[Swift-commit] r8328 - SwiftApps/dsp-swift/galaxy
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Thu Dec 11 13:21:36 CST 2014
Author: ketan
Date: 2014-12-11 13:21:36 -0600 (Thu, 11 Dec 2014)
New Revision: 8328
Removed:
   SwiftApps/dsp-swift/galaxy/README
   SwiftApps/dsp-swift/galaxy/setup.py
   SwiftApps/dsp-swift/galaxy/swiftjumpdsp.py
   SwiftApps/dsp-swift/galaxy/swiftjumpdsp.xml
Log:
cleanup and refactor
Deleted: SwiftApps/dsp-swift/galaxy/README
--- SwiftApps/dsp-swift/galaxy/README	2014-12-11 19:04:26 UTC (rev 8327)
+++ SwiftApps/dsp-swift/galaxy/README	2014-12-11 19:21:36 UTC (rev 8328)
@@ -1,196 +0,0 @@
-The jump-DSP Swift Galaxy Integration
-Introduction
-The Swift-Galaxy integration project aims to build tools which can be used to
-leverage the best features of http://swift-lang.org/main[Swift] and
-http://galaxyproject.org[Galaxy] combined. We start with building a generic
-Galaxy tool, called `foreach` which allows user to compose Galaxy workflows
-such that each computation stage in the workflow is executed by Swift. User can
-compose Galaxy tool and pick up arbitrary executables and dataset to run the
-executable over. User can also run the executable over a list of items such as
-string or file parameters.
-NOTE: This document can be found http://swift-lang.org/tutorials/galaxy/tutorial.html[here].
-Swift-Galaxy `foreach` Mechanism
-The basic mechanism is that the tool user-interface will accept parameters and
-will pass them along to a backend Swift "generator". This generator program
-will run the parameters over Swift source and configuration templates. As a
-result, the right source and configuration files are produced in a temporary
-directory (`/tmp/tmpname`). This is then executed and the results collected.
-There are two ways the `foreach` Swift tool can be utilized. First, over a range
-of numbers. The tool is used to run any arbitrary executable via Swift `foreach`
-loop over a range of numbers. The executable will run with number in range as
-commandline argument, one at a time. Furthermore, user can add arbitrary string
-arguments in addition to the number argument to the call to executable.
-The second way runs the `foreach` loop over a list of items read from an input
-file. These items can be file references or simple strings. The tool will pass
-one item at a time to the executable as argument parameter and run them all in
-parallel. This is similar to the above described number range except that the
-iteration takes place over a list of items provided as a file.
-Installation
-This installation recipe assumes that you have Galaxy preinstalled. If not,
-installation instructions for Galaxy can be found
-https://wiki.galaxyproject.org/Admin/GetGalaxy[here].
-Step 0. Checkout the swift-galaxy SVN directory as follows:
-svn co https://svn.ci.uchicago.edu/svn/vdl2/SwiftApps/swift-galaxy
-Step 1. Create a symbolic link to the +swift-galaxy/swift+ directory from
-galaxy's +tools+ directory. For example, if Galaxy top level directory is
-+galaxy-dist+ and swift directory is $HOME/swift-galaxy/swift:
-cd galaxy-dist/tools
-ln -s $HOME/swift-galaxy/swift swift
-The advantage of symbolic links is that as users update the tool directory via
-`svn up`, they need not worry about reinstallation. Updates in installation
-gets automatically propagated to Galaxy.
-Step 2. Add the tool definitions of the tools contained in this Swift to
-Galaxy's tool_conf.xml. This can be done by copying the text in
-`<section>...</section>` from the tool_conf.xml in swift-galaxy directory and
-paste it to the tool_conf.xml of the Galaxy directory. In the current installation, the text to be copied is:
-<section name="swift" id="swift">
- <tool file="swift/tryswift.xml" />
- <tool file="swift/genericswift.xml" />
- <tool file="swift/swiftforeach.xml" />
-</section>
-Step 3. (Re)start Galaxy.
