[Swift-commit] r7797 - in demo/xsede.2014.0425: . app bin doc doc/figs doc/images doc/images/icons part01 part02 part03 part04 part05 part06 src/c-ray
wilde at ci.uchicago.edu wilde at ci.uchicago.edu
Thu Apr 24 13:34:47 CDT 2014
Author: wilde
Date: 2014-04-24 13:34:47 -0500 (Thu, 24 Apr 2014)
New Revision: 7797
Added:
   demo/xsede.2014.0425/README
   demo/xsede.2014.0425/app/
   demo/xsede.2014.0425/app/simulate
   demo/xsede.2014.0425/app/stats
   demo/xsede.2014.0425/bin/
   demo/xsede.2014.0425/bin/cleanup
   demo/xsede.2014.0425/bin/hosts
   demo/xsede.2014.0425/bin/package_tutorial.sh
   demo/xsede.2014.0425/bin/plot.sh
   demo/xsede.2014.0425/doc/
   demo/xsede.2014.0425/doc/README
   demo/xsede.2014.0425/doc/TODO
   demo/xsede.2014.0425/doc/activeplot.png
   demo/xsede.2014.0425/doc/asciidoc.css
   demo/xsede.2014.0425/doc/build_docs.sh
   demo/xsede.2014.0425/doc/cumulativeplot.png
   demo/xsede.2014.0425/doc/figs/
   demo/xsede.2014.0425/doc/figs/modis.dia
   demo/xsede.2014.0425/doc/figs/modis.png
   demo/xsede.2014.0425/doc/images/
   demo/xsede.2014.0425/doc/images/icons/
   demo/xsede.2014.0425/doc/images/icons/caution.png
   demo/xsede.2014.0425/doc/images/icons/example.png
   demo/xsede.2014.0425/doc/images/icons/home.png
   demo/xsede.2014.0425/doc/images/icons/important.png
   demo/xsede.2014.0425/doc/images/icons/next.png
   demo/xsede.2014.0425/doc/images/icons/note.png
   demo/xsede.2014.0425/doc/images/icons/prev.png
   demo/xsede.2014.0425/doc/images/icons/tip.png
   demo/xsede.2014.0425/doc/images/icons/up.png
   demo/xsede.2014.0425/doc/images/icons/warning.png
   demo/xsede.2014.0425/doc/part01.png
   demo/xsede.2014.0425/doc/part02.png
   demo/xsede.2014.0425/doc/part03.png
   demo/xsede.2014.0425/doc/part04.png
   demo/xsede.2014.0425/doc/part05.png
   demo/xsede.2014.0425/doc/part06.png
   demo/xsede.2014.0425/doc/push.sh
   demo/xsede.2014.0425/part01/
   demo/xsede.2014.0425/part01/p1.swift
   demo/xsede.2014.0425/part01/swift.properties
   demo/xsede.2014.0425/part02/
   demo/xsede.2014.0425/part02/p2.swift
   demo/xsede.2014.0425/part02/swift.properties
   demo/xsede.2014.0425/part03/
   demo/xsede.2014.0425/part03/p3.swift
   demo/xsede.2014.0425/part03/swift.properties
   demo/xsede.2014.0425/part04/
   demo/xsede.2014.0425/part04/p4.swift
   demo/xsede.2014.0425/part04/swift.properties
   demo/xsede.2014.0425/part05/
   demo/xsede.2014.0425/part05/p5.swift
   demo/xsede.2014.0425/part05/swift.properties
   demo/xsede.2014.0425/part06/
   demo/xsede.2014.0425/part06/p6.swift
   demo/xsede.2014.0425/part06/swift.properties
   demo/xsede.2014.0425/setup.sh
   demo/xsede.2014.0425/src/c-ray/test.sh
   demo/xsede.2014.0425/tutorial.pptx
Removed:
   demo/xsede.2014.0425/src/c-ray/RUN
Log:
Copy midway tutorial as base demo code.
Added: demo/xsede.2014.0425/README
--- demo/xsede.2014.0425/README	                        (rev 0)
+++ demo/xsede.2014.0425/README	2014-04-24 18:34:47 UTC (rev 7797)
@@ -0,0 +1 @@
+link doc/README
\ No newline at end of file
Property changes on: demo/xsede.2014.0425/README
___________________________________________________________________
Added: svn:special
Added: demo/xsede.2014.0425/app/simulate
--- demo/xsede.2014.0425/app/simulate	                        (rev 0)
+++ demo/xsede.2014.0425/app/simulate	2014-04-24 18:34:47 UTC (rev 7797)
@@ -0,0 +1,135 @@
+#! /bin/bash
+printparams()
+  printf "\nSimulation parameters:\n\n"
+  echo bias=$bias
+  echo biasfile=$biasfile
+  echo initseed=$initseed
+  echo log=$log
+  echo paramfile=$paramfile
+  echo range=$range
+  echo scale=$scale
+  echo seedfile=$seedfile
+  echo timesteps=$timesteps
+  echo output width=$width
+log() {
+  printf "\nCalled as: $0: $cmdargs\n\n"
+  printf "Start time: "; /bin/date
+  printf "Running as user: "; /usr/bin/id
+  printf "Running on node: "; /bin/hostname
+  printf "Node IP address: "; /bin/hostname -I
+  printparams
+  printf "\nEnvironment:\n\n"
+  printenv | sort
+addsims() {
+  while read f1 ; do
+    read -u 3 f2
+    if [ _$f1 = _ ]; then f1=$lastf1; fi
+    if [ _$f2 = _ ]; then f2=$lastf2; fi
+    printf "%${width}d\n" $(($f1+$f2))
+    lastf1=$f1
+    lastf2=$f2
+  done <$1 3<$2
+# set defaults
+bias=0
+biasfile=none
+initseed=none
+log=yes
+paramfile=none
+range=100
+scale=1
+seedfile=none
+timesteps=0
+nvalues=1
+width=8
+cmdargs="$*"
+usage()
+  echo $( basename $0 ): usage:
+  cat <<END
+    -b|--bias       offset bias: add this integer to all results
+    -B|--biasfile   file of integer biases to add to results
+    -l|--log        generate a log in stderr if not null
+    -n|--nvalues    print this many values per simulation
+    -r|--range      range (limit) of generated results
+    -s|--seed       use this integer [0..32767] as a seed
+    -S|--seedfile   use this file (containing integer seeds [0..32767]) one per line
+    -t|--timesteps  number of simulated "timesteps" in seconds (determines runtime)
+    -x|--scale      scale the results by this integer
+    -h|-?|?|--help  print this help
+END
+# FIXME: NOT YET IMPLEMENTED:
+#    -p|--paramfile  take these parameters (in form param=value) from this file
+#    -p|--paramfile) paramfile=$2 ;;
+while [ $# -gt 0 ]; do
+  case $1 in
+    -b|--bias)      bias=$2      ;;
+    -B|--biasfile)  biasfile=$2  ;;
