[Swift-commit] r8331 - SwiftApps/dsp-swift
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Thu Dec 11 13:44:14 CST 2014
Author: ketan
Date: 2014-12-11 13:44:14 -0600 (Thu, 11 Dec 2014)
New Revision: 8331
Added:
   SwiftApps/dsp-swift/README
   SwiftApps/dsp-swift/setup.py
   SwiftApps/dsp-swift/swiftjumpdsp.py
   SwiftApps/dsp-swift/swiftjumpdsp.xml
Log:
readme and setup
Added: SwiftApps/dsp-swift/README
--- SwiftApps/dsp-swift/README	                        (rev 0)
+++ SwiftApps/dsp-swift/README	2014-12-11 19:44:14 UTC (rev 8331)
@@ -0,0 +1,196 @@
+The jump-DSP Swift Galaxy Integration
+Introduction
+The Swift-Galaxy integration project aims to build tools which can be used to
+leverage the best features of http://swift-lang.org/main[Swift] and
+http://galaxyproject.org[Galaxy] combined. We start with building a generic
+Galaxy tool, called `foreach` which allows user to compose Galaxy workflows
+such that each computation stage in the workflow is executed by Swift. User can
+compose Galaxy tool and pick up arbitrary executables and dataset to run the
+executable over. User can also run the executable over a list of items such as
+string or file parameters.
+NOTE: This document can be found http://swift-lang.org/tutorials/galaxy/tutorial.html[here].
+Swift-Galaxy `foreach` Mechanism
+The basic mechanism is that the tool user-interface will accept parameters and
+will pass them along to a backend Swift "generator". This generator program
+will run the parameters over Swift source and configuration templates. As a
+result, the right source and configuration files are produced in a temporary
+directory (`/tmp/tmpname`). This is then executed and the results collected.
+There are two ways the `foreach` Swift tool can be utilized. First, over a range
+of numbers. The tool is used to run any arbitrary executable via Swift `foreach`
+loop over a range of numbers. The executable will run with number in range as
+commandline argument, one at a time. Furthermore, user can add arbitrary string
+arguments in addition to the number argument to the call to executable.
+The second way runs the `foreach` loop over a list of items read from an input
+file. These items can be file references or simple strings. The tool will pass
+one item at a time to the executable as argument parameter and run them all in
+parallel. This is similar to the above described number range except that the
+iteration takes place over a list of items provided as a file.
+Installation
+This installation recipe assumes that you have Galaxy preinstalled. If not,
+installation instructions for Galaxy can be found
+https://wiki.galaxyproject.org/Admin/GetGalaxy[here].
+Step 0. Checkout the swift-galaxy SVN directory as follows:
+svn co https://svn.ci.uchicago.edu/svn/vdl2/SwiftApps/swift-galaxy
+Step 1. Create a symbolic link to the +swift-galaxy/swift+ directory from
+galaxy's +tools+ directory. For example, if Galaxy top level directory is
++galaxy-dist+ and swift directory is $HOME/swift-galaxy/swift:
+cd galaxy-dist/tools
+ln -s $HOME/swift-galaxy/swift swift
+The advantage of symbolic links is that as users update the tool directory via
+`svn up`, they need not worry about reinstallation. Updates in installation
+gets automatically propagated to Galaxy.
+Step 2. Add the tool definitions of the tools contained in this Swift to
+Galaxy's tool_conf.xml. This can be done by copying the text in
+`<section>...</section>` from the tool_conf.xml in swift-galaxy directory and
+paste it to the tool_conf.xml of the Galaxy directory. In the current installation, the text to be copied is:
+<section name="swift" id="swift">
+ <tool file="swift/tryswift.xml" />
+ <tool file="swift/genericswift.xml" />
+ <tool file="swift/swiftforeach.xml" />
+</section>
+Step 3. (Re)start Galaxy.
+sh run.sh
+In the Galaxy Web GUI, you should see the tools in a toolset titled Swift.
