[Swift-commit] r8136 - demo/xsede.2014.0425/src/md
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Wed Aug 13 11:59:15 CDT 2014
Author: wozniak
Date: 2014-08-13 11:59:15 -0500 (Wed, 13 Aug 2014)
New Revision: 8136
Added:
   demo/xsede.2014.0425/src/md/main.c
   demo/xsede.2014.0425/src/md/md.h
   demo/xsede.2014.0425/src/md/test-md.sh
Modified:
   demo/xsede.2014.0425/src/md/Makefile
   demo/xsede.2014.0425/src/md/md.c
Log:
Latest
Modified: demo/xsede.2014.0425/src/md/Makefile
--- demo/xsede.2014.0425/src/md/Makefile	2014-08-13 16:43:02 UTC (rev 8135)
+++ demo/xsede.2014.0425/src/md/Makefile	2014-08-13 16:59:15 UTC (rev 8136)
@@ -1,15 +1,43 @@
 bin = md
-src = md.c
 CC = gcc
-#CFLAGS = -O3 -ffast-math
+INCLUDES :=
+OPTZ = -O0
+OPTS = -O3 -ffast-math
+CFLAGS = $(OPTZ) -g -fPIC -std=gnu99 $(INCLUDES)
-$(bin): $(src)
-	$(CC) -o $@ $(bin).c -lm
+SRC = main.c md.c
+OBJ = $(patsubst %.c,%.o,$(SRC))
+all: $(bin)
+# Link stand-alone executable:
+$(bin): $(OBJ)
+	$(CC) -o $(@) $(OBJ) -lm
+# Swift/T integration:
+USE_SWIFT = 1
+ifeq ($(USE_SWIFT),1)
+TCL_HOME = $(HOME)/sfw/tcl-8.6.0
+INCLUDES += -I $(TCL_HOME)/include
+swift-pkg: libtclmd.so
+md_wrap.c: md.i
+	swig $(<)
+libtclmd.so: md_wrap.o $(OBJ)
+	gcc -shared -o $(@) $(^) -L $(TCL_HOME)/lib -l tcl8.6
+endif
 .PHONY: clean
 clean:
-	rm -f $(obj) $(bin)
+	rm -f $(OBJ) $(bin)
 .PHONY: install
 install:
@@ -18,3 +46,4 @@
 .PHONY: uninstall
 uninstall:
 	rm -f ../../bin/$(bin)
Added: demo/xsede.2014.0425/src/md/main.c
--- demo/xsede.2014.0425/src/md/main.c	                        (rev 0)
+++ demo/xsede.2014.0425/src/md/main.c	2014-08-13 16:59:15 UTC (rev 8136)
@@ -0,0 +1,221 @@
+ * main.c
+ *  Created on: Aug 13, 2014
+ *      Author: wozniak
+#include <stdio.h>
+#include <stdlib.h>
+#include "md.h"
+char *outfile = "md.dat";
+char *trjfile = "md.trj.tgz";
+int main ( int argc, char *argv[] )
+  Purpose:
+    MAIN is the main program for MD.
+  Discussion:
+    MD implements a simple molecular dynamics simulation.
+    The velocity Verlet time integration scheme is used.
+    The particles interact with a central pair potential.
+  Usage:
+    md nd np step_num print_step_num dt mass printinfo scale_factor scale_offset seed outFile trajectoryFile
+    where
+    * nd is the spatial dimension (2 or 3);
+    * np is the number of particles (500, for instance);
+    * step_num is the number of time steps (500, for instance);
+    * print_step_num is the number of snapshot prints (10 for instance);
+    * dt is size of timestep;
+    * mass is particle mass;
+    * printinfo is a string to append to each particle coord
+    * scale_offset and scale_factor are used to scale particle positions for logging/rendering (FIXME)
+    * seed sets the initial configuration
+  Licensing:
+    This code is distributed under the GNU LGPL license.
+  Modified:
+    05 November 2010
+  Author:
+    Original FORTRAN90 version by Bill Magro.
+    C version by John Burkardt.
+  Parameters:
+    None
+  double ctime;
+  double ctime1;
+  double ctime2;
+  double dt = 0.0001;
+  double e0;
+  double *force;
+  int i;
+  int id;
+  double kinetic;
+  double mass = 1.0 * .0001;
+  int nd;
+  int np;
+  double potential;
+  int seed = 123456789;
+  int step;
+  int step_num;
+  int step_print;
+  int step_print_index = 0;
+  int step_print_num = 10;
+  double *vel;
+  timestamp ( );
+  printf ( "\n" );
+  printf ( "MD\n" );
+  printf ( "  C version\n" );
+  printf ( "  A molecular dynamics program.\n" );
+  Get the spatial dimension.
