[Swift-commit] r8349 - www/Swift-T
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Tue Dec 16 10:40:07 CST 2014
Author: wozniak
Date: 2014-12-16 10:40:06 -0600 (Tue, 16 Dec 2014)
New Revision: 8349
Modified:
   www/Swift-T/turbine-sites.html
Log:
Turbine Sites updates
Modified: www/Swift-T/turbine-sites.html
--- www/Swift-T/turbine-sites.html	2014-12-13 21:48:36 UTC (rev 8348)
+++ www/Swift-T/turbine-sites.html	2014-12-16 16:40:06 UTC (rev 8349)
@@ -747,7 +747,7 @@
 <span id="author">Justin M. Wozniak</span><br />
 <span id="email"><code><<a href="mailto:wozniak at mcs.anl.gov">wozniak at mcs.anl.gov</a>></code></span><br />
 <span id="revnumber">version 0.7.0,</span>
-<span id="revdate">November 2014</span>
+<span id="revdate">December 2014</span>
 <div id="toc">
   <div id="toctitle">Table of Contents</div>
   <noscript><p><b>JavaScript must be enabled in your browser to display the table of contents.</b></p></noscript>
@@ -1360,8 +1360,9 @@
 <div class="paragraph"><p>To run:</p></div>
 <div class="listingblock">
 <div class="content">
-<pre><code>export QUEUE=batch
-~wozniak/Public/turbine/scripts/submit/pbs/turbine-pbs-run.zsh -n 3 program.tic</code></pre>
+<pre><code>$ export QUEUE=batch
+$ export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/software/gcc-4.7.2/lib64
+$ ~wozniak/Public/turbine/scripts/submit/pbs/turbine-pbs-run.zsh -n 3 program.tcl</code></pre>
 </div></div>
 <div class="paragraph"><p>See the <a href="#variables">Turbine scheduler variables</a> and
 <a href="#options">Turbine run script options</a> for additional settings.</p></div>
@@ -1372,6 +1373,39 @@
 <pre><code>$ which gcc
+$ export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/software/gcc-4.7.2/lib64</code></pre>
+</div></div>
+</div>
+</div>
+<div class="sect2">
+<h3 id="_fusion">Fusion</h3>
+<div class="paragraph"><p><a href="http://www.lcrc.anl.gov/about/fusion">Fusion</a> is a 320-node x86
+cluster at ANL.  It uses PBS.</p></div>
+<div class="sect3">
+<h4 id="_public_installation_5">Public installation</h4>
+<div class="ulist"><ul>
+<li>
+<p>
+STC: <code>~wozniak/Public/compute/stc/bin/stc</code>
+</p>
+</li>
+</ul></div>
+<div class="paragraph"><p>To run:</p></div>
+<div class="listingblock">
+<div class="content">
+<pre><code>export QUEUE=batch
+$ export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/soft/gcc/4.7.2/lib64
+$ ~wozniak/Public/sfw/compute/turbine/scripts/submit/pbs/turbine-pbs-run.zsh -n 3 program.tic</code></pre>
+</div></div>
+<div class="paragraph"><p>See the <a href="#variables">Turbine scheduler variables</a> and
+<a href="#options">Turbine run script options</a> for additional settings.</p></div>
+</div>
+<h4 id="_build_procedure_5">Build procedure</h4>
+<div class="paragraph"><p>Use GCC 4.7.2 and set <code>LD_LIBRARY_PATH</code>:</p></div>
+<pre><code>$ which gcc
 /software/gcc-4.7.2/bin/gcc
 </div></div>
@@ -1408,7 +1442,7 @@
 (ALCF).  Other existing Blue Gene/P systems may be configured in a
 similar way.</p></div>
 <div class="sect4">
-<h5 id="_public_installation_5">Public installation</h5>
+<h5 id="_public_installation_6">Public installation</h5>
 <li>
 <p>
@@ -1428,7 +1462,7 @@
 </div></div>
 </div>
 <div class="sect4">
-<h5 id="_build_procedure_5">Build procedure</h5>
+<h5 id="_build_procedure_6">Build procedure</h5>
 <div class="paragraph"><p>To run on the <a href="#login_node">login node</a>:</p></div>
 <li>
@@ -1542,67 +1576,68 @@
 <div class="sect2">
 <h3 id="_blue_gene_q">Blue Gene/Q</h3>
 <div class="sect3">
-<h4 id="_mira_cetus">Mira/Cetus</h4>
-<div class="paragraph"><p><strong>As of:</strong> 0.7.0 - 11/20/2014</p></div>
-<div class="paragraph"><p>Add to <code>PATH</code>:</p></div>
+<h4 id="_alcf">ALCF</h4>
 <li>
 <p>
-STC: <code>~wozniak/Public/ppc64/stc/bin</code>
+Run with:
 </p>
+<pre><code>export MODE=BGQ
+export PROJECT=<project_name>
+export QUEUE=<queue_name>
+swift-t -m cobalt -n 3 program.tic</code></pre>
+</div></div>
+<div class="paragraph"><p>or:</p></div>
+turbine-cobalt-run.zsh -n 2 program.tic</code></pre>
+</div></div>
 </li>
+</ul></div>
+<div class="paragraph"><p>The normal Turbine environment variables are honored, plus the
+<a href="#variables">Turbine scheduler variables</a>.</p></div>
+<div class="sect4">
+<h5 id="_public_installation_vesta">Public installation: Vesta</h5>
+<div class="paragraph"><p><strong>As of:</strong> 0.7.0 - 12/16/2014</p></div>
 <li>
 <p>
-Turbine (optional): <code>~wozniak/Public/ppc64/turbine/scripts/submit/cobalt</code>
+STC: <code>~wozniak/Public/sfw/stc/bin/stc</code>
 </p>
 </li>
 <li>
 <p>
-Run as:
+Turbine: <code>~wozniak/Public/sfw/turbine/scripts/submit/cobalt/turbine-cobalt-run.zsh</code>
 </p>
-<div class="listingblock">
-<div class="content">
-<pre><code>export MODE=BGQ
-export QUEUE=...
