[Swift-commit] r7544 - SwiftApps/swift-galaxy/swift
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Sat Feb 1 20:51:27 CST 2014
Author: ketan
Date: 2014-02-01 20:51:27 -0600 (Sat, 01 Feb 2014)
New Revision: 7544
Modified:
   SwiftApps/swift-galaxy/swift/swiftforeachrange.sh
   SwiftApps/swift-galaxy/swift/swiftforeachrange.xml
Log:
dynamic number of commandline args
Modified: SwiftApps/swift-galaxy/swift/swiftforeachrange.sh
--- SwiftApps/swift-galaxy/swift/swiftforeachrange.sh	2014-02-02 02:51:24 UTC (rev 7543)
+++ SwiftApps/swift-galaxy/swift/swiftforeachrange.sh	2014-02-02 02:51:27 UTC (rev 7544)
@@ -2,9 +2,7 @@
 #ToDo:
-#1. Add arguments, variable number such that user can add and remove them.
-#2. Add a way for users to specify expected outputs.
-#3. Add a type such that only binaries and executable scripts are populated in the executable list.
+#1. Add a variable number of arguments such that user can add and remove them.
 # numeric range
@@ -24,6 +22,7 @@
 shift
 logfile=$1
+#Build Swift source code
 cat << EOF > /tmp/script.swift
 type file;
@@ -42,7 +41,6 @@
 swift=$(which swift)
 #build site
-echo $PWD > /tmp/pwd.txt
 BASEDIR=$(dirname $0)
 $BASEDIR/buildsite.sh $site
@@ -76,6 +74,7 @@
 EXITCODE=$?
 #`for i in \`find $HOME/swift-sandbox -type f\`; do echo "\`basename $i\` $i"; done`
+#Populate output file
 cat << EOF > $outlistfile
 `for i in \`find $outloc -type f\`; do echo "$i"; done`
 EOF
@@ -87,7 +86,6 @@
        cat $logfile >&2
 fi
 exit $EXITCODE
 #dum ditty dum ditty dum dum dum
Modified: SwiftApps/swift-galaxy/swift/swiftforeachrange.xml
--- SwiftApps/swift-galaxy/swift/swiftforeachrange.xml	2014-02-02 02:51:24 UTC (rev 7543)
+++ SwiftApps/swift-galaxy/swift/swiftforeachrange.xml	2014-02-02 02:51:27 UTC (rev 7544)
@@ -1,93 +1,96 @@
 <tool id="swiftforeachrange" name="numrangeforeach">
-  <description>A generic tool to run executable via Swift foreach parallel construct</description>
-  <command interpreter="bash">
+    <description>A generic tool to run executable via Swift foreach parallel construct</description>
+    <command interpreter="bash">
-            $site
-            $executable
-            $rstart
-            $rend
-            $stepsize
-            $outloc
-            $logfile
-            $outlist
-  </command>
+        $site
+        $executable
+        $rstart
+        $rend
+        $stepsize
+        $outloc
+        $logfile
+        $outlist
+    </command>
-  <inputs>
-    <param name="site" type="select" label="Execution Location">
-       <option value="localhost">Localhost</option>
-       <option value="midway">Midway</option>
-       <option value="uc3">UC3</option>
-       <option value="stampede">Stampede</option>
-   </param>
+    <inputs>
+        <param name="site" type="select" label="Execution Location">
+            <option value="localhost">Localhost</option>
+            <option value="midway">Midway</option>
+            <option value="uc3">UC3</option>
+            <option value="stampede">Stampede</option>
+        </param>
-    <param format="sh,binexec" name="executable" type="data" label="Executable"/>
+        <param format="sh,binexec" name="executable" type="data" label="Executable"/>
-    <param name="rstart" size="2" type="integer"  value="0" label="start"/>
-    <param name="rend" size="2" type="integer"  value="9" label="end"/>
-    <param name="stepsize" size="2" type="integer"  value="1" label="stepsize"/>
-    <param name="outloc" size="50" type="text" value="$HOME/swift-sandbox" label="location for output files" help="Swift will write output files here on disc">
-        <sanitizer sanitize="False" />
-    </param>
+        <param name="rstart" size="2" type="integer"  value="0" label="start"/>
+        <param name="rend" size="2" type="integer"  value="9" label="end"/>
+        <param name="stepsize" size="2" type="integer"  value="1" label="stepsize"/>
+        <repeat name="arg" title="arg">
+            <param name="argname" type="text" label="arg" />
+        </repeat>
-    <conditional name="configuration">
-        <param name="mode" type="select" label="Swift configuration">
-          <option value="default">default configuration</option>
-          <option value="advanced">advanced configuration</option>
-       </param>
+        <param name="outloc" size="50" type="text" value="$HOME/swift-sandbox" label="location for output files" help="Swift will write output files here on disc">
+            <sanitizer sanitize="False" />
+        </param>
-        <when value="default">
-        </when>
-        <when value="advanced">
-           <param name="remoteurl" size="50" type="text" value="midway.swift.rcc.uchicago.edu" label="remote url" help="remote resource to run jobs on"></param>
-           <param name="throttle" size="5" type="float" value="0.07" label="job throttle" help="number of parallel jobs to run"></param>
