[Swift-commit] r8166 - SwiftTutorials/ATPESC_2014-08-14/swift-k/part07
wilde at ci.uchicago.edu wilde at ci.uchicago.edu
Wed Aug 13 18:39:59 CDT 2014
Author: wilde
Date: 2014-08-13 18:39:59 -0500 (Wed, 13 Aug 2014)
New Revision: 8166
Added:
   SwiftTutorials/ATPESC_2014-08-14/swift-k/part07/p7.swift
Removed:
   SwiftTutorials/ATPESC_2014-08-14/swift-k/part07/p4.swift
   SwiftTutorials/ATPESC_2014-08-14/swift-k/part07/p4b.swift
Modified:
   SwiftTutorials/ATPESC_2014-08-14/swift-k/part07/swift.properties
Log:
Rename p4 to p7.
Deleted: SwiftTutorials/ATPESC_2014-08-14/swift-k/part07/p4.swift
--- SwiftTutorials/ATPESC_2014-08-14/swift-k/part07/p4.swift	2014-08-13 23:34:36 UTC (rev 8165)
+++ SwiftTutorials/ATPESC_2014-08-14/swift-k/part07/p4.swift	2014-08-13 23:39:59 UTC (rev 8166)
@@ -1,43 +0,0 @@
-type file;
-(int result) randomInt ()
-  float range = 9999999.0;
-  float rand = java("java.lang.Math","random");
-  string s[] = strsplit(toString(range*rand),"\\.");
-  result = toInt(s[0]);
-app (file out, file traj) simulation (string npart, string steps, string mass)
-# mdviz  @out @traj 3 npart steps 50 ".0001" mass "0.1 1.0 0.2 0.05 50.0 0.1" 2.5 2.0 randomInt();
-  md     3 npart steps 10 ".0001" mass "0.1 1.0 0.2 0.05 50.0 0.1" 2.5 2.0 randomInt() @out @traj;
-app (file o) analyze (file s[])
-  mdstats filenames(s) stdout=filename(o);
-app (file o) convert (file s[])
-  convert filenames(s) filename(o);
-int    nsim   = toInt(arg("nsim","10"));
-string npart  = arg("npart","50");
-string steps  = arg("steps","1000");
-string mass   = arg("mass",".005");
-file sim[] <simple_mapper; prefix="output/sim_", suffix=".out">;
-file trj[] <simple_mapper; prefix="output/sim_", suffix=".trj.tgz">;
-foreach i in [0:nsim-1] {
-  (sim[i],trj[i]) = simulation(npart,steps,mass);
-file stats_out<"output/average.out">;
-stats_out = analyze(sim);
-#file viz_all<"output/all.gif">;
-#viz_all = convert(gifs);
Deleted: SwiftTutorials/ATPESC_2014-08-14/swift-k/part07/p4b.swift
--- SwiftTutorials/ATPESC_2014-08-14/swift-k/part07/p4b.swift	2014-08-13 23:34:36 UTC (rev 8165)
+++ SwiftTutorials/ATPESC_2014-08-14/swift-k/part07/p4b.swift	2014-08-13 23:39:59 UTC (rev 8166)
@@ -1,78 +0,0 @@
-type file;
-type kineticInfo {
-  int sim;
-  float energy;
-app (file out, file traj) simulation (int npart, int steps, int trsnaps, float mass)
-  md     3 npart steps trsnaps ".0001" mass "0.1 1.0 0.2 0.05 50.0 0.1" 2.5 2.0 randomInt() @out @traj;
-app (file o) kinetic (file s[])
-  mdmaxk 9999 filenames(s) stdout=filename(o);
-app (file o) render (file traj, int frame)
-  renderframe filename(traj) filename(o) frame;
-  convert "-delay" 20 filenames(s) filename(o);
-int   npart  = toInt(arg("npart","50"));
-int   steps  = toInt(arg("steps","1000"));
-int   trsnaps = 10;
-float mass   = toFloat(arg("mass",".005"));
-file trj[] <simple_mapper; prefix="output/sim_", suffix=".trj">;
-  (sim[i],trj[i]) = simulation(npart,steps,trsnaps,mass);
-file ke_out<"output/kinetic.out">;
-ke_out = kinetic(sim);
-kineticInfo kd[] = readData(ke_out);
-tracef("min eK simulation: %i eK: %f\n", kd[0].sim, kd[0].energy);
-tracef("max eK simulation: %i eK: %f\n", kd[nsim-1].sim, kd[nsim-1].energy);
-file mink[] <simple_mapper; prefix="output/mink/frame_", suffix=".png">;
-file maxk[] <simple_mapper; prefix="output/maxk/frame_", suffix=".png">;