+Screenshots
+The following screenshot shows overall look-and-feel of the Swift-Galaxy tool
+in the Galaxy web GUI.
+image::./screenshots/overall.png["swift-galaxy screenshot", width=600, align="center"]
+The rest of this section walks you through each of the components shown in the
+above screen and their utility. The following screenshot shows execution
+location selector. User can select one or more execution locations from the
+list as their target execution site.
+image::./screenshots/execloc.png["execution location selector screenshot", width=200, align="center"]
+The following screenshot shows a dialog box to add Swift-level commandline
+arguments to be passed to the script.
+image::./screenshots/swift-level-args.png["swift-args screenshot", width=200, align="center"]
+The following screenshot shows a selection dropdown list to chose the execution
+interpreter from. The interpreters currently supported and tested are shell,
+java and python. Upcoming are R and matlab.
+image::./screenshots/execution-interpreter.png["interpreter screenshot", width=150, align="center"]
+The following screenshot shows the selection for an executable. User can upload
+an executable and select it from the list.
+image::./screenshots/executable.png["executable screenshot", width=200, align="center"]
+The following screenshot shows a selection for range of numbers or list of
+items to chose from. User can select one and the corresponding dialog box will
+appear below.
+image::./screenshots/rangeorlist.png["select range or list screenshot", width=150, align="center"]
+The following screenshot shows a dialog for string or file type arguments. A
+user can add string and filetype arguments to their executable and the
+commandline will be built accordingly.
+image::./screenshots/string-or-fileargs.png["string or fileargs screenshot", width=250, align="center"]
+The following screenshot shows a dialog box to enter the directory location for
+results of execution. The Swift output files will be placed here:
+image::./screenshots/outlocation.png["output location screenshot", width=250, align="center"]
+An example
+A simple Hello World Swift tool to run with Galaxy.
+To set up with your Galaxy environment follow the steps below:
+Prerequisite: Sun/Oracle java. Should work with IBM java but not tested. To test your java version:
+java -version
+Typical output is:
+java version "1.7.0_17"
+Java(TM) SE Runtime Environment (build 1.7.0_17-b02)
+Java HotSpot(TM) 64-Bit Server VM (build 23.7-b01, mixed mode)
+Step 1. Download and install Swift where Galaxy server is running. From a
+command prompt the following wget will pull the latest release from
+http://swift-lang.org/downloads/index.php[here].
+Step 2. SVN checkout the swift-galaxy directory and copy the Swift tool directory to Galaxy's tools directory:
+cp -r swift-galaxy/swift /location/of/galaxy-server/tools/
+Step 3. Edit the +tool_conf.xml+ file present at the top-level of galaxy directory tree to add the following lines between the +<toolbox>+ and +</toolbox>+ xml tags:
+<section name="swift-galaxy" id="swift-galaxy">
+  <tool file="currdir/nameoftoolfile.xml" />
+</section>
+Step 4. Restart the Galaxy server. The swift-galaxy tool should be available in the tool box of Galaxy GUI.
+Step 5. Invoke it by entering any number in the dialog box or leaving it to default.
+Step 6. For examples of other Galaxy-Swift tools, look into the swift directoty.
+Troubleshoot
+Each tool generates a set of Swift source and configuration files. These files are placed in a unique directory with a random name generated on the fly. The location of the directory is in `/tmp` and it is prefixed with name `swift-gal.` . The suffix is a four letter random number. You can run Swift from this directory to reproduce possible issues as follows:
+swift -tc.file tc -sites.file sites.xml -config cf script.swift
+Feel free to contact Swift http://swift-lang.org/support/index.php[support] if issues persist.
