handler(tag: 112, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,410+0000 INFO  ReadBuffer RB-LR-Handler(tag: 112, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,410+0000 INFO  LocalIOProvider LR-Handler(tag: 112, GET) rbuf: RB-LR-Handler(tag: 112, GET)
-2013-08-27 01:13:59,410+0000 INFO  GetFileHandler Handler(tag: 112, GET) unregistering (last)
-2013-08-27 01:13:59,410+0000 INFO  ReadBuffer RB-LR-Handler(tag: 112, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,410+0000 INFO  GetFileHandler Handler(tag: 2563, GET) unregistering (last)
-2013-08-27 01:13:59,410+0000 INFO  RequestHandler Handler(tag: 113, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,410+0000 INFO  RequestHandler Handler(tag: 114, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,410+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:13:59,410+0000 INFO  RequestHandler Handler(tag: 3027, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,410+0000 INFO  RequestHandler Handler(tag: 115, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,410+0000 INFO  RequestHandler Handler(tag: 2564, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,411+0000 INFO  RequestHandler Handler(tag: 116, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,411+0000 INFO  GetFileHandler Handler(tag: 3028, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,411+0000 INFO  GetFileHandler Handler(tag: 3028, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,411+0000 INFO  GetFileHandler Handler(tag: 3028, GET) -> 117
-2013-08-27 01:13:59,411+0000 INFO  GetFileHandler Handler(tag: 117, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,411+0000 INFO  GetFileHandler Handler(tag: 2565, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,411+0000 INFO  GetFileHandler Handler(tag: 2565, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,411+0000 INFO  GetFileHandler Handler(tag: 117, GET) reader: LR-Handler(tag: 117, GET)
-2013-08-27 01:13:59,411+0000 INFO  GetFileHandler Handler(tag: 2565, GET) -> 118
-2013-08-27 01:13:59,411+0000 INFO  GetFileHandler Handler(tag: 117, GET) sending length: 1925, 664712664
-2013-08-27 01:13:59,411+0000 INFO  GetFileHandler Handler(tag: 3028, GET) sending length: 1925, 615812154
-2013-08-27 01:13:59,411+0000 INFO  ReadBuffer RB-LR-Handler(tag: 117, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,411+0000 INFO  ReadBuffer RB-LR-Handler(tag: 117, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,411+0000 INFO  LocalIOProvider LR-Handler(tag: 117, GET) rbuf: RB-LR-Handler(tag: 117, GET)
-2013-08-27 01:13:59,411+0000 INFO  GetFileHandler Handler(tag: 117, GET) unregistering (last)
-2013-08-27 01:13:59,411+0000 INFO  GetFileHandler Handler(tag: 118, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,411+0000 INFO  ReadBuffer RB-LR-Handler(tag: 117, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,411+0000 INFO  GetFileHandler Handler(tag: 3028, GET) unregistering (last)
-2013-08-27 01:13:59,411+0000 INFO  GetFileHandler Handler(tag: 118, GET) reader: LR-Handler(tag: 118, GET)
-2013-08-27 01:13:59,411+0000 INFO  GetFileHandler Handler(tag: 118, GET) sending length: 1925, 1222518691
-2013-08-27 01:13:59,411+0000 INFO  GetFileHandler Handler(tag: 2565, GET) sending length: 1925, 864373480
-2013-08-27 01:13:59,411+0000 INFO  ReadBuffer RB-LR-Handler(tag: 118, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,411+0000 INFO  ReadBuffer RB-LR-Handler(tag: 118, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,411+0000 INFO  LocalIOProvider LR-Handler(tag: 118, GET) rbuf: RB-LR-Handler(tag: 118, GET)
-2013-08-27 01:13:59,412+0000 INFO  GetFileHandler Handler(tag: 118, GET) unregistering (last)
-2013-08-27 01:13:59,412+0000 INFO  ReadBuffer RB-LR-Handler(tag: 118, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,412+0000 INFO  GetFileHandler Handler(tag: 2565, GET) unregistering (last)
-2013-08-27 01:13:59,412+0000 INFO  RequestHandler Handler(tag: 119, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,412+0000 INFO  RequestHandler Handler(tag: 120, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,412+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:13:59,412+0000 INFO  RequestHandler Handler(tag: 3029, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,412+0000 INFO  RequestHandler Handler(tag: 121, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,412+0000 INFO  RequestHandler Handler(tag: 2566, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,412+0000 INFO  RequestHandler Handler(tag: 122, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,413+0000 INFO  GetFileHandler Handler(tag: 3030, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,413+0000 INFO  GetFileHandler Handler(tag: 3030, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,413+0000 INFO  GetFileHandler Handler(tag: 3030, GET) -> 123
-2013-08-27 01:13:59,413+0000 INFO  GetFileHandler Handler(tag: 123, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,413+0000 INFO  GetFileHandler Handler(tag: 2567, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,413+0000 INFO  GetFileHandler Handler(tag: 2567, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,413+0000 INFO  GetFileHandler Handler(tag: 123, GET) reader: LR-Handler(tag: 123, GET)
-2013-08-27 01:13:59,413+0000 INFO  GetFileHandler Handler(tag: 2567, GET) -> 124
-2013-08-27 01:13:59,413+0000 INFO  GetFileHandler Handler(tag: 123, GET) sending length: 1925, 200473361
-2013-08-27 01:13:59,413+0000 INFO  ReadBuffer RB-LR-Handler(tag: 123, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,413+0000 INFO  GetFileHandler Handler(tag: 3030, GET) sending length: 1925, 2101419831
-2013-08-27 01:13:59,413+0000 INFO  ReadBuffer RB-LR-Handler(tag: 123, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,413+0000 INFO  LocalIOProvider LR-Handler(tag: 123, GET) rbuf: RB-LR-Handler(tag: 123, GET)
-2013-08-27 01:13:59,413+0000 INFO  GetFileHandler Handler(tag: 123, GET) unregistering (last)
-2013-08-27 01:13:59,413+0000 INFO  GetFileHandler Handler(tag: 124, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,413+0000 INFO  GetFileHandler Handler(tag: 3030, GET) unregistering (last)
-2013-08-27 01:13:59,413+0000 INFO  ReadBuffer RB-LR-Handler(tag: 123, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,413+0000 INFO  GetFileHandler Handler(tag: 124, GET) reader: LR-Handler(tag: 124, GET)
-2013-08-27 01:13:59,413+0000 INFO  GetFileHandler Handler(tag: 124, GET) sending length: 1925, 1274071252
-2013-08-27 01:13:59,413+0000 INFO  GetFileHandler Handler(tag: 2567, GET) sending length: 1925, 1861630750
-2013-08-27 01:13:59,413+0000 INFO  ReadBuffer RB-LR-Handler(tag: 124, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,413+0000 INFO  ReadBuffer RB-LR-Handler(tag: 124, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,413+0000 INFO  LocalIOProvider LR-Handler(tag: 124, GET) rbuf: RB-LR-Handler(tag: 124, GET)
-2013-08-27 01:13:59,413+0000 INFO  GetFileHandler Handler(tag: 124, GET) unregistering (last)
-2013-08-27 01:13:59,413+0000 INFO  ReadBuffer RB-LR-Handler(tag: 124, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,413+0000 INFO  GetFileHandler Handler(tag: 2567, GET) unregistering (last)
-2013-08-27 01:13:59,413+0000 INFO  RequestHandler Handler(tag: 125, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,414+0000 INFO  RequestHandler Handler(tag: 126, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,414+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:13:59,414+0000 INFO  RequestHandler Handler(tag: 3031, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,414+0000 INFO  RequestHandler Handler(tag: 127, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,414+0000 INFO  RequestHandler Handler(tag: 2568, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,414+0000 INFO  RequestHandler Handler(tag: 128, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,414+0000 INFO  GetFileHandler Handler(tag: 3032, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,414+0000 INFO  GetFileHandler Handler(tag: 3032, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,414+0000 INFO  GetFileHandler Handler(tag: 3032, GET) -> 129
-2013-08-27 01:13:59,415+0000 INFO  GetFileHandler Handler(tag: 129, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,415+0000 INFO  GetFileHandler Handler(tag: 2569, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,415+0000 INFO  GetFileHandler Handler(tag: 2569, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,415+0000 INFO  GetFileHandler Handler(tag: 129, GET) reader: LR-Handler(tag: 129, GET)
-2013-08-27 01:13:59,415+0000 INFO  GetFileHandler Handler(tag: 2569, GET) -> 130
-2013-08-27 01:13:59,415+0000 INFO  GetFileHandler Handler(tag: 129, GET) sending length: 1925, 108063412
-2013-08-27 01:13:59,415+0000 INFO  GetFileHandler Handler(tag: 3032, GET) sending length: 1925, 1598083769
-2013-08-27 01:13:59,415+0000 INFO  ReadBuffer RB-LR-Handler(tag: 129, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,415+0000 INFO  ReadBuffer RB-LR-Handler(tag: 129, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,415+0000 INFO  LocalIOProvider LR-Handler(tag: 129, GET) rbuf: RB-LR-Handler(tag: 129, GET)
-2013-08-27 01:13:59,415+0000 INFO  GetFileHandler Handler(tag: 129, GET) unregistering (last)
-2013-08-27 01:13:59,415+0000 INFO  GetFileHandler Handler(tag: 130, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,415+0000 INFO  ReadBuffer RB-LR-Handler(tag: 129, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,415+0000 INFO  GetFileHandler Handler(tag: 3032, GET) unregistering (last)
-2013-08-27 01:13:59,415+0000 INFO  GetFileHandler Handler(tag: 130, GET) reader: LR-Handler(tag: 130, GET)
-2013-08-27 01:13:59,415+0000 INFO  GetFileHandler Handler(tag: 130, GET) sending length: 1925, 803246987
-2013-08-27 01:13:59,415+0000 INFO  GetFileHandler Handler(tag: 2569, GET) sending length: 1925, 889755445
-2013-08-27 01:13:59,415+0000 INFO  ReadBuffer RB-LR-Handler(tag: 130, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,415+0000 INFO  ReadBuffer RB-LR-Handler(tag: 130, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,415+0000 INFO  LocalIOProvider LR-Handler(tag: 130, GET) rbuf: RB-LR-Handler(tag: 130, GET)
-2013-08-27 01:13:59,415+0000 INFO  GetFileHandler Handler(tag: 130, GET) unregistering (last)
-2013-08-27 01:13:59,415+0000 INFO  ReadBuffer RB-LR-Handler(tag: 130, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,415+0000 INFO  GetFileHandler Handler(tag: 2569, GET) unregistering (last)
-2013-08-27 01:13:59,415+0000 INFO  GetFileHandler Handler(tag: 2570, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,415+0000 INFO  RequestHandler Handler(tag: 131, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,415+0000 INFO  GetFileHandler Handler(tag: 2570, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,415+0000 INFO  GetFileHandler Handler(tag: 2570, GET) -> 132
-2013-08-27 01:13:59,416+0000 INFO  GetFileHandler Handler(tag: 132, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,416+0000 INFO  GetFileHandler Handler(tag: 132, GET) reader: LR-Handler(tag: 132, GET)
-2013-08-27 01:13:59,416+0000 INFO  GetFileHandler Handler(tag: 132, GET) sending length: 14799449, 1215840334
-2013-08-27 01:13:59,416+0000 INFO  ReadBuffer RB-LR-Handler(tag: 132, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,416+0000 INFO  GetFileHandler Handler(tag: 2570, GET) sending length: 14799449, 1321592333
-2013-08-27 01:13:59,416+0000 INFO  ReadBuffer RB-LR-Handler(tag: 132, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,416+0000 INFO  LocalIOProvider LR-Handler(tag: 132, GET) rbuf: RB-LR-Handler(tag: 132, GET)
-2013-08-27 01:13:59,416+0000 INFO  GetFileHandler Handler(tag: 2571, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,416+0000 INFO  GetFileHandler Handler(tag: 2571, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,416+0000 INFO  GetFileHandler Handler(tag: 2571, GET) -> 133
-2013-08-27 01:13:59,416+0000 INFO  GetFileHandler Handler(tag: 133, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,416+0000 INFO  GetFileHandler Handler(tag: 133, GET) reader: LR-Handler(tag: 133, GET)
-2013-08-27 01:13:59,416+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:13:59,416+0000 INFO  GetFileHandler Handler(tag: 133, GET) sending length: 14799449, 2115195389
-2013-08-27 01:13:59,416+0000 INFO  ReadBuffer RB-LR-Handler(tag: 133, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,416+0000 INFO  RequestHandler Handler(tag: 3033, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,416+0000 INFO  GetFileHandler Handler(tag: 2571, GET) sending length: 14799449, 2060905927
-2013-08-27 01:13:59,416+0000 INFO  ReadBuffer RB-LR-Handler(tag: 133, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,416+0000 INFO  LocalIOProvider LR-Handler(tag: 133, GET) rbuf: RB-LR-Handler(tag: 133, GET)
-2013-08-27 01:13:59,416+0000 INFO  RequestHandler Handler(tag: 134, JOBSTATUS) unregistering (send)
-2013-08-27 01:13:59,416+0000 INFO  GetFileHandler Handler(tag: 2572, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,416+0000 INFO  GetFileHandler Handler(tag: 2572, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,417+0000 INFO  GetFileHandler Handler(tag: 2572, GET) -> 135
-2013-08-27 01:13:59,417+0000 INFO  GetFileHandler Handler(tag: 135, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,417+0000 INFO  GetFileHandler Handler(tag: 3034, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,417+0000 INFO  GetFileHandler Handler(tag: 135, GET) reader: LR-Handler(tag: 135, GET)
-2013-08-27 01:13:59,417+0000 INFO  GetFileHandler Handler(tag: 135, GET) sending length: 14799449, 837249672
-2013-08-27 01:13:59,417+0000 INFO  GetFileHandler Handler(tag: 3034, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,417+0000 INFO  ReadBuffer RB-LR-Handler(tag: 135, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,417+0000 INFO  GetFileHandler Handler(tag: 2572, GET) sending length: 14799449, 1342382160
-2013-08-27 01:13:59,417+0000 INFO  GetFileHandler Handler(tag: 3034, GET) -> 136
-2013-08-27 01:13:59,417+0000 INFO  ReadBuffer RB-LR-Handler(tag: 135, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,417+0000 INFO  LocalIOProvider LR-Handler(tag: 135, GET) rbuf: RB-LR-Handler(tag: 135, GET)
-2013-08-27 01:13:59,417+0000 INFO  GetFileHandler Handler(tag: 136, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:13:59,417+0000 INFO  GetFileHandler Handler(tag: 136, GET) reader: LR-Handler(tag: 136, GET)
-2013-08-27 01:13:59,417+0000 INFO  GetFileHandler Handler(tag: 136, GET) sending length: 1925, 363452780
-2013-08-27 01:13:59,417+0000 INFO  ReadBuffer RB-LR-Handler(tag: 136, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:13:59,417+0000 INFO  GetFileHandler Handler(tag: 3034, GET) sending length: 1925, 1665770442
-2013-08-27 01:13:59,417+0000 INFO  ReadBuffer RB-LR-Handler(tag: 136, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:13:59,417+0000 INFO  LocalIOProvider LR-Handler(tag: 136, GET) rbuf: RB-LR-Handler(tag: 136, GET)
-2013-08-27 01:13:59,417+0000 INFO  GetFileHandler Handler(tag: 2573, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,417+0000 INFO  GetFileHandler Handler(tag: 2573, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,417+0000 INFO  GetFileHandler Handler(tag: 2573, GET) -> 137
-2013-08-27 01:13:59,417+0000 INFO  GetFileHandler Handler(tag: 137, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,417+0000 INFO  GetFileHandler Handler(tag: 3035, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,417+0000 INFO  GetFileHandler Handler(tag: 137, GET) reader: LR-Handler(tag: 137, GET)
-2013-08-27 01:13:59,417+0000 INFO  GetFileHandler Handler(tag: 3035, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,417+0000 INFO  GetFileHandler Handler(tag: 137, GET) sending length: 14799449, 1062884985
-2013-08-27 01:13:59,417+0000 INFO  GetFileHandler Handler(tag: 3035, GET) -> 138
-2013-08-27 01:13:59,417+0000 INFO  ReadBuffer RB-LR-Handler(tag: 137, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,417+0000 INFO  ReadBuffer RB-LR-Handler(tag: 137, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,417+0000 INFO  LocalIOProvider LR-Handler(tag: 137, GET) rbuf: RB-LR-Handler(tag: 137, GET)
-2013-08-27 01:13:59,417+0000 INFO  GetFileHandler Handler(tag: 2573, GET) sending length: 14799449, 2099127532
-2013-08-27 01:13:59,417+0000 INFO  GetFileHandler Handler(tag: 138, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,418+0000 INFO  GetFileHandler Handler(tag: 138, GET) reader: LR-Handler(tag: 138, GET)
-2013-08-27 01:13:59,418+0000 INFO  GetFileHandler Handler(tag: 138, GET) sending length: 14799449, 871046072
-2013-08-27 01:13:59,418+0000 INFO  ReadBuffer RB-LR-Handler(tag: 138, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,418+0000 INFO  ReadBuffer RB-LR-Handler(tag: 138, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,418+0000 INFO  LocalIOProvider LR-Handler(tag: 138, GET) rbuf: RB-LR-Handler(tag: 138, GET)
-2013-08-27 01:13:59,418+0000 INFO  GetFileHandler Handler(tag: 2574, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,418+0000 INFO  GetFileHandler Handler(tag: 3035, GET) sending length: 14799449, 1463881897
-2013-08-27 01:13:59,418+0000 INFO  GetFileHandler Handler(tag: 2574, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,418+0000 INFO  GetFileHandler Handler(tag: 2574, GET) -> 139
-2013-08-27 01:13:59,418+0000 INFO  GetFileHandler Handler(tag: 139, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,418+0000 INFO  GetFileHandler Handler(tag: 3036, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,418+0000 INFO  GetFileHandler Handler(tag: 139, GET) reader: LR-Handler(tag: 139, GET)
-2013-08-27 01:13:59,418+0000 INFO  GetFileHandler Handler(tag: 3036, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,418+0000 INFO  GetFileHandler Handler(tag: 139, GET) sending length: 14799449, 1791435811
-2013-08-27 01:13:59,418+0000 INFO  GetFileHandler Handler(tag: 3036, GET) -> 140
-2013-08-27 01:13:59,418+0000 INFO  ReadBuffer RB-LR-Handler(tag: 139, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,418+0000 INFO  ReadBuffer RB-LR-Handler(tag: 139, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,418+0000 INFO  GetFileHandler Handler(tag: 136, GET) unregistering (last)
-2013-08-27 01:13:59,418+0000 INFO  LocalIOProvider LR-Handler(tag: 139, GET) rbuf: RB-LR-Handler(tag: 139, GET)
-2013-08-27 01:13:59,418+0000 INFO  ReadBuffer RB-LR-Handler(tag: 136, GET) de-allocating 1 buffers
-2013-08-27 01:13:59,418+0000 INFO  GetFileHandler Handler(tag: 2574, GET) sending length: 14799449, 162554077
-2013-08-27 01:13:59,418+0000 INFO  GetFileHandler Handler(tag: 140, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,418+0000 INFO  GetFileHandler Handler(tag: 140, GET) reader: LR-Handler(tag: 140, GET)
-2013-08-27 01:13:59,418+0000 INFO  GetFileHandler Handler(tag: 3034, GET) unregistering (last)
-2013-08-27 01:13:59,418+0000 INFO  GetFileHandler Handler(tag: 140, GET) sending length: 14799449, 1145414168
-2013-08-27 01:13:59,419+0000 INFO  ReadBuffer RB-LR-Handler(tag: 140, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,419+0000 INFO  GetFileHandler Handler(tag: 2575, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,419+0000 INFO  ReadBuffer RB-LR-Handler(tag: 140, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,419+0000 INFO  GetFileHandler Handler(tag: 3036, GET) sending length: 14799449, 984397737
-2013-08-27 01:13:59,419+0000 INFO  LocalIOProvider LR-Handler(tag: 140, GET) rbuf: RB-LR-Handler(tag: 140, GET)
-2013-08-27 01:13:59,419+0000 INFO  GetFileHandler Handler(tag: 2575, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,419+0000 INFO  GetFileHandler Handler(tag: 2575, GET) -> 141
-2013-08-27 01:13:59,419+0000 INFO  GetFileHandler Handler(tag: 141, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,419+0000 INFO  GetFileHandler Handler(tag: 141, GET) reader: LR-Handler(tag: 141, GET)
-2013-08-27 01:13:59,419+0000 INFO  GetFileHandler Handler(tag: 3037, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,419+0000 INFO  GetFileHandler Handler(tag: 141, GET) sending length: 14799449, 30749609
-2013-08-27 01:13:59,419+0000 INFO  GetFileHandler Handler(tag: 3037, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,419+0000 INFO  GetFileHandler Handler(tag: 2575, GET) sending length: 14799449, 481990858
-2013-08-27 01:13:59,419+0000 INFO  ReadBuffer RB-LR-Handler(tag: 141, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,419+0000 INFO  GetFileHandler Handler(tag: 3037, GET) -> 142
-2013-08-27 01:13:59,419+0000 INFO  ReadBuffer RB-LR-Handler(tag: 141, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,419+0000 INFO  LocalIOProvider LR-Handler(tag: 141, GET) rbuf: RB-LR-Handler(tag: 141, GET)
-2013-08-27 01:13:59,419+0000 INFO  GetFileHandler Handler(tag: 142, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,419+0000 INFO  GetFileHandler Handler(tag: 142, GET) reader: LR-Handler(tag: 142, GET)
-2013-08-27 01:13:59,419+0000 INFO  GetFileHandler Handler(tag: 142, GET) sending length: 14799449, 787153525
-2013-08-27 01:13:59,419+0000 INFO  ReadBuffer RB-LR-Handler(tag: 142, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,419+0000 INFO  GetFileHandler Handler(tag: 3037, GET) sending length: 14799449, 1304803574
-2013-08-27 01:13:59,419+0000 INFO  ReadBuffer RB-LR-Handler(tag: 142, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,419+0000 INFO  LocalIOProvider LR-Handler(tag: 142, GET) rbuf: RB-LR-Handler(tag: 142, GET)
-2013-08-27 01:13:59,419+0000 INFO  GetFileHandler Handler(tag: 2576, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,419+0000 INFO  GetFileHandler Handler(tag: 2576, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,419+0000 INFO  GetFileHandler Handler(tag: 2576, GET) -> 143
-2013-08-27 01:13:59,419+0000 INFO  GetFileHandler Handler(tag: 143, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,419+0000 INFO  GetFileHandler Handler(tag: 3038, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,419+0000 INFO  GetFileHandler Handler(tag: 143, GET) reader: LR-Handler(tag: 143, GET)
-2013-08-27 01:13:59,420+0000 INFO  GetFileHandler Handler(tag: 3038, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,420+0000 INFO  GetFileHandler Handler(tag: 143, GET) sending length: 14799449, 183090454
-2013-08-27 01:13:59,420+0000 INFO  ReadBuffer RB-LR-Handler(tag: 143, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,420+0000 INFO  GetFileHandler Handler(tag: 3038, GET) -> 144
-2013-08-27 01:13:59,420+0000 INFO  ReadBuffer RB-LR-Handler(tag: 143, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,420+0000 INFO  LocalIOProvider LR-Handler(tag: 143, GET) rbuf: RB-LR-Handler(tag: 143, GET)
-2013-08-27 01:13:59,420+0000 INFO  GetFileHandler Handler(tag: 2576, GET) sending length: 14799449, 1787309096
-2013-08-27 01:13:59,420+0000 INFO  GetFileHandler Handler(tag: 144, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,420+0000 INFO  GetFileHandler Handler(tag: 144, GET) reader: LR-Handler(tag: 144, GET)
-2013-08-27 01:13:59,420+0000 INFO  GetFileHandler Handler(tag: 144, GET) sending length: 14799449, 741297553
-2013-08-27 01:13:59,420+0000 INFO  GetFileHandler Handler(tag: 3038, GET) sending length: 14799449, 1435337024
-2013-08-27 01:13:59,420+0000 INFO  ReadBuffer RB-LR-Handler(tag: 144, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,420+0000 INFO  ReadBuffer RB-LR-Handler(tag: 144, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,420+0000 INFO  GetFileHandler Handler(tag: 2577, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,420+0000 INFO  LocalIOProvider LR-Handler(tag: 144, GET) rbuf: RB-LR-Handler(tag: 144, GET)
-2013-08-27 01:13:59,420+0000 INFO  GetFileHandler Handler(tag: 2577, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,420+0000 INFO  GetFileHandler Handler(tag: 2577, GET) -> 145
-2013-08-27 01:13:59,420+0000 INFO  GetFileHandler Handler(tag: 145, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,420+0000 INFO  GetFileHandler Handler(tag: 3039, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,420+0000 INFO  GetFileHandler Handler(tag: 145, GET) reader: LR-Handler(tag: 145, GET)
-2013-08-27 01:13:59,420+0000 INFO  GetFileHandler Handler(tag: 3039, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,420+0000 INFO  GetFileHandler Handler(tag: 145, GET) sending length: 14799449, 809504097
-2013-08-27 01:13:59,420+0000 INFO  GetFileHandler Handler(tag: 3039, GET) -> 146
-2013-08-27 01:13:59,420+0000 INFO  ReadBuffer RB-LR-Handler(tag: 145, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,420+0000 INFO  GetFileHandler Handler(tag: 2577, GET) sending length: 14799449, 1026454534
-2013-08-27 01:13:59,420+0000 INFO  ReadBuffer RB-LR-Handler(tag: 145, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,420+0000 INFO  LocalIOProvider LR-Handler(tag: 145, GET) rbuf: RB-LR-Handler(tag: 145, GET)
-2013-08-27 01:13:59,421+0000 INFO  GetFileHandler Handler(tag: 146, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,421+0000 INFO  GetFileHandler Handler(tag: 146, GET) reader: LR-Handler(tag: 146, GET)
-2013-08-27 01:13:59,421+0000 INFO  GetFileHandler Handler(tag: 146, GET) sending length: 14799449, 1218523345
-2013-08-27 01:13:59,421+0000 INFO  ReadBuffer RB-LR-Handler(tag: 146, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,421+0000 INFO  GetFileHandler Handler(tag: 3039, GET) sending length: 14799449, 1293026250
-2013-08-27 01:13:59,421+0000 INFO  ReadBuffer RB-LR-Handler(tag: 146, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,421+0000 INFO  GetFileHandler Handler(tag: 2578, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,421+0000 INFO  LocalIOProvider LR-Handler(tag: 146, GET) rbuf: RB-LR-Handler(tag: 146, GET)
-2013-08-27 01:13:59,421+0000 INFO  GetFileHandler Handler(tag: 2578, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,421+0000 INFO  GetFileHandler Handler(tag: 2578, GET) -> 147
-2013-08-27 01:13:59,421+0000 INFO  GetFileHandler Handler(tag: 147, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,421+0000 INFO  GetFileHandler Handler(tag: 3040, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,421+0000 INFO  GetFileHandler Handler(tag: 147, GET) reader: LR-Handler(tag: 147, GET)
-2013-08-27 01:13:59,421+0000 INFO  GetFileHandler Handler(tag: 147, GET) sending length: 14799449, 1505159757
-2013-08-27 01:13:59,421+0000 INFO  GetFileHandler Handler(tag: 3040, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,421+0000 INFO  ReadBuffer RB-LR-Handler(tag: 147, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,421+0000 INFO  GetFileHandler Handler(tag: 3040, GET) -> 148
-2013-08-27 01:13:59,421+0000 INFO  ReadBuffer RB-LR-Handler(tag: 147, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,421+0000 INFO  GetFileHandler Handler(tag: 2578, GET) sending length: 14799449, 510855398
-2013-08-27 01:13:59,421+0000 INFO  LocalIOProvider LR-Handler(tag: 147, GET) rbuf: RB-LR-Handler(tag: 147, GET)
-2013-08-27 01:13:59,421+0000 INFO  GetFileHandler Handler(tag: 148, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,421+0000 INFO  GetFileHandler Handler(tag: 148, GET) reader: LR-Handler(tag: 148, GET)
-2013-08-27 01:13:59,421+0000 INFO  GetFileHandler Handler(tag: 148, GET) sending length: 14799449, 244634619
-2013-08-27 01:13:59,421+0000 INFO  ReadBuffer RB-LR-Handler(tag: 148, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,421+0000 INFO  GetFileHandler Handler(tag: 2579, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,421+0000 INFO  ReadBuffer RB-LR-Handler(tag: 148, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,421+0000 INFO  GetFileHandler Handler(tag: 3040, GET) sending length: 14799449, 1474260819
-2013-08-27 01:13:59,421+0000 INFO  LocalIOProvider LR-Handler(tag: 148, GET) rbuf: RB-LR-Handler(tag: 148, GET)
-2013-08-27 01:13:59,421+0000 INFO  GetFileHandler Handler(tag: 2579, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,421+0000 INFO  GetFileHandler Handler(tag: 2579, GET) -> 149
-2013-08-27 01:13:59,421+0000 INFO  GetFileHandler Handler(tag: 149, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,422+0000 INFO  GetFileHandler Handler(tag: 3041, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,422+0000 INFO  GetFileHandler Handler(tag: 149, GET) reader: LR-Handler(tag: 149, GET)
-2013-08-27 01:13:59,422+0000 INFO  GetFileHandler Handler(tag: 3041, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,422+0000 INFO  GetFileHandler Handler(tag: 149, GET) sending length: 14799449, 235265847
-2013-08-27 01:13:59,422+0000 INFO  GetFileHandler Handler(tag: 3041, GET) -> 150
-2013-08-27 01:13:59,422+0000 INFO  ReadBuffer RB-LR-Handler(tag: 149, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,422+0000 INFO  GetFileHandler Handler(tag: 2579, GET) sending length: 14799449, 300666100
-2013-08-27 01:13:59,422+0000 INFO  ReadBuffer RB-LR-Handler(tag: 149, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,422+0000 INFO  LocalIOProvider LR-Handler(tag: 149, GET) rbuf: RB-LR-Handler(tag: 149, GET)
-2013-08-27 01:13:59,422+0000 INFO  GetFileHandler Handler(tag: 150, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,422+0000 INFO  GetFileHandler Handler(tag: 150, GET) reader: LR-Handler(tag: 150, GET)
-2013-08-27 01:13:59,422+0000 INFO  GetFileHandler Handler(tag: 150, GET) sending length: 14799449, 266121309
-2013-08-27 01:13:59,422+0000 INFO  ReadBuffer RB-LR-Handler(tag: 150, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,422+0000 INFO  GetFileHandler Handler(tag: 2580, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,422+0000 INFO  ReadBuffer RB-LR-Handler(tag: 150, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,422+0000 INFO  GetFileHandler Handler(tag: 3041, GET) sending length: 14799449, 1315205412
-2013-08-27 01:13:59,422+0000 INFO  GetFileHandler Handler(tag: 2580, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,422+0000 INFO  LocalIOProvider LR-Handler(tag: 150, GET) rbuf: RB-LR-Handler(tag: 150, GET)
-2013-08-27 01:13:59,422+0000 INFO  GetFileHandler Handler(tag: 2580, GET) -> 151
-2013-08-27 01:13:59,422+0000 INFO  GetFileHandler Handler(tag: 151, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,422+0000 INFO  GetFileHandler Handler(tag: 3042, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,422+0000 INFO  GetFileHandler Handler(tag: 151, GET) reader: LR-Handler(tag: 151, GET)
-2013-08-27 01:13:59,422+0000 INFO  GetFileHandler Handler(tag: 3042, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,422+0000 INFO  GetFileHandler Handler(tag: 151, GET) sending length: 14799449, 608180913
-2013-08-27 01:13:59,422+0000 INFO  GetFileHandler Handler(tag: 3042, GET) -> 152
-2013-08-27 01:13:59,422+0000 INFO  ReadBuffer RB-LR-Handler(tag: 151, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,422+0000 INFO  ReadBuffer RB-LR-Handler(tag: 151, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,422+0000 INFO  GetFileHandler Handler(tag: 2580, GET) sending length: 14799449, 186640853
-2013-08-27 01:13:59,422+0000 INFO  LocalIOProvider LR-Handler(tag: 151, GET) rbuf: RB-LR-Handler(tag: 151, GET)
-2013-08-27 01:13:59,422+0000 INFO  GetFileHandler Handler(tag: 152, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,422+0000 INFO  GetFileHandler Handler(tag: 152, GET) reader: LR-Handler(tag: 152, GET)
-2013-08-27 01:13:59,422+0000 INFO  GetFileHandler Handler(tag: 152, GET) sending length: 14799449, 1546691751
-2013-08-27 01:13:59,423+0000 INFO  ReadBuffer RB-LR-Handler(tag: 152, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,423+0000 INFO  GetFileHandler Handler(tag: 2581, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,423+0000 INFO  ReadBuffer RB-LR-Handler(tag: 152, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,423+0000 INFO  LocalIOProvider LR-Handler(tag: 152, GET) rbuf: RB-LR-Handler(tag: 152, GET)
-2013-08-27 01:13:59,423+0000 INFO  GetFileHandler Handler(tag: 3042, GET) sending length: 14799449, 1376667533
-2013-08-27 01:13:59,423+0000 INFO  GetFileHandler Handler(tag: 2581, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,423+0000 INFO  GetFileHandler Handler(tag: 2581, GET) -> 153
-2013-08-27 01:13:59,423+0000 INFO  GetFileHandler Handler(tag: 153, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,423+0000 INFO  GetFileHandler Handler(tag: 3043, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,423+0000 INFO  GetFileHandler Handler(tag: 153, GET) reader: LR-Handler(tag: 153, GET)
-2013-08-27 01:13:59,423+0000 INFO  GetFileHandler Handler(tag: 153, GET) sending length: 14799449, 642804823
-2013-08-27 01:13:59,423+0000 INFO  GetFileHandler Handler(tag: 3043, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,423+0000 INFO  ReadBuffer RB-LR-Handler(tag: 153, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,423+0000 INFO  GetFileHandler Handler(tag: 3043, GET) -> 154
-2013-08-27 01:13:59,423+0000 INFO  ReadBuffer RB-LR-Handler(tag: 153, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,423+0000 INFO  GetFileHandler Handler(tag: 2581, GET) sending length: 14799449, 1342562699
-2013-08-27 01:13:59,423+0000 INFO  LocalIOProvider LR-Handler(tag: 153, GET) rbuf: RB-LR-Handler(tag: 153, GET)
-2013-08-27 01:13:59,423+0000 INFO  GetFileHandler Handler(tag: 154, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,423+0000 INFO  GetFileHandler Handler(tag: 154, GET) reader: LR-Handler(tag: 154, GET)
-2013-08-27 01:13:59,423+0000 INFO  GetFileHandler Handler(tag: 154, GET) sending length: 14799449, 840603064
-2013-08-27 01:13:59,423+0000 INFO  ReadBuffer RB-LR-Handler(tag: 154, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,423+0000 INFO  ReadBuffer RB-LR-Handler(tag: 154, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,423+0000 INFO  LocalIOProvider LR-Handler(tag: 154, GET) rbuf: RB-LR-Handler(tag: 154, GET)
-2013-08-27 01:13:59,423+0000 INFO  GetFileHandler Handler(tag: 2582, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,423+0000 INFO  GetFileHandler Handler(tag: 3043, GET) sending length: 14799449, 1599721587
-2013-08-27 01:13:59,423+0000 INFO  GetFileHandler Handler(tag: 2582, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,423+0000 INFO  GetFileHandler Handler(tag: 2582, GET) -> 155
-2013-08-27 01:13:59,423+0000 INFO  GetFileHandler Handler(tag: 155, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,423+0000 INFO  GetFileHandler Handler(tag: 3044, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,423+0000 INFO  GetFileHandler Handler(tag: 155, GET) reader: LR-Handler(tag: 155, GET)
-2013-08-27 01:13:59,423+0000 INFO  GetFileHandler Handler(tag: 3044, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,423+0000 INFO  GetFileHandler Handler(tag: 155, GET) sending length: 14799449, 427039330
-2013-08-27 01:13:59,423+0000 INFO  GetFileHandler Handler(tag: 3044, GET) -> 156
-2013-08-27 01:13:59,423+0000 INFO  ReadBuffer RB-LR-Handler(tag: 155, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,423+0000 INFO  ReadBuffer RB-LR-Handler(tag: 155, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,423+0000 INFO  LocalIOProvider LR-Handler(tag: 155, GET) rbuf: RB-LR-Handler(tag: 155, GET)
-2013-08-27 01:13:59,424+0000 INFO  GetFileHandler Handler(tag: 156, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,424+0000 INFO  GetFileHandler Handler(tag: 2582, GET) sending length: 14799449, 1972119394
-2013-08-27 01:13:59,424+0000 INFO  GetFileHandler Handler(tag: 156, GET) reader: LR-Handler(tag: 156, GET)
-2013-08-27 01:13:59,424+0000 INFO  GetFileHandler Handler(tag: 156, GET) sending length: 14799449, 1148047160
-2013-08-27 01:13:59,424+0000 INFO  ReadBuffer RB-LR-Handler(tag: 156, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,424+0000 INFO  ReadBuffer RB-LR-Handler(tag: 156, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,424+0000 INFO  GetFileHandler Handler(tag: 2583, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,424+0000 INFO  LocalIOProvider LR-Handler(tag: 156, GET) rbuf: RB-LR-Handler(tag: 156, GET)
-2013-08-27 01:13:59,424+0000 INFO  GetFileHandler Handler(tag: 2583, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,424+0000 INFO  GetFileHandler Handler(tag: 3044, GET) sending length: 14799449, 487248712
-2013-08-27 01:13:59,424+0000 INFO  GetFileHandler Handler(tag: 2583, GET) -> 157
-2013-08-27 01:13:59,424+0000 INFO  GetFileHandler Handler(tag: 157, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,424+0000 INFO  GetFileHandler Handler(tag: 3045, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,424+0000 INFO  GetFileHandler Handler(tag: 157, GET) reader: LR-Handler(tag: 157, GET)
-2013-08-27 01:13:59,424+0000 INFO  GetFileHandler Handler(tag: 3045, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,424+0000 INFO  GetFileHandler Handler(tag: 157, GET) sending length: 14799449, 1829842089
-2013-08-27 01:13:59,424+0000 INFO  GetFileHandler Handler(tag: 3045, GET) -> 158
-2013-08-27 01:13:59,424+0000 INFO  ReadBuffer RB-LR-Handler(tag: 157, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,424+0000 INFO  ReadBuffer RB-LR-Handler(tag: 157, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,424+0000 INFO  LocalIOProvider LR-Handler(tag: 157, GET) rbuf: RB-LR-Handler(tag: 157, GET)
-2013-08-27 01:13:59,424+0000 INFO  GetFileHandler Handler(tag: 158, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,424+0000 INFO  GetFileHandler Handler(tag: 2583, GET) sending length: 14799449, 82314654
-2013-08-27 01:13:59,424+0000 INFO  GetFileHandler Handler(tag: 158, GET) reader: LR-Handler(tag: 158, GET)
-2013-08-27 01:13:59,424+0000 INFO  GetFileHandler Handler(tag: 158, GET) sending length: 14799449, 482921110
-2013-08-27 01:13:59,424+0000 INFO  ReadBuffer RB-LR-Handler(tag: 158, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,424+0000 INFO  ReadBuffer RB-LR-Handler(tag: 158, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,424+0000 INFO  GetFileHandler Handler(tag: 2584, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,424+0000 INFO  LocalIOProvider LR-Handler(tag: 158, GET) rbuf: RB-LR-Handler(tag: 158, GET)
-2013-08-27 01:13:59,424+0000 INFO  GetFileHandler Handler(tag: 2584, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,424+0000 INFO  GetFileHandler Handler(tag: 2584, GET) -> 159
-2013-08-27 01:13:59,424+0000 INFO  GetFileHandler Handler(tag: 159, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,424+0000 INFO  GetFileHandler Handler(tag: 3045, GET) sending length: 14799449, 1410988412
-2013-08-27 01:13:59,425+0000 INFO  GetFileHandler Handler(tag: 3046, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,425+0000 INFO  GetFileHandler Handler(tag: 159, GET) reader: LR-Handler(tag: 159, GET)
-2013-08-27 01:13:59,425+0000 INFO  GetFileHandler Handler(tag: 3046, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,425+0000 INFO  GetFileHandler Handler(tag: 159, GET) sending length: 14799449, 1967810310
-2013-08-27 01:13:59,425+0000 INFO  GetFileHandler Handler(tag: 3046, GET) -> 160
-2013-08-27 01:13:59,425+0000 INFO  ReadBuffer RB-LR-Handler(tag: 159, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,425+0000 INFO  ReadBuffer RB-LR-Handler(tag: 159, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,425+0000 INFO  LocalIOProvider LR-Handler(tag: 159, GET) rbuf: RB-LR-Handler(tag: 159, GET)
-2013-08-27 01:13:59,425+0000 INFO  GetFileHandler Handler(tag: 160, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,425+0000 INFO  GetFileHandler Handler(tag: 2584, GET) sending length: 14799449, 657684509
-2013-08-27 01:13:59,425+0000 INFO  GetFileHandler Handler(tag: 160, GET) reader: LR-Handler(tag: 160, GET)
-2013-08-27 01:13:59,425+0000 INFO  GetFileHandler Handler(tag: 160, GET) sending length: 14799449, 605211654
-2013-08-27 01:13:59,425+0000 INFO  ReadBuffer RB-LR-Handler(tag: 160, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,425+0000 INFO  GetFileHandler Handler(tag: 2585, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,425+0000 INFO  ReadBuffer RB-LR-Handler(tag: 160, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,425+0000 INFO  LocalIOProvider LR-Handler(tag: 160, GET) rbuf: RB-LR-Handler(tag: 160, GET)
-2013-08-27 01:13:59,425+0000 INFO  GetFileHandler Handler(tag: 2585, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,425+0000 INFO  GetFileHandler Handler(tag: 2585, GET) -> 161
-2013-08-27 01:13:59,425+0000 INFO  GetFileHandler Handler(tag: 161, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,425+0000 INFO  GetFileHandler Handler(tag: 3046, GET) sending length: 14799449, 699279152
-2013-08-27 01:13:59,425+0000 INFO  GetFileHandler Handler(tag: 3047, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,425+0000 INFO  GetFileHandler Handler(tag: 161, GET) reader: LR-Handler(tag: 161, GET)
-2013-08-27 01:13:59,425+0000 INFO  GetFileHandler Handler(tag: 3047, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,425+0000 INFO  GetFileHandler Handler(tag: 161, GET) sending length: 14799449, 1754191280
-2013-08-27 01:13:59,425+0000 INFO  GetFileHandler Handler(tag: 3047, GET) -> 162
-2013-08-27 01:13:59,425+0000 INFO  ReadBuffer RB-LR-Handler(tag: 161, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,425+0000 INFO  ReadBuffer RB-LR-Handler(tag: 161, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,425+0000 INFO  LocalIOProvider LR-Handler(tag: 161, GET) rbuf: RB-LR-Handler(tag: 161, GET)
-2013-08-27 01:13:59,425+0000 INFO  GetFileHandler Handler(tag: 162, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,425+0000 INFO  GetFileHandler Handler(tag: 162, GET) reader: LR-Handler(tag: 162, GET)
-2013-08-27 01:13:59,425+0000 INFO  GetFileHandler Handler(tag: 2585, GET) sending length: 14799449, 678857691
-2013-08-27 01:13:59,425+0000 INFO  GetFileHandler Handler(tag: 162, GET) sending length: 14799449, 2128079773
-2013-08-27 01:13:59,425+0000 INFO  GetFileHandler Handler(tag: 3048, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,425+0000 INFO  ReadBuffer RB-LR-Handler(tag: 162, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,425+0000 INFO  GetFileHandler Handler(tag: 3048, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,425+0000 INFO  ReadBuffer RB-LR-Handler(tag: 162, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,425+0000 INFO  LocalIOProvider LR-Handler(tag: 162, GET) rbuf: RB-LR-Handler(tag: 162, GET)
-2013-08-27 01:13:59,425+0000 INFO  GetFileHandler Handler(tag: 3048, GET) -> 163
-2013-08-27 01:13:59,425+0000 INFO  GetFileHandler Handler(tag: 163, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,426+0000 INFO  GetFileHandler Handler(tag: 163, GET) reader: LR-Handler(tag: 163, GET)
-2013-08-27 01:13:59,426+0000 INFO  GetFileHandler Handler(tag: 163, GET) sending length: 14799449, 714320295
-2013-08-27 01:13:59,426+0000 INFO  GetFileHandler Handler(tag: 3049, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,426+0000 INFO  GetFileHandler Handler(tag: 3047, GET) sending length: 14799449, 1147611335
-2013-08-27 01:13:59,427+0000 INFO  ReadBuffer RB-LR-Handler(tag: 163, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,427+0000 INFO  GetFileHandler Handler(tag: 3049, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,427+0000 INFO  ReadBuffer RB-LR-Handler(tag: 163, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,427+0000 INFO  LocalIOProvider LR-Handler(tag: 163, GET) rbuf: RB-LR-Handler(tag: 163, GET)
-2013-08-27 01:13:59,427+0000 INFO  GetFileHandler Handler(tag: 3049, GET) -> 164
-2013-08-27 01:13:59,427+0000 INFO  GetFileHandler Handler(tag: 164, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,428+0000 INFO  GetFileHandler Handler(tag: 164, GET) reader: LR-Handler(tag: 164, GET)
-2013-08-27 01:13:59,428+0000 INFO  GetFileHandler Handler(tag: 164, GET) sending length: 14799449, 1225872710
-2013-08-27 01:13:59,428+0000 INFO  ReadBuffer RB-LR-Handler(tag: 164, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,428+0000 INFO  GetFileHandler Handler(tag: 3050, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,428+0000 INFO  ReadBuffer RB-LR-Handler(tag: 164, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,428+0000 INFO  LocalIOProvider LR-Handler(tag: 164, GET) rbuf: RB-LR-Handler(tag: 164, GET)
-2013-08-27 01:13:59,428+0000 INFO  GetFileHandler Handler(tag: 3050, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,428+0000 INFO  GetFileHandler Handler(tag: 3050, GET) -> 165
-2013-08-27 01:13:59,428+0000 INFO  GetFileHandler Handler(tag: 165, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:13:59,428+0000 INFO  GetFileHandler Handler(tag: 165, GET) reader: LR-Handler(tag: 165, GET)
-2013-08-27 01:13:59,428+0000 INFO  GetFileHandler Handler(tag: 165, GET) sending length: 14799449, 1757648942
-2013-08-27 01:13:59,428+0000 INFO  ReadBuffer RB-LR-Handler(tag: 165, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:13:59,428+0000 INFO  ReadBuffer RB-LR-Handler(tag: 165, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:13:59,428+0000 INFO  LocalIOProvider LR-Handler(tag: 165, GET) rbuf: RB-LR-Handler(tag: 165, GET)
-2013-08-27 01:13:59,429+0000 INFO  GetFileHandler Handler(tag: 3048, GET) sending length: 14799449, 364561223
-2013-08-27 01:13:59,429+0000 INFO  GetFileHandler Handler(tag: 3049, GET) sending length: 14799449, 409630070
-2013-08-27 01:13:59,430+0000 INFO  GetFileHandler Handler(tag: 3050, GET) sending length: 14799449, 783252479
-2013-08-27 01:13:59,880+0000 INFO  ThrottleManager O maxBuffers=1024, crtBuffers=1023, allowedTransfers=0, active=0, suspended=0
-2013-08-27 01:13:59,881+0000 INFO  ThrottleManager mem=109.09 MB, heap=361.69 MB, maxHeap=910.25 MB
-2013-08-27 01:13:59,881+0000 INFO  ThrottleManager I maxBuffers=1024, crtBuffers=256, allowedTransfers=94, active=0, suspended=0
-2013-08-27 01:14:00,008+0000 INFO  RuntimeStats$ProgressTicker   Selecting site:1  Stage in:32
-2013-08-27 01:14:00,380+0000 INFO  ThrottleManager O maxBuffers=1024, crtBuffers=1023, allowedTransfers=0, active=0, suspended=0
-2013-08-27 01:14:00,380+0000 INFO  ThrottleManager mem=105.72 MB, heap=361.69 MB, maxHeap=910.25 MB
-2013-08-27 01:14:00,381+0000 INFO  ThrottleManager I maxBuffers=1024, crtBuffers=256, allowedTransfers=94, active=0, suspended=0
-2013-08-27 01:14:00,880+0000 INFO  ThrottleManager O maxBuffers=1024, crtBuffers=1023, allowedTransfers=0, active=0, suspended=0
-2013-08-27 01:14:00,880+0000 INFO  ThrottleManager mem=97.68 MB, heap=361.69 MB, maxHeap=910.25 MB
-2013-08-27 01:14:00,881+0000 INFO  ThrottleManager I maxBuffers=1024, crtBuffers=256, allowedTransfers=94, active=0, suspended=0
-2013-08-27 01:14:01,009+0000 INFO  RuntimeStats$ProgressTicker   Selecting site:1  Stage in:32
-2013-08-27 01:14:01,380+0000 INFO  ThrottleManager O maxBuffers=1024, crtBuffers=1023, allowedTransfers=0, active=0, suspended=0
-2013-08-27 01:14:01,380+0000 INFO  ThrottleManager mem=152.99 MB, heap=361.69 MB, maxHeap=910.25 MB
-2013-08-27 01:14:01,381+0000 INFO  ThrottleManager I maxBuffers=1024, crtBuffers=256, allowedTransfers=94, active=0, suspended=0
-2013-08-27 01:14:01,880+0000 INFO  ThrottleManager O maxBuffers=1024, crtBuffers=1023, allowedTransfers=0, active=0, suspended=0
-2013-08-27 01:14:01,880+0000 INFO  ThrottleManager mem=138.58 MB, heap=359.38 MB, maxHeap=910.25 MB
-2013-08-27 01:14:01,881+0000 INFO  ThrottleManager I maxBuffers=1024, crtBuffers=256, allowedTransfers=94, active=0, suspended=0
-2013-08-27 01:14:02,009+0000 INFO  RuntimeStats$ProgressTicker   Selecting site:1  Stage in:32
-2013-08-27 01:14:02,380+0000 INFO  ThrottleManager O maxBuffers=1024, crtBuffers=1023, allowedTransfers=0, active=0, suspended=0
-2013-08-27 01:14:02,380+0000 INFO  ThrottleManager mem=197.81 MB, heap=359.38 MB, maxHeap=910.25 MB
-2013-08-27 01:14:02,381+0000 INFO  ThrottleManager I maxBuffers=1024, crtBuffers=256, allowedTransfers=94, active=0, suspended=0
-2013-08-27 01:14:02,501+0000 INFO  Block Block task status changed: Active
-2013-08-27 01:14:02,501+0000 INFO  RemoteLogHandler BLOCK_ACTIVE id=0827-1301520-000000
-2013-08-27 01:14:02,501+0000 INFO  RequestHandler Handler(tag: 166, RLOG) unregistering (send)
-2013-08-27 01:14:02,501+0000 INFO  RemoteLogHandler BLOCK_ACTIVE id=0827-1301520-000001
-2013-08-27 01:14:02,501+0000 INFO  RequestHandler Handler(tag: 167, RLOG) unregistering (send)
-2013-08-27 01:14:02,502+0000 INFO  AbstractQueuePoller Actively monitored: 2, New: 0, Done: 0
-2013-08-27 01:14:02,635+0000 INFO  GetFileHandler Handler(tag: 132, GET) unregistering (last)
-2013-08-27 01:14:02,635+0000 INFO  ReadBuffer RB-LR-Handler(tag: 132, GET) de-allocating 8 buffers
-2013-08-27 01:14:02,707+0000 INFO  GetFileHandler Handler(tag: 2570, GET) unregistering (last)
-2013-08-27 01:14:02,733+0000 INFO  GetFileHandler Handler(tag: 133, GET) unregistering (last)
-2013-08-27 01:14:02,733+0000 INFO  ReadBuffer RB-LR-Handler(tag: 133, GET) de-allocating 8 buffers
-2013-08-27 01:14:02,798+0000 INFO  GetFileHandler Handler(tag: 2571, GET) unregistering (last)
-2013-08-27 01:14:02,815+0000 INFO  GetFileHandler Handler(tag: 135, GET) unregistering (last)
-2013-08-27 01:14:02,815+0000 INFO  ReadBuffer RB-LR-Handler(tag: 135, GET) de-allocating 8 buffers
-2013-08-27 01:14:02,856+0000 INFO  GetFileHandler Handler(tag: 137, GET) unregistering (last)
-2013-08-27 01:14:02,856+0000 INFO  ReadBuffer RB-LR-Handler(tag: 137, GET) de-allocating 8 buffers
-2013-08-27 01:14:02,876+0000 INFO  GetFileHandler Handler(tag: 138, GET) unregistering (last)
-2013-08-27 01:14:02,876+0000 INFO  ReadBuffer RB-LR-Handler(tag: 138, GET) de-allocating 8 buffers
-2013-08-27 01:14:02,880+0000 INFO  ThrottleManager O maxBuffers=1024, crtBuffers=1023, allowedTransfers=0, active=0, suspended=0
-2013-08-27 01:14:02,880+0000 INFO  ThrottleManager mem=191.87 MB, heap=399.94 MB, maxHeap=910.25 MB
-2013-08-27 01:14:02,881+0000 INFO  ThrottleManager I maxBuffers=1024, crtBuffers=216, allowedTransfers=115, active=0, suspended=0
-2013-08-27 01:14:02,881+0000 INFO  GetFileHandler Handler(tag: 2572, GET) unregistering (last)
-2013-08-27 01:14:02,894+0000 INFO  GetFileHandler Handler(tag: 139, GET) unregistering (last)
-2013-08-27 01:14:02,894+0000 INFO  ReadBuffer RB-LR-Handler(tag: 139, GET) de-allocating 8 buffers
-2013-08-27 01:14:02,905+0000 INFO  GetFileHandler Handler(tag: 140, GET) unregistering (last)
-2013-08-27 01:14:02,905+0000 INFO  ReadBuffer RB-LR-Handler(tag: 140, GET) de-allocating 8 buffers
-2013-08-27 01:14:02,912+0000 INFO  GetFileHandler Handler(tag: 141, GET) unregistering (last)
-2013-08-27 01:14:02,912+0000 INFO  ReadBuffer RB-LR-Handler(tag: 141, GET) de-allocating 8 buffers
-2013-08-27 01:14:02,921+0000 INFO  GetFileHandler Handler(tag: 2573, GET) unregistering (last)
-2013-08-27 01:14:02,923+0000 INFO  GetFileHandler Handler(tag: 142, GET) unregistering (last)
-2013-08-27 01:14:02,923+0000 INFO  ReadBuffer RB-LR-Handler(tag: 142, GET) de-allocating 8 buffers
-2013-08-27 01:14:02,931+0000 INFO  GetFileHandler Handler(tag: 143, GET) unregistering (last)
-2013-08-27 01:14:02,931+0000 INFO  ReadBuffer RB-LR-Handler(tag: 143, GET) de-allocating 8 buffers
-2013-08-27 01:14:02,938+0000 INFO  GetFileHandler Handler(tag: 3035, GET) unregistering (last)
-2013-08-27 01:14:02,939+0000 INFO  GetFileHandler Handler(tag: 144, GET) unregistering (last)
-2013-08-27 01:14:02,939+0000 INFO  ReadBuffer RB-LR-Handler(tag: 144, GET) de-allocating 8 buffers
-2013-08-27 01:14:02,946+0000 INFO  GetFileHandler Handler(tag: 3051, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:02,946+0000 INFO  GetFileHandler Handler(tag: 3051, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:02,946+0000 INFO  GetFileHandler Handler(tag: 3051, GET) -> 168
-2013-08-27 01:14:02,946+0000 INFO  GetFileHandler Handler(tag: 168, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:02,947+0000 INFO  GetFileHandler Handler(tag: 168, GET) reader: LR-Handler(tag: 168, GET)
-2013-08-27 01:14:02,947+0000 INFO  GetFileHandler Handler(tag: 168, GET) sending length: 148937, 161475341
-2013-08-27 01:14:02,947+0000 INFO  ReadBuffer RB-LR-Handler(tag: 168, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:02,947+0000 INFO  ReadBuffer RB-LR-Handler(tag: 168, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:02,947+0000 INFO  LocalIOProvider LR-Handler(tag: 168, GET) rbuf: RB-LR-Handler(tag: 168, GET)
-2013-08-27 01:14:02,947+0000 INFO  GetFileHandler Handler(tag: 168, GET) unregistering (last)
-2013-08-27 01:14:02,947+0000 INFO  ReadBuffer RB-LR-Handler(tag: 168, GET) de-allocating 5 buffers
-2013-08-27 01:14:02,949+0000 INFO  GetFileHandler Handler(tag: 145, GET) unregistering (last)
-2013-08-27 01:14:02,949+0000 INFO  ReadBuffer RB-LR-Handler(tag: 145, GET) de-allocating 8 buffers
-2013-08-27 01:14:02,949+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:02,953+0000 INFO  GetFileHandler Handler(tag: 2574, GET) unregistering (last)
-2013-08-27 01:14:02,959+0000 INFO  GetFileHandler Handler(tag: 146, GET) unregistering (last)
-2013-08-27 01:14:02,959+0000 INFO  ReadBuffer RB-LR-Handler(tag: 146, GET) de-allocating 8 buffers
-2013-08-27 01:14:02,961+0000 INFO  GetFileHandler Handler(tag: 147, GET) unregistering (last)
-2013-08-27 01:14:02,961+0000 INFO  ReadBuffer RB-LR-Handler(tag: 147, GET) de-allocating 8 buffers
-2013-08-27 01:14:02,964+0000 INFO  GetFileHandler Handler(tag: 148, GET) unregistering (last)
-2013-08-27 01:14:02,964+0000 INFO  ReadBuffer RB-LR-Handler(tag: 148, GET) de-allocating 8 buffers
-2013-08-27 01:14:02,964+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:02,964+0000 INFO  GetFileHandler Handler(tag: 3036, GET) unregistering (last)
-2013-08-27 01:14:02,965+0000 INFO  GetFileHandler Handler(tag: 149, GET) unregistering (last)
-2013-08-27 01:14:02,965+0000 INFO  ReadBuffer RB-LR-Handler(tag: 149, GET) de-allocating 8 buffers
-2013-08-27 01:14:02,968+0000 INFO  GetFileHandler Handler(tag: 150, GET) unregistering (last)
-2013-08-27 01:14:02,968+0000 INFO  ReadBuffer RB-LR-Handler(tag: 150, GET) de-allocating 8 buffers
-2013-08-27 01:14:02,968+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:02,970+0000 INFO  GetFileHandler Handler(tag: 2575, GET) unregistering (last)
-2013-08-27 01:14:02,972+0000 INFO  GetFileHandler Handler(tag: 151, GET) unregistering (last)
-2013-08-27 01:14:02,972+0000 INFO  ReadBuffer RB-LR-Handler(tag: 151, GET) de-allocating 8 buffers
-2013-08-27 01:14:02,972+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:02,975+0000 INFO  GetFileHandler Handler(tag: 152, GET) unregistering (last)
-2013-08-27 01:14:02,975+0000 INFO  ReadBuffer RB-LR-Handler(tag: 152, GET) de-allocating 8 buffers
-2013-08-27 01:14:02,975+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:02,976+0000 INFO  GetFileHandler Handler(tag: 3037, GET) unregistering (last)
-2013-08-27 01:14:02,977+0000 INFO  GetFileHandler Handler(tag: 153, GET) unregistering (last)
-2013-08-27 01:14:02,977+0000 INFO  ReadBuffer RB-LR-Handler(tag: 153, GET) de-allocating 8 buffers
-2013-08-27 01:14:02,977+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:02,980+0000 INFO  GetFileHandler Handler(tag: 154, GET) unregistering (last)
-2013-08-27 01:14:02,980+0000 INFO  ReadBuffer RB-LR-Handler(tag: 154, GET) de-allocating 8 buffers
-2013-08-27 01:14:02,980+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:02,982+0000 INFO  GetFileHandler Handler(tag: 2576, GET) unregistering (last)
-2013-08-27 01:14:02,985+0000 INFO  GetFileHandler Handler(tag: 155, GET) unregistering (last)
-2013-08-27 01:14:02,985+0000 INFO  ReadBuffer RB-LR-Handler(tag: 155, GET) de-allocating 8 buffers
-2013-08-27 01:14:02,985+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:02,989+0000 INFO  GetFileHandler Handler(tag: 156, GET) unregistering (last)
-2013-08-27 01:14:02,989+0000 INFO  ReadBuffer RB-LR-Handler(tag: 156, GET) de-allocating 8 buffers
-2013-08-27 01:14:02,989+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:02,989+0000 INFO  GetFileHandler Handler(tag: 3052, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:02,989+0000 INFO  GetFileHandler Handler(tag: 3052, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:02,989+0000 INFO  GetFileHandler Handler(tag: 3052, GET) -> 169
-2013-08-27 01:14:02,989+0000 INFO  GetFileHandler Handler(tag: 169, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:02,989+0000 INFO  GetFileHandler Handler(tag: 169, GET) reader: LR-Handler(tag: 169, GET)
-2013-08-27 01:14:02,989+0000 INFO  GetFileHandler Handler(tag: 169, GET) sending length: 148937, 583779936
-2013-08-27 01:14:02,989+0000 INFO  ReadBuffer RB-LR-Handler(tag: 169, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:02,989+0000 INFO  ReadBuffer RB-LR-Handler(tag: 169, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:02,989+0000 INFO  LocalIOProvider LR-Handler(tag: 169, GET) rbuf: RB-LR-Handler(tag: 169, GET)
-2013-08-27 01:14:02,989+0000 INFO  GetFileHandler Handler(tag: 3038, GET) unregistering (last)
-2013-08-27 01:14:02,989+0000 INFO  GetFileHandler Handler(tag: 169, GET) unregistering (last)
-2013-08-27 01:14:02,989+0000 INFO  ReadBuffer RB-LR-Handler(tag: 169, GET) de-allocating 5 buffers
-2013-08-27 01:14:02,990+0000 INFO  GetFileHandler Handler(tag: 157, GET) unregistering (last)
-2013-08-27 01:14:02,990+0000 INFO  ReadBuffer RB-LR-Handler(tag: 157, GET) de-allocating 8 buffers
-2013-08-27 01:14:02,990+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:02,994+0000 INFO  GetFileHandler Handler(tag: 158, GET) unregistering (last)
-2013-08-27 01:14:02,994+0000 INFO  ReadBuffer RB-LR-Handler(tag: 158, GET) de-allocating 8 buffers
-2013-08-27 01:14:02,994+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:02,997+0000 INFO  GetFileHandler Handler(tag: 159, GET) unregistering (last)
-2013-08-27 01:14:02,997+0000 INFO  GetFileHandler Handler(tag: 3051, GET) sending length: 148937, 91992343
-2013-08-27 01:14:02,997+0000 INFO  ReadBuffer RB-LR-Handler(tag: 159, GET) de-allocating 8 buffers
-2013-08-27 01:14:02,997+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:02,998+0000 INFO  GetFileHandler Handler(tag: 3051, GET) unregistering (last)
-2013-08-27 01:14:02,998+0000 INFO  GetFileHandler Handler(tag: 3053, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:02,998+0000 INFO  GetFileHandler Handler(tag: 3053, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:02,998+0000 INFO  GetFileHandler Handler(tag: 3053, GET) -> 170
-2013-08-27 01:14:02,999+0000 INFO  GetFileHandler Handler(tag: 170, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:02,999+0000 INFO  GetFileHandler Handler(tag: 170, GET) reader: LR-Handler(tag: 170, GET)
-2013-08-27 01:14:02,999+0000 INFO  GetFileHandler Handler(tag: 170, GET) sending length: 148937, 1227704800
-2013-08-27 01:14:02,999+0000 INFO  ReadBuffer RB-LR-Handler(tag: 170, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:02,999+0000 INFO  ReadBuffer RB-LR-Handler(tag: 170, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:02,999+0000 INFO  LocalIOProvider LR-Handler(tag: 170, GET) rbuf: RB-LR-Handler(tag: 170, GET)
-2013-08-27 01:14:02,999+0000 INFO  GetFileHandler Handler(tag: 170, GET) unregistering (last)
-2013-08-27 01:14:02,999+0000 INFO  ReadBuffer RB-LR-Handler(tag: 170, GET) de-allocating 5 buffers
-2013-08-27 01:14:03,000+0000 INFO  GetFileHandler Handler(tag: 2577, GET) unregistering (last)
-2013-08-27 01:14:03,000+0000 INFO  GetFileHandler Handler(tag: 160, GET) unregistering (last)
-2013-08-27 01:14:03,000+0000 INFO  ReadBuffer RB-LR-Handler(tag: 160, GET) de-allocating 8 buffers
-2013-08-27 01:14:03,000+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:03,002+0000 INFO  GetFileHandler Handler(tag: 161, GET) unregistering (last)
-2013-08-27 01:14:03,002+0000 INFO  ReadBuffer RB-LR-Handler(tag: 161, GET) de-allocating 8 buffers
-2013-08-27 01:14:03,002+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:03,005+0000 INFO  GetFileHandler Handler(tag: 3039, GET) unregistering (last)
-2013-08-27 01:14:03,005+0000 INFO  GetFileHandler Handler(tag: 162, GET) unregistering (last)
-2013-08-27 01:14:03,005+0000 INFO  ReadBuffer RB-LR-Handler(tag: 162, GET) de-allocating 8 buffers
-2013-08-27 01:14:03,005+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:03,005+0000 INFO  GetFileHandler Handler(tag: 163, GET) unregistering (last)
-2013-08-27 01:14:03,005+0000 INFO  ReadBuffer RB-LR-Handler(tag: 163, GET) de-allocating 8 buffers
-2013-08-27 01:14:03,006+0000 INFO  GetFileHandler Handler(tag: 2578, GET) unregistering (last)
-2013-08-27 01:14:03,007+0000 INFO  GetFileHandler Handler(tag: 164, GET) unregistering (last)
-2013-08-27 01:14:03,007+0000 INFO  ReadBuffer RB-LR-Handler(tag: 164, GET) de-allocating 8 buffers
-2013-08-27 01:14:03,007+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:03,007+0000 INFO  GetFileHandler Handler(tag: 165, GET) unregistering (last)
-2013-08-27 01:14:03,007+0000 INFO  ReadBuffer RB-LR-Handler(tag: 165, GET) de-allocating 8 buffers
-2013-08-27 01:14:03,008+0000 INFO  GetFileHandler Handler(tag: 3040, GET) unregistering (last)
-2013-08-27 01:14:03,008+0000 INFO  GetFileHandler Handler(tag: 2579, GET) unregistering (last)
-2013-08-27 01:14:03,009+0000 INFO  GetFileHandler Handler(tag: 3041, GET) unregistering (last)
-2013-08-27 01:14:03,009+0000 INFO  RuntimeStats$ProgressTicker   Selecting site:1  Stage in:32
-2013-08-27 01:14:03,010+0000 INFO  GetFileHandler Handler(tag: 3054, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,010+0000 INFO  GetFileHandler Handler(tag: 3054, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,010+0000 INFO  GetFileHandler Handler(tag: 3054, GET) -> 171
-2013-08-27 01:14:03,010+0000 INFO  GetFileHandler Handler(tag: 171, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,010+0000 INFO  GetFileHandler Handler(tag: 2580, GET) unregistering (last)
-2013-08-27 01:14:03,010+0000 INFO  GetFileHandler Handler(tag: 171, GET) reader: LR-Handler(tag: 171, GET)
-2013-08-27 01:14:03,010+0000 INFO  GetFileHandler Handler(tag: 171, GET) sending length: 148937, 1444230150
-2013-08-27 01:14:03,010+0000 INFO  ReadBuffer RB-LR-Handler(tag: 171, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:03,010+0000 INFO  ReadBuffer RB-LR-Handler(tag: 171, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:03,010+0000 INFO  LocalIOProvider LR-Handler(tag: 171, GET) rbuf: RB-LR-Handler(tag: 171, GET)
-2013-08-27 01:14:03,010+0000 INFO  GetFileHandler Handler(tag: 171, GET) unregistering (last)
-2013-08-27 01:14:03,010+0000 INFO  ReadBuffer RB-LR-Handler(tag: 171, GET) de-allocating 5 buffers
-2013-08-27 01:14:03,011+0000 INFO  GetFileHandler Handler(tag: 3042, GET) unregistering (last)
-2013-08-27 01:14:03,012+0000 INFO  GetFileHandler Handler(tag: 2581, GET) unregistering (last)
-2013-08-27 01:14:03,014+0000 INFO  GetFileHandler Handler(tag: 3043, GET) unregistering (last)
-2013-08-27 01:14:03,015+0000 INFO  GetFileHandler Handler(tag: 2582, GET) unregistering (last)
-2013-08-27 01:14:03,016+0000 INFO  GetFileHandler Handler(tag: 3044, GET) unregistering (last)
-2013-08-27 01:14:03,016+0000 INFO  GetFileHandler Handler(tag: 3052, GET) sending length: 148937, 662618683
-2013-08-27 01:14:03,016+0000 INFO  GetFileHandler Handler(tag: 3052, GET) unregistering (last)
-2013-08-27 01:14:03,017+0000 INFO  GetFileHandler Handler(tag: 3055, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,017+0000 INFO  GetFileHandler Handler(tag: 3055, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,017+0000 INFO  GetFileHandler Handler(tag: 3055, GET) -> 172
-2013-08-27 01:14:03,017+0000 INFO  GetFileHandler Handler(tag: 172, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,017+0000 INFO  GetFileHandler Handler(tag: 172, GET) reader: LR-Handler(tag: 172, GET)
-2013-08-27 01:14:03,017+0000 INFO  GetFileHandler Handler(tag: 172, GET) sending length: 543, 428637515
-2013-08-27 01:14:03,017+0000 INFO  ReadBuffer RB-LR-Handler(tag: 172, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,017+0000 INFO  ReadBuffer RB-LR-Handler(tag: 172, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,017+0000 INFO  LocalIOProvider LR-Handler(tag: 172, GET) rbuf: RB-LR-Handler(tag: 172, GET)
-2013-08-27 01:14:03,017+0000 INFO  GetFileHandler Handler(tag: 172, GET) unregistering (last)
-2013-08-27 01:14:03,017+0000 INFO  ReadBuffer RB-LR-Handler(tag: 172, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,017+0000 INFO  GetFileHandler Handler(tag: 2583, GET) unregistering (last)
-2013-08-27 01:14:03,018+0000 INFO  GetFileHandler Handler(tag: 3045, GET) unregistering (last)
-2013-08-27 01:14:03,019+0000 INFO  GetFileHandler Handler(tag: 2584, GET) unregistering (last)
-2013-08-27 01:14:03,019+0000 INFO  GetFileHandler Handler(tag: 3053, GET) sending length: 148937, 1541393422
-2013-08-27 01:14:03,020+0000 INFO  GetFileHandler Handler(tag: 3053, GET) unregistering (last)
-2013-08-27 01:14:03,021+0000 INFO  GetFileHandler Handler(tag: 3046, GET) unregistering (last)
-2013-08-27 01:14:03,022+0000 INFO  GetFileHandler Handler(tag: 2585, GET) unregistering (last)
-2013-08-27 01:14:03,022+0000 INFO  GetFileHandler Handler(tag: 3047, GET) unregistering (last)
-2013-08-27 01:14:03,023+0000 INFO  GetFileHandler Handler(tag: 3048, GET) unregistering (last)
-2013-08-27 01:14:03,023+0000 INFO  GetFileHandler Handler(tag: 3049, GET) unregistering (last)
-2013-08-27 01:14:03,023+0000 INFO  GetFileHandler Handler(tag: 3050, GET) unregistering (last)
-2013-08-27 01:14:03,023+0000 INFO  GetFileHandler Handler(tag: 3054, GET) sending length: 148937, 396532217
-2013-08-27 01:14:03,023+0000 INFO  GetFileHandler Handler(tag: 3056, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,023+0000 INFO  GetFileHandler Handler(tag: 3054, GET) unregistering (last)
-2013-08-27 01:14:03,023+0000 INFO  GetFileHandler Handler(tag: 3055, GET) sending length: 543, 1260563950
-2013-08-27 01:14:03,023+0000 INFO  GetFileHandler Handler(tag: 3055, GET) unregistering (last)
-2013-08-27 01:14:03,023+0000 INFO  GetFileHandler Handler(tag: 3056, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,023+0000 INFO  GetFileHandler Handler(tag: 3056, GET) -> 173
-2013-08-27 01:14:03,023+0000 INFO  GetFileHandler Handler(tag: 173, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,023+0000 INFO  GetFileHandler Handler(tag: 173, GET) reader: LR-Handler(tag: 173, GET)
-2013-08-27 01:14:03,023+0000 INFO  GetFileHandler Handler(tag: 173, GET) sending length: 148937, 1709424479
-2013-08-27 01:14:03,023+0000 INFO  GetFileHandler Handler(tag: 3056, GET) sending length: 148937, 1260988987
-2013-08-27 01:14:03,023+0000 INFO  ReadBuffer RB-LR-Handler(tag: 173, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:03,023+0000 INFO  ReadBuffer RB-LR-Handler(tag: 173, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:03,023+0000 INFO  LocalIOProvider LR-Handler(tag: 173, GET) rbuf: RB-LR-Handler(tag: 173, GET)
-2013-08-27 01:14:03,024+0000 INFO  GetFileHandler Handler(tag: 173, GET) unregistering (last)
-2013-08-27 01:14:03,024+0000 INFO  GetFileHandler Handler(tag: 3056, GET) unregistering (last)
-2013-08-27 01:14:03,024+0000 INFO  ReadBuffer RB-LR-Handler(tag: 173, GET) de-allocating 5 buffers
-2013-08-27 01:14:03,024+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:03,041+0000 INFO  GetFileHandler Handler(tag: 3057, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,041+0000 INFO  GetFileHandler Handler(tag: 3057, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,041+0000 INFO  GetFileHandler Handler(tag: 3057, GET) -> 174
-2013-08-27 01:14:03,041+0000 INFO  GetFileHandler Handler(tag: 174, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,041+0000 INFO  GetFileHandler Handler(tag: 174, GET) reader: LR-Handler(tag: 174, GET)
-2013-08-27 01:14:03,041+0000 INFO  GetFileHandler Handler(tag: 174, GET) sending length: 148937, 23965417
-2013-08-27 01:14:03,042+0000 INFO  GetFileHandler Handler(tag: 3057, GET) sending length: 148937, 1207321530
-2013-08-27 01:14:03,042+0000 INFO  ReadBuffer RB-LR-Handler(tag: 174, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:03,042+0000 INFO  ReadBuffer RB-LR-Handler(tag: 174, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:03,042+0000 INFO  LocalIOProvider LR-Handler(tag: 174, GET) rbuf: RB-LR-Handler(tag: 174, GET)
-2013-08-27 01:14:03,042+0000 INFO  GetFileHandler Handler(tag: 174, GET) unregistering (last)
-2013-08-27 01:14:03,042+0000 INFO  GetFileHandler Handler(tag: 3057, GET) unregistering (last)
-2013-08-27 01:14:03,042+0000 INFO  ReadBuffer RB-LR-Handler(tag: 174, GET) de-allocating 5 buffers
-2013-08-27 01:14:03,042+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:03,043+0000 INFO  GetFileHandler Handler(tag: 3058, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,043+0000 INFO  GetFileHandler Handler(tag: 3058, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,043+0000 INFO  GetFileHandler Handler(tag: 3058, GET) -> 175
-2013-08-27 01:14:03,043+0000 INFO  GetFileHandler Handler(tag: 175, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,043+0000 INFO  GetFileHandler Handler(tag: 175, GET) reader: LR-Handler(tag: 175, GET)
-2013-08-27 01:14:03,043+0000 INFO  GetFileHandler Handler(tag: 175, GET) sending length: 148937, 443097568
-2013-08-27 01:14:03,043+0000 INFO  GetFileHandler Handler(tag: 3058, GET) sending length: 148937, 1815021227
-2013-08-27 01:14:03,043+0000 INFO  ReadBuffer RB-LR-Handler(tag: 175, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:03,043+0000 INFO  ReadBuffer RB-LR-Handler(tag: 175, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:03,043+0000 INFO  LocalIOProvider LR-Handler(tag: 175, GET) rbuf: RB-LR-Handler(tag: 175, GET)
-2013-08-27 01:14:03,043+0000 INFO  GetFileHandler Handler(tag: 175, GET) unregistering (last)
-2013-08-27 01:14:03,043+0000 INFO  GetFileHandler Handler(tag: 3058, GET) unregistering (last)
-2013-08-27 01:14:03,043+0000 INFO  ReadBuffer RB-LR-Handler(tag: 175, GET) de-allocating 5 buffers
-2013-08-27 01:14:03,043+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:03,045+0000 INFO  GetFileHandler Handler(tag: 3059, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,045+0000 INFO  GetFileHandler Handler(tag: 3059, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,045+0000 INFO  GetFileHandler Handler(tag: 3059, GET) -> 176
-2013-08-27 01:14:03,045+0000 INFO  GetFileHandler Handler(tag: 176, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,045+0000 INFO  GetFileHandler Handler(tag: 176, GET) reader: LR-Handler(tag: 176, GET)
-2013-08-27 01:14:03,045+0000 INFO  GetFileHandler Handler(tag: 176, GET) sending length: 148937, 2047058042
-2013-08-27 01:14:03,045+0000 INFO  GetFileHandler Handler(tag: 3059, GET) sending length: 148937, 69003307
-2013-08-27 01:14:03,045+0000 INFO  ReadBuffer RB-LR-Handler(tag: 176, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:03,045+0000 INFO  ReadBuffer RB-LR-Handler(tag: 176, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:03,045+0000 INFO  LocalIOProvider LR-Handler(tag: 176, GET) rbuf: RB-LR-Handler(tag: 176, GET)
-2013-08-27 01:14:03,045+0000 INFO  GetFileHandler Handler(tag: 176, GET) unregistering (last)
-2013-08-27 01:14:03,045+0000 INFO  ReadBuffer RB-LR-Handler(tag: 176, GET) de-allocating 5 buffers
-2013-08-27 01:14:03,045+0000 INFO  GetFileHandler Handler(tag: 3059, GET) unregistering (last)
-2013-08-27 01:14:03,045+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:03,046+0000 INFO  GetFileHandler Handler(tag: 3060, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,046+0000 INFO  GetFileHandler Handler(tag: 3060, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,046+0000 INFO  GetFileHandler Handler(tag: 3060, GET) -> 177
-2013-08-27 01:14:03,046+0000 INFO  GetFileHandler Handler(tag: 177, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,046+0000 INFO  GetFileHandler Handler(tag: 177, GET) reader: LR-Handler(tag: 177, GET)
-2013-08-27 01:14:03,046+0000 INFO  GetFileHandler Handler(tag: 177, GET) sending length: 148937, 521180963
-2013-08-27 01:14:03,046+0000 INFO  GetFileHandler Handler(tag: 3060, GET) sending length: 148937, 2050132675
-2013-08-27 01:14:03,046+0000 INFO  ReadBuffer RB-LR-Handler(tag: 177, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:03,046+0000 INFO  ReadBuffer RB-LR-Handler(tag: 177, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:03,047+0000 INFO  LocalIOProvider LR-Handler(tag: 177, GET) rbuf: RB-LR-Handler(tag: 177, GET)
-2013-08-27 01:14:03,047+0000 INFO  GetFileHandler Handler(tag: 177, GET) unregistering (last)
-2013-08-27 01:14:03,047+0000 INFO  GetFileHandler Handler(tag: 3060, GET) unregistering (last)
-2013-08-27 01:14:03,047+0000 INFO  ReadBuffer RB-LR-Handler(tag: 177, GET) de-allocating 5 buffers
-2013-08-27 01:14:03,047+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:03,048+0000 INFO  GetFileHandler Handler(tag: 3061, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,048+0000 INFO  GetFileHandler Handler(tag: 3061, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,048+0000 INFO  GetFileHandler Handler(tag: 3061, GET) -> 178
-2013-08-27 01:14:03,048+0000 INFO  GetFileHandler Handler(tag: 178, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,048+0000 INFO  GetFileHandler Handler(tag: 178, GET) reader: LR-Handler(tag: 178, GET)
-2013-08-27 01:14:03,048+0000 INFO  GetFileHandler Handler(tag: 178, GET) sending length: 148937, 1263086663
-2013-08-27 01:14:03,048+0000 INFO  GetFileHandler Handler(tag: 3061, GET) sending length: 148937, 821694446
-2013-08-27 01:14:03,048+0000 INFO  ReadBuffer RB-LR-Handler(tag: 178, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:03,048+0000 INFO  ReadBuffer RB-LR-Handler(tag: 178, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:03,048+0000 INFO  LocalIOProvider LR-Handler(tag: 178, GET) rbuf: RB-LR-Handler(tag: 178, GET)
-2013-08-27 01:14:03,048+0000 INFO  GetFileHandler Handler(tag: 178, GET) unregistering (last)
-2013-08-27 01:14:03,048+0000 INFO  GetFileHandler Handler(tag: 3061, GET) unregistering (last)
-2013-08-27 01:14:03,048+0000 INFO  ReadBuffer RB-LR-Handler(tag: 178, GET) de-allocating 5 buffers
-2013-08-27 01:14:03,048+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:03,050+0000 INFO  GetFileHandler Handler(tag: 3062, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,050+0000 INFO  GetFileHandler Handler(tag: 3062, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,050+0000 INFO  GetFileHandler Handler(tag: 3062, GET) -> 179
-2013-08-27 01:14:03,050+0000 INFO  GetFileHandler Handler(tag: 179, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,050+0000 INFO  GetFileHandler Handler(tag: 179, GET) reader: LR-Handler(tag: 179, GET)
-2013-08-27 01:14:03,050+0000 INFO  GetFileHandler Handler(tag: 179, GET) sending length: 543, 2131040067
-2013-08-27 01:14:03,050+0000 INFO  GetFileHandler Handler(tag: 3062, GET) sending length: 543, 658141403
-2013-08-27 01:14:03,050+0000 INFO  ReadBuffer RB-LR-Handler(tag: 179, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,050+0000 INFO  ReadBuffer RB-LR-Handler(tag: 179, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,050+0000 INFO  LocalIOProvider LR-Handler(tag: 179, GET) rbuf: RB-LR-Handler(tag: 179, GET)