+    -l|--log)       log=$2       ;;
+    -n|--nvalues)   nvalues=$2   ;;
+    -s|--seed)      initseed=$2  ;;
+    -S|--seedfile)  seedfile=$2  ;;
+    -t|--timesteps) timesteps=$2 ;;
+    -r|--range)     range=$2     ;;
+    -w|--width)     width=$2     ;;
+    -x|--scale)     scale=$2     ;;
+    -h|-?|--help|*) usage; exit  ;;
+  esac
+  shift 2
+done
+# process initial seed
+if [ $initseed != none ]; then
+  RANDOM=$initseed
+fi
+# process file of seeds
+if [ $seedfile != none ]; then
+  seed=0
+  while read $seedfile s; do
+    seed=$(($seed+$s))
+  done <$seedfile
+  RANDOM=$seed
+fi
+# run for some number of "timesteps"
+sleep $timesteps
+# emit N (nvalues) "simulation results" scaled and biased by argument values
+simout=$(mktemp simout.XXXX)
+for ((i=0;i<nvalues;i++)); do
+  # value=$(( (($RANDOM)*(2**16))+$RANDOM ))
+  value=$(( (($RANDOM)*(2**48)) + (($RANDOM)*(2**32)) + (($RANDOM)*(2**16)) + $RANDOM ))
+  printf "%${width}d\n" $(( ($value%range)*scale+bias))
+done  >$simout
+# process file of biases
+if [ $biasfile != none ]; then
+  addsims $simout $biasfile
+else
+  cat $simout
+fi
+rm $simout
+# log environmental data
+if [ $log != off ]; then
+  log 1>&2
+fi
Property changes on: demo/xsede.2014.0425/app/simulate
Added: svn:executable
Added: demo/xsede.2014.0425/app/stats
--- demo/xsede.2014.0425/app/stats	                        (rev 0)
+++ demo/xsede.2014.0425/app/stats	2014-04-24 18:34:47 UTC (rev 7797)
@@ -0,0 +1,19 @@
+#! /bin/sh
+log() {
+  printenv | sort
+awk '
+{ sum += $1}
+END { printf("%d\n",sum/NR) }
+log 1>&2
Property changes on: demo/xsede.2014.0425/app/stats
Added: demo/xsede.2014.0425/bin/cleanup
--- demo/xsede.2014.0425/bin/cleanup	                        (rev 0)
+++ demo/xsede.2014.0425/bin/cleanup	2014-04-24 18:34:47 UTC (rev 7797)
@@ -0,0 +1,2 @@
+rm -rf *.rlog *.kml *.swiftx *.out output outdir logs hi.* _concurrent .swift/tmp run0*
Property changes on: demo/xsede.2014.0425/bin/cleanup
Added: demo/xsede.2014.0425/bin/hosts
--- demo/xsede.2014.0425/bin/hosts	                        (rev 0)
+++ demo/xsede.2014.0425/bin/hosts	2014-04-24 18:34:47 UTC (rev 7797)
@@ -0,0 +1 @@
+for h in $(cat hosts.txt); do ssh $h hostname -f; done
Property changes on: demo/xsede.2014.0425/bin/hosts
Added: demo/xsede.2014.0425/bin/package_tutorial.sh
--- demo/xsede.2014.0425/bin/package_tutorial.sh	                        (rev 0)
+++ demo/xsede.2014.0425/bin/package_tutorial.sh	2014-04-24 18:34:47 UTC (rev 7797)
@@ -0,0 +1,15 @@
+#! /bin/sh
+BIN=$(cd $(dirname $0); pwd)
+BASE=$(cd $BIN/..; pwd)
+LOC=$(cd $BASE/..; pwd)
+echo executing $0 from BIN=$BIN
+echo making tutorial package of BASE=$BASE
+echo placing tutorial package in LOC=$LOC
+  cd $LOC
+  tar zcf swift-cray-tutorial.tgz  --exclude-vcs swift-cray-tutorial
+  scp swift-cray-tutorial.tgz p01532 at raven.cray.com:
Property changes on: demo/xsede.2014.0425/bin/package_tutorial.sh
Added: demo/xsede.2014.0425/bin/plot.sh
--- demo/xsede.2014.0425/bin/plot.sh	                        (rev 0)
+++ demo/xsede.2014.0425/bin/plot.sh	2014-04-24 18:34:47 UTC (rev 7797)
@@ -0,0 +1,68 @@
+#!/bin/bash
+#usage: ./plotswiftlogs.ketan <swift-logfile.log>
+SWIFTLOGFILE=$1
+#TMPDIR=`mktemp -d plotlog.XXX`
+grep -i ProgressTicker $SWIFTLOGFILE > swiftoutfile.out
+SWIFTOUTFILE=swiftoutfile.out
+#extract start time
+TMPDATE=`grep -i progress $SWIFTOUTFILE 2>/dev/null | head -n 1 | cut -f1-2 -d ' '`
+START_TIME=`date +%s -d "$TMPDATE"`
+#extract end time
+TMPDATE=`grep -i progress $SWIFTOUTFILE 2>/dev/null | tail -n 1 | cut -f1-2 -d ' '`
+END_TIME=`date +%s -d "$TMPDATE"`
+#duration
+DIFFTIME=$((END_TIME - START_TIME))
+#extract active runs in a file
+(grep -o -i "Active:[0-9]*" $SWIFTOUTFILE 2>/dev/null | awk -F: '{print $2}' >active.txt)
+#extract successful completions in a file
+(grep -o -i "Successfully:[0-9]*" $SWIFTOUTFILE 2>/dev/null | awk -F: '{print $2}' > cumulative.txt)
+#prepare tics
+activelines=`wc -l active.txt | awk '{print $1}'`
+cumulines=`wc -l cumulative.txt | awk '{print $1}'`
+if [ $activelines -ne 0 ]
+then
+  activelinespertic=`echo "scale=5 ; $DIFFTIME / $activelines" | bc`
+fi
+seq 0 $activelinespertic $DIFFTIME > activetics.txt
+if [ $cumulines -ne 0 ]
+then
+    cumulinespertic=`echo "scale=5 ; $DIFFTIME / $cumulines" | bc`
+fi
+seq 0 $cumulinespertic $DIFFTIME > cumultics.txt
+#final plot data
+paste activetics.txt active.txt > plot_active.txt
+paste cumultics.txt cumulative.txt > plot_cumulative.txt
+cat << EOF1 > plotit.gp
+set terminal png enhanced
+set nokey
+set output "cumulativeplot.png"
+set xlabel "Time in sec"
+set ylabel "number of completed apps"
+set title "Cumulative Apps Completed"
+plot "plot_cumulative.txt" using 1:2 with lines
+set output "activeplot.png"
+set ylabel "number of active apps"
+set title "Active Apps"
+plot "plot_active.txt" using 1:2 with line
+EOF1
+gnuplot plotit.gp 2>/dev/null
+rm swiftoutfile.out plotit.gp active.txt cumulative.txt activetics.txt plot_active.txt plot_cumulative.txt cumultics.txt
Property changes on: demo/xsede.2014.0425/bin/plot.sh
Added: demo/xsede.2014.0425/doc/README
--- demo/xsede.2014.0425/doc/README	                        (rev 0)
+++ demo/xsede.2014.0425/doc/README	2014-04-24 18:34:47 UTC (rev 7797)
@@ -0,0 +1,717 @@
+Swift Tutorial for RCC Midway Cluster
+This is the asciidoc input file.