+Upcoming Features
+* Mixing the order of file and string arguments
+* Optionally allowing user to not use range number as arguments
+* Providing more Swift patterns, eg. `if-else` conditionals
Added: SwiftApps/dsp-swift/setup.py
--- SwiftApps/dsp-swift/setup.py	                        (rev 0)
+++ SwiftApps/dsp-swift/setup.py	2014-12-11 19:44:14 UTC (rev 8331)
@@ -0,0 +1,40 @@
+#!/usr/bin/env python
+Setup script to install swift-galaxy framework to your Galaxy installation.
+Usage: ./setup.py <path/to/galaxy>
+import xml.etree.ElementTree as ET
+import subprocess
+import sys
+import os
+import distutils.spawn
+import traceback
+import fnmatch
+import tarfile
+import urllib
+galaxyloc=sys.argv[1]
+#step 0. Download swift-galaxy.tgz and swift-rel.tgz untar and set path
+#step 1. Create symlink to the swift directory from the tools directory of galaxyloc if not already present
+if os.path.lexists(galaxyloc+"/tools/swift"):
+    os.remove(galaxyloc+"/tools/swift")
+os.symlink ("/tmp/swift-galaxy/swift", galaxyloc+"/tools/swift");
+#step 2. update the tool_conf.xml
+tree = ET.parse(galaxyloc+"/config/tool_conf.xml.main")
+root = tree.getroot()
+if 'swift' not in root.attrib:
+    root.append((ET.fromstring('<section name="swift" id="swift">\n <tool file="swift/tryswift.xml" />\n <tool file="swift/genericswift.xml" />\n <tool file="swift/swiftforeach.xml" />\n </section>\n ')))
+tree.write (galaxyloc+"/config/tool_conf.xml.main")
+#step 3. Print message
+print "Swift/Galaxy Installed."
Property changes on: SwiftApps/dsp-swift/setup.py
___________________________________________________________________
Added: svn:executable
Added: SwiftApps/dsp-swift/swiftjumpdsp.py
--- SwiftApps/dsp-swift/swiftjumpdsp.py	                        (rev 0)
+++ SwiftApps/dsp-swift/swiftjumpdsp.py	2014-12-11 19:44:14 UTC (rev 8331)
@@ -0,0 +1,201 @@
+This is the Swift foreach driver for Galaxy. It receives inputs from the Swift
+"foreach" Galaxy tool and depending on the options specified, builds a
+canonical Swift/K or Swift/T script and runs over specified computational
+environment.
+swiftjumpdsp.py
+        "${inlocation}"
+        "${a}"
+        "${n}"
+        "${p}"
+        "${I}"
+        "${outlist}"
+import subprocess
+import sys
+import os
+import traceback
+import fnmatch
+import re
+def setwdir():
+    return subprocess.check_output(["mktemp", "-d", "/tmp/swift-gal.XXXX"])
+def genargs(args):
+    for a in args:
+        yield a
+def buildcfg(wdir):
+    f=open(wdir+"/cf", 'w')
+    f.write("use.provider.staging=true\n")
+    f.write("wrapperlog.always.transfer=true\n")
+    f.write("execution.retries=0\n")
+    f.write("provider.staging.pin.swiftfiles=false\n")
+    f.write("sitedir.keep=true\n")
+    f.write("lazy.errors=false\n")
+    f.close()
+def main():
+    myargs = genargs(sys.argv)
+    try:
+        this=next(myargs)
+        inloc = next(myargs)
+        a = next(myargs)
+        n = next(myargs)
+        p = next(myargs)
+        I = next(myargs)