+  if ( 1 < argc )
+    nd = atoi ( argv[1] );
+  else
+    printf ( "\n" );
+    printf ( "  Enter ND, the spatial dimension (2 or 3).\n" );
+    scanf ( "%d", &nd );
+//  Get the number of points.
+  if ( 2 < argc )
+    np = atoi ( argv[2] );
+  else
+    printf ( "\n" );
+    printf ( "  Enter NP, the number of points (500, for instance).\n" );
+    scanf ( "%d", &np );
+//  Get the number of time steps.
+  if ( 3 < argc )
+    step_num = atoi ( argv[3] );
+  else
+    printf ( "\n" );
+    printf ( "  Enter ND, the number of time steps (500 or 1000, for instance).\n" );
+    scanf ( "%d", &step_num );
+        Get any additional args (command-line only)
+        md nd np step_num [ step__print_num dt mass printinfo scale_factor scale_offset randomseed outfile trjfile ]
+  if ( 4 < argc )
+    step_print_num = atoi ( argv[4] );
+  if ( 5 < argc )
+    dt = atof ( argv[5] );
+  if ( 6 < argc )
+    mass = atof ( argv[6] );
+  if ( 7 < argc )
+    printinfo = ( argv[7] );
+  if ( 8 < argc )
+    scale_factor = atof ( argv[8] );
+  if ( 9 < argc )
+    scale_offset = atof ( argv[9] );
+  if ( 10 < argc )
+    seed = atof ( argv[10] );
+  if ( 11 < argc )
+    outfile = argv[11];
+  if ( 12 < argc )
+    trjfile = argv[12];
+  Report.
+  printf ( "\n" );
+  printf ( "  MD: Argument count: %d\n", argc );
+  printf ( "  ND, the spatial dimension, is %d\n", nd );
+  printf ( "  NP, the number of particles in the simulation, is %d\n", np );
+  printf ( "  STEP_NUM, the number of time steps, is %d\n", step_num );
+  printf ( "  STEP_PRINT_NUM, the number of snapshots to print, is %d\n", step_print_num );
+  printf ( "  DT, the size of each time step, is %f\n", dt );
+  printf ( "  MASS, the particle mass, is %f\n", mass );
+  printf ( "  PRINTINFO, the pass-through info to c-ray, is %s\n", printinfo );
+  printf ( "  SCALE_FACTOR, the particle position scaling factor, is %f\n", scale_factor );
+  printf ( "  SCALE_OFFSET, the particle position scaling offset, is %f\n", scale_offset );
+  printf ( "  SEED, the simulation randomization seed, is %d\n", seed );
+  ctime1 = cpu_time ( );
+  simulate (step_num, step_print_num, step_print, step_print_index,
+            np, nd, mass, potential, kinetic, e0,
+            dt, seed, outfile);
+  ctime2 = cpu_time ( );
+  ctime = ctime2 - ctime1;
+  printf ( "\n" );
+  printf ( "  Elapsed cpu time for main computation:\n" );
+  printf ( "  %f seconds.\n", ctime );
+  char tarcmd[2000];
+  sprintf(tarcmd,"tar zcf %s md??.trj",trjfile);
+  system(tarcmd);
+  Terminate.
+  printf ( "\n" );
+  printf ( "  Normal end of execution.\n" );
+  printf ( "\n" );
+  timestamp ( );
+  return 0;
Modified: demo/xsede.2014.0425/src/md/md.c
--- demo/xsede.2014.0425/src/md/md.c	2014-08-13 16:43:02 UTC (rev 8135)
+++ demo/xsede.2014.0425/src/md/md.c	2014-08-13 16:59:15 UTC (rev 8136)
@@ -1,3 +1,4 @@
+# include <assert.h>
 # include <stdlib.h>
 # include <stdio.h>
 # include <time.h>
@@ -3,262 +4,92 @@
 # include <math.h>
-int main ( int argc, char *argv[] );
-void compute ( int np, int nd, double pos[], double vel[],
-  double mass, double f[], double *pot, double *kin );
-double cpu_time ( void );
-double dist ( int nd, double r1[], double r2[], double dr[] );
-void initialize ( int np, int nd, double box[], int *seed, double pos[],
-  double vel[], double acc[] );
-double r8_uniform_01 ( int *seed );
-void timestamp ( void );
-void update ( int np, int nd, double pos[], double vel[], double f[],
-  double acc[], double mass, double dt );
-void snap ( int np, int nd, double pos[], double vel[], double f[],
+#include "md.h"
 double scale_factor = 2.5, scale_offset = -2.0;
 char *printinfo = "0.05 1.0 0.2 0.05 50.0 0.1";
-char *outfile = "md.dat";
-char *trjfile = "md.trj.tgz";
+double dist ( int nd, double r1[], double r2[], double dr[] );
+double r8_uniform_01 ( int *seed );
+void update ( int np, int nd, double pos[], double vel[], double f[],
+  double acc[], double mass, double dt );
+void snap ( int np, int nd, double t, double pos[], double vel[], double f[],
-  Purpose:
+static void snap_file_open(void);
+static void snap_file_close(void);
-    MAIN is the main program for MD.