-sh run.sh
-In the Galaxy Web GUI, you should see the tools in a toolset titled Swift.
-Screenshots
-The following screenshot shows overall look-and-feel of the Swift-Galaxy tool
-in the Galaxy web GUI.
-image::./screenshots/overall.png["swift-galaxy screenshot", width=600, align="center"]
-The rest of this section walks you through each of the components shown in the
-above screen and their utility. The following screenshot shows execution
-location selector. User can select one or more execution locations from the
-list as their target execution site.
-image::./screenshots/execloc.png["execution location selector screenshot", width=200, align="center"]
-The following screenshot shows a dialog box to add Swift-level commandline
-arguments to be passed to the script.
-image::./screenshots/swift-level-args.png["swift-args screenshot", width=200, align="center"]
-The following screenshot shows a selection dropdown list to chose the execution
-interpreter from. The interpreters currently supported and tested are shell,
-java and python. Upcoming are R and matlab.
-image::./screenshots/execution-interpreter.png["interpreter screenshot", width=150, align="center"]
-The following screenshot shows the selection for an executable. User can upload
-an executable and select it from the list.
-image::./screenshots/executable.png["executable screenshot", width=200, align="center"]
-The following screenshot shows a selection for range of numbers or list of
-items to chose from. User can select one and the corresponding dialog box will
-appear below.
-image::./screenshots/rangeorlist.png["select range or list screenshot", width=150, align="center"]
-The following screenshot shows a dialog for string or file type arguments. A
-user can add string and filetype arguments to their executable and the
-commandline will be built accordingly.
-image::./screenshots/string-or-fileargs.png["string or fileargs screenshot", width=250, align="center"]
-The following screenshot shows a dialog box to enter the directory location for
-results of execution. The Swift output files will be placed here:
-image::./screenshots/outlocation.png["output location screenshot", width=250, align="center"]
-An example
-A simple Hello World Swift tool to run with Galaxy.
-To set up with your Galaxy environment follow the steps below:
-Prerequisite: Sun/Oracle java. Should work with IBM java but not tested. To test your java version:
-java -version
-Typical output is:
-java version "1.7.0_17"
-Java(TM) SE Runtime Environment (build 1.7.0_17-b02)
-Java HotSpot(TM) 64-Bit Server VM (build 23.7-b01, mixed mode)
-Step 1. Download and install Swift where Galaxy server is running. From a
-command prompt the following wget will pull the latest release from
-http://swift-lang.org/downloads/index.php[here].
-Step 2. SVN checkout the swift-galaxy directory and copy the Swift tool directory to Galaxy's tools directory:
-cp -r swift-galaxy/swift /location/of/galaxy-server/tools/
-Step 3. Edit the +tool_conf.xml+ file present at the top-level of galaxy directory tree to add the following lines between the +<toolbox>+ and +</toolbox>+ xml tags:
-<section name="swift-galaxy" id="swift-galaxy">
-  <tool file="currdir/nameoftoolfile.xml" />
-</section>
-Step 4. Restart the Galaxy server. The swift-galaxy tool should be available in the tool box of Galaxy GUI.
-Step 5. Invoke it by entering any number in the dialog box or leaving it to default.
-Step 6. For examples of other Galaxy-Swift tools, look into the swift directoty.
-Troubleshoot
-Each tool generates a set of Swift source and configuration files. These files are placed in a unique directory with a random name generated on the fly. The location of the directory is in `/tmp` and it is prefixed with name `swift-gal.` . The suffix is a four letter random number. You can run Swift from this directory to reproduce possible issues as follows:
-swift -tc.file tc -sites.file sites.xml -config cf script.swift
-Feel free to contact Swift http://swift-lang.org/support/index.php[support] if issues persist.