+        outloc = next(myargs)
+        outlistfile = next(myargs)
+        logfile = next(myargs)
+    except:
+        traceback.print_exc()
+        sys.exit(1)
+    #which swift
+    swift = distutils.spawn.find_executable("swift")
+    BASEDIR = os.path.dirname(os.path.realpath(__file__))
+    # workout the file args
+    fileargs=[]
+    for f in myargs:
+        fileargs.append(f)
+    #workout the file array only if user adds args else make it blank
+    if fileargs:
+        if k_or_t == "swiftK":
+            filearrayexpr="file fileargs[] <fixed_array_mapper; files=\""+','.join(fileargs)+"\">;\n"
+        else: #T
+            filearrayexpr="file fileargs[]="+str(fileargs)+";\n"
+    else:
+        filearrayexpr="file fileargs[];\n"
+    # create outloc dir
+    if not os.path.exists(outloc):
+        os.makedirs(outloc)
+    # workout the stringargs
+    if stringargs:
+        stringarrayexpr="string stringargs[]="+re.sub('\'','"',str(stringargs.split()))+";\n"
+    else:
+        stringarrayexpr="string stringargs[];\n"
+    wdir = setwdir().rstrip()
+    #workout standard input file
+    if stdin != "None":
+            stdinfilexpr = "file stdinfile<\""+stdin+"\">;\n"
+        else:
+            stdinfilexpr = "file stdinfile = input(\""+stdin+"\");\n"
+    else:
+        #print "no stdin"
+            stdinfilexpr = "file stdinfile<\"/dev/null\">;\n"
+        else:
+            stdinfilexpr = "file stdinfile = input(\"/dev/null\");\n"
+    #Build Swift source code
+    f = open(wdir+"/script.swift", "w");
+        f.write("type file; \n")
+        f.write("app (file _out, file _err) anapp(file _exec, int _i, string _stringargs[], file _fileargs[], file _stdin){ \n")
+        f.write("    "+interpreter+" @_exec _i _stringargs @_fileargs stdin=@_stdin stdout=@_out stderr=@_err; \n")
+        f.write("}\n")
+        f.write(stringarrayexpr)
+        f.write(filearrayexpr)
+        f.write(stdinfilexpr)
+        f.write("file exec<\""+executable+"\">;\n")
+        if range_or_list == "list":
+            f.write("file listfile<\""+listfile+"\">;\n")
+            f.write("string list[] = readData(listfile);\n");
+            f.write("foreach l, i in list{\n")
+            f.write("    file out <single_file_mapper; file=@strcat(\""+outloc+"\", \"/\", l, \".\", i, \".out\")>;\n")
+            f.write("    file err <single_file_mapper; file=@strcat(\""+outloc+"\", \"/\", l, \".\", i, \".err\")>;\n")
+        else:
+            f.write("foreach i in ["+rstart+":"+rend+":"+stepsize+"]{\n")
+            f.write("    file out <single_file_mapper; file=@strcat(\""+outloc+"\", \"/\", i, \".out\")>;\n")
+            f.write("    file err <single_file_mapper; file=@strcat(\""+outloc+"\", \"/\", i, \".err\")>;\n")
+        f.write("    (out,err) = anapp(exec, i, stringargs, fileargs, stdinfile);\n")
+        f.write("}\n")
+        #build site
+        if os.path.dirname(sys.argv[0]):
+            basedir=os.path.dirname(sys.argv[0])
+        else:
+            basedir='.'