+Its content is viewable as a plain-text README file.
+This tutorial is viewable at:
+http://swiftlang.org/tutorials/midway/tutorial.html
+Tutorial Outline:
+Introductory example, running apps locally on login node:
+  p1 - Run an application under Swift
+  p2 - Parallel loops with foreach
+  p3 - Merging/reducing the results of a parallel foreach loop
+Compute-node exercises, running apps via qsub and aprun:
+  p4 - Running apps on RCC Midway cluster
+  p5 - Running on multiple pools of compute nodes
+  p6 - Running a more complex workflow pattern
+Introduction: Why Parallel Scripting?
+Swift is a simple scripting language for executing many instances of
+ordinary application programs on distributed parallel resources.
+Swift scripts run many copies of ordinary programs concurrently, using
+statements like this:
+foreach protein in proteinList {
+  runBLAST(protein);
+Swift acts like a structured "shell" language. It runs programs
+concurrently as soon as their inputs are available, reducing the need
+for complex parallel programming.  Swift expresses your workflow in a
+portable fashion: The same script runs on multicore computers,
+clusters, clouds, grids, and supercomputers.
+In this tutorial, you'll be able to first try a few Swift examples
+(parts 1-3) on a Midway login host, to get a sense of the
+language. Then in parts 4-6 you'll run similar workflows on Midway
+compute nodes, and see how more complex workflows can be expressed
+with Swift scripts.
+Swift tutorial setup
+If you are using a temporary/guest account to access Midway, follow
+the instructions at http://docs.rcc.uchicago.edu/tutorials/intro-to-rcc-workshop.html
+for more information on using a yubikey to log in.
+Once you are logged into the Midway login host, run the following commands
+to set up your environment.
+$ cd $HOME
+$ wget http://swiftlang.org/tutorials/midway/swift-midway-tutorial.tar.gz
+$ tar xvfz swift-midway-tutorial.tar.gz
+$ cd swift-midway-tutorial
+$ source setup.sh
+Verify your environment
+To verify that Swift loaded, do:
+$ swift -version  # verify that you have Swift 0.95 RC1
+NOTE: If you re-login or open new ssh sessions, you must re-run `source setup.sh` in each ssh shell/window.
+To check out the tutorial scripts from SVN
+If you later want to get the most recent version of this tutorial from
+the Swift Subversion repository, do:
+$ svn co https://svn.ci.uchicago.edu/svn/vdl2/SwiftTutorials/swift-midway-tutorial
+This will create a directory called "swift-midway-tutorial" which contains all of the
+files used in this tutorial.
+Simple "science applications" for the workflow tutorial
+This tutorial is based on two intentionally trivial example programs,
+`simulation` and `stats`, (implemented as bash shell scripts)
+that serve as easy-to-understand proxies for real science
+applications. These "programs" behave as follows.
+simulate.sh
+The simulation script serves as a trivial proxy for any more
+complex scientific simulation application. It generates and prints a
+set of one or more random integers in the range [0-2^62) as controlled
+by its command line arguments, which are:
+$ simulate -help
+simulate: usage:
+All of these arguments are optional, with default values indicated above as `[n]`.
+.simulation arguments
+[width="80%",cols="^2,10",options="header"]
+|Argument|Short|Description
+|1    |runtime: sets run time of simulation in seconds
+|2    |range: limits generated values to the range [0,range-1]
+|3    |biasfile: add the integer contained in this file to each value generated
+|4    |scale: multiplies each generated value by this integer
+|5    |count: number of values to generate in the simulation
+With no arguments, simulate prints 1 number in the range of
+1-100. Otherwise it generates n numbers of the form (R*scale)+bias
+where R is a random integer. By default it logs information about its
+execution environment to stderr.  Here's some examples of its usage:
+$ simulate 2>log
+      51
+$ head -5 log
+Called as: /home/davidkelly999/swift-midway-tutorial/app/simulate:
+Start time: Mon Dec  2 13:47:41 CST 2013
+Running as user: uid=88848(davidkelly999) gid=88848(davidkelly999) groups=88848(davidkelly999),10008(rcc),10030(pi-gavoth),10031(sp-swift),10036(swift),10058(pi-joshuaelliott),10084(pi-wilde),10118(cron-account),10124(cmts),10138(cmtsworkshop)
+$ simulate -n 4 -r 1000000 2>log
+  239454
+  386702
+   13849
+  873526
+$ simulate -n 3 -r 1000000 -x 100 2>log
+ 6643700
+62182300
+ 5230600
+$ simulate -n 2 -r 1000 -x 1000 2>log
+  565000
+  636000
+$ time simulate -n 2 -r 1000 -x 1000 -t 3 2>log
+  336000
+  320000
+real    0m3.012s
+user    0m0.005s
+sys     0m0.006s
+stats
+The stats script serves as a trivial model of an "analysis"
+program. It reads N files each containing M integers and simply prints
+the average of all those numbers to stdout. Similarly to simulate
+it logs environmental information to the stderr.
+$ ls f*
+f1  f2  f3  f4
+$ cat f*
+25
+60
+40
+75
+$ stats f* 2>log
+50
+Basic of the Swift language with local execution
+A Summary of Swift in a nutshell
+* Swift scripts are text files ending in `.swift` The `swift` command
+runs on any host, and executes these scripts. `swift` is a Java
+application, which you can install almost anywhere.  On Linux, just
+unpack the distribution `tar` file and add its `bin/` directory to
+your `PATH`.
+* Swift scripts run ordinary applications, just like shell scripts
+do. Swift makes it easy to run these applications on parallel and
+remote computers (from laptops to supercomputers). If you can `ssh` to
+the system, Swift can likely run applications there.