-2013-08-27 01:14:03,050+0000 INFO  GetFileHandler Handler(tag: 179, GET) unregistering (last)
-2013-08-27 01:14:03,050+0000 INFO  ReadBuffer RB-LR-Handler(tag: 179, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,050+0000 INFO  GetFileHandler Handler(tag: 3062, GET) unregistering (last)
-2013-08-27 01:14:03,051+0000 INFO  GetFileHandler Handler(tag: 3063, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,051+0000 INFO  GetFileHandler Handler(tag: 3063, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,051+0000 INFO  GetFileHandler Handler(tag: 3063, GET) -> 180
-2013-08-27 01:14:03,051+0000 INFO  GetFileHandler Handler(tag: 180, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,051+0000 INFO  GetFileHandler Handler(tag: 180, GET) reader: LR-Handler(tag: 180, GET)
-2013-08-27 01:14:03,051+0000 INFO  GetFileHandler Handler(tag: 180, GET) sending length: 148937, 220931271
-2013-08-27 01:14:03,051+0000 INFO  GetFileHandler Handler(tag: 3063, GET) sending length: 148937, 192646034
-2013-08-27 01:14:03,051+0000 INFO  ReadBuffer RB-LR-Handler(tag: 180, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:03,051+0000 INFO  ReadBuffer RB-LR-Handler(tag: 180, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:03,051+0000 INFO  LocalIOProvider LR-Handler(tag: 180, GET) rbuf: RB-LR-Handler(tag: 180, GET)
-2013-08-27 01:14:03,052+0000 INFO  GetFileHandler Handler(tag: 180, GET) unregistering (last)
-2013-08-27 01:14:03,052+0000 INFO  GetFileHandler Handler(tag: 3063, GET) unregistering (last)
-2013-08-27 01:14:03,052+0000 INFO  ReadBuffer RB-LR-Handler(tag: 180, GET) de-allocating 5 buffers
-2013-08-27 01:14:03,052+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:03,054+0000 INFO  GetFileHandler Handler(tag: 3064, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,054+0000 INFO  GetFileHandler Handler(tag: 3064, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,054+0000 INFO  GetFileHandler Handler(tag: 3064, GET) -> 181
-2013-08-27 01:14:03,054+0000 INFO  GetFileHandler Handler(tag: 181, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,054+0000 INFO  GetFileHandler Handler(tag: 181, GET) reader: LR-Handler(tag: 181, GET)
-2013-08-27 01:14:03,054+0000 INFO  GetFileHandler Handler(tag: 181, GET) sending length: 543, 714233355
-2013-08-27 01:14:03,054+0000 INFO  GetFileHandler Handler(tag: 3064, GET) sending length: 543, 1833894402
-2013-08-27 01:14:03,054+0000 INFO  ReadBuffer RB-LR-Handler(tag: 181, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,054+0000 INFO  ReadBuffer RB-LR-Handler(tag: 181, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,054+0000 INFO  LocalIOProvider LR-Handler(tag: 181, GET) rbuf: RB-LR-Handler(tag: 181, GET)
-2013-08-27 01:14:03,054+0000 INFO  GetFileHandler Handler(tag: 181, GET) unregistering (last)
-2013-08-27 01:14:03,054+0000 INFO  ReadBuffer RB-LR-Handler(tag: 181, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,054+0000 INFO  GetFileHandler Handler(tag: 3064, GET) unregistering (last)
-2013-08-27 01:14:03,055+0000 INFO  GetFileHandler Handler(tag: 3065, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,055+0000 INFO  GetFileHandler Handler(tag: 3065, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,055+0000 INFO  GetFileHandler Handler(tag: 3065, GET) -> 182
-2013-08-27 01:14:03,056+0000 INFO  GetFileHandler Handler(tag: 182, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,056+0000 INFO  GetFileHandler Handler(tag: 182, GET) reader: LR-Handler(tag: 182, GET)
-2013-08-27 01:14:03,056+0000 INFO  GetFileHandler Handler(tag: 182, GET) sending length: 148937, 556589322
-2013-08-27 01:14:03,056+0000 INFO  GetFileHandler Handler(tag: 3065, GET) sending length: 148937, 157968522
-2013-08-27 01:14:03,056+0000 INFO  ReadBuffer RB-LR-Handler(tag: 182, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:03,056+0000 INFO  ReadBuffer RB-LR-Handler(tag: 182, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:03,056+0000 INFO  LocalIOProvider LR-Handler(tag: 182, GET) rbuf: RB-LR-Handler(tag: 182, GET)
-2013-08-27 01:14:03,056+0000 INFO  GetFileHandler Handler(tag: 182, GET) unregistering (last)
-2013-08-27 01:14:03,056+0000 INFO  GetFileHandler Handler(tag: 3065, GET) unregistering (last)
-2013-08-27 01:14:03,056+0000 INFO  ReadBuffer RB-LR-Handler(tag: 182, GET) de-allocating 5 buffers
-2013-08-27 01:14:03,056+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:03,057+0000 INFO  GetFileHandler Handler(tag: 3066, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,057+0000 INFO  GetFileHandler Handler(tag: 3066, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,057+0000 INFO  GetFileHandler Handler(tag: 3066, GET) -> 183
-2013-08-27 01:14:03,057+0000 INFO  GetFileHandler Handler(tag: 183, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,057+0000 INFO  GetFileHandler Handler(tag: 183, GET) reader: LR-Handler(tag: 183, GET)
-2013-08-27 01:14:03,057+0000 INFO  GetFileHandler Handler(tag: 183, GET) sending length: 148937, 137489369
-2013-08-27 01:14:03,057+0000 INFO  GetFileHandler Handler(tag: 3066, GET) sending length: 148937, 91420611
-2013-08-27 01:14:03,057+0000 INFO  ReadBuffer RB-LR-Handler(tag: 183, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:03,057+0000 INFO  ReadBuffer RB-LR-Handler(tag: 183, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:03,057+0000 INFO  LocalIOProvider LR-Handler(tag: 183, GET) rbuf: RB-LR-Handler(tag: 183, GET)
-2013-08-27 01:14:03,057+0000 INFO  GetFileHandler Handler(tag: 183, GET) unregistering (last)
-2013-08-27 01:14:03,057+0000 INFO  GetFileHandler Handler(tag: 3066, GET) unregistering (last)
-2013-08-27 01:14:03,057+0000 INFO  ReadBuffer RB-LR-Handler(tag: 183, GET) de-allocating 5 buffers
-2013-08-27 01:14:03,057+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:03,059+0000 INFO  GetFileHandler Handler(tag: 3067, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,059+0000 INFO  GetFileHandler Handler(tag: 3067, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,059+0000 INFO  GetFileHandler Handler(tag: 3067, GET) -> 184
-2013-08-27 01:14:03,059+0000 INFO  GetFileHandler Handler(tag: 184, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,059+0000 INFO  GetFileHandler Handler(tag: 184, GET) reader: LR-Handler(tag: 184, GET)
-2013-08-27 01:14:03,059+0000 INFO  GetFileHandler Handler(tag: 184, GET) sending length: 148937, 783837048
-2013-08-27 01:14:03,059+0000 INFO  GetFileHandler Handler(tag: 3067, GET) sending length: 148937, 1284575038
-2013-08-27 01:14:03,059+0000 INFO  ReadBuffer RB-LR-Handler(tag: 184, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:03,059+0000 INFO  ReadBuffer RB-LR-Handler(tag: 184, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:03,059+0000 INFO  LocalIOProvider LR-Handler(tag: 184, GET) rbuf: RB-LR-Handler(tag: 184, GET)
-2013-08-27 01:14:03,059+0000 INFO  GetFileHandler Handler(tag: 184, GET) unregistering (last)
-2013-08-27 01:14:03,059+0000 INFO  GetFileHandler Handler(tag: 3067, GET) unregistering (last)
-2013-08-27 01:14:03,059+0000 INFO  ReadBuffer RB-LR-Handler(tag: 184, GET) de-allocating 5 buffers
-2013-08-27 01:14:03,059+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:03,060+0000 INFO  GetFileHandler Handler(tag: 3068, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,060+0000 INFO  GetFileHandler Handler(tag: 3068, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,060+0000 INFO  GetFileHandler Handler(tag: 3068, GET) -> 185
-2013-08-27 01:14:03,060+0000 INFO  GetFileHandler Handler(tag: 185, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,060+0000 INFO  GetFileHandler Handler(tag: 185, GET) reader: LR-Handler(tag: 185, GET)
-2013-08-27 01:14:03,061+0000 INFO  GetFileHandler Handler(tag: 185, GET) sending length: 148937, 523754722
-2013-08-27 01:14:03,061+0000 INFO  GetFileHandler Handler(tag: 3068, GET) sending length: 148937, 210143601
-2013-08-27 01:14:03,061+0000 INFO  ReadBuffer RB-LR-Handler(tag: 185, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:03,061+0000 INFO  ReadBuffer RB-LR-Handler(tag: 185, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:03,061+0000 INFO  LocalIOProvider LR-Handler(tag: 185, GET) rbuf: RB-LR-Handler(tag: 185, GET)
-2013-08-27 01:14:03,061+0000 INFO  GetFileHandler Handler(tag: 185, GET) unregistering (last)
-2013-08-27 01:14:03,061+0000 INFO  GetFileHandler Handler(tag: 3068, GET) unregistering (last)
-2013-08-27 01:14:03,061+0000 INFO  ReadBuffer RB-LR-Handler(tag: 185, GET) de-allocating 5 buffers
-2013-08-27 01:14:03,061+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:03,062+0000 INFO  GetFileHandler Handler(tag: 3069, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,062+0000 INFO  GetFileHandler Handler(tag: 3069, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,062+0000 INFO  GetFileHandler Handler(tag: 3069, GET) -> 186
-2013-08-27 01:14:03,062+0000 INFO  GetFileHandler Handler(tag: 186, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,062+0000 INFO  GetFileHandler Handler(tag: 186, GET) reader: LR-Handler(tag: 186, GET)
-2013-08-27 01:14:03,062+0000 INFO  GetFileHandler Handler(tag: 186, GET) sending length: 148937, 1641998555
-2013-08-27 01:14:03,062+0000 INFO  GetFileHandler Handler(tag: 3069, GET) sending length: 148937, 1904849935
-2013-08-27 01:14:03,062+0000 INFO  ReadBuffer RB-LR-Handler(tag: 186, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:03,062+0000 INFO  ReadBuffer RB-LR-Handler(tag: 186, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:03,062+0000 INFO  LocalIOProvider LR-Handler(tag: 186, GET) rbuf: RB-LR-Handler(tag: 186, GET)
-2013-08-27 01:14:03,062+0000 INFO  GetFileHandler Handler(tag: 186, GET) unregistering (last)
-2013-08-27 01:14:03,062+0000 INFO  GetFileHandler Handler(tag: 3069, GET) unregistering (last)
-2013-08-27 01:14:03,062+0000 INFO  ReadBuffer RB-LR-Handler(tag: 186, GET) de-allocating 5 buffers
-2013-08-27 01:14:03,062+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:03,064+0000 INFO  GetFileHandler Handler(tag: 3070, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,064+0000 INFO  GetFileHandler Handler(tag: 3070, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,064+0000 INFO  GetFileHandler Handler(tag: 3070, GET) -> 187
-2013-08-27 01:14:03,064+0000 INFO  GetFileHandler Handler(tag: 187, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,064+0000 INFO  GetFileHandler Handler(tag: 187, GET) reader: LR-Handler(tag: 187, GET)
-2013-08-27 01:14:03,064+0000 INFO  GetFileHandler Handler(tag: 187, GET) sending length: 543, 1191209411
-2013-08-27 01:14:03,064+0000 INFO  GetFileHandler Handler(tag: 3070, GET) sending length: 543, 1814013343
-2013-08-27 01:14:03,064+0000 INFO  ReadBuffer RB-LR-Handler(tag: 187, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,064+0000 INFO  ReadBuffer RB-LR-Handler(tag: 187, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,064+0000 INFO  LocalIOProvider LR-Handler(tag: 187, GET) rbuf: RB-LR-Handler(tag: 187, GET)
-2013-08-27 01:14:03,064+0000 INFO  GetFileHandler Handler(tag: 187, GET) unregistering (last)
-2013-08-27 01:14:03,065+0000 INFO  GetFileHandler Handler(tag: 3070, GET) unregistering (last)
-2013-08-27 01:14:03,065+0000 INFO  GetFileHandler Handler(tag: 3071, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,065+0000 INFO  ReadBuffer RB-LR-Handler(tag: 187, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,065+0000 INFO  GetFileHandler Handler(tag: 3071, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,065+0000 INFO  GetFileHandler Handler(tag: 3071, GET) -> 188
-2013-08-27 01:14:03,065+0000 INFO  GetFileHandler Handler(tag: 188, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,065+0000 INFO  GetFileHandler Handler(tag: 188, GET) reader: LR-Handler(tag: 188, GET)
-2013-08-27 01:14:03,065+0000 INFO  GetFileHandler Handler(tag: 188, GET) sending length: 2093, 813732571
-2013-08-27 01:14:03,065+0000 INFO  GetFileHandler Handler(tag: 3071, GET) sending length: 2093, 1227456701
-2013-08-27 01:14:03,065+0000 INFO  ReadBuffer RB-LR-Handler(tag: 188, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,065+0000 INFO  ReadBuffer RB-LR-Handler(tag: 188, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,065+0000 INFO  LocalIOProvider LR-Handler(tag: 188, GET) rbuf: RB-LR-Handler(tag: 188, GET)
-2013-08-27 01:14:03,065+0000 INFO  GetFileHandler Handler(tag: 188, GET) unregistering (last)
-2013-08-27 01:14:03,065+0000 INFO  ReadBuffer RB-LR-Handler(tag: 188, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,065+0000 INFO  GetFileHandler Handler(tag: 3071, GET) unregistering (last)
-2013-08-27 01:14:03,067+0000 INFO  GetFileHandler Handler(tag: 3072, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,067+0000 INFO  GetFileHandler Handler(tag: 3072, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,067+0000 INFO  GetFileHandler Handler(tag: 3072, GET) -> 189
-2013-08-27 01:14:03,067+0000 INFO  GetFileHandler Handler(tag: 189, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,067+0000 INFO  GetFileHandler Handler(tag: 189, GET) reader: LR-Handler(tag: 189, GET)
-2013-08-27 01:14:03,067+0000 INFO  GetFileHandler Handler(tag: 189, GET) sending length: 543, 1363276325
-2013-08-27 01:14:03,067+0000 INFO  GetFileHandler Handler(tag: 3072, GET) sending length: 543, 1082164432
-2013-08-27 01:14:03,067+0000 INFO  ReadBuffer RB-LR-Handler(tag: 189, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,067+0000 INFO  ReadBuffer RB-LR-Handler(tag: 189, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,067+0000 INFO  LocalIOProvider LR-Handler(tag: 189, GET) rbuf: RB-LR-Handler(tag: 189, GET)
-2013-08-27 01:14:03,067+0000 INFO  GetFileHandler Handler(tag: 189, GET) unregistering (last)
-2013-08-27 01:14:03,067+0000 INFO  ReadBuffer RB-LR-Handler(tag: 189, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,067+0000 INFO  GetFileHandler Handler(tag: 3072, GET) unregistering (last)
-2013-08-27 01:14:03,069+0000 INFO  GetFileHandler Handler(tag: 3073, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,069+0000 INFO  GetFileHandler Handler(tag: 3073, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,069+0000 INFO  GetFileHandler Handler(tag: 3073, GET) -> 190
-2013-08-27 01:14:03,069+0000 INFO  GetFileHandler Handler(tag: 190, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,069+0000 INFO  GetFileHandler Handler(tag: 190, GET) reader: LR-Handler(tag: 190, GET)
-2013-08-27 01:14:03,069+0000 INFO  GetFileHandler Handler(tag: 190, GET) sending length: 543, 1851880922
-2013-08-27 01:14:03,069+0000 INFO  GetFileHandler Handler(tag: 3073, GET) sending length: 543, 1082160083
-2013-08-27 01:14:03,070+0000 INFO  ReadBuffer RB-LR-Handler(tag: 190, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,070+0000 INFO  ReadBuffer RB-LR-Handler(tag: 190, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,070+0000 INFO  LocalIOProvider LR-Handler(tag: 190, GET) rbuf: RB-LR-Handler(tag: 190, GET)
-2013-08-27 01:14:03,070+0000 INFO  GetFileHandler Handler(tag: 190, GET) unregistering (last)
-2013-08-27 01:14:03,070+0000 INFO  ReadBuffer RB-LR-Handler(tag: 190, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,070+0000 INFO  GetFileHandler Handler(tag: 3073, GET) unregistering (last)
-2013-08-27 01:14:03,072+0000 INFO  GetFileHandler Handler(tag: 3074, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,072+0000 INFO  GetFileHandler Handler(tag: 3074, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,072+0000 INFO  GetFileHandler Handler(tag: 3074, GET) -> 191
-2013-08-27 01:14:03,072+0000 INFO  GetFileHandler Handler(tag: 191, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,072+0000 INFO  GetFileHandler Handler(tag: 191, GET) reader: LR-Handler(tag: 191, GET)
-2013-08-27 01:14:03,072+0000 INFO  GetFileHandler Handler(tag: 191, GET) sending length: 543, 1841754451
-2013-08-27 01:14:03,072+0000 INFO  GetFileHandler Handler(tag: 3074, GET) sending length: 543, 537770099
-2013-08-27 01:14:03,072+0000 INFO  ReadBuffer RB-LR-Handler(tag: 191, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,072+0000 INFO  ReadBuffer RB-LR-Handler(tag: 191, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,072+0000 INFO  LocalIOProvider LR-Handler(tag: 191, GET) rbuf: RB-LR-Handler(tag: 191, GET)
-2013-08-27 01:14:03,072+0000 INFO  GetFileHandler Handler(tag: 191, GET) unregistering (last)
-2013-08-27 01:14:03,072+0000 INFO  ReadBuffer RB-LR-Handler(tag: 191, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,072+0000 INFO  GetFileHandler Handler(tag: 3074, GET) unregistering (last)
-2013-08-27 01:14:03,075+0000 INFO  GetFileHandler Handler(tag: 3075, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,075+0000 INFO  GetFileHandler Handler(tag: 3075, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,075+0000 INFO  GetFileHandler Handler(tag: 3075, GET) -> 192
-2013-08-27 01:14:03,075+0000 INFO  GetFileHandler Handler(tag: 192, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,075+0000 INFO  GetFileHandler Handler(tag: 192, GET) reader: LR-Handler(tag: 192, GET)
-2013-08-27 01:14:03,075+0000 INFO  GetFileHandler Handler(tag: 192, GET) sending length: 543, 15244440
-2013-08-27 01:14:03,075+0000 INFO  GetFileHandler Handler(tag: 3075, GET) sending length: 543, 662749087
-2013-08-27 01:14:03,075+0000 INFO  ReadBuffer RB-LR-Handler(tag: 192, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,075+0000 INFO  ReadBuffer RB-LR-Handler(tag: 192, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,075+0000 INFO  LocalIOProvider LR-Handler(tag: 192, GET) rbuf: RB-LR-Handler(tag: 192, GET)
-2013-08-27 01:14:03,075+0000 INFO  GetFileHandler Handler(tag: 192, GET) unregistering (last)
-2013-08-27 01:14:03,075+0000 INFO  ReadBuffer RB-LR-Handler(tag: 192, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,075+0000 INFO  GetFileHandler Handler(tag: 3075, GET) unregistering (last)
-2013-08-27 01:14:03,077+0000 INFO  GetFileHandler Handler(tag: 3076, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,077+0000 INFO  GetFileHandler Handler(tag: 3076, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,077+0000 INFO  GetFileHandler Handler(tag: 3076, GET) -> 193
-2013-08-27 01:14:03,077+0000 INFO  GetFileHandler Handler(tag: 193, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,077+0000 INFO  GetFileHandler Handler(tag: 193, GET) reader: LR-Handler(tag: 193, GET)
-2013-08-27 01:14:03,077+0000 INFO  GetFileHandler Handler(tag: 193, GET) sending length: 543, 383169910
-2013-08-27 01:14:03,077+0000 INFO  GetFileHandler Handler(tag: 3076, GET) sending length: 543, 1780703664
-2013-08-27 01:14:03,077+0000 INFO  ReadBuffer RB-LR-Handler(tag: 193, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,077+0000 INFO  ReadBuffer RB-LR-Handler(tag: 193, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,077+0000 INFO  LocalIOProvider LR-Handler(tag: 193, GET) rbuf: RB-LR-Handler(tag: 193, GET)
-2013-08-27 01:14:03,077+0000 INFO  GetFileHandler Handler(tag: 193, GET) unregistering (last)
-2013-08-27 01:14:03,077+0000 INFO  ReadBuffer RB-LR-Handler(tag: 193, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,077+0000 INFO  GetFileHandler Handler(tag: 3076, GET) unregistering (last)
-2013-08-27 01:14:03,080+0000 INFO  GetFileHandler Handler(tag: 3077, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,080+0000 INFO  GetFileHandler Handler(tag: 3077, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,080+0000 INFO  GetFileHandler Handler(tag: 3077, GET) -> 194
-2013-08-27 01:14:03,080+0000 INFO  GetFileHandler Handler(tag: 194, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,080+0000 INFO  GetFileHandler Handler(tag: 194, GET) reader: LR-Handler(tag: 194, GET)
-2013-08-27 01:14:03,080+0000 INFO  GetFileHandler Handler(tag: 194, GET) sending length: 543, 1544057083
-2013-08-27 01:14:03,080+0000 INFO  GetFileHandler Handler(tag: 3077, GET) sending length: 543, 775003633
-2013-08-27 01:14:03,080+0000 INFO  ReadBuffer RB-LR-Handler(tag: 194, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,080+0000 INFO  ReadBuffer RB-LR-Handler(tag: 194, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,080+0000 INFO  LocalIOProvider LR-Handler(tag: 194, GET) rbuf: RB-LR-Handler(tag: 194, GET)
-2013-08-27 01:14:03,080+0000 INFO  GetFileHandler Handler(tag: 194, GET) unregistering (last)
-2013-08-27 01:14:03,080+0000 INFO  GetFileHandler Handler(tag: 3078, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,080+0000 INFO  GetFileHandler Handler(tag: 3077, GET) unregistering (last)
-2013-08-27 01:14:03,080+0000 INFO  ReadBuffer RB-LR-Handler(tag: 194, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,080+0000 INFO  GetFileHandler Handler(tag: 3078, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,080+0000 INFO  GetFileHandler Handler(tag: 3078, GET) -> 195
-2013-08-27 01:14:03,080+0000 INFO  GetFileHandler Handler(tag: 195, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,080+0000 INFO  GetFileHandler Handler(tag: 195, GET) reader: LR-Handler(tag: 195, GET)
-2013-08-27 01:14:03,080+0000 INFO  GetFileHandler Handler(tag: 195, GET) sending length: 2093, 1154926722
-2013-08-27 01:14:03,080+0000 INFO  GetFileHandler Handler(tag: 3078, GET) sending length: 2093, 1896215068
-2013-08-27 01:14:03,080+0000 INFO  ReadBuffer RB-LR-Handler(tag: 195, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,080+0000 INFO  ReadBuffer RB-LR-Handler(tag: 195, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,080+0000 INFO  LocalIOProvider LR-Handler(tag: 195, GET) rbuf: RB-LR-Handler(tag: 195, GET)
-2013-08-27 01:14:03,080+0000 INFO  GetFileHandler Handler(tag: 195, GET) unregistering (last)
-2013-08-27 01:14:03,080+0000 INFO  GetFileHandler Handler(tag: 3078, GET) unregistering (last)
-2013-08-27 01:14:03,080+0000 INFO  ReadBuffer RB-LR-Handler(tag: 195, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,082+0000 INFO  GetFileHandler Handler(tag: 3079, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,082+0000 INFO  GetFileHandler Handler(tag: 3079, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,082+0000 INFO  GetFileHandler Handler(tag: 3079, GET) -> 196
-2013-08-27 01:14:03,082+0000 INFO  GetFileHandler Handler(tag: 196, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,082+0000 INFO  GetFileHandler Handler(tag: 196, GET) reader: LR-Handler(tag: 196, GET)
-2013-08-27 01:14:03,082+0000 INFO  GetFileHandler Handler(tag: 196, GET) sending length: 543, 682231079
-2013-08-27 01:14:03,082+0000 INFO  GetFileHandler Handler(tag: 3079, GET) sending length: 543, 842553420
-2013-08-27 01:14:03,082+0000 INFO  ReadBuffer RB-LR-Handler(tag: 196, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,082+0000 INFO  ReadBuffer RB-LR-Handler(tag: 196, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,082+0000 INFO  LocalIOProvider LR-Handler(tag: 196, GET) rbuf: RB-LR-Handler(tag: 196, GET)
-2013-08-27 01:14:03,082+0000 INFO  GetFileHandler Handler(tag: 196, GET) unregistering (last)
-2013-08-27 01:14:03,082+0000 INFO  ReadBuffer RB-LR-Handler(tag: 196, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,082+0000 INFO  GetFileHandler Handler(tag: 3079, GET) unregistering (last)
-2013-08-27 01:14:03,082+0000 INFO  GetFileHandler Handler(tag: 3080, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,082+0000 INFO  GetFileHandler Handler(tag: 3080, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,083+0000 INFO  GetFileHandler Handler(tag: 3080, GET) -> 197
-2013-08-27 01:14:03,083+0000 INFO  GetFileHandler Handler(tag: 197, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,083+0000 INFO  GetFileHandler Handler(tag: 197, GET) reader: LR-Handler(tag: 197, GET)
-2013-08-27 01:14:03,083+0000 INFO  GetFileHandler Handler(tag: 197, GET) sending length: 2093, 2030607121
-2013-08-27 01:14:03,083+0000 INFO  GetFileHandler Handler(tag: 3080, GET) sending length: 2093, 603764523
-2013-08-27 01:14:03,083+0000 INFO  ReadBuffer RB-LR-Handler(tag: 197, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,083+0000 INFO  ReadBuffer RB-LR-Handler(tag: 197, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,083+0000 INFO  LocalIOProvider LR-Handler(tag: 197, GET) rbuf: RB-LR-Handler(tag: 197, GET)
-2013-08-27 01:14:03,083+0000 INFO  GetFileHandler Handler(tag: 197, GET) unregistering (last)
-2013-08-27 01:14:03,083+0000 INFO  ReadBuffer RB-LR-Handler(tag: 197, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,083+0000 INFO  GetFileHandler Handler(tag: 3080, GET) unregistering (last)
-2013-08-27 01:14:03,085+0000 INFO  GetFileHandler Handler(tag: 3081, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,085+0000 INFO  GetFileHandler Handler(tag: 3081, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,085+0000 INFO  GetFileHandler Handler(tag: 3081, GET) -> 198
-2013-08-27 01:14:03,085+0000 INFO  GetFileHandler Handler(tag: 198, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,085+0000 INFO  GetFileHandler Handler(tag: 198, GET) reader: LR-Handler(tag: 198, GET)
-2013-08-27 01:14:03,085+0000 INFO  GetFileHandler Handler(tag: 198, GET) sending length: 543, 2074868858
-2013-08-27 01:14:03,085+0000 INFO  GetFileHandler Handler(tag: 3081, GET) sending length: 543, 1481436420
-2013-08-27 01:14:03,085+0000 INFO  ReadBuffer RB-LR-Handler(tag: 198, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,085+0000 INFO  ReadBuffer RB-LR-Handler(tag: 198, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,085+0000 INFO  LocalIOProvider LR-Handler(tag: 198, GET) rbuf: RB-LR-Handler(tag: 198, GET)
-2013-08-27 01:14:03,085+0000 INFO  GetFileHandler Handler(tag: 198, GET) unregistering (last)
-2013-08-27 01:14:03,085+0000 INFO  ReadBuffer RB-LR-Handler(tag: 198, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,085+0000 INFO  GetFileHandler Handler(tag: 3081, GET) unregistering (last)
-2013-08-27 01:14:03,087+0000 INFO  GetFileHandler Handler(tag: 3082, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,087+0000 INFO  GetFileHandler Handler(tag: 3082, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,087+0000 INFO  GetFileHandler Handler(tag: 3082, GET) -> 199
-2013-08-27 01:14:03,087+0000 INFO  GetFileHandler Handler(tag: 199, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,087+0000 INFO  GetFileHandler Handler(tag: 199, GET) reader: LR-Handler(tag: 199, GET)
-2013-08-27 01:14:03,087+0000 INFO  GetFileHandler Handler(tag: 199, GET) sending length: 543, 1900896764
-2013-08-27 01:14:03,087+0000 INFO  GetFileHandler Handler(tag: 3082, GET) sending length: 543, 257696129
-2013-08-27 01:14:03,087+0000 INFO  ReadBuffer RB-LR-Handler(tag: 199, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,087+0000 INFO  ReadBuffer RB-LR-Handler(tag: 199, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,087+0000 INFO  LocalIOProvider LR-Handler(tag: 199, GET) rbuf: RB-LR-Handler(tag: 199, GET)
-2013-08-27 01:14:03,087+0000 INFO  GetFileHandler Handler(tag: 199, GET) unregistering (last)
-2013-08-27 01:14:03,087+0000 INFO  ReadBuffer RB-LR-Handler(tag: 199, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,087+0000 INFO  GetFileHandler Handler(tag: 3082, GET) unregistering (last)
-2013-08-27 01:14:03,089+0000 INFO  GetFileHandler Handler(tag: 3083, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,089+0000 INFO  GetFileHandler Handler(tag: 3083, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,089+0000 INFO  GetFileHandler Handler(tag: 3083, GET) -> 200
-2013-08-27 01:14:03,089+0000 INFO  GetFileHandler Handler(tag: 200, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,089+0000 INFO  GetFileHandler Handler(tag: 200, GET) reader: LR-Handler(tag: 200, GET)
-2013-08-27 01:14:03,089+0000 INFO  GetFileHandler Handler(tag: 200, GET) sending length: 543, 1587291032
-2013-08-27 01:14:03,089+0000 INFO  GetFileHandler Handler(tag: 3083, GET) sending length: 543, 1558511790
-2013-08-27 01:14:03,089+0000 INFO  ReadBuffer RB-LR-Handler(tag: 200, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,089+0000 INFO  ReadBuffer RB-LR-Handler(tag: 200, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,089+0000 INFO  LocalIOProvider LR-Handler(tag: 200, GET) rbuf: RB-LR-Handler(tag: 200, GET)
-2013-08-27 01:14:03,089+0000 INFO  GetFileHandler Handler(tag: 200, GET) unregistering (last)
-2013-08-27 01:14:03,089+0000 INFO  ReadBuffer RB-LR-Handler(tag: 200, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,089+0000 INFO  GetFileHandler Handler(tag: 3083, GET) unregistering (last)
-2013-08-27 01:14:03,091+0000 INFO  GetFileHandler Handler(tag: 3084, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,091+0000 INFO  GetFileHandler Handler(tag: 3084, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,091+0000 INFO  GetFileHandler Handler(tag: 3084, GET) -> 201
-2013-08-27 01:14:03,091+0000 INFO  GetFileHandler Handler(tag: 201, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,092+0000 INFO  GetFileHandler Handler(tag: 201, GET) reader: LR-Handler(tag: 201, GET)
-2013-08-27 01:14:03,092+0000 INFO  GetFileHandler Handler(tag: 201, GET) sending length: 543, 1787983760
-2013-08-27 01:14:03,092+0000 INFO  GetFileHandler Handler(tag: 3084, GET) sending length: 543, 904381849
-2013-08-27 01:14:03,092+0000 INFO  ReadBuffer RB-LR-Handler(tag: 201, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,092+0000 INFO  ReadBuffer RB-LR-Handler(tag: 201, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,092+0000 INFO  LocalIOProvider LR-Handler(tag: 201, GET) rbuf: RB-LR-Handler(tag: 201, GET)
-2013-08-27 01:14:03,092+0000 INFO  GetFileHandler Handler(tag: 201, GET) unregistering (last)
-2013-08-27 01:14:03,092+0000 INFO  GetFileHandler Handler(tag: 3084, GET) unregistering (last)
-2013-08-27 01:14:03,092+0000 INFO  ReadBuffer RB-LR-Handler(tag: 201, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,093+0000 INFO  GetFileHandler Handler(tag: 3085, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,093+0000 INFO  GetFileHandler Handler(tag: 3085, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,093+0000 INFO  GetFileHandler Handler(tag: 3085, GET) -> 202
-2013-08-27 01:14:03,094+0000 INFO  GetFileHandler Handler(tag: 202, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,094+0000 INFO  GetFileHandler Handler(tag: 202, GET) reader: LR-Handler(tag: 202, GET)
-2013-08-27 01:14:03,094+0000 INFO  GetFileHandler Handler(tag: 202, GET) sending length: 543, 758111104
-2013-08-27 01:14:03,094+0000 INFO  GetFileHandler Handler(tag: 3085, GET) sending length: 543, 552847277
-2013-08-27 01:14:03,094+0000 INFO  ReadBuffer RB-LR-Handler(tag: 202, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,094+0000 INFO  ReadBuffer RB-LR-Handler(tag: 202, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,094+0000 INFO  LocalIOProvider LR-Handler(tag: 202, GET) rbuf: RB-LR-Handler(tag: 202, GET)
-2013-08-27 01:14:03,094+0000 INFO  GetFileHandler Handler(tag: 202, GET) unregistering (last)
-2013-08-27 01:14:03,094+0000 INFO  GetFileHandler Handler(tag: 3086, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,094+0000 INFO  ReadBuffer RB-LR-Handler(tag: 202, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,094+0000 INFO  GetFileHandler Handler(tag: 3085, GET) unregistering (last)
-2013-08-27 01:14:03,094+0000 INFO  GetFileHandler Handler(tag: 3086, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,094+0000 INFO  GetFileHandler Handler(tag: 3086, GET) -> 203
-2013-08-27 01:14:03,094+0000 INFO  GetFileHandler Handler(tag: 203, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,094+0000 INFO  GetFileHandler Handler(tag: 203, GET) reader: LR-Handler(tag: 203, GET)
-2013-08-27 01:14:03,094+0000 INFO  GetFileHandler Handler(tag: 203, GET) sending length: 2093, 1026776958
-2013-08-27 01:14:03,094+0000 INFO  GetFileHandler Handler(tag: 3086, GET) sending length: 2093, 2009229461
-2013-08-27 01:14:03,094+0000 INFO  ReadBuffer RB-LR-Handler(tag: 203, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,094+0000 INFO  ReadBuffer RB-LR-Handler(tag: 203, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,094+0000 INFO  LocalIOProvider LR-Handler(tag: 203, GET) rbuf: RB-LR-Handler(tag: 203, GET)
-2013-08-27 01:14:03,094+0000 INFO  GetFileHandler Handler(tag: 3087, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,094+0000 INFO  GetFileHandler Handler(tag: 203, GET) unregistering (last)
-2013-08-27 01:14:03,094+0000 INFO  ReadBuffer RB-LR-Handler(tag: 203, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,094+0000 INFO  GetFileHandler Handler(tag: 3086, GET) unregistering (last)
-2013-08-27 01:14:03,094+0000 INFO  GetFileHandler Handler(tag: 3087, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,094+0000 INFO  GetFileHandler Handler(tag: 3087, GET) -> 204
-2013-08-27 01:14:03,094+0000 INFO  GetFileHandler Handler(tag: 204, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,094+0000 INFO  GetFileHandler Handler(tag: 204, GET) reader: LR-Handler(tag: 204, GET)
-2013-08-27 01:14:03,094+0000 INFO  GetFileHandler Handler(tag: 204, GET) sending length: 5032, 567175767
-2013-08-27 01:14:03,094+0000 INFO  GetFileHandler Handler(tag: 3087, GET) sending length: 5032, 1990690583
-2013-08-27 01:14:03,094+0000 INFO  ReadBuffer RB-LR-Handler(tag: 204, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,094+0000 INFO  ReadBuffer RB-LR-Handler(tag: 204, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,094+0000 INFO  LocalIOProvider LR-Handler(tag: 204, GET) rbuf: RB-LR-Handler(tag: 204, GET)
-2013-08-27 01:14:03,094+0000 INFO  GetFileHandler Handler(tag: 204, GET) unregistering (last)
-2013-08-27 01:14:03,094+0000 INFO  ReadBuffer RB-LR-Handler(tag: 204, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,094+0000 INFO  GetFileHandler Handler(tag: 3087, GET) unregistering (last)
-2013-08-27 01:14:03,094+0000 INFO  GetFileHandler Handler(tag: 3088, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,094+0000 INFO  GetFileHandler Handler(tag: 3088, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,094+0000 INFO  GetFileHandler Handler(tag: 3088, GET) -> 205
-2013-08-27 01:14:03,094+0000 INFO  GetFileHandler Handler(tag: 205, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,094+0000 INFO  GetFileHandler Handler(tag: 205, GET) reader: LR-Handler(tag: 205, GET)
-2013-08-27 01:14:03,094+0000 INFO  GetFileHandler Handler(tag: 205, GET) sending length: 2093, 960635056
-2013-08-27 01:14:03,094+0000 INFO  GetFileHandler Handler(tag: 3088, GET) sending length: 2093, 611328046
-2013-08-27 01:14:03,094+0000 INFO  ReadBuffer RB-LR-Handler(tag: 205, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,094+0000 INFO  ReadBuffer RB-LR-Handler(tag: 205, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,095+0000 INFO  LocalIOProvider LR-Handler(tag: 205, GET) rbuf: RB-LR-Handler(tag: 205, GET)
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 3089, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 205, GET) unregistering (last)
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 3088, GET) unregistering (last)
-2013-08-27 01:14:03,095+0000 INFO  ReadBuffer RB-LR-Handler(tag: 205, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 3089, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 3089, GET) -> 206
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 206, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 206, GET) reader: LR-Handler(tag: 206, GET)
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 206, GET) sending length: 2093, 472445342
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 3089, GET) sending length: 2093, 1141820035
-2013-08-27 01:14:03,095+0000 INFO  ReadBuffer RB-LR-Handler(tag: 206, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,095+0000 INFO  ReadBuffer RB-LR-Handler(tag: 206, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,095+0000 INFO  LocalIOProvider LR-Handler(tag: 206, GET) rbuf: RB-LR-Handler(tag: 206, GET)
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 206, GET) unregistering (last)
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 3090, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,095+0000 INFO  ReadBuffer RB-LR-Handler(tag: 206, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 3089, GET) unregistering (last)
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 3090, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 3090, GET) -> 207
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 207, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 207, GET) reader: LR-Handler(tag: 207, GET)
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 207, GET) sending length: 2093, 1472287907
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 3090, GET) sending length: 2093, 1436272215
-2013-08-27 01:14:03,095+0000 INFO  ReadBuffer RB-LR-Handler(tag: 207, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 3091, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,095+0000 INFO  ReadBuffer RB-LR-Handler(tag: 207, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,095+0000 INFO  LocalIOProvider LR-Handler(tag: 207, GET) rbuf: RB-LR-Handler(tag: 207, GET)
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 207, GET) unregistering (last)
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 3091, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,095+0000 INFO  ReadBuffer RB-LR-Handler(tag: 207, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 3090, GET) unregistering (last)
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 3091, GET) -> 208
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 208, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 208, GET) reader: LR-Handler(tag: 208, GET)
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 208, GET) sending length: 2093, 338029290
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 3091, GET) sending length: 2093, 1164030715
-2013-08-27 01:14:03,095+0000 INFO  ReadBuffer RB-LR-Handler(tag: 208, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,095+0000 INFO  ReadBuffer RB-LR-Handler(tag: 208, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,095+0000 INFO  LocalIOProvider LR-Handler(tag: 208, GET) rbuf: RB-LR-Handler(tag: 208, GET)
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 208, GET) unregistering (last)
-2013-08-27 01:14:03,095+0000 INFO  ReadBuffer RB-LR-Handler(tag: 208, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 3091, GET) unregistering (last)
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 3092, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 3092, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 3092, GET) -> 209
-2013-08-27 01:14:03,095+0000 INFO  GetFileHandler Handler(tag: 209, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,096+0000 INFO  GetFileHandler Handler(tag: 209, GET) reader: LR-Handler(tag: 209, GET)
-2013-08-27 01:14:03,096+0000 INFO  GetFileHandler Handler(tag: 209, GET) sending length: 2093, 630205034
-2013-08-27 01:14:03,096+0000 INFO  GetFileHandler Handler(tag: 3092, GET) sending length: 2093, 466659434
-2013-08-27 01:14:03,096+0000 INFO  ReadBuffer RB-LR-Handler(tag: 209, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,096+0000 INFO  ReadBuffer RB-LR-Handler(tag: 209, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,096+0000 INFO  LocalIOProvider LR-Handler(tag: 209, GET) rbuf: RB-LR-Handler(tag: 209, GET)
-2013-08-27 01:14:03,096+0000 INFO  GetFileHandler Handler(tag: 209, GET) unregistering (last)
-2013-08-27 01:14:03,096+0000 INFO  GetFileHandler Handler(tag: 3093, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,096+0000 INFO  GetFileHandler Handler(tag: 3092, GET) unregistering (last)
-2013-08-27 01:14:03,096+0000 INFO  ReadBuffer RB-LR-Handler(tag: 209, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,096+0000 INFO  GetFileHandler Handler(tag: 3093, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,096+0000 INFO  GetFileHandler Handler(tag: 3093, GET) -> 210
-2013-08-27 01:14:03,096+0000 INFO  GetFileHandler Handler(tag: 210, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,096+0000 INFO  GetFileHandler Handler(tag: 210, GET) reader: LR-Handler(tag: 210, GET)
-2013-08-27 01:14:03,096+0000 INFO  GetFileHandler Handler(tag: 210, GET) sending length: 2093, 997520141
-2013-08-27 01:14:03,096+0000 INFO  GetFileHandler Handler(tag: 3093, GET) sending length: 2093, 2063661305
-2013-08-27 01:14:03,096+0000 INFO  ReadBuffer RB-LR-Handler(tag: 210, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,096+0000 INFO  ReadBuffer RB-LR-Handler(tag: 210, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,096+0000 INFO  LocalIOProvider LR-Handler(tag: 210, GET) rbuf: RB-LR-Handler(tag: 210, GET)
-2013-08-27 01:14:03,096+0000 INFO  GetFileHandler Handler(tag: 210, GET) unregistering (last)
-2013-08-27 01:14:03,096+0000 INFO  GetFileHandler Handler(tag: 3093, GET) unregistering (last)
-2013-08-27 01:14:03,096+0000 INFO  ReadBuffer RB-LR-Handler(tag: 210, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,096+0000 INFO  GetFileHandler Handler(tag: 3094, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,096+0000 INFO  GetFileHandler Handler(tag: 3094, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,096+0000 INFO  GetFileHandler Handler(tag: 3094, GET) -> 211
-2013-08-27 01:14:03,096+0000 INFO  GetFileHandler Handler(tag: 211, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,096+0000 INFO  GetFileHandler Handler(tag: 211, GET) reader: LR-Handler(tag: 211, GET)
-2013-08-27 01:14:03,096+0000 INFO  GetFileHandler Handler(tag: 211, GET) sending length: 5032, 1682698427
-2013-08-27 01:14:03,096+0000 INFO  GetFileHandler Handler(tag: 3094, GET) sending length: 5032, 900315246
-2013-08-27 01:14:03,096+0000 INFO  ReadBuffer RB-LR-Handler(tag: 211, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,096+0000 INFO  ReadBuffer RB-LR-Handler(tag: 211, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,096+0000 INFO  LocalIOProvider LR-Handler(tag: 211, GET) rbuf: RB-LR-Handler(tag: 211, GET)
-2013-08-27 01:14:03,096+0000 INFO  GetFileHandler Handler(tag: 211, GET) unregistering (last)
-2013-08-27 01:14:03,096+0000 INFO  GetFileHandler Handler(tag: 3095, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,096+0000 INFO  GetFileHandler Handler(tag: 3094, GET) unregistering (last)
-2013-08-27 01:14:03,096+0000 INFO  ReadBuffer RB-LR-Handler(tag: 211, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,096+0000 INFO  GetFileHandler Handler(tag: 3095, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,096+0000 INFO  GetFileHandler Handler(tag: 3095, GET) -> 212
-2013-08-27 01:14:03,096+0000 INFO  GetFileHandler Handler(tag: 212, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,096+0000 INFO  GetFileHandler Handler(tag: 212, GET) reader: LR-Handler(tag: 212, GET)
-2013-08-27 01:14:03,096+0000 INFO  GetFileHandler Handler(tag: 212, GET) sending length: 2093, 883641278
-2013-08-27 01:14:03,096+0000 INFO  GetFileHandler Handler(tag: 3095, GET) sending length: 2093, 1509540341
-2013-08-27 01:14:03,096+0000 INFO  ReadBuffer RB-LR-Handler(tag: 212, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,096+0000 INFO  ReadBuffer RB-LR-Handler(tag: 212, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,096+0000 INFO  LocalIOProvider LR-Handler(tag: 212, GET) rbuf: RB-LR-Handler(tag: 212, GET)
-2013-08-27 01:14:03,096+0000 INFO  GetFileHandler Handler(tag: 212, GET) unregistering (last)
-2013-08-27 01:14:03,097+0000 INFO  GetFileHandler Handler(tag: 3095, GET) unregistering (last)
-2013-08-27 01:14:03,097+0000 INFO  ReadBuffer RB-LR-Handler(tag: 212, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,097+0000 INFO  GetFileHandler Handler(tag: 3096, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,097+0000 INFO  GetFileHandler Handler(tag: 3096, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,097+0000 INFO  GetFileHandler Handler(tag: 3096, GET) -> 213
-2013-08-27 01:14:03,097+0000 INFO  GetFileHandler Handler(tag: 213, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,097+0000 INFO  GetFileHandler Handler(tag: 213, GET) reader: LR-Handler(tag: 213, GET)
-2013-08-27 01:14:03,097+0000 INFO  GetFileHandler Handler(tag: 213, GET) sending length: 5032, 1166982606
-2013-08-27 01:14:03,097+0000 INFO  GetFileHandler Handler(tag: 3096, GET) sending length: 5032, 508510991
-2013-08-27 01:14:03,097+0000 INFO  ReadBuffer RB-LR-Handler(tag: 213, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,097+0000 INFO  ReadBuffer RB-LR-Handler(tag: 213, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,097+0000 INFO  LocalIOProvider LR-Handler(tag: 213, GET) rbuf: RB-LR-Handler(tag: 213, GET)
-2013-08-27 01:14:03,097+0000 INFO  GetFileHandler Handler(tag: 213, GET) unregistering (last)
-2013-08-27 01:14:03,097+0000 INFO  ReadBuffer RB-LR-Handler(tag: 213, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,097+0000 INFO  GetFileHandler Handler(tag: 3096, GET) unregistering (last)
-2013-08-27 01:14:03,097+0000 INFO  GetFileHandler Handler(tag: 3097, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,097+0000 INFO  GetFileHandler Handler(tag: 3097, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,097+0000 INFO  GetFileHandler Handler(tag: 3097, GET) -> 214
-2013-08-27 01:14:03,097+0000 INFO  GetFileHandler Handler(tag: 214, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,097+0000 INFO  GetFileHandler Handler(tag: 214, GET) reader: LR-Handler(tag: 214, GET)
-2013-08-27 01:14:03,097+0000 INFO  GetFileHandler Handler(tag: 214, GET) sending length: 2093, 1865721865
-2013-08-27 01:14:03,097+0000 INFO  GetFileHandler Handler(tag: 3097, GET) sending length: 2093, 1778655208
-2013-08-27 01:14:03,097+0000 INFO  ReadBuffer RB-LR-Handler(tag: 214, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,097+0000 INFO  ReadBuffer RB-LR-Handler(tag: 214, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,097+0000 INFO  LocalIOProvider LR-Handler(tag: 214, GET) rbuf: RB-LR-Handler(tag: 214, GET)
-2013-08-27 01:14:03,097+0000 INFO  GetFileHandler Handler(tag: 3098, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,097+0000 INFO  GetFileHandler Handler(tag: 214, GET) unregistering (last)
-2013-08-27 01:14:03,097+0000 INFO  GetFileHandler Handler(tag: 3097, GET) unregistering (last)
-2013-08-27 01:14:03,097+0000 INFO  ReadBuffer RB-LR-Handler(tag: 214, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,097+0000 INFO  GetFileHandler Handler(tag: 3098, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,097+0000 INFO  GetFileHandler Handler(tag: 3098, GET) -> 215
-2013-08-27 01:14:03,097+0000 INFO  GetFileHandler Handler(tag: 215, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,097+0000 INFO  GetFileHandler Handler(tag: 215, GET) reader: LR-Handler(tag: 215, GET)
-2013-08-27 01:14:03,097+0000 INFO  GetFileHandler Handler(tag: 215, GET) sending length: 2093, 1019898453
-2013-08-27 01:14:03,097+0000 INFO  GetFileHandler Handler(tag: 3098, GET) sending length: 2093, 218829217
-2013-08-27 01:14:03,097+0000 INFO  ReadBuffer RB-LR-Handler(tag: 215, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,097+0000 INFO  ReadBuffer RB-LR-Handler(tag: 215, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,097+0000 INFO  LocalIOProvider LR-Handler(tag: 215, GET) rbuf: RB-LR-Handler(tag: 215, GET)
-2013-08-27 01:14:03,097+0000 INFO  GetFileHandler Handler(tag: 215, GET) unregistering (last)
-2013-08-27 01:14:03,097+0000 INFO  ReadBuffer RB-LR-Handler(tag: 215, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,097+0000 INFO  GetFileHandler Handler(tag: 3098, GET) unregistering (last)
-2013-08-27 01:14:03,097+0000 INFO  GetFileHandler Handler(tag: 3099, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,097+0000 INFO  GetFileHandler Handler(tag: 3099, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,097+0000 INFO  GetFileHandler Handler(tag: 3099, GET) -> 216
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 216, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 216, GET) reader: LR-Handler(tag: 216, GET)
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 216, GET) sending length: 2093, 872217871
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 3099, GET) sending length: 2093, 642383475
-2013-08-27 01:14:03,098+0000 INFO  ReadBuffer RB-LR-Handler(tag: 216, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 3100, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,098+0000 INFO  ReadBuffer RB-LR-Handler(tag: 216, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,098+0000 INFO  LocalIOProvider LR-Handler(tag: 216, GET) rbuf: RB-LR-Handler(tag: 216, GET)
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 216, GET) unregistering (last)
-2013-08-27 01:14:03,098+0000 INFO  ReadBuffer RB-LR-Handler(tag: 216, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 3099, GET) unregistering (last)
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 3100, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 3100, GET) -> 217
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 217, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 217, GET) reader: LR-Handler(tag: 217, GET)
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 217, GET) sending length: 2093, 719362507
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 3100, GET) sending length: 2093, 2140206186
-2013-08-27 01:14:03,098+0000 INFO  ReadBuffer RB-LR-Handler(tag: 217, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,098+0000 INFO  ReadBuffer RB-LR-Handler(tag: 217, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,098+0000 INFO  LocalIOProvider LR-Handler(tag: 217, GET) rbuf: RB-LR-Handler(tag: 217, GET)
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 3101, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 217, GET) unregistering (last)
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 3100, GET) unregistering (last)
-2013-08-27 01:14:03,098+0000 INFO  ReadBuffer RB-LR-Handler(tag: 217, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 3101, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 3101, GET) -> 218
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 218, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 218, GET) reader: LR-Handler(tag: 218, GET)
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 218, GET) sending length: 2093, 445936141
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 3101, GET) sending length: 2093, 130793757
-2013-08-27 01:14:03,098+0000 INFO  ReadBuffer RB-LR-Handler(tag: 218, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,098+0000 INFO  ReadBuffer RB-LR-Handler(tag: 218, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,098+0000 INFO  LocalIOProvider LR-Handler(tag: 218, GET) rbuf: RB-LR-Handler(tag: 218, GET)
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 3102, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 218, GET) unregistering (last)
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 3101, GET) unregistering (last)
-2013-08-27 01:14:03,098+0000 INFO  ReadBuffer RB-LR-Handler(tag: 218, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 3102, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 3102, GET) -> 219
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 219, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 219, GET) reader: LR-Handler(tag: 219, GET)
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 219, GET) sending length: 5032, 1261965694
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 3102, GET) sending length: 5032, 1308921286
-2013-08-27 01:14:03,098+0000 INFO  ReadBuffer RB-LR-Handler(tag: 219, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,098+0000 INFO  ReadBuffer RB-LR-Handler(tag: 219, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,098+0000 INFO  LocalIOProvider LR-Handler(tag: 219, GET) rbuf: RB-LR-Handler(tag: 219, GET)
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 3103, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,098+0000 INFO  GetFileHandler Handler(tag: 219, GET) unregistering (last)
-2013-08-27 01:14:03,099+0000 INFO  GetFileHandler Handler(tag: 3102, GET) unregistering (last)
-2013-08-27 01:14:03,099+0000 INFO  ReadBuffer RB-LR-Handler(tag: 219, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,099+0000 INFO  GetFileHandler Handler(tag: 3103, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,099+0000 INFO  GetFileHandler Handler(tag: 3103, GET) -> 220
-2013-08-27 01:14:03,099+0000 INFO  GetFileHandler Handler(tag: 220, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,099+0000 INFO  GetFileHandler Handler(tag: 220, GET) reader: LR-Handler(tag: 220, GET)
-2013-08-27 01:14:03,099+0000 INFO  GetFileHandler Handler(tag: 220, GET) sending length: 6078, 1142899061
-2013-08-27 01:14:03,099+0000 INFO  GetFileHandler Handler(tag: 3103, GET) sending length: 6078, 1610779459
-2013-08-27 01:14:03,099+0000 INFO  ReadBuffer RB-LR-Handler(tag: 220, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,099+0000 INFO  ReadBuffer RB-LR-Handler(tag: 220, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,099+0000 INFO  GetFileHandler Handler(tag: 3104, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,099+0000 INFO  LocalIOProvider LR-Handler(tag: 220, GET) rbuf: RB-LR-Handler(tag: 220, GET)
-2013-08-27 01:14:03,099+0000 INFO  GetFileHandler Handler(tag: 220, GET) unregistering (last)
-2013-08-27 01:14:03,099+0000 INFO  GetFileHandler Handler(tag: 3104, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,099+0000 INFO  ReadBuffer RB-LR-Handler(tag: 220, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,099+0000 INFO  GetFileHandler Handler(tag: 3103, GET) unregistering (last)
-2013-08-27 01:14:03,099+0000 INFO  GetFileHandler Handler(tag: 3104, GET) -> 221
-2013-08-27 01:14:03,099+0000 INFO  GetFileHandler Handler(tag: 221, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,099+0000 INFO  GetFileHandler Handler(tag: 221, GET) reader: LR-Handler(tag: 221, GET)
-2013-08-27 01:14:03,099+0000 INFO  GetFileHandler Handler(tag: 221, GET) sending length: 5032, 970015136
-2013-08-27 01:14:03,099+0000 INFO  GetFileHandler Handler(tag: 3104, GET) sending length: 5032, 1496026375
-2013-08-27 01:14:03,099+0000 INFO  ReadBuffer RB-LR-Handler(tag: 221, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,099+0000 INFO  ReadBuffer RB-LR-Handler(tag: 221, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,099+0000 INFO  LocalIOProvider LR-Handler(tag: 221, GET) rbuf: RB-LR-Handler(tag: 221, GET)
-2013-08-27 01:14:03,099+0000 INFO  GetFileHandler Handler(tag: 3105, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,099+0000 INFO  GetFileHandler Handler(tag: 221, GET) unregistering (last)
-2013-08-27 01:14:03,099+0000 INFO  GetFileHandler Handler(tag: 3104, GET) unregistering (last)
-2013-08-27 01:14:03,099+0000 INFO  ReadBuffer RB-LR-Handler(tag: 221, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,099+0000 INFO  GetFileHandler Handler(tag: 3105, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,099+0000 INFO  GetFileHandler Handler(tag: 3105, GET) -> 222
-2013-08-27 01:14:03,099+0000 INFO  GetFileHandler Handler(tag: 222, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,099+0000 INFO  GetFileHandler Handler(tag: 222, GET) reader: LR-Handler(tag: 222, GET)
-2013-08-27 01:14:03,099+0000 INFO  GetFileHandler Handler(tag: 222, GET) sending length: 5032, 1942381564
-2013-08-27 01:14:03,099+0000 INFO  GetFileHandler Handler(tag: 3105, GET) sending length: 5032, 1708028101
-2013-08-27 01:14:03,099+0000 INFO  ReadBuffer RB-LR-Handler(tag: 222, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,099+0000 INFO  ReadBuffer RB-LR-Handler(tag: 222, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,099+0000 INFO  LocalIOProvider LR-Handler(tag: 222, GET) rbuf: RB-LR-Handler(tag: 222, GET)
-2013-08-27 01:14:03,099+0000 INFO  GetFileHandler Handler(tag: 222, GET) unregistering (last)
-2013-08-27 01:14:03,099+0000 INFO  GetFileHandler Handler(tag: 3106, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,099+0000 INFO  GetFileHandler Handler(tag: 3105, GET) unregistering (last)
-2013-08-27 01:14:03,099+0000 INFO  ReadBuffer RB-LR-Handler(tag: 222, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,099+0000 INFO  GetFileHandler Handler(tag: 3106, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,099+0000 INFO  GetFileHandler Handler(tag: 3106, GET) -> 223
-2013-08-27 01:14:03,099+0000 INFO  GetFileHandler Handler(tag: 223, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,100+0000 INFO  GetFileHandler Handler(tag: 223, GET) reader: LR-Handler(tag: 223, GET)
-2013-08-27 01:14:03,100+0000 INFO  GetFileHandler Handler(tag: 223, GET) sending length: 5032, 1701072366
-2013-08-27 01:14:03,100+0000 INFO  GetFileHandler Handler(tag: 3106, GET) sending length: 5032, 473462851
-2013-08-27 01:14:03,100+0000 INFO  ReadBuffer RB-LR-Handler(tag: 223, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,100+0000 INFO  ReadBuffer RB-LR-Handler(tag: 223, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,100+0000 INFO  LocalIOProvider LR-Handler(tag: 223, GET) rbuf: RB-LR-Handler(tag: 223, GET)
-2013-08-27 01:14:03,100+0000 INFO  GetFileHandler Handler(tag: 223, GET) unregistering (last)
-2013-08-27 01:14:03,100+0000 INFO  GetFileHandler Handler(tag: 3107, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,100+0000 INFO  ReadBuffer RB-LR-Handler(tag: 223, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,100+0000 INFO  GetFileHandler Handler(tag: 3106, GET) unregistering (last)
-2013-08-27 01:14:03,100+0000 INFO  GetFileHandler Handler(tag: 3107, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,100+0000 INFO  GetFileHandler Handler(tag: 3107, GET) -> 224
-2013-08-27 01:14:03,100+0000 INFO  GetFileHandler Handler(tag: 224, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,100+0000 INFO  GetFileHandler Handler(tag: 224, GET) reader: LR-Handler(tag: 224, GET)
-2013-08-27 01:14:03,100+0000 INFO  GetFileHandler Handler(tag: 224, GET) sending length: 5032, 310439165
-2013-08-27 01:14:03,100+0000 INFO  GetFileHandler Handler(tag: 3107, GET) sending length: 5032, 1313267592
-2013-08-27 01:14:03,100+0000 INFO  ReadBuffer RB-LR-Handler(tag: 224, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,100+0000 INFO  ReadBuffer RB-LR-Handler(tag: 224, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,100+0000 INFO  GetFileHandler Handler(tag: 3108, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,100+0000 INFO  LocalIOProvider LR-Handler(tag: 224, GET) rbuf: RB-LR-Handler(tag: 224, GET)
-2013-08-27 01:14:03,100+0000 INFO  GetFileHandler Handler(tag: 224, GET) unregistering (last)
-2013-08-27 01:14:03,100+0000 INFO  GetFileHandler Handler(tag: 3107, GET) unregistering (last)
-2013-08-27 01:14:03,100+0000 INFO  GetFileHandler Handler(tag: 3108, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,100+0000 INFO  ReadBuffer RB-LR-Handler(tag: 224, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,100+0000 INFO  GetFileHandler Handler(tag: 3108, GET) -> 225
-2013-08-27 01:14:03,100+0000 INFO  GetFileHandler Handler(tag: 225, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,100+0000 INFO  GetFileHandler Handler(tag: 225, GET) reader: LR-Handler(tag: 225, GET)
-2013-08-27 01:14:03,100+0000 INFO  GetFileHandler Handler(tag: 225, GET) sending length: 5032, 690610498
-2013-08-27 01:14:03,100+0000 INFO  GetFileHandler Handler(tag: 3108, GET) sending length: 5032, 2089011498
-2013-08-27 01:14:03,100+0000 INFO  ReadBuffer RB-LR-Handler(tag: 225, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,100+0000 INFO  ReadBuffer RB-LR-Handler(tag: 225, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,100+0000 INFO  LocalIOProvider LR-Handler(tag: 225, GET) rbuf: RB-LR-Handler(tag: 225, GET)
-2013-08-27 01:14:03,100+0000 INFO  GetFileHandler Handler(tag: 225, GET) unregistering (last)
-2013-08-27 01:14:03,100+0000 INFO  ReadBuffer RB-LR-Handler(tag: 225, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,100+0000 INFO  GetFileHandler Handler(tag: 3108, GET) unregistering (last)
-2013-08-27 01:14:03,100+0000 INFO  GetFileHandler Handler(tag: 3109, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,100+0000 INFO  GetFileHandler Handler(tag: 3109, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,100+0000 INFO  GetFileHandler Handler(tag: 3109, GET) -> 226
-2013-08-27 01:14:03,100+0000 INFO  GetFileHandler Handler(tag: 226, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,100+0000 INFO  GetFileHandler Handler(tag: 226, GET) reader: LR-Handler(tag: 226, GET)
-2013-08-27 01:14:03,100+0000 INFO  GetFileHandler Handler(tag: 226, GET) sending length: 5032, 1528401192
-2013-08-27 01:14:03,100+0000 INFO  GetFileHandler Handler(tag: 3109, GET) sending length: 5032, 1786932177
-2013-08-27 01:14:03,100+0000 INFO  ReadBuffer RB-LR-Handler(tag: 226, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,100+0000 INFO  ReadBuffer RB-LR-Handler(tag: 226, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,100+0000 INFO  GetFileHandler Handler(tag: 3110, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,100+0000 INFO  LocalIOProvider LR-Handler(tag: 226, GET) rbuf: RB-LR-Handler(tag: 226, GET)
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 226, GET) unregistering (last)
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 3109, GET) unregistering (last)
-2013-08-27 01:14:03,101+0000 INFO  ReadBuffer RB-LR-Handler(tag: 226, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 3110, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 3110, GET) -> 227
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 227, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 227, GET) reader: LR-Handler(tag: 227, GET)
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 227, GET) sending length: 6078, 1544698800
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 3110, GET) sending length: 6078, 822923017
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 3111, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,101+0000 INFO  ReadBuffer RB-LR-Handler(tag: 227, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,101+0000 INFO  ReadBuffer RB-LR-Handler(tag: 227, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,101+0000 INFO  LocalIOProvider LR-Handler(tag: 227, GET) rbuf: RB-LR-Handler(tag: 227, GET)
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 3111, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 227, GET) unregistering (last)
-2013-08-27 01:14:03,101+0000 INFO  ReadBuffer RB-LR-Handler(tag: 227, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 3110, GET) unregistering (last)
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 3111, GET) -> 228
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 228, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 228, GET) reader: LR-Handler(tag: 228, GET)
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 228, GET) sending length: 5032, 794520776
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 3111, GET) sending length: 5032, 457365186
-2013-08-27 01:14:03,101+0000 INFO  ReadBuffer RB-LR-Handler(tag: 228, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 3112, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,101+0000 INFO  ReadBuffer RB-LR-Handler(tag: 228, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,101+0000 INFO  LocalIOProvider LR-Handler(tag: 228, GET) rbuf: RB-LR-Handler(tag: 228, GET)
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 228, GET) unregistering (last)
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 3111, GET) unregistering (last)
-2013-08-27 01:14:03,101+0000 INFO  ReadBuffer RB-LR-Handler(tag: 228, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 3112, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 3112, GET) -> 229
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 229, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 229, GET) reader: LR-Handler(tag: 229, GET)
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 229, GET) sending length: 6078, 1360909638
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 3112, GET) sending length: 6078, 2107445316
-2013-08-27 01:14:03,101+0000 INFO  ReadBuffer RB-LR-Handler(tag: 229, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,101+0000 INFO  ReadBuffer RB-LR-Handler(tag: 229, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 3113, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,101+0000 INFO  LocalIOProvider LR-Handler(tag: 229, GET) rbuf: RB-LR-Handler(tag: 229, GET)
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 229, GET) unregistering (last)
-2013-08-27 01:14:03,101+0000 INFO  ReadBuffer RB-LR-Handler(tag: 229, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 3113, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 3112, GET) unregistering (last)
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 3113, GET) -> 230
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 230, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,101+0000 INFO  GetFileHandler Handler(tag: 230, GET) reader: LR-Handler(tag: 230, GET)
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 230, GET) sending length: 5032, 5445987
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 3113, GET) sending length: 5032, 1336390335
-2013-08-27 01:14:03,102+0000 INFO  ReadBuffer RB-LR-Handler(tag: 230, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,102+0000 INFO  ReadBuffer RB-LR-Handler(tag: 230, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 3114, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,102+0000 INFO  LocalIOProvider LR-Handler(tag: 230, GET) rbuf: RB-LR-Handler(tag: 230, GET)
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 230, GET) unregistering (last)
-2013-08-27 01:14:03,102+0000 INFO  ReadBuffer RB-LR-Handler(tag: 230, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 3113, GET) unregistering (last)
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 3114, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 3114, GET) -> 231
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 231, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 231, GET) reader: LR-Handler(tag: 231, GET)
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 231, GET) sending length: 5032, 1894667608
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 3114, GET) sending length: 5032, 790969940
-2013-08-27 01:14:03,102+0000 INFO  ReadBuffer RB-LR-Handler(tag: 231, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,102+0000 INFO  ReadBuffer RB-LR-Handler(tag: 231, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,102+0000 INFO  LocalIOProvider LR-Handler(tag: 231, GET) rbuf: RB-LR-Handler(tag: 231, GET)
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 3115, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 231, GET) unregistering (last)
-2013-08-27 01:14:03,102+0000 INFO  ReadBuffer RB-LR-Handler(tag: 231, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 3114, GET) unregistering (last)
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 3115, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 3115, GET) -> 232
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 232, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 232, GET) reader: LR-Handler(tag: 232, GET)
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 232, GET) sending length: 5032, 1739180957
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 3115, GET) sending length: 5032, 1014424982
-2013-08-27 01:14:03,102+0000 INFO  ReadBuffer RB-LR-Handler(tag: 232, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,102+0000 INFO  ReadBuffer RB-LR-Handler(tag: 232, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,102+0000 INFO  LocalIOProvider LR-Handler(tag: 232, GET) rbuf: RB-LR-Handler(tag: 232, GET)
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 3116, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 232, GET) unregistering (last)
-2013-08-27 01:14:03,102+0000 INFO  ReadBuffer RB-LR-Handler(tag: 232, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 3115, GET) unregistering (last)
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 3116, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 3116, GET) -> 233
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 233, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 233, GET) reader: LR-Handler(tag: 233, GET)
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 233, GET) sending length: 5032, 476804695
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 3116, GET) sending length: 5032, 1395021908
-2013-08-27 01:14:03,102+0000 INFO  ReadBuffer RB-LR-Handler(tag: 233, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,102+0000 INFO  ReadBuffer RB-LR-Handler(tag: 233, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,102+0000 INFO  LocalIOProvider LR-Handler(tag: 233, GET) rbuf: RB-LR-Handler(tag: 233, GET)
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 3117, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 233, GET) unregistering (last)
-2013-08-27 01:14:03,102+0000 INFO  ReadBuffer RB-LR-Handler(tag: 233, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 3116, GET) unregistering (last)
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 3117, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,102+0000 INFO  GetFileHandler Handler(tag: 3117, GET) -> 234
-2013-08-27 01:14:03,103+0000 INFO  GetFileHandler Handler(tag: 234, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,103+0000 INFO  GetFileHandler Handler(tag: 234, GET) reader: LR-Handler(tag: 234, GET)
-2013-08-27 01:14:03,103+0000 INFO  GetFileHandler Handler(tag: 234, GET) sending length: 5032, 117281144
-2013-08-27 01:14:03,103+0000 INFO  GetFileHandler Handler(tag: 3117, GET) sending length: 5032, 1901682909
-2013-08-27 01:14:03,103+0000 INFO  ReadBuffer RB-LR-Handler(tag: 234, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,103+0000 INFO  ReadBuffer RB-LR-Handler(tag: 234, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,103+0000 INFO  LocalIOProvider LR-Handler(tag: 234, GET) rbuf: RB-LR-Handler(tag: 234, GET)
-2013-08-27 01:14:03,103+0000 INFO  GetFileHandler Handler(tag: 234, GET) unregistering (last)
-2013-08-27 01:14:03,103+0000 INFO  GetFileHandler Handler(tag: 3118, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,103+0000 INFO  GetFileHandler Handler(tag: 3117, GET) unregistering (last)
-2013-08-27 01:14:03,103+0000 INFO  ReadBuffer RB-LR-Handler(tag: 234, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,103+0000 INFO  GetFileHandler Handler(tag: 3118, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,103+0000 INFO  GetFileHandler Handler(tag: 3118, GET) -> 235
-2013-08-27 01:14:03,103+0000 INFO  GetFileHandler Handler(tag: 235, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,103+0000 INFO  GetFileHandler Handler(tag: 235, GET) reader: LR-Handler(tag: 235, GET)
-2013-08-27 01:14:03,103+0000 INFO  GetFileHandler Handler(tag: 235, GET) sending length: 6078, 1850846567
-2013-08-27 01:14:03,103+0000 INFO  GetFileHandler Handler(tag: 3118, GET) sending length: 6078, 877624774
-2013-08-27 01:14:03,103+0000 INFO  ReadBuffer RB-LR-Handler(tag: 235, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,103+0000 INFO  ReadBuffer RB-LR-Handler(tag: 235, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,103+0000 INFO  LocalIOProvider LR-Handler(tag: 235, GET) rbuf: RB-LR-Handler(tag: 235, GET)
-2013-08-27 01:14:03,103+0000 INFO  GetFileHandler Handler(tag: 235, GET) unregistering (last)
-2013-08-27 01:14:03,103+0000 INFO  GetFileHandler Handler(tag: 3118, GET) unregistering (last)
-2013-08-27 01:14:03,103+0000 INFO  ReadBuffer RB-LR-Handler(tag: 235, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,104+0000 DEBUG Cpu Active workerid=0827-1301520-000000:000000
-2013-08-27 01:14:03,104+0000 INFO  RequestHandler Handler(tag: 3119, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,104+0000 INFO  RequestHandler Handler(tag: 236, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,104+0000 INFO  GetFileHandler Handler(tag: 3120, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,104+0000 INFO  GetFileHandler Handler(tag: 3120, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,104+0000 INFO  GetFileHandler Handler(tag: 3120, GET) -> 237
-2013-08-27 01:14:03,104+0000 INFO  GetFileHandler Handler(tag: 237, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,104+0000 INFO  GetFileHandler Handler(tag: 237, GET) reader: LR-Handler(tag: 237, GET)
-2013-08-27 01:14:03,104+0000 INFO  GetFileHandler Handler(tag: 237, GET) sending length: 6078, 705361098
-2013-08-27 01:14:03,104+0000 INFO  GetFileHandler Handler(tag: 3120, GET) sending length: 6078, 894242646
-2013-08-27 01:14:03,104+0000 INFO  ReadBuffer RB-LR-Handler(tag: 237, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,104+0000 INFO  ReadBuffer RB-LR-Handler(tag: 237, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,104+0000 INFO  LocalIOProvider LR-Handler(tag: 237, GET) rbuf: RB-LR-Handler(tag: 237, GET)
-2013-08-27 01:14:03,104+0000 INFO  GetFileHandler Handler(tag: 3121, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,104+0000 INFO  GetFileHandler Handler(tag: 237, GET) unregistering (last)
-2013-08-27 01:14:03,104+0000 INFO  GetFileHandler Handler(tag: 3120, GET) unregistering (last)
-2013-08-27 01:14:03,104+0000 INFO  ReadBuffer RB-LR-Handler(tag: 237, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,104+0000 INFO  GetFileHandler Handler(tag: 3121, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,104+0000 INFO  GetFileHandler Handler(tag: 3121, GET) -> 238
-2013-08-27 01:14:03,104+0000 INFO  GetFileHandler Handler(tag: 238, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 238, GET) reader: LR-Handler(tag: 238, GET)
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 238, GET) sending length: 6078, 183756732
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 3122, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,105+0000 INFO  ReadBuffer RB-LR-Handler(tag: 238, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 3121, GET) sending length: 6078, 317910338
-2013-08-27 01:14:03,105+0000 INFO  ReadBuffer RB-LR-Handler(tag: 238, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,105+0000 INFO  LocalIOProvider LR-Handler(tag: 238, GET) rbuf: RB-LR-Handler(tag: 238, GET)
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 3122, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 238, GET) unregistering (last)
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 3122, GET) -> 239
-2013-08-27 01:14:03,105+0000 INFO  ReadBuffer RB-LR-Handler(tag: 238, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 3121, GET) unregistering (last)
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 239, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 239, GET) reader: LR-Handler(tag: 239, GET)
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 239, GET) sending length: 6078, 1118901176
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 3122, GET) sending length: 6078, 2005251900
