[Swift-commit] r8325 - SwiftApps/dsp-swift/galaxy
ketan at ci.uchicago.edu ketan at ci.uchicago.edu
Wed Dec 10 21:21:32 CST 2014
Author: ketan
Date: 2014-12-10 21:21:32 -0600 (Wed, 10 Dec 2014)
New Revision: 8325
Modified:
   SwiftApps/dsp-swift/galaxy/setup.py
   SwiftApps/dsp-swift/galaxy/swiftjumpdsp.py
Log:
adapt to dsp
Modified: SwiftApps/dsp-swift/galaxy/setup.py
--- SwiftApps/dsp-swift/galaxy/setup.py	2014-12-11 02:47:54 UTC (rev 8324)
+++ SwiftApps/dsp-swift/galaxy/setup.py	2014-12-11 03:21:32 UTC (rev 8325)
@@ -19,19 +19,7 @@
 galaxyloc=sys.argv[1]
 #step 0. Download swift-galaxy.tgz and swift-rel.tgz untar and set path
-if not os.path.isfile("/tmp/swift-galaxy.tgz"):
-    urllib.urlretrieve("http://mcs.anl.gov/~ketan/swift-galaxy.tgz", filename="/tmp/swift-galaxy.tgz")
-    swiftgaltar = tarfile.open("/tmp/swift-galaxy.tgz")
-    swiftgaltar.extractall(path="/tmp")
-    swiftgaltar.close()
-if not os.path.isfile("/tmp/swift-0.94.1-RC3.tar.gz"):
-    urllib.urlretrieve("http://swift-lang.org/packages/swift-0.94.1-RC3.tar.gz", filename="/tmp/swift-0.94.1-RC3.tar.gz")
-    swiftar = tarfile.open("/tmp/swift-0.94.1-RC3.tar.gz")
-    swiftar.extractall(path="/tmp")
-    swiftar.close()
-    os.environ["PATH"] = os.environ["PATH"] + ":/tmp/swift-0.94.1-RC3/bin"
 #step 1. Create symlink to the swift directory from the tools directory of galaxyloc if not already present
 if os.path.lexists(galaxyloc+"/tools/swift"):
     os.remove(galaxyloc+"/tools/swift")
Modified: SwiftApps/dsp-swift/galaxy/swiftjumpdsp.py
--- SwiftApps/dsp-swift/galaxy/swiftjumpdsp.py	2014-12-11 02:47:54 UTC (rev 8324)
+++ SwiftApps/dsp-swift/galaxy/swiftjumpdsp.py	2014-12-11 03:21:32 UTC (rev 8325)
@@ -187,58 +187,10 @@
     f.close()
     #Invocation
-    if k_or_t == "swiftK":
-        with open(logfile,"wb") as errfile:
-            exitcode=subprocess.check_call([swift, "-sites.file", wdir+"/sites.xml", "-tc.file", wdir+"/tc", "-config", wdir+"/cf", wdir+"/script.swift", swiftargs],stderr=errfile)
-        print exitcode
-    else:
-        #print "Invoking T"
-        stc=distutils.spawn.find_executable("stc")
-        java=distutils.spawn.find_executable("java")
-        turbine= distutils.spawn.find_executable("turbine")
-        if sites == "localhost":
-            print "localhost"
-            with open(logfile, "wb") as errfile:
-                exitcode=subprocess.check_call([stc, "-j", java, wdir+"/script.swift"], stderr=errfile)
+    with open(logfile,"wb") as errfile:
+        exitcode=subprocess.check_call([swift, "-sites.file", wdir+"/sites.xml", "-tc.file", wdir+"/tc", "-config", wdir+"/cf", wdir+"/script.swift", swiftargs],stderr=errfile)
+    print exitcode
-            if exitcode == 0:
-                with open(logfile, "wb") as errfile, open("/dev/null", "r") as infile:
-                    exitcode=subprocess.check_call([turbine, "-n", str(n), wdir+"/script.tcl", swiftargs], stdin=infile, stderr=errfile)
-        elif sites == "Vesta":
-            print "vesta"
-            pwd=os.path.getcwd()
-            turbine_home="/home/wozniak/Public/sfw/turbine"
-                exitcode=subprocess.check_call([stc, "-t", "checkpointing", "-r", pwd, "-j", java, wdir+"/script.swift"], stderr=errfile)
-            if exitcode == 0:
-                    exitcode=subprocess.check_call([turbine_home+"/scripts/submit/cobalt/turbine-cobalt-run.zsh", "-n", str(n), wdir+"/script.tcl"], stdin=infile, stderr=errfile)
-        elif sites == "Mira":
-            print "mira"
-            turbine_home="/home/wozniak/Public/sfw/ppc64/turbine"
-            stc="/home/wozniak/Public/sfw/ppc64/stc/bin/stc"
-            if exitcode == 0:
-        else:
-            print "Site not recognized."
     #Populate output file
     outlist=subprocess.check_output(["find", outloc, "-type", "f", "-iname", "*.out"])
     f=open(outlistfile, "w")