+* The details of where to run applications and how to get files back
+and forth are described in configuration files separate from your
+program. Swift speaks ssh, PBS, Condor, SLURM, LSF, SGE, Cobalt, and
+Globus to run applications, and scp, http, ftp, and GridFTP to move
+data.
+* The Swift language has 5 main data types: `boolean`, `int`,
+`string`, `float`, and `file`. Collections of these are dynamic,
+sparse arrays of arbitrary dimension and structures of scalars and/or
+arrays defined by the `type` declaration.
+* Swift file variables are "mapped" to external files. Swift sends
+files to and from remote systems for you automatically.
+* Swift variables are "single assignment": once you set them you can't
+change them (in a given block of code).  This makes Swift a natural,
+"parallel data flow" language. This programming model keeps your
+workflow scripts simple and easy to write and understand.
+* Swift lets you define functions to "wrap" application programs, and
+to cleanly structure more complex scripts. Swift `app` functions take
+files and parameters as inputs and return files as outputs.
+* A compact set of built-in functions for string and file
+manipulation, type conversions, high level IO, etc. is provided.
+Swift's equivalent of `printf()` is `tracef()`, with limited and
+slightly different format codes.
+* Swift's `foreach {}` statement is the main parallel workhorse of the
+language, and executes all iterations of the loop concurrently. The
+actual number of parallel tasks executed is based on available
+resources and settable "throttles".
+* In fact, Swift conceptually executes *all* the statements,
+expressions and function calls in your program in parallel, based on
+data flow. These are similarly throttled based on available resources
+and settings.
+* Swift also has `if` and `switch` statements for conditional
+execution. These are seldom needed in simple workflows but they enable
+very dynamic workflow patterns to be specified.
+We'll see many of these points in action in the examples below. Lets
+get started!
+Part 1: Run a single application under Swift
+The first swift script, p1.swift, runs simulate to generate a
+single random number. It writes the number to a file.
+image::part01.png["p1 workflow",align="center"]
+.p1.swift
+sys::[cat ../part01/p1.swift]
+To run this script, run the following command:
+$ cd part01
+$ swift p1.swift
+Swift 0.94.1 RC2 swift-r6895 cog-r3765
+RunID: 20130827-1413-oa6fdib2
+Progress:  time: Tue, 27 Aug 2013 14:13:33 -0500
+Final status: Tue, 27 Aug 2013 14:13:33 -0500  Finished successfully:1
+$ cat sim.out
+      84
+$ swift p1.swift
+$ cat sim.out
+      36
+To cleanup the directory and remove all outputs (including the log
+files and directories that Swift generates), run the cleanup script
+which is located in the tutorial PATH:
+$ cleanup
+NOTE: You'll also find a Swift configuration file in each `partNN`
+directory of this tutorial. This file specifies the environment-specific
+details of how to run. These files will be explained in more
+detail in parts 4-6, and can be ignored for now.
+Part 2: Running an ensemble of many apps in parallel with a "foreach" loop
+The `p2.swift` script introduces the `foreach` parallel iteration
+construct to run many concurrent simulations.
+image::part02.png[align="center"]
+.p2.swift
+sys::[cat ../part02/p2.swift]
+The script also shows an
+example of naming the output files of an ensemble run. In this case, the output files will be named
+`output/sim_N.out`.
+To run the script and view the output:
+$ cd ../part02
+$ swift p2.swift
+$ ls output
+sim_0.out  sim_1.out  sim_2.out  sim_3.out  sim_4.out  sim_5.out  sim_6.out  sim_7.out  sim_8.out  sim_9.out
+$ more output/*
+output/sim_0.out
+      44
+output/sim_1.out
+      55
+output/sim_9.out
+      82
+Part 3: Analyzing results of a parallel ensemble
+After all the parallel simulations in an ensemble run have completed,
+its typically necessary to gather and analyze their results with some
+kind of post-processing analysis program or script.  p3.swift
+introduces such a postprocessing step. In this case, the files created
+by all of the parallel runs of `simulation` will be averaged by by
+the trivial "analysis application" `stats`:
+image::part03.png[align="center"]
+.p3.swift
+sys::[cat ../part03/p3.swift]
+To run:
+$ cd part03
+$ swift p3.swift
+Note that in `p3.swift` we expose more of the capabilities of the
+`simulate` application to the `simulation()` app function:
+app (file o) simulation (int sim_steps, int sim_range, int sim_values)
+  simulate "--timesteps" sim_steps "--range" sim_range "--nvalues" sim_values stdout=@filename(o);
+`p3.swift` also shows how to fetch application-specific values from
+the `swift` command line in a Swift script using `arg()` which
+accepts a keyword-style argument and its default value:
+int nsim   = toInt(arg("nsim","10"));
+int steps  = toInt(arg("steps","1"));
+int range  = toInt(arg("range","100"));
+int values = toInt(arg("values","5"));
+Now we can specify that more runs should be performed and that each should run
+for more timesteps, and produce more that one value each, within a specified range,
+using command line arguments placed after the Swift script name in the form `-parameterName=value`:
+$ swift p3.swift -nsim=3 -steps=10 -values=4 -range=1000000
+RunID: 20130827-1439-s3vvo809
+Progress:  time: Tue, 27 Aug 2013 14:39:42 -0500
+Progress:  time: Tue, 27 Aug 2013 14:39:53 -0500  Active:2  Stage out:1
+Final status: Tue, 27 Aug 2013 14:39:53 -0500  Finished successfully:4
+$ ls output/
+average.out  sim_0.out  sim_1.out  sim_2.out
+$ more output/*
+output/average.out
+651368
+output/sim_0.out
+  735700
+  886206
+  997391
+  982970
+output/sim_1.out
+  260071
+  264195
+  869198
+  933537
+output/sim_2.out
+  201806
+  213540
+  527576
+  944233
+Now try running (`-nsim=`) 100 simulations of (`-steps=`) 1 second each:
+$ swift p3.swift -nsim=100 -steps=1
+RunID: 20130827-1444-rq809ts6
+Progress:  time: Tue, 27 Aug 2013 14:44:55 -0500
+Progress:  time: Tue, 27 Aug 2013 14:44:56 -0500  Selecting site:79  Active:20  Stage out:1
+Progress:  time: Tue, 27 Aug 2013 14:44:58 -0500  Selecting site:58  Active:20  Stage out:1  Finished successfully:21
+Progress:  time: Tue, 27 Aug 2013 14:44:59 -0500  Selecting site:37  Active:20  Stage out:1  Finished successfully:42
+Progress:  time: Tue, 27 Aug 2013 14:45:00 -0500  Selecting site:16  Active:20  Stage out:1  Finished successfully:63
+Progress:  time: Tue, 27 Aug 2013 14:45:02 -0500  Active:15  Stage out:1  Finished successfully:84
+Progress:  time: Tue, 27 Aug 2013 14:45:03 -0500  Finished successfully:101
+Final status: Tue, 27 Aug 2013 14:45:03 -0500  Finished successfully:101
+We can see from Swift's "progress" status that the tutorial's default
+parameters for local execution allow Swift to run up to 20
+application invocations concurrently on the login node. We'll look at
+this in more detail in the next sections where we execute applications
+on the site's compute nodes.
