[Swift-commit] r8124 - SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/05-md
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Wed Aug 13 10:46:03 CDT 2014
Author: wozniak
Date: 2014-08-13 10:46:03 -0500 (Wed, 13 Aug 2014)
New Revision: 8124
Added:
   SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/05-md/md.c
Log:
Copied from:
URL: https://svn.ci.uchicago.edu/svn/vdl2/demo/xsede.2014.0425/src/md
Revision: 8122
Added: SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/05-md/md.c
--- SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/05-md/md.c	                        (rev 0)
+++ SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/05-md/md.c	2014-08-13 15:46:03 UTC (rev 8124)
@@ -0,0 +1,787 @@
+# include <stdlib.h>
+# include <stdio.h>
+# include <time.h>
+# include <math.h>
+int main ( int argc, char *argv[] );
+void compute ( int np, int nd, double pos[], double vel[],
+  double mass, double f[], double *pot, double *kin );
+double cpu_time ( void );
+double dist ( int nd, double r1[], double r2[], double dr[] );
+void initialize ( int np, int nd, double box[], int *seed, double pos[],
+  double vel[], double acc[] );
+double r8_uniform_01 ( int *seed );
+void timestamp ( void );
+void update ( int np, int nd, double pos[], double vel[], double f[],
+  double acc[], double mass, double dt );
+void snap ( int np, int nd, double pos[], double vel[], double f[],
+double scale_factor = 2.5, scale_offset = -2.0;
+char *printinfo = "0.05 1.0 0.2 0.05 50.0 0.1";
+char *outfile = "md.dat";
+char *trjfile = "md.trj.tgz";
+  Purpose:
+    MAIN is the main program for MD.
+  Discussion:
+    MD implements a simple molecular dynamics simulation.
+    The velocity Verlet time integration scheme is used.
+    The particles interact with a central pair potential.
+  Usage:
+    md nd np step_num print_step_num dt mass printinfo scale_factor scale_offset seed outFile trajectoryFile
+    where
+    * nd is the spatial dimension (2 or 3);
+    * np is the number of particles (500, for instance);
+    * step_num is the number of time steps (500, for instance);
+    * print_step_num is the number of snapshot prints (10 for instance);
+    * dt is size of timestep;
+    * mass is particle mass;
+    * printinfo is a string to append to each particle coord
+    * scale_offset and scale_factor are used to scale particle positions for logging/rendering (FIXME)
+    * seed sets the initial configuration
+  Licensing:
+    This code is distributed under the GNU LGPL license.
+  Modified:
+    05 November 2010
+  Author:
+    Original FORTRAN90 version by Bill Magro.
+    C version by John Burkardt.
+  Parameters:
+    None
+  double *acc;
+  double *box;
+  double ctime;
+  double ctime1;
+  double ctime2;
+  double dt = 0.0001;
+  double e0;
+  double *force;
+  int i;
+  int id;
+  double kinetic;
+  double mass = 1.0 * .0001;
+  int nd;
+  int np;
+  double *pos;
+  double potential;
+  int seed = 123456789;
+  int step;
+  int step_num;
+  int step_print;
+  int step_print_index;
+  int step_print_num=10;
+  double *vel;
+  timestamp ( );
+  printf ( "\n" );
+  printf ( "MD\n" );
+  printf ( "  C version\n" );
+  printf ( "  A molecular dynamics program.\n" );
+  Get the spatial dimension.
+  if ( 1 < argc )
+    nd = atoi ( argv[1] );
+  else
+    printf ( "\n" );
+    printf ( "  Enter ND, the spatial dimension (2 or 3).\n" );
+    scanf ( "%d", &nd );
+//  Get the number of points.
+  if ( 2 < argc )
+    np = atoi ( argv[2] );
+  else
+    printf ( "\n" );
+    printf ( "  Enter NP, the number of points (500, for instance).\n" );
+    scanf ( "%d", &np );
+//  Get the number of time steps.