+void simulate (int step_num, int step_print_num,
+               int step_print, int step_print_index,
+               int np, int nd,
+               double mass,
+               double potential, double kinetic, double e0,
+               double dt,
+               int seed,
+               char* outfile)
+    Allocate memory.
+    double* acc = ( double * ) malloc ( nd * np * sizeof ( double ) );
+    double* box = ( double * ) malloc ( nd * sizeof ( double ) );
+    double* force = ( double * ) malloc ( nd * np * sizeof ( double ) );
+    double* pos = ( double * ) malloc ( nd * np * sizeof ( double ) );
+    double* vel = ( double * ) malloc ( nd * np * sizeof ( double ) );
+    Set the dimensions of the box.
+    for (int i = 0; i < nd; i++ )
+      box[i] = 10.0;
-  Discussion:
+    printf ( "\n" );
+    printf ( "  Initializing positions, velocities, and accelerations.\n" );
-    MD implements a simple molecular dynamics simulation.
+    snap_file_open();
-    The velocity Verlet time integration scheme is used.
+    Set initial positions, velocities, and accelerations.
+    initialize ( np, nd, box, &seed, pos, vel, acc );
+    Compute the forces and energies.
+    printf ( "\n" );
+    printf ( "  Computing initial forces and energies.\n" );
-    The particles interact with a central pair potential.
+    compute ( np, nd, pos, vel, mass, force, &potential, &kinetic );
-  Usage:
-    md nd np step_num print_step_num dt mass printinfo scale_factor scale_offset seed outFile trajectoryFile
-    where
-    * nd is the spatial dimension (2 or 3);
-    * np is the number of particles (500, for instance);
-    * step_num is the number of time steps (500, for instance);
-    * print_step_num is the number of snapshot prints (10 for instance);
-    * dt is size of timestep;
-    * mass is particle mass;
-    * printinfo is a string to append to each particle coord
-    * scale_offset and scale_factor are used to scale particle positions for logging/rendering (FIXME)
-    * seed sets the initial configuration
-  Licensing:
-    This code is distributed under the GNU LGPL license.
-  Modified:
-    05 November 2010
-  Author:
-    Original FORTRAN90 version by Bill Magro.
-    C version by John Burkardt.
-  Parameters:
-    None
-  double *acc;
-  double *box;
-  double ctime;
-  double ctime1;
-  double ctime2;
-  double dt = 0.0001;
-  double e0;
-  double *force;
-  int i;
-  int id;
-  double kinetic;
-  double mass = 1.0 * .0001;
-  int nd;
-  int np;
-  double *pos;
-  double potential;
-  int seed = 123456789;
-  int step;
-  int step_num;
-  int step_print;
-  int step_print_index;
-  int step_print_num=10;
-  double *vel;
-  timestamp ( );
-  printf ( "\n" );
-  printf ( "MD\n" );
-  printf ( "  C version\n" );
-  printf ( "  A molecular dynamics program.\n" );
-  Get the spatial dimension.
-  if ( 1 < argc )
-    nd = atoi ( argv[1] );
-  else
+    e0 = potential + kinetic;
+    This is the main time stepping loop:
+      Compute forces and energies,
+      Update positions, velocities, accelerations.
     printf ( "\n" );
-    printf ( "  Enter ND, the spatial dimension (2 or 3).\n" );
-    scanf ( "%d", &nd );
-//  Get the number of points.
-  if ( 2 < argc )
-    np = atoi ( argv[2] );
-  else
+    printf ( "  At each step, we report the potential and kinetic energies.\n" );
+    printf ( "  The sum of these energies should be a constant.\n" );
+    printf ( "  As an accuracy check, we also print the relative error\n" );
+    printf ( "  in the total energy.\n" );
     printf ( "\n" );
-    printf ( "  Enter NP, the number of points (500, for instance).\n" );
-    scanf ( "%d", &np );
-//  Get the number of time steps.