-2013-08-27 01:14:03,105+0000 INFO  ReadBuffer RB-LR-Handler(tag: 239, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,105+0000 INFO  ReadBuffer RB-LR-Handler(tag: 239, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,105+0000 INFO  LocalIOProvider LR-Handler(tag: 239, GET) rbuf: RB-LR-Handler(tag: 239, GET)
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 239, GET) unregistering (last)
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 3123, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,105+0000 INFO  ReadBuffer RB-LR-Handler(tag: 239, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 3122, GET) unregistering (last)
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 3123, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 3123, GET) -> 240
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 240, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 240, GET) reader: LR-Handler(tag: 240, GET)
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 240, GET) sending length: 6078, 168584795
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 3124, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 3123, GET) sending length: 6078, 873719172
-2013-08-27 01:14:03,105+0000 INFO  ReadBuffer RB-LR-Handler(tag: 240, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,105+0000 INFO  ReadBuffer RB-LR-Handler(tag: 240, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 3124, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,105+0000 INFO  LocalIOProvider LR-Handler(tag: 240, GET) rbuf: RB-LR-Handler(tag: 240, GET)
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 240, GET) unregistering (last)
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 3124, GET) -> 241
-2013-08-27 01:14:03,105+0000 INFO  ReadBuffer RB-LR-Handler(tag: 240, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 3123, GET) unregistering (last)
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 241, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 241, GET) reader: LR-Handler(tag: 241, GET)
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 241, GET) sending length: 6078, 1160688957
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 3124, GET) sending length: 6078, 2105334598
-2013-08-27 01:14:03,105+0000 INFO  ReadBuffer RB-LR-Handler(tag: 241, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,105+0000 INFO  ReadBuffer RB-LR-Handler(tag: 241, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 3125, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,105+0000 INFO  LocalIOProvider LR-Handler(tag: 241, GET) rbuf: RB-LR-Handler(tag: 241, GET)
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 241, GET) unregistering (last)
-2013-08-27 01:14:03,105+0000 INFO  ReadBuffer RB-LR-Handler(tag: 241, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 3124, GET) unregistering (last)
-2013-08-27 01:14:03,105+0000 INFO  GetFileHandler Handler(tag: 3125, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,106+0000 INFO  GetFileHandler Handler(tag: 3125, GET) -> 242
-2013-08-27 01:14:03,106+0000 INFO  GetFileHandler Handler(tag: 242, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,106+0000 INFO  GetFileHandler Handler(tag: 242, GET) reader: LR-Handler(tag: 242, GET)
-2013-08-27 01:14:03,106+0000 INFO  GetFileHandler Handler(tag: 242, GET) sending length: 6078, 1298625981
-2013-08-27 01:14:03,106+0000 INFO  GetFileHandler Handler(tag: 3125, GET) sending length: 6078, 1130558206
-2013-08-27 01:14:03,106+0000 INFO  ReadBuffer RB-LR-Handler(tag: 242, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,106+0000 INFO  ReadBuffer RB-LR-Handler(tag: 242, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,106+0000 INFO  LocalIOProvider LR-Handler(tag: 242, GET) rbuf: RB-LR-Handler(tag: 242, GET)
-2013-08-27 01:14:03,106+0000 INFO  GetFileHandler Handler(tag: 242, GET) unregistering (last)
-2013-08-27 01:14:03,106+0000 INFO  ReadBuffer RB-LR-Handler(tag: 242, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,106+0000 INFO  GetFileHandler Handler(tag: 3125, GET) unregistering (last)
-2013-08-27 01:14:03,106+0000 DEBUG Cpu Active workerid=0827-1301520-000000:000000
-2013-08-27 01:14:03,106+0000 INFO  RequestHandler Handler(tag: 3126, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,106+0000 INFO  RequestHandler Handler(tag: 243, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,107+0000 INFO  GetFileHandler Handler(tag: 3127, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,107+0000 INFO  GetFileHandler Handler(tag: 3127, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,107+0000 INFO  GetFileHandler Handler(tag: 3127, GET) -> 244
-2013-08-27 01:14:03,107+0000 INFO  GetFileHandler Handler(tag: 244, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,107+0000 INFO  GetFileHandler Handler(tag: 244, GET) reader: LR-Handler(tag: 244, GET)
-2013-08-27 01:14:03,107+0000 INFO  GetFileHandler Handler(tag: 244, GET) sending length: 6078, 1894736744
-2013-08-27 01:14:03,107+0000 INFO  GetFileHandler Handler(tag: 3127, GET) sending length: 6078, 1952938692
-2013-08-27 01:14:03,107+0000 INFO  ReadBuffer RB-LR-Handler(tag: 244, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,107+0000 INFO  ReadBuffer RB-LR-Handler(tag: 244, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,107+0000 INFO  LocalIOProvider LR-Handler(tag: 244, GET) rbuf: RB-LR-Handler(tag: 244, GET)
-2013-08-27 01:14:03,107+0000 INFO  GetFileHandler Handler(tag: 244, GET) unregistering (last)
-2013-08-27 01:14:03,107+0000 INFO  ReadBuffer RB-LR-Handler(tag: 244, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,107+0000 INFO  GetFileHandler Handler(tag: 3127, GET) unregistering (last)
-2013-08-27 01:14:03,107+0000 DEBUG Cpu Active workerid=0827-1301520-000000:000000
-2013-08-27 01:14:03,107+0000 INFO  RequestHandler Handler(tag: 3128, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,108+0000 INFO  RequestHandler Handler(tag: 245, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,108+0000 INFO  GetFileHandler Handler(tag: 3129, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,108+0000 INFO  GetFileHandler Handler(tag: 3129, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,108+0000 INFO  GetFileHandler Handler(tag: 3129, GET) -> 246
-2013-08-27 01:14:03,108+0000 INFO  GetFileHandler Handler(tag: 246, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,108+0000 INFO  GetFileHandler Handler(tag: 246, GET) reader: LR-Handler(tag: 246, GET)
-2013-08-27 01:14:03,108+0000 INFO  GetFileHandler Handler(tag: 246, GET) sending length: 6078, 2037886922
-2013-08-27 01:14:03,108+0000 INFO  GetFileHandler Handler(tag: 3130, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,108+0000 INFO  GetFileHandler Handler(tag: 3129, GET) sending length: 6078, 548812051
-2013-08-27 01:14:03,108+0000 INFO  ReadBuffer RB-LR-Handler(tag: 246, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,108+0000 INFO  ReadBuffer RB-LR-Handler(tag: 246, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,108+0000 INFO  GetFileHandler Handler(tag: 3130, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,108+0000 INFO  LocalIOProvider LR-Handler(tag: 246, GET) rbuf: RB-LR-Handler(tag: 246, GET)
-2013-08-27 01:14:03,108+0000 INFO  GetFileHandler Handler(tag: 246, GET) unregistering (last)
-2013-08-27 01:14:03,108+0000 INFO  GetFileHandler Handler(tag: 3130, GET) -> 247
-2013-08-27 01:14:03,108+0000 INFO  ReadBuffer RB-LR-Handler(tag: 246, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,108+0000 INFO  GetFileHandler Handler(tag: 3129, GET) unregistering (last)
-2013-08-27 01:14:03,108+0000 INFO  GetFileHandler Handler(tag: 247, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,108+0000 INFO  GetFileHandler Handler(tag: 247, GET) reader: LR-Handler(tag: 247, GET)
-2013-08-27 01:14:03,108+0000 INFO  GetFileHandler Handler(tag: 247, GET) sending length: 6078, 579340670
-2013-08-27 01:14:03,108+0000 INFO  GetFileHandler Handler(tag: 3130, GET) sending length: 6078, 287785192
-2013-08-27 01:14:03,108+0000 INFO  ReadBuffer RB-LR-Handler(tag: 247, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,108+0000 INFO  ReadBuffer RB-LR-Handler(tag: 247, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,108+0000 INFO  LocalIOProvider LR-Handler(tag: 247, GET) rbuf: RB-LR-Handler(tag: 247, GET)
-2013-08-27 01:14:03,108+0000 INFO  GetFileHandler Handler(tag: 3131, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,108+0000 INFO  GetFileHandler Handler(tag: 247, GET) unregistering (last)
-2013-08-27 01:14:03,108+0000 INFO  ReadBuffer RB-LR-Handler(tag: 247, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,108+0000 INFO  GetFileHandler Handler(tag: 3130, GET) unregistering (last)
-2013-08-27 01:14:03,108+0000 INFO  GetFileHandler Handler(tag: 3131, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,108+0000 INFO  GetFileHandler Handler(tag: 3131, GET) -> 248
-2013-08-27 01:14:03,108+0000 INFO  GetFileHandler Handler(tag: 248, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,109+0000 INFO  GetFileHandler Handler(tag: 248, GET) reader: LR-Handler(tag: 248, GET)
-2013-08-27 01:14:03,109+0000 INFO  GetFileHandler Handler(tag: 248, GET) sending length: 6078, 1524650473
-2013-08-27 01:14:03,109+0000 INFO  GetFileHandler Handler(tag: 3132, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,109+0000 INFO  GetFileHandler Handler(tag: 3131, GET) sending length: 6078, 1025623707
-2013-08-27 01:14:03,109+0000 INFO  ReadBuffer RB-LR-Handler(tag: 248, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,109+0000 INFO  ReadBuffer RB-LR-Handler(tag: 248, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,109+0000 INFO  GetFileHandler Handler(tag: 3132, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,109+0000 INFO  LocalIOProvider LR-Handler(tag: 248, GET) rbuf: RB-LR-Handler(tag: 248, GET)
-2013-08-27 01:14:03,109+0000 INFO  GetFileHandler Handler(tag: 248, GET) unregistering (last)
-2013-08-27 01:14:03,109+0000 INFO  GetFileHandler Handler(tag: 3132, GET) -> 249
-2013-08-27 01:14:03,109+0000 INFO  ReadBuffer RB-LR-Handler(tag: 248, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,109+0000 INFO  GetFileHandler Handler(tag: 3131, GET) unregistering (last)
-2013-08-27 01:14:03,109+0000 INFO  GetFileHandler Handler(tag: 249, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,109+0000 INFO  GetFileHandler Handler(tag: 249, GET) reader: LR-Handler(tag: 249, GET)
-2013-08-27 01:14:03,109+0000 INFO  GetFileHandler Handler(tag: 249, GET) sending length: 6078, 6051787
-2013-08-27 01:14:03,109+0000 INFO  GetFileHandler Handler(tag: 3132, GET) sending length: 6078, 780652700
-2013-08-27 01:14:03,109+0000 INFO  ReadBuffer RB-LR-Handler(tag: 249, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,109+0000 INFO  ReadBuffer RB-LR-Handler(tag: 249, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,109+0000 INFO  LocalIOProvider LR-Handler(tag: 249, GET) rbuf: RB-LR-Handler(tag: 249, GET)
-2013-08-27 01:14:03,109+0000 INFO  GetFileHandler Handler(tag: 249, GET) unregistering (last)
-2013-08-27 01:14:03,109+0000 INFO  GetFileHandler Handler(tag: 3133, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,109+0000 INFO  ReadBuffer RB-LR-Handler(tag: 249, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,109+0000 INFO  GetFileHandler Handler(tag: 3132, GET) unregistering (last)
-2013-08-27 01:14:03,109+0000 INFO  GetFileHandler Handler(tag: 3133, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,109+0000 INFO  GetFileHandler Handler(tag: 3133, GET) -> 250
-2013-08-27 01:14:03,109+0000 INFO  GetFileHandler Handler(tag: 250, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,109+0000 INFO  GetFileHandler Handler(tag: 250, GET) reader: LR-Handler(tag: 250, GET)
-2013-08-27 01:14:03,109+0000 INFO  GetFileHandler Handler(tag: 250, GET) sending length: 6078, 767405246
-2013-08-27 01:14:03,109+0000 INFO  GetFileHandler Handler(tag: 3133, GET) sending length: 6078, 2140669287
-2013-08-27 01:14:03,109+0000 INFO  ReadBuffer RB-LR-Handler(tag: 250, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,109+0000 INFO  ReadBuffer RB-LR-Handler(tag: 250, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,109+0000 INFO  LocalIOProvider LR-Handler(tag: 250, GET) rbuf: RB-LR-Handler(tag: 250, GET)
-2013-08-27 01:14:03,109+0000 INFO  GetFileHandler Handler(tag: 250, GET) unregistering (last)
-2013-08-27 01:14:03,109+0000 INFO  ReadBuffer RB-LR-Handler(tag: 250, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,109+0000 INFO  GetFileHandler Handler(tag: 3133, GET) unregistering (last)
-2013-08-27 01:14:03,110+0000 DEBUG Cpu Active workerid=0827-1301520-000000:000000
-2013-08-27 01:14:03,110+0000 INFO  RequestHandler Handler(tag: 3134, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,110+0000 INFO  RequestHandler Handler(tag: 251, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,111+0000 DEBUG Cpu Active workerid=0827-1301520-000000:000000
-2013-08-27 01:14:03,111+0000 INFO  RequestHandler Handler(tag: 3135, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,111+0000 INFO  RequestHandler Handler(tag: 252, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,111+0000 INFO  RequestHandler Handler(tag: 3136, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,111+0000 INFO  RequestHandler Handler(tag: 253, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,112+0000 DEBUG Cpu Active workerid=0827-1301520-000000:000000
-2013-08-27 01:14:03,112+0000 INFO  RequestHandler Handler(tag: 3137, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,112+0000 INFO  RequestHandler Handler(tag: 254, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,113+0000 DEBUG Cpu Active workerid=0827-1301520-000000:000000
-2013-08-27 01:14:03,113+0000 INFO  RequestHandler Handler(tag: 3138, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,113+0000 INFO  RequestHandler Handler(tag: 255, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,114+0000 DEBUG Cpu Active workerid=0827-1301520-000000:000000
-2013-08-27 01:14:03,114+0000 INFO  RequestHandler Handler(tag: 3139, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,114+0000 INFO  RequestHandler Handler(tag: 256, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,115+0000 DEBUG Cpu Active workerid=0827-1301520-000000:000000
-2013-08-27 01:14:03,115+0000 INFO  RequestHandler Handler(tag: 3140, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,115+0000 INFO  RequestHandler Handler(tag: 257, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,116+0000 DEBUG Cpu Active workerid=0827-1301520-000000:000000
-2013-08-27 01:14:03,116+0000 INFO  RequestHandler Handler(tag: 3141, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,116+0000 INFO  RequestHandler Handler(tag: 258, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,116+0000 INFO  RequestHandler Handler(tag: 3142, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,116+0000 INFO  RequestHandler Handler(tag: 259, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,117+0000 DEBUG Cpu Active workerid=0827-1301520-000000:000000
-2013-08-27 01:14:03,117+0000 INFO  RequestHandler Handler(tag: 3143, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,117+0000 INFO  RequestHandler Handler(tag: 260, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,118+0000 DEBUG Cpu Active workerid=0827-1301520-000000:000000
-2013-08-27 01:14:03,118+0000 INFO  RequestHandler Handler(tag: 3144, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,118+0000 INFO  RequestHandler Handler(tag: 261, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,119+0000 DEBUG Cpu Active workerid=0827-1301520-000000:000000
-2013-08-27 01:14:03,119+0000 INFO  RequestHandler Handler(tag: 3145, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,119+0000 INFO  RequestHandler Handler(tag: 262, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,120+0000 DEBUG Cpu Active workerid=0827-1301520-000000:000000
-2013-08-27 01:14:03,120+0000 INFO  RequestHandler Handler(tag: 3146, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,120+0000 INFO  RequestHandler Handler(tag: 263, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,294+0000 INFO  GetFileHandler Handler(tag: 2586, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,295+0000 INFO  GetFileHandler Handler(tag: 2586, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,295+0000 INFO  GetFileHandler Handler(tag: 2586, GET) -> 264
-2013-08-27 01:14:03,295+0000 INFO  GetFileHandler Handler(tag: 264, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,295+0000 INFO  GetFileHandler Handler(tag: 264, GET) reader: LR-Handler(tag: 264, GET)
-2013-08-27 01:14:03,295+0000 INFO  GetFileHandler Handler(tag: 264, GET) sending length: 148937, 1691809533
-2013-08-27 01:14:03,295+0000 INFO  ReadBuffer RB-LR-Handler(tag: 264, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:03,295+0000 INFO  GetFileHandler Handler(tag: 2586, GET) sending length: 148937, 1997896416
-2013-08-27 01:14:03,295+0000 INFO  ReadBuffer RB-LR-Handler(tag: 264, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:03,295+0000 INFO  LocalIOProvider LR-Handler(tag: 264, GET) rbuf: RB-LR-Handler(tag: 264, GET)
-2013-08-27 01:14:03,295+0000 INFO  GetFileHandler Handler(tag: 264, GET) unregistering (last)
-2013-08-27 01:14:03,295+0000 INFO  GetFileHandler Handler(tag: 2586, GET) unregistering (last)
-2013-08-27 01:14:03,295+0000 INFO  ReadBuffer RB-LR-Handler(tag: 264, GET) de-allocating 5 buffers
-2013-08-27 01:14:03,295+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:03,341+0000 INFO  GetFileHandler Handler(tag: 2587, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,341+0000 INFO  GetFileHandler Handler(tag: 2587, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,341+0000 INFO  GetFileHandler Handler(tag: 2587, GET) -> 265
-2013-08-27 01:14:03,341+0000 INFO  GetFileHandler Handler(tag: 265, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,341+0000 INFO  GetFileHandler Handler(tag: 265, GET) reader: LR-Handler(tag: 265, GET)
-2013-08-27 01:14:03,341+0000 INFO  GetFileHandler Handler(tag: 265, GET) sending length: 148937, 1073310459
-2013-08-27 01:14:03,341+0000 INFO  GetFileHandler Handler(tag: 2587, GET) sending length: 148937, 266249613
-2013-08-27 01:14:03,341+0000 INFO  ReadBuffer RB-LR-Handler(tag: 265, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:03,341+0000 INFO  ReadBuffer RB-LR-Handler(tag: 265, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:03,341+0000 INFO  LocalIOProvider LR-Handler(tag: 265, GET) rbuf: RB-LR-Handler(tag: 265, GET)
-2013-08-27 01:14:03,341+0000 INFO  GetFileHandler Handler(tag: 265, GET) unregistering (last)
-2013-08-27 01:14:03,341+0000 INFO  ReadBuffer RB-LR-Handler(tag: 265, GET) de-allocating 5 buffers
-2013-08-27 01:14:03,341+0000 INFO  GetFileHandler Handler(tag: 2587, GET) unregistering (last)
-2013-08-27 01:14:03,341+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:03,380+0000 INFO  GetFileHandler Handler(tag: 2588, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,380+0000 INFO  GetFileHandler Handler(tag: 2588, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,380+0000 INFO  GetFileHandler Handler(tag: 2588, GET) -> 266
-2013-08-27 01:14:03,381+0000 INFO  GetFileHandler Handler(tag: 266, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,381+0000 INFO  GetFileHandler Handler(tag: 266, GET) reader: LR-Handler(tag: 266, GET)
-2013-08-27 01:14:03,381+0000 INFO  GetFileHandler Handler(tag: 266, GET) sending length: 148937, 1321063021
-2013-08-27 01:14:03,381+0000 INFO  GetFileHandler Handler(tag: 2588, GET) sending length: 148937, 272767614
-2013-08-27 01:14:03,381+0000 INFO  ReadBuffer RB-LR-Handler(tag: 266, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:03,381+0000 INFO  ReadBuffer RB-LR-Handler(tag: 266, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:03,381+0000 INFO  LocalIOProvider LR-Handler(tag: 266, GET) rbuf: RB-LR-Handler(tag: 266, GET)
-2013-08-27 01:14:03,381+0000 INFO  ThrottleManager I maxBuffers=1024, crtBuffers=5, allowedTransfers=252, active=0, suspended=0
-2013-08-27 01:14:03,381+0000 INFO  ThrottleManager O maxBuffers=1024, crtBuffers=1, allowedTransfers=255, active=0, suspended=0
-2013-08-27 01:14:03,381+0000 INFO  GetFileHandler Handler(tag: 266, GET) unregistering (last)
-2013-08-27 01:14:03,381+0000 INFO  ReadBuffer RB-LR-Handler(tag: 266, GET) de-allocating 5 buffers
-2013-08-27 01:14:03,381+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:03,381+0000 INFO  ThrottleManager mem=223.81 MB, heap=399.94 MB, maxHeap=910.25 MB
-2013-08-27 01:14:03,381+0000 INFO  GetFileHandler Handler(tag: 2588, GET) unregistering (last)
-2013-08-27 01:14:03,399+0000 INFO  GetFileHandler Handler(tag: 2589, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,399+0000 INFO  GetFileHandler Handler(tag: 2589, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,399+0000 INFO  GetFileHandler Handler(tag: 2589, GET) -> 267
-2013-08-27 01:14:03,400+0000 INFO  GetFileHandler Handler(tag: 267, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,400+0000 INFO  GetFileHandler Handler(tag: 267, GET) reader: LR-Handler(tag: 267, GET)
-2013-08-27 01:14:03,400+0000 INFO  GetFileHandler Handler(tag: 267, GET) sending length: 148937, 357102764
-2013-08-27 01:14:03,400+0000 INFO  GetFileHandler Handler(tag: 2589, GET) sending length: 148937, 1756844830
-2013-08-27 01:14:03,400+0000 INFO  ReadBuffer RB-LR-Handler(tag: 267, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:03,400+0000 INFO  ReadBuffer RB-LR-Handler(tag: 267, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:03,400+0000 INFO  LocalIOProvider LR-Handler(tag: 267, GET) rbuf: RB-LR-Handler(tag: 267, GET)
-2013-08-27 01:14:03,400+0000 INFO  GetFileHandler Handler(tag: 267, GET) unregistering (last)
-2013-08-27 01:14:03,400+0000 INFO  GetFileHandler Handler(tag: 2589, GET) unregistering (last)
-2013-08-27 01:14:03,400+0000 INFO  ReadBuffer RB-LR-Handler(tag: 267, GET) de-allocating 5 buffers
-2013-08-27 01:14:03,400+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:03,414+0000 INFO  GetFileHandler Handler(tag: 2590, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,414+0000 INFO  GetFileHandler Handler(tag: 2590, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,414+0000 INFO  GetFileHandler Handler(tag: 2590, GET) -> 268
-2013-08-27 01:14:03,414+0000 INFO  GetFileHandler Handler(tag: 268, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,414+0000 INFO  GetFileHandler Handler(tag: 268, GET) reader: LR-Handler(tag: 268, GET)
-2013-08-27 01:14:03,414+0000 INFO  GetFileHandler Handler(tag: 268, GET) sending length: 148937, 1376434098
-2013-08-27 01:14:03,414+0000 INFO  GetFileHandler Handler(tag: 2590, GET) sending length: 148937, 1034039602
-2013-08-27 01:14:03,414+0000 INFO  ReadBuffer RB-LR-Handler(tag: 268, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:03,414+0000 INFO  ReadBuffer RB-LR-Handler(tag: 268, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:03,414+0000 INFO  LocalIOProvider LR-Handler(tag: 268, GET) rbuf: RB-LR-Handler(tag: 268, GET)
-2013-08-27 01:14:03,415+0000 INFO  GetFileHandler Handler(tag: 268, GET) unregistering (last)
-2013-08-27 01:14:03,415+0000 INFO  GetFileHandler Handler(tag: 2590, GET) unregistering (last)
-2013-08-27 01:14:03,415+0000 INFO  ReadBuffer RB-LR-Handler(tag: 268, GET) de-allocating 5 buffers
-2013-08-27 01:14:03,415+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:03,422+0000 INFO  GetFileHandler Handler(tag: 2591, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,422+0000 INFO  GetFileHandler Handler(tag: 2591, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,422+0000 INFO  GetFileHandler Handler(tag: 2591, GET) -> 269
-2013-08-27 01:14:03,422+0000 INFO  GetFileHandler Handler(tag: 269, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,422+0000 INFO  GetFileHandler Handler(tag: 269, GET) reader: LR-Handler(tag: 269, GET)
-2013-08-27 01:14:03,422+0000 INFO  GetFileHandler Handler(tag: 269, GET) sending length: 148937, 284152826
-2013-08-27 01:14:03,422+0000 INFO  GetFileHandler Handler(tag: 2591, GET) sending length: 148937, 1900399301
-2013-08-27 01:14:03,422+0000 INFO  ReadBuffer RB-LR-Handler(tag: 269, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:03,422+0000 INFO  ReadBuffer RB-LR-Handler(tag: 269, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:03,422+0000 INFO  LocalIOProvider LR-Handler(tag: 269, GET) rbuf: RB-LR-Handler(tag: 269, GET)
-2013-08-27 01:14:03,422+0000 INFO  GetFileHandler Handler(tag: 269, GET) unregistering (last)
-2013-08-27 01:14:03,422+0000 INFO  GetFileHandler Handler(tag: 2591, GET) unregistering (last)
-2013-08-27 01:14:03,422+0000 INFO  ReadBuffer RB-LR-Handler(tag: 269, GET) de-allocating 5 buffers
-2013-08-27 01:14:03,422+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:03,428+0000 INFO  GetFileHandler Handler(tag: 2592, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,428+0000 INFO  GetFileHandler Handler(tag: 2592, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,428+0000 INFO  GetFileHandler Handler(tag: 2592, GET) -> 270
-2013-08-27 01:14:03,428+0000 INFO  GetFileHandler Handler(tag: 270, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,428+0000 INFO  GetFileHandler Handler(tag: 270, GET) reader: LR-Handler(tag: 270, GET)
-2013-08-27 01:14:03,428+0000 INFO  GetFileHandler Handler(tag: 270, GET) sending length: 148937, 1232199135
-2013-08-27 01:14:03,428+0000 INFO  GetFileHandler Handler(tag: 2592, GET) sending length: 148937, 1386053924
-2013-08-27 01:14:03,428+0000 INFO  ReadBuffer RB-LR-Handler(tag: 270, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:03,428+0000 INFO  ReadBuffer RB-LR-Handler(tag: 270, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:03,428+0000 INFO  LocalIOProvider LR-Handler(tag: 270, GET) rbuf: RB-LR-Handler(tag: 270, GET)
-2013-08-27 01:14:03,428+0000 INFO  GetFileHandler Handler(tag: 270, GET) unregistering (last)
-2013-08-27 01:14:03,428+0000 INFO  ReadBuffer RB-LR-Handler(tag: 270, GET) de-allocating 5 buffers
-2013-08-27 01:14:03,428+0000 INFO  GetFileHandler Handler(tag: 2592, GET) unregistering (last)
-2013-08-27 01:14:03,428+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:03,435+0000 INFO  GetFileHandler Handler(tag: 2593, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,435+0000 INFO  GetFileHandler Handler(tag: 2593, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,436+0000 INFO  GetFileHandler Handler(tag: 2593, GET) -> 271
-2013-08-27 01:14:03,436+0000 INFO  GetFileHandler Handler(tag: 271, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,436+0000 INFO  GetFileHandler Handler(tag: 271, GET) reader: LR-Handler(tag: 271, GET)
-2013-08-27 01:14:03,436+0000 INFO  GetFileHandler Handler(tag: 271, GET) sending length: 148937, 2134119327
-2013-08-27 01:14:03,436+0000 INFO  GetFileHandler Handler(tag: 2593, GET) sending length: 148937, 871656695
-2013-08-27 01:14:03,436+0000 INFO  ReadBuffer RB-LR-Handler(tag: 271, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:03,436+0000 INFO  ReadBuffer RB-LR-Handler(tag: 271, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:03,436+0000 INFO  LocalIOProvider LR-Handler(tag: 271, GET) rbuf: RB-LR-Handler(tag: 271, GET)
-2013-08-27 01:14:03,436+0000 INFO  GetFileHandler Handler(tag: 271, GET) unregistering (last)
-2013-08-27 01:14:03,436+0000 INFO  GetFileHandler Handler(tag: 2593, GET) unregistering (last)
-2013-08-27 01:14:03,436+0000 INFO  ReadBuffer RB-LR-Handler(tag: 271, GET) de-allocating 5 buffers
-2013-08-27 01:14:03,436+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:03,439+0000 INFO  GetFileHandler Handler(tag: 2594, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,439+0000 INFO  GetFileHandler Handler(tag: 2594, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,439+0000 INFO  GetFileHandler Handler(tag: 2594, GET) -> 272
-2013-08-27 01:14:03,439+0000 INFO  GetFileHandler Handler(tag: 272, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,439+0000 INFO  GetFileHandler Handler(tag: 272, GET) reader: LR-Handler(tag: 272, GET)
-2013-08-27 01:14:03,439+0000 INFO  GetFileHandler Handler(tag: 272, GET) sending length: 148937, 788065887
-2013-08-27 01:14:03,439+0000 INFO  GetFileHandler Handler(tag: 2594, GET) sending length: 148937, 1491711760
-2013-08-27 01:14:03,439+0000 INFO  ReadBuffer RB-LR-Handler(tag: 272, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:03,439+0000 INFO  ReadBuffer RB-LR-Handler(tag: 272, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:03,439+0000 INFO  LocalIOProvider LR-Handler(tag: 272, GET) rbuf: RB-LR-Handler(tag: 272, GET)
-2013-08-27 01:14:03,439+0000 INFO  GetFileHandler Handler(tag: 272, GET) unregistering (last)
-2013-08-27 01:14:03,439+0000 INFO  GetFileHandler Handler(tag: 2594, GET) unregistering (last)
-2013-08-27 01:14:03,439+0000 INFO  ReadBuffer RB-LR-Handler(tag: 272, GET) de-allocating 5 buffers
-2013-08-27 01:14:03,439+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:03,440+0000 INFO  GetFileHandler Handler(tag: 2595, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,440+0000 INFO  GetFileHandler Handler(tag: 2595, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,440+0000 INFO  GetFileHandler Handler(tag: 2595, GET) -> 273
-2013-08-27 01:14:03,440+0000 INFO  GetFileHandler Handler(tag: 273, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,440+0000 INFO  GetFileHandler Handler(tag: 273, GET) reader: LR-Handler(tag: 273, GET)
-2013-08-27 01:14:03,440+0000 INFO  GetFileHandler Handler(tag: 273, GET) sending length: 148937, 838473809
-2013-08-27 01:14:03,440+0000 INFO  GetFileHandler Handler(tag: 2595, GET) sending length: 148937, 441616249
-2013-08-27 01:14:03,440+0000 INFO  ReadBuffer RB-LR-Handler(tag: 273, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:03,440+0000 INFO  ReadBuffer RB-LR-Handler(tag: 273, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:03,440+0000 INFO  LocalIOProvider LR-Handler(tag: 273, GET) rbuf: RB-LR-Handler(tag: 273, GET)
-2013-08-27 01:14:03,440+0000 INFO  GetFileHandler Handler(tag: 273, GET) unregistering (last)
-2013-08-27 01:14:03,440+0000 INFO  GetFileHandler Handler(tag: 2595, GET) unregistering (last)
-2013-08-27 01:14:03,440+0000 INFO  ReadBuffer RB-LR-Handler(tag: 273, GET) de-allocating 5 buffers
-2013-08-27 01:14:03,440+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:03,441+0000 INFO  GetFileHandler Handler(tag: 2596, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,441+0000 INFO  GetFileHandler Handler(tag: 2596, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,441+0000 INFO  GetFileHandler Handler(tag: 2596, GET) -> 274
-2013-08-27 01:14:03,441+0000 INFO  GetFileHandler Handler(tag: 274, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,441+0000 INFO  GetFileHandler Handler(tag: 274, GET) reader: LR-Handler(tag: 274, GET)
-2013-08-27 01:14:03,441+0000 INFO  GetFileHandler Handler(tag: 274, GET) sending length: 148937, 2096061374
-2013-08-27 01:14:03,441+0000 INFO  GetFileHandler Handler(tag: 2596, GET) sending length: 148937, 1181767430
-2013-08-27 01:14:03,441+0000 INFO  ReadBuffer RB-LR-Handler(tag: 274, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:03,441+0000 INFO  ReadBuffer RB-LR-Handler(tag: 274, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:03,441+0000 INFO  LocalIOProvider LR-Handler(tag: 274, GET) rbuf: RB-LR-Handler(tag: 274, GET)
-2013-08-27 01:14:03,441+0000 INFO  GetFileHandler Handler(tag: 274, GET) unregistering (last)
-2013-08-27 01:14:03,441+0000 INFO  GetFileHandler Handler(tag: 2596, GET) unregistering (last)
-2013-08-27 01:14:03,441+0000 INFO  ReadBuffer RB-LR-Handler(tag: 274, GET) de-allocating 5 buffers
-2013-08-27 01:14:03,441+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:03,442+0000 INFO  GetFileHandler Handler(tag: 2597, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,442+0000 INFO  GetFileHandler Handler(tag: 2597, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,442+0000 INFO  GetFileHandler Handler(tag: 2597, GET) -> 275
-2013-08-27 01:14:03,442+0000 INFO  GetFileHandler Handler(tag: 275, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,442+0000 INFO  GetFileHandler Handler(tag: 275, GET) reader: LR-Handler(tag: 275, GET)
-2013-08-27 01:14:03,442+0000 INFO  GetFileHandler Handler(tag: 275, GET) sending length: 148937, 2028897604
-2013-08-27 01:14:03,442+0000 INFO  GetFileHandler Handler(tag: 2597, GET) sending length: 148937, 1936683362
-2013-08-27 01:14:03,442+0000 INFO  ReadBuffer RB-LR-Handler(tag: 275, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:03,442+0000 INFO  ReadBuffer RB-LR-Handler(tag: 275, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:03,442+0000 INFO  LocalIOProvider LR-Handler(tag: 275, GET) rbuf: RB-LR-Handler(tag: 275, GET)
-2013-08-27 01:14:03,442+0000 INFO  GetFileHandler Handler(tag: 275, GET) unregistering (last)
-2013-08-27 01:14:03,442+0000 INFO  GetFileHandler Handler(tag: 2597, GET) unregistering (last)
-2013-08-27 01:14:03,442+0000 INFO  ReadBuffer RB-LR-Handler(tag: 275, GET) de-allocating 5 buffers
-2013-08-27 01:14:03,443+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:03,443+0000 INFO  GetFileHandler Handler(tag: 2598, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,443+0000 INFO  GetFileHandler Handler(tag: 2598, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,443+0000 INFO  GetFileHandler Handler(tag: 2598, GET) -> 276
-2013-08-27 01:14:03,443+0000 INFO  GetFileHandler Handler(tag: 276, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,443+0000 INFO  GetFileHandler Handler(tag: 276, GET) reader: LR-Handler(tag: 276, GET)
-2013-08-27 01:14:03,443+0000 INFO  GetFileHandler Handler(tag: 276, GET) sending length: 148937, 1105636392
-2013-08-27 01:14:03,443+0000 INFO  GetFileHandler Handler(tag: 2598, GET) sending length: 148937, 254842853
-2013-08-27 01:14:03,443+0000 INFO  ReadBuffer RB-LR-Handler(tag: 276, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:03,443+0000 INFO  ReadBuffer RB-LR-Handler(tag: 276, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:03,443+0000 INFO  LocalIOProvider LR-Handler(tag: 276, GET) rbuf: RB-LR-Handler(tag: 276, GET)
-2013-08-27 01:14:03,443+0000 INFO  GetFileHandler Handler(tag: 276, GET) unregistering (last)
-2013-08-27 01:14:03,443+0000 INFO  GetFileHandler Handler(tag: 2598, GET) unregistering (last)
-2013-08-27 01:14:03,443+0000 INFO  ReadBuffer RB-LR-Handler(tag: 276, GET) de-allocating 5 buffers
-2013-08-27 01:14:03,444+0000 INFO  GetFileHandler Handler(tag: 2599, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,444+0000 INFO  GetFileHandler Handler(tag: 2599, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,444+0000 INFO  GetFileHandler Handler(tag: 2599, GET) -> 277
-2013-08-27 01:14:03,444+0000 INFO  GetFileHandler Handler(tag: 277, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,444+0000 INFO  GetFileHandler Handler(tag: 277, GET) reader: LR-Handler(tag: 277, GET)
-2013-08-27 01:14:03,444+0000 INFO  GetFileHandler Handler(tag: 277, GET) sending length: 148937, 1647217756
-2013-08-27 01:14:03,444+0000 INFO  GetFileHandler Handler(tag: 2599, GET) sending length: 148937, 1577131615
-2013-08-27 01:14:03,444+0000 INFO  ReadBuffer RB-LR-Handler(tag: 277, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:03,444+0000 INFO  ReadBuffer RB-LR-Handler(tag: 277, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:03,444+0000 INFO  LocalIOProvider LR-Handler(tag: 277, GET) rbuf: RB-LR-Handler(tag: 277, GET)
-2013-08-27 01:14:03,445+0000 INFO  GetFileHandler Handler(tag: 277, GET) unregistering (last)
-2013-08-27 01:14:03,445+0000 INFO  GetFileHandler Handler(tag: 2599, GET) unregistering (last)
-2013-08-27 01:14:03,445+0000 INFO  ReadBuffer RB-LR-Handler(tag: 277, GET) de-allocating 5 buffers
-2013-08-27 01:14:03,445+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:03,445+0000 INFO  GetFileHandler Handler(tag: 2600, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,445+0000 INFO  GetFileHandler Handler(tag: 2600, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,445+0000 INFO  GetFileHandler Handler(tag: 2600, GET) -> 278
-2013-08-27 01:14:03,445+0000 INFO  GetFileHandler Handler(tag: 278, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,445+0000 INFO  GetFileHandler Handler(tag: 278, GET) reader: LR-Handler(tag: 278, GET)
-2013-08-27 01:14:03,445+0000 INFO  GetFileHandler Handler(tag: 278, GET) sending length: 148937, 1200320659
-2013-08-27 01:14:03,445+0000 INFO  GetFileHandler Handler(tag: 2600, GET) sending length: 148937, 327935895
-2013-08-27 01:14:03,445+0000 INFO  ReadBuffer RB-LR-Handler(tag: 278, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:03,445+0000 INFO  ReadBuffer RB-LR-Handler(tag: 278, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:03,445+0000 INFO  LocalIOProvider LR-Handler(tag: 278, GET) rbuf: RB-LR-Handler(tag: 278, GET)
-2013-08-27 01:14:03,446+0000 INFO  GetFileHandler Handler(tag: 278, GET) unregistering (last)
-2013-08-27 01:14:03,446+0000 INFO  GetFileHandler Handler(tag: 2600, GET) unregistering (last)
-2013-08-27 01:14:03,446+0000 INFO  ReadBuffer RB-LR-Handler(tag: 278, GET) de-allocating 5 buffers
-2013-08-27 01:14:03,446+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:03,446+0000 INFO  GetFileHandler Handler(tag: 2601, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,446+0000 INFO  GetFileHandler Handler(tag: 2601, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,446+0000 INFO  GetFileHandler Handler(tag: 2601, GET) -> 279
-2013-08-27 01:14:03,446+0000 INFO  GetFileHandler Handler(tag: 279, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,446+0000 INFO  GetFileHandler Handler(tag: 279, GET) reader: LR-Handler(tag: 279, GET)
-2013-08-27 01:14:03,446+0000 INFO  GetFileHandler Handler(tag: 279, GET) sending length: 148937, 1776907850
-2013-08-27 01:14:03,446+0000 INFO  GetFileHandler Handler(tag: 2601, GET) sending length: 148937, 1582639768
-2013-08-27 01:14:03,446+0000 INFO  ReadBuffer RB-LR-Handler(tag: 279, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:03,446+0000 INFO  ReadBuffer RB-LR-Handler(tag: 279, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:03,446+0000 INFO  LocalIOProvider LR-Handler(tag: 279, GET) rbuf: RB-LR-Handler(tag: 279, GET)
-2013-08-27 01:14:03,447+0000 INFO  GetFileHandler Handler(tag: 279, GET) unregistering (last)
-2013-08-27 01:14:03,447+0000 INFO  GetFileHandler Handler(tag: 2601, GET) unregistering (last)
-2013-08-27 01:14:03,447+0000 INFO  ReadBuffer RB-LR-Handler(tag: 279, GET) de-allocating 5 buffers
-2013-08-27 01:14:03,447+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:03,448+0000 INFO  GetFileHandler Handler(tag: 2602, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,448+0000 INFO  GetFileHandler Handler(tag: 2602, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,448+0000 INFO  GetFileHandler Handler(tag: 2602, GET) -> 280
-2013-08-27 01:14:03,448+0000 INFO  GetFileHandler Handler(tag: 280, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,448+0000 INFO  GetFileHandler Handler(tag: 280, GET) reader: LR-Handler(tag: 280, GET)
-2013-08-27 01:14:03,448+0000 INFO  GetFileHandler Handler(tag: 280, GET) sending length: 543, 34352041
-2013-08-27 01:14:03,448+0000 INFO  GetFileHandler Handler(tag: 2602, GET) sending length: 543, 1829135691
-2013-08-27 01:14:03,448+0000 INFO  ReadBuffer RB-LR-Handler(tag: 280, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,448+0000 INFO  ReadBuffer RB-LR-Handler(tag: 280, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,448+0000 INFO  LocalIOProvider LR-Handler(tag: 280, GET) rbuf: RB-LR-Handler(tag: 280, GET)
-2013-08-27 01:14:03,448+0000 INFO  GetFileHandler Handler(tag: 280, GET) unregistering (last)
-2013-08-27 01:14:03,448+0000 INFO  ReadBuffer RB-LR-Handler(tag: 280, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,448+0000 INFO  GetFileHandler Handler(tag: 2602, GET) unregistering (last)
-2013-08-27 01:14:03,449+0000 INFO  GetFileHandler Handler(tag: 2603, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,449+0000 INFO  GetFileHandler Handler(tag: 2603, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,449+0000 INFO  GetFileHandler Handler(tag: 2603, GET) -> 281
-2013-08-27 01:14:03,449+0000 INFO  GetFileHandler Handler(tag: 281, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,449+0000 INFO  GetFileHandler Handler(tag: 281, GET) reader: LR-Handler(tag: 281, GET)
-2013-08-27 01:14:03,449+0000 INFO  GetFileHandler Handler(tag: 281, GET) sending length: 543, 2031668134
-2013-08-27 01:14:03,449+0000 INFO  GetFileHandler Handler(tag: 2603, GET) sending length: 543, 1256340838
-2013-08-27 01:14:03,449+0000 INFO  ReadBuffer RB-LR-Handler(tag: 281, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,449+0000 INFO  ReadBuffer RB-LR-Handler(tag: 281, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,449+0000 INFO  LocalIOProvider LR-Handler(tag: 281, GET) rbuf: RB-LR-Handler(tag: 281, GET)
-2013-08-27 01:14:03,449+0000 INFO  GetFileHandler Handler(tag: 281, GET) unregistering (last)
-2013-08-27 01:14:03,449+0000 INFO  ReadBuffer RB-LR-Handler(tag: 281, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,449+0000 INFO  GetFileHandler Handler(tag: 2603, GET) unregistering (last)
-2013-08-27 01:14:03,450+0000 INFO  GetFileHandler Handler(tag: 2604, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,450+0000 INFO  GetFileHandler Handler(tag: 2604, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,450+0000 INFO  GetFileHandler Handler(tag: 2604, GET) -> 282
-2013-08-27 01:14:03,450+0000 INFO  GetFileHandler Handler(tag: 282, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,451+0000 INFO  GetFileHandler Handler(tag: 282, GET) reader: LR-Handler(tag: 282, GET)
-2013-08-27 01:14:03,451+0000 INFO  GetFileHandler Handler(tag: 282, GET) sending length: 543, 1093820001
-2013-08-27 01:14:03,451+0000 INFO  GetFileHandler Handler(tag: 2604, GET) sending length: 543, 1372738487
-2013-08-27 01:14:03,451+0000 INFO  ReadBuffer RB-LR-Handler(tag: 282, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,451+0000 INFO  ReadBuffer RB-LR-Handler(tag: 282, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,451+0000 INFO  LocalIOProvider LR-Handler(tag: 282, GET) rbuf: RB-LR-Handler(tag: 282, GET)
-2013-08-27 01:14:03,451+0000 INFO  GetFileHandler Handler(tag: 282, GET) unregistering (last)
-2013-08-27 01:14:03,451+0000 INFO  ReadBuffer RB-LR-Handler(tag: 282, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,451+0000 INFO  GetFileHandler Handler(tag: 2604, GET) unregistering (last)
-2013-08-27 01:14:03,452+0000 INFO  GetFileHandler Handler(tag: 2605, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,452+0000 INFO  GetFileHandler Handler(tag: 2605, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,452+0000 INFO  GetFileHandler Handler(tag: 2605, GET) -> 283
-2013-08-27 01:14:03,452+0000 INFO  GetFileHandler Handler(tag: 283, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,452+0000 INFO  GetFileHandler Handler(tag: 283, GET) reader: LR-Handler(tag: 283, GET)
-2013-08-27 01:14:03,452+0000 INFO  GetFileHandler Handler(tag: 283, GET) sending length: 543, 876927033
-2013-08-27 01:14:03,452+0000 INFO  GetFileHandler Handler(tag: 2605, GET) sending length: 543, 332374270
-2013-08-27 01:14:03,452+0000 INFO  ReadBuffer RB-LR-Handler(tag: 283, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,452+0000 INFO  ReadBuffer RB-LR-Handler(tag: 283, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,452+0000 INFO  LocalIOProvider LR-Handler(tag: 283, GET) rbuf: RB-LR-Handler(tag: 283, GET)
-2013-08-27 01:14:03,452+0000 INFO  GetFileHandler Handler(tag: 283, GET) unregistering (last)
-2013-08-27 01:14:03,452+0000 INFO  ReadBuffer RB-LR-Handler(tag: 283, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,452+0000 INFO  GetFileHandler Handler(tag: 2605, GET) unregistering (last)
-2013-08-27 01:14:03,453+0000 INFO  GetFileHandler Handler(tag: 2606, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,453+0000 INFO  GetFileHandler Handler(tag: 2606, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,453+0000 INFO  GetFileHandler Handler(tag: 2606, GET) -> 284
-2013-08-27 01:14:03,453+0000 INFO  GetFileHandler Handler(tag: 284, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,453+0000 INFO  GetFileHandler Handler(tag: 284, GET) reader: LR-Handler(tag: 284, GET)
-2013-08-27 01:14:03,453+0000 INFO  GetFileHandler Handler(tag: 284, GET) sending length: 543, 1320243813
-2013-08-27 01:14:03,453+0000 INFO  GetFileHandler Handler(tag: 2606, GET) sending length: 543, 1536724287
-2013-08-27 01:14:03,453+0000 INFO  ReadBuffer RB-LR-Handler(tag: 284, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,453+0000 INFO  ReadBuffer RB-LR-Handler(tag: 284, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,453+0000 INFO  LocalIOProvider LR-Handler(tag: 284, GET) rbuf: RB-LR-Handler(tag: 284, GET)
-2013-08-27 01:14:03,453+0000 INFO  GetFileHandler Handler(tag: 284, GET) unregistering (last)
-2013-08-27 01:14:03,453+0000 INFO  ReadBuffer RB-LR-Handler(tag: 284, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,453+0000 INFO  GetFileHandler Handler(tag: 2606, GET) unregistering (last)
-2013-08-27 01:14:03,455+0000 INFO  GetFileHandler Handler(tag: 2607, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,455+0000 INFO  GetFileHandler Handler(tag: 2607, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,455+0000 INFO  GetFileHandler Handler(tag: 2607, GET) -> 285
-2013-08-27 01:14:03,455+0000 INFO  GetFileHandler Handler(tag: 285, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,455+0000 INFO  GetFileHandler Handler(tag: 285, GET) reader: LR-Handler(tag: 285, GET)
-2013-08-27 01:14:03,455+0000 INFO  GetFileHandler Handler(tag: 285, GET) sending length: 543, 105603519
-2013-08-27 01:14:03,455+0000 INFO  ReadBuffer RB-LR-Handler(tag: 285, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,455+0000 INFO  ReadBuffer RB-LR-Handler(tag: 285, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,455+0000 INFO  GetFileHandler Handler(tag: 2607, GET) sending length: 543, 664420340
-2013-08-27 01:14:03,455+0000 INFO  LocalIOProvider LR-Handler(tag: 285, GET) rbuf: RB-LR-Handler(tag: 285, GET)
-2013-08-27 01:14:03,461+0000 INFO  GetFileHandler Handler(tag: 285, GET) unregistering (last)
-2013-08-27 01:14:03,461+0000 INFO  GetFileHandler Handler(tag: 2608, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,461+0000 INFO  ReadBuffer RB-LR-Handler(tag: 285, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,461+0000 INFO  GetFileHandler Handler(tag: 2607, GET) unregistering (last)
-2013-08-27 01:14:03,462+0000 INFO  GetFileHandler Handler(tag: 2608, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,462+0000 INFO  GetFileHandler Handler(tag: 2608, GET) -> 286
-2013-08-27 01:14:03,462+0000 INFO  GetFileHandler Handler(tag: 286, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,463+0000 INFO  GetFileHandler Handler(tag: 2609, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,463+0000 INFO  GetFileHandler Handler(tag: 2609, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,463+0000 INFO  GetFileHandler Handler(tag: 286, GET) reader: LR-Handler(tag: 286, GET)
-2013-08-27 01:14:03,463+0000 INFO  GetFileHandler Handler(tag: 2609, GET) -> 287
-2013-08-27 01:14:03,463+0000 INFO  GetFileHandler Handler(tag: 286, GET) sending length: 543, 1665051819
-2013-08-27 01:14:03,464+0000 INFO  GetFileHandler Handler(tag: 2608, GET) sending length: 543, 1722468755
-2013-08-27 01:14:03,464+0000 INFO  ReadBuffer RB-LR-Handler(tag: 286, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,464+0000 INFO  ReadBuffer RB-LR-Handler(tag: 286, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,464+0000 INFO  LocalIOProvider LR-Handler(tag: 286, GET) rbuf: RB-LR-Handler(tag: 286, GET)
-2013-08-27 01:14:03,464+0000 INFO  GetFileHandler Handler(tag: 2610, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,464+0000 INFO  GetFileHandler Handler(tag: 286, GET) unregistering (last)
-2013-08-27 01:14:03,464+0000 INFO  GetFileHandler Handler(tag: 287, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,464+0000 INFO  ReadBuffer RB-LR-Handler(tag: 286, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,464+0000 INFO  GetFileHandler Handler(tag: 2608, GET) unregistering (last)
-2013-08-27 01:14:03,464+0000 INFO  GetFileHandler Handler(tag: 2610, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,464+0000 INFO  GetFileHandler Handler(tag: 2610, GET) -> 288
-2013-08-27 01:14:03,464+0000 INFO  GetFileHandler Handler(tag: 287, GET) reader: LR-Handler(tag: 287, GET)
-2013-08-27 01:14:03,464+0000 INFO  GetFileHandler Handler(tag: 287, GET) sending length: 543, 1671906019
-2013-08-27 01:14:03,464+0000 INFO  GetFileHandler Handler(tag: 2611, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,464+0000 INFO  GetFileHandler Handler(tag: 2609, GET) sending length: 543, 2048423985
-2013-08-27 01:14:03,464+0000 INFO  ReadBuffer RB-LR-Handler(tag: 287, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,464+0000 INFO  ReadBuffer RB-LR-Handler(tag: 287, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,464+0000 INFO  GetFileHandler Handler(tag: 2611, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,464+0000 INFO  LocalIOProvider LR-Handler(tag: 287, GET) rbuf: RB-LR-Handler(tag: 287, GET)
-2013-08-27 01:14:03,464+0000 INFO  GetFileHandler Handler(tag: 287, GET) unregistering (last)
-2013-08-27 01:14:03,464+0000 INFO  GetFileHandler Handler(tag: 2611, GET) -> 289
-2013-08-27 01:14:03,464+0000 INFO  ReadBuffer RB-LR-Handler(tag: 287, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,464+0000 INFO  GetFileHandler Handler(tag: 2609, GET) unregistering (last)
-2013-08-27 01:14:03,464+0000 INFO  GetFileHandler Handler(tag: 288, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,464+0000 INFO  GetFileHandler Handler(tag: 2612, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,464+0000 INFO  GetFileHandler Handler(tag: 288, GET) reader: LR-Handler(tag: 288, GET)
-2013-08-27 01:14:03,464+0000 INFO  GetFileHandler Handler(tag: 2612, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,464+0000 INFO  GetFileHandler Handler(tag: 288, GET) sending length: 543, 1153793061
-2013-08-27 01:14:03,464+0000 INFO  GetFileHandler Handler(tag: 2612, GET) -> 290
-2013-08-27 01:14:03,464+0000 INFO  GetFileHandler Handler(tag: 2610, GET) sending length: 543, 22643817
-2013-08-27 01:14:03,464+0000 INFO  ReadBuffer RB-LR-Handler(tag: 288, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,464+0000 INFO  ReadBuffer RB-LR-Handler(tag: 288, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,464+0000 INFO  GetFileHandler Handler(tag: 2613, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,464+0000 INFO  LocalIOProvider LR-Handler(tag: 288, GET) rbuf: RB-LR-Handler(tag: 288, GET)
-2013-08-27 01:14:03,465+0000 INFO  GetFileHandler Handler(tag: 288, GET) unregistering (last)
-2013-08-27 01:14:03,465+0000 INFO  ReadBuffer RB-LR-Handler(tag: 288, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,465+0000 INFO  GetFileHandler Handler(tag: 2610, GET) unregistering (last)
-2013-08-27 01:14:03,465+0000 INFO  GetFileHandler Handler(tag: 2613, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,465+0000 INFO  GetFileHandler Handler(tag: 289, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,465+0000 INFO  GetFileHandler Handler(tag: 2613, GET) -> 291
-2013-08-27 01:14:03,465+0000 INFO  GetFileHandler Handler(tag: 289, GET) reader: LR-Handler(tag: 289, GET)
-2013-08-27 01:14:03,465+0000 INFO  GetFileHandler Handler(tag: 289, GET) sending length: 543, 1777164509
-2013-08-27 01:14:03,465+0000 INFO  GetFileHandler Handler(tag: 2614, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,465+0000 INFO  GetFileHandler Handler(tag: 2611, GET) sending length: 543, 1601340287
-2013-08-27 01:14:03,465+0000 INFO  ReadBuffer RB-LR-Handler(tag: 289, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,465+0000 INFO  GetFileHandler Handler(tag: 2614, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,465+0000 INFO  ReadBuffer RB-LR-Handler(tag: 289, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,465+0000 INFO  LocalIOProvider LR-Handler(tag: 289, GET) rbuf: RB-LR-Handler(tag: 289, GET)
-2013-08-27 01:14:03,465+0000 INFO  GetFileHandler Handler(tag: 2614, GET) -> 292
-2013-08-27 01:14:03,465+0000 INFO  GetFileHandler Handler(tag: 289, GET) unregistering (last)
-2013-08-27 01:14:03,465+0000 INFO  ReadBuffer RB-LR-Handler(tag: 289, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,465+0000 INFO  GetFileHandler Handler(tag: 2611, GET) unregistering (last)
-2013-08-27 01:14:03,465+0000 INFO  GetFileHandler Handler(tag: 290, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,465+0000 INFO  GetFileHandler Handler(tag: 290, GET) reader: LR-Handler(tag: 290, GET)
-2013-08-27 01:14:03,465+0000 INFO  GetFileHandler Handler(tag: 290, GET) sending length: 543, 1850701830
-2013-08-27 01:14:03,465+0000 INFO  GetFileHandler Handler(tag: 2612, GET) sending length: 543, 592513662
-2013-08-27 01:14:03,465+0000 INFO  ReadBuffer RB-LR-Handler(tag: 290, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,465+0000 INFO  ReadBuffer RB-LR-Handler(tag: 290, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,465+0000 INFO  LocalIOProvider LR-Handler(tag: 290, GET) rbuf: RB-LR-Handler(tag: 290, GET)
-2013-08-27 01:14:03,465+0000 INFO  GetFileHandler Handler(tag: 290, GET) unregistering (last)
-2013-08-27 01:14:03,465+0000 INFO  GetFileHandler Handler(tag: 291, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,465+0000 INFO  ReadBuffer RB-LR-Handler(tag: 290, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,465+0000 INFO  GetFileHandler Handler(tag: 2612, GET) unregistering (last)
-2013-08-27 01:14:03,465+0000 INFO  GetFileHandler Handler(tag: 291, GET) reader: LR-Handler(tag: 291, GET)
-2013-08-27 01:14:03,465+0000 INFO  GetFileHandler Handler(tag: 291, GET) sending length: 543, 1788226358
-2013-08-27 01:14:03,465+0000 INFO  GetFileHandler Handler(tag: 2613, GET) sending length: 543, 686759141
-2013-08-27 01:14:03,465+0000 INFO  ReadBuffer RB-LR-Handler(tag: 291, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,465+0000 INFO  ReadBuffer RB-LR-Handler(tag: 291, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,465+0000 INFO  LocalIOProvider LR-Handler(tag: 291, GET) rbuf: RB-LR-Handler(tag: 291, GET)
-2013-08-27 01:14:03,465+0000 INFO  GetFileHandler Handler(tag: 291, GET) unregistering (last)
-2013-08-27 01:14:03,465+0000 INFO  GetFileHandler Handler(tag: 292, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,465+0000 INFO  ReadBuffer RB-LR-Handler(tag: 291, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,465+0000 INFO  GetFileHandler Handler(tag: 2613, GET) unregistering (last)
-2013-08-27 01:14:03,465+0000 INFO  GetFileHandler Handler(tag: 292, GET) reader: LR-Handler(tag: 292, GET)
-2013-08-27 01:14:03,465+0000 INFO  GetFileHandler Handler(tag: 292, GET) sending length: 543, 683166940
-2013-08-27 01:14:03,465+0000 INFO  GetFileHandler Handler(tag: 2614, GET) sending length: 543, 1539183718
-2013-08-27 01:14:03,465+0000 INFO  ReadBuffer RB-LR-Handler(tag: 292, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,465+0000 INFO  ReadBuffer RB-LR-Handler(tag: 292, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,465+0000 INFO  LocalIOProvider LR-Handler(tag: 292, GET) rbuf: RB-LR-Handler(tag: 292, GET)
-2013-08-27 01:14:03,465+0000 INFO  GetFileHandler Handler(tag: 292, GET) unregistering (last)
-2013-08-27 01:14:03,465+0000 INFO  ReadBuffer RB-LR-Handler(tag: 292, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,465+0000 INFO  GetFileHandler Handler(tag: 2614, GET) unregistering (last)
-2013-08-27 01:14:03,466+0000 INFO  GetFileHandler Handler(tag: 2615, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,466+0000 INFO  GetFileHandler Handler(tag: 2615, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,466+0000 INFO  GetFileHandler Handler(tag: 2615, GET) -> 293
-2013-08-27 01:14:03,466+0000 INFO  GetFileHandler Handler(tag: 293, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,466+0000 INFO  GetFileHandler Handler(tag: 293, GET) reader: LR-Handler(tag: 293, GET)
-2013-08-27 01:14:03,466+0000 INFO  GetFileHandler Handler(tag: 293, GET) sending length: 543, 662823661
-2013-08-27 01:14:03,466+0000 INFO  GetFileHandler Handler(tag: 2615, GET) sending length: 543, 1079593438
-2013-08-27 01:14:03,466+0000 INFO  ReadBuffer RB-LR-Handler(tag: 293, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,466+0000 INFO  ReadBuffer RB-LR-Handler(tag: 293, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,466+0000 INFO  LocalIOProvider LR-Handler(tag: 293, GET) rbuf: RB-LR-Handler(tag: 293, GET)
-2013-08-27 01:14:03,466+0000 INFO  GetFileHandler Handler(tag: 293, GET) unregistering (last)
-2013-08-27 01:14:03,466+0000 INFO  ReadBuffer RB-LR-Handler(tag: 293, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,466+0000 INFO  GetFileHandler Handler(tag: 2615, GET) unregistering (last)
-2013-08-27 01:14:03,467+0000 INFO  GetFileHandler Handler(tag: 2616, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,467+0000 INFO  GetFileHandler Handler(tag: 2616, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,468+0000 INFO  GetFileHandler Handler(tag: 2616, GET) -> 294
-2013-08-27 01:14:03,468+0000 INFO  GetFileHandler Handler(tag: 294, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,468+0000 INFO  GetFileHandler Handler(tag: 294, GET) reader: LR-Handler(tag: 294, GET)
-2013-08-27 01:14:03,468+0000 INFO  GetFileHandler Handler(tag: 294, GET) sending length: 543, 1055629929
-2013-08-27 01:14:03,468+0000 INFO  GetFileHandler Handler(tag: 2616, GET) sending length: 543, 1609808836
-2013-08-27 01:14:03,468+0000 INFO  ReadBuffer RB-LR-Handler(tag: 294, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,468+0000 INFO  ReadBuffer RB-LR-Handler(tag: 294, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,468+0000 INFO  LocalIOProvider LR-Handler(tag: 294, GET) rbuf: RB-LR-Handler(tag: 294, GET)
-2013-08-27 01:14:03,468+0000 INFO  GetFileHandler Handler(tag: 294, GET) unregistering (last)
-2013-08-27 01:14:03,468+0000 INFO  ReadBuffer RB-LR-Handler(tag: 294, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,468+0000 INFO  GetFileHandler Handler(tag: 2616, GET) unregistering (last)
-2013-08-27 01:14:03,469+0000 INFO  GetFileHandler Handler(tag: 2617, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,469+0000 INFO  GetFileHandler Handler(tag: 2617, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,469+0000 INFO  GetFileHandler Handler(tag: 2617, GET) -> 295
-2013-08-27 01:14:03,469+0000 INFO  GetFileHandler Handler(tag: 295, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:03,469+0000 INFO  GetFileHandler Handler(tag: 295, GET) reader: LR-Handler(tag: 295, GET)
-2013-08-27 01:14:03,469+0000 INFO  GetFileHandler Handler(tag: 295, GET) sending length: 543, 681653798
-2013-08-27 01:14:03,469+0000 INFO  GetFileHandler Handler(tag: 2617, GET) sending length: 543, 1877609888
-2013-08-27 01:14:03,469+0000 INFO  ReadBuffer RB-LR-Handler(tag: 295, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:03,469+0000 INFO  ReadBuffer RB-LR-Handler(tag: 295, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,469+0000 INFO  LocalIOProvider LR-Handler(tag: 295, GET) rbuf: RB-LR-Handler(tag: 295, GET)
-2013-08-27 01:14:03,469+0000 INFO  GetFileHandler Handler(tag: 2618, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,469+0000 INFO  GetFileHandler Handler(tag: 295, GET) unregistering (last)
-2013-08-27 01:14:03,469+0000 INFO  GetFileHandler Handler(tag: 2617, GET) unregistering (last)
-2013-08-27 01:14:03,469+0000 INFO  ReadBuffer RB-LR-Handler(tag: 295, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,469+0000 INFO  GetFileHandler Handler(tag: 2618, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,469+0000 INFO  GetFileHandler Handler(tag: 2618, GET) -> 296
-2013-08-27 01:14:03,469+0000 INFO  GetFileHandler Handler(tag: 296, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,469+0000 INFO  GetFileHandler Handler(tag: 296, GET) reader: LR-Handler(tag: 296, GET)
-2013-08-27 01:14:03,469+0000 INFO  GetFileHandler Handler(tag: 296, GET) sending length: 2093, 2077760136
-2013-08-27 01:14:03,469+0000 INFO  GetFileHandler Handler(tag: 2618, GET) sending length: 2093, 683021885
-2013-08-27 01:14:03,469+0000 INFO  ReadBuffer RB-LR-Handler(tag: 296, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,469+0000 INFO  ReadBuffer RB-LR-Handler(tag: 296, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,469+0000 INFO  LocalIOProvider LR-Handler(tag: 296, GET) rbuf: RB-LR-Handler(tag: 296, GET)
-2013-08-27 01:14:03,469+0000 INFO  GetFileHandler Handler(tag: 296, GET) unregistering (last)
-2013-08-27 01:14:03,469+0000 INFO  ReadBuffer RB-LR-Handler(tag: 296, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,469+0000 INFO  GetFileHandler Handler(tag: 2618, GET) unregistering (last)
-2013-08-27 01:14:03,469+0000 INFO  GetFileHandler Handler(tag: 2619, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,469+0000 INFO  GetFileHandler Handler(tag: 2619, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,470+0000 INFO  GetFileHandler Handler(tag: 2619, GET) -> 297
-2013-08-27 01:14:03,470+0000 INFO  GetFileHandler Handler(tag: 297, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,470+0000 INFO  GetFileHandler Handler(tag: 297, GET) reader: LR-Handler(tag: 297, GET)
-2013-08-27 01:14:03,470+0000 INFO  GetFileHandler Handler(tag: 297, GET) sending length: 2093, 1639608796
-2013-08-27 01:14:03,470+0000 INFO  GetFileHandler Handler(tag: 2619, GET) sending length: 2093, 394876068
-2013-08-27 01:14:03,470+0000 INFO  ReadBuffer RB-LR-Handler(tag: 297, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,470+0000 INFO  ReadBuffer RB-LR-Handler(tag: 297, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,470+0000 INFO  LocalIOProvider LR-Handler(tag: 297, GET) rbuf: RB-LR-Handler(tag: 297, GET)
-2013-08-27 01:14:03,470+0000 INFO  GetFileHandler Handler(tag: 297, GET) unregistering (last)
-2013-08-27 01:14:03,470+0000 INFO  ReadBuffer RB-LR-Handler(tag: 297, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,470+0000 INFO  GetFileHandler Handler(tag: 2619, GET) unregistering (last)
-2013-08-27 01:14:03,470+0000 INFO  GetFileHandler Handler(tag: 2620, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,470+0000 INFO  GetFileHandler Handler(tag: 2620, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,470+0000 INFO  GetFileHandler Handler(tag: 2620, GET) -> 298
-2013-08-27 01:14:03,470+0000 INFO  GetFileHandler Handler(tag: 298, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,470+0000 INFO  GetFileHandler Handler(tag: 298, GET) reader: LR-Handler(tag: 298, GET)
-2013-08-27 01:14:03,470+0000 INFO  GetFileHandler Handler(tag: 298, GET) sending length: 2093, 1865175183
-2013-08-27 01:14:03,470+0000 INFO  GetFileHandler Handler(tag: 2620, GET) sending length: 2093, 1180505422
-2013-08-27 01:14:03,470+0000 INFO  ReadBuffer RB-LR-Handler(tag: 298, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,470+0000 INFO  ReadBuffer RB-LR-Handler(tag: 298, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,470+0000 INFO  GetFileHandler Handler(tag: 2621, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,470+0000 INFO  LocalIOProvider LR-Handler(tag: 298, GET) rbuf: RB-LR-Handler(tag: 298, GET)
-2013-08-27 01:14:03,470+0000 INFO  GetFileHandler Handler(tag: 298, GET) unregistering (last)
-2013-08-27 01:14:03,470+0000 INFO  ReadBuffer RB-LR-Handler(tag: 298, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,470+0000 INFO  GetFileHandler Handler(tag: 2620, GET) unregistering (last)
-2013-08-27 01:14:03,470+0000 INFO  GetFileHandler Handler(tag: 2621, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,470+0000 INFO  GetFileHandler Handler(tag: 2621, GET) -> 299
-2013-08-27 01:14:03,470+0000 INFO  GetFileHandler Handler(tag: 299, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,470+0000 INFO  GetFileHandler Handler(tag: 299, GET) reader: LR-Handler(tag: 299, GET)
-2013-08-27 01:14:03,470+0000 INFO  GetFileHandler Handler(tag: 299, GET) sending length: 2093, 921328496
-2013-08-27 01:14:03,470+0000 INFO  GetFileHandler Handler(tag: 2621, GET) sending length: 2093, 1410937402
-2013-08-27 01:14:03,470+0000 INFO  ReadBuffer RB-LR-Handler(tag: 299, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,470+0000 INFO  ReadBuffer RB-LR-Handler(tag: 299, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,470+0000 INFO  LocalIOProvider LR-Handler(tag: 299, GET) rbuf: RB-LR-Handler(tag: 299, GET)
-2013-08-27 01:14:03,470+0000 INFO  GetFileHandler Handler(tag: 299, GET) unregistering (last)
-2013-08-27 01:14:03,470+0000 INFO  GetFileHandler Handler(tag: 2622, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,470+0000 INFO  ReadBuffer RB-LR-Handler(tag: 299, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,470+0000 INFO  GetFileHandler Handler(tag: 2621, GET) unregistering (last)
-2013-08-27 01:14:03,470+0000 INFO  GetFileHandler Handler(tag: 2622, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,470+0000 INFO  GetFileHandler Handler(tag: 2622, GET) -> 300
-2013-08-27 01:14:03,470+0000 INFO  GetFileHandler Handler(tag: 300, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,470+0000 INFO  GetFileHandler Handler(tag: 300, GET) reader: LR-Handler(tag: 300, GET)
-2013-08-27 01:14:03,470+0000 INFO  GetFileHandler Handler(tag: 300, GET) sending length: 2093, 1771766873
-2013-08-27 01:14:03,471+0000 INFO  GetFileHandler Handler(tag: 2622, GET) sending length: 2093, 1077585209
-2013-08-27 01:14:03,471+0000 INFO  ReadBuffer RB-LR-Handler(tag: 300, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,471+0000 INFO  ReadBuffer RB-LR-Handler(tag: 300, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,471+0000 INFO  LocalIOProvider LR-Handler(tag: 300, GET) rbuf: RB-LR-Handler(tag: 300, GET)
-2013-08-27 01:14:03,471+0000 INFO  GetFileHandler Handler(tag: 300, GET) unregistering (last)
-2013-08-27 01:14:03,471+0000 INFO  GetFileHandler Handler(tag: 2623, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,471+0000 INFO  ReadBuffer RB-LR-Handler(tag: 300, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,471+0000 INFO  GetFileHandler Handler(tag: 2622, GET) unregistering (last)
-2013-08-27 01:14:03,471+0000 INFO  GetFileHandler Handler(tag: 2623, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,471+0000 INFO  GetFileHandler Handler(tag: 2623, GET) -> 301
-2013-08-27 01:14:03,471+0000 INFO  GetFileHandler Handler(tag: 301, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,471+0000 INFO  GetFileHandler Handler(tag: 301, GET) reader: LR-Handler(tag: 301, GET)
-2013-08-27 01:14:03,471+0000 INFO  GetFileHandler Handler(tag: 301, GET) sending length: 2093, 1879359552
-2013-08-27 01:14:03,471+0000 INFO  GetFileHandler Handler(tag: 2623, GET) sending length: 2093, 1206510388
-2013-08-27 01:14:03,471+0000 INFO  ReadBuffer RB-LR-Handler(tag: 301, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,471+0000 INFO  ReadBuffer RB-LR-Handler(tag: 301, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,471+0000 INFO  LocalIOProvider LR-Handler(tag: 301, GET) rbuf: RB-LR-Handler(tag: 301, GET)
-2013-08-27 01:14:03,471+0000 INFO  GetFileHandler Handler(tag: 301, GET) unregistering (last)
-2013-08-27 01:14:03,471+0000 INFO  ReadBuffer RB-LR-Handler(tag: 301, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,471+0000 INFO  GetFileHandler Handler(tag: 2623, GET) unregistering (last)
-2013-08-27 01:14:03,471+0000 INFO  GetFileHandler Handler(tag: 2624, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,471+0000 INFO  GetFileHandler Handler(tag: 2624, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,471+0000 INFO  GetFileHandler Handler(tag: 2624, GET) -> 302
-2013-08-27 01:14:03,471+0000 INFO  GetFileHandler Handler(tag: 302, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,471+0000 INFO  GetFileHandler Handler(tag: 302, GET) reader: LR-Handler(tag: 302, GET)
-2013-08-27 01:14:03,471+0000 INFO  GetFileHandler Handler(tag: 302, GET) sending length: 2093, 695450558
-2013-08-27 01:14:03,471+0000 INFO  GetFileHandler Handler(tag: 2624, GET) sending length: 2093, 1831521332
-2013-08-27 01:14:03,471+0000 INFO  ReadBuffer RB-LR-Handler(tag: 302, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,471+0000 INFO  ReadBuffer RB-LR-Handler(tag: 302, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,471+0000 INFO  LocalIOProvider LR-Handler(tag: 302, GET) rbuf: RB-LR-Handler(tag: 302, GET)
-2013-08-27 01:14:03,471+0000 INFO  GetFileHandler Handler(tag: 302, GET) unregistering (last)
-2013-08-27 01:14:03,471+0000 INFO  ReadBuffer RB-LR-Handler(tag: 302, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,471+0000 INFO  GetFileHandler Handler(tag: 2624, GET) unregistering (last)
-2013-08-27 01:14:03,471+0000 INFO  GetFileHandler Handler(tag: 2625, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,471+0000 INFO  GetFileHandler Handler(tag: 2625, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,471+0000 INFO  GetFileHandler Handler(tag: 2625, GET) -> 303
-2013-08-27 01:14:03,471+0000 INFO  GetFileHandler Handler(tag: 303, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,471+0000 INFO  GetFileHandler Handler(tag: 303, GET) reader: LR-Handler(tag: 303, GET)
-2013-08-27 01:14:03,471+0000 INFO  GetFileHandler Handler(tag: 303, GET) sending length: 2093, 668074440
-2013-08-27 01:14:03,471+0000 INFO  GetFileHandler Handler(tag: 2625, GET) sending length: 2093, 1282606564
-2013-08-27 01:14:03,471+0000 INFO  ReadBuffer RB-LR-Handler(tag: 303, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,471+0000 INFO  ReadBuffer RB-LR-Handler(tag: 303, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,471+0000 INFO  LocalIOProvider LR-Handler(tag: 303, GET) rbuf: RB-LR-Handler(tag: 303, GET)
-2013-08-27 01:14:03,471+0000 INFO  GetFileHandler Handler(tag: 303, GET) unregistering (last)
-2013-08-27 01:14:03,471+0000 INFO  GetFileHandler Handler(tag: 2626, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,471+0000 INFO  ReadBuffer RB-LR-Handler(tag: 303, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,471+0000 INFO  GetFileHandler Handler(tag: 2625, GET) unregistering (last)
-2013-08-27 01:14:03,472+0000 INFO  GetFileHandler Handler(tag: 2626, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,472+0000 INFO  GetFileHandler Handler(tag: 2626, GET) -> 304
-2013-08-27 01:14:03,472+0000 INFO  GetFileHandler Handler(tag: 304, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,472+0000 INFO  GetFileHandler Handler(tag: 304, GET) reader: LR-Handler(tag: 304, GET)
-2013-08-27 01:14:03,472+0000 INFO  GetFileHandler Handler(tag: 304, GET) sending length: 2093, 1694353035
-2013-08-27 01:14:03,472+0000 INFO  GetFileHandler Handler(tag: 2626, GET) sending length: 2093, 1358300025
-2013-08-27 01:14:03,472+0000 INFO  ReadBuffer RB-LR-Handler(tag: 304, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,472+0000 INFO  ReadBuffer RB-LR-Handler(tag: 304, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,472+0000 INFO  LocalIOProvider LR-Handler(tag: 304, GET) rbuf: RB-LR-Handler(tag: 304, GET)
-2013-08-27 01:14:03,472+0000 INFO  GetFileHandler Handler(tag: 304, GET) unregistering (last)
-2013-08-27 01:14:03,472+0000 INFO  GetFileHandler Handler(tag: 2627, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,472+0000 INFO  ReadBuffer RB-LR-Handler(tag: 304, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,472+0000 INFO  GetFileHandler Handler(tag: 2626, GET) unregistering (last)
-2013-08-27 01:14:03,472+0000 INFO  GetFileHandler Handler(tag: 2627, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,472+0000 INFO  GetFileHandler Handler(tag: 2627, GET) -> 305
-2013-08-27 01:14:03,472+0000 INFO  GetFileHandler Handler(tag: 305, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,472+0000 INFO  GetFileHandler Handler(tag: 305, GET) reader: LR-Handler(tag: 305, GET)
-2013-08-27 01:14:03,472+0000 INFO  GetFileHandler Handler(tag: 305, GET) sending length: 2093, 1924425353
-2013-08-27 01:14:03,472+0000 INFO  GetFileHandler Handler(tag: 2627, GET) sending length: 2093, 565700404
-2013-08-27 01:14:03,472+0000 INFO  ReadBuffer RB-LR-Handler(tag: 305, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,472+0000 INFO  ReadBuffer RB-LR-Handler(tag: 305, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,472+0000 INFO  GetFileHandler Handler(tag: 2628, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,472+0000 INFO  LocalIOProvider LR-Handler(tag: 305, GET) rbuf: RB-LR-Handler(tag: 305, GET)
-2013-08-27 01:14:03,472+0000 INFO  GetFileHandler Handler(tag: 305, GET) unregistering (last)
-2013-08-27 01:14:03,472+0000 INFO  ReadBuffer RB-LR-Handler(tag: 305, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,472+0000 INFO  GetFileHandler Handler(tag: 2628, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,472+0000 INFO  GetFileHandler Handler(tag: 2627, GET) unregistering (last)
-2013-08-27 01:14:03,472+0000 INFO  GetFileHandler Handler(tag: 2628, GET) -> 306
-2013-08-27 01:14:03,472+0000 INFO  GetFileHandler Handler(tag: 306, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,472+0000 INFO  GetFileHandler Handler(tag: 306, GET) reader: LR-Handler(tag: 306, GET)
-2013-08-27 01:14:03,472+0000 INFO  GetFileHandler Handler(tag: 306, GET) sending length: 2093, 355004788
-2013-08-27 01:14:03,472+0000 INFO  GetFileHandler Handler(tag: 2628, GET) sending length: 2093, 855900550
-2013-08-27 01:14:03,472+0000 INFO  ReadBuffer RB-LR-Handler(tag: 306, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,472+0000 INFO  ReadBuffer RB-LR-Handler(tag: 306, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,472+0000 INFO  LocalIOProvider LR-Handler(tag: 306, GET) rbuf: RB-LR-Handler(tag: 306, GET)
-2013-08-27 01:14:03,472+0000 INFO  GetFileHandler Handler(tag: 2629, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,472+0000 INFO  GetFileHandler Handler(tag: 306, GET) unregistering (last)
-2013-08-27 01:14:03,472+0000 INFO  GetFileHandler Handler(tag: 2628, GET) unregistering (last)
-2013-08-27 01:14:03,472+0000 INFO  ReadBuffer RB-LR-Handler(tag: 306, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,472+0000 INFO  GetFileHandler Handler(tag: 2629, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,472+0000 INFO  GetFileHandler Handler(tag: 2629, GET) -> 307
-2013-08-27 01:14:03,472+0000 INFO  GetFileHandler Handler(tag: 307, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,472+0000 INFO  GetFileHandler Handler(tag: 307, GET) reader: LR-Handler(tag: 307, GET)
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 307, GET) sending length: 2093, 1123254663
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 2629, GET) sending length: 2093, 12380264
-2013-08-27 01:14:03,473+0000 INFO  ReadBuffer RB-LR-Handler(tag: 307, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,473+0000 INFO  ReadBuffer RB-LR-Handler(tag: 307, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,473+0000 INFO  LocalIOProvider LR-Handler(tag: 307, GET) rbuf: RB-LR-Handler(tag: 307, GET)