+Running applications on Midway compute nodes with Swift
+Part 4: Running a parallel ensemble on Midway compute nodes
+`p4.swift` will run our mock "simulation" applications on Midway
+compute nodes. The script is similar to as `p3.swift`, but specifies
+that each simulation app invocation should additionally return the
+log file which the application writes to `stderr`.
+Now when you run `swift p4.swift` you'll see that two types output
+files will placed in the `output/` directory: `sim_N.out` and
+`sim_N.log`.  The log files provide data on the runtime environment of
+each app invocation. For example:
+$ cat output/sim_0.log
+Called as: /home/davidkelly999/swift-midway-tutorial/app/simulate: --timesteps 1 --range 100 --nvalues 5
+Start time: Mon Dec  2 12:17:06 CST 2013
+Running on node: midway002
+Node IP address: 10.50.181.2 172.25.181.2
+Simulation parameters:
+bias=0
+biasfile=none
+initseed=none
+log=yes
+paramfile=none
+range=100
+scale=1
+seedfile=none
+timesteps=1
+output width=8
+Environment:
+ANTLR_ROOT=/software/antlr-2.7-el6-x86_64
+ANT_HOME=/software/ant-1.8.4-all
+ANT_HOME_modshare=/software/ant-1.8.4-all:3
+Swift's `swift.properties` configuration file allows many parameters to
+specify how jobs should be run on a given cluster.
+Consider for example that Midway has several Slurm partitions. The sandyb
+partition has 16 cores, and the westmere partition has 12 cores. Depending
+on the application and which partitions are busy, you may want to modify
+where you run.
+Here is an example of the swift.properties in the part04 directory:
+site=westmere
+site.westmere.slurm.reservation=workshop
+site.westmere.slurm.exclusive=false
+The first line, site=westmere, allows you to define which partition to run on. Swift includes
+templates for each partition that provides some reasonable default values. Other valid partitions
+are amd, bigmem, gpu, local, and sandyb.
+The second and third line override some of the default values, by specifying a reservation that will
+be used for this session, and enabling node sharing.
+Try changing the queue to run on the sandyb queue. The new swift.properties should look like this:
+site=sandyb
+site.sandyb.slurm.reservation=workshop
+site.sandyb.slurm.exclusive=false
+Performing larger Swift runs
+To test with larger runs, there are two changes that are required. The first is a
+change to the command line arguments. The example below will run 1000 simulations
+with each simulation taking 5 seconds.
+$ swift p6.swift -steps=5 -nsim=1000
+Plotting run activity
+The tutorial `bin` directory in your `PATH` provides a script
+`plot.sh` to plot the progress of a Swift script.  It generates two
+image files: `activeplot.png`, which shows the number of active jobs
+over time, and `cumulativeplot.png`, which shows the total number of
+app calls completed as the Swift script progresses.
+After each Swift run, a new run directory is created called runNNN.
+Each run directory will have a log file with a similar name called
+runNNN.log. Once you have identified the log file name, run the
+command `plot.sh` <logfile>` to generate the plots for that
+specific run. For example:
+$ ls
+output  p3.swift  run000  swift.properties
+$ cd run000/
+$ ls
+apps  cf  p3-20131202-2004-0kh4ha6e.d  run000.log  sites.xml
+$ plot.sh run000.log
+This yields plots like:
+image::activeplot.png[width=700,align=center]
+image::cumulativeplot.png[width=700,align=center]
+Part 5: Controlling the compute-node pools where applications run
+This section is under development.
+Part 6: Specifying more complex workflow patterns
+p6.swift expands the workflow pattern of p4.swift to add additional
+stages to the workflow. Here, we generate a dynamic seed value that
+will be used by all of the simulations, and for each simulation, we
+run an pre-processing application to generate a unique "bias
+file". This pattern is shown below, followed by the Swift script.
+image::part06.png[align="center"]
+.p6.swift
+sys::[cat ../part06/p6.swift]
+Note that the workflow is based on data flow dependencies: each simulation depends on the seed value, calculated in this statement:
+seedfile = genseed(1);
+and on the bias file, computed and then consumed in these two dependent statements:
+  biasfile = genbias(1000, 20);
+  (simout,simlog) = simulation(steps, range, biasfile, 1000000, values, seedfile);
+To run:
+$ cd ../part06
+$ swift p6.swift
+The default parameters result in the following execution log:
+$ swift p6.swift
+RunID: 20130827-1917-jvs4gqm5
+Progress:  time: Tue, 27 Aug 2013 19:17:56 -0500
+*** Script parameters: nsim=10 range=100 num values=10
+Progress:  time: Tue, 27 Aug 2013 19:17:57 -0500  Stage in:1  Submitted:10
+Generated seed=382537
+Progress:  time: Tue, 27 Aug 2013 19:17:59 -0500  Active:9  Stage out:1  Finished successfully:11
+Final status: Tue, 27 Aug 2013 19:18:00 -0500  Finished successfully:22
+which produces the following output:
+$ ls -lrt output
+total 264
+-rw-r--r-- 1 p01532 61532     9 Aug 27 19:17 seed.dat
+-rw-r--r-- 1 p01532 61532   180 Aug 27 19:17 bias_9.dat
+-rw-r--r-- 1 p01532 61532   180 Aug 27 19:17 bias_8.dat
+-rw-r--r-- 1 p01532 61532   180 Aug 27 19:17 bias_7.dat
+-rw-r--r-- 1 p01532 61532   180 Aug 27 19:17 bias_6.dat
+-rw-r--r-- 1 p01532 61532   180 Aug 27 19:17 bias_5.dat
+-rw-r--r-- 1 p01532 61532   180 Aug 27 19:17 bias_4.dat
+-rw-r--r-- 1 p01532 61532   180 Aug 27 19:17 bias_3.dat
+-rw-r--r-- 1 p01532 61532   180 Aug 27 19:17 bias_2.dat
+-rw-r--r-- 1 p01532 61532   180 Aug 27 19:17 bias_1.dat
+-rw-r--r-- 1 p01532 61532   180 Aug 27 19:17 bias_0.dat