-Upcoming Features
-* Mixing the order of file and string arguments
-* Optionally allowing user to not use range number as arguments
-* Providing more Swift patterns, eg. `if-else` conditionals
Deleted: SwiftApps/dsp-swift/galaxy/setup.py
--- SwiftApps/dsp-swift/galaxy/setup.py	2014-12-11 19:04:26 UTC (rev 8327)
+++ SwiftApps/dsp-swift/galaxy/setup.py	2014-12-11 19:21:36 UTC (rev 8328)
@@ -1,40 +0,0 @@
-#!/usr/bin/env python
-Setup script to install swift-galaxy framework to your Galaxy installation.
-Usage: ./setup.py <path/to/galaxy>
-import xml.etree.ElementTree as ET
-import subprocess
-import sys
-import os
-import distutils.spawn
-import traceback
-import fnmatch
-import tarfile
-import urllib
-galaxyloc=sys.argv[1]
-#step 0. Download swift-galaxy.tgz and swift-rel.tgz untar and set path
-#step 1. Create symlink to the swift directory from the tools directory of galaxyloc if not already present
-if os.path.lexists(galaxyloc+"/tools/swift"):
-    os.remove(galaxyloc+"/tools/swift")
-os.symlink ("/tmp/swift-galaxy/swift", galaxyloc+"/tools/swift");
-#step 2. update the tool_conf.xml
-tree = ET.parse(galaxyloc+"/config/tool_conf.xml.main")
-root = tree.getroot()
-if 'swift' not in root.attrib:
-    root.append((ET.fromstring('<section name="swift" id="swift">\n <tool file="swift/tryswift.xml" />\n <tool file="swift/genericswift.xml" />\n <tool file="swift/swiftforeach.xml" />\n </section>\n ')))
-tree.write (galaxyloc+"/config/tool_conf.xml.main")
-#step 3. Print message
-print "Swift/Galaxy Installed."
Deleted: SwiftApps/dsp-swift/galaxy/swiftjumpdsp.py
--- SwiftApps/dsp-swift/galaxy/swiftjumpdsp.py	2014-12-11 19:04:26 UTC (rev 8327)
+++ SwiftApps/dsp-swift/galaxy/swiftjumpdsp.py	2014-12-11 19:21:36 UTC (rev 8328)
@@ -1,201 +0,0 @@
-This is the Swift foreach driver for Galaxy. It receives inputs from the Swift
-"foreach" Galaxy tool and depending on the options specified, builds a
-canonical Swift/K or Swift/T script and runs over specified computational
-environment.
-swiftjumpdsp.py
-        "${inlocation}"
-        "${a}"
-        "${n}"
-        "${p}"
-        "${I}"
-        "${outlist}"
-import subprocess
-import sys
-import os
-import traceback
-import fnmatch
-import re
-def setwdir():
-    return subprocess.check_output(["mktemp", "-d", "/tmp/swift-gal.XXXX"])
-def genargs(args):
-    for a in args:
-        yield a
-def buildcfg(wdir):
-    f=open(wdir+"/cf", 'w')
-    f.write("use.provider.staging=true\n")
-    f.write("wrapperlog.always.transfer=true\n")
-    f.write("execution.retries=0\n")
-    f.write("provider.staging.pin.swiftfiles=false\n")
-    f.write("sitedir.keep=true\n")
-    f.write("lazy.errors=false\n")
-    f.close()
-def main():
-    myargs = genargs(sys.argv)
-    try:
-        this=next(myargs)
-        inloc = next(myargs)
-        a = next(myargs)
-        n = next(myargs)
-        p = next(myargs)
-        I = next(myargs)
-        outloc = next(myargs)
-        outlistfile = next(myargs)