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 307, GET) unregistering (last)
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 2630, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,473+0000 INFO  ReadBuffer RB-LR-Handler(tag: 307, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 2629, GET) unregistering (last)
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 2630, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 2630, GET) -> 308
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 308, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 308, GET) reader: LR-Handler(tag: 308, GET)
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 308, GET) sending length: 2093, 106758567
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 2630, GET) sending length: 2093, 1142390324
-2013-08-27 01:14:03,473+0000 INFO  ReadBuffer RB-LR-Handler(tag: 308, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,473+0000 INFO  ReadBuffer RB-LR-Handler(tag: 308, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,473+0000 INFO  LocalIOProvider LR-Handler(tag: 308, GET) rbuf: RB-LR-Handler(tag: 308, GET)
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 2631, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 308, GET) unregistering (last)
-2013-08-27 01:14:03,473+0000 INFO  ReadBuffer RB-LR-Handler(tag: 308, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 2630, GET) unregistering (last)
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 2631, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 2631, GET) -> 309
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 309, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 309, GET) reader: LR-Handler(tag: 309, GET)
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 309, GET) sending length: 2093, 2069901328
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 2631, GET) sending length: 2093, 1744021943
-2013-08-27 01:14:03,473+0000 INFO  ReadBuffer RB-LR-Handler(tag: 309, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,473+0000 INFO  ReadBuffer RB-LR-Handler(tag: 309, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,473+0000 INFO  LocalIOProvider LR-Handler(tag: 309, GET) rbuf: RB-LR-Handler(tag: 309, GET)
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 309, GET) unregistering (last)
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 2632, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 2631, GET) unregistering (last)
-2013-08-27 01:14:03,473+0000 INFO  ReadBuffer RB-LR-Handler(tag: 309, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 2632, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 2632, GET) -> 310
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 310, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 310, GET) reader: LR-Handler(tag: 310, GET)
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 310, GET) sending length: 2093, 1198969446
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 2632, GET) sending length: 2093, 1240419121
-2013-08-27 01:14:03,473+0000 INFO  ReadBuffer RB-LR-Handler(tag: 310, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,473+0000 INFO  ReadBuffer RB-LR-Handler(tag: 310, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,473+0000 INFO  LocalIOProvider LR-Handler(tag: 310, GET) rbuf: RB-LR-Handler(tag: 310, GET)
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 310, GET) unregistering (last)
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 2633, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,473+0000 INFO  ReadBuffer RB-LR-Handler(tag: 310, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,473+0000 INFO  GetFileHandler Handler(tag: 2632, GET) unregistering (last)
-2013-08-27 01:14:03,474+0000 INFO  GetFileHandler Handler(tag: 2633, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,474+0000 INFO  GetFileHandler Handler(tag: 2633, GET) -> 311
-2013-08-27 01:14:03,474+0000 INFO  GetFileHandler Handler(tag: 311, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:03,474+0000 INFO  GetFileHandler Handler(tag: 311, GET) reader: LR-Handler(tag: 311, GET)
-2013-08-27 01:14:03,474+0000 INFO  GetFileHandler Handler(tag: 311, GET) sending length: 2093, 705236334
-2013-08-27 01:14:03,474+0000 INFO  GetFileHandler Handler(tag: 2633, GET) sending length: 2093, 944817745
-2013-08-27 01:14:03,474+0000 INFO  ReadBuffer RB-LR-Handler(tag: 311, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:03,474+0000 INFO  ReadBuffer RB-LR-Handler(tag: 311, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,474+0000 INFO  LocalIOProvider LR-Handler(tag: 311, GET) rbuf: RB-LR-Handler(tag: 311, GET)
-2013-08-27 01:14:03,474+0000 INFO  GetFileHandler Handler(tag: 311, GET) unregistering (last)
-2013-08-27 01:14:03,474+0000 INFO  ReadBuffer RB-LR-Handler(tag: 311, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,474+0000 INFO  GetFileHandler Handler(tag: 2633, GET) unregistering (last)
-2013-08-27 01:14:03,474+0000 INFO  GetFileHandler Handler(tag: 2634, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,474+0000 INFO  GetFileHandler Handler(tag: 2634, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,474+0000 INFO  GetFileHandler Handler(tag: 2634, GET) -> 312
-2013-08-27 01:14:03,474+0000 INFO  GetFileHandler Handler(tag: 312, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,474+0000 INFO  GetFileHandler Handler(tag: 312, GET) reader: LR-Handler(tag: 312, GET)
-2013-08-27 01:14:03,474+0000 INFO  GetFileHandler Handler(tag: 312, GET) sending length: 5032, 1850369317
-2013-08-27 01:14:03,474+0000 INFO  GetFileHandler Handler(tag: 2634, GET) sending length: 5032, 1446418612
-2013-08-27 01:14:03,474+0000 INFO  ReadBuffer RB-LR-Handler(tag: 312, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,474+0000 INFO  ReadBuffer RB-LR-Handler(tag: 312, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,474+0000 INFO  LocalIOProvider LR-Handler(tag: 312, GET) rbuf: RB-LR-Handler(tag: 312, GET)
-2013-08-27 01:14:03,474+0000 INFO  GetFileHandler Handler(tag: 2635, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,474+0000 INFO  GetFileHandler Handler(tag: 312, GET) unregistering (last)
-2013-08-27 01:14:03,474+0000 INFO  GetFileHandler Handler(tag: 2634, GET) unregistering (last)
-2013-08-27 01:14:03,474+0000 INFO  ReadBuffer RB-LR-Handler(tag: 312, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,474+0000 INFO  GetFileHandler Handler(tag: 2635, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,474+0000 INFO  GetFileHandler Handler(tag: 2635, GET) -> 313
-2013-08-27 01:14:03,474+0000 INFO  GetFileHandler Handler(tag: 313, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,474+0000 INFO  GetFileHandler Handler(tag: 313, GET) reader: LR-Handler(tag: 313, GET)
-2013-08-27 01:14:03,474+0000 INFO  GetFileHandler Handler(tag: 313, GET) sending length: 5032, 121943304
-2013-08-27 01:14:03,474+0000 INFO  GetFileHandler Handler(tag: 2635, GET) sending length: 5032, 801711090
-2013-08-27 01:14:03,474+0000 INFO  ReadBuffer RB-LR-Handler(tag: 313, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,474+0000 INFO  ReadBuffer RB-LR-Handler(tag: 313, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,474+0000 INFO  LocalIOProvider LR-Handler(tag: 313, GET) rbuf: RB-LR-Handler(tag: 313, GET)
-2013-08-27 01:14:03,474+0000 INFO  GetFileHandler Handler(tag: 313, GET) unregistering (last)
-2013-08-27 01:14:03,474+0000 INFO  GetFileHandler Handler(tag: 2636, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,474+0000 INFO  ReadBuffer RB-LR-Handler(tag: 313, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,474+0000 INFO  GetFileHandler Handler(tag: 2635, GET) unregistering (last)
-2013-08-27 01:14:03,474+0000 INFO  GetFileHandler Handler(tag: 2636, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,474+0000 INFO  GetFileHandler Handler(tag: 2636, GET) -> 314
-2013-08-27 01:14:03,474+0000 INFO  GetFileHandler Handler(tag: 314, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,475+0000 INFO  GetFileHandler Handler(tag: 314, GET) reader: LR-Handler(tag: 314, GET)
-2013-08-27 01:14:03,475+0000 INFO  GetFileHandler Handler(tag: 314, GET) sending length: 5032, 1335732606
-2013-08-27 01:14:03,475+0000 INFO  GetFileHandler Handler(tag: 2636, GET) sending length: 5032, 2011346951
-2013-08-27 01:14:03,475+0000 INFO  ReadBuffer RB-LR-Handler(tag: 314, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,475+0000 INFO  ReadBuffer RB-LR-Handler(tag: 314, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,475+0000 INFO  LocalIOProvider LR-Handler(tag: 314, GET) rbuf: RB-LR-Handler(tag: 314, GET)
-2013-08-27 01:14:03,475+0000 INFO  GetFileHandler Handler(tag: 314, GET) unregistering (last)
-2013-08-27 01:14:03,475+0000 INFO  ReadBuffer RB-LR-Handler(tag: 314, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,475+0000 INFO  GetFileHandler Handler(tag: 2636, GET) unregistering (last)
-2013-08-27 01:14:03,475+0000 INFO  GetFileHandler Handler(tag: 2637, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,475+0000 INFO  GetFileHandler Handler(tag: 2637, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,475+0000 INFO  GetFileHandler Handler(tag: 2637, GET) -> 315
-2013-08-27 01:14:03,475+0000 INFO  GetFileHandler Handler(tag: 315, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,475+0000 INFO  GetFileHandler Handler(tag: 315, GET) reader: LR-Handler(tag: 315, GET)
-2013-08-27 01:14:03,475+0000 INFO  GetFileHandler Handler(tag: 315, GET) sending length: 5032, 1206155004
-2013-08-27 01:14:03,475+0000 INFO  GetFileHandler Handler(tag: 2637, GET) sending length: 5032, 1749008195
-2013-08-27 01:14:03,475+0000 INFO  ReadBuffer RB-LR-Handler(tag: 315, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,475+0000 INFO  ReadBuffer RB-LR-Handler(tag: 315, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,475+0000 INFO  LocalIOProvider LR-Handler(tag: 315, GET) rbuf: RB-LR-Handler(tag: 315, GET)
-2013-08-27 01:14:03,475+0000 INFO  GetFileHandler Handler(tag: 2638, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,475+0000 INFO  GetFileHandler Handler(tag: 315, GET) unregistering (last)
-2013-08-27 01:14:03,475+0000 INFO  GetFileHandler Handler(tag: 2637, GET) unregistering (last)
-2013-08-27 01:14:03,475+0000 INFO  ReadBuffer RB-LR-Handler(tag: 315, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,475+0000 INFO  GetFileHandler Handler(tag: 2638, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,475+0000 INFO  GetFileHandler Handler(tag: 2638, GET) -> 316
-2013-08-27 01:14:03,475+0000 INFO  GetFileHandler Handler(tag: 316, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,475+0000 INFO  GetFileHandler Handler(tag: 316, GET) reader: LR-Handler(tag: 316, GET)
-2013-08-27 01:14:03,475+0000 INFO  GetFileHandler Handler(tag: 316, GET) sending length: 5032, 561340542
-2013-08-27 01:14:03,475+0000 INFO  GetFileHandler Handler(tag: 2638, GET) sending length: 5032, 554828123
-2013-08-27 01:14:03,475+0000 INFO  ReadBuffer RB-LR-Handler(tag: 316, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,475+0000 INFO  ReadBuffer RB-LR-Handler(tag: 316, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,475+0000 INFO  LocalIOProvider LR-Handler(tag: 316, GET) rbuf: RB-LR-Handler(tag: 316, GET)
-2013-08-27 01:14:03,475+0000 INFO  GetFileHandler Handler(tag: 316, GET) unregistering (last)
-2013-08-27 01:14:03,475+0000 INFO  ReadBuffer RB-LR-Handler(tag: 316, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,475+0000 INFO  GetFileHandler Handler(tag: 2639, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,475+0000 INFO  GetFileHandler Handler(tag: 2638, GET) unregistering (last)
-2013-08-27 01:14:03,475+0000 INFO  GetFileHandler Handler(tag: 2639, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,475+0000 INFO  GetFileHandler Handler(tag: 2639, GET) -> 317
-2013-08-27 01:14:03,475+0000 INFO  GetFileHandler Handler(tag: 317, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,475+0000 INFO  GetFileHandler Handler(tag: 317, GET) reader: LR-Handler(tag: 317, GET)
-2013-08-27 01:14:03,475+0000 INFO  GetFileHandler Handler(tag: 317, GET) sending length: 5032, 707143228
-2013-08-27 01:14:03,475+0000 INFO  GetFileHandler Handler(tag: 2639, GET) sending length: 5032, 781730498
-2013-08-27 01:14:03,475+0000 INFO  ReadBuffer RB-LR-Handler(tag: 317, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,475+0000 INFO  ReadBuffer RB-LR-Handler(tag: 317, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,475+0000 INFO  LocalIOProvider LR-Handler(tag: 317, GET) rbuf: RB-LR-Handler(tag: 317, GET)
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 317, GET) unregistering (last)
-2013-08-27 01:14:03,476+0000 INFO  ReadBuffer RB-LR-Handler(tag: 317, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 2639, GET) unregistering (last)
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 2640, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 2640, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 2640, GET) -> 318
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 318, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 318, GET) reader: LR-Handler(tag: 318, GET)
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 318, GET) sending length: 5032, 1761579281
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 2640, GET) sending length: 5032, 1653418225
-2013-08-27 01:14:03,476+0000 INFO  ReadBuffer RB-LR-Handler(tag: 318, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,476+0000 INFO  ReadBuffer RB-LR-Handler(tag: 318, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,476+0000 INFO  LocalIOProvider LR-Handler(tag: 318, GET) rbuf: RB-LR-Handler(tag: 318, GET)
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 318, GET) unregistering (last)
-2013-08-27 01:14:03,476+0000 INFO  ReadBuffer RB-LR-Handler(tag: 318, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 2640, GET) unregistering (last)
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 2641, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 2641, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 2641, GET) -> 319
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 319, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 319, GET) reader: LR-Handler(tag: 319, GET)
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 319, GET) sending length: 5032, 43341430
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 2641, GET) sending length: 5032, 442457677
-2013-08-27 01:14:03,476+0000 INFO  ReadBuffer RB-LR-Handler(tag: 319, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,476+0000 INFO  ReadBuffer RB-LR-Handler(tag: 319, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,476+0000 INFO  LocalIOProvider LR-Handler(tag: 319, GET) rbuf: RB-LR-Handler(tag: 319, GET)
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 319, GET) unregistering (last)
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 2642, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,476+0000 INFO  ReadBuffer RB-LR-Handler(tag: 319, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 2641, GET) unregistering (last)
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 2642, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 2642, GET) -> 320
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 320, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 320, GET) reader: LR-Handler(tag: 320, GET)
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 320, GET) sending length: 5032, 530634372
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 2642, GET) sending length: 5032, 2019787860
-2013-08-27 01:14:03,476+0000 INFO  ReadBuffer RB-LR-Handler(tag: 320, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,476+0000 INFO  ReadBuffer RB-LR-Handler(tag: 320, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,476+0000 INFO  LocalIOProvider LR-Handler(tag: 320, GET) rbuf: RB-LR-Handler(tag: 320, GET)
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 320, GET) unregistering (last)
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 2643, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,476+0000 INFO  ReadBuffer RB-LR-Handler(tag: 320, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 2642, GET) unregistering (last)
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 2643, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,476+0000 INFO  GetFileHandler Handler(tag: 2643, GET) -> 321
-2013-08-27 01:14:03,477+0000 INFO  GetFileHandler Handler(tag: 321, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,477+0000 INFO  GetFileHandler Handler(tag: 321, GET) reader: LR-Handler(tag: 321, GET)
-2013-08-27 01:14:03,477+0000 INFO  GetFileHandler Handler(tag: 321, GET) sending length: 5032, 710467494
-2013-08-27 01:14:03,477+0000 INFO  GetFileHandler Handler(tag: 2643, GET) sending length: 5032, 818094338
-2013-08-27 01:14:03,477+0000 INFO  ReadBuffer RB-LR-Handler(tag: 321, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,477+0000 INFO  ReadBuffer RB-LR-Handler(tag: 321, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,477+0000 INFO  LocalIOProvider LR-Handler(tag: 321, GET) rbuf: RB-LR-Handler(tag: 321, GET)
-2013-08-27 01:14:03,477+0000 INFO  GetFileHandler Handler(tag: 321, GET) unregistering (last)
-2013-08-27 01:14:03,477+0000 INFO  ReadBuffer RB-LR-Handler(tag: 321, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,477+0000 INFO  GetFileHandler Handler(tag: 2643, GET) unregistering (last)
-2013-08-27 01:14:03,477+0000 INFO  GetFileHandler Handler(tag: 2644, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,477+0000 INFO  GetFileHandler Handler(tag: 2644, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,477+0000 INFO  GetFileHandler Handler(tag: 2644, GET) -> 322
-2013-08-27 01:14:03,477+0000 INFO  GetFileHandler Handler(tag: 322, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,477+0000 INFO  GetFileHandler Handler(tag: 322, GET) reader: LR-Handler(tag: 322, GET)
-2013-08-27 01:14:03,477+0000 INFO  GetFileHandler Handler(tag: 322, GET) sending length: 5032, 856410920
-2013-08-27 01:14:03,477+0000 INFO  GetFileHandler Handler(tag: 2644, GET) sending length: 5032, 1262930246
-2013-08-27 01:14:03,477+0000 INFO  ReadBuffer RB-LR-Handler(tag: 322, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,477+0000 INFO  ReadBuffer RB-LR-Handler(tag: 322, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,477+0000 INFO  LocalIOProvider LR-Handler(tag: 322, GET) rbuf: RB-LR-Handler(tag: 322, GET)
-2013-08-27 01:14:03,477+0000 INFO  GetFileHandler Handler(tag: 2645, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,477+0000 INFO  GetFileHandler Handler(tag: 322, GET) unregistering (last)
-2013-08-27 01:14:03,477+0000 INFO  ReadBuffer RB-LR-Handler(tag: 322, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,477+0000 INFO  GetFileHandler Handler(tag: 2644, GET) unregistering (last)
-2013-08-27 01:14:03,477+0000 INFO  GetFileHandler Handler(tag: 2645, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,477+0000 INFO  GetFileHandler Handler(tag: 2645, GET) -> 323
-2013-08-27 01:14:03,477+0000 INFO  GetFileHandler Handler(tag: 323, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,477+0000 INFO  GetFileHandler Handler(tag: 323, GET) reader: LR-Handler(tag: 323, GET)
-2013-08-27 01:14:03,477+0000 INFO  GetFileHandler Handler(tag: 323, GET) sending length: 5032, 441718654
-2013-08-27 01:14:03,477+0000 INFO  GetFileHandler Handler(tag: 2645, GET) sending length: 5032, 114450099
-2013-08-27 01:14:03,477+0000 INFO  ReadBuffer RB-LR-Handler(tag: 323, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,477+0000 INFO  ReadBuffer RB-LR-Handler(tag: 323, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,477+0000 INFO  LocalIOProvider LR-Handler(tag: 323, GET) rbuf: RB-LR-Handler(tag: 323, GET)
-2013-08-27 01:14:03,477+0000 INFO  GetFileHandler Handler(tag: 323, GET) unregistering (last)
-2013-08-27 01:14:03,477+0000 INFO  GetFileHandler Handler(tag: 2646, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,477+0000 INFO  ReadBuffer RB-LR-Handler(tag: 323, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,477+0000 INFO  GetFileHandler Handler(tag: 2645, GET) unregistering (last)
-2013-08-27 01:14:03,477+0000 INFO  GetFileHandler Handler(tag: 2646, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,477+0000 INFO  GetFileHandler Handler(tag: 2646, GET) -> 324
-2013-08-27 01:14:03,477+0000 INFO  GetFileHandler Handler(tag: 324, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,477+0000 INFO  GetFileHandler Handler(tag: 324, GET) reader: LR-Handler(tag: 324, GET)
-2013-08-27 01:14:03,477+0000 INFO  GetFileHandler Handler(tag: 324, GET) sending length: 5032, 141259909
-2013-08-27 01:14:03,477+0000 INFO  GetFileHandler Handler(tag: 2646, GET) sending length: 5032, 1185860628
-2013-08-27 01:14:03,477+0000 INFO  ReadBuffer RB-LR-Handler(tag: 324, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,477+0000 INFO  ReadBuffer RB-LR-Handler(tag: 324, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,477+0000 INFO  LocalIOProvider LR-Handler(tag: 324, GET) rbuf: RB-LR-Handler(tag: 324, GET)
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 324, GET) unregistering (last)
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 2647, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,478+0000 INFO  ReadBuffer RB-LR-Handler(tag: 324, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 2646, GET) unregistering (last)
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 2647, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 2647, GET) -> 325
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 325, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 325, GET) reader: LR-Handler(tag: 325, GET)
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 325, GET) sending length: 5032, 1579302610
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 2647, GET) sending length: 5032, 441089350
-2013-08-27 01:14:03,478+0000 INFO  ReadBuffer RB-LR-Handler(tag: 325, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,478+0000 INFO  ReadBuffer RB-LR-Handler(tag: 325, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,478+0000 INFO  LocalIOProvider LR-Handler(tag: 325, GET) rbuf: RB-LR-Handler(tag: 325, GET)
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 325, GET) unregistering (last)
-2013-08-27 01:14:03,478+0000 INFO  ReadBuffer RB-LR-Handler(tag: 325, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 2647, GET) unregistering (last)
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 2648, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 2648, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 2648, GET) -> 326
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 326, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 326, GET) reader: LR-Handler(tag: 326, GET)
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 326, GET) sending length: 5032, 969437262
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 2648, GET) sending length: 5032, 373632645
-2013-08-27 01:14:03,478+0000 INFO  ReadBuffer RB-LR-Handler(tag: 326, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,478+0000 INFO  ReadBuffer RB-LR-Handler(tag: 326, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,478+0000 INFO  LocalIOProvider LR-Handler(tag: 326, GET) rbuf: RB-LR-Handler(tag: 326, GET)
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 326, GET) unregistering (last)
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 2649, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 2648, GET) unregistering (last)
-2013-08-27 01:14:03,478+0000 INFO  ReadBuffer RB-LR-Handler(tag: 326, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 2649, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 2649, GET) -> 327
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 327, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 327, GET) reader: LR-Handler(tag: 327, GET)
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 327, GET) sending length: 5032, 179640746
-2013-08-27 01:14:03,478+0000 INFO  ReadBuffer RB-LR-Handler(tag: 327, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:03,478+0000 INFO  ReadBuffer RB-LR-Handler(tag: 327, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 2649, GET) sending length: 5032, 835861492
-2013-08-27 01:14:03,478+0000 INFO  LocalIOProvider LR-Handler(tag: 327, GET) rbuf: RB-LR-Handler(tag: 327, GET)
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 327, GET) unregistering (last)
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 2650, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,478+0000 INFO  ReadBuffer RB-LR-Handler(tag: 327, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 2649, GET) unregistering (last)
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 2650, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 2650, GET) -> 328
-2013-08-27 01:14:03,478+0000 INFO  GetFileHandler Handler(tag: 328, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,479+0000 INFO  GetFileHandler Handler(tag: 328, GET) reader: LR-Handler(tag: 328, GET)
-2013-08-27 01:14:03,479+0000 INFO  GetFileHandler Handler(tag: 328, GET) sending length: 6078, 1235943735
-2013-08-27 01:14:03,479+0000 INFO  GetFileHandler Handler(tag: 2650, GET) sending length: 6078, 2044520361
-2013-08-27 01:14:03,479+0000 INFO  ReadBuffer RB-LR-Handler(tag: 328, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,479+0000 INFO  GetFileHandler Handler(tag: 2651, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,479+0000 INFO  ReadBuffer RB-LR-Handler(tag: 328, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,479+0000 INFO  LocalIOProvider LR-Handler(tag: 328, GET) rbuf: RB-LR-Handler(tag: 328, GET)
-2013-08-27 01:14:03,479+0000 INFO  GetFileHandler Handler(tag: 2651, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,479+0000 INFO  GetFileHandler Handler(tag: 328, GET) unregistering (last)
-2013-08-27 01:14:03,479+0000 INFO  GetFileHandler Handler(tag: 2650, GET) unregistering (last)
-2013-08-27 01:14:03,479+0000 INFO  ReadBuffer RB-LR-Handler(tag: 328, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,479+0000 INFO  GetFileHandler Handler(tag: 2651, GET) -> 329
-2013-08-27 01:14:03,479+0000 INFO  GetFileHandler Handler(tag: 329, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,479+0000 INFO  GetFileHandler Handler(tag: 329, GET) reader: LR-Handler(tag: 329, GET)
-2013-08-27 01:14:03,479+0000 INFO  GetFileHandler Handler(tag: 329, GET) sending length: 6078, 1208820522
-2013-08-27 01:14:03,479+0000 INFO  GetFileHandler Handler(tag: 2651, GET) sending length: 6078, 1451212634
-2013-08-27 01:14:03,479+0000 INFO  ReadBuffer RB-LR-Handler(tag: 329, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,479+0000 INFO  GetFileHandler Handler(tag: 2652, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,479+0000 INFO  ReadBuffer RB-LR-Handler(tag: 329, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,479+0000 INFO  LocalIOProvider LR-Handler(tag: 329, GET) rbuf: RB-LR-Handler(tag: 329, GET)
-2013-08-27 01:14:03,479+0000 INFO  GetFileHandler Handler(tag: 329, GET) unregistering (last)
-2013-08-27 01:14:03,479+0000 INFO  GetFileHandler Handler(tag: 2652, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,479+0000 INFO  ReadBuffer RB-LR-Handler(tag: 329, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,479+0000 INFO  GetFileHandler Handler(tag: 2651, GET) unregistering (last)
-2013-08-27 01:14:03,479+0000 INFO  GetFileHandler Handler(tag: 2652, GET) -> 330
-2013-08-27 01:14:03,479+0000 INFO  GetFileHandler Handler(tag: 330, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,479+0000 INFO  GetFileHandler Handler(tag: 330, GET) reader: LR-Handler(tag: 330, GET)
-2013-08-27 01:14:03,479+0000 INFO  GetFileHandler Handler(tag: 330, GET) sending length: 6078, 1962408005
-2013-08-27 01:14:03,479+0000 INFO  GetFileHandler Handler(tag: 2652, GET) sending length: 6078, 1137489409
-2013-08-27 01:14:03,479+0000 INFO  ReadBuffer RB-LR-Handler(tag: 330, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,479+0000 INFO  ReadBuffer RB-LR-Handler(tag: 330, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,479+0000 INFO  LocalIOProvider LR-Handler(tag: 330, GET) rbuf: RB-LR-Handler(tag: 330, GET)
-2013-08-27 01:14:03,479+0000 INFO  GetFileHandler Handler(tag: 2653, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,479+0000 INFO  GetFileHandler Handler(tag: 330, GET) unregistering (last)
-2013-08-27 01:14:03,479+0000 INFO  GetFileHandler Handler(tag: 2652, GET) unregistering (last)
-2013-08-27 01:14:03,479+0000 INFO  ReadBuffer RB-LR-Handler(tag: 330, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,479+0000 INFO  GetFileHandler Handler(tag: 2653, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,479+0000 INFO  GetFileHandler Handler(tag: 2653, GET) -> 331
-2013-08-27 01:14:03,479+0000 INFO  GetFileHandler Handler(tag: 331, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,479+0000 INFO  GetFileHandler Handler(tag: 331, GET) reader: LR-Handler(tag: 331, GET)
-2013-08-27 01:14:03,479+0000 INFO  GetFileHandler Handler(tag: 331, GET) sending length: 6078, 39795140
-2013-08-27 01:14:03,479+0000 INFO  GetFileHandler Handler(tag: 2653, GET) sending length: 6078, 969503763
-2013-08-27 01:14:03,479+0000 INFO  ReadBuffer RB-LR-Handler(tag: 331, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,479+0000 INFO  GetFileHandler Handler(tag: 2654, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,479+0000 INFO  ReadBuffer RB-LR-Handler(tag: 331, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,480+0000 INFO  LocalIOProvider LR-Handler(tag: 331, GET) rbuf: RB-LR-Handler(tag: 331, GET)
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 331, GET) unregistering (last)
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 2654, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,480+0000 INFO  ReadBuffer RB-LR-Handler(tag: 331, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 2653, GET) unregistering (last)
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 2654, GET) -> 332
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 332, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 332, GET) reader: LR-Handler(tag: 332, GET)
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 332, GET) sending length: 6078, 1018363463
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 2654, GET) sending length: 6078, 190056051
-2013-08-27 01:14:03,480+0000 INFO  ReadBuffer RB-LR-Handler(tag: 332, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,480+0000 INFO  ReadBuffer RB-LR-Handler(tag: 332, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,480+0000 INFO  LocalIOProvider LR-Handler(tag: 332, GET) rbuf: RB-LR-Handler(tag: 332, GET)
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 2655, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 332, GET) unregistering (last)
-2013-08-27 01:14:03,480+0000 INFO  ReadBuffer RB-LR-Handler(tag: 332, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 2654, GET) unregistering (last)
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 2655, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 2655, GET) -> 333
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 333, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 333, GET) reader: LR-Handler(tag: 333, GET)
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 333, GET) sending length: 6078, 525567291
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 2655, GET) sending length: 6078, 609219726
-2013-08-27 01:14:03,480+0000 INFO  ReadBuffer RB-LR-Handler(tag: 333, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,480+0000 INFO  ReadBuffer RB-LR-Handler(tag: 333, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,480+0000 INFO  LocalIOProvider LR-Handler(tag: 333, GET) rbuf: RB-LR-Handler(tag: 333, GET)
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 2656, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 333, GET) unregistering (last)
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 2655, GET) unregistering (last)
-2013-08-27 01:14:03,480+0000 INFO  ReadBuffer RB-LR-Handler(tag: 333, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 2656, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 2656, GET) -> 334
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 334, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 334, GET) reader: LR-Handler(tag: 334, GET)
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 334, GET) sending length: 6078, 854738610
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 2656, GET) sending length: 6078, 1073703487
-2013-08-27 01:14:03,480+0000 INFO  ReadBuffer RB-LR-Handler(tag: 334, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,480+0000 INFO  ReadBuffer RB-LR-Handler(tag: 334, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,480+0000 INFO  LocalIOProvider LR-Handler(tag: 334, GET) rbuf: RB-LR-Handler(tag: 334, GET)
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 2657, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 334, GET) unregistering (last)
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 2656, GET) unregistering (last)
-2013-08-27 01:14:03,480+0000 INFO  ReadBuffer RB-LR-Handler(tag: 334, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 2657, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 2657, GET) -> 335
-2013-08-27 01:14:03,480+0000 INFO  GetFileHandler Handler(tag: 335, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 335, GET) reader: LR-Handler(tag: 335, GET)
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 335, GET) sending length: 6078, 1221495030
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 2657, GET) sending length: 6078, 1870787537
-2013-08-27 01:14:03,481+0000 INFO  ReadBuffer RB-LR-Handler(tag: 335, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,481+0000 INFO  ReadBuffer RB-LR-Handler(tag: 335, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 2658, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,481+0000 INFO  LocalIOProvider LR-Handler(tag: 335, GET) rbuf: RB-LR-Handler(tag: 335, GET)
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 335, GET) unregistering (last)
-2013-08-27 01:14:03,481+0000 INFO  ReadBuffer RB-LR-Handler(tag: 335, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 2657, GET) unregistering (last)
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 2658, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 2658, GET) -> 336
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 336, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 336, GET) reader: LR-Handler(tag: 336, GET)
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 336, GET) sending length: 6078, 1873907781
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 2658, GET) sending length: 6078, 1920392012
-2013-08-27 01:14:03,481+0000 INFO  ReadBuffer RB-LR-Handler(tag: 336, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,481+0000 INFO  ReadBuffer RB-LR-Handler(tag: 336, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,481+0000 INFO  LocalIOProvider LR-Handler(tag: 336, GET) rbuf: RB-LR-Handler(tag: 336, GET)
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 336, GET) unregistering (last)
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 2659, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 2658, GET) unregistering (last)
-2013-08-27 01:14:03,481+0000 INFO  ReadBuffer RB-LR-Handler(tag: 336, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 2659, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 2659, GET) -> 337
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 337, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 337, GET) reader: LR-Handler(tag: 337, GET)
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 337, GET) sending length: 6078, 2108050098
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 2659, GET) sending length: 6078, 812788880
-2013-08-27 01:14:03,481+0000 INFO  ReadBuffer RB-LR-Handler(tag: 337, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,481+0000 INFO  ReadBuffer RB-LR-Handler(tag: 337, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 2660, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,481+0000 INFO  LocalIOProvider LR-Handler(tag: 337, GET) rbuf: RB-LR-Handler(tag: 337, GET)
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 337, GET) unregistering (last)
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 2660, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,481+0000 INFO  ReadBuffer RB-LR-Handler(tag: 337, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 2659, GET) unregistering (last)
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 2660, GET) -> 338
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 338, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 338, GET) reader: LR-Handler(tag: 338, GET)
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 338, GET) sending length: 6078, 422906358
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 2660, GET) sending length: 6078, 1763770983
-2013-08-27 01:14:03,481+0000 INFO  ReadBuffer RB-LR-Handler(tag: 338, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,481+0000 INFO  ReadBuffer RB-LR-Handler(tag: 338, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,481+0000 INFO  LocalIOProvider LR-Handler(tag: 338, GET) rbuf: RB-LR-Handler(tag: 338, GET)
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 2661, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 338, GET) unregistering (last)
-2013-08-27 01:14:03,481+0000 INFO  ReadBuffer RB-LR-Handler(tag: 338, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,481+0000 INFO  GetFileHandler Handler(tag: 2660, GET) unregistering (last)
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 2661, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 2661, GET) -> 339
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 339, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 339, GET) reader: LR-Handler(tag: 339, GET)
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 339, GET) sending length: 6078, 87308272
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 2661, GET) sending length: 6078, 658796603
-2013-08-27 01:14:03,482+0000 INFO  ReadBuffer RB-LR-Handler(tag: 339, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,482+0000 INFO  ReadBuffer RB-LR-Handler(tag: 339, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,482+0000 INFO  LocalIOProvider LR-Handler(tag: 339, GET) rbuf: RB-LR-Handler(tag: 339, GET)
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 2662, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 339, GET) unregistering (last)
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 2661, GET) unregistering (last)
-2013-08-27 01:14:03,482+0000 INFO  ReadBuffer RB-LR-Handler(tag: 339, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 2662, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 2662, GET) -> 340
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 340, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 340, GET) reader: LR-Handler(tag: 340, GET)
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 340, GET) sending length: 6078, 422692628
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 2662, GET) sending length: 6078, 319094520
-2013-08-27 01:14:03,482+0000 INFO  ReadBuffer RB-LR-Handler(tag: 340, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,482+0000 INFO  ReadBuffer RB-LR-Handler(tag: 340, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 2663, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,482+0000 INFO  LocalIOProvider LR-Handler(tag: 340, GET) rbuf: RB-LR-Handler(tag: 340, GET)
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 340, GET) unregistering (last)
-2013-08-27 01:14:03,482+0000 INFO  ReadBuffer RB-LR-Handler(tag: 340, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 2662, GET) unregistering (last)
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 2663, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 2663, GET) -> 341
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 341, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 341, GET) reader: LR-Handler(tag: 341, GET)
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 341, GET) sending length: 6078, 1919339665
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 2663, GET) sending length: 6078, 989888068
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 2664, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,482+0000 INFO  ReadBuffer RB-LR-Handler(tag: 341, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,482+0000 INFO  ReadBuffer RB-LR-Handler(tag: 341, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,482+0000 INFO  LocalIOProvider LR-Handler(tag: 341, GET) rbuf: RB-LR-Handler(tag: 341, GET)
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 2664, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 341, GET) unregistering (last)
-2013-08-27 01:14:03,482+0000 INFO  ReadBuffer RB-LR-Handler(tag: 341, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 2663, GET) unregistering (last)
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 2664, GET) -> 342
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 342, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 342, GET) reader: LR-Handler(tag: 342, GET)
-2013-08-27 01:14:03,482+0000 INFO  GetFileHandler Handler(tag: 342, GET) sending length: 6078, 720758883
-2013-08-27 01:14:03,483+0000 INFO  GetFileHandler Handler(tag: 2664, GET) sending length: 6078, 1986777501
-2013-08-27 01:14:03,483+0000 INFO  ReadBuffer RB-LR-Handler(tag: 342, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,483+0000 INFO  ReadBuffer RB-LR-Handler(tag: 342, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,483+0000 INFO  LocalIOProvider LR-Handler(tag: 342, GET) rbuf: RB-LR-Handler(tag: 342, GET)
-2013-08-27 01:14:03,483+0000 INFO  GetFileHandler Handler(tag: 2665, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,483+0000 INFO  GetFileHandler Handler(tag: 342, GET) unregistering (last)
-2013-08-27 01:14:03,483+0000 INFO  ReadBuffer RB-LR-Handler(tag: 342, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,483+0000 INFO  GetFileHandler Handler(tag: 2664, GET) unregistering (last)
-2013-08-27 01:14:03,483+0000 INFO  GetFileHandler Handler(tag: 2665, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,483+0000 INFO  GetFileHandler Handler(tag: 2665, GET) -> 343
-2013-08-27 01:14:03,483+0000 INFO  GetFileHandler Handler(tag: 343, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:03,483+0000 INFO  GetFileHandler Handler(tag: 343, GET) reader: LR-Handler(tag: 343, GET)
-2013-08-27 01:14:03,483+0000 INFO  GetFileHandler Handler(tag: 343, GET) sending length: 6078, 1203499810
-2013-08-27 01:14:03,483+0000 INFO  GetFileHandler Handler(tag: 2665, GET) sending length: 6078, 72835577
-2013-08-27 01:14:03,483+0000 INFO  ReadBuffer RB-LR-Handler(tag: 343, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:03,483+0000 INFO  ReadBuffer RB-LR-Handler(tag: 343, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,483+0000 INFO  LocalIOProvider LR-Handler(tag: 343, GET) rbuf: RB-LR-Handler(tag: 343, GET)
-2013-08-27 01:14:03,483+0000 INFO  GetFileHandler Handler(tag: 343, GET) unregistering (last)
-2013-08-27 01:14:03,483+0000 INFO  GetFileHandler Handler(tag: 2665, GET) unregistering (last)
-2013-08-27 01:14:03,483+0000 INFO  ReadBuffer RB-LR-Handler(tag: 343, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,484+0000 DEBUG Cpu Active workerid=0827-1301520-000001:000000
-2013-08-27 01:14:03,484+0000 INFO  RequestHandler Handler(tag: 2666, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,484+0000 INFO  RequestHandler Handler(tag: 344, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,485+0000 DEBUG Cpu Active workerid=0827-1301520-000001:000000
-2013-08-27 01:14:03,485+0000 INFO  RequestHandler Handler(tag: 2667, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,485+0000 INFO  RequestHandler Handler(tag: 345, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,486+0000 DEBUG Cpu Active workerid=0827-1301520-000001:000000
-2013-08-27 01:14:03,486+0000 INFO  RequestHandler Handler(tag: 2668, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,486+0000 INFO  RequestHandler Handler(tag: 346, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,486+0000 INFO  RequestHandler Handler(tag: 2669, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,486+0000 INFO  RequestHandler Handler(tag: 347, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,487+0000 DEBUG Cpu Active workerid=0827-1301520-000001:000000
-2013-08-27 01:14:03,487+0000 INFO  RequestHandler Handler(tag: 2670, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,487+0000 INFO  RequestHandler Handler(tag: 348, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,488+0000 DEBUG Cpu Active workerid=0827-1301520-000001:000000
-2013-08-27 01:14:03,488+0000 INFO  RequestHandler Handler(tag: 2671, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,488+0000 INFO  RequestHandler Handler(tag: 349, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,489+0000 DEBUG Cpu Active workerid=0827-1301520-000001:000000
-2013-08-27 01:14:03,489+0000 INFO  RequestHandler Handler(tag: 2672, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,489+0000 INFO  RequestHandler Handler(tag: 350, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,490+0000 DEBUG Cpu Active workerid=0827-1301520-000001:000000
-2013-08-27 01:14:03,490+0000 INFO  RequestHandler Handler(tag: 2673, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,490+0000 INFO  RequestHandler Handler(tag: 351, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,491+0000 DEBUG Cpu Active workerid=0827-1301520-000001:000000
-2013-08-27 01:14:03,491+0000 INFO  RequestHandler Handler(tag: 2674, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,491+0000 INFO  RequestHandler Handler(tag: 352, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,492+0000 DEBUG Cpu Active workerid=0827-1301520-000001:000000
-2013-08-27 01:14:03,492+0000 INFO  RequestHandler Handler(tag: 2675, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,492+0000 INFO  RequestHandler Handler(tag: 353, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,493+0000 DEBUG Cpu Active workerid=0827-1301520-000001:000000
-2013-08-27 01:14:03,493+0000 INFO  RequestHandler Handler(tag: 2676, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,493+0000 INFO  RequestHandler Handler(tag: 354, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,493+0000 INFO  RequestHandler Handler(tag: 355, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,493+0000 INFO  RequestHandler Handler(tag: 2677, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,494+0000 DEBUG Cpu Active workerid=0827-1301520-000001:000000
-2013-08-27 01:14:03,494+0000 INFO  RequestHandler Handler(tag: 2678, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,494+0000 INFO  RequestHandler Handler(tag: 356, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,495+0000 DEBUG Cpu Active workerid=0827-1301520-000001:000000
-2013-08-27 01:14:03,495+0000 INFO  RequestHandler Handler(tag: 2679, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,495+0000 INFO  RequestHandler Handler(tag: 357, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,496+0000 DEBUG Cpu Active workerid=0827-1301520-000001:000000
-2013-08-27 01:14:03,496+0000 INFO  RequestHandler Handler(tag: 2680, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,496+0000 INFO  RequestHandler Handler(tag: 358, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,497+0000 DEBUG Cpu Active workerid=0827-1301520-000001:000000
-2013-08-27 01:14:03,497+0000 INFO  RequestHandler Handler(tag: 2681, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,497+0000 INFO  RequestHandler Handler(tag: 359, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,767+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:03,767+0000 INFO  RequestHandler Handler(tag: 3147, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,767+0000 INFO  RequestHandler Handler(tag: 360, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,768+0000 INFO  PutFileHandler Handler(tag: 3148, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/p/runampl-pcztedel/wrapper.error
-2013-08-27 01:14:03,768+0000 INFO  PutFileHandler Handler(tag: 3148, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-pcztedel.error
-2013-08-27 01:14:03,770+0000 INFO  PutFileCommand Sending Command(tag: 361, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,771+0000 INFO  PutFileCommand Command(tag: 361, PUT) (t) sending data
-2013-08-27 01:14:03,771+0000 INFO  PutFileHandler Handler(tag: 3148, PUT) -> 361
-2013-08-27 01:14:03,771+0000 INFO  PutFileHandler Handler(tag: 361, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/p/runampl-pcztedel/wrapper.error
-2013-08-27 01:14:03,771+0000 INFO  PutFileHandler Handler(tag: 361, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-pcztedel.error
-2013-08-27 01:14:03,771+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:03,771+0000 INFO  RequestHandler Handler(tag: 3149, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,771+0000 INFO  PutFileHandler Handler(tag: 3150, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/p/runampl-pcztedel/wrapper.log
-2013-08-27 01:14:03,771+0000 INFO  PutFileHandler Handler(tag: 3150, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-pcztedel.info
-2013-08-27 01:14:03,771+0000 INFO  PutFileCommand Sending Command(tag: 363, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,771+0000 INFO  PutFileCommand Command(tag: 363, PUT) (t) sending data
-2013-08-27 01:14:03,771+0000 INFO  PutFileHandler Handler(tag: 3150, PUT) -> 363
-2013-08-27 01:14:03,772+0000 INFO  RequestHandler Handler(tag: 362, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,772+0000 INFO  PutFileHandler Handler(tag: 363, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/p/runampl-pcztedel/wrapper.log
-2013-08-27 01:14:03,772+0000 INFO  PutFileHandler Handler(tag: 363, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-pcztedel.info
-2013-08-27 01:14:03,779+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:03,779+0000 INFO  RequestHandler Handler(tag: 3151, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,779+0000 INFO  RequestHandler Handler(tag: 364, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,779+0000 INFO  PutFileHandler Handler(tag: 3152, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/5/runampl-5cztedel/wrapper.error
-2013-08-27 01:14:03,779+0000 INFO  PutFileHandler Handler(tag: 3152, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-5cztedel.error
-2013-08-27 01:14:03,779+0000 INFO  PutFileCommand Sending Command(tag: 365, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,779+0000 INFO  PutFileCommand Command(tag: 365, PUT) (t) sending data
-2013-08-27 01:14:03,779+0000 INFO  PutFileHandler Handler(tag: 3152, PUT) -> 365
-2013-08-27 01:14:03,779+0000 INFO  PutFileHandler Handler(tag: 365, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/5/runampl-5cztedel/wrapper.error
-2013-08-27 01:14:03,779+0000 INFO  PutFileHandler Handler(tag: 365, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-5cztedel.error
-2013-08-27 01:14:03,779+0000 INFO  RequestHandler Handler(tag: 3153, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,779+0000 INFO  RequestHandler Handler(tag: 366, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,779+0000 INFO  PutFileHandler Handler(tag: 3154, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/5/runampl-5cztedel/wrapper.log
-2013-08-27 01:14:03,779+0000 INFO  PutFileHandler Handler(tag: 3154, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-5cztedel.info
-2013-08-27 01:14:03,779+0000 INFO  PutFileCommand Sending Command(tag: 367, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,779+0000 INFO  PutFileCommand Command(tag: 367, PUT) (t) sending data
-2013-08-27 01:14:03,779+0000 INFO  PutFileHandler Handler(tag: 3154, PUT) -> 367
-2013-08-27 01:14:03,779+0000 INFO  PutFileHandler Handler(tag: 367, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/5/runampl-5cztedel/wrapper.log
-2013-08-27 01:14:03,779+0000 INFO  PutFileHandler Handler(tag: 367, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-5cztedel.info
-2013-08-27 01:14:03,780+0000 INFO  PutFileHandler Handler(tag: 361, PUT) Transfer done
-2013-08-27 01:14:03,780+0000 INFO  RequestHandler Handler(tag: 361, PUT) unregistering (send)
-2013-08-27 01:14:03,780+0000 INFO  PutFileHandler Handler(tag: 3148, PUT) Transfer done
-2013-08-27 01:14:03,780+0000 INFO  RequestHandler Handler(tag: 3148, PUT) unregistering (send)
-2013-08-27 01:14:03,783+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:03,783+0000 INFO  RequestHandler Handler(tag: 3155, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,783+0000 INFO  RequestHandler Handler(tag: 368, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,783+0000 INFO  PutFileHandler Handler(tag: 3156, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/s/runampl-scztedel/wrapper.log
-2013-08-27 01:14:03,783+0000 INFO  PutFileHandler Handler(tag: 3156, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-scztedel.info
-2013-08-27 01:14:03,783+0000 INFO  PutFileCommand Sending Command(tag: 369, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,783+0000 INFO  PutFileCommand Command(tag: 369, PUT) (t) sending data
-2013-08-27 01:14:03,783+0000 INFO  PutFileHandler Handler(tag: 3156, PUT) -> 369
-2013-08-27 01:14:03,783+0000 INFO  PutFileHandler Handler(tag: 369, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/s/runampl-scztedel/wrapper.log
-2013-08-27 01:14:03,783+0000 INFO  PutFileHandler Handler(tag: 369, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-scztedel.info
-2013-08-27 01:14:03,784+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:03,784+0000 INFO  PutFileHandler Handler(tag: 363, PUT) Transfer done
-2013-08-27 01:14:03,784+0000 INFO  RequestHandler Handler(tag: 3157, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,784+0000 INFO  RequestHandler Handler(tag: 363, PUT) unregistering (send)
-2013-08-27 01:14:03,784+0000 INFO  RequestHandler Handler(tag: 370, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,784+0000 INFO  PutFileHandler Handler(tag: 3150, PUT) Transfer done
-2013-08-27 01:14:03,784+0000 INFO  RequestHandler Handler(tag: 3150, PUT) unregistering (send)
-2013-08-27 01:14:03,784+0000 INFO  PutFileHandler Handler(tag: 3158, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/s/runampl-scztedel/wrapper.error
-2013-08-27 01:14:03,784+0000 INFO  PutFileHandler Handler(tag: 3158, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-scztedel.error
-2013-08-27 01:14:03,784+0000 INFO  PutFileCommand Sending Command(tag: 371, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,784+0000 INFO  PutFileCommand Command(tag: 371, PUT) (t) sending data
-2013-08-27 01:14:03,784+0000 INFO  PutFileHandler Handler(tag: 3158, PUT) -> 371
-2013-08-27 01:14:03,784+0000 INFO  PutFileHandler Handler(tag: 371, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/s/runampl-scztedel/wrapper.error
-2013-08-27 01:14:03,784+0000 INFO  PutFileHandler Handler(tag: 371, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-scztedel.error
-2013-08-27 01:14:03,785+0000 INFO  PutFileHandler Handler(tag: 365, PUT) Transfer done
-2013-08-27 01:14:03,785+0000 INFO  RequestHandler Handler(tag: 365, PUT) unregistering (send)
-2013-08-27 01:14:03,785+0000 INFO  PutFileHandler Handler(tag: 3152, PUT) Transfer done
-2013-08-27 01:14:03,785+0000 INFO  RequestHandler Handler(tag: 3152, PUT) unregistering (send)
-2013-08-27 01:14:03,786+0000 INFO  PutFileHandler Handler(tag: 367, PUT) Transfer done
-2013-08-27 01:14:03,786+0000 INFO  RequestHandler Handler(tag: 367, PUT) unregistering (send)
-2013-08-27 01:14:03,786+0000 INFO  PutFileHandler Handler(tag: 3154, PUT) Transfer done
-2013-08-27 01:14:03,786+0000 INFO  RequestHandler Handler(tag: 3154, PUT) unregistering (send)
-2013-08-27 01:14:03,787+0000 INFO  PutFileHandler Handler(tag: 369, PUT) Transfer done
-2013-08-27 01:14:03,787+0000 INFO  RequestHandler Handler(tag: 369, PUT) unregistering (send)
-2013-08-27 01:14:03,787+0000 INFO  PutFileHandler Handler(tag: 3156, PUT) Transfer done
-2013-08-27 01:14:03,787+0000 INFO  RequestHandler Handler(tag: 3156, PUT) unregistering (send)
-2013-08-27 01:14:03,788+0000 DEBUG Cpu Failed Job failed with and exit code of 1
-2013-08-27 01:14:03,788+0000 INFO  Cpu 0827-1301520-000000:6 jobTerminated
-2013-08-27 01:14:03,788+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=6
-2013-08-27 01:14:03,788+0000 INFO  RequestHandler Handler(tag: 3159, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,788+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=6 Cpus sleeping: 1
-2013-08-27 01:14:03,788+0000 DEBUG Cpu 0827-1301520-000000:6 sleeping
-2013-08-27 01:14:03,788+0000 INFO  PutFileHandler Handler(tag: 371, PUT) Transfer done
-2013-08-27 01:14:03,788+0000 INFO  RequestHandler Handler(tag: 371, PUT) unregistering (send)
-2013-08-27 01:14:03,788+0000 INFO  Cpu 0827-1301520-000000:7 jobTerminated
-2013-08-27 01:14:03,788+0000 INFO  PutFileHandler Handler(tag: 3158, PUT) Transfer done
-2013-08-27 01:14:03,788+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=7
-2013-08-27 01:14:03,788+0000 INFO  RequestHandler Handler(tag: 3158, PUT) unregistering (send)
-2013-08-27 01:14:03,789+0000 INFO  RequestHandler Handler(tag: 3160, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,789+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=7 Cpus sleeping: 2
-2013-08-27 01:14:03,789+0000 DEBUG Cpu 0827-1301520-000000:7 sleeping
-2013-08-27 01:14:03,789+0000 INFO  RequestHandler Handler(tag: 372, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,789+0000 INFO  RequestHandler Handler(tag: 373, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,789+0000 DEBUG Cpu Failed Job failed with and exit code of 1
-2013-08-27 01:14:03,789+0000 INFO  Cpu 0827-1301520-000000:5 jobTerminated
-2013-08-27 01:14:03,789+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=5
-2013-08-27 01:14:03,789+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=5 Cpus sleeping: 3
-2013-08-27 01:14:03,789+0000 INFO  RequestHandler Handler(tag: 3161, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,789+0000 DEBUG Cpu 0827-1301520-000000:5 sleeping
-2013-08-27 01:14:03,789+0000 INFO  RequestHandler Handler(tag: 374, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,790+0000 INFO  LateBindingScheduler jobs queued: 1
-2013-08-27 01:14:03,791+0000 INFO  LateBindingScheduler jobs queued: 1
-2013-08-27 01:14:03,791+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-5cztedel - Application exception: Job failed with and exit code of 1
-org.globus.cog.abstraction.impl.common.execution.JobException: Job failed with and exit code of 1 (exit code: 1)
-	at org.globus.cog.abstraction.coaster.service.local.JobStatusHandler.requestComplete(JobStatusHandler.java:40)
-	at org.globus.cog.coaster.handlers.RequestHandler.receiveCompleted(RequestHandler.java:88)
-	at org.globus.cog.coaster.channels.AbstractCoasterChannel.handleRequest(AbstractCoasterChannel.java:527)
-	at org.globus.cog.coaster.channels.AbstractStreamCoasterChannel.stepNIO(AbstractStreamCoasterChannel.java:238)
-	at org.globus.cog.coaster.channels.NIOMultiplexer.loop(NIOMultiplexer.java:97)
-	at org.globus.cog.coaster.channels.NIOMultiplexer.run(NIOMultiplexer.java:56)
-Caused by: org.globus.cog.abstraction.impl.common.execution.JobException: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:03,791+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-pcztedel - Application exception: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:03,792+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-scztedel - Application exception: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:03,793+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-2dztedel thread=R-42-0-1x2-20-0 host=midway replicationGroup=null
-2013-08-27 01:14:03,793+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-3dztedel thread=R-42-0-1x2-18-0 host=midway replicationGroup=null
-2013-08-27 01:14:03,793+0000 DEBUG swift JOB_START jobid=runampl-2dztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0020.out, outdir/xhat_l20000_0001.0020.out, obj_outdir/obj_out_l0000_0001.0020.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0020.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/2/runampl-2dztedel host=midway
-2013-08-27 01:14:03,793+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-4dztedel thread=R-42-0-1x3-0 host=midway replicationGroup=null
-2013-08-27 01:14:03,793+0000 DEBUG swift JOB_START jobid=runampl-3dztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0018.out, outdir/xhat_l20000_0001.0018.out, obj_outdir/obj_out_l0000_0001.0018.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0018.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/3/runampl-3dztedel host=midway
-2013-08-27 01:14:03,793+0000 DEBUG swift JOB_START jobid=runampl-4dztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0001.out, outdir/xhat_l20000_0001.0001.out, obj_outdir/obj_out_l0000_0001.0001.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0001.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/4/runampl-4dztedel host=midway
-2013-08-27 01:14:03,795+0000 INFO  RequestHandler Handler(tag: 34, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:03,795+0000 INFO  RequestHandler Handler(tag: 35, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:03,796+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:03,796+0000 INFO  RequestHandler Handler(tag: 3162, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,796+0000 INFO  RequestHandler Handler(tag: 375, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,796+0000 INFO  PutFileHandler Handler(tag: 3163, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/b/runampl-bcztedel/wrapper.error
-2013-08-27 01:14:03,796+0000 INFO  PutFileHandler Handler(tag: 3163, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-bcztedel.error
-2013-08-27 01:14:03,796+0000 INFO  PutFileCommand Sending Command(tag: 376, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,796+0000 INFO  PutFileCommand Command(tag: 376, PUT) (t) sending data
-2013-08-27 01:14:03,796+0000 INFO  PutFileHandler Handler(tag: 3163, PUT) -> 376
-2013-08-27 01:14:03,796+0000 INFO  PutFileHandler Handler(tag: 376, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/b/runampl-bcztedel/wrapper.error
-2013-08-27 01:14:03,796+0000 INFO  PutFileHandler Handler(tag: 376, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-bcztedel.error
-2013-08-27 01:14:03,796+0000 INFO  RequestHandler Handler(tag: 36, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:03,796+0000 INFO  RequestHandler Handler(tag: 377, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,796+0000 INFO  RequestHandler Handler(tag: 3164, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,796+0000 INFO  PutFileHandler Handler(tag: 3165, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/b/runampl-bcztedel/wrapper.log
-2013-08-27 01:14:03,796+0000 INFO  PutFileHandler Handler(tag: 3165, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-bcztedel.info
-2013-08-27 01:14:03,796+0000 INFO  PutFileCommand Sending Command(tag: 378, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,797+0000 INFO  PutFileCommand Command(tag: 378, PUT) (t) sending data
-2013-08-27 01:14:03,797+0000 INFO  PutFileHandler Handler(tag: 3165, PUT) -> 378
-2013-08-27 01:14:03,797+0000 INFO  PutFileHandler Handler(tag: 378, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/b/runampl-bcztedel/wrapper.log
-2013-08-27 01:14:03,797+0000 INFO  PutFileHandler Handler(tag: 378, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-bcztedel.info
-2013-08-27 01:14:03,797+0000 INFO  PutFileHandler Handler(tag: 376, PUT) Transfer done
-2013-08-27 01:14:03,797+0000 INFO  RequestHandler Handler(tag: 376, PUT) unregistering (send)
-2013-08-27 01:14:03,797+0000 INFO  PutFileHandler Handler(tag: 3163, PUT) Transfer done
-2013-08-27 01:14:03,797+0000 INFO  RequestHandler Handler(tag: 3163, PUT) unregistering (send)
-2013-08-27 01:14:03,798+0000 INFO  PutFileHandler Handler(tag: 378, PUT) Transfer done
-2013-08-27 01:14:03,799+0000 INFO  RequestHandler Handler(tag: 378, PUT) unregistering (send)
-2013-08-27 01:14:03,799+0000 INFO  PutFileHandler Handler(tag: 3165, PUT) Transfer done
-2013-08-27 01:14:03,799+0000 INFO  RequestHandler Handler(tag: 3165, PUT) unregistering (send)
-2013-08-27 01:14:03,801+0000 DEBUG Cpu Failed Job failed with and exit code of 1
-2013-08-27 01:14:03,801+0000 INFO  Cpu 0827-1301520-000000:2 jobTerminated
-2013-08-27 01:14:03,801+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=2
-2013-08-27 01:14:03,801+0000 INFO  RequestHandler Handler(tag: 3166, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,801+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=2 Cpus sleeping: 4
-2013-08-27 01:14:03,801+0000 INFO  Cpu 0827-1301520-000000:2 (quality: 0.5) submitting urn:1377566032080-1377566032083-1377566032084: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0001.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0001.out|outdir/xhat_l10000_000
 1.0001.out|outdir/xhat_l20000_0001.0001.out|Results/ampl_res_l0000_0001.0001.out|outdir/out_l0000_0001.0001.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0001.out outdir/xhat_l20000_0001.0001.out obj_outdir/obj_out_l0000_0001.0001.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0001.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,801+0000 INFO  RequestHandler Handler(tag: 379, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,801+0000 INFO  RequestHandler Handler(tag: 380, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,801+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=5 Cpus sleeping: 1
-2013-08-27 01:14:03,801+0000 INFO  Cpu 0827-1301520-000000:5 (quality: 0.5) submitting urn:1377566032081-1377566032086-1377566032087: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0018.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0018.out|outdir/xhat_l10000_000
 1.0018.out|outdir/xhat_l20000_0001.0018.out|Results/ampl_res_l0000_0001.0018.out|outdir/out_l0000_0001.0018.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0018.out outdir/xhat_l20000_0001.0018.out obj_outdir/obj_out_l0000_0001.0018.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0018.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,802+0000 INFO  RequestHandler Handler(tag: 381, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,802+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=6 Cpus sleeping: 1
-2013-08-27 01:14:03,802+0000 INFO  Cpu 0827-1301520-000000:6 (quality: 0.5) submitting urn:1377566032079-1377566032089-1377566032090: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0020.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0020.out|outdir/xhat_l10000_000
 1.0020.out|outdir/xhat_l20000_0001.0020.out|Results/ampl_res_l0000_0001.0020.out|outdir/out_l0000_0001.0020.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0020.out outdir/xhat_l20000_0001.0020.out obj_outdir/obj_out_l0000_0001.0020.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0020.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,802+0000 INFO  RequestHandler Handler(tag: 382, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,802+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=7 Cpus sleeping: 1
-2013-08-27 01:14:03,802+0000 INFO  LateBindingScheduler jobs queued: 1
-2013-08-27 01:14:03,802+0000 DEBUG Cpu 0827-1301520-000000:7 sleeping
-2013-08-27 01:14:03,803+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-bcztedel - Application exception: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:03,803+0000 INFO  RequestHandler Handler(tag: 383, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,803+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:14:03,803+0000 INFO  RequestHandler Handler(tag: 3167, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,803+0000 INFO  RequestHandler Handler(tag: 384, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,803+0000 INFO  GetFileHandler Handler(tag: 3168, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:03,803+0000 INFO  GetFileHandler Handler(tag: 3168, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:03,803+0000 INFO  GetFileHandler Handler(tag: 3168, GET) -> 385
-2013-08-27 01:14:03,804+0000 INFO  GetFileHandler Handler(tag: 385, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:03,804+0000 INFO  GetFileHandler Handler(tag: 385, GET) reader: LR-Handler(tag: 385, GET)
-2013-08-27 01:14:03,804+0000 INFO  GetFileHandler Handler(tag: 385, GET) sending length: 1925, 60241307
-2013-08-27 01:14:03,804+0000 INFO  ReadBuffer RB-LR-Handler(tag: 385, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:03,804+0000 INFO  GetFileHandler Handler(tag: 3168, GET) sending length: 1925, 1010849012
-2013-08-27 01:14:03,804+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-5dztedel thread=R-42-0-1-0-3-0 host=midway replicationGroup=null
-2013-08-27 01:14:03,804+0000 INFO  ReadBuffer RB-LR-Handler(tag: 385, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,804+0000 INFO  LocalIOProvider LR-Handler(tag: 385, GET) rbuf: RB-LR-Handler(tag: 385, GET)
-2013-08-27 01:14:03,804+0000 INFO  GetFileHandler Handler(tag: 385, GET) unregistering (last)
-2013-08-27 01:14:03,804+0000 INFO  ReadBuffer RB-LR-Handler(tag: 385, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,804+0000 INFO  GetFileHandler Handler(tag: 3168, GET) unregistering (last)
-2013-08-27 01:14:03,804+0000 DEBUG swift JOB_START jobid=runampl-5dztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0000.0003.out, outdir/xhat_l20000_0000.0003.out, obj_outdir/obj_out_l0000_0000.0003.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0000.0003.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/5/runampl-5dztedel host=midway
-2013-08-27 01:14:03,804+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:03,804+0000 INFO  RequestHandler Handler(tag: 3169, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,804+0000 INFO  RequestHandler Handler(tag: 386, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,804+0000 INFO  PutFileHandler Handler(tag: 3170, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/k/runampl-kcztedel/wrapper.error
-2013-08-27 01:14:03,804+0000 INFO  PutFileHandler Handler(tag: 3170, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-kcztedel.error
-2013-08-27 01:14:03,804+0000 INFO  PutFileCommand Sending Command(tag: 387, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,804+0000 INFO  PutFileCommand Command(tag: 387, PUT) (t) sending data
-2013-08-27 01:14:03,804+0000 INFO  PutFileHandler Handler(tag: 3170, PUT) -> 387
-2013-08-27 01:14:03,804+0000 INFO  PutFileHandler Handler(tag: 387, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/k/runampl-kcztedel/wrapper.error
-2013-08-27 01:14:03,804+0000 INFO  PutFileHandler Handler(tag: 387, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-kcztedel.error
-2013-08-27 01:14:03,805+0000 INFO  RequestHandler Handler(tag: 388, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,805+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:14:03,805+0000 INFO  RequestHandler Handler(tag: 3171, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,805+0000 INFO  RequestHandler Handler(tag: 389, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,805+0000 INFO  GetFileHandler Handler(tag: 3172, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:03,805+0000 INFO  GetFileHandler Handler(tag: 3172, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:03,805+0000 INFO  GetFileHandler Handler(tag: 3172, GET) -> 390
-2013-08-27 01:14:03,805+0000 INFO  GetFileHandler Handler(tag: 390, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:03,805+0000 INFO  GetFileHandler Handler(tag: 390, GET) reader: LR-Handler(tag: 390, GET)
-2013-08-27 01:14:03,805+0000 INFO  GetFileHandler Handler(tag: 390, GET) sending length: 1925, 280400968
-2013-08-27 01:14:03,805+0000 INFO  ReadBuffer RB-LR-Handler(tag: 390, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:03,805+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:03,805+0000 INFO  ReadBuffer RB-LR-Handler(tag: 390, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,805+0000 INFO  LocalIOProvider LR-Handler(tag: 390, GET) rbuf: RB-LR-Handler(tag: 390, GET)
-2013-08-27 01:14:03,805+0000 INFO  RequestHandler Handler(tag: 3173, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,805+0000 INFO  GetFileHandler Handler(tag: 390, GET) unregistering (last)
-2013-08-27 01:14:03,805+0000 INFO  ReadBuffer RB-LR-Handler(tag: 390, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,805+0000 INFO  RequestHandler Handler(tag: 391, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,805+0000 INFO  PutFileHandler Handler(tag: 3174, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/k/runampl-kcztedel/wrapper.log
-2013-08-27 01:14:03,805+0000 INFO  PutFileHandler Handler(tag: 3174, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-kcztedel.info
-2013-08-27 01:14:03,806+0000 INFO  PutFileCommand Sending Command(tag: 392, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,806+0000 INFO  PutFileCommand Command(tag: 392, PUT) (t) sending data
-2013-08-27 01:14:03,806+0000 INFO  PutFileHandler Handler(tag: 3174, PUT) -> 392
-2013-08-27 01:14:03,806+0000 INFO  PutFileHandler Handler(tag: 392, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/k/runampl-kcztedel/wrapper.log
-2013-08-27 01:14:03,806+0000 INFO  PutFileHandler Handler(tag: 392, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-kcztedel.info
-2013-08-27 01:14:03,806+0000 INFO  RequestHandler Handler(tag: 37, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:03,806+0000 INFO  GetFileHandler Handler(tag: 3172, GET) sending length: 1925, 1715600847
-2013-08-27 01:14:03,806+0000 INFO  PutFileHandler Handler(tag: 387, PUT) Transfer done
-2013-08-27 01:14:03,806+0000 INFO  RequestHandler Handler(tag: 387, PUT) unregistering (send)
-2013-08-27 01:14:03,806+0000 INFO  PutFileHandler Handler(tag: 3170, PUT) Transfer done
-2013-08-27 01:14:03,806+0000 INFO  RequestHandler Handler(tag: 3170, PUT) unregistering (send)
-2013-08-27 01:14:03,807+0000 INFO  GetFileHandler Handler(tag: 3172, GET) unregistering (last)
-2013-08-27 01:14:03,807+0000 INFO  PutFileHandler Handler(tag: 392, PUT) Transfer done
-2013-08-27 01:14:03,807+0000 INFO  RequestHandler Handler(tag: 392, PUT) unregistering (send)
-2013-08-27 01:14:03,807+0000 INFO  PutFileHandler Handler(tag: 3174, PUT) Transfer done
-2013-08-27 01:14:03,807+0000 INFO  RequestHandler Handler(tag: 3174, PUT) unregistering (send)