+-rw-r--r-- 1 p01532 61532    90 Aug 27 19:17 sim_9.out
+-rw-r--r-- 1 p01532 61532 14897 Aug 27 19:17 sim_9.log
+-rw-r--r-- 1 p01532 61532 14897 Aug 27 19:17 sim_8.log
+-rw-r--r-- 1 p01532 61532    90 Aug 27 19:17 sim_7.out
+-rw-r--r-- 1 p01532 61532    90 Aug 27 19:17 sim_6.out
+-rw-r--r-- 1 p01532 61532 14897 Aug 27 19:17 sim_6.log
+-rw-r--r-- 1 p01532 61532    90 Aug 27 19:17 sim_5.out
+-rw-r--r-- 1 p01532 61532 14897 Aug 27 19:17 sim_5.log
+-rw-r--r-- 1 p01532 61532    90 Aug 27 19:17 sim_4.out
+-rw-r--r-- 1 p01532 61532 14897 Aug 27 19:17 sim_4.log
+-rw-r--r-- 1 p01532 61532 14897 Aug 27 19:17 sim_1.log
+-rw-r--r-- 1 p01532 61532    90 Aug 27 19:18 sim_8.out
+-rw-r--r-- 1 p01532 61532 14897 Aug 27 19:18 sim_7.log
+-rw-r--r-- 1 p01532 61532    90 Aug 27 19:18 sim_3.out
+-rw-r--r-- 1 p01532 61532 14897 Aug 27 19:18 sim_3.log
+-rw-r--r-- 1 p01532 61532    90 Aug 27 19:18 sim_2.out
+-rw-r--r-- 1 p01532 61532 14898 Aug 27 19:18 sim_2.log
+-rw-r--r-- 1 p01532 61532    90 Aug 27 19:18 sim_1.out
+-rw-r--r-- 1 p01532 61532    90 Aug 27 19:18 sim_0.out
+-rw-r--r-- 1 p01532 61532 14897 Aug 27 19:18 sim_0.log
+-rw-r--r-- 1 p01532 61532     9 Aug 27 19:18 average.out
+-rw-r--r-- 1 p01532 61532 14675 Aug 27 19:18 average.log
+Each sim_N.out file is the sum of its bias file plus newly "simulated" random output scaled by 1,000,000:
+$ cat output/bias_0.dat
+     302
+     489
+      81
+     582
+     664
+     290
+     839
+     258
+     506
+     310
+     293
+     508
+      88
+     261
+     453
+     187
+      26
+     198
+     402
+     555
+$ cat output/sim_0.out
+64000302
+38000489
+32000081
+12000582
+46000664
+36000290
+35000839
+22000258
+49000506
+75000310
+We produce 20 values in each bias file. Simulations of less than that
+number of values ignore the unneeded number, while simualtions of more
+than 20 will use the last bias number for all remoaining values past
+20.  As an exercise, adjust the code to produce the same number of
+bias values as is needed for each simulation.  As a further exercise,
+modify the script to generate a unique seed value for each simulation,
+which is a common practice in ensemble computations.
Added: demo/xsede.2014.0425/doc/TODO
--- demo/xsede.2014.0425/doc/TODO	                        (rev 0)
+++ demo/xsede.2014.0425/doc/TODO	2014-04-24 18:34:47 UTC (rev 7797)
@@ -0,0 +1,137 @@
+PLAN
+basics
+cloud
+uc3
+multisystems
+(modis)
+get hosts.txt for cloud dynamically
+Show variety of UC3 activity and what ran where
+get hostname and app_resources into provider staging (hostname into all _swiftwrap)
+Show gridftp and go connect to process the modis dataset
+Show SwiftR for R users, SwiftPy for Enthought PY?
+fetching apps vs sending apps vs parrot/cvmfs/oasis etc ????
+Demo script-aps, bin apps, building apps, caching apps. etc.
+Do a Swift BLAST workflow  -- with viz !!!  (spice it up with help from Dina)
+OSG page from Mats: "Is your job HTC-ready"
+Use new Trunk config in tutorial?
+Add viz and status display; add node probing to tutorial.
+Debug failure with pinfiles
+What "exercises to suggest?"
+- run stats app locally
+- installed vs transferred apps
+- transferred programs vs transferred scripts
+- summarize things about the env from the .log files, ala stats.
+Y-style dag: 2 sims and average
+Show how to find temp files at runtime...
+Show how to find hung processes at runtime...  (or get other trace data...)
+make your owb versions of the programs; verify that you can substitute them
+Add a layer to isolate shell version v installed version
+Show how to handle a paramfile
+Test if OSGCOnnect works and account string (PorjectName) works OK for both!
+SHow how to handle long lists of files (eg writeData and other swift.properties)
+Expand arith to arb prec using bc
+ISSUES
+error in pin files? debug and turn back on
+PATH issues for various providers
+bin dir?
+setup.csh and .csh testing
+IMPROVEMENTS
+1. Cleanup.sh mentioned in the tutorial
+[fixed]
+2. cd ../part02
+[fixed]
+3. support for zsh, csh
+[pending]
+4. What results are created and where did the outputs go ?
+and pointers to what the log files mean
+[pending]
+5. Part4,
+- cd ../part04 is missing. Cleanup the README
+[fixed]
+6. Part5
+- cd ../part05 is missing. Cleanup
+[fixed]
+7. Part7
+-Change from running on Tukey analysis cluster compute nodes
+[fixed]
+8. Part6
+command line args for nsim and steps, tell user the different behavior
+that can be expected with different arg options
+[pending]
+9. Draw workflow for the modis demos
+[pending]
+10. Link to more technical swift-lang references
+[pending]
+11. Links to detailed language constructs, when explaining
+apps, link to the section on apps in the userguide.
+[pending]
+From Yadu:
+I've committed all the changes that I made on Friday and you can get them
+from -> https://svn.ci.uchicago.edu/svn/vdl2/SwiftTutorials/CIC_2013-08-09
+I'm trying to make this tutorial easily work on several sites so that, we
+do not have to tweak things for every single tutorial. Once this is done,
+I can also add it to the test-battery as well. I think this has value
+considering that we spend atleast 1-2 days for every demo.
+Now, the major pending item is the Modis demo, specifically the issue of
+bringing data to any site and scripts. Slight tweaks to allow for sending
+the scripts as args to apps would also be needed.
+So the major changes are:
+1. Source the setup.sh script with the target site name
+eg. source setups.sh <cloud|uc3|midway|beagle>
+2. No separate cloud folder
+3. [pending] fix modis data and scripts
+4. [pending] support for zsh and other shells?