+  if ( 3 < argc )
+    step_num = atoi ( argv[3] );
+  else
+    printf ( "\n" );
+    printf ( "  Enter ND, the number of time steps (500 or 1000, for instance).\n" );
+    scanf ( "%d", &step_num );
+	Get any additional args (command-line only)
+	md nd np step_num [ step__print_num dt mass printinfo scale_factor scale_offset randomseed outfile trjfile ]
+  if ( 4 < argc )
+    step_print_num = atoi ( argv[4] );
+  if ( 5 < argc )
+    dt = atof ( argv[5] );
+  if ( 6 < argc )
+    mass = atof ( argv[6] );
+  if ( 7 < argc )
+    printinfo = ( argv[7] );
+  if ( 8 < argc )
+    scale_factor = atof ( argv[8] );
+  if ( 9 < argc )
+    scale_offset = atof ( argv[9] );
+  if ( 10 < argc )
+    seed = atof ( argv[10] );
+  if ( 11 < argc )
+    outfile = argv[11];
+  if ( 12 < argc )
+    trjfile = argv[12];
+  Report.
+  printf ( "\n" );
+  printf ( "  MD: Argument count: %d\n", argc );
+  printf ( "  ND, the spatial dimension, is %d\n", nd );
+  printf ( "  NP, the number of particles in the simulation, is %d\n", np );
+  printf ( "  STEP_NUM, the number of time steps, is %d\n", step_num );
+  printf ( "  STEP_PRINT_NUM, the number of snapshots to print, is %d\n", step_print_num );
+  printf ( "  DT, the size of each time step, is %f\n", dt );
+  printf ( "  MASS, the particle mass, is %f\n", mass );
+  printf ( "  PRINTINFO, the pass-through info to c-ray, is %s\n", printinfo );
+  printf ( "  SCALE_FACTOR, the particle position scaling factor, is %f\n", scale_factor );
+  printf ( "  SCALE_OFFSET, the particle position scaling offset, is %f\n", scale_offset );
+  printf ( "  SEED, the simulation randomization seed, is %d\n", seed );
+  Allocate memory.
+  acc = ( double * ) malloc ( nd * np * sizeof ( double ) );
+  box = ( double * ) malloc ( nd * sizeof ( double ) );
+  force = ( double * ) malloc ( nd * np * sizeof ( double ) );
+  pos = ( double * ) malloc ( nd * np * sizeof ( double ) );
+  vel = ( double * ) malloc ( nd * np * sizeof ( double ) );
+  Set the dimensions of the box.
+  for ( i = 0; i < nd; i++ )
+    box[i] = 10.0;
+  printf ( "\n" );
+  printf ( "  Initializing positions, velocities, and accelerations.\n" );
+  Set initial positions, velocities, and accelerations.
+  initialize ( np, nd, box, &seed, pos, vel, acc );
+  Compute the forces and energies.
+  printf ( "\n" );
+  printf ( "  Computing initial forces and energies.\n" );
+  compute ( np, nd, pos, vel, mass, force, &potential, &kinetic );
+  e0 = potential + kinetic;
+  This is the main time stepping loop:
+    Compute forces and energies,
+    Update positions, velocities, accelerations.
+  printf ( "\n" );
+  printf ( "  At each step, we report the potential and kinetic energies.\n" );
+  printf ( "  The sum of these energies should be a constant.\n" );
+  printf ( "  As an accuracy check, we also print the relative error\n" );
+  printf ( "  in the total energy.\n" );
+  printf ( "\n" );
+  printf ( "      Step      Potential       Kinetic        (P+K-E0)/E0\n" );
+  printf ( "                Energy P        Energy K       Relative Energy Error\n" );
+  printf ( "\n" );
+  FILE *ofile = fopen(outfile,"w");
+  fprintf (ofile, "      Step      Potential       Kinetic        RelativeErr\n" );
+  step_print = 0;
+  step_print_index = 0;
+  step = 0;
+  printf ( "  %8d  %14f  %14f  %14e\n",
+    step, potential, kinetic, ( potential + kinetic - e0 ) / e0 );
+  fprintf ( ofile, "  %8d  %14f  %14f  %14e\n",
+  step_print_index = step_print_index + 1;
+  step_print = ( step_print_index * step_num ) / step_print_num;
+  ctime1 = cpu_time ( );
+  for ( step = 1; step <= step_num; step++ )
+    if ( step == step_print )
+      printf ( "  %8d  %14f  %14f  %14e\n", step, potential, kinetic,
+       ( potential + kinetic - e0 ) / e0 );
+      fprintf ( ofile, "  %8d  %14f  %14f  %14e\n", step, potential, kinetic,
+    snap ( np, nd, pos, vel, force, acc, mass, dt );
+    update ( np, nd, pos, vel, force, acc, mass, dt );
+  ctime2 = cpu_time ( );
+  ctime = ctime2 - ctime1;
+  printf ( "\n" );
+  printf ( "  Elapsed cpu time for main computation:\n" );
+  printf ( "  %f seconds.\n", ctime );
+  free ( acc );
+  free ( box );
+  free ( force );
+  free ( pos );
+  free ( vel );
+  char tarcmd[2000];
+  sprintf(tarcmd,"tar zcf %s md??.trj",trjfile);
+  system(tarcmd);
+  Terminate.