-2013-08-27 01:14:03,811+0000 INFO  RequestHandler Handler(tag: 393, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,811+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:14:03,811+0000 INFO  RequestHandler Handler(tag: 3175, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,811+0000 INFO  RequestHandler Handler(tag: 394, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,811+0000 INFO  GetFileHandler Handler(tag: 3176, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:03,811+0000 INFO  GetFileHandler Handler(tag: 3176, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:03,811+0000 INFO  GetFileHandler Handler(tag: 3176, GET) -> 395
-2013-08-27 01:14:03,811+0000 INFO  GetFileHandler Handler(tag: 395, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:03,811+0000 INFO  GetFileHandler Handler(tag: 395, GET) reader: LR-Handler(tag: 395, GET)
-2013-08-27 01:14:03,811+0000 INFO  GetFileHandler Handler(tag: 395, GET) sending length: 1925, 2078468944
-2013-08-27 01:14:03,811+0000 INFO  GetFileHandler Handler(tag: 3176, GET) sending length: 1925, 1858539706
-2013-08-27 01:14:03,811+0000 INFO  ReadBuffer RB-LR-Handler(tag: 395, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:03,811+0000 INFO  ReadBuffer RB-LR-Handler(tag: 395, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,811+0000 INFO  LocalIOProvider LR-Handler(tag: 395, GET) rbuf: RB-LR-Handler(tag: 395, GET)
-2013-08-27 01:14:03,811+0000 INFO  GetFileHandler Handler(tag: 395, GET) unregistering (last)
-2013-08-27 01:14:03,812+0000 INFO  ReadBuffer RB-LR-Handler(tag: 395, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,812+0000 INFO  GetFileHandler Handler(tag: 3176, GET) unregistering (last)
-2013-08-27 01:14:03,812+0000 INFO  GetFileHandler Handler(tag: 3177, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:03,812+0000 INFO  GetFileHandler Handler(tag: 3177, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:03,812+0000 INFO  GetFileHandler Handler(tag: 3177, GET) -> 396
-2013-08-27 01:14:03,812+0000 INFO  GetFileHandler Handler(tag: 396, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:03,812+0000 INFO  GetFileHandler Handler(tag: 396, GET) reader: LR-Handler(tag: 396, GET)
-2013-08-27 01:14:03,812+0000 INFO  GetFileHandler Handler(tag: 396, GET) sending length: 14799449, 1688878172
-2013-08-27 01:14:03,812+0000 INFO  GetFileHandler Handler(tag: 3177, GET) sending length: 14799449, 1684074405
-2013-08-27 01:14:03,812+0000 INFO  ReadBuffer RB-LR-Handler(tag: 396, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:03,812+0000 INFO  ReadBuffer RB-LR-Handler(tag: 396, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:03,812+0000 INFO  LocalIOProvider LR-Handler(tag: 396, GET) rbuf: RB-LR-Handler(tag: 396, GET)
-2013-08-27 01:14:03,812+0000 INFO  GetFileHandler Handler(tag: 3178, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:03,812+0000 INFO  GetFileHandler Handler(tag: 3178, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:03,812+0000 INFO  GetFileHandler Handler(tag: 3178, GET) -> 397
-2013-08-27 01:14:03,812+0000 INFO  GetFileHandler Handler(tag: 397, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:03,812+0000 INFO  GetFileHandler Handler(tag: 397, GET) reader: LR-Handler(tag: 397, GET)
-2013-08-27 01:14:03,812+0000 INFO  GetFileHandler Handler(tag: 397, GET) sending length: 14799449, 128557122
-2013-08-27 01:14:03,812+0000 INFO  ReadBuffer RB-LR-Handler(tag: 397, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:03,812+0000 INFO  GetFileHandler Handler(tag: 3178, GET) sending length: 14799449, 291000572
-2013-08-27 01:14:03,812+0000 INFO  ReadBuffer RB-LR-Handler(tag: 397, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:03,812+0000 INFO  LocalIOProvider LR-Handler(tag: 397, GET) rbuf: RB-LR-Handler(tag: 397, GET)
-2013-08-27 01:14:03,813+0000 DEBUG Cpu Failed Job failed with and exit code of 1
-2013-08-27 01:14:03,813+0000 INFO  Cpu 0827-1301520-000000:4 jobTerminated
-2013-08-27 01:14:03,813+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=4
-2013-08-27 01:14:03,813+0000 INFO  RequestHandler Handler(tag: 3179, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,813+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=4 Cpus sleeping: 2
-2013-08-27 01:14:03,813+0000 INFO  Cpu 0827-1301520-000000:4 (quality: 0.5) submitting urn:1377566032095-1377566032097-1377566032098: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0000.0003.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0000.0003.out|outdir/xhat_l10000_000
 0.0003.out|outdir/xhat_l20000_0000.0003.out|Results/ampl_res_l0000_0000.0003.out|outdir/out_l0000_0000.0003.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0000.0003.out outdir/xhat_l20000_0000.0003.out obj_outdir/obj_out_l0000_0000.0003.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0000.0003.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,813+0000 INFO  GetFileHandler Handler(tag: 3180, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:03,813+0000 INFO  RequestHandler Handler(tag: 398, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,813+0000 INFO  GetFileHandler Handler(tag: 3180, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:03,813+0000 INFO  GetFileHandler Handler(tag: 3180, GET) -> 400
-2013-08-27 01:14:03,813+0000 INFO  RequestHandler Handler(tag: 399, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,813+0000 INFO  GetFileHandler Handler(tag: 400, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:03,813+0000 INFO  GetFileHandler Handler(tag: 400, GET) reader: LR-Handler(tag: 400, GET)
-2013-08-27 01:14:03,813+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=7 Cpus sleeping: 1
-2013-08-27 01:14:03,813+0000 INFO  GetFileHandler Handler(tag: 400, GET) sending length: 14799449, 1001004128
-2013-08-27 01:14:03,813+0000 DEBUG Cpu 0827-1301520-000000:7 sleeping
-2013-08-27 01:14:03,813+0000 INFO  GetFileHandler Handler(tag: 3180, GET) sending length: 14799449, 489488698
-2013-08-27 01:14:03,813+0000 INFO  ReadBuffer RB-LR-Handler(tag: 400, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:03,813+0000 INFO  ReadBuffer RB-LR-Handler(tag: 400, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:03,813+0000 INFO  LocalIOProvider LR-Handler(tag: 400, GET) rbuf: RB-LR-Handler(tag: 400, GET)
-2013-08-27 01:14:03,814+0000 INFO  LateBindingScheduler jobs queued: 1
-2013-08-27 01:14:03,815+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-kcztedel - Application exception: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:03,816+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-6dztedel thread=R-42-0-1x2-8-0 host=midway replicationGroup=null
-2013-08-27 01:14:03,816+0000 DEBUG swift JOB_START jobid=runampl-6dztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0008.out, outdir/xhat_l20000_0001.0008.out, obj_outdir/obj_out_l0000_0001.0008.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0008.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/6/runampl-6dztedel host=midway
-2013-08-27 01:14:03,818+0000 INFO  RequestHandler Handler(tag: 38, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:03,824+0000 INFO  RequestHandler Handler(tag: 401, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,824+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:14:03,824+0000 INFO  RequestHandler Handler(tag: 3181, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,824+0000 INFO  RequestHandler Handler(tag: 402, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,824+0000 INFO  GetFileHandler Handler(tag: 3182, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:03,824+0000 INFO  GetFileHandler Handler(tag: 3182, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:03,825+0000 INFO  GetFileHandler Handler(tag: 3182, GET) -> 403
-2013-08-27 01:14:03,825+0000 INFO  GetFileHandler Handler(tag: 403, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:03,825+0000 INFO  GetFileHandler Handler(tag: 403, GET) reader: LR-Handler(tag: 403, GET)
-2013-08-27 01:14:03,825+0000 INFO  GetFileHandler Handler(tag: 403, GET) sending length: 1925, 376821660
-2013-08-27 01:14:03,825+0000 INFO  ReadBuffer RB-LR-Handler(tag: 403, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:03,825+0000 INFO  ReadBuffer RB-LR-Handler(tag: 403, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:03,825+0000 INFO  LocalIOProvider LR-Handler(tag: 403, GET) rbuf: RB-LR-Handler(tag: 403, GET)
-2013-08-27 01:14:03,825+0000 INFO  GetFileHandler Handler(tag: 403, GET) unregistering (last)
-2013-08-27 01:14:03,825+0000 INFO  ReadBuffer RB-LR-Handler(tag: 403, GET) de-allocating 1 buffers
-2013-08-27 01:14:03,825+0000 INFO  GetFileHandler Handler(tag: 3182, GET) sending length: 1925, 1462084651
-2013-08-27 01:14:03,825+0000 INFO  GetFileHandler Handler(tag: 3182, GET) unregistering (last)
-2013-08-27 01:14:03,834+0000 INFO  ProxyIOProvider Command(tag: 396, GET) suspending
-2013-08-27 01:14:03,834+0000 INFO  GetFileHandler Handler(tag: 396, GET) suspending
-2013-08-27 01:14:03,834+0000 INFO  ProxyIOProvider Command(tag: 397, GET) suspending
-2013-08-27 01:14:03,834+0000 INFO  GetFileHandler Handler(tag: 397, GET) suspending
-2013-08-27 01:14:03,834+0000 INFO  ProxyIOProvider Command(tag: 400, GET) suspending
-2013-08-27 01:14:03,834+0000 INFO  GetFileHandler Handler(tag: 400, GET) suspending
-2013-08-27 01:14:03,834+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:03,834+0000 INFO  RequestHandler Handler(tag: 3183, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,834+0000 INFO  RequestHandler Handler(tag: 404, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,834+0000 INFO  PutFileHandler Handler(tag: 3184, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/m/runampl-mcztedel/wrapper.error
-2013-08-27 01:14:03,834+0000 INFO  PutFileHandler Handler(tag: 3184, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-mcztedel.error
-2013-08-27 01:14:03,835+0000 INFO  PutFileCommand Sending Command(tag: 405, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,835+0000 INFO  PutFileCommand Command(tag: 405, PUT) (t) sending data
-2013-08-27 01:14:03,835+0000 INFO  PutFileHandler Handler(tag: 3184, PUT) -> 405
-2013-08-27 01:14:03,835+0000 INFO  PutFileHandler Handler(tag: 405, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/m/runampl-mcztedel/wrapper.error
-2013-08-27 01:14:03,835+0000 INFO  PutFileHandler Handler(tag: 405, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-mcztedel.error
-2013-08-27 01:14:03,835+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:03,835+0000 INFO  RequestHandler Handler(tag: 3185, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,835+0000 INFO  RequestHandler Handler(tag: 406, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,835+0000 INFO  PutFileHandler Handler(tag: 3186, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/m/runampl-mcztedel/wrapper.log
-2013-08-27 01:14:03,835+0000 INFO  PutFileHandler Handler(tag: 3186, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-mcztedel.info
-2013-08-27 01:14:03,835+0000 INFO  PutFileCommand Sending Command(tag: 407, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,835+0000 INFO  PutFileCommand Command(tag: 407, PUT) (t) sending data
-2013-08-27 01:14:03,835+0000 INFO  PutFileHandler Handler(tag: 3186, PUT) -> 407
-2013-08-27 01:14:03,835+0000 INFO  PutFileHandler Handler(tag: 407, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/m/runampl-mcztedel/wrapper.log
-2013-08-27 01:14:03,835+0000 INFO  PutFileHandler Handler(tag: 407, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-mcztedel.info
-2013-08-27 01:14:03,836+0000 INFO  PutFileHandler Handler(tag: 405, PUT) Transfer done
-2013-08-27 01:14:03,836+0000 INFO  RequestHandler Handler(tag: 405, PUT) unregistering (send)
-2013-08-27 01:14:03,836+0000 INFO  PutFileHandler Handler(tag: 3184, PUT) Transfer done
-2013-08-27 01:14:03,836+0000 INFO  RequestHandler Handler(tag: 3184, PUT) unregistering (send)
-2013-08-27 01:14:03,837+0000 INFO  PutFileHandler Handler(tag: 407, PUT) Transfer done
-2013-08-27 01:14:03,837+0000 INFO  RequestHandler Handler(tag: 407, PUT) unregistering (send)
-2013-08-27 01:14:03,837+0000 INFO  PutFileHandler Handler(tag: 3186, PUT) Transfer done
-2013-08-27 01:14:03,837+0000 INFO  RequestHandler Handler(tag: 3186, PUT) unregistering (send)
-2013-08-27 01:14:03,863+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=7 Cpus sleeping: 1
-2013-08-27 01:14:03,863+0000 INFO  Cpu 0827-1301520-000000:7 (quality: 0.5) submitting urn:1377566032103-1377566032105-1377566032106: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0008.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0008.out|outdir/xhat_l10000_000
 1.0008.out|outdir/xhat_l20000_0001.0008.out|Results/ampl_res_l0000_0001.0008.out|outdir/out_l0000_0001.0008.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0008.out outdir/xhat_l20000_0001.0008.out obj_outdir/obj_out_l0000_0001.0008.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0008.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:03,864+0000 INFO  RequestHandler Handler(tag: 408, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,864+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:03,864+0000 INFO  RequestHandler Handler(tag: 3187, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,864+0000 INFO  RequestHandler Handler(tag: 409, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,864+0000 INFO  PutFileHandler Handler(tag: 3188, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/x/runampl-xcztedel/wrapper.log
-2013-08-27 01:14:03,864+0000 INFO  PutFileHandler Handler(tag: 3188, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-xcztedel.info
-2013-08-27 01:14:03,864+0000 INFO  PutFileCommand Sending Command(tag: 410, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,864+0000 INFO  PutFileCommand Command(tag: 410, PUT) (t) sending data
-2013-08-27 01:14:03,864+0000 INFO  PutFileHandler Handler(tag: 3188, PUT) -> 410
-2013-08-27 01:14:03,864+0000 INFO  PutFileHandler Handler(tag: 410, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/x/runampl-xcztedel/wrapper.log
-2013-08-27 01:14:03,864+0000 INFO  PutFileHandler Handler(tag: 410, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-xcztedel.info
-2013-08-27 01:14:03,865+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:03,865+0000 INFO  RequestHandler Handler(tag: 3189, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,865+0000 INFO  RequestHandler Handler(tag: 411, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,865+0000 INFO  PutFileHandler Handler(tag: 3190, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/x/runampl-xcztedel/wrapper.error
-2013-08-27 01:14:03,865+0000 INFO  PutFileHandler Handler(tag: 3190, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-xcztedel.error
-2013-08-27 01:14:03,865+0000 INFO  PutFileCommand Sending Command(tag: 412, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,865+0000 INFO  PutFileCommand Command(tag: 412, PUT) (t) sending data
-2013-08-27 01:14:03,865+0000 INFO  PutFileHandler Handler(tag: 3190, PUT) -> 412
-2013-08-27 01:14:03,865+0000 INFO  PutFileHandler Handler(tag: 412, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/x/runampl-xcztedel/wrapper.error
-2013-08-27 01:14:03,865+0000 INFO  PutFileHandler Handler(tag: 412, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-xcztedel.error
-2013-08-27 01:14:03,866+0000 INFO  PutFileHandler Handler(tag: 410, PUT) Transfer done
-2013-08-27 01:14:03,866+0000 INFO  RequestHandler Handler(tag: 410, PUT) unregistering (send)
-2013-08-27 01:14:03,866+0000 INFO  PutFileHandler Handler(tag: 3188, PUT) Transfer done
-2013-08-27 01:14:03,866+0000 INFO  RequestHandler Handler(tag: 3188, PUT) unregistering (send)
-2013-08-27 01:14:03,866+0000 INFO  PutFileHandler Handler(tag: 412, PUT) Transfer done
-2013-08-27 01:14:03,866+0000 INFO  RequestHandler Handler(tag: 412, PUT) unregistering (send)
-2013-08-27 01:14:03,866+0000 INFO  PutFileHandler Handler(tag: 3190, PUT) Transfer done
-2013-08-27 01:14:03,866+0000 INFO  RequestHandler Handler(tag: 3190, PUT) unregistering (send)
-2013-08-27 01:14:03,886+0000 INFO  ThrottleManager O maxBuffers=1024, crtBuffers=786, allowedTransfers=0, active=0, suspended=0
-2013-08-27 01:14:03,886+0000 INFO  ThrottleManager mem=164.43 MB, heap=399.81 MB, maxHeap=910.25 MB
-2013-08-27 01:14:03,892+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:03,892+0000 INFO  RequestHandler Handler(tag: 3191, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,892+0000 INFO  RequestHandler Handler(tag: 413, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,892+0000 INFO  PutFileHandler Handler(tag: 3192, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/1/runampl-1dztedel/wrapper.log
-2013-08-27 01:14:03,892+0000 INFO  PutFileHandler Handler(tag: 3192, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-1dztedel.info
-2013-08-27 01:14:03,892+0000 INFO  PutFileCommand Sending Command(tag: 414, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,892+0000 INFO  PutFileCommand Command(tag: 414, PUT) (t) sending data
-2013-08-27 01:14:03,892+0000 INFO  PutFileHandler Handler(tag: 3192, PUT) -> 414
-2013-08-27 01:14:03,892+0000 INFO  PutFileHandler Handler(tag: 414, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/1/runampl-1dztedel/wrapper.log
-2013-08-27 01:14:03,892+0000 INFO  PutFileHandler Handler(tag: 414, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-1dztedel.info
-2013-08-27 01:14:03,893+0000 INFO  ThrottleManager I maxBuffers=1024, crtBuffers=25, allowedTransfers=237, active=0, suspended=0
-2013-08-27 01:14:03,893+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:03,893+0000 INFO  RequestHandler Handler(tag: 3193, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,893+0000 INFO  RequestHandler Handler(tag: 415, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,893+0000 INFO  PutFileHandler Handler(tag: 3194, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/1/runampl-1dztedel/wrapper.error
-2013-08-27 01:14:03,893+0000 INFO  PutFileHandler Handler(tag: 3194, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-1dztedel.error
-2013-08-27 01:14:03,893+0000 INFO  PutFileCommand Sending Command(tag: 416, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,893+0000 INFO  PutFileCommand Command(tag: 416, PUT) (t) sending data
-2013-08-27 01:14:03,893+0000 INFO  PutFileHandler Handler(tag: 3194, PUT) -> 416
-2013-08-27 01:14:03,893+0000 INFO  PutFileHandler Handler(tag: 416, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/1/runampl-1dztedel/wrapper.error
-2013-08-27 01:14:03,893+0000 INFO  PutFileHandler Handler(tag: 416, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-1dztedel.error
-2013-08-27 01:14:03,893+0000 INFO  PutFileHandler Handler(tag: 414, PUT) Transfer done
-2013-08-27 01:14:03,893+0000 INFO  RequestHandler Handler(tag: 414, PUT) unregistering (send)
-2013-08-27 01:14:03,893+0000 INFO  PutFileHandler Handler(tag: 3192, PUT) Transfer done
-2013-08-27 01:14:03,893+0000 INFO  RequestHandler Handler(tag: 3192, PUT) unregistering (send)
-2013-08-27 01:14:03,894+0000 INFO  PutFileHandler Handler(tag: 416, PUT) Transfer done
-2013-08-27 01:14:03,894+0000 INFO  RequestHandler Handler(tag: 416, PUT) unregistering (send)
-2013-08-27 01:14:03,894+0000 INFO  PutFileHandler Handler(tag: 3194, PUT) Transfer done
-2013-08-27 01:14:03,894+0000 INFO  RequestHandler Handler(tag: 3194, PUT) unregistering (send)
-2013-08-27 01:14:03,922+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:03,922+0000 INFO  RequestHandler Handler(tag: 3195, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,922+0000 INFO  RequestHandler Handler(tag: 417, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,922+0000 INFO  PutFileHandler Handler(tag: 3196, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/u/runampl-ucztedel/wrapper.error
-2013-08-27 01:14:03,922+0000 INFO  PutFileHandler Handler(tag: 3196, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-ucztedel.error
-2013-08-27 01:14:03,922+0000 INFO  PutFileCommand Sending Command(tag: 418, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,922+0000 INFO  PutFileCommand Command(tag: 418, PUT) (t) sending data
-2013-08-27 01:14:03,922+0000 INFO  PutFileHandler Handler(tag: 3196, PUT) -> 418
-2013-08-27 01:14:03,922+0000 INFO  PutFileHandler Handler(tag: 418, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/u/runampl-ucztedel/wrapper.error
-2013-08-27 01:14:03,922+0000 INFO  PutFileHandler Handler(tag: 418, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-ucztedel.error
-2013-08-27 01:14:03,922+0000 INFO  RequestHandler Handler(tag: 3197, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,922+0000 INFO  RequestHandler Handler(tag: 419, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,922+0000 INFO  PutFileHandler Handler(tag: 418, PUT) Transfer done
-2013-08-27 01:14:03,922+0000 INFO  RequestHandler Handler(tag: 418, PUT) unregistering (send)
-2013-08-27 01:14:03,922+0000 INFO  PutFileHandler Handler(tag: 3198, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/u/runampl-ucztedel/wrapper.log
-2013-08-27 01:14:03,922+0000 INFO  PutFileHandler Handler(tag: 3196, PUT) Transfer done
-2013-08-27 01:14:03,922+0000 INFO  PutFileHandler Handler(tag: 3198, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-ucztedel.info
-2013-08-27 01:14:03,922+0000 INFO  RequestHandler Handler(tag: 3196, PUT) unregistering (send)
-2013-08-27 01:14:03,922+0000 INFO  PutFileCommand Sending Command(tag: 420, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,922+0000 INFO  PutFileCommand Command(tag: 420, PUT) (t) sending data
-2013-08-27 01:14:03,922+0000 INFO  PutFileHandler Handler(tag: 3198, PUT) -> 420
-2013-08-27 01:14:03,922+0000 INFO  PutFileHandler Handler(tag: 420, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/u/runampl-ucztedel/wrapper.log
-2013-08-27 01:14:03,922+0000 INFO  PutFileHandler Handler(tag: 420, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-ucztedel.info
-2013-08-27 01:14:03,923+0000 INFO  PutFileHandler Handler(tag: 420, PUT) Transfer done
-2013-08-27 01:14:03,923+0000 INFO  RequestHandler Handler(tag: 420, PUT) unregistering (send)
-2013-08-27 01:14:03,923+0000 INFO  PutFileHandler Handler(tag: 3198, PUT) Transfer done
-2013-08-27 01:14:03,923+0000 INFO  RequestHandler Handler(tag: 3198, PUT) unregistering (send)
-2013-08-27 01:14:03,936+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:03,936+0000 INFO  RequestHandler Handler(tag: 3199, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,936+0000 INFO  RequestHandler Handler(tag: 421, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,936+0000 INFO  PutFileHandler Handler(tag: 3200, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/0/runampl-0dztedel/wrapper.log
-2013-08-27 01:14:03,936+0000 INFO  PutFileHandler Handler(tag: 3200, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-0dztedel.info
-2013-08-27 01:14:03,936+0000 INFO  PutFileCommand Sending Command(tag: 422, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,936+0000 INFO  PutFileCommand Command(tag: 422, PUT) (t) sending data
-2013-08-27 01:14:03,936+0000 INFO  PutFileHandler Handler(tag: 422, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/0/runampl-0dztedel/wrapper.log
-2013-08-27 01:14:03,936+0000 INFO  PutFileHandler Handler(tag: 3200, PUT) -> 422
-2013-08-27 01:14:03,936+0000 INFO  PutFileHandler Handler(tag: 422, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-0dztedel.info
-2013-08-27 01:14:03,936+0000 INFO  RequestHandler Handler(tag: 3201, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,936+0000 INFO  RequestHandler Handler(tag: 423, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,936+0000 INFO  PutFileHandler Handler(tag: 3202, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/y/runampl-ycztedel/wrapper.error
-2013-08-27 01:14:03,936+0000 INFO  PutFileHandler Handler(tag: 3202, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-ycztedel.error
-2013-08-27 01:14:03,936+0000 INFO  PutFileCommand Sending Command(tag: 424, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,937+0000 INFO  PutFileCommand Command(tag: 424, PUT) (t) sending data
-2013-08-27 01:14:03,937+0000 INFO  PutFileHandler Handler(tag: 3202, PUT) -> 424
-2013-08-27 01:14:03,937+0000 INFO  PutFileHandler Handler(tag: 424, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/y/runampl-ycztedel/wrapper.error
-2013-08-27 01:14:03,937+0000 INFO  PutFileHandler Handler(tag: 424, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-ycztedel.error
-2013-08-27 01:14:03,937+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:03,937+0000 INFO  RequestHandler Handler(tag: 3203, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,937+0000 INFO  PutFileHandler Handler(tag: 424, PUT) Transfer done
-2013-08-27 01:14:03,937+0000 INFO  RequestHandler Handler(tag: 425, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,937+0000 INFO  RequestHandler Handler(tag: 424, PUT) unregistering (send)
-2013-08-27 01:14:03,937+0000 INFO  PutFileHandler Handler(tag: 3202, PUT) Transfer done
-2013-08-27 01:14:03,937+0000 INFO  PutFileHandler Handler(tag: 3204, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/c/runampl-ccztedel/wrapper.log
-2013-08-27 01:14:03,937+0000 INFO  RequestHandler Handler(tag: 3202, PUT) unregistering (send)
-2013-08-27 01:14:03,937+0000 INFO  PutFileHandler Handler(tag: 3204, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-ccztedel.info
-2013-08-27 01:14:03,937+0000 INFO  PutFileCommand Sending Command(tag: 426, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,937+0000 INFO  PutFileCommand Command(tag: 426, PUT) (t) sending data
-2013-08-27 01:14:03,937+0000 INFO  PutFileHandler Handler(tag: 3204, PUT) -> 426
-2013-08-27 01:14:03,937+0000 INFO  PutFileHandler Handler(tag: 426, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/c/runampl-ccztedel/wrapper.log
-2013-08-27 01:14:03,937+0000 INFO  PutFileHandler Handler(tag: 426, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-ccztedel.info
-2013-08-27 01:14:03,937+0000 INFO  RequestHandler Handler(tag: 3205, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,937+0000 INFO  RequestHandler Handler(tag: 427, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,937+0000 INFO  PutFileHandler Handler(tag: 3206, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/i/runampl-icztedel/wrapper.error
-2013-08-27 01:14:03,937+0000 INFO  PutFileHandler Handler(tag: 3206, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-icztedel.error
-2013-08-27 01:14:03,937+0000 INFO  PutFileCommand Sending Command(tag: 428, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,937+0000 INFO  PutFileCommand Command(tag: 428, PUT) (t) sending data
-2013-08-27 01:14:03,937+0000 INFO  PutFileHandler Handler(tag: 3206, PUT) -> 428
-2013-08-27 01:14:03,937+0000 INFO  PutFileHandler Handler(tag: 428, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/i/runampl-icztedel/wrapper.error
-2013-08-27 01:14:03,937+0000 INFO  PutFileHandler Handler(tag: 428, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-icztedel.error
-2013-08-27 01:14:03,938+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:03,938+0000 INFO  RequestHandler Handler(tag: 3207, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,938+0000 INFO  PutFileHandler Handler(tag: 428, PUT) Transfer done
-2013-08-27 01:14:03,938+0000 INFO  RequestHandler Handler(tag: 429, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,938+0000 INFO  RequestHandler Handler(tag: 428, PUT) unregistering (send)
-2013-08-27 01:14:03,938+0000 INFO  PutFileHandler Handler(tag: 3206, PUT) Transfer done
-2013-08-27 01:14:03,938+0000 INFO  RequestHandler Handler(tag: 3206, PUT) unregistering (send)
-2013-08-27 01:14:03,938+0000 INFO  PutFileHandler Handler(tag: 3208, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/z/runampl-zcztedel/wrapper.error
-2013-08-27 01:14:03,938+0000 INFO  PutFileHandler Handler(tag: 3208, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-zcztedel.error
-2013-08-27 01:14:03,938+0000 INFO  PutFileCommand Sending Command(tag: 430, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,938+0000 INFO  PutFileCommand Command(tag: 430, PUT) (t) sending data
-2013-08-27 01:14:03,938+0000 INFO  PutFileHandler Handler(tag: 3208, PUT) -> 430
-2013-08-27 01:14:03,938+0000 INFO  PutFileHandler Handler(tag: 430, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/z/runampl-zcztedel/wrapper.error
-2013-08-27 01:14:03,938+0000 INFO  PutFileHandler Handler(tag: 430, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-zcztedel.error
-2013-08-27 01:14:03,939+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:03,939+0000 INFO  RequestHandler Handler(tag: 3209, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,939+0000 INFO  RequestHandler Handler(tag: 431, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,939+0000 INFO  PutFileHandler Handler(tag: 3210, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/v/runampl-vcztedel/wrapper.error
-2013-08-27 01:14:03,939+0000 INFO  PutFileHandler Handler(tag: 430, PUT) Transfer done
-2013-08-27 01:14:03,939+0000 INFO  PutFileHandler Handler(tag: 3210, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-vcztedel.error
-2013-08-27 01:14:03,939+0000 INFO  RequestHandler Handler(tag: 430, PUT) unregistering (send)
-2013-08-27 01:14:03,939+0000 INFO  PutFileHandler Handler(tag: 3208, PUT) Transfer done
-2013-08-27 01:14:03,939+0000 INFO  PutFileCommand Sending Command(tag: 432, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,939+0000 INFO  RequestHandler Handler(tag: 3208, PUT) unregistering (send)
-2013-08-27 01:14:03,939+0000 INFO  PutFileHandler Handler(tag: 432, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/v/runampl-vcztedel/wrapper.error
-2013-08-27 01:14:03,939+0000 INFO  PutFileCommand Command(tag: 432, PUT) (t) sending data
-2013-08-27 01:14:03,939+0000 INFO  PutFileHandler Handler(tag: 432, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-vcztedel.error
-2013-08-27 01:14:03,939+0000 INFO  PutFileHandler Handler(tag: 3210, PUT) -> 432
-2013-08-27 01:14:03,939+0000 INFO  PutFileHandler Handler(tag: 432, PUT) Transfer done
-2013-08-27 01:14:03,939+0000 INFO  RequestHandler Handler(tag: 3211, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,939+0000 INFO  RequestHandler Handler(tag: 432, PUT) unregistering (send)
-2013-08-27 01:14:03,939+0000 INFO  RequestHandler Handler(tag: 433, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,939+0000 INFO  PutFileHandler Handler(tag: 3210, PUT) Transfer done
-2013-08-27 01:14:03,939+0000 INFO  RequestHandler Handler(tag: 3210, PUT) unregistering (send)
-2013-08-27 01:14:03,939+0000 INFO  PutFileHandler Handler(tag: 3212, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/y/runampl-ycztedel/wrapper.log
-2013-08-27 01:14:03,939+0000 INFO  PutFileHandler Handler(tag: 3212, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-ycztedel.info
-2013-08-27 01:14:03,939+0000 INFO  PutFileCommand Sending Command(tag: 434, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,939+0000 INFO  PutFileCommand Command(tag: 434, PUT) (t) sending data
-2013-08-27 01:14:03,939+0000 INFO  PutFileHandler Handler(tag: 422, PUT) Transfer done
-2013-08-27 01:14:03,939+0000 INFO  PutFileHandler Handler(tag: 3212, PUT) -> 434
-2013-08-27 01:14:03,939+0000 INFO  PutFileHandler Handler(tag: 434, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/y/runampl-ycztedel/wrapper.log
-2013-08-27 01:14:03,939+0000 INFO  RequestHandler Handler(tag: 422, PUT) unregistering (send)
-2013-08-27 01:14:03,939+0000 INFO  PutFileHandler Handler(tag: 434, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-ycztedel.info
-2013-08-27 01:14:03,939+0000 INFO  PutFileHandler Handler(tag: 3200, PUT) Transfer done
-2013-08-27 01:14:03,939+0000 INFO  RequestHandler Handler(tag: 3200, PUT) unregistering (send)
-2013-08-27 01:14:03,940+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:03,940+0000 INFO  RequestHandler Handler(tag: 435, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,940+0000 INFO  RequestHandler Handler(tag: 3213, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,940+0000 INFO  PutFileHandler Handler(tag: 3214, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/i/runampl-icztedel/wrapper.log
-2013-08-27 01:14:03,940+0000 INFO  PutFileHandler Handler(tag: 3214, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-icztedel.info
-2013-08-27 01:14:03,940+0000 INFO  PutFileCommand Sending Command(tag: 436, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,940+0000 INFO  PutFileCommand Command(tag: 436, PUT) (t) sending data
-2013-08-27 01:14:03,940+0000 INFO  PutFileHandler Handler(tag: 3214, PUT) -> 436
-2013-08-27 01:14:03,940+0000 INFO  PutFileHandler Handler(tag: 436, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/i/runampl-icztedel/wrapper.log
-2013-08-27 01:14:03,940+0000 INFO  PutFileHandler Handler(tag: 436, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-icztedel.info
-2013-08-27 01:14:03,940+0000 INFO  PutFileHandler Handler(tag: 426, PUT) Transfer done
-2013-08-27 01:14:03,940+0000 INFO  RequestHandler Handler(tag: 426, PUT) unregistering (send)
-2013-08-27 01:14:03,940+0000 INFO  PutFileHandler Handler(tag: 3204, PUT) Transfer done
-2013-08-27 01:14:03,940+0000 INFO  RequestHandler Handler(tag: 3204, PUT) unregistering (send)
-2013-08-27 01:14:03,940+0000 INFO  RequestHandler Handler(tag: 3215, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,940+0000 INFO  RequestHandler Handler(tag: 437, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,940+0000 INFO  PutFileHandler Handler(tag: 3216, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/z/runampl-zcztedel/wrapper.log
-2013-08-27 01:14:03,940+0000 INFO  PutFileHandler Handler(tag: 3216, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-zcztedel.info
-2013-08-27 01:14:03,940+0000 INFO  PutFileCommand Sending Command(tag: 438, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,940+0000 INFO  PutFileCommand Command(tag: 438, PUT) (t) sending data
-2013-08-27 01:14:03,940+0000 INFO  PutFileHandler Handler(tag: 3216, PUT) -> 438
-2013-08-27 01:14:03,940+0000 INFO  PutFileHandler Handler(tag: 438, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/z/runampl-zcztedel/wrapper.log
-2013-08-27 01:14:03,940+0000 INFO  PutFileHandler Handler(tag: 438, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-zcztedel.info
-2013-08-27 01:14:03,940+0000 INFO  RequestHandler Handler(tag: 3217, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,940+0000 INFO  RequestHandler Handler(tag: 439, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,940+0000 INFO  PutFileHandler Handler(tag: 3218, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/v/runampl-vcztedel/wrapper.log
-2013-08-27 01:14:03,940+0000 INFO  PutFileHandler Handler(tag: 3218, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-vcztedel.info
-2013-08-27 01:14:03,941+0000 INFO  PutFileCommand Sending Command(tag: 440, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,941+0000 INFO  PutFileCommand Command(tag: 440, PUT) (t) sending data
-2013-08-27 01:14:03,941+0000 INFO  PutFileHandler Handler(tag: 3218, PUT) -> 440
-2013-08-27 01:14:03,941+0000 INFO  PutFileHandler Handler(tag: 440, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/v/runampl-vcztedel/wrapper.log
-2013-08-27 01:14:03,941+0000 INFO  PutFileHandler Handler(tag: 440, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-vcztedel.info
-2013-08-27 01:14:03,941+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:03,941+0000 INFO  RequestHandler Handler(tag: 3219, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,941+0000 INFO  RequestHandler Handler(tag: 441, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,941+0000 INFO  PutFileHandler Handler(tag: 3220, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/0/runampl-0dztedel/wrapper.error
-2013-08-27 01:14:03,941+0000 INFO  PutFileHandler Handler(tag: 3220, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-0dztedel.error
-2013-08-27 01:14:03,941+0000 INFO  PutFileCommand Sending Command(tag: 442, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,941+0000 INFO  PutFileCommand Command(tag: 442, PUT) (t) sending data
-2013-08-27 01:14:03,941+0000 INFO  PutFileHandler Handler(tag: 3220, PUT) -> 442
-2013-08-27 01:14:03,941+0000 INFO  PutFileHandler Handler(tag: 442, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/0/runampl-0dztedel/wrapper.error
-2013-08-27 01:14:03,941+0000 INFO  PutFileHandler Handler(tag: 442, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-0dztedel.error
-2013-08-27 01:14:03,941+0000 INFO  PutFileHandler Handler(tag: 442, PUT) Transfer done
-2013-08-27 01:14:03,941+0000 INFO  RequestHandler Handler(tag: 442, PUT) unregistering (send)
-2013-08-27 01:14:03,941+0000 INFO  PutFileHandler Handler(tag: 3220, PUT) Transfer done
-2013-08-27 01:14:03,941+0000 INFO  RequestHandler Handler(tag: 3220, PUT) unregistering (send)
-2013-08-27 01:14:03,943+0000 INFO  PutFileHandler Handler(tag: 434, PUT) Transfer done
-2013-08-27 01:14:03,943+0000 INFO  RequestHandler Handler(tag: 434, PUT) unregistering (send)
-2013-08-27 01:14:03,943+0000 INFO  PutFileHandler Handler(tag: 3212, PUT) Transfer done
-2013-08-27 01:14:03,943+0000 INFO  RequestHandler Handler(tag: 3212, PUT) unregistering (send)
-2013-08-27 01:14:03,946+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:03,946+0000 INFO  RequestHandler Handler(tag: 3221, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,946+0000 INFO  RequestHandler Handler(tag: 443, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,946+0000 INFO  PutFileHandler Handler(tag: 3222, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/c/runampl-ccztedel/wrapper.error
-2013-08-27 01:14:03,946+0000 INFO  PutFileHandler Handler(tag: 3222, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-ccztedel.error
-2013-08-27 01:14:03,946+0000 INFO  PutFileCommand Sending Command(tag: 444, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,946+0000 INFO  PutFileCommand Command(tag: 444, PUT) (t) sending data
-2013-08-27 01:14:03,946+0000 INFO  PutFileHandler Handler(tag: 3222, PUT) -> 444
-2013-08-27 01:14:03,946+0000 INFO  PutFileHandler Handler(tag: 444, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/c/runampl-ccztedel/wrapper.error
-2013-08-27 01:14:03,946+0000 INFO  PutFileHandler Handler(tag: 444, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-ccztedel.error
-2013-08-27 01:14:03,946+0000 INFO  PutFileHandler Handler(tag: 444, PUT) Transfer done
-2013-08-27 01:14:03,946+0000 INFO  RequestHandler Handler(tag: 444, PUT) unregistering (send)
-2013-08-27 01:14:03,946+0000 INFO  PutFileHandler Handler(tag: 3222, PUT) Transfer done
-2013-08-27 01:14:03,946+0000 INFO  RequestHandler Handler(tag: 3222, PUT) unregistering (send)
-2013-08-27 01:14:03,949+0000 INFO  PutFileHandler Handler(tag: 436, PUT) Transfer done
-2013-08-27 01:14:03,949+0000 INFO  RequestHandler Handler(tag: 436, PUT) unregistering (send)
-2013-08-27 01:14:03,949+0000 INFO  PutFileHandler Handler(tag: 3214, PUT) Transfer done
-2013-08-27 01:14:03,949+0000 INFO  RequestHandler Handler(tag: 3214, PUT) unregistering (send)
-2013-08-27 01:14:03,952+0000 INFO  PutFileHandler Handler(tag: 438, PUT) Transfer done
-2013-08-27 01:14:03,952+0000 INFO  RequestHandler Handler(tag: 438, PUT) unregistering (send)
-2013-08-27 01:14:03,952+0000 INFO  PutFileHandler Handler(tag: 3216, PUT) Transfer done
-2013-08-27 01:14:03,952+0000 INFO  RequestHandler Handler(tag: 3216, PUT) unregistering (send)
-2013-08-27 01:14:03,955+0000 INFO  PutFileHandler Handler(tag: 440, PUT) Transfer done
-2013-08-27 01:14:03,955+0000 INFO  RequestHandler Handler(tag: 440, PUT) unregistering (send)
-2013-08-27 01:14:03,955+0000 INFO  PutFileHandler Handler(tag: 3218, PUT) Transfer done
-2013-08-27 01:14:03,955+0000 INFO  RequestHandler Handler(tag: 3218, PUT) unregistering (send)
-2013-08-27 01:14:03,958+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:03,958+0000 INFO  RequestHandler Handler(tag: 3223, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,958+0000 INFO  RequestHandler Handler(tag: 445, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,958+0000 INFO  PutFileHandler Handler(tag: 3224, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/t/runampl-tcztedel/wrapper.log
-2013-08-27 01:14:03,958+0000 INFO  PutFileHandler Handler(tag: 3224, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-tcztedel.info
-2013-08-27 01:14:03,958+0000 INFO  PutFileCommand Sending Command(tag: 446, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,958+0000 INFO  PutFileCommand Command(tag: 446, PUT) (t) sending data
-2013-08-27 01:14:03,958+0000 INFO  PutFileHandler Handler(tag: 3224, PUT) -> 446
-2013-08-27 01:14:03,958+0000 INFO  PutFileHandler Handler(tag: 446, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/t/runampl-tcztedel/wrapper.log
-2013-08-27 01:14:03,958+0000 INFO  PutFileHandler Handler(tag: 446, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-tcztedel.info
-2013-08-27 01:14:03,959+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:03,959+0000 INFO  RequestHandler Handler(tag: 3225, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,959+0000 INFO  RequestHandler Handler(tag: 447, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:03,959+0000 INFO  PutFileHandler Handler(tag: 446, PUT) Transfer done
-2013-08-27 01:14:03,959+0000 INFO  RequestHandler Handler(tag: 446, PUT) unregistering (send)
-2013-08-27 01:14:03,959+0000 INFO  PutFileHandler Handler(tag: 3224, PUT) Transfer done
-2013-08-27 01:14:03,959+0000 INFO  PutFileHandler Handler(tag: 3226, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/t/runampl-tcztedel/wrapper.error
-2013-08-27 01:14:03,959+0000 INFO  RequestHandler Handler(tag: 3224, PUT) unregistering (send)
-2013-08-27 01:14:03,959+0000 INFO  PutFileHandler Handler(tag: 3226, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-tcztedel.error
-2013-08-27 01:14:03,959+0000 INFO  PutFileCommand Sending Command(tag: 448, PUT) (t) on cpipe://1
-2013-08-27 01:14:03,959+0000 INFO  PutFileCommand Command(tag: 448, PUT) (t) sending data
-2013-08-27 01:14:03,959+0000 INFO  PutFileHandler Handler(tag: 3226, PUT) -> 448
-2013-08-27 01:14:03,959+0000 INFO  PutFileHandler Handler(tag: 448, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/t/runampl-tcztedel/wrapper.error
-2013-08-27 01:14:03,959+0000 INFO  PutFileHandler Handler(tag: 448, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-tcztedel.error
-2013-08-27 01:14:03,959+0000 INFO  PutFileHandler Handler(tag: 448, PUT) Transfer done
-2013-08-27 01:14:03,959+0000 INFO  RequestHandler Handler(tag: 448, PUT) unregistering (send)
-2013-08-27 01:14:03,959+0000 INFO  PutFileHandler Handler(tag: 3226, PUT) Transfer done
-2013-08-27 01:14:03,959+0000 INFO  RequestHandler Handler(tag: 3226, PUT) unregistering (send)
-2013-08-27 01:14:04,010+0000 INFO  RuntimeStats$ProgressTicker   Stage in:4  Submitted:1  Active:16  Stage out:11  Failed but can retry:1
-2013-08-27 01:14:04,115+0000 INFO  GetFileHandler Handler(tag: 3227, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,115+0000 INFO  GetFileHandler Handler(tag: 3227, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,115+0000 INFO  GetFileHandler Handler(tag: 3227, GET) -> 449
-2013-08-27 01:14:04,115+0000 INFO  GetFileHandler Handler(tag: 449, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,115+0000 INFO  GetFileHandler Handler(tag: 449, GET) reader: LR-Handler(tag: 449, GET)
-2013-08-27 01:14:04,115+0000 INFO  GetFileHandler Handler(tag: 449, GET) sending length: 14799449, 1664306559
-2013-08-27 01:14:04,115+0000 INFO  ReadBuffer RB-LR-Handler(tag: 449, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:04,115+0000 INFO  GetFileHandler Handler(tag: 3227, GET) sending length: 14799449, 1025834938
-2013-08-27 01:14:04,115+0000 INFO  ReadBuffer RB-LR-Handler(tag: 449, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:04,115+0000 INFO  LocalIOProvider LR-Handler(tag: 449, GET) rbuf: RB-LR-Handler(tag: 449, GET)
-2013-08-27 01:14:04,120+0000 INFO  ProxyIOProvider Command(tag: 449, GET) suspending
-2013-08-27 01:14:04,120+0000 INFO  GetFileHandler Handler(tag: 449, GET) suspending
-2013-08-27 01:14:04,167+0000 INFO  ProxyIOProvider Command(tag: 397, GET) resuming
-2013-08-27 01:14:04,167+0000 INFO  GetFileHandler Handler(tag: 397, GET) resuming
-2013-08-27 01:14:04,168+0000 INFO  ProxyIOProvider Command(tag: 396, GET) resuming
-2013-08-27 01:14:04,168+0000 INFO  GetFileHandler Handler(tag: 396, GET) resuming
-2013-08-27 01:14:04,168+0000 INFO  GetFileHandler Handler(tag: 397, GET) unregistering (last)
-2013-08-27 01:14:04,169+0000 INFO  GetFileHandler Handler(tag: 3178, GET) unregistering (last)
-2013-08-27 01:14:04,169+0000 INFO  ReadBuffer RB-LR-Handler(tag: 397, GET) de-allocating 8 buffers
-2013-08-27 01:14:04,169+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:04,169+0000 INFO  GetFileHandler Handler(tag: 396, GET) unregistering (last)
-2013-08-27 01:14:04,169+0000 INFO  ReadBuffer RB-LR-Handler(tag: 396, GET) de-allocating 8 buffers
-2013-08-27 01:14:04,169+0000 INFO  GetFileHandler Handler(tag: 3177, GET) unregistering (last)
-2013-08-27 01:14:04,171+0000 INFO  ProxyIOProvider Command(tag: 400, GET) resuming
-2013-08-27 01:14:04,171+0000 INFO  GetFileHandler Handler(tag: 400, GET) resuming
-2013-08-27 01:14:04,172+0000 INFO  GetFileHandler Handler(tag: 400, GET) unregistering (last)
-2013-08-27 01:14:04,172+0000 INFO  ReadBuffer RB-LR-Handler(tag: 400, GET) de-allocating 8 buffers
-2013-08-27 01:14:04,173+0000 INFO  GetFileHandler Handler(tag: 3180, GET) unregistering (last)
-2013-08-27 01:14:04,246+0000 INFO  ProxyIOProvider Command(tag: 449, GET) resuming
-2013-08-27 01:14:04,246+0000 INFO  GetFileHandler Handler(tag: 449, GET) resuming
-2013-08-27 01:14:04,249+0000 INFO  GetFileHandler Handler(tag: 449, GET) unregistering (last)
-2013-08-27 01:14:04,249+0000 INFO  ReadBuffer RB-LR-Handler(tag: 449, GET) de-allocating 8 buffers
-2013-08-27 01:14:04,249+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:04,249+0000 INFO  GetFileHandler Handler(tag: 3227, GET) unregistering (last)
-2013-08-27 01:14:04,267+0000 DEBUG Cpu Failed Job failed with and exit code of 1
-2013-08-27 01:14:04,267+0000 INFO  Cpu 0827-1301520-000000:1 jobTerminated
-2013-08-27 01:14:04,267+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=1
-2013-08-27 01:14:04,267+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=1 Cpus sleeping: 1
-2013-08-27 01:14:04,267+0000 INFO  RequestHandler Handler(tag: 3228, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,267+0000 DEBUG Cpu 0827-1301520-000000:1 sleeping
-2013-08-27 01:14:04,267+0000 INFO  RequestHandler Handler(tag: 450, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,268+0000 INFO  RequestHandler Handler(tag: 451, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,268+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:14:04,269+0000 INFO  RequestHandler Handler(tag: 3229, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,269+0000 INFO  RequestHandler Handler(tag: 452, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,269+0000 INFO  GetFileHandler Handler(tag: 3230, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,269+0000 INFO  LateBindingScheduler jobs queued: 1
-2013-08-27 01:14:04,269+0000 INFO  GetFileHandler Handler(tag: 3230, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,269+0000 INFO  GetFileHandler Handler(tag: 3230, GET) -> 453
-2013-08-27 01:14:04,269+0000 INFO  GetFileHandler Handler(tag: 453, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,269+0000 INFO  GetFileHandler Handler(tag: 453, GET) reader: LR-Handler(tag: 453, GET)
-2013-08-27 01:14:04,269+0000 INFO  GetFileHandler Handler(tag: 453, GET) sending length: 1925, 1845692530
-2013-08-27 01:14:04,269+0000 INFO  GetFileHandler Handler(tag: 3230, GET) sending length: 1925, 153070795
-2013-08-27 01:14:04,269+0000 INFO  ReadBuffer RB-LR-Handler(tag: 453, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:04,269+0000 DEBUG Cpu Failed Job failed with and exit code of 1
-2013-08-27 01:14:04,269+0000 INFO  ReadBuffer RB-LR-Handler(tag: 453, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,269+0000 INFO  Cpu 0827-1301520-000000:11 jobTerminated
-2013-08-27 01:14:04,269+0000 INFO  LocalIOProvider LR-Handler(tag: 453, GET) rbuf: RB-LR-Handler(tag: 453, GET)
-2013-08-27 01:14:04,269+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=11
-2013-08-27 01:14:04,269+0000 INFO  GetFileHandler Handler(tag: 453, GET) unregistering (last)
-2013-08-27 01:14:04,269+0000 INFO  ReadBuffer RB-LR-Handler(tag: 453, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,269+0000 INFO  RequestHandler Handler(tag: 3231, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,269+0000 INFO  GetFileHandler Handler(tag: 3230, GET) unregistering (last)
-2013-08-27 01:14:04,269+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=11 Cpus sleeping: 2
-2013-08-27 01:14:04,269+0000 DEBUG Cpu 0827-1301520-000000:11 sleeping
-2013-08-27 01:14:04,270+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-mcztedel - Application exception: Job failed with and exit code of 1
-org.globus.cog.abstraction.impl.common.execution.JobException: Job failed with and exit code of 1 (exit code: 1)
-	at org.globus.cog.abstraction.coaster.service.local.JobStatusHandler.requestComplete(JobStatusHandler.java:40)
-	at org.globus.cog.coaster.handlers.RequestHandler.receiveCompleted(RequestHandler.java:88)
-	at org.globus.cog.coaster.channels.AbstractCoasterChannel.handleRequest(AbstractCoasterChannel.java:527)
-	at org.globus.cog.coaster.channels.AbstractStreamCoasterChannel.stepNIO(AbstractStreamCoasterChannel.java:238)
-	at org.globus.cog.coaster.channels.NIOMultiplexer.loop(NIOMultiplexer.java:97)
-	at org.globus.cog.coaster.channels.NIOMultiplexer.run(NIOMultiplexer.java:56)
-Caused by: org.globus.cog.abstraction.impl.common.execution.JobException: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:04,270+0000 INFO  RequestHandler Handler(tag: 454, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,270+0000 DEBUG Cpu Failed Job failed with and exit code of 1
-2013-08-27 01:14:04,270+0000 INFO  Cpu 0827-1301520-000000:12 jobTerminated
-2013-08-27 01:14:04,270+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=12
-2013-08-27 01:14:04,270+0000 INFO  RequestHandler Handler(tag: 3232, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,270+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=12 Cpus sleeping: 3
-2013-08-27 01:14:04,270+0000 DEBUG Cpu 0827-1301520-000000:12 sleeping
-2013-08-27 01:14:04,270+0000 INFO  RequestHandler Handler(tag: 455, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,270+0000 INFO  Cpu 0827-1301520-000000:15 jobTerminated
-2013-08-27 01:14:04,270+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=15
-2013-08-27 01:14:04,270+0000 INFO  RequestHandler Handler(tag: 3233, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,270+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=15 Cpus sleeping: 4
-2013-08-27 01:14:04,271+0000 DEBUG Cpu 0827-1301520-000000:15 sleeping
-2013-08-27 01:14:04,271+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-7dztedel thread=R-42-0-1-0-2-0 host=midway replicationGroup=null
-2013-08-27 01:14:04,271+0000 DEBUG Cpu Failed Job failed with and exit code of 1
-2013-08-27 01:14:04,271+0000 INFO  RequestHandler Handler(tag: 456, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,271+0000 INFO  Cpu 0827-1301520-000000:14 jobTerminated
-2013-08-27 01:14:04,271+0000 INFO  LateBindingScheduler jobs queued: 1
-2013-08-27 01:14:04,271+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=14
-2013-08-27 01:14:04,271+0000 DEBUG swift JOB_START jobid=runampl-7dztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0000.0002.out, outdir/xhat_l20000_0000.0002.out, obj_outdir/obj_out_l0000_0000.0002.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0000.0002.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/7/runampl-7dztedel host=midway
-2013-08-27 01:14:04,271+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=14 Cpus sleeping: 5
-2013-08-27 01:14:04,271+0000 DEBUG Cpu 0827-1301520-000000:14 sleeping
-2013-08-27 01:14:04,271+0000 INFO  RequestHandler Handler(tag: 3234, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,272+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-1dztedel - Application exception: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:04,272+0000 INFO  RequestHandler Handler(tag: 457, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,272+0000 DEBUG Cpu Failed Job failed with and exit code of 1
-2013-08-27 01:14:04,272+0000 INFO  Cpu 0827-1301520-000000:13 jobTerminated
-2013-08-27 01:14:04,272+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=13
-2013-08-27 01:14:04,272+0000 INFO  RequestHandler Handler(tag: 3235, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,272+0000 INFO  LateBindingScheduler jobs queued: 2
-2013-08-27 01:14:04,273+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=13 Cpus sleeping: 6
-2013-08-27 01:14:04,273+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-xcztedel - Application exception: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:04,273+0000 DEBUG Cpu 0827-1301520-000000:13 sleeping
-2013-08-27 01:14:04,274+0000 DEBUG Cpu Failed Job failed with and exit code of 1
-2013-08-27 01:14:04,274+0000 INFO  Cpu 0827-1301520-000000:0 jobTerminated
-2013-08-27 01:14:04,274+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=0
-2013-08-27 01:14:04,274+0000 INFO  RequestHandler Handler(tag: 458, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,274+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-ucztedel - Application exception: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:04,274+0000 INFO  LateBindingScheduler jobs queued: 2
-2013-08-27 01:14:04,274+0000 INFO  RequestHandler Handler(tag: 3236, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,274+0000 INFO  RequestHandler Handler(tag: 459, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,274+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-8dztedel thread=R-42-0-1x2-15-0 host=midway replicationGroup=null
-2013-08-27 01:14:04,274+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=0 Cpus sleeping: 7
-2013-08-27 01:14:04,274+0000 DEBUG Cpu 0827-1301520-000000:0 sleeping
-2013-08-27 01:14:04,275+0000 DEBUG swift JOB_START jobid=runampl-8dztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0015.out, outdir/xhat_l20000_0001.0015.out, obj_outdir/obj_out_l0000_0001.0015.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0015.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/8/runampl-8dztedel host=midway
-2013-08-27 01:14:04,275+0000 DEBUG Cpu Failed Job failed with and exit code of 1
-2013-08-27 01:14:04,275+0000 INFO  Cpu 0827-1301520-000000:3 jobTerminated
-2013-08-27 01:14:04,275+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=3
-2013-08-27 01:14:04,275+0000 INFO  RequestHandler Handler(tag: 3237, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,275+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-9dztedel thread=R-42-0-1x2-19-0 host=midway replicationGroup=null
-2013-08-27 01:14:04,275+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=3 Cpus sleeping: 8
-2013-08-27 01:14:04,275+0000 DEBUG Cpu 0827-1301520-000000:3 sleeping
-2013-08-27 01:14:04,275+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-adztedel thread=R-42-0-1x2-6-0 host=midway replicationGroup=null
-2013-08-27 01:14:04,275+0000 INFO  RequestHandler Handler(tag: 460, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,275+0000 DEBUG swift JOB_START jobid=runampl-9dztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0019.out, outdir/xhat_l20000_0001.0019.out, obj_outdir/obj_out_l0000_0001.0019.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0019.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/9/runampl-9dztedel host=midway
-2013-08-27 01:14:04,275+0000 INFO  Cpu 0827-1301520-000000:9 jobTerminated
-2013-08-27 01:14:04,275+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=9
-2013-08-27 01:14:04,275+0000 DEBUG swift JOB_START jobid=runampl-adztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0006.out, outdir/xhat_l20000_0001.0006.out, obj_outdir/obj_out_l0000_0001.0006.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0006.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/a/runampl-adztedel host=midway
-2013-08-27 01:14:04,275+0000 INFO  RequestHandler Handler(tag: 3238, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,275+0000 INFO  LateBindingScheduler jobs queued: 1
-2013-08-27 01:14:04,275+0000 INFO  RequestHandler Handler(tag: 461, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,276+0000 DEBUG Cpu Failed Job failed with and exit code of 1
-2013-08-27 01:14:04,276+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-0dztedel - Application exception: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:04,276+0000 INFO  Cpu 0827-1301520-000000:8 jobTerminated
-2013-08-27 01:14:04,276+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=8
-2013-08-27 01:14:04,276+0000 INFO  RequestHandler Handler(tag: 3239, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,276+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=9 Cpus sleeping: 9
-2013-08-27 01:14:04,276+0000 DEBUG Cpu 0827-1301520-000000:9 sleeping
-2013-08-27 01:14:04,276+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=8 Cpus sleeping: 10
-2013-08-27 01:14:04,276+0000 DEBUG Cpu 0827-1301520-000000:8 sleeping
-2013-08-27 01:14:04,276+0000 INFO  RequestHandler Handler(tag: 39, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:04,276+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-ycztedel - Application exception: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:04,276+0000 INFO  LateBindingScheduler jobs queued: 2
-2013-08-27 01:14:04,277+0000 INFO  Cpu 0827-1301520-000000:10 jobTerminated
-2013-08-27 01:14:04,277+0000 INFO  LateBindingScheduler jobs queued: 3
-2013-08-27 01:14:04,277+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=10
-2013-08-27 01:14:04,277+0000 INFO  RequestHandler Handler(tag: 3240, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,277+0000 INFO  RequestHandler Handler(tag: 462, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,278+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=10 Cpus sleeping: 11
-2013-08-27 01:14:04,278+0000 INFO  Cpu 0827-1301520-000000:10 (quality: 0.5) submitting urn:1377566032121-1377566032128-1377566032129: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0000.0002.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0000.0002.out|outdir/xhat_l10000_00
 00.0002.out|outdir/xhat_l20000_0000.0002.out|Results/ampl_res_l0000_0000.0002.out|outdir/out_l0000_0000.0002.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0000.0002.out outdir/xhat_l20000_0000.0002.out obj_outdir/obj_out_l0000_0000.0002.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0000.0002.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,278+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-bdztedel thread=R-42-0-1-0-7-0 host=midway replicationGroup=null
-2013-08-27 01:14:04,278+0000 INFO  RequestHandler Handler(tag: 463, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,278+0000 DEBUG swift JOB_START jobid=runampl-bdztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0000.0007.out, outdir/xhat_l20000_0000.0007.out, obj_outdir/obj_out_l0000_0000.0007.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0000.0007.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/b/runampl-bdztedel host=midway
-2013-08-27 01:14:04,278+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-cdztedel thread=R-42-0-1-0-6-0 host=midway replicationGroup=null
-2013-08-27 01:14:04,278+0000 INFO  RequestHandler Handler(tag: 464, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,278+0000 INFO  LateBindingScheduler jobs queued: 4
-2013-08-27 01:14:04,279+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-icztedel - Application exception: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:04,279+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-ccztedel - Application exception: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:04,279+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=14 Cpus sleeping: 1
-2013-08-27 01:14:04,279+0000 DEBUG Cpu 0827-1301520-000000:14 sleeping
-2013-08-27 01:14:04,279+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=8 Cpus sleeping: 2
-2013-08-27 01:14:04,279+0000 DEBUG swift JOB_START jobid=runampl-cdztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0000.0006.out, outdir/xhat_l20000_0000.0006.out, obj_outdir/obj_out_l0000_0000.0006.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0000.0006.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/c/runampl-cdztedel host=midway
-2013-08-27 01:14:04,279+0000 DEBUG Cpu 0827-1301520-000000:8 sleeping
-2013-08-27 01:14:04,279+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=3 Cpus sleeping: 3
-2013-08-27 01:14:04,279+0000 DEBUG Cpu 0827-1301520-000000:3 sleeping
-2013-08-27 01:14:04,279+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=11 Cpus sleeping: 4
-2013-08-27 01:14:04,279+0000 DEBUG Cpu 0827-1301520-000000:11 sleeping
-2013-08-27 01:14:04,279+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=13 Cpus sleeping: 5
-2013-08-27 01:14:04,279+0000 DEBUG Cpu 0827-1301520-000000:13 sleeping
-2013-08-27 01:14:04,279+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=0 Cpus sleeping: 6
-2013-08-27 01:14:04,279+0000 DEBUG Cpu 0827-1301520-000000:0 sleeping
-2013-08-27 01:14:04,279+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=12 Cpus sleeping: 7
-2013-08-27 01:14:04,279+0000 DEBUG Cpu 0827-1301520-000000:12 sleeping
-2013-08-27 01:14:04,279+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=9 Cpus sleeping: 8
-2013-08-27 01:14:04,279+0000 DEBUG Cpu 0827-1301520-000000:9 sleeping
-2013-08-27 01:14:04,279+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=1 Cpus sleeping: 9
-2013-08-27 01:14:04,279+0000 DEBUG Cpu 0827-1301520-000000:1 sleeping
-2013-08-27 01:14:04,279+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=15 Cpus sleeping: 10
-2013-08-27 01:14:04,279+0000 DEBUG Cpu 0827-1301520-000000:15 sleeping
-2013-08-27 01:14:04,280+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-zcztedel - Application exception: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:04,280+0000 INFO  LateBindingScheduler jobs queued: 3
-2013-08-27 01:14:04,280+0000 INFO  LateBindingScheduler jobs queued: 1
-2013-08-27 01:14:04,280+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-ddztedel thread=R-42-0-1x2-4-0 host=midway replicationGroup=null
-2013-08-27 01:14:04,280+0000 INFO  RequestHandler Handler(tag: 40, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:04,280+0000 DEBUG swift JOB_START jobid=runampl-ddztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0004.out, outdir/xhat_l20000_0001.0004.out, obj_outdir/obj_out_l0000_0001.0004.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0004.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/d/runampl-ddztedel host=midway
-2013-08-27 01:14:04,281+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-vcztedel - Application exception: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:04,281+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-edztedel thread=R-42-0-1x2-10-0 host=midway replicationGroup=null
-2013-08-27 01:14:04,281+0000 DEBUG swift JOB_START jobid=runampl-edztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0010.out, outdir/xhat_l20000_0001.0010.out, obj_outdir/obj_out_l0000_0001.0010.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0010.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/e/runampl-edztedel host=midway
-2013-08-27 01:14:04,281+0000 INFO  RequestHandler Handler(tag: 41, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:04,282+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-fdztedel thread=R-42-0-1x2-14-0 host=midway replicationGroup=null
-2013-08-27 01:14:04,282+0000 DEBUG swift JOB_START jobid=runampl-fdztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0014.out, outdir/xhat_l20000_0001.0014.out, obj_outdir/obj_out_l0000_0001.0014.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0014.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/f/runampl-fdztedel host=midway
-2013-08-27 01:14:04,283+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-tcztedel - Application exception: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:04,283+0000 INFO  RequestHandler Handler(tag: 42, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:04,283+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-gdztedel thread=R-42-0-1x2-5-0 host=midway replicationGroup=null
-2013-08-27 01:14:04,283+0000 DEBUG swift JOB_START jobid=runampl-gdztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0005.out, outdir/xhat_l20000_0001.0005.out, obj_outdir/obj_out_l0000_0001.0005.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0005.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/g/runampl-gdztedel host=midway
-2013-08-27 01:14:04,283+0000 INFO  RequestHandler Handler(tag: 43, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:04,284+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-hdztedel thread=R-42-0-1-0-5-0 host=midway replicationGroup=null
-2013-08-27 01:14:04,284+0000 DEBUG swift JOB_START jobid=runampl-hdztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0000.0005.out, outdir/xhat_l20000_0000.0005.out, obj_outdir/obj_out_l0000_0000.0005.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0000.0005.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/h/runampl-hdztedel host=midway
-2013-08-27 01:14:04,284+0000 INFO  RequestHandler Handler(tag: 44, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:04,284+0000 INFO  RequestHandler Handler(tag: 46, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:04,285+0000 INFO  RequestHandler Handler(tag: 45, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:04,285+0000 INFO  RequestHandler Handler(tag: 47, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:04,286+0000 INFO  RequestHandler Handler(tag: 48, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:04,286+0000 INFO  RequestHandler Handler(tag: 49, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:04,329+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=14 Cpus sleeping: 1
-2013-08-27 01:14:04,330+0000 INFO  Cpu 0827-1301520-000000:14 (quality: 0.5) submitting urn:1377566032136-1377566032146-1377566032147: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0015.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0015.out|outdir/xhat_l10000_00
 01.0015.out|outdir/xhat_l20000_0001.0015.out|Results/ampl_res_l0000_0001.0015.out|outdir/out_l0000_0001.0015.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0015.out outdir/xhat_l20000_0001.0015.out obj_outdir/obj_out_l0000_0001.0015.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0015.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,330+0000 INFO  RequestHandler Handler(tag: 465, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,330+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=8 Cpus sleeping: 1
-2013-08-27 01:14:04,330+0000 INFO  Cpu 0827-1301520-000000:8 (quality: 0.5) submitting urn:1377566032140-1377566032153-1377566032154: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0006.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0006.out|outdir/xhat_l10000_000
 1.0006.out|outdir/xhat_l20000_0001.0006.out|Results/ampl_res_l0000_0001.0006.out|outdir/out_l0000_0001.0006.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0006.out outdir/xhat_l20000_0001.0006.out obj_outdir/obj_out_l0000_0001.0006.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0006.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,330+0000 INFO  RequestHandler Handler(tag: 466, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,330+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=3 Cpus sleeping: 1
-2013-08-27 01:14:04,330+0000 INFO  Cpu 0827-1301520-000000:3 (quality: 0.5) submitting urn:1377566032141-1377566032159-1377566032160: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0019.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0019.out|outdir/xhat_l10000_000
 1.0019.out|outdir/xhat_l20000_0001.0019.out|Results/ampl_res_l0000_0001.0019.out|outdir/out_l0000_0001.0019.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0019.out outdir/xhat_l20000_0001.0019.out obj_outdir/obj_out_l0000_0001.0019.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0019.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,331+0000 INFO  RequestHandler Handler(tag: 467, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,331+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=11 Cpus sleeping: 1
-2013-08-27 01:14:04,331+0000 INFO  Cpu 0827-1301520-000000:11 (quality: 0.5) submitting urn:1377566032157-1377566032168-1377566032169: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0000.0006.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0000.0006.out|outdir/xhat_l10000_00
 00.0006.out|outdir/xhat_l20000_0000.0006.out|Results/ampl_res_l0000_0000.0006.out|outdir/out_l0000_0000.0006.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0000.0006.out outdir/xhat_l20000_0000.0006.out obj_outdir/obj_out_l0000_0000.0006.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0000.0006.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,331+0000 INFO  RequestHandler Handler(tag: 468, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,331+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=13 Cpus sleeping: 1
-2013-08-27 01:14:04,331+0000 INFO  Cpu 0827-1301520-000000:13 (quality: 0.5) submitting urn:1377566032162-1377566032172-1377566032173: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0004.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0004.out|outdir/xhat_l10000_00
 01.0004.out|outdir/xhat_l20000_0001.0004.out|Results/ampl_res_l0000_0001.0004.out|outdir/out_l0000_0001.0004.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0004.out outdir/xhat_l20000_0001.0004.out obj_outdir/obj_out_l0000_0001.0004.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0004.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,331+0000 INFO  RequestHandler Handler(tag: 469, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,331+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=0 Cpus sleeping: 1
-2013-08-27 01:14:04,331+0000 INFO  Cpu 0827-1301520-000000:0 (quality: 0.5) submitting urn:1377566032165-1377566032177-1377566032178: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0010.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0010.out|outdir/xhat_l10000_000
 1.0010.out|outdir/xhat_l20000_0001.0010.out|Results/ampl_res_l0000_0001.0010.out|outdir/out_l0000_0001.0010.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0010.out outdir/xhat_l20000_0001.0010.out obj_outdir/obj_out_l0000_0001.0010.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0010.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,331+0000 INFO  RequestHandler Handler(tag: 470, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,332+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=12 Cpus sleeping: 1
-2013-08-27 01:14:04,332+0000 INFO  Cpu 0827-1301520-000000:12 (quality: 0.5) submitting urn:1377566032164-1377566032182-1377566032183: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0000.0007.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0000.0007.out|outdir/xhat_l10000_00
 00.0007.out|outdir/xhat_l20000_0000.0007.out|Results/ampl_res_l0000_0000.0007.out|outdir/out_l0000_0000.0007.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0000.0007.out outdir/xhat_l20000_0000.0007.out obj_outdir/obj_out_l0000_0000.0007.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0000.0007.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,332+0000 INFO  RequestHandler Handler(tag: 471, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,332+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=9 Cpus sleeping: 1
-2013-08-27 01:14:04,332+0000 INFO  Cpu 0827-1301520-000000:9 (quality: 0.5) submitting urn:1377566032175-1377566032187-1377566032188: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0014.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0014.out|outdir/xhat_l10000_000
 1.0014.out|outdir/xhat_l20000_0001.0014.out|Results/ampl_res_l0000_0001.0014.out|outdir/out_l0000_0001.0014.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0014.out outdir/xhat_l20000_0001.0014.out obj_outdir/obj_out_l0000_0001.0014.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0014.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,332+0000 INFO  RequestHandler Handler(tag: 472, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,332+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=1 Cpus sleeping: 1
-2013-08-27 01:14:04,332+0000 INFO  Cpu 0827-1301520-000000:1 (quality: 0.5) submitting urn:1377566032180-1377566032190-1377566032191: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0005.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0005.out|outdir/xhat_l10000_000
 1.0005.out|outdir/xhat_l20000_0001.0005.out|Results/ampl_res_l0000_0001.0005.out|outdir/out_l0000_0001.0005.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0005.out outdir/xhat_l20000_0001.0005.out obj_outdir/obj_out_l0000_0001.0005.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0005.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,332+0000 INFO  RequestHandler Handler(tag: 473, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,332+0000 DEBUG Cpu requesting work: block=0827-1301520-000000 id=15 Cpus sleeping: 1
-2013-08-27 01:14:04,332+0000 INFO  Cpu 0827-1301520-000000:15 (quality: 0.5) submitting urn:1377566032185-1377566032193-1377566032194: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0000.0005.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0000.0005.out|outdir/xhat_l10000_00
 00.0005.out|outdir/xhat_l20000_0000.0005.out|Results/ampl_res_l0000_0000.0005.out|outdir/out_l0000_0000.0005.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0000.0005.out outdir/xhat_l20000_0000.0005.out obj_outdir/obj_out_l0000_0000.0005.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0000.0005.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,333+0000 INFO  RequestHandler Handler(tag: 474, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,365+0000 INFO  GetFileHandler Handler(tag: 3241, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,365+0000 INFO  GetFileHandler Handler(tag: 3241, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,365+0000 INFO  GetFileHandler Handler(tag: 3241, GET) -> 475
