[Swift-commit] r8097 - SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas
wozniak at ci.uchicago.edu wozniak at ci.uchicago.edu
Tue Aug 12 11:09:05 CDT 2014
Author: wozniak
Date: 2014-08-12 11:09:05 -0500 (Tue, 12 Aug 2014)
New Revision: 8097
Added:
   SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/blas.swift
   SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/build.sh
   SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/make-package.tcl
   SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/test-blas.sh
   SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/test-blas.swift
Log:
Check in BLAS example
Added: SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/blas.swift
--- SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/blas.swift	                        (rev 0)
+++ SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/blas.swift	2014-08-12 16:09:05 UTC (rev 8097)
@@ -0,0 +1,9 @@
+(float z) blas_ddot(int N, float X[], float Y[])
+  blob x = blob_from_floats(X);
+  blob y = blob_from_floats(Y);
+  z = blas_ddot_blobs(N, x, y);
+(float z) blas_ddot_blobs(int n, blob x, blob y) "blas" "0.0.1" "ddot";
Added: SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/build.sh
--- SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/build.sh	                        (rev 0)
+++ SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/build.sh	2014-08-12 16:09:05 UTC (rev 8097)
@@ -0,0 +1,58 @@
+#!/bin/bash -eu
+# Build the blas leaf package
+LEAF_PKG=blas
+LEAF_SO="libtcl${LEAF_PKG}.so"
+LEAF_TCL="${LEAF_PKG}.tcl"
+CBLAS_HOME=/home/wozniak/downloads/ppc64/gcc-login/CBLAS
+# BLAS_O=$( ls ${BLAS_HOME}/*.o )
+# CBLAS_INCLUDE=${CBLAS_HOME}/include
+# CBLAS_O=$( ls ${CBLAS_HOME}/src/*.o )
+BLAS_A=$(  ls ${BLAS_HOME}/*.a )
+CBLAS_A=$( ls ${CBLAS_HOME}/lib/*.a )
+check()
+  CODE=${?}
+  if [[ ${CODE} != 0 ]]
+  then
+    MSG=$1
+    echo ${MSG}
+    exit ${CODE}
+  fi
+check "Could not find tclsh in PATH!"
+TCL_HOME=/home/wozniak/Public/sfw/ppc64-login/tcl-8.5.12
+TCL_CONFIG=${TCL_HOME}/lib/tclConfig.sh
+# TCLSH=
+# This loads many Tcl configuration variables
+source ${TCL_CONFIG}
+check "tclConfig.sh failed!"
+CFLAGS="-fPIC -std=gnu99 -g -I ${CBLAS_INCLUDE}"
+# Compile the Tcl extension
+gcc ${CFLAGS} ${TCL_INCLUDE_SPEC} -c ${LEAF_PKG}_wrap.c
+check
+# Build the Tcl extension as a shared library
+gcc -shared -o ${LEAF_SO} ${LEAF_PKG}_wrap.o ${CBLAS_A} ${BLAS_A}
+check
+echo "created library: ${LEAF_SO}"
+# Make the Tcl package index
+export LEAF_PKG LEAF_SO LEAF_TCL
+${TCLSH} make-package.tcl > pkgIndex.tcl
+check
+echo "created package."
+# Tell the user what they need to do to run this
+echo "Set in environment: TURBINE_USER_LIB=${PWD}"
+exit 0
Property changes on: SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/build.sh
___________________________________________________________________
Added: svn:executable
Added: SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/make-package.tcl
--- SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/make-package.tcl	                        (rev 0)
+++ SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/make-package.tcl	2014-08-12 16:09:05 UTC (rev 8097)
@@ -0,0 +1,8 @@
+set name     $env(LEAF_PKG)
+set version  0.0.1
+set leaf_so  $env(LEAF_SO)
+set leaf_tcl $env(LEAF_TCL)
+puts [ ::pkg::create -name $name -version $version \
+           -load $leaf_so -source $leaf_tcl ]
Added: SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/test-blas.sh
--- SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/test-blas.sh	                        (rev 0)
+++ SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/test-blas.sh	2014-08-12 16:09:05 UTC (rev 8097)
@@ -0,0 +1,33 @@
+#!/bin/bash
+export TURBINE_USER_LIB=${PWD}
+check()
+  if [[ ${?} != 0 ]]
+  then
+    MSG=$1
+    echo ${MSG}
+  fi
+STC=$( which stc )
+check
+echo "using stc: ${STC}"
+TURBINE=$( which turbine )
+check
+echo "using turbine: ${TURBINE}"
+STC_OUT=test-blas.tcl
+${STC} test-blas.swift ${STC_OUT}
+check
+echo "compiled to: ${STC_OUT}"
+export ADLB_EXHAUST_TIME=1
+${TURBINE} -l -n 3 ${STC_OUT}
+check
+exit 0
Property changes on: SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/test-blas.sh
Added: SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/test-blas.swift
--- SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/test-blas.swift	                        (rev 0)
+++ SwiftTutorials/ATPESC_2014-08-14/swift-t/examples/03-blas/test-blas.swift	2014-08-12 16:09:05 UTC (rev 8097)
@@ -0,0 +1,19 @@
+#include <builtins.swift>
+#include <io.swift>
+#include "blas.swift"
+main {
+  // Swift floats are 64-bit
+  float A[];
+  float B[];
+  int N = 3;
+  foreach i in [0:N-1]
+    A[i] = itof(i);
+    B[i] = itof(i+1);
+  float z = blas_ddot(N, A, B);
+  printf("A*B=%0.1f", z);