-           <param name="project" type="text" value="TG-STA110005S" label="Project allocation" help="name/code of project"></param>
-           <param name="slots" size="5" type="integer" value="1" label="slots" help="number of scheduler jobs"></param>
-           <param name="queue" size="5" type="text" value="normal" label="queue" help="queue to run jobs on"></param>
-           <param name="nodes" size="5" type="integer" value="1" label="nodes" help="number of nodes requested"></param>
-           <param name="nodegranularity" size="5" type="integer" value="1" label="node granularity" help="node granularity"></param>
-           <param name="jobspernode" size="5" type="integer" value="8" label="jobs per node" help="number of jobs per node requested"></param>
-           <param name="ppn" size="5" type="integer" value="8" label="ppn" help="processes per node requested"></param>
-           <param name="walltime" size="5" type="text" value="00:10:00" label="Job walltime" help="time in hh:mm:ss to request to scheduler for this job"></param>
-           <param name="maxtime" size="5" type="integer" value="700" label="application maxtime" help="Application maxtime in seconds for this job"></param>
-        </when>
-    </conditional>
-  </inputs>
-  <outputs>
-     <data format="txt" name="logfile" type="data" label="Swift output" />
-     <data format="txt" name="outlist" type="data" label="Output list" />
-  </outputs>
+        <conditional name="configuration">
+            <param name="mode" type="select" label="Swift configuration">
+                <option value="default">default configuration</option>
+                <option value="advanced">advanced configuration</option>
+            </param>
+            <when value="default">
+            </when>
+            <when value="advanced">
+                <param name="remoteurl" size="50" type="text" value="midway.swift.rcc.uchicago.edu" label="remote url" help="remote resource to run jobs on"></param>
+                <param name="throttle" size="5" type="float" value="0.07" label="job throttle" help="number of parallel jobs to run"></param>
+                <param name="project" type="text" value="TG-STA110005S" label="Project allocation" help="name/code of project"></param>
+                <param name="slots" size="5" type="integer" value="1" label="slots" help="number of scheduler jobs"></param>
+                <param name="queue" size="5" type="text" value="normal" label="queue" help="queue to run jobs on"></param>
+                <param name="nodes" size="5" type="integer" value="1" label="nodes" help="number of nodes requested"></param>
+                <param name="nodegranularity" size="5" type="integer" value="1" label="node granularity" help="node granularity"></param>
+                <param name="jobspernode" size="5" type="integer" value="8" label="jobs per node" help="number of jobs per node requested"></param>
+                <param name="ppn" size="5" type="integer" value="8" label="ppn" help="processes per node requested"></param>
+                <param name="walltime" size="5" type="text" value="00:10:00" label="Job walltime" help="time in hh:mm:ss to request to scheduler for this job"></param>
+                <param name="maxtime" size="5" type="integer" value="700" label="application maxtime" help="Application maxtime in seconds for this job"></param>
+            </when>
+        </conditional>
+    </inputs>
+    <outputs>
+        <data format="txt" name="logfile" type="data" label="Swift output" />
+        <data format="txt" name="outlist" type="data" label="Output list" />
+    </outputs>
   <code file="postprocess.py">
     <hook postprocess="writeoutlist" />
   </code>
 <help>
-.. class:: warningmark
+    .. class:: warningmark
-**TIP**. A generic Swift foreach to run arbitrary executables in parallel over a range of numbers.
+    **TIP**. A generic Swift foreach to run arbitrary executables in parallel over a range of numbers.
-**What it does**
+    **What it does**
-This is a generic Swift tool that runs an executable over a range of numbers with arbitrary stepsize.
+    This is a generic Swift tool that runs an executable over a range of numbers with arbitrary stepsize.
-**Example**
+    **Example**
-Pick up an executable from the Executable list. Enter the start, end and the step size values.
+    Pick up an executable from the Executable list. Enter the start, end and the step size values.
-If an executable is echo.sh:
+    If an executable is echo.sh:
-echo $1
+    echo $1
-The start, end and step is 0, 9 and 2, the executable will be invoked in parallel 5 times for n where n is 0 2 4 6 8:
+    The start, end and step is 0, 9 and 2, the executable will be invoked in parallel 5 times for n where n is 0 2 4 6 8:
-echo n
+    echo n
 </help>
 </tool>