-2013-08-27 01:14:04,365+0000 INFO  GetFileHandler Handler(tag: 475, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,365+0000 INFO  GetFileHandler Handler(tag: 475, GET) reader: LR-Handler(tag: 475, GET)
-2013-08-27 01:14:04,365+0000 INFO  GetFileHandler Handler(tag: 475, GET) sending length: 148937, 672775134
-2013-08-27 01:14:04,365+0000 INFO  GetFileHandler Handler(tag: 3241, GET) sending length: 148937, 830275683
-2013-08-27 01:14:04,365+0000 INFO  ReadBuffer RB-LR-Handler(tag: 475, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:04,365+0000 INFO  ReadBuffer RB-LR-Handler(tag: 475, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:04,365+0000 INFO  LocalIOProvider LR-Handler(tag: 475, GET) rbuf: RB-LR-Handler(tag: 475, GET)
-2013-08-27 01:14:04,365+0000 INFO  GetFileHandler Handler(tag: 475, GET) unregistering (last)
-2013-08-27 01:14:04,365+0000 INFO  GetFileHandler Handler(tag: 3241, GET) unregistering (last)
-2013-08-27 01:14:04,365+0000 INFO  ReadBuffer RB-LR-Handler(tag: 475, GET) de-allocating 5 buffers
-2013-08-27 01:14:04,365+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:04,371+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:04,371+0000 INFO  RequestHandler Handler(tag: 2682, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,371+0000 INFO  RequestHandler Handler(tag: 476, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,371+0000 INFO  PutFileHandler Handler(tag: 2683, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/f/runampl-fcztedel/wrapper.log
-2013-08-27 01:14:04,371+0000 INFO  PutFileHandler Handler(tag: 2683, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-fcztedel.info
-2013-08-27 01:14:04,371+0000 INFO  PutFileCommand Sending Command(tag: 477, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,371+0000 INFO  PutFileCommand Command(tag: 477, PUT) (t) sending data
-2013-08-27 01:14:04,371+0000 INFO  PutFileHandler Handler(tag: 2683, PUT) -> 477
-2013-08-27 01:14:04,371+0000 INFO  PutFileHandler Handler(tag: 477, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/f/runampl-fcztedel/wrapper.log
-2013-08-27 01:14:04,372+0000 INFO  PutFileHandler Handler(tag: 477, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-fcztedel.info
-2013-08-27 01:14:04,372+0000 INFO  GetFileHandler Handler(tag: 3242, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,372+0000 INFO  GetFileHandler Handler(tag: 3242, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,372+0000 INFO  GetFileHandler Handler(tag: 3242, GET) -> 478
-2013-08-27 01:14:04,372+0000 INFO  GetFileHandler Handler(tag: 478, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,372+0000 INFO  GetFileHandler Handler(tag: 478, GET) reader: LR-Handler(tag: 478, GET)
-2013-08-27 01:14:04,372+0000 INFO  GetFileHandler Handler(tag: 478, GET) sending length: 148937, 2099550687
-2013-08-27 01:14:04,372+0000 INFO  ReadBuffer RB-LR-Handler(tag: 478, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:04,372+0000 INFO  GetFileHandler Handler(tag: 3242, GET) sending length: 148937, 1844592552
-2013-08-27 01:14:04,372+0000 INFO  ReadBuffer RB-LR-Handler(tag: 478, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:04,372+0000 INFO  LocalIOProvider LR-Handler(tag: 478, GET) rbuf: RB-LR-Handler(tag: 478, GET)
-2013-08-27 01:14:04,374+0000 INFO  GetFileHandler Handler(tag: 478, GET) unregistering (last)
-2013-08-27 01:14:04,374+0000 INFO  ReadBuffer RB-LR-Handler(tag: 478, GET) de-allocating 5 buffers
-2013-08-27 01:14:04,374+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:04,374+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:04,374+0000 INFO  RequestHandler Handler(tag: 2684, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,374+0000 INFO  RequestHandler Handler(tag: 479, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,374+0000 INFO  PutFileHandler Handler(tag: 2685, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/f/runampl-fcztedel/wrapper.error
-2013-08-27 01:14:04,374+0000 INFO  PutFileHandler Handler(tag: 2685, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-fcztedel.error
-2013-08-27 01:14:04,374+0000 INFO  PutFileCommand Sending Command(tag: 480, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,374+0000 INFO  PutFileCommand Command(tag: 480, PUT) (t) sending data
-2013-08-27 01:14:04,374+0000 INFO  PutFileHandler Handler(tag: 2685, PUT) -> 480
-2013-08-27 01:14:04,374+0000 INFO  PutFileHandler Handler(tag: 480, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/f/runampl-fcztedel/wrapper.error
-2013-08-27 01:14:04,374+0000 INFO  PutFileHandler Handler(tag: 480, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-fcztedel.error
-2013-08-27 01:14:04,374+0000 INFO  PutFileHandler Handler(tag: 477, PUT) Transfer done
-2013-08-27 01:14:04,374+0000 INFO  RequestHandler Handler(tag: 477, PUT) unregistering (send)
-2013-08-27 01:14:04,374+0000 INFO  GetFileHandler Handler(tag: 3242, GET) unregistering (last)
-2013-08-27 01:14:04,374+0000 INFO  PutFileHandler Handler(tag: 2683, PUT) Transfer done
-2013-08-27 01:14:04,374+0000 INFO  RequestHandler Handler(tag: 2683, PUT) unregistering (send)
-2013-08-27 01:14:04,375+0000 INFO  PutFileHandler Handler(tag: 480, PUT) Transfer done
-2013-08-27 01:14:04,375+0000 INFO  RequestHandler Handler(tag: 480, PUT) unregistering (send)
-2013-08-27 01:14:04,375+0000 INFO  PutFileHandler Handler(tag: 2685, PUT) Transfer done
-2013-08-27 01:14:04,375+0000 INFO  RequestHandler Handler(tag: 2685, PUT) unregistering (send)
-2013-08-27 01:14:04,376+0000 DEBUG Cpu Failed Job failed with and exit code of 1
-2013-08-27 01:14:04,376+0000 INFO  Cpu 0827-1301520-000001:0 jobTerminated
-2013-08-27 01:14:04,376+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=0
-2013-08-27 01:14:04,376+0000 INFO  RequestHandler Handler(tag: 2686, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,376+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=0 Cpus sleeping: 1
-2013-08-27 01:14:04,376+0000 DEBUG Cpu 0827-1301520-000001:0 sleeping
-2013-08-27 01:14:04,376+0000 INFO  RequestHandler Handler(tag: 481, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,377+0000 INFO  LateBindingScheduler jobs queued: 1
-2013-08-27 01:14:04,378+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-fcztedel - Application exception: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:04,379+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-idztedel thread=R-42-0-1x2-17-0 host=midway replicationGroup=null
-2013-08-27 01:14:04,379+0000 DEBUG swift JOB_START jobid=runampl-idztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0017.out, outdir/xhat_l20000_0001.0017.out, obj_outdir/obj_out_l0000_0001.0017.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0017.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/i/runampl-idztedel host=midway
-2013-08-27 01:14:04,380+0000 INFO  RequestHandler Handler(tag: 50, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:04,391+0000 INFO  GetFileHandler Handler(tag: 3243, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,391+0000 INFO  GetFileHandler Handler(tag: 3243, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,391+0000 INFO  GetFileHandler Handler(tag: 3243, GET) -> 482
-2013-08-27 01:14:04,391+0000 INFO  GetFileHandler Handler(tag: 482, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,391+0000 INFO  GetFileHandler Handler(tag: 482, GET) reader: LR-Handler(tag: 482, GET)
-2013-08-27 01:14:04,391+0000 INFO  GetFileHandler Handler(tag: 482, GET) sending length: 148937, 1590791653
-2013-08-27 01:14:04,391+0000 INFO  ReadBuffer RB-LR-Handler(tag: 482, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:04,391+0000 INFO  GetFileHandler Handler(tag: 3243, GET) sending length: 148937, 263906821
-2013-08-27 01:14:04,391+0000 INFO  ReadBuffer RB-LR-Handler(tag: 482, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:04,391+0000 INFO  LocalIOProvider LR-Handler(tag: 482, GET) rbuf: RB-LR-Handler(tag: 482, GET)
-2013-08-27 01:14:04,391+0000 INFO  ThrottleManager O maxBuffers=1024, crtBuffers=1, allowedTransfers=255, active=0, suspended=0
-2013-08-27 01:14:04,391+0000 INFO  GetFileHandler Handler(tag: 482, GET) unregistering (last)
-2013-08-27 01:14:04,391+0000 INFO  ThrottleManager mem=110.8 MB, heap=401.94 MB, maxHeap=910.25 MB
-2013-08-27 01:14:04,391+0000 INFO  ReadBuffer RB-LR-Handler(tag: 482, GET) de-allocating 5 buffers
-2013-08-27 01:14:04,391+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:04,391+0000 INFO  GetFileHandler Handler(tag: 3243, GET) unregistering (last)
-2013-08-27 01:14:04,400+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:04,400+0000 INFO  RequestHandler Handler(tag: 2687, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,400+0000 INFO  RequestHandler Handler(tag: 483, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,400+0000 INFO  PutFileHandler Handler(tag: 2688, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/6/runampl-6cztedel/wrapper.error
-2013-08-27 01:14:04,400+0000 INFO  PutFileHandler Handler(tag: 2688, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-6cztedel.error
-2013-08-27 01:14:04,400+0000 INFO  PutFileCommand Sending Command(tag: 484, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,400+0000 INFO  PutFileCommand Command(tag: 484, PUT) (t) sending data
-2013-08-27 01:14:04,400+0000 INFO  PutFileHandler Handler(tag: 484, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/6/runampl-6cztedel/wrapper.error
-2013-08-27 01:14:04,400+0000 INFO  PutFileHandler Handler(tag: 2688, PUT) -> 484
-2013-08-27 01:14:04,400+0000 INFO  PutFileHandler Handler(tag: 484, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-6cztedel.error
-2013-08-27 01:14:04,400+0000 INFO  ThrottleManager I maxBuffers=1024, crtBuffers=0, allowedTransfers=256, active=0, suspended=0
-2013-08-27 01:14:04,400+0000 INFO  RequestHandler Handler(tag: 2689, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,400+0000 INFO  PutFileHandler Handler(tag: 484, PUT) Transfer done
-2013-08-27 01:14:04,400+0000 INFO  RequestHandler Handler(tag: 485, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,400+0000 INFO  RequestHandler Handler(tag: 484, PUT) unregistering (send)
-2013-08-27 01:14:04,400+0000 INFO  PutFileHandler Handler(tag: 2688, PUT) Transfer done
-2013-08-27 01:14:04,400+0000 INFO  PutFileHandler Handler(tag: 2690, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/6/runampl-6cztedel/wrapper.log
-2013-08-27 01:14:04,400+0000 INFO  RequestHandler Handler(tag: 2688, PUT) unregistering (send)
-2013-08-27 01:14:04,401+0000 INFO  PutFileHandler Handler(tag: 2690, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-6cztedel.info
-2013-08-27 01:14:04,401+0000 INFO  PutFileCommand Sending Command(tag: 486, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,401+0000 INFO  PutFileCommand Command(tag: 486, PUT) (t) sending data
-2013-08-27 01:14:04,401+0000 INFO  PutFileHandler Handler(tag: 2690, PUT) -> 486
-2013-08-27 01:14:04,401+0000 INFO  PutFileHandler Handler(tag: 486, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/6/runampl-6cztedel/wrapper.log
-2013-08-27 01:14:04,401+0000 INFO  PutFileHandler Handler(tag: 486, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-6cztedel.info
-2013-08-27 01:14:04,402+0000 INFO  PutFileHandler Handler(tag: 486, PUT) Transfer done
-2013-08-27 01:14:04,402+0000 INFO  RequestHandler Handler(tag: 486, PUT) unregistering (send)
-2013-08-27 01:14:04,402+0000 INFO  PutFileHandler Handler(tag: 2690, PUT) Transfer done
-2013-08-27 01:14:04,402+0000 INFO  RequestHandler Handler(tag: 2690, PUT) unregistering (send)
-2013-08-27 01:14:04,405+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:04,405+0000 INFO  RequestHandler Handler(tag: 2691, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,405+0000 INFO  RequestHandler Handler(tag: 487, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,405+0000 INFO  PutFileHandler Handler(tag: 2692, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/h/runampl-hcztedel/wrapper.log
-2013-08-27 01:14:04,405+0000 INFO  PutFileHandler Handler(tag: 2692, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-hcztedel.info
-2013-08-27 01:14:04,405+0000 INFO  PutFileCommand Sending Command(tag: 488, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,405+0000 INFO  PutFileCommand Command(tag: 488, PUT) (t) sending data
-2013-08-27 01:14:04,405+0000 INFO  PutFileHandler Handler(tag: 2692, PUT) -> 488
-2013-08-27 01:14:04,405+0000 INFO  PutFileHandler Handler(tag: 488, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/h/runampl-hcztedel/wrapper.log
-2013-08-27 01:14:04,405+0000 INFO  PutFileHandler Handler(tag: 488, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-hcztedel.info
-2013-08-27 01:14:04,406+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:04,406+0000 INFO  RequestHandler Handler(tag: 2693, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,406+0000 INFO  RequestHandler Handler(tag: 489, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,406+0000 INFO  PutFileHandler Handler(tag: 2694, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/h/runampl-hcztedel/wrapper.error
-2013-08-27 01:14:04,406+0000 INFO  PutFileHandler Handler(tag: 2694, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-hcztedel.error
-2013-08-27 01:14:04,406+0000 INFO  PutFileCommand Sending Command(tag: 490, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,406+0000 INFO  PutFileCommand Command(tag: 490, PUT) (t) sending data
-2013-08-27 01:14:04,406+0000 INFO  PutFileHandler Handler(tag: 2694, PUT) -> 490
-2013-08-27 01:14:04,406+0000 INFO  PutFileHandler Handler(tag: 490, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/h/runampl-hcztedel/wrapper.error
-2013-08-27 01:14:04,406+0000 INFO  PutFileHandler Handler(tag: 490, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-hcztedel.error
-2013-08-27 01:14:04,406+0000 INFO  PutFileHandler Handler(tag: 488, PUT) Transfer done
-2013-08-27 01:14:04,406+0000 INFO  RequestHandler Handler(tag: 488, PUT) unregistering (send)
-2013-08-27 01:14:04,406+0000 INFO  PutFileHandler Handler(tag: 2692, PUT) Transfer done
-2013-08-27 01:14:04,406+0000 INFO  RequestHandler Handler(tag: 2692, PUT) unregistering (send)
-2013-08-27 01:14:04,407+0000 INFO  PutFileHandler Handler(tag: 490, PUT) Transfer done
-2013-08-27 01:14:04,407+0000 INFO  RequestHandler Handler(tag: 490, PUT) unregistering (send)
-2013-08-27 01:14:04,407+0000 INFO  PutFileHandler Handler(tag: 2694, PUT) Transfer done
-2013-08-27 01:14:04,407+0000 INFO  RequestHandler Handler(tag: 2694, PUT) unregistering (send)
-2013-08-27 01:14:04,410+0000 DEBUG Cpu Failed Job failed with and exit code of 1
-2013-08-27 01:14:04,410+0000 INFO  Cpu 0827-1301520-000001:5 jobTerminated
-2013-08-27 01:14:04,410+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=5
-2013-08-27 01:14:04,410+0000 INFO  RequestHandler Handler(tag: 2695, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,410+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=5 Cpus sleeping: 2
-2013-08-27 01:14:04,410+0000 INFO  Cpu 0827-1301520-000001:5 (quality: 0.5) submitting urn:1377566032199-1377566032201-1377566032202: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0017.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0017.out|outdir/xhat_l10000_000
 1.0017.out|outdir/xhat_l20000_0001.0017.out|Results/ampl_res_l0000_0001.0017.out|outdir/out_l0000_0001.0017.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0017.out outdir/xhat_l20000_0001.0017.out obj_outdir/obj_out_l0000_0001.0017.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0017.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,410+0000 INFO  RequestHandler Handler(tag: 491, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,410+0000 INFO  RequestHandler Handler(tag: 492, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,410+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=0 Cpus sleeping: 1
-2013-08-27 01:14:04,410+0000 DEBUG Cpu 0827-1301520-000001:0 sleeping
-2013-08-27 01:14:04,410+0000 INFO  Cpu 0827-1301520-000001:1 jobTerminated
-2013-08-27 01:14:04,410+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=1
-2013-08-27 01:14:04,410+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=1 Cpus sleeping: 2
-2013-08-27 01:14:04,410+0000 INFO  RequestHandler Handler(tag: 2696, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,410+0000 DEBUG Cpu 0827-1301520-000001:1 sleeping
-2013-08-27 01:14:04,411+0000 INFO  RequestHandler Handler(tag: 493, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,411+0000 INFO  LateBindingScheduler jobs queued: 1
-2013-08-27 01:14:04,411+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-6cztedel - Application exception: Job failed with and exit code of 1
-org.globus.cog.abstraction.impl.common.execution.JobException: Job failed with and exit code of 1 (exit code: 1)
-	at org.globus.cog.abstraction.coaster.service.local.JobStatusHandler.requestComplete(JobStatusHandler.java:40)
-	at org.globus.cog.coaster.handlers.RequestHandler.receiveCompleted(RequestHandler.java:88)
-	at org.globus.cog.coaster.channels.AbstractCoasterChannel.handleRequest(AbstractCoasterChannel.java:527)
-	at org.globus.cog.coaster.channels.AbstractStreamCoasterChannel.stepNIO(AbstractStreamCoasterChannel.java:238)
-	at org.globus.cog.coaster.channels.NIOMultiplexer.loop(NIOMultiplexer.java:97)
-	at org.globus.cog.coaster.channels.NIOMultiplexer.run(NIOMultiplexer.java:56)
-Caused by: org.globus.cog.abstraction.impl.common.execution.JobException: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:04,412+0000 INFO  RequestHandler Handler(tag: 494, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,412+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-hcztedel - Application exception: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:04,412+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:14:04,412+0000 INFO  RequestHandler Handler(tag: 2697, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,412+0000 INFO  RequestHandler Handler(tag: 495, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,412+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-jdztedel thread=R-42-0-1-0-9-0 host=midway replicationGroup=null
-2013-08-27 01:14:04,412+0000 INFO  GetFileHandler Handler(tag: 2698, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,412+0000 INFO  GetFileHandler Handler(tag: 2698, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,412+0000 INFO  GetFileHandler Handler(tag: 2698, GET) -> 496
-2013-08-27 01:14:04,412+0000 INFO  GetFileHandler Handler(tag: 496, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,412+0000 DEBUG swift JOB_START jobid=runampl-jdztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0000.0009.out, outdir/xhat_l20000_0000.0009.out, obj_outdir/obj_out_l0000_0000.0009.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0000.0009.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/j/runampl-jdztedel host=midway
-2013-08-27 01:14:04,413+0000 INFO  GetFileHandler Handler(tag: 496, GET) reader: LR-Handler(tag: 496, GET)
-2013-08-27 01:14:04,413+0000 INFO  GetFileHandler Handler(tag: 496, GET) sending length: 1925, 629630208
-2013-08-27 01:14:04,413+0000 INFO  ReadBuffer RB-LR-Handler(tag: 496, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:04,413+0000 INFO  GetFileHandler Handler(tag: 2698, GET) sending length: 1925, 1542977087
-2013-08-27 01:14:04,413+0000 INFO  ReadBuffer RB-LR-Handler(tag: 496, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,413+0000 INFO  LocalIOProvider LR-Handler(tag: 496, GET) rbuf: RB-LR-Handler(tag: 496, GET)
-2013-08-27 01:14:04,413+0000 INFO  GetFileHandler Handler(tag: 496, GET) unregistering (last)
-2013-08-27 01:14:04,413+0000 INFO  ReadBuffer RB-LR-Handler(tag: 496, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,413+0000 INFO  GetFileHandler Handler(tag: 2698, GET) unregistering (last)
-2013-08-27 01:14:04,413+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-kdztedel thread=R-42-0-1x2-3-0 host=midway replicationGroup=null
-2013-08-27 01:14:04,413+0000 DEBUG swift JOB_START jobid=runampl-kdztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0003.out, outdir/xhat_l20000_0001.0003.out, obj_outdir/obj_out_l0000_0001.0003.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0003.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/k/runampl-kdztedel host=midway
-2013-08-27 01:14:04,414+0000 INFO  GetFileHandler Handler(tag: 2699, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,414+0000 INFO  GetFileHandler Handler(tag: 2699, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,414+0000 INFO  GetFileHandler Handler(tag: 2699, GET) -> 497
-2013-08-27 01:14:04,414+0000 INFO  GetFileHandler Handler(tag: 497, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,414+0000 INFO  GetFileHandler Handler(tag: 497, GET) reader: LR-Handler(tag: 497, GET)
-2013-08-27 01:14:04,414+0000 INFO  GetFileHandler Handler(tag: 497, GET) sending length: 14799449, 645444545
-2013-08-27 01:14:04,414+0000 INFO  ReadBuffer RB-LR-Handler(tag: 497, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:04,414+0000 INFO  GetFileHandler Handler(tag: 2699, GET) sending length: 14799449, 1046566818
-2013-08-27 01:14:04,414+0000 INFO  ReadBuffer RB-LR-Handler(tag: 497, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:04,414+0000 INFO  LocalIOProvider LR-Handler(tag: 497, GET) rbuf: RB-LR-Handler(tag: 497, GET)
-2013-08-27 01:14:04,414+0000 INFO  RequestHandler Handler(tag: 51, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:04,415+0000 INFO  RequestHandler Handler(tag: 52, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:04,422+0000 INFO  GetFileHandler Handler(tag: 497, GET) unregistering (last)
-2013-08-27 01:14:04,422+0000 INFO  ReadBuffer RB-LR-Handler(tag: 497, GET) de-allocating 8 buffers
-2013-08-27 01:14:04,422+0000 INFO  GetFileHandler Handler(tag: 2699, GET) unregistering (last)
-2013-08-27 01:14:04,453+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:04,453+0000 INFO  RequestHandler Handler(tag: 2700, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,454+0000 INFO  RequestHandler Handler(tag: 498, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,454+0000 INFO  PutFileHandler Handler(tag: 2701, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/j/runampl-jcztedel/wrapper.error
-2013-08-27 01:14:04,454+0000 INFO  PutFileHandler Handler(tag: 2701, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-jcztedel.error
-2013-08-27 01:14:04,454+0000 INFO  PutFileCommand Sending Command(tag: 499, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,454+0000 INFO  PutFileCommand Command(tag: 499, PUT) (t) sending data
-2013-08-27 01:14:04,454+0000 INFO  PutFileHandler Handler(tag: 499, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/j/runampl-jcztedel/wrapper.error
-2013-08-27 01:14:04,454+0000 INFO  PutFileHandler Handler(tag: 2701, PUT) -> 499
-2013-08-27 01:14:04,454+0000 INFO  PutFileHandler Handler(tag: 499, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-jcztedel.error
-2013-08-27 01:14:04,454+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:04,454+0000 INFO  RequestHandler Handler(tag: 2702, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,454+0000 INFO  RequestHandler Handler(tag: 500, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,454+0000 INFO  PutFileHandler Handler(tag: 2703, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/j/runampl-jcztedel/wrapper.log
-2013-08-27 01:14:04,454+0000 INFO  PutFileHandler Handler(tag: 2703, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-jcztedel.info
-2013-08-27 01:14:04,454+0000 INFO  PutFileCommand Sending Command(tag: 501, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,454+0000 INFO  PutFileCommand Command(tag: 501, PUT) (t) sending data
-2013-08-27 01:14:04,454+0000 INFO  PutFileHandler Handler(tag: 501, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/j/runampl-jcztedel/wrapper.log
-2013-08-27 01:14:04,454+0000 INFO  PutFileHandler Handler(tag: 2703, PUT) -> 501
-2013-08-27 01:14:04,454+0000 INFO  PutFileHandler Handler(tag: 501, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-jcztedel.info
-2013-08-27 01:14:04,454+0000 INFO  PutFileHandler Handler(tag: 499, PUT) Transfer done
-2013-08-27 01:14:04,454+0000 INFO  RequestHandler Handler(tag: 499, PUT) unregistering (send)
-2013-08-27 01:14:04,454+0000 INFO  PutFileHandler Handler(tag: 2701, PUT) Transfer done
-2013-08-27 01:14:04,454+0000 INFO  RequestHandler Handler(tag: 2701, PUT) unregistering (send)
-2013-08-27 01:14:04,455+0000 INFO  PutFileHandler Handler(tag: 501, PUT) Transfer done
-2013-08-27 01:14:04,455+0000 INFO  RequestHandler Handler(tag: 501, PUT) unregistering (send)
-2013-08-27 01:14:04,456+0000 INFO  PutFileHandler Handler(tag: 2703, PUT) Transfer done
-2013-08-27 01:14:04,456+0000 INFO  RequestHandler Handler(tag: 2703, PUT) unregistering (send)
-2013-08-27 01:14:04,460+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:04,460+0000 INFO  RequestHandler Handler(tag: 2704, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,461+0000 INFO  RequestHandler Handler(tag: 502, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,461+0000 INFO  PutFileHandler Handler(tag: 2705, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/8/runampl-8cztedel/wrapper.log
-2013-08-27 01:14:04,461+0000 INFO  PutFileHandler Handler(tag: 2705, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-8cztedel.info
-2013-08-27 01:14:04,461+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=0 Cpus sleeping: 1
-2013-08-27 01:14:04,461+0000 INFO  PutFileCommand Sending Command(tag: 503, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,461+0000 INFO  PutFileCommand Command(tag: 503, PUT) (t) sending data
-2013-08-27 01:14:04,461+0000 INFO  PutFileHandler Handler(tag: 2705, PUT) -> 503
-2013-08-27 01:14:04,461+0000 INFO  PutFileHandler Handler(tag: 503, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/8/runampl-8cztedel/wrapper.log
-2013-08-27 01:14:04,461+0000 INFO  PutFileHandler Handler(tag: 503, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-8cztedel.info
-2013-08-27 01:14:04,461+0000 INFO  Cpu 0827-1301520-000001:0 (quality: 0.5) submitting urn:1377566032210-1377566032213-1377566032214: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0000.0009.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0000.0009.out|outdir/xhat_l10000_000
 0.0009.out|outdir/xhat_l20000_0000.0009.out|Results/ampl_res_l0000_0000.0009.out|outdir/out_l0000_0000.0009.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0000.0009.out outdir/xhat_l20000_0000.0009.out obj_outdir/obj_out_l0000_0000.0009.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0000.0009.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,461+0000 INFO  RequestHandler Handler(tag: 504, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,461+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=1 Cpus sleeping: 1
-2013-08-27 01:14:04,461+0000 INFO  Cpu 0827-1301520-000001:1 (quality: 0.5) submitting urn:1377566032215-1377566032217-1377566032218: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0003.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0003.out|outdir/xhat_l10000_000
 1.0003.out|outdir/xhat_l20000_0001.0003.out|Results/ampl_res_l0000_0001.0003.out|outdir/out_l0000_0001.0003.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0003.out outdir/xhat_l20000_0001.0003.out obj_outdir/obj_out_l0000_0001.0003.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0003.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,461+0000 INFO  GetFileHandler Handler(tag: 3244, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,461+0000 INFO  RequestHandler Handler(tag: 505, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,461+0000 INFO  GetFileHandler Handler(tag: 3244, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,461+0000 INFO  GetFileHandler Handler(tag: 3244, GET) -> 506
-2013-08-27 01:14:04,461+0000 INFO  GetFileHandler Handler(tag: 506, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,461+0000 INFO  GetFileHandler Handler(tag: 506, GET) reader: LR-Handler(tag: 506, GET)
-2013-08-27 01:14:04,461+0000 INFO  GetFileHandler Handler(tag: 506, GET) sending length: 148937, 636469761
-2013-08-27 01:14:04,461+0000 INFO  ReadBuffer RB-LR-Handler(tag: 506, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:04,461+0000 INFO  GetFileHandler Handler(tag: 3244, GET) sending length: 148937, 531227420
-2013-08-27 01:14:04,461+0000 INFO  ReadBuffer RB-LR-Handler(tag: 506, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:04,461+0000 INFO  LocalIOProvider LR-Handler(tag: 506, GET) rbuf: RB-LR-Handler(tag: 506, GET)
-2013-08-27 01:14:04,461+0000 INFO  GetFileHandler Handler(tag: 3245, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,462+0000 INFO  GetFileHandler Handler(tag: 3245, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,462+0000 INFO  GetFileHandler Handler(tag: 3245, GET) -> 507
-2013-08-27 01:14:04,462+0000 INFO  GetFileHandler Handler(tag: 507, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,462+0000 INFO  GetFileHandler Handler(tag: 507, GET) reader: LR-Handler(tag: 507, GET)
-2013-08-27 01:14:04,462+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:04,462+0000 INFO  GetFileHandler Handler(tag: 506, GET) unregistering (last)
-2013-08-27 01:14:04,462+0000 INFO  RequestHandler Handler(tag: 2706, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,462+0000 INFO  GetFileHandler Handler(tag: 507, GET) sending length: 14799449, 567695038
-2013-08-27 01:14:04,462+0000 INFO  PutFileHandler Handler(tag: 503, PUT) Transfer done
-2013-08-27 01:14:04,462+0000 INFO  ReadBuffer RB-LR-Handler(tag: 506, GET) de-allocating 5 buffers
-2013-08-27 01:14:04,462+0000 INFO  RequestHandler Handler(tag: 503, PUT) unregistering (send)
-2013-08-27 01:14:04,462+0000 INFO  NIOChannelReadBuffer Transfer done. De-allocating one unused buffer
-2013-08-27 01:14:04,462+0000 INFO  ReadBuffer RB-LR-Handler(tag: 507, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:04,462+0000 INFO  GetFileHandler Handler(tag: 3244, GET) unregistering (last)
-2013-08-27 01:14:04,462+0000 INFO  GetFileHandler Handler(tag: 3245, GET) sending length: 14799449, 2128143692
-2013-08-27 01:14:04,462+0000 INFO  ReadBuffer RB-LR-Handler(tag: 507, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:04,462+0000 INFO  PutFileHandler Handler(tag: 2705, PUT) Transfer done
-2013-08-27 01:14:04,462+0000 INFO  PutFileHandler Handler(tag: 2707, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/o/runampl-ocztedel/wrapper.log
-2013-08-27 01:14:04,462+0000 INFO  RequestHandler Handler(tag: 2705, PUT) unregistering (send)
-2013-08-27 01:14:04,462+0000 INFO  LocalIOProvider LR-Handler(tag: 507, GET) rbuf: RB-LR-Handler(tag: 507, GET)
-2013-08-27 01:14:04,462+0000 INFO  PutFileHandler Handler(tag: 2707, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-ocztedel.info
-2013-08-27 01:14:04,462+0000 INFO  PutFileCommand Sending Command(tag: 509, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,462+0000 INFO  PutFileCommand Command(tag: 509, PUT) (t) sending data
-2013-08-27 01:14:04,462+0000 INFO  RequestHandler Handler(tag: 508, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,462+0000 INFO  PutFileHandler Handler(tag: 2707, PUT) -> 509
-2013-08-27 01:14:04,462+0000 INFO  PutFileHandler Handler(tag: 509, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/o/runampl-ocztedel/wrapper.log
-2013-08-27 01:14:04,462+0000 INFO  PutFileHandler Handler(tag: 509, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-ocztedel.info
-2013-08-27 01:14:04,462+0000 INFO  RequestHandler Handler(tag: 2708, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,462+0000 INFO  RequestHandler Handler(tag: 510, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,462+0000 INFO  PutFileHandler Handler(tag: 2709, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/8/runampl-8cztedel/wrapper.error
-2013-08-27 01:14:04,462+0000 INFO  PutFileHandler Handler(tag: 2709, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-8cztedel.error
-2013-08-27 01:14:04,462+0000 INFO  PutFileCommand Sending Command(tag: 511, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,462+0000 INFO  PutFileCommand Command(tag: 511, PUT) (t) sending data
-2013-08-27 01:14:04,462+0000 INFO  PutFileHandler Handler(tag: 2709, PUT) -> 511
-2013-08-27 01:14:04,462+0000 INFO  PutFileHandler Handler(tag: 511, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/8/runampl-8cztedel/wrapper.error
-2013-08-27 01:14:04,462+0000 INFO  PutFileHandler Handler(tag: 511, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-8cztedel.error
-2013-08-27 01:14:04,463+0000 INFO  RequestHandler Handler(tag: 512, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,463+0000 INFO  PutFileHandler Handler(tag: 511, PUT) Transfer done
-2013-08-27 01:14:04,463+0000 INFO  RequestHandler Handler(tag: 511, PUT) unregistering (send)
-2013-08-27 01:14:04,463+0000 INFO  PutFileHandler Handler(tag: 2709, PUT) Transfer done
-2013-08-27 01:14:04,463+0000 INFO  RequestHandler Handler(tag: 2709, PUT) unregistering (send)
-2013-08-27 01:14:04,463+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:14:04,463+0000 INFO  RequestHandler Handler(tag: 3246, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,463+0000 INFO  RequestHandler Handler(tag: 513, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,463+0000 INFO  GetFileHandler Handler(tag: 3247, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,463+0000 INFO  GetFileHandler Handler(tag: 3247, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,463+0000 INFO  GetFileHandler Handler(tag: 3247, GET) -> 514
-2013-08-27 01:14:04,463+0000 INFO  GetFileHandler Handler(tag: 514, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,463+0000 INFO  GetFileHandler Handler(tag: 514, GET) reader: LR-Handler(tag: 514, GET)
-2013-08-27 01:14:04,463+0000 INFO  GetFileHandler Handler(tag: 514, GET) sending length: 1925, 514149607
-2013-08-27 01:14:04,463+0000 INFO  ReadBuffer RB-LR-Handler(tag: 514, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:04,463+0000 INFO  ReadBuffer RB-LR-Handler(tag: 514, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,463+0000 INFO  LocalIOProvider LR-Handler(tag: 514, GET) rbuf: RB-LR-Handler(tag: 514, GET)
-2013-08-27 01:14:04,463+0000 INFO  GetFileHandler Handler(tag: 514, GET) unregistering (last)
-2013-08-27 01:14:04,463+0000 INFO  ReadBuffer RB-LR-Handler(tag: 514, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,463+0000 INFO  GetFileHandler Handler(tag: 3247, GET) sending length: 1925, 170635149
-2013-08-27 01:14:04,463+0000 INFO  GetFileHandler Handler(tag: 3247, GET) unregistering (last)
-2013-08-27 01:14:04,464+0000 INFO  RequestHandler Handler(tag: 515, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,464+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:14:04,464+0000 INFO  RequestHandler Handler(tag: 3248, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,464+0000 INFO  RequestHandler Handler(tag: 516, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,464+0000 INFO  GetFileHandler Handler(tag: 3249, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,464+0000 INFO  GetFileHandler Handler(tag: 3249, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,464+0000 INFO  GetFileHandler Handler(tag: 3249, GET) -> 517
-2013-08-27 01:14:04,464+0000 INFO  GetFileHandler Handler(tag: 517, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,464+0000 INFO  GetFileHandler Handler(tag: 517, GET) reader: LR-Handler(tag: 517, GET)
-2013-08-27 01:14:04,464+0000 INFO  GetFileHandler Handler(tag: 517, GET) sending length: 1925, 1584719455
-2013-08-27 01:14:04,464+0000 INFO  ReadBuffer RB-LR-Handler(tag: 517, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:04,464+0000 INFO  ReadBuffer RB-LR-Handler(tag: 517, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,464+0000 INFO  LocalIOProvider LR-Handler(tag: 517, GET) rbuf: RB-LR-Handler(tag: 517, GET)
-2013-08-27 01:14:04,464+0000 INFO  GetFileHandler Handler(tag: 517, GET) unregistering (last)
-2013-08-27 01:14:04,464+0000 INFO  ReadBuffer RB-LR-Handler(tag: 517, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,464+0000 INFO  GetFileHandler Handler(tag: 3249, GET) sending length: 1925, 2014648618
-2013-08-27 01:14:04,464+0000 INFO  GetFileHandler Handler(tag: 3249, GET) unregistering (last)
-2013-08-27 01:14:04,465+0000 INFO  RequestHandler Handler(tag: 518, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,465+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:14:04,465+0000 INFO  RequestHandler Handler(tag: 3250, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,465+0000 INFO  RequestHandler Handler(tag: 519, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,465+0000 INFO  GetFileHandler Handler(tag: 3251, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,465+0000 INFO  GetFileHandler Handler(tag: 3251, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,465+0000 INFO  GetFileHandler Handler(tag: 3251, GET) -> 520
-2013-08-27 01:14:04,465+0000 INFO  GetFileHandler Handler(tag: 520, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,465+0000 INFO  GetFileHandler Handler(tag: 520, GET) reader: LR-Handler(tag: 520, GET)
-2013-08-27 01:14:04,465+0000 INFO  GetFileHandler Handler(tag: 520, GET) sending length: 1925, 244101068
-2013-08-27 01:14:04,465+0000 INFO  ReadBuffer RB-LR-Handler(tag: 520, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:04,465+0000 INFO  ReadBuffer RB-LR-Handler(tag: 520, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,465+0000 INFO  LocalIOProvider LR-Handler(tag: 520, GET) rbuf: RB-LR-Handler(tag: 520, GET)
-2013-08-27 01:14:04,465+0000 INFO  GetFileHandler Handler(tag: 520, GET) unregistering (last)
-2013-08-27 01:14:04,465+0000 INFO  ReadBuffer RB-LR-Handler(tag: 520, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,465+0000 INFO  GetFileHandler Handler(tag: 3251, GET) sending length: 1925, 1219995374
-2013-08-27 01:14:04,465+0000 INFO  GetFileHandler Handler(tag: 3251, GET) unregistering (last)
-2013-08-27 01:14:04,466+0000 INFO  RequestHandler Handler(tag: 521, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,466+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:14:04,466+0000 INFO  RequestHandler Handler(tag: 3252, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,466+0000 INFO  RequestHandler Handler(tag: 522, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,466+0000 INFO  GetFileHandler Handler(tag: 3253, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,466+0000 INFO  GetFileHandler Handler(tag: 3253, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,466+0000 INFO  GetFileHandler Handler(tag: 3253, GET) -> 523
-2013-08-27 01:14:04,466+0000 INFO  GetFileHandler Handler(tag: 523, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,466+0000 INFO  GetFileHandler Handler(tag: 523, GET) reader: LR-Handler(tag: 523, GET)
-2013-08-27 01:14:04,466+0000 INFO  GetFileHandler Handler(tag: 523, GET) sending length: 1925, 1390968243
-2013-08-27 01:14:04,466+0000 INFO  ReadBuffer RB-LR-Handler(tag: 523, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:04,466+0000 INFO  ReadBuffer RB-LR-Handler(tag: 523, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,466+0000 INFO  LocalIOProvider LR-Handler(tag: 523, GET) rbuf: RB-LR-Handler(tag: 523, GET)
-2013-08-27 01:14:04,466+0000 INFO  GetFileHandler Handler(tag: 523, GET) unregistering (last)
-2013-08-27 01:14:04,466+0000 INFO  ReadBuffer RB-LR-Handler(tag: 523, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,466+0000 INFO  GetFileHandler Handler(tag: 3253, GET) sending length: 1925, 132298265
-2013-08-27 01:14:04,466+0000 INFO  GetFileHandler Handler(tag: 3253, GET) unregistering (last)
-2013-08-27 01:14:04,467+0000 INFO  RequestHandler Handler(tag: 524, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,467+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:14:04,467+0000 INFO  RequestHandler Handler(tag: 3254, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,467+0000 INFO  RequestHandler Handler(tag: 525, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,467+0000 INFO  GetFileHandler Handler(tag: 3255, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,467+0000 INFO  GetFileHandler Handler(tag: 3255, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,467+0000 INFO  GetFileHandler Handler(tag: 3255, GET) -> 526
-2013-08-27 01:14:04,467+0000 INFO  GetFileHandler Handler(tag: 526, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,467+0000 INFO  PutFileHandler Handler(tag: 509, PUT) Transfer done
-2013-08-27 01:14:04,467+0000 INFO  RequestHandler Handler(tag: 509, PUT) unregistering (send)
-2013-08-27 01:14:04,467+0000 INFO  GetFileHandler Handler(tag: 526, GET) reader: LR-Handler(tag: 526, GET)
-2013-08-27 01:14:04,467+0000 INFO  GetFileHandler Handler(tag: 526, GET) sending length: 1925, 324632714
-2013-08-27 01:14:04,467+0000 INFO  ReadBuffer RB-LR-Handler(tag: 526, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:04,467+0000 INFO  PutFileHandler Handler(tag: 2707, PUT) Transfer done
-2013-08-27 01:14:04,467+0000 INFO  ReadBuffer RB-LR-Handler(tag: 526, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,467+0000 INFO  LocalIOProvider LR-Handler(tag: 526, GET) rbuf: RB-LR-Handler(tag: 526, GET)
-2013-08-27 01:14:04,467+0000 INFO  RequestHandler Handler(tag: 2707, PUT) unregistering (send)
-2013-08-27 01:14:04,467+0000 INFO  GetFileHandler Handler(tag: 526, GET) unregistering (last)
-2013-08-27 01:14:04,467+0000 INFO  ReadBuffer RB-LR-Handler(tag: 526, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,467+0000 INFO  GetFileHandler Handler(tag: 3255, GET) sending length: 1925, 340318343
-2013-08-27 01:14:04,467+0000 INFO  GetFileHandler Handler(tag: 3255, GET) unregistering (last)
-2013-08-27 01:14:04,468+0000 INFO  RequestHandler Handler(tag: 527, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,468+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:04,468+0000 INFO  RequestHandler Handler(tag: 2710, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,468+0000 INFO  RequestHandler Handler(tag: 528, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,468+0000 INFO  PutFileHandler Handler(tag: 2711, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/o/runampl-ocztedel/wrapper.error
-2013-08-27 01:14:04,468+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:14:04,468+0000 INFO  RequestHandler Handler(tag: 3256, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,468+0000 INFO  PutFileHandler Handler(tag: 2711, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-ocztedel.error
-2013-08-27 01:14:04,468+0000 INFO  RequestHandler Handler(tag: 529, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,468+0000 INFO  PutFileCommand Sending Command(tag: 530, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,468+0000 INFO  PutFileCommand Command(tag: 530, PUT) (t) sending data
-2013-08-27 01:14:04,468+0000 INFO  PutFileHandler Handler(tag: 2711, PUT) -> 530
-2013-08-27 01:14:04,468+0000 INFO  PutFileHandler Handler(tag: 530, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/o/runampl-ocztedel/wrapper.error
-2013-08-27 01:14:04,468+0000 INFO  PutFileHandler Handler(tag: 530, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-ocztedel.error
-2013-08-27 01:14:04,468+0000 INFO  GetFileHandler Handler(tag: 3257, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,468+0000 INFO  GetFileHandler Handler(tag: 3257, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,468+0000 INFO  GetFileHandler Handler(tag: 3257, GET) -> 531
-2013-08-27 01:14:04,468+0000 INFO  GetFileHandler Handler(tag: 531, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,468+0000 INFO  GetFileHandler Handler(tag: 531, GET) reader: LR-Handler(tag: 531, GET)
-2013-08-27 01:14:04,468+0000 INFO  GetFileHandler Handler(tag: 531, GET) sending length: 1925, 1960480050
-2013-08-27 01:14:04,468+0000 INFO  ReadBuffer RB-LR-Handler(tag: 531, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:04,468+0000 INFO  ReadBuffer RB-LR-Handler(tag: 531, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,468+0000 INFO  LocalIOProvider LR-Handler(tag: 531, GET) rbuf: RB-LR-Handler(tag: 531, GET)
-2013-08-27 01:14:04,468+0000 INFO  GetFileHandler Handler(tag: 531, GET) unregistering (last)
-2013-08-27 01:14:04,468+0000 INFO  ReadBuffer RB-LR-Handler(tag: 531, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,468+0000 INFO  GetFileHandler Handler(tag: 3257, GET) sending length: 1925, 1797840777
-2013-08-27 01:14:04,468+0000 INFO  PutFileHandler Handler(tag: 530, PUT) Transfer done
-2013-08-27 01:14:04,468+0000 INFO  RequestHandler Handler(tag: 532, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,468+0000 INFO  RequestHandler Handler(tag: 530, PUT) unregistering (send)
-2013-08-27 01:14:04,469+0000 INFO  GetFileHandler Handler(tag: 3257, GET) unregistering (last)
-2013-08-27 01:14:04,469+0000 INFO  PutFileHandler Handler(tag: 2711, PUT) Transfer done
-2013-08-27 01:14:04,469+0000 INFO  RequestHandler Handler(tag: 2711, PUT) unregistering (send)
-2013-08-27 01:14:04,469+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:14:04,469+0000 INFO  RequestHandler Handler(tag: 3258, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,469+0000 INFO  RequestHandler Handler(tag: 533, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,469+0000 INFO  GetFileHandler Handler(tag: 3259, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,469+0000 INFO  GetFileHandler Handler(tag: 3259, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,469+0000 INFO  GetFileHandler Handler(tag: 3259, GET) -> 534
-2013-08-27 01:14:04,469+0000 INFO  GetFileHandler Handler(tag: 534, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,469+0000 INFO  GetFileHandler Handler(tag: 534, GET) reader: LR-Handler(tag: 534, GET)
-2013-08-27 01:14:04,469+0000 INFO  GetFileHandler Handler(tag: 534, GET) sending length: 1925, 515764120
-2013-08-27 01:14:04,469+0000 INFO  ReadBuffer RB-LR-Handler(tag: 534, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:04,469+0000 INFO  ReadBuffer RB-LR-Handler(tag: 534, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,469+0000 INFO  LocalIOProvider LR-Handler(tag: 534, GET) rbuf: RB-LR-Handler(tag: 534, GET)
-2013-08-27 01:14:04,469+0000 INFO  GetFileHandler Handler(tag: 534, GET) unregistering (last)
-2013-08-27 01:14:04,469+0000 INFO  ReadBuffer RB-LR-Handler(tag: 534, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,469+0000 INFO  GetFileHandler Handler(tag: 3259, GET) sending length: 1925, 1177694143
-2013-08-27 01:14:04,469+0000 INFO  GetFileHandler Handler(tag: 3259, GET) unregistering (last)
-2013-08-27 01:14:04,469+0000 INFO  RequestHandler Handler(tag: 535, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,470+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:14:04,470+0000 INFO  RequestHandler Handler(tag: 3260, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,470+0000 INFO  RequestHandler Handler(tag: 536, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,470+0000 INFO  GetFileHandler Handler(tag: 3261, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,470+0000 INFO  GetFileHandler Handler(tag: 3261, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,470+0000 INFO  GetFileHandler Handler(tag: 3261, GET) -> 537
-2013-08-27 01:14:04,470+0000 INFO  GetFileHandler Handler(tag: 537, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,470+0000 INFO  GetFileHandler Handler(tag: 537, GET) reader: LR-Handler(tag: 537, GET)
-2013-08-27 01:14:04,470+0000 INFO  GetFileHandler Handler(tag: 537, GET) sending length: 1925, 791817025
-2013-08-27 01:14:04,470+0000 INFO  ReadBuffer RB-LR-Handler(tag: 537, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:04,470+0000 INFO  ReadBuffer RB-LR-Handler(tag: 537, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,470+0000 INFO  LocalIOProvider LR-Handler(tag: 537, GET) rbuf: RB-LR-Handler(tag: 537, GET)
-2013-08-27 01:14:04,470+0000 INFO  GetFileHandler Handler(tag: 537, GET) unregistering (last)
-2013-08-27 01:14:04,470+0000 INFO  ReadBuffer RB-LR-Handler(tag: 537, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,470+0000 INFO  GetFileHandler Handler(tag: 3261, GET) sending length: 1925, 177386805
-2013-08-27 01:14:04,470+0000 INFO  GetFileHandler Handler(tag: 3261, GET) unregistering (last)
-2013-08-27 01:14:04,470+0000 INFO  RequestHandler Handler(tag: 538, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,471+0000 INFO  RequestHandler Handler(tag: 3262, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,471+0000 INFO  RequestHandler Handler(tag: 539, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,471+0000 INFO  GetFileHandler Handler(tag: 3263, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,471+0000 INFO  GetFileHandler Handler(tag: 3263, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,471+0000 INFO  GetFileHandler Handler(tag: 3263, GET) -> 540
-2013-08-27 01:14:04,471+0000 INFO  GetFileHandler Handler(tag: 540, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,471+0000 INFO  GetFileHandler Handler(tag: 540, GET) reader: LR-Handler(tag: 540, GET)
-2013-08-27 01:14:04,471+0000 INFO  GetFileHandler Handler(tag: 540, GET) sending length: 1925, 2029742554
-2013-08-27 01:14:04,471+0000 INFO  ReadBuffer RB-LR-Handler(tag: 540, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:04,471+0000 INFO  ReadBuffer RB-LR-Handler(tag: 540, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,471+0000 INFO  LocalIOProvider LR-Handler(tag: 540, GET) rbuf: RB-LR-Handler(tag: 540, GET)
-2013-08-27 01:14:04,471+0000 INFO  GetFileHandler Handler(tag: 540, GET) unregistering (last)
-2013-08-27 01:14:04,471+0000 INFO  ReadBuffer RB-LR-Handler(tag: 540, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,471+0000 INFO  GetFileHandler Handler(tag: 3263, GET) sending length: 1925, 114291584
-2013-08-27 01:14:04,471+0000 INFO  GetFileHandler Handler(tag: 3263, GET) unregistering (last)
-2013-08-27 01:14:04,471+0000 INFO  GetFileHandler Handler(tag: 507, GET) unregistering (last)
-2013-08-27 01:14:04,471+0000 INFO  ReadBuffer RB-LR-Handler(tag: 507, GET) de-allocating 8 buffers
-2013-08-27 01:14:04,471+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:04,471+0000 INFO  RequestHandler Handler(tag: 2712, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,471+0000 INFO  RequestHandler Handler(tag: 541, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,471+0000 INFO  GetFileHandler Handler(tag: 3245, GET) unregistering (last)
-2013-08-27 01:14:04,471+0000 INFO  RequestHandler Handler(tag: 542, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,471+0000 INFO  PutFileHandler Handler(tag: 2713, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/a/runampl-acztedel/wrapper.error
-2013-08-27 01:14:04,471+0000 INFO  PutFileHandler Handler(tag: 2713, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-acztedel.error
-2013-08-27 01:14:04,471+0000 INFO  PutFileCommand Sending Command(tag: 543, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,471+0000 INFO  PutFileCommand Command(tag: 543, PUT) (t) sending data
-2013-08-27 01:14:04,472+0000 INFO  PutFileHandler Handler(tag: 2713, PUT) -> 543
-2013-08-27 01:14:04,472+0000 INFO  PutFileHandler Handler(tag: 543, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/a/runampl-acztedel/wrapper.error
-2013-08-27 01:14:04,472+0000 INFO  PutFileHandler Handler(tag: 543, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-acztedel.error
-2013-08-27 01:14:04,472+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:14:04,472+0000 INFO  RequestHandler Handler(tag: 3264, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,472+0000 INFO  RequestHandler Handler(tag: 544, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,472+0000 INFO  GetFileHandler Handler(tag: 3265, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,472+0000 INFO  PutFileHandler Handler(tag: 543, PUT) Transfer done
-2013-08-27 01:14:04,472+0000 INFO  RequestHandler Handler(tag: 543, PUT) unregistering (send)
-2013-08-27 01:14:04,472+0000 INFO  GetFileHandler Handler(tag: 3265, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,472+0000 INFO  PutFileHandler Handler(tag: 2713, PUT) Transfer done
-2013-08-27 01:14:04,472+0000 INFO  GetFileHandler Handler(tag: 3265, GET) -> 545
-2013-08-27 01:14:04,472+0000 INFO  RequestHandler Handler(tag: 2713, PUT) unregistering (send)
-2013-08-27 01:14:04,472+0000 INFO  GetFileHandler Handler(tag: 545, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,472+0000 INFO  GetFileHandler Handler(tag: 545, GET) reader: LR-Handler(tag: 545, GET)
-2013-08-27 01:14:04,472+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:04,472+0000 INFO  GetFileHandler Handler(tag: 545, GET) sending length: 1925, 170381322
-2013-08-27 01:14:04,472+0000 INFO  RequestHandler Handler(tag: 2714, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,472+0000 INFO  ReadBuffer RB-LR-Handler(tag: 545, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:04,472+0000 INFO  GetFileHandler Handler(tag: 3265, GET) sending length: 1925, 1003177403
-2013-08-27 01:14:04,472+0000 INFO  ReadBuffer RB-LR-Handler(tag: 545, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,472+0000 INFO  LocalIOProvider LR-Handler(tag: 545, GET) rbuf: RB-LR-Handler(tag: 545, GET)
-2013-08-27 01:14:04,472+0000 INFO  PutFileHandler Handler(tag: 2715, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/g/runampl-gcztedel/wrapper.error
-2013-08-27 01:14:04,472+0000 INFO  GetFileHandler Handler(tag: 545, GET) unregistering (last)
-2013-08-27 01:14:04,472+0000 INFO  PutFileHandler Handler(tag: 2715, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-gcztedel.error
-2013-08-27 01:14:04,472+0000 INFO  ReadBuffer RB-LR-Handler(tag: 545, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,472+0000 INFO  GetFileHandler Handler(tag: 3265, GET) unregistering (last)
-2013-08-27 01:14:04,472+0000 INFO  RequestHandler Handler(tag: 546, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,472+0000 INFO  PutFileCommand Sending Command(tag: 547, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,472+0000 INFO  PutFileCommand Command(tag: 547, PUT) (t) sending data
-2013-08-27 01:14:04,472+0000 INFO  PutFileHandler Handler(tag: 547, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/g/runampl-gcztedel/wrapper.error
-2013-08-27 01:14:04,472+0000 INFO  PutFileHandler Handler(tag: 2715, PUT) -> 547
-2013-08-27 01:14:04,472+0000 INFO  PutFileHandler Handler(tag: 547, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-gcztedel.error
-2013-08-27 01:14:04,472+0000 INFO  RequestHandler Handler(tag: 548, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,473+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:14:04,473+0000 INFO  RequestHandler Handler(tag: 3266, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,473+0000 INFO  RequestHandler Handler(tag: 549, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,473+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:04,473+0000 INFO  PutFileHandler Handler(tag: 547, PUT) Transfer done
-2013-08-27 01:14:04,473+0000 INFO  RequestHandler Handler(tag: 2716, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,473+0000 INFO  RequestHandler Handler(tag: 550, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,473+0000 INFO  RequestHandler Handler(tag: 547, PUT) unregistering (send)
-2013-08-27 01:14:04,473+0000 INFO  PutFileHandler Handler(tag: 2715, PUT) Transfer done
-2013-08-27 01:14:04,473+0000 INFO  RequestHandler Handler(tag: 2715, PUT) unregistering (send)
-2013-08-27 01:14:04,473+0000 INFO  GetFileHandler Handler(tag: 3267, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,473+0000 INFO  GetFileHandler Handler(tag: 3267, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,473+0000 INFO  GetFileHandler Handler(tag: 3267, GET) -> 551
-2013-08-27 01:14:04,473+0000 INFO  GetFileHandler Handler(tag: 551, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,473+0000 INFO  PutFileHandler Handler(tag: 2717, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/a/runampl-acztedel/wrapper.log
-2013-08-27 01:14:04,473+0000 INFO  GetFileHandler Handler(tag: 551, GET) reader: LR-Handler(tag: 551, GET)
-2013-08-27 01:14:04,473+0000 INFO  PutFileHandler Handler(tag: 2717, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-acztedel.info
-2013-08-27 01:14:04,473+0000 INFO  GetFileHandler Handler(tag: 551, GET) sending length: 1925, 1354255499
-2013-08-27 01:14:04,473+0000 INFO  PutFileCommand Sending Command(tag: 552, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,473+0000 INFO  ReadBuffer RB-LR-Handler(tag: 551, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:04,473+0000 INFO  GetFileHandler Handler(tag: 3267, GET) sending length: 1925, 1940480787
-2013-08-27 01:14:04,473+0000 INFO  PutFileCommand Command(tag: 552, PUT) (t) sending data
-2013-08-27 01:14:04,473+0000 INFO  GetFileHandler Handler(tag: 551, GET) unregistering (last)
-2013-08-27 01:14:04,473+0000 INFO  PutFileHandler Handler(tag: 2717, PUT) -> 552
-2013-08-27 01:14:04,473+0000 INFO  GetFileHandler Handler(tag: 3267, GET) unregistering (last)
-2013-08-27 01:14:04,473+0000 INFO  ReadBuffer RB-LR-Handler(tag: 551, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,473+0000 INFO  LocalIOProvider LR-Handler(tag: 551, GET) rbuf: RB-LR-Handler(tag: 551, GET)
-2013-08-27 01:14:04,473+0000 INFO  ReadBuffer RB-LR-Handler(tag: 551, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,473+0000 INFO  PutFileHandler Handler(tag: 552, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/a/runampl-acztedel/wrapper.log
-2013-08-27 01:14:04,473+0000 INFO  PutFileHandler Handler(tag: 552, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-acztedel.info
-2013-08-27 01:14:04,473+0000 INFO  RequestHandler Handler(tag: 2718, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,473+0000 INFO  RequestHandler Handler(tag: 553, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,473+0000 INFO  PutFileHandler Handler(tag: 2719, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/g/runampl-gcztedel/wrapper.log
-2013-08-27 01:14:04,473+0000 INFO  PutFileHandler Handler(tag: 2719, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-gcztedel.info
-2013-08-27 01:14:04,473+0000 INFO  PutFileCommand Sending Command(tag: 554, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,473+0000 INFO  PutFileCommand Command(tag: 554, PUT) (t) sending data
-2013-08-27 01:14:04,473+0000 INFO  PutFileHandler Handler(tag: 2719, PUT) -> 554
-2013-08-27 01:14:04,473+0000 INFO  PutFileHandler Handler(tag: 554, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/g/runampl-gcztedel/wrapper.log
-2013-08-27 01:14:04,473+0000 INFO  PutFileHandler Handler(tag: 554, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-gcztedel.info
-2013-08-27 01:14:04,474+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:04,474+0000 INFO  RequestHandler Handler(tag: 2720, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,474+0000 INFO  RequestHandler Handler(tag: 555, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,474+0000 INFO  PutFileHandler Handler(tag: 2721, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/l/runampl-lcztedel/wrapper.log
-2013-08-27 01:14:04,474+0000 INFO  PutFileHandler Handler(tag: 2721, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-lcztedel.info
-2013-08-27 01:14:04,474+0000 INFO  PutFileCommand Sending Command(tag: 556, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,474+0000 INFO  PutFileCommand Command(tag: 556, PUT) (t) sending data
-2013-08-27 01:14:04,474+0000 INFO  PutFileHandler Handler(tag: 2721, PUT) -> 556
-2013-08-27 01:14:04,474+0000 INFO  PutFileHandler Handler(tag: 556, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/l/runampl-lcztedel/wrapper.log
-2013-08-27 01:14:04,474+0000 INFO  PutFileHandler Handler(tag: 556, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-lcztedel.info
-2013-08-27 01:14:04,474+0000 INFO  GetFileHandler Handler(tag: 3268, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:04,474+0000 INFO  GetFileHandler Handler(tag: 3268, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:04,474+0000 INFO  GetFileHandler Handler(tag: 3268, GET) -> 557
-2013-08-27 01:14:04,474+0000 INFO  GetFileHandler Handler(tag: 557, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:04,474+0000 INFO  GetFileHandler Handler(tag: 557, GET) reader: LR-Handler(tag: 557, GET)
-2013-08-27 01:14:04,474+0000 INFO  GetFileHandler Handler(tag: 557, GET) sending length: 543, 444126246
-2013-08-27 01:14:04,474+0000 INFO  ReadBuffer RB-LR-Handler(tag: 557, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:04,474+0000 INFO  GetFileHandler Handler(tag: 3268, GET) sending length: 543, 1924143197
-2013-08-27 01:14:04,474+0000 INFO  ReadBuffer RB-LR-Handler(tag: 557, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,474+0000 INFO  LocalIOProvider LR-Handler(tag: 557, GET) rbuf: RB-LR-Handler(tag: 557, GET)
-2013-08-27 01:14:04,474+0000 INFO  GetFileHandler Handler(tag: 557, GET) unregistering (last)
-2013-08-27 01:14:04,474+0000 INFO  ReadBuffer RB-LR-Handler(tag: 557, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,475+0000 INFO  PutFileHandler Handler(tag: 552, PUT) Transfer done
-2013-08-27 01:14:04,475+0000 INFO  RequestHandler Handler(tag: 552, PUT) unregistering (send)
-2013-08-27 01:14:04,475+0000 INFO  PutFileHandler Handler(tag: 2717, PUT) Transfer done
-2013-08-27 01:14:04,475+0000 INFO  GetFileHandler Handler(tag: 3268, GET) unregistering (last)
-2013-08-27 01:14:04,475+0000 INFO  RequestHandler Handler(tag: 2717, PUT) unregistering (send)
-2013-08-27 01:14:04,476+0000 INFO  GetFileHandler Handler(tag: 3269, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:04,476+0000 INFO  GetFileHandler Handler(tag: 3269, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:04,476+0000 INFO  GetFileHandler Handler(tag: 3269, GET) -> 558
-2013-08-27 01:14:04,476+0000 INFO  GetFileHandler Handler(tag: 558, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:04,476+0000 INFO  GetFileHandler Handler(tag: 558, GET) reader: LR-Handler(tag: 558, GET)
-2013-08-27 01:14:04,476+0000 INFO  GetFileHandler Handler(tag: 558, GET) sending length: 543, 684115901
-2013-08-27 01:14:04,476+0000 INFO  GetFileHandler Handler(tag: 3269, GET) sending length: 543, 308502069
-2013-08-27 01:14:04,476+0000 INFO  ReadBuffer RB-LR-Handler(tag: 558, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:04,476+0000 INFO  ReadBuffer RB-LR-Handler(tag: 558, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,476+0000 INFO  LocalIOProvider LR-Handler(tag: 558, GET) rbuf: RB-LR-Handler(tag: 558, GET)
-2013-08-27 01:14:04,476+0000 INFO  GetFileHandler Handler(tag: 558, GET) unregistering (last)
-2013-08-27 01:14:04,476+0000 INFO  ReadBuffer RB-LR-Handler(tag: 558, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,476+0000 INFO  GetFileHandler Handler(tag: 3269, GET) unregistering (last)
-2013-08-27 01:14:04,477+0000 INFO  PutFileHandler Handler(tag: 554, PUT) Transfer done
-2013-08-27 01:14:04,477+0000 INFO  RequestHandler Handler(tag: 554, PUT) unregistering (send)
-2013-08-27 01:14:04,477+0000 INFO  PutFileHandler Handler(tag: 2719, PUT) Transfer done
-2013-08-27 01:14:04,477+0000 INFO  RequestHandler Handler(tag: 2719, PUT) unregistering (send)
-2013-08-27 01:14:04,477+0000 INFO  GetFileHandler Handler(tag: 3270, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:04,477+0000 INFO  GetFileHandler Handler(tag: 3270, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:04,477+0000 INFO  GetFileHandler Handler(tag: 3270, GET) -> 559
-2013-08-27 01:14:04,477+0000 INFO  GetFileHandler Handler(tag: 559, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:04,477+0000 INFO  GetFileHandler Handler(tag: 559, GET) reader: LR-Handler(tag: 559, GET)
-2013-08-27 01:14:04,477+0000 INFO  GetFileHandler Handler(tag: 559, GET) sending length: 543, 525230202
-2013-08-27 01:14:04,477+0000 INFO  ReadBuffer RB-LR-Handler(tag: 559, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:04,477+0000 INFO  GetFileHandler Handler(tag: 3270, GET) sending length: 543, 1386215844
-2013-08-27 01:14:04,477+0000 INFO  ReadBuffer RB-LR-Handler(tag: 559, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,477+0000 INFO  LocalIOProvider LR-Handler(tag: 559, GET) rbuf: RB-LR-Handler(tag: 559, GET)
-2013-08-27 01:14:04,477+0000 INFO  GetFileHandler Handler(tag: 559, GET) unregistering (last)
-2013-08-27 01:14:04,477+0000 INFO  GetFileHandler Handler(tag: 3270, GET) unregistering (last)
-2013-08-27 01:14:04,477+0000 INFO  ReadBuffer RB-LR-Handler(tag: 559, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,478+0000 INFO  GetFileHandler Handler(tag: 3271, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:04,478+0000 INFO  GetFileHandler Handler(tag: 3271, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:04,479+0000 INFO  GetFileHandler Handler(tag: 3271, GET) -> 560
-2013-08-27 01:14:04,479+0000 INFO  GetFileHandler Handler(tag: 560, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:04,479+0000 INFO  GetFileHandler Handler(tag: 560, GET) reader: LR-Handler(tag: 560, GET)
-2013-08-27 01:14:04,479+0000 INFO  GetFileHandler Handler(tag: 560, GET) sending length: 543, 939480969
-2013-08-27 01:14:04,479+0000 INFO  ReadBuffer RB-LR-Handler(tag: 560, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:04,479+0000 INFO  GetFileHandler Handler(tag: 3271, GET) sending length: 543, 1556873239
-2013-08-27 01:14:04,479+0000 INFO  ReadBuffer RB-LR-Handler(tag: 560, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,479+0000 INFO  LocalIOProvider LR-Handler(tag: 560, GET) rbuf: RB-LR-Handler(tag: 560, GET)
-2013-08-27 01:14:04,479+0000 INFO  GetFileHandler Handler(tag: 560, GET) unregistering (last)
-2013-08-27 01:14:04,479+0000 INFO  GetFileHandler Handler(tag: 3271, GET) unregistering (last)
-2013-08-27 01:14:04,479+0000 INFO  ReadBuffer RB-LR-Handler(tag: 560, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,484+0000 INFO  PutFileHandler Handler(tag: 556, PUT) Transfer done
-2013-08-27 01:14:04,484+0000 INFO  RequestHandler Handler(tag: 556, PUT) unregistering (send)
-2013-08-27 01:14:04,484+0000 INFO  PutFileHandler Handler(tag: 2721, PUT) Transfer done
-2013-08-27 01:14:04,484+0000 INFO  RequestHandler Handler(tag: 2721, PUT) unregistering (send)
-2013-08-27 01:14:04,484+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:04,484+0000 INFO  RequestHandler Handler(tag: 561, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,484+0000 INFO  RequestHandler Handler(tag: 2722, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,484+0000 INFO  PutFileHandler Handler(tag: 2723, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/l/runampl-lcztedel/wrapper.error
-2013-08-27 01:14:04,484+0000 INFO  PutFileHandler Handler(tag: 2723, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-lcztedel.error
-2013-08-27 01:14:04,484+0000 INFO  PutFileCommand Sending Command(tag: 562, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,484+0000 INFO  PutFileCommand Command(tag: 562, PUT) (t) sending data
-2013-08-27 01:14:04,484+0000 INFO  PutFileHandler Handler(tag: 2723, PUT) -> 562
-2013-08-27 01:14:04,484+0000 INFO  PutFileHandler Handler(tag: 562, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/l/runampl-lcztedel/wrapper.error
-2013-08-27 01:14:04,484+0000 INFO  PutFileHandler Handler(tag: 562, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-lcztedel.error
-2013-08-27 01:14:04,486+0000 INFO  PutFileHandler Handler(tag: 562, PUT) Transfer done
-2013-08-27 01:14:04,486+0000 INFO  RequestHandler Handler(tag: 562, PUT) unregistering (send)
-2013-08-27 01:14:04,486+0000 INFO  PutFileHandler Handler(tag: 2723, PUT) Transfer done
-2013-08-27 01:14:04,486+0000 INFO  RequestHandler Handler(tag: 2723, PUT) unregistering (send)
-2013-08-27 01:14:04,504+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:04,504+0000 INFO  RequestHandler Handler(tag: 563, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,504+0000 INFO  RequestHandler Handler(tag: 2724, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,505+0000 INFO  PutFileHandler Handler(tag: 2725, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/7/runampl-7cztedel/wrapper.error
-2013-08-27 01:14:04,505+0000 INFO  PutFileHandler Handler(tag: 2725, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-7cztedel.error
-2013-08-27 01:14:04,505+0000 INFO  PutFileCommand Sending Command(tag: 564, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,505+0000 INFO  PutFileCommand Command(tag: 564, PUT) (t) sending data
-2013-08-27 01:14:04,505+0000 INFO  PutFileHandler Handler(tag: 2725, PUT) -> 564
-2013-08-27 01:14:04,505+0000 INFO  PutFileHandler Handler(tag: 564, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/7/runampl-7cztedel/wrapper.error
-2013-08-27 01:14:04,505+0000 INFO  PutFileHandler Handler(tag: 564, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-7cztedel.error
-2013-08-27 01:14:04,505+0000 INFO  PutFileHandler Handler(tag: 564, PUT) Transfer done
-2013-08-27 01:14:04,505+0000 INFO  RequestHandler Handler(tag: 564, PUT) unregistering (send)
-2013-08-27 01:14:04,505+0000 INFO  PutFileHandler Handler(tag: 2725, PUT) Transfer done
-2013-08-27 01:14:04,505+0000 INFO  RequestHandler Handler(tag: 2725, PUT) unregistering (send)
-2013-08-27 01:14:04,505+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:04,505+0000 INFO  RequestHandler Handler(tag: 2726, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,505+0000 INFO  RequestHandler Handler(tag: 565, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,505+0000 INFO  PutFileHandler Handler(tag: 2727, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/7/runampl-7cztedel/wrapper.log
-2013-08-27 01:14:04,506+0000 INFO  PutFileHandler Handler(tag: 2727, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-7cztedel.info
-2013-08-27 01:14:04,506+0000 INFO  PutFileCommand Sending Command(tag: 566, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,506+0000 INFO  PutFileCommand Command(tag: 566, PUT) (t) sending data
-2013-08-27 01:14:04,506+0000 INFO  PutFileHandler Handler(tag: 2727, PUT) -> 566
-2013-08-27 01:14:04,506+0000 INFO  PutFileHandler Handler(tag: 566, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/7/runampl-7cztedel/wrapper.log
-2013-08-27 01:14:04,506+0000 INFO  PutFileHandler Handler(tag: 566, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-7cztedel.info
-2013-08-27 01:14:04,507+0000 INFO  PutFileHandler Handler(tag: 566, PUT) Transfer done
-2013-08-27 01:14:04,507+0000 INFO  RequestHandler Handler(tag: 566, PUT) unregistering (send)
-2013-08-27 01:14:04,507+0000 INFO  PutFileHandler Handler(tag: 2727, PUT) Transfer done
-2013-08-27 01:14:04,507+0000 INFO  RequestHandler Handler(tag: 2727, PUT) unregistering (send)
-2013-08-27 01:14:04,509+0000 INFO  GetFileHandler Handler(tag: 3272, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,509+0000 INFO  GetFileHandler Handler(tag: 3272, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,509+0000 INFO  GetFileHandler Handler(tag: 3272, GET) -> 567
-2013-08-27 01:14:04,509+0000 INFO  GetFileHandler Handler(tag: 567, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,509+0000 INFO  GetFileHandler Handler(tag: 567, GET) reader: LR-Handler(tag: 567, GET)
-2013-08-27 01:14:04,509+0000 INFO  GetFileHandler Handler(tag: 567, GET) sending length: 14799449, 1347371049
-2013-08-27 01:14:04,509+0000 INFO  ReadBuffer RB-LR-Handler(tag: 567, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:04,509+0000 INFO  GetFileHandler Handler(tag: 3272, GET) sending length: 14799449, 50162928
-2013-08-27 01:14:04,509+0000 INFO  ReadBuffer RB-LR-Handler(tag: 567, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:04,509+0000 INFO  LocalIOProvider LR-Handler(tag: 567, GET) rbuf: RB-LR-Handler(tag: 567, GET)
-2013-08-27 01:14:04,514+0000 INFO  ProxyIOProvider Command(tag: 567, GET) suspending
-2013-08-27 01:14:04,514+0000 INFO  GetFileHandler Handler(tag: 567, GET) suspending
-2013-08-27 01:14:04,531+0000 INFO  GetFileHandler Handler(tag: 3273, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,532+0000 INFO  GetFileHandler Handler(tag: 3273, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,532+0000 INFO  GetFileHandler Handler(tag: 3273, GET) -> 568
-2013-08-27 01:14:04,532+0000 INFO  GetFileHandler Handler(tag: 568, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,532+0000 INFO  GetFileHandler Handler(tag: 568, GET) reader: LR-Handler(tag: 568, GET)
-2013-08-27 01:14:04,532+0000 INFO  GetFileHandler Handler(tag: 568, GET) sending length: 14799449, 802485119
-2013-08-27 01:14:04,532+0000 INFO  ReadBuffer RB-LR-Handler(tag: 568, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:04,532+0000 INFO  ReadBuffer RB-LR-Handler(tag: 568, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:04,532+0000 INFO  GetFileHandler Handler(tag: 3273, GET) sending length: 14799449, 1226353932
-2013-08-27 01:14:04,532+0000 INFO  LocalIOProvider LR-Handler(tag: 568, GET) rbuf: RB-LR-Handler(tag: 568, GET)
-2013-08-27 01:14:04,536+0000 INFO  ProxyIOProvider Command(tag: 568, GET) suspending
-2013-08-27 01:14:04,536+0000 INFO  GetFileHandler Handler(tag: 568, GET) suspending
-2013-08-27 01:14:04,537+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:04,537+0000 INFO  RequestHandler Handler(tag: 2728, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,537+0000 INFO  RequestHandler Handler(tag: 569, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,537+0000 INFO  PutFileHandler Handler(tag: 2729, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/r/runampl-rcztedel/wrapper.log
-2013-08-27 01:14:04,537+0000 INFO  PutFileHandler Handler(tag: 2729, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-rcztedel.info
-2013-08-27 01:14:04,537+0000 INFO  PutFileCommand Sending Command(tag: 570, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,538+0000 INFO  PutFileCommand Command(tag: 570, PUT) (t) sending data
-2013-08-27 01:14:04,538+0000 INFO  PutFileHandler Handler(tag: 2729, PUT) -> 570
-2013-08-27 01:14:04,538+0000 INFO  PutFileHandler Handler(tag: 570, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/r/runampl-rcztedel/wrapper.log
-2013-08-27 01:14:04,538+0000 INFO  PutFileHandler Handler(tag: 570, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-rcztedel.info
-2013-08-27 01:14:04,538+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:04,538+0000 INFO  RequestHandler Handler(tag: 2730, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,538+0000 INFO  RequestHandler Handler(tag: 571, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,538+0000 INFO  PutFileHandler Handler(tag: 2731, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/n/runampl-ncztedel/wrapper.error
-2013-08-27 01:14:04,538+0000 INFO  PutFileHandler Handler(tag: 2731, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-ncztedel.error
