[Swift-commit] r8337 - SwiftApps/dsp-swift
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Thu Dec 11 20:51:45 CST 2014
Author: ketan
Date: 2014-12-11 20:51:45 -0600 (Thu, 11 Dec 2014)
New Revision: 8337
Modified:
   SwiftApps/dsp-swift/swiftjumpdsp.xml
Log:
typo
Modified: SwiftApps/dsp-swift/swiftjumpdsp.xml
--- SwiftApps/dsp-swift/swiftjumpdsp.xml	2014-12-12 02:41:55 UTC (rev 8336)
+++ SwiftApps/dsp-swift/swiftjumpdsp.xml	2014-12-12 02:51:45 UTC (rev 8337)
@@ -31,7 +31,7 @@
            <option value="local" selected="true">local</option>
            <option value="compute">compute</option>
         </param>
-        <param name="resloc" size="60" type="text" label="Location for resulst" help="Enter the path to a directory to put resuts in, eg. /tmp/outdir"/>
+        <param name="resloc" size="60" type="text" label="Location for results" help="Enter the path to a directory to put results in, eg. /tmp/outdir"/>
     </inputs>
     <outputs>
         <data format="txt" name="outlist" type="data" label="Output List" />