-  if ( 3 < argc )
-    step_num = atoi ( argv[3] );
-  else
+    printf ( "      Step      Potential       Kinetic        (P+K-E0)/E0\n" );
+    printf ( "                Energy P        Energy K       Relative Energy Error\n" );
     printf ( "\n" );
-    printf ( "  Enter ND, the number of time steps (500 or 1000, for instance).\n" );
-    scanf ( "%d", &step_num );
-	Get any additional args (command-line only)
-	md nd np step_num [ step__print_num dt mass printinfo scale_factor scale_offset randomseed outfile trjfile ]
-  if ( 4 < argc )
-    step_print_num = atoi ( argv[4] );
-  if ( 5 < argc )
-    dt = atof ( argv[5] );
-  if ( 6 < argc )
-    mass = atof ( argv[6] );
-  if ( 7 < argc )
-    printinfo = ( argv[7] );
-  if ( 8 < argc )
-    scale_factor = atof ( argv[8] );
-  if ( 9 < argc )
-    scale_offset = atof ( argv[9] );
-  if ( 10 < argc )
-    seed = atof ( argv[10] );
-  if ( 11 < argc )
-    outfile = argv[11];
-  if ( 12 < argc )
-    trjfile = argv[12];
-  Report.
-  printf ( "\n" );
-  printf ( "  MD: Argument count: %d\n", argc );
-  printf ( "  ND, the spatial dimension, is %d\n", nd );
-  printf ( "  NP, the number of particles in the simulation, is %d\n", np );
-  printf ( "  STEP_NUM, the number of time steps, is %d\n", step_num );
-  printf ( "  STEP_PRINT_NUM, the number of snapshots to print, is %d\n", step_print_num );
-  printf ( "  DT, the size of each time step, is %f\n", dt );
-  printf ( "  MASS, the particle mass, is %f\n", mass );
-  printf ( "  PRINTINFO, the pass-through info to c-ray, is %s\n", printinfo );
-  printf ( "  SCALE_FACTOR, the particle position scaling factor, is %f\n", scale_factor );
-  printf ( "  SCALE_OFFSET, the particle position scaling offset, is %f\n", scale_offset );
-  printf ( "  SEED, the simulation randomization seed, is %d\n", seed );
-  Allocate memory.
-  acc = ( double * ) malloc ( nd * np * sizeof ( double ) );
-  box = ( double * ) malloc ( nd * sizeof ( double ) );
-  force = ( double * ) malloc ( nd * np * sizeof ( double ) );
-  pos = ( double * ) malloc ( nd * np * sizeof ( double ) );
-  vel = ( double * ) malloc ( nd * np * sizeof ( double ) );
-  Set the dimensions of the box.
-  for ( i = 0; i < nd; i++ )
-    box[i] = 10.0;
+    FILE *ofile = fopen(outfile,"w");
+    fprintf (ofile, "      Step      Potential       Kinetic        RelativeErr\n" );
-  printf ( "\n" );
-  printf ( "  Initializing positions, velocities, and accelerations.\n" );
-  Set initial positions, velocities, and accelerations.
-  initialize ( np, nd, box, &seed, pos, vel, acc );
-  Compute the forces and energies.
-  printf ( "\n" );
-  printf ( "  Computing initial forces and energies.\n" );
+    int step = 0;
+    printf ( "  %8d  %14f  %14f  %14e\n",
+      step, potential, kinetic, ( potential + kinetic - e0 ) / e0 );
+    fprintf ( ofile, "  %8d  %14f  %14f  %14e\n",
+    step_print_index = step_print_index + 1;
+    step_print = ( step_print_index * step_num ) / step_print_num;
-  compute ( np, nd, pos, vel, mass, force, &potential, &kinetic );
-  e0 = potential + kinetic;
-  This is the main time stepping loop:
-    Compute forces and energies,
-    Update positions, velocities, accelerations.
