[Swift-commit] r8346 - in SwiftApps: dsp-swift subjobs
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Fri Dec 12 17:30:23 CST 2014
Author: ketan
Date: 2014-12-12 17:30:23 -0600 (Fri, 12 Dec 2014)
New Revision: 8346
Modified:
   SwiftApps/dsp-swift/swiftjumpdsp.xml
   SwiftApps/subjobs/README.txt
Log:
_
Modified: SwiftApps/dsp-swift/swiftjumpdsp.xml
--- SwiftApps/dsp-swift/swiftjumpdsp.xml	2014-12-12 23:06:20 UTC (rev 8345)
+++ SwiftApps/dsp-swift/swiftjumpdsp.xml	2014-12-12 23:30:23 UTC (rev 8346)
@@ -39,19 +39,21 @@
         <data format="txt" name="outlogfile" type="data" label="Swift Progress" />
     </outputs>
 <help>
-    **What is this?**
-    A tool to run dsp in parallel parameter sweeps.
-    **What it does?**
-    Runs dsp in parallel over a user provided input dataset and parameters.
+**What is this?**
-    **How does it do?**
-    The user provides input to the tool which is then delivered to the
-    underlying Swift script. The script is then invoked on local/login or
-    compute nodes as selected by the user. Once the tool has run, the output is
-    produced in the directory location provided by the user.
+A tool to run dsp in parallel parameter sweeps.
+**What it does?**
+Runs dsp in parallel over a user provided input dataset and parameters.
+**How does it do?**
+The user provides input to the tool which is then delivered to the
+underlying Swift script. The script is then invoked on local/login or
+compute nodes as selected by the user. Once the tool has run, the output is
+produced in the directory location provided by the user.
 More description to come.
 </help>
 </tool>
Modified: SwiftApps/subjobs/README.txt
--- SwiftApps/subjobs/README.txt	2014-12-12 23:06:20 UTC (rev 8345)
+++ SwiftApps/subjobs/README.txt	2014-12-12 23:30:23 UTC (rev 8346)
@@ -208,6 +208,15 @@
 ./runmira.sh #run on mira
+GridPack
+GridPack is a simulation package designed for powergrid design application.
+HALO
+HALO is a astrophysics application.
 Internals
 The key driver of the Swift sub-block jobs is a script called +bg.sh+ that does the sub-block jobs calculations and othe chores for the users. The script looks as follows:
