[Swift-commit] r7782 - in branches/release-0.95/src/org/griphyn/vdl: karajan/lib karajan/lib/swiftscript mapping
hategan at ci.uchicago.edu hategan at ci.uchicago.edu
Sat Apr 19 14:30:29 CDT 2014
Author: hategan
Date: 2014-04-19 14:30:28 -0500 (Sat, 19 Apr 2014)
New Revision: 7782
Added:
   branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/AbstractSingleValuedSwiftFunction.java
Modified:
   branches/release-0.95/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java
   branches/release-0.95/src/org/griphyn/vdl/karajan/lib/SwiftFunction.java
   branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/Assert.java
   branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/ExtractFloat.java
   branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/ExtractInt.java
   branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/FileName.java
   branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/FileNames.java
   branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/FnArg.java
   branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/Fprintf.java
   branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
   branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadData.java
   branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadStructured.java
   branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/Tracef.java
   branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/WriteData.java
   branches/release-0.95/src/org/griphyn/vdl/mapping/RootDataNode.java
Log:
fixed (to some extent) the lazy errors not propagating through built-in functions issue (0.95 version)
Modified: branches/release-0.95/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java
--- branches/release-0.95/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java	2014-04-18 21:32:30 UTC (rev 7781)
+++ branches/release-0.95/src/org/griphyn/vdl/karajan/lib/SetFieldValue.java	2014-04-19 19:30:28 UTC (rev 7782)
@@ -45,6 +45,8 @@
 import org.griphyn.vdl.karajan.WaitingThreadsMonitor;
 import org.griphyn.vdl.mapping.AbstractDataNode;
 import org.griphyn.vdl.mapping.DSHandle;
+import org.griphyn.vdl.mapping.DataDependentException;
+import org.griphyn.vdl.mapping.DependentException;
 import org.griphyn.vdl.mapping.Mapper;
 import org.griphyn.vdl.mapping.Path;
 import org.griphyn.vdl.type.Type;
@@ -188,7 +190,13 @@
 	protected void deepCopy(DSHandle dest, DSHandle source, Stack stack) {
 	    // don't create a state if only a non-composite is copied
-	    ((AbstractDataNode) source).waitFor(this);
+	    try {
+	        ((AbstractDataNode) source).waitFor(this);
+	    catch (DependentException e) {
+	        dest.setValue(new DataDependentException(dest, e));
+	        return;
         if (source.getType().isPrimitive()) {
             dest.setValue(source.getValue());
@@ -208,7 +216,13 @@
     /** make dest look like source - if its a simple value, copy that
 	    and if its an array then recursively copy */
 	public void deepCopy(DSHandle dest, DSHandle source, State state, int level) {
+	    try {
+            return;
Modified: branches/release-0.95/src/org/griphyn/vdl/karajan/lib/SwiftFunction.java
--- branches/release-0.95/src/org/griphyn/vdl/karajan/lib/SwiftFunction.java	2014-04-18 21:32:30 UTC (rev 7781)
+++ branches/release-0.95/src/org/griphyn/vdl/karajan/lib/SwiftFunction.java	2014-04-19 19:30:28 UTC (rev 7782)
@@ -52,6 +52,7 @@
 import org.griphyn.vdl.mapping.AbsFile;
 import org.griphyn.vdl.mapping.GeneralizedFileFormat;
 import org.griphyn.vdl.mapping.HandleOpenException;
@@ -60,6 +61,7 @@
 import org.griphyn.vdl.mapping.PathComparator;
 import org.griphyn.vdl.mapping.PhysicalFormat;
+import org.griphyn.vdl.mapping.RootDataNode;
 import org.griphyn.vdl.mapping.RootHandle;
 import org.griphyn.vdl.type.Types;
@@ -103,8 +105,8 @@
     @Override
     public void runBody(LWThread thr) {
+        Stack stack = thr.getStack();
 		try {
-		    Stack stack = thr.getStack();
 		    ret(stack, function(stack));
 		catch (AssertFailedException e) {
@@ -112,11 +114,15 @@
             throw e;
-            // This would not be the primal fault so in non-lazy errors mode it
-            // should not matter
-            throw new ExecutionException("Wrapping a dependent exception in VDLFunction.post() - errors in data dependencies",e);
+            RootDataNode rdn = new RootDataNode(getReturnType());
+            rdn.setValue(new DataDependentException(rdn, e));
+            ret(stack, rdn);
+    protected Type getReturnType() {
+        return Types.ANY;
 	 * This will likely break if the engine changes in fundamental ways. It also
Added: branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/AbstractSingleValuedSwiftFunction.java
--- branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/AbstractSingleValuedSwiftFunction.java	                        (rev 0)
+++ branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/AbstractSingleValuedSwiftFunction.java	2014-04-19 19:30:28 UTC (rev 7782)
@@ -0,0 +1,40 @@
+//This code is developed as part of the Java CoG Kit project
+//The terms of the license can be found at http://www.cogkit.org/license
+//This message may not be removed or altered.
+ * Created on Apr 18, 2014
+package org.griphyn.vdl.karajan.lib.swiftscript;
+import k.rt.Stack;
+import k.thr.LWThread;
+import org.globus.cog.karajan.compiled.nodes.functions.AbstractSingleValuedFunction;
+import org.griphyn.vdl.type.Type;
+import org.griphyn.vdl.type.Types;
+public abstract class AbstractSingleValuedSwiftFunction extends AbstractSingleValuedFunction {
+    @Override
+    public void runBody(LWThread thr) {
+        try {
+            ret(stack, function(stack));
+            ret(stack, rdn);
+        return Types.ANY;
Modified: branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/Assert.java
--- branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/Assert.java	2014-04-18 21:32:30 UTC (rev 7781)
+++ branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/Assert.java	2014-04-19 19:30:28 UTC (rev 7782)
@@ -28,6 +28,7 @@
 import org.griphyn.vdl.karajan.lib.SwiftFunction;
@@ -59,17 +60,22 @@
         String message;
-        if (hmessage != null) {
-            hmessage.waitFor(this);
-            message = (String) hmessage.getValue();
+        try {
+            if (hmessage != null) {
+                hmessage.waitFor(this);
+                message = (String) hmessage.getValue();
+            else {
+                message = "Assertion failed";
+            AbstractDataNode hvalue = fargs.get(0);
+            hvalue.waitFor(this);
+            checkAssert(hvalue, message);
-        else {
-            message = "Assertion failed";
+            // cannot make assertion so ignore
-        AbstractDataNode hvalue = fargs.get(0);
-        hvalue.waitFor(this);
-        checkAssert(hvalue, message);
         return null;
Modified: branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/ExtractFloat.java
--- branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/ExtractFloat.java	2014-04-18 21:32:30 UTC (rev 7781)
+++ branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/ExtractFloat.java	2014-04-19 19:30:28 UTC (rev 7782)
@@ -31,6 +31,7 @@
@@ -41,6 +42,11 @@
     protected Signature getSignature() {
         return new Signature(params("var"));
+    @Override
+        return Types.FLOAT;
     @Override
 	public Object function(Stack stack) {
Modified: branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/ExtractInt.java
--- branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/ExtractInt.java	2014-04-18 21:32:30 UTC (rev 7781)
+++ branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/ExtractInt.java	2014-04-19 19:30:28 UTC (rev 7782)
@@ -31,6 +31,7 @@
@@ -43,6 +44,11 @@
     @Override
+        return Types.INT;
+    @Override
 		AbstractDataNode handle = this.var.getValue(stack);
 		try {
Modified: branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/FileName.java
--- branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/FileName.java	2014-04-18 21:32:30 UTC (rev 7781)
+++ branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/FileName.java	2014-04-19 19:30:28 UTC (rev 7782)
@@ -25,6 +25,7 @@
 public class FileName extends SwiftFunction {
@@ -34,6 +35,11 @@
+    @Override
+        return Types.STRING;
     @Override
Modified: branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/FileNames.java
--- branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/FileNames.java	2014-04-18 21:32:30 UTC (rev 7781)
+++ branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/FileNames.java	2014-04-19 19:30:28 UTC (rev 7782)
@@ -31,6 +31,7 @@
 import org.griphyn.vdl.mapping.InvalidPathException;
 import org.griphyn.vdl.mapping.RootArrayDataNode;
 public class FileNames extends SwiftFunction {
@@ -40,6 +41,11 @@
+    @Override
+        return Types.STRING.arrayType();
     @Override
Modified: branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/FnArg.java
--- branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/FnArg.java	2014-04-18 21:32:30 UTC (rev 7781)
+++ branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/FnArg.java	2014-04-19 19:30:28 UTC (rev 7782)
@@ -36,6 +36,7 @@
@@ -48,6 +49,11 @@
         return new Signature(params("..."));
+	@Override
     @Override
     protected void addLocals(Scope scope) {
Modified: branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/Fprintf.java
--- branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/Fprintf.java	2014-04-18 21:32:30 UTC (rev 7781)
+++ branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/Fprintf.java	2014-04-19 19:30:28 UTC (rev 7782)
@@ -31,6 +31,7 @@
 import org.globus.cog.karajan.analyzer.Signature;
     Formatted file output. <br>
@@ -57,24 +58,29 @@
         AbstractDataNode hfilename = this.filename.getValue(stack);
         AbstractDataNode hspec = this.spec.getValue(stack);
-        hfilename.waitFor(this);
-        hspec.waitFor(this);
-        Channel<AbstractDataNode> args = c_vargs.get(stack);
-        waitForAll(this, args);
-        String filename = (String) hfilename.getValue();
-        String spec = (String) hspec.getValue();
-        StringBuilder output = new StringBuilder();
         try {
-            Sprintf.format(spec, args, output);
+            hfilename.waitFor(this);
+            hspec.waitFor(this);
+            Channel<AbstractDataNode> args = c_vargs.get(stack);
+            waitForAll(this, args);
+            String filename = (String) hfilename.getValue();
+            String spec = (String) hspec.getValue();
+            StringBuilder output = new StringBuilder();
+            try {
+                Sprintf.format(spec, args, output);
+            catch (RuntimeException e) {
+                throw new ExecutionException(this, e.getMessage());
+            String msg = output.toString();
+            logger.debug("file: " + filename + " msg: " + msg);
+            write(filename, msg);
-        catch (RuntimeException e) {
-            throw new ExecutionException(this, e.getMessage());
+            logger.debug("<exception>");
-        String msg = output.toString();
-        logger.debug("file: " + filename + " msg: " + msg);
-        write(filename, msg);
         return null;
Modified: branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java
--- branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java	2014-04-18 21:32:30 UTC (rev 7781)
+++ branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/Misc.java	2014-04-19 19:30:28 UTC (rev 7782)
@@ -32,14 +32,15 @@
 import org.globus.cog.karajan.analyzer.ChannelRef;
 import org.globus.cog.karajan.compiled.nodes.InternalFunction;
-import org.globus.cog.karajan.compiled.nodes.functions.AbstractSingleValuedFunction;
 import org.globus.cog.karajan.util.TypeUtil;
 import org.griphyn.vdl.util.VDL2Config;
@@ -73,22 +74,26 @@
         @Override
         protected void runBody(LWThread thr) {
         	Channel<AbstractDataNode> vargs = c_vargs.get(thr.getStack());
-            SwiftFunction.waitForAll(this, vargs);
-            StringBuilder buf = new StringBuilder();
-            buf.append("SwiftScript trace: ");
-            boolean first = true;
-            for (AbstractDataNode n : vargs) {
-                if (!first) {
-                    buf.append(", ");
+        	try {
+        	    SwiftFunction.waitForAll(this, vargs);
+        	    StringBuilder buf = new StringBuilder();
+                buf.append("SwiftScript trace: ");
+                boolean first = true;
+                for (AbstractDataNode n : vargs) {
+                    if (!first) {
+                        buf.append(", ");
+                    else {
+                        first = false;
+                    //buf.append(v == null ? args[i] : v);
+                    prettyPrint(buf, n);
-                else {
-                	first = false;
-                //buf.append(v == null ? args[i] : v);
-                prettyPrint(buf, n);
-            traceLogger.warn(buf);
+                traceLogger.warn(buf);
+        	    traceLogger.warn("<exception>");
@@ -128,7 +133,7 @@
-	public static class StrCat extends AbstractSingleValuedFunction {
+	public static class StrCat extends AbstractSingleValuedSwiftFunction {
         private ChannelRef<AbstractDataNode> c_vargs;
         @Override
@@ -137,6 +142,13 @@
         @Override
+        @Override
             Channel<AbstractDataNode> vargs = c_vargs.get(stack);
             Channel<Object> args = SwiftFunction.unwrapAll(this, vargs);
@@ -161,7 +173,7 @@
-	public static class Exists extends AbstractSingleValuedFunction {
+	public static class Exists extends AbstractSingleValuedSwiftFunction {
         private ArgRef<AbstractDataNode> file;
         @Override
@@ -170,6 +182,11 @@
         @Override
+            return Types.BOOLEAN;
+        @Override
         	AbstractDataNode dn = file.getValue(stack);
             String filename = SwiftFunction.unwrap(this, dn);
@@ -190,7 +207,7 @@
-	public static class StrCut extends AbstractSingleValuedFunction {
+	public static class StrCut extends AbstractSingleValuedSwiftFunction {
         private ArgRef<AbstractDataNode> input;
         private ArgRef<AbstractDataNode> pattern;
@@ -200,6 +217,11 @@
         @Override
+        @Override
         	AbstractDataNode hinput = this.input.getValue(stack);
         	String input = SwiftFunction.unwrap(this, hinput);
@@ -238,7 +260,7 @@
-	public static class StrStr extends AbstractSingleValuedFunction {
+	public static class StrStr extends AbstractSingleValuedSwiftFunction {
@@ -248,6 +270,11 @@
         @Override
+        @Override
@@ -271,7 +298,7 @@
-	public static class StrSplit extends AbstractSingleValuedFunction {
+	public static class StrSplit extends AbstractSingleValuedSwiftFunction {
@@ -281,6 +308,11 @@
         @Override
+        @Override
@@ -318,7 +350,7 @@
 	 * @return DSHandle representing the resulting string
 	 * @throws ExecutionException
-	public static class StrJoin extends AbstractSingleValuedFunction {
+	public static class StrJoin extends AbstractSingleValuedSwiftFunction {
         private ArgRef<AbstractDataNode> array;
         private ArgRef<AbstractDataNode> delim;
@@ -328,6 +360,11 @@
         @Override
+        @Override
             AbstractDataNode harray = this.array.getValue(stack);
             Map<Comparable<?>, DSHandle> arrayValues = SwiftFunction.waitForArray(this, harray);
@@ -359,7 +396,7 @@
-	public static class Regexp extends AbstractSingleValuedFunction {
+	public static class Regexp extends AbstractSingleValuedSwiftFunction {
         private ArgRef<AbstractDataNode> transform;
@@ -370,6 +407,11 @@
         @Override
+        @Override
@@ -410,7 +452,7 @@
-	public static class ToInt extends AbstractSingleValuedFunction {
+	public static class ToInt extends AbstractSingleValuedSwiftFunction {
         private ArgRef<AbstractDataNode> str;
         @Override
@@ -419,6 +461,11 @@
         @Override
+            return Types.INT;
+        @Override
             AbstractDataNode hstr = str.getValue(stack);
             String str = SwiftFunction.unwrap(this, hstr);
@@ -435,7 +482,7 @@
-	public static class ToFloat extends AbstractSingleValuedFunction {
+	public static class ToFloat extends AbstractSingleValuedSwiftFunction {
         @Override
@@ -444,6 +491,11 @@
         @Override
+        @Override
             Object obj = SwiftFunction.unwrap(this, hstr);
@@ -474,7 +526,7 @@
 	 * Takes in a float and formats to desired precision and returns a string
-	public static class Format extends AbstractSingleValuedFunction {
+	public static class Format extends AbstractSingleValuedSwiftFunction {
         @Override
@@ -483,6 +535,11 @@
         @Override
+        @Override
@@ -507,7 +564,7 @@
 	 * Takes in an int and pads zeros to the left and returns a string
-	public static class Pad extends AbstractSingleValuedFunction {
+	public static class Pad extends AbstractSingleValuedSwiftFunction {
         private ArgRef<AbstractDataNode> size;
         private ArgRef<AbstractDataNode> value;
@@ -517,6 +574,11 @@
         @Override
+        @Override
             AbstractDataNode hsize = this.size.getValue(stack);
             Integer size = SwiftFunction.unwrap(this, hsize);
@@ -536,7 +598,7 @@
-	public static class ToString extends AbstractSingleValuedFunction {
+	public static class ToString extends AbstractSingleValuedSwiftFunction {
         @Override
@@ -545,6 +607,11 @@
         @Override
+        @Override
             AbstractDataNode hvalue = this.value.getValue(stack);
@@ -570,7 +637,7 @@
      * Good for debugging because array needs to be closed
      *   before the length is determined
-	public static class Dirname extends AbstractSingleValuedFunction {
+	public static class Dirname extends AbstractSingleValuedSwiftFunction {
         @Override
@@ -579,6 +646,11 @@
         @Override
+        @Override
             String name = SwiftFunction.filename(dn)[0];
@@ -596,7 +668,7 @@
-	public static class Length extends AbstractSingleValuedFunction {
+	public static class Length extends AbstractSingleValuedSwiftFunction {
         @Override
@@ -605,6 +677,11 @@
         @Override
+            return Types.INT;
+        @Override
             harray.waitFor(this);
Modified: branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadData.java
--- branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadData.java	2014-04-18 21:32:30 UTC (rev 7781)
+++ branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadData.java	2014-04-19 19:30:28 UTC (rev 7782)
@@ -38,6 +38,8 @@
@@ -59,7 +61,13 @@
 		AbstractDataNode dest = this.dest.getValue(stack);
 		AbstractDataNode src = this.src.getValue(stack);
-		src.waitFor(this);
+		try {
+		    src.waitFor(this);
+		    return null;
 		if (src.getType().equals(Types.STRING)) {
 			readData(dest, (String) src.getValue());
Modified: branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadStructured.java
--- branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadStructured.java	2014-04-18 21:32:30 UTC (rev 7781)
+++ branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/ReadStructured.java	2014-04-19 19:30:28 UTC (rev 7782)
@@ -35,6 +35,8 @@
@@ -57,7 +59,13 @@
+        try {
+            return null;
 			dest.closeDeep();
Modified: branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/Tracef.java
--- branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/Tracef.java	2014-04-18 21:32:30 UTC (rev 7781)
+++ branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/Tracef.java	2014-04-19 19:30:28 UTC (rev 7782)
@@ -26,6 +26,7 @@
     Formatted trace output. <br>
@@ -52,12 +53,18 @@
     @Override
-        String msg = Sprintf.format(spec, args);
+        String msg;
+        try {
+            msg = Sprintf.format(spec, args);
+            msg = "<exception>";
         logger.info(msg);
         System.out.print(msg);
         return null;
Modified: branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/WriteData.java
--- branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/WriteData.java	2014-04-18 21:32:30 UTC (rev 7781)
+++ branches/release-0.95/src/org/griphyn/vdl/karajan/lib/swiftscript/WriteData.java	2014-04-19 19:30:28 UTC (rev 7782)
@@ -34,6 +34,8 @@
@@ -62,7 +64,13 @@
 		// src can be any of several forms of value
+		try {
+            return null;
 		if (dest.getType().equals(Types.STRING)) {
 			writeData((String)dest.getValue(), src);
Modified: branches/release-0.95/src/org/griphyn/vdl/mapping/RootDataNode.java
--- branches/release-0.95/src/org/griphyn/vdl/mapping/RootDataNode.java	2014-04-18 21:32:30 UTC (rev 7781)
+++ branches/release-0.95/src/org/griphyn/vdl/mapping/RootDataNode.java	2014-04-19 19:30:28 UTC (rev 7782)
@@ -54,6 +54,10 @@
         this("?", type, value);
+	public RootDataNode(Type type) {
+        this("?", type, null);
 	public RootDataNode(String name, Type type) {
 	    this(name, type, null);
@@ -64,7 +68,7 @@
 	    setValue(value);
-	    public int getLine() {
+	public int getLine() {
         return line;