-2013-08-27 01:14:04,538+0000 INFO  PutFileCommand Sending Command(tag: 572, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,538+0000 INFO  PutFileCommand Command(tag: 572, PUT) (t) sending data
-2013-08-27 01:14:04,538+0000 INFO  PutFileHandler Handler(tag: 2731, PUT) -> 572
-2013-08-27 01:14:04,539+0000 INFO  PutFileHandler Handler(tag: 572, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/n/runampl-ncztedel/wrapper.error
-2013-08-27 01:14:04,539+0000 INFO  PutFileHandler Handler(tag: 572, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-ncztedel.error
-2013-08-27 01:14:04,539+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:04,539+0000 INFO  RequestHandler Handler(tag: 2732, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,539+0000 INFO  RequestHandler Handler(tag: 573, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,539+0000 INFO  PutFileHandler Handler(tag: 2733, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/n/runampl-ncztedel/wrapper.log
-2013-08-27 01:14:04,539+0000 INFO  PutFileHandler Handler(tag: 2733, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-ncztedel.info
-2013-08-27 01:14:04,539+0000 INFO  PutFileCommand Sending Command(tag: 574, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,539+0000 INFO  PutFileCommand Command(tag: 574, PUT) (t) sending data
-2013-08-27 01:14:04,539+0000 INFO  PutFileHandler Handler(tag: 2733, PUT) -> 574
-2013-08-27 01:14:04,539+0000 INFO  PutFileHandler Handler(tag: 574, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/n/runampl-ncztedel/wrapper.log
-2013-08-27 01:14:04,539+0000 INFO  PutFileHandler Handler(tag: 574, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-ncztedel.info
-2013-08-27 01:14:04,539+0000 INFO  PutFileHandler Handler(tag: 572, PUT) Transfer done
-2013-08-27 01:14:04,539+0000 INFO  RequestHandler Handler(tag: 572, PUT) unregistering (send)
-2013-08-27 01:14:04,539+0000 INFO  PutFileHandler Handler(tag: 2731, PUT) Transfer done
-2013-08-27 01:14:04,539+0000 INFO  RequestHandler Handler(tag: 2731, PUT) unregistering (send)
-2013-08-27 01:14:04,539+0000 INFO  PutFileHandler Handler(tag: 570, PUT) Transfer done
-2013-08-27 01:14:04,539+0000 INFO  RequestHandler Handler(tag: 570, PUT) unregistering (send)
-2013-08-27 01:14:04,539+0000 INFO  PutFileHandler Handler(tag: 2729, PUT) Transfer done
-2013-08-27 01:14:04,539+0000 INFO  RequestHandler Handler(tag: 2729, PUT) unregistering (send)
-2013-08-27 01:14:04,540+0000 INFO  RequestHandler Handler(tag: 2734, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,540+0000 INFO  RequestHandler Handler(tag: 575, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,540+0000 INFO  PutFileHandler Handler(tag: 2735, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/d/runampl-dcztedel/wrapper.log
-2013-08-27 01:14:04,540+0000 INFO  PutFileHandler Handler(tag: 2735, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-dcztedel.info
-2013-08-27 01:14:04,540+0000 INFO  PutFileCommand Sending Command(tag: 576, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,540+0000 INFO  PutFileCommand Command(tag: 576, PUT) (t) sending data
-2013-08-27 01:14:04,540+0000 INFO  PutFileHandler Handler(tag: 2735, PUT) -> 576
-2013-08-27 01:14:04,540+0000 INFO  PutFileHandler Handler(tag: 576, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/d/runampl-dcztedel/wrapper.log
-2013-08-27 01:14:04,540+0000 INFO  PutFileHandler Handler(tag: 576, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-dcztedel.info
-2013-08-27 01:14:04,540+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:04,540+0000 INFO  RequestHandler Handler(tag: 2736, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,540+0000 INFO  RequestHandler Handler(tag: 577, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,540+0000 INFO  PutFileHandler Handler(tag: 2737, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/q/runampl-qcztedel/wrapper.error
-2013-08-27 01:14:04,540+0000 INFO  PutFileHandler Handler(tag: 2737, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-qcztedel.error
-2013-08-27 01:14:04,540+0000 INFO  PutFileCommand Sending Command(tag: 578, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,540+0000 INFO  PutFileCommand Command(tag: 578, PUT) (t) sending data
-2013-08-27 01:14:04,540+0000 INFO  PutFileHandler Handler(tag: 2737, PUT) -> 578
-2013-08-27 01:14:04,540+0000 INFO  PutFileHandler Handler(tag: 578, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/q/runampl-qcztedel/wrapper.error
-2013-08-27 01:14:04,540+0000 INFO  PutFileHandler Handler(tag: 578, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-qcztedel.error
-2013-08-27 01:14:04,540+0000 INFO  RequestHandler Handler(tag: 2738, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,540+0000 INFO  RequestHandler Handler(tag: 579, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,540+0000 INFO  PutFileHandler Handler(tag: 2739, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/9/runampl-9cztedel/wrapper.log
-2013-08-27 01:14:04,540+0000 INFO  PutFileHandler Handler(tag: 2739, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-9cztedel.info
-2013-08-27 01:14:04,540+0000 INFO  PutFileCommand Sending Command(tag: 580, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,540+0000 INFO  PutFileCommand Command(tag: 580, PUT) (t) sending data
-2013-08-27 01:14:04,540+0000 INFO  PutFileHandler Handler(tag: 2739, PUT) -> 580
-2013-08-27 01:14:04,540+0000 INFO  PutFileHandler Handler(tag: 578, PUT) Transfer done
-2013-08-27 01:14:04,540+0000 INFO  PutFileHandler Handler(tag: 580, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/9/runampl-9cztedel/wrapper.log
-2013-08-27 01:14:04,540+0000 INFO  PutFileHandler Handler(tag: 580, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-9cztedel.info
-2013-08-27 01:14:04,540+0000 INFO  RequestHandler Handler(tag: 578, PUT) unregistering (send)
-2013-08-27 01:14:04,541+0000 INFO  PutFileHandler Handler(tag: 2737, PUT) Transfer done
-2013-08-27 01:14:04,541+0000 INFO  RequestHandler Handler(tag: 2737, PUT) unregistering (send)
-2013-08-27 01:14:04,541+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:04,541+0000 INFO  RequestHandler Handler(tag: 2740, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,541+0000 INFO  RequestHandler Handler(tag: 581, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,541+0000 INFO  PutFileHandler Handler(tag: 2741, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/r/runampl-rcztedel/wrapper.error
-2013-08-27 01:14:04,541+0000 INFO  PutFileHandler Handler(tag: 2741, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-rcztedel.error
-2013-08-27 01:14:04,541+0000 INFO  PutFileCommand Sending Command(tag: 582, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,541+0000 INFO  PutFileCommand Command(tag: 582, PUT) (t) sending data
-2013-08-27 01:14:04,541+0000 INFO  PutFileHandler Handler(tag: 2741, PUT) -> 582
-2013-08-27 01:14:04,541+0000 INFO  PutFileHandler Handler(tag: 582, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/r/runampl-rcztedel/wrapper.error
-2013-08-27 01:14:04,541+0000 INFO  PutFileHandler Handler(tag: 582, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-rcztedel.error
-2013-08-27 01:14:04,541+0000 INFO  PutFileHandler Handler(tag: 582, PUT) Transfer done
-2013-08-27 01:14:04,541+0000 INFO  RequestHandler Handler(tag: 582, PUT) unregistering (send)
-2013-08-27 01:14:04,541+0000 INFO  PutFileHandler Handler(tag: 2741, PUT) Transfer done
-2013-08-27 01:14:04,541+0000 INFO  RequestHandler Handler(tag: 2741, PUT) unregistering (send)
-2013-08-27 01:14:04,547+0000 INFO  PutFileHandler Handler(tag: 574, PUT) Transfer done
-2013-08-27 01:14:04,547+0000 INFO  RequestHandler Handler(tag: 574, PUT) unregistering (send)
-2013-08-27 01:14:04,547+0000 INFO  PutFileHandler Handler(tag: 2733, PUT) Transfer done
-2013-08-27 01:14:04,547+0000 INFO  GetFileHandler Handler(tag: 3274, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,547+0000 INFO  RequestHandler Handler(tag: 2733, PUT) unregistering (send)
-2013-08-27 01:14:04,547+0000 INFO  GetFileHandler Handler(tag: 3274, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,547+0000 INFO  GetFileHandler Handler(tag: 3274, GET) -> 583
-2013-08-27 01:14:04,548+0000 INFO  GetFileHandler Handler(tag: 583, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,548+0000 INFO  GetFileHandler Handler(tag: 583, GET) reader: LR-Handler(tag: 583, GET)
-2013-08-27 01:14:04,548+0000 INFO  GetFileHandler Handler(tag: 583, GET) sending length: 14799449, 711210194
-2013-08-27 01:14:04,548+0000 INFO  ReadBuffer RB-LR-Handler(tag: 583, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:04,548+0000 INFO  GetFileHandler Handler(tag: 3274, GET) sending length: 14799449, 415751356
-2013-08-27 01:14:04,548+0000 INFO  ReadBuffer RB-LR-Handler(tag: 583, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:04,548+0000 INFO  LocalIOProvider LR-Handler(tag: 583, GET) rbuf: RB-LR-Handler(tag: 583, GET)
-2013-08-27 01:14:04,551+0000 INFO  ProxyIOProvider Command(tag: 583, GET) suspending
-2013-08-27 01:14:04,551+0000 INFO  GetFileHandler Handler(tag: 583, GET) suspending
-2013-08-27 01:14:04,555+0000 INFO  PutFileHandler Handler(tag: 576, PUT) Transfer done
-2013-08-27 01:14:04,555+0000 INFO  RequestHandler Handler(tag: 576, PUT) unregistering (send)
-2013-08-27 01:14:04,555+0000 INFO  PutFileHandler Handler(tag: 2735, PUT) Transfer done
-2013-08-27 01:14:04,555+0000 INFO  RequestHandler Handler(tag: 2735, PUT) unregistering (send)
-2013-08-27 01:14:04,556+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:04,556+0000 INFO  RequestHandler Handler(tag: 2742, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,556+0000 INFO  RequestHandler Handler(tag: 584, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,556+0000 INFO  PutFileHandler Handler(tag: 2743, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/q/runampl-qcztedel/wrapper.log
-2013-08-27 01:14:04,556+0000 INFO  PutFileHandler Handler(tag: 2743, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-qcztedel.info
-2013-08-27 01:14:04,556+0000 INFO  PutFileCommand Sending Command(tag: 585, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,556+0000 INFO  PutFileCommand Command(tag: 585, PUT) (t) sending data
-2013-08-27 01:14:04,556+0000 INFO  PutFileHandler Handler(tag: 2743, PUT) -> 585
-2013-08-27 01:14:04,556+0000 INFO  PutFileHandler Handler(tag: 585, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/q/runampl-qcztedel/wrapper.log
-2013-08-27 01:14:04,556+0000 INFO  PutFileHandler Handler(tag: 585, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-qcztedel.info
-2013-08-27 01:14:04,557+0000 INFO  PutFileHandler Handler(tag: 580, PUT) Transfer done
-2013-08-27 01:14:04,557+0000 INFO  RequestHandler Handler(tag: 580, PUT) unregistering (send)
-2013-08-27 01:14:04,557+0000 INFO  PutFileHandler Handler(tag: 2739, PUT) Transfer done
-2013-08-27 01:14:04,557+0000 INFO  RequestHandler Handler(tag: 2739, PUT) unregistering (send)
-2013-08-27 01:14:04,558+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:04,558+0000 INFO  RequestHandler Handler(tag: 2744, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,558+0000 INFO  RequestHandler Handler(tag: 586, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,558+0000 INFO  PutFileHandler Handler(tag: 2745, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/d/runampl-dcztedel/wrapper.error
-2013-08-27 01:14:04,558+0000 INFO  PutFileHandler Handler(tag: 2745, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-dcztedel.error
-2013-08-27 01:14:04,558+0000 INFO  PutFileCommand Sending Command(tag: 587, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,558+0000 INFO  PutFileCommand Command(tag: 587, PUT) (t) sending data
-2013-08-27 01:14:04,558+0000 INFO  PutFileHandler Handler(tag: 2745, PUT) -> 587
-2013-08-27 01:14:04,558+0000 INFO  PutFileHandler Handler(tag: 587, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/d/runampl-dcztedel/wrapper.error
-2013-08-27 01:14:04,558+0000 INFO  PutFileHandler Handler(tag: 587, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-dcztedel.error
-2013-08-27 01:14:04,558+0000 INFO  PutFileHandler Handler(tag: 587, PUT) Transfer done
-2013-08-27 01:14:04,558+0000 INFO  RequestHandler Handler(tag: 587, PUT) unregistering (send)
-2013-08-27 01:14:04,558+0000 INFO  PutFileHandler Handler(tag: 2745, PUT) Transfer done
-2013-08-27 01:14:04,558+0000 INFO  RequestHandler Handler(tag: 2745, PUT) unregistering (send)
-2013-08-27 01:14:04,561+0000 INFO  GetFileHandler Handler(tag: 3275, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,561+0000 INFO  GetFileHandler Handler(tag: 3275, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,561+0000 INFO  GetFileHandler Handler(tag: 3275, GET) -> 588
-2013-08-27 01:14:04,561+0000 INFO  GetFileHandler Handler(tag: 588, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,561+0000 INFO  GetFileHandler Handler(tag: 588, GET) reader: LR-Handler(tag: 588, GET)
-2013-08-27 01:14:04,561+0000 INFO  GetFileHandler Handler(tag: 588, GET) sending length: 14799449, 1999234218
-2013-08-27 01:14:04,561+0000 INFO  ReadBuffer RB-LR-Handler(tag: 588, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:04,561+0000 INFO  GetFileHandler Handler(tag: 3275, GET) sending length: 14799449, 1600360964
-2013-08-27 01:14:04,561+0000 INFO  ReadBuffer RB-LR-Handler(tag: 588, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:04,561+0000 INFO  LocalIOProvider LR-Handler(tag: 588, GET) rbuf: RB-LR-Handler(tag: 588, GET)
-2013-08-27 01:14:04,565+0000 INFO  ProxyIOProvider Command(tag: 588, GET) suspending
-2013-08-27 01:14:04,565+0000 INFO  GetFileHandler Handler(tag: 588, GET) suspending
-2013-08-27 01:14:04,566+0000 INFO  PutFileHandler Handler(tag: 585, PUT) Transfer done
-2013-08-27 01:14:04,566+0000 INFO  RequestHandler Handler(tag: 585, PUT) unregistering (send)
-2013-08-27 01:14:04,566+0000 INFO  PutFileHandler Handler(tag: 2743, PUT) Transfer done
-2013-08-27 01:14:04,566+0000 INFO  RequestHandler Handler(tag: 2743, PUT) unregistering (send)
-2013-08-27 01:14:04,573+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:04,573+0000 INFO  RequestHandler Handler(tag: 2746, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,573+0000 INFO  RequestHandler Handler(tag: 589, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,574+0000 INFO  PutFileHandler Handler(tag: 2747, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/9/runampl-9cztedel/wrapper.error
-2013-08-27 01:14:04,574+0000 INFO  PutFileHandler Handler(tag: 2747, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-9cztedel.error
-2013-08-27 01:14:04,574+0000 INFO  PutFileCommand Sending Command(tag: 590, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,574+0000 INFO  PutFileCommand Command(tag: 590, PUT) (t) sending data
-2013-08-27 01:14:04,574+0000 INFO  PutFileHandler Handler(tag: 2747, PUT) -> 590
-2013-08-27 01:14:04,574+0000 INFO  PutFileHandler Handler(tag: 590, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/9/runampl-9cztedel/wrapper.error
-2013-08-27 01:14:04,574+0000 INFO  PutFileHandler Handler(tag: 590, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-9cztedel.error
-2013-08-27 01:14:04,574+0000 INFO  PutFileHandler Handler(tag: 590, PUT) Transfer done
-2013-08-27 01:14:04,574+0000 INFO  RequestHandler Handler(tag: 590, PUT) unregistering (send)
-2013-08-27 01:14:04,574+0000 INFO  PutFileHandler Handler(tag: 2747, PUT) Transfer done
-2013-08-27 01:14:04,574+0000 INFO  RequestHandler Handler(tag: 2747, PUT) unregistering (send)
-2013-08-27 01:14:04,574+0000 INFO  GetFileHandler Handler(tag: 3276, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,575+0000 INFO  GetFileHandler Handler(tag: 3276, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,575+0000 INFO  GetFileHandler Handler(tag: 3276, GET) -> 591
-2013-08-27 01:14:04,575+0000 INFO  GetFileHandler Handler(tag: 591, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,575+0000 INFO  GetFileHandler Handler(tag: 591, GET) reader: LR-Handler(tag: 591, GET)
-2013-08-27 01:14:04,575+0000 INFO  GetFileHandler Handler(tag: 591, GET) sending length: 14799449, 764557967
-2013-08-27 01:14:04,575+0000 INFO  ReadBuffer RB-LR-Handler(tag: 591, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:04,575+0000 INFO  GetFileHandler Handler(tag: 3276, GET) sending length: 14799449, 1903563622
-2013-08-27 01:14:04,575+0000 INFO  ReadBuffer RB-LR-Handler(tag: 591, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:04,575+0000 INFO  LocalIOProvider LR-Handler(tag: 591, GET) rbuf: RB-LR-Handler(tag: 591, GET)
-2013-08-27 01:14:04,581+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:04,582+0000 INFO  RequestHandler Handler(tag: 2748, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,582+0000 INFO  RequestHandler Handler(tag: 592, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,582+0000 INFO  PutFileHandler Handler(tag: 2749, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/e/runampl-ecztedel/wrapper.error
-2013-08-27 01:14:04,582+0000 INFO  PutFileHandler Handler(tag: 2749, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-ecztedel.error
-2013-08-27 01:14:04,582+0000 INFO  PutFileCommand Sending Command(tag: 593, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,582+0000 INFO  PutFileCommand Command(tag: 593, PUT) (t) sending data
-2013-08-27 01:14:04,582+0000 INFO  PutFileHandler Handler(tag: 2749, PUT) -> 593
-2013-08-27 01:14:04,582+0000 INFO  PutFileHandler Handler(tag: 593, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/e/runampl-ecztedel/wrapper.error
-2013-08-27 01:14:04,582+0000 INFO  PutFileHandler Handler(tag: 593, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-ecztedel.error
-2013-08-27 01:14:04,582+0000 INFO  PutFileHandler Handler(tag: 593, PUT) Transfer done
-2013-08-27 01:14:04,582+0000 INFO  RequestHandler Handler(tag: 593, PUT) unregistering (send)
-2013-08-27 01:14:04,583+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:04,583+0000 INFO  RequestHandler Handler(tag: 2750, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,583+0000 INFO  RequestHandler Handler(tag: 594, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,583+0000 INFO  PutFileHandler Handler(tag: 2751, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/e/runampl-ecztedel/wrapper.log
-2013-08-27 01:14:04,583+0000 INFO  PutFileHandler Handler(tag: 2751, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-ecztedel.info
-2013-08-27 01:14:04,583+0000 INFO  PutFileCommand Sending Command(tag: 595, PUT) (t) on cpipe://1
-2013-08-27 01:14:04,583+0000 INFO  PutFileCommand Command(tag: 595, PUT) (t) sending data
-2013-08-27 01:14:04,583+0000 INFO  PutFileHandler Handler(tag: 2751, PUT) -> 595
-2013-08-27 01:14:04,583+0000 INFO  PutFileHandler Handler(tag: 595, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/e/runampl-ecztedel/wrapper.log
-2013-08-27 01:14:04,583+0000 INFO  PutFileHandler Handler(tag: 595, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-ecztedel.info
-2013-08-27 01:14:04,585+0000 INFO  PutFileHandler Handler(tag: 595, PUT) Transfer done
-2013-08-27 01:14:04,585+0000 INFO  RequestHandler Handler(tag: 595, PUT) unregistering (send)
-2013-08-27 01:14:04,585+0000 INFO  PutFileHandler Handler(tag: 2749, PUT) Transfer done
-2013-08-27 01:14:04,585+0000 INFO  RequestHandler Handler(tag: 2749, PUT) unregistering (send)
-2013-08-27 01:14:04,587+0000 INFO  PutFileHandler Handler(tag: 2751, PUT) Transfer done
-2013-08-27 01:14:04,587+0000 INFO  RequestHandler Handler(tag: 2751, PUT) unregistering (send)
-2013-08-27 01:14:04,591+0000 INFO  GetFileHandler Handler(tag: 3277, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,591+0000 INFO  GetFileHandler Handler(tag: 3277, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,591+0000 INFO  GetFileHandler Handler(tag: 3277, GET) -> 596
-2013-08-27 01:14:04,591+0000 INFO  GetFileHandler Handler(tag: 596, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,591+0000 INFO  GetFileHandler Handler(tag: 596, GET) reader: LR-Handler(tag: 596, GET)
-2013-08-27 01:14:04,591+0000 INFO  GetFileHandler Handler(tag: 596, GET) sending length: 14799449, 622473303
-2013-08-27 01:14:04,591+0000 INFO  ReadBuffer RB-LR-Handler(tag: 596, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:04,591+0000 INFO  ReadBuffer RB-LR-Handler(tag: 596, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:04,591+0000 INFO  LocalIOProvider LR-Handler(tag: 596, GET) rbuf: RB-LR-Handler(tag: 596, GET)
-2013-08-27 01:14:04,595+0000 INFO  GetFileHandler Handler(tag: 3277, GET) sending length: 14799449, 976656080
-2013-08-27 01:14:04,604+0000 INFO  GetFileHandler Handler(tag: 3278, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,605+0000 INFO  GetFileHandler Handler(tag: 3278, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,605+0000 INFO  GetFileHandler Handler(tag: 3278, GET) -> 597
-2013-08-27 01:14:04,605+0000 INFO  GetFileHandler Handler(tag: 597, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,605+0000 INFO  GetFileHandler Handler(tag: 597, GET) reader: LR-Handler(tag: 597, GET)
-2013-08-27 01:14:04,605+0000 INFO  GetFileHandler Handler(tag: 597, GET) sending length: 14799449, 1159158460
-2013-08-27 01:14:04,605+0000 INFO  ReadBuffer RB-LR-Handler(tag: 597, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:04,605+0000 INFO  ReadBuffer RB-LR-Handler(tag: 597, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:04,605+0000 INFO  LocalIOProvider LR-Handler(tag: 597, GET) rbuf: RB-LR-Handler(tag: 597, GET)
-2013-08-27 01:14:04,612+0000 INFO  GetFileHandler Handler(tag: 3278, GET) sending length: 14799449, 2009698607
-2013-08-27 01:14:04,618+0000 INFO  ProxyIOProvider Command(tag: 567, GET) resuming
-2013-08-27 01:14:04,618+0000 INFO  GetFileHandler Handler(tag: 567, GET) resuming
-2013-08-27 01:14:04,625+0000 INFO  GetFileHandler Handler(tag: 3279, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,625+0000 INFO  GetFileHandler Handler(tag: 3279, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,625+0000 INFO  GetFileHandler Handler(tag: 3279, GET) -> 598
-2013-08-27 01:14:04,625+0000 INFO  GetFileHandler Handler(tag: 598, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,625+0000 INFO  GetFileHandler Handler(tag: 598, GET) reader: LR-Handler(tag: 598, GET)
-2013-08-27 01:14:04,625+0000 INFO  GetFileHandler Handler(tag: 598, GET) sending length: 14799449, 1286734220
-2013-08-27 01:14:04,625+0000 INFO  ReadBuffer RB-LR-Handler(tag: 598, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:04,625+0000 INFO  ReadBuffer RB-LR-Handler(tag: 598, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:04,625+0000 INFO  LocalIOProvider LR-Handler(tag: 598, GET) rbuf: RB-LR-Handler(tag: 598, GET)
-2013-08-27 01:14:04,639+0000 INFO  GetFileHandler Handler(tag: 3279, GET) sending length: 14799449, 487311849
-2013-08-27 01:14:04,646+0000 INFO  GetFileHandler Handler(tag: 3280, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,646+0000 INFO  GetFileHandler Handler(tag: 3280, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,646+0000 INFO  GetFileHandler Handler(tag: 3280, GET) -> 599
-2013-08-27 01:14:04,646+0000 INFO  GetFileHandler Handler(tag: 599, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,646+0000 INFO  GetFileHandler Handler(tag: 599, GET) reader: LR-Handler(tag: 599, GET)
-2013-08-27 01:14:04,646+0000 INFO  GetFileHandler Handler(tag: 599, GET) sending length: 14799449, 1617949867
-2013-08-27 01:14:04,647+0000 INFO  ReadBuffer RB-LR-Handler(tag: 599, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:04,647+0000 INFO  ReadBuffer RB-LR-Handler(tag: 599, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:04,647+0000 INFO  LocalIOProvider LR-Handler(tag: 599, GET) rbuf: RB-LR-Handler(tag: 599, GET)
-2013-08-27 01:14:04,652+0000 INFO  GetFileHandler Handler(tag: 3281, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,652+0000 INFO  GetFileHandler Handler(tag: 3281, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,652+0000 INFO  GetFileHandler Handler(tag: 3281, GET) -> 600
-2013-08-27 01:14:04,652+0000 INFO  GetFileHandler Handler(tag: 600, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,652+0000 INFO  GetFileHandler Handler(tag: 600, GET) reader: LR-Handler(tag: 600, GET)
-2013-08-27 01:14:04,652+0000 INFO  GetFileHandler Handler(tag: 600, GET) sending length: 148937, 1786083621
-2013-08-27 01:14:04,652+0000 INFO  ReadBuffer RB-LR-Handler(tag: 600, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:04,652+0000 INFO  ReadBuffer RB-LR-Handler(tag: 600, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:04,652+0000 INFO  LocalIOProvider LR-Handler(tag: 600, GET) rbuf: RB-LR-Handler(tag: 600, GET)
-2013-08-27 01:14:04,652+0000 INFO  GetFileHandler Handler(tag: 600, GET) unregistering (last)
-2013-08-27 01:14:04,652+0000 INFO  ReadBuffer RB-LR-Handler(tag: 600, GET) de-allocating 5 buffers
-2013-08-27 01:14:04,652+0000 INFO  GetFileHandler Handler(tag: 3282, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,652+0000 INFO  GetFileHandler Handler(tag: 3282, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,652+0000 INFO  GetFileHandler Handler(tag: 3282, GET) -> 601
-2013-08-27 01:14:04,652+0000 INFO  GetFileHandler Handler(tag: 601, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,652+0000 INFO  GetFileHandler Handler(tag: 601, GET) reader: LR-Handler(tag: 601, GET)
-2013-08-27 01:14:04,652+0000 INFO  GetFileHandler Handler(tag: 601, GET) sending length: 14799449, 2029537893
-2013-08-27 01:14:04,652+0000 INFO  ReadBuffer RB-LR-Handler(tag: 601, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:04,652+0000 INFO  ReadBuffer RB-LR-Handler(tag: 601, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:04,652+0000 INFO  LocalIOProvider LR-Handler(tag: 601, GET) rbuf: RB-LR-Handler(tag: 601, GET)
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 3283, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 3283, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 3283, GET) -> 602
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 602, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 3284, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 3284, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 602, GET) reader: LR-Handler(tag: 602, GET)
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 3284, GET) -> 603
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 602, GET) sending length: 14799449, 172249620
-2013-08-27 01:14:04,658+0000 INFO  ReadBuffer RB-LR-Handler(tag: 602, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:04,658+0000 INFO  ReadBuffer RB-LR-Handler(tag: 602, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:04,658+0000 INFO  LocalIOProvider LR-Handler(tag: 602, GET) rbuf: RB-LR-Handler(tag: 602, GET)
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 3285, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 603, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 3285, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 603, GET) reader: LR-Handler(tag: 603, GET)
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 3285, GET) -> 604
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 603, GET) sending length: 2093, 50038282
-2013-08-27 01:14:04,658+0000 INFO  ReadBuffer RB-LR-Handler(tag: 603, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:04,658+0000 INFO  ReadBuffer RB-LR-Handler(tag: 603, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,658+0000 INFO  LocalIOProvider LR-Handler(tag: 603, GET) rbuf: RB-LR-Handler(tag: 603, GET)
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 3286, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 604, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 603, GET) unregistering (last)
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 3286, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 604, GET) reader: LR-Handler(tag: 604, GET)
-2013-08-27 01:14:04,658+0000 INFO  ReadBuffer RB-LR-Handler(tag: 603, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 3286, GET) -> 605
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 604, GET) sending length: 2093, 2011685390
-2013-08-27 01:14:04,658+0000 INFO  ReadBuffer RB-LR-Handler(tag: 604, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:04,658+0000 INFO  ReadBuffer RB-LR-Handler(tag: 604, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,658+0000 INFO  LocalIOProvider LR-Handler(tag: 604, GET) rbuf: RB-LR-Handler(tag: 604, GET)
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 604, GET) unregistering (last)
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 3287, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 605, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:04,658+0000 INFO  ReadBuffer RB-LR-Handler(tag: 604, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 3287, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 605, GET) reader: LR-Handler(tag: 605, GET)
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 3287, GET) -> 606
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 605, GET) sending length: 2093, 1375512148
-2013-08-27 01:14:04,658+0000 INFO  ReadBuffer RB-LR-Handler(tag: 605, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:04,658+0000 INFO  ReadBuffer RB-LR-Handler(tag: 605, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,658+0000 INFO  LocalIOProvider LR-Handler(tag: 605, GET) rbuf: RB-LR-Handler(tag: 605, GET)
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 605, GET) unregistering (last)
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 606, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:04,658+0000 INFO  ReadBuffer RB-LR-Handler(tag: 605, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 606, GET) reader: LR-Handler(tag: 606, GET)
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 606, GET) sending length: 2093, 1099459077
-2013-08-27 01:14:04,658+0000 INFO  ReadBuffer RB-LR-Handler(tag: 606, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:04,658+0000 INFO  ReadBuffer RB-LR-Handler(tag: 606, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,658+0000 INFO  LocalIOProvider LR-Handler(tag: 606, GET) rbuf: RB-LR-Handler(tag: 606, GET)
-2013-08-27 01:14:04,658+0000 INFO  GetFileHandler Handler(tag: 606, GET) unregistering (last)
-2013-08-27 01:14:04,659+0000 INFO  ReadBuffer RB-LR-Handler(tag: 606, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,667+0000 INFO  GetFileHandler Handler(tag: 3280, GET) sending length: 14799449, 306031668
-2013-08-27 01:14:04,676+0000 INFO  GetFileHandler Handler(tag: 3281, GET) sending length: 148937, 1525752316
-2013-08-27 01:14:04,678+0000 INFO  GetFileHandler Handler(tag: 3281, GET) unregistering (last)
-2013-08-27 01:14:04,678+0000 INFO  GetFileHandler Handler(tag: 3282, GET) sending length: 14799449, 1934782336
-2013-08-27 01:14:04,688+0000 INFO  GetFileHandler Handler(tag: 3283, GET) sending length: 14799449, 34162781
-2013-08-27 01:14:04,691+0000 INFO  GetFileHandler Handler(tag: 3284, GET) sending length: 2093, 1394918157
-2013-08-27 01:14:04,694+0000 INFO  GetFileHandler Handler(tag: 3284, GET) unregistering (last)
-2013-08-27 01:14:04,694+0000 INFO  GetFileHandler Handler(tag: 3285, GET) sending length: 2093, 26890590
-2013-08-27 01:14:04,695+0000 INFO  GetFileHandler Handler(tag: 3285, GET) unregistering (last)
-2013-08-27 01:14:04,695+0000 INFO  GetFileHandler Handler(tag: 3286, GET) sending length: 2093, 1568661094
-2013-08-27 01:14:04,695+0000 INFO  GetFileHandler Handler(tag: 3286, GET) unregistering (last)
-2013-08-27 01:14:04,695+0000 INFO  GetFileHandler Handler(tag: 3287, GET) sending length: 2093, 1398010536
-2013-08-27 01:14:04,696+0000 INFO  GetFileHandler Handler(tag: 3287, GET) unregistering (last)
-2013-08-27 01:14:04,747+0000 INFO  ProxyIOProvider Command(tag: 568, GET) resuming
-2013-08-27 01:14:04,748+0000 INFO  GetFileHandler Handler(tag: 568, GET) resuming
-2013-08-27 01:14:04,790+0000 INFO  GetFileHandler Handler(tag: 2752, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,790+0000 INFO  GetFileHandler Handler(tag: 2752, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,790+0000 INFO  GetFileHandler Handler(tag: 2752, GET) -> 607
-2013-08-27 01:14:04,790+0000 INFO  GetFileHandler Handler(tag: 607, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,791+0000 INFO  GetFileHandler Handler(tag: 607, GET) reader: LR-Handler(tag: 607, GET)
-2013-08-27 01:14:04,791+0000 INFO  GetFileHandler Handler(tag: 607, GET) sending length: 148937, 1516729653
-2013-08-27 01:14:04,791+0000 INFO  ReadBuffer RB-LR-Handler(tag: 607, GET) will ask for 5 buffers for a size of 148937
-2013-08-27 01:14:04,791+0000 INFO  ReadBuffer RB-LR-Handler(tag: 607, GET) actual allocated buffers 5(0 queued)
-2013-08-27 01:14:04,791+0000 INFO  LocalIOProvider LR-Handler(tag: 607, GET) rbuf: RB-LR-Handler(tag: 607, GET)
-2013-08-27 01:14:04,791+0000 INFO  GetFileHandler Handler(tag: 607, GET) unregistering (last)
-2013-08-27 01:14:04,791+0000 INFO  ReadBuffer RB-LR-Handler(tag: 607, GET) de-allocating 5 buffers
-2013-08-27 01:14:04,791+0000 DEBUG Cpu Failed Job failed with and exit code of 1
-2013-08-27 01:14:04,791+0000 INFO  Cpu 0827-1301520-000001:2 jobTerminated
-2013-08-27 01:14:04,791+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=2
-2013-08-27 01:14:04,791+0000 INFO  RequestHandler Handler(tag: 2753, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,791+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=2 Cpus sleeping: 1
-2013-08-27 01:14:04,791+0000 DEBUG Cpu 0827-1301520-000001:2 sleeping
-2013-08-27 01:14:04,791+0000 INFO  RequestHandler Handler(tag: 608, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,792+0000 INFO  RequestHandler Handler(tag: 609, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,792+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:14:04,792+0000 INFO  RequestHandler Handler(tag: 2754, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,792+0000 INFO  RequestHandler Handler(tag: 610, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,792+0000 INFO  GetFileHandler Handler(tag: 2755, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,792+0000 INFO  GetFileHandler Handler(tag: 2755, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,792+0000 INFO  GetFileHandler Handler(tag: 2755, GET) -> 611
-2013-08-27 01:14:04,792+0000 INFO  GetFileHandler Handler(tag: 611, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,792+0000 INFO  GetFileHandler Handler(tag: 611, GET) reader: LR-Handler(tag: 611, GET)
-2013-08-27 01:14:04,792+0000 INFO  GetFileHandler Handler(tag: 611, GET) sending length: 1925, 915935524
-2013-08-27 01:14:04,792+0000 INFO  ReadBuffer RB-LR-Handler(tag: 611, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:04,792+0000 INFO  ReadBuffer RB-LR-Handler(tag: 611, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,792+0000 INFO  LocalIOProvider LR-Handler(tag: 611, GET) rbuf: RB-LR-Handler(tag: 611, GET)
-2013-08-27 01:14:04,792+0000 INFO  GetFileHandler Handler(tag: 611, GET) unregistering (last)
-2013-08-27 01:14:04,792+0000 INFO  ReadBuffer RB-LR-Handler(tag: 611, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,793+0000 INFO  LateBindingScheduler jobs queued: 1
-2013-08-27 01:14:04,793+0000 INFO  RequestHandler Handler(tag: 612, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,793+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:14:04,793+0000 INFO  RequestHandler Handler(tag: 2756, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,793+0000 INFO  RequestHandler Handler(tag: 613, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,793+0000 INFO  GetFileHandler Handler(tag: 2757, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,793+0000 INFO  GetFileHandler Handler(tag: 2757, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,794+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-jcztedel - Application exception: Job failed with and exit code of 1
-org.globus.cog.abstraction.impl.common.execution.JobException: Job failed with and exit code of 1 (exit code: 1)
-	at org.globus.cog.abstraction.coaster.service.local.JobStatusHandler.requestComplete(JobStatusHandler.java:40)
-	at org.globus.cog.coaster.handlers.RequestHandler.receiveCompleted(RequestHandler.java:88)
-	at org.globus.cog.coaster.channels.AbstractCoasterChannel.handleRequest(AbstractCoasterChannel.java:527)
-	at org.globus.cog.coaster.channels.AbstractStreamCoasterChannel.stepNIO(AbstractStreamCoasterChannel.java:238)
-	at org.globus.cog.coaster.channels.NIOMultiplexer.loop(NIOMultiplexer.java:97)
-	at org.globus.cog.coaster.channels.NIOMultiplexer.run(NIOMultiplexer.java:56)
-Caused by: org.globus.cog.abstraction.impl.common.execution.JobException: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:04,794+0000 INFO  GetFileHandler Handler(tag: 2757, GET) -> 614
-2013-08-27 01:14:04,794+0000 INFO  GetFileHandler Handler(tag: 614, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,794+0000 INFO  GetFileHandler Handler(tag: 614, GET) reader: LR-Handler(tag: 614, GET)
-2013-08-27 01:14:04,794+0000 INFO  GetFileHandler Handler(tag: 614, GET) sending length: 1925, 364847502
-2013-08-27 01:14:04,794+0000 INFO  ReadBuffer RB-LR-Handler(tag: 614, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:04,794+0000 INFO  ReadBuffer RB-LR-Handler(tag: 614, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,794+0000 INFO  LocalIOProvider LR-Handler(tag: 614, GET) rbuf: RB-LR-Handler(tag: 614, GET)
-2013-08-27 01:14:04,794+0000 INFO  GetFileHandler Handler(tag: 614, GET) unregistering (last)
-2013-08-27 01:14:04,794+0000 INFO  ReadBuffer RB-LR-Handler(tag: 614, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,794+0000 DEBUG Cpu Failed Job failed with and exit code of 1
-2013-08-27 01:14:04,794+0000 INFO  Cpu 0827-1301520-000001:4 jobTerminated
-2013-08-27 01:14:04,794+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=4
-2013-08-27 01:14:04,794+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=4 Cpus sleeping: 2
-2013-08-27 01:14:04,794+0000 INFO  RequestHandler Handler(tag: 2758, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,794+0000 DEBUG Cpu 0827-1301520-000001:4 sleeping
-2013-08-27 01:14:04,794+0000 INFO  RequestHandler Handler(tag: 615, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,794+0000 INFO  Cpu 0827-1301520-000001:6 jobTerminated
-2013-08-27 01:14:04,794+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=6
-2013-08-27 01:14:04,794+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=6 Cpus sleeping: 3
-2013-08-27 01:14:04,794+0000 INFO  RequestHandler Handler(tag: 2759, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,794+0000 DEBUG Cpu 0827-1301520-000001:6 sleeping
-2013-08-27 01:14:04,794+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-ldztedel thread=R-42-0-1x2-13-0 host=midway replicationGroup=null
-2013-08-27 01:14:04,795+0000 INFO  RequestHandler Handler(tag: 616, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,795+0000 DEBUG Cpu Failed Job failed with and exit code of 1
-2013-08-27 01:14:04,795+0000 INFO  Cpu 0827-1301520-000001:3 jobTerminated
-2013-08-27 01:14:04,795+0000 DEBUG swift JOB_START jobid=runampl-ldztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0013.out, outdir/xhat_l20000_0001.0013.out, obj_outdir/obj_out_l0000_0001.0013.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0013.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/l/runampl-ldztedel host=midway
-2013-08-27 01:14:04,795+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=3
-2013-08-27 01:14:04,795+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=3 Cpus sleeping: 4
-2013-08-27 01:14:04,795+0000 INFO  RequestHandler Handler(tag: 2760, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,795+0000 DEBUG Cpu 0827-1301520-000001:3 sleeping
-2013-08-27 01:14:04,795+0000 INFO  RequestHandler Handler(tag: 617, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,795+0000 INFO  Cpu 0827-1301520-000001:9 jobTerminated
-2013-08-27 01:14:04,795+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=9
-2013-08-27 01:14:04,795+0000 INFO  RequestHandler Handler(tag: 2761, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,795+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=9 Cpus sleeping: 5
-2013-08-27 01:14:04,795+0000 DEBUG Cpu 0827-1301520-000001:9 sleeping
-2013-08-27 01:14:04,795+0000 INFO  LateBindingScheduler jobs queued: 1
-2013-08-27 01:14:04,796+0000 INFO  Cpu 0827-1301520-000001:12 jobTerminated
-2013-08-27 01:14:04,796+0000 INFO  RequestHandler Handler(tag: 618, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,796+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=12
-2013-08-27 01:14:04,796+0000 INFO  RequestHandler Handler(tag: 2762, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,796+0000 DEBUG Cpu Failed Job failed with and exit code of 1
-2013-08-27 01:14:04,796+0000 INFO  RequestHandler Handler(tag: 619, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,796+0000 INFO  Cpu 0827-1301520-000001:10 jobTerminated
-2013-08-27 01:14:04,796+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=10
-2013-08-27 01:14:04,796+0000 INFO  RequestHandler Handler(tag: 2763, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,796+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=12 Cpus sleeping: 6
-2013-08-27 01:14:04,796+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-8cztedel - Application exception: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:04,796+0000 DEBUG Cpu 0827-1301520-000001:12 sleeping
-2013-08-27 01:14:04,796+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=10 Cpus sleeping: 7
-2013-08-27 01:14:04,796+0000 DEBUG Cpu 0827-1301520-000001:10 sleeping
-2013-08-27 01:14:04,796+0000 INFO  LateBindingScheduler jobs queued: 1
-2013-08-27 01:14:04,796+0000 INFO  RequestHandler Handler(tag: 620, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,797+0000 DEBUG Cpu Failed Job failed with and exit code of 1
-2013-08-27 01:14:04,797+0000 INFO  LateBindingScheduler jobs queued: 3
-2013-08-27 01:14:04,797+0000 INFO  Cpu 0827-1301520-000001:8 jobTerminated
-2013-08-27 01:14:04,797+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=8
-2013-08-27 01:14:04,797+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=8 Cpus sleeping: 8
-2013-08-27 01:14:04,797+0000 INFO  RequestHandler Handler(tag: 2764, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,797+0000 DEBUG Cpu 0827-1301520-000001:8 sleeping
-2013-08-27 01:14:04,797+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-ocztedel - Application exception: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:04,797+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-acztedel - Application exception: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:04,797+0000 INFO  Cpu 0827-1301520-000001:15 jobTerminated
-2013-08-27 01:14:04,797+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=15
-2013-08-27 01:14:04,797+0000 INFO  RequestHandler Handler(tag: 621, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,798+0000 INFO  RequestHandler Handler(tag: 2765, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,798+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-mdztedel thread=R-42-0-1x2-9-0 host=midway replicationGroup=null
-2013-08-27 01:14:04,798+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=15 Cpus sleeping: 9
-2013-08-27 01:14:04,798+0000 DEBUG Cpu 0827-1301520-000001:15 sleeping
-2013-08-27 01:14:04,798+0000 INFO  LateBindingScheduler jobs queued: 2
-2013-08-27 01:14:04,798+0000 DEBUG Cpu Failed Job failed with and exit code of 1
-2013-08-27 01:14:04,798+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-gcztedel - Application exception: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:04,798+0000 INFO  RequestHandler Handler(tag: 622, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,798+0000 DEBUG swift JOB_START jobid=runampl-mdztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0009.out, outdir/xhat_l20000_0001.0009.out, obj_outdir/obj_out_l0000_0001.0009.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0009.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/m/runampl-mdztedel host=midway
-2013-08-27 01:14:04,798+0000 INFO  Cpu 0827-1301520-000001:11 jobTerminated
-2013-08-27 01:14:04,799+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-ndztedel thread=R-42-0-1x2-2-0 host=midway replicationGroup=null
-2013-08-27 01:14:04,799+0000 INFO  RequestHandler Handler(tag: 623, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,799+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=11
-2013-08-27 01:14:04,799+0000 INFO  RequestHandler Handler(tag: 2766, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,799+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=11 Cpus sleeping: 10
-2013-08-27 01:14:04,799+0000 DEBUG Cpu 0827-1301520-000001:11 sleeping
-2013-08-27 01:14:04,799+0000 DEBUG swift JOB_START jobid=runampl-ndztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0002.out, outdir/xhat_l20000_0001.0002.out, obj_outdir/obj_out_l0000_0001.0002.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0002.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/n/runampl-ndztedel host=midway
-2013-08-27 01:14:04,800+0000 INFO  LateBindingScheduler jobs queued: 0
-2013-08-27 01:14:04,800+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-odztedel thread=R-42-0-1x2-11-0 host=midway replicationGroup=null
-2013-08-27 01:14:04,800+0000 DEBUG Cpu Failed Job failed with and exit code of 1
-2013-08-27 01:14:04,800+0000 INFO  Cpu 0827-1301520-000001:13 jobTerminated
-2013-08-27 01:14:04,800+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=13
-2013-08-27 01:14:04,800+0000 INFO  RequestHandler Handler(tag: 2767, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,800+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-lcztedel - Application exception: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:04,800+0000 INFO  LateBindingScheduler jobs queued: 2
-2013-08-27 01:14:04,800+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=13 Cpus sleeping: 11
-2013-08-27 01:14:04,801+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-rcztedel - Application exception: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:04,801+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-pdztedel thread=R-42-0-1-0x3 host=midway replicationGroup=null
-2013-08-27 01:14:04,801+0000 DEBUG Cpu 0827-1301520-000001:13 sleeping
-2013-08-27 01:14:04,800+0000 DEBUG swift JOB_START jobid=runampl-odztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0011.out, outdir/xhat_l20000_0001.0011.out, obj_outdir/obj_out_l0000_0001.0011.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0011.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/o/runampl-odztedel host=midway
-2013-08-27 01:14:04,801+0000 DEBUG Cpu Failed Job failed with and exit code of 1
-2013-08-27 01:14:04,801+0000 INFO  Cpu 0827-1301520-000001:7 jobTerminated
-2013-08-27 01:14:04,801+0000 DEBUG swift JOB_START jobid=runampl-pdztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0000.0000.out, outdir/xhat_l20000_0000.0000.out, obj_outdir/obj_out_l0000_0000.0000.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0000.0000.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/p/runampl-pdztedel host=midway
-2013-08-27 01:14:04,801+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=7
-2013-08-27 01:14:04,801+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=7 Cpus sleeping: 12
-2013-08-27 01:14:04,801+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-7cztedel - Application exception: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:04,801+0000 DEBUG Cpu 0827-1301520-000001:7 sleeping
-2013-08-27 01:14:04,801+0000 INFO  LateBindingScheduler jobs queued: 1
-2013-08-27 01:14:04,801+0000 INFO  RequestHandler Handler(tag: 2768, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,801+0000 INFO  RequestHandler Handler(tag: 624, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,802+0000 DEBUG Cpu Failed Job failed with and exit code of 1
-2013-08-27 01:14:04,802+0000 INFO  Cpu 0827-1301520-000001:14 jobTerminated
-2013-08-27 01:14:04,802+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=14
-2013-08-27 01:14:04,803+0000 INFO  RequestHandler Handler(tag: 2769, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,802+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-dcztedel - Application exception: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:04,803+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-qdztedel thread=R-42-0x2 host=midway replicationGroup=null
-2013-08-27 01:14:04,803+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-ncztedel - Application exception: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:04,803+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=14 Cpus sleeping: 13
-2013-08-27 01:14:04,803+0000 DEBUG Cpu 0827-1301520-000001:14 sleeping
-2013-08-27 01:14:04,803+0000 INFO  RequestHandler Handler(tag: 625, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,803+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-rdztedel thread=R-42-0-1x2-16-0 host=midway replicationGroup=null
-2013-08-27 01:14:04,803+0000 DEBUG swift JOB_START jobid=runampl-qdztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat10000.out, outdir/xhat20000.out, obj_outdir/obj_ampl0000.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res0000.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/q/runampl-qdztedel host=midway
-2013-08-27 01:14:04,803+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-sdztedel thread=R-42-0-1-0-8-0 host=midway replicationGroup=null
-2013-08-27 01:14:04,804+0000 INFO  LateBindingScheduler jobs queued: 0
-2013-08-27 01:14:04,804+0000 DEBUG swift JOB_START jobid=runampl-sdztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0000.0008.out, outdir/xhat_l20000_0000.0008.out, obj_outdir/obj_out_l0000_0000.0008.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0000.0008.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/s/runampl-sdztedel host=midway
-2013-08-27 01:14:04,804+0000 INFO  RequestHandler Handler(tag: 626, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,804+0000 DEBUG swift JOB_START jobid=runampl-rdztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0016.out, outdir/xhat_l20000_0001.0016.out, obj_outdir/obj_out_l0000_0001.0016.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0016.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/r/runampl-rdztedel host=midway
-2013-08-27 01:14:04,804+0000 INFO  LateBindingScheduler jobs queued: 4
-2013-08-27 01:14:04,804+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-qcztedel - Application exception: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:04,805+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-udztedel thread=R-42-0-1x2-0x2 host=midway replicationGroup=null
-2013-08-27 01:14:04,805+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-vdztedel thread=R-42-0-1-0-4-0 host=midway replicationGroup=null
-2013-08-27 01:14:04,805+0000 DEBUG swift JOB_START jobid=runampl-udztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0000.out, outdir/xhat_l20000_0001.0000.out, obj_outdir/obj_out_l0000_0001.0000.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0000.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/u/runampl-udztedel host=midway
-2013-08-27 01:14:04,805+0000 DEBUG swift JOB_START jobid=runampl-vdztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0000.0004.out, outdir/xhat_l20000_0000.0004.out, obj_outdir/obj_out_l0000_0000.0004.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0000.0004.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/v/runampl-vdztedel host=midway
-2013-08-27 01:14:04,807+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-9cztedel - Application exception: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:04,807+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-tdztedel thread=R-42-0-1-0-10-0 host=midway replicationGroup=null
-2013-08-27 01:14:04,807+0000 DEBUG swift JOB_START jobid=runampl-tdztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0000.0010.out, outdir/xhat_l20000_0000.0010.out, obj_outdir/obj_out_l0000_0000.0010.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0000.0010.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/t/runampl-tdztedel host=midway
-2013-08-27 01:14:04,807+0000 INFO  LateBindingScheduler jobs queued: 1
-2013-08-27 01:14:04,809+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-xdztedel thread=R-42-0-1-0-1-0 host=midway replicationGroup=null
-2013-08-27 01:14:04,809+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-ecztedel - Application exception: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:04,809+0000 DEBUG swift JOB_START jobid=runampl-xdztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0000.0001.out, outdir/xhat_l20000_0000.0001.out, obj_outdir/obj_out_l0000_0000.0001.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0000.0001.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/x/runampl-xdztedel host=midway
-2013-08-27 01:14:04,809+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-ydztedel thread=R-42-0-1x2-7-0 host=midway replicationGroup=null
-2013-08-27 01:14:04,810+0000 DEBUG swift JOB_START jobid=runampl-ydztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0007.out, outdir/xhat_l20000_0001.0007.out, obj_outdir/obj_out_l0000_0001.0007.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0007.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/y/runampl-ydztedel host=midway
-2013-08-27 01:14:04,811+0000 INFO  GetFileHandler Handler(tag: 2752, GET) sending length: 148937, 1043552805
-2013-08-27 01:14:04,811+0000 INFO  GetFileHandler Handler(tag: 2752, GET) unregistering (last)
-2013-08-27 01:14:04,812+0000 INFO  GetFileHandler Handler(tag: 2755, GET) sending length: 1925, 29141635
-2013-08-27 01:14:04,813+0000 INFO  GetFileHandler Handler(tag: 2755, GET) unregistering (last)
-2013-08-27 01:14:04,814+0000 INFO  GetFileHandler Handler(tag: 2770, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:04,814+0000 INFO  GetFileHandler Handler(tag: 2770, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:04,814+0000 INFO  GetFileHandler Handler(tag: 2770, GET) -> 627
-2013-08-27 01:14:04,814+0000 INFO  GetFileHandler Handler(tag: 627, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:04,814+0000 INFO  GetFileHandler Handler(tag: 627, GET) reader: LR-Handler(tag: 627, GET)
-2013-08-27 01:14:04,814+0000 INFO  GetFileHandler Handler(tag: 627, GET) sending length: 543, 1583157172
-2013-08-27 01:14:04,814+0000 INFO  ReadBuffer RB-LR-Handler(tag: 627, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:04,814+0000 INFO  ReadBuffer RB-LR-Handler(tag: 627, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,814+0000 INFO  LocalIOProvider LR-Handler(tag: 627, GET) rbuf: RB-LR-Handler(tag: 627, GET)
-2013-08-27 01:14:04,814+0000 INFO  GetFileHandler Handler(tag: 2771, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,814+0000 INFO  GetFileHandler Handler(tag: 627, GET) unregistering (last)
-2013-08-27 01:14:04,814+0000 INFO  ReadBuffer RB-LR-Handler(tag: 627, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,814+0000 INFO  GetFileHandler Handler(tag: 2771, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,814+0000 INFO  GetFileHandler Handler(tag: 2771, GET) -> 628
-2013-08-27 01:14:04,814+0000 INFO  GetFileHandler Handler(tag: 628, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,814+0000 INFO  GetFileHandler Handler(tag: 628, GET) reader: LR-Handler(tag: 628, GET)
-2013-08-27 01:14:04,814+0000 INFO  GetFileHandler Handler(tag: 628, GET) sending length: 14799449, 1477190004
-2013-08-27 01:14:04,814+0000 INFO  ReadBuffer RB-LR-Handler(tag: 628, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:04,814+0000 INFO  ReadBuffer RB-LR-Handler(tag: 628, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:04,814+0000 INFO  LocalIOProvider LR-Handler(tag: 628, GET) rbuf: RB-LR-Handler(tag: 628, GET)
-2013-08-27 01:14:04,815+0000 INFO  GetFileHandler Handler(tag: 2757, GET) sending length: 1925, 1703716661
-2013-08-27 01:14:04,816+0000 INFO  GetFileHandler Handler(tag: 2757, GET) unregistering (last)
-2013-08-27 01:14:04,816+0000 INFO  GetFileHandler Handler(tag: 2772, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,816+0000 INFO  GetFileHandler Handler(tag: 2772, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,816+0000 INFO  GetFileHandler Handler(tag: 2772, GET) -> 629
-2013-08-27 01:14:04,816+0000 INFO  GetFileHandler Handler(tag: 629, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,816+0000 INFO  GetFileHandler Handler(tag: 629, GET) reader: LR-Handler(tag: 629, GET)
-2013-08-27 01:14:04,816+0000 INFO  GetFileHandler Handler(tag: 629, GET) sending length: 14799449, 1211075981
-2013-08-27 01:14:04,816+0000 INFO  ReadBuffer RB-LR-Handler(tag: 629, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:04,816+0000 INFO  ReadBuffer RB-LR-Handler(tag: 629, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:04,816+0000 INFO  LocalIOProvider LR-Handler(tag: 629, GET) rbuf: RB-LR-Handler(tag: 629, GET)
-2013-08-27 01:14:04,820+0000 INFO  RequestHandler Handler(tag: 53, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:04,826+0000 INFO  RequestHandler Handler(tag: 55, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:04,826+0000 INFO  RequestHandler Handler(tag: 56, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:04,827+0000 INFO  RequestHandler Handler(tag: 57, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:04,827+0000 INFO  RequestHandler Handler(tag: 54, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:04,827+0000 INFO  ProxyIOProvider Command(tag: 591, GET) suspending
-2013-08-27 01:14:04,827+0000 INFO  GetFileHandler Handler(tag: 591, GET) suspending
-2013-08-27 01:14:04,828+0000 INFO  RequestHandler Handler(tag: 58, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:04,830+0000 INFO  RequestHandler Handler(tag: 59, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:04,830+0000 INFO  RequestHandler Handler(tag: 60, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:04,831+0000 INFO  RequestHandler Handler(tag: 61, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:04,831+0000 INFO  RequestHandler Handler(tag: 62, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:04,832+0000 INFO  RequestHandler Handler(tag: 63, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:04,832+0000 INFO  RequestHandler Handler(tag: 64, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:04,833+0000 INFO  RequestHandler Handler(tag: 65, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:04,834+0000 INFO  GetFileHandler Handler(tag: 2770, GET) sending length: 543, 805363256
-2013-08-27 01:14:04,834+0000 INFO  GetFileHandler Handler(tag: 2770, GET) unregistering (last)
-2013-08-27 01:14:04,835+0000 INFO  GetFileHandler Handler(tag: 2771, GET) sending length: 14799449, 1146586674
-2013-08-27 01:14:04,835+0000 INFO  GetFileHandler Handler(tag: 2773, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:04,835+0000 INFO  GetFileHandler Handler(tag: 2773, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:04,835+0000 INFO  GetFileHandler Handler(tag: 2773, GET) -> 630
-2013-08-27 01:14:04,835+0000 INFO  GetFileHandler Handler(tag: 630, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run
-2013-08-27 01:14:04,835+0000 INFO  GetFileHandler Handler(tag: 630, GET) reader: LR-Handler(tag: 630, GET)
-2013-08-27 01:14:04,835+0000 INFO  GetFileHandler Handler(tag: 630, GET) sending length: 2093, 498863731
-2013-08-27 01:14:04,835+0000 INFO  ReadBuffer RB-LR-Handler(tag: 630, GET) will ask for 1 buffers for a size of 2093
-2013-08-27 01:14:04,835+0000 INFO  ReadBuffer RB-LR-Handler(tag: 630, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,835+0000 INFO  LocalIOProvider LR-Handler(tag: 630, GET) rbuf: RB-LR-Handler(tag: 630, GET)
-2013-08-27 01:14:04,835+0000 INFO  GetFileHandler Handler(tag: 630, GET) unregistering (last)
-2013-08-27 01:14:04,835+0000 INFO  ReadBuffer RB-LR-Handler(tag: 630, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,838+0000 INFO  GetFileHandler Handler(tag: 2772, GET) sending length: 14799449, 1349382820
-2013-08-27 01:14:04,843+0000 INFO  ProxyIOProvider Command(tag: 583, GET) resuming
-2013-08-27 01:14:04,843+0000 INFO  GetFileHandler Handler(tag: 583, GET) resuming
-2013-08-27 01:14:04,853+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=8 Cpus sleeping: 1
-2013-08-27 01:14:04,853+0000 INFO  Cpu 0827-1301520-000001:8 (quality: 0.5) submitting urn:1377566032233-1377566032285-1377566032286: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0013.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0013.out|outdir/xhat_l10000_000
 1.0013.out|outdir/xhat_l20000_0001.0013.out|Results/ampl_res_l0000_0001.0013.out|outdir/out_l0000_0001.0013.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0013.out outdir/xhat_l20000_0001.0013.out obj_outdir/obj_out_l0000_0001.0013.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0013.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,853+0000 INFO  RequestHandler Handler(tag: 631, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,853+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=13 Cpus sleeping: 1
-2013-08-27 01:14:04,853+0000 INFO  Cpu 0827-1301520-000001:13 (quality: 0.5) submitting urn:1377566032256-1377566032288-1377566032289: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0011.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0011.out|outdir/xhat_l10000_00
 01.0011.out|outdir/xhat_l20000_0001.0011.out|Results/ampl_res_l0000_0001.0011.out|outdir/out_l0000_0001.0011.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0011.out outdir/xhat_l20000_0001.0011.out obj_outdir/obj_out_l0000_0001.0011.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0011.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,854+0000 INFO  RequestHandler Handler(tag: 632, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,854+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=2 Cpus sleeping: 1
-2013-08-27 01:14:04,854+0000 INFO  Cpu 0827-1301520-000001:2 (quality: 0.5) submitting urn:1377566032259-1377566032291-1377566032292: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0002.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0002.out|outdir/xhat_l10000_000
 1.0002.out|outdir/xhat_l20000_0001.0002.out|Results/ampl_res_l0000_0001.0002.out|outdir/out_l0000_0001.0002.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0002.out outdir/xhat_l20000_0001.0002.out obj_outdir/obj_out_l0000_0001.0002.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0002.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,854+0000 INFO  RequestHandler Handler(tag: 633, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,854+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=3 Cpus sleeping: 1
-2013-08-27 01:14:04,854+0000 INFO  Cpu 0827-1301520-000001:3 (quality: 0.5) submitting urn:1377566032262-1377566032294-1377566032295: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0000.0000.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0000.0000.out|outdir/xhat_l10000_000
 0.0000.out|outdir/xhat_l20000_0000.0000.out|Results/ampl_res_l0000_0000.0000.out|outdir/out_l0000_0000.0000.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0000.0000.out outdir/xhat_l20000_0000.0000.out obj_outdir/obj_out_l0000_0000.0000.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0000.0000.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,854+0000 INFO  RequestHandler Handler(tag: 634, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,854+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=6 Cpus sleeping: 1
-2013-08-27 01:14:04,854+0000 INFO  Cpu 0827-1301520-000001:6 (quality: 0.5) submitting urn:1377566032251-1377566032297-1377566032298: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0009.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0009.out|outdir/xhat_l10000_000
 1.0009.out|outdir/xhat_l20000_0001.0009.out|Results/ampl_res_l0000_0001.0009.out|outdir/out_l0000_0001.0009.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0009.out outdir/xhat_l20000_0001.0009.out obj_outdir/obj_out_l0000_0001.0009.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0009.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,854+0000 INFO  RequestHandler Handler(tag: 635, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,855+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=11 Cpus sleeping: 1
-2013-08-27 01:14:04,855+0000 INFO  Cpu 0827-1301520-000001:11 (quality: 0.5) submitting urn:1377566032264-1377566032300-1377566032301: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/ampl0000.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_ampl0000.out|outdir/xhat10000.out|outdir/xhat20000.out|R
 esults/ampl_res0000.out|outdir/ampl0000.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat10000.out outdir/xhat20000.out obj_outdir/obj_ampl0000.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res0000.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,855+0000 INFO  RequestHandler Handler(tag: 636, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,855+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=10 Cpus sleeping: 1
-2013-08-27 01:14:04,855+0000 INFO  Cpu 0827-1301520-000001:10 (quality: 0.5) submitting urn:1377566032267-1377566032303-1377566032304: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0000.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0000.out|outdir/xhat_l10000_00
 01.0000.out|outdir/xhat_l20000_0001.0000.out|Results/ampl_res_l0000_0001.0000.out|outdir/out_l0000_0001.0000.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0000.out outdir/xhat_l20000_0001.0000.out obj_outdir/obj_out_l0000_0001.0000.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0000.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,855+0000 INFO  RequestHandler Handler(tag: 637, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,855+0000 INFO  RequestHandler Handler(tag: 638, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,855+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:14:04,855+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=7 Cpus sleeping: 1
-2013-08-27 01:14:04,855+0000 INFO  RequestHandler Handler(tag: 2774, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,855+0000 INFO  RequestHandler Handler(tag: 639, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,855+0000 INFO  Cpu 0827-1301520-000001:7 (quality: 0.5) submitting urn:1377566032268-1377566032306-1377566032307: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0000.0004.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0000.0004.out|outdir/xhat_l10000_000
 0.0004.out|outdir/xhat_l20000_0000.0004.out|Results/ampl_res_l0000_0000.0004.out|outdir/out_l0000_0000.0004.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0000.0004.out outdir/xhat_l20000_0000.0004.out obj_outdir/obj_out_l0000_0000.0004.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0000.0004.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,855+0000 INFO  GetFileHandler Handler(tag: 2775, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,855+0000 INFO  RequestHandler Handler(tag: 640, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,855+0000 INFO  GetFileHandler Handler(tag: 2775, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,855+0000 INFO  GetFileHandler Handler(tag: 2775, GET) -> 641
-2013-08-27 01:14:04,855+0000 INFO  GetFileHandler Handler(tag: 641, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,855+0000 INFO  GetFileHandler Handler(tag: 641, GET) reader: LR-Handler(tag: 641, GET)
-2013-08-27 01:14:04,855+0000 INFO  GetFileHandler Handler(tag: 641, GET) sending length: 1925, 652953127
-2013-08-27 01:14:04,855+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=9 Cpus sleeping: 1
-2013-08-27 01:14:04,855+0000 INFO  ReadBuffer RB-LR-Handler(tag: 641, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:04,855+0000 INFO  ReadBuffer RB-LR-Handler(tag: 641, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,855+0000 INFO  LocalIOProvider LR-Handler(tag: 641, GET) rbuf: RB-LR-Handler(tag: 641, GET)
-2013-08-27 01:14:04,855+0000 INFO  GetFileHandler Handler(tag: 641, GET) unregistering (last)
-2013-08-27 01:14:04,855+0000 INFO  Cpu 0827-1301520-000001:9 (quality: 0.5) submitting urn:1377566032275-1377566032309-1377566032310: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0016.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0016.out|outdir/xhat_l10000_000
 1.0016.out|outdir/xhat_l20000_0001.0016.out|Results/ampl_res_l0000_0001.0016.out|outdir/out_l0000_0001.0016.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0016.out outdir/xhat_l20000_0001.0016.out obj_outdir/obj_out_l0000_0001.0016.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0016.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,855+0000 INFO  ReadBuffer RB-LR-Handler(tag: 641, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,856+0000 INFO  RequestHandler Handler(tag: 642, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,856+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=14 Cpus sleeping: 1
-2013-08-27 01:14:04,856+0000 INFO  Cpu 0827-1301520-000001:14 (quality: 0.5) submitting urn:1377566032276-1377566032312-1377566032313: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0000.0008.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0000.0008.out|outdir/xhat_l10000_00
 00.0008.out|outdir/xhat_l20000_0000.0008.out|Results/ampl_res_l0000_0000.0008.out|outdir/out_l0000_0000.0008.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0000.0008.out outdir/xhat_l20000_0000.0008.out obj_outdir/obj_out_l0000_0000.0008.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0000.0008.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,856+0000 INFO  RequestHandler Handler(tag: 643, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,856+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=12 Cpus sleeping: 1
-2013-08-27 01:14:04,856+0000 INFO  Cpu 0827-1301520-000001:12 (quality: 0.5) submitting urn:1377566032279-1377566032315-1377566032316: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0000.0010.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0000.0010.out|outdir/xhat_l10000_00
 00.0010.out|outdir/xhat_l20000_0000.0010.out|Results/ampl_res_l0000_0000.0010.out|outdir/out_l0000_0000.0010.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0000.0010.out outdir/xhat_l20000_0000.0010.out obj_outdir/obj_out_l0000_0000.0010.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0000.0010.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,856+0000 INFO  RequestHandler Handler(tag: 644, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,856+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=4 Cpus sleeping: 1
-2013-08-27 01:14:04,856+0000 INFO  Cpu 0827-1301520-000001:4 (quality: 0.5) submitting urn:1377566032281-1377566032318-1377566032319: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0000.0001.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0000.0001.out|outdir/xhat_l10000_000
 0.0001.out|outdir/xhat_l20000_0000.0001.out|Results/ampl_res_l0000_0000.0001.out|outdir/out_l0000_0000.0001.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0000.0001.out outdir/xhat_l20000_0000.0001.out obj_outdir/obj_out_l0000_0000.0001.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0000.0001.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,856+0000 INFO  RequestHandler Handler(tag: 645, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,856+0000 INFO  RequestHandler Handler(tag: 646, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,856+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=15 Cpus sleeping: 1
-2013-08-27 01:14:04,857+0000 INFO  Cpu 0827-1301520-000001:15 (quality: 0.5) submitting urn:1377566032283-1377566032321-1377566032322: /bin/bash _swiftwrap.staging -e /home/maheshwari/powergridapps/bin/run_ampl.py -out outdir/out_l0000_0001.0007.out -err stderr.txt -i -d obj_outdir|outdir|Results -if __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc|__root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat -of obj_outdir/obj_out_l0000_0001.0007.out|outdir/xhat_l10000_00
 01.0007.out|outdir/xhat_l20000_0001.0007.out|Results/ampl_res_l0000_0001.0007.out|outdir/out_l0000_0001.0007.out -k -cdmfile  -status provider -a 10 0 __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run outdir/xhat_l10000_0001.0007.out outdir/xhat_l20000_0001.0007.out obj_outdir/obj_out_l0000_0001.0007.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc Results/ampl_res_l0000_0001.0007.out __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat
-2013-08-27 01:14:04,857+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:14:04,857+0000 INFO  RequestHandler Handler(tag: 2776, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,857+0000 INFO  RequestHandler Handler(tag: 647, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,857+0000 INFO  RequestHandler Handler(tag: 648, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,857+0000 INFO  GetFileHandler Handler(tag: 2777, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,857+0000 INFO  GetFileHandler Handler(tag: 2777, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,857+0000 INFO  GetFileHandler Handler(tag: 2777, GET) -> 649
-2013-08-27 01:14:04,857+0000 INFO  GetFileHandler Handler(tag: 649, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,857+0000 INFO  GetFileHandler Handler(tag: 649, GET) reader: LR-Handler(tag: 649, GET)
-2013-08-27 01:14:04,857+0000 INFO  GetFileHandler Handler(tag: 649, GET) sending length: 1925, 1451474685
-2013-08-27 01:14:04,857+0000 INFO  ReadBuffer RB-LR-Handler(tag: 649, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:04,857+0000 INFO  ReadBuffer RB-LR-Handler(tag: 649, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,857+0000 INFO  LocalIOProvider LR-Handler(tag: 649, GET) rbuf: RB-LR-Handler(tag: 649, GET)
-2013-08-27 01:14:04,857+0000 INFO  GetFileHandler Handler(tag: 649, GET) unregistering (last)
-2013-08-27 01:14:04,857+0000 INFO  ReadBuffer RB-LR-Handler(tag: 649, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,858+0000 INFO  RequestHandler Handler(tag: 650, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,858+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:14:04,858+0000 INFO  RequestHandler Handler(tag: 2778, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,858+0000 INFO  RequestHandler Handler(tag: 651, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,858+0000 INFO  GetFileHandler Handler(tag: 2779, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,858+0000 INFO  GetFileHandler Handler(tag: 2779, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,858+0000 INFO  GetFileHandler Handler(tag: 2779, GET) -> 652
-2013-08-27 01:14:04,858+0000 INFO  GetFileHandler Handler(tag: 652, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,858+0000 INFO  GetFileHandler Handler(tag: 652, GET) reader: LR-Handler(tag: 652, GET)