Added: demo/xsede.2014.0425/doc/activeplot.png
(Binary files differ)
Property changes on: demo/xsede.2014.0425/doc/activeplot.png
Added: svn:mime-type
   + application/octet-stream
Added: demo/xsede.2014.0425/doc/asciidoc.css
--- demo/xsede.2014.0425/doc/asciidoc.css	                        (rev 0)
+++ demo/xsede.2014.0425/doc/asciidoc.css	2014-04-24 18:34:47 UTC (rev 7797)
@@ -0,0 +1,26 @@
+a:link { color:navy; }
+a:visited { color:navy; }
+.monospaced, code, pre {
+  font-family: "Courier New", Courier, monospace;
+  font-size: medium; /* inherit; */
+  color: black;
+  padding: 0;
+  margin: 0;
+  background: #f8f8f8;
+  border: 1px solid #dddddd;
+  border-left: 5px solid #f0f0f0;
+  margin-right: 10%;
+div.listingblock > div.content {
+  padding: 0.5em;
+  background: none;
+  border: none;
+  border-left: none;
+  margin-right: none;
Added: demo/xsede.2014.0425/doc/build_docs.sh
--- demo/xsede.2014.0425/doc/build_docs.sh	                        (rev 0)
+++ demo/xsede.2014.0425/doc/build_docs.sh	2014-04-24 18:34:47 UTC (rev 7797)
@@ -0,0 +1,3 @@
+#!/bin/bash -e
+asciidoc -a icons -a toc -a toplevels=2 -a stylesheet=$PWD/asciidoc.css -a max-width=800px -o tutorial.html README
Property changes on: demo/xsede.2014.0425/doc/build_docs.sh
Added: demo/xsede.2014.0425/doc/cumulativeplot.png
Property changes on: demo/xsede.2014.0425/doc/cumulativeplot.png
Added: demo/xsede.2014.0425/doc/figs/modis.dia
Property changes on: demo/xsede.2014.0425/doc/figs/modis.dia
Added: demo/xsede.2014.0425/doc/figs/modis.png
Property changes on: demo/xsede.2014.0425/doc/figs/modis.png
Added: demo/xsede.2014.0425/doc/images/icons/caution.png
Property changes on: demo/xsede.2014.0425/doc/images/icons/caution.png
Added: demo/xsede.2014.0425/doc/images/icons/example.png
Property changes on: demo/xsede.2014.0425/doc/images/icons/example.png
Added: demo/xsede.2014.0425/doc/images/icons/home.png
Property changes on: demo/xsede.2014.0425/doc/images/icons/home.png
Added: demo/xsede.2014.0425/doc/images/icons/important.png
Property changes on: demo/xsede.2014.0425/doc/images/icons/important.png
Added: demo/xsede.2014.0425/doc/images/icons/next.png
Property changes on: demo/xsede.2014.0425/doc/images/icons/next.png
Added: demo/xsede.2014.0425/doc/images/icons/note.png
Property changes on: demo/xsede.2014.0425/doc/images/icons/note.png
Added: demo/xsede.2014.0425/doc/images/icons/prev.png
Property changes on: demo/xsede.2014.0425/doc/images/icons/prev.png
Added: demo/xsede.2014.0425/doc/images/icons/tip.png
Property changes on: demo/xsede.2014.0425/doc/images/icons/tip.png
Added: demo/xsede.2014.0425/doc/images/icons/up.png
Property changes on: demo/xsede.2014.0425/doc/images/icons/up.png
Added: demo/xsede.2014.0425/doc/images/icons/warning.png
Property changes on: demo/xsede.2014.0425/doc/images/icons/warning.png
Added: demo/xsede.2014.0425/doc/part01.png
Property changes on: demo/xsede.2014.0425/doc/part01.png
Added: demo/xsede.2014.0425/doc/part02.png
Property changes on: demo/xsede.2014.0425/doc/part02.png
Added: demo/xsede.2014.0425/doc/part03.png
Property changes on: demo/xsede.2014.0425/doc/part03.png
Added: demo/xsede.2014.0425/doc/part04.png
Property changes on: demo/xsede.2014.0425/doc/part04.png
Added: demo/xsede.2014.0425/doc/part05.png
Property changes on: demo/xsede.2014.0425/doc/part05.png
Added: demo/xsede.2014.0425/doc/part06.png
Property changes on: demo/xsede.2014.0425/doc/part06.png
Added: demo/xsede.2014.0425/doc/push.sh
--- demo/xsede.2014.0425/doc/push.sh	                        (rev 0)
+++ demo/xsede.2014.0425/doc/push.sh	2014-04-24 18:34:47 UTC (rev 7797)
@@ -0,0 +1,5 @@
+#! /bin/sh
+# scp -r swift-cray-tutorial.html images *png login.ci.uchicago.edu:/ci/www/projects/swift/tutorials/cray
+tar zcf - --exclude-vcs *html *png images | ssh ci "cd /ci/www/projects/swift/tutorials/midway; tar zxf -"
Property changes on: demo/xsede.2014.0425/doc/push.sh
Added: demo/xsede.2014.0425/part01/p1.swift
--- demo/xsede.2014.0425/part01/p1.swift	                        (rev 0)
+++ demo/xsede.2014.0425/part01/p1.swift	2014-04-24 18:34:47 UTC (rev 7797)
@@ -0,0 +1,9 @@
+type file;
+app (file o) simulation ()
+  simulate stdout=filename(o);
+file f <"sim.out">;
+f = simulation();
Added: demo/xsede.2014.0425/part01/swift.properties
--- demo/xsede.2014.0425/part01/swift.properties	                        (rev 0)
+++ demo/xsede.2014.0425/part01/swift.properties	2014-04-24 18:34:47 UTC (rev 7797)
@@ -0,0 +1 @@
+site=local
Added: demo/xsede.2014.0425/part02/p2.swift
--- demo/xsede.2014.0425/part02/p2.swift	                        (rev 0)
+++ demo/xsede.2014.0425/part02/p2.swift	2014-04-24 18:34:47 UTC (rev 7797)
@@ -0,0 +1,11 @@
+type file;
+foreach i in [0:9] {
+  file f <single_file_mapper; file=strcat("output/sim_",i,".out")>;
+  f = simulation();
Added: demo/xsede.2014.0425/part02/swift.properties
--- demo/xsede.2014.0425/part02/swift.properties	                        (rev 0)
+++ demo/xsede.2014.0425/part02/swift.properties	2014-04-24 18:34:47 UTC (rev 7797)
@@ -0,0 +1 @@
+site=local
Added: demo/xsede.2014.0425/part03/p3.swift
--- demo/xsede.2014.0425/part03/p3.swift	                        (rev 0)
+++ demo/xsede.2014.0425/part03/p3.swift	2014-04-24 18:34:47 UTC (rev 7797)
@@ -0,0 +1,27 @@
+type file;