+  printf ( "\n" );
+  printf ( "  Normal end of execution.\n" );
+  printf ( "\n" );
+  timestamp ( );
+  fclose(ofile);
+  return 0;
+  Purpose:
+    COMPUTE computes the forces and energies.
+  Discussion:
+    The computation of forces and energies is fully parallel.
+    The potential function V(X) is a harmonic well which smoothly
+    saturates to a maximum value at PI/2:
+      v(x) = ( sin ( min ( x, PI2 ) ) )^2
+    The derivative of the potential is:
+      dv(x) = 2.0 * sin ( min ( x, PI2 ) ) * cos ( min ( x, PI2 ) )
+            = sin ( 2.0 * min ( x, PI2 ) )
+  Licensing:
+  Modified:
+    21 November 2007
+  Author:
+  Parameters:
+    Input, int NP, the number of particles.
+    Input, int ND, the number of spatial dimensions.
+    Input, double POS[ND*NP], the position of each particle.
+    Input, double VEL[ND*NP], the velocity of each particle.
+    Input, double MASS, the mass of each particle.
+    Output, double F[ND*NP], the forces.
+    Output, double *POT, the total potential energy.
+    Output, double *KIN, the total kinetic energy.
+  double d;
+  double d2;
+  int i;
+  int j;
+  int k;
+  double ke;
+  double pe;
+  double PI2 = 3.141592653589793 / 2.0;
+  double rij[3];
+  pe = 0.0;
+  ke = 0.0;
+  for ( k = 0; k < np; k++ )
+  Compute the potential energy and forces.
+      f[i+k*nd] = 0.0;
+    for ( j = 0; j < np; j++ )
+      if ( k != j )
+        d = dist ( nd, pos+k*nd, pos+j*nd, rij );
+  Attribute half of the potential energy to particle J.
+        if ( d < PI2 )
+          d2 = d;
+        else
+          d2 = PI2;
+        pe = pe + 0.5 * pow ( sin ( d2 ), 2 );
+          f[i+k*nd] = f[i+k*nd] - rij[i] * sin ( 2.0 * d2 ) / d;
+  Compute the kinetic energy.
+      ke = ke + vel[i+k*nd] * vel[i+k*nd];
+  ke = ke * 0.5 * mass;
+  *pot = pe;
+  *kin = ke;
+  return;
+  Purpose:
+    CPU_TIME reports the total CPU time for a program.
+  Licensing:
+  Modified:
+    27 September 2005
+  Author:
+    John Burkardt
+  Parameters:
+    Output, double CPU_TIME, the current total elapsed CPU time in second.
+  double value;
+  value = ( double ) clock ( ) / ( double ) CLOCKS_PER_SEC;
+  return value;
+  Purpose:
+    DIST computes the displacement (and its norm) between two particles.
+  Licensing:
+  Modified:
+    21 November 2007
+  Author:
+  Parameters:
+    Input, double R1[ND], R2[ND], the positions of the particles.
+    Output, double DR[ND], the displacement vector.
+    Output, double D, the Euclidean norm of the displacement.
+  double d;
+  int i;
+  d = 0.0;
+    dr[i] = r1[i] - r2[i];
+    d = d + dr[i] * dr[i];
+  d = sqrt ( d );
+  return d;
+  Purpose:
+    INITIALIZE initializes the positions, velocities, and accelerations.
+  Licensing:
+  Modified:
+    20 July 2008
+  Author:
+  Parameters:
+    Input, double BOX[ND], specifies the maximum position
+    of particles in each dimension.
+    Input, int *SEED, a seed for the random number generator.
+    Output, double POS[ND*NP], the position of each particle.
+    Output, double VEL[ND*NP], the velocity of each particle.
+    Output, double ACC[ND*NP], the acceleration of each particle.
+  int i;
+  int j;
+  Give the particles random positions within the box.
+      pos[i+j*nd] = box[i] * r8_uniform_01 ( seed );
+      vel[i+j*nd] = 0.0;
+      acc[i+j*nd] = 0.0;
+  return;
+  Purpose:
+    R8_UNIFORM_01 is a unit pseudorandom R8.