-export PROJECT=...
-swift-t -m cobalt -n 3 program.tic</code></pre>
-</div></div>
 </li>
 </ul></div>
 </div>
-<div class="sect3">
-<h4 id="_vesta">Vesta</h4>
+<h5 id="_public_installation_mira_cetus">Public installation: Mira/Cetus</h5>
+<div class="paragraph"><p><strong>As of:</strong> 0.5.0 - 4/4/2014</p></div>
 <li>
 <p>
-STC: <code>~wozniak/Public/sfw/stc/bin</code>
+STC: <code>~wozniak/Public/ppc64/stc/bin/stc</code>
 </p>
 </li>
 <li>
 <p>
-Turbine (optional): <code>~wozniak/Public/sfw/turbine/scripts/submit/turbine-cobalt-run.zsh</code>
+Turbine:
+<code>~wozniak/Public/ppc64/turbine/scripts/submit/cobalt/turbine-cobalt-run.zsh</code>
 </p>
 </li>
-<li>
-<p>
-Run as:
-</p>
-export QUEUE=default
-swift-t -m cobalt -n 2 program.tic</code></pre>
-</div></div>
-</li>
 </ul></div>
-<div class="paragraph"><p>The normal Turbine environment variables are honored, plus the
-<a href="#variables">Turbine scheduler variables</a>.</p></div>
 </div>
+</div>
 <div class="sect3">
-<h4 id="_build_procedure_6">Build procedure</h4>
+<h4 id="_build_procedure_7">Build procedure</h4>
-<div class="paragraph"><p><strong>Tcl:</strong></p></div>
+<div class="paragraph"><p><strong>Building Tcl:</strong></p></div>
 <div class="paragraph"><p>The GCC installation does not support shared libraries.  Thus, you
 must compile Tcl with <code>bgxlc</code>.  You must modify the Makefile to use
 <code>bgxlc</code> arguments: <code>-qpic</code>, <code>-qmkshrobj</code>.  You must link with
@@ -1610,6 +1645,7 @@
 <div class="paragraph"><p>You may get errors that say <code>wrong digit</code>.  This is apparently a bgxlc
 bug when applied to Tcl’s <code>StrToD.c</code>.  Compiling this file with <code>-O3</code> fixes
 the problem.</p></div>
+<div class="paragraph"><p><strong>Building Swift/T:</strong></p></div>
 <li>
 <p>
@@ -1685,7 +1721,7 @@
 <h3 id="_titan">Titan</h3>
 <div class="paragraph"><p>Titan is a Cray XK7 at the Oak Ridge Leadership Computing Facility.</p></div>
 <div class="sect3">
-<h4 id="_public_installation_6">Public installation</h4>
+<h4 id="_public_installation_7">Public installation</h4>
 <div class="paragraph"><p><strong>As of:</strong> 8/27/2014</p></div>
 <li>
@@ -1748,7 +1784,7 @@
 <a href="#options">settings file</a>.</p></div>
 </div>
 <div class="sect3">
-<h4 id="_build_procedure_7">Build procedure</h4>
+<h4 id="_build_procedure_8">Build procedure</h4>
 <div class="paragraph"><p>Cray systems do not use <code>mpicc</code>.  We set <code>CC=gcc</code> and use compiler
 flags to configure the MPI library.</p></div>
@@ -1805,7 +1841,7 @@
 <div class="paragraph"><p>Blue Waters is a Cray XE6/XK7 at the University of Illinois at
 Urbana-Champaign.</p></div>
 <div class="sect3">
-<h4 id="_build_procedure_8">Build procedure</h4>
+<h4 id="_build_procedure_9">Build procedure</h4>
 <div class="paragraph"><p><strong>As of:</strong>  11/05/2013</p></div>
@@ -2023,7 +2059,7 @@
 NFS (including home directories).  Thus, you must install Turbine and
 its libraries in <code>/lustre</code>.  Also, your data must be in <code>/lustre</code>.</p></div>
 <div class="sect3">
-<h4 id="_public_installation_7">Public installation</h4>
+<h4 id="_public_installation_8">Public installation</h4>
 <div class="sect4">
 <h5 id="_login_nodes">Login nodes</h5>
 <div class="paragraph"><p>This installation is for use on the <a href="#login_node">login node</a>.</p></div>
@@ -2085,7 +2121,7 @@
 </div>
 </div>
 <div class="sect3">
-<h4 id="_build_procedure_9">Build procedure</h4>
+<h4 id="_build_procedure_10">Build procedure</h4>
@@ -2144,7 +2180,7 @@
 <h3 id="_raven">Raven</h3>
 <div class="paragraph"><p>Raven is a Cray XE6/XK7 at Cray.</p></div>
 <div class="sect3">
-<h4 id="_build_procedure_10">Build procedure</h4>
+<h4 id="_build_procedure_11">Build procedure</h4>
 <li>
 <p>
@@ -2305,7 +2341,7 @@
 <div id="footer">
 <div id="footer-text">
 Version 0.7.0<br />
-Last updated 2014-11-20 14:46:46 CST
+Last updated 2014-12-16 10:28:58 CST
 </div>
 </div>
 </body>