-        logfile = next(myargs)
-    except:
-        traceback.print_exc()
-        sys.exit(1)
-    #which swift
-    swift = distutils.spawn.find_executable("swift")
-    BASEDIR = os.path.dirname(os.path.realpath(__file__))
-    # workout the file args
-    fileargs=[]
-    for f in myargs:
-        fileargs.append(f)
-    #workout the file array only if user adds args else make it blank
-    if fileargs:
-        if k_or_t == "swiftK":
-            filearrayexpr="file fileargs[] <fixed_array_mapper; files=\""+','.join(fileargs)+"\">;\n"
-        else: #T
-            filearrayexpr="file fileargs[]="+str(fileargs)+";\n"
-    else:
-        filearrayexpr="file fileargs[];\n"
-    # create outloc dir
-    if not os.path.exists(outloc):
-        os.makedirs(outloc)
-    # workout the stringargs
-    if stringargs:
-        stringarrayexpr="string stringargs[]="+re.sub('\'','"',str(stringargs.split()))+";\n"
-    else:
-        stringarrayexpr="string stringargs[];\n"
-    wdir = setwdir().rstrip()
-    #workout standard input file
-    if stdin != "None":
-            stdinfilexpr = "file stdinfile<\""+stdin+"\">;\n"
-        else:
-            stdinfilexpr = "file stdinfile = input(\""+stdin+"\");\n"
-    else:
-        #print "no stdin"
-            stdinfilexpr = "file stdinfile<\"/dev/null\">;\n"
-        else:
-            stdinfilexpr = "file stdinfile = input(\"/dev/null\");\n"
-    #Build Swift source code
-    f = open(wdir+"/script.swift", "w");
-        f.write("type file; \n")
-        f.write("app (file _out, file _err) anapp(file _exec, int _i, string _stringargs[], file _fileargs[], file _stdin){ \n")
-        f.write("    "+interpreter+" @_exec _i _stringargs @_fileargs stdin=@_stdin stdout=@_out stderr=@_err; \n")
-        f.write("}\n")
-        f.write(stringarrayexpr)
-        f.write(filearrayexpr)
-        f.write(stdinfilexpr)
-        f.write("file exec<\""+executable+"\">;\n")
-        if range_or_list == "list":
-            f.write("file listfile<\""+listfile+"\">;\n")
-            f.write("string list[] = readData(listfile);\n");
-            f.write("foreach l, i in list{\n")
-            f.write("    file out <single_file_mapper; file=@strcat(\""+outloc+"\", \"/\", l, \".\", i, \".out\")>;\n")
-            f.write("    file err <single_file_mapper; file=@strcat(\""+outloc+"\", \"/\", l, \".\", i, \".err\")>;\n")
-        else:
-            f.write("foreach i in ["+rstart+":"+rend+":"+stepsize+"]{\n")
-            f.write("    file out <single_file_mapper; file=@strcat(\""+outloc+"\", \"/\", i, \".out\")>;\n")
-            f.write("    file err <single_file_mapper; file=@strcat(\""+outloc+"\", \"/\", i, \".err\")>;\n")
-        f.write("    (out,err) = anapp(exec, i, stringargs, fileargs, stdinfile);\n")
-        f.write("}\n")
-        #build site
-        if os.path.dirname(sys.argv[0]):
-            basedir=os.path.dirname(sys.argv[0])
-        else:
-            basedir='.'