+  simulate "--timesteps" sim_steps "--range" sim_range "--nvalues" sim_values stdout=filename(o);
+app (file o) analyze (file s[])
+  stats filenames(s) stdout=filename(o);
+file sims[];
+foreach i in [0:nsim-1] {
+  file simout <single_file_mapper; file=strcat("output/sim_",i,".out")>;
+  simout = simulation(steps,range,values);
+  sims[i] = simout;
+file stats<"output/average.out">;
+stats = analyze(sims);
Added: demo/xsede.2014.0425/part03/swift.properties
--- demo/xsede.2014.0425/part03/swift.properties	                        (rev 0)
+++ demo/xsede.2014.0425/part03/swift.properties	2014-04-24 18:34:47 UTC (rev 7797)
@@ -0,0 +1 @@
+site=local
Added: demo/xsede.2014.0425/part04/p4.swift
--- demo/xsede.2014.0425/part04/p4.swift	                        (rev 0)
+++ demo/xsede.2014.0425/part04/p4.swift	2014-04-24 18:34:47 UTC (rev 7797)
@@ -0,0 +1,29 @@
+type file;
+app (file out, file log) simulation (int sim_steps, int sim_range, int sim_values)
+  simulate "--timesteps" sim_steps "--range" sim_range "--nvalues" sim_values stdout=@out stderr=@log;
+app (file out, file log) analyze (file s[])
+  stats filenames(s) stdout=@out stderr=@log;
+int nsim   = toInt(arg("nsim",   "10"));
+int steps  = toInt(arg("steps",  "1"));
+int range  = toInt(arg("range",  "100"));
+int values = toInt(arg("values", "5"));
+file sims[];
+  file simlog <single_file_mapper; file=strcat("output/sim_",i,".log")>;
+  (simout,simlog) = simulation(steps,range,values);
+  sims[i] = simout;
+file stats_out<"output/average.out">;
+file stats_log<"output/average.log">;
+(stats_out, stats_log) = analyze(sims);
Added: demo/xsede.2014.0425/part04/swift.properties
--- demo/xsede.2014.0425/part04/swift.properties	                        (rev 0)
+++ demo/xsede.2014.0425/part04/swift.properties	2014-04-24 18:34:47 UTC (rev 7797)
@@ -0,0 +1,2 @@
+site=westmere
Added: demo/xsede.2014.0425/part05/p5.swift
--- demo/xsede.2014.0425/part05/p5.swift	                        (rev 0)
+++ demo/xsede.2014.0425/part05/p5.swift	2014-04-24 18:34:47 UTC (rev 7797)
@@ -0,0 +1,29 @@
+type file;
+file sims[];
+  sims[i] = simout;
Added: demo/xsede.2014.0425/part05/swift.properties
--- demo/xsede.2014.0425/part05/swift.properties	                        (rev 0)
+++ demo/xsede.2014.0425/part05/swift.properties	2014-04-24 18:34:47 UTC (rev 7797)
@@ -0,0 +1,2 @@
+site=westmere
Added: demo/xsede.2014.0425/part06/p6.swift
--- demo/xsede.2014.0425/part06/p6.swift	                        (rev 0)
+++ demo/xsede.2014.0425/part06/p6.swift	2014-04-24 18:34:47 UTC (rev 7797)
@@ -0,0 +1,53 @@
+type file;
+# app() functions for application programs to be called:
+app (file out) genseed (int nseeds)
+  simulate "-r" 2000000 "-n" nseeds stdout=@out;
+app (file out) genbias (int bias_range, int nvalues)
+  simulate "-r" bias_range "-n" nvalues stdout=@out;
+app (file out, file log) simulation (int timesteps, int sim_range, file bias_file,
+                                     int scale, int sim_count, file seed_file)
+  simulate "-t" timesteps "-r" sim_range "-B" @bias_file "-x" scale
+           "-n" sim_count "-S" @seed_file stdout=@out stderr=@log;
+# Command line arguments
+int   nsim = toInt(arg("nsim",   "10"));  # number of simulation programs to run
+int  steps = toInt(arg("steps",  "1"));   # number of timesteps (seconds) per simulation
+int  range = toInt(arg("range",  "100")); # range of the generated random numbers
+int values = toInt(arg("values", "10"));  # number of values generated per simulation
+# Main script and data
+file seedfile <"output/seed.dat">;        # Dynamically generated bias for simulation ensemble
+tracef("\n*** Script parameters: nsim=%i range=%i num values=%i\n\n", nsim, range, values);
+file sims[];                      # Array of files to hold each simulation output
+  file biasfile <single_file_mapper; file=strcat("output/bias_",i,".dat")>;
+  sims[i] = simout;
+(stats_out,stats_log) = analyze(sims);
Added: demo/xsede.2014.0425/part06/swift.properties
--- demo/xsede.2014.0425/part06/swift.properties	                        (rev 0)
+++ demo/xsede.2014.0425/part06/swift.properties	2014-04-24 18:34:47 UTC (rev 7797)
@@ -0,0 +1,2 @@
+site=westmere
Added: demo/xsede.2014.0425/setup.sh
--- demo/xsede.2014.0425/setup.sh	                        (rev 0)
+++ demo/xsede.2014.0425/setup.sh	2014-04-24 18:34:47 UTC (rev 7797)
@@ -0,0 +1,8 @@
+# Load modules
+module unload swift
+module load swift/0.95-RC1
+echo Swift version is $(swift -version)
+# Add applications to $PATH
+TUTDIR="$( cd "$( dirname "${BASH_SOURCE[0]}" )" && pwd )"
+PATH=$TUTDIR/bin:$TUTDIR/app:$PATH
Deleted: demo/xsede.2014.0425/src/c-ray/RUN
--- demo/xsede.2014.0425/src/c-ray/RUN	2014-04-24 18:08:55 UTC (rev 7796)
+++ demo/xsede.2014.0425/src/c-ray/RUN	2014-04-24 18:34:47 UTC (rev 7797)
@@ -1,2 +0,0 @@
-#!/bin/sh
-cat scene.cr | ./c-ray > scene.ppm
Copied: demo/xsede.2014.0425/src/c-ray/test.sh (from rev 7795, demo/xsede.2014.0425/src/c-ray/RUN)
--- demo/xsede.2014.0425/src/c-ray/test.sh	                        (rev 0)
+++ demo/xsede.2014.0425/src/c-ray/test.sh	2014-04-24 18:34:47 UTC (rev 7797)
@@ -0,0 +1,2 @@
+#!/bin/sh
+cat scene.cr | ./c-ray > scene.ppm
Added: demo/xsede.2014.0425/tutorial.pptx
Property changes on: demo/xsede.2014.0425/tutorial.pptx