-2013-08-27 01:14:04,858+0000 INFO  GetFileHandler Handler(tag: 652, GET) sending length: 1925, 37278946
-2013-08-27 01:14:04,858+0000 INFO  ReadBuffer RB-LR-Handler(tag: 652, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:04,858+0000 INFO  ReadBuffer RB-LR-Handler(tag: 652, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,858+0000 INFO  LocalIOProvider LR-Handler(tag: 652, GET) rbuf: RB-LR-Handler(tag: 652, GET)
-2013-08-27 01:14:04,858+0000 INFO  GetFileHandler Handler(tag: 652, GET) unregistering (last)
-2013-08-27 01:14:04,858+0000 INFO  ReadBuffer RB-LR-Handler(tag: 652, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,858+0000 INFO  GetFileHandler Handler(tag: 2773, GET) sending length: 2093, 217214824
-2013-08-27 01:14:04,858+0000 INFO  GetFileHandler Handler(tag: 2773, GET) unregistering (last)
-2013-08-27 01:14:04,859+0000 INFO  RequestHandler Handler(tag: 653, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,859+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:14:04,859+0000 INFO  RequestHandler Handler(tag: 2780, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,859+0000 INFO  RequestHandler Handler(tag: 654, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,859+0000 INFO  GetFileHandler Handler(tag: 2781, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,859+0000 INFO  GetFileHandler Handler(tag: 2781, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,860+0000 INFO  GetFileHandler Handler(tag: 2781, GET) -> 655
-2013-08-27 01:14:04,860+0000 INFO  GetFileHandler Handler(tag: 655, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,860+0000 INFO  GetFileHandler Handler(tag: 655, GET) reader: LR-Handler(tag: 655, GET)
-2013-08-27 01:14:04,860+0000 INFO  GetFileHandler Handler(tag: 655, GET) sending length: 1925, 1519238493
-2013-08-27 01:14:04,860+0000 INFO  ReadBuffer RB-LR-Handler(tag: 655, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:04,860+0000 INFO  ReadBuffer RB-LR-Handler(tag: 655, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,860+0000 INFO  LocalIOProvider LR-Handler(tag: 655, GET) rbuf: RB-LR-Handler(tag: 655, GET)
-2013-08-27 01:14:04,860+0000 INFO  GetFileHandler Handler(tag: 655, GET) unregistering (last)
-2013-08-27 01:14:04,860+0000 INFO  ReadBuffer RB-LR-Handler(tag: 655, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,861+0000 INFO  RequestHandler Handler(tag: 656, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,861+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:14:04,861+0000 INFO  RequestHandler Handler(tag: 657, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,861+0000 INFO  RequestHandler Handler(tag: 2782, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,861+0000 INFO  GetFileHandler Handler(tag: 2783, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,861+0000 INFO  GetFileHandler Handler(tag: 2783, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,861+0000 INFO  GetFileHandler Handler(tag: 2783, GET) -> 658
-2013-08-27 01:14:04,861+0000 INFO  GetFileHandler Handler(tag: 658, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,861+0000 INFO  GetFileHandler Handler(tag: 658, GET) reader: LR-Handler(tag: 658, GET)
-2013-08-27 01:14:04,861+0000 INFO  GetFileHandler Handler(tag: 658, GET) sending length: 1925, 1807020015
-2013-08-27 01:14:04,861+0000 INFO  ReadBuffer RB-LR-Handler(tag: 658, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:04,861+0000 INFO  ReadBuffer RB-LR-Handler(tag: 658, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,861+0000 INFO  LocalIOProvider LR-Handler(tag: 658, GET) rbuf: RB-LR-Handler(tag: 658, GET)
-2013-08-27 01:14:04,861+0000 INFO  GetFileHandler Handler(tag: 658, GET) unregistering (last)
-2013-08-27 01:14:04,861+0000 INFO  ReadBuffer RB-LR-Handler(tag: 658, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,862+0000 INFO  RequestHandler Handler(tag: 659, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,862+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:14:04,862+0000 INFO  RequestHandler Handler(tag: 2784, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,862+0000 INFO  RequestHandler Handler(tag: 660, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,862+0000 INFO  GetFileHandler Handler(tag: 2785, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,862+0000 INFO  GetFileHandler Handler(tag: 2785, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,862+0000 INFO  GetFileHandler Handler(tag: 2785, GET) -> 661
-2013-08-27 01:14:04,862+0000 INFO  GetFileHandler Handler(tag: 661, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,862+0000 INFO  GetFileHandler Handler(tag: 661, GET) reader: LR-Handler(tag: 661, GET)
-2013-08-27 01:14:04,862+0000 INFO  GetFileHandler Handler(tag: 661, GET) sending length: 1925, 1389311915
-2013-08-27 01:14:04,862+0000 INFO  ReadBuffer RB-LR-Handler(tag: 661, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:04,862+0000 INFO  ReadBuffer RB-LR-Handler(tag: 661, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,862+0000 INFO  LocalIOProvider LR-Handler(tag: 661, GET) rbuf: RB-LR-Handler(tag: 661, GET)
-2013-08-27 01:14:04,862+0000 INFO  GetFileHandler Handler(tag: 661, GET) unregistering (last)
-2013-08-27 01:14:04,862+0000 INFO  ReadBuffer RB-LR-Handler(tag: 661, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,863+0000 INFO  RequestHandler Handler(tag: 662, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,864+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:14:04,864+0000 INFO  RequestHandler Handler(tag: 2786, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,864+0000 INFO  RequestHandler Handler(tag: 663, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,864+0000 INFO  GetFileHandler Handler(tag: 2787, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,864+0000 INFO  GetFileHandler Handler(tag: 2787, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,864+0000 INFO  GetFileHandler Handler(tag: 2787, GET) -> 664
-2013-08-27 01:14:04,864+0000 INFO  GetFileHandler Handler(tag: 664, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,864+0000 INFO  GetFileHandler Handler(tag: 664, GET) reader: LR-Handler(tag: 664, GET)
-2013-08-27 01:14:04,864+0000 INFO  GetFileHandler Handler(tag: 664, GET) sending length: 1925, 349983176
-2013-08-27 01:14:04,864+0000 INFO  ReadBuffer RB-LR-Handler(tag: 664, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:04,864+0000 INFO  ReadBuffer RB-LR-Handler(tag: 664, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,864+0000 INFO  LocalIOProvider LR-Handler(tag: 664, GET) rbuf: RB-LR-Handler(tag: 664, GET)
-2013-08-27 01:14:04,864+0000 INFO  GetFileHandler Handler(tag: 664, GET) unregistering (last)
-2013-08-27 01:14:04,864+0000 INFO  ReadBuffer RB-LR-Handler(tag: 664, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,865+0000 INFO  RequestHandler Handler(tag: 665, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,865+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:14:04,865+0000 INFO  RequestHandler Handler(tag: 2788, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,865+0000 INFO  RequestHandler Handler(tag: 666, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,865+0000 INFO  GetFileHandler Handler(tag: 2789, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,865+0000 INFO  GetFileHandler Handler(tag: 2789, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,865+0000 INFO  GetFileHandler Handler(tag: 2789, GET) -> 667
-2013-08-27 01:14:04,865+0000 INFO  GetFileHandler Handler(tag: 667, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,865+0000 INFO  GetFileHandler Handler(tag: 667, GET) reader: LR-Handler(tag: 667, GET)
-2013-08-27 01:14:04,865+0000 INFO  GetFileHandler Handler(tag: 667, GET) sending length: 1925, 997121798
-2013-08-27 01:14:04,865+0000 INFO  ReadBuffer RB-LR-Handler(tag: 667, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:04,865+0000 INFO  ReadBuffer RB-LR-Handler(tag: 667, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,865+0000 INFO  LocalIOProvider LR-Handler(tag: 667, GET) rbuf: RB-LR-Handler(tag: 667, GET)
-2013-08-27 01:14:04,865+0000 INFO  GetFileHandler Handler(tag: 667, GET) unregistering (last)
-2013-08-27 01:14:04,865+0000 INFO  ReadBuffer RB-LR-Handler(tag: 667, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,866+0000 INFO  RequestHandler Handler(tag: 668, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,866+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:14:04,866+0000 INFO  RequestHandler Handler(tag: 2790, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,866+0000 INFO  RequestHandler Handler(tag: 669, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,866+0000 INFO  GetFileHandler Handler(tag: 2791, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,866+0000 INFO  GetFileHandler Handler(tag: 2791, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,866+0000 INFO  GetFileHandler Handler(tag: 2791, GET) -> 670
-2013-08-27 01:14:04,866+0000 INFO  GetFileHandler Handler(tag: 670, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,866+0000 INFO  GetFileHandler Handler(tag: 670, GET) reader: LR-Handler(tag: 670, GET)
-2013-08-27 01:14:04,866+0000 INFO  GetFileHandler Handler(tag: 670, GET) sending length: 1925, 956662815
-2013-08-27 01:14:04,866+0000 INFO  ReadBuffer RB-LR-Handler(tag: 670, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:04,866+0000 INFO  ReadBuffer RB-LR-Handler(tag: 670, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,866+0000 INFO  LocalIOProvider LR-Handler(tag: 670, GET) rbuf: RB-LR-Handler(tag: 670, GET)
-2013-08-27 01:14:04,866+0000 INFO  GetFileHandler Handler(tag: 670, GET) unregistering (last)
-2013-08-27 01:14:04,866+0000 INFO  ReadBuffer RB-LR-Handler(tag: 670, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,867+0000 INFO  RequestHandler Handler(tag: 671, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,867+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:14:04,867+0000 INFO  RequestHandler Handler(tag: 672, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,867+0000 INFO  RequestHandler Handler(tag: 2792, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,867+0000 INFO  GetFileHandler Handler(tag: 2793, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,867+0000 INFO  GetFileHandler Handler(tag: 2793, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,867+0000 INFO  GetFileHandler Handler(tag: 2793, GET) -> 673
-2013-08-27 01:14:04,867+0000 INFO  GetFileHandler Handler(tag: 673, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,867+0000 INFO  GetFileHandler Handler(tag: 673, GET) reader: LR-Handler(tag: 673, GET)
-2013-08-27 01:14:04,867+0000 INFO  GetFileHandler Handler(tag: 673, GET) sending length: 1925, 1202767937
-2013-08-27 01:14:04,867+0000 INFO  ReadBuffer RB-LR-Handler(tag: 673, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:04,867+0000 INFO  ReadBuffer RB-LR-Handler(tag: 673, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,867+0000 INFO  LocalIOProvider LR-Handler(tag: 673, GET) rbuf: RB-LR-Handler(tag: 673, GET)
-2013-08-27 01:14:04,867+0000 INFO  GetFileHandler Handler(tag: 673, GET) unregistering (last)
-2013-08-27 01:14:04,867+0000 INFO  ReadBuffer RB-LR-Handler(tag: 673, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,868+0000 INFO  RequestHandler Handler(tag: 674, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,868+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:14:04,868+0000 INFO  RequestHandler Handler(tag: 2794, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,868+0000 INFO  RequestHandler Handler(tag: 675, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,868+0000 INFO  GetFileHandler Handler(tag: 2795, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,868+0000 INFO  GetFileHandler Handler(tag: 2795, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,868+0000 INFO  GetFileHandler Handler(tag: 2795, GET) -> 676
-2013-08-27 01:14:04,868+0000 INFO  GetFileHandler Handler(tag: 676, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,868+0000 INFO  GetFileHandler Handler(tag: 676, GET) reader: LR-Handler(tag: 676, GET)
-2013-08-27 01:14:04,868+0000 INFO  GetFileHandler Handler(tag: 676, GET) sending length: 1925, 1208475863
-2013-08-27 01:14:04,868+0000 INFO  ReadBuffer RB-LR-Handler(tag: 676, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:04,868+0000 INFO  ReadBuffer RB-LR-Handler(tag: 676, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,868+0000 INFO  LocalIOProvider LR-Handler(tag: 676, GET) rbuf: RB-LR-Handler(tag: 676, GET)
-2013-08-27 01:14:04,868+0000 INFO  GetFileHandler Handler(tag: 676, GET) unregistering (last)
-2013-08-27 01:14:04,868+0000 INFO  ReadBuffer RB-LR-Handler(tag: 676, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,869+0000 INFO  RequestHandler Handler(tag: 677, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,869+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:14:04,869+0000 INFO  RequestHandler Handler(tag: 2796, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,869+0000 INFO  RequestHandler Handler(tag: 678, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,869+0000 INFO  GetFileHandler Handler(tag: 2797, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,869+0000 INFO  GetFileHandler Handler(tag: 2797, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,869+0000 INFO  GetFileHandler Handler(tag: 2797, GET) -> 679
-2013-08-27 01:14:04,869+0000 INFO  GetFileHandler Handler(tag: 679, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,869+0000 INFO  GetFileHandler Handler(tag: 679, GET) reader: LR-Handler(tag: 679, GET)
-2013-08-27 01:14:04,869+0000 INFO  GetFileHandler Handler(tag: 679, GET) sending length: 1925, 1776045928
-2013-08-27 01:14:04,869+0000 INFO  ReadBuffer RB-LR-Handler(tag: 679, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:04,869+0000 INFO  ReadBuffer RB-LR-Handler(tag: 679, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,869+0000 INFO  LocalIOProvider LR-Handler(tag: 679, GET) rbuf: RB-LR-Handler(tag: 679, GET)
-2013-08-27 01:14:04,869+0000 INFO  GetFileHandler Handler(tag: 679, GET) unregistering (last)
-2013-08-27 01:14:04,869+0000 INFO  ReadBuffer RB-LR-Handler(tag: 679, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,870+0000 INFO  RequestHandler Handler(tag: 680, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,870+0000 DEBUG Cpu Stagein workerid=000000
-2013-08-27 01:14:04,870+0000 INFO  RequestHandler Handler(tag: 2798, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,870+0000 INFO  RequestHandler Handler(tag: 681, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,870+0000 INFO  GetFileHandler Handler(tag: 2799, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,870+0000 INFO  GetFileHandler Handler(tag: 2799, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,870+0000 INFO  GetFileHandler Handler(tag: 2799, GET) -> 682
-2013-08-27 01:14:04,870+0000 INFO  GetFileHandler Handler(tag: 682, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc
-2013-08-27 01:14:04,870+0000 INFO  GetFileHandler Handler(tag: 682, GET) reader: LR-Handler(tag: 682, GET)
-2013-08-27 01:14:04,870+0000 INFO  GetFileHandler Handler(tag: 682, GET) sending length: 1925, 1416516259
-2013-08-27 01:14:04,870+0000 INFO  ReadBuffer RB-LR-Handler(tag: 682, GET) will ask for 1 buffers for a size of 1925
-2013-08-27 01:14:04,870+0000 INFO  ReadBuffer RB-LR-Handler(tag: 682, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,870+0000 INFO  LocalIOProvider LR-Handler(tag: 682, GET) rbuf: RB-LR-Handler(tag: 682, GET)
-2013-08-27 01:14:04,870+0000 INFO  GetFileHandler Handler(tag: 682, GET) unregistering (last)
-2013-08-27 01:14:04,870+0000 INFO  ReadBuffer RB-LR-Handler(tag: 682, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,872+0000 INFO  GetFileHandler Handler(tag: 2800, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:04,872+0000 INFO  GetFileHandler Handler(tag: 2800, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:04,872+0000 INFO  GetFileHandler Handler(tag: 2800, GET) -> 683
-2013-08-27 01:14:04,872+0000 INFO  GetFileHandler Handler(tag: 683, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:04,872+0000 INFO  GetFileHandler Handler(tag: 683, GET) reader: LR-Handler(tag: 683, GET)
-2013-08-27 01:14:04,872+0000 INFO  GetFileHandler Handler(tag: 683, GET) sending length: 5032, 1240584986
-2013-08-27 01:14:04,872+0000 INFO  ReadBuffer RB-LR-Handler(tag: 683, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:04,872+0000 INFO  ReadBuffer RB-LR-Handler(tag: 683, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,872+0000 INFO  LocalIOProvider LR-Handler(tag: 683, GET) rbuf: RB-LR-Handler(tag: 683, GET)
-2013-08-27 01:14:04,872+0000 INFO  GetFileHandler Handler(tag: 683, GET) unregistering (last)
-2013-08-27 01:14:04,872+0000 INFO  ReadBuffer RB-LR-Handler(tag: 683, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,880+0000 INFO  GetFileHandler Handler(tag: 2775, GET) sending length: 1925, 133274679
-2013-08-27 01:14:04,881+0000 INFO  GetFileHandler Handler(tag: 2775, GET) unregistering (last)
-2013-08-27 01:14:04,881+0000 INFO  GetFileHandler Handler(tag: 2801, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,881+0000 INFO  GetFileHandler Handler(tag: 2801, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,881+0000 INFO  GetFileHandler Handler(tag: 2801, GET) -> 684
-2013-08-27 01:14:04,881+0000 INFO  GetFileHandler Handler(tag: 684, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,881+0000 INFO  GetFileHandler Handler(tag: 684, GET) reader: LR-Handler(tag: 684, GET)
-2013-08-27 01:14:04,881+0000 INFO  GetFileHandler Handler(tag: 684, GET) sending length: 14799449, 226356279
-2013-08-27 01:14:04,881+0000 INFO  ReadBuffer RB-LR-Handler(tag: 684, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:04,881+0000 INFO  ReadBuffer RB-LR-Handler(tag: 684, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:04,881+0000 INFO  LocalIOProvider LR-Handler(tag: 684, GET) rbuf: RB-LR-Handler(tag: 684, GET)
-2013-08-27 01:14:04,882+0000 INFO  GetFileHandler Handler(tag: 2777, GET) sending length: 1925, 584067083
-2013-08-27 01:14:04,882+0000 INFO  GetFileHandler Handler(tag: 2777, GET) unregistering (last)
-2013-08-27 01:14:04,882+0000 INFO  GetFileHandler Handler(tag: 2802, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,882+0000 INFO  GetFileHandler Handler(tag: 2802, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,882+0000 INFO  GetFileHandler Handler(tag: 2802, GET) -> 685
-2013-08-27 01:14:04,882+0000 INFO  GetFileHandler Handler(tag: 685, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,882+0000 INFO  GetFileHandler Handler(tag: 2779, GET) sending length: 1925, 931424247
-2013-08-27 01:14:04,882+0000 INFO  GetFileHandler Handler(tag: 685, GET) reader: LR-Handler(tag: 685, GET)
-2013-08-27 01:14:04,882+0000 INFO  GetFileHandler Handler(tag: 685, GET) sending length: 14799449, 586894708
-2013-08-27 01:14:04,882+0000 INFO  ReadBuffer RB-LR-Handler(tag: 685, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:04,883+0000 INFO  ReadBuffer RB-LR-Handler(tag: 685, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:04,883+0000 INFO  LocalIOProvider LR-Handler(tag: 685, GET) rbuf: RB-LR-Handler(tag: 685, GET)
-2013-08-27 01:14:04,883+0000 INFO  GetFileHandler Handler(tag: 2779, GET) unregistering (last)
-2013-08-27 01:14:04,884+0000 INFO  GetFileHandler Handler(tag: 2803, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,884+0000 INFO  GetFileHandler Handler(tag: 2803, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,884+0000 INFO  GetFileHandler Handler(tag: 2803, GET) -> 686
-2013-08-27 01:14:04,884+0000 INFO  GetFileHandler Handler(tag: 686, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,884+0000 INFO  GetFileHandler Handler(tag: 686, GET) reader: LR-Handler(tag: 686, GET)
-2013-08-27 01:14:04,884+0000 INFO  GetFileHandler Handler(tag: 686, GET) sending length: 14799449, 1670602101
-2013-08-27 01:14:04,884+0000 INFO  ReadBuffer RB-LR-Handler(tag: 686, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:04,884+0000 INFO  ReadBuffer RB-LR-Handler(tag: 686, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:04,884+0000 INFO  LocalIOProvider LR-Handler(tag: 686, GET) rbuf: RB-LR-Handler(tag: 686, GET)
-2013-08-27 01:14:04,885+0000 INFO  GetFileHandler Handler(tag: 2781, GET) sending length: 1925, 500076814
-2013-08-27 01:14:04,886+0000 INFO  GetFileHandler Handler(tag: 2781, GET) unregistering (last)
-2013-08-27 01:14:04,888+0000 INFO  GetFileHandler Handler(tag: 2804, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,888+0000 INFO  GetFileHandler Handler(tag: 2783, GET) sending length: 1925, 1607436604
-2013-08-27 01:14:04,888+0000 INFO  GetFileHandler Handler(tag: 2783, GET) unregistering (last)
-2013-08-27 01:14:04,888+0000 INFO  GetFileHandler Handler(tag: 2804, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,888+0000 INFO  GetFileHandler Handler(tag: 2804, GET) -> 687
-2013-08-27 01:14:04,888+0000 INFO  GetFileHandler Handler(tag: 687, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,889+0000 INFO  GetFileHandler Handler(tag: 687, GET) reader: LR-Handler(tag: 687, GET)
-2013-08-27 01:14:04,889+0000 INFO  GetFileHandler Handler(tag: 687, GET) sending length: 14799449, 157861601
-2013-08-27 01:14:04,889+0000 INFO  ReadBuffer RB-LR-Handler(tag: 687, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:04,889+0000 INFO  ReadBuffer RB-LR-Handler(tag: 687, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:04,889+0000 INFO  LocalIOProvider LR-Handler(tag: 687, GET) rbuf: RB-LR-Handler(tag: 687, GET)
-2013-08-27 01:14:04,890+0000 INFO  GetFileHandler Handler(tag: 2785, GET) sending length: 1925, 1778715694
-2013-08-27 01:14:04,891+0000 INFO  ThrottleManager O maxBuffers=1024, crtBuffers=1023, allowedTransfers=0, active=0, suspended=0
-2013-08-27 01:14:04,891+0000 INFO  ThrottleManager mem=180.27 MB, heap=371.44 MB, maxHeap=910.25 MB
-2013-08-27 01:14:04,891+0000 INFO  GetFileHandler Handler(tag: 2785, GET) unregistering (last)
-2013-08-27 01:14:04,893+0000 INFO  GetFileHandler Handler(tag: 2805, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,893+0000 INFO  GetFileHandler Handler(tag: 2805, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,893+0000 INFO  GetFileHandler Handler(tag: 2805, GET) -> 688
-2013-08-27 01:14:04,893+0000 INFO  GetFileHandler Handler(tag: 688, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,893+0000 INFO  GetFileHandler Handler(tag: 2787, GET) sending length: 1925, 1519150663
-2013-08-27 01:14:04,893+0000 INFO  GetFileHandler Handler(tag: 688, GET) reader: LR-Handler(tag: 688, GET)
-2013-08-27 01:14:04,893+0000 INFO  GetFileHandler Handler(tag: 688, GET) sending length: 14799449, 932113858
-2013-08-27 01:14:04,893+0000 INFO  ReadBuffer RB-LR-Handler(tag: 688, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:04,893+0000 INFO  ReadBuffer RB-LR-Handler(tag: 688, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:04,893+0000 INFO  LocalIOProvider LR-Handler(tag: 688, GET) rbuf: RB-LR-Handler(tag: 688, GET)
-2013-08-27 01:14:04,893+0000 INFO  GetFileHandler Handler(tag: 2806, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,893+0000 INFO  GetFileHandler Handler(tag: 2806, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,893+0000 INFO  GetFileHandler Handler(tag: 2806, GET) -> 689
-2013-08-27 01:14:04,893+0000 INFO  GetFileHandler Handler(tag: 689, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,893+0000 INFO  GetFileHandler Handler(tag: 689, GET) reader: LR-Handler(tag: 689, GET)
-2013-08-27 01:14:04,893+0000 INFO  GetFileHandler Handler(tag: 689, GET) sending length: 14799449, 2140065057
-2013-08-27 01:14:04,893+0000 INFO  ReadBuffer RB-LR-Handler(tag: 689, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:04,893+0000 INFO  ReadBuffer RB-LR-Handler(tag: 689, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:04,893+0000 INFO  LocalIOProvider LR-Handler(tag: 689, GET) rbuf: RB-LR-Handler(tag: 689, GET)
-2013-08-27 01:14:04,893+0000 INFO  GetFileHandler Handler(tag: 2787, GET) unregistering (last)
-2013-08-27 01:14:04,894+0000 INFO  GetFileHandler Handler(tag: 2789, GET) sending length: 1925, 1541493866
-2013-08-27 01:14:04,894+0000 INFO  GetFileHandler Handler(tag: 2807, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,894+0000 INFO  GetFileHandler Handler(tag: 2807, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,894+0000 INFO  GetFileHandler Handler(tag: 2807, GET) -> 690
-2013-08-27 01:14:04,894+0000 INFO  GetFileHandler Handler(tag: 690, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,894+0000 INFO  GetFileHandler Handler(tag: 690, GET) reader: LR-Handler(tag: 690, GET)
-2013-08-27 01:14:04,894+0000 INFO  GetFileHandler Handler(tag: 690, GET) sending length: 14799449, 1223847263
-2013-08-27 01:14:04,894+0000 INFO  ReadBuffer RB-LR-Handler(tag: 690, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:04,894+0000 INFO  ReadBuffer RB-LR-Handler(tag: 690, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:04,894+0000 INFO  LocalIOProvider LR-Handler(tag: 690, GET) rbuf: RB-LR-Handler(tag: 690, GET)
-2013-08-27 01:14:04,894+0000 INFO  GetFileHandler Handler(tag: 2789, GET) unregistering (last)
-2013-08-27 01:14:04,895+0000 INFO  GetFileHandler Handler(tag: 2791, GET) sending length: 1925, 1350986978
-2013-08-27 01:14:04,895+0000 INFO  GetFileHandler Handler(tag: 2808, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,895+0000 INFO  GetFileHandler Handler(tag: 2808, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,895+0000 INFO  GetFileHandler Handler(tag: 2808, GET) -> 691
-2013-08-27 01:14:04,895+0000 INFO  GetFileHandler Handler(tag: 691, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,895+0000 INFO  GetFileHandler Handler(tag: 691, GET) reader: LR-Handler(tag: 691, GET)
-2013-08-27 01:14:04,895+0000 INFO  GetFileHandler Handler(tag: 691, GET) sending length: 14799449, 1924876336
-2013-08-27 01:14:04,895+0000 INFO  ReadBuffer RB-LR-Handler(tag: 691, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:04,895+0000 INFO  ReadBuffer RB-LR-Handler(tag: 691, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:04,895+0000 INFO  LocalIOProvider LR-Handler(tag: 691, GET) rbuf: RB-LR-Handler(tag: 691, GET)
-2013-08-27 01:14:04,895+0000 INFO  GetFileHandler Handler(tag: 2791, GET) unregistering (last)
-2013-08-27 01:14:04,896+0000 INFO  GetFileHandler Handler(tag: 2809, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,896+0000 INFO  GetFileHandler Handler(tag: 2809, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,896+0000 INFO  GetFileHandler Handler(tag: 2809, GET) -> 692
-2013-08-27 01:14:04,896+0000 INFO  GetFileHandler Handler(tag: 692, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,896+0000 INFO  GetFileHandler Handler(tag: 692, GET) reader: LR-Handler(tag: 692, GET)
-2013-08-27 01:14:04,896+0000 INFO  GetFileHandler Handler(tag: 692, GET) sending length: 14799449, 950746193
-2013-08-27 01:14:04,896+0000 INFO  ReadBuffer RB-LR-Handler(tag: 692, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:04,896+0000 INFO  ReadBuffer RB-LR-Handler(tag: 692, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:04,896+0000 INFO  LocalIOProvider LR-Handler(tag: 692, GET) rbuf: RB-LR-Handler(tag: 692, GET)
-2013-08-27 01:14:04,896+0000 INFO  GetFileHandler Handler(tag: 2793, GET) sending length: 1925, 671638060
-2013-08-27 01:14:04,897+0000 INFO  GetFileHandler Handler(tag: 2793, GET) unregistering (last)
-2013-08-27 01:14:04,897+0000 INFO  GetFileHandler Handler(tag: 2795, GET) sending length: 1925, 1769117532
-2013-08-27 01:14:04,897+0000 INFO  GetFileHandler Handler(tag: 2795, GET) unregistering (last)
-2013-08-27 01:14:04,897+0000 INFO  GetFileHandler Handler(tag: 2810, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,897+0000 INFO  GetFileHandler Handler(tag: 2810, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,897+0000 INFO  GetFileHandler Handler(tag: 2810, GET) -> 693
-2013-08-27 01:14:04,897+0000 INFO  GetFileHandler Handler(tag: 693, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,897+0000 INFO  GetFileHandler Handler(tag: 693, GET) reader: LR-Handler(tag: 693, GET)
-2013-08-27 01:14:04,897+0000 INFO  GetFileHandler Handler(tag: 693, GET) sending length: 14799449, 1648713402
-2013-08-27 01:14:04,897+0000 INFO  ReadBuffer RB-LR-Handler(tag: 693, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:04,897+0000 INFO  ReadBuffer RB-LR-Handler(tag: 693, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:04,897+0000 INFO  LocalIOProvider LR-Handler(tag: 693, GET) rbuf: RB-LR-Handler(tag: 693, GET)
-2013-08-27 01:14:04,897+0000 INFO  GetFileHandler Handler(tag: 2811, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,898+0000 INFO  GetFileHandler Handler(tag: 2811, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,898+0000 INFO  GetFileHandler Handler(tag: 2811, GET) -> 694
-2013-08-27 01:14:04,898+0000 INFO  GetFileHandler Handler(tag: 694, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,898+0000 INFO  GetFileHandler Handler(tag: 694, GET) reader: LR-Handler(tag: 694, GET)
-2013-08-27 01:14:04,898+0000 INFO  GetFileHandler Handler(tag: 694, GET) sending length: 14799449, 388855340
-2013-08-27 01:14:04,898+0000 INFO  ReadBuffer RB-LR-Handler(tag: 694, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:04,898+0000 INFO  ReadBuffer RB-LR-Handler(tag: 694, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:04,898+0000 INFO  LocalIOProvider LR-Handler(tag: 694, GET) rbuf: RB-LR-Handler(tag: 694, GET)
-2013-08-27 01:14:04,898+0000 INFO  GetFileHandler Handler(tag: 2797, GET) sending length: 1925, 711373023
-2013-08-27 01:14:04,898+0000 INFO  GetFileHandler Handler(tag: 2797, GET) unregistering (last)
-2013-08-27 01:14:04,899+0000 INFO  GetFileHandler Handler(tag: 2812, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,899+0000 INFO  GetFileHandler Handler(tag: 2812, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,899+0000 INFO  GetFileHandler Handler(tag: 2812, GET) -> 695
-2013-08-27 01:14:04,899+0000 INFO  GetFileHandler Handler(tag: 695, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,899+0000 INFO  GetFileHandler Handler(tag: 695, GET) reader: LR-Handler(tag: 695, GET)
-2013-08-27 01:14:04,899+0000 INFO  GetFileHandler Handler(tag: 695, GET) sending length: 14799449, 1816197624
-2013-08-27 01:14:04,899+0000 INFO  ReadBuffer RB-LR-Handler(tag: 695, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:04,899+0000 INFO  ReadBuffer RB-LR-Handler(tag: 695, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:04,899+0000 INFO  LocalIOProvider LR-Handler(tag: 695, GET) rbuf: RB-LR-Handler(tag: 695, GET)
-2013-08-27 01:14:04,899+0000 INFO  GetFileHandler Handler(tag: 2799, GET) sending length: 1925, 626708530
-2013-08-27 01:14:04,899+0000 INFO  GetFileHandler Handler(tag: 2799, GET) unregistering (last)
-2013-08-27 01:14:04,900+0000 INFO  GetFileHandler Handler(tag: 2813, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,900+0000 INFO  GetFileHandler Handler(tag: 2813, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,900+0000 INFO  GetFileHandler Handler(tag: 2813, GET) -> 696
-2013-08-27 01:14:04,900+0000 INFO  GetFileHandler Handler(tag: 696, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz
-2013-08-27 01:14:04,900+0000 INFO  GetFileHandler Handler(tag: 696, GET) reader: LR-Handler(tag: 696, GET)
-2013-08-27 01:14:04,900+0000 INFO  GetFileHandler Handler(tag: 696, GET) sending length: 14799449, 1574160590
-2013-08-27 01:14:04,900+0000 INFO  ReadBuffer RB-LR-Handler(tag: 696, GET) will ask for 8 buffers for a size of 14799449
-2013-08-27 01:14:04,900+0000 INFO  ReadBuffer RB-LR-Handler(tag: 696, GET) actual allocated buffers 8(0 queued)
-2013-08-27 01:14:04,900+0000 INFO  LocalIOProvider LR-Handler(tag: 696, GET) rbuf: RB-LR-Handler(tag: 696, GET)
-2013-08-27 01:14:04,900+0000 INFO  ThrottleManager I maxBuffers=1024, crtBuffers=208, allowedTransfers=119, active=0, suspended=0
-2013-08-27 01:14:04,900+0000 INFO  GetFileHandler Handler(tag: 2800, GET) sending length: 5032, 409614416
-2013-08-27 01:14:04,901+0000 INFO  GetFileHandler Handler(tag: 2800, GET) unregistering (last)
-2013-08-27 01:14:04,901+0000 INFO  GetFileHandler Handler(tag: 2814, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:04,901+0000 INFO  GetFileHandler Handler(tag: 2814, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:04,901+0000 INFO  GetFileHandler Handler(tag: 2814, GET) -> 697
-2013-08-27 01:14:04,901+0000 INFO  GetFileHandler Handler(tag: 697, GET) request complete; src=file://localhost//home/maheshwari/swift-devel/cog/modules/swift/dist/swift-svn/bin/../libexec/_swiftwrap.staging
-2013-08-27 01:14:04,901+0000 INFO  GetFileHandler Handler(tag: 697, GET) reader: LR-Handler(tag: 697, GET)
-2013-08-27 01:14:04,901+0000 INFO  GetFileHandler Handler(tag: 697, GET) sending length: 6078, 2010359593
-2013-08-27 01:14:04,901+0000 INFO  ReadBuffer RB-LR-Handler(tag: 697, GET) will ask for 1 buffers for a size of 6078
-2013-08-27 01:14:04,902+0000 INFO  ReadBuffer RB-LR-Handler(tag: 697, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:04,902+0000 INFO  LocalIOProvider LR-Handler(tag: 697, GET) rbuf: RB-LR-Handler(tag: 697, GET)
-2013-08-27 01:14:04,902+0000 INFO  GetFileHandler Handler(tag: 697, GET) unregistering (last)
-2013-08-27 01:14:04,902+0000 INFO  ReadBuffer RB-LR-Handler(tag: 697, GET) de-allocating 1 buffers
-2013-08-27 01:14:04,906+0000 INFO  GetFileHandler Handler(tag: 2801, GET) sending length: 14799449, 505981319
-2013-08-27 01:14:04,908+0000 INFO  GetFileHandler Handler(tag: 2802, GET) sending length: 14799449, 1944447489
-2013-08-27 01:14:04,910+0000 INFO  GetFileHandler Handler(tag: 2803, GET) sending length: 14799449, 1322260417
-2013-08-27 01:14:04,915+0000 INFO  GetFileHandler Handler(tag: 2804, GET) sending length: 14799449, 1561651729
-2013-08-27 01:14:04,919+0000 INFO  GetFileHandler Handler(tag: 2805, GET) sending length: 14799449, 540078594
-2013-08-27 01:14:04,921+0000 INFO  GetFileHandler Handler(tag: 2806, GET) sending length: 14799449, 1063990225
-2013-08-27 01:14:04,922+0000 INFO  GetFileHandler Handler(tag: 2807, GET) sending length: 14799449, 1723247785
-2013-08-27 01:14:04,923+0000 INFO  GetFileHandler Handler(tag: 2808, GET) sending length: 14799449, 1477014130
-2013-08-27 01:14:04,925+0000 INFO  GetFileHandler Handler(tag: 2809, GET) sending length: 14799449, 1909592106
-2013-08-27 01:14:04,928+0000 INFO  GetFileHandler Handler(tag: 2810, GET) sending length: 14799449, 1617017195
-2013-08-27 01:14:04,929+0000 INFO  GetFileHandler Handler(tag: 2811, GET) sending length: 14799449, 635077497
-2013-08-27 01:14:04,931+0000 INFO  GetFileHandler Handler(tag: 2812, GET) sending length: 14799449, 547346970
-2013-08-27 01:14:04,933+0000 INFO  GetFileHandler Handler(tag: 2813, GET) sending length: 14799449, 300243664
-2013-08-27 01:14:04,935+0000 INFO  GetFileHandler Handler(tag: 2814, GET) sending length: 6078, 2026604207
-2013-08-27 01:14:04,936+0000 INFO  GetFileHandler Handler(tag: 2814, GET) unregistering (last)
-2013-08-27 01:14:04,949+0000 INFO  ProxyIOProvider Command(tag: 588, GET) resuming
-2013-08-27 01:14:04,949+0000 INFO  GetFileHandler Handler(tag: 588, GET) resuming
-2013-08-27 01:14:04,983+0000 DEBUG Cpu Active workerid=0827-1301520-000001:000000
-2013-08-27 01:14:04,983+0000 INFO  RequestHandler Handler(tag: 2815, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:04,983+0000 INFO  RequestHandler Handler(tag: 698, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,010+0000 INFO  RuntimeStats$ProgressTicker   Stage in:31  Active:1  Failed but can retry:1
-2013-08-27 01:14:05,255+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:05,255+0000 INFO  RequestHandler Handler(tag: 2816, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,255+0000 INFO  RequestHandler Handler(tag: 699, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,255+0000 INFO  PutFileHandler Handler(tag: 2817, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/i/runampl-idztedel/wrapper.log
-2013-08-27 01:14:05,255+0000 INFO  PutFileHandler Handler(tag: 2817, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-idztedel.info
-2013-08-27 01:14:05,255+0000 INFO  PutFileCommand Sending Command(tag: 700, PUT) (t) on cpipe://1
-2013-08-27 01:14:05,255+0000 INFO  PutFileCommand Command(tag: 700, PUT) (t) sending data
-2013-08-27 01:14:05,255+0000 INFO  PutFileHandler Handler(tag: 2817, PUT) -> 700
-2013-08-27 01:14:05,255+0000 INFO  PutFileHandler Handler(tag: 700, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/i/runampl-idztedel/wrapper.log
-2013-08-27 01:14:05,255+0000 INFO  PutFileHandler Handler(tag: 700, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-idztedel.info
-2013-08-27 01:14:05,256+0000 DEBUG Cpu Stageout workerid=000000
-2013-08-27 01:14:05,256+0000 INFO  RequestHandler Handler(tag: 2818, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,256+0000 INFO  RequestHandler Handler(tag: 701, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,256+0000 INFO  PutFileHandler Handler(tag: 2819, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/i/runampl-idztedel/wrapper.error
-2013-08-27 01:14:05,256+0000 INFO  PutFileHandler Handler(tag: 2819, PUT) destination: proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S/inference4galaxy-20130827-0113-r1k3cjmc/runampl-idztedel.error
-2013-08-27 01:14:05,256+0000 INFO  PutFileCommand Sending Command(tag: 702, PUT) (t) on cpipe://1
-2013-08-27 01:14:05,256+0000 INFO  PutFileHandler Handler(tag: 702, PUT) source: /tmp/swift.work/inference4galaxy-20130827-0113-r1k3cjmc/jobs/i/runampl-idztedel/wrapper.error
-2013-08-27 01:14:05,256+0000 INFO  PutFileCommand Command(tag: 702, PUT) (t) sending data
-2013-08-27 01:14:05,256+0000 INFO  PutFileHandler Handler(tag: 2819, PUT) -> 702
-2013-08-27 01:14:05,256+0000 INFO  PutFileHandler Handler(tag: 702, PUT) destination: file://localhost/inference4galaxy-20130827-0113-r1k3cjmc/runampl-idztedel.error
-2013-08-27 01:14:05,257+0000 INFO  PutFileHandler Handler(tag: 700, PUT) Transfer done
-2013-08-27 01:14:05,257+0000 INFO  RequestHandler Handler(tag: 700, PUT) unregistering (send)
-2013-08-27 01:14:05,257+0000 INFO  PutFileHandler Handler(tag: 702, PUT) Transfer done
-2013-08-27 01:14:05,257+0000 INFO  RequestHandler Handler(tag: 702, PUT) unregistering (send)
-2013-08-27 01:14:05,267+0000 INFO  GetFileHandler Handler(tag: 3288, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:05,267+0000 INFO  GetFileHandler Handler(tag: 3288, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:05,267+0000 INFO  GetFileHandler Handler(tag: 3288, GET) -> 703
-2013-08-27 01:14:05,267+0000 INFO  GetFileHandler Handler(tag: 703, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc
-2013-08-27 01:14:05,267+0000 INFO  GetFileHandler Handler(tag: 703, GET) reader: LR-Handler(tag: 703, GET)
-2013-08-27 01:14:05,267+0000 INFO  GetFileHandler Handler(tag: 703, GET) sending length: 543, 119759377
-2013-08-27 01:14:05,267+0000 INFO  ReadBuffer RB-LR-Handler(tag: 703, GET) will ask for 1 buffers for a size of 543
-2013-08-27 01:14:05,267+0000 INFO  ReadBuffer RB-LR-Handler(tag: 703, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:05,267+0000 INFO  LocalIOProvider LR-Handler(tag: 703, GET) rbuf: RB-LR-Handler(tag: 703, GET)
-2013-08-27 01:14:05,267+0000 INFO  GetFileHandler Handler(tag: 703, GET) unregistering (last)
-2013-08-27 01:14:05,267+0000 INFO  ReadBuffer RB-LR-Handler(tag: 703, GET) de-allocating 1 buffers
-2013-08-27 01:14:05,277+0000 INFO  ProxyIOProvider Command(tag: 591, GET) resuming
-2013-08-27 01:14:05,277+0000 INFO  GetFileHandler Handler(tag: 591, GET) resuming
-2013-08-27 01:14:05,279+0000 INFO  GetFileHandler Handler(tag: 3289, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:05,279+0000 INFO  GetFileHandler Handler(tag: 3289, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:05,279+0000 INFO  GetFileHandler Handler(tag: 3289, GET) -> 704
-2013-08-27 01:14:05,279+0000 INFO  GetFileHandler Handler(tag: 704, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:05,279+0000 INFO  GetFileHandler Handler(tag: 704, GET) reader: LR-Handler(tag: 704, GET)
-2013-08-27 01:14:05,279+0000 INFO  GetFileHandler Handler(tag: 704, GET) sending length: 5032, 1202555572
-2013-08-27 01:14:05,279+0000 INFO  ReadBuffer RB-LR-Handler(tag: 704, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:05,279+0000 INFO  ReadBuffer RB-LR-Handler(tag: 704, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:05,279+0000 INFO  LocalIOProvider LR-Handler(tag: 704, GET) rbuf: RB-LR-Handler(tag: 704, GET)
-2013-08-27 01:14:05,279+0000 INFO  GetFileHandler Handler(tag: 704, GET) unregistering (last)
-2013-08-27 01:14:05,279+0000 INFO  ReadBuffer RB-LR-Handler(tag: 704, GET) de-allocating 1 buffers
-2013-08-27 01:14:05,279+0000 INFO  GetFileHandler Handler(tag: 3290, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:05,279+0000 INFO  GetFileHandler Handler(tag: 3290, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:05,279+0000 INFO  GetFileHandler Handler(tag: 3290, GET) -> 705
-2013-08-27 01:14:05,279+0000 INFO  GetFileHandler Handler(tag: 705, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:05,279+0000 INFO  GetFileHandler Handler(tag: 705, GET) reader: LR-Handler(tag: 705, GET)
-2013-08-27 01:14:05,280+0000 INFO  GetFileHandler Handler(tag: 705, GET) sending length: 5032, 129106928
-2013-08-27 01:14:05,280+0000 INFO  ReadBuffer RB-LR-Handler(tag: 705, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:05,280+0000 INFO  ReadBuffer RB-LR-Handler(tag: 705, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:05,280+0000 INFO  LocalIOProvider LR-Handler(tag: 705, GET) rbuf: RB-LR-Handler(tag: 705, GET)
-2013-08-27 01:14:05,280+0000 INFO  GetFileHandler Handler(tag: 705, GET) unregistering (last)
-2013-08-27 01:14:05,280+0000 INFO  ReadBuffer RB-LR-Handler(tag: 705, GET) de-allocating 1 buffers
-2013-08-27 01:14:05,280+0000 INFO  GetFileHandler Handler(tag: 3291, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:05,280+0000 INFO  GetFileHandler Handler(tag: 3291, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:05,280+0000 INFO  GetFileHandler Handler(tag: 3291, GET) -> 706
-2013-08-27 01:14:05,280+0000 INFO  GetFileHandler Handler(tag: 706, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:05,280+0000 INFO  GetFileHandler Handler(tag: 706, GET) reader: LR-Handler(tag: 706, GET)
-2013-08-27 01:14:05,280+0000 INFO  GetFileHandler Handler(tag: 706, GET) sending length: 5032, 1595750039
-2013-08-27 01:14:05,280+0000 INFO  ReadBuffer RB-LR-Handler(tag: 706, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:05,280+0000 INFO  ReadBuffer RB-LR-Handler(tag: 706, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:05,280+0000 INFO  LocalIOProvider LR-Handler(tag: 706, GET) rbuf: RB-LR-Handler(tag: 706, GET)
-2013-08-27 01:14:05,280+0000 INFO  GetFileHandler Handler(tag: 706, GET) unregistering (last)
-2013-08-27 01:14:05,280+0000 INFO  ReadBuffer RB-LR-Handler(tag: 706, GET) de-allocating 1 buffers
-2013-08-27 01:14:05,280+0000 INFO  GetFileHandler Handler(tag: 3292, GET) request complete; src=proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:05,280+0000 INFO  GetFileHandler Handler(tag: 3292, GET) reader: PR proxy://u45ce06b6-140bd55810a--7fff-u45ce06b6-140bd55810a--8000S//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:05,280+0000 INFO  GetFileHandler Handler(tag: 3292, GET) -> 707
-2013-08-27 01:14:05,280+0000 INFO  GetFileHandler Handler(tag: 707, GET) request complete; src=file://localhost//scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod
-2013-08-27 01:14:05,280+0000 INFO  GetFileHandler Handler(tag: 707, GET) reader: LR-Handler(tag: 707, GET)
-2013-08-27 01:14:05,280+0000 INFO  GetFileHandler Handler(tag: 707, GET) sending length: 5032, 1201369501
-2013-08-27 01:14:05,280+0000 INFO  ReadBuffer RB-LR-Handler(tag: 707, GET) will ask for 1 buffers for a size of 5032
-2013-08-27 01:14:05,280+0000 INFO  ReadBuffer RB-LR-Handler(tag: 707, GET) actual allocated buffers 1(0 queued)
-2013-08-27 01:14:05,280+0000 INFO  LocalIOProvider LR-Handler(tag: 707, GET) rbuf: RB-LR-Handler(tag: 707, GET)
-2013-08-27 01:14:05,280+0000 INFO  GetFileHandler Handler(tag: 707, GET) unregistering (last)
-2013-08-27 01:14:05,280+0000 INFO  ReadBuffer RB-LR-Handler(tag: 707, GET) de-allocating 1 buffers
-2013-08-27 01:14:05,312+0000 INFO  PutFileHandler Handler(tag: 2817, PUT) Transfer done
-2013-08-27 01:14:05,312+0000 INFO  RequestHandler Handler(tag: 2817, PUT) unregistering (send)
-2013-08-27 01:14:05,312+0000 INFO  PutFileHandler Handler(tag: 2819, PUT) Transfer done
-2013-08-27 01:14:05,312+0000 INFO  RequestHandler Handler(tag: 2819, PUT) unregistering (send)
-2013-08-27 01:14:05,322+0000 INFO  GetFileHandler Handler(tag: 3288, GET) sending length: 543, 1941753307
-2013-08-27 01:14:05,322+0000 INFO  GetFileHandler Handler(tag: 3288, GET) unregistering (last)
-2013-08-27 01:14:05,336+0000 INFO  GetFileHandler Handler(tag: 3289, GET) sending length: 5032, 262977498
-2013-08-27 01:14:05,337+0000 INFO  GetFileHandler Handler(tag: 3289, GET) unregistering (last)
-2013-08-27 01:14:05,337+0000 INFO  GetFileHandler Handler(tag: 3290, GET) sending length: 5032, 898386736
-2013-08-27 01:14:05,337+0000 INFO  GetFileHandler Handler(tag: 3290, GET) unregistering (last)
-2013-08-27 01:14:05,337+0000 INFO  GetFileHandler Handler(tag: 3291, GET) sending length: 5032, 323408076
-2013-08-27 01:14:05,338+0000 INFO  GetFileHandler Handler(tag: 3291, GET) unregistering (last)
-2013-08-27 01:14:05,339+0000 INFO  GetFileHandler Handler(tag: 3292, GET) sending length: 5032, 2114577770
-2013-08-27 01:14:05,339+0000 INFO  GetFileHandler Handler(tag: 3292, GET) unregistering (last)
-2013-08-27 01:14:05,391+0000 INFO  ThrottleManager O maxBuffers=1024, crtBuffers=1023, allowedTransfers=0, active=0, suspended=0
-2013-08-27 01:14:05,391+0000 INFO  ThrottleManager mem=174.48 MB, heap=398.88 MB, maxHeap=910.25 MB
-2013-08-27 01:14:05,400+0000 INFO  ThrottleManager I maxBuffers=1024, crtBuffers=208, allowedTransfers=119, active=0, suspended=0
-2013-08-27 01:14:05,444+0000 INFO  GetFileHandler Handler(tag: 567, GET) unregistering (last)
-2013-08-27 01:14:05,444+0000 INFO  ReadBuffer RB-LR-Handler(tag: 567, GET) de-allocating 8 buffers
-2013-08-27 01:14:05,501+0000 INFO  GetFileHandler Handler(tag: 3272, GET) unregistering (last)
-2013-08-27 01:14:05,613+0000 DEBUG Cpu Failed Job failed with and exit code of 1
-2013-08-27 01:14:05,613+0000 INFO  Cpu 0827-1301520-000001:5 jobTerminated
-2013-08-27 01:14:05,613+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=5
-2013-08-27 01:14:05,613+0000 INFO  RequestHandler Handler(tag: 2820, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,613+0000 DEBUG Cpu requesting work: block=0827-1301520-000001 id=5 Cpus sleeping: 1
-2013-08-27 01:14:05,613+0000 DEBUG Cpu 0827-1301520-000001:5 sleeping
-2013-08-27 01:14:05,614+0000 INFO  RequestHandler Handler(tag: 708, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,615+0000 INFO  LateBindingScheduler jobs queued: 1
-2013-08-27 01:14:05,615+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-idztedel - Application exception: Job failed with and exit code of 1
-org.globus.cog.abstraction.impl.common.execution.JobException: Job failed with and exit code of 1 (exit code: 1)
-	at org.globus.cog.abstraction.coaster.service.local.JobStatusHandler.requestComplete(JobStatusHandler.java:40)
-	at org.globus.cog.coaster.handlers.RequestHandler.receiveCompleted(RequestHandler.java:88)
-	at org.globus.cog.coaster.channels.AbstractCoasterChannel.handleRequest(AbstractCoasterChannel.java:527)
-	at org.globus.cog.coaster.channels.AbstractStreamCoasterChannel.stepNIO(AbstractStreamCoasterChannel.java:238)
-	at org.globus.cog.coaster.channels.NIOMultiplexer.loop(NIOMultiplexer.java:97)
-	at org.globus.cog.coaster.channels.NIOMultiplexer.run(NIOMultiplexer.java:56)
-Caused by: org.globus.cog.abstraction.impl.common.execution.JobException: Job failed with and exit code of 1
- (exit code: 1)
-2013-08-27 01:14:05,615+0000 INFO  swift END_FAILURE thread=R-42-0-1x2-17-0 tr=runampl
-2013-08-27 01:14:05,617+0000 INFO  Loader Swift finished with errors
-2013-08-27 01:14:05,618+0000 INFO  ServiceManager Cleaning up...
-2013-08-27 01:14:05,618+0000 INFO  ServiceManager Shutting down service at https://128.135.112.73:50002
-2013-08-27 01:14:05,674+0000 INFO  RequestHandler Handler(tag: 66, SHUTDOWNSERVICE) unregistering (send)
-2013-08-27 01:14:05,715+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-zdztedel thread=R-42-0-1x2-12-0 host=midway replicationGroup=null
-2013-08-27 01:14:05,715+0000 DEBUG swift JOB_START jobid=runampl-zdztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0012.out, outdir/xhat_l20000_0001.0012.out, obj_outdir/obj_out_l0000_0001.0012.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0012.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/z/runampl-zdztedel host=midway
-2013-08-27 01:14:05,775+0000 INFO  RequestHandler Handler(tag: 709, UNREGISTER) unregistering (send)
-2013-08-27 01:14:05,778+0000 INFO  BlockQueueProcessor Shutting down blocks
-2013-08-27 01:14:05,778+0000 INFO  Block Shutting down block Block 0827-1301520-000000 (16x7440.000s)
-2013-08-27 01:14:05,778+0000 INFO  Cpu 0827-1301520-000000-0: Job still running while shutting down
-2013-08-27 01:14:05,778+0000 INFO  RemoteLogHandler BLOCK_SHUTDOWN id=0827-1301520-000000
-2013-08-27 01:14:05,778+0000 INFO  RequestHandler Handler(tag: 710, RLOG) unregistering (send)
-2013-08-27 01:14:05,778+0000 DEBUG Cpu Failed Shutting down worker
-2013-08-27 01:14:05,778+0000 INFO  Cpu 0827-1301520-000000:0 jobTerminated
-2013-08-27 01:14:05,778+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=0
-2013-08-27 01:14:05,779+0000 INFO  RequestHandler Handler(tag: 711, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,779+0000 INFO  Cpu 0827-1301520-000000-1: Job still running while shutting down
-2013-08-27 01:14:05,779+0000 DEBUG Cpu Failed Shutting down worker
-2013-08-27 01:14:05,779+0000 INFO  Cpu 0827-1301520-000000:1 jobTerminated
-2013-08-27 01:14:05,779+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=1
-2013-08-27 01:14:05,779+0000 INFO  Cpu 0827-1301520-000000-2: Job still running while shutting down
-2013-08-27 01:14:05,779+0000 INFO  Cpu 0827-1301520-000000:2 jobTerminated
-2013-08-27 01:14:05,779+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=2
-2013-08-27 01:14:05,779+0000 INFO  Cpu 0827-1301520-000000-3: Job still running while shutting down
-2013-08-27 01:14:05,779+0000 INFO  RequestHandler Handler(tag: 712, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,779+0000 INFO  Cpu 0827-1301520-000000:3 jobTerminated
-2013-08-27 01:14:05,779+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=3
-2013-08-27 01:14:05,779+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-edztedel - Application exception: Shutting down worker
-2013-08-27 01:14:05,779+0000 INFO  Cpu 0827-1301520-000000-4: Job still running while shutting down
-2013-08-27 01:14:05,779+0000 INFO  Cpu 0827-1301520-000000:4 jobTerminated
-2013-08-27 01:14:05,779+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=4
-2013-08-27 01:14:05,779+0000 INFO  Cpu 0827-1301520-000000-5: Job still running while shutting down
-2013-08-27 01:14:05,779+0000 INFO  RequestHandler Handler(tag: 713, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,780+0000 DEBUG Cpu Failed Shutting down worker
-2013-08-27 01:14:05,780+0000 INFO  RequestHandler Handler(tag: 714, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,780+0000 INFO  Cpu 0827-1301520-000000:5 jobTerminated
-2013-08-27 01:14:05,780+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=5
-2013-08-27 01:14:05,780+0000 INFO  Cpu 0827-1301520-000000-6: Job still running while shutting down
-2013-08-27 01:14:05,780+0000 INFO  Cpu 0827-1301520-000000:6 jobTerminated
-2013-08-27 01:14:05,780+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=6
-2013-08-27 01:14:05,780+0000 INFO  Cpu 0827-1301520-000000-7: Job still running while shutting down
-2013-08-27 01:14:05,780+0000 INFO  RequestHandler Handler(tag: 715, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,780+0000 INFO  swift END_FAILURE thread=R-42-0-1x2-10-0 tr=runampl
-2013-08-27 01:14:05,780+0000 INFO  Cpu 0827-1301520-000000:7 jobTerminated
-2013-08-27 01:14:05,780+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=7
-2013-08-27 01:14:05,780+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-gdztedel - Application exception: Shutting down worker
-2013-08-27 01:14:05,780+0000 INFO  Cpu 0827-1301520-000000-8: Job still running while shutting down
-2013-08-27 01:14:05,780+0000 INFO  Cpu 0827-1301520-000000:8 jobTerminated
-2013-08-27 01:14:05,780+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=8
-2013-08-27 01:14:05,780+0000 INFO  Cpu 0827-1301520-000000-9: Job still running while shutting down
-2013-08-27 01:14:05,780+0000 INFO  Cpu 0827-1301520-000000:9 jobTerminated
-2013-08-27 01:14:05,780+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=9
-2013-08-27 01:14:05,780+0000 INFO  Cpu 0827-1301520-000000-10: Job still running while shutting down
-2013-08-27 01:14:05,780+0000 INFO  swift END_FAILURE thread=R-42-0-1x2-5-0 tr=runampl
-2013-08-27 01:14:05,782+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-5dztedel - Application exception: Shutting down worker
-2013-08-27 01:14:05,782+0000 INFO  Cpu 0827-1301520-000000:10 jobTerminated
-2013-08-27 01:14:05,782+0000 INFO  RequestHandler Handler(tag: 716, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,782+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=10
-2013-08-27 01:14:05,782+0000 INFO  Cpu 0827-1301520-000000-11: Job still running while shutting down
-2013-08-27 01:14:05,782+0000 DEBUG Cpu Failed Shutting down worker
-2013-08-27 01:14:05,782+0000 INFO  Cpu 0827-1301520-000000:11 jobTerminated
-2013-08-27 01:14:05,782+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=11
-2013-08-27 01:14:05,782+0000 INFO  Cpu 0827-1301520-000000-12: Job still running while shutting down
-2013-08-27 01:14:05,782+0000 INFO  Cpu 0827-1301520-000000:12 jobTerminated
-2013-08-27 01:14:05,782+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=12
-2013-08-27 01:14:05,782+0000 INFO  swift END_FAILURE thread=R-42-0-1-0-3-0 tr=runampl
-2013-08-27 01:14:05,782+0000 INFO  Cpu 0827-1301520-000000-13: Job still running while shutting down
-2013-08-27 01:14:05,782+0000 INFO  Cpu 0827-1301520-000000:13 jobTerminated
-2013-08-27 01:14:05,782+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=13
-2013-08-27 01:14:05,782+0000 INFO  Cpu 0827-1301520-000000-14: Job still running while shutting down
-2013-08-27 01:14:05,782+0000 INFO  Cpu 0827-1301520-000000:14 jobTerminated
-2013-08-27 01:14:05,782+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=14
-2013-08-27 01:14:05,782+0000 INFO  Cpu 0827-1301520-000000-15: Job still running while shutting down
-2013-08-27 01:14:05,782+0000 INFO  Cpu 0827-1301520-000000:15 jobTerminated
-2013-08-27 01:14:05,782+0000 DEBUG Cpu ready for work: block=0827-1301520-000000 id=15
-2013-08-27 01:14:05,782+0000 INFO  Block Adding short shutdown watchdog: count = 16, workers = 16, now = true
-2013-08-27 01:14:05,782+0000 INFO  Block Average utilization: 98.53%
-2013-08-27 01:14:05,780+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-4dztedel - Application exception: Shutting down worker
-2013-08-27 01:14:05,781+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-9dztedel - Application exception: Shutting down worker
-2013-08-27 01:14:05,782+0000 INFO  Block Shutting down block Block 0827-1301520-000001 (16x7440.000s)
-2013-08-27 01:14:05,782+0000 INFO  Cpu 0827-1301520-000001-0: Job still running while shutting down
-2013-08-27 01:14:05,782+0000 INFO  Cpu 0827-1301520-000001:0 jobTerminated
-2013-08-27 01:14:05,782+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=0
-2013-08-27 01:14:05,783+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-3dztedel - Application exception: Shutting down worker
-2013-08-27 01:14:05,783+0000 INFO  RequestHandler Handler(tag: 717, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,783+0000 INFO  Cpu 0827-1301520-000001-1: Job still running while shutting down
-2013-08-27 01:14:05,783+0000 INFO  swift END_FAILURE thread=R-42-0-1x2-19-0 tr=runampl
-2013-08-27 01:14:05,783+0000 DEBUG Cpu Failed Shutting down worker
-2013-08-27 01:14:05,783+0000 INFO  Cpu 0827-1301520-000001:1 jobTerminated
-2013-08-27 01:14:05,783+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=1
-2013-08-27 01:14:05,783+0000 INFO  Cpu 0827-1301520-000001-2: Job still running while shutting down
-2013-08-27 01:14:05,783+0000 INFO  Cpu 0827-1301520-000001:2 jobTerminated
-2013-08-27 01:14:05,783+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=2
-2013-08-27 01:14:05,783+0000 INFO  swift END_FAILURE thread=R-42-0-1x3-0 tr=runampl
-2013-08-27 01:14:05,783+0000 INFO  swift END_FAILURE thread=R-42-0-1x2-18-0 tr=runampl
-2013-08-27 01:14:05,783+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-2dztedel - Application exception: Shutting down worker
-2013-08-27 01:14:05,783+0000 INFO  Cpu 0827-1301520-000001-3: Job still running while shutting down
-2013-08-27 01:14:05,783+0000 INFO  Cpu 0827-1301520-000001:3 jobTerminated
-2013-08-27 01:14:05,783+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=3
-2013-08-27 01:14:05,783+0000 INFO  Cpu 0827-1301520-000001-4: Job still running while shutting down
-2013-08-27 01:14:05,783+0000 INFO  RequestHandler Handler(tag: 718, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,783+0000 INFO  Cpu 0827-1301520-000001:4 jobTerminated
-2013-08-27 01:14:05,783+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=4
-2013-08-27 01:14:05,784+0000 INFO  RequestHandler Handler(tag: 719, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,784+0000 INFO  Cpu 0827-1301520-000001-6: Job still running while shutting down
-2013-08-27 01:14:05,784+0000 DEBUG Cpu Failed Shutting down worker
-2013-08-27 01:14:05,784+0000 INFO  Cpu 0827-1301520-000001:6 jobTerminated
-2013-08-27 01:14:05,784+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=6
-2013-08-27 01:14:05,784+0000 INFO  Cpu 0827-1301520-000001-7: Job still running while shutting down
-2013-08-27 01:14:05,784+0000 INFO  RequestHandler Handler(tag: 720, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,784+0000 INFO  RequestHandler Handler(tag: 721, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,784+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-6dztedel - Application exception: Shutting down worker
-2013-08-27 01:14:05,784+0000 INFO  RequestHandler Handler(tag: 722, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,784+0000 DEBUG swift THREAD_ASSOCIATION jobid=runampl-0eztedel thread=R-42-0-1x2-20-0 host=midway replicationGroup=null
-2013-08-27 01:14:05,785+0000 INFO  RequestHandler Handler(tag: 723, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,785+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-adztedel - Application exception: Shutting down worker
-2013-08-27 01:14:05,785+0000 INFO  Cpu 0827-1301520-000001:7 jobTerminated
-2013-08-27 01:14:05,785+0000 INFO  RequestHandler Handler(tag: 724, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,785+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=7
-2013-08-27 01:14:05,785+0000 INFO  Cpu 0827-1301520-000001-8: Job still running while shutting down
-2013-08-27 01:14:05,785+0000 DEBUG Cpu Failed Shutting down worker
-2013-08-27 01:14:05,785+0000 INFO  Cpu 0827-1301520-000001:8 jobTerminated
-2013-08-27 01:14:05,785+0000 INFO  swift END_FAILURE thread=R-42-0-1x2-6-0 tr=runampl
-2013-08-27 01:14:05,785+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=8
-2013-08-27 01:14:05,785+0000 DEBUG swift JOB_START jobid=runampl-0eztedel tr=runampl arguments=[10, 0, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/stochmodel.run, outdir/xhat_l10000_0001.0020.out, outdir/xhat_l20000_0001.0020.out, obj_outdir/obj_out_l0000_0001.0020.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/Illinois.tgz, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/edrevised.mod, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/set_data_ascii.inc, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/print_results_revised.inc, Results/ampl_res_l0000_0001.0020.out, __root__/scratch/midway/maheshwari/globusonline-galaxy-globus-738fb324c285/tools/swift/wind_data.dat] tmpdir=inference4galaxy-20130827-0113-r1k3cjmc/jobs/0/runampl-0eztedel host=midway
-2013-08-27 01:14:05,785+0000 INFO  Cpu 0827-1301520-000001-9: Job still running while shutting down
-2013-08-27 01:14:05,785+0000 INFO  swift END_FAILURE thread=R-42-0-1x2-8-0 tr=runampl
-2013-08-27 01:14:05,785+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-fdztedel - Application exception: Shutting down worker
-2013-08-27 01:14:05,785+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-ddztedel - Application exception: Shutting down worker
-2013-08-27 01:14:05,785+0000 INFO  Cpu 0827-1301520-000001:9 jobTerminated
-2013-08-27 01:14:05,785+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-cdztedel - Application exception: Shutting down worker
-2013-08-27 01:14:05,785+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=9
-2013-08-27 01:14:05,785+0000 INFO  swift END_FAILURE thread=R-42-0-1x2-14-0 tr=runampl
-2013-08-27 01:14:05,785+0000 INFO  Cpu 0827-1301520-000001-10: Job still running while shutting down
-2013-08-27 01:14:05,785+0000 INFO  Cpu 0827-1301520-000001:10 jobTerminated
-2013-08-27 01:14:05,785+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-7dztedel - Application exception: Shutting down worker
-2013-08-27 01:14:05,785+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=10
-2013-08-27 01:14:05,785+0000 INFO  Cpu 0827-1301520-000001-11: Job still running while shutting down
-2013-08-27 01:14:05,785+0000 INFO  Cpu 0827-1301520-000001:11 jobTerminated
-2013-08-27 01:14:05,785+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=11
-2013-08-27 01:14:05,785+0000 INFO  Cpu 0827-1301520-000001-12: Job still running while shutting down
-2013-08-27 01:14:05,785+0000 INFO  Cpu 0827-1301520-000001:12 jobTerminated
-2013-08-27 01:14:05,785+0000 INFO  swift END_FAILURE thread=R-42-0-1-0-6-0 tr=runampl
-2013-08-27 01:14:05,785+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=12
-2013-08-27 01:14:05,785+0000 INFO  Cpu 0827-1301520-000001-13: Job still running while shutting down
-2013-08-27 01:14:05,785+0000 INFO  swift END_FAILURE thread=R-42-0-1-0-2-0 tr=runampl
-2013-08-27 01:14:05,785+0000 INFO  Cpu 0827-1301520-000001:13 jobTerminated
-2013-08-27 01:14:05,785+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=13
-2013-08-27 01:14:05,786+0000 INFO  Cpu 0827-1301520-000001-14: Job still running while shutting down
-2013-08-27 01:14:05,786+0000 DEBUG Cpu Failed Shutting down worker
-2013-08-27 01:14:05,786+0000 INFO  Cpu 0827-1301520-000001:14 jobTerminated
-2013-08-27 01:14:05,786+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=14
-2013-08-27 01:14:05,786+0000 INFO  Cpu 0827-1301520-000001-15: Job still running while shutting down
-2013-08-27 01:14:05,786+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-bdztedel - Application exception: Shutting down worker
-2013-08-27 01:14:05,786+0000 INFO  swift END_FAILURE thread=R-42-0-1x2-4-0 tr=runampl
-2013-08-27 01:14:05,786+0000 INFO  Cpu 0827-1301520-000001:15 jobTerminated
-2013-08-27 01:14:05,786+0000 DEBUG Cpu ready for work: block=0827-1301520-000001 id=15
-2013-08-27 01:14:05,786+0000 INFO  Block Adding short shutdown watchdog: count = 16, workers = 16, now = true
-2013-08-27 01:14:05,786+0000 INFO  Block Average utilization: 98.76%
-2013-08-27 01:14:05,786+0000 INFO  CoasterService Shutdown sequence completed
-2013-08-27 01:14:05,786+0000 INFO  swift END_FAILURE thread=R-42-0-1-0-7-0 tr=runampl
-2013-08-27 01:14:05,786+0000 INFO  RequestHandler Handler(tag: 725, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,786+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-8dztedel - Application exception: Shutting down worker
-2013-08-27 01:14:05,786+0000 INFO  swift END_FAILURE thread=R-42-0-1x2-15-0 tr=runampl
-2013-08-27 01:14:05,787+0000 INFO  RequestHandler Handler(tag: 726, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,787+0000 INFO  RemoteLogHandler BLOCK_UTILIZATION id=0827-1301520-000000, u=98.53
-2013-08-27 01:14:05,787+0000 INFO  RequestHandler Handler(tag: 727, RLOG) unregistering (send)
-2013-08-27 01:14:05,787+0000 INFO  RemoteLogHandler BLOCK_SHUTDOWN id=0827-1301520-000001
-2013-08-27 01:14:05,787+0000 INFO  RequestHandler Handler(tag: 728, RLOG) unregistering (send)
-2013-08-27 01:14:05,787+0000 INFO  RequestHandler Handler(tag: 729, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,788+0000 INFO  RequestHandler Handler(tag: 730, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,788+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-hdztedel - Application exception: Shutting down worker
-2013-08-27 01:14:05,788+0000 INFO  RequestHandler Handler(tag: 731, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,788+0000 INFO  swift END_FAILURE thread=R-42-0-1-0-5-0 tr=runampl
-2013-08-27 01:14:05,788+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-jdztedel - Application exception: Shutting down worker
-2013-08-27 01:14:05,788+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-ndztedel - Application exception: Shutting down worker
-2013-08-27 01:14:05,788+0000 INFO  swift END_FAILURE thread=R-42-0-1-0-9-0 tr=runampl
-2013-08-27 01:14:05,788+0000 INFO  swift END_FAILURE thread=R-42-0-1x2-2-0 tr=runampl
-2013-08-27 01:14:05,789+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-kdztedel - Application exception: Shutting down worker
-2013-08-27 01:14:05,789+0000 INFO  RequestHandler Handler(tag: 732, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,789+0000 INFO  RequestHandler Handler(tag: 733, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,789+0000 INFO  swift END_FAILURE thread=R-42-0-1x2-3-0 tr=runampl
-2013-08-27 01:14:05,789+0000 INFO  RequestHandler Handler(tag: 734, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,789+0000 INFO  RequestHandler Handler(tag: 735, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,790+0000 INFO  RequestHandler Handler(tag: 736, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,790+0000 INFO  RequestHandler Handler(tag: 737, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,790+0000 INFO  RequestHandler Handler(tag: 738, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,795+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-mdztedel - Application exception: Shutting down worker
-2013-08-27 01:14:05,795+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-udztedel - Application exception: Shutting down worker
-2013-08-27 01:14:05,795+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-rdztedel - Application exception: Shutting down worker
-2013-08-27 01:14:05,795+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-xdztedel - Application exception: Shutting down worker
-2013-08-27 01:14:05,795+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-ldztedel - Application exception: Shutting down worker
-2013-08-27 01:14:05,795+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-pdztedel - Application exception: Shutting down worker
-2013-08-27 01:14:05,796+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-vdztedel - Application exception: Shutting down worker
-2013-08-27 01:14:05,796+0000 INFO  RequestHandler Handler(tag: 739, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,796+0000 INFO  RequestHandler Handler(tag: 740, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,796+0000 INFO  swift END_FAILURE thread=R-42-0-1x2-9-0 tr=runampl
-2013-08-27 01:14:05,797+0000 INFO  RequestHandler Handler(tag: 741, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,797+0000 INFO  swift END_FAILURE thread=R-42-0-1x2-0x2 tr=runampl
-2013-08-27 01:14:05,797+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-tdztedel - Application exception: Shutting down worker
-2013-08-27 01:14:05,797+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-odztedel - Application exception: Shutting down worker
-2013-08-27 01:14:05,797+0000 INFO  swift END_FAILURE thread=R-42-0-1-0x3 tr=runampl
-2013-08-27 01:14:05,797+0000 INFO  swift END_FAILURE thread=R-42-0-1-0-10-0 tr=runampl
-2013-08-27 01:14:05,797+0000 INFO  swift END_FAILURE thread=R-42-0-1x2-11-0 tr=runampl
-2013-08-27 01:14:05,797+0000 INFO  swift END_FAILURE thread=R-42-0-1x2-13-0 tr=runampl
-2013-08-27 01:14:05,797+0000 INFO  swift END_FAILURE thread=R-42-0-1-0-1-0 tr=runampl
-2013-08-27 01:14:05,797+0000 INFO  swift END_FAILURE thread=R-42-0-1-0-4-0 tr=runampl
-2013-08-27 01:14:05,797+0000 INFO  RequestHandler Handler(tag: 67, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:05,797+0000 INFO  swift END_FAILURE thread=R-42-0-1x2-16-0 tr=runampl
-2013-08-27 01:14:05,798+0000 INFO  RequestHandler Handler(tag: 68, SUBMITJOB) unregistering (send)
-2013-08-27 01:14:05,799+0000 INFO  GetFileHandler Handler(tag: 568, GET) unregistering (last)
-2013-08-27 01:14:05,799+0000 INFO  ReadBuffer RB-LR-Handler(tag: 568, GET) de-allocating 8 buffers
-2013-08-27 01:14:05,800+0000 INFO  RequestHandler Handler(tag: 742, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,801+0000 INFO  RequestHandler Handler(tag: 743, JOBSTATUS) unregistering (send)
-2013-08-27 01:14:05,801+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-ydztedel - Application exception: Shutting down worker
-2013-08-27 01:14:05,801+0000 DEBUG swift APPLICATION_EXCEPTION jobid=runampl-sdztedel - Application exception: Shutting down worker
-2013-08-27 01:14:05,801+0000 INFO  swift END_FAILURE thread=R-42-0-1x2-7-0 tr=runampl
-2013-08-27 01:14:05,801+0000 INFO  swift END_FAILURE thread=R-42-0-1-0-8-0 tr=runampl
-2013-08-27 01:14:05,802+0000 INFO  RemoteLogHandler BLOCK_UTILIZATION id=0827-1301520-000001, u=98.76
-2013-08-27 01:14:05,802+0000 INFO  RequestHandler Handler(tag: 744, RLOG) unregistering (send)
-2013-08-27 01:14:05,803+0000 INFO  GetFileHandler Handler(tag: 3273, GET) unregistering (last)
Deleted: SwiftApps/swift-galaxy/swift/datlist.txt
--- SwiftApps/swift-galaxy/swift/datlist.txt	2014-02-07 20:32:46 UTC (rev 7581)
+++ SwiftApps/swift-galaxy/swift/datlist.txt	2014-02-10 21:52:59 UTC (rev 7582)
@@ -1,10 +0,0 @@
-sample.000.txt
-sample.001.txt
-sample.002.txt
-sample.003.txt
-sample.004.txt
-sample.005.txt
-sample.006.txt
-sample.007.txt
-sample.008.txt
-sample.009.txt
Modified: SwiftApps/swift-galaxy/swift/swiftforeach.xml
--- SwiftApps/swift-galaxy/swift/swiftforeach.xml	2014-02-07 20:32:46 UTC (rev 7581)
+++ SwiftApps/swift-galaxy/swift/swiftforeach.xml	2014-02-10 21:52:59 UTC (rev 7582)
@@ -2,10 +2,11 @@
          ToDo:
          1. Option if the counter should be an argument, first one or last one.
-         2. Option to add files (in Galaxy dataset format) as arguments.
-         3. Allow user to add more than one resource to run a job for load balancing.
-         4. Add ability to run Swift/T.
+         2. Option to add files (in Galaxy dataset format) as arguments. These files then be added to Swift app as arguments.
+         3. Allow the tool to select another tool and run it.
+         4. Allow user to add more than one resource to run a job for load balancing.
+         5. Add ability to run Swift/T.
+         6. Let the localhost option be selected by default
     <description>A generic tool to run executable via Swift foreach parallel construct</description>
@@ -34,9 +35,12 @@
     $outloc
     $logfile
     $outlist
-    #for $a in $arg
-    ${a.argname}
+    #for $a in $stringarg
+    ${a.stringargname}
     #end for
+    #for $a in $filearg
+    ${a.fileargname}
+    #end for
     #end if
     </command>
@@ -78,10 +82,14 @@
         </conditional>
-        <repeat name="arg" title="arg">
-            <param name="argname" type="text" label="arg" />
+        <repeat name="stringarg" title="string arg">
+            <param name="stringargname" type="text" label="stringarg" />
         </repeat>
+        <repeat name="filearg" title="file arg">
+            <param name="fileargname" type="data" label="filearg" />
+        </repeat>
         <param name="outloc" size="50" type="text" value="$HOME/swift-sandbox" label="location for output files" help="Swift will write output files here on disc">
             <sanitizer sanitize="False" />
         </param>
@@ -129,7 +137,7 @@
 **What it does**
-This is a generic Swift tool that runs an executable over a range of numbers with arbitrary stepsize.
+This is a generic Swift tool that runs an executable in parallel over a range of numbers or a list of items in a file.
 Execution location allows user to declare where to run the tool. Executable can be any arbitrary executable of type "binexec" uploaded by user.
Modified: SwiftApps/swift-galaxy/swift/swiftforeachlist.sh
--- SwiftApps/swift-galaxy/swift/swiftforeachlist.sh	2014-02-07 20:32:46 UTC (rev 7581)
+++ SwiftApps/swift-galaxy/swift/swiftforeachlist.sh	2014-02-10 21:52:59 UTC (rev 7582)
@@ -18,28 +18,42 @@
 logfile=$1
 shift
-a=()
+stringargs=()
 while [ $# -gt 0 ] ; do
-  a+=("\"$1\"")
+  stringargs+=("\"$1\"")
   shift
 done
 #workout the array only if user adds args else make it blank
-if [ ${#a[@]} -gt 0 ] ; then
-    tmp=$(printf -- '%s,' "${a[@]}")
-    arrayexpr='string args[]=['$(echo $tmp | sed s/,$//)'];';
+if [ ${#stringargs[@]} -gt 0 ] ; then
+    tmp=$(printf -- '%s,' "${stringargs[@]}")
+    stringarrayexpr='string stringargs[]=['$(echo $tmp | sed s/,$//)'];';
 else
-    arrayexpr='string args[];'
+    stringarrayexpr='string stringargs[];'
 fi
+fileargs=()
+while [ $# -gt 0 ] ; do
+    fileargs+=("\"$1\"")
+  shift
+done
+#workout the array only if user adds args else make it blank
+if [ ${#fileargs[@]} -gt 0 ] ; then
+    tmp=$(printf -- '%s,' "${fileargs[@]}")
+    filearrayexpr='file fileargs[]=['$(echo $tmp | sed s/,$//)'];';
+else
+    filearrayexpr='file fileargs[];'
+fi
 cat << EOF > $wdir/script.swift
 type file;
-app (file _out, file _err) anapp(file _exec, int _i, string _args[]){
-    $interpreter @_exec _i _args stdout=@_out stderr=@_err;
+app (file _out, file _err) anapp(file _exec, int _i, string _stringargs[], file _fileargs[]){
+    $interpreter @_exec _i _stringargs _fileargs stdout=@_out stderr=@_err;
-$arrayexpr
+$stringarrayexpr
+$filearrayexpr
 file exec<"$executable">;
 file listfile<"$listfile">;
@@ -47,7 +61,7 @@
 foreach l, i in list{
     file out <single_file_mapper; file=@strcat("$outloc", "/", l, ".", i, ".out")>;
     file err <single_file_mapper; file=@strcat("$outloc", "/", l, ".", i, ".err")>;
-    (out,err) = anapp(exec, i, args);
+    (out,err) = anapp(exec, i, stringargs, fileargs);
 EOF