-        #print "%s %s %s" %(basedir, sites, wdir)
-        subprocess.call([basedir+"/buildsite.sh", sites, wdir])
-        #build config file
-        buildcfg(wdir)
-        #build tc file
-        with open(wdir+"/tc", 'w') as tc:
-            for site in sites.split():
-                tc.write(site+' '+interpreter+' '+interpreter)
-    else: # T
-        f.write("import files;\n");
-        f.write("import string;\n");
-        f.write("import io;\n");
-        f.write("\n");
-        f.write(" app (file _out, file _err) anapp(file _exec, int _i, string _stringargs[], file _fileargs[], file _stdin){\n");
-        f.write("  \"" +interpreter+"\"  _exec _i _stringargs _fileargs @stdin=_stdin @stdout=_out @stderr=_err; \n");
-        f.write("}\n");
-        f.write("main{\n");
-        f.write(stringarrayexpr + " \n");
-        f.write(filearrayexpr + " \n");
-        f.write(stdinfilexpr + " \n");
-        f.write("file exec = input(\""+executable+"\");\n");
-            f.write(" \n");
-            f.write("file listfile=input(\""+listfile+"\");\n")
-            f.write("string list[] = split(read(listfile),);\n");
-            f.write("    file out <sprintf(\""+outloc+"/%s.%i.out\", l, i)>;\n")
-            f.write("    file err <sprintf(\""+outloc+"/%s.%i.err\", l, i)>;\n")
-        else:
-            f.write("foreach i in ["+rstart+":"+rend+":"+stepsize+"]{ \n");
-            f.write("    file out <sprintf(\""+outloc+"/%i.out\", i)>; \n");
-            f.write("    file err <sprintf(\""+outloc+"/%i.err\", i)>; \n");
-        f.write("}\n");
-        f.write("printf(\"%s\", \"Done!\");\n");
-        f.write("}\n");
-    f.close()
-    #Invocation
-    with open(logfile,"wb") as errfile:
-        exitcode=subprocess.check_call([swift, "-sites.file", wdir+"/sites.xml", "-tc.file", wdir+"/tc", "-config", wdir+"/cf", wdir+"/script.swift", swiftargs],stderr=errfile)
-    print exitcode
-    #Populate output file
-    outlist=subprocess.check_output(["find", outloc, "-type", "f", "-iname", "*.out"])
-    f=open(outlistfile, "w")
-    f.write(outlist);
-    f.close()
-if __name__=='__main__':
-    main()
Deleted: SwiftApps/dsp-swift/galaxy/swiftjumpdsp.xml
--- SwiftApps/dsp-swift/galaxy/swiftjumpdsp.xml	2014-12-11 19:04:26 UTC (rev 8327)
+++ SwiftApps/dsp-swift/galaxy/swiftjumpdsp.xml	2014-12-11 19:21:36 UTC (rev 8328)
@@ -1,59 +0,0 @@
-<tool id="swiftjumpdsp" name="jumpdsp">
-         ToDo:
-         1. Option if the counter should be an argument, first one or last one.
-         2. Option to add files (in Galaxy dataset format) as arguments. These files then be added to Swift app as arguments.
-         3. Allow the tool to select another tool and run it.
-         4. Allow user to add more than one resource to run a job for load balancing.
-         5. Add ability to run Swift/T.
-         6. Let the localhost option be selected by default
-    <description>A Galaxy tool to run Dsp parameter sweeps via Swift foreach parallel construct</description>
-    <command interpreter="python">
-        swiftjumpdsp.py
-        "${inlocation}"
-        "${a}"
-        "${n}"
-        "${p}"
-        "${I}"
-        "${outlist}"
-    </command>
-       #if $swiftargs.mode == "advanced"
-       #for $sa in $swiftarg
-          ${sa.swiftargname}
-       #end for
-       #end if
-    <inputs>
-        <param name="inlocation" size="60" type="text" label="inlocation" help="Enter the path of the directory containing input data, eg. /home/ketan/farmer" />
-        <param name="a" size="60" type="text" label="aval" help="Enter the value of a"/>
-        <param name="n" size="60" type="text" label="nval" help="Enter the value of n"/>
-        <param name="p" size="60" type="text" label="pval" help="Enter the value of p"/>
-        <param name="I" size="60" type="text" label="Ival" help="Enter the value of I"/>
-    </inputs>
-    <outputs>
-        <data format="txt" name="logfile" type="data" label="Application Output" />
-        <data format="txt" name="outlist" type="data" label="Output List" />
-    </outputs>
-  <code file="postprocess.py">
-    <hook postprocess="writeoutlist" />
-  </code>
-<help>
-.. class:: warningmark
-**TIP**. Add args to provide additional arguments to your executable.
-**What it does**
-This is a tool to run dsp via Swift in parallel over files provided by user.
-</help>
-</tool>
