[Swift-commit] r8100 - SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Tue Aug 12 11:14:32 CDT 2014
Author: wozniak
Date: 2014-08-12 11:14:32 -0500 (Tue, 12 Aug 2014)
New Revision: 8100
Added:
   SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/run-local.sh
Removed:
   SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/test-blas.sh
Log:
Rename
Copied: SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/run-local.sh (from rev 8098, SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/test-blas.sh)
--- SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/run-local.sh	                        (rev 0)
+++ SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/run-local.sh	2014-08-12 16:14:32 UTC (rev 8100)
@@ -0,0 +1,33 @@
+#!/bin/bash
+export TURBINE_USER_LIB=${PWD}
+check()
+  if [[ ${?} != 0 ]]
+  then
+    MSG=$1
+    echo ${MSG}
+  fi
+STC=$( which stc )
+check
+echo "using stc: ${STC}"
+TURBINE=$( which turbine )
+check
+echo "using turbine: ${TURBINE}"
+STC_OUT=test-blas.tcl
+${STC} test-blas.swift ${STC_OUT}
+check
+echo "compiled to: ${STC_OUT}"
+export ADLB_EXHAUST_TIME=1
+${TURBINE} -l -n 3 ${STC_OUT}
+check
+exit 0
Deleted: SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/test-blas.sh
--- SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/test-blas.sh	2014-08-12 16:14:02 UTC (rev 8099)
+++ SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/test-blas.sh	2014-08-12 16:14:32 UTC (rev 8100)
@@ -1,33 +0,0 @@
-#!/bin/bash
-export TURBINE_USER_LIB=${PWD}
-check()
-  if [[ ${?} != 0 ]]
-  then
-    MSG=$1
-    echo ${MSG}
-  fi
-STC=$( which stc )
-check
-echo "using stc: ${STC}"
-TURBINE=$( which turbine )
-check
-echo "using turbine: ${TURBINE}"
-STC_OUT=test-blas.tcl
-${STC} test-blas.swift ${STC_OUT}
-check
-echo "compiled to: ${STC_OUT}"
-export ADLB_EXHAUST_TIME=1
-${TURBINE} -l -n 3 ${STC_OUT}
-check
-exit 0
