[Swift-commit] r8105 - SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/04-py
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Tue Aug 12 11:59:38 CDT 2014
Author: wozniak
Date: 2014-08-12 11:59:37 -0500 (Tue, 12 Aug 2014)
New Revision: 8105
Added:
   SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/04-py/add.swift
Removed:
   SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/04-py/numpy.swift
Modified:
   SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/04-py/run-local.sh
Log:
Rename, make numpy library
Copied: SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/04-py/add.swift (from rev 8104, SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/04-py/numpy.swift)
--- SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/04-py/add.swift	                        (rev 0)
+++ SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/04-py/add.swift	2014-08-12 16:59:37 UTC (rev 8105)
@@ -0,0 +1,27 @@
+// Swift/T libraries:
+import io;
+import python;
+import string;
+// This example: See ./numpy.swift
+import numpy;
+f()
+  python(
+print("Python works!")
+repr(0)
+main
+  f();
+  matrix A1 = eye(3);
+  matrix A2 = eye(3);
+  matrix sum = add(A1, A2);
+  printf("2*eye(3)=%s", sum);
Deleted: SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/04-py/numpy.swift
--- SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/04-py/numpy.swift	2014-08-12 16:56:24 UTC (rev 8104)
+++ SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/04-py/numpy.swift	2014-08-12 16:59:37 UTC (rev 8105)
@@ -1,43 +0,0 @@
-import io;
-import python;
-import string;
-f()
-  python(
-print("Python works!")
-repr(0)
-global const string numpy = "from numpy import *\n\n";
-typedef matrix string;
-(matrix A) eye(int n)
-  string command = sprintf("repr(eye(%i))", n);
-  string code = numpy+command;
-  matrix t = python(code);
-  A = replace_all(t, "\n", "", 0);
-(matrix R) add(matrix A1, matrix A2)
-  string command = sprintf("repr(%s+%s)", A1, A2);
-  R = replace_all(t, "\n", "", 0);
-main
-  f();
-  matrix A1 = eye(3);
-  matrix A2 = eye(3);
-  matrix sum = add(A1, A2);
-  printf("2*eye(3)=%s", sum);
Modified: SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/04-py/run-local.sh
--- SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/04-py/run-local.sh	2014-08-12 16:56:24 UTC (rev 8104)
+++ SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/04-py/run-local.sh	2014-08-12 16:59:37 UTC (rev 8105)
@@ -2,6 +2,6 @@
 source ../../cfg/setup-local.sh
-PROGRAM=numpy
+PROGRAM=add
 stc     ${PROGRAM}.swift
 turbine ${PROGRAM}.tcl
