[Swift-commit] r7575 - in trunk: . bin etc etc/provenance
lgadelha at ci.uchicago.edu lgadelha at ci.uchicago.edu
Thu Feb 6 17:53:25 CST 2014
Author: lgadelha
Date: 2014-02-06 17:53:25 -0600 (Thu, 06 Feb 2014)
New Revision: 7575
Added:
   trunk/etc/provenance/
   trunk/etc/provenance/schema_sqlite.sql
Removed:
   trunk/provenance/
Modified:
   trunk/bin/swiftlog
Log:
Moved schema to etc/provenance/
Modified: trunk/bin/swiftlog
--- trunk/bin/swiftlog	2014-02-06 22:14:52 UTC (rev 7574)
+++ trunk/bin/swiftlog	2014-02-06 23:53:25 UTC (rev 7575)
@@ -195,7 +195,7 @@
     # Initializes database if it not yet exists
     if not(os.path.exists(provDB)):
         print "Provenance import: creating database"
-        schemaFilename=swiftHomeDir + "/provenance/schema_sqlite.sql"
+        schemaFilename=swiftHomeDir + "/etc/provenance/schema_sqlite.sql"
         schema=open(schemaFilename, "r").read()
         conn = sqlite3.connect(provDB)
         c = conn.cursor()
@@ -243,7 +243,7 @@
                 if 'APP_RESOURCES' in line:
                     for i, pair in enumerate(line.lstrip('APP_RESOURCES=').split(',')):
                         entry=pair.split(':')
-                        if i == 1:
+                        if i == 0:
                             c.execute("INSERT INTO resource_usage (app_exec_id, %s) VALUES ('%s',%s)" % (entry[0], appExecId, entry[1].rstrip('%')))
                         else:
                             c.execute("UPDATE resource_usage SET %s=%s WHERE app_exec_id='%s'" % (entry[0], entry[1].rstrip('%'), appExecId))
Added: trunk/etc/provenance/schema_sqlite.sql
--- trunk/etc/provenance/schema_sqlite.sql	                        (rev 0)
+++ trunk/etc/provenance/schema_sqlite.sql	2014-02-06 23:53:25 UTC (rev 7575)
@@ -0,0 +1,74 @@
+create table script_run (
+	script_run_id	   text primary key,
+        script_filename    text,
+	log_filename       text,
+	hostname	   text,
+	script_run_dir	   text,
+        swift_version      text,
+        cog_version        text,
+        final_state        text,
+        start_time         text,
+        duration           real
+create table app_exec (
+	app_exec_id			text primary key,
+        script_run_id   		references script_run(script_run_id),
+	app__name			text,
+	execution_site			text,
+	start_time			text,
+	duration			real,
+	staging_in_duration		real,
+	staging_out_duration		real,
+	work_directory			text
+create table argument (
+	app_exec_id			text references app_exec (app_exec_id),
+	arg_position			integer,
+	app_exec_arg			text
+create table resource_usage (
+       app_exec_id	    		text primary key references app_exec (app_exec_id),
+       real_secs	       		real,
+       kernel_secs             		real,
+       user_secs	       		real,
+       percent_cpu             		integer,
+       max_rss	       	       		integer,
+       avg_rss	       			integer,
+       avg_tot_vm	       		integer,
+       avg_priv_data     		integer,
+       avg_priv_stack    		integer,
+       avg_shared_text   		integer,
+       page_size	       		integer,
+       major_pgfaults    		integer,
+       minor_pgfaults    		integer,
+       swaps	       			integer,
+       invol_context_switches		integer,
+       vol_waits			integer,
+       fs_reads				integer,
+       fs_writes			integer,
+       sock_recv			integer,
+       sock_send			integer,
+       signals				integer,
+       exit_status			integer
+create table file (
+       file_id		text primary key,
+       host		text,
+       name		text,
+       size		integer,
+       modify		integer
+create table staged_in (
+       file_id 				text references file (file_id)
+create table staged_out (
\ No newline at end of file