-foreach i in [0:trsnaps-1] {
-  mink[i] = render(trj[kd[0].sim], i);
-  maxk[i] = render(trj[kd[nsim-1].sim], i);
-file minkmovie <"output/mink.gif">;
-file maxkmovie <"output/maxk.gif">;
-minkmovie = convert(mink);
-maxkmovie = convert(maxk);
Copied: SwiftTutorials/ATPESC_2014-08-14/swift-k/part07/p7.swift (from rev 8165, SwiftTutorials/ATPESC_2014-08-14/swift-k/part07/p4b.swift)
--- SwiftTutorials/ATPESC_2014-08-14/swift-k/part07/p7.swift	                        (rev 0)
+++ SwiftTutorials/ATPESC_2014-08-14/swift-k/part07/p7.swift	2014-08-13 23:39:59 UTC (rev 8166)
@@ -0,0 +1,78 @@
+type file;
+type kineticInfo {
+  int sim;
+  float energy;
+(int result) randomInt ()
+  float range = 9999999.0;
+  float rand = java("java.lang.Math","random");
+  string s[] = strsplit(toString(range*rand),"\\.");
+  result = toInt(s[0]);
+app (file out, file traj) simulation (int npart, int steps, int trsnaps, float mass)
+# mdviz  @out @traj 3 npart steps 50 ".0001" mass "0.1 1.0 0.2 0.05 50.0 0.1" 2.5 2.0 randomInt();
+  md     3 npart steps trsnaps ".0001" mass "0.1 1.0 0.2 0.05 50.0 0.1" 2.5 2.0 randomInt() @out @traj;
+app (file o) analyze (file s[])
+  mdstats filenames(s) stdout=filename(o);
+app (file o) kinetic (file s[])
+  mdmaxk 9999 filenames(s) stdout=filename(o);
+app (file o) render (file traj, int frame)
+  renderframe filename(traj) filename(o) frame;
+app (file o) convert (file s[])
+  convert "-delay" 20 filenames(s) filename(o);
+int   nsim   = toInt(arg("nsim","10"));
+int   npart  = toInt(arg("npart","50"));
+int   steps  = toInt(arg("steps","1000"));
+int   trsnaps = 10;
+float mass   = toFloat(arg("mass",".005"));
+file sim[] <simple_mapper; prefix="output/sim_", suffix=".out">;
+file trj[] <simple_mapper; prefix="output/sim_", suffix=".trj">;
+foreach i in [0:nsim-1] {
+  (sim[i],trj[i]) = simulation(npart,steps,trsnaps,mass);
+file stats_out<"output/average.out">;
+stats_out = analyze(sim);
+file ke_out<"output/kinetic.out">;
+ke_out = kinetic(sim);
+kineticInfo kd[] = readData(ke_out);
+tracef("min eK simulation: %i eK: %f\n", kd[0].sim, kd[0].energy);
+tracef("max eK simulation: %i eK: %f\n", kd[nsim-1].sim, kd[nsim-1].energy);
+file mink[] <simple_mapper; prefix="output/mink/frame_", suffix=".png">;
+file maxk[] <simple_mapper; prefix="output/maxk/frame_", suffix=".png">;
+foreach i in [0:trsnaps-1] {
+  mink[i] = render(trj[kd[0].sim], i);
+  maxk[i] = render(trj[kd[nsim-1].sim], i);
+file minkmovie <"output/mink.gif">;
+file maxkmovie <"output/maxk.gif">;
+minkmovie = convert(mink);
+maxkmovie = convert(maxk);
Modified: SwiftTutorials/ATPESC_2014-08-14/swift-k/part07/swift.properties
--- SwiftTutorials/ATPESC_2014-08-14/swift-k/part07/swift.properties	2014-08-13 23:34:36 UTC (rev 8165)
+++ SwiftTutorials/ATPESC_2014-08-14/swift-k/part07/swift.properties	2014-08-13 23:39:59 UTC (rev 8166)
@@ -1,2 +1,22 @@
-site=midway-sandyb
+site=tukey
+site.tukey {
+   jobmanager=localhost:cobalt
+   taskWalltime=00:15:00
+   workdir=/home/$USER/swiftwork
+   filesystem=local
+   maxJobs=10
+   tasksPerWorker=8
+   taskThrottle=300
+   initialscore=10000
+app.tukey.md=$PWD/../app/md
+app.tukey.mdstats=$PWD/../app/mdstats
+app.tukey.mdmaxk=$PWD/../app/mdmaxk
+app.tukey.renderframe=$PWD/../app/renderframe
+app.tukey.convert=/usr/bin/convert
+# site=midway-sandyb
 site.midway-sandyb.slurm.exclusive=false