+        #print "%s %s %s" %(basedir, sites, wdir)
+        subprocess.call([basedir+"/buildsite.sh", sites, wdir])
+        #build config file
+        buildcfg(wdir)
+        #build tc file
+        with open(wdir+"/tc", 'w') as tc:
+            for site in sites.split():
+                tc.write(site+' '+interpreter+' '+interpreter)
+    else: # T
+        f.write("import files;\n");
+        f.write("import string;\n");
+        f.write("import io;\n");
+        f.write("\n");
+        f.write(" app (file _out, file _err) anapp(file _exec, int _i, string _stringargs[], file _fileargs[], file _stdin){\n");
+        f.write("  \"" +interpreter+"\"  _exec _i _stringargs _fileargs @stdin=_stdin @stdout=_out @stderr=_err; \n");
+        f.write("}\n");
+        f.write("main{\n");
+        f.write(stringarrayexpr + " \n");
+        f.write(filearrayexpr + " \n");
+        f.write(stdinfilexpr + " \n");
+        f.write("file exec = input(\""+executable+"\");\n");
+            f.write(" \n");
+            f.write("file listfile=input(\""+listfile+"\");\n")
+            f.write("string list[] = split(read(listfile),);\n");
+            f.write("    file out <sprintf(\""+outloc+"/%s.%i.out\", l, i)>;\n")
+            f.write("    file err <sprintf(\""+outloc+"/%s.%i.err\", l, i)>;\n")
+        else:
+            f.write("foreach i in ["+rstart+":"+rend+":"+stepsize+"]{ \n");
+            f.write("    file out <sprintf(\""+outloc+"/%i.out\", i)>; \n");
+            f.write("    file err <sprintf(\""+outloc+"/%i.err\", i)>; \n");
+        f.write("}\n");
+        f.write("printf(\"%s\", \"Done!\");\n");
+        f.write("}\n");
+    f.close()
+    #Invocation
+    with open(logfile,"wb") as errfile:
+        exitcode=subprocess.check_call([swift, "-sites.file", wdir+"/sites.xml", "-tc.file", wdir+"/tc", "-config", wdir+"/cf", wdir+"/script.swift", swiftargs],stderr=errfile)
+    print exitcode
+    #Populate output file
+    outlist=subprocess.check_output(["find", outloc, "-type", "f", "-iname", "*.out"])
+    f=open(outlistfile, "w")
+    f.write(outlist);
+    f.close()
+if __name__=='__main__':
+    main()
Property changes on: SwiftApps/dsp-swift/swiftjumpdsp.py
Added: SwiftApps/dsp-swift/swiftjumpdsp.xml
--- SwiftApps/dsp-swift/swiftjumpdsp.xml	                        (rev 0)
+++ SwiftApps/dsp-swift/swiftjumpdsp.xml	2014-12-11 19:44:14 UTC (rev 8331)
@@ -0,0 +1,59 @@
+<tool id="swiftjumpdsp" name="jumpdsp">
+         ToDo:
+         1. Option if the counter should be an argument, first one or last one.
+         2. Option to add files (in Galaxy dataset format) as arguments. These files then be added to Swift app as arguments.
+         3. Allow the tool to select another tool and run it.
+         4. Allow user to add more than one resource to run a job for load balancing.
+         5. Add ability to run Swift/T.
+         6. Let the localhost option be selected by default
+    <description>A Galaxy tool to run Dsp parameter sweeps via Swift foreach parallel construct</description>
+    <command interpreter="python">
+        swiftjumpdsp.py
+        "${inlocation}"
+        "${a}"
+        "${n}"
+        "${p}"
+        "${I}"
+        "${outlist}"
+    </command>
+       #if $swiftargs.mode == "advanced"
+       #for $sa in $swiftarg
+          ${sa.swiftargname}
+       #end for
+       #end if
+    <inputs>
+        <param name="inlocation" size="60" type="text" label="inlocation" help="Enter the path of the directory containing input data, eg. /home/ketan/farmer" />
+        <param name="a" size="60" type="text" label="aval" help="Enter the value of a"/>
+        <param name="n" size="60" type="text" label="nval" help="Enter the value of n"/>
+        <param name="p" size="60" type="text" label="pval" help="Enter the value of p"/>
+        <param name="I" size="60" type="text" label="Ival" help="Enter the value of I"/>
+    </inputs>
+    <outputs>
+        <data format="txt" name="logfile" type="data" label="Application Output" />
+        <data format="txt" name="outlist" type="data" label="Output List" />
+    </outputs>
+  <code file="postprocess.py">
+    <hook postprocess="writeoutlist" />
+  </code>
+<help>
+.. class:: warningmark
+**TIP**. Add args to provide additional arguments to your executable.
+**What it does**
+This is a tool to run dsp via Swift in parallel over files provided by user.
+</help>
+</tool>