+  Discussion:
+    This routine implements the recursion
+      seed = 16807 * seed mod ( 2^31 - 1 )
+      unif = seed / ( 2^31 - 1 )
+    The integer arithmetic never requires more than 32 bits,
+    including a sign bit.
+  Licensing:
+  Modified:
+    11 August 2004
+  Author:
+    John Burkardt
+  Reference:
+    Paul Bratley, Bennett Fox, Linus Schrage,
+    A Guide to Simulation,
+    Springer Verlag, pages 201-202, 1983.
+    Bennett Fox,
+    Algorithm 647:
+    Implementation and Relative Efficiency of Quasirandom
+    Sequence Generators,
+    ACM Transactions on Mathematical Software,
+    Volume 12, Number 4, pages 362-376, 1986.
+  Parameters:
+    Input/output, int *SEED, a seed for the random number generator.
+    Output, double R8_UNIFORM_01, a new pseudorandom variate, strictly between
+    0 and 1.
+  int k;
+  double r;
+  k = *seed / 127773;
+  *seed = 16807 * ( *seed - k * 127773 ) - k * 2836;
+  if ( *seed < 0 )
+    *seed = *seed + 2147483647;
+  r = ( double ) ( *seed ) * 4.656612875E-10;
+  return r;
+  Purpose:
+    TIMESTAMP prints the current YMDHMS date as a time stamp.
+  Example:
+    31 May 2001 09:45:54 AM
+  Licensing:
+  Modified:
+    24 September 2003
+  Author:
+    John Burkardt
+  Parameters:
+    None
+# define TIME_SIZE 40
+  static char time_buffer[TIME_SIZE];
+  const struct tm *tm;
+  size_t len;
+  time_t now;
+  now = time ( NULL );
+  tm = localtime ( &now );
+  len = strftime ( time_buffer, TIME_SIZE, "%d %B %Y %I:%M:%S %p", tm );
+  printf ( "%s\n", time_buffer );
+  return;
+# undef TIME_SIZE
+  Purpose:
+    UPDATE updates positions, velocities and accelerations.
+  Discussion:
+    The time integration is fully parallel.
+    A velocity Verlet algorithm is used for the updating.
+    x(t+dt) = x(t) + v(t) * dt + 0.5 * a(t) * dt * dt
+    v(t+dt) = v(t) + 0.5 * ( a(t) + a(t+dt) ) * dt
+    a(t+dt) = f(t) / m
+  Licensing:
+  Modified:
+    21 November 2007
+  Author:
+  Parameters:
+    Input/output, double POS[ND*NP], the position of each particle.
+    Input/output, double VEL[ND*NP], the velocity of each particle.
+    Input, double F[ND*NP], the force on each particle.
+    Input/output, double ACC[ND*NP], the acceleration of each particle.
+    Input, double DT, the time step.
+  int i;
+  int j;
+  double rmass;
+  rmass = 1.0 / mass;
+      pos[i+j*nd] = pos[i+j*nd] + vel[i+j*nd] * dt + 0.5 * acc[i+j*nd] * dt * dt;
+      vel[i+j*nd] = vel[i+j*nd] + 0.5 * dt * ( f[i+j*nd] * rmass + acc[i+j*nd] );
+      acc[i+j*nd] = f[i+j*nd] * rmass;
+s	-0.5 -0.3 -1	0.05	1.0 0.2 0.05		50.0	0.1
+s	0.5 -0.4 0		0.05	0.1 0.85 1.0		50.0	0.1
+    char *s = "0.05 1.0 0.2 0.05 50.0 0.1";
+    /* printf("s %f %f %f %s\n", pos[0+j*nd]/20.0, pos[1+j*nd]/20.0, pos[2+j*nd]/20.0, s); */
+  return;
+double scale (double x)
+  return( (x / scale_factor) - scale_offset);
+  /* return( (x / 2.5) - 2.0); */
+static int snapid = 0;
+  int j;
+  char snapfile[100];
+  sprintf(snapfile, "md%02d.trj", snapid);
+  FILE *sf = fopen(snapfile, "w");
+    fprintf(sf, "s %f %f %f %s\n", scale(pos[0+j*nd]), scale(pos[1+j*nd]), scale(pos[2+j*nd]), printinfo);
+  fclose(sf);
+  snapid++;
