[Swift-commit] r7805 - in demo/xsede.2014.0425: . part04m src/md
wilde at ci.uchicago.edu wilde at ci.uchicago.edu
Sat Apr 26 16:11:05 CDT 2014
Author: wilde
Date: 2014-04-26 16:11:04 -0500 (Sat, 26 Apr 2014)
New Revision: 7805
Added:
   demo/xsede.2014.0425/part04m/
   demo/xsede.2014.0425/part04m/p4.swift
   demo/xsede.2014.0425/part04m/swift.properties
Modified:
   demo/xsede.2014.0425/src/md/md.c
Log:
Added random state var to md command line. Added part04m to generate N simulations with one viz output per sim.
Added: demo/xsede.2014.0425/part04m/p4.swift
--- demo/xsede.2014.0425/part04m/p4.swift	                        (rev 0)
+++ demo/xsede.2014.0425/part04m/p4.swift	2014-04-26 21:11:04 UTC (rev 7805)
@@ -0,0 +1,43 @@
+type file;
+(int result) randomInt ()
+  float range = 9999999.0;
+  float rand = java("java.lang.Math","random");
+  string s[] = strsplit(toString(range*rand),"\\.");
+  result = toInt(s[0]);
+app (file o, file v) simulation (string npart, string steps, string mass)
+# mdviz  @o @v 3 npart steps 50 ".0001" mass "0.1 1.0 0.2 0.05 50.0 0.1" 2.5 2.0 randomInt();
+  mdviz  @o @v 3 npart steps 10 ".0001" mass "0.1 1.0 0.2 0.05 50.0 0.1" 2.5 2.0 randomInt();
+app (file o) analyze (file s[])
+  mdstats filenames(s) stdout=filename(o);
+app (file o) convert (file s[])
+  convert filenames(s) filename(o);
+int    nsim   = toInt(arg("nsim","10"));
+string npart  = arg("npart","50");
+string steps  = arg("steps","1000");
+string mass   = arg("mass",".005");
+file sims[] <simple_mapper; prefix="output/sim_", suffix=".out">;
+file gifs[] <simple_mapper; prefix="output/sim_", suffix=".gif">;
+foreach i in [0:nsim-1] {
+  (sims[i],gifs[i]) = simulation(npart,steps,mass);
+file stats_out<"output/average.out">;
+stats_out = analyze(sims);
+file viz_all<"output/all.gif">;
+viz_all = convert(gifs);
Added: demo/xsede.2014.0425/part04m/swift.properties
--- demo/xsede.2014.0425/part04m/swift.properties	                        (rev 0)
+++ demo/xsede.2014.0425/part04m/swift.properties	2014-04-26 21:11:04 UTC (rev 7805)
@@ -0,0 +1,2 @@
+site=midway-westmere
+site.midway-westmere.slurm.exclusive=false
Modified: demo/xsede.2014.0425/src/md/md.c
--- demo/xsede.2014.0425/src/md/md.c	2014-04-26 18:18:37 UTC (rev 7804)
+++ demo/xsede.2014.0425/src/md/md.c	2014-04-26 21:11:04 UTC (rev 7805)
@@ -166,6 +166,10 @@
     scale_offset = atof ( argv[9] );
+  if ( 10 < argc )
+    seed = atof ( argv[10] );
   Report.
@@ -181,6 +185,7 @@
   printf ( "  PRINTINFO, the pass-through info to c-ray, is %s\n", printinfo );
   printf ( "  SCALE_FACTOR, the particle position scaling factor, is %f\n", scale_factor );
   printf ( "  SCALE_OFFSET, the particle position scaling offset, is %f\n", scale_offset );
+  printf ( "  SEED, the simulation randomization seed, is %d\n", seed );
   Allocate memory.