-  printf ( "\n" );
-  printf ( "  At each step, we report the potential and kinetic energies.\n" );
-  printf ( "  The sum of these energies should be a constant.\n" );
-  printf ( "  As an accuracy check, we also print the relative error\n" );
-  printf ( "  in the total energy.\n" );
-  printf ( "\n" );
-  printf ( "      Step      Potential       Kinetic        (P+K-E0)/E0\n" );
-  printf ( "                Energy P        Energy K       Relative Energy Error\n" );
-  printf ( "\n" );
-  FILE *ofile = fopen(outfile,"w");
-  fprintf (ofile, "      Step      Potential       Kinetic        RelativeErr\n" );
-  step_print = 0;
-  step_print_index = 0;
-  step = 0;
-  printf ( "  %8d  %14f  %14f  %14e\n",
-    step, potential, kinetic, ( potential + kinetic - e0 ) / e0 );
-  fprintf ( ofile, "  %8d  %14f  %14f  %14e\n",
-  step_print_index = step_print_index + 1;
-  step_print = ( step_print_index * step_num ) / step_print_num;
-  ctime1 = cpu_time ( );
-  for ( step = 1; step <= step_num; step++ )
+  for (step = 1; step <= step_num; step++ )
@@ -267,43 +98,26 @@
     if ( step == step_print )
       printf ( "  %8d  %14f  %14f  %14e\n", step, potential, kinetic,
-       ( potential + kinetic - e0 ) / e0 );
+               ( potential + kinetic - e0 ) / e0 );
       fprintf ( ofile, "  %8d  %14f  %14f  %14e\n", step, potential, kinetic,
-    snap ( np, nd, pos, vel, force, acc, mass, dt );
+      snap (np, nd, step*dt, pos, vel, force, acc, mass, dt );
     update ( np, nd, pos, vel, force, acc, mass, dt );
-  ctime2 = cpu_time ( );
-  ctime = ctime2 - ctime1;
-  printf ( "\n" );
-  printf ( "  Elapsed cpu time for main computation:\n" );
-  printf ( "  %f seconds.\n", ctime );
   free ( acc );
   free ( box );
   free ( force );
   free ( pos );
   free ( vel );
-  char tarcmd[2000];
-  sprintf(tarcmd,"tar zcf %s md??.trj",trjfile);
-  system(tarcmd);
-  Terminate.
-  printf ( "\n" );
-  printf ( "  Normal end of execution.\n" );
-  printf ( "\n" );
-  timestamp ( );
   fclose(ofile);
-  return 0;
+  snap_file_close();
@@ -766,22 +580,32 @@
 static int snapid = 0;
+static FILE *snap_file = NULL;
+static void snap_file_open()
-  int j;
   char snapfile[100];
   sprintf(snapfile, "md%02d.trj", snapid);
+  snap_file = fopen(snapfile, "w");
+  assert(snap_file != NULL);
-  FILE *sf = fopen(snapfile, "w");
+static void snap_file_close()
+  fclose(snap_file);
+  snap_file = NULL;
+  int j;
   for ( j = 0; j < np; j++ )
-    fprintf(sf, "s %f %f %f %s\n", scale(pos[0+j*nd]), scale(pos[1+j*nd]), scale(pos[2+j*nd]), printinfo);
+    fprintf(snap_file, "%f s %f %f %f %s\n",
+            t, scale(pos[0+j*nd]), scale(pos[1+j*nd]), scale(pos[2+j*nd]), printinfo);
-  fclose(sf);
   snapid++;
Added: demo/xsede.2014.0425/src/md/md.h
--- demo/xsede.2014.0425/src/md/md.h	                        (rev 0)
+++ demo/xsede.2014.0425/src/md/md.h	2014-08-13 16:59:15 UTC (rev 8136)
@@ -0,0 +1,33 @@
+ * md.h
+ *      Author: wozniak
+#ifndef MD_H
+#define MD_H
+extern double scale_factor, scale_offset;
+extern char *printinfo;
+double cpu_time ( void );
+void timestamp ( void );
+void initialize ( int np, int nd, double box[], int *seed, double pos[],
+  double vel[], double acc[] );
+void compute ( int np, int nd, double pos[], double vel[],
+  double mass, double f[], double *pot, double *kin );
+               int np, int nd,
+               double mass,
+               double dt,
+               int seed,
+               char* outfile);
+#endif
Added: demo/xsede.2014.0425/src/md/test-md.sh
--- demo/xsede.2014.0425/src/md/test-md.sh	                        (rev 0)
+++ demo/xsede.2014.0425/src/md/test-md.sh	2014-08-13 16:59:15 UTC (rev 8136)
@@ -0,0 +1,10 @@
+#!/bin/sh -eu
+NPART=4
+STEPS=10
+MASS=1
+SEED=42
+OUT=output.txt
+TRJ=output.trj
+./md 3 ${NPART} ${STEPS} 10 ".0001" ${MASS} "0.1 1.0 0.2 0.05 50.0 0.1" 2.5 2.0 ${SEED} ${OUT} ${TRJ}
Property changes on: demo/xsede.2014.0425/src/md/test-md.sh
___________________________________________________________________
Added: svn:executable
